How to proceed
Sandbender
Denmark
C?ID=658569
Hi
I have a 2024 ID.7 Tourer where I'm having problems with 11kW AC charging that seemingly drops one of the 3 phases at a random time during charging - it's happened 10 mins into a session and a few hours in and anything in between.
I've tried other chargers and different cables but the issue remains, so I'm convinced it's something in the car thats at fault.
Due to other reasons the car han been seen by the dealership, but they say they didn't see any intermittent faults or anything that relates to the issue I'm seeing.
However over the summer it's now more unexpected to see the car charge at 11kW for the whole charging session than it is to drop down to 7kW.
I'm ---> <--- so close to purchasing a HEX-V2 for collecting my own diagnostics before challenging the dealership again, and I managed to borrow a friends HEX-NET that I got the following full auto-scan from - and it's lead me to a few questions.
1. I see faults logged under "C6: Batt. Chrg." that happened on 2026.09.15 at 09:42:30
This happened to be during a charging sessions yesterday where I checked perhaps 10 minutes prior to see that the car was charging at 11kW, and when I checked again at around 10, it had dropped down to 7kW.
2. One of the reasons for purchasing a HEX-V2 was so I could see the measurements from the "C6: Batt Chrg." controller, but when I try an access measurements from it, almost every measurement returns "N/A".
Is that due to SFD not beeing unlocked in the CAN gateway?
I should probably mention that my buddy hasn't bought SFD unlocking (and I won't buy it for him), but it would be a natural add-on for me as soon as I purchase my own HEX-V2.. :D
3. In case SFD is involved for me to get measurements, can I expect mesurements to keep working after the unlock has expired - ie. if I want to gather measurements for a few hours during a complete charging session?
4. Is there anything in the scan below that I'm overlooking or cannot see (due to SFD) that would be a "smoking gun" towards explaining my issues with charging on all 3 phases?
5. Is it also normal for a "Clear all DTCs" not to clear a lot of errors due to SFD as well?
I have a prior full auto-scan that had a few other errors that is gone from below, but everything that remains seems to be behind a SFD-protected controller
Thanks in advance!
/Jens
Wednesday,16,September,2026,16:42:41:21937
VCDS Version: 26.9.0.3 (x64)  HEX-NET CB: 0.4713.4
VIN: WVWZZZED3RE001110   License Plate:
Chassis Type: ED-VWE4 (1EE)
Scan: 01 03 05 06 08 09 10 13 15 16 19 23 2B 36 3C 42 44 51 52 5F
          69 6C 6D 75 7E 82 8C A5 BB BC C0 C6 D6 D7 DE 8105 8107 8117 811E 811F
          8120 8121 8123 8124 8125 8128 C002 C003
VIN: WVWZZZED3RE001110   Mileage: 29004km-18022miles
51-Electric Drive -- Status: Malfunction 0010
7E-Ctrl Head Dash -- Status: OK 0000
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8117-Rear surroundings cam -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623----A)       Labels: 0EA-907-425-V2.clb
   Part No SW: 0EA 906 014 FT    HW: 0EA 907 425 K
   Component: E-Vehicle     H80 4098
   Dataset Number: V03935424SD 0001
   Coding: 010200030C042C020E050000000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0200EA906014FT 003003
   ROD: EV_VCU00XXX0200EA906014GA.rod
   VCID: 04448ED38F4EAEBD64-8050-R SFD+SFD2 [x]
   VINID: 9E69EAAAA5540E2540001041008E9AE31D
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501 B    HW: 1EA 965 501 B
   Component: V711           023 0008
   Serial number: 20240411060604084254
43490 - Communication Authentication
          U3036 00 [00100110] - Signal Malfunction
          [Communication Authentication Signal Performance]
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:26:07
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 12.636 V
                    Driver intention torque: 0.0 Nm
                    PV: 0.00 %
                    LV_IGK: 00000000
                    Outside temperature: 256.0 °C
                    Position: P
                    Brake light switch status-actuated__activated: Not operated
                    Brake light switch status-Ident_32: 0
                    Hybrid batt charge cond act val standardized: 127.50 %
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 1EA-614-517-V2.clb
   Part No SW: 1EA 907 379 BQ    HW: 1EA 614 517 M
   Component: ESC-ZF_EBC470 H18 0754
   Serial number: 0000000         Dataset Number: V03935436FR 0001 CVN: 5D980B
   Coding: 6810438404815902430B990000B78C00250090614000
