Is it correct that the mileage stored in the ABS unit cannot be reduced?I mean: if I want to double‑check whether the mileage is genuine, I can read out the ABS module, since the instrument cluster and the ECU can be rolled back.
This is something my son mentioned, and I’m not completely sure about it. I’m about to buy a newer car and want to make sure the mileage is accurate.
If someone can hack an ECU and/or the cluster, its not inconceivable they can also hack the ABS controller. The level of robustness for this kind of thing will be determined by whatever levels of security and anti-tamper measures were built into that unit. Obviously the more modern units are much more robust in this regard - what car / platform are we talking about here ?
Im buying a 2019 Touareg and according to the seller it should have 135000km, the signs on the seats and steeringwheel are ok, no signs of wear. So I have a good feeling, but for nearly 40K I want to make sure, as I can only spend it once
If you were to post measuring value maps of all controllers in your car, along with an autoscan, this would indeed be the correct sub-forum, AND people would be able to assist you in looking up mileages.
Sure, I’d be happy to share a full file once I have the car.But of course I don’t want to end up making a 40K mistake.
I do have a HEX‑NET and I can take it with me to scan the car before buying it. So this is more of a preliminary question to understand what I should look for and which modules are most reliable for verifying the mileage.
If the purchase goes ahead, I promise I’ll post an AutoScan and measuring value maps from all controllers!
Get the vehicle up in the air on a lift ; and you and the machanic take a look around for 30 minutes or so. That single effort will reveal more than any other.
;SW:760-907-401-N HW:059-907-309-L --- 01: Engine
;Component:3.0l V6 TDI H26 0002, Coding:292A403A057E050335380000000400000000000000000000
;EV_ECM30TDI011760907401N,001002,EV_ECM30TDI011760907401M.rod
;Monday,21,September,2026,18:57:03:25381
;VCDS Version: 26.9.0.3 (arm64) Data version: 20260918 DS378.0
;VCID: A0120ED01A45515A470-80F4
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WVGZZZCRZKD020971,
IDE00019,Voltage terminal 30,12.860, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,632, /min
IDE00022,Transmission input speed,612.0, /min
IDE00025,Coolant temperature,69, °C
IDE00078,Time since engine start,1175, s
IDE00083,Throttle valve position (absolute),33.3, %
IDE00085,Normed load value,32.2, %
IDE00086,Accelerator pedal position,14.9, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,44.6, Nm
IDE00102,Control Module temperature,44.2, °C
IDE00151,Oil fill level,67.940, mm
IDE00167,Exhaust temperature 1 bank 1,119.6, °C
IDE00169,Exhaust temperature 2 bank 1,114.9, °C
IDE00172,A/C compressor torque,25.0, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00182,Camshaft adaptation intake bank 1: phase position,-3.87, °
IDE00186,Fuel low pressure: actual value,495.5, kPa
IDE00188,Fuel high-pressure: actual value,248600, hPa
IDE00190,Charge air pressure: specified value,1020, hPa
IDE00191,Charge air pressure: actual value,1021.95, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,32.0, °C
IDE00194,Coolant temperature at radiator output: specified value,90.0, °C
IDE00196,Engine oil temperature,73.2, °C
IDE00201,Fuel high-pressure: specified value,250100, hPa
IDE00304,Fuel level,55.00, l
IDE00347,Air mass: actual value:,6.80, g/s
IDE00348,Intake air temperature,26, °C
IDE00349,Throttle valve position: normed,72.2, %
IDE00350,Air mass: specified value,221.0, mg/stroke
IDE00351,Main injection: start of activation,-3.98, °
IDE00352,Main injection: duration of activation,0.0, µs
IDE00353,Engine start: start quantity,17.07, mg/stroke
IDE00354,Engine start: start synchronization,EPM_MODE_OK,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,48,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,2,
IDE00357,Fuel temperature,28.4, °C
IDE00358,Limitation: torque,139.1, Nm
IDE00359,Limitation: smoke,138.9, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,1026, hPa
IDE00362,Charge Pressure Actuator: activation,80.00, %
IDE00363-ENG188621,Glow status-Bits 0-7,0,
IDE00363-ENG188621,Glow status-Bits 0-7,255,
IDE00365,Injection quantity deviation cylinder 1,-0.08, mg/stroke
IDE00366,Injection quantity deviation cylinder 2,0.16, mg/stroke
IDE00367,Injection quantity deviation cylinder 3,0.15, mg/stroke
IDE00368,Injection quantity deviation cylinder 4,-0.29, mg/stroke
IDE00369,Injection quantity deviation cylinder 5,-0.05, mg/stroke
IDE00370,Injection quantity deviation cylinder 6,0.09, mg/stroke
IDE00371,Fuel consumption,0.67, l/h
IDE00375,Generator: load signal,38.65, %
IDE00380,Coolant fan 1: activation,28.51, %
IDE00381,Coolant fan 2: activation,39.05, %
IDE00383,Pre-injection 1: activation start,1.76, °
IDE00384,Pre-injection 1: activation duration,0.0, µs
IDE00385,Pre-injection 2: activation start,14.11, °
IDE00386,Pre-injection 2: activation duration,368.4, µs
IDE00387,Post-injection 1: activation start,0.00, °
IDE00388,Post-injection 1: activation duration,0.0, µs
IDE00389,Post-injection 2: activation start,0.00, °
IDE00390,Post-injection 2: activation duration,0.0, µs
IDE00392,Accelerator pedal: sensor voltage 1,749.4, mV
IDE00393,Accelerator pedal: sensor voltage 2,374.6, mV
IDE00394,Camshaft position: start of phase window,184.17, °
IDE00395,Camshaft position: end of phase window,215.27, °
IDE00396,Charge air pressure actuator: acknowledgment,79.79, %
IDE00399,Regulation factor: total,1.0000,
IDE00400,Intake manifold Runner Control (IMRC): activation,80.77, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,80.42, %
IDE00404,Throttle valve: activation,-13.66, %
IDE00405,Crankshaft speed (RPM),632.5, /min
IDE00406,Camshaft RPM,316.5, /min
IDE00408-ENG188621,Engine mount 1-Bits 0-7,1,
IDE00409-ENG188621,Engine mount 2-Bits 0-7,1,
IDE00410-ENG188621,Transmission mount 1-Bits 0-7,0,
IDE00411-ENG188621,Transmission mount 2-Bits 0-7,0,
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,1,
IDE00420,Service regeneration: current duration,0.00, s
IDE00422-ENG188621,Service regeneration: release conditions 1-Bits 0-7,0,
IDE00424-ENG188621,Service regeneration: cancel conditions-Bits 0-7,255,
IDE00424-ENG188621,Service regeneration: cancel conditions-Bits 0-7,251,
IDE00425-ENG188621,Service regeneration: phase-Bits 0-7,1,
IDE00425-ENG188621,Service regeneration: phase-Bits 0-7,0,
IDE00427,Particle filter: difference pressure,4, hPa
IDE00428,DPF: offset for differential pressure,2, hPa
IDE00430-ENG188621,Particle filter: field regeneration request status-Bits 0-7,0,
IDE00431-ENG188621,Particle filter: field regeneration lock status-Bits 0-7,0,
IDE00432,Particle filter: time since last regeneration,29254, s
IDE00433,Particle filter: oil ash volume,0.19, l
IDE00434,Particle filter: soot mass calculated,19.23, g
IDE00435,Particle filter: soot mass measured,18.40, g
IDE00436,Particle filter: kilometers since last regeneration,545596, m
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,9,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,5.19, mg/stroke
IDE00473,EGR Vacuum Regulator Solen.val.: activation,25.00, %
IDE00474,Ambient air pressure,102, kPa abs
IDE00475,Fuel Pressure Regulator Valve,23.60, %
IDE00476,Fuel Metering Valve,48.34, %
IDE00477,Torque request: sum of auxiliary aggregate,9.2, Nm
IDE00478,Engine-drag torque,40.2, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,21, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.187 Lambda / 0.863 mA,
IDE00583,Throttle valve specified value,72.2, %
IDE00584,Distance driven since erasing DTC memory,67, km
IDE00595,Allocation of oxygen sensors,B1S1 ,
IDE00600,Conversion factors,Max eq. ratio 32 / Max V O2s 0 V,
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,1,
IDE00608,Fuel type,Diesel,
IDE00773,Terminal 15 status via CAN,1,
IDE00784,Current test step,0,
IDE00973,Outside temperature,21.0, °C
IDE01259,EGR Solen.val.: actual value,25.06, %
IDE01260,Generator performance,442.965, W
IDE01266-ENG188621,Coolant shut-off valve-Bits 0-7,2,
IDE01363-ENG188621,exh.gas recirc.: shut-off conditions-Bits 0-7,252,
IDE01363-ENG188621,exh.gas recirc.: shut-off conditions-Bits 0-7,36,
IDE01363-ENG188621,exh.gas recirc.: shut-off conditions-Bits 0-7,0,
IDE01366,Exhaust flap: actual value,4042.6, mV
IDE01367,Turbocharger boost control: offset closed,0.00, %
IDE01369,Intake manifold runner control (IMRC): offset closed,0.00, %
IDE01373,EGR valve: offset closed,-1.71, %
IDE01375,Throttle valve adapter: offset closed,0.29, %
IDE01377,Throttle valve adapter: actual value,27.60, %
IDE01378,Fuel high pressure: control deviation,-400, hPa
IDE01380,Pre-injection 3: activation start,4.66, °
IDE01381,Pre-injection 3: activation duration,419.2, µs
IDE01382,Post-injection 3: activation start,0.00, °
IDE01383,Post-injection 3: activation duration,0.0, µs
IDE01384,Map controlled engine cooling thermostat: specified value,0.00, %
IDE01385,Wear index,3, m
IDE01386,Soot index,0, m
IDE01387,Injector 1: rail pressure calibration point 1,3.60, µs
IDE01388,Injector 1: rail pressure calibration point 2,-8.40, µs
IDE01389,Injector 1: rail pressure calibration point 3,-8.40, µs
IDE01390,Injector 2: rail pressure calibration point 1,5.20, µs
IDE01391,Injector 2: rail pressure calibration point 2,5.60, µs
IDE01392,Injector 2: rail pressure calibration point 3,-2.40, µs
IDE01393,Injector 3: rail pressure calibration point 1,25.60, µs
IDE01394,Injector 3: rail pressure calibration point 2,-4.40, µs
IDE01395,Injector 3: rail pressure calibration point 3,-10.40, µs
IDE01396,Injector 4: rail pressure calibration point 1,9.20, µs
IDE01397,Injector 4: rail pressure calibration point 2,-3.20, µs
IDE01398,Injector 4: rail pressure calibration point 3,-10.00, µs
IDE01399,Injector 5: rail pressure calibration point 1,11.20, µs
IDE01400,Injector 5: rail pressure calibration point 2,7.20, µs
IDE01401,Injector 5: rail pressure calibration point 3,2.80, µs
IDE01402,Injector 6: rail pressure calibration point 1,7.60, µs
IDE01403,Injector 6: rail pressure calibration point 2,-2.80, µs
IDE01404,Injector 6: rail pressure calibration point 3,-8.40, µs
IDE01405-ENG188621,Starter activation: status-Bits 0-7,2,
IDE01406-ENG188621,Service regeneration: status-Bits 0-7,0,
IDE01407,Particle filter: fuel consumption since last regeneration,52.84, l
IDE01408,Charge limit for field regeneration,24.04, g
IDE01409,Charge limit for service regeneration,34.35, g
IDE01410,Charge limit over-charge,51.53, g
IDE01834,Battery voltage,12900, mV
IDE01880,Accelerator pedal position 2,14.9, %
IDE01922,Vehicle distance driven,139851, km
IDE02211,Brake pressure,0.00, MPa
IDE02228,Fuel pressure regulator valve: specified value rail pressure,1160000, hPa
IDE02229,Exhaust gas temperature sensor 1,131.4, °C
IDE02230,Torque reduction due to exhaust temperature,1.0000,
IDE02233,Exhaust gas temperature sensor 2,120.3, °C
IDE02234,Exhaust gas temperature sensor 3,119.1, °C
IDE02236,Exhaust gas temperature sensor 4,95.3, °C
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02558-ENG100471,High pressure test: cancel condition-Param 1 Tst Abort Fid,-,
IDE02558-ENG100389,High pressure test: cancel condition-Param 10 Tst Abort Inj Quant,-,
IDE02558-ENG103668,High pressure test: cancel condition-Param 11 Tst Abort Eng Speed,-,
IDE02558-ENG102582,High pressure test: cancel condition-Param 12 Tst Abort Rail Pres High,-,
IDE02558-ENG104255,High pressure test: cancel condition-Param 13 Tst Abort Rail Pres Low,-,
IDE02558-ENG163334,High pressure test: cancel condition-Param 14 Tst Abort Acctlst Nez,-,
IDE02558-ENG163335,High pressure test: cancel condition-Param 15 Tst Abort Covehtrqacs High,-,
IDE02558-ENG100876,High pressure test: cancel condition-Param 16 Undefined Abort Reason,Undefined Abort Reason,
IDE02558-ENG101560,High pressure test: cancel condition-Param 2 Tst Abort Clutch,-,
IDE02558-ENG102266,High pressure test: cancel condition-Param 3 Tst Abort Speed Nez,-,
IDE02558-ENG100337,High pressure test: cancel condition-Param 4 Tst Abort Brake Press,-,
IDE02558-ENG101825,High pressure test: cancel condition-Param 5 Tst Abort Thrpedal Press,-,
IDE02558-ENG103033,High pressure test: cancel condition-Param 6 Tst Abort Loop Ctl,-,
IDE02558-ENG103871,High pressure test: cancel condition-Param 7 Tst Abort Eng Idle Speed,-,
IDE02558-ENG102719,High pressure test: cancel condition-Param 8 Tst Abort Eng Cold,-,
IDE02558-ENG99486,High pressure test: cancel condition-Param 9 Tst Abort Pf Regen,-,
IDE02742,Oil pressure actual value,2468, hPa
IDE02756,Number of manual engine starts,16881,
IDE02757,Number of automatic engine starts,18127,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,3438,
IDE03010-MAS01627,Number of prevented stop processes-Steering,4544,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,17000,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,730,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,3949,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,94,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,77,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,521,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,74,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,91,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03033,Specified value of low pressure EGR valve,100.00, %
IDE03034,Actual value of low pressure EGR valve,99.96, %
IDE03035,Specified value of low pressure exhaust flap,94.30, %
IDE03036,Actual value of low pressure exhaust flap,94.34, %
IDE03129,Reducing agent pump: activation,50.00, %
IDE03131,Reducing agent injector: activation,0.00, %
IDE03132,Pressure sensor for reducing agent: measured pressure,4986, hPa
IDE03133,Heating circuit 1 for reducing agent metering system: actual current,0.0, A
IDE03134,Heating circuit 2 for reducing agent metering system: actual current,0.0, A
IDE03135,Sensor for reducing agent tank temperature: temperature,20.0, °C
IDE03139,Reducing agent injector: resistance,15016, mOhm
IDE03140,NOx sensor 1: NOx concentration,38, ppm
IDE03141,NOx sensor 2: NOx concentration,0, ppm
IDE03142,Remaining vehicle distance until reducing agent deficiency,5014.20, km
IDE03143-ENG188621,Remaining engine starts until reducing agent deficiency-Bits 0-7,25,
IDE03144,Used reducing agent since last service,152263.749, g
IDE03146,Pressure sensor for reducing agent: voltage,2810.0, mV
IDE03147,Sensor for reducing agent tank temperature: voltage,1520, mV
IDE03148,Sensor for reducing agent fill level: voltage,13107.0, mV
IDE03187,Checksum of flash,7866,
IDE03241,Status of reduction agent level,OK,
IDE03241-ENG127378,Status of reduction agent level-Test_Program_UDC st U Tnk Lvl st UBYTE,3,
IDE03242,Injector for reduction agent: current holding phase,865, mA
IDE03243,Reducing agent injector: current saturation phase,883, mA
IDE03248,Pressure control valve adaptation factor,1.0000,
IDE03266,Fuel temperature: unconditioned voltage,1833.8, mV
IDE03267,Intake air temperature: unconditioned voltage,2295.2, mV
IDE03269,Exhaust temp. EGR: unconditioned voltage,2057.2, mV
IDE03270,Exh.gas temp.sen 1: unconditioned voltage,1147.6, mV
IDE03271,Exh.gas temp.sen 2: unconditioned voltage,1123.0, mV
IDE03272,Catalytic converter temperature sensor 1: unconditioned voltage,0.0, mV
IDE03273,Exh.gas temp.sen 3: unconditioned voltage,1120.6, mV
IDE03275,Exh.gas temp.sen 4: unconditioned voltage,0.0, mV
IDE03288-ENG188621,Heating circuit 1 for reducing agent metering system: activation-Bits 0-7,0,
IDE03289-ENG188621,Heating circuit 2 for reducing agent metering system: activation-Bits 0-7,0,
IDE03327,Temperature sensor for low-pressure EGR: unconditioned voltage,0.0, mV
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3067.0, mV
IDE03383,Exhaust mass flow of EGR,32.5, kg/h
IDE03386,Long-term adaptation of reduction agent dosage,1.00,
IDE03387,Duration of overtemperature at the reduction agent injector,5975, s
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03405-ENG188621,Particle filter field regeneration: cancel conditions-Bits 0-7,0,
IDE03582,Temperature sensor for engine temperature management,77.4, °C
IDE03584-ENG188621,Engine starting requirements-Bits 0-7,0,
IDE03585,System status for the start/stop function master,No release by coordinator,
IDE03586-ENG188621,Starting requirements for active participants-Bits 0-7,0,
IDE03587-IDE02697,Stopping prohibitions for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping prohibitions for active participants-A/C system,not active,
IDE03587-MAS00127,Stopping prohibitions for active participants-Brake,not active,
IDE03587-MAS00506,Stopping prohibitions for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping prohibitions for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping prohibitions for active participants-Gearbox,not active,
IDE03587-MAS01106,Stopping prohibitions for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping prohibitions for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping prohibitions for active participants-Steering,not active,
IDE03587-MAS02237,Stopping prohibitions for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping prohibitions for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping prohibitions for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping prohibitions for active participants-Motor,not active,
IDE03587-MAS06709,Stopping prohibitions for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping prohibitions for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping prohibitions for active participants-Front sensor for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C system,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-Brake,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Gearbox,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication errors,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03660,Longitudinal acceleration,-0.063, m/s²
IDE03712-ENG188621,Engine diagnostic status in curr driving cycle (end-of-line)-Bits 0-7,255,
IDE03765-ENG188621,NOx Sensor 1: Status-Bits 0-7,31,
IDE03766-ENG188621,NOx sensor 2: status-Bits 0-7,0,
IDE03767,Engine status,COENG_RUNNING,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,3,
IDE03768,NOx sensor 1: feed voltage,12480, mV
IDE03769,NOx sensor 2: feed voltage,0, mV
IDE03892,Fuel high pressure sensor: unconditioned voltage,951.0, mV
IDE03949,Air mass: actual value (mg/stroke),221.3, mg/stroke
IDE04002,Charge air pressure control,BP_A cmd/act:102.0/102.3, kPa
IDE04007,Start of injection,-3.98, °
IDE04008,Fuel consumption per hour,0.65, L/h
IDE04015,Exhaust gas recirculation,EGR A:75/75/0 % / EGR B:---/---/--- %,
IDE04016,Fuel Pressure Regulation,FRP CMD:25020/--- kPa / FRP ACT:24860/--- kPa,
IDE04035,exh.gas recirc. temperature,EGRTemp 11/12:100/--- °C / EGRTemp 21/22:---/--- °C,
IDE04083,Coolant temperatures,ECT 1:69, °C
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:80.0/79.6 % / VGT_B cmd/act:---/--- %,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4: / 131/120/118/--- °C,
IDE04092,Particulate filter bank 1,0.60/---/---, kPa
IDE04098,NOX Sensor,NOx11:39 ppm / NOx21:0 ppm,
IDE04099,Reduction agent dosing,ReAg Rate/Demand:0.1/0.07 L/h / Reag Tnk Lvl:52.2 %,
IDE04110,Additional inputs and outputs, / GPL_STAT:OFF ,
IDE04255,Temp sensor for EGR after cooler: raw value,102.9, °C
IDE04256,Temp sensor for engine coolant: unconditioned voltage,1553.0, mV
IDE04257,High pressure EGR actuator: activation,-7.13, %
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,7,
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,16,
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,0,
IDE04258-ENG188621,Actuator for high pressure EGR: status-Bits 0-7,64,
IDE04259,High press EGR actuator: actual unconditioned volt val,2826.6, mV
IDE04260-ENG188621,Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7,1,
IDE04260-ENG188621,Learning cycle counter of zero quant calib: bottom press pt-Bits 0-7,210,
IDE04261-ENG188621,Learning cycle counter of zero quant calib: middle press pt-Bits 0-7,211,
IDE04261-ENG188621,Learning cycle counter of zero quant calib: middle press pt-Bits 0-7,1,
IDE04262-ENG188621,Learning cycle counter of zero quant calib: top press pt-Bits 0-7,211,
IDE04262-ENG188621,Learning cycle counter of zero quant calib: top press pt-Bits 0-7,1,
IDE04263,Sensor for particle filter differential press: raw value,6, hPa
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,0,
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,64,
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,16,
IDE04264-ENG188621,Throttle valve adapter: status-Bits 0-7,7,
IDE04265,Throttle valve adapter: uncond voltage actual value,1682.0, mV
IDE04266,High press turbocharger actuator: activation,2.94, %
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,15,
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,16,
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,64,
IDE04267-ENG188621,High press turbocharger actuator: status-Bits 0-7,0,
IDE04268,High press turbocharger actuator: actual uncond volt value,1582.4, mV
IDE04269,Intake manifold runner actuator: activation,0.00, %
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,64,
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,0,
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,7,
IDE04270-ENG188621,Actuator for intake manifold runner control: status-Bits 0-7,16,
IDE04271,Intake manif runner actuator: uncond volt actual value,2895.0, mV
IDE04272,Counter for regeneration time of particulate filter,0.00, s
IDE04468,Air mass at air mass meter 1,25.3, kg/h
IDE04470,Exhaust gas pressure sensor 1,1041, hPa
IDE04551,Exh gas press sensor 1: uncond voltage value,0.0, mV
IDE04604,Accelerator pedal travel,0.00, %
IDE04623,Kick-down threshold,4125.2, mV
IDE04638,Transmission coolant valve,Correct result,
IDE04638-ENG127289,Transmission coolant valve-Test_Program_B TRUE UBYTE,1,
IDE04651,Torque request: A/C compressor,2.5, Nm
IDE04652,Exhaust gas jet volume in particle filter,26.1, m³/h
IDE04653,Simulated particle filter surface temperature,92.1, °C
IDE04666,Heat delivery temperature in cooling system,-273.1, °C
IDE04667-ENG188621,Bypass valve for EGR cooler: status-Bits 0-7,1,
IDE04668-ENG188621,EGR cooling function: status-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,GAPFOUND,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,8,
IDE04671,Fuel volume adaptation correction volume,0.00, mg/stroke
IDE04682-ENG188621,Allowed number of injections-Bits 0-7,3,
IDE04683-ENG188621,Injection release status-Bits 0-7,88,
IDE04684-ENG188621,Desired injection characteristic-Bits 0-7,88,
IDE04685,Setpoint generation interior torque,45.1, Nm
IDE04686,Calculated clutch limit torque,-41.0, Nm
IDE04687,Mean temperature of SCR catalyst,105.7, °C
IDE04690-ENG188621,Transmission torque intervention status-Bits 0-7,0,
IDE04693,Increasing desired torque intervention of ESP,-50462.7, Nm
IDE04694-ENG188621,Engine diagnostic status 2 in curr driving cycle (end-of-line)-Bits 0-7,255,
IDE04695-ENG137752,Immobilizer snapshot A-Sia Error Snap,00 00 00,
IDE04696-ENG137752,Immobilizer snapshot B-Sia Error Snap,00 00 00,
IDE04814,Transmission oil cooler valve,Correct result,
IDE04814-ENG127289,Transmission oil cooler valve-Test_Program_B TRUE UBYTE,1,
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,206,
IDE04868-ENG188621,Glow cycles above temperature threshold-Bits 0-7,23,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,15,
IDE04869-ENG188621,Glow cycles below temperature threshold-Bits 0-7,112,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,39,
IDE04870-ENG188621,Glow cycles upon reaching temperature threshold-Bits 0-7,62,
IDE04872,Brake pedal value sensor: relative value filtered,0.00, %
IDE04876-ENG188621,Charge map from e-machine/motor torque distribution-Bits 0-7,0,
IDE04885,Hybrid batt charge cond act val standardized,-327.68, %
IDE04887,Powertrain target torque,65.5, Nm
IDE04937,Sensor for engine block temperature: raw value,69.6, °C
IDE04938,Sensor for temp after charge air cooler: raw value,26.3, °C
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,16,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,0,
IDE05136-ENG188621,Current operating mode_2-Bits 0-7,1,
IDE05138,Shut-off timer: last engine shut-off time,8119, s
IDE05219,Electric drive torque: actual value,0.00, A
IDE05220,Electric drive voltage: actual value,0.00, V
IDE05221,Electric drive torque: actual value,0.0, Nm
IDE05232,Reducing agent fill level,40.65, %
IDE05330,Pulse-controlled inverter temperature: actual value,3003.6, °C
IDE05331,DC/DC converter temperature: actual value,-273.1, °C
IDE05343-ENG188621,Target value of heating temperature of NOx sensor 2-Bits 0-7,0,
IDE05346,NOx Emission NOx-Sensor 2,0, ppm
IDE05347,NOx Emission NOx Sensor,38, ppm
IDE05348,NOx-Sensor 2: O2-Concentration,0.20950,
IDE05352-ENG188621,Status of trailing throttle detec in trailing throttle coord-Bits 0-7,0,
IDE05353,Measured NOx conversion,0.000,
IDE05354,Calculated efficiency of NOx conversion,0.000,
IDE05355,Efficiency threshold of NOx conversion,0.000,
IDE05356,Calculated NOx concentration behind turbocharger,46, ppm
IDE05357,Current temperature with NOx Reduction CAT,105.7, °C
IDE05358,Temp sensor for low-pressure EGR after cooler: raw value,222.0, °C
IDE05359,Exhaust mass flow of low-pressure EGR,0.0, kg/h
IDE05361,Maximum cylinder 2 cylinder pressure,0.000, bar
IDE05369,Corrected inner torque from combustion chamb press of cyl 2,0.0, Nm
IDE05374,Low-pressure EGR valve: offset closed,0.38, %
IDE05375,Low-pressure EGR valve: offset open,-0.38, %
IDE05376-ENG188621,Low-pressure EGR valve: status-Bits 0-7,7,
IDE05376-ENG188621,Low-pressure EGR valve: status-Bits 0-7,0,
IDE05376-ENG188621,Low-pressure EGR valve: status-Bits 0-7,64,
IDE05376-ENG188621,Low-pressure EGR valve: status-Bits 0-7,18,
IDE05377,Low-pressure EGR valve: uncond voltage,589.0, mV
IDE05378,Low-pressure exhaust flap: offset closed,-1.20, %
IDE05379,Low-pressure exhaust flap: offset open,1.20, %
IDE05380-ENG188621,Low-pressure exhaust flap: status-Bits 0-7,0,
IDE05380-ENG188621,Low-pressure exhaust flap: status-Bits 0-7,7,
IDE05380-ENG188621,Low-pressure exhaust flap: status-Bits 0-7,16,
IDE05380-ENG188621,Low-pressure exhaust flap: status-Bits 0-7,64,
IDE05381,Low-pressure EGR differential pressure sensor: raw signal,0.47, hPa
IDE05386,Exhaust gas model temperature 0,129.8, °C
IDE05387,Exhaust gas model temperature 1,128.4, °C
IDE05388,Exhaust gas model temperature 2,114.9, °C
IDE05389,Exhaust gas model temperature 3,114.2, °C
IDE05390,Exhaust gas model temperature 4,126.9, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.000,
IDE05442,Roadway slope angle acceleration interface: calculated,-0.0043, rad
IDE05507-ENG188621,Current particulate filter statistics memory range-Bits 0-7,0,
IDE05520,Pump for reducing agent: speed,1368.0, /min
IDE05521,Correction factor of the eng temp for eng protection,1.0000,
IDE05522,Correction factor of the oil temp for eng protection,1.0000,
IDE05523,Correction factor of the fuel temp for eng protection,1.0000,
IDE05524,Charge air press temp correction factor for engine prot,1.0000,
IDE05623,Measured NOx conversion range 1,0.000,
IDE05624,Efficiency threshold of NOx conversion range 1,0.000,
IDE05625,Speed regulation requested torque,64.0, Nm
IDE05626,Calculated temperature at reduction agent injection valve,79.6, °C
IDE05627,Activation of presupply pump duty cycle,29.62, %
IDE05628,Discharge capacity of presupply pump specified value,94.9, l/h
IDE05629-ENG188621,Presupply pump activation status-Bits 0-7,0,
IDE05630,Reducing agent tank fill level indicator: raw value,81.57, %
IDE05797,Throttle valve adapter: specified value,27.53, %
IDE05798,Air mass slow response air mass specified value negative slope,0.0, mg/stroke
IDE05799,Air mass slow response air mass specified value positive slope,0.0, mg/stroke
IDE05805,Calculated temperature of compressor wall,25.2, °C
IDE05846,DPF statistics: current average speed,0.01, km/h
IDE05849,DPF statistics: current average torque gradient,4.9, Nm/s
IDE05851,DPF statistics: current average RPM,650.0, /min
IDE05853,DPF statistics: current avg temperature after part filter,91.2, °C
IDE05855,DPF statistics: current regeneration time slice not possible,0.0000,
IDE05857,DPF statistics: current measured charging rate,-4.0000, g/km
IDE05859,DPF statistics: current calculated charging rate,3.9999, g/km
IDE05861-ENG188621,DPF statistics: number of interrupted regenerations-Bits 0-7,0,
IDE05863,DPF statistics: soot mass at start of regeneration,0.00, g
IDE05865,DPF statistics: soot mass measured at start of regeneration,0.00, g
IDE05867,DPF statistics: soot mass calculated at start of regen,0.00, g
IDE05869,DPF statistics: current average speed in charge cycle,0.00, km/h
IDE05871,DPF statistics: current avg torque gradient in charge cycle,0.0, Nm/s
IDE05873,DPF statistics: average RPM in charge cycle,0.0, /min
IDE05875,DPF statistics: average temp after DPF in charge cycle,-273.1, °C
IDE05877,DPF statistics: regen time slice not poss in charge cycle,0.0000,
IDE05879,DPF statistics: measured charging rate in charge cycle,0.0000, g/km
IDE05881,DPF statistics: calculated charging rate in charge cycle,0.0000, g/km
IDE05883,DPF statistics: regeneration time,0.00, s
IDE05885,DPF statistics: soot mass measured at end of regeneration,0.00, g
IDE05887,DPF statistics: soot mass calculated at end of regeneration,0.00, g
IDE05889,DPF statistics: max temperature before DPF during regen,-273.1, °C
IDE05891,DPF statistics: max temperature after DPF during regen,-273.1, °C
IDE05893,DPF statistics: average soot burn-off during regeneration,0.0000,
IDE05895,DPF statistics: average speed during regeneration,0.00, km/h
IDE05897,DPF statistics: average RPM during regeneration,0.0, /min
IDE05899,DPF statistics: average torque gradient during regeneration,0.0, Nm/s
IDE05901,DPF statistics: route in charge cycle,0, m
IDE05903,DPF statistics: avg driv cycle time during charge cycle,0.00, s
IDE05906,DPF statistics: route since successful regeneration,4, m
IDE05908-ENG188621,DPF statistics: regeneration request-Bits 0-7,0,
IDE05910,DPF statistics: exhaust temperature regulation average value,0.000,
IDE05912-ENG188621,DPF statistics: reason for regeneration interruption-Bits 0-7,0,
IDE05914-ENG188621,DPF statistics: reason 2 for regeneration interruption-Bits 0-7,0,
IDE05916-ENG188621,DPF statistics: regeneration end status-Bits 0-7,0,
IDE05918-ENG188621,DPF statistics: regeneration blocked status-Bits 0-7,0,
IDE05920-ENG188621,DPF statistics: regeneration data index-Bits 0-7,0,
IDE05922-ENG188621,DPF statistics: error status-Bits 0-7,0,
IDE06013,Engine start: start synchronization 2,EPM_FULL_SYNC,
IDE06013-ENG127375,Engine start: start synchronization 2-Test_Program_Epm st Sync State t UBYTE,30,
IDE06041-ENG188621,PDTC drive cycle conditions status-Bits 0-7,37,
IDE06059,Particulate filter: oil ash mass,47.9, g
IDE06060,Particulate filter ash load limit,327.67, g
IDE06112-ENG188621,Test of cylinder deactivation-Bits 0-7,5,
IDE06216,DPF Statistics: average val.: exhaust temp. ctrl before DPF,0.000,
IDE06237,Glow-control unit: activation voltage,10340, mV
IDE06238,Glow-control unit: calculated glow voltage,0, mV
IDE06254-ENG188621,Status of a reducing agent warning-Bits 0-7,0,
IDE06255,Vehicle lateral acceleration,0.03, g
IDE06256,Vehicle lateral acceleration: raw value,0.03, g
IDE06257,Vehicle inclination acceleration angle: raw value,0.000, m/s²
IDE06258,Charge air temperature at the turbocharger outlet: calculated,22.7, °C
IDE06298-ENG188621,Status of engine during start-Bits 0-7,0,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06391,Oil temperature sensor 2,74.0, °C
IDE06392,Oil temperature sensor 2: raw value,1432.0, mV
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,1313.6, mV
IDE06405,Engine oil temperature_SAE,74, °C
IDE06433,Standardized airflow ratio: filtered,2.4779,
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06445,Longitudinal acceleration: raw value,0.000, m/s²
IDE06446-ENG188621,Status: incline angle-Bits 0-7,0,
IDE06567,Frequency counter deactivate start/stop function,11944,
IDE06568,Stop prevention by driver frequency counter,26812,
IDE06569,Frequency counter vehicle standstill,19183,
IDE06610,Frequency counter vehicle standstill with stop,20411,
IDE06647-ENG188621,Start-stop switch status-Bits 0-7,0,
IDE06703-ENG188621,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,32,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707-ENG188621,CCS Switch-Bits 0-7,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06834-ENG188621,Heating circuit 2 for red. agent metering: diag. status-Bits 0-7,0,
IDE06835-ENG188621,Reducing agent pressure sensor: diag. status-Bits 0-7,0,
IDE06836-ENG188621,Heating circuit 1 for red. agent metering: diag. status-Bits 0-7,0,
IDE06837-ENG188621,Reducing agent pump: diag. status-Bits 0-7,0,
IDE06840-ENG188621,Reducing agent tank temperature sensor: diag. status-Bits 0-7,0,
IDE06866-ENG188621,Range limit cancellation due to red. agent metering sys. fault-Bits 0-7,0,
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06947-ENG188621,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06975-ENG188621,Regeneration stages-Bits 0-7,0,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,100.0, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,485, km
IDE06986,H-V battery charge current: maximum value,0.00, A
IDE06988,Reducing agent efficiency diagnosis progress,0.00, g
IDE06989-ENG188621,Reducing agent efficiency-diagnosis release status-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,92,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,4,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,1,
IDE07077,AVS valve stroke position: exhaust,0,
IDE07081,Reducing agent efficiency diagnosis progress 2,0.00, g
IDE07082-ENG188621,Reducing agent efficiency-diagnosis release status 2-Bits 0-7,0,
IDE07087-ENG188621,Target value of heating temperature of NOx sensor 1-Bits 0-7,1,
IDE07088,NOx sensor 1: oxygen concentration,0.12741,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,2,
IDE07090-ENG188621,Speed control: status of external torque request-Bits 0-7,0,
IDE07091,NOx-Raw emission model value before reduction catalyst,38, ppm
IDE07173-ENG188621,Electric drive motor: mode of operation-Bits 0-7,15,
IDE07197,Average reducing agent since last filling,1.02, l/1000 km
IDE07239,Operating state of electric drive,3276.7, Nm
IDE07241-ENG188621,Status transition of transmission control module sequencing-Bits 0-7,0,
IDE07242,Heater support pump: spec. value,94.19, %
IDE07282,Bypass valve of the el. driven compressor: reference value,0.00, %
IDE07285,Electrically driven compressor: speed,131070, /min
IDE07286,Electrically driven compressor: current,260, A
IDE07287,Electrically driven compressor: supply voltage,63.8, V
