2025 SQ5 Service reset?
Rallyedude
Aylmer QC, Canada
C?ID=6146
So, I went to rest service indicator. It started reading the info as normal , but then came to a point where it stop and didn't allow it . I uploaded latest version VCDS just in case. Same result . apparently, Some of the SQ5's around this year have a owner option for reset . This car does not. The client was told by Audi it was available but as an added cost. Am I missing something here ? Or will I not be able to to a service reset on this Audi ?
Wednesday,16,September,2026,12:05:09:15191
VCDS Version: 26.9.0.3 (x64)  HEX-NET2 CB: 0.4713.5
VIN: WA135AGU4S2043870   License Plate: 2025SQ5
Mileage: 9242km-5742mi   Repair Order:
Chassis Type: GU-AU40 (85F)
Scan: 01 02 03 09 13 15 16 17 19 22 29 2C 36 39 42 44 46 52 5F 65
          69 6C 75 7E 81 82 8B A5 BB BC C5 CA DE 8103 8109 810A 810B 810C 8119 811E
          811F 8120 8121 8122 8124 8125 8128 812C 812D 8131 8132 8133 8136 813F 8147 8153 8157 C002 C003
VIN: WA135AGU4S2043870   Mileage: 9242km-5742miles
29-Left Light -- Status: Malfunction 0010
2C-Rear pres. detection -- Status: Cannot be reached 0100
39-Right Light -- Status: Malfunction 0010
7E-Ctrl Head Dash -- Status: Malfunction 0010
82-Head Up Display -- Status: Malfunction 0010
C5-Therm. mgt. -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: Malfunction 0010
8103-Driver assist main -- Status: Malfunction 0010
8109-Close Rge Radar 1 -- Status: Malfunction 0010
810A-Close Rge Radar 2 -- Status: Malfunction 0010
810B-Close Rge Radar 3 -- Status: Malfunction 0010
810C-Close Rge Radar 4 -- Status: Malfunction 0010
8119-Multifunc. St. Wheel 3 -- Status: OK 0000
8122-Burglary Protection Interior -- Status: OK 0000
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: Malfunction 0010
812C-Drive/Chassis Main Ctrl -- Status: Malfunction 0010
812D-Snd enhanct 3 -- Status: Malfunction 0010
8131-Air suspension -- Status: OK 0000
8132-Electrical system main 1 -- Status: Malfunction 0010
8133-Low volt. power distrib. 1 -- Status: OK 0000
8136-Close rnge comm antenna;drv side -- Status: Malfunction 0010
813F-Main; cockpit system 1 sound -- Status: OK 0000
8147-Passenger displ for multimedia -- Status: OK 0000
8153-Main; cockpit sys. 3 Android -- Status: Malfunction 0010
8157-Burglar prot. 6; veh. interior 2 -- Status: OK 0000
Address 01: Engine (J623-DWVA)       Labels: Redir Fail!
   Part No SW: 8MA 907 559 C    HW: 06M 907 309 N
   Component: V6 3.0l TFSI  H80 0004
   Revision: 43H80001    Dataset Number: 06M909102CK 0002 CVN: DEF87956
   Coding: 302500026002010600000000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0118MA907559C 001006
   ROD: EV_ECM30TFS0118MA907559C.rod
   VCID: 4CCA0C187638A21A4B8-8118-R SFD+SFD2 [x]
   VINID: 9D10431515E51230801032070016458A2A
45123 - Main Drive and Chassis Control Module
          U0595 00 [00100000] - Implausible Signal
          [Drive and chassis main control moduleimplausible signal]
                    Reset counter: 20
4710 - No Communications with Airbag Control Module
          U0151 00 [00100000] - -
45118 - Drive and Chassis Main Control Module
          U0294 00 [00100000] - No Communication
          [Drive and chassis main control moduleno communication]
45131 - Diagnostic Gateway
          U0146 00 [00100000] - No Communications
          [Lost Communication With Serial Data Gateway Module "A"]
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 8MA 927 153 AA    HW: 0F0 927 156 C
   Component: 30TSI US 1430 H80 0002
   Revision: --H80---    Serial number: 0000000271 CVN: 32D755BD
   ASAM Dataset: EV_TCMDL382022 001010
   ROD: EV_TCMDL382022_001.rod
   VCID: 0358E7241BE6AD62FA2-8156-R SFD [x]
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AB    HW: 0CK 321 281 N
   Component: V553 MTFP  005 0713
   Serial number: 75408051250062002623
41873 - Online Remote Update
          U192A 00 [00100000] - No Signal
          [Online Remote Update No signal]
Address 03: ABS Brakes (J104)       Labels:* 8B3-909-059-V1.clb
   Part No SW: 8B3 909 059 S    HW: 8B3 909 059 B
   Component: ABS           H04 0381
   Serial number: ZSC864300425012 Dataset Number: 8MA909504AS 0001 CVN: F6C34A7D
   Coding: 30891D4010A69A10D2B50900AF0000000000000000000000
   ASAM Dataset: EV_BRSAU41X 020035
   ROD: EV_BRSAU41X_020_AU40.rod
   VCID: 40D228284A70767AA70-8114-R SFD+SFD2 [x]
21 Faults Found:
0016 - No Communications with Airbag Control Module
          [PDU_IMU_02_-_Timeout_error-RBNet_ComSc_l_IMU_02_Timeo_ut]
0130 - Airbag Control Module
          U1243 00 [00100000] - Implausible Message
          [Signal_IMU_YawRate_Qlfr_-_Init_(14_65534)-RBNet_IMU_02_Scl_IMU_YawRa_te_Init]
0268 - Implausible Data Received from Airbag Control Module
          U0452 00 [00100000] - -
          [Signal_IMU_YawRate_-_Error_or_Init_or_Invalid_OR_Signal_IMU_YawRate_Qlfr_-_Error_or_Init_or_Invalid_or_TempError_or_SensorNotCalibrated_or_QTSError_OR_PDU_IMU_02_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_IMU_02_Scl_IMU_YawRa_te_Cumul]
0455 - Implausible Data Received from Airbag Control Module
          [Signal_IMU_PitchRate_-_Init_(65534)_OR_Signal_IMU_PitchRate_Qlfr_-_Init_(14)-RBNet_IMU_02_Scl_IMU_Pitch_Rate_Init]
0461 - Implausible Data Received from Airbag Control Module
          [Signal_IMU_PitchRate_-_Error_or_Init_or_Invalid_OR_Signal_IMU_PitchRate_Qlfr_-_Error_or_Init_or_Invalid_or_TempError_or_SensorNotCalibrated_or_QTSError_OR_PDU_IMU_02_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_IMU_02_Scl_IMU_Pitch_Rate]
0468 - Implausible Data Received from Airbag Control Module
          [Signal_IMU_ALat_Qlfr_-_Init_(14_65534)-RBNet_IMU_02_Scl_IMU_ALat_Init]
0474 - Implausible Data Received from Airbag Control Module
          [Signal_IMU_ALat_-_Error_or_Init_or_Invalid_OR_Signal_IMU_ALat_Qlfr_-_Error_or_Init_or_Invalid_or_TempError_or_SensorNotCalibrated_or_QTSError_OR_PDU_IMU_02_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_IMU_02_Scl_IMU_ALat_Cumul]
0475 - Implausible Data Received from Airbag Control Module
          [Signal_IMU_ALgt_Qlfr_-_Init_(14_65534)-RBNet_IMU_02_Scl_IMU_ALgt_Init]
0481 - Implausible Data Received from Airbag Control Module
          [Signal_IMU_ALgt_-_Error_or_Init_or_Invalid_OR_Signal_IMU_ALgt_Qlfr_-_Error_or_Init_or_Invalid_or_TempError_or_SensorNotCalibrated_or_QTSError_OR_PDU_IMU_02_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_IMU_02_Scl_IMU_ALgt_Cumul]
0492 - No Communications with Airbag Control Module
          [PDU_Airbag_10_-_Timeout_error-RBNet_ComSc_l_Airba_g_10_Timeo_ut]
0628 - Main Drive and Chassis Control Module
          U0595 00 [00101110] - Implausible Signal
          [Signal_VMM_HldMng_StHldAvl_-_Invalid_(6)-RBNet_VMM_10_Scl_VMM_HldMn_g_StHld_Avl_Inval_id]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:12
0629 - Main Drive and Chassis Control Module
          U0595 00 [00100010] - Implausible Signal
          [Signal_VMM_HldMng_StHldAvl_-_Error_or_Invalid_OR_PDU_VMM_10_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_VMM_10_Scl_VMM_HldMn_g_StHld_Avl_Cumul]
0631 - Main Drive and Chassis Control Module
          [Signal_VMM_HldMng_StHldAcv_-_Invalid_(14)-RBNet_VMM_10_Scl_VMM_HldMn_g_StHld_Acv_Inval_id]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:12
0632 - Main Drive and Chassis Control Module
          [Signal_VMM_HldMng_StHldAcv_-_Error_or_Invalid_OR_PDU_VMM_10_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_VMM_10_Scl_VMM_HldMn_g_StHld_Acv_Cumul]
0639 - Main Drive and Chassis Control Module
          [Signal_LODM_TqWhlDece_StAvl_-_Invalid_(2)-RBNet_LODM_01_Scl_LODM_TqWhl_Dece_StAvl_Inval_id]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:12
0640 - Main Drive and Chassis Control Module
          [Signal_LODM_TqWhlDece_StAvl_-_Error_or_Invalid_OR_PDU_LODM_01_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_LODM_01_Scl_LODM_TqWhl_Dece_StAvl_Cumul]
0644 - Databus
          U1123 00 [00100000] - Received Error Message
          [Signal_VMM_ACALgtCtl_StAcv_-_Error_(7)-RBNet_VMM_07_Scl_VMM_ACALg_tCtl_StAcv_Error]
0646 - Main Drive and Chassis Control Module
          [Signal_VMM_ACALgtCtl_StAcv_-_Error_or_Invalid_OR_PDU_VMM_07_not_received_correctly_(combination_of_TO_CRC_AC)-RBNet_VMM_07_Scl_VMM_ACALg_tCtl_StAcv_Cumul]
0675 - Access/Start Control Module
          U3033 00 [00100000] - Certificate Missing or Invalid
          [The_current_BUS_VIN_does_not_match_the_VIN_stored_from_the_last_received_Downloadcontainer.-VKMS_DLC_vehic_le_chang_e]
0678 - Communication Authentication
          U3035 00 [00100000] - Invalid Signal
          [The_MAC_of_at_least_one_secured_Rx_PDU_could_not_be_verified.-RBNET_SOK_Signa_ture_Verif_icati_on_Faile_d]
5308452 - System Voltage
          P0562 00 [00100000] - Too Low
          [Supply_voltage_too_low._Reduced_brake_system_performance.-PSCUn_derVo_ltage_Level_1]
   Part No: V04 007 000 PK
   Component: BCM1 E3 1.2   1437
   Dataset Number: 8MA909514S  0124
   Coding: 20F83500720704003F70CB0000000020021F01A521000000000000000000581F00000000000000060FE4933740600D000500C1C34C8114B17D68930505000000000000000000244059000000000000000000000000B7110000000812480000002B300C100000000000A00013E96003F113000000000200005007013603BE4800000000000000000800000000000000000000000000008104070600000000000000000000000700000000030000000001000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_HCP4Contr1AU41X 010023
   ROD: EV_HCP4Contr1AU41X_010_AU40.rod
   VCID: 7CAA9CD86618D29ABB8-8128-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 8MB 955 119 C    HW: 8MB 955 119
   Component: J400FRWISCH    H07 0402
   Serial number: VALSLP27052501000777
   Subsystem 2 - Part No SW: 85E 955 555 A    HW: 85E 955 555
   Component: G397_RLFSS     H09 0009
   Serial number: 40490547X85E955555A0
   Subsystem 3 - Part No SW: 85E 925 301 AH    HW: 85E 925 301 AH
   Component: E791 - SL1     H06 0111
   Serial number: 17S 2025-05-15 02021
   Control unit 2 for driving and convenience functions:
   Subsystem 4 - Part No SW: 85H 959 673     HW: 85H 959 673
   Component: AUDI_SBW_SAAM  H06 0370
   Serial number: 01571XLC02452-------
   Interior Light Module:
   Subsystem 5 - Part No SW: 85E 947 135 BC    HW: 85E 947 135 BC
   Component:   WX3   LIM_1  H52 0070
   Serial number: 00000000000000147255
   Subsystem 6 - Part No SW: 5Q0 951 172 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA    006 0501
   Serial number: 0000000000000Q3GR5WL
   Subsystem 7 - Part No SW: 85J 857 511     HW: 85J 857 511
   Component: Y7_Innenspieg  H03 0001
   Serial number: GX1CE109052523310357
   Subsystem 8 - Part No SW: 85E 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H17 0420
   Serial number: GX1GRA150525000100YU
   Subsystem 9 - Part No SW: 80A 907 705 C    HW: 80A 907 705 B
   Component: J866-EVLS-SG   H02 0352
   Serial number: WA174019000171864393
   Power rear lid opening control module:
   Subsystem 10 - Part No SW: 80A 962 243     HW: 80A 962 243
   Component: GEB.F.Heckoef  H17 0911
   Serial number: 40845012
   Subsystem 11 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA    005 0314
   Serial number: 00000000000044718357
   Left taillight 1:
   Subsystem 12 - Part No SW: 8MA 945 423 E    HW: 8MA 945 423 E
   Component:   MX3 SHL_li1  H10 0007
   Left taillight 2:
   Subsystem 13 - Part No SW: 8MA 945 429 E    HW: 8MA 945 429 E
   Component:  MX13 SHL_li2  H10 0007
   Left taillight 3:
   Right taillight 1:
   Subsystem 15 - Part No SW: 8MA 945 424 E    HW: 8MA 945 424 E
   Component:   MX4 SHL_re1  H10 0007
   Right taillight 2:
   Subsystem 16 - Part No SW: 8MA 945 430 E    HW: 8MA 945 430 E
   Component:  MX13 SHL_re2  H10 0007
   Right taillight 3:
   Left taillight 4:
   Subsystem 18 - Part No SW: 8MA 945 423 F    HW: 8MA 945 423 F
   Component:   MX3 SHL_li4  H10 0410
   Right taillight 4:
   Subsystem 19 - Part No SW: 8MA 945 424 F    HW: 8MA 945 424 F
   Component:   MX4 SHL_re4  H10 0410
   Left taillight 6:
   Subsystem 20 - Part No SW: 8MA 945 429 F    HW: 8MA 945 429 F
   Component:  MX13 SHL_li6  H10 0410
   Right taillight 6:
   Subsystem 21 - Part No SW: 8MA 945 430 F    HW: 8MA 945 430 F
   Component:  MX13 SHL_re6  H10 0410
42 Faults Found:
0002 - Internal Fault