   ASAM Dataset: EV_BrakeZFESCMEBUNECE 001035
   ROD: EV_BrakeZFESCMEBUNECE_001.rod
   VCID: 0D52ABF7DC04EFF53B-8058-R SFD+SFD2 [x]
70032 - Rear View Camera System Control Module
          U104C 00 [00100000] - No communication
          [MSG_REAR_VIEW_05_TIMEOUT]
                    Reset counter: 12
                    Mileage: 28310 km
                    Date: 2026.08.31
                    Time: 13:45:52
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 N    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0757
   Serial number: --------------- Dataset Number: V03935383MW 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 5F8EA1BF46682D6519-800A-R
   Part No SW: 1N3 959 760 H    HW: 1N3 959 760 H
   Component: MEM-BFS       011 0571
   Serial number: 2441901KA05354 Dataset Number: V03935380RK 0001
   Coding: 0118BA4000012A008803010101010000000000000000000000000000211000
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
   VCID: 3E303C3BA122046D72-806A-R
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EE 907 007 C    HW: 1EE 907 007 B
   Component: Climatronic   H01 0247
   Serial number: 115052405342550 Dataset Number: V03935419BZ 0001
   Coding: 30202204A010120010200010111001102000102110201001000100000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002051
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 352223179414C735A3-8060-R SFD+SFD2 [x]
   Interior temperature sensor:
   Air quality sensor:
   A/C compressor sub:
   Auxiliary Heater Control Module/PTC 2:
   Expansion valve 1 for refrigerant:
   Part No SW: 1EE 937 089 B    HW: 1EE 937 089
   Component: SAM_H         H08 0555
   Serial number: 01102413501018- Dataset Number: V03935437F  0001
   ASAM Dataset: EV_SAMVW31x 006001
   ROD: EV_SAMVW31x_006.rod
   VCID: 41CA47C7D0DC7B950F-8014-R SFD [x]
   Subsystem 1 - Part No SW: 14A 955 119     HW: 14A 955 119
   Component: WISCHER_MYJTL  004 0114
   Serial number: VSCCHA23042403008277
   Wiper motor control unit 2:
   Subsystem 2 - Part No SW: 14A 955 120     HW: 14A 955 120
   Component: FWISCHER_SL02  004 0114
   Serial number: VSCCHA07052404007080
   Subsystem 3 - Part No SW: 89A 955 555 A    HW: 89A 955 555 A
   Component: G397_RLFSS     004 0005
   Serial number: MRO71331012400010755
   Subsystem 4 - Part No SW: 10A 941 193 R    HW: 10A 941 193 R
   Component: LiSi           H04 0515
   Serial number: RRB71529042400025971
   Subsystem 5 - Part No SW: 14A 953 509     HW: 14A 953 509
   Component: DiETa          H06 0026
   Serial number: LZH 8BS00136365
   Subsystem 6 - Part No SW: 5H0 959 569 C    HW: 5H0 959 569 C
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092661XEB00405
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 14A 881 643 B    HW: 14A 881 643 B
   Component: J873 MKS_FSv   H02 0152
   Serial number: 7009362240C241600341
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 14A 881 643 B    HW: 14A 881 643 B
   Component: J872 MKS_BFSv  H02 0152
   Serial number: 7009362240C241601674
Address 10: Park/Steer Assist (J446)       Labels:| 1EE-919-300.clb
   Part No SW: 1EE 919 300 B    HW: 1EE 919 300
   Component: RPA12K        H01 0630
   Serial number: 000008042494630 Dataset Number: V03935417BX 0001
   Coding: 0238026101
   ASAM Dataset: EV_EPHBO3CVW4130000 001014
   ROD: EV_EPHBO3CVW4130000.rod
   VCID: 33261D0F9A60D9058D-8066-R
   Part No SW: 1EA 907 567 B    HW: 1EA 907 819
   Component: ARS512VW13    H05 0232
   Dataset Number: V03935435JU 0001
   Coding: 06831AE3407140441257400800C040C52F4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 004013
   ROD: EV_FRONTRADARCONTIVW310.rod
   VCID: 3B36352FB230114555-806E-R SFD+SFD2 [x]
Address 15: Airbags (J234)       Labels:* 3WA-959-655.clb
   Part No SW: 3WA 959 655 AA    HW: 3WA 959 655 AA
   Component: Airbag VW50   006 0151
   Revision: --------    Serial number: 003C0T5CA4HA9P Dataset Number: V03935437UR 0001
   Coding: 88CC008000F0C0000000C0200000000091540000A1540000C000F680C02B0065
   Shop #: WSC 00015 015 00574
   ASAM Dataset: EV_AirbaVW50TS6VW49X 001001
   ROD: EV_AirbaVW50TS6VW49X.rod
   VCID: 1464BE93FF2E3E3DF4-8040-R SFD+SFD2 [x]
   Left seat belt tensioner:
   Right seat belt tensioner:
   Subsystem 3 - Part No SW: -----------    HW: 654 001 402 24
   Component: SideSensor_Df  010 0887
   Serial number: 3570000473890D255870
   Subsystem 4 - Part No SW: -----------    HW: 654 002 302 24
   Component: SideSensor_Pf  010 0887
   Serial number: 3580000FC4890F50626C
   Subsystem 5 - Part No SW: -----------    HW: 654 000 804 24
   Component: SideSensor_Dr  040 0148
