HEX-NET3 / VCDS-Mobile repeatedly loses ROD/ASAM data for 2017 Audi R8 4S
pwickersham
Seattle, WA, USA
C?ID=667593
I am unable to access ASAM-dependent functions in VCDS-Mobile on my 2017 Audi R8 4S, even though the same HEX-NET and vehicle work correctly with Windows VCDS.
Summary: VCDS-Mobile repeatedly downloads the requested ASAM/ROD update, but the data never becomes available. Returning to the controller produces the same “No ASAM data found locally” warning.
Vehicle and interface:
  • Vehicle: 2017 Audi R8 4S
  • VIN: WUAKBAFX5H7901447
  • Interface: HEX-NET3
  • Serial number: HN3-000xxx
  • VCDS-Mobile codebase: Apr 10 2026, 14:52:31
  • CodeBlock: V0.4713
  • Firmware: 2.66
  • Dataset: 00000066
  • Connection: Infrastructure mode through my home Wi-Fi, with working internet access
The attached Windows Auto-Scan identifies the vehicle as chassis FX-AU72 (4S0).
Windows VCDS:
  • VCDS version: 26.9.0.3 x64
  • Windows: Windows 8 x64
  • Interface reported as HEX-NET3
  • CodeBlock: 0.4713.5
  • Dataset: DS378.0
Windows VCDS communicates normally with both engine controllers.
Address 01:
  • ASAM Dataset: EV_ECM52FSI1114S0907552BC 001001
  • ROD: EV_ECM52FSI1114S0907552BC.rod
Address 11:
  • ASAM Dataset: EV_ECM52FSI2114S0907552BC 001001
  • ROD: EV_ECM52FSI2114S0907552BC.rod
Problem in VCDS-Mobile:
  1. Opening Address 01 or Address 11 produces:
    “ASAM data update found”
  2. Selecting “Download Update” downloads and processes the update, but the ASAM data is still unavailable afterward.
  3. Reopening the controller produces the same warning and offers the same update again.
  4. Selecting “Continue Anyway” results in extremely limited functionality because no ASAM data is loaded.
  5. The VCDS-Mobile Auto-Scan chassis list does not contain the 4S/FX Audi R8. The only R8 entry displayed is “42 or FG - Audi R8,” which is for the earlier R8 generation.
Troubleshooting already completed:
  • Repeated the VCDS-Mobile ASAM download several times.
  • Confirmed that the HEX-NET is connected through infrastructure Wi-Fi with internet access.
  • Repeated the available updates on the current update channel.
  • I have not switched the interface to the Beta channel.
  • Used Options → Clear Dataset Cache and downloaded the data again.
  • Ran the interface update through Windows VCDS/VCIConfig.
  • Repeated the Windows update using a separate desktop PC with a fresh VCDS installation.
  • That update completed successfully, including copying ROD files.
  • A subsequent update check reported that the interface was fully up to date.
  • Returned the HEX-NET to the vehicle and retried VCDS-Mobile.
  • VCDS-Mobile still reported that no ASAM data was available locally.
The successful Windows update and normal Windows VCDS communication appear to rule out the vehicle, the engine controllers, the ROD files used by desktop VCDS, and the interface hardware generally.
Related reports:
Thread 52209 appears particularly relevant:
https://forums.ross-tech.com/index.php?threads/52209/
That thread describes missing VCDS-Mobile ROD coverage while using CodeBlock 0.4713 and Dataset 00000066—the same versions currently reported by my HEX-NET. Ross-Tech temporarily enabled an alpha/test update for that interface, and the user subsequently reported restored ROD coverage and working Advanced Measuring Values.
I also found these related reports:
https://forums.ross-tech.com/index.php?threads/56351/
https://forums.ross-tech.com/index.php?threads/51560/
https://forums.ross-tech.com/index.php?threads/51373/
https://forums.ross-tech.com/index.php?threads/46860/
Thread 46860 describes a workaround involving starting a Mobile Auto-Scan, cancelling its update, and immediately running the Windows update without power-cycling the HEX-NET. I cannot practically perform that exact sequence because my currently working Windows VCDS installation is on a desktop PC located away from the vehicle.
