2014 Audi Q5
mark2002be
SF Bay Area, CA, USA
Hello all,
Purchased my VCDS so I can intelligently shop for an eGolf, and my friend with a 2014 Q5 with some engine misfire issues came right over once he heard I got it :-)
He had the engine check light come on last year and has been using some additives to deal with (known?) issues with ring failure / wear in this motor. Looks like cylinder misfires (among other things), but might also be downstream issues with vacuum leaks. What's the best way to go about diagnostics for engine issues like this? I'm solid with suspension and chassis stuff, but engine work is not something I'm super familiar with. Thanks in advance, and thanks for such a great tool and forum!
Here is the auto-scan from today:
Monday,14,September,2026,18:40:44:65191
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 arm64(arm64 CPU)(Parallels)
VCDS Version 26.9.0.3 (arm64)  HEX-V2 CB: 0.4713.5
VIN: WA1LFBFP6EA063904   License Plate:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          69 6C 6D 72
VIN: WA1LFBFP6EA063904   Mileage: 108820km-67617miles
Address 01: Engine (DET-CPMB)       Labels:. 06J-907-309-V2.clb
   Part No SW: 8R1 907 115 L    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---    CVN: E5EDE92F
   Coding: 6A2A0013243600062000
   Shop #: WSC 27576 001 1048576
   ASAM Dataset: EV_ECM20TFS0118R1907115L 001006
   ROD: EV_ECM20TFS0118R1907115L.rod
   VCID: 3E22DEB380F85F8AD5C-806B
   VINID: 9D105C5925A019544018324010A6E720A6
11 Faults Found:
4571 - Ignition Control Circuit for Cylinder 1
          P0351 00 [01100000] - Malfunction
4573 - Ignition Control Circuit for Cylinder 3
          P0353 00 [01100000] - Malfunction
4574 - Ignition Control Circuit for Cylinder 4
          P0354 00 [01100000] - Malfunction
4572 - Ignition Control Circuit for Cylinder 2
          P0352 00 [01100000] - Malfunction
5646 - Leak in Air Intake System
          P2279 00 [01100000] - -
22656 - Fuel Trim; Bank 1
          P0172 00 [01100000] - System Too Rich
5671 - Boost Pressure Regulation
          P0299 00 [01100101] - Control Range Not Reached
                    Mileage: 108747 km
                    Date: 2026.09.12
                    Time: 15:38:19
                    Engine speed: 3263.50 /min
                    Normed load value: 80.8 %
                    Vehicle speed: 91 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 13.970 V
                    Engine status: COENG_RUNNING
4010 - Idle Control System
          P0506 00 [01100000] - RPM Lower than Expected
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [01100000] - -
10591 - Cylinder 1
          P0301 00 [01100000] - Misfire Detected
10594 - Cylinder 4
          P0304 00 [01100000] - Misfire Detected
   Part No SW: 8R1 927 158 C    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1006
   Revision: --H16---    CVN: E4D666BC
   Coding: 000002
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AM    HW: 8R0 907 379 AM
   Component: ESP8 quattro  H09 0030
   Coding: 159D1803
   Shop #: WSC 22803 444 120602
   VCID: 0B444767834ABA22822-805F
   Part No SW: 8K0 907 064 HP    HW: 8K0 907 064 GP
   Component: BCM2 2.0      H13 0641
   Coding: 0D854040000000000000
   Shop #: WSC 06335 000 00000
   VCID: 0550715FA52ECC52D46-8051
   Serial number: 0213000362251004
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01131120130700
   Coding: 6481208000
   VCID: 3928CDAF995678B2E0E-806D
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000055225301
   Coding: 26000091863CAFC00000480300003D0D0F1C6608A2090221000008004000030100000034000000
   VCID: 78AE08ABE2DCA1BADF0-802D
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 131105  H11 0050
   Serial number: 90243014131025024158
   Coding: 01DD13
   Serial number: 21943448
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000711130343
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R8G0803
   Serial number: FAD889D6000000000001
                    Reset counter: 32
                    Mileage: 108609 km
                    Date: 2026.09.03
                    Time: 11:33:09
01229 - A/C Humidity Sensor (G260)
                    Reset counter: 32
                    Mileage: 108609 km
                    Date: 2026.09.03
                    Time: 11:33:09
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Component: AirbagVW-AU10 H47 0610
   Serial number: 003GPDB0M99M   Dataset Number: 8R0909602B  0021
   Coding: 303334313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 47CCBB57DF221E4266A-8013
   Seat occupant detection:
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R130000G8ER
   Serial number: 6334MSME7F606337K
   Serial number: 6344MSME402A793DM
   Serial number: 6352QSME5E384146M
   Serial number: 6362QSME4D384348P
   Serial number: 63732SME7E37396CH
   Serial number: 63832SME04382968/
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862MIL000EC
   Coding: 000017
   VCID: 48CEB86BD2BC113A6F0-801D