          B200F F0 [01101101] - -
          [Control module: internal faulty Alive supervision of CO]
                    Date: 2026.05.18
                    Time: 17:08:42
65734 - Control module for rear lid opening
          B1303 F0 [00101000] - Play protection active
          [Control module for tailgate spoiler opening: play protection active]
                    Fault Frequency: 8
                    Reset counter: 29
                    Date: 2026.05.13
                    Time: 23:59:27
262161 - Databus
          U1121 00 [00101000] - Missing Message
          [NWD: VC_01 Timeout]
                    Fault Frequency: 83
                    Reset counter: 36
                    Mileage: 414 km
                    Date: 2025.11.09
                    Time: 18:57:50
66688 - Databus
          U1121 00 [00101111] - Missing Message
          [High performance platform 2 control module: ACA_01: no signal/communication]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:46
67328 - Databus
          U1121 00 [00100000] - Missing Message
          [Telematics communication unit: VTS_01: no signal/communication]
69632 - Implausible Data Received from Brake System Control Module
          U0418 00 [01101000] - -
          [WSS no or invalid signed data esc]
                    Reset counter: 17
                    Mileage: 8244 km
                    Date: 2026.08.09
                    Time: 15:08:28
69633 - Main Drive and Chassis Control Module
          U0595 00 [01101000] - Implausible Signal
          [WSS no or invalid signed data hcp1]
                    Reset counter: 17
                    Mileage: 8244 km
                    Date: 2026.08.09
                    Time: 15:08:28
2162691 - VKMS
          B18B0 F3 [01101101] - Invalid Key Request During Use
          [VKMS_application_requested_missing_key]
2163456 - Communication Authentication
          U3036 00 [00101110] - Signal Malfunction
          [SOK_timeserver_not_available]
                    Fault Frequency: 195
2163457 - Communication Authentication
          [SOK_signature_verification_failed]
2163713 - Clock Syncronization Failure
          U138F 00 [00101000] - -
          [Ip_clock_sync_outage_2]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:20:40
197632 - Remote key 1
          B1479 18 [01101000] - Current Too Low
          [Remote key 1: voltage too low]
                    Fault Frequency: 62
                    Reset counter: 32
                    Date: 2025.10.30
                    Time: 21:04:18
327681 - Data Set Implausible
          B2012 00 [00101000] - -
          [VLK implausible dataset]
                    Reset counter: 20
                    Date: 2026.07.24
                    Time: 20:16:08
458755 - High Beam Assist
          C12A9 F0 [00100000] - Fog Mode Active
          [FLA headlight fog mode active]
458766 - Driver Assistance System Front Camera
          U16DE 00 [01100000] - Received Malfunction Value
          [MXB camera signals blindness signal received error value]
524293 - Adaptive Front Light Distribution
          C1411 F0 [00100000] - Function Restriction
          [AFS reduced functionality]
590120 - Databus
          U1121 00 [01100000] - Missing Message
          [EL ECALL 01 no communication]
590136 - Databus
          U1121 00 [01101101] - Missing Message
          [EL SM ZAM 01: no signal/communication]
                    Fault Frequency: 206
                    Date: 2025.10.29
                    Time: 13:43:46
721152 - Parking Sensor(s); Rear
          B107B F0 [01100100] - Function Limitation due to External Factors
          [Rear parking aid sensors: function restriction due to environmental conditions]
721153 - Parking Sensor(s); Front
          B10FC F0 [01100100] - Function Limitation due to External Factors
          [Front parking aid sensors: function restriction due to environmental conditions]
721154 - Side Parking Aid Sensor
          B1CED F0 [01100100] - Function Limitation due to Environmental Influences
          [Side parking aid sensors: function restriction due to environmental conditions]
721412 - Parking Sensor; Rear Left
          B1076 F5 [00100000] - Ice or Dirt Detection
          [Rear outer left parking aid sensor: function restriction due to ice or dirt]
721414 - Parking Sensor; Rear Left
          B1076 F4 [00100000] - Function Limitation due to Environmental Influences
          [Rear outer left parking aid sensor: malfunctioning]
721428 - Parking Sensor; Rear Left Side
          B107D F5 [00100000] - Ice or Dirt Detection
          [Rear side left parking aid sensor: function restriction due to ice or dirt]
721444 - Parking Sensor; Rear Left Center
          B1077 F5 [00100000] - Ice or Dirt Detection
          [Rear center left parking aid sensor: function restriction due to ice or dirt]
721446 - Parking Sensor; Rear Left Center
          B1077 F4 [00100000] - Function Limitation due to Environmental Influences
          [Rear center left parking aid sensor: malfunctioning]
721460 - Parking Sensor; Rear Right Center
          B1078 F5 [00100000] - Ice or Dirt Detection
          [Rear center right parking aid sensor: function restriction due to ice or dirt]
721462 - Parking Sensor; Rear Right Center
          B1078 F4 [00100000] - Function Limitation due to Environmental Influences
          [Rear center right parking aid sensor: malfunctioning]
721476 - Parking Sensor; Rear Right Side
          B107E F5 [00100000] - Ice or Dirt Detection
          [Rear side right parking aid sensor: function restriction due to ice or dirt]
721478 - Parking Sensor; Rear Right Side
          B107E F4 [00100000] - Function Limited due to Environmental Influences
          [Rear side right parking aid sensor: malfunctioning]
721494 - Parking Sensor; Rear Right
          B1079 F4 [00100000] - Function Limitation due to Environmental Influences
          [Rear outer right parking aid sensor: malfunctioning]
721508 - Parking Sensor; Front Left
          B10F7 F5 [00100000] - Ice or Dirt Detection
          [Front outer left parking aid sensor: function restriction due to ice or dirt]
721510 - Parking Sensor; Front Left
          B10F7 F4 [00100000] - Function Limited due to Environmental Influences
          [Front outer left parking aid sensor: malfunctioning]
721540 - Parking Sensor; Front Left Center
          B10F8 F5 [00100000] - Ice or Dirt Detection
          [Front center left parking aid sensor: function restriction due to ice or dirt]
721542 - Parking Sensor; Front Left Center
          B10F8 F4 [00100000] - Function Limited due to Environmental Influences
          [Front center left parking aid sensor: malfunctioning]
721556 - Parking Sensor; Front Right Center
          B10F9 F5 [00100000] - Ice or Dirt Detection
          [Front center right parking aid sensor: function restriction due to ice or dirt]
721558 - Parking Sensor; Front Right Center
          B10F9 F4 [00100000] - Function Limited due to Environmental Influences
          [Front center right parking aid sensor: malfunctioning]
721572 - Parking Sensor; Front Right Side
          B10FB F5 [00100000] - Ice or Dirt Detection
          [Front side right parking aid sensor: function restriction due to ice or dirt]
721588 - Parking Sensor; Front Right
          B10FA F5 [00100000] - Ice or Dirt Detection
          [Front outer right parking aid sensor: function restriction due to ice or dirt]
721590 - Parking Sensor; Front Right
          B10FA F4 [00100000] - Function Limited due to Environmental Influences
          [Front outer right parking aid sensor: malfunctioning]
721664 - Intelligent Parking Assistant; high
          U2062 00 [01100000] - Function Restriction
          [IPA not available]
721673 - Drive and Chassis Main Control Module
          U195E 00 [01100000] - Received Malfunction Value
          [IPA VMM received error value]
   Part No SW: 85E 907 572 N    HW: 85E 907 572 D
   Component: ACC Bosch MQB H03 0325
   Dataset Number: 8MA909863X  0001
   Coding: A59120024071C4E8A02200004000000000009400640A000000000000000000
   ASAM Dataset: EV_MidRangeRadar5AU416 001027
   ROD: EV_MidRangeRadar5AU416_001_AU40.rod
   VCID: 3E2E56D03084008AD5C-816A-R SFD+SFD2 [x]
79 Faults Found:
0315 - Control Module Improper Shut Down
          U3001 00 [00101000] - -
          [FAULT_IMPROPER_SHUTDOWN]
                    Fault Frequency: 66
                    Reset counter: 37
                    Mileage: 4291 km
0371 - Databus
          U1122 00 [00100000] - Implausible Message
          [FAULT_SMLWS_01_BZ]
0380 - Databus
          [FAULT_TIMEOUT_VMM_07]
0392 - Databus
          U1122 00 [10101111] - Implausible Message
          [FAULT_VMM_ACCLGTCTL_STVLD_INIT]
                    Mileage: 6307 km
                    Date: 2026.05.16
                    Time: 22:48:05
0428 - Databus
          [FAULT_OBJECTDETECTION_TIMESTAMPSTATUS_FEHLER]
0430 - Databus
          [FAULT_PEDESTRIANDETECTION_TIMESTAMPSTATUS_FEHLER]
0432 - Databus
          [FAULT_LDA_TIMESTAMPSTATUS_FEHLER]
0435 - Databus
          [FAULT_TIMEOUT_NR_RS_HEADER]
0436 - Databus
          [FAULT_TIMEOUT_NR_RS_OBJECT_01_02]
0437 - Databus
          [FAULT_TIMEOUT_NR_RS_OBJECT_03_04]
0639 - Clock Syncronization Failure
          U138F 00 [00100000] - -
0764 - Databus
          [FAULT_TIMEOUT_VDSO_05]
0790 - Internal Fault
          B200F F0 [00100000] - -
          [FAULT_RB_PER_HV_SERVICE_OOS]
1396 - Sensor for Automatic Distance Control
          C110B F0 [00100000] - Limited Visibility
          [FAULT_SENSOR_NO_FREE_SIGHT]
1538 - Sensor for Automatic Distance Control
          C110B F0 [00101000] - Limited Visibility
          [FAULT_SENSOR_BLINDNESS]
                    Reset counter: 14
                    Mileage: 7314 km
                    Date: 2026.07.09
                    Time: 20:01:14
1842 - Databus
          U1122 00 [00101000] - Implausible Message
          [FAULT_RB_MFK_BLINDNESS_ODACC]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:27
1845 - Databus
          [FAULT_RB_CAL_FC1_STATUS_DEVIATION]
1846 - Databus
          [FAULT_RB_MFK_OD_INIT]
                    Reset counter: 37
                    Mileage: 9123 km
                    Date: 2026.09.12
                    Time: 02:08:18
1847 - Databus
          [FAULT_RB_MFK_PED_INIT]
                    Reset counter: 37
                    Mileage: 9123 km
                    Date: 2026.09.12
                    Time: 02:08:18
1850 - Databus
          [FAULT_RB_NR_FL_NOT_AVAILABLE]
1851 - Databus
          [FAULT_RB_NR_FR_NOT_AVAILABLE]
1852 - Databus
          [FAULT_RB_MFK_OD_NOT_AVAILABLE]
1853 - Databus
          [FAULT_RB_MFK_PED_NOT_AVAILABLE]
1854 - Databus
          [FAULT_RB_MFK_LDA_NOT_AVAILABLE]
1856 - Databus
          U1123 00 [00101110] - Received Error Message
          [FAULT_RB_NR_FL_FAILURE]
                    Fault Frequency: 9
                    Mileage: 6840 km
                    Date: 2026.06.12
                    Time: 19:18:52
1857 - Databus
          [FAULT_RB_NR_FR_FAILURE]
                    Fault Frequency: 8
                    Mileage: 6840 km
                    Date: 2026.06.12
                    Time: 19:18:52
1860 - Databus
          [FAULT_RB_MFK_LDA_FAILURE]
1866 - Databus
          [FAULT_RB_CAL_FC1_STATUS_NOTAVAILABLE]
1876 - Databus
          [FAULT_RB_BHE_FC1_STATUS_INIT_UNAVAILABLE_QM]
1877 - Databus
          [FAULT_RB_MFK_OD_TIMESTAMP_INVALID]
1878 - Databus
          [FAULT_RB_CAL_FC1_STATUS_ERROR_OOR]
1880 - Databus
          [FAULT_RB_MFK_PD_TIMESTAMP_INVALID]
1883 - Databus
          [FAULT_RB_MFK_LDA_TIMESTAMP_INVALID]
1884 - Databus
          [FAULT_RB_MFK_BLINDNESS_OD_PED]
                    Mileage: 7036 km
                    Date: 2026.06.23
                    Time: 11:34:44
1885 - Databus
          [FAULT_RB_MFK_BLINDNESS_LDA]
                    Mileage: 7036 km
                    Date: 2026.06.23
                    Time: 11:34:44
1886 - Databus
          [FAULT_RB_BHE_FC1_STATUS_ERROR]
1891 - Databus
          [FAULT_RB_MFK_OD_FAILURE]
1892 - Databus
          [FAULT_RB_MFK_PED_FAILURE]
1920 - Databus
          [FAULT_RB_TIMEOUT_BHE_01]
1923 - Databus
          [FAULT_RB_TIMEOUT_CAMERACALIBRATION_01]
