- Aug 22, 2014
- 539
- 241
- Maryland, USA
- C?ID=66650
Hello Folks-
This AUDI Q7 MMI works normal but sometimes drives back into slot by itself and comes out of dashboard again while driving. It looks like it shuts down by itself and reboot. I did the first auto scan and cleared all faults and rescanned again but I do not see related issues to the MMI functionality in scanned results, apart from tuner fault, AC fault and some other. Would this be a software related issue or any pointers to look out for? Power supply checked ok, no lose connections found on infotainment systems..
Address 5F: DTCs cleared
Thursday,03,September,2026,10:54:40:02426
VCDS Version: 26.9.0.3 (x64) HEX-NET3 CB: 0.4713.5
VIN: WA1LAAF73JD043000 License Plate: JOWIL Q7
Mileage: 132612km-82401mi Repair Order:
Chassis Type: F7-AU73 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 50 52 5F
69 6C 6D 81 A5 BB BC CA CF
VIN: WA1LAAF73JD043000 Mileage: 132612km-82401miles
50-Seat Adj. 3rd row -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CREC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4M0 907 551 A HW: 06E 907 425
Component: 3.0l V6 TFSI H10 0005
Revision: --H10--- CVN: 08BDF7A0
Coding: 2A2A00320536010D74280000000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TFS0214M0907551A 001007
ROD: EV_ECM30TFS021_AU73.rod
VCID: 2D0F562DAD91A9C27C6-8078
VINID: 9D105C4515870DA50010300000D8B0C013
24194 - PCV Valve Malfunction
P052E 00 [01100000] - -
Address 02: Auto Trans Labels:| 0BK-927-156.clb
Part No SW: 4M0 927 158 L HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1006
Revision: --H05--- CVN: 228D7428
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 3D2F666D7DF13942CC6-8068
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M0 907 379 Q HW: 4M0 907 379 N
Component: ESP9 Premium H09 0657
Dataset Number: 4M0909504M 0003 CVN: ACFBEF4F
Coding: 28AA149C30A60A99919E5891007D5292E6269A14280C50891A004A49676459
ASAM Dataset: EV_ESP9BOSCHAU536K 012013
ROD: EV_ESP9BOSCHAU536K_AU73.rod
VCID: 45DF0E8D15217182946-8010
415488 - TPMS Warning; Front Left Tire
C1055 00 [00100000] - Flat
419328 - TPMS Warning; Front Right Tire
C1057 00 [00100000] - Flat
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 R HW: 4M0 820 043 R
Component: Klima Zone 3 H52 0112
Coding: 6608090C5148000D10200180000000000000000000000000000000000000
Shop #: WSC 01422 005 1048576
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 343943494EBBF80A338-8060
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002369960
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4G0 907 658 B HW: 4G0 907 658 B
Component: Humidity_Sens H02 0007
Serial number: 6051542900PAG0FSA002
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: E265 Kli Fond H40 0080
328003 - Motor for Recirculation Flap
B1092 07 [00001000] - Mechanical Failure
Reset counter: 153
Mileage: 131694 km
Date: 2026.07.25
Time: 11:36:19
Recirc. air flap motor: spec.value: 9699
Recirculation air flap motor: actual value: 11584
System run time-Engine running time: 23 s
System run time-Terminal 15 on: 24 s
Recirculation air flap motor: diagnostic-Last operating state: No routine started
Recirculation air flap motor: diagnostic-Operating State: Blocking handling
Voltage terminal 30: 13.93 V
Outside temperature: 25.50 C
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Dataset Number: 4M0909514AA 0055
Coding: C2500362C0081CCD450D8715583E1CB911033D01900000000000000020001A0100610022025705
VCID: 0255D591448F86BAF14-8056
Subsystem 1 - Part No SW: 4M8 955 119 HW: 4N1 955 119
Component: J400FRWISCH 052 0996
Serial number: 904753F0401807002230
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21330703X81A955547A0
Coding: 02006E
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 26 02 2018 01337167
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z01AA02
Coding: 350000
Garage door opener control head:
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180309072421 00079
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE108021823610131
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 4M0 947 135 CT HW: 4M0 947 135
Component: J528-Dachele H14 0140
Serial number: Q00554308
Subsystem 8 - Part No SW: 80A 907 705 HW: 80A 907 705
Component: J866-EVLS-SG H03 0100
Serial number: WA131897000047782626
Coding: 0A0100
Subsystem 9 - Part No SW: 4M0 925 301 K HW: 4M0 925 301 K
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000191131
Address 15: Airbags (J234) Labels:| 8W0-959-655-V1.clb
Part No SW: 4M0 959 655 F HW: 4M0 959 655 F
Component: Airbag10.44 H02 0107
Serial number: 003UM0022TKM Dataset Number: 4M0909602AK 0001
Coding: AECCFCC000800000A0F00033D24C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 3E2D616170F7225AD5C-806A
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705K0101S00854
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706K0108S00988
Coding: 88001B
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J1800090BA30L
Subsystem 4 - Part No SW: ----------- HW: 442 060 202 18
Serial number: 3577Y00B528643D101BZ
Subsystem 5 - Part No SW: ----------- HW: 442 060 302 18
Serial number: 3587Y00B328643D392C4
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 604 18
Serial number: 3517700BD2AAB9F2217U
Subsystem 7 - Part No SW: ----------- HW: 442 0B0 604 18
Serial number: 3527700BD2AAB9F6210S
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 003 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500AF2A9BCA0E32.
