- Oct 10, 2024
- 18
- 11
- Houston, TX, USA
- C?ID=81723
Hello, I have a Passat CC 2009.
Recently the battery went dead due to excessive drain due to a defective radio.
Removed the fuse for the radio and still have a slight high amperage draw of 1.0AMP.
I removed the fuse for the rear door modules and the drain disappeared.
Also the master and the rf door report the rear door modules both offline.
Installed fuse back on and the drain appeared. Disconnected both rear door connectors at the B pillar and the drain disappeared.
Is this a fault from loosing its programming or both door modules went dead or I am missing something.
Bare in mind. At the rear doors, the power windows do work with their respective door switches, but the door locks and remotely with the master switch the windows do not work and the door locks do not set. Also the door ajar does not appear open when the doors are open.
Power and ground are present. The comm wire oscillates between 8.5 to 9.5 volts using a DVOM.
Please help.
Here is the Latest scan read:
Please help.
Thursday,10,September,2026,16:17:27:08745
VCDS Version: 26.9.0.3 (x64) HEX-NET CB: 0.4713.4
VIN: WVWHL73C69E552529 License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4F 52 53 56 62
65 6C 72 77
VIN: WVWHL73C69E552529 Mileage: 244450km-151894miles
2E-Media Player 3 -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 AG HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3319
Revision: AAH03--- Serial number: VWZCZ000000000
Coding: 0404010A19070160
Shop #: WSC 05314 000 00000
VCID: EFAEA2A8FEBFA5E529-80BA
VINID: 9E69D87070D318954514214224C9E43F29
Readiness: 0110 0101
Part No SW: 09G 927 750 GP HW: 09G 927 750 GP
Component: AQ 250 6F 1391
Revision: 00H76000 Serial number:
Coding: 0000840
Shop #: WSC 05311 000 00000
VCID: 8542E000CC038FB5F3-80D0
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 T HW: 3C0 614 109 T
Component: J104 C4 440 V2 0013
Revision: --025--- Serial number: 00000786510880
Coding: 0000376
VCID: AF2E62A83E3FE5E569-80FA
Part No SW: 5K0 907 044 AR HW: 5K0 907 044 AR
Component: Climatronic 130 0305
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: FBB686F872C7C94595-80AE
13701520 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[T rsteuerger t hinten links - kein Signal/Kommunikation]
Reset counter: 106
Mileage: 244455 km
Date: 2026.09.10.
Time: 00:08:12
13701536 - Function Restricted due to Missing Message(s)
[T rsteuerger t hinten rechts - kein Signal/Kommunikation]
Reset counter: 106
Mileage: 244455 km
Date: 2026.09.10.
Time: 00:08:12
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 01000005797147
Coding: 7184CE0340041A00800A00000F00000000385D435C000014000000000000
Shop #: WSC 01367 785 00200
VCID: B3266ED8D217C1050D-80E6
Subsystem 1 - Part No: 3C8 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 091208 022 0602
Coding: 00046997
Shop #: WSC 01367
Component: RLS 200109 054 0402
Coding: 00209133
Shop #: WSC 01367
Reset counter: 106
Mileage: 244455 km
Voltage: 12.20 V
Reset counter: 106
Mileage: 244455 km
Voltage: 12.20 V
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97540834416807
Coding: 300101
VCID: F1AAA4D0288BB3153F-80A4
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__313 VW10 HI 1815
Revision: 19013000 Serial number: 0039BP0YTYT2
Coding: 0012595
VCID: FAB883FCB5FDF04D8E-80AE
Subsystem 1 - Part No: 3C8 959 339 A
Subsystem 2 - Serial number: 000000000028D9
Subsystem 3 - Serial number: 0017.12.100000300000640079 63
Subsystem 4 - Serial number: 640079 6333FTS644370079 63
Subsystem 5 - Serial number: 70079 6343FTS674012781 63
Subsystem 6 - Serial number: 12781 6353ETS6AFNJV5KR 63
Subsystem 7 - Serial number: JV5KR 6363ETS6PUF2V5KJ 63
Subsystem 8 - Serial number: 2V5KJ 6374CTS65BDDV5KR 63
Subsystem 9 - Serial number: DV5KR 6384CTS6E7GDV5KJ
Subsystem 10 - Serial number: DV5KJ
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C5953507CN
Coding: 0001711
VCID: F4A4ADC49799863DD4-80A0
Subsystem 1 - Part No: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4 0021
Coding: 00000226
Part No SW: 3C8 920 970 F HW: 3C8 920 970 F
Component: KOMBI H05 0107
Coding: 240F00
Shop #: WSC 05314 115 00000
VCID: AF2E62A8F63FE5E569-80FA
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 J HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 2900R091088104
Coding: FDA07F07004613009002
Shop #: WSC 05314 123 12345
VCID: A81C89B41BD1B2DDA8-80FC
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:22
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:22
01304 - Radio
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:26
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:26
03272 - Control Module for Audio Interface
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:26
Part No SW: 3C0 959 433 AP HW: 3C0 959 433 AP
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 25642 444 04951
VCID: F8BC99F48BF1E25DF8-80AC
Subsystem 1 - Component: ELV No Answer
ELV No Answer
Address 2E: Media Player 3
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 J HW: 5N1 909 148 F
Component: J500__APA-BS KL.075 0502
Revision: 1AH02254 Serial number: 00083350049802
Coding: 0000258
Shop #: WSC 08103 002 1048576
VCID: B93A5CF0F07B3B55C7-80EC
Fault Status: 11100101
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:06:49
(no units): 4.0
Steering Angle: 0.00
Not OK
(no units): 0
Component: KSG PQ46 RDK 052 0412
Coding: 13910F8001862E521204141FF08A8F0E085801
Shop #: WSC 00137 211 56823
Address 4F: Centr. Electr. II (J533_) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Revision: -------- Serial number: 2900R091088104
Coding: 01030100
VCID: E680C78C114564AD5A-80B2
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245/J878 H04 0054
Serial number: 848600042449
Coding: 000006
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1533
Revision: 71009005 Serial number: 00000266089021
Coding: 0001462
VCID: C1CA341098AB63958F-8094
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:04
Fault Status: 01100101
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:09:02
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000234195
Coding: 0000057
Address 56: Radio
Address 62: Door, Rear Left Labels: None
Part No: No response
Component: Error LIN Slave 0
VCID: AC1475A40F299EFD4C-80F8
Component: RDK 0453
Coding: 0100101
Address 6C: Back-up Cam.
Address 72: Door, Rear Right Labels: None
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 A HW: 1Z0 035 729 A
Component: FSE_2P8x H34 0150
Revision: 00000000 Serial number: 00000005008898
Coding: 0013077
VCID: B62057CCC165D42D2A-80E2
01304 - Radio
Reset counter: 106
Mileage: 244455 km
Date: 2021.01.31.
Time: 00:06:49
End----------(Elapsed Time: 03:04, VBatt start/end: 12.3V/12.3V)-----------
------------------------------14 Faults Found---------------------
