Hello Team ,
looking for EU mapping for 2013 AUDI A8 L 3.0 TFSI
my plan to get the best of the car tweaks
this is my mapping
this is my mapping
Monday,10,August,2026,20:52:10:10378
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.5
VIN: WAURGAFDXDN008261 License Plate:
Address 34: Level Control Labels: 4G0-907-553.clb
Control Module Part Number: 4H0 907 553 E HW: 4H0 907 553
Component and/or Version: LUFE-DAEMPFER H17 0099
Software Coding: 008000
Work Shop Code: WSC 02391 785 00200
ASAM Dataset: EV_AirSuspe 003024 (AU64)
ROD: EV_AirSuspe_003_AU64.rod
VCID: 2E02EFD33095CDDA6DF-807A
677384 - Ride-Height System; Plausibility Error
C1046 00 [00001001] - -
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 15:37:46
677385 - Ride-Height System; Plausibility Error
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 16:30:56
115968 - Functional Limitation due to Excessive Temperature
P178E 00 [00001000] - -
Reset counter: 153
Mileage: 157452 km
Date: 2026.08.10
Time: 16:24:31
Address 0x34,4H0 907 553 E,UDS Selective Output Tests,IDE02930-Left front shock absorber hard
Advanced Identification/FAZIT
Identification: WBW-115
Date: 25.06.12
Manufacturer number: 3613
Test stand number: 0345
Flash Status
Programming Attempts(application): 0/0/1/1
Programming Attempts(data): 1/1
Successful Attempts(data): 1/1
Flash Date-Workshop ID-Status:
00.00.00 00000 000 00000 (OK) | 00.00.00 00000 000 00000 (OK) | 12.07.19 00200 785 02391 (OK) | 12.07.19 00200 785 02391 (OK)
Flash Tool Code(data): 00200 785 02391
Misc.
Hardware number: 4H0 907 553
Workshop System Name: J197
Workshop ID (Adaptation): 00200 785 02391
Workshop ID (Coding): 00200 785 02391
Equipment/PR Code: 0000000000000001
Dataset Number: 4H0909553G
Dataset Version: 0036
End of Line Equipment Level: ------------------
ASAM Dataset Revision: 003024
Car Info
Chassis Number: WAURGAFDXDN008261
VCDS Info:
Date: 25.06.12
Flash Status
Misc.
Car Info
VCDS Info:
Address 0x34,4H0 907 553 E,UDS Basic Settings,IDE03757-Fill air shock absorbers for front axle
Address 0x34,4H0 907 553 E,UDS Basic Settings,IDE02983-System function test
Address 0x34,4H0 907 553 E,UDS Basic Settings,IDE03751-Activate level control system
Address 55: Headlight Range Labels: 4H4-907-357-V1.clb
Control Module Part Number: 4H4 907 357 C HW: 4H4 907 357 A
Component and/or Version: ....AFS13.... H01 0020
Software Coding: 12116F33701AA500
Work Shop Code: WSC 02313 785 00200
ASAM Dataset: EV_AdvanFrontSyste 005001 (AU64)
ROD: EV_AdvanFrontSyste_AU57.rod
VCID: 323AFBA324ADE93A097-8066
120589 - Function Restriction due to Faults in Other Modules
U1113 00 [10001001] - -
[Fehlerhaftes Signal in CAN-Message Fahrwerk_01_FR (0x108)]
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 16:38:00
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 16:38:00
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 28 34 36 3B 42 46 47 52
53 55 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAURGAFDXDN008261 Mileage: 157452km-97836miles
88-Multicont. Seat Driver -- Status: Malfunction 0010
Address 01: Engine (J623-CTUB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4H0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0005
Revision: --H07--- CVN: 9C4BF5E0
Coding: 0A2A0034052E01060000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214H0907551G 001006
ROD: EV_ECM30TFS0214H0907551G.rod
VINID: 9D19625D1594A1478000808604FBAEC416
Part No SW: 4H1 927 158 AR HW: 0BK 927 156 AG
Component: 0BK 30TFSIUSA H16 1005
Revision: --H16--- CVN: 33721114
Coding: 000002
ASAM Dataset: EV_TCMALX51011 002018
VCID: 005E616BDA818BAACF3-8054
