VCDS - Control Select Module
Kvetosm
Czech Republic
C?ID=429474
Edit:
Hi, I'm having trouble loading the control modules. In the original version (26.9.0), the vehicle's modules either don't load or aren't visible. However, the "Auto-Scan" function works correctly. I tried uninstalling and reinstalling the software, but the problem persists. In the Czech version (25.3.2), everything works fine and I can see all the modules. Everything is up to date (see screenshot). Do you have any idea what might be causing this? Thanks.
Ahoj, mám problém s načtením ovládacích jednotek. V původní verzi (26.9.0) se nenačítají nebo nevidím všechny jednotky vozidla. Funkce "Auto-Scan" však funguje správně. Zkoušel jsem software odinstalovat a znovu nainstalovat, ale problém přetrvává. V české verzi (25.3.2) všechno funguje bez problémů a vidím všechny jednotky. Vše je aktuální (viz screenshot). Máš tušení, co by to mohlo způsobovat? Díky.
Greetings, English please.
Also, be sure the ignition key is "ON" (or engine running) when you start VCDS.
Hi, I'm having trouble loading the control modules. In the current version (26.9.0), the vehicle's modules either don't load or aren't all visible. However, the "Auto-Scan" function works correctly. I tried uninstalling and reinstalling the software, but the problem persists. In the Czech version (25.3.2), everything works fine and I can see all the modules. Everything is up to date (see screenshot). Do you have any idea what might be causing this? Thanks.
Your going to need to download the English version of VCDS ; both your Czech version and English version can be loaded on your PC together and used independently.
English version of VCDS (for use on the Forum)
Kvetosm
Czech Republic
C?ID=429474
Sorry about the language. Anyway, I had the ignition on, and I have the original English version installed.I’ve been using both versions this way for several years, but I’m only encountering this problem now.
Kvetosm
Czech Republic
C?ID=429474
Here is autoscan VW Caddy
Monday,14,September,2026,18:39:26:41917
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: WV1ZZZSK4TX077200   License Plate:
Chassis Type: SK-VN3SP PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5
          8109 810A 810B 810C 815A C002 C003
VIN: WV1ZZZSK4TX077200   Mileage: 7540km-4685miles
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: Malfunction 0010
810C-Close Rge Radar 4 -- Status: Malfunction 0010
815A-Multifunction Interior Camera -- Status: OK 0000
Address 01: Engine (J623-DXDE)       Labels: Redir Fail!
   Part No SW: 05E 906 019 BE    HW: 05E 907 309 CA
   Component: R4 1.5l TFS   H80 4508
   Revision: KNH80000    Dataset Number: V03935404LB 0001 CVN: AF2B0E79
   Coding: 0125007223640D0830080000001000000000000000000000
   Shop #: WSC 35110 377 00031
   ASAM Dataset: EV_ECM15TFS01105E906019BE 001007
   ROD: EV_ECM15TFS01105E906019BE.rod
   VCID: 6A8C3CEEFCF5D28A594-803E-R SFD+SFD2 [x]
   VINID: 9E606AAAA8DB124A001C7080004F598E96
   Active oil separating system:
4718 - No Communication with Transmission Control Module
          U0101 00 [00100000] - -
   Part No SW: 0GC 906 556 BE    HW: 0GC 300 060 N
   Component: GSG DQ381     H06 0860
   CVN: 552BD38C
   ASAM Dataset: EV_TCMDQ381064 001012
   ROD: EV_TCMDQ381064.rod
   VCID: 00587E46EA8938DAE70-8054-R SFD [x]
   Parking lock:
   Subsystem 1 - Part No SW: 5WA 907 484 A    HW: 5WA 907 484
   Component: ZSB_SB_AUTO    H03 1092
   Serial number: 00000000000102045503
   Selector lever:
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 30032606S00000164014
   MTF pump:
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700008512200
Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb
   Part No SW: 5WA 614 517 EA    HW: 5WA 614 517 BS
   Component: ESC           H31 0339
   Serial number: 60856000001001  Dataset Number: V03935480WF 0001 CVN: 5052230971E25BB0