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 N    HW: 8R0 920 981 N
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZD32C87CE
   Coding: 8BB622000301D705020000
   VCID: 45D0B15FE5AE0C52946-8011
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0056
   Revision: 1Y070028    Serial number: 2841Y13A240BB7
   Coding: 80C303FF00
   VCID: 4ACA8263CCB0E32A794-801F
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 30299854071461311324
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000081048372
   Coding: 00581B00000000000000
   VCID: 42DAAA43F4803B6AB14-8017
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000081914493
   Coding: 011D13205E00440004
   VCID: 4FFC937737D2C6022EA-801B
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H39 0507
   Revision: 00001000    Serial number: 0029998932 Dataset Number: 8R0909852H  0021
   Coding: 100000000000
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B24D7A793EA4AA2F22-806F
   Revision: 00002001    Serial number: 0319077662
   Coding: 0126023A20FA709584B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000761133
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
   Revision: 00005001    Serial number: 94813022370103
   VCID: 2D00E9FF5D1ED4127C6-8079
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000081141453
   VCID: 4EC28E7330D8CF0A25C-801B
   Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
   Component: EPB-4         H01 0004
   Revision: --------    Serial number: 10000000291640
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3928CDAF99D678B2E0E-806D
   Revision: AB001007    Serial number: 156K90D7934287
   Coding: 020007010000000001
   VCID: 24160CDB0ED4155AA38-8071
   Part No SW: 8R1 035 746 E    HW: 8R1 035 746 D
   Component: H-BNT-NA      H41 0756
   Revision: --------    Serial number: 204K/0D7625446
   Coding: 160200060005A1EF4102AB5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Serial number: A130K$0D2872763
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001674066
   Component: CD-Database  5571
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000081736061
   Coding: 010C13204000240004
   VCID: 46D2B653D8A8074A9DC-8013
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000194065750
   Coding: 0200000000000000
   VCID: 3632C693A84897CA0DC-8063
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H08---    Serial number: 525PA8-J38A4FP
   Coding: 1030010
   VCID: 3436FC9BB23485DA338-8061
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B24D7A7936A4AA2F22-806F
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000081735902
End----------(Elapsed Time: 02:04, VBatt start/end: 12.6V/12.5V)-----------
------------------------------13 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Any vacuum leaks?
mark2002be
We did the PCV Valve test with the engine running - major suction keeping the oil cap on. I'm kind of a n00b to this motor (I had a 4000 CS Quattro and an 80 Quattro years ago!), but I think that means the PCV Valve diaphram has failed. Sounds like this is a common failure on this motor. Not sure which variant of the PCV Valve is on the car currently, but I am going to assume it's original. We ran another auto-scan yesterday and here are the results.
He has had some of the vacuum lines replaced recently by a competent shop, although one wonders why they didn't do the 2-minute PCV Valve check.
Sunday,20,September,2026,18:41:37:65191
          69 6C 6D 72
VIN: WA1LFBFP6EA063904   Mileage: 108940km-67692miles
          P0300 00 [01100101] - -
                    Mileage: 108873 km
                    Date: 2026.09.16
                    Time: 18:19:44
                    Engine speed: 696.50 /min
                    Normed load value: 11.4 %
                    Coolant temperature: 98 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 13.617 V
                    Unlearning counter according OBD: 80
10591 - Cylinder 1
          P0301 00 [01100101] - Misfire Detected
                    Mileage: 108949 km
                    Date: 2026.09.20
                    Time: 18:35:06
                    Engine speed: 704.00 /min
                    Normed load value: 12.5 %
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 13.829 V
10593 - Cylinder 3
          P0303 00 [01100101] - Misfire Detected
                    Mileage: 108873 km
                    Date: 2026.09.16
                    Time: 18:20:34
10594 - Cylinder 4
          P0304 00 [01100101] - Misfire Detected
                    Mileage: 108949 km
                    Date: 2026.09.20
                    Time: 18:35:06
10592 - Cylinder 2
          P0302 00 [01100101] - Misfire Detected
                    Mileage: 108949 km
                    Date: 2026.09.20
                    Time: 18:35:06
Readiness: 0000 0001
End----------(Elapsed Time: 02:04, VBatt start/end: 12.4V/12.2V)-----------
------------------------------7 Faults Found-------------------------------