1927 - Databus
          [FAULT_RB_TIMEOUT_SERVICE_OBJECTDETECTION]
1931 - Databus
          [FAULT_RB_TIMEOUT_SERVICE_PEDESTRIANDETECTION]
1935 - Databus
          [FAULT_RB_TIMEOUT_LDA_FC1]
2009 - Databus
          [FAULT_RB_TIMEOUT_VDSO_02]
2010 - Databus
          [FAULT_RB_TIMEOUT_VDSO_03]
2011 - Databus
          [FAULT_RB_TIMEOUT_VDSO_04]
2012 - Databus
          [FAULT_RB_TIMEOUT_VDSO_07]
2013 - Databus
          [FAULT_RB_TIMEOUT_VDSO_09]
2261 - Databus
          [FAULT_RB_MFK_OD_TIMESTAMP_NOT_PLAUSIBLE]
2262 - Databus
          [FAULT_RB_MFK_PD_TIMESTAMP_NOT_PLAUSIBLE]
2263 - Databus
          [FAULT_RB_MFK_LDA_TIMESTAMP_NOT_PLAUSIBLE]
2264 - Databus
          [FAULT_RB_NR_FL_TIMESTAMP_NOT_PLAUSIBLE]
2265 - Databus
          [FAULT_RB_NR_FR_TIMESTAMP_NOT_PLAUSIBLE]
16776817 - Online Remote Update
          B199A 00 [00100000] - -
          [FAULT_REMOTE_PRODUCTION_CLIENT_UPDATE]
16776844 - Databus
          [FAULT_TIMEOUT_VMM_09]
16776854 - Databus
          [FAULT_TIMEOUT_VMM_10]
16776864 - Databus
          [FAULT_TIMEOUT_GRA_01]
16776943 - Databus
          [FAULT_TIMEOUT_VMM_06]
16776944 - Databus
          [FAULT_TIMEOUT_VMM_05]
16776945 - Databus
          [FAULT_TIMEOUT_VMM_04]
16776948 - Databus
          [FAULT_TIMEOUT_EPS_01]
16776949 - Databus
          [FAULT_TIMEOUT_AIRBAG_10]
16776951 - Databus
          [FAULT_TIMEOUT_LWI_03]
16776953 - Databus
          [FAULT_TIMEOUT_FAS_HCP1_02]
16776955 - Databus
          [FAULT_TIMEOUT_ESC_06]
16776956 - Databus
          [FAULT_TIMEOUT_ESC_03]
16776958 - Databus
          [FAULT_TIMEOUT_ESC_11]
16777017 - Databus
          [FAULT_TIMEOUT_NR_RS_OBJECT_05_06]
16777024 - Databus
          [FAULT_TIMEOUT_NR_RS_OBJECT_07_08]
16777025 - Databus
          [FAULT_TIMEOUT_NR_RS_OBJECT_09_10]
16777033 - Databus
          [FAULT_NANORADAR_REAR_LEFT_ERROR]
16777041 - Databus
          U1123 00 [00101000] - Received Error Message
          [FAULT_NANORADAR_REAR_REAR_ERROR]
                    Fault Frequency: 8
                    Reset counter: 30
                    Mileage: 6450 km
                    Date: 2026.05.27
                    Time: 19:09:38
16777127 - Databus
          [FAULT_VMM_WBATRJCTL_STACV_ERROR]
16777129 - Databus
          [FAULT_VMM_WBAPRECDN_STACV_ERROR]
16777131 - Databus
          [FAULT_VMM_WBALGTLIMA_STACV_ERROR]
16777133 - Databus
          [FAULT_VMM_WBAHYDBRKASI_STACV_ERROR]
16777186 - Databus
          [FAULT_US_PB_FRONT]
16777187 - Databus
          [FAULT_US_PB_FREESPACE_FRONT]
16777207 - Databus
          U1467 00 [00101110] - Service Not Available
          [SOME_IP_service_interface_not_available]
                    Fault Frequency: 13
                    Mileage: 6840 km
                    Date: 2026.06.12
                    Time: 19:18:55
   Part No SW: 85E 959 655 AM    HW: 85E 959 655 AM
   Component: AirbagVW60    H40 0640
   Serial number: 00000000301CVRD Dataset Number: 8MA909602N  0003
   Coding: AEFC008000FCC0000000008000000000A1540000000000005C003FF4001B41C5
   ASAM Dataset: EV_AirbaVW60SMEAU41X 001008
   ROD: EV_AirbaVW60SMEAU41X_AU40.rod
   VCID: 0740F3342FDE8142A6A-8152-R SFD+SFD2 [x]
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 85E 980 945 G    HW: 85E 980 945 G
   Component: BeltPretRevFL  005 0062
   Serial number: 00AC2025073079100000
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 85E 980 946 G    HW: 85E 980 946 G
   Component: BeltPretRevFR  005 0062
   Serial number: 00AC2025074109400000
   Subsystem 3 - Part No SW: 85E 959 340 A    HW: 85E 959 340 A
   Component: BF-Gewichtss.  H02 0001
   Serial number: 6310000D25000F3V3X0T
   Subsystem 4 - Part No SW: -----------    HW: 480 001 F03 19
   Serial number: 35700000868D24919B55
   Subsystem 5 - Part No SW: -----------    HW: 480 001 F03 19
   Serial number: 358000008685031C315P
   Subsystem 6 - Part No SW: -----------    HW: 480 050 802 19
   Component: SideSensor_Dr  000 0149
   Serial number: 35100009ADF75EC4477U
   Subsystem 7 - Part No SW: -----------    HW: 480 050 802 19
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000B8E19DACD0B6W
   Subsystem 8 - Part No SW: -----------    HW: 480 050 602 19
   Component: FrontSensor_D  000 014A
   Serial number: 3550000B2D9016D5453%
   Subsystem 9 - Part No SW: -----------    HW: 480 050 602 19
   Component: FrontSensor_P  000 014A
   Serial number: 3560000B0D9016CCCAFT
   Central crash sensor X/Y:
   Subsystem 10 - Part No SW: -----------    HW: 480 051 20B 18
   Component: CentrSensorXY  000 0109
   Serial number: I0O0000B6D901009A75R
1089029 - Databus
          [NWD: 0x31C PCS_Li_01 error value PCS_Li_Status]
                    Reset counter: 12
                    Mileage: 7937 km
                    Date: 2026.07.28
                    Time: 14:03:04
9777408 - Forward-Looking Safety System Function Restriction
          B1531 00 [01101000] - Implausible Message(s)
                    Mileage: 9234 km
                    Date: 2026.09.15
                    Time: 11:25:17
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 85E 907 129 L    HW: 85E 907 129 L
   Component: Lenks.Modul   H07 0066
   ASAM Dataset: EV_SMLWSKLOAU41X 001010
   ROD: EV_SMLWSKLOAU41X_AU40.rod
   VCID: 3A265AC02CAC2CAAE94-816E-R SFD [x]
Address 17: Instruments (SWC12)       Labels:* None
   Part No: V04 007 009 DB
   Component: Cluster       4188
   Dataset Number: 85H909525D  0015
   Coding: 21001B001100002008180000
   ASAM Dataset: EV_DashBoardAU41X 001001
   ROD: EV_DashBoardAU41X_001_AU40.rod
   VCID: 70B2B8E83A50A6FA170-8124-R SFD+SFD2 [x]
11 Faults Found:
1742374 - Databus
          U1467 00 [00101100] - Service Not Available
          [TriggerNotification_client_VZE_timeout]
                    Mileage: 4212 km
                    Date: 2026.02.15
                    Time: 01:13:31
16773120 - Databus
          U1467 00 [00100100] - Service Not Available
          [Service_ActiveLaneDepartureWarningHMI not available]
                    Mileage: 4212 km
                    Date: 2026.02.15
                    Time: 01:13:31
16773123 - Databus
          U1467 00 [00101111] - Service Not Available
          [Service_ChargingManagementCore not available]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:55
16773126 - Databus
          [Service_LimiterHMI not available]
                    Mileage: 4212 km
                    Date: 2026.02.15
                    Time: 01:13:31
16773133 - Databus
          [Service_extChargingManagementExtended not available]
                    Mileage: 668 km
                    Date: 2025.11.19
                    Time: 21:21:02
16773134 - Databus
          [Service_Driving_ProfileSelection not available]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:17:21
16773138 - Databus
          [Service_RecuperationSettings not available]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:17:21
16773139 - Databus
          [Service_SportHMI not available]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:17:22
16773140 - Databus
          [Service_Tires not available]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:17:22
16773144 - Databus
          [Service_AirSuspensionHeightControl not available]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:17:21
16776970 - Databus
          U1121 00 [00101110] - Missing Message
          [ClampControl_01 communication error ethernet_error_timeout]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:03:15
Address 19: CAN Gateway (J1273)       Labels:* None
   Part No SW: 85F 907 468 F    HW: 85F 907 468
   Component: Gateway       H24 0044
   Dataset Number: 85H909515AJ 0117
   Coding: 03000501000018000000007D7BC344191D1907290F800000000001CE031100A30A0ACA050000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   GVL: 0700080000008000040820800002080000000000204892880400000000000000
   ASAM Dataset: EV_HCP5GatewAU416 014040
   ROD: EV_HCP5GatewAU416_014_AU40.rod
   VCID: 3B285FC4239615A2F22-816E SFD+SFD2 [x]
   Central 4 sub-server application:
   Subsystem 1 - Part No: V04 007 007 TT
   Component: Gateway        0044
   Subsystem 2 - Part No SW: 8MA 915 181 B    HW: 8MA 915 181 B
   Component: J367-BDMHella  H11 2362
   Serial number: 5203315606
43 Faults Found:
66099 - Charging Communication Control Module
          U01E4 00 [00101111] - No Communication
          [HVLMSF_hvls_ladedose_sg1_timeout]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:29
66103 - No Communication with Battery Energy Control Module
          U0111 00 [00101111] - -
          [HVLMSF_bmc_hv_01_timeout]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:29
66121 - Function Restriction due to
          C1249 F5 [00101111] - Safety Functions of Charging Management
          [FUSI_safetyfunction_01_active]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:29
67630 - Drive and Chassis Main Control Module
          [VDSO_05_message_timeout]
71685 - Communication Authentication
          U3035 00 [00101000] - Invalid Signal
          [SOK_signature_verification_failed_2]
                    Reset counter: 11
                    Mileage: 4244 km
                    Date: 2026.02.16
                    Time: 12:37:12
73984 - Trustworthy Time Synchronization
          U18D8 00 [01101000] - Recalculation of the Lap Counter Failed
          [TLT_Master_lap_counter_redefinition_error]
                    Reset counter: 2
                    Mileage: 7100 km
                    Date: 2026.06.27
                    Time: 21:02:25
74240 - Time Synchronization
          U182D 00 [00101000] - Function Restriction
          [CLT_max_deviation_Mastertime]
                    Fault Frequency: 9
                    Reset counter: 39
                    Mileage: 265 km
                    Date: 2025.11.06
                    Time: 01:10:12
1551 - Internal Temperature Sensor 3; Implausible Signal
          U358C 00 [00100000] - -
          [Temperatur_Sensor_C_out of range low]
1569 - Internal Temperature Sensor 5
          U36CF 00 [00100000] - Implausible Signal
          [Temperatur_Sensor_E_out of range low]
4435 - Main Module for Driver Assistance
          U015C 00 [00100000] - No Communications
          [Timeout_Node_0xB3_DiagAddress_0x8103_HCP2_SMH_SAFE_CAN]
4474 - Control Module for Emergency Call and Communications
          U1421 00 [00101000] - No Communication
          [Timeout_Node_0x67_DiagAddress_0x75_ConMod_CD]
                    Fault Frequency: 32
                    Reset counter: 38
                    Mileage: 188 km
                    Date: 2025.11.02
                    Time: 16:14:33
4540 - Driver Assistance Main Module
          U1712 00 [00100000] - No Communication on Ethernet
          [Timeout_Node_0xB3_DiagAddress_0x8103_HCP2_SMH_SAFE_HCP5_HCP2_1_ETH_VLAN_fas]
4563 - Emergency Call and Communication Module
          U170B 00 [00101000] - No Communication on Ethernet
          [Timeout_Node_0x67_DiagAddress_0x75_ConMod_CD_VLAN_connect]
                    Fault Frequency: 30
                    Reset counter: 38
                    Mileage: 188 km
                    Date: 2025.11.02
                    Time: 16:14:34
4609 - Diagnostic Filter
          U17A0 00 [00100000] - Not Activated
          [Filter_is_not_active]
4983 - Camera Control Module
          U18A9 00 [00101110] - Ethernet Bus Faulty
          [Ethernet_databus_no_communication_switch_xView]
                    Mileage: 6188 km
                    Date: 2026.05.13
                    Time: 17:00:33
4990 - Information Electronics Module 1
          U18B0 00 [00100000] - Ethernet Bus Faulty
          [Ethernet_databus_no_communication_switch_HCP3]
4993 - Driver Assistance Main Control Module Ethernet Data Bus
          U3659 00 [00100000] - Faulty
          [Ethernet_databus_no_communication_switch_HCP2]
5648 - Databus
          U1467 00 [01101101] - Service Not Available
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:33:38
5650 - Databus
          U159C 00 [01101101] - Service Malfuction Value Received
          [SOME_IP_infrastructure_fault]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:32:05
70400 - Emergency Assistant
          C12D7 F0 [00101110] - Status Feedback for HMI Implausible