   Coding: 4A185428A049399C4001A5AC9EB601450ACF952151A000
   ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026
   ROD: EV_Brake1ESCMQB37WUNECE_006_VN3SP.rod
   VCID: 0B42596AD3CF6B82822-805E-R SFD+SFD2 [x]
8505 - Implausible Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [00100000] - -
          [CCan_AWV_03_Counter]
8521 - No Communications with Parking Assist Control Module A
          U0159 00 [00100000] - -
          [CCan_Parken_01_Timeout]
                    Reset counter: 26
                    Mileage: 6803 km
                    Date: 2026.09.07
                    Time: 11:30:22
                    Vehlicle_speed: 1.3 km/h
                    Resolution Mileage: 706 m
                    Voltage_value_KL.30_ESC_V: 12.3 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: completed successfully
                    Comparison_yaw_rate_sensor: completed successfully
                    LWS_comparison: completed successfully
                    Internal_failure_code: 00 D6
                    00 02 00 00 0C 8D 80 08 80 88 80 80 80 01 00 40 00 00 08 40 04
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 AC    HW: 5WA 959 436 M
   Component: Kessy IOBOX   122 0771
   Serial number: --------------- Dataset Number: V03935389DZ 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 15763F12850BAD72246-8040-R
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 3WA 907 007 F    HW: 3WA 907 007
   Component: Climatronic   H01 5089
   Serial number: 117032600154950 Dataset Number: V03935468GT 0001
   Coding: 023000010011020000100000011001110000112100100100000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002062
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 48C8A6668239C09A6F0-801C-R SFD+SFD2 [x]
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527     HW: 5WA 907 527
   Component: E857           H01 0103
   Serial number: 00003060326212213508
523532 - BCM
          U15BA 00 [00101111] - Received Malfunction Value
          [Body computer 1/vehicle electrical system control module/el.ZE Received malfunction value 2]
                    Mileage: 5 km
                    Date: 2026.05.19
                    Time: 15:17:21
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 CD    HW: 5WA 937 086 BJ
   Component: BCM37w_M238 0517
   Serial number: BXJ53F300326940 Dataset Number: V03935483EC 0001
   ASAM Dataset: EV_BCMwBL 005001
   ROD: EV_BCMwBL_005.rod
   VCID: 15763F12850BAD72246-8040-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53511012600018085
   Subsystem 2 - Part No SW: 5H0 941 193 AF    HW: 5H0 941 193 AF
   Component: LiSi           H04 0513
   Serial number: TW571423032600010551
   Subsystem 3 - Part No SW: 5H0 925 200 T    HW: 5H0 925 200 T
   Component: DiETa          H07 0008
   Serial number: 92471ACQ000FC
   Subsystem 4 - Part No SW: 5H0 959 561 CG    HW: 5H0 959 561 CG
   Component: -VW----LINDA-  505 0835
   Serial number: MW3LND13032600013504
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 EB    HW: 5Q1 953 549 D
   Serial number: 00000002032604220767
   Part No SW: 5QS 919 298 D    HW: 5QS 919 298
   Component: PLA 12ch mid  H01 0340
   Serial number: 000023032695580 Dataset Number: V03935494XL 0001
   Coding: 8204026031
   ASAM Dataset: EV_EPHBO2CVW3360000 001013
   ROD: EV_EPHBO2CVW3360000_AU38P.rod
   VCID: 639251CA1BDF83C29A2-8036-R
1114113 - Driver Assistance Systems Audio Output
          B1AE2 F0 [00100000] - Infotainment System; Implausible Signal
          [sound_output_MIB_totally_disturbed]
13640966 - Control Module for Parking Aid
          B1B17 06 [01100000] - Algorithm Failure
          [SW timeout error]
   Part No SW: 1N3 907 567 E    HW: 1N3 907 819 A
   Component: ACC Bosch MQB H03 0550
   Dataset Number: V03935488SS 0001
   Coding: 0E09206F0071C04040020000000040C0000020000004000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW412 002017
   ROD: EV_FRONTRADARBOSCHVW412_002_VW41.rod