IDE07288,Electrically driven compressor: component temperature,215, °C
IDE07289,Electrically driven compressor: reference speed,0, /min
IDE07374,Cylinder mass flow: act. value calculated,57.6, kg/h
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,211,
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,159,
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,67,
IDE07518-ENG188621,Reducing agent efficiency-diagnosis releases: current-Bits 0-7,134,
IDE07519-ENG188621,Reducing agent efficiency-diagnosis releases: stored-Bits 0-7,0,
IDE07524,Reducing agent efficiency-diagnosis releases: short-trip status,invalid,
IDE07524-ENG127377,Reducing agent efficiency-diagnosis releases: short-trip status-Test_Program_SCR Chk Compu Valid UBYTE,0,
IDE07525,Reducing agent efficiency-diagnosis progress: short trip,0.00, g
IDE07526,Efficiency threshold of NOx conversion during short trips,0.000,
IDE07527,Measured NOx conversion during short trips,0.000,
IDE07538,Intake manifold press. sensor: act. value calculated,1022, hPa
IDE07660,Minimum permissible torque of e-machine,0.0, Nm
IDE07662,Minimum current permissible torque of e-machine,0.0, Nm
IDE07663,Maximum current permissible torque of e-machine,0.0, Nm
IDE07666,Spec. torque for electric drive: coordinated output signal,0.0, Nm
IDE07667,Desired torque of regeneration,-40.0, Nm
IDE07724,Coolant temperature at engine outlet: calculated,69.7, °C
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07924,Oxygen sensor bank 1 before oxi cat: heater activation,38.785, %
IDE07928,Oxygen sensor bank 1 before oxi cat: exhaust temper. calculated,128.2, °C
IDE07930,Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.,0,
IDE07932-ENG188621,Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.-Bits 0-7,0,
IDE07979,Particle filter: unburned fuel calculated,0.000,
IDE07980,SCR efficiency test 1,0.000,
IDE07982,SCR efficiency test overall,0.00, %
IDE07983,SCR error threshold of efficiency test,0.00, %
IDE07984,Particle sensor: cleaning deviation reaction time,0.000,
IDE07986,Particle sensor: soot volume in exhaust,0.33, mg/m³
IDE07987,Particle sensor: exhaust temperature,89.1, °C
IDE07988,Particle sensor: exhust speed,1.68, m/s
IDE07989,Particle sensor: heat voltage,1.52, V
IDE07990,Particle sensor: surface temperature,199.85, °C
IDE08069-ENG188621,Fuel filter: water level sensor 1-Bits 0-7,0,
IDE08076,Fuel filter: water level sensor 1 raw voltage,0.0, mV
IDE08132-ENG122793,SCR error notification reset status-SCR Inducement Group,0,
IDE08132-ENG122794,SCR error notification reset status-SCR Inducement State DFCC,0,
IDE08132-ENG176596,SCR error notification reset status-SCR Inducement Tester DFCC Five,0,
IDE08132-ENG176595,SCR error notification reset status-SCR Inducement Tester DFCC Four,0,
IDE08132-ENG176592,SCR error notification reset status-SCR Inducement Tester DFCC One,0,
IDE08132-ENG176594,SCR error notification reset status-SCR Inducement Tester DFCC Three,0,
IDE08132-ENG176593,SCR error notification reset status-SCR Inducement Tester DFCC Two,0,
IDE08212,Standardized air flow ratio,2.4722,
IDE08213-ENG188621,Standardised airflow ratio plausibility-Bits 0-7,0,
IDE08213-ENG188621,Standardised airflow ratio plausibility-Bits 0-7,136,
IDE08285-ENG188621,Filling reducing agent metering system status-Bits 0-7,0,
IDE08497,Engine compartment temperature raw value,-273.1, °C
IDE08498,Engine compartment temperature raw voltage,0.0, mV
IDE08527-ENG188621,Counter Index2 of release hindrances-Bits 0-7,255,
IDE08532-ENG188621,Counter Index1 of release hindrances-Bits 0-7,255,
IDE08533-ENG188621,Counter Index3 of release hindrances-Bits 0-7,255,
IDE08534-ENG188621,Counter Index4 of release hindrances-Bits 0-7,255,
IDE08634-ENG188621,Index 1 of release hindrance-Bits 0-7,0,
IDE08635-ENG188621,Index 2 of release hindrance-Bits 0-7,0,
IDE08636-ENG188621,Index 3 of release hindrance-Bits 0-7,0,
IDE08637-ENG188621,Index 4 of release hindrance-Bits 0-7,0,
IDE08721,Particle sensor: time in op. mode measurement,0.0, s
IDE08723-ENG188621,Checking red. medium quality: condition of next proof step-Bits 0-7,34,
IDE08723-ENG188621,Checking red. medium quality: condition of next proof step-Bits 0-7,193,
IDE08724-ENG188621,Checking red. medium quality: reason for cancel-Bits 0-7,0,
IDE08725-ENG188621,Checking red. medium quality: status-Bits 0-7,1,
IDE08726,Checking red. medium quality: remaining time of test,0, s
IDE08727,Checking red. med. quality: remaining time of current test step,0, s
IDE09164,Efficiency of the SCR catalytic converter,0.000,
IDE09556-ENG188621,Particle filter empty conduit diagnosis: release conditions-Bits 0-7,27,
IDE09556-ENG188621,Particle filter empty conduit diagnosis: release conditions-Bits 0-7,80,
IDE09842-ENG188621,Delete engine diagnostic stat. since error memory (end-of-line)-Bits 0-7,255,
IDE09843-ENG188621,Delete engine diagn. stat. 2 since error memory (end-of-line)-Bits 0-7,255,
IDE09879,O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current,0.0008713, A
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,3.0078,
IDE09976,Coolant fan 1: activation,28.51, %
IDE09977,Control module temp.: max. value,65.2, °C
IDE10024,Heating circuit 1 for reducing agent: power,0, W
IDE10025,Heating circuit 3 for reducing agent: power set value,0, W
IDE10027,Heating circuit 3 for reducing agent: power limitation,0,
IDE10028,Heating circuit 1 for reducing agent: power set value,0, W
IDE10029,Heating circuit 3 for reducing agent: current,0.0, A
IDE10030-ENG188621,Heating circuit 3 for reducing agent metering system: activation-Bits 0-7,0,
IDE10031,Sensor for reducing agent fill level: fill level height,201, mm
IDE10032,Reducing agent quality sensor: urea concentration,399.99, %
IDE10033-ENG188621,Heating circuit 3 for red. agent metering: diag. status-Bits 0-7,0,
IDE10037,Heating circuit 3 for reducing agent: power,0, W
IDE10039,Reducing agent quality sensor: validity,1,
IDE10044,Sensor 2 for temp. reducing agent: act. value,19.5, °C
IDE10063-MAS00666,Engine oil level: current value-Warning,0,
IDE10063-MAS00900,Engine oil level: current value-Oil level,31.6, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,138530, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,138518, km
IDE10063-MAS09807,Engine oil level: current value-Qualification,7,
IDE10063-ENG137751,Engine oil level: current value-OilLvlDisp_stTstPrcd_VW,3,
IDE10064-MAS00666,Engine oil level: history 1-Warning,0,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,36.8, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,137030, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,137014, km
IDE10064-MAS09807,Engine oil level: history 1-Qualification,7,
IDE10064-ENG137751,Engine oil level: history 1-OilLvlDisp_stTstPrcd_VW,3,
IDE10065-MAS00666,Engine oil level: history 2-Warning,0,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,81.0, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,135530, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,135528, km
IDE10065-MAS09807,Engine oil level: history 2-Qualification,7,
IDE10065-ENG137751,Engine oil level: history 2-OilLvlDisp_stTstPrcd_VW,3,
IDE10066-MAS00666,Engine oil level: history 3-Warning,0,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,102.0, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,134030, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,134024, km
IDE10066-MAS09807,Engine oil level: history 3-Qualification,7,
IDE10066-ENG137751,Engine oil level: history 3-OilLvlDisp_stTstPrcd_VW,3,
IDE10067-MAS00666,Engine oil level: history 4-Warning,0,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,36.8, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,132530, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,132526, km
IDE10067-MAS09807,Engine oil level: history 4-Qualification,7,
IDE10067-ENG137751,Engine oil level: history 4-OilLvlDisp_stTstPrcd_VW,3,
IDE10068-MAS00666,Engine oil level: history 5-Warning,0,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,61.5, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,131030, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,131020, km
IDE10068-MAS09807,Engine oil level: history 5-Qualification,7,
IDE10068-ENG137751,Engine oil level: history 5-OilLvlDisp_stTstPrcd_VW,3,
IDE10069-MAS00666,Engine oil level: history 6-Warning,0,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,80.1, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,129530, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,129529, km
IDE10069-MAS09807,Engine oil level: history 6-Qualification,7,
IDE10069-ENG137751,Engine oil level: history 6-OilLvlDisp_stTstPrcd_VW,3,
IDE10070-MAS00666,Engine oil level: history 7-Warning,0,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,102.9, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,128030, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,128023, km
IDE10070-MAS09807,Engine oil level: history 7-Qualification,7,
IDE10070-ENG137751,Engine oil level: history 7-OilLvlDisp_stTstPrcd_VW,3,
IDE10071-MAS00666,Engine oil level: history 8-Warning,0,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,74.9, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,126530, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,126516, km
IDE10071-MAS09807,Engine oil level: history 8-Qualification,7,
IDE10071-ENG137751,Engine oil level: history 8-OilLvlDisp_stTstPrcd_VW,3,
IDE10072-MAS00666,Engine oil level: history 9-Warning,0,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,84.8, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,125030, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,125026, km
IDE10072-MAS09807,Engine oil level: history 9-Qualification,7,
IDE10072-ENG137751,Engine oil level: history 9-OilLvlDisp_stTstPrcd_VW,3,
IDE10246,Reducing agent tank volume: act. value filtered,12510, ml
IDE10247,Reducing agent tank volume: act. value calculated,12.52, l
IDE10252,Operatingn hour reducing agent system: flawless,655350, s
IDE10256,Intake manifold 1 bank 1: pos. contr. spec. value,19.95, %
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10579-ENG188621,Reducing agent system pressurization release conditions-Bits 0-7,255,
IDE10580,Engine oil level: test method 1,82.3, %
IDE10581,Engine oil level: test method 2,79.8, %
IDE10582,Engine oil level: test method 3,91.6, %
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,80, ml/mm
IDE10814,Exhaust recirculation cooler 2 Bank 1: efficiency calculated,0.0000,
IDE10822,Min. quantity adaptation: error status,ZMM_STESMDEACTV,
IDE10822-ENG127433,Min. quantity adaptation: error status-Test_Program_ZMM ESM State UBYTE,0,
IDE10823,Exhaust gas model temperature 5,91.0, °C
IDE10824,Exhaust gas model temperature 6,91.4, °C
IDE10825,Exhaust gas model temperature 7,-273.1, °C
IDE10878,Remaining veh distance until reducing agent deficiency:display,5014.20, km
IDE10879,Sensor for reducing agent fill level: calibrated,46.59, %
IDE10880-ENG188621,Reducing agent system: remaining operating range unit-Bits 0-7,0,
IDE10881,Reducing agent tank: min. refill volume,6000, ml
IDE10882,Reducing agent tank: max. refill volume,11480, ml
IDE10883-ENG188621,Reducing agent system: filling quantity unit-Bits 0-7,0,
IDE10884,Reducing agent tank: volume,24000, ml
IDE10916,Reducing agent system debounce distance,0, m
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,3,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,6,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11061,Odometer reading when changing oxidation cat. converter,561, km
IDE11062,Odometer reading when changing particulate filter,561, km
IDE11063,Odometer reading when changing SCR cat. convert.,556, km
IDE11065-ENG188621,Accel. pedal pos. sensor 1-Bits 0-7,102,
IDE11065-ENG188621,Accel. pedal pos. sensor 1-Bits 0-7,2,
IDE11066-ENG188621,Accel. pedal pos. sensor 2-Bits 0-7,51,
IDE11066-ENG188621,Accel. pedal pos. sensor 2-Bits 0-7,1,
IDE11080,AVS operating state: outlet,0,
IDE11083-ENG160864,Special software: name-SigXL Bypass tool output name 4F47,ORIGINAL A2L,
IDE11115,Start/stop driver request: counter restart by starter,1474,
IDE11116,Start/stop driver request: counter internal-motor restart,953,
IDE11117,Charge press. ctrl deviation after throttle valve bank 1,1026.8, hPa
IDE11203,Oil pressure setpoint,212.0, kPa
IDE11219,Reducing agent inj. quantity: spec. value,0.0, mg/s
IDE11220,Reducing agent system: current status,COSCR_PRESSURECTL,
IDE11220-ENG127431,Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE,4,
IDE11221,Reducing agent system: last status,COSCR_NOPRESSURECTL,
IDE11221-ENG127431,Reducing agent system: last status-Test_Program_SCR Con State 01 UBYTE,2,
IDE11222,Reducing agent system: current substatus,COSCR_METERINGCONTROL,
IDE11222-ENG127432,Reducing agent system: current substatus-Test_Program_SCR Con State 02 UBYTE,15,
IDE11223,Reducing agent system: last substatus,COSCR_PRESSUREBUILDUP,
IDE11223-ENG127432,Reducing agent system: last substatus-Test_Program_SCR Con State 02 UBYTE,13,
IDE11250,Reducing agent quality sensor: raw temperature value,3003.6, °C
IDE11267,Oil level: max. value: relative,-3276.8, %
IDE11268,Oil level: min. value: relative,3276.7, %
IDE11272-ENG188621,Temperature threshold for fuel gelling-Bits 0-7,1,
IDE11302-ENG188621,Engine oil level: test method 1 qualification-Bits 0-7,7,
IDE11303-ENG188621,Engine oil level: test method 3 qualification-Bits 0-7,7,
IDE11321-ENG188621,Rail press. regulation: operating condition-Bits 0-7,1,
IDE11323-ENG188621,Fuel pres.sen. for low pressure: raw value-Bits 0-7,6,
IDE11323-ENG188621,Fuel pres.sen. for low pressure: raw value-Bits 0-7,124,
IDE11325-ENG188621,Press. differential sensor of particle filter: raw value-Bits 0-7,2,
IDE11325-ENG188621,Press. differential sensor of particle filter: raw value-Bits 0-7,163,
IDE11327-ENG188621,Manifold press: sensor: raw value-Bits 0-7,41,
IDE11327-ENG188621,Manifold press: sensor: raw value-Bits 0-7,4,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,246,
IDE11329-ENG188621,Oil press. sensor: raw value-Bits 0-7,2,
IDE11330,Oil press. control valve: activation pulse duty factor,76.29, %
IDE11351-ENG188621,Position sensor for chrg. press. actuator: digit. value-Bits 0-7,6,
IDE11351-ENG188621,Position sensor for chrg. press. actuator: digit. value-Bits 0-7,46,
IDE11352-ENG188621,Potentiometer for intake manifold flap: digit. value-Bits 0-7,11,
IDE11352-ENG188621,Potentiometer for intake manifold flap: digit. value-Bits 0-7,73,
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11492,Disengaging clutch actuator: spec. position,0.00000, mm
IDE11531,Starter generator: number of restarts,0,
IDE11533,Starter generator: number of first starts,0,
IDE11541-ENG188621,Autom.pre-selection sys operat.state of the actuator test-Bits 0-7,0,
IDE11568,Starter generator: status,0,
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,not active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,not active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11635-ENG188621,Radiator shutter 1: status referencing-Bits 0-7,0,
IDE11636-ENG188621,Radiator shutter 2: status referencing-Bits 0-7,0,
IDE11854,Mileage of the oxidation catalytic converter,139290, km
IDE11856,Mileage of the SCR catalytic converter,139290, km
IDE11905-ENG188621,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,0,
IDE11905-ENG188621,Exhaust recirculation valve 2 bank 1: adaptation status-Bits 0-7,142,
IDE11906-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
IDE11906-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,14,
IDE11907-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,15,
IDE11907-ENG188621,Exhaust recirculation valve 1 bank 1: adaptation status-Bits 0-7,0,
IDE11908-ENG188621,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,15,
IDE11908-ENG188621,Throttle position actuator 1 bank 1: adaptation status-Bits 0-7,0,
IDE11909-ENG188621,Actuator for intake manifold air flow control: adaptation stat-Bits 0-7,0,
IDE11909-ENG188621,Actuator for intake manifold air flow control: adaptation stat-Bits 0-7,15,
IDE11910-ENG188621,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,0,
IDE11910-ENG188621,Turbine actuator 1 bank 1: adaptation status-Bits 0-7,15,
IDE12270-MAS00106,History data of the electrical compressor-Year,2000,
IDE12270-MAS00107,History data of the electrical compressor-Month,0,
IDE12270-MAS00108,History data of the electrical compressor-Day,0,
IDE12270-MAS14207,History data of the electrical compressor-Number of boost processes,0,
IDE12270-MAS14208,History data of the electrical compressor-Number of derating processes due to temperature,0,
IDE12270-MAS14209,History data of the electrical compressor-Number of derating processes due to voltage,0,
IDE12272,Electrical compressor: total number of short boost processes,0,
IDE12273,Electrical compressor: total number of long boost processes,0,
IDE12274,Electrical compressor total number of retractions due to temperature,0,
IDE12275,Electrical compressor total number of retractions due to voltage,0,
IDE12278,Electrical compressor total number of retractions due to 48 V system,0,
IDE12389-ENG188621,Electrically driven compressor: malfunction status-Bits 0-7,0,
IDE12390,Turbocharger: current minimum throughput position,1100.0, mV
IDE12392,Turbocharger: pin separation from min. throughput position,319.0, mV
IDE12401-ENG188621,Turbocharger: positioner status-Bits 0-7,0,
IDE12401-ENG188621,Turbocharger: positioner status-Bits 0-7,64,
IDE12404-ENG188621,Low pressure EGR valve: positioner status-Bits 0-7,2,
IDE12404-ENG188621,Low pressure EGR valve: positioner status-Bits 0-7,0,
IDE12405-ENG188621,EGR valve: position status-Bits 0-7,0,
IDE12408-ENG188621,Intake manifold flap for airflow control bank 1: actuator status-Bits 0-7,0,
IDE12411-ENG188621,Low pressure EGR exhaust flap: positioner status-Bits 0-7,0,
IDE12457-ENG188621,Turbocharger 1 bypass valve 1 bank 1: position feedback adaption value-Bits 0-7,4,
IDE12547-ENG167791,End of line tests: interrupt conditions-EOL_Quickstarts_abort_conditions_text,Unknown (0)
IDE12547-ENG167792,End of line tests: interrupt conditions-EOL_Quickstarts_abort_conditions_value,0,
IDE12584-ENG188621,Position sensor for EGR valve: digital value-Bits 0-7,11,
IDE12584-ENG188621,Position sensor for EGR valve: digital value-Bits 0-7,10,
IDE12585-ENG188621,Position sensor for low pressure EGR valve: digital value-Bits 0-7,76,
IDE12585-ENG188621,Position sensor for low pressure EGR valve: digital value-Bits 0-7,2,
IDE12586-ENG188621,Position sensor for throttle position actuator bank 1: digital value-Bits 0-7,0,
IDE13385,Turbocharger : current actual minimum throughput position raw value,0.0, mV
IDE13387,Turbocharger: current averaged minimum throughput position,1419.0, mV
IDE13538-ENG188621,Low pressure EGR differential pressure sensor: digital signal-Bits 0-7,2,
IDE13538-ENG188621,Low pressure EGR differential pressure sensor: digital signal-Bits 0-7,153,
IDE13539,Low pressure EGR differential pressure sensor: current pressure raw value,1.25, hPa
IDE13596,NOx sensor 3: status,0,
IDE13597,NOx sensor 3: NOx concentration,0, ppm
IDE13598,NOx sensor 3: feed voltage,0, mV
IDE13692,Starter generator: number of positioning operations,0,
IDE13693,Starter generator: engine control module condition state machine,OFF,
IDE13693-ENG170620,Starter generator: engine control module condition state machine-Test_Program_X Ex Chpd eiu Fhob Bys Cica nfrr6 sp UBYTE,0,
IDE13695,Starter generator: thermal load,0, %
IDE13696,Starter generator: actual mode 48V,0,
IDE13697,Starter generator: number of comfort stops,0,
IDE14202,Electric compressor number of returns re: 48V battery voltage,0,
IDE14203,Electric compressor number of returns re: 48V battery temperature,0,
IDE14518,High Pressure test: standard deviation phase 4,0, hPa
IDE14519,High Pressure test: standard deviation phase 3,0, hPa
IDE14520,High Pressure test: standard deviation phase 2,0, hPa
IDE14521,High Pressure test: standard deviation phase 1,0, hPa
IDE14522,High Pressure test: pressure build-up time phase 4,0, ms
IDE14523,High Pressure test: pressure build-up time phase 3,0, ms
IDE14524,High Pressure test: pressure build-up time phase 2,0, ms
IDE14525,High Pressure test: pressure build-up time phase 1,0, ms
IDE14526,High Pressure test: pressure reduction time phase 4,0, ms
IDE14527,High Pressure test: pressure reduction time phase 3,0, ms
IDE14528,High Pressure test: pressure reduction time phase 2,0, ms
IDE14529,High Pressure test: pressure reduction time phase 1,0, ms
IDE14536,High Pressure test: high pressure average value phase 1,0, hPa
IDE14537,High Pressure test: high pressure average value phase 2,0, hPa
IDE14538,High Pressure test: high pressure average value phase 3,0, hPa
IDE14539,High Pressure test: high pressure average value phase 4,0, hPa
IDE14540,High Pressure test: pressure build-up time: final value 1,0, ms
IDE14541,High Pressure test: pressure build-up time: final value 2,0, ms
IDE14542,High Pressure test: pressure build-up time: final value 3,0, ms
IDE14624,EGR determined air mass test: EGR active,0.0, mg/stroke
IDE14625,EGR determined air mass test: EGR not active,0.0, mg/stroke
IDE14626,EGR determined Lambda test: EGR active,0.000,
IDE14627,EGR determined Lambda test: EGR not active,0.000,
IDE14628,Turbocharger determined air pressure test: charger closed,0.00, hPa
IDE14629,Turbocharger determined air pressure test: charger open,0.00, hPa
IDE14630,Intake Manifold Flap determined air mass test: flap open,0.0, mg/stroke
IDE14631,Intake Manifold Flap determined air mass test: flap closed,0.0, mg/stroke
IDE14632,EGR cooler test: bypass determined air mass: bypass to,0.0, mg/stroke
IDE14633,EGR cooler test: bypass determined air mass: bypass off,0.0, mg/stroke
IDE14634,EGR cooler test: bypass determined maximum temperature: bypass to,-273.1, °C
IDE14635,EGR cooler test: bypass determined minimum temperature: bypass off,-273.1, °C
IDE14636,EGR cooler 2 test: bypass determined minimum air mass: bypass to,0.0, mg/stroke
IDE14637,EGR cooler 2 test: bypass determined air mass: bypass off,0.0, mg/stroke
IDE14638,EGR cooler 2 test: bypass determined maximum temperature: bypass to,-273.1, °C
IDE14639,EGR cooler 2 test: bypass determined minimum temperature: bypass off,-273.1, °C
IDE15926,Heated Oxygen Sensor: oxygen adaptation factor,1.0232,
MAS15730,Additive deviation diagnostics Main phase active: additive from tank,0.00, mg
MAS15732,Additive deviation diagnostics main phase active: additive metered,0.00, mg
MAS15733,Additive deviation diagnostics passive: average Pump stroke confirmed,0.060, mg/stroke
MAS15734,Additive deviation diagnostics passive: average pump stroke,0.000, mg/stroke
MAS16086,Additive deviation diagnostics Active main phase pressure loss identified,0, hPa
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
MAS16689,Reducing agent pump: differential speed calculated,0.0, /min
MAS17031,Radiator shutter 1: actual position,399.99, %
MAS17032,Radiator shutter 2: actual position,399.99, %
MAS17033,Radiator shutter 3: actual position,399.99, %
MAS17034,Radiator shutter 4: actual position,399.99, %
MAS17159,Activation radiator shutter 3: result,0.00, %
MAS17160,Activation radiator shutter 4: result,0.00, %
MAS17236-ENG188621,Adaptation of radiator shutter 2: status-Bits 0-7,0,
MAS17237-ENG188621,Adaptation of radiator shutter 3: status-Bits 0-7,0,
MAS17238-ENG188621,Adaptation of radiator shutter 4: status-Bits 0-7,0,
ENG105135,Actual charge pressure,1027, hPa
ENG119898,Actual_section_of_standard_test,0,
ENG105090-ENG188621,AF Vlv st Ps-Bits 0-7,0,
ENG105098,AFS dm Sens,24.2, kg/h
ENG105131-ENG188621,Air Ctl st Air Ctl Bits-Bits 0-7,0,
ENG105131-ENG188621,Air Ctl st Air Ctl Bits-Bits 0-7,1,
ENG105133-ENG188621,Air Ctl st Mon-Bits 0-7,0,
ENG105142,Air t EGR Clr Ds,102.9, °C
ENG110882-ENG188621,Air_filter_flap_state-Bits 0-7,1,
ENG105146,Air_flow_sensor_temperature_raw_value,26.6, °C
ENG106231,Ambient temperature,20.5, °C
ENG105192,APP r,0.00, %
ENG105204,AS Mod dm Exh Mnf Ds,25.8, kg/h
ENG105205,AS Mod dm Ind Air Ref,59.1, kg/h
ENG138028,AS Mod p P Flt Sim Ds,1027, hPa
ENG122779,AS Mod t EGR Ds,107.0, °C
ENG249098,Bas Svr Appl St Tst Id221 m Air Per Cyl Flt EGR Off Avrg,0.0, mg/stroke
ENG249099,Bas Svr Appl St Tst Id221 m Air Per Cyl Flt EGR On Avrg,0.0, mg/stroke
ENG249100,Bas Svr Appl St Tst Id221 r Lam Sensl Flt EGR Off Avrg,0.000,
ENG249101,Bas Svr Appl St Tst Id221 r Lam Sensl Flt EGR On Avrg,0.000,
ENG249102,Bas Svr Appl St Tst Id222 p Lin Flt Hi Avrg,0.00, hPa
ENG249103,Bas Svr Appl St Tst Id222 p Lin Flt Lo Avrg,0.00, hPa
ENG249104,Bas Svr Appl St Tst Id223 m Air Per Cyl Flt V Sw Vlv Off Avrg,0.0, mg/stroke
ENG249105,Bas Svr Appl St Tst Id223 m Air Per Cyl Flt V Sw Vlv On Avrg,0.0, mg/stroke
ENG249106,Bas Svr Appl St Tst Id224 m Air Per Cyl Flt ECB Vlv Main Off Avrg,0.0, mg/stroke
ENG249107,Bas Svr Appl St Tst Id224 m Air Per Cyl Flt ECB Vlv Main On Avrg,0.0, mg/stroke
ENG249108,Bas Svr Appl St Tst Id224 t EGR Ds Max Avrg,-273.1, °C
ENG249109,Bas Svr Appl St Tst Id224 t EGR Ds Min Avrg,-273.1, °C
ENG135348,Bas Svr Appl St Tst Id226 Oil P Ctl p Diff Nom Act Flt,0.0, kPa
ENG129393,Bas Svr Appl St Tst Id226 Oil p Flt,0.0, kPa
ENG138693-ENG188621,Bas Svr Appl St Tst Id226 st Oil Shtrp Rslt-Bits 0-7,0,
ENG138694-ENG188621,Bas Svr Appl St Tst Id226 st Oil Shtrp Rslt Full Ld-Bits 0-7,0,
ENG138695-ENG188621,Bas Svr Appl St Tst Id226 st Oil Shtrp Rslt MOP-Bits 0-7,0,
ENG129394-ENG188621,Bas Svr Appl St Tst Id226 st Tst State-Bits 0-7,0,
ENG167626,Brk Bst P p,976, hPa
ENG105359-ENG188621,Brk st Mn Raw-Bits 0-7,0,
ENG105360-ENG188621,Brk st Red Raw-Bits 0-7,0,
ENG105387,C Hd T t,77.7, °C
ENG122780,C Thmst r Ps,0.00, %
ENG101413,Calibration Identifications,760401N 0002BEAB,
ENG99697,Calibration Verification Numbers,9C CC CE 8F,
ENG109599,Charge pressure adjuster activation,80.00, %
ENG105483-ENG188621,Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7,0,
ENG105483-ENG188621,Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7,216,
ENG105483-ENG188621,Charge_press_positioner_counter_of_mechanic_hitting-Bits 0-7,5,
ENG157700-ENG188621,Co Eng st Sp Vlv Lft Intk-Bits 0-7,0,
ENG157701-ENG188621,Co Eng st Sp Vlv Lft Outl-Bits 0-7,0,
ENG105528-ENG188621,Co EOM st Op Mode Short-Bits 0-7,0,
ENG139844-ENG188621,Com cntr Bus Knk Out Tmr-Bits 0-7,0,
ENG122787,Com i PP Ds IDE Raw,0.000, µA
ENG105580,Com r Lam Lin Rec Cat2 Ds,0.0000,
ENG105581,Com r Lam Lin Rec Ds,0.3800,
ENG105591-ENG188621,Com st N Ox Vld Cat2 Ds-Bits 0-7,0,
ENG105592-ENG188621,Com st N Ox Vld Ds-Bits 0-7,1,
ENG139866-ENG188621,Com st X Set1 Val1-Bits 0-7,0,
ENG139867-ENG188621,Com st X Set1 Val2-Bits 0-7,0,
ENG139868-ENG188621,Com st X Set1 Val3-Bits 0-7,0,
ENG139869-ENG188621,Com st X Set1 Val4-Bits 0-7,0,
ENG139870-ENG188621,Com st X Set1 Val5-Bits 0-7,0,
ENG139871-ENG188621,Com st X Set1 Val6-Bits 0-7,0,
ENG139872-ENG188621,Com st X Set1 Val7-Bits 0-7,0,
ENG139873-ENG188621,Com st X Set2 Val1-Bits 0-7,0,
ENG139874-ENG188621,Com st X Set2 Val2-Bits 0-7,0,
ENG139875-ENG188621,Com st X Set2 Val3-Bits 0-7,0,
ENG139876-ENG188621,Com st X Set2 Val4-Bits 0-7,0,
ENG139877-ENG188621,Com st X Set2 Val5-Bits 0-7,0,
ENG139878-ENG188621,Com st X Set2 Val6-Bits 0-7,0,
ENG139879-ENG188621,Com st X Set2 Val7-Bits 0-7,0,
ENG139880-ENG188621,Com st X Set3 Val1-Bits 0-7,0,
ENG139881-ENG188621,Com st X Set3 Val2-Bits 0-7,0,
ENG139882-ENG188621,Com st X Set3 Val3-Bits 0-7,0,
ENG139883-ENG188621,Com st X Set3 Val4-Bits 0-7,0,
ENG139884-ENG188621,Com st X Set3 Val5-Bits 0-7,0,
ENG139885-ENG188621,Com st X Set3 Val6-Bits 0-7,0,
ENG139886-ENG188621,Com st X Set3 Val7-Bits 0-7,0,
ENG132845-ENG188621,Configuration_of_cruise_control-Bits 0-7,255,
ENG110877,Cpp p Cyl Min 4,0.000, bar
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,0,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,1,
ENG126403-ENG188621,Cruise_control_shutoff_conditions_reversible-Bits 0-7,64,
ENG122710,Cruise_control_velocity_setpoint,0.000, km/h
ENG122781,Ct T t Eng Des,90.0, °C
ENG105862-ENG188621,DIUMPR ct Gen Denom-Bits 0-7,115,
ENG105862-ENG188621,DIUMPR ct Gen Denom-Bits 0-7,9,
ENG105863-ENG188621,DIUMPR ct Ign-Bits 0-7,194,
ENG105863-ENG188621,DIUMPR ct Ign-Bits 0-7,49,
ENG157799,ECB Vlv r Ps,100.00, %
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG138032,EGR Clg eta Flt,0.0000,
ENG138033,EGR Clg eta Thres,0.5500,
ENG138029,EGR Clg mf Egr Mon Heat Avrg,0.0, kg/h
ENG112277-ENG188621,EGR Clg st EGR Clg Bits-Bits 0-7,0,
ENG112277-ENG188621,EGR Clg st EGR Clg Bits-Bits 0-7,1,
ENG138030,EGR Clg t Egr Ds De Mon Heat Avrg,0.0, K
ENG138031,EGR Clg t Trb Us Mon Avrg,-0.0, °C
ENG106065,EGR valve feedback,74.90, %
ENG157815,EGR Vlv LP p Dsbc,0, hPa
ENG157816,EGR Vlv LP r Act,-0.01, %
ENG157817,EGR Vlv LP r Act Tst,0.04, %
ENG157818,EGR Vlv LP r Des Val,-10.00, %
ENG157819,EGR Vlv LP r Gov Des Val Inv,100.00, %
ENG157820,EGR Vlv p Dsbc,20, hPa
ENG106069,EGR Vlv r Des Val,75.00, %
ENG106084,EGR_governor_deviation,-0.9, mg/stroke
ENG106085,EGR_governor_deviation_lower_limit,-1293.4, mg/stroke
ENG106086-ENG188621,EGR_governor_deviation_monitoring_enabling-Bits 0-7,0,
ENG106087,EGR_governor_deviation_upper_limit,3276.7, mg/stroke
ENG114508,EGR_valve_LP_control,-10.85, %
ENG139887,EGSDO2 rat Lam S1 B1,2.975,
ENG106186,Eng Da l Run In,1001, km
ENG106187,Eng Da st Eng Frst Run Cond,False result,
ENG106187-ENG127289,Eng Da st Eng Frst Run Cond-Test_Program_B TRUE UBYTE,0,
ENG106188,Eng Da st Eng Run In Tstr,False result,
ENG106188-ENG127289,Eng Da st Eng Run In Tstr-Test_Program_B TRUE UBYTE,0,
ENG135326,Eng Da ti Eng On,10611953, s
ENG112279,Eng Prt t Pre Trbn,130.2, °C
ENG106223,Engine_torque_limitation_mechanical,290.0, Nm
ENG105968-ENG188621,EOBD data B-Bits 0-7,14,
ENG105968-ENG188621,EOBD data B-Bits 0-7,0,
ENG105968-ENG188621,EOBD data B-Bits 0-7,96,
ENG105968-ENG188621,EOBD data B-Bits 0-7,235,
ENG127383,ET Ctl q Po I2,0.00, mg/injection
ENG127384,ET Ctl r I Inr,0.000,
ENG127385,ET Ctl t Inr Des,450.0, °C
ENG157854,Exh Flp LP r Act,5.69, %
ENG157855,Exh Flp LP r Act Tst,5.66, %
ENG157856,Exh Flp LP r Des Val,5.71, %
ENG157857,Exh Flp LP r Gov Des Val Inv,94.29, %
ENG122788,Exh i PP Ds IDE Shnt Circ,0.0, µA
ENG135335,Exh Mod rat Dew Det Integ Finshd S1 B1,0.000, %
ENG135336,Exh Mod rat Dew Det Integ Finshd S2 B1,100.000, %
ENG135337,Exh Mod rat Dew Det Integ Finshd S3 B1,4.106, %
ENG135338,Exh Mod rat Dew Det Integ Finshd S4 B1,4.106, %
ENG112280,Exh p Diff Ofs Val Old,2, hPa
ENG106394,Exh r N Ox Pres Comp No Cat2 Ds,0, ppm
ENG106395,Exh r N Ox Pres Comp NSC Ds,38, ppm
ENG122789-ENG188621,Exh st PP Ds St Ma-Bits 0-7,0,
ENG106416,Exh t Adap T Oxi Cat Ds,116.4, °C
ENG106417,Exh t Adap T Trbn Us,130.9, °C
ENG106420,Exh t Adap TP Flt Ds,95.3, °C
ENG146942,Exh t P Flt Ds,95.3, °C
ENG106437,Exh t Trbn Us,130.9, °C
ENG122790,Exh u PP Ds Batt Snsr Raw,12.9, V
ENG114511,Exhaust_flap_valve_control,-11.73, %
ENG106510,Fan r2 Ps,39.05, %
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,132,
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,160,
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,102,
ENG112281-ENG188621,FMO ct Lrn Evt-Bits 0-7,0,
ENG112282,FMO n Adap Map Pnt,3000.0, /min
ENG112283,FMO q Adap Map,0.00, mg/stroke
ENG112284,FMO q Adap Map Pnt,10.00, mg/stroke
ENG129395-ENG188621,Fuel P num P Sent Snsr Slow MID1and MID3-Bits 0-7,4,
ENG129395-ENG188621,Fuel P num P Sent Snsr Slow MID1and MID3-Bits 0-7,0,
ENG129396-ENG188621,Fuel P num P Sent Snsr Slow MID4and MID5-Bits 0-7,5,
ENG129396-ENG188621,Fuel P num P Sent Snsr Slow MID4and MID5-Bits 0-7,0,
ENG129396-ENG188621,Fuel P num P Sent Snsr Slow MID4and MID5-Bits 0-7,1,
ENG129397,Fuel P r Sent Qly,100.00, %
ENG106694,Fuel temperature,28.8, °C
ENG106774-ENG188621,General_rail_press_calibr_ctrl_duration_enble_stat-Bits 0-7,255,
ENG111022,Glow_period_control_unit_calculated_glow_voltage,0, mV
ENG111025,Glow_period_control_unit_energy_integrator_calculated_value,97.5, V²s
ENG111024,Glow_period_control_unit_energy_integrator_input_voltage,0, mV
ENG111026,Glow_period_control_unit_engine_temperature,74.5, °C
ENG111023,Glow_period_control_unit_ground_offset_voltage,-80, mV
ENG106877-ENG188621,High_press_EGR_vlv_cnter_strtd_jam_off_trial-Bits 0-7,0,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,200,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,0,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,149,
ENG106876-ENG188621,High_press_EGR_vlv_counter_of_mech_hitting-Bits 0-7,3,
ENG179915,Hv Batt t VW,3276.7, °C
ENG112940,Inj Crv ti Pi IET 0,435.2, µs
ENG112941,Inj Crv ti Pi IET 1,198.4, µs
ENG112942,Inj Crv ti Pi IET 2,333.2, µs
ENG107015,Inj Ctl q Curr,5.22, mg/stroke
ENG107036-ENG188621,Injctr_spec_rail_press_calibr_ctrl_dur_enbl_stat-Bits 0-7,63,
ENG105141,Intake air temperature,26.9, °C
ENG107046-ENG188621,Intake_manifold_runner_counter_of_mechanic_hitting-Bits 0-7,0,
ENG107047-ENG188621,Intake_manifold_runner_counter_started_jam_off_trial-Bits 0-7,2,
ENG107047-ENG188621,Intake_manifold_runner_counter_started_jam_off_trial-Bits 0-7,0,
ENG103875-ENG99452,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Completion Condition Counts,2687, counts
ENG103875-ENG103994,In-use Performance Tracking: 16 counters-Boost Pressure Monitor Conditions Encountered Counts,2419, counts
ENG103875-ENG125935,In-use Performance Tracking: 16 counters-Counters 17-18,|Fuel Monitor Completion Condition Counts,Fuel Monitor Conditions Encountered Counts|0
ENG103875-ENG100817,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Completion Condition Counts,0, counts
ENG103875-ENG101113,In-use Performance Tracking: 16 counters-EGR and/or VVT Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG104133,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Completion Condition Counts,0, counts
ENG103875-ENG104165,In-use Performance Tracking: 16 counters-Exhaust Gas Sensor Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG102823,In-use Performance Tracking: 16 counters-Ignition Cycle Counter,0, counts
ENG103875-ENG99234,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG99167,In-use Performance Tracking: 16 counters-NMHC Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG101363,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Completion Condition Counts,0, counts
ENG103875-ENG103522,In-use Performance Tracking: 16 counters-NOx Adsorber Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG125933,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Completion Condition Counts,0, counts
ENG103875-ENG125934,In-use Performance Tracking: 16 counters-NOx/SCR Catalyst Monitor Conditions Encountered Counts,0, counts
ENG103875-ENG99988,In-use Performance Tracking: 16 counters-OBD Monitoring Conditions Encountered Counts,0, counts
ENG103875-ENG100240,In-use Performance Tracking: 16 counters-PM Filter Monitor Completion Condition Counts,0, counts
ENG103875-ENG103730,In-use Performance Tracking: 16 counters-PM Filter Monitor Conditions Encountered Counts,0, counts
ENG110883,IUMPR_minimum_ratio_group_0,0.6072,