Could you please check:
  1. Are the two ROD files listed above present in the VCDS-Mobile dataset supplied to my interface?
  2. Is there a known ROD indexing, dataset-cache, or update-channel problem affecting CodeBlock 0.4713 / Dataset 00000066?
  3. Do you recommend switching HN3-000xxx to the Beta channel before further diagnosis, or would you prefer to review its logs and current state first?
  4. Can HN3-000xxx be placed temporarily on the applicable alpha/test channel, or receive the HEX-NET3 equivalent of the fix supplied in thread 52209?
  5. Is the Audi R8 4S/FX Auto-Scan chassis definition absent from the current VCDS-Mobile build?
  6. Is there anything further I can do locally, or does this require a server-side dataset or firmware/codeblock correction?
My immediate goal is to use VCDS-Mobile from a phone to view and log EGT, lambda, and related measuring values from Addresses 01 and 11 during cold starts and driving. Longer term, I also want read-only access to adaptation and channel inventories from the vehicle’s other controllers.
pwickersham
Seattle, WA, USA
C?ID=667593
Wednesday,09,September,2026,12:07:26:50436
VCDS Version: 26.9.0.3 (x64)  HEX-NET3 CB: 0.4713.5
VIN: WUAKBAFX5H7901447   License Plate:
Chassis Type: FX-AU72 (4S0)
Scan: 01 02 03 05 06 08 09 11 31 15 16 17 19 1B 20 22 36 3B 42 44
          46 52 53 55 5F 65 6C 81 A6 C2
VIN: WUAKBAFX5H7901447   Mileage: 64673km-40185miles
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPA)       Labels:. 07L-907-552-V1.clb
   Part No SW: 4S0 907 552 BC    HW: 4T0 907 552 A
   Component: V10 5.2l FSI  H56 0001
   Revision: NHH56---    CVN: 6CC5D91B
   Coding: 1A2500320526000D3000
   Shop #: WSC 26288 004 1048576
   VCID: 78A1B741D25F1B8ADF0-802C
   VINID: 9E545B4915A81581C90011041C323F40EF
30817 - EGT Sensor 1
          P108C 00 [00100000] - Temperature too High
                    Mileage: 64381 km
                    Date: 2026.09.07
                    Time: 10:42:32
                    Engine speed: 1379.00 /min
                    Normed load value: 38.8 %
                    Coolant temperature: 20 ∞C
                    Intake air temperature: 23 ∞C
                    Voltage terminal 30: 13.360 V
                    Exh Dvt t Eng Bay: 0.0 ∞C
                    Exh Dv T t Snsr Mdl Eng Bay Fild: 23.7 ∞C
                    Exh T Snsr t Val Sent Snsr Plus Offs: 120.4 ∞C
                    Engine status: COENG_RUNNING
11104 - Sensor 1 for Exhaust Temp Bank 1 (G235)
          P0544 00 [11101101] - Circuit Malfunction
                    Mileage: 64381 km
                    Date: 2026.09.07
                    Time: 10:42:32
                    Engine speed: 1378.50 /min
                    Normed load value: 37.3 %
                    Coolant temperature: 25 ∞C
                    Intake air temperature: 25 ∞C
                    Voltage terminal 30: 13.340 V
7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
          P2096 00 [01101000] - Too Lean
                    Fault Frequency: 11
                    Mileage: 63491 km
                    Date: 2026.09.02
                    Time: 14:31:11
                    Engine speed: 2638.50 /min
                    Normed load value: 27.5 %
                    Vehicle speed: 54 km/h
                    Coolant temperature: 93 ∞C
                    Voltage terminal 30: 12.920 V
Address 02: Auto Trans (J217)       Labels: 0BZ-927-711.clb
   Part No SW: 4S0 927 155 A    HW: 0BH 927 711 F
   Component: AU 7G D   NAR H10 3709
   Revision: 00H10V01    CVN: C1816BD7
   ASAM Dataset: EV_TCMDL800041 001013
   ROD: EV_TCMDL800041_AU72.rod
   VCID: 353F7E7585CD26E2046-8060
   Part No SW: 4S0 907 379 A    HW: 4S0 907 379 A
   Component: ESP PREMIUM   H09 0210
   Coding: 21A88109841581904B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004048
