2024 audi Q3 autoscan
bigpauly33
C?ID=82875
Need to reset inspection due. Locked out; I hope I did this correctly.
VIN: WA1EECF3XR1189400   License Plate: TANYA
Mileage: 19719km-12252mi   Repair Order:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 2B 36 3C 42 44 4B 52 5F
          6C 6D 75 A5 BB BC CA CF D6 D7 DE
VIN: WA1EECF3XR1189400   Mileage: 19719km-12252miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DSNA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 83A 906 259 G    HW: 06K 907 425 J
   Component: R4 2.0l TFS   H13 0003
   Revision: --H13---    CVN: 7F892D8F
   Coding: 0A2A00122466010F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS02083A906259G 001005
   ROD: EV_ECM20TFS02083A906259G.rod
   VCID: 323673B8B4ABB7DA214-8066
   VINID: 9D1055553583A220412091000067F0A521
21423 - Secondary Air Injection System Switching Valve Bank 1
          P2440 00 [01100000] - Stuck Open
Address 02: Auto Trans (J217)       Labels: 09P-927-749-V1.clb
   Part No SW: 09G 927 158 HD    HW: 09G 927 158
   Component: AISIN AQ8     206 4071
   CVN: A093B105
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 7CAA9D80266FB1AABB8-8028
Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb
   Part No SW: 5QA 614 517 BB    HW: 5QA 614 517 B
   Component: ESC           H34 0664
   Serial number: 61954000011772  Dataset Number: F30909504LA 0002 CVN: CC33A56C
   Coding: 8C98556CA052839C200955BC9C0542E404007664892000
   ASAM Dataset: EV_Brake1ESCMQB37CLASS 008020
   ROD: EV_Brake1ESCMQB37CLASS.rod
   VCID: 0358E67C5B91CE52FA2-8056 SFD+SFD2 [x]
16401 - Tire Pressure Warning
          C102D 00 [00100000] - -
   Part No SW: 3Q1 959 435 C    HW: 3Q1 959 435 C
   Component: VWKESSYMQB    037 1501
   Revision: 00037000    Serial number: 0647383107 Dataset Number: 83A909577A  0006
   Coding: 0F00000723
   ASAM Dataset: EV_KessyHellaMQBAB 004056
   VCID: 3B285E9C63E17692F22-806E
   Power rear lid opening control module:
   Subsystem 1 - Part No SW: 3G0 962 243 D    HW: 3G0 962 243 D
   Component: GEB.F.Heckoef  H17 0908
   Serial number: 45317674
   Part No SW: 83A 820 043 AJ    HW: 83A 820 043 AJ
   Component: AC Automat    H04 0085
   Revision: 20026000    Serial number: 00000001746067 Dataset Number: 83A909862D
   Coding: 070000240100000010011000000014000000000000000000
   ASAM Dataset: EV_AirCondiFrontVaAU326 001011
   ROD: EV_AirCondiFrontVaAU326.rod
   VCID: 6882D1D042F70D0A4F0-803C
   Humidity sensor: exterior:
   Subsystem 1 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H06 0012
   Serial number: C38617AC00PAG0MUFU04
   Part No SW: 5Q1 937 085 B    HW: 5Q1 937 085 B
   Component: BCM MQBAB HLN H50 0618
   Serial number: 04102418600367 Dataset Number: 83A909514J  0079
   ASAM Dataset: EV_BCMMQB 023001
   ROD: EV_BCMBOSCH_023.rod
   VCID: 3924449469DD4482E0E-806C SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 83B 955 119 B    HW: 83B 955 119
   Component: J400FRWISCH  063 0051
   Serial number: 890153F0302417800866
   Coding: 5DC72F
   Component: G397_RLFSS  H06 0004
   Serial number: 23842964X81A955555B0
   Coding: 00005D
   Subsystem 3 - Part No SW: 4K1 941 501 N    HW: 4K1 941 501 N
   Component: E1 - LTM  H07 0060
   Serial number: 21S09.07.2400301277
   Subsystem 4 - Part No SW: 5Q0 951 177 C    HW: 5Q0 951 172 C
   Component: Sensor, DWA  006 0501
   Serial number: 0000000000000Q3DL64M
   Serial number: 00000000000042742314
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 NF    HW: 5Q1 953 549 E
   Serial number: 00000001072420240805
204290 - Remote key 1
          B1479 18 [00001001] - Current Too Low
                    Reset counter: 54
                    Mileage: 10232 km
                    Date: 2025.12.08