   Serial number: 351005068C6BF78FE850
   Subsystem 6 - Part No SW: -----------    HW: 654 000 804 24
   Component: SideSensor_Pr  040 0148
   Serial number: 35200507CC6BF791669U
   Subsystem 7 - Part No SW: -----------    HW: 654 000 202 24
   Component: FrontSensor_D  030 010A
   Serial number: 355005066C87D397889S
   Subsystem 8 - Part No SW: -----------    HW: 654 000 202 24
   Component: FrontSensor_P  030 010A
   Serial number: 35600509523FE4920769
   Subsystem 9 - Part No SW: -----------    HW: 654 001 703 24
   Component: PedP_Sensor_D  010 014A
   Serial number: 228005094C47010E87A7
   Subsystem 10 - Part No SW: -----------    HW: 654 001 603 24
   Component: PedP_Sensor_P  010 014A
   Serial number: 229005096C6BF784260I
   Subsystem 11 - Part No SW: -----------    HW: 654 002 712 22
   Component: PedP_Sensor_C  070 014A
   Serial number: 23000509724F49D26A8D
   Subsystem 12 - Part No SW: -----------    HW: 654 800 803 24
   Component: PedPSensor_D2  010 0887
   Serial number: I0M0000053DD3784381M
   Subsystem 13 - Part No SW: -----------    HW: 654 800 803 24
   Component: PedPSensor_P2  010 0887
   Serial number: I0N0000053D117844C1E
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 14 - Part No SW: -----------    HW: 654 000 804 24
   Component: Side_Sens_B_D  040 0148
   Serial number: I0P005092C6BF792AAFR
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 15 - Part No SW: -----------    HW: 654 000 804 24
   Component: Side_Sens_B_P  040 0148
   Serial number: I0Q0050A2CA8D38C436B
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 D    HW: 1EE 953 507 D
   Component: GSMMEB        005 0067
   Serial number: 000000100524260
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2_009_VWE3.rod
   VCID: 3C343633B73E167D5C-8068-R SFD [x]
Address 19: CAN Gateway (J533)       Labels: 1EE-937-012.clb
   Part No SW: 1EE 937 012 K    HW: 1EE 937 012
   Component: ICAS1 Host-SG 021 0711
   Serial number: SMERBG150524006 Dataset Number: V03935439ZH 0001
   GVL: 2D08080006C8D0FC8062904248180040C000200001060000040200000000DE57
   ASAM Dataset: EV_GatewICAS1MEBUNECE 001024
   ROD: EV_GatewICAS1MEBUNECE_VWE2.rod
   VCID: 3C343633B73E167D5C-8068 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 1EE 915 181     HW: 1EE 915 181
   Component: J367-BDMConti  H05 1076
   Serial number: 78561200002404050376
   Left taillight 1:
   Left taillight 2:
   Right taillight 1:
   Right taillight 2:
   Power rear lid opening control module:
7467521 - Data Set Implausible
          B2012 00 [00100111] - -
          [Data_set_implausible_CMS]
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:37:37
7467522 - Data Set Implausible
          [Data_set_implausible_HLC]
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:37:37
15361792 - Data Set Implausible
          [Data_set_implausible_MDK_CCC]
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:37:38
Address 23: Brake Booster (J539)       Labels: 1EA-909-059-V2.clb
   Part No SW: 1EA 909 059 BG    HW: 1EA 909 059 Q
   Component: EBB-ZF-Gen1   H33 0853
   Serial number: ÿÿÿÿÿÿÿ         Dataset Number: V03935435CU 0001
   Coding: 60302040300028
   ASAM Dataset: EV_BrakeBoostZFMEBUNECE 001034
   ROD: EV_BrakeBoostZFMEBUNECE_001.rod
   VCID: 004C82C39B56B29D40-8054-R SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000116288004 Dataset Number: V03935370PA 0001
   Coding: 8880000000000000
   Shop #: WSC 00015 015 00547
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 085C9AE3B3668ADD08-805C-R SFD+SFD2 [x]
   Component: MEM-FS        011 0571
   Serial number: 2441901KA04713 Dataset Number: V03935379EA 0001
   Coding: 0118BA4000012A008803010101010000000000000000000000000000215000
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 14520044821074  Dataset Number: V03935407CY 0001
   Coding: 6AA54750
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FCE413FA6280D6579-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 14520046870067
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 1EA 959 593 H    HW: 1EA 959 593 F
   Component: TSG FS        009 0571
   Serial number: 0000528354080  Dataset Number: V03935471   0001
   Coding: 0035DA20DE000480A6009030
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001004
   ROD: EV_DCU3DriveSideMAXHCONT.rod
   VCID: 47DE59DFFEF845A5C1-8012-R
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 10A 959 862 AQ    HW: 10A 959 862 AQ
   Component: EX36 TBF_FS    H22 0110
   Serial number: 0692-07.05.24-------
Address 44: Steering Assist (J500)       Labels: Redir Fail!