ENG110884,IUMPR_minimum_ratio_group_1,0.4043,
ENG110885,IUMPR_minimum_ratio_group_2,0.6072,
ENG110886,IUMPR_minimum_ratio_group_3,4.5000,
ENG110887,IUMPR_minimum_ratio_group_4,0.3922,
ENG110888,IUMPR_minimum_ratio_group_5,2.2318,
ENG110889,IUMPR_minimum_ratio_group_6,1.1107,
ENG110890,IUMPR_minimum_ratio_group_7,0.0000,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG114506-ENG188621,Low_Pressure_EGR_Valve_counter_of_mechanic_hitting-Bits 0-7,0,
ENG114506-ENG188621,Low_Pressure_EGR_Valve_counter_of_mechanic_hitting-Bits 0-7,1,
ENG114506-ENG188621,Low_Pressure_EGR_Valve_counter_of_mechanic_hitting-Bits 0-7,238,
ENG114506-ENG188621,Low_Pressure_EGR_Valve_counter_of_mechanic_hitting-Bits 0-7,61,
ENG114507-ENG188621,Low_Pressure_EGR_Valve_counter_started_jam_off_trial-Bits 0-7,0,
ENG114509-ENG188621,Low_Pressure_Exhaust_Gas_Flap_counter_of_mechanic_hitting-Bits 0-7,236,
ENG114509-ENG188621,Low_Pressure_Exhaust_Gas_Flap_counter_of_mechanic_hitting-Bits 0-7,0,
ENG114509-ENG188621,Low_Pressure_Exhaust_Gas_Flap_counter_of_mechanic_hitting-Bits 0-7,199,
ENG114510-ENG188621,Low_Pressure_Exhaust_Gas_Flap_counter_started_jam_off_trial-Bits 0-7,0,
ENG107569,Main_injection_quantity,2.79, mg/stroke
ENG107596,Me Un dvol Set,580, mm³/s
ENG107654-ENG188621,Mo F Brk st-Bits 0-7,0,
ENG107655,Mo F Inj Dat ti TDC Avrg,1134.8, µs
ENG158049,Mo F Veh Acc trq Veh Ptd,60.8, Nm
ENG158050-ENG188621,Mo XEMM st EMM Alrms Idx0-Bits 0-7,0,
ENG158051-ENG188621,Mo XEMM st EMM Alrms Idx1-Bits 0-7,0,
ENG158052-ENG188621,Mo XEMM st EMM Alrms Idx2-Bits 0-7,0,
ENG107673,Model_corr._factor_of_exh._mass_flow_rate_into_exh._manifold,1.0000,
ENG158068-ENG188621,OEM2RB VW Byp flg E Hmnplt u8-Bits 0-7,0,
ENG129398-ENG188621,Oil P num P Sent Snsr Slow MID1and MID3-Bits 0-7,0,
ENG129398-ENG188621,Oil P num P Sent Snsr Slow MID1and MID3-Bits 0-7,4,
ENG129399-ENG188621,Oil P num P Sent Snsr Slow MID4and MID5-Bits 0-7,0,
ENG129399-ENG188621,Oil P num P Sent Snsr Slow MID4and MID5-Bits 0-7,5,
ENG129399-ENG188621,Oil P num P Sent Snsr Slow MID4and MID5-Bits 0-7,1,
ENG129401,Oil P r Sent Qly,100.00, %
ENG112943,Oil t Sens PULS,73.5, °C
ENG107969,P Flt Ld fac Ash Cor,0.8589,
ENG135342,P Flt Ld len Snce P Flt Chng,139290, km
ENG137924,P Flt Ld r Lam,2.982,
ENG108011-ENG188621,P Flt Srv st Rgn Suc-Bits 0-7,0,
ENG129402-ENG188621,P Intk V Us num P Sent Snsr Slow MID1and MID3-Bits 0-7,0,
ENG129402-ENG188621,P Intk V Us num P Sent Snsr Slow MID1and MID3-Bits 0-7,3,
ENG129403-ENG188621,P Intk V Us num P Sent Snsr Slow MID4and MID5-Bits 0-7,66,
ENG129403-ENG188621,P Intk V Us num P Sent Snsr Slow MID4and MID5-Bits 0-7,0,
ENG129403-ENG188621,P Intk V Us num P Sent Snsr Slow MID4and MID5-Bits 0-7,39,
ENG129403-ENG188621,P Intk V Us num P Sent Snsr Slow MID4and MID5-Bits 0-7,4,
ENG129404,P Intk V Us r Sent Qly,100.00, %
ENG129405-ENG188621,P Pfil Dif Snsr num P Sent Snsr Slow MID1and MID3-Bits 0-7,0,
ENG129405-ENG188621,P Pfil Dif Snsr num P Sent Snsr Slow MID1and MID3-Bits 0-7,4,
ENG129406-ENG188621,P Pfil Dif Snsr num P Sent Snsr Slow MID4and MID5-Bits 0-7,0,
ENG129406-ENG188621,P Pfil Dif Snsr num P Sent Snsr Slow MID4and MID5-Bits 0-7,5,
ENG129406-ENG188621,P Pfil Dif Snsr num P Sent Snsr Slow MID4and MID5-Bits 0-7,1,
ENG129407,P Pfil Dif Snsr r Sent Qly,100.00, %
ENG108162,Particle_filter_service_regeneration_duration_with_headup,0.00, s
ENG106384,Particul.filter diff.pressure,6, hPa
ENG127252-ENG151857,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 1 Sensor 1,not active,
ENG127252-ENG151859,Particulate Matter (PM) Sensor Output-PM Sensor active status Bank 2 Sensor 1,not active,
ENG127252-ENG151855,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 1 Sensor 1,-0.01, %
ENG127252-ENG151856,Particulate Matter (PM) Sensor Output-PM Sensor normalized output value Bank 2 Sensor 1,0.00, %
ENG127252-ENG151861,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 1 Sensor 1 supported,Available,
ENG127252-ENG151863,Particulate Matter (PM) Sensor Output-PM Sensor operating status Bank 2 Sensor 1 supported,Not available,
ENG127252-ENG151858,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 1 Sensor 1,not active,
ENG127252-ENG151860,Particulate Matter (PM) Sensor Output-PM Sensor regen status Bank 2 Sensor 1,not active,
ENG127252-ENG151862,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 1 Sensor 1 supported,Available,
ENG127252-ENG151864,Particulate Matter (PM) Sensor Output-PM Sensor signal Bank 2 Sensor 1 supported,Not available,
ENG108181-ENG188621,PCR st Mon-Bits 0-7,0,
ENG158100,PEGRLP Diff p,0.47, hPa
ENG108227-ENG188621,Pos MC Ctl st Lim 4-Bits 0-7,0,
ENG108252,Postinjection_1_quantity,0.00, mg/stroke
ENG108253,Postinjection_2_quantity,0.00, mg/stroke
ENG108254,Postinjection_3_quantity,0.00, mg/stroke
ENG108270,Preinjection_1_quantity,1.04, mg/stroke
ENG108271,Preinjection_2_quantity,0.00, mg/stroke
ENG108272,Preinjection_3_quantity,1.44, mg/stroke
ENG167648,Rba Io Sig Rtc st Diag Stop Counter,96,
ENG127401,Reductant_inducement_system_error,False result,
ENG127401-ENG127289,Reductant_inducement_system_error-Test_Program_B TRUE UBYTE,0,
ENG110382-ENG151591,SCR inducem system status-deviation of reagent consumption,Unknown (0)
ENG110382-ENG151584,SCR inducem system status-Distance traveled in current 10K block,8898, km
ENG110382-ENG151585,SCR inducem system status-Distance traveled while inducement system active in 20K block,0, km
ENG110382-ENG151586,SCR inducem system status-Distance traveled while inducement system active in 30K block,0, km
ENG110382-ENG151587,SCR inducem system status-Distance traveled while inducement system active in 40K block,0, km
ENG110382-ENG151583,SCR inducem system status-Distance traveled while inducement system active in current 10K block,0, km
ENG110382-ENG151590,SCR inducem system status-incorrect reagent,Unknown (0)
ENG110382-ENG151588,SCR inducem system status-inducement system active,not_active,
ENG110382-ENG151592,SCR inducem system status-NOx emissions too high,Unknown (0)
ENG110382-ENG151589,SCR inducem system status-reagent level too low,Unknown (0)
ENG108629,SCR Mod fac Eff SCR Age,0.000,
ENG158186,SCRFFC dm N Ox Us Flt,0.4, mg/s
ENG108641,SCRFFC st Pre Ctl Mode Actv,0,
ENG108950-ENG188621,Shtrp num Curr Tst-Bits 0-7,0,
ENG108990,Smk Lim q Lim Smk,16.28, mg/stroke
ENG121093-ENG188621,State_of_cruise_control_or_speedlimiter-Bits 0-7,0,
ENG132858-ENG188621,State_of_requestor_for_drivetrain_coordinator-Bits 0-7,2,
ENG109106-ENG188621,Status_of_adaption_of_toothed_speed-Bits 0-7,1,
ENG158239,Sw SVW p Cmpr Ds GEM,1026.8, hPa
ENG158244,Sy C st Vld Ti Ecu Off,1,
ENG138035,Thr Vlv r Act Tst,72.57, %
ENG158253-ENG188621,Thr Vlv st Mon Tstr-Bits 0-7,0,
ENG109419,Throttle valve activation,72.71, %
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,11,
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,1,
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,0,
ENG109431-ENG188621,Throttle_valve_counter_of_mech_hitting-Bits 0-7,40,
ENG109432-ENG188621,Thrttle_vlv_cntr_strtd_jam_off_trial-Bits 0-7,0,
ENG132847,Top_speed_limitation,250.000, km/h
ENG132857-ENG188621,Transmission_state_of_drivetrain_coordinator-Bits 0-7,255,
ENG158274,Trb Ch r Gov Des Val,80.00, %
ENG158284,Trb Ch u Rel Pos Clsd Lrn Fst,0.0, mV
ENG158285,Trb Ch u Rel Pos Clsd Lrn Lst,0.0, mV
ENG109657-ENG188621,Trbochrgr_press_postionr_cnter_strtd_jam_off_trial-Bits 0-7,0,
ENG138027,UDC m Rdc Ag Rmn,13656, g
ENG109727,V Sw Vlv r Act,19.63, %
ENG109861,Vehicle speed,0.00, km/h
ENG132846,Velocity_limiter_setpoint,511.000, km/h
ENG158331-ENG162583,Virtual_SigXL_FMO_AdapMap-FMO_qAdapMap_Value,-1.82, mg/stroke
ENG158332-ENG162581,Virtual_SigXL_FMO_nAdapMapPnt-FMO_N,500.00, /min
ENG158333-ENG162582,Virtual_SigXL_FMO_qAdapMapPnt-FMO_Q,3.00, mg/stroke
ENG158334,Virtual_SigXSet_SyC_tiPostDrv,0, s
ENG158335,Virtual_SigXSet_TiEngOff_tiDiagRef,603, s
ENG158336,Virtual_SigXSet_TiEngOff_tiStopCnt_Dif,8124, s
ENG158337,Virtual_SigXSet_TiEngOff_tiStopCnt_Raw,8691876, s
ENG158338,Virtual_SigXSet_TiOff_tiStrtEnd_Off,8120, s
ENG129392,Vlv Hd Block r Ps,29.99, %
ENG158342,Vvl Ena st Ena It VW,65532,
ENG158343,Vvl Ena st Ena VW,65532,
ENG158344,Vvl Ena t Actr Mod VW,60.0, °C
Elapsed Time: 04:03
;SW:4N0-907-063-DG HW:4N0-907-063-AG --- 09: Cent. Elect.
;Component:BCM1 MLBevo H10 0652, Coding:07501140E13B0009070F170858BF8C40800B30110000009301100A00FB24F6019BC501BB12B7C6370000030100D122195D02040144010104000000000000000000
;EV_BCM1BOSCHAU651,014010,EV_BCM1BOSCHAU651_014.rod
;Monday,21,September,2026,19:09:46:25381
;VCDS Version: 26.9.0.3 (arm64) Data version: 20260918 DS378.0
;VCID: F6BE0888E8418FEA4DC-80A2
Group,Description,Actual
IDE00025,Coolant temperature,71.10, °C
IDE00198,Refrigerant pressure,7.00, bar
IDE00957,Resulting distance of front sensors,infinite,
IDE00958,Resulting distance of rear sensors,88, cm
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00970,Coolant fan activation: actual value,42.00, %
IDE00971,Coolant fan activation: specified value,42.00, %
IDE00972,Idle speed increase,not active,
IDE00974,Outside air temperature internally calculated,19.00, °C
IDE00983,Inside temperature,24.40, °C
IDE01063,Status of recirculation air,Fresh air,
IDE01068,Rear blower voltage: actual value,2.30, V
IDE01069,Rear blower voltage: specified value,2.40, V
IDE01076,Time since ignition off,135, min
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,No,
IDE01123,Distance of left rear park assist sensor,infinite,
IDE01124,Distance of left rear center park assist sensors,infinite,
IDE01125,Distance of right rear center park assist sensors,infinite,
IDE01126,Distance of right rear park assist sensor,89, cm
IDE01127,Distance sensor for left front park assist,infinite,
IDE01128,Distance sensor for left front center park assist,infinite,
IDE01129,Distance sensor for right front center park assist,infinite,
IDE01130,Distance of right front park assist sensors,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,1.04, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,1.04, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,0.99, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,1.10, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.99, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,1.01, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,1.01, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,1.02, ms
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Rear parking aid buzzer: volume,Stage 6,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 4,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Front parking aid buzzer: volume,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 6,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164-MAS06614,Parking aid button-Variant,not coded / not installed,
IDE01164-MAS07693,Parking aid button-Button Status,not coded / not installed,
IDE01164-MAS07694,Parking aid button-Button status on CAN,Initialization/not installed,
IDE01164-MAS07699,Parking aid button-Status indicator light on CAN,OFF,
IDE01164-MAS08062,Parking aid button-Indicator lamp activation,not coded / not installed,
IDE01166,Supply voltage for park assist sensor,12.00, V
IDE01171-IDE01167,Convertible factory setting offset for volume level 1-Convertible offset for volume level 1,not installed,
IDE01172-IDE01168,Factory setting for increment for convertible volume levels-Increment for convertible volume levels,not installed,
IDE01173,Factory setting: audio lowering,Yes,
IDE01174,Factory setting: visual display for park assist,with OPS 360°,
IDE01175,Distance of side left rear parking aid sensors,infinite,
IDE01176,Distance of side right rear parking aid sensors,89, cm
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.00, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.00, ms
IDE01185,Distance sensor for left front parking aid,infinite,
IDE01186,Distance sensor for right front parking aid,infinite,
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,0.00, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,0.00, ms
IDE01227,Blower current,0.75, A
IDE01229,Blower current of rear fresh air blower,0.50, A
IDE01230,Control module for rear fresh air blower: temperature,33, °C
IDE01241,Position sensor in left side vent: voltage,not coded / not installed,
IDE01243,Position sensor in right side vent: voltage,not coded / not installed,
IDE01245,Position sensor in left center vent: voltage,not coded / not installed,
IDE01247,Position sensor in right center vent: voltage,not coded / not installed,
IDE01249,Left rear upper body vent position sensor: voltage,not coded / not installed,
IDE01251,Right rear upper body vent position sensor: voltage,not coded / not installed,
IDE01264,Remaining time of parking heater/ventilation operation,0, s
IDE01266-MAS01580,Coolant shut-off valve-Activation,not coded / not installed,
IDE01266-MAS07806,Coolant shut-off valve-Specified status,not coded / not installed,
IDE01266-MAS12621,Coolant shut-off valve-Current draw (effective value),not coded / not installed,
IDE01268-MAS01464,Front windshield wiper-Emergency running mode,not active,
IDE01268-MAS01632,Front windshield wiper-Status,not active,
IDE01268-MAS02832,Front windshield wiper-Malfunction status,not faulty,
IDE01268-MAS03006,Front windshield wiper-Overload,not active,
IDE01268-MAS03638,Front windshield wiper-Wipe speed,No wiping,
IDE01268-MAS06732,Front windshield wiper-Status local activity,not active,
IDE01268-MAS06897,Front windshield wiper-Wipe cycle counter,2549,
IDE01268-MAS07055,Front windshield wiper-Response error,not active,
IDE01268-MAS07998,Front windshield wiper-park position,active,
IDE01268-MAS09379,Front windshield wiper-Service position,not active,
IDE01268-MAS09595,Front windshield wiper-Production mode,not active,
IDE01268-MAS09596,Front windshield wiper-Debug Data,Not available,
IDE01268-MAS09597,Front windshield wiper-Turn posn.,not active,
IDE01268-MAS09626,Front windshield wiper-Status error validity,valid,
IDE01268-MAS09627,Front windshield wiper-Error status: wiper 2,not faulty,
IDE01268-MAS09628,Front windshield wiper-Overload: wiper 2,not active,
IDE01268-MAS09629,Front windshield wiper-Status error validity: wiper 2,valid,
IDE01287,Counter of compressor switch-offs,2,
IDE01309,Recirculation air flap motor: actual value,10000,
IDE01311,Left side vent flap motor: actual value,11071,
IDE01312,Right side vent flap motor: actual value,10869,
IDE01313,Left footwell flap motor: actual value,10000,
IDE01314,Right footwell flap motor: actual value,10000,
IDE01315,Left center vent flap motor: actual value,10914,
IDE01316,Right center vent flap motor: actual value,11004,
IDE01323,Left rear upper body vent motor: actual value,10000,
IDE01324,Right rear upper body vent motor: actual value,10000,
IDE01325,Left B-Pillar/Footwell Shut-Off Flap Motor: actual value,10000,
IDE01326,Right B-Pillar/Footwell Shut-Off Flap Motor: actual value,10000,
IDE01328-IDE09056,Recirculation air flap motor: diagnostic-Last operating state,blockage,
IDE01328-MAS01458,Recirculation air flap motor: diagnostic-Operating State,No routine started,
IDE01330-IDE09056,Left side vent flap motor: diagnostic-Last operating state,Move control motor,
IDE01330-MAS01458,Left side vent flap motor: diagnostic-Operating State,No routine started,
IDE01331-IDE09056,Right side vent flap motor: diagnostic-Last operating state,Move control motor,
IDE01331-MAS01458,Right side vent flap motor: diagnostic-Operating State,No routine started,
IDE01332-IDE09056,Left footwell flap motor: diagnostic-Last operating state,blockage,
IDE01332-MAS01458,Left footwell flap motor: diagnostic-Operating State,No routine started,
IDE01333-IDE09056,Right footwell flap motor: diagnostic-Last operating state,blockage,
IDE01333-MAS01458,Right footwell flap motor: diagnostic-Operating State,No routine started,
IDE01334-IDE09056,Left center vent flap motor: diagnostic-Last operating state,Move control motor,
IDE01334-MAS01458,Left center vent flap motor: diagnostic-Operating State,No routine started,
IDE01335-IDE09056,Right center vent flap motor: diagnostic-Last operating state,blockage,
IDE01335-MAS01458,Right center vent flap motor: diagnostic-Operating State,No routine started,
IDE01342-IDE09056,Left rear upper body vent motor: diagnostic-Last operating state,blockage,
IDE01342-MAS01458,Left rear upper body vent motor: diagnostic-Operating State,No routine started,
IDE01343-IDE09056,Right rear upper body vent motor: diagnostic-Last operating state,blockage,
IDE01343-MAS01458,Right rear upper body vent motor: diagnostic-Operating State,No routine started,
IDE01344-IDE09056,Left B-pillar shut-off flap motor: diagnostic-Last operating state,blockage,
IDE01344-MAS01458,Left B-pillar shut-off flap motor: diagnostic-Operating State,No routine started,
IDE01345-IDE09056,Right B-pillar shut-off flap motor: diagnostic-Last operating state,blockage,
IDE01345-MAS01458,Right B-pillar shut-off flap motor: diagnostic-Operating State,No routine started,
IDE01352,Temperature unit,°C,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Rear parking aid buzzer: volume,Stage 6,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01411-MAS01428,Personalization 1 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,active,
IDE01411-MAS12596,Personalization 1 for park assist-Park brake assistant,not activated,
IDE01411-MAS15621,Personalization 1 for park assist-Restart information,not activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Rear parking aid buzzer: volume,Stage 6,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01412-MAS01428,Personalization 2 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,not active,
IDE01412-MAS12596,Personalization 2 for park assist-Park brake assistant,not activated,
IDE01412-MAS15621,Personalization 2 for park assist-Restart information,not activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Rear parking aid buzzer: volume,Stage 6,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01413-MAS01428,Personalization 3 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12596,Personalization 3 for park assist-Park brake assistant,not activated,
IDE01413-MAS15621,Personalization 3 for park assist-Restart information,not activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Rear parking aid buzzer: volume,Stage 6,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 4,
IDE01414-MAS01428,Personalization 4 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 6,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12596,Personalization 4 for park assist-Park brake assistant,not activated,
IDE01414-MAS15621,Personalization 4 for park assist-Restart information,not activated,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Malfunction on fresh air blower,
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01425,Defrost flap motor: actual value,10000,
IDE01426,Left temperature flap motor: actual value,10434,
IDE01427,Right temperature flap motor: actual value,10447,
IDE01428-IDE09056,Defrost flap motor: diagnostic-Last operating state,blockage,
IDE01428-MAS01458,Defrost flap motor: diagnostic-Operating State,No routine started,
IDE01429-IDE09056,Left temperature flap motor: diagnostic-Last operating state,No routine started,
IDE01429-MAS01458,Left temperature flap motor: diagnostic-Operating State,Move control motor,
IDE01430-IDE09056,Right temperature flap motor: diagnostic-Last operating state,Move control motor,
IDE01430-MAS01458,Right temperature flap motor: diagnostic-Operating State,No routine started,
IDE01433,Air quality status,Clean air,
IDE01455,Key number,1,
IDE01488-MAS01458,Auxiliary heating retrofit without CAN-Operating State,not coded / not installed,
IDE01488-MAS05773,Auxiliary heating retrofit without CAN-Voltage of signal line,not coded / not installed,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,67, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,47, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,57.30, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,53.00, °C
IDE01540-MAS07052,Left front heated seat-Setting,Not available,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,2.60, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,2.23, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Not available,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,0, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,-0.04, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),5.00, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),4.40, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,21.90, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,22.50, °C
IDE01541-MAS07052,Right front heated seat-Setting,Not available,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,9.15, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,9.42, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Not available,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,0, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,OFF,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,OFF,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not active,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,-0.03, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.00, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01544-IDE01270,Auxiliary Air Heater-Enabling for auxiliary heater operation,not coded / not installed,
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,not coded / not installed,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,not coded / not installed,
IDE01544-MAS07913,Auxiliary Air Heater-Heating stage: current value,not coded / not installed,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,not coded / not installed,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),not coded / not installed,
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),not coded / not installed,
IDE01588,Direction of travel,forward,
IDE01622,Fresh air blower: speed,1320, /min
IDE01632,System status of parking aid,not active,
IDE01633,Cause for parking aid shut-off,Parking aid button,
IDE01946,ESP intervention,OFF,
IDE01965-MAS06614,Parallel parking assistance button-Variant,not coded / not installed,
IDE01965-MAS07693,Parallel parking assistance button-Button Status,not coded / not installed,
IDE01965-MAS07694,Parallel parking assistance button-Button status on CAN,Initialization/not installed,
IDE01965-MAS07699,Parallel parking assistance button-Status indicator light on CAN,OFF,
IDE01965-MAS08062,Parallel parking assistance button-Indicator lamp activation,not coded / not installed,
IDE01966,Cause of parallel park assist switching off,No shut-off requirement,
IDE01967,Parking side,Right,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,5C DC 4B EB,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,reachable,
IDE01992-SFT00041,Installation list: current installations-Left light control,reachable,
IDE01992-SFT00057,Installation list: current installations-Right light control,reachable,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,reachable,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,reachable,
IDE01993-SFT00009,Control module reference number-Electronic central electric,Electronic central electric,
IDE01993-SFT00041,Control module reference number-Left light control,Left light control,
IDE01993-SFT00057,Control module reference number-Right light control,Right light control,
IDE01993-SFT00214,Control module reference number-Light Control Left 2,Light Control Left 2,
IDE01993-SFT00215,Control module reference number-Light Control Right 2,Light Control Right 2,
IDE01995-SFT00009,Control module protocol information-Electronic central electric,ISO-TP,
IDE01995-SFT00041,Control module protocol information-Left light control,ISO-TP,
IDE01995-SFT00057,Control module protocol information-Right light control,ISO-TP,
IDE01995-SFT00214,Control module protocol information-Light Control Left 2,ISO-TP,
IDE01995-SFT00215,Control module protocol information-Light Control Right 2,ISO-TP,
IDE02384-SFT00009,Status of event memory-Electronic central electric,Malfunction,
IDE02384-SFT00041,Status of event memory-Left light control,OK,
IDE02384-SFT00057,Status of event memory-Right light control,OK,
IDE02384-SFT00214,Status of event memory-Light Control Left 2,OK,
IDE02384-SFT00215,Status of event memory-Light Control Right 2,OK,
IDE02433,Left rear temperature flap motor: actual value,10520,
IDE02434-IDE09056,Left rear temperature flap motor: diagnostic-Last operating state,No routine started,
IDE02434-MAS01458,Left rear temperature flap motor: diagnostic-Operating State,Move control motor,
IDE02436,Right rear temperature flap motor: actual value,10483,
IDE02437-IDE09056,Right rear temperature flap motor: diagnostic-Last operating state,No routine started,
IDE02437-MAS01458,Right rear temperature flap motor: diagnostic-Operating State,Move control motor,
IDE02455-MAS06911,Light function "Coming/Leaving Home"-Status Coming Home,not active,
IDE02455-MAS06912,Light function "Coming/Leaving Home"-Status Leaving Home,not active,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE02711-MAS09598,Rear wiper-Request on CAN,OFF,
IDE02711-MAS09599,Rear wiper-Error status via CAN,No error: no wiper activation,
IDE02834,Fresh air flap motor: actual value,11263,
IDE02835-IDE09056,Fresh air flap motor: diagnostic-Last operating state,blockage,
IDE02835-MAS01458,Fresh air flap motor: diagnostic-Operating State,No routine started,
IDE03008-IDE80251,Stop process prevented-Neck heating,not active,
IDE03008-MAS00385,Stop process prevented-Basic setting active,not active,
IDE03008-MAS01957,Stop process prevented-Outside temperature,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS03902,Stop process prevented-Adaptation A/C comfort stop activation,not active,
IDE03010-IDE80251,Number of prevented stop processes-Neck heating,0,
IDE03010-MAS00385,Number of prevented stop processes-Basic setting active,1,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,128,
IDE03010-MAS01957,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,48139,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,40002,
IDE03010-MAS03902,Number of prevented stop processes-Adaptation A/C comfort stop activation,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),1876,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),328,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,1243,
IDE03011-IDE80251,Number of requested start processes-Neck heating,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,3,
IDE03011-MAS01957,Number of requested start processes-Outside temperature,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,2,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,53,
IDE03011-MAS03902,Number of requested start processes-Adaptation A/C comfort stop activation,0,
IDE03011-MAS03903,Number of requested start processes-Dew point gradient,1,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),1,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,6,
IDE03111-MAS06885,Interior lighting-Terminal 30 for interior lighting,92, %
IDE03111-MAS06886,Interior lighting-Dimming for interior lighting,0, %
IDE03111-MAS06986,Interior lighting-Footwell illumination rear,92, %
IDE03111-MAS06987,Interior lighting-Footwell illumination front,92, %
IDE03111-MAS09295,Interior lighting-Ambient lighting channel 1,not coded / not installed,
IDE03111-MAS09297,Interior lighting-Ambient illumination power supply,100, %
IDE03111-MAS12622,Interior lighting-Terminal 30 for interior lighting: current draw (effect. value),0, mA
IDE03111-MAS12623,Interior lighting-Foot well illumination: rear: current draw (effective value),46, mA
IDE03111-MAS12624,Interior lighting-Foot well illumination: front: current draw (effective value),55, mA
IDE03111-MAS12625,Interior lighting-Ambient illumination channel 1: current draw (effective value),not coded / not installed,
IDE03111-MAS12626,Interior lighting-Supply for ambient illumination: current draw (effective value),336, mA
IDE03111-MAS12627,Interior lighting-Trunk illumination: front: current draw (effective value),not coded / not installed,
IDE03111-MAS12917,Interior lighting-Rear ambient lighting channel 1,not coded / not installed,
IDE03111-MAS12918,Interior lighting-Rear ambient light.chan. 1: current drawn (effective value),not coded / not installed,
IDE03111-MAS12919,Interior lighting-Roof ambient lighting channel 1,not coded / not installed,
IDE03111-MAS12920,Interior lighting-Roof ambient lighting channel 1: current drawn (effective value),not coded / not installed,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00041,Readiness for bus sleep mode-Left light control,Bus sleep mode,
IDE03150-SFT00057,Readiness for bus sleep mode-Right light control,Bus sleep mode,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,active,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,active,
IDE03197-IDE08190,Rain/Light Recognition Sensor-Request exterior illumination,On,
IDE03197-MAS02475,Rain/Light Recognition Sensor-Brightness infrared,1600, lx
IDE03197-MAS03637,Rain/Light Recognition Sensor-Rain quantity,0, %
IDE03197-MAS04806,Rain/Light Recognition Sensor-Splash,not active,
IDE03197-MAS06899,Rain/Light Recognition Sensor-Request glass close,not active,
IDE03197-MAS06900,Rain/Light Recognition Sensor-Status glass,closed,
IDE03197-MAS06998,Rain/Light Recognition Sensor-Request exterior illumination: inverse,OFF,
IDE03197-MAS06999,Rain/Light Recognition Sensor-Bright/dark information,Dark,
IDE03197-MAS07055,Rain/Light Recognition Sensor-Response error,not active,
IDE03197-MAS09630,Rain/Light Recognition Sensor-Qualification status of exterior lighting requirement,valid,
IDE03197-MAS09631,Rain/Light Recognition Sensor-Highway light requirement,OFF,
IDE03197-MAS09632,Rain/Light Recognition Sensor-Rain light requirement,OFF,
IDE03197-MAS09633,Rain/Light Recognition Sensor-Wiper speed requirement,No wiping,
IDE03197-MAS09634,Rain/Light Recognition Sensor-Adaptation error,not active,
IDE03197-MAS09635,Rain/Light Recognition Sensor-Error status rain sensors,not faulty,
IDE03197-MAS09636,Rain/Light Recognition Sensor-Error status light sensors,not faulty,
IDE03197-MAS10232,Rain/Light Recognition Sensor-Brightness ahead,168, lx
IDE03197-MAS10233,Rain/Light Recognition Sensor-Brightness ahead: boost,up to 6428 Lux,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03602,Left front level control system sensor,Measuring value not available,
IDE03604,Left rear level control system sensor,Measuring value not available,
IDE03620,Front jounce travel,0, mm
IDE03621,Rear jounce travel,-3, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,Measuring value not available,
IDE03625,Right dynamic AFS light motor: specified value,Measuring value not available,
IDE03626,Left dynamic AFS light motor: status,Measuring value not available,
IDE03627,Right dynamic AFS light motor: status,Measuring value not available,
IDE03628,Adjusting motor for variable left front lighting: status,Measuring value not available,
IDE03629,Adjusting motor for variable right front lighting: status,Measuring value not available,
IDE03630,Left headlight beam adjusting motor: specified value,-9.00, mm
IDE03631,Right headlight beam adjusting motor: specified value,-9.00, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Static cornering light-Dim static left AFS light,0.00, %
IDE03638-IDE03718,Static cornering light-Dim static right AFS light,0.00, %
IDE03640,Dynamic AFS light,OFF,
IDE03662-MAS06614,ASR/ESP button-Variant,not coded / not installed,
IDE03662-MAS07693,ASR/ESP button-Button Status,not coded / not installed,
IDE03662-MAS07694,ASR/ESP button-Button status on CAN,Initialization/not installed,
IDE03662-MAS07699,ASR/ESP button-Status indicator light on CAN,OFF,
IDE03662-MAS08062,ASR/ESP button-Indicator lamp activation,not coded / not installed,
IDE03663-MAS06614,-AUTO HOLD- Button-Variant,discreet wire with series resistance,
IDE03663-MAS07693,-AUTO HOLD- Button-Button Status,Not operated,
IDE03663-MAS07694,-AUTO HOLD- Button-Button status on CAN,Not operated,
IDE03663-MAS07699,-AUTO HOLD- Button-Status indicator light on CAN,OFF,
IDE03663-MAS08062,-AUTO HOLD- Button-Indicator lamp activation,OFF,
IDE03669,Status of light distribution,Measuring value not available,
IDE03679-MAS09575,Adaptive light functions-High beam request,OFF,
IDE03679-MAS10260,Adaptive light functions-Request for automatic high beam,On,
IDE03679-MAS10261,Adaptive light functions-Automatic high beam availability,not coded / not installed,
IDE03679-MAS10264,Adaptive light functions-High beam: status,not coded / not installed,
IDE03679-MAS10265,Adaptive light functions-Left high beam: error status,not coded / not installed,
IDE03679-MAS10266,Adaptive light functions-Right high beam: error status,not coded / not installed,
IDE03679-MAS10268,Adaptive light functions-Matrix automatic high beam availability,Matrix auto. high beam is available,
IDE03679-MAS10271,Adaptive light functions-Matrix high beam: status,OFF,
IDE03679-MAS10272,Adaptive light functions-Left Matrix high beam: error status,No malfunction,
IDE03679-MAS10273,Adaptive light functions-Right Matrix high beam: error status,No malfunction,
IDE03679-MAS10274,Adaptive light functions-Sensor status: auto. high beam,not coded / not installed,
IDE03679-MAS10275,Adaptive light functions-Matrix auto. high beam: sensor status,Not blocked,
IDE03680-MAS00043,Supply voltages-Terminal 30 power supply,13.01, V
IDE03680-MAS06254,Supply voltages-Supply voltage Terminal 30 - 2,12.95, V
IDE03680-MAS06255,Supply voltages-Supply voltage Terminal 30 - 3,12.85, V
IDE03680-MAS06490,Supply voltages-Terminal 15 load,12.78, V
IDE03680-MAS06838,Supply voltages-Supply voltage: terminal 30 left,12.89, V
IDE03680-MAS06839,Supply voltages-Supply voltage terminal 30 right,12.87, V
IDE03680-MAS06840,Supply voltages-Supply voltage Terminal 30 - 4,12.97, V
IDE03680-MAS06841,Supply voltages-Supply voltage Terminal 30 - 5,12.93, V
IDE03680-MAS06842,Supply voltages-Supply voltage Terminal 30 - 6,13.01, V
IDE03683,Request power steering boost,No,
IDE03684,Vehicle stopped,Yes,
IDE03727,Variable left front lighting specified position,Measuring value not available,
IDE03728,Variable right front lighting specified position,Measuring value not available,
IDE03784,Temporary function limitation due to environmental influences,No,
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),Measuring value not available,
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),Measuring value not available,
IDE04312-IDE04095,System run time-Engine running time,1968, s
IDE04312-MAS00084,System run time-Terminal 15 on,1969, s
IDE04343-SFT00009,Bus identification-Electronic central electric,Bus master,
IDE04343-SFT00041,Bus identification-Left light control,AFS/From light data bus,
IDE04343-SFT00057,Bus identification-Right light control,AFS/From light data bus,
IDE04343-SFT00214,Bus identification-Light Control Left 2,AFS/From light data bus,