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 D HW: 4H0 907 379 D
Component: ESP PREMIUM H10 0352
Coding: 80E5F30001A7CF00E200
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremi 005013
ROD: EV_ESPPremi_005_AU64.rod
VCID: 3334FEA7DBB7E032021-8066
0677 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Error]
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 15:40:51
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: A2
Bit Info 4: 00
F-Path: 39
F-Type: 1A
Uz: B0
0778 - Function Restriction due to Implausible Message(s)
U1112 00 [00001000] - -
[Net_Fahrwerk_03_FA_Niveau_Druck_VL_Invalid]
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 16:14:13
VzRef: 00
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: A2
Bit Info 4: 00
F-Path: 39
F-Type: 19
Uz: 99
Part No SW: 4H0 907 064 DD HW: 4H0 907 064 CD
Component: BCM2 2.0 H32 0510
Coding: 0DA72046000000000000
Shop #: WSC 04352 001 1048576
VCID: 6E822FD3F0958DDA2DF-803A
Serial number: 2312000146961012
No Faults Found
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00000033613687
Coding: C018320085047201010001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 3530C0BFD543FE022C5-8060
No Faults Found
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 H HW: 4H0 820 043 H
Component: Klima 4 Zonen H20 0120
Coding: 6601227E78
ASAM Dataset: EV_AirCondiFront 001050
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 251010FF65638E829C5-8070
0137 - Motor for Right Side Window Defrost Flap
B10D8 22 [00001001] - Signal Amplitude Too High
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 15:35:13
0315 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
Reset counter: 153
Mileage: 157452 km
Date: 2026.08.10
Time: 15:35:13
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001371038
Coding: 02002091163C9FE1CB008804A0003908009CD30886000121800008406000
VCID: 6C8625DBC6897FCA03B-8038
Subsystem 1 - Part No SW: 4H1 955 119 C HW: 4H1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 120419 H35 0080
Serial number: 120618083238
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 C HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10266384
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 D HW: 4H0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 04 07 2012 00000677
Component: USHL4.2 H30 0030
Serial number: 0000002274555R28PX02
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA103815000001529472
Coding: 020300
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 1A788736000000000001
No Faults Found
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061219100339
Coding: A80302
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77AC0AB78F4FCC12FE9-8022
Part No SW: 4H0 959 655 D HW: 4H0 959 655 D
Component: Airbag10.43 H44 0041
Revision: -------- Serial number: 003JS001BA8. Dataset Number: 4H0909602D 0004
Coding: 303143303230303030344A55304C34483053
VCID: 372CCAB7CFCF0C123E9-8062
Seat occupant detection:
Subsystem 1 - Part No SW: 4H0 959 339 A HW: 4H0 959 339 A
Component: BF-Gewichtss. H03 0040
Serial number: 5850000R1261604QE7
Serial number: 3575HRB405B1DED69H84
Serial number: 3585HRB40611F0BC7HCX
Serial number: 3515JRB40144UH24JQ2C
Serial number: 3525JRB40144UH24S150
Serial number: 3554VRB401E4UJ4OCPLT
Serial number: 3564VRB401I4UJ4OIPJ
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815LG100007
Coding: 000034
VCID: 372CCAB7CF4F0C123E9-8062
Subsystem 1 - Part No SW: 4H0 951 528 J HW: 4H0 951 528 J
Component: E221 - MFL H09 0009
Serial number: 20 04 2012 D1026140
No Faults Found
Part No SW: 4H0 920 920 G HW: 4H0 920 920 G
Component: TBenUSA------ H71 0515
