No Main Gauge Lights with Headlights ON
Supermoto65
Charlotte, NC, USA
C?ID=641192
2014 S4 Prestige
So ... when I first got VCDS I went a little crazy changing stuff like lighting etc. I did not save a backup. I made several changes. Some that worked and others did not. I do not remember everything I changed and now I have an issue with the main gauge cluster lights.
Symptoms: When headlight switch is in Auto ... Gauge Cluster Lights work. When turning on fog lights (while headlight switch is in Auto) or turning headlight switch to manual on the Gauge Cluster Lights turn off.
Already tried replacing the light switch with same result.
I am fairly sure I messed something up with VCDS but i do not know where to look.
Can I upload a file from VCDS that someone more knowledgable here could take a look at and point me in the right direction?
Well... there are adaptation and coding logs that might've captured whatever rawdogging you did..... not sure why you'd make lots of changes at the same time, or why you wouldn't do a backup first.... but YOLO
Been here?
Supermoto65
Charlotte, NC, USA
C?ID=641192
Been here?
No and I wish I would have looked it up sooner. I changed computers since and nothing there that will help. I think I also made some changes with OBD11 as well. Would an autoscan log help? I don't see anything in them like the examples in the changes files at that link. I'll probably just start going through the things I remember changing one by one and see what happens. Doing a backup for sure first.