          [Emergency Assist no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:44:35
70401 - Front Cross Traffic Assist
          C13FC F0 [01101101] - Status Feedback for HMI Implausible
          [Front Cross Assist no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70402 - Lane Assist
          C13E2 F0 [00101110] - Status Feedback for HMI Implausible
          [Active Lane Departure Warning no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:44:35
70403 - Attention Assist and Driver Alert
          C13E3 F0 [01101100] - Status Feedback for HMI Implausible
          [Tiredness Warning no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:04:22
70404 - Lane Change Warning
          C13FB F0 [00101110] - Status Feedback for HMI Implausible
          [Side Assist no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:44:35
70405 - Egress Warning
          C12DD F0 [00101100] - Status Feedback for HMI Implausible
          [Exit Warner no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:36:36
70407 - Pre-Sense
          C12DF F0 [01101101] - Status Feedback for HMI Implausible
          [Pre Sense no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70408 - Following-Distance Warning (Low)
          C12DB F0 [00101110] - Status Feedback for HMI Implausible
          [Distance Warner Low no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:44:35
70411 - Predictive Efficiency Assistant
          C13A0 F0 [00101110] - Status Feedback for HMI Implausible
          [Predictive Efficiency Assist no expected reply: number of attempts exceeded]
                    Fault Frequency: 196
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:04:22
70412 - Rear Turning Assist
          C13BA F0 [00101111] - Status Feedback for HMI Implausible
          [Turn Assist Rear no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70413 - Cross Traffic Assistant
          C13A5 F0 [00101110] - Status Feedback for HMI Implausible
          [Rear Cross Traffic Assist no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:44:35
70415 - Traffic Sign Detection
          C13E4 F0 [01101101] - Status Feedback for HMI Implausible
          [Trafficsign Visualisation no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70416 - Intersection Assistant
          C12D8 F0 [00101111] - Status Feedback for HMI Implausible
          [Adaptive Cruise Assist no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70419 - Swerve Support
          C13E5 F0 [01101101] - Status Feedback for HMI Implausible
          [Collision Avoidance Assist no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70420 - Online Traffic Light Info
          C13E6 F0 [00101110] - Status Feedback for HMI Implausible
          [Trafficlight Information no expected reply: number of attempts exceeded]
                    Fault Frequency: 83
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
70424 - BCM
          U15BA 00 [01101100] - Received Malfunction Value
          [FAS-Button reported error]
                    Mileage: 5712 km
                    Date: 2026.04.15
                    Time: 15:56:46
70427 - Front Turn-off Assist
          C13EA F0 [00101110] - Status Feedback for HMI Implausible
          [Turn Assis no expected reply: number of attempts exceeded]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:14
70428 - Driver Assistance Systems; Personalization
          U202B 00 [01101101] - Function Restriction
          [FAS-Profile_Master_funktionaltity_restricted]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
71201 - Databus
          [error_value_Parkhilfe_04_01.OPS_PB_PaCo_MainState]
                    Fault Frequency: 71
                    Mileage: 74 km
                    Date: 2025.10.30
                    Time: 21:24:58
71202 - Databus
          [error_value_PB_PaCo_01.PB_PaCo_MainState]
                    Fault Frequency: 103
                    Mileage: 74 km
                    Date: 2025.10.30
                    Time: 21:25:03
71223 - Databus
          [Message_TimeOut_eCall_01]
                    Fault Frequency: 29
                    Mileage: 209 km
                    Date: 2025.11.03
                    Time: 14:28:05
71225 - Databus
          [error_communication_TriggerNotificationService_to_PaCo]
                    Fault Frequency: 69
                    Mileage: 74 km
                    Date: 2025.10.30
                    Time: 21:08:26
71229 - Databus
          [error_value_RCTA_02]
                    Reset counter: 25
                    Mileage: 4175 km
                    Date: 2026.02.12
                    Time: 00:38:10
71681 - Communication Authentication
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:44:19
Address 22: AWD (J492)       Labels:* None
   Part No SW: 8MA 927 755 G    HW: 0CJ 927 749 C
   Component: Q5_5X_N5_K_S2 H80 0007
   Serial number: RB0580212502047 Dataset Number: 8MA909104C  0001
   Coding: 02
   ASAM Dataset: EV_AWDCQUOD32 004024
   ROD: EV_AWDCQUOD32_004.rod
   VCID: 50F218689A1086FA370-8104-R SFD+SFD2 [x]
Address 29: Left Light (MX1)       Labels: None
   Part No SW: 95C 941 572 AE    HW: 95C 941 572 AE
   Component: LSG_L         H16 0612
   Serial number: MEC1ST0212240E6 Dataset Number: 8MA909519E  0001
   ASAM Dataset: EV_LSGLeftMELCOPO426 001039
   ROD: EV_LSGLeftMELCOPO426_AU40.rod
   VCID: 73B8B7E44B469DE2EA2-8126-R SFD+SFD2 [x]
131329 - Databus
          U1201 00 [00101000] - No Communications
          [can data bus - no communication]
                    Reset counter: 17
                    Mileage: 8975 km
                    Date: 2026.08.31
                    Time: 19:15:56
Address 2C: Rear pres. detection (J1315)       Labels: None
   Part No SW: 8B9 980 341 B    HW: 8B9 980 341
   Component: AnwErkenHin   006 0010
   Dataset Number: 8MA909341H  0001
   ASAM Dataset: EV_ChildPreseDetecAU40X 002003
   ROD: EV_ChildPreseDetecAU40X_AU40.rod
   VCID: 2E0E6690E0E4F00A45C-817A-R SFD+SFD2 [x]
   Part No SW: 85E 959 760 AE    HW: 85E 959 760 AA
   Component: SSG_F_nGen    011 0109
   Serial number: CNKSCU100325010 Dataset Number: 8MA909856A  0017
   Coding: 005C1A400000E40000030101010100000000000000000000000000000040001A000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU413 002012
   ROD: EV_SCMDriveSideCONTIAU413_002_AU40.rod
1507442 - Databus
          [KeylessAccess_01_missing_message]
1507650 - Databus
          [CentralLocking_01_missing_message]
1509901 - Databus
          [ORU_01_missing_message]
Address 39: Right Light (MX2)       Labels: None
   Component: LSG_R         H16 0612
   Serial number: MEC1ST0212240E6 Dataset Number: 8MA909520E  0001
   ASAM Dataset: EV_LSGRightMELCOPO426 001039
131329 - Databus
                    Reset counter: 17
                    Mileage: 8975 km
                    Date: 2026.08.31
                    Time: 19:15:56
   Part No SW: 85E 959 593 A    HW: 85E 959 593
   Component: TSG FS        001 0222
   Serial number: Y2007YCT00P87   Dataset Number: 8MA909872G  0031
   Coding: 0035CB005E008080A227A030
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_AU40.rod
   VCID: 3B285FC4239615A2F22-816E-R SFD+SFD2 [x]
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 85E 959 441 B    HW: 85E 959 441 B
   Component: EX55           H04 0142
   Serial number: 2025 05 26 14S 01709
          B1487 54 [01100000] - Missing Calibration / Basic Setting
   Part No SW: 8MA 909 144 L    HW: 8MA 909 144 B
   Component: EPSFSBAS_E3   H06 1182
   Serial number: 00457113        Dataset Number: 8MA909852AG 0001
   Coding: 02060400000001
   Shop #: WSC 12336 024 394758
   ASAM Dataset: EV_EPSFSBASE3 002026
   ROD: EV_EPSFSBASE3_AU40.rod
   VCID: 4DCC011C8D22AB125C6-8118-R SFD+SFD2 [x]
2056 - Secure Onboard Communication
          U14FD 00 [00101000] - Time Server not Available
                    Reset counter: 25
8709 - Databus
          [CFFP_01_FEHLER]
   Part No SW: 85E 907 064 EH    HW: 85E 907 064 CH
   Component: SAR           046 0213
   Dataset Number: 8MA909501J  0031
   Coding: 01000000001001010D0010031100460000000000000000000000000000003E00000000000A0D0000
   ASAM Dataset: EV_SensoActorRear 008009
   ROD: EV_SensoActorRear_008_AU40.rod
   VCID: 79A485CC692AE7B2A0E-812C-R SFD+SFD2 [x]
65573 - Release Button in Rear Lid Handle
          B1BAB F0 [00101000] - Play Protection Active
          [Release button in tailgate spoiler handl: play protection active]
                    Reset counter: 27
                    Mileage: 8893 km
                    Date: 2026.08.18
                    Time: 14:24:32
65554 - Communication Authentication
          U3036 00 [00100000] - Signal Malfunction
65555 - Communication Authentication
          U3035 00 [01101000] - Invalid Signal
                    Reset counter: 17
                    Mileage: 7659 km
                    Date: 2026.07.20
                    Time: 01:24:21
   Part No SW: 85E 959 592 A    HW: 85E 959 592
   Component: TSG BFS       001 0222
   Serial number: Y2007YC200O1F   Dataset Number: 8MA909873G  0030
   Coding: 0035C3005E009080A207A030
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_AU40.rod
   VCID: 3A265AC02CAC2CAAE94-816E-R SFD+SFD2 [x]
   Part No SW: 8MA 035 044 M    HW: 8MA 035 044 H
   Component: J794          045 4361
   Dataset Number: 8B3909545E  0018
   Coding: 416300000042000000000000
   ASAM Dataset: EV_HCP3BaseNodeAU41X 001001
   ROD: EV_HCP3BaseNodeAU41X_AU40.rod
   VCID: 43D827245B166D62BA2-8016-R SFD+SFD2 [x]
   Volume Control 1:
   Subsystem 1 - Part No SW: 85E 919 616     HW: 85E 919 616
   Component: E67_LSR        H33 0132
   Digital Sound System Control Module 2:
   Subsystem 2 - Part No SW: 8Y0 035 465 A    HW: 8Y0 035 465 A
   Component: B_A_3_P_0_AU  H11 0100
1249298 - Automotive Audio Bus (A2B) Slave 1
          B1A07 F2 [00100000] - Incorrect Polarity / Defective
          [a2b_bus_slave_1_reverse_wires_or_defective_node]
8208 - Communication Authentication
                    Reset counter: 33
8209 - Communication Authentication
8210 - Communication Authentication
          U3034 00 [00100000] - Key/Certificate Missing/Invalid
          [SOK_signature_creation_failed]
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 95C 907 273 P    HW: 95C 907 273 B
   Component: RDKHUFPO426   H04 1300
   Serial number: 000000000047247 Dataset Number: FYA909850A  0001
   ASAM Dataset: EV_RDKHUFPO426 001001
   ROD: EV_RDKHUFPO426_AU40.rod
   VCID: 3D2C51DC3D821B92CC6-8168-R SFD+SFD2 [x]
8390147 - Tire Pressure Monitoring
          C10DC 54 [01100000] - Missing Calibration / Basic Setting
          [Calibration_request]
Address 69: Trailer (J345)       Labels:* None
   Part No SW: 85A 907 383 D    HW: 85A 907 383
   Component: Anhaenger     H12 0115
   Serial number: 000000000006578 Dataset Number: 8Y0909527D  0023
   Coding: 0200000200001500
   ASAM Dataset: EV_TrailFunctG3MLB3Hella 001022
   ROD: EV_TrailFunctG3MLB3Hella_AU40.rod
   VCID: 303278E8FAD0E6FA570-8164-R SFD+SFD2 [x]
336897 - Drive and Chassis Main Control Module
          U1765 00 [00100000] - Implausible Signal
          [Mainunit drive and chassis - implausible signal]
   Part No SW: 85E 907 428 P    HW: 85E 907 428
   Component: TV eEntry     H06 0211
   Serial number: TVE02.03.252203 Dataset Number: 8MA909460L  0001
   Coding: 0103FC06F914000044C0
   ASAM Dataset: EV_CamSysTVContiPPEC 005024
   ROD: EV_CamSysTVContiPPEC_AU40.rod
   Front peripheral camera slave:
   Subsystem 1 - Part No SW: 85E 980 551 B    HW: 85E 980 551
   Component: R243 UmfKamSV  H05 0090
   Serial number: A050153320
   Peripheral camera slave: left:
   Subsystem 2 - Part No SW: 85E 980 551 B    HW: 85E 980 551
   Component: R244 UmfKamSL  H05 0090
   Serial number: A050786242
   Right peripheral camera slave:
   Subsystem 3 - Part No SW: 85E 980 551 B    HW: 85E 980 551
   Component: R245 UmfKamSR  H05 0090
   Serial number: A051128745
   Rear peripheral camera slave:
   Subsystem 4 - Part No SW: 85E 980 551 B    HW: 85E 980 551
   Component: R246 UmfKamSH  H05 0090
   Serial number: A046354633
282656 - Cable for Video Signal to Display
          C135B 01 [00101100] - Electrical Failure
          [Video link to display unit - connection error]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:46:48