Revision: 35081077 Serial number: 658220612592048
Coding: 0B6608011B40D705020000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU64.rod
VCID: 29081CCF097BAAE2B8D-807C
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 G HW: 4H0 919 204 G
Component: Analoguhr D4 H05 0224
Serial number: 1120622001153
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4H0 907 468 AB HW: 4H0 907 468 AA
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000588289 Dataset Number: 4H0909515F 0064
Coding: 00CD075200
GVL: FFA3E848FE63E0CC8000
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 71B834AFE12B922230D-8024
Control module for battery monitoring:
Subsystem 1 - Part No SW: 4H0 915 181 F HW: 4H0 915 181 F
Component: J367-BDM H08 0181
Serial number: 00000000004970657859
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Serial number: 12163000533011200410
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 C HW: 4H0 919 158 C
Component: Klima Fond H16 0120
Coding: 2000000000
ASAM Dataset: EV_AirCondiHeck 001039
ROD: EV_AirCondiHeck_AU64.rod
VCID: 303EF1AB2AA1DB2A7F3-8064
Part No SW: 4H0 907 553 E HW: 4H0 907 553
Component: LUFE-DAEMPFER H17 0099
Dataset Number: 4H0909553G 0036
Coding: 008000
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 15:37:46
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 16:30:56
C10C8 00 [00001000] - -
Reset counter: 153
Mileage: 157452 km
Date: 2026.08.10
Time: 20:58:37
Reset counter: 153
Mileage: 157452 km
Date: 2026.08.10
Time: 16:24:31
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00000033615766
Coding: C0183B0085057201010001010101112131313333203333
No Faults Found
Part No SW: 4H0 907 637 K HW: 4H0 907 637 F
Component: SARA 6D H02 0053
Revision: -------- Serial number: EJ1BPA770046J.
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
Part No SW: 4H0 959 793 R HW: 4H0 959 793 G
Component: TSG FA H06 0263
Revision: -------- Serial number: 0000128767141
Coding: 011F1F005E0062C202003006
Shop #: WSC 02312 785 00200
VCID: 48CEB94BB2B173EA473-801C
No Faults Found
Revision: 00002001 Serial number: 0179809806
Coding: 0106023A00FA7585B0B0C7C40203010F0000000000000000000000000000
Subsystem 1 - Part No SW: 4H0 959 719 HW: 4H0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000092705
Subsystem 3 - Part No SW: 4H0 959 591 HW: 4H0 959 591
Component: J245 PS50.030 H07 0006
Serial number: WOO17159737
Coding: 020200
Subsystem 4 - Part No SW: 4H0 947 135 BK HW: 4H0 947 135 BK
Component: Dachelektroni H11 0080
Serial number: A2012000000000594437
Subsystem 5 - Part No SW: 4H0 959 591 A HW: 4H0 959 591 A
Component: V252 PS010 H05 0005
Serial number: WOO1000QQZJ
Subsystem 6 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0719
Serial number: 84281058
No Faults Found
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000070814
Coding: 030000
VCID: 1D60381F4DB34642C45-8048
No Faults Found
Part No SW: 4H0 959 792 G HW: 4H0 959 792 G
Component: TSG BF H06 0261
Revision: -------- Serial number: 0000129024013
VCID: 3C26D59BF6692F4AD3B-8068
No Faults Found
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000404546 Dataset Number: 4H0909522C 0010
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B04E6C70387B8F24A1-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 120629-0004-025
H02 0009
Coding: 1C0000
H02 0009
Coding: 1C0000
Reset counter: 113
Mileage: 157452 km
Date: 2026.08.10
Time: 16:38:00
Part No SW: 4H0 035 082 D HW: 4H0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 155G00C7522876
Coding: 020007010000000001
VCID: 221A0BE374CD79BAF97-8076
No Faults Found
Part No SW: 4H0 035 746 C HW: 4H0 035 746 C
Component: H-BNT-NA H49 0549