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 3B2B684DA3E9F092F22-806E
   Part No SW: 4H0 907 064 GD    HW: 4H0 907 064 GD
   Component: BCM2 2.0      H37 0572
   Coding: 0D806006000000000000
   VCID: 71B78A65B1A54AC218E-8024
   Serial number: 3216000036446007
   Part No SW: 4S0 959 760     HW: 4S0 959 760
   Component: MEM-BFS       001 0010
   Revision: AA001002    Serial number: 00000172178896
   Coding: 00001000000420F1000001210101210000000000000000
   VCID: 7BABA84DE3E93092B22-802E
   Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
   Component: AC Automat    H08 0040
   Revision: 20012000    Serial number: 96800000002714
   Coding: 4000A01000000410
   ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
   ROD: EV_AirCondiVAPrehAU72x.rod
   VCID: 333B406D8BB938D22A2-8066
   Rear A/C Control Head 2:
   Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Serial number: 00000000000000003860
   Rear A/C Control Head 3:
   Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Rear A/C Control Head 4:
   Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Part No SW: 4H0 907 063 GK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H20 0369
   Revision: 25020001    Serial number: 00001330541101
   Coding: 010D0011143C9FF0750048C380003800C59CD2882A08322100040894F1001100006000340B0000
   VCID: 77A3B47DDFC114F2D6A-8022
   Subsystem 1 - Part No SW: 4S1 955 119     HW: 8V2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS624 160401  043 0071
   Serial number: 90248139160405065801
   Coding: 3247FD
   Serial number: 61626387
   Coding: 02005D
   Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
   Component: E1 - LDS  H01 0044
   Serial number: 06 04 2016  00000858
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z023641AF
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: 3F59491800PAG0MUFU01
Address 11: Engine II (-----)       Labels:. 07L-907-552-V1.clb
                    Mileage: 63808 km
                    Date: 2026.09.04
                    Time: 12:11:27
                    Engine speed: 1377.50 /min
                    Voltage terminal 30: 13.380 V
                    Exh T Snsr t Val Sent Snsr Plus Offs: 123.8 ∞C
22437 - Sensor 1 for Exhaust Temp Bank 2 (G236)
          P0547 00 [11101101] - Circuit Malfunction
                    Mileage: 63808 km
                    Date: 2026.09.04
                    Time: 12:11:27
                    Engine speed: 1382.00 /min
                    Normed load value: 36.9 %
30940 - Oxygen (Lambda) Sensor B2 S2
          P014A 00 [01101000] - Delayed Response Rich to Lean
                    Mileage: 64400 km
                    Date: 2026.09.07
                    Time: 11:35:01
                    Engine speed: 2542.00 /min
                    Normed load value: 25.9 %
                    Vehicle speed: 66 km/h
                    Intake air temperature: 29 ∞C
                    Voltage terminal 30: 13.120 V
13488 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
          P2098 00 [11101101] - Too Lean
                    Mileage: 64091 km
                    Date: 2026.09.05
                    Time: 19:49:18
                    Engine speed: 2499.00 /min
                    Normed load value: 32.9 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 66 ∞C
                    Intake air temperature: 27 ∞C
                    Voltage terminal 30: 14.360 V
   Part No SW: 4S0 959 655     HW: 4S0 959 655
   Component: Airbag10.43   H62 0203
   Revision: --------    Serial number: 003NJ0012GBW Dataset Number: 4S0909602D  0005
   Coding: 30333845303530303731554A304C34533053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001034
   VCID: 7EADA159F07B25BA95C-802A
   Seat occupant detection:
   Serial number: 6940000Y160001GKKB0%
   Serial number: 3575HRB400I55BE6CA6.