                    Time: 15:26:20
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 12.8 V
                    Outside temperature: 9.0 ∞C
204546 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 60
                    Mileage: 19113 km
                    Date: 2026.08.29
                    Time: 08:06:25
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 12.5 V
                    Outside temperature: 19.5 ∞C
   Part No SW: 5QA 919 294 L    HW: 5QA 919 294
   Component: PDC 8 Kanal   H12 0083
   Serial number: 000150058324179 Dataset Number: 83A909526F  0006
   Coding: 8471255811
   ASAM Dataset: EV_EPHVA18AU3700000 010058
   ROD: EV_EPHVA18AU3700000_010_AU37.rod
   VCID: 55FCE824E58580E2E46-8000
   Part No SW: 2Q0 907 567 B    HW: 2Q0 907 819
   Component: ACCCONTIMQB   H03 0534
   Dataset Number: 83A909863S  0013
   Coding: B00007D21CF78728747C61448040A700000000000000000024
   ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
   ROD: EV_ACCMRRCONTIUNECEMQB_AU37.rod
   VCID: 372042AC5FC952F216A-8062 SFD+SFD2 [x]
   Part No SW: 5Q0 959 655 BQ    HW: 5Q0 959 655 BQ
   Component: AirbagVW21    011 0421
   Serial number: 003FKRBL90R4 Dataset Number: 83A909602L  0005
   Coding: BFCCFCC000000000A000001FC248000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
   VCID: 1072D9301AE7A5CA770-8044
   Left seat belt tensioner:
   Component: BeltPretRevFL  506 1062
   Serial number: 83A857705L0191Y01326
   Coding: 802006
   Right seat belt tensioner:
   Component: BeltPretRevFR  506 1062
   Serial number: 83A857706L0192Y00654
   Coding: 802006
   Component: BF-Gewichtss.  H15 0022
   Serial number: IBH00000000000MSOAPQ
   Coding: 303032
   Subsystem 4 - Part No SW: -----------    HW: 480 002 706 24
   Serial number: 357000000007522CA07H
   Subsystem 5 - Part No SW: -----------    HW: 480 002 706 24
   Serial number: 358000000004522CA07F
   Subsystem 6 - Part No SW: -----------    HW: 480 402 706 24
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001D83142754409R
   Subsystem 7 - Part No SW: -----------    HW: 480 402 706 24
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B115BA7962671
   Subsystem 8 - Part No SW: -----------    HW: 480 401 505 24
   Component: FrontSensor_D  003 6149
   Serial number: 3550001BAAFE0F44F81Z
   Subsystem 9 - Part No SW: -----------    HW: 480 401 505 24
   Component: FrontSensor_P  003 6149
   Serial number: 3560001B8AFE0F4411BN
   Part No SW: 83A 920 890 L    HW: 83A 920 890 H
   Component: FBenUSA------ H03 0039
   Coding: 0A462A576D88CF050280E8401800030008000000
   ASAM Dataset: EV_DashBoardFPK2AU326 002045
   ROD: EV_DashBoardFPK2AU326.rod
   VCID: 343A75A04EBFB9EA338-8060 SFD+SFD2 [x]
   Part No SW: 3Q0 907 530 BB    HW: 3Q0 907 530 BA
   Component: GW 2023 CLA   542 5555
   Revision: --------    Serial number: CU5SIB160724009 Dataset Number: 83A909515L  0014
   Coding: 0000808D0F00000000000000000000325302200103000100030000000001010000000000000000000000000000000000
   GVL: 3D000800060040DC80000002C8001004000000020000000000000000000000C6
   ASAM Dataset: EV_GatewMQB2020Class 001001
   ROD: EV_GatewMQB2020Class_VW27.rod
   VCID: 70B2B9B07A27C5CA170-8024 SFD+SFD2 [x]
   Generator:
   Component: 5-01-14-01-04
   Subsystem 2 - Part No SW: 5QA 915 181 D    HW: 5QA 915 181 D
   Component: J367-BDMHella  H11 9070
   Serial number: 6439564606
   Subsystem 3 - Part No SW: 83A 951 523 J    HW: 83A 951 523 J
   Component: J453 MFL       H07 0004
   Serial number: 20240418095121 30819
   Subsystem 4 - Part No SW: 8Y0 419 508     HW: 8Y0 419 508
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230201213093
8417280 - Diagnostic Filter
          U17A0 00 [00100000] - Not Activated