   VCID: 392ED3A2C9D3A912E0E-806C-R SFD+SFD2 [x]
7 Faults Found:
0322 - Databus
          U1122 00 [00101110] - Implausible Message
          [FAULT_SWA_MODE_SYSTEM_NOT_AVAILABLE]
                    Fault Frequency: 209
                    Mileage: 5 km
                    Date: 2026.05.21
                    Time: 14:50:17
                    Outside temperature: 20.00  C
                    Control Module temperature: 18  C
                    Voltage terminal 30: 11.0 V
                    Vehicle speed: -0.00 m/s
                    Longitudinal acceleration: -0.00 m/s
                    Adaptive distance regulation: status: initialized
                    kilometer reading: 5 km
                    Monitoring_debug_information: 00 00 00 00 00 00 00 00
                    Event_Id: 02 36
1416 - Databus
          U1122 00 [00101000] - Implausible Message
          [FAULT_VMM_INCONSISTENCY_AWV_PCF]
                    Reset counter: 16
                    Mileage: 2394 km
                    Date: 2026.08.03
                    Time: 16:46:27
                    Outside temperature: 45.00  C
                    Control Module temperature: 50  C
                    Voltage terminal 30: 11.3 V
                    kilometer reading: 2394 km
                    Event_Id: 02 55
1842 - Databus
          [FAULT_RB_MFK_BLINDNESS_ODACC]
                    Reset counter: 6
                    Mileage: 1594 km
                    Date: 2026.07.25
                    Time: 00:31:40
                    Outside temperature: 14.00  C
                    Control Module temperature: 24  C
                    Voltage terminal 30: 11.8 V
                    Vehicle speed: 6.10 m/s
                    Longitudinal acceleration: -0.66 m/s
                    Adaptive distance regulation: status: Readiness
                    kilometer reading: 1594 km
                    Event_Id: 02 05
1884 - Databus
          [FAULT_RB_MFK_BLINDNESS_OD_PED]
                    Reset counter: 6
                    Mileage: 1594 km
                    Date: 2026.07.25
                    Time: 00:31:40
                    Event_Id: 02 06
1885 - Databus
          [FAULT_RB_MFK_BLINDNESS_LDA]
                    Reset counter: 6
                    Mileage: 1594 km
                    Date: 2026.07.25
                    Time: 00:31:40
                    Event_Id: 02 04
2068 - Databus
          U1122 00 [00100000] - Implausible Message
          [FAULT_TSK_IRREV_ERROR]
2260 - Databus
          [FAULT_RB_IMU_TIMESTAMP_NOT_PLAUSIBLE]
                    Reset counter: 16
                    Mileage: 510 km
                    Date: 2026.07.09
                    Time: 17:01:06
                    Outside temperature: 28.00  C
                    Control Module temperature: 45  C
                    Voltage terminal 30: 11.4 V
                    kilometer reading: 510 km
                    Event_Id: 01 FE
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 AE    HW: 5QS 959 655 AE
   Component: AirbagVW50    010 0251
   Serial number: 000000003C0UCRF Dataset Number: V03935484FY 0001
   Coding: 88CC000000C00000000000000000000091000000A1000000C000F680002B00A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001062
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 261408DE286D36EABDC-8072-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 480 001 103 1A
   Serial number: 35700001D789493C1740
   Subsystem 2 - Part No SW: -----------    HW: 480 001 103 1A
   Serial number: 35800001D789493A1860
   Subsystem 3 - Part No SW: -----------    HW: 480 050 203 1A
   Component: FrontSensor_D  000 014A
   Serial number: 3550000BEEC3A6870710
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 480 051 303 1A
   Component: Side_Sens_B_D  000 0149
   Serial number: I0P0000B4EA64A90A440
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 480 051 303 1A
   Component: Side_Sens_B_P  000 0149