   Part No SW: 1EB 907 164 F    HW: 1EB 907 164 B
   Component: EPS_ECU       450 4305
   Serial number: 000008.09.23000 Dataset Number: V03935426LP 0001
   Coding: 000000000000020100000201010001000000010001010001
   ASAM Dataset: EV_SteerAssisNSKGEN4MEB 006009
   ROD: EV_SteerAssisNSKGEN4MEB.rod
   VCID: 393A2F27B80C235547-806C-R SFD+SFD2 [x]
Address 51: Electric Drive (J841)       Labels: 0ET-907-INV-V1.clb
   Part No SW: 0ET 907 121 J    HW: 0ET 907 121 D
   Component: MEB INV6.0    H10 7252
   Dataset Number: V03935396ZD 0001
   ASAM Dataset: EV_DMCM21000110ET907121J 001001
   ROD: EV_DMCM21000110ET907121J_VWE4.rod
   VCID: 47DE59DFFEF845A5C1-8012-R SFD+SFD2 [x]
41631 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [00101110] - -
          [Lost Communication With Vehicle Dynamics Control Module]
                    Fault Frequency: 27
41665 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00101000] - -
          [Lost Communication with ECM/PCM]
                    Reset counter: 28
                    Mileage: 28448 km
                    Date: 2026.09.04
                    Time: 08:08:41
43408 - Online Remote Update
          U192A 00 [00101110] - No Signal
          [Online Remote UpdateNo signal]
                    Fault Frequency: 227
                    Mileage: 28310 km
                    Date: 2026.08.31
                    Time: 13:20:29
Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
   Part No SW: 1EA 959 592 H    HW: 1EA 959 592 F
   Component: TSG BFS       009 0571
   Serial number: 0000528448332  Dataset Number: V03935471AF 0001
   Coding: 00355020DE000480A2809030
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001004
   ROD: EV_DCU3PasseSideMAXHCONT.rod
   VCID: 46C054DBF9F25CAD3A-8012-R
   Part No SW: 10C 035 816 B    HW: 10C 035 816 A
   Component: IC3GSF-AR--EU H09 3612
   Dataset Number: V03935425YS 0001
   Coding: 24121030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 002001
   ROD: EV_MUICASSAFEPart_002_VWE3.rod
   VCID: 1D72DBB70CE47F754B-8048-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 1T3 919 606 H    HW: 1T3 919 606
   Component: ABT-E3_15      H52 7046
   Serial number: TPO00126112315010702
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H2 907 383 D    HW: 5H2 907 383
   Component: Anhaenger     H12 0204
   Serial number: 000000000006451 Dataset Number: V03935340SJ 0001
   Coding: 0100000202001400
   ASAM Dataset: EV_TrailFunctG3MPFMHella 001009
   ROD: EV_TrailFunctG3MPFMHella_VW27.rod
   VCID: 312A1707607CEB15FF-8064-R SFD+SFD2 [x]
Address 6C: Back-up Cam. (J928)       Labels:| 5WA-980-556.clb
   Part No SW: 1EE 907 556 A    HW: 5WA 907 556 D
   Component: TV eEntry     H32 0605
   Serial number: FZ6ESP080524000 Dataset Number: V03935434ND 0001
   Coding: 020380003F140080
   ASAM Dataset: EV_CamSysTVFicosUNECE 002004
   ROD: EV_CamSysTVFicosUNECE_VWE3.rod
   Part No SW: 4KE 959 107 B    HW: 4KE 959 107 B
   Component: HDSG-Modul    H08 0342
   Revision: --------    Serial number: A2-C765-4922-2 Dataset Number: V03935422FB 0001
   Coding: 5488
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_VWE4.rod
   VCID: 45C253D7C4F457B533-8010-R
   Part No SW: 14A 035 284 A    HW: 14A 035 284
   Component: OCU4MEB_UNECE H11 0554
   Serial number: 0000000401VILZL Dataset Number: V03935438KZ 0001
   Coding: 02010700010000000000010013000000101112111012000010
   ASAM Dataset: EV_OCUGen4UNECE 001050
   ROD: EV_OCUGen4UNECE.rod
Address 7E: Ctrl Head Dash (J1254)       Labels:* None
   Part No SW: 14A 920 441 A    HW: 14A 920 441 A
   Component: Fahrerdisplay 200 1622
   Serial number: 4TUJ00301023000 Dataset Number: V03935429DF 0001
   Coding: 500F80
   ASAM Dataset: EV_DashBoardALPINEMEB 002014
   ROD: EV_DashBoardALPINEMEB.rod
   VCID: 1B76D5AF12F07145B5-804E-R SFD+SFD2 [x]
Address 82: Head Up Display (J898)       Labels: 10B-919-608.clb
   Part No SW: 14G 919 608 A    HW: 14G 919 608 A
   Component: HeadupDisplay H05 0505
   Serial number: ARHUD
   ASAM Dataset: EV_ARHeadUpDisplMEB 002044
   ROD: EV_ARHeadUpDisplMEB_002.rod
   VCID: 2E100C7B7142F4EDE2-807A-R
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 AE    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 010 1141
   Serial number: 000000040324010 Dataset Number: V03935430CT 0001
   ASAM Dataset: EV_BMCeVWBSMEB 003018
   ROD: EV_BMCeVWBSMEB_003_VWE3.rod
   VCID: 7DB2FB37ECA4DF752B-8028-R
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Component: SX6  X74  CMC  005 1140
   Serial number: 00000024042401062565
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000024042401062562
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000024042401052564
   Coolant heating:
   Subsystem 4 - Part No SW: 1EE 963 231     HW: 1EE 963 231
   Component: J848 HV-PTC    H04 0026
   Serial number: 1EE96323124120000715
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* 1EA-980-65X-V2.clb
   Part No SW: 1EA 980 653 E    HW: 1EA 980 653 A
   Component: MEB MFK 4.1   H08 5556
   Dataset Number: V03935437DL 0001
   Coding: 0008306E1FD100E93F243A2C4000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001080
   ROD: EV_MFK41ValeoMEB.rod
Address BB: Door Rear Drv (J388)       Labels:* Redir Fail!
   Part No SW: 1EA 959 597 H    HW: 1EA 959 597 F
   Component: TSG HFS       009 0571
   Serial number: 0000513415629  Dataset Number: V03935471AJ 0001
   Coding: 0001D02000000480A2009030
   ASAM Dataset: EV_DCU3RearDriveMAXHCONT 001004
   ROD: EV_DCU3RearDriveMAXHKLO.rod
   VCID: 4BD665EFE290A1C5E5-801E-R
Address BC: Door Rear Pass (J389)       Labels:* Redir Fail!
