HEX-NET3 / VCDS-Mobile repeatedly loses ROD/ASAM data for 2017 Audi R8 4S
   #22
Shaun
The archive you sent shows that the ROD file is present on the interface, and the debug log shows that it is getting the ASAM ID fine from the module which should be all it needs to find this ROD, but then opening the ROD fails. This might be caused by corruption of the ASAM data files needed to load all other RODs. So I think the next thing to try is to do an SD card reset feature code, this will re-initialize the data on the SD card and hopefully fix or at least rule out any possibility of corruption.
Make sure you have a block of time to do this, it takes about a half hour for it to do it's thing. The process is like this:
Interface connected by USB, in VCIConfig [Advanced] tab, Feat. Code enter: 0701020304 [Check Feat. Update]
Once that works, disconnect and reconnect interface to reboot it
Check for updates in VCIConfig and download the updates it finds, this should download a large update that re-initializes a bunch of files on the SD card.
Once that has finished, you might need to autoscan again with Mobile and download the ROD files again, then see if it is working better.
   #23
pwickersham
Seattle, WA, USA
C?ID=667593
I get an error dialog:
Not supported: USB feature code requires CB 0.4324+
   #24
Shaun
Your CB is way newer than that, you should not see that message. Can you replug the interface, restart VCIConfig, and try again? If you see that message again, go to the updates tab and check for updates and you can send me a screenshot of what it shows there, but you might need to download an update.
   #25
pwickersham
Seattle, WA, USA
C?ID=667593
Ah, restarted VCIConfig and got the update to complete on the second attempt. No more errors in Mobile. Select and Advanced Measuring now are working. Everything seems to be working on this front.
Thank you!
