Golf r, 2016. Can vcds help with my back up camera intermittenly not working
tedsung44
C?ID=666808
I was curious if VCDS could help me with an intermittent issue I have where my back camera view does not appear when I put the car into reverse.
I've tried to be systematic to see if occurs with or without the radio or CD on but it seems pretty random and happens about once a week.
Any ideas how to diagnose what could be the issue? Is it possibly some software issue?
Thanks, Ted
Below are the results of my autoscan.
Tuesday,01,September,2026,20:01:13:12879
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.5
VIN: License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
VIN:  Mileage: 131816km-81906miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 91CDE70D
   Coding: 091D00122426000E3004
   Shop #: WSC 28905 004 1048576
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001002
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 45D0B14B7522C2D2946-8010
   VINID:
21400 - Valve for Exhaust Flap 2 (N322)
          P3022 00 [00101111] - Short to Ground
                    Mileage: 131762 km
                    Date: 2026.08.19
                    Time: 13:46:05
                    Engine speed: 706.50 /min
                    Normed load value: 3.5 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 13.886 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: CL
                    T_AST_SAE: 7 s
                    MAP_MES_SAE: 30 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
                    FAC_TPS_1_SAE: 12.500000 %
                    FUP_H_SAE: 2960.0 kPa
Readiness: 0000 0100
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4904
   Revision: 06253104    Serial number: TFK01511262144 CVN: 0000DBBB
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53F49F138B766C620A2-8006
8 Faults Found:
21153 - Gear 1
          P072C 00 [00000010] - Not Selectable
21154 - Gear 2
          P072D 00 [00000010] - Not Selectable
21155 - Gear 3
          P072E 00 [00000010] - Not Selectable
21156 - Gear 4
          P072F 00 [00000010] - Not Selectable
21159 - Gear R
          P072B 00 [00000010] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [00000010] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [00000010] - Electrical malfunction
10906 - Cooling Oil Valve
          P179D 00 [00000010] - Electrical Malfunction
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 60136000000570
Coding: 01FA6BA154230971057D030941CA6980D62A90A0C08296B700400058C208
   VCID: 79A80DBB495A7632A0E-802C
16401 - Tire Pressure Warning
          C102D 00 [00001000] - -
                    Reset counter: 131
                    Mileage: 126843 km
                    Date: 2026.04.10
                    Time: 08:46:16
   Revision: 00021000    Serial number: 0391819917 Dataset Number: V03935197YW 0001
   Coding: 030C0C
   VCID: 3A2AD2B70CDCBD2AE94-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
Coding: 00020004200100000005000012111402
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A8A22F73CFCCDAA594-803E
   Air quality sensor:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
          B10F0 00 [00001000] - -
                    Reset counter: 209
                    Mileage: 131762 km
                    Date: 2026.08.19
                    Time: 13:20:55
                    Voltage terminal 30: 13.0 V
                    Compressor shut-off condition: Shut-off of engine control module via CAN (T > 15 sec.)
   Part No SW: 5Q0 937 085 AJ    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061601800577 Dataset Number: V03935231NH 0001
Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 0158655B218A2EF2E8E-8054
   Component: WWS    160105  043 0551
   Serial number:         160117033321
   Component: RLHS  037 0059
   Serial number: S3Y16M02D02H05M23S58
   Coding: 90A8DD
204546 - Remote key 2
          B147A 18 [00001001] - Current Too Low
                    Reset counter: 65
                    Mileage: 123734 km
                    Date: 2026.01.05
                    Time: 13:32:20
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Position lamps: Not operated
                    Low beams: Not operated
                    Voltage: 12.3 V
                    Outside temperature: 4.0 °C
   Serial number: 003GCR04A8LF Dataset Number: V03935221QJ 0001
   VCID: 47CCBB434F2ED0C266A-8012
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003VLU68
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 002 701 16
   Serial number: 35700000000B2620B81D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 701 16
   Serial number: 35800000000791C4E81T
   Subsystem 4 - Part No SW: -----------    HW: 480 402 701 16
   Serial number: 3510002C11E85EA5B17E
   Subsystem 5 - Part No SW: -----------    HW: 480 402 701 16
   Serial number: 35200029F1EDD3E2304H
   Subsystem 6 - Part No SW: -----------    HW: 480 402 301 16
   Serial number: 3550002BF1E9F10151BD
   Subsystem 7 - Part No SW: -----------    HW: 480 402 301 16
   Serial number: 3560002BD1E9F10293EM
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 23011604220046
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 074C7B430FAE10C2A6A-8052
   Part No SW: 5G1 920 858 A    HW: 5G1 920 858 A
   Component: KOMBI         303 6420
Coding: 0BAD081A2B80CF0502082A001400000000000000
   VCID: 2E02EEE7C094618A45C-807A
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004424941 Dataset Number: 5G0067V____ 2407
Coding: 0101000838085900FB00022A1C0F00000001050000000000000000000000
GVL: 01D03C1000000600400C10008000C80000000000000000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29150002475110056012
   Coding: 31FFFF
   Serial number: HA1-00015.12.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   VCID: 4ACA82775C3C2DAA794-801E
   Revision: 00000000    Serial number: 16000012390007
   Coding: 5D00000000000000
   VCID: 3436FC8F2EB84B5A338-8060
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-DCD-V1.clb
   Serial number: 121215ELC00631 Dataset Number: 5G0222v____ 0068
   Coding: 003E13208000040000000000
   VCID: 43D4AF537B16FCE2BA2-8016
   Serial number: 00000000000008615112
   Coding: 111000
          B1487 54 [00001000] - Missing Calibration / Basic Setting
                    Fault Frequency: 18
                    Reset counter: 208
                    Mileage: 129483 km
                    Date: 2026.05.30
                    Time: 18:21:30
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Dataset Number: V03935226XD 0001
   Coding: 8102
   VCID: 3928CDBB09DAB632E0E-806C
   Serial number: 251115BKN0877A Dataset Number: 5G0157v____ 0064
   Coding: 003E13208000040000800000
   VCID: 42DAAA57640CF5EAB14-8016
   Serial number: 00000000000008670366
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0001
   Coding: 022A01010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40DEA05F6A00E7FAA70-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Serial number:                Dataset Number: 5G0CV1v____ 0001
Coding: 02730000FF00000051220001001808001F0207D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6C8624EF3608D39A2B8-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H43 4063
   Serial number: VWZ6Z9S0151397
                    Reset counter: 178
                    Mileage: 123601 km
                    Date: 2026.01.02
                    Time: 09:19:46
                    Voltage terminal 30: 13.1 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 133 mA
                    SDARS_tuner_status_2-Reception quality: good_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
6691 - Local Data Bus
          U10BA 00 [00001000] - No Communication
          [Sub-Bus keine Kommunikation]
                    Reset counter: 209
                    Mileage: 130772 km
                    Date: 2026.07.14
                    Time: 16:00:57
                    Voltage terminal 30: 13.7 V
                    Network diagnosis-Status: not enabled
Address 75: Telematics (J949)       Labels:| 5QE-035-28X-V1.clb
   Component: OCULowMQBUS   007 0568
   Dataset Number: V03935221QP 0001
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB_VW37.rod
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 151211200765
   VCID: 2F3CF3E3C79E68824EA-807A
End----------(Elapsed Time: 01:38, VBatt start/end: 14.1V/14.1V)-----------
------------------------------15 Faults Found------------------------------[/*code]
Take a look at all the connections to the camera. Unplug and inspect the plug connections on the wiring harness at or near the camera itself. Water ingress? Corrosion inside the plug connections?