13709320 - Databus
          [Ausfall Diagnose_01]
                    Fault Frequency: 38
                    Mileage: 8303 km
                    Date: 2026.08.13
                    Time: 13:28:48
   Part No SW: 85B 035 282 E    HW: 85B 035 282 A
   Component: CM_CAN        H22 0546
   Serial number: V03849S05690022 Dataset Number: 8B3909612VJ 0001
   Coding: 01E080FAE000C0F00E07
   ASAM Dataset: EV_ConModAU41X 001013
   ROD: EV_ConModAU41X_AU40.rod
   VCID: 28029088C200AE3A8F0-817C-R SFD+SFD2 [x]
Address 7E: Ctrl Head Dash (KX2)       Labels:* None
   Part No SW: 8B1 919 605 L    HW: 8B1 919 605 L
   Component: Main_Disp PPx H34 0320
   Serial number: AUZ6Z9D28.03.25
   Coding: 040000A0A0A0050505A0C30505
   ASAM Dataset: EV_MainDisplAU51X 001007
   ROD: EV_MainDisplAU51X_001_AU40.rod
   VCID: 353C49FC05B2C3D2046-8160-R SFD+SFD2 [x]
7 Faults Found:
9582602 - Video Cable
          B125C F2 [00100000] - Multimedia Display Unit; Electrical Fault
          [LVDS electrical defect (CID)]
9582603 - Video Cable
          B125C F3 [00100000] - Drivers Display Unit; Electrical Fault
          [LVDS electrical defect (FID)]
9582604 - Video Transmission
          B1BE8 F2 [00100000] - Protocol Error Multimedia Display Unit
          [LVDS protocol failure (CID)]
9582605 - Video Transmission
          B1BE8 F1 [00100000] - Protocol Error Driver Display Unit
          [LVDS protocol failure (FID)]
13636864 - LVDS Interface
          B1991 31 [00100000] - No Signal
          [FID_Video_State failure value send (2)]
16711685 - Communication Authentication
          U3036 00 [00101000] - Signal Malfunction
                    Fault Frequency: 58
                    Reset counter: 22
                    Mileage: 8879 km
16711686 - Communication Authentication
   Part No SW: 85E 713 041 B    HW: 85E 713 041 B
   Component: GSM           H05 0325
   Serial number: YC075XKQ10994--
   ASAM Dataset: EV_GearShiftModulAU416 001007
   ROD: EV_GearShiftModulAU416_AU40.rod
   VCID: 241A84B8BE284A5AA38-8170-R SFD [x]
   Gearshift cover:
   Subsystem 1 - Part No SW: 8B3 713 203 J    HW: 85H 713 203 N
Address 82: Head Up Display (J898)       Labels: None
   Part No SW: 8MB 919 617 D    HW: 8MB 919 617
   Component: HUD           H07 2340
   ASAM Dataset: EV_HeadUpDisplAU40X 001017
   ROD: EV_HeadUpDisplAU40X_001.rod
   VCID: 4CCA0C187638A21A4B8-8118-R SFD [x]
9582603 - Video Transmission
          B1BE8 F0 [00101000] - Protocol Error
          [LVDS protocol failure]
                    Reset counter: 24
                    Mileage: 8983 km
                    Date: 2026.09.02
                    Time: 19:27:01
16777040 - Databus
          [ORU_01 communication error can_error_timeout]
Address 8B: Adaptive Cruise 2 (J428)       Labels:* None
   Part No SW: 8B3 907 567 N    HW: 8B3 907 567 B
   Component: WBA Bosch PPE H03 0325
   Dataset Number: 8MA909885T  0001
   Coding: 20902000000000406022000000000000000090300000000000000000000000
   ASAM Dataset: EV_LongRangeRadar5AU416 001022
   ROD: EV_LongRangeRadar5AU416_001_AU40.rod
63 Faults Found:
                    Fault Frequency: 66
                    Reset counter: 37
                    Mileage: 4291 km
0764 - Databus
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [00101100] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Mileage: 6309 km
                    Date: 2026.05.16
                    Time: 23:18:11
1842 - Databus
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:27
1845 - Databus
1846 - Databus
                    Reset counter: 37
                    Mileage: 9087 km
                    Date: 2026.09.10
                    Time: 19:40:14
1847 - Databus
                    Reset counter: 37
                    Mileage: 9087 km
                    Date: 2026.09.10
                    Time: 19:40:14
1850 - Databus
1851 - Databus
1852 - Databus
1853 - Databus
1854 - Databus
1856 - Databus
                    Fault Frequency: 9
                    Mileage: 6840 km
                    Date: 2026.06.12
                    Time: 19:18:52
1857 - Databus
                    Fault Frequency: 8
                    Mileage: 6840 km
                    Date: 2026.06.12
                    Time: 19:18:52
1860 - Databus
1866 - Databus
1876 - Databus
1877 - Databus
1878 - Databus
1880 - Databus
1883 - Databus
1884 - Databus
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:27
1885 - Databus
                    Mileage: 7036 km
                    Date: 2026.06.23
                    Time: 11:34:44
1886 - Databus
1891 - Databus
1892 - Databus
1920 - Databus
1923 - Databus
1927 - Databus
1931 - Databus
1935 - Databus
2009 - Databus
2010 - Databus
2011 - Databus
2012 - Databus
2013 - Databus
2261 - Databus
2262 - Databus
2263 - Databus
2264 - Databus
2265 - Databus
3207 - Internal Fault
          B200F F0 [00101000] - -
          [FAULT_RB_XCS_RUNTIME_FAILURE]
                    Fault Frequency: 53
                    Reset counter: 37
                    Mileage: 318 km
16776844 - Databus
16776943 - Databus
16776944 - Databus
16776945 - Databus
16776948 - Databus
16776951 - Databus
16776953 - Databus
16776956 - Databus
16776958 - Databus
16777125 - Databus
          [FAULT_VMM_WBAWARNBRK_STACV_ERROR]
16777127 - Databus
16777129 - Databus
16777131 - Databus
16777133 - Databus
16777135 - Databus
          [FAULT_VMM_WBA_STVLD_ERROR]
16777207 - Databus
                    Mileage: 7204 km
                    Date: 2026.07.04
                    Time: 19:24:07
   Part No SW: 85E 907 217 N    HW: 85E 907 217 A
   Component: MFK5          H18 0295
   Dataset Number: 8MA909466AJ 0002
   Coding: 0408200000000000000090DB44348080000000000000000000000000000008185FFC60000000000000000000A61400000000000049000000000000001820000000000000
   ASAM Dataset: EV_MFK5 002022
   ROD: EV_MFK5_002_AU40.rod
49 Faults Found:
221202 - Front Camera for Driver Assist Systems
          C12B3 F0 [00100000] - Dynamic Calibration Limit Exceeded
          [Frontcamera_dynamic_calibration_out_of_range]
1048604 - Databus
          [TIMEOUT_ClampControl_01_E2E]
                    Reset counter: 15
                    Mileage: 8879 km
                    Date: 2026.08.15
                    Time: 18:38:30
1048597 - Ethernet Databus
          U11C4 00 [01100100] - No Communications
          [Ethernet_databus_no_communication_to_MFK5]
1048658 - Internal Fault
          [EyeQ_Core_Dump_Mini_Core_Dump]
1048957 - Databus
          [TIMEOUT_NR_RS_Header]
1049095 - Databus
          [TIMEOUT_ACA_01]
1048909 - Databus
          [TIMEOUT_POS_GNSS_01_Ortung]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1048910 - Databus
          [TIMEOUT_POS_GNSS_02_Geschw]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1048911 - Databus
          [TIMEOUT_POS_GNSS_03_Status]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1048912 - Databus
          [TIMEOUT_POS_GNSS_04_Guete]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1048913 - Databus
          [TIMEOUT_POS_GNSS_05_Position]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1048914 - Databus
          [TIMEOUT_POS_GNSS_07_Sat_konf]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1048915 - Databus
          [TIMEOUT_POS_GNSS_08_Zeit]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:15
1049656 - Databus
          [TIMEOUT_ACA_02]
1049152 - Databus
          [TIMEOUT_eCall_01]
                    Reset counter: 17
                    Mileage: 8936 km
                    Date: 2026.08.29
                    Time: 00:07:15
1049170 - Databus
          [TIMEOUT_AMPH_01]
1049189 - Databus
          U1467 00 [00100000] - Service Not Available
          [SOMEIP_Service_Positioning_not_available]
1049191 - Databus
          [SOMEIP_Service_UnitMaster_not_available]
1049197 - Databus
          U1467 00 [00101000] - Service Not Available
          [SOMEIP_Service_Predictive_StreetDataSlim_not_available]
                    Fault Frequency: 22
                    Reset counter: 34
                    Mileage: 9071 km
                    Date: 2026.09.08
                    Time: 19:13:01
1049199 - Databus
          [SOMEIP_Service_GNSS_not_available]
                    Fault Frequency: 247
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:17
1049200 - Databus
          [SOMEIP_Service_TriggerNotification_not_available]
221209 - Driver Assistance Systems Front Camera
          C13B0 F0 [00100000] - Change in Load Detected
          [Calibration_deviation_detected_at_startup]
221210 - Internal Fault
          B200F FE [00100000] - -
          [Calibration_internal_fault]
1049428 - Internal Fault
          B200F F2 [00101110] - -
          [SWC_HCA_Init_Values_Received]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:19
1049405 - Data Fusion for Driver Assistance Systems Service
          U198B 00 [00100000] - Received Malfunction Value
          [Service_AdasFusedObjectsSmall_Fusion_Error]
                    Reset counter: 25
                    Mileage: 8971 km
                    Date: 2026.08.29
                    Time: 15:47:37
1049406 - Data Fusion for Driver Assistance Systems Service
          [Service_AdasFusedObjectsSmall_Front_Radar_Blind]
1049429 - Data Fusion for Driver Assistance Systems Service
          [Service_AdasFusedObjectsSmall_Front_Radar_Error]
1049430 - Data Fusion for Driver Assistance Systems Service
          U198B 00 [00101110] - Received Malfunction Value
          [Service_AdasFusedObjectsSmall_Front_Radar_Right_Error]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:17
1049431 - Data Fusion for Driver Assistance Systems Service
          [Service_AdasFusedObjectsSmall_Front_Radar_Left_Error]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:22
1049432 - Data Fusion for Driver Assistance Systems Service
          [Service_AdasFusedObjectsSmall_Rear_Radar_Right_Error]
1049204 - Databus
          [TIMEOUT_CarMenues_IVI_01]
1049422 - Databus
          [TIMEOUT_ORU_01]
1049417 - Databus
          [TIMEOUT_RoadGraph_RA_01]
1049217 - Short-Range Radar Control Module 4
          U198A 00 [00100000] - Received Malfunction Value
          [SWA_Status_System_ERROR]
1049207 - Control Module for Driver Assistance Systems
          U1593 00 [00100000] - Received Malfunction Value
          [ACA_Status_Quer_ERROR]
                    Reset counter: 38
                    Mileage: 9168 km
                    Date: 2026.09.14
                    Time: 17:17:49
1049229 - BCM
          U15BA 00 [00100000] - Received Malfunction Value
          [US_PB_Side_HLS_State_ERROR]
1049230 - BCM
          [US_PB_Side_HRS_State_ERROR]
1049469 - Transport Layer Security Participant
          U160B 00 [00101111] - Un-Allowed Extensions
          [sec_tls_forbidden_extensions_requested]
                    Fault Frequency: 39
                    Mileage: 8936 km
                    Date: 2026.08.29
                    Time: 00:10:43
1049470 - Data Fusion for Driver Assistance Systems Service
          [Service_AdasFusedObjectsSmall_Rear_Radar_Left_Error]
1049655 - Databus
          [SOMEIP_Service_TimezoneData_not_available]
                    Reset counter: 17
                    Mileage: 8925 km
                    Date: 2026.08.28
                    Time: 14:50:36
1048963 - Databus
          [TIMEOUT_NR_RS_Structure]
1048958 - Databus
          [Timeout_NR_RS_Object_01_02]
1048959 - Databus
          [Timeout_NR_RS_Object_03_04]
1048960 - Databus
          [Timeout_NR_RS_Object_05_06]
1048961 - Databus
          [Timeout_NR_RS_Object_07_08]
1048962 - Databus
          [Timeout_NR_RS_Object_09_10]
1049685 - Front Camera for Driver Assist Systems
          C12B3 FD [00100000] - View Temporarily Restricted
          [temp_blindness_detected_lda_impairment]
                    Mileage: 9234 km
                    Date: 2026.09.15
                    Time: 11:25:29
1049703 - Road Graph
          U198C 00 [00100000] - Received Malfunction Value
          [RoadGraph_TrafficSigns_Invalid]
1049704 - Road Graph
          [RoadGraph_SpeedLimits_Invalid]
                    Mileage: 9236 km
                    Date: 2026.09.15
                    Time: 11:27:51
Address BB: Door Rear Drv (J388)       Labels:* Redir Fail!