IDE04343-SFT00215,Bus identification-Light Control Right 2,AFS/From light data bus,
IDE04741-MAS06614,Rear window defogger button-Variant,not coded / not installed,
IDE04741-MAS07693,Rear window defogger button-Button Status,not coded / not installed,
IDE04741-MAS07694,Rear window defogger button-Button status on CAN,Initialization/not installed,
IDE04741-MAS07699,Rear window defogger button-Status indicator light on CAN,OFF,
IDE04741-MAS08062,Rear window defogger button-Indicator lamp activation,not coded / not installed,
IDE04806-MAS06614,Driving profile selection button-Variant,not coded / not installed,
IDE04806-MAS07693,Driving profile selection button-Button Status,not coded / not installed,
IDE04806-MAS07694,Driving profile selection button-Button status on CAN,Initialization/not installed,
IDE04923-MAS08125,Turn signal control-Left front turn signal bulb: status,OFF,
IDE04923-MAS08127,Turn signal control-Right front turn signal bulb: status,OFF,
IDE04923-MAS08131,Turn signal control-Left turn signal lights: clock,OFF,
IDE04923-MAS08132,Turn signal control-Right turn signal lights: clock,OFF,
IDE05042-MAS06614,Emergency flasher button-Variant,Discreet wire,
IDE05042-MAS07693,Emergency flasher button-Button Status,Not operated,
IDE05042-MAS07694,Emergency flasher button-Button status on CAN,Not operated,
IDE05042-MAS08062,Emergency flasher button-Indicator lamp activation,OFF,
IDE05071-MAS06614,Lane change assistance button-Variant,not coded / not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not coded / not installed,
IDE05071-MAS07694,Lane change assistance button-Button status on CAN,Initialization/not installed,
IDE05071-MAS08062,Lane change assistance button-Indicator lamp activation,not coded / not installed,
IDE05194-IDE09056,Flap motor for indirect ventilation: left: diagnosis-Last operating state,No routine started,
IDE05194-MAS01458,Flap motor for indirect ventilation: left: diagnosis-Operating State,No routine started,
IDE05196,Flap motor for indirect ventilation: left: actual value,65535,
IDE05197-IDE09056,Flap motor for indirect ventilation: right: diagnosis-Last operating state,No routine started,
IDE05197-MAS01458,Flap motor for indirect ventilation: right: diagnosis-Operating State,No routine started,
IDE05199,Flap motor for indirect ventilation: right: actual value,65535,
IDE05534-MAS01580,Headlamp washer system-Activation,OFF,
IDE05534-MAS12621,Headlamp washer system-Current draw (effective value),0, mA
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,21.20, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,21.00, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,55.50, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,11.90, °C
IDE06091-MAS07055,Humidity sensor: interior-Response error,not active,
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,22.20, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,40.50, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,12.70, °C
IDE06307-MAS00106,Stop prevention history data-Year,2026,
IDE06307-MAS00107,Stop prevention history data-Month,9,
IDE06307-MAS00108,Stop prevention history data-Day,21,
IDE06307-MAS00109,Stop prevention history data-Hours,18,
IDE06307-MAS00110,Stop prevention history data-Minutes,37,
IDE06307-MAS00111,Stop prevention history data-Seconds,22,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Interior vent difference to setting,
IDE06308-MAS00106,Start request history data-Year,2026,
IDE06308-MAS00107,Start request history data-Month,3,
IDE06308-MAS00108,Start request history data-Day,18,
IDE06308-MAS00109,Start request history data-Hours,10,
IDE06308-MAS00110,Start request history data-Minutes,59,
IDE06308-MAS00111,Start request history data-Seconds,53,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Interior vent difference to setting,
IDE06644-MAS06993,Vehicle positioning system-Request signal horn,not coded / not installed,
IDE06644-MAS09570,Vehicle positioning system-Parking light request,not coded / not installed,
IDE06644-MAS09571,Vehicle positioning system-Low beam request,not coded / not installed,
IDE06752-MAS06614,Hill descent control button-Variant,not coded / not installed,
IDE06752-MAS07693,Hill descent control button-Button Status,not coded / not installed,
IDE06752-MAS07694,Hill descent control button-Button status on CAN,Initialization/not installed,
IDE06752-MAS07699,Hill descent control button-Status indicator light on CAN,OFF,
IDE06752-MAS08062,Hill descent control button-Indicator lamp activation,not coded / not installed,
IDE06807,Fresh-air door motor / specified value,11263,
IDE06808,Fresh-air door motor / dynamics,1263,
IDE06809,Left temp. door motor / specified value,10449,
IDE06810,Left temp. door motor / dynamics,1449,
IDE06811,Right temp. door motor: specified value,10462,
IDE06812,Right temp. door motor: dynamics,1445,
IDE06813,Defroster door motor: specified value,10000,
IDE06814,Defroster door motor: dynamics,1526,
IDE06815,Recirc. air flap motor: spec.value,10000,
IDE06816,Recirc. air flap motor: dynamics,1600,
IDE06823,Left center vent motor / specified value,10914,
IDE06824,Left center vent motor / dynamics,1016,
IDE06825,Right center vent motor: specified value,11004,
IDE06826,Right center vent motor: dynamics,1004,
IDE07080-MAS07921,Left rear seat ventilation setting-Balance setting,not coded / not installed,
IDE07080-MAS07928,Left rear seat ventilation setting-Ventilation stage,not coded / not installed,
IDE07080-MAS07929,Left rear seat ventilation setting-Power quota setting by energy management,not coded / not installed,
IDE07133,Fresh air blower motor: temperature,25, °C
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07244-MAS07921,Right rear seat ventilation setting-Balance setting,not coded / not installed,
IDE07244-MAS07928,Right rear seat ventilation setting-Ventilation stage,not coded / not installed,
IDE07244-MAS07929,Right rear seat ventilation setting-Power quota setting by energy management,not coded / not installed,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Actual value,not coded / not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Specified value,not coded / not installed,
IDE07246-MAS01447,Left rear seat backrest fan 2: activation-Actual value,not coded / not installed,
IDE07246-MAS01448,Left rear seat backrest fan 2: activation-Specified value,not coded / not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Actual value,not coded / not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Specified value,not coded / not installed,
IDE07248-MAS01447,Left rear seat cushion fan 2: activation-Actual value,not coded / not installed,
IDE07248-MAS01448,Left rear seat cushion fan 2: activation-Specified value,not coded / not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Actual value,not coded / not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Specified value,not coded / not installed,
IDE07250-MAS01447,Right rear seat backrest fan 2: activation-Actual value,not coded / not installed,
IDE07250-MAS01448,Right rear seat backrest fan 2: activation-Specified value,not coded / not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Actual value,not coded / not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Specified value,not coded / not installed,
IDE07252-MAS01447,Right rear seat cushion fan 2: activation-Actual value,not coded / not installed,
IDE07252-MAS01448,Right rear seat cushion fan 2: activation-Specified value,not coded / not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE07253-IDE11723,Installation info: rear seat ventilation-Fan 2 for left rear seat backrest,not installed,
IDE07253-IDE11724,Installation info: rear seat ventilation-Fan 2 for left rear seat cushion,not installed,
IDE07253-IDE11725,Installation info: rear seat ventilation-Fan 2 for right rear seat backrest,not installed,
IDE07253-IDE11726,Installation info: rear seat ventilation-Fan 2 for right rear seat cushion,not installed,
IDE07259,Rear left air distribution servomotor: actual value,10189,
IDE07260,Rear left air distribution servomotor: reference value,10189,
IDE07261,Rear left air distribution servomotor: dynamic,6324,
IDE07262-IDE09056,Rear left air distribution servomotor: diagnosis-Last operating state,Move control motor,
IDE07262-MAS01458,Rear left air distribution servomotor: diagnosis-Operating State,No routine started,
IDE07263,Rear right air distribution servomotor: actual value,10190,
IDE07264,Rear right air distribution servomotor: reference value,10190,
IDE07265,Rear right air distribution servomotor: dynamic,6337,
IDE07266-IDE09056,Rear right air distribution servomotor: diagnosis-Last operating state,Move control motor,
IDE07266-MAS01458,Rear right air distribution servomotor: diagnosis-Operating State,No routine started,
IDE07459,Left footwell door motor / specified value,10000,
IDE07460,Left footwell door motor: dynamics,968,
IDE07461,Right footwell door motor / specified value,10000,
IDE07462,Right footwell door motor: dynamics,989,
IDE07491,Left rear temp door motor: spec. value,10536,
IDE07492,Left rear temp door motor: dynamics,1578,
IDE07493,Right rear temp door motor: spec. value,10483,
IDE07494,Right rear temp door motor: dynamics,1561,
IDE07495,Left rear upper body vent motor: spec. value,10000,
IDE07496,Left rear upper body vent motor: dynamics,1462,
IDE07497,Right rear upper body vent motor: spec. value,10000,
IDE07498,Right rear upper body vent motor: dynamics,1481,
IDE07499,Left side vent flap motor: spec.value,11071,
IDE07500,Left side vent flap motor: dynamics,1674,
IDE07501,Right side vent flap motor: spec. value,10869,
IDE07502,Right side vent flap motor: dynamics,1774,
IDE07505,Left B-Pillar/Footwell Shut-Off Flap Motor: specified value,10000,
IDE07506,Left B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1045,
IDE07507,Right B-Pillar/Footwell Shut-Off Flap Motor: specified value,10000,
IDE07508,Right B-Pillar/Footwell Shut-Off Flap Motor: dynamic,1052,
IDE07950-IDE04095,Historical data of motors-Engine running time,28, s
IDE07950-IDE09056,Historical data of motors-Last operating state,blockage,
IDE07950-MAS00084,Historical data of motors-Terminal 15 on,32, s
IDE07950-MAS00106,Historical data of motors-Year,2026,
IDE07950-MAS00107,Historical data of motors-Month,9,
IDE07950-MAS00108,Historical data of motors-Day,20,
IDE07950-MAS00109,Historical data of motors-Hours,17,
IDE07950-MAS00110,Historical data of motors-Minutes,16,
IDE07950-MAS00111,Historical data of motors-Seconds,24,
IDE07950-MAS01458,Historical data of motors-Operating State,Blocking handling,
IDE07950-MAS03118,Historical data of motors-Logic address,39,
IDE07950-MAS03180,Historical data of motors-Local data bus,9,
IDE07950,Historical data of motors,14.20, V
IDE07991-MAS01580,A/C clutch-Activation,100, %
IDE07991-MAS07919,A/C clutch-Min current consumption: spec value,2.50, A
IDE07991-MAS12621,A/C clutch-Current draw (effective value),1975, mA
IDE07991-MAS12776,A/C clutch-Spec.val. min.cur. draw prior to rec.op.circ./short circ. to B+,Open circuit/short circuit not yet recognized,
IDE07991-MAS12778,A/C clutch-Act.val. min.curr. draw prior to recogn open circ/sh circ to B+,Open circuit/short circuit not yet recognized,
IDE08125-MAS01458,Left neck heater-Operating State,not coded / not installed,
IDE08125-MAS02832,Left neck heater-Malfunction status,not coded / not installed,
IDE08125-MAS06652,Left neck heater-Blower motor: speed,not coded / not installed,
IDE08125-MAS06653,Left neck heater-Indicator light for head area heater,not coded / not installed,
IDE08125-MAS07055,Left neck heater-Response error,not coded / not installed,
IDE08125-MAS09644,Left neck heater-Vent temperature,not coded / not installed,
IDE08125-MAS12677,Left neck heater-PTC heater element: current draw (effective value),not coded / not installed,
IDE08126-MAS01458,Right neck heater-Operating State,not coded / not installed,
IDE08126-MAS02832,Right neck heater-Malfunction status,not coded / not installed,
IDE08126-MAS06652,Right neck heater-Blower motor: speed,not coded / not installed,
IDE08126-MAS06653,Right neck heater-Indicator light for head area heater,not coded / not installed,
IDE08126-MAS07055,Right neck heater-Response error,not coded / not installed,
IDE08126-MAS09644,Right neck heater-Vent temperature,not coded / not installed,
IDE08126-MAS12677,Right neck heater-PTC heater element: current draw (effective value),not coded / not installed,
IDE08196-IDE01351,Terminal activation-Terminal 75 status,On,
IDE08196-MAS06982,Terminal activation-Terminal 15 status signal,On,
IDE08196-MAS07720,Terminal activation-Terminal 15 via CAN,On,
IDE08196-MAS08123,Terminal activation-Term 75: qualification,OFF,
IDE08343,Immobilizer Challenge,9E 64 E0 04,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,28, °C
IDE08356-MAS01447,Left seat backrest fan 1-Actual value,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,12.80, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7, bit
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7, bit
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,25, °C
IDE08358-MAS01447,Left seat cushion fan 1-Actual value,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,12.80, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6, bit
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6, bit
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,26, °C
IDE08360-MAS01447,Right seat backrest fan 1-Actual value,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,12.90, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3, bit
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3, bit
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0, counts
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,24, °C
IDE08362-MAS01447,Right seat cushion fan 1-Actual value,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,12.90, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2, bit
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2, bit
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0, counts
IDE08364-MAS01447,Left seat backrest fan 1: activation-Actual value,0, %
IDE08364-MAS01448,Left seat backrest fan 1: activation-Specified value,0, %
IDE08365-MAS01447,Left seat backrest fan 2: activation-Actual value,not coded / not installed,
IDE08365-MAS01448,Left seat backrest fan 2: activation-Specified value,not coded / not installed,
IDE08366-MAS01447,Left seat seat cushion fan 1: activation-Actual value,0, %
IDE08366-MAS01448,Left seat seat cushion fan 1: activation-Specified value,0, %
IDE08367-MAS01447,Left seat seat cushion fan 2: activation-Actual value,not coded / not installed,
IDE08367-MAS01448,Left seat seat cushion fan 2: activation-Specified value,not coded / not installed,
IDE08368-MAS01447,Right seat backrest fan 1: activation-Actual value,0, %
IDE08368-MAS01448,Right seat backrest fan 1: activation-Specified value,0, %
IDE08369-MAS01447,Right seat backrest fan 2: activation-Actual value,not coded / not installed,
IDE08369-MAS01448,Right seat backrest fan 2: activation-Specified value,not coded / not installed,
IDE08370-MAS01447,Right seat cushion fan 1: activation-Actual value,0, %
IDE08370-MAS01448,Right seat cushion fan 1: activation-Specified value,0, %
IDE08371-MAS01447,Right seat cushion fan 2: activation-Actual value,not coded / not installed,
IDE08371-MAS01448,Right seat cushion fan 2: activation-Specified value,not coded / not installed,
IDE08372,Fresh air blower: target speed,1400, /min
IDE08376-MAS01580,Right daytime running lamp and position lamp bulb-Activation,not coded / not installed,
IDE08376-MAS01737,Right daytime running lamp and position lamp bulb-Diagnosis,not coded / not installed,
IDE08376-MAS12621,Right daytime running lamp and position lamp bulb-Current draw (effective value),not coded / not installed,
IDE08377-MAS01580,Left daytime running lamp and position lamp bulb-Activation,not coded / not installed,
IDE08377-MAS01737,Left daytime running lamp and position lamp bulb-Diagnosis,not coded / not installed,
IDE08377-MAS12621,Left daytime running lamp and position lamp bulb-Current draw (effective value),not coded / not installed,
IDE08378-MAS01580,Right front turn signal bulb-Activation,not coded / not installed,
IDE08378-MAS01737,Right front turn signal bulb-Diagnosis,not coded / not installed,
IDE08378-MAS12621,Right front turn signal bulb-Current draw (effective value),not coded / not installed,
IDE08379-MAS01580,Left front turn signal bulb-Activation,not coded / not installed,
IDE08379-MAS01737,Left front turn signal bulb-Diagnosis,not coded / not installed,
IDE08379-MAS12621,Left front turn signal bulb-Current draw (effective value),not coded / not installed,
IDE08380-MAS01580,Right side marker lamp bulb-Activation,not coded / not installed,
IDE08380-MAS01737,Right side marker lamp bulb-Diagnosis,not coded / not installed,
IDE08380-MAS12621,Right side marker lamp bulb-Current draw (effective value),not coded / not installed,
IDE08381-MAS01580,Left side marker lamp bulb-Activation,not coded / not installed,
IDE08381-MAS01737,Left side marker lamp bulb-Diagnosis,not coded / not installed,
IDE08381-MAS12621,Left side marker lamp bulb-Current draw (effective value),not coded / not installed,
IDE08382-MAS01580,Right front side marker lamp bulb-Activation,not coded / not installed,
IDE08382-MAS01737,Right front side marker lamp bulb-Diagnosis,not coded / not installed,
IDE08382-MAS12621,Right front side marker lamp bulb-Current draw (effective value),not coded / not installed,
IDE08383-MAS01580,Left front side marker lamp bulb-Activation,not coded / not installed,
IDE08383-MAS01737,Left front side marker lamp bulb-Diagnosis,not coded / not installed,
IDE08383-MAS12621,Left front side marker lamp bulb-Current draw (effective value),not coded / not installed,
IDE08384-MAS01580,Right daytime running lamp bulb-Activation,not coded / not installed,
IDE08384-MAS01737,Right daytime running lamp bulb-Diagnosis,not coded / not installed,
IDE08384-MAS12621,Right daytime running lamp bulb-Current draw (effective value),not coded / not installed,
IDE08385-MAS01580,Left daytime running lamp bulb-Activation,not coded / not installed,
IDE08385-MAS01737,Left daytime running lamp bulb-Diagnosis,not coded / not installed,
IDE08385-MAS12621,Left daytime running lamp bulb-Current draw (effective value),not coded / not installed,
IDE08386-MAS01580,Right low beam headlamp bulb-Activation,100.00, %
IDE08386-MAS01737,Right low beam headlamp bulb-Diagnosis,No malfunction,
IDE08386-MAS12621,Right low beam headlamp bulb-Current draw (effective value),2368, mA
IDE08387-MAS01580,Left low beam headlamp bulb-Activation,100.00, %
IDE08387-MAS01737,Left low beam headlamp bulb-Diagnosis,No malfunction,
IDE08387-MAS12621,Left low beam headlamp bulb-Current draw (effective value),2507, mA
IDE08388-MAS01580,Right high beam headlamp-Activation,not coded / not installed,
IDE08388-MAS01737,Right high beam headlamp-Diagnosis,not coded / not installed,
IDE08388-MAS12621,Right high beam headlamp-Current draw (effective value),not coded / not installed,
IDE08389-MAS01580,Left high beam headlamp bulb-Activation,not coded / not installed,
IDE08389-MAS01737,Left high beam headlamp bulb-Diagnosis,not coded / not installed,
IDE08389-MAS12621,Left high beam headlamp bulb-Current draw (effective value),not coded / not installed,
IDE08390-MAS01580,Right fog light lamp-Activation,not coded / not installed,
IDE08390-MAS01737,Right fog light lamp-Diagnosis,not coded / not installed,
IDE08390-MAS12621,Right fog light lamp-Current draw (effective value),not coded / not installed,
IDE08391-MAS01580,Left fog light lamp-Activation,not coded / not installed,
IDE08391-MAS01737,Left fog light lamp-Diagnosis,not coded / not installed,
IDE08391-MAS12621,Left fog light lamp-Current draw (effective value),not coded / not installed,
IDE08392-MAS01580,Right LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08392-MAS01737,Right LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded / not installed,
IDE08392-MAS12621,Right LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded / not installed,
IDE08393-MAS01580,Left LED module daytime running lamp and parking lamp: supply-Activation,Not available,
IDE08393-MAS01737,Left LED module daytime running lamp and parking lamp: supply-Diagnosis,not coded / not installed,
IDE08393-MAS12621,Left LED module daytime running lamp and parking lamp: supply-Current draw (effective value),not coded / not installed,
IDE08394-MAS01580,Right LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08394-MAS01737,Right LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded / not installed,
IDE08394-MAS12621,Right LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded / not installed,
IDE08395-MAS01580,Left LED module daytime running lamp and park.lamp: activation-Activation,Not available,
IDE08395-MAS01737,Left LED module daytime running lamp and park.lamp: activation-Diagnosis,not coded / not installed,
IDE08395-MAS12621,Left LED module daytime running lamp and park.lamp: activation-Current draw (effective value),not coded / not installed,
IDE08396-MAS01580,Headlights right: supply-Activation,not coded / not installed,
IDE08396-MAS01737,Headlights right: supply-Diagnosis,not coded / not installed,
IDE08396-MAS12621,Headlights right: supply-Current draw (effective value),not coded / not installed,
IDE08397-MAS01580,Headlights left: supply-Activation,not coded / not installed,
IDE08397-MAS01737,Headlights left: supply-Diagnosis,not coded / not installed,
IDE08397-MAS12621,Headlights left: supply-Current draw (effective value),not coded / not installed,
IDE08402-IDE05742,Light switch-Light switch position,Not available,
IDE08402-IDE07956,Light switch-redundant signal line,OFF,
IDE08402-MAS03866,Light switch-Head-Up-Display button,Not available,
IDE08402-MAS03868,Light switch-Position of the Eyebox,Not available,
IDE08402-MAS06887,Light switch-Light switch position on CAN,Malfunction,
IDE08402-MAS06888,Light switch-Fog Lamp Button,Not available,
IDE08402-MAS06889,Light switch-Rear fog lamp button,Not available,
IDE08402-MAS06890,Light switch-Night vision system button,Not available,
IDE08402-MAS06891,Light switch-Control for Eyebox position,Not available,
IDE08404-IDE01351,Local data bus 1: information-Terminal 75 status,On,
IDE08404-MAS00370,Local data bus 1: information-Vehicle speed,0.00, km/h
IDE08404-MAS03679,Local data bus 1: information-Terminal 15 status,On,
IDE08404-MAS06495,Local data bus 1: information-Engine hood contact switch,closed,
IDE08405-MAS05030,Outside air temperature sensor-Resistance,1.17, kOhm
IDE08405-MAS08858,Outside air temperature sensor-Outside air temperature on CAN,22.00, °C
IDE08408,Hood contact,closed,
IDE08408-MAS14040,Hood contact-Voltage ratio,98, %
IDE08434-MAS01580,Right turn signal light bulb-Activation,not coded / not installed,
IDE08434-MAS01737,Right turn signal light bulb-Diagnosis,not coded / not installed,
IDE08434-MAS12621,Right turn signal light bulb-Current draw (effective value),not coded / not installed,
IDE08435-MAS01580,Left turn signal light bulb-Activation,not coded / not installed,
IDE08435-MAS01737,Left turn signal light bulb-Diagnosis,not coded / not installed,
IDE08435-MAS12621,Left turn signal light bulb-Current draw (effective value),not coded / not installed,
IDE08441-MAS06992,Control module for steering col electronics: requirements-Request wiping,Intermittent operation,
IDE08441-MAS06993,Control module for steering col electronics: requirements-Request signal horn,OFF,
IDE08441-MAS09575,Control module for steering col electronics: requirements-High beam request,OFF,
IDE08441-MAS09576,Control module for steering col electronics: requirements-Wash request,OFF,
IDE08441-MAS09577,Control module for steering col electronics: requirements-Rear interval wash request,OFF,
IDE08441-MAS09586,Control module for steering col electronics: requirements-Headlight flasher request,OFF,
IDE08441-MAS09587,Control module for steering col electronics: requirements-Headlight washer request,OFF,
IDE08441-MAS09600,Control module for steering col electronics: requirements-Request to flashing left,not active,
IDE08441-MAS09601,Control module for steering col electronics: requirements-Request to flashing right,not active,
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0, mA
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0, mA
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Neutral,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,OFF,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,0, %
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Neutral,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,OFF,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,0, %
IDE08502-MAS01580,A/C compressor regulator valve-Activation,28, %
IDE08502-MAS09777,A/C compressor regulator valve-Target current,262, mA
IDE08502-MAS09780,A/C compressor regulator valve-Supply Highside,On,
IDE08502-MAS12632,A/C compressor regulator valve-Current draw (mean value),260, mA
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,both sides,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02946,LED headlights: light distribution requirement-Static cornering light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,Measuring value not available,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-insufficient voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excessive voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-excessive temperature,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal error,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE08795-MAS06614,Rear shade button-Variant,not coded / not installed,
IDE08795-MAS07693,Rear shade button-Button Status,not coded / not installed,
IDE08795-MAS07694,Rear shade button-Button status on CAN,Initialization/not installed,
IDE08948-MAS01632,Electrically Adjustable Steering Column-Status,Not moving,
IDE08948-MAS06732,Electrically Adjustable Steering Column-Status local activity,was not local active,
IDE08948-MAS09493,Electrically Adjustable Steering Column-Position: vertical,1307,
IDE08948-MAS09494,Electrically Adjustable Steering Column-Position: axial,65,
IDE08948-MAS09495,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation up,Not operated,
IDE08948-MAS09496,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation down,Not operated,
IDE08948-MAS09497,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation out,Not operated,
IDE08948-MAS09498,Electrically Adjustable Steering Column-Button for steering column adjust.: direction of operation in,Not operated,
IDE08948-MAS09501,Electrically Adjustable Steering Column-Entry assistance button,Not operated,
IDE08948-MAS12678,Electrically Adjustable Steering Column-Motor for vertical adjustment: current draw (effective value),0.00, A
IDE08948-MAS12679,Electrically Adjustable Steering Column-Motor for axial adjustment: current draw (effective value),0.00, A
IDE08957-MAS01632,Supply for power outlets-Status,On,
IDE08957-MAS04445,Supply for power outlets-Relay output voltage,12.92, V
IDE08957-MAS07309,Supply for power outlets-Maximum current draw,46.80, A
IDE08957-MAS08025,Supply for power outlets-Output to input voltage ratio with relay switched off,46.33, %
IDE08957-MAS12621,Supply for power outlets-Current draw (effective value),132, mA
IDE08960-MAS08026,Status: control heads for driving and comfort functions-Control head for driving and comfort functions,not coded / not installed,
IDE08960-MAS08027,Status: control heads for driving and comfort functions-Control unit 2 for driving and convenience functions,not coded / not installed,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Separate activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Separate activation of backrest and seat cushion,
IDE08962-IDE08356,Installation info: seat ventilation-Left seat backrest fan 1,installed,
IDE08962-IDE08357,Installation info: seat ventilation-Left seat backrest fan 2,not installed,
IDE08962-IDE08358,Installation info: seat ventilation-Left seat cushion fan 1,installed,
IDE08962-IDE08359,Installation info: seat ventilation-Left seat cushion fan 2,not installed,
IDE08962-IDE08360,Installation info: seat ventilation-Right seat backrest fan 1,installed,
IDE08962-IDE08361,Installation info: seat ventilation-Right seat backrest fan 2,not installed,
IDE08962-IDE08362,Installation info: seat ventilation-Right seat cushion fan 1,installed,
IDE08962-IDE08363,Installation info: seat ventilation-Right seat cushion fan 2,not installed,
IDE08978-MAS01580,Windshield washer pump-Activation,OFF,
IDE08978-MAS09022,Windshield washer pump-PWM value,0, %
IDE08978-MAS12621,Windshield washer pump-Current draw (effective value),0, mA
IDE08979-MAS06614,Valet parking lock button-Variant,not coded / not installed,
IDE08979-MAS07693,Valet parking lock button-Button Status,not coded / not installed,
IDE08979-MAS07694,Valet parking lock button-Button status on CAN,Not operated,
IDE08979-MAS08062,Valet parking lock button-Indicator lamp activation,not coded / not installed,
IDE08980-MAS06614,Button for rear spoiler adjustment-Variant,not coded / not installed,
IDE08980-MAS07693,Button for rear spoiler adjustment-Button Status,not coded / not installed,
IDE08980-MAS07694,Button for rear spoiler adjustment-Button status on CAN,Initialization/not installed,
IDE08980-MAS07699,Button for rear spoiler adjustment-Status indicator light on CAN,OFF,
IDE08980-MAS08062,Button for rear spoiler adjustment-Indicator lamp activation,not coded / not installed,
IDE08981-MAS06614,Front display open/close button-Variant,not coded / not installed,
IDE08981-MAS07693,Front display open/close button-Button Status,not coded / not installed,
IDE08981-MAS07694,Front display open/close button-Button status on CAN,Initialization/not installed,
IDE08982-MAS06614,Button for start/stop operation/electrical driving-Variant,not coded / not installed,
IDE08982-MAS07693,Button for start/stop operation/electrical driving-Button Status,not coded / not installed,
IDE08982-MAS07694,Button for start/stop operation/electrical driving-Button status on CAN,Not operated,
IDE08982-MAS08062,Button for start/stop operation/electrical driving-Indicator lamp activation,not coded / not installed,
IDE08983-MAS06614,Driving profile selection button 2-Variant,not coded / not installed,
IDE08983-MAS07693,Driving profile selection button 2-Button Status,not coded / not installed,
IDE08983-MAS07694,Driving profile selection button 2-Button status on CAN,Initialization/not installed,
IDE08998-MAS06901,Driver info-Washer fluid level,OK,
IDE08998-MAS08063,Driver info-Coolant level from sensor for low coolant display,OK,
IDE08998-MAS08064,Driver info-Coolant level from sensor 2 for low coolant display,OK,
IDE08998-MAS08065,Driver info-Brake fluid level,OK,
IDE08998-MAS08122,Driver info-Brake lining,OK,
IDE08999-MAS08124,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: request,OFF,
IDE08999-MAS08125,Control modules for light activation: turn sig ctrl-Left front turn signal bulb: status,OFF,
IDE08999-MAS08126,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: request,OFF,
IDE08999-MAS08127,Control modules for light activation: turn sig ctrl-Right front turn signal bulb: status,OFF,
IDE08999-MAS08128,Control modules for light activation: turn sig ctrl-Left flashing function,not active,
IDE08999-MAS08129,Control modules for light activation: turn sig ctrl-Right flashing function,not active,
IDE08999-MAS08133,Control modules for light activation: turn sig ctrl-Flashing mode,Wiping,
IDE09000-MAS01580,Control module for light activation: left: supply-Activation,100, %
IDE09000-MAS01737,Control module for light activation: left: supply-Diagnosis,No malfunction,
IDE09000-MAS12621,Control module for light activation: left: supply-Current draw (effective value),544, mA
IDE09001-MAS01580,Control module for light activation: right: supply-Activation,100, %
IDE09001-MAS01737,Control module for light activation: right: supply-Diagnosis,No malfunction,
IDE09001-MAS12621,Control module for light activation: right: supply-Current draw (effective value),186, mA
IDE09234-MAS01580,Subfloor lighting-Activation,not coded / not installed,
IDE09234-MAS12621,Subfloor lighting-Current draw (effective value),not coded / not installed,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded / not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded / not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded / not installed,
IDE09887-MAS01580,Right daytime running lamp bulb 2-Activation,not coded / not installed,
IDE09887-MAS01737,Right daytime running lamp bulb 2-Diagnosis,not coded / not installed,
IDE09887-MAS12621,Right daytime running lamp bulb 2-Current draw (effective value),not coded / not installed,
IDE09888-MAS01580,Left daytime running lamp bulb 2-Activation,not coded / not installed,
IDE09888-MAS01737,Left daytime running lamp bulb 2-Diagnosis,not coded / not installed,
IDE09888-MAS12621,Left daytime running lamp bulb 2-Current draw (effective value),not coded / not installed,
IDE09920-MAS06614,Special vehicle control module-Variant,not coded / not installed,
IDE09920-MAS06992,Special vehicle control module-Request wiping,not coded / not installed,
IDE09920-MAS06993,Special vehicle control module-Request signal horn,not coded / not installed,
IDE09920-MAS09569,Special vehicle control module-Remote control status,not coded / not installed,
IDE09920-MAS09570,Special vehicle control module-Parking light request,not coded / not installed,
IDE09920-MAS09571,Special vehicle control module-Low beam request,not coded / not installed,
IDE09920-MAS09572,Special vehicle control module-Intermittent high beam request,not coded / not installed,
IDE09920-MAS09573,Special vehicle control module-Footwell illumination request,not coded / not installed,
IDE09920-MAS09574,Special vehicle control module-Interior illumination request,not coded / not installed,
IDE09920-MAS09575,Special vehicle control module-High beam request,not coded / not installed,
IDE09920-MAS09576,Special vehicle control module-Wash request,not coded / not installed,
IDE09920-MAS09577,Special vehicle control module-Rear interval wash request,not coded / not installed,
IDE09920-MAS09586,Special vehicle control module-Headlight flasher request,not coded / not installed,
IDE09920-MAS09588,Special vehicle control module-Emerg. sig. flasher request,not coded / not installed,
IDE09920-MAS09589,Special vehicle control module-Daytime running light deactivation req.,not coded / not installed,
IDE09920-MAS09590,Special vehicle control module-Suppression of interior illumination request,not coded / not installed,
IDE09922-MAS01448,Static headlamp range control-Specified value,not coded / not installed,
IDE09922-MAS09527,Static headlamp range control-Activation voltage: act. value,not coded / not installed,
IDE09922-MAS10074,Static headlamp range control-Supply voltage: actual value,not coded / not installed,