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 003 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500AF2A9BCA3A3A2
Part No SW: 4M0 907 129 KM HW: 4M0 907 129 KM
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 055FCE8D55A1B182D46-8050
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 870 C HW: 4M0 920 870 C
Component: TBenUSA H19 0629
Coding: 09E400C12888CF05020369601800200008000000
ROD: EV_DashBoardAU736_AU73.rod
VCID: 2E0D5121A097D2DA45C-807A
Part No SW: 8W6 907 468 F HW: 8W6 907 468 E
Component: Gateway H43 0123
Revision: 7B000002 Serial number: 0287B529718420 Dataset Number: 4M0909515N 0087
Coding: 030100010000064054070000005900324C1A0007100000000150000000000000
GVL: 01503C0008000000C0DC08000002C800100C2000000000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003111
VCID: 4DCF36ADCD5189C25C6-8018
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0004
Serial number: 20180424200431 31475
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 5161287404
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AA HW: 4M0 907 397 A
Component: LCM_MLBevoH05 0024
ROD: EV_LCMLeftHELLAAU736_AU37.rod
VCID: 76BDB9411847AA1ACDC-8022
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000317011642 Dataset Number: 4M0909856D 0023
Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
VCID: 79A7B27D2959C562A0E-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:| 4M0-907-566.clb
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: -------- Dataset Number: 4M0909535L 0016
Coding: 1E8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
VCID: 363D794158C7EA1A0DC-8062
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0129
Serial number: 0000316278273 Dataset Number: 4M0909872H 0033
Coding: 005F8B005E001080000120B0
VCID: 43DB10951B154FB2BA2-8016
Address 44: Steering Assist (J500) Labels:* 4N0-909-144-V1.clb
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000609826 Dataset Number: 4M0909852P 0002
Coding: 90000001000100
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
Part No SW: 8W0 907 064 ED HW: 8W0 907 064 DD
Component: BCM2 MLBevo 025 0387
Dataset Number: 4M0909501K 0066
Coding: 01341E00492100C0650B80006E01580003024000810000502F0400000F04803F001E0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU73.rod
Subsystem 1 - Part No SW: 5QD 951 605 HW: 5QD 951 605
Serial number: 00002856223980850958
Power rear lid opening control module:
Subsystem 2 - Part No SW: 3AA 962 243 F HW: 3AA 962 243 F
Component: GEB.F.Heckoef H16 0816
Serial number: 94295336
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 172
Mileage: 128565 km
Date: 2025.10.04
Time: 15:45:54
Supply voltages-Terminal 30 power supply: 12.663 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.636 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.636 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 C
general_additional_freeze_frame-interior_temperature: -50.0 C
general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 12 02 98
Part No SW: 4M0 035 223 C HW: 4M0 035 223
Component: MIB2_amp_PD H03 0440
Serial number: 00000000096418 Dataset Number: 4M1909510E 0012
Coding: 0135060A008AF53AAF0000010000
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
VCID: 231BB015FB556FB2DA2-8076
Address 50: Seat Adj. 3rd row (J857) Labels:* None
Part No SW: 4M1 959 760 G HW: 4M1 959 760 G
Component: MEM-SR3 008 0016
Serial number: 00000317470405 Dataset Number: 4M0909467C 0016
Coding: FF041020F1000000000F000000000900000021210900000000000000440000
ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
ROD: EV_SCM3rdRowCONTIAU736_AU73.rod
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0129
Serial number: 0000316879233 Dataset Number: 4M0909873H 0033