   Part No SW: 85E 959 595 A    HW: 85E 959 595
   Component: TSG HFS       001 0222
   Serial number: Y2007YD600E3D   Dataset Number: 8MA909897F  0033
   Coding: 0025C30000008080E200A020
   ASAM Dataset: EV_DCU4RearDriveMAXHKLO 001016
   ROD: EV_DCU4RearDriveMAXHBRO_AU40.rod
   Part No SW: 85E 959 594 A    HW: 85E 959 594
   Component: TSG HBFS      001 0222
   Serial number: Y2007YC900AGG   Dataset Number: 8MA909896F  0033
   Coding: 0025C30000008080E000A020
   ASAM Dataset: EV_DCU4RearPasseMAXHKLO 001016
   ROD: EV_DCU4RearPasseMAXHBRO_AU40.rod
   VCID: 3C2A5CD82698129AFB8-8168-R SFD+SFD2 [x]
Address C5: Therm. mgt. (J519)       Labels: None
   Part No SW: 85E 907 059 Q    HW: 85E 907 059 J
   Component: TME E3 1.2    H12 2434
   Dataset Number: 8MA909476AE 0066
   ASAM Dataset: EV_HCP4Contr2OBDAU41X 010024
   ROD: EV_HCP4Contr2OBDAU41X_010_AU40.rod
   VCID: 41D42D2C417A7F72A8E-8114-R SFD+SFD2 [x]
   Radiator fan 1:
   Subsystem 1 - Part No SW: 4K0 959 455 D    HW: 4K0 959 455 D
   Component: J293 KLE 1     H01 0011
   Serial number: G5573310300001974882
   Radiator fan 2:
   Subsystem 2 - Part No SW: 4K0 959 455 E    HW: 4K0 959 455 E
   Component: J671 KLE 2     H01 0011
   Serial number: G5573410300001981982
          U3036 00 [01101100] - Signal Malfunction
          [Communication Authentication Signal Performance]
                    Fault Frequency: 240
                    Mileage: 64 km
          U138F 00 [01100000] - -
          [Ip_clock_sync_outage]
Address CA: Sunroof
Address DE: Charger 1 for mobile dev (J1146)       Labels:* None
   Part No SW: 85E 035 507     HW: 85E 035 507
   Component: WLC1          H11 0039
   Serial number: E2B001190225E8C Dataset Number: 85H909485A  0008
   Coding: 8080
   ASAM Dataset: EV_Charg1MobilDevicAU41X 003013
   ROD: EV_Charg1MobilDevicAU41X_003_AU40.rod
   VCID: 669EDEB00894784A7DC-8132-R SFD+SFD2 [x]
0009 - Cooling Fan for Housing
          B126B 07 [01100000] - Mechanical Failure
          [Fan_mechanical_fault]
Address 8103: Driver assist main (J1274)       Labels:* None
   Part No SW: 85E 907 156 N    HW: 85E 907 156
   Component: HCP2.Low      H02 0471
   Serial number: A2C781607140000 Dataset Number: 8MA909402AB 0047
   Coding: 2100000000001101100000000000FC6C2640EF64FEFD030000000000000000000000000000000000000000000000000000000901024F3E6F1E0300000000000000000A000001000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_HCP2MainContiAU416 007015
   ROD: EV_HCP2MainContiAU416_007_AU40.rod
   Driver assistance system: subsystem:
   Subsystem 1 - Part No: V04 007 006 SF
   Component: HCP2_1_SMH_PE  0471
69 Faults Found:
2097187 - Internal Fault
          B200F F1 [00101000] - -
          [Signal_Out-Of-Range]
                    Fault Frequency: 38
                    Reset counter: 20
                    Mileage: 8304 km
                    Date: 2026.08.13
                    Time: 13:31:04
2097200 - Databus
2097190 - Short-Range Radar Control Module 4
          U17D8 00 [00100000] - BlockID not Plausible
          [NR_RS_BlockID_04]
2097234 - Databus
          [SOME/IP_Service_WakeupCLusterConfiguration_not_available_for_VNSM]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:33
2097224 - Databus
          [SOME/IP_Service_LoggingSmall_Instance_0x0001_not_available_for_TLR_Adapter_HCP2_Performance]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2097221 - Databus
          [SOME/IP_Service_TriggerNotification_not_available_for_ACA4.0]
2097208 - Databus
          U1467 00 [10101111] - Service Not Available
          [SOME/IP_Service_MonocularSceneReconstruc_not_available_for_ACA4.0]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2097207 - Databus
          [SOME/IP_Service_PredictiveStreetDataStd_not_available_for_RoadgraphHD]
                    Fault Frequency: 35
                    Reset counter: 35
                    Mileage: 9071 km
                    Date: 2026.09.08
                    Time: 19:13:05
2097206 - Databus
          [SOME/IP_Service_Positioning_not_available_for_RoadgraphHD]
2098296 - Adaptive Cruise Control 2
          U148A 00 [01101100] - Implausible Signal
          [aca_LrrSensorStatus_BlindForAssist_blindness]
                    Mileage: 3122 km
                    Date: 2026.01.15
                    Time: 18:00:50
2098255 - Databus
          [TIMEOUT_ORU_01__SH]
2098290 - Driver Assistance System Front Camera
          U16DE 00 [01100100] - Received Malfunction Value
          [aca_ObjectDetection_TimestampStatus_error]
2098291 - Driver Assistance System Front Camera
          U16DE 00 [01100101] - Received Malfunction Value
          [aca_PedestrianDetection_TimestampStatus_error]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:28
2098297 - Adaptive Cruise Control 2
          U148A 00 [01100100] - Implausible Signal
          [aca_LrrSensorStatus_functionStatus_not_available]
2097646 - Short-Range Radar Control Module
          U17D6 00 [00100000] - BlockID not Plausible
          [NR_FL_BlockID_01_ACA]
2097647 - Short-Range Radar Control Module 2
          U17D7 00 [00100000] - BlockID not Plausible
          [NR_FR_BlockID_02_ACA]
2097419 - Databus
          [TIMEOUT_KundenSpezFunk_01]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2097295 - Reset of Control Module
          B16CE 00 [00100000] - -
          [Unexpected_reset]
2098302 - Short-Range Radar Control Module
          U1921 00 [01100100] - Implausible Signal
          [aca_NR_FL_NotAvailable_not_available]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098303 - Short-Range Radar Control Module
          [aca_NR_FL_Measurement_Time_LapNumber_error]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098304 - Short-Range Radar Control Module 2
          U1922 00 [01100100] - Implausible Signal
          [aca_NR_FR_NotAvailable_not_available]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098305 - Short-Range Radar Control Module 2
          [aca_NR_FR_Measurement_Time_LapNumber_error]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098306 - Short-Range Radar Control Module 3
          U1923 00 [01100100] - Implausible Signal
          [aca_NR_RL_NotAvailable_not_available]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098308 - Short-Range Radar Control Module 4
          U1924 00 [01100100] - Implausible Signal
          [aca_NR_RS_NotAvailable_not_available]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098309 - Short-Range Radar Control Module 4
          [aca_NR_RS_Measurement_Time_LapNumber_error]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098311 - Front Sensors for Driver-Assist Systems
          U12EF 00 [01100100] - Implausible Signal
          [aca_ObjectDetection_functionStatus_not_available]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:30
2098312 - Front Sensors for Driver-Assist Systems
          [aca_ObjectDetection_timestampStatus_not_available]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:28
2098314 - Front Sensors for Driver-Assist Systems
          U12EF 00 [01100101] - Implausible Signal
          [aca_PedestrianDetection_functionStatus_not_available]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:30
2098315 - Front Sensors for Driver-Assist Systems
          [aca_PedestrianDetection_timestampStatus_not_available]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:28
2097289 - Communication Authentication
          [PH_SOK_signature_verification_failed]
                    Reset counter: 37
                    Mileage: 9123 km
                    Date: 2026.09.12
                    Time: 02:09:14
2097461 - Clock Syncronization Failure
          [Failure_of_time_synchronization_pdelay_PLT]
2097298 - Internal Fault
          B200F F4 [00100000] - -
          [BIST_failed_temporary]
2098287 - Driver Assistance System Front Camera
          [aca_ECR_FC1_FunctionStatus_error]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:28
2097948 - Reset of Control Module
          B16CE 00 [00101000] - -
          [Task_monitoring_error]
                    Reset counter: 27
                    Mileage: 8910 km
2097819 - Internal Fault
          B200F F2 [01101100] - -
          [aca_RoadGraph_error]
                    Mileage: 9168 km
                    Date: 2026.09.14
                    Time: 17:17:49
2097828 - Driver Assistance System Front Camera
          [aca_PedestrianDetection_error]
2097976 - Combined Longitudinal and Lateral Guide Assistance
          U202D 00 [00101111] - Function Restriction
          [aca_FunctionConstraint]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:24
2098271 - BCM
          U15BA 00 [01100100] - Received Malfunction Value
          [aca_US_PB_Front_Dist_FrSp_error]
2098023 - BCM
          [aca_US_PB_Front_State_error]
2098072 - Drive and Chassis Main Control Module
          U195E 00 [01100100] - Received Malfunction Value
          [aca_VMM_ACALgtCtl_StAcv_error]
2098193 - Drive and Chassis Main Control Module
          [aca_VMM_LgtGuide_St_Acce_Avl_error]
2098216 - Driver Assistance System Front Camera
          [aca_BHE_FC1_Status_error]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:28
2098217 - Driver Assistance System Front Camera
          U16DE 00 [01101100] - Received Malfunction Value
          [aca_CAL_FC1_Status_error]
                    Mileage: 3777 km
                    Date: 2026.01.30
                    Time: 12:35:43
2098224 - Short-Range Radar Control Module
          U1994 00 [01101100] - Received Malfunction Value
          [aca_NR_FL_Failure_error]
                    Mileage: 7937 km
                    Date: 2026.07.28
                    Time: 14:03:04
2098228 - Short-Range Radar Control Module 3
          U1996 00 [01100100] - Received Malfunction Value
          [aca_NR_RL_Failure_error]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2098230 - Short-Range Radar Control Module 4
          U198A 00 [01101100] - Received Malfunction Value
          [aca_NR_RS_Failure_error]
                    Mileage: 6450 km
                    Date: 2026.05.27
                    Time: 19:09:38
2098233 - Instrument Cluster
          U12DD 00 [01101100] - Received Malfunction Message
          [aca_FID_Display_Ready_error]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:18:33
2098246 - Front Sensors for Driver-Assist Systems
          U12EF 00 [01101101] - Implausible Signal
          [aca_CAL_FC1_Status_not_available]
                    Mileage: 3772 km
                    Date: 2026.01.30
                    Time: 01:36:31
2098250 - Front Sensors for Driver-Assist Systems
          [aca_BHE_FC1_Status_not_available]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:30
2098251 - Front Sensors for Driver-Assist Systems
          [aca_BHE_FC1_ImpairmentODACC_not_available]
                    Fault Frequency: 115
                    Mileage: 9234 km
                    Date: 2026.09.15
                    Time: 11:25:29
2098340 - Internal Fault
          B200F F2 [01101101] - -
          [aca_AMP_error]
                    Mileage: 1238 km
                    Date: 2025.11.23
                    Time: 19:02:27
2098342 - Internal Fault
          [aca_HCP2_error]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:54:17
2098393 - Databus
          [SOMEIPTestability_MCClient_notavailableforSOMEIPTestabilitySWC_SMH_Performance]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2098394 - Databus
          [SOMEIPTestability_Segm_MCClient_notavailableforSOMEIPTestabilitySWC_SMH_Performance]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2098395 - Databus
          [SOMEIPTestability_Segm_Client_notavailableforSOMEIPTestabilitySWC_SMH_Performance]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2098396 - Databus
          [SOMEIPTestability_Client_Reliable_notavailableforSOMEIPTestabilitySWC_SMH_Performance]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2098355 - Adaptive Cruise Control 2
          [aca_LrrMeasurements_functionStatus_not_available]
2098361 - Short-Range Radar Control Module 4
          [aca_NR_RS_MeasurementTimeStatus_not_available]
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
2097755 - Internal Fault
          B200F F1 [00101110] - -
          [Amp_ACA_status]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:46:42
2099022 - Databus
          [SOME/IP_Service_GNSSHdShift_not_available_for_RoadgraphHD]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:30
2098813 - Databus
          [TIMEOUT_NR_RS_Header_ACA]
2097648 - Short-Range Radar Control Module 4
          [NR_RS_BlockID_04_ACA]
2099011 - Supply Voltage Input 1
          U16C1 00 [00100000] - Voltage too Low
          [Platform_voltage_line_1_too_low]
2098951 - Front Sensors for Driver-Assist Systems
          [aca_PedestrianDetection_Timestamp_error]
                    Mileage: 6291 km
                    Date: 2026.05.16
                    Time: 18:28:28
2098984 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [01101100] - -
          [aca_Triggernotification_not_available]
                    Mileage: 5764 km
                    Date: 2026.04.18
                    Time: 16:18:31
2099009 - Control Module
          B1788 06 [01100100] - Algorithm Failure
          [aca_FAULT_RB_HV_YAW_RATE_OFFSET_NOT_CONFIRMED]
2098793 - Application Server 3 for System 1 Infotainment
          U194E 00 [00101000] - Implausible Signal
          [RGHD_PSD_unplausibel]