IDE09922-MAS10075,Static headlamp range control-Activation voltage/supply voltage ratio,not coded / not installed,
IDE09922-MAS12621,Static headlamp range control-Current draw (effective value),not coded / not installed,
IDE09933,Multifunction steerg. wheel: request signal horn,OFF,
IDE09934-MAS09591,Shift lever / selector lever position-Signal transm. ctrl. mod.,Selector lever in position P,
IDE09934-MAS09592,Shift lever / selector lever position-Signal engine ctrl. mod.,Unknown (9)
IDE09936-MAS01580,Right daytime running lamp and parking lamp bulb 2-Activation,not coded / not installed,
IDE09936-MAS01737,Right daytime running lamp and parking lamp bulb 2-Diagnosis,not coded / not installed,
IDE09936-MAS12621,Right daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded / not installed,
IDE09937-MAS01580,Left daytime running lamp and parking lamp bulb 2-Activation,not coded / not installed,
IDE09937-MAS01737,Left daytime running lamp and parking lamp bulb 2-Diagnosis,not coded / not installed,
IDE09937-MAS12621,Left daytime running lamp and parking lamp bulb 2-Current draw (effective value),not coded / not installed,
IDE09938-MAS01580,Right front turn signal bulb 2-Activation,not coded / not installed,
IDE09938-MAS01737,Right front turn signal bulb 2-Diagnosis,not coded / not installed,
IDE09938-MAS12621,Right front turn signal bulb 2-Current draw (effective value),not coded / not installed,
IDE09939-MAS01580,Left front turn signal bulb 2-Activation,not coded / not installed,
IDE09939-MAS01737,Left front turn signal bulb 2-Diagnosis,not coded / not installed,
IDE09939-MAS12621,Left front turn signal bulb 2-Current draw (effective value),not coded / not installed,
IDE09940-MAS01580,Right side marker bulb 2-Activation,not coded / not installed,
IDE09940-MAS01737,Right side marker bulb 2-Diagnosis,not coded / not installed,
IDE09940-MAS12621,Right side marker bulb 2-Current draw (effective value),not coded / not installed,
IDE09941-MAS01580,Left side marker bulb 2-Activation,not coded / not installed,
IDE09941-MAS01737,Left side marker bulb 2-Diagnosis,not coded / not installed,
IDE09941-MAS12621,Left side marker bulb 2-Current draw (effective value),not coded / not installed,
IDE09955-MAS07693,Automatic dimming interior mirror-Button Status,Not operated,
IDE09955-MAS09651,Automatic dimming interior mirror-Error status sensor front,not faulty,
IDE09955-MAS09652,Automatic dimming interior mirror-Error status sensor rear,not faulty,
IDE09955-MAS10386,Automatic dimming interior mirror-Dim. value spec.: exterior mirror,0.00, V
IDE09958-MAS01580,Right low beam reflector motor-Activation,not coded / not installed,
IDE09958-MAS01737,Right low beam reflector motor-Diagnosis,not coded / not installed,
IDE09958-MAS12621,Right low beam reflector motor-Current draw (effective value),not coded / not installed,
IDE09959-MAS01580,Left low beam headlamp reflector-Activation,not coded / not installed,
IDE09959-MAS01737,Left low beam headlamp reflector-Diagnosis,not coded / not installed,
IDE09959-MAS12621,Left low beam headlamp reflector-Current draw (effective value),not coded / not installed,
IDE10085-MAS09757,Switch and display illumination-Terminal 58xs on CAN,100, %
IDE10085-MAS09815,Switch and display illumination-Terminal 58xd on CAN,100,
IDE10085-MAS09816,Switch and display illumination-Phototransistor wert,Not available,
IDE10085-MAS09817,Switch and display illumination-Terminal 58xs,100.00, %
IDE10085-MAS09819,Switch and display illumination-T. 58xs: Diagnosis,No malfunction,
IDE10085-MAS09820,Switch and display illumination-Terminal 58xt,100.00, %
IDE10085-MAS09822,Switch and display illumination-T. 58xt: Diagnosis,No malfunction,
IDE10085-MAS09823,Switch and display illumination-Driver's request (light switch),Not available,
IDE10085-MAS09824,Switch and display illumination-Driver's request (Kombi),Not available,
IDE10085-MAS09825,Switch and display illumination-Driver's request (MMI),not coded / not installed,
IDE10085-MAS09826,Switch and display illumination-Driver's request on CAN,100, %
IDE10085-MAS09827,Switch and display illumination-Terminal 58xt on CAN,100, %
IDE10085-MAS12628,Switch and display illumination-Terminal 58xs: current draw (effective value),91, mA
IDE10085-MAS12629,Switch and display illumination-Terminal 58xt: current draw (effective value),20, mA
IDE10124-MAS07052,Front left seat heating-Setting,Stage 6,
IDE10124-MAS07921,Front left seat heating-Balance setting,Neutral,
IDE10124-MAS07951,Front left seat heating-Automatic down-shift,not coded / not installed,
IDE10124-MAS15417,Front left seat heating-Area heating adjustment,OFF,
IDE10125-MAS07052,Front right seat heating-Setting,OFF,
IDE10125-MAS07921,Front right seat heating-Balance setting,Neutral,
IDE10125-MAS07951,Front right seat heating-Automatic down-shift,not coded / not installed,
IDE10125-MAS15417,Front right seat heating-Area heating adjustment,OFF,
IDE10126-MAS07052,Rear left seat heating-Setting,OFF,
IDE10126-MAS07921,Rear left seat heating-Balance setting,Neutral,
IDE10126-MAS07951,Rear left seat heating-Automatic down-shift,not coded / not installed,
IDE10126-MAS15417,Rear left seat heating-Area heating adjustment,OFF,
IDE10127-MAS07052,Rear right seat heating-Setting,OFF,
IDE10127-MAS07921,Rear right seat heating-Balance setting,Neutral,
IDE10127-MAS07951,Rear right seat heating-Automatic down-shift,not coded / not installed,
IDE10127-MAS15417,Rear right seat heating-Area heating adjustment,OFF,
IDE10128-MAS01632,Front left seat cushion heating-Status,PI-regulation active,
IDE10128-MAS05945,Front left seat cushion heating-Target temperature,53.00, °C
IDE10128-MAS05946,Front left seat cushion heating-Actual temp.,53.00, °C
IDE10128-MAS07929,Front left seat cushion heating-Power quota setting by energy management,3,
IDE10128-MAS12066,Front left seat cushion heating-Cancellation status,Heating process not interrupted,
IDE10128-MAS14067,Front left seat cushion heating-Actuation specified value,48, %
IDE10129-MAS01632,Seat backrest heater: left front-Status,PI-regulation active,
IDE10129-MAS05945,Seat backrest heater: left front-Target temperature,57.00, °C
IDE10129-MAS05946,Seat backrest heater: left front-Actual temp.,57.00, °C
IDE10129-MAS07929,Seat backrest heater: left front-Power quota setting by energy management,3,
IDE10129-MAS12066,Seat backrest heater: left front-Cancellation status,Heating process not interrupted,
IDE10129-MAS14067,Seat backrest heater: left front-Actuation specified value,67, %
IDE10130-MAS01632,Front right seat cushion heating-Status,not active,
IDE10130-MAS05945,Front right seat cushion heating-Target temperature,OFF,
IDE10130-MAS05946,Front right seat cushion heating-Actual temp.,22.00, °C
IDE10130-MAS07929,Front right seat cushion heating-Power quota setting by energy management,0,
IDE10130-MAS12066,Front right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10130-MAS14067,Front right seat cushion heating-Actuation specified value,0, %
IDE10131-MAS01632,Seat backrest heater: right front-Status,not active,
IDE10131-MAS05945,Seat backrest heater: right front-Target temperature,OFF,
IDE10131-MAS05946,Seat backrest heater: right front-Actual temp.,21.00, °C
IDE10131-MAS07929,Seat backrest heater: right front-Power quota setting by energy management,0,
IDE10131-MAS12066,Seat backrest heater: right front-Cancellation status,Heating process interrupted,
IDE10131-MAS14067,Seat backrest heater: right front-Actuation specified value,0, %
IDE10132-MAS01632,Rear left seat cushion heating-Status,not active,
IDE10132-MAS05945,Rear left seat cushion heating-Target temperature,OFF,
IDE10132-MAS05946,Rear left seat cushion heating-Actual temp.,24.00, °C
IDE10132-MAS07929,Rear left seat cushion heating-Power quota setting by energy management,0,
IDE10132-MAS12066,Rear left seat cushion heating-Cancellation status,Heating process interrupted,
IDE10132-MAS14067,Rear left seat cushion heating-Actuation specified value,0, %
IDE10133-MAS01632,Seat backrest heater: left rear-Status,not coded / not installed,
IDE10133-MAS05945,Seat backrest heater: left rear-Target temperature,not coded / not installed,
IDE10133-MAS05946,Seat backrest heater: left rear-Actual temp.,not coded / not installed,
IDE10133-MAS07929,Seat backrest heater: left rear-Power quota setting by energy management,not coded / not installed,
IDE10133-MAS12066,Seat backrest heater: left rear-Cancellation status,not coded / not installed,
IDE10133-MAS14067,Seat backrest heater: left rear-Actuation specified value,not coded / not installed,
IDE10134-MAS01632,Rear right seat cushion heating-Status,not active,
IDE10134-MAS05945,Rear right seat cushion heating-Target temperature,OFF,
IDE10134-MAS05946,Rear right seat cushion heating-Actual temp.,22.00, °C
IDE10134-MAS07929,Rear right seat cushion heating-Power quota setting by energy management,0,
IDE10134-MAS12066,Rear right seat cushion heating-Cancellation status,Heating process interrupted,
IDE10134-MAS14067,Rear right seat cushion heating-Actuation specified value,0, %
IDE10135-MAS01632,Seat backrest heater: right rear-Status,not coded / not installed,
IDE10135-MAS05945,Seat backrest heater: right rear-Target temperature,not coded / not installed,
IDE10135-MAS05946,Seat backrest heater: right rear-Actual temp.,not coded / not installed,
IDE10135-MAS07929,Seat backrest heater: right rear-Power quota setting by energy management,not coded / not installed,
IDE10135-MAS12066,Seat backrest heater: right rear-Cancellation status,not coded / not installed,
IDE10135-MAS14067,Seat backrest heater: right rear-Actuation specified value,not coded / not installed,
IDE10136-MAS01632,Front left door area heating-Status,not coded / not installed,
IDE10136-MAS05945,Front left door area heating-Target temperature,not coded / not installed,
IDE10136-MAS05946,Front left door area heating-Actual temp.,not coded / not installed,
IDE10136-MAS07929,Front left door area heating-Power quota setting by energy management,not coded / not installed,
IDE10136-MAS12066,Front left door area heating-Cancellation status,not coded / not installed,
IDE10136-MAS14067,Front left door area heating-Actuation specified value,not coded / not installed,
IDE10138-MAS01632,Front right door area heating-Status,not coded / not installed,
IDE10138-MAS05945,Front right door area heating-Target temperature,not coded / not installed,
IDE10138-MAS05946,Front right door area heating-Actual temp.,not coded / not installed,
IDE10138-MAS07929,Front right door area heating-Power quota setting by energy management,not coded / not installed,
IDE10138-MAS12066,Front right door area heating-Cancellation status,not coded / not installed,
IDE10138-MAS14067,Front right door area heating-Actuation specified value,not coded / not installed,
IDE10140-MAS01632,Rear left door area heating-Status,not coded / not installed,
IDE10140-MAS05945,Rear left door area heating-Target temperature,not coded / not installed,
IDE10140-MAS05946,Rear left door area heating-Actual temp.,not coded / not installed,
IDE10140-MAS07929,Rear left door area heating-Power quota setting by energy management,not coded / not installed,
IDE10140-MAS12066,Rear left door area heating-Cancellation status,not coded / not installed,
IDE10140-MAS14067,Rear left door area heating-Actuation specified value,not coded / not installed,
IDE10142-MAS01632,Rear right door area heating-Status,not coded / not installed,
IDE10142-MAS05945,Rear right door area heating-Target temperature,not coded / not installed,
IDE10142-MAS05946,Rear right door area heating-Actual temp.,not coded / not installed,
IDE10142-MAS07929,Rear right door area heating-Power quota setting by energy management,not coded / not installed,
IDE10142-MAS12066,Rear right door area heating-Cancellation status,not coded / not installed,
IDE10142-MAS14067,Rear right door area heating-Actuation specified value,not coded / not installed,
IDE10144-MAS01632,Front center arm rest heating-Status,not coded / not installed,
IDE10144-MAS05945,Front center arm rest heating-Target temperature,not coded / not installed,
IDE10144-MAS05946,Front center arm rest heating-Actual temp.,not coded / not installed,
IDE10144-MAS07929,Front center arm rest heating-Power quota setting by energy management,not coded / not installed,
IDE10144-MAS12066,Front center arm rest heating-Cancellation status,not coded / not installed,
IDE10144-MAS14067,Front center arm rest heating-Actuation specified value,not coded / not installed,
IDE10145-MAS01632,Rear center arm rest heating-Status,not coded / not installed,
IDE10145-MAS05945,Rear center arm rest heating-Target temperature,not coded / not installed,
IDE10145-MAS05946,Rear center arm rest heating-Actual temp.,not coded / not installed,
IDE10145-MAS07929,Rear center arm rest heating-Power quota setting by energy management,not coded / not installed,
IDE10145-MAS12066,Rear center arm rest heating-Cancellation status,not coded / not installed,
IDE10145-MAS14067,Rear center arm rest heating-Actuation specified value,not coded / not installed,
IDE10219-MAS01580,High/low tone horn-Activation,OFF,
IDE10219-MAS12621,High/low tone horn-Current draw (effective value),0, mA
IDE10260-MAS01448,Static headlight range adjustment: spec./counter-Specified value,not coded / not installed,
IDE10260-MAS10076,Static headlight range adjustment: spec./counter-Step index,not coded / not installed,
IDE10260-MAS11358,Static headlight range adjustment: spec./counter-Number of adjustments left motor,0,
IDE10260-MAS11359,Static headlight range adjustment: spec./counter-Number of adjustments right motor,0,
IDE10327-MAS01632,Cup holder with heating and cooling element-Status,not coded / not installed,
IDE10327-MAS01968,Cup holder with heating and cooling element-Fan,not coded / not installed,
IDE10327-MAS02819,Cup holder with heating and cooling element-CURRENT temperature,not coded / not installed,
IDE10327-MAS02832,Cup holder with heating and cooling element-Malfunction status,not coded / not installed,
IDE10327-MAS10303,Cup holder with heating and cooling element-Heating function indicator lamp,not coded / not installed,
IDE10327-MAS10304,Cup holder with heating and cooling element-Cooling function indicator lamp,not coded / not installed,
IDE10327-MAS10305,Cup holder with heating and cooling element-Light for residual heat display,not coded / not installed,
IDE10327-MAS10333,Cup holder with heating and cooling element-Heat function button,not coded / not installed,
IDE10327-MAS10334,Cup holder with heating and cooling element-Cooling function button,not coded / not installed,
IDE10327-MAS10336,Cup holder with heating and cooling element-Peltier element,not coded / not installed,
IDE10327-MAS10337,Cup holder with heating and cooling element-Peltier element: PWM value,not coded / not installed,
IDE10338,Ctrl. motor for left headlight range adjust.: act. value,-9.00, mm
IDE10339,Ctrl. motor for right headlight range adjust.: act. value,-9.00, mm
IDE10340-IDE00104,Roof electronics control module-DTC,0,
IDE10340-MAS01634,Roof electronics control module-Supply voltage,12.80, V
IDE10340-MAS02832,Roof electronics control module-Malfunction status,not faulty,
IDE10340-MAS05946,Roof electronics control module-Actual temp.,31, °C
IDE10340-MAS09113,Roof electronics control module-Maximum temperature,65, °C
IDE10343-MAS01795,Roof electronics control module: dim. value-Front interior light,0, %
IDE10343-MAS10434,Roof electronics control module: dim. value-Indicator lamps,8, %
IDE10343-MAS10497,Roof electronics control module: dim. value-Ceiling contour lights: dim. value,0, %
IDE10343-MAS10498,Roof electronics control module: dim. value-Ceiling contour lights: diagnosis,Unknown (0)
IDE10343-MAS14264,Roof electronics control module: dim. value-Front search illumination,100, %
IDE10343-MAS14268,Roof electronics control module: dim. value-Left rear interior lamp: dimming value,0, %
IDE10343-MAS14269,Roof electronics control module: dim. value-Left rear interior light: diagnostics,No malfunction,
IDE10343-MAS14270,Roof electronics control module: dim. value-Right rear interior lamp: dimming value,0, %
IDE10343-MAS14271,Roof electronics control module: dim. value-Right rear interior lamp: diagnostics,No malfunction,
IDE10343-MAS15403,Roof electronics control module: dim. value-Front passenger airbag indicator lamp,0, %
IDE10345-MAS10416,Roof electronics control module: button-Front interior light button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10418,Roof electronics control module: button-Front button for rear reading light,Not operated,
IDE10345-MAS10419,Roof electronics control module: button-Front reading lamp button: left,Not operated,
IDE10345-MAS10420,Roof electronics control module: button-Front reading lamp button: right,Not operated,
IDE10345-MAS10421,Roof electronics control module: button-Left rear reading lamp switch,Not operated,
IDE10345-MAS10422,Roof electronics control module: button-Right rear reading lamp button,Not operated,
IDE10345-MAS10423,Roof electronics control module: button-Left reading light button: 3rd seat row,Not operated,
IDE10345-MAS10424,Roof electronics control module: button-Right reading light button: 3rd seat row,Not operated,
IDE10345-MAS10425,Roof electronics control module: button-Emergency call button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10346-IDE01097,Roof electronics control module: indicator lights-Front passenger airbag -disabled- indicator lamp,OFF,
IDE10346-MAS10427,Roof electronics control module: indicator lights-Indicator lamp for interior light: front,OFF,
IDE10346-MAS10428,Roof electronics control module: indicator lights-Indicator light for door contact switching,On,
IDE10346-MAS10429,Roof electronics control module: indicator lights-Indicator lamp for front reading light,OFF,
IDE10346-MAS10431,Roof electronics control module: indicator lights-Indicator light for roadside assist.,OFF,
IDE10346-MAS14279,Roof electronics control module: indicator lights-Indicator lamp for emergency call: green,On,
IDE10346-MAS14280,Roof electronics control module: indicator lights-Indicator lamp for emergency call: red,OFF,
IDE10346-MAS15376,Roof electronics control module: indicator lights-Front passenger airbag indicator lamp on,OFF,
IDE10346-MAS15377,Roof electronics control module: indicator lights-Front passenger airbag lettering,OFF,
IDE10360-MAS01442,A/C compressor speed sensor-Compressor speed,not coded / not installed,
IDE10360-MAS10225,A/C compressor speed sensor-Signal level,not coded / not installed,
IDE10360-MAS10455,A/C compressor speed sensor-Deviation of compressor speed from specified RPM,not coded / not installed,
IDE10361-MAS06905,Driver information sensor-Washer fluid level sensor,2.49, kOhm
IDE10361-MAS06906,Driver information sensor-Sensor for inadequate coolant level display,1.30, kOhm
IDE10361-MAS07003,Driver information sensor-Engine Coolant Level Sensor 2,not coded / not installed,
IDE10482-MAS01632,Activation for external systems-Status,not coded / not installed,
IDE10482-MAS07929,Activation for external systems-Power quota setting by energy management,not coded / not installed,
IDE10482-MAS10746,Activation for external systems-Installation info.: external system,no system,
IDE10602-MAS01632,Reclining seat: lower leg support heating-Status,not coded / not installed,
IDE10602-MAS05945,Reclining seat: lower leg support heating-Target temperature,not coded / not installed,
IDE10602-MAS05946,Reclining seat: lower leg support heating-Actual temp.,not coded / not installed,
IDE10602-MAS07929,Reclining seat: lower leg support heating-Power quota setting by energy management,not coded / not installed,
IDE10602-MAS12066,Reclining seat: lower leg support heating-Cancellation status,not coded / not installed,
IDE10602-MAS14067,Reclining seat: lower leg support heating-Actuation specified value,not coded / not installed,
IDE10603-MAS01632,Reclining seat: foot sole heating-Status,not coded / not installed,
IDE10603-MAS05945,Reclining seat: foot sole heating-Target temperature,not coded / not installed,
IDE10603-MAS05946,Reclining seat: foot sole heating-Actual temp.,not coded / not installed,
IDE10603-MAS07929,Reclining seat: foot sole heating-Power quota setting by energy management,not coded / not installed,
IDE10603-MAS12066,Reclining seat: foot sole heating-Cancellation status,not coded / not installed,
IDE10603-MAS14067,Reclining seat: foot sole heating-Actuation specified value,not coded / not installed,
IDE10645,Status of optical display park assist,OFF,
IDE10646,State status machine for rear wheel drive,operational,
IDE10662-MAS00530,Light switch (button module)-Rear fog light indicator lamp,OFF,
IDE10662-MAS01632,Light switch (button module)-Status,operational,
IDE10662-MAS05451,Light switch (button module)-Low beam indicator lamp,On,
IDE10662-MAS06614,Light switch (button module)-Variant,Variant 1,
IDE10662-MAS06732,Light switch (button module)-Status local activity,not active,
IDE10662-MAS06888,Light switch (button module)-Fog Lamp Button,Not operated,
IDE10662-MAS06889,Light switch (button module)-Rear fog lamp button,Not operated,
IDE10662-MAS07055,Light switch (button module)-Response error,not active,
IDE10662-MAS07376,Light switch (button module)-Terminal 58xd,100,
IDE10662-MAS09817,Light switch (button module)-Terminal 58xs,100, %
IDE10662-MAS09820,Light switch (button module)-Terminal 58xt,100, %
IDE10662-MAS12385,Light switch (button module)-Automatic driving light control indicator lamp,On,
IDE10662-MAS12415,Light switch (button module)-Parking lamp indicator lamp,OFF,
IDE10662-MAS12416,Light switch (button module)-Daytime running lamp indicator lamp,OFF,
IDE10662-MAS12417,Light switch (button module)-Fog lights indicator lights,OFF,
IDE10662-MAS12419,Light switch (button module)-Side light button,not installed,
IDE10662-MAS12420,Light switch (button module)-Low-beam light button,not installed,
IDE10662-MAS12421,Light switch (button module)-Proximity sensor,no approach,
IDE10662-MAS14302,Light switch (button module)-Automatic high beam button/exterior lighting button,Not operated,
IDE10808-MAS06614,Directional stabilization assistance button-Variant,not coded / not installed,
IDE10808-MAS07693,Directional stabilization assistance button-Button Status,not coded / not installed,
IDE10808-MAS07694,Directional stabilization assistance button-Button status on CAN,Initialization/not installed,
IDE10808-MAS08062,Directional stabilization assistance button-Indicator lamp activation,not coded / not installed,
IDE10809-MAS06993,Driver assistance systems control module-Request signal horn,not coded / not installed,
IDE10809-MAS13254,Driver assistance systems control module-Active parking function,not coded / not installed,
IDE10810-MAS06614,Button for side view camera-Variant,not coded / not installed,
IDE10810-MAS07693,Button for side view camera-Button Status,not coded / not installed,
IDE10810-MAS07694,Button for side view camera-Button status on CAN,Initialization/not installed,
IDE10945-MAS01580,Refrigerant Shut-Off Valve 1-Activation,not coded / not installed,
IDE10945-MAS12621,Refrigerant Shut-Off Valve 1-Current draw (effective value),not coded / not installed,
IDE10946-MAS01580,Refrigerant Shut-Off Valve 2-Activation,not coded / not installed,
IDE10946-MAS12621,Refrigerant Shut-Off Valve 2-Current draw (effective value),not coded / not installed,
IDE10964-MAS06614,Button for instrument panel vents-Variant,not coded / not installed,
IDE10964-MAS07693,Button for instrument panel vents-Button Status,not coded / not installed,
IDE10964-MAS07694,Button for instrument panel vents-Button status on CAN,Initialization/not installed,
IDE10964-MAS07699,Button for instrument panel vents-Status indicator light on CAN,OFF,
IDE10964-MAS08062,Button for instrument panel vents-Indicator lamp activation,not coded / not installed,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,2426, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,2428, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,2433, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,2428, mm
IDE11273-MAS10360,Control unit 2 for driv.and convenience funct.: special funct.-Lift button for vehicle leveling,not coded / not installed,
IDE11273-MAS10361,Control unit 2 for driv.and convenience funct.: special funct.-Lower button for vehicle leveling,not coded / not installed,
IDE11273-MAS12379,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: actual mode,not coded / not installed,
IDE11273-MAS12380,Control unit 2 for driv.and convenience funct.: special funct.-Drive program rotary switch: mode setting,not coded / not installed,
IDE11273-MAS12499,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for load level,not coded / not installed,
IDE11273-MAS12500,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for low level,not coded / not installed,
IDE11273-MAS12501,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for high level,not coded / not installed,
IDE11273-MAS12502,Control unit 2 for driv.and convenience funct.: special funct.-Indicator light for special off-road level,not coded / not installed,
IDE11274-MAS08932,Operating controls for sunroof/tilt roof and roof blind-Sunroof shade button,Not operated,
IDE11274-MAS12383,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof,Not operated,
IDE11274-MAS12515,Operating controls for sunroof/tilt roof and roof blind-Button for sunroof/tilt roof: rear,Not operated,
IDE11274-MAS12516,Operating controls for sunroof/tilt roof and roof blind-Button sunroof shade button: rear,Not operated,
IDE11301-MAS12561,Number of events: headlight theft monitoring-Theft: left headlight suspected due to cold monitoring,0,
IDE11301-MAS12562,Number of events: headlight theft monitoring-Theft: right headlight suspected due to cold monitoring,0,
IDE11301-MAS12563,Number of events: headlight theft monitoring-Theft: left headlight confirmed due to heat monitoring,0,
IDE11301-MAS12564,Number of events: headlight theft monitoring-Theft: right headlight confirmed due to heat monitoring,0,
IDE11348,Variable left front lighting: actual position,Measuring value not available,
IDE11349,Variable right front lighting: actual position,Measuring value not available,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,10, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,10, W/m²
IDE11361-MAS06732,Control unit for windshield washer pump-Status local activity,not coded / not installed,
IDE11361-MAS12606,Control unit for windshield washer pump-Status of windshield wiper pump,not coded / not installed,
IDE11361-MAS12607,Control unit for windshield washer pump-Status of wiper arm heater,not coded / not installed,
IDE11361-MAS12608,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of upper change pos.,not coded / not installed,
IDE11361-MAS12609,Control unit for windshield washer pump-Activ. of windsh. wiper pump: direction of lower change pos.,not coded / not installed,
IDE11361-MAS12610,Control unit for windshield washer pump-Activation of wiper arm heater,not coded / not installed,
IDE11551-IDE01078,Status of identification data query on LIN-Bus-Fresh air blower: front,Data complete but not secured,
IDE11551-IDE06163,Status of identification data query on LIN-Bus-Humidity sensor: exterior,Data complete but not secured,
IDE11551-IDE11361,Status of identification data query on LIN-Bus-Control unit for windshield washer pump,not coded / not installed,
IDE11551-IDE11719,Status of identification data query on LIN-Bus-Fan 1 for left rear seat backrest,not coded / not installed,
IDE11551-IDE11720,Status of identification data query on LIN-Bus-Fan 1 for left rear seat cushion,not coded / not installed,
IDE11551-IDE11721,Status of identification data query on LIN-Bus-Fan 1 for right rear seat backrest,not coded / not installed,
IDE11551-IDE11722,Status of identification data query on LIN-Bus-Fan 1 for right rear seat cushion,not coded / not installed,
IDE11551-IDE11723,Status of identification data query on LIN-Bus-Fan 2 for left rear seat backrest,not coded / not installed,
IDE11551-IDE11724,Status of identification data query on LIN-Bus-Fan 2 for left rear seat cushion,not coded / not installed,
IDE11551-IDE11725,Status of identification data query on LIN-Bus-Fan 2 for right rear seat backrest,not coded / not installed,
IDE11551-IDE11726,Status of identification data query on LIN-Bus-Fan 2 for right rear seat cushion,not coded / not installed,
IDE11551-IDE11794,Status of identification data query on LIN-Bus-Fragrance diffuser system control module,not coded / not installed,
IDE11551-IDE12358,Status of identification data query on LIN-Bus-Roof electronics control module 2,not coded / not installed,
IDE11551-MAS00746,Status of identification data query on LIN-Bus-Wiper motor control module,Data complete but not secured,
IDE11551-MAS00747,Status of identification data query on LIN-Bus-Rain/Light Recognition Sensor,Data complete but not secured,
IDE11551-MAS00748,Status of identification data query on LIN-Bus-Light switch,Data complete but not secured,
IDE11551-MAS00749,Status of identification data query on LIN-Bus-Garage door opener control module,not coded / not installed,
IDE11551-MAS00750,Status of identification data query on LIN-Bus-Garage door opener control head,not coded / not installed,
IDE11551-MAS00762,Status of identification data query on LIN-Bus-Automatic dimming interior mirror,Data complete but not secured,
IDE11551-MAS01562,Status of identification data query on LIN-Bus-Air quality sensor,not coded / not installed,
IDE11551-MAS08026,Status of identification data query on LIN-Bus-Control head for driving and comfort functions,not coded / not installed,
IDE11551-MAS08027,Status of identification data query on LIN-Bus-Control unit 2 for driving and convenience functions,not coded / not installed,
IDE11551-MAS10760,Status of identification data query on LIN-Bus-Coolant expansion valve: A/C,not coded / not installed,
IDE11551-MAS12901,Status of identification data query on LIN-Bus-Control module for roof electronics,Data complete but not secured,
IDE11551-MAS12902,Status of identification data query on LIN-Bus-Control module for steering column adjustment,Data complete but not secured,
IDE11551-MAS12903,Status of identification data query on LIN-Bus-Right Neck Heating Control Module,not coded / not installed,
IDE11551-MAS12904,Status of identification data query on LIN-Bus-Left Neck Heating Control Module,not coded / not installed,
IDE11551-MAS12905,Status of identification data query on LIN-Bus-Blower 1 for left front backrest,Data complete but not secured,
IDE11551-MAS12906,Status of identification data query on LIN-Bus-Blower 2 for left front backrest,not coded / not installed,
IDE11551-MAS12907,Status of identification data query on LIN-Bus-Blower 1 for left front seat cushion,Data complete but not secured,
IDE11551-MAS12908,Status of identification data query on LIN-Bus-Blower 2 for left front seat cushion,not coded / not installed,
IDE11551-MAS12909,Status of identification data query on LIN-Bus-Blower 1 for right front backrest,Data complete but not secured,
IDE11551-MAS12910,Status of identification data query on LIN-Bus-Blower 2 for right front backrest,not coded / not installed,
IDE11551-MAS12911,Status of identification data query on LIN-Bus-Blower 1 for right front seat cushion,Data complete but not secured,
IDE11551-MAS12912,Status of identification data query on LIN-Bus-Blower 2 for right front seat cushion,not coded / not installed,
IDE11551-MAS12913,Status of identification data query on LIN-Bus-Valve block 1 in front seat driver side,not coded / not installed,
IDE11551-MAS12914,Status of identification data query on LIN-Bus-Valve block 1 in front seat passenger side,not coded / not installed,
IDE11551-MAS12915,Status of identification data query on LIN-Bus-Cup holder with heating and cooling element,not coded / not installed,
IDE11551-MAS12916,Status of identification data query on LIN-Bus-Humidity sensor: interior,not coded / not installed,
IDE11551-MAS14926,Status of identification data query on LIN-Bus-Sensor for carbon dioxide content in the interior,not coded / not installed,
IDE11551-MAS14927,Status of identification data query on LIN-Bus-Rear A/C control and display head,Data complete but not secured,
IDE11551-MAS15174,Status of identification data query on LIN-Bus-Front A/C display control head,not coded / not installed,
IDE11551-MAS15185,Status of identification data query on LIN-Bus-Sensor for particulate matter content in the A/C,not coded / not installed,
IDE11551-MAS16271,Status of identification data query on LIN-Bus-Sensor for visibility distance measurement,not coded / not installed,
IDE11551-SFT271903,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor,not coded / not installed,
IDE11551-SFT271920,Status of identification data query on LIN-Bus-Ionization,not coded / not installed,
IDE11551-SFT272022,Status of identification data query on LIN-Bus-Rear A/C Control Head 6,not coded / not installed,
IDE11551-SFT272046,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 2,not coded / not installed,
IDE11551-SFT272047,Status of identification data query on LIN-Bus-A/C pressure/coolant temperature sensor 3,not coded / not installed,
IDE11551-SFT272073,Status of identification data query on LIN-Bus-Rear A/C Control Head 1,not coded / not installed,
IDE11551-SFT272074,Status of identification data query on LIN-Bus-Rear A/C Control Head 2,not coded / not installed,
IDE11551-SFT272075,Status of identification data query on LIN-Bus-Rear A/C Control Head 3,not coded / not installed,
IDE11551-SFT272076,Status of identification data query on LIN-Bus-Rear A/C Control Head 4,not coded / not installed,
IDE11551-SFT272077,Status of identification data query on LIN-Bus-Rear A/C Control Head 5,not coded / not installed,
IDE11551-SFT272171,Status of identification data query on LIN-Bus-Control module for heating element 1,Data complete but not secured,
IDE11551-SFT272172,Status of identification data query on LIN-Bus-Control module for heating element 2,not coded / not installed,
IDE11551-SFT272173,Status of identification data query on LIN-Bus-Control module for heating element 3,not coded / not installed,
IDE11551-SFT272174,Status of identification data query on LIN-Bus-Control module for heating element 4,not coded / not installed,
IDE11577-IDE03726,Stop process prevented 2-Parallel Parking Assistance,passive,
IDE11577-MAS00825,Stop process prevented 2-Parking Aid Control Module,passive,
IDE11578,Start-stop conditions 2,Stop release,
IDE11579-IDE03726,Number of prevented stop processes 2-Parallel Parking Assistance,0,
IDE11579-MAS00825,Number of prevented stop processes 2-Parking Aid Control Module,0,
IDE11580-MAS00106,Stop prevention history data 2-Year,2000,
IDE11580-MAS00107,Stop prevention history data 2-Month,0,
IDE11580-MAS00108,Stop prevention history data 2-Day,0,
IDE11580-MAS00109,Stop prevention history data 2-Hours,31,