   Serial number: 3585HRB40573VRKK70D+
   Serial number: 3515JRB400855COAHHEF
   Serial number: 3525JRB400855COAI1UH
   Serial number: 3554VRB401G5570AIA1Y
   Serial number: 3564VRB401G5570AA1Q0
   Part No SW: 4S0 907 129 K    HW: 4S0 907 129 K
   Component: Lenks.Modul   H06 0006
   Revision: C0071527    Serial number: 91335PD700177-
   Coding: 000034
   VCID: 3E2D6159B07BE5BAD5C-806A
   Part No SW: 4S0 920 890     HW: 4S0 920 890
   Component: FBenUSA       H14 0228
   Coding: 086F32C1AA81D7050230ECC41800001000000000
   ASAM Dataset: EV_DashBoardBOSCHAU724 001020
   ROD: EV_DashBoardBOSCHAU724.rod
   VCID: 73BB806DCB3978D2EA2-8026
   Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
   Component: J533--Gateway H15 0074
   Revision: --------    Serial number: 00000002192020 Dataset Number: 4S0909515A  0025
   Coding: 802103161C
   GVL: FF91CD88DC0A200180640000
   Control module for battery monitoring:
   Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
   Component: J367-BDM  H08 0270
   Serial number: 63082N53543371775997
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Revision: 52001005    Serial number: --------------
   Coding: 0D0000
   VCID: 3A256D49AC53C99AE94-806E
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 4S0 857 511 A    HW: 8S0 857 511 D
   Component: FLA           H09 0003
   Revision: AB001001
   Coding: 0404001D00010001000001
   ASAM Dataset: EV_HighBeamAssisAU724 001007
   ROD: EV_HighBeamAssisAU724_AU72.rod
Address 22: AWD (J492)       Labels: 4T0-907-160.clb
   Part No SW: 4S0 907 160     HW: 4S0 907 160
   Component: 4 Wheel Drive H07 0207
   Revision: 00001002    Serial number: BBNR32H        Dataset Number: 4S0909104B  0007
   ASAM Dataset: EV_AllWheelContrBORGLB724 006012
   ROD: EV_AllWheelContrBORGLB724.rod
   VCID: 6E8D9119A01B553A05C-803A
   Component: MEM-FS        001 0010
   Revision: AA001002    Serial number: 00000172189717
   Coding: 00181900000420F1C00001210101210000000000000000
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02481U Dataset Number: 4S0909573A  0002
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3723747D9FC1D4F216A-8062
   Component: TSG FA        H03 0511
   Coding: 011C53425000000300000402
   VCID: 47C304BDEFA1A47266A-8012
Address 44: Steering Assist (J500)       Labels:| 4S0-909-144.clb
   Part No SW: 4S0 909 144 G    HW: 4S0 909 144 B
   Component: EPS           H13 0904
   Revision: 00000000    Serial number:      L00132803
   Coding: 0903
   ASAM Dataset: EV_EPSZFAU72X 002010
   ROD: EV_EPSZFAU72X_002_AU72.rod
   VCID: 39277245A9D5C282E0E-806C
   Revision: 00002001    Serial number: 0401175365
   Coding: 0106029A00F24081E0B0CC00008500000001000000000000000000000000
   Subsystem 1 - Part No SW: 4S0 959 719 A    HW: 4S0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20160217190558 00141
   Component: TSG BF        H03 0511
   Coding: 011C53425E00000300000400
   VCID: 46DD09B9E8ABBD7A9DC-8012
   Part No SW: 4S0 907 801     HW: 8K0 907 801 J
   Component: EPB-4         H03 0001
   Revision: --------    Serial number: 30000000001747
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70B18F61BA2F43CA170-8024
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Revision: --------    Serial number: -------------- Dataset Number: 4S0909865C  0010
   Coding: 077A081122600400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
   VCID: 363D797998CB2DFA0DC-8062
   Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0008
   Coding: E02200
   Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0008
   Coding: E02200