                    Fault Frequency: 109
                    Reset counter: 35
                    Mileage: 9087 km
                    Date: 2026.09.10
                    Time: 19:52:07
2098794 - Front Sensors for Driver-Assist Systems
          U12EF 00 [00100000] - Implausible Signal
          [RGHD_TSR_unplausibel]
2098796 - Front Sensors for Driver-Assist Systems
          [RGHD_Cam_LDA_unplausibel]
Address 8109: Close Rge Radar 1 (J1098)       Labels: None
   Part No SW: 95C 907 541 BA    HW: 95C 907 541
   Component: Nanoradar 1   H09 0579
   Serial number: 10140102079194  Dataset Number: 8MA909410AQ 0002
   ASAM Dataset: EV_NR1HELLAPO426 001081
   ROD: EV_NR1HELLAPO426_AU40.rod
   VCID: 6E8EA6902064B00A05C-813A-R SFD+SFD2 [x]
9 Faults Found:
1282 - Radar Sensors
          C12BF F2 [00101000] - Software Error Detected
          [Control unit -ASIL Application Sw Error]
                    Fault Frequency: 84
                    Reset counter: 37
                    Mileage: 9138 km
                    Date: 2026.09.13
                    Time: 17:05:31
1302 - No Basic Setting
          B2010 00 [00101000] - -
          [Control unit -Radar Synchronization Error]
                    Fault Frequency: 52
                    Reset counter: 34
1305 - Short-Range Radar Control Module
          B1D5B 1F [00101000] - No or Intermittent Signal
          [Control unit -Radar Recoverable Failure]
                    Reset counter: 6
                    Mileage: 8294 km
                    Date: 2026.08.13
                    Time: 13:11:09
14680243 - Databus
          [ORU_Control_A_01_XIX_HCP1_CANFD04 BZ Fehler]
                    Reset counter: 9
                    Mileage: 8511 km
                    Date: 2026.08.13
                    Time: 18:08:00
14680245 - Databus
          [ORU_Control_D_01_XIX_HCP1_CANFD04 BZ Fehler]
                    Reset counter: 34
                    Mileage: 9092 km
                    Date: 2026.09.10
                    Time: 20:16:32
14680247 - Databus
          [OTAMC_D_01_XIX_HCP1_CANFD04 BZ Fehler]
                    Fault Frequency: 15
                    Reset counter: 2
                    Mileage: 8244 km
                    Date: 2026.08.09
                    Time: 15:58:30
16056326 - Side Collision Assist
          C1429 F0 [00100000] - Internal Malfunction
          [Function PCS internal malfunction]
                    Reset counter: 0
                    Mileage: 7937 km
                    Date: 2026.07.28
                    Time: 14:03:04
16056338 - Databus
          U1121 00 [00101100] - Missing Message
          [OTAMC_D_01_XIX_HCP1_CANFD04 keine Kommunikation]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:41
16056417 - Short-Range Radar Front Left
          B1EDB F0 [00101110] - Error Status Detected
          [Control unit -NR_FL_Failure_State]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:40
Address 810A: Close Rge Radar 2 (J1089)       Labels: None
   Component: Nanoradar 2   H09 0579
   Serial number: 10140102086561  Dataset Number: 8MA909411AQ 0002
   ASAM Dataset: EV_NR2HELLAPO426 001081
   ROD: EV_NR2HELLAPO426_AU40.rod
8 Faults Found:
                    Fault Frequency: 83
                    Reset counter: 37
                    Mileage: 9138 km
                    Date: 2026.09.13
                    Time: 17:05:31
                    Fault Frequency: 53
                    Reset counter: 34
14680243 - Databus
                    Reset counter: 9
                    Mileage: 8511 km
                    Date: 2026.08.13
                    Time: 18:08:00
14680245 - Databus
                    Reset counter: 34
                    Mileage: 9092 km
                    Date: 2026.09.10
                    Time: 20:16:32
14680247 - Databus
                    Fault Frequency: 15
                    Reset counter: 2
                    Mileage: 8244 km
                    Date: 2026.08.09
                    Time: 15:58:30
                    Reset counter: 0
                    Mileage: 4274 km
                    Date: 2026.02.20
                    Time: 16:40:46
16056338 - Databus
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:41
16056418 - Short-Range Radar Front Right
          B1EDA F0 [00101110] - Error Status Detected
          [Control unit -NR_FR_Failure_State]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:40
Address 810B: Close Rge Radar 3 (J770)       Labels: None
   Part No SW: 95C 907 550 BA    HW: 95C 907 550
   Component: Nanoradar 3   H09 0579
   Serial number: 10140099853551  Dataset Number: 8MA909412AQ 0002
   ASAM Dataset: EV_NR3HELLAPO426 001081
   ROD: EV_NR3HELLAPO426_AU40.rod
15 Faults Found:
          C12BF F2 [00100000] - Software Error Detected
                    Fault Frequency: 34
                    Reset counter: 0
                    Mileage: 5973 km
                    Date: 2026.05.02
                    Time: 14:07:02
                    Fault Frequency: 63
                    Reset counter: 34
          B1D5B 1F [00100000] - No or Intermittent Signal
                    Reset counter: 0
                    Mileage: 1555 km
                    Date: 2025.12.07
                    Time: 02:23:58
14680217 - Databus
          [VDSO_08_XIX_HCP1_CANFD05 keine Kommunikation]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:41
14680228 - Databus
          [ORU_Control_A_01_XIX_HCP1_CANFD05 BZ Fehler]
                    Reset counter: 9
                    Mileage: 8511 km
                    Date: 2026.08.13
                    Time: 18:08:00
14680230 - Databus
          [ORU_Control_D_01_XIX_HCP1_CANFD05 BZ Fehler]
                    Reset counter: 34
                    Mileage: 9092 km
                    Date: 2026.09.10
                    Time: 20:16:32
14680232 - Databus
          [OTAMC_D_01_XIX_HCP1_CANFD05 BZ Fehler]
                    Fault Frequency: 17
                    Reset counter: 2
                    Mileage: 8244 km
                    Date: 2026.08.09
                    Time: 15:58:30
15859773 - Databus
          U1123 00 [00100000] - Received Error Message
          [NR_RS_Failure Fehlerwert]
                    Reset counter: 0
                    Mileage: 6450 km
                    Date: 2026.05.27
                    Time: 19:09:38
15990785 - Databus
          [VDSO_08_XIX_HCP1_CANFD05 BZ Fehler]
                    Reset counter: 0
                    Mileage: 6721 km
                    Date: 2026.06.08
                    Time: 19:45:41
16056327 - Rear Collision Assist
          C142A F0 [00100000] - Internal Malfunction
          [Function PCH internal malfunction]
                    Reset counter: 0
                    Mileage: 6078 km
                    Date: 2026.05.08
                    Time: 19:05:07
16056341 - Databus
          [OTAMC_D_01_XIX_HCP1_CANFD05 keine Kommunikation]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:41
16056419 - Short-Range Radar Rear Left
          B1EDD F0 [00101110] - Error Status Detected
          [Control unit -NR_RL_Failure_State]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:40
16056481 - Ethernet Databus
          U1B5C 00 [00100000] - Verification Error
          [Ethernet_E2E_VerificationError]
                    Reset counter: 0
                    Mileage: 6846 km
                    Date: 2026.06.13
                    Time: 19:50:51
16056483 - Ethernet Databus
          U11C4 00 [00100000] - No Communications
          [Ethernet_LostCommError]
                    Reset counter: 0
                    Mileage: 5264 km
                    Date: 2026.03.10
                    Time: 19:09:15
1231364 - Short-Range Radar Module
          U17EE 00 [00100000] - No Communication on Ethernet
          [Ethernet-Datenbus keine Kommunikation]
                    Reset counter: 0
                    Mileage: 5264 km
                    Date: 2026.03.10
                    Time: 19:09:15
Address 810C: Close Rge Radar 4 (J769)       Labels: None
   Component: Nanoradar 4   H09 0579
   Serial number: 10140099854616  Dataset Number: 8MA909413AQ 0002
   ASAM Dataset: EV_NR4HELLAPO426 001081
   ROD: EV_NR4HELLAPO426_AU40.rod
22 Faults Found:
                    Fault Frequency: 61
                    Reset counter: 34
                    Reset counter: 0
                    Mileage: 7486 km
                    Date: 2026.07.19
                    Time: 14:57:57
14680208 - Databus
          U1121 00 [00101000] - Missing Message
          [NR_RL_Header_XIX_HCP1_CANFD05 keine Kommunikation]
                    Fault Frequency: 72
                    Reset counter: 34
                    Mileage: 9092 km
                    Date: 2026.09.10
                    Time: 20:16:32
14680217 - Databus
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:41
15859766 - Databus
          [VMM_08_VMM_RCTA_StVld_HCP1_CANFD05 error value]
                    Fault Frequency: 0
15859767 - Databus
          [VMM_08_VMM_RCTALgtLimA_StAcv_HCP1_CANFD05 error value]
                    Reset counter: 2
                    Mileage: 8244 km
                    Date: 2026.08.06
                    Time: 20:32:22
15859768 - Databus
          [VMM_08_VMM_RCTAWarnBrk_StAcv_HCP1_CANFD05 error value]
                    Fault Frequency: 0
14680228 - Databus
                    Reset counter: 9
                    Mileage: 8511 km
                    Date: 2026.08.13
                    Time: 18:08:00
14680230 - Databus
                    Reset counter: 34
                    Mileage: 9092 km
                    Date: 2026.09.10
                    Time: 20:16:32
14680232 - Databus
                    Fault Frequency: 17
                    Reset counter: 2
                    Mileage: 8244 km
                    Date: 2026.08.09
                    Time: 15:58:30
15859775 - Databus
          U1123 00 [00101100] - Received Error Message
          [NR_RL_Failure Fehlerwert]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:40
15859779 - Databus
          [NR_FL_Failure Fehlerwert]
                    Reset counter: 0
                    Mileage: 7937 km
                    Date: 2026.07.28
                    Time: 14:03:04
15859783 - Databus
          [NR_FR_Failure Fehlerwert]
15990785 - Databus
                    Reset counter: 0
                    Mileage: 6721 km
                    Date: 2026.06.08
                    Time: 19:45:41
15990788 - Databus
          [NR_RL_Header_XIX_HCP1_CANFD05 BZ Fehler]
                    Reset counter: 0
                    Mileage: 7963 km
                    Date: 2026.07.29
                    Time: 10:32:14
16056341 - Databus
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:41
16056420 - Short-Range Radar Rear Right
          B1EDC F0 [00101110] - Error Status Detected
          [Control unit -NR_RS_Failure_State]
                    Mileage: 9242 km
                    Date: 2026.09.16
                    Time: 15:49:40
1332 - Short-Range Radar Control Module
          U1A0E 00 [00100000] - Terminal 30 Input too Low
          [Control Unit Klemmen 30 Abriss]
                    Reset counter: 0
                    Mileage: 6723 km
                    Date: 2026.06.09
                    Time: 11:32:52
                    Reset counter: 0
                    Mileage: 6723 km
                    Date: 2026.06.09
                    Time: 11:32:52
                    Reset counter: 0
                    Mileage: 6723 km
                    Date: 2026.06.09
                    Time: 11:32:52
Address 8119: Multifunc. St. Wheel 3 (J453)       Labels:* None
   Part No SW: 8B3 951 523     HW: 8B3 951 523
   Component: J453 MFL      H23 0110
   Serial number: 08S230110012506 Dataset Number: 8B3909406A  0004
   Coding: 1F0000
   ASAM Dataset: EV_MFLGen3AU416 002011
   ROD: EV_MFLGen3AU416_002_AU40.rod
   Subsystem 1 - Part No SW: 8B3 419 508     HW: 8B3 419 508
   Component: J1158 KLR      H02 0006
   Serial number: 00000000000000050951
Address 811E: Burglary Protection FL (J1191)       Labels: 85H-962-133.clb
   Part No SW: 85H 962 133 AA    HW: 85H 962 133 A
   Component: Einbrsch1VL   H32 0262
   ASAM Dataset: EV_UWBRSADVLAU41X 003002
   ROD: EV_UWBRSADHLAU41X_AU40.rod
   VCID: 6FB0BB94276EB9020EA-813A-R SFD [x]
Address 811F: Burglary Protection FR (J1192)       Labels: 85H-962-133.clb
   Part No SW: 85H 962 133 AB    HW: 85H 962 133 B
   Component: Einbrsch2VRB  H32 0262
   ASAM Dataset: EV_UWBRSADVRAU41X 003002
   VCID: 70B2B8E83A50A6FA170-8124-R SFD [x]
Address 8120: Burglary Protection RL (J1193)       Labels: 85H-962-133.clb
   Component: Einbrsch3HLB  H32 0262
   ASAM Dataset: EV_UWBRSADHLAU41X 003002
Address 8121: Burglary Protection RR (J1194)       Labels: 85H-962-133.clb
   Component: Einbrsch4HR   H32 0262
   ASAM Dataset: EV_UWBRSADHRAU41X 003002
Address 8122: Burglary Protection Interior (J1195)       Labels: 85H-962-133.clb
   Component: Einbrsch5I1   H32 0262
   ASAM Dataset: EV_UWBRSADINAU41X 003002
Address 8124: App server 1 system 2 Java (J1273)       Labels:* None
   Part No: V04 007 008 A
   Component: ------------- 0044
   Dataset Number: 85H909441Q  0063
   Coding: 0000000002110000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_HCP5MODAU416 009034
   ROD: EV_HCP5MODAU416_009_AU40.rod
   VCID: 2A066A80DC0C9C2A994-817E-R SFD+SFD2 [x]
   Central 3 sub-server application:
   Subsystem 1 - Part No: V04 007 008
   Component: -------------  0043