Revision: -------- Serial number: 183GR0C7502015
Coding: 020200000001F1EF45128B1E00000003140001000000000000
VCID: 280E19CB12F193EAA73-807C
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 4H0 919 604 F HW: 4H0 919 604 F
Component: DU8 D4 SV NB H47 0021
Serial number: AUZ8ZDC9300N3JS
Subsystem 3 - Part No SW: 4H1 919 600 H HW: 4H1 919 600
Component: E380 BDT D4 H09 0065
Serial number: 00000000085937
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
No Faults Found
Part No SW: 4H0 959 795 D HW: 4H0 959 795 D
Component: TSG HL H06 0262
Revision: -------- Serial number: 0000128898019
Coding: 010F1F00400062C202003006
No Faults Found
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4H0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H06--- Serial number: 525 PA8J25D1SE
Coding: 1080003
VCID: 261217F314E5859A95F-8072
No Faults Found
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 4H0 959 107 R HW: 4H0 959 107 M
Component: HDSG-Modul H11 0039
Revision: 10011001 Serial number: 175200832 Dataset Number: 4H0909541D 0019
Coding: 0210044100
ASAM Dataset: EV_DeckLidContrUnit 001025
ROD: EV_DeckLidContrUnit.rod
VCID: 3D20D89FEDF32642E45-8068
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000079709 Dataset Number: 4F0000000__ U001
Coding: 200000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 63944EE72BD730B2B21-8036
Component: TSG HR H06 0262
Revision: -------- Serial number: 0000128898010
No Faults Found
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H1 927 731 A HW: 4H1 927 731 A
Component: GSM-LL H08 0083
Revision: 0L0D5014 Serial number: SN120529 0032
ROD: EV_GSM2x3Mono_AU64.rod
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00006525093902 Dataset Number: 4H0909880D 0019
Coding: 766FF2
ROD: EV_IVBDriveSideFrnt_AU57.rod
VCID: 2F3CF2D7379FC4D2669-807A
0006 - invalid data record
B2005 00 [00001001] - -
Reset counter: 113
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00006524220202 Dataset Number: 4H0909881D 0019
Coding: 366FF2
Component: RGS-VL H13 0080
Dataset Number: 4H0909614C 0002
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 3138F4AF21ABD22270D-8064
Component: RGS-VR H13 0080
Dataset Number: 4H0909615C 0002
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:50, VBatt start/end: 13.8V/13.7V)-----------
------------------------------10 Faults Found------------------------------
Saturday,15,August,2026,23:22:14:10378
Address 34: Level Control (4H0 907 553 E)
23:22:13
IDE03980 Results: ventilate air shock absorbers for front axle Front_axle_bleeding
IDE03981 Results: ventilate air shock absorbers for rear axle Rear_axle_bleeding
IDE03982 Results: fill air shock absorbers for front axle Fill front axle
IDE03983 Results: fill air shock absorbers for rear axle Rear_axle_filling
IDE03984 Results: fill left rear air shock absorber Spring_leg_rear_left_filling
IDE03985 Results: fill right rear air shock absorber Spring_leg_rear_right_filling
ENG107358 learned_PWM_value_level_sensor_front_left 24.78 %
ENG107359 learned_PWM_value_level_sensor_front_right 79.44 %
Tuesday,08,September,2026,23:34:26:10378
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
Address 34: Level Control Labels: 4G0-907-553.CLB
VCID: 2E02EFD33095CDDA45C-807A
Reset counter: 171
Mileage: 158736 km
Date: 2026.09.08
Time: 23:25:10
367877 - Ride Height Not Learned
C1044 00 [00001000] - -
Reset counter: 171
Mileage: 158736 km
Date: 2026.09.08
Time: 23:23:04
403713 - Function limitation due to excessive temperature
B1050 00 [00001000] - -
Reset counter: 167
Mileage: 157823 km
Date: 2026.09.05
Time: 16:29:34
Address 34: DTCs cleared