IDE11580-MAS00110,Stop prevention history data 2-Minutes,63,
IDE11580-MAS00111,Stop prevention history data 2-Seconds,63,
IDE11580,Stop prevention history data 2,not active,
IDE11619-MAS13023,Photo sensors for solar radiation (discrete)-Front left sunlight intensity,not coded / not installed,
IDE11619-MAS13024,Photo sensors for solar radiation (discrete)-Front right sunlight intensity,not coded / not installed,
IDE11619-MAS13025,Photo sensors for solar radiation (discrete)-Rear left sunlight intensity,not coded / not installed,
IDE11619-MAS13026,Photo sensors for solar radiation (discrete)-Rear right sunlight intensity,not coded / not installed,
IDE11619-MAS13077,Photo sensors for solar radiation (discrete)-Sunlight photo sensor,not coded / not installed,
IDE11619-MAS13078,Photo sensors for solar radiation (discrete)-Sunlight photo sensor 2,not coded / not installed,
IDE11619-MAS13079,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor,not coded / not installed,
IDE11619-MAS13080,Photo sensors for solar radiation (discrete)-Rear sunlight photo sensor 2,not coded / not installed,
IDE11637,Outside air temperature internally calculated: climate,18.50, °C
IDE11641-MAS01632,Supply voltage for A/C actuators-Status,On,
IDE11641-MAS12621,Supply voltage for A/C actuators-Current draw (effective value),102, mA
IDE11642-MAS01632,Supply voltage 2 for A/C actuators-Status,On,
IDE11642-MAS12621,Supply voltage 2 for A/C actuators-Current draw (effective value),290, mA
IDE11643-MAS01632,Voltage supply for climate sensor system-Status,On,
IDE11643-MAS04121,Voltage supply for climate sensor system-Voltage,5.01, V
IDE11654-MAS05030,Evaporator temperature sensor-Resistance,5.51, kOhm
IDE11654-MAS13081,Evaporator temperature sensor-Air temperature downstream of evaporator,10.75, °C
IDE11655-MAS05030,Left footwell vent temperature sensor-Resistance,11.03, kOhm
IDE11655-MAS13082,Left footwell vent temperature sensor-Left footwell vent temperature,22.81, °C
IDE11656-MAS05030,Right footwell vent temperature sensor-Resistance,10.58, kOhm
IDE11656-MAS13083,Right footwell vent temperature sensor-Right footwell vent temperature,23.88, °C
IDE11657-MAS05030,Left rear upper body vent temperature sensor-Resistance,not coded / not installed,
IDE11657-MAS13084,Left rear upper body vent temperature sensor-Left rear vent temperature,not coded / not installed,
IDE11658-MAS05030,Right rear upper body vent temperature sensor-Resistance,not coded / not installed,
IDE11658-MAS13085,Right rear upper body vent temperature sensor-Right rear vent temperature,not coded / not installed,
IDE11659-MAS05030,Left rear footwell vent temperature sensor-Resistance,12.27, kOhm
IDE11659-MAS13086,Left rear footwell vent temperature sensor-Left rear footwell vent temperature,20.19, °C
IDE11660-MAS05030,Right rear footwell vent temperature sensor-Resistance,11.99, kOhm
IDE11660-MAS13087,Right rear footwell vent temperature sensor-Right rear footwell vent temperature,20.69, °C
IDE11692-MAS00359,Temperature sensor after heat exchanger-Coolant temperature,not coded / not installed,
IDE11692-MAS05030,Temperature sensor after heat exchanger-Resistance,not coded / not installed,
IDE11693-MAS05030,Left side air outlet temperature sensor-Resistance,12.69, kOhm
IDE11693-MAS13110,Left side air outlet temperature sensor-Left side air outlet temperature,19.38, °C
IDE11694-MAS05030,Right side air outlet temperature sensor-Resistance,12.56, kOhm
IDE11694-MAS13111,Right side air outlet temperature sensor-Right side air outlet temperature,19.75, °C
IDE11695-MAS05030,Left central air outlet temperature sensor-Resistance,not coded / not installed,
IDE11695-MAS13112,Left central air outlet temperature sensor-Left center air outlet temperature,not coded / not installed,
IDE11696-MAS05030,Right central air outlet temperature sensor-Resistance,not coded / not installed,
IDE11696-MAS13113,Right central air outlet temperature sensor-Right center air outlet temperature,not coded / not installed,
IDE11697-MAS05030,Front defrost flap air outlet temperature sensor-Resistance,not coded / not installed,
IDE11697-MAS13114,Front defrost flap air outlet temperature sensor-Defrosting air outlet temperature,not coded / not installed,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,not coded / not installed,
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded / not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,24.44, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,10.24, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,24.94, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,10.03, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,25.00, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,9.97, kOhm
IDE11774-IDE01290,Assembly position of users at local data bus 9-Recirculation flap motor,0,
IDE11774-IDE01292,Assembly position of users at local data bus 9-Left side vent motor,5,
IDE11774-IDE01293,Assembly position of users at local data bus 9-Right side vent motor,12,
IDE11774-IDE01294,Assembly position of users at local data bus 9-Left footwell flap motor,2,
IDE11774-IDE01295,Assembly position of users at local data bus 9-Right footwell flap motor,13,
IDE11774-IDE01296,Assembly position of users at local data bus 9-Left center vent motor,7,
IDE11774-IDE01297,Assembly position of users at local data bus 9-Right center vent motor,9,
IDE11774-IDE01300,Assembly position of users at local data bus 9-Rear temperature door motor,0,
IDE11774-IDE01301,Assembly position of users at local data bus 9-Rear air quantity motor,0,
IDE11774-IDE01304,Assembly position of users at local data bus 9-Left Rear Upper Body Vent Motor,0,
IDE11774-IDE01305,Assembly position of users at local data bus 9-Right Rear Upper Body Vent Motor,0,
IDE11774-IDE01422,Assembly position of users at local data bus 9-Defroster flap motor,8,
IDE11774-IDE01423,Assembly position of users at local data bus 9-Left temperature flap positioning motor,6,
IDE11774-IDE01424,Assembly position of users at local data bus 9-Right temperature flap positioning motor,15,
IDE11774-IDE02432,Assembly position of users at local data bus 9-Left rear temperature door motor,4,
IDE11774-IDE02435,Assembly position of users at local data bus 9-Right rear temperature door motor,11,
IDE11774-IDE02753,Assembly position of users at local data bus 9-Temperature flap motor,0,
IDE11774-IDE02833,Assembly position of users at local data bus 9-Fresh air door motor,0,
IDE11774-IDE07267,Assembly position of users at local data bus 9-Rear left air distribution servomotor,1,
IDE11774-IDE07268,Assembly position of users at local data bus 9-Rear right air distribution servomotor,14,
IDE11774-MAS07679,Assembly position of users at local data bus 9-Air distribution door motor,0,
IDE11774-MAS07681,Assembly position of users at local data bus 9-Left footwell temperature door motor,0,
IDE11774-MAS07682,Assembly position of users at local data bus 9-Right footwell temperature door motor,0,
IDE11774-MAS07683,Assembly position of users at local data bus 9-Left side window defroster door motor,0,
IDE11774-MAS07684,Assembly position of users at local data bus 9-Right side window defroster door motor,0,
IDE11774-MAS07685,Assembly position of users at local data bus 9-Rear air distribution door motor,0,
IDE11774-MAS07686,Assembly position of users at local data bus 9-Left B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07687,Assembly position of users at local data bus 9-Right B-pillar/footwell shut-off flap motor,0,
IDE11774-MAS07688,Assembly position of users at local data bus 9-Rear recirc. flap motor,0,
IDE11774-MAS11831,Assembly position of users at local data bus 9-Ctrl. motor for instrument panel vents,0,
IDE11775-IDE01290,Assembly position of users at local data bus 10-Recirculation flap motor,2,
IDE11775-IDE01292,Assembly position of users at local data bus 10-Left side vent motor,0,
IDE11775-IDE01293,Assembly position of users at local data bus 10-Right side vent motor,0,
IDE11775-IDE01294,Assembly position of users at local data bus 10-Left footwell flap motor,0,
IDE11775-IDE01295,Assembly position of users at local data bus 10-Right footwell flap motor,0,
IDE11775-IDE01296,Assembly position of users at local data bus 10-Left center vent motor,0,
IDE11775-IDE01297,Assembly position of users at local data bus 10-Right center vent motor,0,
IDE11775-IDE01300,Assembly position of users at local data bus 10-Rear temperature door motor,0,
IDE11775-IDE01301,Assembly position of users at local data bus 10-Rear air quantity motor,0,
IDE11775-IDE01304,Assembly position of users at local data bus 10-Left Rear Upper Body Vent Motor,0,
IDE11775-IDE01305,Assembly position of users at local data bus 10-Right Rear Upper Body Vent Motor,0,
IDE11775-IDE01422,Assembly position of users at local data bus 10-Defroster flap motor,0,
IDE11775-IDE01423,Assembly position of users at local data bus 10-Left temperature flap positioning motor,0,
IDE11775-IDE01424,Assembly position of users at local data bus 10-Right temperature flap positioning motor,0,
IDE11775-IDE02432,Assembly position of users at local data bus 10-Left rear temperature door motor,0,
IDE11775-IDE02435,Assembly position of users at local data bus 10-Right rear temperature door motor,0,
IDE11775-IDE02753,Assembly position of users at local data bus 10-Temperature flap motor,0,
IDE11775-IDE02833,Assembly position of users at local data bus 10-Fresh air door motor,1,
IDE11775-IDE07267,Assembly position of users at local data bus 10-Rear left air distribution servomotor,0,
IDE11775-IDE07268,Assembly position of users at local data bus 10-Rear right air distribution servomotor,0,
IDE11775-MAS07679,Assembly position of users at local data bus 10-Air distribution door motor,0,
IDE11775-MAS07681,Assembly position of users at local data bus 10-Left footwell temperature door motor,0,
IDE11775-MAS07682,Assembly position of users at local data bus 10-Right footwell temperature door motor,0,
IDE11775-MAS07683,Assembly position of users at local data bus 10-Left side window defroster door motor,0,
IDE11775-MAS07684,Assembly position of users at local data bus 10-Right side window defroster door motor,0,
IDE11775-MAS07685,Assembly position of users at local data bus 10-Rear air distribution door motor,0,
IDE11775-MAS07686,Assembly position of users at local data bus 10-Left B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07687,Assembly position of users at local data bus 10-Right B-pillar/footwell shut-off flap motor,0,
IDE11775-MAS07688,Assembly position of users at local data bus 10-Rear recirc. flap motor,0,
IDE11775-MAS11831,Assembly position of users at local data bus 10-Ctrl. motor for instrument panel vents,0,
IDE11776-IDE01290,Assembly position of users at local data bus 11-Recirculation flap motor,0,
IDE11776-IDE01292,Assembly position of users at local data bus 11-Left side vent motor,0,
IDE11776-IDE01293,Assembly position of users at local data bus 11-Right side vent motor,0,
IDE11776-IDE01294,Assembly position of users at local data bus 11-Left footwell flap motor,0,
IDE11776-IDE01295,Assembly position of users at local data bus 11-Right footwell flap motor,0,
IDE11776-IDE01296,Assembly position of users at local data bus 11-Left center vent motor,0,
IDE11776-IDE01297,Assembly position of users at local data bus 11-Right center vent motor,0,
IDE11776-IDE01300,Assembly position of users at local data bus 11-Rear temperature door motor,0,
IDE11776-IDE01301,Assembly position of users at local data bus 11-Rear air quantity motor,0,
IDE11776-IDE01304,Assembly position of users at local data bus 11-Left Rear Upper Body Vent Motor,4,
IDE11776-IDE01305,Assembly position of users at local data bus 11-Right Rear Upper Body Vent Motor,1,
IDE11776-IDE01422,Assembly position of users at local data bus 11-Defroster flap motor,0,
IDE11776-IDE01423,Assembly position of users at local data bus 11-Left temperature flap positioning motor,0,
IDE11776-IDE01424,Assembly position of users at local data bus 11-Right temperature flap positioning motor,0,
IDE11776-IDE02432,Assembly position of users at local data bus 11-Left rear temperature door motor,0,
IDE11776-IDE02435,Assembly position of users at local data bus 11-Right rear temperature door motor,0,
IDE11776-IDE02753,Assembly position of users at local data bus 11-Temperature flap motor,0,
IDE11776-IDE02833,Assembly position of users at local data bus 11-Fresh air door motor,0,
IDE11776-IDE07267,Assembly position of users at local data bus 11-Rear left air distribution servomotor,0,
IDE11776-IDE07268,Assembly position of users at local data bus 11-Rear right air distribution servomotor,0,
IDE11776-MAS07679,Assembly position of users at local data bus 11-Air distribution door motor,0,
IDE11776-MAS07681,Assembly position of users at local data bus 11-Left footwell temperature door motor,0,
IDE11776-MAS07682,Assembly position of users at local data bus 11-Right footwell temperature door motor,0,
IDE11776-MAS07683,Assembly position of users at local data bus 11-Left side window defroster door motor,0,
IDE11776-MAS07684,Assembly position of users at local data bus 11-Right side window defroster door motor,0,
IDE11776-MAS07685,Assembly position of users at local data bus 11-Rear air distribution door motor,0,
IDE11776-MAS07686,Assembly position of users at local data bus 11-Left B-pillar/footwell shut-off flap motor,3,
IDE11776-MAS07687,Assembly position of users at local data bus 11-Right B-pillar/footwell shut-off flap motor,2,
IDE11776-MAS07688,Assembly position of users at local data bus 11-Rear recirc. flap motor,0,
IDE11776-MAS11831,Assembly position of users at local data bus 11-Ctrl. motor for instrument panel vents,0,
IDE11777-IDE01290,Assembly position of users at local data bus 12-Recirculation flap motor,0,
IDE11777-IDE01292,Assembly position of users at local data bus 12-Left side vent motor,0,
IDE11777-IDE01293,Assembly position of users at local data bus 12-Right side vent motor,0,
IDE11777-IDE01294,Assembly position of users at local data bus 12-Left footwell flap motor,0,
IDE11777-IDE01295,Assembly position of users at local data bus 12-Right footwell flap motor,0,
IDE11777-IDE01296,Assembly position of users at local data bus 12-Left center vent motor,0,
IDE11777-IDE01297,Assembly position of users at local data bus 12-Right center vent motor,0,
IDE11777-IDE01300,Assembly position of users at local data bus 12-Rear temperature door motor,0,
IDE11777-IDE01301,Assembly position of users at local data bus 12-Rear air quantity motor,0,
IDE11777-IDE01304,Assembly position of users at local data bus 12-Left Rear Upper Body Vent Motor,0,
IDE11777-IDE01305,Assembly position of users at local data bus 12-Right Rear Upper Body Vent Motor,0,
IDE11777-IDE01422,Assembly position of users at local data bus 12-Defroster flap motor,0,
IDE11777-IDE01423,Assembly position of users at local data bus 12-Left temperature flap positioning motor,0,
IDE11777-IDE01424,Assembly position of users at local data bus 12-Right temperature flap positioning motor,0,
IDE11777-IDE02432,Assembly position of users at local data bus 12-Left rear temperature door motor,0,
IDE11777-IDE02435,Assembly position of users at local data bus 12-Right rear temperature door motor,0,
IDE11777-IDE02753,Assembly position of users at local data bus 12-Temperature flap motor,0,
IDE11777-IDE02833,Assembly position of users at local data bus 12-Fresh air door motor,0,
IDE11777-IDE07267,Assembly position of users at local data bus 12-Rear left air distribution servomotor,0,
IDE11777-IDE07268,Assembly position of users at local data bus 12-Rear right air distribution servomotor,0,
IDE11777-MAS07679,Assembly position of users at local data bus 12-Air distribution door motor,0,
IDE11777-MAS07681,Assembly position of users at local data bus 12-Left footwell temperature door motor,0,
IDE11777-MAS07682,Assembly position of users at local data bus 12-Right footwell temperature door motor,0,
IDE11777-MAS07683,Assembly position of users at local data bus 12-Left side window defroster door motor,0,
IDE11777-MAS07684,Assembly position of users at local data bus 12-Right side window defroster door motor,0,
IDE11777-MAS07685,Assembly position of users at local data bus 12-Rear air distribution door motor,0,
IDE11777-MAS07686,Assembly position of users at local data bus 12-Left B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07687,Assembly position of users at local data bus 12-Right B-pillar/footwell shut-off flap motor,0,
IDE11777-MAS07688,Assembly position of users at local data bus 12-Rear recirc. flap motor,0,
IDE11777-MAS11831,Assembly position of users at local data bus 12-Ctrl. motor for instrument panel vents,0,
IDE11789-MAS11878,Air quality in the interior-Degree of contamination,Unknown (255)
IDE11790,Carbon dioxide content in the interior,Initialization,
IDE11912-MAS00106,Start requirement history data 2-Year,2000,
IDE11912-MAS00107,Start requirement history data 2-Month,0,
IDE11912-MAS00108,Start requirement history data 2-Day,0,
IDE11912-MAS00109,Start requirement history data 2-Hours,31,
IDE11912-MAS00110,Start requirement history data 2-Minutes,63,
IDE11912-MAS00111,Start requirement history data 2-Seconds,63,
IDE11912,Start requirement history data 2,not active,
IDE11913-IDE03726,Number of requested start processes 2-Parallel Parking Assistance,0,
IDE11913-MAS08785,Number of requested start processes 2-Parking aid,0,
IDE11936-MAS06614,Button for defrost function-Variant,not coded / not installed,
IDE11936-MAS07693,Button for defrost function-Button Status,not coded / not installed,
IDE11936-MAS07694,Button for defrost function-Button status on CAN,Initialization/not installed,
IDE11936-MAS07699,Button for defrost function-Status indicator light on CAN,OFF,
IDE11936-MAS08062,Button for defrost function-Indicator lamp activation,not coded / not installed,
IDE11939-MAS06614,Button for auxiliary water heater-Variant,not coded / not installed,
IDE11939-MAS07693,Button for auxiliary water heater-Button Status,not coded / not installed,
IDE11939-MAS07694,Button for auxiliary water heater-Button status on CAN,Not operated,
IDE11939-MAS14852,Button for auxiliary water heater-Auxiliary coolant heater indicator lamp activation,not coded / not installed,
IDE11939-MAS14853,Button for auxiliary water heater-Activation of indicator lamp for auxiliary coolant heater timer,not coded / not installed,
IDE11939-MAS14854,Button for auxiliary water heater-Status off indicator lamp for auxiliary coolant heater on CAN,OFF,
IDE11979,Parking distance control secure condition: cause,00 00,
IDE12151-MAS01580,Left LED headlamp power output module: supply-Activation,not coded / not installed,
IDE12151-MAS01737,Left LED headlamp power output module: supply-Diagnosis,not coded / not installed,
IDE12151-MAS12621,Left LED headlamp power output module: supply-Current draw (effective value),not coded / not installed,
IDE12152-MAS01580,Right LED headlamp power output module: supply-Activation,not coded / not installed,
IDE12152-MAS01737,Right LED headlamp power output module: supply-Diagnosis,not coded / not installed,
IDE12152-MAS12621,Right LED headlamp power output module: supply-Current draw (effective value),not coded / not installed,
IDE12156,Parking aid: system status master module,00 00 00 00 FF 00 00 00,
IDE12318-MAS01580,Left signature light bulb: supply-Activation,not coded / not installed,
IDE12318-MAS01737,Left signature light bulb: supply-Diagnosis,not coded / not installed,
IDE12318-MAS12621,Left signature light bulb: supply-Current draw (effective value),not coded / not installed,
IDE12319-MAS01580,Right signature light bulb: supply-Activation,not coded / not installed,
IDE12319-MAS01737,Right signature light bulb: supply-Diagnosis,not coded / not installed,
IDE12319-MAS12621,Right signature light bulb: supply-Current draw (effective value),not coded / not installed,
IDE12340-MAS10485,Roof electronics control module: reading lights left-Left front reading lamp: dim. value,100, %
IDE12340-MAS10489,Roof electronics control module: reading lights left-Left rear reading lamp: dim. value,100, %
IDE12340-MAS10490,Roof electronics control module: reading lights left-Left rear reading lamp: diagnosis,Unknown (0)
IDE12340-MAS10493,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: dim. value,0, %
IDE12340-MAS10494,Roof electronics control module: reading lights left-Left read. lamp: 3rd seat row: diagnosis,Unknown (0)
IDE12340-MAS14272,Roof electronics control module: reading lights left-Left rear reading lamp 2: dimming value,0, %
IDE12340-MAS14273,Roof electronics control module: reading lights left-Left rear reading lamp 2: diagnostic,No malfunction,
IDE12341-MAS10487,Roof electronics control module: reading lights right-Right front reading lamp: dim. value,100, %
IDE12341-MAS10491,Roof electronics control module: reading lights right-Right rear reading lamp: dim. value,100, %
IDE12341-MAS10492,Roof electronics control module: reading lights right-Right rear reading lamp: diagnosis,Unknown (0)
IDE12341-MAS10495,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: dim. value,0, %
IDE12341-MAS10496,Roof electronics control module: reading lights right-Right read. lamp: 3rd seat row: diagnosis,Unknown (0)
IDE12341-MAS14274,Roof electronics control module: reading lights right-Right rear reading lamp 2: dim. value,0, %
IDE12341-MAS14276,Roof electronics control module: reading lights right-Right rear reading lamp 2: diagnosis,No malfunction,
IDE12342-MAS06614,Button engine sound generation-Variant,not coded / not installed,
IDE12342-MAS07693,Button engine sound generation-Button Status,not coded / not installed,
IDE12342-MAS07694,Button engine sound generation-Button status on CAN,Initialization/not installed,
IDE12342-MAS07699,Button engine sound generation-Status indicator light on CAN,OFF,
IDE12342-MAS08062,Button engine sound generation-Indicator lamp activation,not coded / not installed,
IDE12343-MAS07693,Automated driving button-Button Status,not coded / not installed,
IDE12343-MAS07694,Automated driving button-Button status on CAN,Initialization/not installed,
IDE12343-MAS14277,Automated driving button-Indicator lamp activation: color,not coded / not installed,
IDE12343-MAS14278,Automated driving button-Indicator lamp activation: mode,normal,
IDE12606-MAS06526,Installation information multicolor ambient and contour lighting 2-Local data bus 5,A0 A1 A4 A5 FF FF FF FF FF FF FF FF FF FF FF FF,
IDE12606-MAS06527,Installation information multicolor ambient and contour lighting 2-Local data bus 6,40 41 50 51 52 FF FF FF FF FF FF FF FF FF FF FF,
IDE12606-MAS14771,Installation information multicolor ambient and contour lighting 2-Local data bus 7,A2 A3 A6 A7 FF FF FF FF FF FF FF FF FF FF FF FF,
IDE12607-MAS01458,Trailer shunting assistant: operating condition-Operating State,operational,
IDE12607-MAS14851,Trailer shunting assistant: operating condition-Request trailer shunting mode in the door control module,not requested,
IDE12608-MAS00106,Trailer shunting assistant: drop-off history data-Year,2025,
IDE12608-MAS00107,Trailer shunting assistant: drop-off history data-Month,11,
IDE12608-MAS00108,Trailer shunting assistant: drop-off history data-Day,11,
IDE12608-MAS00109,Trailer shunting assistant: drop-off history data-Hours,13,
IDE12608-MAS00110,Trailer shunting assistant: drop-off history data-Minutes,35,
IDE12608-MAS00111,Trailer shunting assistant: drop-off history data-Seconds,49,
IDE12608-MAS11095,Trailer shunting assistant: drop-off history data-cause:,Faulty communication,
IDE12826-MAS07693,Engine noise selection button-Button Status,not coded / not installed,
IDE12826-MAS07694,Engine noise selection button-Button status on CAN,Not operated,
IDE12882-MAS06614,Rear window shade button 2-Variant,not coded / not installed,
IDE12882-MAS07693,Rear window shade button 2-Button Status,not coded / not installed,
IDE12882-MAS07694,Rear window shade button 2-Button status on CAN,Initialization/not installed,
IDE12945-MAS01632,Door surface heating 2: left front-Status,not coded / not installed,
IDE12945-MAS05945,Door surface heating 2: left front-Target temperature,not coded / not installed,
IDE12945-MAS05946,Door surface heating 2: left front-Actual temp.,not coded / not installed,
IDE12945-MAS07929,Door surface heating 2: left front-Power quota setting by energy management,not coded / not installed,
IDE12945-MAS12066,Door surface heating 2: left front-Cancellation status,not coded / not installed,
IDE12945-MAS14067,Door surface heating 2: left front-Actuation specified value,not coded / not installed,
IDE12946-MAS01632,Door surface heater 2: right front-Status,not coded / not installed,
IDE12946-MAS05945,Door surface heater 2: right front-Target temperature,not coded / not installed,
IDE12946-MAS05946,Door surface heater 2: right front-Actual temp.,not coded / not installed,
IDE12946-MAS07929,Door surface heater 2: right front-Power quota setting by energy management,not coded / not installed,
IDE12946-MAS12066,Door surface heater 2: right front-Cancellation status,not coded / not installed,
IDE12946-MAS14067,Door surface heater 2: right front-Actuation specified value,not coded / not installed,
IDE12947-MAS01632,Door surface heater 2: left rear-Status,not coded / not installed,
IDE12947-MAS05945,Door surface heater 2: left rear-Target temperature,not coded / not installed,
IDE12947-MAS05946,Door surface heater 2: left rear-Actual temp.,not coded / not installed,
IDE12947-MAS07929,Door surface heater 2: left rear-Power quota setting by energy management,not coded / not installed,
IDE12947-MAS12066,Door surface heater 2: left rear-Cancellation status,not coded / not installed,
IDE12947-MAS14067,Door surface heater 2: left rear-Actuation specified value,not coded / not installed,
IDE12948-MAS01632,Door surface heater 2: right rear-Status,not coded / not installed,
IDE12948-MAS05945,Door surface heater 2: right rear-Target temperature,not coded / not installed,
IDE12948-MAS05946,Door surface heater 2: right rear-Actual temp.,not coded / not installed,
IDE12948-MAS07929,Door surface heater 2: right rear-Power quota setting by energy management,not coded / not installed,
IDE12948-MAS12066,Door surface heater 2: right rear-Cancellation status,not coded / not installed,
IDE12948-MAS14067,Door surface heater 2: right rear-Actuation specified value,not coded / not installed,
IDE12950-MAS07052,Foot level heating-Setting,not coded / not installed,
IDE13120,Flap motor for indirect ventilation: left: specified value,65535,
IDE13121,Flap motor for indirect ventilation: left: dynamics,65535,
IDE13122,Flap motor for indirect ventilation: right: specified value,65535,
IDE13123,Flap motor for indirect ventilation: right: dynamics,65535,
IDE80251-MAS06439,Neck heating-Crash status,not coded / not installed,
IDE80251-MAS06646,Neck heating-Head area heater left: specified level,not coded / not installed,
IDE80251-MAS06647,Neck heating-Head area heater right: specified level,not coded / not installed,
IDE80251-MAS06648,Neck heating-Continuation at terminal 15 on,not coded / not installed,
IDE80251-MAS06649,Neck heating-Left front seat occupation status,not coded / not installed,
IDE80251-MAS06997,Neck heating-Outside temperature: filtered,Temp. sensor not installed,
IDE80251-MAS09637,Neck heating-Head area heater left: release,not coded / not installed,
IDE80251-MAS09638,Neck heating-Head area heater right: release,not coded / not installed,
IDE80251-MAS09639,Neck heating-Head area heater left: output DTM,not coded / not installed,
IDE80251-MAS09640,Neck heating-Head area heater right: output DTM,not coded / not installed,
IDE80251-MAS09641,Neck heating-Inside temperature,Temp. sensor not installed,
IDE80251-MAS09642,Neck heating-Adaptation vent temperature,not coded / not installed,
IDE80251-MAS09643,Neck heating-Adaptation fan speed,not coded / not installed,
IDE80251-MAS09646,Neck heating-Occupation status not available,not coded / not installed,
IDE80251-MAS09778,Neck heating-Convert. top open and locked,not coded / not installed,
IDE80251-MAS09779,Neck heating-Convert. top closed and locked,not coded / not installed,
MAS02311-MAS06614,Steering wheel heating button-Variant,not coded / not installed,
MAS02311-MAS07693,Steering wheel heating button-Button Status,not coded / not installed,
MAS02311-MAS07694,Steering wheel heating button-Button status on CAN,Initialization/not installed,
MAS02311-MAS07699,Steering wheel heating button-Status indicator light on CAN,OFF,
MAS02311-MAS08062,Steering wheel heating button-Indicator lamp activation,not coded / not installed,
MAS13807-MAS06419,Fault condition counter-Blocking handling,255,
MAS13807-MAS06420,Fault condition counter-Calibration drive,255,
MAS13807-MAS06421,Fault condition counter-Verification drive,2,
MAS17268,Functions which can be activated: connection error counter,9171,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,6,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS17521,Unlockable functions: activation status,|ID number,Release code for a SWaP function
SFT00032-MAS01632,High beam assistant-Status,not coded / not installed,
SFT00032-MAS02832,High beam assistant-Malfunction status,not coded / not installed,
SFT00032-MAS09580,High beam assistant-Sensor status,not coded / not installed,
SFT00032-MAS09581,High beam assistant-PWM specs.,not coded / not installed,
SFT00032-MAS09582,High beam assistant-Status on combi,not coded / not installed,
SFT00032-MAS09583,High beam assistant-error status on combi,not coded / not installed,
SFT00032-MAS09584,High beam assistant-Sensor status on combi,not coded / not installed,
SFT00032-MAS09585,High beam assistant-Turn up headlights request,not coded / not installed,
ENG139082-ENG101382,actual_abort_reason_APS_PLA-System_state,00 16,
ENG157540-ENG161748,Aftermarket_auxiliary_heater-Counter_of_activation_of_child_lock,0,
ENG157540-ENG163812,Aftermarket_auxiliary_heater-State_of_child_lock,Unknown (255)
ENG139081-ENG101382,APS_PLA_error_message-System_state,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF,
ENG133681,average_Voltage_terminals,12.80, V
ENG128341-ENG110385,Climate_OBD-Channel,0,
ENG128341-ENG133586,Climate_OBD-Comma,not active,
ENG128341-ENG99000,Climate_OBD-Value,-9999,
ENG157716-ENG161775,Data_Definitions-Data_Definition_BAP_Climate_Master,DF33,
ENG157716-ENG161776,Data_Definitions-Data_Definition_BAP_Climate_Zone_1_2,DF72,
ENG157716-ENG161777,Data_Definitions-Data_Definition_BAP_Climate_Zone_3_4,DF72,
ENG157716-ENG161778,Data_Definitions-Data_Definition_BAP_Clock,DF42,
ENG157716-ENG161779,Data_Definitions-Data_Definition_BAP_ExteriorLight,DF55,
ENG157716-ENG161780,Data_Definitions-Data_Definition_BAP_InteriorLight,DF56,
ENG157716-ENG161781,Data_Definitions-Data_Definition_BAP_Parkheater,DF44,
ENG157716-ENG161782,Data_Definitions-Data_Definition_BAP_PDC,DF46,
ENG157716-ENG161783,Data_Definitions-Data_Definition_BAP_SeatPneumatic,DF30,
ENG157716-ENG161784,Data_Definitions-Data_Definition_BAP_TrailorAssist,DF33,
ENG157716-ENG161785,Data_Definitions-Data_Definition_BAP_Wiper,DF33,
ENG157716-ENG161786,Data_Definitions-Data_Definition_CAN_Frontlight,1.14F,
ENG157716-ENG161787,Data_Definitions-Data_Definition_CAN_Komfort,08.13.00F,
ENG157716-ENG161788,Data_Definitions-Data_Definition_LIN_1,08.13.00F,
ENG157716-ENG161789,Data_Definitions-Data_Definition_LIN_10,08.13.00F,
ENG157716-ENG161790,Data_Definitions-Data_Definition_LIN_11,08.11.00F,
ENG157716-ENG161791,Data_Definitions-Data_Definition_LIN_12,08.13.00F,
ENG157716-ENG161792,Data_Definitions-Data_Definition_LIN_2,08.11.01F,
ENG157716-ENG161793,Data_Definitions-Data_Definition_LIN_3,08.12.00F,
ENG157716-ENG161794,Data_Definitions-Data_Definition_LIN_4,08.13.00F,
ENG157716-ENG161795,Data_Definitions-Data_Definition_LIN_5,08.07.00F,
ENG157716-ENG161796,Data_Definitions-Data_Definition_LIN_6,08.07.00F,
ENG157716-ENG161797,Data_Definitions-Data_Definition_LIN_7,08.08.00F,
ENG157716-ENG161798,Data_Definitions-Data_Definition_LIN_8,08.13.00F,
ENG157716-ENG161799,Data_Definitions-Data_Definition_LIN_9,08.11.00F,
ENG133683-ENG133924,EVLS-block_counter_axial_in,1,
ENG133683-ENG133923,EVLS-block_counter_axial_out,10,
ENG133683-ENG133922,EVLS-block_counter_vertically_down,15,
ENG133683-ENG133921,EVLS-block_counter_vertically_up,8,
ENG133683-ENG133919,EVLS-drivers_door_open,Open,
ENG133683-ENG133928,EVLS-Electrically_adjustable_steering_column_BCM1_down,not active,
ENG133683-ENG133930,EVLS-Electrically_adjustable_steering_column_BCM1_in,not active,
ENG133683-ENG133929,EVLS-Electrically_adjustable_steering_column_BCM1_out,not active,
ENG133683-ENG133927,EVLS-Electrically_adjustable_steering_column_BCM1_up,not active,
ENG133683-ENG133917,EVLS-Electrically_adjustable_steering_column_error,00000000 00000000 ,
ENG133683-ENG133925,EVLS-Electrically_adjustable_steering_column_response_error,No malfunction,
ENG133683-ENG133920,EVLS-Electrically_adjustable_steering_column_state,00000001 ,
ENG133683-ENG133916,EVLS-Electrically_adjustable_steering_column_state_HV,00000000 11000001 ,
ENG133683-ENG133915,EVLS-Electrically_adjustable_steering_column_state_LV,00000000 11000001 ,
ENG133683-ENG133914,EVLS-FS_MMB_global_stop_mode,no_global_break_off,
ENG133683-ENG133910,EVLS-FS_MMB_storage_mode,no_assignation,
ENG133683-ENG133913,EVLS-FS_MMB_store_mode,no_storage,
ENG133683-ENG133912,EVLS-FS_MMB_tap_mode,no_button_mode,
ENG133683-ENG133911,EVLS-FS_MMB_tip_mode,no_tip_mode,
ENG133683-ENG133918,EVLS-LSV_EE_switch,operated,
ENG133683-ENG133926,EVLS-motor_start_stopp_restart,not active,
ENG179581-MAS17268,FoD_slave_operating_state-Functions which can be activated: connection error counter,02,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,6,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Release code for a SWaP function
ENG101323,Headlight leveling control state,static,
ENG133682,interior_temperature,24.00, °C
ENG107365,Left dynamic cornering light value,Measuring value not available,
ENG107366,Left headlight leveling motor position,60.00, %
ENG116804-ENG121679,Light sensor parameter-BRGC6,0,
ENG116804-ENG121663,Light sensor parameter-darkstart_mode,not active,
ENG116804-ENG121664,Light sensor parameter-night_mode,active,
ENG116804-ENG121667,Light sensor parameter-night_sensitivity,not active,
ENG116804-ENG121666,Light sensor parameter-rain_mode,not active,
ENG116804-ENG121671,Light sensor parameter-rb_Amb_Night_Threshold_g,135,
ENG116804-ENG134678,Light sensor parameter-rb_E2_Sensor_Error_1_g,0,
ENG116804-ENG134679,Light sensor parameter-rb_E2_Sensor_Error_2_g,0,
ENG116804-ENG134680,Light sensor parameter-rb_E2_Sensor_Error_3_g,0,
ENG116804-ENG134681,Light sensor parameter-rb_E2_Sensor_Error_4_g,0,
ENG116804-ENG121672,Light sensor parameter-rb_FW_Night_Threshold_g,135,
ENG116804-ENG121670,Light sensor parameter-rb_IR_Day_Threshold_g,45,
ENG116804-ENG121673,Light sensor parameter-rb_IR_Night_Threshold_g,68,
ENG116804-ENG121676,Light sensor parameter-rb_LIN_BIT_ERROR_COUNTER_g,0,