   Central 2 sub-server application:
   Subsystem 2 - Part No: V04 007 005 DK
   Component: -------------  1758
12 Faults Found:
5248513 - Mobile Online Services; Token Authentication
          U2043 00 [00101000] - Function Restriction
          [OAuth_token_function_restricted]
                    Fault Frequency: 93
                    Mileage: 73 km
                    Date: 2025.10.30
                    Time: 14:02:13
5248514 - Mobile Online Services; MQTT Connection
          U2044 00 [00101000] - Function Restriction
          [MQTT_Connection_function_restricted]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:18
6308352 - Group Data Collector
          U205E 00 [00101100] - Function Restriction
          [Group_data_collector_function_restricted]
                    Fault Frequency: 27
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:22
5247552 - Databus
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:33:58
5247749 - Emergency Call and Communication Unit
          U19EA 00 [00101110] - BAP Communication Error
          [BAP_Timeout_ConnectionManager]
                    Mileage: 74 km
                    Date: 2025.10.30
                    Time: 17:58:43
5248512 - Mobile Online Services; Basic Communication
          U2042 00 [00101100] - Function Restriction
          [Backend_Basic_Communication_function_restricted]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 14:43:20
5247554 - Databus
          U159C 00 [01101000] - Service Malfuction Value Received
                    Reset counter: 36
                    Mileage: 209 km
                    Date: 2025.11.03
                    Time: 15:12:37
6299905 - Databus
          [TM_SP_data_bus_service_not_available]
                    Fault Frequency: 63
                    Mileage: 1048335 km
                    Date: 2026.09.01
                    Time: 19:27:05
6299907 - Databus
          U158F 00 [00101110] - Service Implausible
          [TM_SP_data_bus_service_implausible]
                    Fault Frequency: 48
                    Mileage: 1048335 km
                    Date: 2026.09.01
                    Time: 11:30:18
6299909 - Authentic Time
          B1CEB F0 [00101100] - Certificate Validation Fault
          [TM_SP_Ati_ceritificate_unplausible]
                    Mileage: 271360 km
                    Date: 2026.09.15
                    Time: 19:06:15
6299911 - Time Master
          U2019 00 [00101110] - Function Restriction
          [TM_SP_function_restriction]
                    Fault Frequency: 74
                    Mileage: 1048335 km
                    Date: 2026.09.01
                    Time: 11:30:18
6301184 - Wake-Up Monitor
          U2065 00 [00101100] - Function Restriction
          [clamp_15_function_restricted]
                    Mileage: 1048335 km
                    Date: 2025.10.29
                    Time: 13:43:47
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 009 DA
   Component: J794_SWC6     4188
   Dataset Number: 8B3909595E  0018
   ASAM Dataset: EV_ContrElect1AU41X 001001
   ROD: EV_ContrElect1AU41X_AU40.rod
   VCID: 6FB0BB94276EB9020EA-813A-R SFD+SFD2 [x]
16391 - Display Module 2 for Multimedia System
          B1298 FD [00101100] - Secure Communication Not Fulfilled
          [Secure_touch_communication_initialization_did]
                    Mileage: 631 km
                    Date: 2025.11.18
                    Time: 12:39:19
16392 - Display Module 2 for Multimedia System
          B1298 FD [00100100] - Secure Communication Not Fulfilled
          [Secure_touch_communication_switch_encrypted_did]
                    Mileage: 5712 km
                    Date: 2026.04.11
                    Time: 16:45:18
2031620 - Head-Up Display Control Module
          U183A 00 [00101100] - Checksum Faulty
          [Hud_data_not_valid]
                    Mileage: 1107 km
                    Date: 2025.11.22
                    Time: 18:45:55
Address 8128: Light line display (L383)       Labels: None
   Part No SW: 8MB 919 451 C    HW: 8MB 919 451 A
   Component: ICL 1         031 0017
   Dataset Number: 85H909640C  0007
   ASAM Dataset: EV_SmartLight1AU51X 002013
   ROD: EV_SmartLight1AU51X_002_AU40.rod
   VCID: 47C033346F5E414266A-8112-R SFD+SFD2 [x]
1536 - Databus
          [Functional_restriction_due_to_preconditions]
1288 - Databus
          U1121 00 [00101111] - Missing Message
          [Message_bmc_hv_02_missing]
                    Mileage: 64 km
                    Date: 2025.10.29
                    Time: 13:18:52
Address 812C: Drive/Chassis Main Ctrl        Labels:
   VCID: 55FCE97CAC02E3D2E46-FFFE
Address 812D: Snd enhanct 3 (J1177)       Labels: None
   Part No SW: 85E 035 466 H    HW: 95C 035 751
   Component: PASD_High _AU H07 0175
   Serial number: AUZ8ZAS6T015UTd Dataset Number: 8MS909619B  0013
   ASAM Dataset: EV_PASDALPINPO426 001056
   ROD: EV_PASDALPINPO426_001_AU40.rod
   VCID: 323672E0F4DCD4EA214-8166-R SFD+SFD2 [x]
1231648 - Databus
          [SomeIP Datenbus Dienst nicht verf�gbar]
                    Reset counter: 15
                    Mileage: 8248 km
                    Date: 2026.08.11
                    Time: 16:12:20
1049347 - Information Electronics Control Module 1
          B1C03 F2 [00101000] - Missing RTP Message
          [ECU HeadUnit missing Audio RTP message]
                    Fault Frequency: 85
                    Mileage: 183 km
                    Date: 2025.11.01
                    Time: 15:28:00
Address 8131: Air suspension (J1075)       Labels: None
   Part No SW: 95C 907 778 M    HW: 95C 907 778 F
   Component: Luftfeder ASC H03 0852
   Serial number: 571020003761211
   ASAM Dataset: EV_ASCWABCOPO426 001066
   ROD: EV_ASCWABCOPO426.rod
   VCID: 44DA24385E686A5A838-8110-R SFD+SFD2 [x]
Address 8132: Electrical system main 1 (J519)       Labels:* None
   Part No: V04 007 008 BM
   Component: Komfo E3 1.2  3434
   Dataset Number: 8B3909594AD 0086
   Coding: 000000811F000000000001000000000000000000500064050980008000000082100000000000000000000000000000000000630100000000000000008000DF03000000000000000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_HCP4Contr2NoOBDAU41X 010024
   ROD: EV_HCP4Contr2NoOBDAU41X_010_AU40.rod
   VCID: 78A280C85220FEBADF0-812C-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 89A 919 158 A    HW: 89A 919 158 A
   Component: E265 KPH BH    H23 0270
   Serial number: G07S19.12.2400972339
   Subsystem 2 - Part No SW: 8MB 820 021     HW: 8MB 820 021
   Component: J126 FLuftV    H03 0020
   Serial number: 39722504100410014505
   Humidity sensor: exterior:
   Subsystem 3 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu      H06 0012
   Serial number: C91E111900PAG0MUFU04
   Interior temperature sensor:
   Subsystem 4 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001041224045109504
   Subsystem 5 - Part No SW: 4N0 963 575 H    HW: 4N0 963 575 H
   Component: V512 LLR1SLvL  H01 0013
   Serial number: X48AS09000358
   Subsystem 6 - Part No SW: 4N0 963 575 H    HW: 4N0 963 575 H
   Component: V514 LLR1SKvL  H01 0013
   Serial number: X48AS09100313
   Subsystem 7 - Part No SW: 4N0 963 575 H    HW: 4N0 963 575 H
   Component: V516 LLR1SLvR  H01 0013
   Serial number: X48AS09000361
   Subsystem 8 - Part No SW: 4N0 963 575 H    HW: 4N0 963 575 H
   Component: V518 LLR1SKvR  H01 0013
   Serial number: X48AS09700106
   Valve block 1 in front seat driver side:
   Subsystem 9 - Part No SW: 8Y0 907 182     HW: 8Y0 907 182
   Component: J873 MKS_FSv   H11 0012
   Serial number: 714002020A0244200121
   Valve block 1 in front seat passenger side:
   Subsystem 10 - Part No SW: 8Y0 907 182     HW: 8Y0 907 182
   Component: J872 MKS_BFSv  H11 0012
   Serial number: 714002020A0244203558
2163456 - Communication Authentication
          U3036 00 [00101110] - Signal Malfunction
          [SOK_timeserver_not_available]
                    Mileage: 9154 km
Address 8133: Low volt. power distrib. 1 (J1282)       Labels:* None
   Part No SW: 85E 907 808 M    HW: 85E 907 808 H
   Component: ELVIS         H12 0220
   Dataset Number: 85H909405K  0024
   Coding: 8000C0
   ASAM Dataset: EV_ELVISAU41X 003021
   ROD: EV_ELVISAU41X_AU40.rod
   VCID: 3FD02BD4378E0982DEA-816A-R SFD+SFD2 [x]
0325 - Databus
          U1121 00 [00100000] - Missing Message
          [Dtc_nwd_timeout_ORU_01_loss_of_message]
Address 8136: Close rnge comm antenna;drv side (J1169)       Labels:* None
   Part No SW: 85E 927 753 A    HW: 85E 927 753 A
   Component: NFCTGS        H06 0130
   Serial number:            6510
   Coding: E01315051914000448000328148F051900030A060A141100000000000000000000000000000000000000000000000A1E141E
   ASAM Dataset: EV_NFCDriveSideAU41X 001003
   ROD: EV_NFCDriveSideAU41X_AU40.rod
   VCID: 343A74F80EC8DADA338-8160-R SFD+SFD2 [x]
65538 - Supply voltage
          U1011 00 [00100000] - Voltage too Low
          [Voltage supply: voltage too low]
                    Fault Frequency: 0
                    Reset counter: 0
                    Mileage: 8497 km
                    Date: 2026.08.13
                    Time: 15:25:12
65540 - Function Restricted due to Insufficient Voltage
          U1400 00 [00100000] - -
          [Function restriction due to insufficient voltage]
                    Fault Frequency: 0
                    Reset counter: 0
                    Mileage: 8497 km
                    Date: 2026.08.13
                    Time: 15:25:12
65553 - Body Control Module (Central Electric)
          U0140 00 [00100000] - No Communications
          [Data_bus_message_no_signal_communication]
                    Fault Frequency: 0
                    Reset counter: 0
Address 813F: Main; cockpit system 1 sound (SWC11)       Labels:* None
   Part No: V04 007 009 DC
   Component: J794_SWC11    4188
   Dataset Number: 8B3909443E  0018
   ASAM Dataset: EV_SoundCubeAU41X 001001
   ROD: EV_SoundCubeAU41X_AU40.rod
   VCID: 71B4BDEC315AAFF218E-8124-R SFD+SFD2 [x]
Address 8147: Passenger displ for multimedia (J1060)       Labels: None
   Part No SW: 8MB 919 604 C    HW: 8MB 919 604
   Component: PID 10.9      H31 0225
   ASAM Dataset: EV_PasseInforDisplAU51X 001008
   ROD: EV_PasseInforDisplAU51X_001_AU40.rod
Address 8153: Main; cockpit sys. 3 Android (SWC13)       Labels:* None
   Part No: V04 007 009 CR
   Component: J794_SWC13    4500
   Dataset Number: 8B3909444E  0020
   ASAM Dataset: EV_InVehicInfotAU41X 001001
   ROD: EV_InVehicInfotAU41X_AU40.rod
   VCID: 7F506BD4770EC9829EA-812A-R SFD+SFD2 [x]
   Subsystem 1 - Part No: V04 007 005 JB
   Component: HCP3_NAR26.07  0036
   Media socket:
   Subsystem 2 - Part No SW: 85E 035 700     HW: 85E 035 700
003 0004
          B11CF 53 [00101111] - Deactivated
                    Mileage: 4062 km
                    Date: 2026.02.03
                    Time: 12:32:46
1637 - Interface for External Media
          U11B8 00 [00100100] - No Communications
          [USB - communication error]
                    Date: 2063.12.31
Address 8157: Burglar prot. 6; veh. interior 2 (J1309)       Labels: 85H-962-133.clb
   Component: Einbrsch6I2B  H32 0262
   ASAM Dataset: EV_UWBRSADIN2AU41X 003002
End----(Elapsed Time: 08:54, VBatt start/end: 12.0V/12.0V. VIgn 11.8V)-----
-----------------------------495 Faults Found------------------------------
You can reset the Oil and Inspection based reminders using VCDS but this vehicle uses SFD. More on that can be found here:
If you choose to subscribe to our SFD annual subscription please be aware that the B10 based (PPC platform) models changed things up. After getting past the SFD hurdle they work like this:
  • Oil Change is done in address 01.
  • The time and distance based Inspection resets are done in address 17.
B10/PPC based SRI manual steps
It may be best to use the screen shots on this page along with the steps if you aren't already familiar with unlocking SFD using VCDS: https://www.ross-tech.com/vcds/tour/sfd-online.php
1) SFD will need to be unlocked in address 19-CAN Gateway before any service actions. Make sure the Turn filter off tick box is enabled at that time.
2) If the Oil change service needs to be reset connect to Address 01-Engine and unlock SFD in that control unit. Then, click onto the Adaptation function and save the the new value "Reset" to channel:
IDE00342-ESI: Resetting ESI
Note: After doing so these channels should change to new values of zero:
IDE12964-Oil: driven distance since last oil service​
IDE12965-Oil: time since last oil service​
3) If the time and distance Inspection specific service needs reset as well connect to address 17-Instruments and unlock SFD, Then, click onto the Adaptation function and save the the new values of zero to both of these channels:
IDE12980-Inspection: distance driven since the last inspection
IDE12981-Inspection: time since the last inspection
Note: You may need to cycle the ignition before the MIB and Instrument cluster refresh the service statistics.
4) Provided the car doesn't need any additional work you can re-lock all if the control modules using the [SFD-Relock All Controllers] button found on the Applications screen. After doing so it will be possible to clear all of the Release / Enable Active DTCs after the final Auto-Scan.
Rallyedude
Aylmer QC, Canada
C?ID=6146
Fantastic 👍. I had not been following the SFD developments. I ran into the issue last year on a newer Tiguan where I couldn't do rear brakes. Glad to see it is resolved .I'll look into it more and sign up $.