   Serial number: I0Q0000AEEC3A6876750
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 F    HW: 5H0 920 340 F
   Component: KOMBI         501 3365
   Dataset Number: V03935500QX 0001
   Coding: 04240547639C00080180620B2000080800307C0800
   ASAM Dataset: EV_DashBoardVDDMQB37W 006052
   ROD: EV_DashBoardVDDMQB37W_006_VW38.rod
   VCID: 25160FD2556B3DF2B46-8070-R SFD [x]
8667138 - Distance
          U197A 00 [00001000] - Plausibility Check
          [Wegstrecke Plausibilisierung ist fehlerhaft]
                    Fault Frequency: 150
                    Reset counter: 169
                    Mileage: 5 km
                    Date: 2026.05.21
                    Time: 14:50:14
   Part No SW: 5QS 907 530 K    HW: 5QS 907 530
   Component: GW MQB 23     005 2097
   Serial number: SMERBG230326007 Dataset Number: V03935488MP 0001
   Coding: 000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000
   GVL: 3D000000022A408C80408042C800004004004000047800000000000000000044
   ASAM Dataset: EV_GatewMQBwBL 001027
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 5CE06A3626A1BC3ADB8-8008 SFD+SFD2 [x]
   Generator:
   Component: 5-00-18-01-03
   Subsystem 2 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 5473598106
   Inverter for socket:
   Subsystem 3 - Part No SW: 7C0 907 155     HW: 7C0 907 155
   Component: U13DCAC        H05 0870
   Serial number: A280987
   Subsystem 4 - Part No SW: 571 959 442 B    HW: 571 959 442 B
   Component: E221__MFL-PR6  H07 0130
   Serial number: PR6-0440036068262386
8491266 - Secure Onboard Communication
          U14FE 00 [00101000] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Reset counter: 37
                    Mileage: 7369 km
                    Date: 2026.09.13
                    Time: 17:02:34
8389392 - Control Module for Driver Assist Systems
          C12D5 87 [01101100] - Missing Message
          [FAS messsages retention time to long]
                    Reset counter: 38
                    Mileage: 7404 km
                    Date: 2026.09.13
                    Time: 20:24:37
   Part No SW: 5WA 909 059 AH    HW: 3Q0 909 059 D
   Component: EBKV          H10 0563
   Serial number: BPA085220226013 Dataset Number: V03935447DC 0001
   Coding: 5402C100700000008018638C000049922449922400
   ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005
   ROD: EV_BrakeBoostVW37WUNECE_013.rod
   VCID: 1674381E980DA66A2DC-8042-R SFD+SFD2 [x]
108400 - Immobilizer Control Module
          U0167 00 [00100000] - No Communications
          [NoVINDetected]
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861 A    HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0071
   Serial number: 26000074605006- Dataset Number: V03935458YW 0001
   Coding: 8820000000000000
   ASAM Dataset: EV_ELVMarqUNECE 004001
   ROD: EV_ELVMarqUNECE_004_VW27.rod
   VCID: 49CEA3629933399270E-801C-R SFD+SFD2 [x]
   Part No SW: 3WA 959 593 A    HW: 3WA 959 593
   Component: TSG FS        001 0222
   Serial number: Y2007ZC800HN1   Dataset Number: V03935454MY 0001
   Coding: 00208320D000000100001030
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
   VCID: 54F082164E71747A138-8000-R SFD+SFD2 [x]
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 5QS 907 146 D    HW: 5QS 907 146
   Component: BASGEN1MQB37  263 2122
   Serial number: 01424736 Dataset Number: V03935491RH 0001
   Coding: 00000000000000000001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017.rod
   VCID: 58E876265299501AFF0-800C-R SFD+SFD2 [x]
   Part No SW: 3WA 959 592 A    HW: 3WA 959 592
   Component: TSG BFS       001 0222
   Serial number: Y3007ZC80065G   Dataset Number: V03935454MZ 0001
   Coding: 00200120D000000100001030
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
   VCID: 53F2810A4B7F73420A2-8006-R SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 572 035 816 C    HW: 572 035 816
   Component: MU-O-ND-EU    H11 2768