VCID: 42D51591040F46BAB14-8016
Address 5F: Information Electr. (J794) Labels:* 4M0-035-MIB-HGH2.clb
Part No SW: 4M1 035 025 D HW: 4M1 035 025
Component: MU-H-LNS-US 034 1320
Serial number: A807D0JB014507 Dataset Number: 4M0909545M 0045
Coding: 013706020000000013220002041A00102F001BE501700904FE
VCID: 251FAE0DF5619182B46-8070
Subsystem 1 - Part No SW: V03 959 803 AG HW: -----------
Component: NAR 2020/2021 --- 0079
Multimedia display unit 1:
Subsystem 2 - Part No SW: 4M0 919 605 HW: 4M0 919 605
Component: AU536_DU_HIGH H43 0008
Serial number: AUZ8Z9JJ406BK6
Subsystem 3 - Part No SW: 4M0 919 615 M HW: 4M0 919 615 M
Component: ControlUnit_P H15 0306
Serial number: 18041800000000001219
Compact disc data bank:
Component: Gracenote2 --- 3012
Reset counter: 29
Mileage: 128565 km
Date: 2025.10.04
Time: 14:21:32
Voltage terminal 30: 12.1 V
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
Part No SW: 4M0 907 383 E HW: 4M0 907 383
Component: Anhaenger H27 0253
Revision: 9C001003 Serial number: 0476522149 Dataset Number: 4M0909527C 0024
Coding: 0210000200000000
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Dataset Number: 4M0909460B 0014
Coding: 0237060103002005400040
ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
VCID: 333B40554BB5FF322A2-8066
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0163
Revision: -------- Serial number: 31889136300000 Dataset Number: 4M0909541G 0026
Coding: 00B0
ASAM Dataset: EV_DeckLidCONTIAU736 001015
VCID: 48C107B922336CEA6F0-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 E HW: 4M1 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18040746761730
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2703A4058F6D839286A-8072
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 E HW: 4M0 907 217 E
Component: BVS H16 0050
Dataset Number: 4M0909466M 0045
Coding: 0407030600000201022023A3A50000B400F0C010C000
ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
VCID: 30314F59BAA3C42A570-8064
1123986 - Dynamic Calibration
C1106 F1 [00001000] - Function Restriction due to Limitation Exceeded
[Online_calibration_safe-state_active]
Reset counter: 148
Mileage: 131686 km
Date: 2026.07.18
Time: 12:41:53
Control Module temperature: 66 C
Voltage terminal 15: 14.30 V
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS 005 0129
Serial number: 0000317150352 Dataset Number: 4M0909897H 0033
Coding: 004F8B0000001080400020A0
ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS 005 0129
Serial number: 0000317150150 Dataset Number: 4M0909896H 0033
ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
Part No SW: 4M0 907 594 G HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Dataset Number: 4M0909469G 0015
Coding: 2A8000053602
ROD: EV_SunRoofCONTIAU736_006_VW37.rod
VCID: 3A256D716CDF0E7AE94-806E
Address CF: Lane Chge Asst 2 (J770) Labels:. 4M0-907-566.clb
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 1E8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
End----------(Elapsed Time: 02:25, VBatt start/end: 12.2V/12.0V)-----------
------------------------------7 Faults Found-------------------------------
Coding: 100000
Reset counter: 153
Mileage: 131694 km
Date: 2026.07.25
Time: 11:36:19
Coding: 7DC727
Coding: 02006E
Coding: 350000
Coding: 030000
Coding: 0A0100
Coding: 88001B
Coding: 88001B
Coding: 1E8002
65896 - Databus
Reset counter: 172
Mileage: 128565 km
Date: 2025.10.04
Time: 15:45:54
Reset counter: 29
Mileage: 128565 km
Date: 2025.10.04
Time: 14:21:32
Coding: 00B0
Reset counter: 148
Mileage: 131686 km
Date: 2026.07.18
Time: 12:41:53
Revision: --------
Coding: 1E8002
End----------(Elapsed Time: 02:19, VBatt start/end: 12.7V/12.7V)-----------