   Part No SW: 1EA 959 596 H    HW: 1EA 959 596 F
   Component: TSG HBFS      009 0571
   Serial number: 0000528397256  Dataset Number: V03935471AG 0001
   Coding: 0001D02001000480A2009030
   ASAM Dataset: EV_DCU3RearPasseMAXHCONT 001004
   ROD: EV_DCU3RearPasseMAXHCONT.rod
   VCID: 4AD860EBEDEAB8CDDE-801E-R
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 14B 035 335 C    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0005
   Serial number: JTK072070524953
   ASAM Dataset: EV_ESounHarmaMEBUNECE 001006
   ROD: EV_ESounHarmaMEBUNECE.rod
   Part No SW: 1EE 915 684 Q    HW: 1EE 915 684 E
   Component: HV_CHARGER    H65 1026
   Serial number: 93286XAF000ET   Dataset Number: V03935370KP 0001
   Coding: 10C0
   ASAM Dataset: EV_OCC2XPhaseKLOMEB01B 001006
   ROD: EV_OCC2XPhaseKLOMEB01B_VWE3.rod
   VCID: 4DD26BF71C84AFF5FB-8018-R SFD+SFD2 [x]
3276827 - Discrepancy between Specified and Measured Current
          P33E0 00 [00100000] - Too High
          [exceedance_max.current_deviation_rail1]
                    Reset counter: 36
                    Mileage: 28927 km
                    Date: 2026.09.15
                    Time: 09:42:30
                    DID 0286: 13.0 V
                    DID 1DA0: AC main charge
                    DID 1DAC: Charging
                    Activation charge cover lock charge socket A: not requested
                    Lock for high-voltage charging connector: locked
                    Status connect. recognition: detected
                    Charging socket temperature sensor AC: 30.0 °C
                    Temperature sensor 1: resistance value: 1017 Ohm
                    DID 15E2: 34.0 °C
                    DID 497C: not active
                    DID 537A: 14.4 V
                    DID 4219: high-voltage de-energization not detected
3276829 - Discrepancy between Specified and Measured Current
          [exceedance_max.current_deviation_rail3]
3280899 - Charging Station
          B1AD0 F0 [00101111] - Identification Failed
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
                    Mileage: 28328 km
                    Date: 2026.08.31
                    Time: 15:16:16
                    DID 1DAC: Charging
                    Frequency: 1000 Hz
                    Control voltage: 5967.0 mV
                    Pulse duty factor: 26.1 %
                    Temperature sensor 1: resistance value: 1023 Ohm
                    DID 15E2: 24.0 °C
                    DID 081C: 3392 W
                    DID 081D: 3464 W
                    DID 081E: 0 W
                    DID 0286: 13.7 V
                    DID 537A: 14.4 V
                    DID 1525: 1966 mV
                    DID 5372: 23.0 °C
                    No. of lockings: 1392
                    No. of connections: 342
                    Number of successful charging connector locks: 633
                    Wake-up counter: contact (proximity): 0
                    Wake-up counter: Control Pilot: 0
                    Charging standard abort: status: not active
                    Loading plan: status: Not available
                    Price/performance table: status: Not available
                    Transport Layer Security (TLS) status communication: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 1
                    DID 1033: SLAC_active
                    DID 1038: no_description
                    DID 1039: supported
                    Target HV charge current: 27.5 A
                    Powerline communication: charging process status: Standby
14750981 - Charging Socket 1
          P1CF6 00 [01100000] - Unlock Prohibited
          [Plug_unlocking_error]
                    Reset counter: 3
                    Mileage: 28698 km
                    Date: 2026.09.10
                    Time: 05:16:40
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Temperature sensor 1: resistance value: 1028 Ohm
                    DID 15E2: 13.0 °C
                    Sensor 1: Malfunction
                    Sensor 2: Malfunction
                    Sensor 3: Malfunction
                    DID 0286: 12.0 V
                    DID 537A: 14.2 V
                    DID 5372: 13.0 °C
                    DID 4219: high-voltage de-energization detected
   Part No SW: 992 941 592 AG    HW: 992 941 592 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6A98C06B8D2A58CDFE-803E-R
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address DE: Charger 1 for mobile dev (J0000)       Labels:* None
   Part No SW: 3P0 035 502 B    HW: 3P0 035 502
   Component: COUPLING BOX  004 0170
   Serial number: 324000000000017 Dataset Number: V03935426MT 0001
   Coding: 400080
   ASAM Dataset: EV_DualCouplBoxSK336 001006
   ROD: EV_DualCouplBoxSK336.rod
   VCID: 2404EE532F8E4EBD04-8070-R SFD+SFD2 [x]
Address 8105: DC/DC Converter 12V (A19)       Labels: 1EA-907-190-V2.clb
   Part No SW: 1EA 907 190 R    HW: 1EA 907 190 M
   Component: DCDC Gen4     H52 1354
   Revision: 00H52000
   ASAM Dataset: EV_DCDC2101011VW31X 001030
   ROD: EV_DCDC2101011VW31X.rod
   VCID: 43C64DCFCAC069851D-8016-R SFD+SFD2 [x]
Address 8107: Antenna
Address 8117: Rear surroundings cam (J772)       Labels:* None
   Part No SW: 1EA 980 568 C    HW: 1EA 980 568 B
   Component: RV eSmart     H20 0425
   Serial number: FCLK20230524000 Dataset Number: V03935434M  0001
   Coding: 0203800027140080
   ASAM Dataset: EV_AVCamerRearFicosUNECE 004031
   ROD: EV_AVCamerRearFicosUNECE_004_VWE3.rod
   VCID: 3E303C3BA122046D72-806A-R SFD+SFD2 [x]
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 E    HW: 5WA 962 133 E