   Serial number: WG8LGM250326003 Dataset Number: V03935477NS 0001
   Coding: 63521006002020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 002001
   ROD: EV_MUOIMQB37w_002_VW41.rod
   VCID: 186836269219901A3F0-804C-R SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 5H0 919 605 G    HW: 5H0 919 605 G
   Component: ABT_W_10       H50 2115
   Serial number: APUFX728032600010017
   Subsystem 2 - Part No: V03 959 822 LE
   Component: EUR 2025/26    3129
1872 - Automotive Audio Bus (A2B)
          B1994 F4 [00001000] - Microphone Module Defective
          [a2b_bus_micro_defect]
                    Fault Frequency: 11
                    Reset counter: 36
                    Mileage: 6138 km
                    Date: 2026.08.28
                    Time: 12:28:40
                    Voltage terminal 30: 14.6 V
                    amount_of_nodes: 2
                    Node number: 1
                    Node name: Emergency call module and communication unit
                    Node status: OK
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 H    HW: 5WA 980 556 C
   Component: RV eCompact   H52 0604
   Serial number: V6DK20090326010 Dataset Number: V03935459KL 0001
   Coding: 06034E0027140000
   ASAM Dataset: EV_CamSysRVCeCFicosBL 003010
   ROD: EV_CamSysRVCeCFicosBL.rod
   VCID: 56F4781E588D666AEDC-8002-R
   Part No SW: 571 035 284 D    HW: 571 035 284
   Component: OCUMQBW2023_H H09 0668
   Serial number: 0000000512VIJHA Dataset Number: V03935480SG 0001
   Coding: 06010601000000110000010013002607101112111012011110
   ASAM Dataset: EV_OCUMWB2023 001072
   ROD: EV_OCUMWB2023_VW42.rod
   VCID: 176A351A9F079F6236A-8042-R SFD+SFD2 [x]
   Part No SW: 3WA 907 217 F    HW: 3WA 907 217
   Component: MFK120_MQB    H18 1550
   Dataset Number: V03935484WW 0001
   Coding: 00050000000000000000008AF940000500000000004500000000FE00000038EE43F24074C000000000800000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK120MAGNAMQBWB 005004
   ROD: EV_MFK120MAGNAMQBWB_005_VW42.rod
   VCID: 4BC2996A934F2B82422-801E-R SFD+SFD2 [x]
2097152 - Fan for Front Camera
          B1CDC 92 [01100000] - Performance or Incorrect Operation
          [Fan_operational_fault_or_open_load]
1049685 - Front Camera for Driver Assist Systems
          C12B3 FD [00100000] - View Temporarily Restricted
          [temp_blindness_detected_lda_impairment]
Address 8109: Close Rge Radar 1 (J1088)       Labels:* None
   Part No SW: 3WA 907 541 F    HW: 95C 907 541
   Component: Nanoradar 1   H08 0162
   Serial number: 14520099743009  Dataset Number: V03935488RY 0001
   Coding: 55555A1529C405000000
   ASAM Dataset: EV_NR1HELLAVW38X 002116
   ROD: EV_NR1HELLAVW38X_001_VWE3.rod
Address 810A: Close Rge Radar 2 (J1089)       Labels:* None
   Component: Nanoradar 2   H08 0162
   Serial number: 14520099743006  Dataset Number: V03935488TB 0001
   ASAM Dataset: EV_NR2HELLAVW38X 002116
   ROD: EV_NR2HELLAVW38X_001_VWE3.rod
Address 810B: Close Rge Radar 3 (J770)       Labels:* None
   Component: Nanoradar 3   H08 0162
   Serial number: 14520099804071  Dataset Number: V03935488TL 0001
   ASAM Dataset: EV_NR3HELLAVW38X 002116
   ROD: EV_NR3HELLAVW38X_001_VWE3.rod
12582983 - No Basic Setting
          B2010 00 [00101110] - -
          [No_basic_setting]
Address 810C: Close Rge Radar 4 (J769)       Labels:* None
   Component: Nanoradar 4   H08 0162
   Serial number: 14520099804069  Dataset Number: V03935488UA 0001
   Coding: 55696A1631C40F000000
   ASAM Dataset: EV_NR4HELLAVW38X 002116
   ROD: EV_NR4HELLAVW38X_001_VWE3.rod
          [No_basic_setting]
Address 815A: Multifunction Interior Camera (R434)       Labels:* None
   Part No SW: 3JD 857 511 AA    HW: 3JD 857 511 AA
   Component: MIK           H08 0663
   Serial number: Z9115145P079260 Dataset Number: V03935484DN 0001
   Coding: 01
   ASAM Dataset: EV_MIKVW491 002022
   ROD: EV_MIKVW491_002_VW41.rod
   VCID: 7EA400BE907D4E2A95C-802A-R SFD+SFD2 [x]