ENG116804-ENG121678,Light sensor parameter-rb_LIN_BIT_NORESPONSE_COUNTER_g,0,
ENG116804-ENG134675,Light sensor parameter-rb_LIN_CHECKSUM_ERROR_COUNTER_g,0,
ENG116804-ENG134677,Light sensor parameter-rb_LIN_FRAME_ERROR_COUNTER_g,0,
ENG116804-ENG134676,Light sensor parameter-rb_LIN_OVER_T_FRAME_MAX_COUNTER_g,0,
ENG116804-ENG134674,Light sensor parameter-rb_LIN_OVER_T_HEADER_MAX_COUNTER_g,0,
ENG116804-ENG121668,Light sensor parameter-rw_Amb_Day_Threshold_g,93,
ENG116804-ENG121662,Light sensor parameter-rw_Amb_light16bit_g,96, bit
ENG116804-ENG121674,Light sensor parameter-rw_dayCounter_mg,0,
ENG116804-ENG121669,Light sensor parameter-rw_FW_Day_Threshold_g,90,
ENG116804-ENG121660,Light sensor parameter-rw_FW_light16bit_g,21, bit
ENG116804-ENG121661,Light sensor parameter-rw_IR_light16bit_g,31, bit
ENG116804-ENG121675,Light sensor parameter-rw_nightCounter_mg,186,
ENG116804-ENG121665,Light sensor parameter-tunnel_mode,not active,
ENG133744-ENG121648,Rain_sensor_parameters-rb_CloseTypeStandby_g,0,
ENG133744-ENG121657,Rain_sensor_parameters-rb_Errorflags_g,0,
ENG133744-ENG121651,Rain_sensor_parameters-rb_HumTemp_ErrorCode_g,0,
ENG133744-ENG121653,Rain_sensor_parameters-rb_NoCommunicationCounter,0,
ENG133744-ENG121641,Rain_sensor_parameters-rb_PotiStageFromBox_g,3,
ENG133744-ENG121642,Rain_sensor_parameters-rb_PWM_Voltage_g,127,
ENG133744-ENG121652,Rain_sensor_parameters-rb_StaticNoCommunicationCounter,0,
ENG133744-ENG121654,Rain_sensor_parameters-rb_SupplyVoltage_mg,163,
ENG133744-ENG134683,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Max_g,141,
ENG133744-ENG134682,Rain_sensor_parameters-rb_WDG_Fast_Task_Counter_Min_g,139,
ENG133744-ENG121640,Rain_sensor_parameters-rub_Empf_Faktor,15,
ENG133744-ENG121639,Rain_sensor_parameters-rub_Int_Speicher,0,
ENG133744-ENG121645,Rain_sensor_parameters-rub_LengthCounter,99,
ENG133744-ENG121643,Rain_sensor_parameters-rub_Nachwisch_Count,0,
ENG133744-ENG121638,Rain_sensor_parameters-rub_Ovr_Speicher,0,
ENG133744-ENG121646,Rain_sensor_parameters-rub_PulseCounter,1,
ENG133744-ENG121647,Rain_sensor_parameters-rub_SignalIntegral_g,0,
ENG133744-ENG121644,Rain_sensor_parameters-ruw_StX_Speicher,0,
ENG133744-ENG121650,Rain_sensor_parameters-rw_HumiTicks_g,32608,
ENG133744-ENG121649,Rain_sensor_parameters-rw_TempTicks_g,607,
ENG108468,Right dynamic cornering light value,Measuring value not available,
ENG108469,Right headlight leveling motor position,60.00, %
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,6,
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,0,
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,4,
ENG158240-ENG163881,sw_history-sw_version_1,----,
ENG158240-ENG163882,sw_history-sw_version_2,----,
ENG158240-ENG163883,sw_history-sw_version_3,----,
ENG158240-ENG163884,sw_history-sw_version_4,----,
ENG158240-ENG163885,sw_history-sw_version_5,----,
ENG134772-ENG109174,sw_version_integration_afs-SW_VERSION,I648,
ENG134776-ENG109174,sw_version_integration_alm-SW_VERSION,l650,
ENG134773-ENG109174,sw_version_integration_aps-SW_VERSION,5600,
ENG134775-ENG109174,sw_version_integration_ara-SW_VERSION,A648,
ENG134775-ENG163886,sw_version_integration_ara-sw_version_camera,A652,
ENG158241-ENG163887,sw_version_integration_klima-sw_version_climate_control,6520,
ENG158241-ENG163888,sw_version_integration_klima-sw_version_preh_uif,0000,
ENG158241-ENG163889,sw_version_integration_klima-sw_version_psd,P620,
ENG158241-ENG163890,sw_version_integration_klima-sw_version_ssb,0000,
ENG158242-ENG109174,sw_version_integration_sufk-SW_VERSION,H650,
ENG134774-ENG109174,sw_version_integration_wpca-SW_VERSION,0710,
ENG133737-ENG134633,UPIT-Counter_UPIT_shortcut_ground_front,255,
ENG133737-ENG134634,UPIT-Counter_UPIT_shortcut_ground_rear,255,
ENG133737-ENG134632,UPIT-UPIT_system_state,00000001 00000000 ,
ENG133737-ENG134631,UPIT-UPIT_version,00000000 00100011 ,
blockmap-15-4M0-959-655-J_WVGZZZCRZKD020971-20260921-1916.CSV
;SW:4M0-959-655-J HW:4M0-959-655-J --- 15: Airbags
;Component:AirbagVW31 H07 2710, Coding:99FCC0C00C800000585400EF301D41A80065
;EV_AirbaVW31SMEAU65x,001032,EV_AirbaVW31SMEAU65x_001.rod
;Monday,21,September,2026,19:16:04:25381
;VCDS Version: 26.9.0.3 (arm64) Data version: 20260918 DS378.0
;VCID: C2D6A458F409634A314-8096
Group,Description,Actual
IDE00821,Seat belt switch 2nd row driver's side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Seat belt switch 2nd row center,not connected,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE01099,Driver side airbag igniter 2 ohm value,no measured value present,
IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,too large,
IDE01102,Driver thorax airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.8, Ohm
IDE01104,driver side rear airbag igniter ohm value,2.6, Ohm
IDE01105,Ft. pass.side rear airbag igniter ohm value,2.8, Ohm
IDE01106,Driver side head curtain airbag igniter ohm value,2.7, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.8, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,2.5, Ohm
IDE01110,Driver side belt tensioner igniter ohm value,2.3, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.8, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,no measured value present,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,no measured value present,
IDE01114,Driver side belt force limiter igniter ohm value,too large,
IDE01115,side belt force limiter igniter ohm value,too large,
IDE01116,driver side rear belt tensioner igniter ohm value,2.4, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.6, Ohm
IDE01118,Rear center belt tensioner igniter ohm value,no measured value present,
IDE01119,Battery open circuit igniter ohm value,2.9, Ohm
IDE01120,Driver side active head restraint igniter ohm value,no measured value present,
IDE01121,Passenger side active head restraint igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,4.0, Ohm
IDE01194,Frt.pass. belt tensioner ohm value,4.0, Ohm
IDE01195,Front passenger side seat occupancy detection: Ohm value,412.0, Ohm
IDE01197,Key switch contact 1 ohm value,700.0, Ohm
IDE01198,Key switch contact 2 ohm value,1480.0, Ohm
IDE01200,Driver seat position sensor current value,Too Small,
IDE01201,Frt.pass. seat position sensor current value,Too Small,
IDE01204,Center rear seat occupied recognition ohm value,Too Small,
IDE01205,Safety belt switch 2nd row driver side ohm value,420.0, Ohm
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,412.0, Ohm
IDE01207,Safety belt switch center 2nd row ohm value,412.0, Ohm
IDE01208,Seat belt switch 3rd row driver side ohm value,too large,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,too large,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Left pedestrian protection igniter,correct,
IDE01358,Right pedestrian protection igniter,correct,
IDE01359,Front pedestrian protection trigger,cannot be measured currently,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,2097151,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,1023,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,131071,
IDE01555,Number of frontal crashes,0,
IDE01560,Number of activations of active head restraint,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,2.3, Ohm
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,2.6, Ohm
IDE01636,Pedestrian protection trigger: front ohmic value,no measured value present,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,too large,
IDE03730,Driver airbag release valve igniter ohm value,too large,
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,too large,
IDE03800,Driver airbag release valve igniter,not installed,
IDE03801,Frt.pass. airbag release valve igniter,not installed,
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,no measured value present,
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,no measured value present,
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,no measured value present,
IDE06034,Rollover protection trigger: driver side,cannot be measured currently,
IDE06035,Rollover protection trigger: front passenger side,cannot be measured currently,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE06110,Right belt tensioner supply voltage,correct,
IDE06118,Right belt tensioner current consumption,0.0, A
IDE06119,Left belt tensioner tensioning cycles charac. curve 1,1,
IDE06120,Left belt tensioner tensioning cycles charac. curve 2,0,
IDE06121,Left belt tensioner tensioning cycles charac. curve 3,3,
IDE06122,Left belt tensioner tensioning cycles charac. curve 4,12291,
IDE06123,Right belt tensioner tensioning cycles charac. curve 1,0,
IDE06124,Right belt tensioner tensioning cycles charac. curve 2,1,
IDE06125,Right belt tensioner tensioning cycles charac. curve 3,0,
IDE06126,Right belt tensioner tensioning cycles charac. curve 4,5141,
IDE06128,Left belt tensioner temperature,31.0, °C
IDE06129,Right belt tensioner temperature,31.0, °C
IDE06130,Left belt tensioner supply voltage,correct,
IDE06131,Left belt tensioner current consumption,0.0, A
IDE06525,Left belt tensioner error status,|
IDE06525,Left belt tensioner error status,0,
IDE06526,Right belt tensioner error status,|
IDE06526,Right belt tensioner error status,0,
IDE07190,Igniter for battery open circuit 2nd battery,not installed,
IDE07191,2nd Battery open circuit igniter ohm value,too large,
IDE07192,Thorax airbag igniter,cannot be measured currently,
IDE07193,Igniter for window airbag Ohm-value,no measured value present,
IDE08436,Front driver side third row seat belt tensioner igniter,cannot be measured currently,
IDE08437,Front passenger side third row seat belt tensioner igniter,cannot be measured currently,
IDE08438,Driver side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE08439,Frt.pass. side seat belt tensioner igniter 3rd row ohm value,no measured value present,
IDE10187,Supply voltage {V},12.7, V
IDE10188,Left belt tensioner supply voltage {V},12.9, V
IDE10189,Right belt tensioner supply voltage {V},12.9, V
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,cannot be measured currently,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,cannot be measured currently,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,cannot be measured currently,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,cannot be measured currently,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,cannot be measured currently,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,too large,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,too large,
IDE80003,Analysis 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80004,Analysis 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80005,Analysis 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80006,Analysis 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00001,Driver airbag igniter,correct,
MAS00002,Driver's Airbag Igniter 2,cannot be measured currently,
MAS00003,Front passenger front airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,not installed,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger thorax airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,correct,
MAS00008,Passenger side rear thorax airbag igniter,correct,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,correct,
MAS00013,Driver seat belt tension igniter,correct,
MAS00014,Front passenger seat belt tensioner igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,cannot be measured currently,
MAS00016,Front passenger seat belt tensioner igniter 2,cannot be measured currently,
MAS00017,Igniter for Driver Belt Force Limiter,not installed,
MAS00018,Front passenger side belt force limiter igniter,not installed,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00021,Center rear seat belt tensioner igniter,cannot be measured currently,
MAS00022,Battery Interrupt Igniter,correct,
MAS00023,Driver active head restraint igniter/trigger,cannot be measured currently,
MAS00024,Front passenger active head restraint igniter/trigger,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupant detection,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,On,
MAS00033,Key switch terminal 2,On,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,not installed,
MAS00038,Seat occupied recognition rear driver side,Not assigned,
MAS00039,Seat occupied recognition rear passenger side,Not assigned,
MAS00040,Seat occupied recognition: center: rear,Not assigned,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:28
;SW:4N2-907-468-AB HW:4N2-907-468-AB --- 19: CAN Gateway
;Component:Gateway H14 0037, Coding:0301000300800E407F07000000DB05325E9E00071C000000037D078F10000100
;EV_CGateCONTIAU491,003150,EV_CGateCONTIAU491_003_VW53.rod
;Monday,21,September,2026,19:35:33:25381
;VCID: F9A403B4D95FE09220E-80AC
IDE00009,Date of manufacture,18 11 26,
IDE00010,Serial number,0588P763918B26,
IDE00019,Voltage terminal 30,12.90, V
IDE00020-MAS00044,Terminal 15 status-Terminal 15 power supply,13.00, V
IDE00020-MAS03680,Terminal 15 status-Terminal 15 status measured,On,
IDE00020-MAS05562,Terminal 15 status-Terminal 15 resulting,On,
IDE00020-MAS07720,Terminal 15 status-Terminal 15 via CAN,On,
IDE00020-MAS08946,Terminal 15 status-Terminal 15 via comparator,On,
IDE00056,History data 1,000*2025-12-04-12:20*25.5*01**,
IDE00056,History data 1,000*2025-12-06-05:56*25.5*01**,
IDE00056,History data 1,000*2025-11-03-15:42*25.5*01**,
IDE00056,History data 1,000*2026-08-25-19:49*25.5*01**,
IDE00056,History data 1,000*2000-01-01-00:00*00.0*00**,
IDE00056,History data 1,000*2026-04-20-22:25*25.5*01**,
IDE00056,History data 1,000*2026-08-26-13:09*00.1*01*02186**,
IDE00056,History data 1,000*2025-10-29-15:54*25.5*01**,
IDE00056,History data 1,000*2025-12-20-07:12*25.5*01*00499**,
IDE00056,History data 1,000*2026-03-18-10:54*00.4*01**,
IDE00057,History data 2,139*2025-10-10-04:53*0008.8*000*00280*0000*01*00080**,
IDE00057,History data 2,139*2025-10-09-14:39*0004.7*002*00282*3000*01**,
IDE00057,History data 2,139*2025-10-09-21:21*0007.3*008*00272*3000*01**,
IDE00057,History data 2,000*2000-01-01-00:00*0000.0*000*00000*0000*00**,
IDE00057,History data 2,076*2020-05-16-15:26*0003.2*044*01492*0002*01**,
IDE00057,History data 2,139*2025-10-09-20:03*0001.2*009*00260*3000*01**,
IDE00057,History data 2,139*2025-10-09-19:02*0001.2*006*00261*3000*01**,
IDE00058,History data 3,216*2026-08-26-13:12*0*1*0*048*007*201C*0*00.0*06.9**,
IDE00058,History data 3,217*2026-08-26-13:12*0*1*0*048*006*200C*0*00.0*00.0**,
IDE00058,History data 3,173*2026-03-18-10:17*3*1*0*040*000*0400*0*00.0*00.0**,
IDE00058,History data 3,219*2026-08-26-13:12*0*1*0*045*000*2008*0*00.0*00.0**,
IDE00058,History data 3,221*2026-08-26-13:13*0*1*0*043*000*2008*0*00.0*00.0**,
IDE00058,History data 3,218*2026-08-26-13:12*0*1*0*046*004*2008*0*00.0*00.0**,
IDE00058,History data 3,173*2026-03-18-10:16*0*1*0*040*000*0400*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*00*000*0000000000*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,007*2018-12-06-00:04*01*105*01*JCB*381125P0MI*09869*27517*001.4*000.0*000.0**,
IDE00060,History data 5,054*2024-02-03-16:41*1*089167*9999*11.6*000*03*-08.3*20576*09979*001C*0107007F*000*00.1*00.0*0000.2**,
IDE00060,History data 5,157*2025-10-28-09:00*1*136697*0000*11.3*000*04*-09.8*26992*09966*021C*0107007F*008*00.0*00.1*0227.6**,
IDE00060,History data 5,136*2025-10-09-10:34*1*136669*0000*11.4*000*04*-00.3*26943*09959*0214*0107007F*000*00.0*00.0*0000.0**,
IDE00060,History data 5,142*2023-09-18-12:34*1*076909*0000*11.1*000*04*-03.2*18582*09960*0010*0107007F*002*00.0*00.0*0139.8**,
IDE00061,History data 6,118*2026-09-19-10:49*037*+18*+000.8*0000*00*00.08**,
IDE00061,History data 6,120*2026-09-20-17:15*040*+17*+001.2*0000*00*00.25**,
IDE00061,History data 6,122*2026-09-21-16:00*039*+18*+001.1*0000*00*00.35**,
IDE00061,History data 6,117*2026-09-19-10:44*037*+18*-000.1*0000*00*00.00**,
IDE00061,History data 6,114*2026-09-18-21:25*043*+26*+000.3*0000*00*00.00**,
IDE00061,History data 6,121*2026-09-21-06:39*040*+15*+001.7*0012*01*00.43**,
IDE00061,History data 6,107*2026-09-18-16:19*037*+24*-000.1*0000*00*00.00**,
IDE00061,History data 6,108*2026-09-18-16:19*041*+24*+001.9*0011*01*00.75**,
IDE00061,History data 6,115*2026-09-18-21:30*032*+26*+001.2*0002*01*00.23**,
IDE00061,History data 6,111*2026-09-18-18:41*036*+26*+000.2*0000*01*00.00**,
IDE00061,History data 6,119*2026-09-19-10:57*038*+18*+000.8*0000*00*00.08**,
IDE00061,History data 6,109*2026-09-18-17:17*039*+25*+001.7*0000*00*00.91**,
IDE00061,History data 6,000*2026-09-18-15:09*040*+22*+000.0*0003*01*01.98**,
IDE00061,History data 6,113*2026-09-18-21:13*043*+26*+001.4*0000*00*00.18**,
IDE00061,History data 6,105*2026-09-18-14:05*041*+19*+006.4*0002*01*00.88**,
IDE00062,History data 7,121*2026-09-21-07:06*038*-001.1*00.0*00.0*0003.0**,
IDE00062,History data 7,123*2026-09-21-16:22*034*-003.0*00.0*00.0*0002.2**,
IDE00062,History data 7,115*2026-09-18-21:44*035*-001.3*00.0*00.0*0012.4**,
IDE00062,History data 7,111*2026-09-18-18:42*036*-004.7*00.1*00.0*0002.5**,
IDE00062,History data 7,114*2026-09-18-21:26*038*-001.5*00.0*00.0*0000.0**,
IDE00062,History data 7,106*2026-09-18-16:16*039*-000.7*00.0*00.0*0000.0**,
IDE00062,History data 7,120*2026-09-20-17:31*031*-001.0*00.0*00.0*0013.0**,
IDE00062,History data 7,117*2026-09-19-10:44*035*-000.3*00.0*00.0*0000.0**,
IDE00062,History data 7,119*2026-09-19-11:03*035*-002.1*00.0*00.0*0025.3**,
IDE00062,History data 7,105*2026-09-18-14:58*037*-001.1*00.0*00.0*0000.1**,
IDE00062,History data 7,113*2026-09-18-21:25*043*-000.1*00.0*00.0*0000.0**,
IDE00062,History data 7,107*2026-09-18-16:19*037*-000.1*00.0*00.0*0000.0**,
IDE00062,History data 7,118*2026-09-19-10:55*037*-000.3*00.0*00.0*0000.0**,
IDE00062,History data 7,108*2026-09-18-17:05*038*-000.7*00.0*00.0*0000.2**,
IDE00062,History data 7,109*2026-09-18-18:13*036*-001.1*00.0*00.0*0000.5**,
IDE00063,History data 8,000*2026-03-18-00:00*4*-09.6*13.7*100*+28**,
IDE00063,History data 8,000*2026-06-15-22:52*1*+00.0*14.2*090*+18*66*00*00*10*00*00*000*000*00**,
IDE00063,History data 8,000*2026-01-05-00:00*4*-15.0*11.5*041*+04**,
IDE00063,History data 8,000*2026-03-18-00:00*4*-15.1*12.5*100*+15**,
IDE00063,History data 8,165*2025-11-11-13:41*1*+03.7*11.9*054*+10**,
IDE00063,History data 8,000*2026-01-05-00:00*4*-14.8*11.8*038*+04**,
IDE00064,History data 9,000*2025-10-26-23:51*082*086*041*010*26990*04.4*+07*09.4*02.3*03629*23407**,
IDE00064,History data 9,000*2026-06-16-11:35*079*086*093*055*27161*03.8*+15*09.4*03.1*03630*23409**,
IDE00064,History data 9,000*2026-05-15-17:16*079*086*075*041*27148*03.6*+14*09.6*12.6*03630*23408**,
IDE00064,History data 9,000*2025-07-12-12:25*080*088*080*046*26533*03.4*+16*10.1*02.3*03588*23147**,
IDE00064,History data 9,000*2026-04-14-06:58*079*086*056*022*27139*05.0*+11*08.4*03.2*03630*23408**,
IDE00064,History data 9,000*2025-09-23-07:26*082*088*074*041*26895*03.4*+11*09.7*02.3*03629*23405**,
IDE00064,History data 9,000*2025-12-30-20:19*082*086*000*000*27115*04.0*-02*09.6*03.0*03629*23407**,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*00.0*+00*02.0*00.0*00000*00000**,
IDE00064,History data 9,000*2025-08-19-08:53*087*090*072*045*26679*03.4*+18*09.8*02.3*03603*23245**,
IDE00064,History data 9,000*2026-08-20-16:59*080*086*070*040*27199*03.8*+21*10.6*02.6*03630*23414**,
IDE00064,History data 9,000*2026-07-20-12:43*080*086*088*052*27182*03.4*+15*10.0*02.8*03630*23409**,
IDE00064,History data 9,000*2025-11-30-14:41*082*086*040*010*27070*04.4*+05*09.6*03.0*03629*23407**,
IDE00065,History data 10,094*2026-09-17-06:59*08*00000*00000*00000*00054*00000*00000*00000*00000**,
IDE00065,History data 10,105*2026-09-18-14:06*80*00368*00000*00000*00219*00000*00000*00008*01728**,
IDE00065,History data 10,072*2026-09-11-20:22*88**,
IDE00065,History data 10,092*2025-02-22-13:26*08**,
IDE00065,History data 10,236*2025-09-09-09:54*08**,
IDE00065,History data 10,251*2025-04-22-08:06*08**,
IDE00065,History data 10,034*2026-09-08-17:57*88**,
IDE00065,History data 10,163*2025-11-11-13:28*1*100*126*+08*16*30*-28*08.8*6**,
IDE00065,History data 10,048*2025-03-24-16:51*08**,
IDE00065,History data 10,070*2026-09-11-17:27*80**,
IDE00065,History data 10,190*2026-04-06-18:06*2*060*027*+13*04*30*-85*11.2*6**,
IDE00065,History data 10,090*2026-09-16-17:05*08**,
IDE00065,History data 10,070*2026-09-11-17:26*80**,
IDE00065,History data 10,069*2026-09-11-15:04*80**,
IDE00065,History data 10,186*2026-03-18-11:35*2*099*051*+17*02*30*-90*11.9*6**,
IDE00065,History data 10,118*2025-09-23-08:59*2*059*028*+11*03*30*+75*13.0*6**,
IDE00065,History data 10,251*2026-08-31-12:46*2*059*022*+25*03*30*-50*11.6*6*00001*00055*00000**,
IDE00066,History data 11,123*2026-09-21-16:22*000*000*000*000*0000*000*00.1*00.1*073*039*073*039*00*01948*02953*08096*15751*00000**,
IDE00066,History data 11,122*2026-09-21-16:00*000*000*000*000*0282*021*00.4*01.5*072*038*073*039*00**,
IDE00066,History data 11,120*2026-09-20-17:15*000*000*000*000*0092*015*00.2*01.4*073*035*074*040*00**,
IDE00066,History data 11,121*2026-09-21-06:57*000*000*000*000*0109*026*00.2*00.4*075*039*075*040*01**,
IDE00066,History data 11,119*2026-09-19-10:57*000*000*000*000*0043*005*00.2*01.0*071*037*072*038*00**,
IDE00066,History data 11,118*2026-09-19-10:49*000*000*000*000*0047*005*00.1*00.9*070*035*071*037*00**,
IDE00067,History data 12,169*2025-11-13-10:18*0017*11*00*00CA*13*00*0052*13*00**,
IDE00067,History data 12,162*2025-11-10-00:00*0001*13*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,171*2026-01-05-00:00*0069*12*00*0009*12*00*0046*13*00**,
IDE00067,History data 12,163*2025-11-11-13:28*0001*13*00*0000*00*00*0000*00*00**,
IDE00067,History data 12,166*2024-06-04-15:27*0069*11*00*0009*11*00*0046*12*00**,
IDE00068,History data 13,006*2026-09-07-11:07*2*00.00*000*255*000*000*000*000*000**,
IDE00068,History data 13,115*2026-09-18-21:30*2*00.00*000*255*000*000*000*000*000**,
IDE00068,History data 13,003*2026-09-02-11:45*2*00.00*000*255*000*000*000*000*000**,
IDE00068,History data 13,106*2026-09-18-15:10*2*00.80*000*255*000*000*000*000*000**,
IDE00068,History data 13,098*2026-09-17-19:46*2*00.00*000*255*000*000*000*000*000**,
IDE00069,History data 14,000*2000-01-01-00:00*0*00.00*000*000*000*000*000*000*000**,
IDE00070,History data 15,000*2000-01-01-00:00*0*000*00.00*000*000*000**,
IDE00071,History data 16,095*2022-12-02-07:35*000*000*000*00.00*003*000*000**,
IDE00071,History data 16,192*2024-01-11-10:03*005*000*000*00.48*006*000*000**,
IDE00071,History data 16,180*2022-12-14-07:39*005*000*000*00.15*004*000*000**,
IDE00071,History data 16,122*2023-08-03-14:34*002*000*000*00.05*005*000*000**,
IDE00071,History data 16,219*2022-11-19-18:49*005*000*000*00.13*002*000*000**,
IDE00102,Control Module temperature,55, °C
IDE00667,Microphone status,electrically OK,
IDE00668,Microphone voltage consumption,6.40, mA
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00725,Manufacturer test stand number,0032,
IDE00726,Component group and serial number,0139,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,23,
IDE00767-ENG136153,No. of unscheduled ECU resets-Last_Main_Controller_Reset_Reason,00 04,
IDE00767-ENG136150,No. of unscheduled ECU resets-Last_WD_Reset_Reason,08,
IDE00767-ENG136154,No. of unscheduled ECU resets-Main_Controller_Reset_Counter,1,
IDE00767-ENG136151,No. of unscheduled ECU resets-Wd_Reset_Counter,6,
IDE00767-ENG164456,No. of unscheduled ECU resets-Z0_Reset_Counter,0,
IDE01215,Dimmer terminal 58d,39.70, %
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS02230,GPS Position-Height,12, m
IDE01713-MAS01632,Status GPS reception-Status,Not available,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,0,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,0, mA
IDE01803,History data 17,000*2000-01-01-00:00*000*000*000*00.00*000*000*000**,
IDE01804,History data 18,124*2026-09-21-18:50*2*000*00.90*000020*999*999*430**,
IDE01804,History data 18,124*2026-09-21-18:50*3*000*00.20*000042*999*999*430**,
IDE01804,History data 18,124*2026-09-21-18:40*1*002*00.20*000800*999*999*429**,
IDE01804,History data 18,123*2026-09-21-16:22*2*000*00.00*000801*999*999*429**,
IDE01804,History data 18,124*2026-09-21-18:37*2*003*00.05*000800*999*999*429**,
IDE01805,History data 19,044*2018-12-06-06:42*0010*0009.6*0004.5*0004.6*0000*0107007F*000*000*002**,
IDE01805,History data 19,000*2000-01-01-00:00*0000*0000.0*0000.0*0000.0*0000*00000000*000*000*000**,
IDE01806,History data 20,000*2000-01-01-00:00*0000*000*000*+0000000*+0000000**,
IDE01806,History data 20,076*2019-01-04-07:41*0542*019*087*-55D4A80*-ABA9500**,
IDE01807,History data 21,00285*02971*13970*00232*00042**,
IDE01807,History data 21,03258*08837*02154*02612**,
IDE01807,History data 21,05234*01334*00583**,
IDE01807,History data 21,17171*00192*00084*00050**,
IDE01807,History data 21,00227*00009*00005**,
IDE01807,History data 21,00000*00000*00000*00000*00000**,
IDE01807,History data 21,12213*03326*01322**,
IDE01807,History data 21,19553*49784*00927*00085**,
IDE01807,History data 21,139851**,
IDE01807,History data 21,00371*01430*01461*03987**,
IDE01807,History data 21,00036*00002*00003**,
IDE01807,History data 21,00058*00093*00005*00000**,
IDE01807,History data 21,13724*02395*01485*01098*00873*00734*01182*00717*00428*00888*00000**,
IDE01808,History data 22,000*2000-01-01-00:00*0*0*000*000*000*000*0*00000*00000**,
IDE01808,History data 22,000*2000-01-01-00:00*0*0*000*000*000*000*0**,
IDE01809,History data 23,000*2000-01-01-00:00*0*00000*00000**,
IDE01810,History data 24,000*2000-01-01-00:00*0*0000*0000*0000*00000*00000*00000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*000*00000*000.0*000*000*000**,
IDE01811,History data 25,000*2000-01-01-00:00*000.0*000*000*000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01812,History data 26,000*2000-01-01-00:00*0000**,
IDE01813,History data 27,000*2000-01-01-00:00*0000**,
IDE01813,History data 27,000*2000-01-01-00:00*0000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE01816,History data 30,000*2000-00-00-00:00*0*0*0*0*0*000.00*000.00*-40**,
IDE01817,History data 31,Nur für BEV ,
IDE01817,History data 31, ,
IDE01818,History data 32,000*2000-00-00-00:00*0*000*000*00.0*00.0*000*000*00.0*00.0*00000**,
IDE01819,History data 33,000*2000-00-00-00:00*0*000*000*000*000*00000*00000**,
IDE01820,History data 34,000*2000-00-00-00:00*0*0*000*000.0*00.0*00.0*000.0*00.0**,
IDE01821,History data 35,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01822,History data 36,000*2000-01-01-00:00*0*000*000*000*000*000*000*000*000*000*000**,
IDE01823,History data 37,000*2000-01-01-00:00*0*0*0*0*0*0*0*0*0**,
IDE01824,History data 38,000*2000-01-01-00:00*0*+000*000*0**,
IDE01825,History data 39,
IDE01825,History data 39,000*2026-09-20-17:00*000*001*000**,
IDE01825,History data 39,000*2026-09-21-07:13*000*001*000**,
IDE01825,History data 39,000*2026-09-21-18:33*000*001*000**,
IDE01825,History data 39,000*2026-09-21-16:00*000*001*000**,
IDE01825,History data 39,000*2026-09-21-12:53*000*001*000**,
IDE01825,History data 39,000*2026-09-21-06:32*000*001*000**,
IDE01825,History data 39,000*2026-09-21-14:29*000*001*000**,
IDE01825,History data 39,000*2026-09-20-12:44*000*001*000**,
IDE01826,History data 40,000*2000-01-01-00:00*0*0*0*0*0*000.00*000.00*+00**,
IDE01827,Specified generator voltage,13.3, V
IDE01828,Generator DF Signal,41.950, %
IDE01829,Generator exciter current,2.05, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Denso,
IDE01831-MAS06310,Generator variant-Generator identifier,140A - 210A MOSFET,
IDE01832-MAS06311,Generator regulator variant-ASIC manufacturer,1,
IDE01832-MAS06312,Generator regulator variant-ASIC variant,4,
IDE01833-MAS06105,Battery version-Rated battery capacity,105, Ah
IDE01833-MAS06106,Battery version-Battery technology,Fleece,
IDE01833-MAS06107,Battery version-Battery manufacturer,JCI,
IDE01834,Battery voltage,13.114, V
IDE01836,Battery current,1.534, A
IDE01837,Temperature of battery sensor,25, °C
IDE01838,Battery temperature,22, °C
IDE01839,Battery charge status,76, %
IDE01841,Battery internal resistance,3.6, mOhm
IDE01842,Usable battery charge,43, Ah
IDE01843,Battery voltage at rest,12.5, V
IDE01844,request idle speed increase,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847-MAS01577,Auxiliary heater activation restriction request-Auxiliary heating,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,4.60, Ah
IDE01849,Duration of last driving cycle,0.98, H
IDE01850,Overall energy balance,9872.20, Ah
IDE01851,Entire energy throughput,27519.7, Ah
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Cancel,
IDE01854-MAS09891,Energy reclamation request-recuperation active,active,
IDE01854-MAS09892,Energy reclamation request-Charge contingent for feedback,16560, As
IDE01855,Generator current,49.7, A
IDE01864-MAS03179,Status of current bus communication-Local data bus 2,active: local wakeup event,
IDE01864-MAS03180,Status of current bus communication-Local data bus,active: local wakeup event,
IDE01864-MAS05972,Status of current bus communication-Local data bus 3,active: local wakeup event,
IDE01864-MAS10445,Status of current bus communication-Data bus CAN 1,active: local wakeup event,
IDE01864-MAS10446,Status of current bus communication-Data bus CAN 2,active: local wakeup event,
IDE01864-MAS10447,Status of current bus communication-Data bus CAN 3,active: local wakeup event,
IDE01864-MAS10448,Status of current bus communication-Data bus CAN 4,active: local wakeup event,
IDE01864-MAS10449,Status of current bus communication-Data bus CAN 5,active: local wakeup event,
IDE01864-MAS10450,Status of current bus communication-Data bus CAN 6,active: local wakeup event,
IDE01864-MAS11107,Status of current bus communication-Data bus CAN 7,active: local wakeup event,
IDE01864-MAS11108,Status of current bus communication-FlexRay star 3,active: local wakeup event,
IDE01864-MAS11244,Status of current bus communication-FlexRay star 1,active: local wakeup event,
IDE01864-MAS11245,Status of current bus communication-FlexRay star 2,active: local wakeup event,
IDE01948,Battery internal resistance not normed,3.6, mOhm
IDE01971,Lowest recorded control module temperature,30, °C
IDE01972,Highest recorded control module temperature,55, °C
IDE01992-IDE14867,Installation list: current installations-Subgateway as firewall control module,Not available,
IDE01992-SFT00001,Installation list: current installations-Engine Electronics,Available,
IDE01992-SFT00002,Installation list: current installations-Transmission Electronics,Available,
IDE01992-SFT00006,Installation list: current installations-Seat adjustment: passenger's side,Available,
IDE01992-SFT00007,Installation list: current installations-Display/control head,Not available,
IDE01992-SFT00008,Installation list: current installations-HVAC electronics,Not available,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,Available,
IDE01992-SFT00012,Installation list: current installations-Rear Axle Steering 2,Not available,
IDE01992-SFT00017,Installation list: current installations-Engine electronics 2,Not available,
IDE01992-SFT00019,Installation list: current installations-Adaptive Cruise Control,Available,
IDE01992-SFT00022,Installation list: current installations-Steering Column Electronics,Available,
IDE01992-SFT00023,Installation list: current installations-Instrument cluster,Available,
IDE01992-SFT00024,Installation list: current installations-Auxiliary/parking heating,Available,
IDE01992-SFT00025,Installation list: current installations-Data Bus OBD Interface,Available,
IDE01992-SFT00027,Installation list: current installations-Active Steering,Not available,
IDE01992-SFT00032,Installation list: current installations-High beam assistant,Not available,
IDE01992-SFT00033,Installation list: current installations-Battery management 2,Not available,
IDE01992-SFT00034,Installation list: current installations-All-wheel drive electronics,Not available,
IDE01992-SFT00035,Installation list: current installations-Brake Boost,Not available,
IDE01992-SFT00038,Installation list: current installations-Convertible top operation,Not available,
IDE01992-SFT00039,Installation list: current installations-Display/operating unit rear,Not available,
IDE01992-SFT00040,Installation list: current installations-Rear A/C control head,Not available,
IDE01992-SFT00042,Installation list: current installations-Control module for inductive charging,Not available,
IDE01992-SFT00043,Installation list: current installations-Steering column lock,Available,
IDE01992-SFT00048,Installation list: current installations-Special Function 2,Not available,
IDE01992-SFT00050,Installation list: current installations-Differential lock electronics,Not available,
IDE01992-SFT00054,Installation list: current installations-Seat adjustment: driver side,Available,
IDE01992-SFT00061,Installation list: current installations-Special Function,Not available,
IDE01992-SFT00066,Installation list: current installations-Driver's door electronics,Available,
IDE01992-SFT00068,Installation list: current installations-Power steering,Available,
IDE01992-SFT00070,Installation list: current installations-Convenience system central module,Available,
IDE01992-SFT00072,Installation list: current installations-Seat adjustment: rear driver's side,Not available,
IDE01992-SFT00074,Installation list: current installations-Taillight_XXX,Not available,
IDE01992-SFT00077,Installation list: current installations-Vital data collection for vehicle occupants,Not available,
IDE01992-SFT00080,Installation list: current installations-Seat adjustment 3rd seat row,Not available,
IDE01992-SFT00081,Installation list: current installations-Electric drive,Not available,
IDE01992-SFT00082,Installation list: current installations-Passenger's door electronics,Available,
IDE01992-SFT00090,Installation list: current installations-Automated longitudinal control,Not available,
IDE01992-SFT00091,Installation list: current installations-Seat adjustment: rear passenger's side,Not available,
IDE01992-SFT00095,Installation list: current installations-Information electronics 1,Available,
IDE01992-SFT00101,Installation list: current installations-Tire Pressure Monitoring System (TPMS),Available,
IDE01992-SFT00105,Installation list: current installations-Trailer Function,Available,
IDE01992-SFT00107,Installation list: current installations-Aerodynamic control module,Not available,
IDE01992-SFT00108,Installation list: current installations-Rear view camera system,Available,
IDE01992-SFT00109,Installation list: current installations-Rear lid electronics,Available,
IDE01992-SFT00116,Installation list: current installations-Chassis Control,Available,
IDE01992-SFT00118,Installation list: current installations-Parking aid,Not available,
IDE01992-SFT00127,Installation list: current installations-Information electronics 2,Not available,
IDE01992-SFT00128,Installation list: current installations-Battery control additional memory 1,Not available,
IDE01992-SFT00129,Installation list: current installations-Shift lever,Available,
IDE01992-SFT00130,Installation list: current installations-Head-Up-Display,Available,