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 4S0 035 025 K    HW: 4S0 035 025
   Component: MU-H-LNS-US   051 0383
   Serial number: A353D0GB000876 Dataset Number: 4S0909545E  0020
   Coding: 012704020000000013220002041A00102F0000E1007000047E
   ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
   ROD: EV_MUHig6C8Gen2HBAS.rod
   VCID: 31374A6571A50AC258E-8064
   Subsystem 1 - Part No SW: V03 959 801 GE    HW: -----------
   Component: NAR 2016  --- 0048
   Subsystem 2 - Part No SW: 4S1 919 614     HW: 4S1 919 614
   Component: ControlUnit_H  H23 0136
   Serial number: APVAK103031600010011
   Compact disc data bank:
   Component: Gracenote2  --- 3008
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0900
   Serial number: 10000000026154 Dataset Number: 4S0909850A  0005
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU72.rod
   VCID: 2C095B115687672A6B8-8078
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Dataset Number: 4S0909460A  0008
   Coding: 022704010A01000100
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 3235456974A331DA214-8066
   Part No SW: 4S1 713 041 B    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20160323001362
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 2A055D095C73791A994-807E
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394 A    HW: 420 907 394
   Component: BELTMICBOX    H10 0600
   Coding: 0101030202
   ASAM Dataset: EV_BeltMicPARAGAU335 003011
   ROD: EV_BeltMicPARAGAU335.rod
   VCID: 176394FDFF01F4F236A-8042
Address C2: Auto Trans 2 (J217)       Labels:. 0BZ-927-109.clb
   Part No SW: 4S0 927 109     HW: 4S0 927 109
   Component: DL800 ZSG     H11 0002
   Revision: --H11---    Serial number: 0000000021 CVN: 0000CB9C
   ASAM Dataset: EV_TCMDL800421 001024
   ROD: EV_TCMDL800.rod
End----------(Elapsed Time: 02:03, VBatt start/end: 12.0V/12.1V)-----------
------------------------------7 Faults Found-------------------------------
Shaun
Those rod files should be available on the server. There have been a couple fixes related to ROD files in an updated codeblock on the alpha testing channel, it might be good to try this and see if the problem is already fixed in source. If you are willing to test the latest stuff, please let me know and I will switch your interface to the alpha channel.
pwickersham
Seattle, WA, USA
C?ID=667593
I’d be willing to test the alpha channel. Before switching, will the alpha codeblock affect both Windows VCDS and VCDS-Mobile functionality, or only VCDS-Mobile? Also, can the interface be returned to the release channel if necessary?
Shaun
It can yes. Though these specific updates are mostly focused on VCDS-Mobile.
It will automatically return to the release channel in a couple of weeks, so you will eventually be back in sync with the regular release schedule. But you will still have any alpha updates you downloaded ahead of the general public.
pwickersham
Seattle, WA, USA
C?ID=667593
ok. that sounds good. Let me know when switched. thank you
Shaun
I switched your interface to the alpha channel. If you check for updates with VCIConfig you should see a codeblock update for CB 0.4717
Please give that a try and see if mobile works better.
pwickersham
Seattle, WA, USA
C?ID=667593
I installed the alpha update on HN3-000xxx through VCIConfig on the Windows desktop. The update completed successfully, and VCIConfig subsequently reported that the interface was up to date.
Afterward, the HEX-NET’s previous network configuration was no longer available, so I reconfigured the device and set up its infrastructure Wi-Fi connection again.