          [Filter_is_not_active]
                    Fault Frequency: 0
                    Reset counter: 0
   Part No SW: 5WA 907 554 R    HW: 5WA 525 130
   Component: 4Motion       H66 2020
   Serial number: 000022.05.24000 Dataset Number: 83A909104A  0001
   Coding: 0101
   ASAM Dataset: EV_AllWheelContrHA1VW37X 006001
   ROD: EV_AllWheelContrHA1VW37X_006_VW27.rod
   VCID: 5DECF0049DB558A2AC6-8008
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000176323007 Dataset Number: 81A909564C  0005
   Coding: 0808000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F15062B7ED0AAF0-805C SFD+SFD2 [x]
   Part No SW: 8Y4 959 760     HW: 8Y4 959 760
   Component: MEM-FS        011 0372
   Serial number: 2461401KA04337 Dataset Number: 83A909856B  0005
   Coding: 015C1A000000B0010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_AU37.rod
   VCID: 0944F45479BD9402B0E-805C
   Part No SW: 3Q0 907 566 L    HW: 3Q0 907 566
   Component: MRR1Rear      H27 0550
   Revision: --------    Dataset Number: 83A909535B  0009
   Coding: 06C002
   ROD: EV_RearRadarS1BoschVW48X_AU37.rod
   VCID: 41D42C74010D1C42A8E-8014
1188157 - Databus
          [databus unreasonable message - Perso_Status]
                    Reset counter: 54
                    Mileage: 10231 km
                    Date: 2025.12.08
                    Time: 15:05:11
                    Control Module temperature: 36 ∞C
                    Voltage terminal 30: Measuring value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measuring value not available
                    Voltage terminal 15: 14.50 V
   Part No SW: 8Y0 959 593 M    HW: 8Y0 959 593 M
   Component: TSG FS        002 0363
   Serial number: YE007XFN01209 Dataset Number: 83A909872D  0030
   Coding: 001E9B005E00108000010032
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
   VCID: 56FEEF28F8838BFAEDC-8002
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 5QS 907 145 E    HW: 5QS 907 145
   Component: BASGEN1MQB37  503 1122
   Serial number: 03498232 Dataset Number: 83A909852AE 0005
   Coding: 01000000010000010001020101000100000001010100
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017.rod
   VCID: 58E2E110F297BD8AFF0-800C SFD+SFD2 [x]
   Part No SW: 3Q0 907 338 P    HW: 3Q0 907 338 R
   Component: FCM MQB High  H09 0408
   Serial number: 06072410800457 Dataset Number: 83A909583F  0018
   Coding: 000000050900197200112303010000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiMQBCl 001009
   ROD: EV_MultiModulContiMQBCl_VW27.rod
   VCID: 42D62378040B075AB14-8016
   Part No SW: 5Q0 959 592 M    HW: 5Q0 959 592 M
   Component: TSG BFS       002 0363
   Serial number: YE007XFT17966 Dataset Number: 83A909873D  0030
   Coding: 001E9B005E00108000010030
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 4AC60B583C3BDF1A794-801E
   Part No SW: 82A 035 050 K    HW: 82A 035 050 A
   Component: MU-TH-NS-US   044 3841
   Serial number: GRO-63301.07.24 Dataset Number: 83C909545R  0034
   Coding: 13260000804000000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU27.rod
   VCID: 231886FCFB512E52DA2-8076
   Multimedia display unit 1:
   Subsystem 1 - Part No SW: 83A 919 620 A    HW: 83A 919 620 A
   Component: CenterDisplay  H40 0132
   Serial number: AUZ8ZHR2205N4K
   Subsystem 2 - Part No: V03 959 823 LN
   Component: MIB3_NA_       1466
   Compact disc data bank:
   Component: Gracenote2     3007
   Volume Control 1:
   Subsystem 4 - Part No SW: 83A 919 616 A    HW: 83A 919 616
   Component: LSR-D5/C8      H33 0110
   Serial number: 00008324000100141051
   Media socket:
   Digital Sound System Control Module 2:
   Subsystem 6 - Part No SW: 8Y0 035 465 A    HW: 8Y0 035 465 A