524305 - Driver Monitoring
          B1E33 F1 [00100000] - Function Restriction
          [Driver_monitoring_function_error]
589845 - Internal Voltage Supply
          B1872 F1 [00100000] - Malfunction
          [PMIC_fault_temp]
End----(Elapsed Time: 01:41, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
------------------------------24 Faults Found------------------------------
Kvetosm
Czech Republic
C?ID=429474
Here is My Octavia 3
Monday,14,September,2026,13:21:45:41917
VIN: TMBAC7NE4J0299857   License Plate:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 47 4B 52 5F 6C 75 D6
          D7
VIN: TMBAC7NE4J0299857   Mileage: 115510km-71774miles
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---    CVN: 65239CB2
   Coding: 01190032232401081000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD_SK37.rod
   VCID: 6D8637F2CD1BC5B23C6-8038
   VINID: 91D4914C779511A0022492051C9C347556
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
   Component: ESC           H62 0973
   Revision: 00000000    Serial number: 60598000001120
   Coding: 24076A9124292175407F060560CA242456248402600624722023F070C007430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037.rod
   VCID: 04507256FE9124FAC38-8050
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0472643327 Dataset Number: V03935253VG 0001
   Coding: 132C0C
   Shop #: WSC 73430 790 00063
   VCID: 3C20CAB6C6E19C3AFB8-8068
   Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 01010004000110011005004800101022
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   VCID: 74B02296AE31147AF38-8020
   Air quality sensor:
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001720200755 Dataset Number: V03935276SP 0001
   Shop #: WSC 73430 790 12345
   ROD: EV_BCMBOSCH_018.rod
   VCID: 08486666C2B9009AAF0-805C
   Subsystem 1 - Part No SW: 5E1 955 119 A    HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180216  051 0916
   Serial number: 887353F0401804703084
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: SBY18M03D07H19M12S15
   Coding: 06885D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY171700ZBY
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223980183194
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418018044 Dataset Number: V03935256AD 0001
   Coding: 0471151041
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P4B2NW7 Dataset Number: V03935266KC 0001
   Coding: 98CCC000000000005C5400CC000840000065
   VCID: 05566F52F5AB1DF2D46-8050
   Subsystem 1 - Part No SW: -----------    HW: 454 002 602 18
   Serial number: 35700000000A64187D2N
   Subsystem 2 - Part No SW: -----------    HW: 454 002 102 18
   Serial number: 35800000000D47DC6D20
   Subsystem 3 - Part No SW: -----------    HW: 454 802 202 18
   Serial number: 3510059CBB413000000M
   Subsystem 4 - Part No SW: -----------    HW: 454 802 002 18
   Serial number: 3520073D9BB13000000P
   Subsystem 5 - Part No SW: -----------    HW: 454 801 702 18
   Serial number: 355006D2E8413000000L
   Part No SW: 5Q0 953 507 HQ    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 07031808491408
   Coding: 1400
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 0C405A76D6C16CBA8B8-8058
   Part No SW: 5E0 920 750 E    HW: 5E0 920 750 E
   Component: KOMBI         303 0310
   Coding: 06AD02102980000801007A001001000800000000
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007558199 Dataset Number: V03935276GC 0001
   Coding: 0B0100047F085709EB0002CA080F00010001070000000000000000000000
   GVL: 01563C0000000600400C00008002480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3828D6A6F2D9B01A1F0-806C
   Generator:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Serial number: 000000000D2240060318
   Serial number: 7588600000180309155E
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: U13DCAC  H25 0780
   Serial number: 0087570
   Revision: 00000000    Serial number: 18000065696004
   Coding: 5500000000000000