   Component: Kessy RSAD    122 0756
   ASAM Dataset: EV_RSADVL37w 004018
   ROD: EV_RSADHR37w_004_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 004018
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 004018
   ROD: EV_RSADHL37w_004_VW38.rod
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 004018
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 009 JP
   Component: ICAS1 Sys_Ada 0711
   Dataset Number: V03935433DL 0001
   ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE 001006
   ROD: EV_AppServ1Sys1ICAS1UNECE.rod
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 009 JQ
   Component: ICAS1 Sys_Jav 0711
   Dataset Number: V03935433MX 0001
   ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE 001009
   ROD: EV_AppServ1Sys2ICAS1UNECE.rod
   VCID: 054293D7847497B573-8050-R SFD+SFD2 [x]
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 003 RG
   Component: IC3GIVI-D--EU 3612
   Dataset Number: V03935440NS 0001
   ASAM Dataset: EV_MUICASIVIPart 003001
   ROD: EV_MUICASIVIPart_003_VWE3.rod
   VCID: 7DB2FB37ECA4DF752B-8028-R SFD+SFD2 [x]
Address 8128: Light line display (J145)       Labels: 1T3-919-451.clb
   Part No SW: 14A 919 451 C    HW: 14A 919 451 C
   Component: ID_Light_GA   033 0064
   ASAM Dataset: EV_SmartLight1MEBGA 001014
   ROD: EV_SmartLight1MEBGA.rod
   VCID: 2600F45B59B2BCAD1A-8072-R SFD+SFD2 [x]
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 009 JR
   Component: ICAS1 SWCL_Em 0711
   Dataset Number: V03935434JA 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE 001011
   ROD: EV_SWCLEmbed1ICAS1UNECE.rod
   VCID: 064094DBB9729CAD7A-8052-R SFD+SFD2 [x]
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 009 JS
   Component: ICAS1 SWCL_HK 0711
   ASAM Dataset: EV_SWCLHouse1ICAS1UNECE 001007
   ROD: EV_SWCLHouse1ICAS1UNECE.rod
   VCID: 075E99DFBE7885A501-8052-R SFD+SFD2 [x]
End----(Elapsed Time: 03:39, VBatt start/end: 14.6V/14.6V. VIgn 0.0V)------
------------------------------12 Faults Found------------------------------
TTT
C?ID=547002
I think clear dtc is logged. So you want to go claim warranty work, while they could see someone has been messing about? If I would be your dealer, I would invite you out the door, or come back when you're prepared to pay? Just saying all this to help you?
Generally speaking, if all works as intended and there is no CEL icon on the dash ; I doubt if the dealer will do anything for you. Even if it is under warranty as in there eyes "nothing is wrong".
You could ask them if there have been any "updates" that they could apply to your vehicle.
End----(Elapsed Time: 03:39, VBatt start/end: 14.6V/14.6V. VIgn 0.0V)------ ------------------------------
Be sure you have the Ignition "ON" when scanning and if you are using a Amazon DLC cable, that voltage pin may not be wired (?) ; as that number should show Ignition voltage when the key is ON.
The record here on the forum is over 450 faults :eek:on a new vehicle! So, you are doing just fine. IMO.
Just realized :othat this is a EV, but I still think you are OK as your C6 faults appear to be intermittent .
Also, there are a few RT administrators who own EV's here on the forum who may comment as well
Sandbender
Denmark
C?ID=658569
Be sure you have the Ignition "ON" when scanning and if you are using a Amazon DLC cable, that voltage pin may not be wired (?) ; as that number should show battery voltage when the key is ON.
Argh.. damn.. I'll do a rerun in a bit and see if it doesn't help and post a updated scan - sometimes it's annoying that the car powers down as soon as you get up from the seat.. :D
Alas, a CEL icon would at least be something, but given that it's the car that decides to drop a phase it must have a reason to do so, and I need to find out why it happens.
My wall-charger (a Zaptec Go) is nothing but a glorified switch - it can't limit or modify currents or voltage and my neighbours (5 out of 5) also have EVs with no similar problems - they charge 11kW just fine even though I experience problems regularly.
Sandbender
Denmark
C?ID=658569
In Denmark it's pretty normal for independent workshops to do service and clear errors as part of that.
I'm not overly worried, but I still need to have some tangible errors that I can point to as they otherwise just charge me for having the car parked in their lot and not looking at it all day.. :/
In this case, it sounds like it doesn't all work as intended; charge rate dropping from 11 kW to 7 kW, but since this is an intermittent problem, if it doesn't happen at the dealer, they may brush it off.
Difficult to say without seeing an MVB map. How long do you have access to that HEX-NET for?
Sandbender
Denmark
C?ID=658569
Yes, exactly why I want some diagnostics prior to engaging them.
I also want (need..) to know that every time it happens the car actually logs an error, because the lack of any kind of technical data is driving me crazy..
I know it happened 2 or 3 times this saturday - I disconnected and started charging 2 or 3 times - but I can only find the most recent error from yesterday, so I feel like I need the diagnostics data to prove to the dealer that it's a problem.
At least a week or two - perhaps more if I ask nice.
/Jens
Sandbender
Denmark
C?ID=658569
Thanks, I'll take a look later this evening.
I'll see if I can get somewhere with MVB mapping as well or if it's blocked by SFD.
After looking at https://www.ross-tech.com/vcds/tour/controller-channels-map.php I can see that my scan above have several controllers without labels.