   Component: B_A_3_P_0_AU   H11 0100
   Serial number: HHA-07311.06.2442960
5529 - Secure Control Modules; Internal Communication
          U15CA 00 [00001000] - Not Available
                    Reset counter: 105
                    Mileage: 19701 km
                    Date: 2026.09.05
                    Time: 12:38:35
                    Voltage terminal 30: 12.5 V
   Part No SW: 83A 907 428 E    HW: 83A 907 428 D
   Component: Areaview 2    H34 0062
   Serial number: C855611JA003354 Dataset Number: 83D909460F  0019
   Coding: 02230602A20FA10038004004
   ASAM Dataset: EV_CamSysRVAV2CE2AU326 002001
   ROD: EV_CamSysRVAV2CE2AU326_002.rod
   VCID: 2F307ACCA7999A324EA-807A
   Part No SW: 5WB 959 107 B    HW: 5WB 959 107 B
   Component: HDSG-Modul    H08 0442
   Revision: --------    Serial number: A2-C767-1201-9 Dataset Number: 83A909541F  0015
   Coding: 2928
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
   VCID: 4FF01A4CC759FA322EA-801A
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 285 C    HW: 5WA 035 285
   Component: OCUGen3High   H14 0322
   Serial number: 0000000403VIAXB Dataset Number: 83A909612N  0023
   Coding: 013260201FE82C009025460120012E07
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 47C0326C2F29227266A-8012
   Part No SW: 2Q0 980 653 G    HW: 2Q0 980 653 A
   Component: MQB MFK 3.0   H19 1505
   Serial number: ED3659911241760 Dataset Number: 83B909466A  0018
   Coding: 00040A88216E4024089F10000020002000410000E00000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007057
1126517 - Databus
          [ACC_06_ACC_Status_ACC_reversibel_ERROR]
                    Mileage: 19719 km
                    Date: 2026.09.06
                    Time: 16:20:57
1126434 - Front Camera for Driver Assist Systems
          C12B3 FD [00001000] - View Temporarily Restricted
          [Temporary blindness of lane detection]
                    Reset counter: 27
                    Mileage: 18914 km
                    Date: 2026.08.29
                    Time: 06:02:18
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q0 959 595 M    HW: 8W1 959 595 K
   Component: TSG HFS       006 0363
   Serial number: YE007XFS1475E Dataset Number: 83A909897D  0030
   Coding: 000E9B004000108000000020
   ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
   VCID: 4DCC0044CD55C8225C6-8018
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS      006 0363
   Serial number: YE007XFS13347 Dataset Number: 83A909896D  0030
   ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
   Part No SW: 4K8 907 594 AC    HW: 4K0 907 594
   Component: SAD_STG_1     010 0010
   Dataset Number: 83A909469E  0013
   Coding: 228040032602
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 7DAC90843D75B8A28C6-8028
   Part No SW: 3Q0 907 590 L    HW: 3Q0 907 590
   Revision: --------
   Coding: 06C002
   ROD: EV_RearRadarS2BoschVW48X_AU37.rod
   VCID: 3E2E578870F363BAD5C-806A
   Part No SW: 4K0 941 572 CG    HW: 4K0 941 572 C
   Component: LMS_MQB       H20 0133
   Dataset Number: 83A909471F  0015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 75BC88A40545E0E2C46-8020
   Dataset Number: 83A909472F  0015
Address DE: Charger 1 for mobile dev (J1146)       Labels:| 4N0-035-502.clb
   Part No SW: 4N0 035 502 B    HW: 4N0 035 502 B
   Component: WLC Front     H14 0061
   Dataset Number: 4N0909485A  0007
   Coding: 400080
End----(Elapsed Time: 02:19, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
------------------------------9 Faults Found-------------------------------
Have you tried applying for/ordering SFD Service? Although the Service itself remains in Beta for a bit yet, orders are no longer restricted to systems eligible for a free year.