   VCID: 3430E296EEB1547A338-8060
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 0000308209266  Dataset Number: V03935252QV 0001
   Coding: 00110020D000040000001100
   VCID: 47CAA55A8F27CFE266A-8012
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019815368
   Coding: 010200
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1081
   Dataset Number: V03935278BA 0001
   Coding: 01170000
   Shop #: WSC 73430 790 00000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73B2218AAB3F1342EA2-8026
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE042K6. Dataset Number: V03935267AD 0001
   Coding: 0373010000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EE732229934912C0E-800C
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 01031810802654 Dataset Number: V03935265KN 0001
   Coding: 000000070100046200003D01010000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_001_VW37.rod
   VCID: 72BC248ED4251A4AE14-8026
   Serial number: 0000307357246  Dataset Number: V03935252QY 0001
   Coding: 00110020D400040000001100
   VCID: 46D4A85E882DD6EA9DC-8012
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000019565710
   Coding: 190200
   Part No SW: 5Q0 035 864 C    HW: 5Q0 035 864 C
   Component: MU-S-N-ER     H41 0480
   Serial number: SKZAZ2U0469226 Dataset Number: V03935278EJ 0001
   Coding: 037301010000000041110002000802232F0208E401200500CE
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 3332E18AEBBF53422A2-8066
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHV0694494
   Subsystem 2 - Part No SW: V03 959 823 MN    HW: -----------
   Component: ECE DL1 26/27  --- 2610
   Dataset Number: V03935257YE 0001
   Coding: 0473010102002017000040
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------    Dataset Number: V03935277FY 0001
   Coding: 03730101EA421A0D3B1C9E000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   Part No SW: 7P5 941 591 AJ    HW: 7P5 941 591 A
   Component: LED1R         H07 0011
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW37.rod
1091 - Bulb for Blinker
          C11A4 F1 [10101111] - Temperature Sensor Electrical Malfunction
                    Reset counter: 0
                    Mileage: 115510 km
                    Date: 2026.09.14
                    Time: 13:10:22
1123 - Bulb for DRL and Parking Light
          C123A F0 [10101111] - Temperature Sensor Electical Malfunction
                    Reset counter: 0
                    Mileage: 115510 km
                    Date: 2026.09.14
                    Time: 13:10:22
End----------(Elapsed Time: 07:47, VBatt start/end: 12.2V/12.1V)-----------
------------------------------2 Faults Found-------------------------------
It looks like VCDS isn't getting the Installation list from your Gateway when you click [Select] and is thus presenting the generic list of control modules on the buttons instead of the ones that are actually installed in the car. @Eric may ask you for some debug data.
What happens if you go to [Auto-Scan] and just click [Gateway Installation List]? Do you get the list of installed modules there?
Kvetosm
Czech Republic
C?ID=429474
Yes. In the case of image 4, it wasn't connected to the vehicle; I included that just to show the CB and FW versions. However, screenshots 2 and 3 were taken at the same time with the ignition on and the cable connected. The Czech version works fine, but the English one doesn't. I tried it on two different cars and encountered the same problem.
@Uwe I'll check the Gateway Installation List in the autoscan next time I'm with the car.
Eric
HC800000
OK, can you show us a screenshot of 26.9->Options->User interface and identification?
Kvetosm
Czech Republic
C?ID=429474
I can now see a difference in the user interface between the Czech and English versions... Could it be? :-)
Kvetosm
Czech Republic
C?ID=429474
I can confirm that was indeed the cause. Everything is fine now. Thanks again.