What's the difference between "Labels:* None" and "Labels: None"?
/Jens
The former means there's "experimental" coding data available directly from the .ROD/ASAM data.
Sandbender
Denmark
C?ID=658569
Ah, I see (.. as if I understood what that actually meant, but that's not really important right now :D)
/Jens
Sandbender
Denmark
C?ID=658569
Okay, so this is interesting (unfortunately in that annoying way where I can't really understand what it happening)..
I did a new full auto-scan with the ignition on, and the numer of logges errors has gone down.
The interesting this is, that the errors logged in controller "C6: Batt. Chrg." are gone.
That will help explain why the dealership didn't see anything when I asked about it the last time, but that only makes it even more aggravating trying to get them to handle the issue..
Last evening I did mess around with measurements, but more or less everything under "C6: Batt. Chrg." is lock behind SFD, but the errors were still listed at that time.
The only thing that's happened since are 4 trips totaling 94km during today - no charging or anything else.
(Note: VCDS version has been removed - not sure if I should post that (Uwe knows what I'm talking about.. :D)
Thursday,17,September,2026,19:04:25:21937
VCDS Version: 26.x.x.x (x64)  HEX-NET CB: 0.4713.4
Data version: 20260828 DS379.0
VIN: WVWZZZED3RE001110   Mileage: 29098km-18080miles
8107-Antenna -- Status: Malfunction 0010
   Dataset Number: V03935424SD 0001 CVN: 12BEA25D
   VCID: 04448ED38F4EAEBDA5-8050-R SFD+SFD2 [x]
   Radiator shutter:
   VCID: 0D52ABF7DC04EFF5FA-8058-R SFD+SFD2 [x]
   VCID: 5F8EA1BF46682D65D8-800A-R
   VCID: 3E303C3BA122046DB3-806A-R
   VCID: 352223179414C73562-8060-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002280424140615503
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000010000275679
   A/C compressor sub:
   Subsystem 3 - Part No SW: 1EA 816 797 G    HW: 1EA 816 797 G
   Component: J842 eKK       H09 0005
   Serial number: 1EA816797G15042410Q1
   Subsystem 4 - Part No SW: 1EA 963 581 E    HW: 1EA 963 581 E
   Component: 0123456789012  020 0172
   Serial number: T745647BB24141000104
   Subsystem 5 - Part No SW: 1EA 820 021 B    HW: 1EA 820 021 B
   Component: J126 J126      001 0001
   Serial number: 00000000000000000151
   Subsystem 6 - Part No SW: 1EA 816 590 A    HW: 1EA 816 590 A
   Component: N636 EV1_KaMi  H17 0020
   Serial number: 01500387230707110290
   Subsystem 7 - Part No SW: 4M0 959 603 F    HW: 4M0 959 603 F
   Component: G395 pT-Sens1  H15 0015
   Subsystem 8 - Part No SW: 11A 907 049     HW: 11A 907 049
   Component: E265 KPH       H02 0183
   Serial number: G07S25.04.2400973255
   VCID: 41CA47C7D0DC7B95CE-8014-R SFD [x]
15401472 - Secure Onboard Communication
          U14FF 00 [01100100] - Signature Generation Failed
          [Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen]
                    Reset counter: 36
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 15:33:32
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating State: Normal mode
                    Voltage: 14.5 V
                    Outside temperature: 19.0 °C
                    Light switch position: automatic
8667507 - Databus
          U1121 00 [00101110] - Missing Message
          [BMS_07 Datenbus fehlende Botschaft]
                    Mileage: 29026 km
                    Date: 2026.09.17
                    Time: 09:25:55
                    Terminal 15 status: OFF
                    Voltage: 12.3 V
                    Outside temperature: 14.5 °C
   Coding: 0238026101
   VCID: 33261D0F9A60D9054C-8066-R
   VCID: 3B36352FB230114594-806E-R SFD+SFD2 [x]
   VCID: 1464BE93FF2E3E3D35-8040-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 85E 980 945 D    HW: 85E 980 945 D
   Component: BeltPretRevFL  002 3040
   Serial number: 14B857705A0131Y00682
   Subsystem 2 - Part No SW: 85E 980 946 D    HW: 85E 980 946 D
   Component: BeltPretRevFR  002 3040
   Serial number: 14B857706A0131Y00376
   VCID: 3C343633B73E167D9D-8068-R SFD [x]
   VCID: 3C343633B73E167D9D-8068 SFD+SFD2 [x]
   Subsystem 2 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230201226831
   Left taillight 1:
   Subsystem 3 - Part No SW: 14B 945 423     HW: 14B 945 423
   Component: SBBR-LINKS1    H01 0001
   Serial number: 3000000001100L000411
   Left taillight 2:
   Subsystem 4 - Part No SW: 14B 945 429     HW: 14B 945 429
   Component: SBBR-LINKS2    H03 0001
   Serial number: 3000000001300L000051
   Right taillight 1:
   Subsystem 5 - Part No SW: 14B 945 424     HW: 14B 945 424
   Component: SBBR-RECHTS1   H01 0001
   Serial number: 3000000001200R000045
   Right taillight 2:
   Subsystem 6 - Part No SW: 14B 945 430     HW: 14B 945 430
   Component: SBBR-RECHTS2   H03 0001
   Serial number: 3000000001300R000034
   Subsystem 7 - Part No SW: 5Q0 951 172 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA    006 0501