I then returned the interface to the R8 and performed the following steps in this order:
  1. I first ran a complete Auto-Scan using Windows VCDS.
  2. I then opened VCDS-Mobile.
  3. In VCDS-Mobile, I used Select → 01 Engine because I wanted to view the engine fault codes.
  4. VCDS-Mobile displayed “No ASAM data found locally.”
  5. VCDS-Mobile found an ASAM update, downloaded it, and completed the installation.
  6. I selected Address 01 Engine again.
  7. VCDS-Mobile displayed the same “No ASAM data found locally” message and offered the update again.
Address 01 uses:
Before installing the alpha update, the same problem also affected Address 11 Engine II:
During this post-update Mobile test, I checked only Address 01.
The behavior after installing the alpha update is unchanged for Address 01: the requested ASAM/ROD data appears to download and install successfully but is not subsequently recognized or made available to VCDS-Mobile.
TTT
C?ID=547002
Why would you put your interface serial number public, when ross tech tries to obfuscate them. :banghead:
pwickersham
Seattle, WA, USA
C?ID=667593
I saw nothing saying not to and just coughed up all the info i imagined would be needed for support
I have redacted it now
TTT
C?ID=547002
Ross tech probably already has your serial, how otherwise would they put your dongle to alpha. ... Being Verified means your dongle serial is coupled to your account. You don't want clones to have your serial isn't it?
pwickersham
Seattle, WA, USA
C?ID=667593
This is my first odb reader ever as i am getting into the car community later in life. Had no idea what cloning even meant until just researching now. My quick read of how the latest HEX-NET authentication works suggests cloning is no longer so easy (hopefully). Regardless, I appreciate the feedback even though i'm sure mine is now happily cached on internet search engines :facepalm:
Reactions: TTT
TTT
C?ID=547002
For you to know, hex-net already has been cloned.
Very poorly, and it took them many years to do that.
Also, it takes far more than a serial number to clone an interface, but we still prefer serial numbers not to be posted.
pwickersham
Seattle, WA, USA
C?ID=667593
Good to know. I swear i looked everywhere on rules on posting and never saw anything about this. happy to follow for future postings, though
Shaun
Ok, let me do some testing with that ROD file. If I don't get back to you by later in the week feel free to bump this thread and remind me.
Shaun
So I tested loading that ROD file on one of my debug interfaces using the data from your controller, and mobile loads it up fine for me. Sometimes not reading the VIN correctly is known to cause issues with finding ROD files, but in this case mobile is able to find the right file even without a VIN. So I'm scratching my head a little now trying to understand the issue you are seeing, it may be something to do with the comms to that ECU that I can't easily simulate. If you want to help debug this further, I think the next step is to make a debug log in mobile so that I can try to see what is happening between your interface and that ECU.
To make a debug log, in VCDS-Mobile:
[Options]
Debug Level: 003F
[Submit]
[Done, Go Back]
[Select]
[01 - Engine]
Give it a couple seconds to talk to the module, then [Done, Go Back].
[Done, Go Back]
When you are back on public internet.
[View Saved Files]
Find the debug log this generated and make sure it is synced to cloud, then please send us the docid.
pwickersham
Seattle, WA, USA
C?ID=667593
Ok. Selected both [01 - Engine] and [11 - Engine ll]
docid :
0000-B98B
Reactions: TTT
Shaun
Ok the debug log shows the interface retrieving the ASAM ID correctly, the comms look good, but then it fails to find the ROD file. So I think the next thing to check is to verify if the ROD file is actually present on the interface. This can be a little complicated, there's two ways to do this:
Option 1: Open the interface and remove the SD card and read it with anything that can read a micro SD card.
Option 2: Check for updates again with VCIConfig and when it goes to write the files to the interface force close VCIConfig, you should then see the interface mounted to the PC as a drive and you can access the files.
In either case once you can access the files, create an archive like a .rar or .zip of the rods directory, and email it to Support@Ross-Tech.com, you can reference this thread in the email.
