2016 Audi A4 quattro vag com help
Mayorj
C?ID=271567
Hello everyone I'm trying to figure out a few more things to enhance my vehicle hopefully someone can help. I have the mmi setup with nav 3G with sim card. 1: I would like to see the tire pressure in each tire instead of the tpms just telling me when the pressure is low. 2: I would like to see the battery gauge. 3:memory seats with remote (no button). 4: speed on center display. (drivivg School) Any info would be appreciated.
for the tpms I tried random changes in the green screen not sure if its possible.
for the battery meter i tried to enable it in green screen and set to 5. no change also i tried 56-radio > adaption channel 39 and was going to add 16 to my value but it says error channel 39 not available.
for memory seats with remote i tried to enable it in the green screen and it displays on the settings but its grayed out and says not available. I need to be able to access that screen to enable the remote option
for the speed on center display (driving school) my vag com code list says does not work if nav equiped. 56-radio > adaptation > channel 2, set to 1
here is a copy of my auto scan:
VCDS Version: Release 15.7.4 (x64) Running on Windows 8 x64
Data version: 20160216
Wednesday,24,February,2016,19:50:40:18400
Chassis Type: FL (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6C 72
VIN: WAUBFAFL6GN013439   Mileage: 570km-354miles
Address 01: Engine (DET-CPMB)       Labels: None
   Part No SW: 8K5 907 115 Q    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0001
   Revision: ECH09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0118K5907115Q 001003
   ROD: EV_ECM20TFS0118K5907115Q.rod
   VCID: 408F2FDEDBC4233E3E-8014
Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
   Part No SW: 8K0 927 158 AD    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H19 1005
   Revision: --H19---
   ROD: EV_TCMAL551211_AU48.rod
   VCID: 78FF873EC394ABFE46-802C
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 2D1D1801
   VCID: 0919F2FAA07EA27629-805C
   Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
   Component: BCM2 2.0      H15 0711
   Coding: 0D814040000000000000
   VCID: 0501FECA8C66C6164D-8050
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01230920151492
   Coding: 6480208000
   VCID: 77FD8402C68AA4864F-8022
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001164250701
   Coding: 26000091863CAFE01600480300003D0D0F9C5308A2090221000008004000030100000030000000
   VCID: 78FF873ECB94ABFE46-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B
   Component: MITSUBA270815  H19 0461
   Coding: 004577
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Component: USHL4.2  H30 0030
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H53 0812
   Serial number: 003NDD207F9%
   Coding: 303844354730383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   ROD: EV_AirbaECUVWAUDI010_AU48.rod
   VCID: 4B9508F2E282F066DB-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R150000NN3L
   Serial number: 6334MSME525A2C42F
   Serial number: 6344MSME54386C11E
   Serial number: 6352QSME3C500F66O
   Serial number: 6362QSME68511C5CS
   Serial number: 63732SME30502852O
   Serial number: 63832SME30501264L
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862OIH00090
   Coding: 000016
   VCID: 489F37FEFBF41B7EF6-801C
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 61U528W8G
   Coding: 83BF09000301D705020000
   VCID: 387F473E8B146BFE86-806C
   Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0070
   Revision: 1Y090032    Serial number: 3241Y159110218
   Coding: 80C303FF00
   VCID: 50AF1F9E03A4D3BEAE-8004
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Coding: 011C13204000410001
   VCID: 56A3E9862140BD8E74-8002
02111 - Motor for Window Regulator
                    Fault Status: 00100101
                    Reset counter: 67
                    Mileage: 318 km
                    Date: 2016.02.21
                    Time: 11:41:41
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0017236903
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X.rod
   VCID: 3E735126A13055CE4C-806A
   Revision: 00002001    Serial number: 0380913770
   Coding: 0106063A00FA40058030013200000000
   Component: GTO BF  H01 0080
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS051  H08 0043
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   VCID: 55A1EE8A3C46B6967D-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001718916
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7B5D36BD1879EE70-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156I-0F2500575
   Coding: 020007020100000001
   VCID: 2447834E279C1F1E3A-8070
   Part No SW: 8R1 035 746 H    HW: 8R1 035 746 G
   Component: H-BNT-NA      H43 0937
   Revision: --------    Serial number: 523IW0F2500645
   Coding: 0F0200000006A1EF07028B5E00000403140000000000000000
   VCID: 3C775B2EBF2C47DE62-8068
   Subsystem 1 - Part No: 8R0 060 884 CS
   Component: NAR 2015  1201
   Component: DU7 High  H42 0104
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Component: CD-Database  6208
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C13204000210001
   VCID: 59B9E2BA505E92F659-800C
   Revision: --H09---    Serial number: 525PA8-JA891AD
   Coding: 1000006
   VCID: 387F473E4B146BFE86-806C
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Component: TSG HR        H08 0305
End-------------------------(Elapsed Time: 03:16)--------------------------
Eric
HC800000
AFAIK battery display has been removed on our 2016s. I tried too :-)
TPMS with pressure display, don't think that's doable because we don't have sensors in the wheels, it's just circumference based. You'll be glad it's like that if you keep the car for any length of time or need to do anything with tires.
I've also read about speed display not available on Nav units, but if you really want it, you can tweak the cluster to display it if it doesn't already.
Mayorj
C?ID=271567
I have the reset button on my 2016 A4. My wife's 2011 non mmi A4 doesn't. How would i tweak hers to display on the cluster instead of the fuel consumption display. I have driving school enabled on hers that is good enough just like to learn