   Serial number: 0000000000000Q3G95AT
   Subsystem 8 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000004294055
   Subsystem 9 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 45130056
          B2012 00 [00101111] - -
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:37:37
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:37:37
8491266 - Secure Onboard Communication
          U14FE 00 [00101100] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Mileage: 29026 km
                    Date: 2026.09.17
                    Time: 04:15:15
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 14:37:38
   VCID: 004C82C39B56B29D81-8054-R SFD+SFD2 [x]
   VCID: 085C9AE3B3668ADDC9-805C-R SFD+SFD2 [x]
   Coding: 6AA54750
   VCID: 3FCE413FA6280D65B8-806A-R
   VCID: 47DE59DFFEF845A500-8012-R
   VCID: 393A2F27B80C235586-806C-R SFD+SFD2 [x]
   ROD: EV_DMCM21000110ET907121J_VWE3.rod
   VCID: 47DE59DFFEF845A500-8012-R SFD+SFD2 [x]
          U0122 00 [00100000] - -
                    Fault Frequency: 19
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 15:45:42
   VCID: 46C054DBF9F25CADFB-8012-R
   VCID: 1D72DBB70CE47F758A-8048-R SFD+SFD2 [x]
   VCID: 312A1707607CEB153E-8064-R SFD+SFD2 [x]
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R243 UmfKamSV  H23 0070
   Serial number: FCLMAR100524000709DD
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R244 UmfKamSL  H23 0070
   Serial number: FCLMAR25042401060277
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 5WA 980 546 E    HW: 5WA 980 546 D
   Component: R245 UmfKamSR  H23 0070
   Serial number: FCLMAR200424000512E9
   Coding: 5488
   VCID: 45C253D7C4F457B5F2-8010-R
   Coding: 500F80
   VCID: 1B76D5AF12F0714574-804E-R SFD+SFD2 [x]
   VCID: 2E100C7B7142F4ED23-807A-R
   Serial number: 000000040324010 Dataset Number: V03935430CT 0001 CVN: 30DE26FF00000000384B0A12384B0A12384B0A12
   VCID: 7DB2FB37ECA4DF75EA-8028-R
   Coolant heating:
   VCID: 4BD665EFE290A1C524-801E-R
   VCID: 4AD860EBEDEAB8CD1F-801E-R
   Coding: 10C0
   VCID: 4DD26BF71C84AFF53A-8018-R SFD+SFD2 [x]
   VCID: 6A98C06B8D2A58CD3F-803E-R
   Coding: 400080
   VCID: 2404EE532F8E4EBDC5-8070-R SFD+SFD2 [x]
   Revision: 00H52000
   VCID: 43C64DCFCAC06985DC-8016-R SFD+SFD2 [x]
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 1EA 035 741 L    HW: 1EA 035 741 F
   Component: TrxModulBasic H04 0522
   Dataset Number: V03935426AC 0001
   Coding: 0231210101010002000001010101010101000000
   ASAM Dataset: EV_TrxMLGEMEB31 001026
   ROD: EV_TrxMLGEMEB31_VWE3.rod
   VCID: 373E291F8E18352570-8062-R SFD+SFD2 [x]
1375488 - Communication Authentication
          U3036 00 [01101100] - Signal Malfunction
          [SOK_timeserver_not_available]
                    Reset counter: 38
                    Mileage: 29098 km
                    Date: 2026.09.17
                    Time: 15:09:27
1375744 - Communication Authentication
          U3035 00 [00101100] - Invalid Signal
                    Mileage: 29050 km
                    Date: 2026.09.17
                    Time: 09:53:55
                    Failed verification status: valid
                    Number of failed verifications: 14
                    Verification failed: 00 08
   VCID: 3E303C3BA122046DB3-806A-R SFD+SFD2 [x]
   VCID: 054293D7847497B5B2-8050-R SFD+SFD2 [x]
   VCID: 7DB2FB37ECA4DF75EA-8028-R SFD+SFD2 [x]
1872 - Automotive Audio Bus (A2B)
          B1994 F4 [00001000] - Microphone Module Defective
          [a2b_bus_micro_defect]
                    Fault Frequency: 15
                    Mileage: 29004 km
                    Date: 2026.09.16
                    Time: 15:06:41
                    Voltage terminal 30: 14.5 V
                    amount_of_nodes: 2
                    Node number: 1
                    Node name: Emergency call module and communication unit
                    Node status: OK
   VCID: 2600F45B59B2BCADDB-8072-R SFD+SFD2 [x]
   VCID: 064094DBB9729CADBB-8052-R SFD+SFD2 [x]
   VCID: 075E99DFBE7885A5C0-8052-R SFD+SFD2 [x]
End----------(Elapsed Time: 03:31, VBatt start/end: 14.8V/14.8V)-----------
------------------------------11 Faults Found------------------------------
Sandbender
Denmark
C?ID=658569
Oh, another thing:
When SFD unlock expires after 90 minutes - can a measurement from an unlocked module keep beeing measured even though the controller has relocked?
I suspect not, but is there any way of automating unlocking and restarting measurements, so I can keep measuring data from the "C6: Batt. Chrg." controller while charging for 2-3-4 hours and hope it doesn't drop down from 11kW just at the right (wrong..) time?
I could probably use AutoIt (or something similar) to just press VCDS' various buttons as if it was myself doing it, but it just as well be that VCDS has a feature up its sleave I havn't heard of yet? :)