IDE01992-SFT00132,Installation list: current installations-Night vision system,Available,
IDE01992-SFT00139,Installation list: current installations-Distance regulation 2,Not available,
IDE01992-SFT00140,Installation list: current installations-Hybrid Battery Management,Not available,
IDE01992-SFT00166,Installation list: current installations-Microphone control module,Not available,
IDE01992-SFT00169,Installation list: current installations-Structure-borne sound actuator,Not available,
IDE01992-SFT00172,Installation list: current installations-Reducing Agent Metering System,Available,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,Not available,
IDE01992-SFT00186,Installation list: current installations-Subframe mount,Not available,
IDE01992-SFT00192,Installation list: current installations-Actuator For Exterior Noise,Not available,
IDE01992-SFT00195,Installation list: current installations-Electric drive 3,Not available,
IDE01992-SFT00196,Installation list: current installations-Voltage converter,Not available,
IDE01992-SFT00197,Installation list: current installations-Thermal management,Not available,
IDE01992-SFT00198,Installation list: current installations-High-voltage battery charger,Not available,
IDE01992-SFT00203,Installation list: current installations-Rear Axle Steering,Available,
IDE01992-SFT00205,Installation list: current installations-Laser for adaptive cruise control,Not available,
IDE01992-SFT00206,Installation list: current installations-Electric drive 2,Not available,
IDE01992-SFT00208,Installation list: current installations-Front Axle Lift System,Not available,
IDE01992-SFT00219,Installation list: current installations-Front Corner Radar 1,Available,
IDE01992-SFT00220,Installation list: current installations-Front Corner Radar 2,Available,
IDE01992-SFT00221,Installation list: current installations-Sunroof control module 2,Not available,
IDE01992-SFT33031,Installation list: current installations-Antenna module,Not available,
IDE01992-SFT33232,Installation list: current installations-Central control for digital matrix light,Not available,
IDE01992-SFT271904,Installation list: current installations-Sunroof control module,Available,
IDE01993-IDE14867,Control module reference number-Subgateway as firewall control module,49,
IDE01993-SFT00001,Control module reference number-Engine Electronics,76,
IDE01993-SFT00002,Control module reference number-Transmission Electronics,77,
IDE01993-SFT00003,Control module reference number-Brake electronics,05,
IDE01993-SFT00003,Control module reference number-Brake electronics,13,
IDE01993-SFT00006,Control module reference number-Seat adjustment: passenger's side,4D,
IDE01993-SFT00007,Control module reference number-Display/control head,8E,
IDE01993-SFT00008,Control module reference number-HVAC electronics,46,
IDE01993-SFT00009,Control module reference number-Electronic central electric,0E,
IDE01993-SFT00012,Control module reference number-Rear Axle Steering 2,61,
IDE01993-SFT00017,Control module reference number-Engine electronics 2,78,
IDE01993-SFT00019,Control module reference number-Adaptive Cruise Control,57,
IDE01993-SFT00021,Control module reference number-Airbag,06,
IDE01993-SFT00021,Control module reference number-Airbag,15,
IDE01993-SFT00022,Control module reference number-Steering Column Electronics,0C,
IDE01993-SFT00023,Control module reference number-Instrument cluster,14,
IDE01993-SFT00024,Control module reference number-Auxiliary/parking heating,6A,
IDE01993-SFT00025,Control module reference number-Data Bus OBD Interface,10,
IDE01993-SFT00027,Control module reference number-Active Steering,16,
IDE01993-SFT00032,Control module reference number-High beam assistant,30,
IDE01993-SFT00033,Control module reference number-Battery management 2,9C,
IDE01993-SFT00034,Control module reference number-All-wheel drive electronics,0F,
IDE01993-SFT00035,Control module reference number-Brake Boost,3B,
IDE01993-SFT00038,Control module reference number-Convertible top operation,2D,
IDE01993-SFT00039,Control module reference number-Display/operating unit rear,93,
IDE01993-SFT00040,Control module reference number-Rear A/C control head,00,
IDE01993-SFT00042,Control module reference number-Control module for inductive charging,8F,
IDE01993-SFT00043,Control module reference number-Steering column lock,31,
IDE01993-SFT00048,Control module reference number-Special Function 2,2B,
IDE01993-SFT00050,Control module reference number-Differential lock electronics,1E,
IDE01993-SFT00054,Control module reference number-Seat adjustment: driver side,4C,
IDE01993-SFT00060,Control module reference number-Lane change assistance,08,
IDE01993-SFT00060,Control module reference number-Lane change assistance,4E,
IDE01993-SFT00061,Control module reference number-Special Function,2C,
IDE01993-SFT00066,Control module reference number-Driver's door electronics,4A,
IDE01993-SFT00068,Control module reference number-Power steering,12,
IDE01993-SFT00070,Control module reference number-Convenience system central module,8B,
IDE01993-SFT00072,Control module reference number-Seat adjustment: rear driver's side,87,
IDE01993-SFT00074,Control module reference number-Taillight_XXX,00,
IDE01993-SFT00077,Control module reference number-Vital data collection for vehicle occupants,00,
IDE01993-SFT00080,Control module reference number-Seat adjustment 3rd seat row,95,
IDE01993-SFT00081,Control module reference number-Electric drive,7C,
IDE01993-SFT00081,Control module reference number-Electric drive,03,
IDE01993-SFT00082,Control module reference number-Passenger's door electronics,4B,
IDE01993-SFT00090,Control module reference number-Automated longitudinal control,94,
IDE01993-SFT00091,Control module reference number-Seat adjustment: rear passenger's side,88,
IDE01993-SFT00095,Control module reference number-Information electronics 1,73,
IDE01993-SFT00101,Control module reference number-Tire Pressure Monitoring System (TPMS),0B,
IDE01993-SFT00105,Control module reference number-Trailer Function,47,
IDE01993-SFT00107,Control module reference number-Aerodynamic control module,24,
IDE01993-SFT00108,Control module reference number-Rear view camera system,69,
IDE01993-SFT00109,Control module reference number-Rear lid electronics,23,
IDE01993-SFT00116,Control module reference number-Chassis Control,80,
IDE01993-SFT00118,Control module reference number-Parking aid,00,
IDE01993-SFT00127,Control module reference number-Information electronics 2,00,
IDE01993-SFT00128,Control module reference number-Battery control additional memory 1,AE,
IDE01993-SFT00129,Control module reference number-Shift lever,53,
IDE01993-SFT00130,Control module reference number-Head-Up-Display,1B,
IDE01993-SFT00132,Control module reference number-Night vision system,27,
IDE01993-SFT00139,Control module reference number-Distance regulation 2,00,
IDE01993-SFT00140,Control module reference number-Hybrid Battery Management,7B,
IDE01993-SFT00165,Control module reference number-Front sensor for driver assistance systems,4F,
IDE01993-SFT00165,Control module reference number-Front sensor for driver assistance systems,04,
IDE01993-SFT00166,Control module reference number-Microphone control module,00,
IDE01993-SFT00169,Control module reference number-Structure-borne sound actuator,1C,
IDE01993-SFT00172,Control module reference number-Reducing Agent Metering System,2A,
IDE01993-SFT00183,Control module reference number-Interface for access/start system,00,
IDE01993-SFT00186,Control module reference number-Subframe mount,2E,
IDE01993-SFT00192,Control module reference number-Actuator For Exterior Noise,64,
IDE01993-SFT00195,Control module reference number-Electric drive 3,43,
IDE01993-SFT00196,Control module reference number-Voltage converter,41,
IDE01993-SFT00197,Control module reference number-Thermal management,42,
IDE01993-SFT00198,Control module reference number-High-voltage battery charger,44,
IDE01993-SFT00203,Control module reference number-Rear Axle Steering,60,
IDE01993-SFT00205,Control module reference number-Laser for adaptive cruise control,89,
IDE01993-SFT00206,Control module reference number-Electric drive 2,B8,
IDE01993-SFT00207,Control module reference number-Lane Change Assistance 2,8A,
IDE01993-SFT00207,Control module reference number-Lane Change Assistance 2,07,
IDE01993-SFT00208,Control module reference number-Front Axle Lift System,59,
IDE01993-SFT00219,Control module reference number-Front Corner Radar 1,9D,
IDE01993-SFT00220,Control module reference number-Front Corner Radar 2,9E,
IDE01993-SFT00221,Control module reference number-Sunroof control module 2,A0,
IDE01993-SFT33031,Control module reference number-Antenna module,00,
IDE01993-SFT33232,Control module reference number-Central control for digital matrix light,00,
IDE01993-SFT271904,Control module reference number-Sunroof control module,84,
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,0, mA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,-84.79,
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,Not available,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,Not available,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,Not available,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,Not available,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE02384-IDE14867,Status of event memory-Subgateway as firewall control module,OK,
IDE02384-SFT00001,Status of event memory-Engine Electronics,OK,
IDE02384-SFT00002,Status of event memory-Transmission Electronics,OK,
IDE02384-SFT00003,Status of event memory-Brake electronics,OK,
IDE02384-SFT00006,Status of event memory-Seat adjustment: passenger's side,OK,
IDE02384-SFT00007,Status of event memory-Display/control head,OK,
IDE02384-SFT00008,Status of event memory-HVAC electronics,OK,
IDE02384-SFT00009,Status of event memory-Electronic central electric,Malfunction,
IDE02384-SFT00012,Status of event memory-Rear Axle Steering 2,OK,
IDE02384-SFT00017,Status of event memory-Engine electronics 2,OK,
IDE02384-SFT00019,Status of event memory-Adaptive Cruise Control,Malfunction,
IDE02384-SFT00021,Status of event memory-Airbag,OK,
IDE02384-SFT00022,Status of event memory-Steering Column Electronics,OK,
IDE02384-SFT00023,Status of event memory-Instrument cluster,OK,
IDE02384-SFT00024,Status of event memory-Auxiliary/parking heating,OK,
IDE02384-SFT00025,Status of event memory-Data Bus OBD Interface,OK,
IDE02384-SFT00027,Status of event memory-Active Steering,OK,
IDE02384-SFT00032,Status of event memory-High beam assistant,OK,
IDE02384-SFT00033,Status of event memory-Battery management 2,OK,
IDE02384-SFT00034,Status of event memory-All-wheel drive electronics,OK,
IDE02384-SFT00035,Status of event memory-Brake Boost,OK,
IDE02384-SFT00038,Status of event memory-Convertible top operation,OK,
IDE02384-SFT00039,Status of event memory-Display/operating unit rear,OK,
IDE02384-SFT00040,Status of event memory-Rear A/C control head,OK,
IDE02384-SFT00042,Status of event memory-Control module for inductive charging,OK,
IDE02384-SFT00043,Status of event memory-Steering column lock,OK,
IDE02384-SFT00048,Status of event memory-Special Function 2,OK,
IDE02384-SFT00050,Status of event memory-Differential lock electronics,OK,
IDE02384-SFT00054,Status of event memory-Seat adjustment: driver side,OK,
IDE02384-SFT00060,Status of event memory-Lane change assistance,OK,
IDE02384-SFT00061,Status of event memory-Special Function,OK,
IDE02384-SFT00066,Status of event memory-Driver's door electronics,OK,
IDE02384-SFT00068,Status of event memory-Power steering,OK,
IDE02384-SFT00070,Status of event memory-Convenience system central module,OK,
IDE02384-SFT00072,Status of event memory-Seat adjustment: rear driver's side,OK,
IDE02384-SFT00074,Status of event memory-Taillight_XXX,OK,
IDE02384-SFT00077,Status of event memory-Vital data collection for vehicle occupants,OK,
IDE02384-SFT00080,Status of event memory-Seat adjustment 3rd seat row,OK,
IDE02384-SFT00081,Status of event memory-Electric drive,OK,
IDE02384-SFT00082,Status of event memory-Passenger's door electronics,OK,
IDE02384-SFT00090,Status of event memory-Automated longitudinal control,OK,
IDE02384-SFT00091,Status of event memory-Seat adjustment: rear passenger's side,OK,
IDE02384-SFT00095,Status of event memory-Information electronics 1,OK,
IDE02384-SFT00101,Status of event memory-Tire Pressure Monitoring System (TPMS),OK,
IDE02384-SFT00105,Status of event memory-Trailer Function,OK,
IDE02384-SFT00107,Status of event memory-Aerodynamic control module,OK,
IDE02384-SFT00108,Status of event memory-Rear view camera system,OK,
IDE02384-SFT00109,Status of event memory-Rear lid electronics,OK,
IDE02384-SFT00116,Status of event memory-Chassis Control,OK,
IDE02384-SFT00118,Status of event memory-Parking aid,OK,
IDE02384-SFT00127,Status of event memory-Information electronics 2,OK,
IDE02384-SFT00128,Status of event memory-Battery control additional memory 1,OK,
IDE02384-SFT00129,Status of event memory-Shift lever,OK,
IDE02384-SFT00130,Status of event memory-Head-Up-Display,OK,
IDE02384-SFT00132,Status of event memory-Night vision system,OK,
IDE02384-SFT00139,Status of event memory-Distance regulation 2,OK,
IDE02384-SFT00140,Status of event memory-Hybrid Battery Management,OK,
IDE02384-SFT00165,Status of event memory-Front sensor for driver assistance systems,OK,
IDE02384-SFT00165,Status of event memory-Front sensor for driver assistance systems,Malfunction,
IDE02384-SFT00166,Status of event memory-Microphone control module,OK,
IDE02384-SFT00169,Status of event memory-Structure-borne sound actuator,OK,
IDE02384-SFT00172,Status of event memory-Reducing Agent Metering System,OK,
IDE02384-SFT00183,Status of event memory-Interface for access/start system,OK,
IDE02384-SFT00186,Status of event memory-Subframe mount,OK,
IDE02384-SFT00192,Status of event memory-Actuator For Exterior Noise,OK,
IDE02384-SFT00195,Status of event memory-Electric drive 3,OK,
IDE02384-SFT00196,Status of event memory-Voltage converter,OK,
IDE02384-SFT00197,Status of event memory-Thermal management,OK,
IDE02384-SFT00198,Status of event memory-High-voltage battery charger,OK,
IDE02384-SFT00203,Status of event memory-Rear Axle Steering,OK,
IDE02384-SFT00205,Status of event memory-Laser for adaptive cruise control,OK,
IDE02384-SFT00206,Status of event memory-Electric drive 2,OK,
IDE02384-SFT00207,Status of event memory-Lane Change Assistance 2,OK,
IDE02384-SFT00208,Status of event memory-Front Axle Lift System,OK,
IDE02384-SFT00219,Status of event memory-Front Corner Radar 1,OK,
IDE02384-SFT00220,Status of event memory-Front Corner Radar 2,OK,
IDE02384-SFT00221,Status of event memory-Sunroof control module 2,OK,
IDE02384-SFT33031,Status of event memory-Antenna module,OK,
IDE02384-SFT33232,Status of event memory-Central control for digital matrix light,OK,
IDE02384-SFT271904,Status of event memory-Sunroof control module,OK,
IDE02578-IDE05118,Play protection status-Counter for function calls,0,
IDE02578-MAS02040,Play protection status-Anti-play protection,not active,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09775,Steering wheel heating-Steering wheel temp.,73, °C
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04055,Stop process prevented-Extractable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04059,Stop process prevented-Battery temperature,not active,
IDE03008-MAS04060,Stop process prevented-Other reasons active,not active,
IDE03008-MAS04061,Stop process prevented-Idle increase active,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS09832,Stop process prevented-Intermittent mode,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04055,Start process requested-Extractable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS04060,Start process requested-Other reasons active,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04055,Number of prevented stop processes-Extractable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,1728,
IDE03010-MAS04059,Number of prevented stop processes-Battery temperature,368,
IDE03010-MAS04060,Number of prevented stop processes-Other reasons active,0,
IDE03010-MAS04061,Number of prevented stop processes-Idle increase active,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,219,
IDE03010-MAS06001,Number of prevented stop processes-Energy management special veto,0,
IDE03010-MAS09832,Number of prevented stop processes-Intermittent mode,8,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04055,Number of requested start processes-Extractable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS04060,Number of requested start processes-Other reasons active,0,
IDE03011-MAS06003,Number of requested start processes-Charge contingency,54,
IDE03011-MAS06004,Number of requested start processes-Special start request,0,
IDE03150-IDE14867,Readiness for bus sleep mode-Subgateway as firewall control module,Bus sleep mode,
IDE03150-SFT00001,Readiness for bus sleep mode-Engine Electronics,active,
IDE03150-SFT00002,Readiness for bus sleep mode-Transmission Electronics,active,
IDE03150-SFT00003,Readiness for bus sleep mode-Brake electronics,Bus sleep mode,
IDE03150-SFT00003,Readiness for bus sleep mode-Brake electronics,active,
IDE03150-SFT00006,Readiness for bus sleep mode-Seat adjustment: passenger's side,Bus sleep mode,
IDE03150-SFT00007,Readiness for bus sleep mode-Display/control head,Bus sleep mode,
IDE03150-SFT00008,Readiness for bus sleep mode-HVAC electronics,Bus sleep mode,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,active,
IDE03150-SFT00012,Readiness for bus sleep mode-Rear Axle Steering 2,Bus sleep mode,
IDE03150-SFT00017,Readiness for bus sleep mode-Engine electronics 2,Bus sleep mode,
IDE03150-SFT00019,Readiness for bus sleep mode-Adaptive Cruise Control,Bus sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,Bus sleep mode,
IDE03150-SFT00021,Readiness for bus sleep mode-Airbag,active,
IDE03150-SFT00022,Readiness for bus sleep mode-Steering Column Electronics,active,
IDE03150-SFT00023,Readiness for bus sleep mode-Instrument cluster,active,
IDE03150-SFT00024,Readiness for bus sleep mode-Auxiliary/parking heating,active,
IDE03150-SFT00025,Readiness for bus sleep mode-Data Bus OBD Interface,active,
IDE03150-SFT00027,Readiness for bus sleep mode-Active Steering,Bus sleep mode,
IDE03150-SFT00032,Readiness for bus sleep mode-High beam assistant,Bus sleep mode,
IDE03150-SFT00033,Readiness for bus sleep mode-Battery management 2,Bus sleep mode,
IDE03150-SFT00034,Readiness for bus sleep mode-All-wheel drive electronics,Bus sleep mode,
IDE03150-SFT00035,Readiness for bus sleep mode-Brake Boost,Bus sleep mode,
IDE03150-SFT00038,Readiness for bus sleep mode-Convertible top operation,Bus sleep mode,
IDE03150-SFT00039,Readiness for bus sleep mode-Display/operating unit rear,Bus sleep mode,
IDE03150-SFT00040,Readiness for bus sleep mode-Rear A/C control head,Bus sleep mode,
IDE03150-SFT00042,Readiness for bus sleep mode-Control module for inductive charging,Bus sleep mode,
IDE03150-SFT00043,Readiness for bus sleep mode-Steering column lock,active,
IDE03150-SFT00048,Readiness for bus sleep mode-Special Function 2,Bus sleep mode,
IDE03150-SFT00050,Readiness for bus sleep mode-Differential lock electronics,Bus sleep mode,
IDE03150-SFT00054,Readiness for bus sleep mode-Seat adjustment: driver side,Bus sleep mode,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane change assistance,active,
IDE03150-SFT00060,Readiness for bus sleep mode-Lane change assistance,Bus sleep mode,
IDE03150-SFT00061,Readiness for bus sleep mode-Special Function,Bus sleep mode,
IDE03150-SFT00066,Readiness for bus sleep mode-Driver's door electronics,active,
IDE03150-SFT00068,Readiness for bus sleep mode-Power steering,active,
IDE03150-SFT00070,Readiness for bus sleep mode-Convenience system central module,active,
IDE03150-SFT00072,Readiness for bus sleep mode-Seat adjustment: rear driver's side,Bus sleep mode,
IDE03150-SFT00074,Readiness for bus sleep mode-Taillight_XXX,Bus sleep mode,
IDE03150-SFT00077,Readiness for bus sleep mode-Vital data collection for vehicle occupants,Bus sleep mode,
IDE03150-SFT00080,Readiness for bus sleep mode-Seat adjustment 3rd seat row,Bus sleep mode,
IDE03150-SFT00081,Readiness for bus sleep mode-Electric drive,Bus sleep mode,
IDE03150-SFT00082,Readiness for bus sleep mode-Passenger's door electronics,Bus sleep mode,
IDE03150-SFT00090,Readiness for bus sleep mode-Automated longitudinal control,Bus sleep mode,
IDE03150-SFT00091,Readiness for bus sleep mode-Seat adjustment: rear passenger's side,Bus sleep mode,
IDE03150-SFT00095,Readiness for bus sleep mode-Information electronics 1,active,
IDE03150-SFT00101,Readiness for bus sleep mode-Tire Pressure Monitoring System (TPMS),active,
IDE03150-SFT00105,Readiness for bus sleep mode-Trailer Function,Bus sleep mode,
IDE03150-SFT00107,Readiness for bus sleep mode-Aerodynamic control module,Bus sleep mode,
IDE03150-SFT00108,Readiness for bus sleep mode-Rear view camera system,active,
IDE03150-SFT00109,Readiness for bus sleep mode-Rear lid electronics,Bus sleep mode,
IDE03150-SFT00116,Readiness for bus sleep mode-Chassis Control,active,
IDE03150-SFT00118,Readiness for bus sleep mode-Parking aid,Bus sleep mode,
IDE03150-SFT00127,Readiness for bus sleep mode-Information electronics 2,Bus sleep mode,
IDE03150-SFT00128,Readiness for bus sleep mode-Battery control additional memory 1,Bus sleep mode,
IDE03150-SFT00129,Readiness for bus sleep mode-Shift lever,active,
IDE03150-SFT00130,Readiness for bus sleep mode-Head-Up-Display,active,
IDE03150-SFT00132,Readiness for bus sleep mode-Night vision system,active,
IDE03150-SFT00139,Readiness for bus sleep mode-Distance regulation 2,Bus sleep mode,
IDE03150-SFT00140,Readiness for bus sleep mode-Hybrid Battery Management,Bus sleep mode,
IDE03150-SFT00165,Readiness for bus sleep mode-Front sensor for driver assistance systems,active,
IDE03150-SFT00165,Readiness for bus sleep mode-Front sensor for driver assistance systems,Bus sleep mode,
IDE03150-SFT00166,Readiness for bus sleep mode-Microphone control module,Bus sleep mode,
IDE03150-SFT00169,Readiness for bus sleep mode-Structure-borne sound actuator,Bus sleep mode,
IDE03150-SFT00172,Readiness for bus sleep mode-Reducing Agent Metering System,active,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,Bus sleep mode,
IDE03150-SFT00186,Readiness for bus sleep mode-Subframe mount,Bus sleep mode,
IDE03150-SFT00192,Readiness for bus sleep mode-Actuator For Exterior Noise,Bus sleep mode,
IDE03150-SFT00195,Readiness for bus sleep mode-Electric drive 3,Bus sleep mode,
IDE03150-SFT00196,Readiness for bus sleep mode-Voltage converter,Bus sleep mode,
IDE03150-SFT00197,Readiness for bus sleep mode-Thermal management,Bus sleep mode,
IDE03150-SFT00198,Readiness for bus sleep mode-High-voltage battery charger,Bus sleep mode,
IDE03150-SFT00203,Readiness for bus sleep mode-Rear Axle Steering,active,
IDE03150-SFT00205,Readiness for bus sleep mode-Laser for adaptive cruise control,Bus sleep mode,
IDE03150-SFT00206,Readiness for bus sleep mode-Electric drive 2,Bus sleep mode,
IDE03150-SFT00207,Readiness for bus sleep mode-Lane Change Assistance 2,active,
IDE03150-SFT00207,Readiness for bus sleep mode-Lane Change Assistance 2,Bus sleep mode,
IDE03150-SFT00208,Readiness for bus sleep mode-Front Axle Lift System,Bus sleep mode,
IDE03150-SFT00219,Readiness for bus sleep mode-Front Corner Radar 1,Bus sleep mode,
IDE03150-SFT00220,Readiness for bus sleep mode-Front Corner Radar 2,Bus sleep mode,
IDE03150-SFT00221,Readiness for bus sleep mode-Sunroof control module 2,Bus sleep mode,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Bus sleep mode,
IDE03150-SFT33232,Readiness for bus sleep mode-Central control for digital matrix light,Bus sleep mode,
IDE03150-SFT271904,Readiness for bus sleep mode-Sunroof control module,Bus sleep mode,
IDE03205,Manufacturer code,SME,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03477-MAS00107,GPS time-Month,Not available,
IDE03477-MAS00108,GPS time-Day,Not available,
IDE03477-MAS00109,GPS time-Hours,Not available,
IDE03477-MAS00110,GPS time-Minutes,Not available,
IDE03477-MAS00111,GPS time-Seconds,Not available,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,No malfunction,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,No malfunction,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,No malfunction,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,No malfunction,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,No malfunction,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,No malfunction,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04343-IDE14867,Bus identification-Subgateway as firewall control module,Data bus Sensor/Hybrid,
IDE04343-SFT00001,Bus identification-Engine Electronics,Data bus Flexray A,
IDE04343-SFT00002,Bus identification-Transmission Electronics,Data bus Flexray A,
IDE04343-SFT00003,Bus identification-Brake electronics,FlexRay B data bus,
IDE04343-SFT00003,Bus identification-Brake electronics,Data bus Flexray A,
IDE04343-SFT00006,Bus identification-Seat adjustment: passenger's side,Comfort data bus,
IDE04343-SFT00007,Bus identification-Display/control head,Infotainment data bus,
IDE04343-SFT00008,Bus identification-HVAC electronics,Comfort CAN bus 2,
IDE04343-SFT00009,Bus identification-Electronic central electric,Comfort CAN bus 2,
IDE04343-SFT00012,Bus identification-Rear Axle Steering 2,Data bus Flexray A,
IDE04343-SFT00017,Bus identification-Engine electronics 2,Data bus Flexray A,
IDE04343-SFT00019,Bus identification-Adaptive Cruise Control,FlexRay B data bus,
IDE04343-SFT00021,Bus identification-Airbag,FlexRay B data bus,
IDE04343-SFT00021,Bus identification-Airbag,Data bus Flexray A,
IDE04343-SFT00022,Bus identification-Steering Column Electronics,Data bus Flexray A,
IDE04343-SFT00023,Bus identification-Instrument cluster,Combi/dashboard data bus,
IDE04343-SFT00024,Bus identification-Auxiliary/parking heating,Extended data bus,
IDE04343-SFT00025,Bus identification-Data Bus OBD Interface,Bus master,
IDE04343-SFT00027,Bus identification-Active Steering,Data bus Flexray A,
IDE04343-SFT00032,Bus identification-High beam assistant,Extended data bus,
IDE04343-SFT00033,Bus identification-Battery management 2,Data bus Sensor/Hybrid,
IDE04343-SFT00034,Bus identification-All-wheel drive electronics,Data bus Flexray A,
IDE04343-SFT00035,Bus identification-Brake Boost,Data bus Flexray A,
IDE04343-SFT00038,Bus identification-Convertible top operation,Comfort data bus,
IDE04343-SFT00039,Bus identification-Display/operating unit rear,Infotainment data bus,
IDE04343-SFT00040,Bus identification-Rear A/C control head,Unknown,
IDE04343-SFT00042,Bus identification-Control module for inductive charging,Data bus Sensor/Hybrid,
IDE04343-SFT00043,Bus identification-Steering column lock,Comfort data bus,
IDE04343-SFT00048,Bus identification-Special Function 2,Comfort data bus,
IDE04343-SFT00050,Bus identification-Differential lock electronics,Data bus Flexray A,
IDE04343-SFT00054,Bus identification-Seat adjustment: driver side,Comfort data bus,
IDE04343-SFT00060,Bus identification-Lane change assistance,FlexRay B data bus,
IDE04343-SFT00060,Bus identification-Lane change assistance,Extended data bus,
IDE04343-SFT00061,Bus identification-Special Function,Comfort data bus,
IDE04343-SFT00066,Bus identification-Driver's door electronics,Comfort data bus,
IDE04343-SFT00068,Bus identification-Power steering,Data bus Flexray A,
IDE04343-SFT00070,Bus identification-Convenience system central module,Comfort data bus,
IDE04343-SFT00072,Bus identification-Seat adjustment: rear driver's side,Comfort data bus,
IDE04343-SFT00074,Bus identification-Taillight_XXX,Unknown,
IDE04343-SFT00077,Bus identification-Vital data collection for vehicle occupants,Unknown,
IDE04343-SFT00080,Bus identification-Seat adjustment 3rd seat row,Comfort data bus,
IDE04343-SFT00081,Bus identification-Electric drive,Data bus Sensor/Hybrid,
IDE04343-SFT00081,Bus identification-Electric drive,Data bus Flexray A,
IDE04343-SFT00082,Bus identification-Passenger's door electronics,Comfort data bus,
IDE04343-SFT00090,Bus identification-Automated longitudinal control,Data bus Flexray A,
IDE04343-SFT00091,Bus identification-Seat adjustment: rear passenger's side,Comfort data bus,
IDE04343-SFT00095,Bus identification-Information electronics 1,Infotainment data bus,
IDE04343-SFT00101,Bus identification-Tire Pressure Monitoring System (TPMS),Extended data bus,
IDE04343-SFT00105,Bus identification-Trailer Function,Comfort data bus,
IDE04343-SFT00107,Bus identification-Aerodynamic control module,Comfort data bus,
IDE04343-SFT00108,Bus identification-Rear view camera system,Extended data bus,
IDE04343-SFT00109,Bus identification-Rear lid electronics,Comfort data bus,
IDE04343-SFT00116,Bus identification-Chassis Control,Data bus Flexray A,
IDE04343-SFT00118,Bus identification-Parking aid,Unknown,
IDE04343-SFT00127,Bus identification-Information electronics 2,Unknown,
IDE04343-SFT00128,Bus identification-Battery control additional memory 1,Data bus Sensor/Hybrid,
IDE04343-SFT00129,Bus identification-Shift lever,Combi/dashboard data bus,
IDE04343-SFT00130,Bus identification-Head-Up-Display,Combi/dashboard data bus,
IDE04343-SFT00132,Bus identification-Night vision system,Extended data bus,
IDE04343-SFT00139,Bus identification-Distance regulation 2,Unknown,
IDE04343-SFT00140,Bus identification-Hybrid Battery Management,Data bus Sensor/Hybrid,
IDE04343-SFT00165,Bus identification-Front sensor for driver assistance systems,FlexRay B data bus,
IDE04343-SFT00165,Bus identification-Front sensor for driver assistance systems,Data bus Flexray A,
IDE04343-SFT00166,Bus identification-Microphone control module,Unknown,
IDE04343-SFT00169,Bus identification-Structure-borne sound actuator,Extended data bus,
IDE04343-SFT00172,Bus identification-Reducing Agent Metering System,Extended data bus,
IDE04343-SFT00183,Bus identification-Interface for access/start system,Unknown,
IDE04343-SFT00186,Bus identification-Subframe mount,Extended data bus,
IDE04343-SFT00192,Bus identification-Actuator For Exterior Noise,Extended data bus,
IDE04343-SFT00195,Bus identification-Electric drive 3,Data bus Flexray A,
IDE04343-SFT00196,Bus identification-Voltage converter,Data bus Sensor/Hybrid,
IDE04343-SFT00197,Bus identification-Thermal management,Data bus Sensor/Hybrid,
IDE04343-SFT00198,Bus identification-High-voltage battery charger,Data bus Sensor/Hybrid,
IDE04343-SFT00203,Bus identification-Rear Axle Steering,Data bus Flexray A,
IDE04343-SFT00205,Bus identification-Laser for adaptive cruise control,FlexRay B data bus,
IDE04343-SFT00206,Bus identification-Electric drive 2,Data bus Flexray A,
IDE04343-SFT00207,Bus identification-Lane Change Assistance 2,FlexRay B data bus,
IDE04343-SFT00207,Bus identification-Lane Change Assistance 2,Extended data bus,
IDE04343-SFT00208,Bus identification-Front Axle Lift System,Comfort CAN bus 2,
IDE04343-SFT00219,Bus identification-Front Corner Radar 1,FlexRay B data bus,
IDE04343-SFT00220,Bus identification-Front Corner Radar 2,Unknown,
IDE04343-SFT00221,Bus identification-Sunroof control module 2,Unknown,
IDE04343-SFT33031,Bus identification-Antenna module,Unknown,
IDE04343-SFT33232,Bus identification-Central control for digital matrix light,Unknown,
IDE04343-SFT271904,Bus identification-Sunroof control module,Comfort data bus,
IDE04605-IDE01712,Navigation: Corrected position-GPS Position,Not available,
IDE04605-MAS01779,Navigation: Corrected position-Length,37 31 32 33 35 34 33 00 00 00 00 00 00 00,
IDE04605-MAS01780,Navigation: Corrected position-Width,35 32 38 33 30 38 30 33 00 00 00 00 00 00,
IDE04605-MAS04183,Navigation: Corrected position-Position error,0, m
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03877,SIM card-SIM ID,351617100600903,
IDE04750-MAS03878,SIM card-SIM IMSI,204047108137611,
IDE04750-MAS04226,SIM card-Telephone number,
IDE04750-MAS08401,SIM card-SIM intern,Available,
IDE04750-MAS08402,SIM card-SIM extern,Not available,
IDE04790,Call for help button,Not available,
IDE04806-MAS10929,Driving profile selection button-Button for load profile selection,Not operated,
IDE04806-MAS10937,Driving profile selection button-Driving profile selection button 1,operated,
IDE04806-MAS10938,Driving profile selection button-Driving profile selection button 2,operated,
IDE04806-MAS10939,Driving profile selection button-Drive profile selection rotary switch,Profile 2,
IDE05430,Telephone serial number,351617100600903,
IDE05583-IDE09851,Break recommendation-Function active,Yes,
IDE05583-MAS03095,Break recommendation-Function status,Initialization,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No display,
IDE05583-MAS13273,Break recommendation-deactivation status,No malfunction,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG136079,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG136080,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG136081,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG136082,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG136083,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG136084,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG136085,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG136086,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,D6 27 FB 08 6C,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,no entry,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,Engine/Motor Control Module,
IDE06007-MAS00106,Driving profile history data 1-Year,2000, yr
IDE06007-MAS00107,Driving profile history data 1-Month,0, m
IDE06007-MAS00108,Driving profile history data 1-Day,0, d
IDE06007-MAS00109,Driving profile history data 1-Hours,0, H
IDE06007-MAS00110,Driving profile history data 1-Minutes,0, min
IDE06007-MAS00111,Driving profile history data 1-Seconds,0, s
IDE06007-MAS00711,Driving profile history data 1-kilometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,no entry,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,Start-stop,
IDE06008-MAS00106,Driving profile history data 2-Year,2000, yr
IDE06008-MAS00107,Driving profile history data 2-Month,0, m
IDE06008-MAS00108,Driving profile history data 2-Day,0, d
IDE06008-MAS00109,Driving profile history data 2-Hours,0, H
IDE06008-MAS00110,Driving profile history data 2-Minutes,0, min
IDE06008-MAS00111,Driving profile history data 2-Seconds,0, s
IDE06008-MAS00711,Driving profile history data 2-kilometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,no entry,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,no entry,
IDE06009-MAS00106,Driving profile history data 3-Year,2000, yr
IDE06009-MAS00107,Driving profile history data 3-Month,0, m
IDE06009-MAS00108,Driving profile history data 3-Day,0, d
IDE06009-MAS00109,Driving profile history data 3-Hours,0, H
IDE06009-MAS00110,Driving profile history data 3-Minutes,0, min
IDE06009-MAS00111,Driving profile history data 3-Seconds,0, s
IDE06009-MAS00711,Driving profile history data 3-kilometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,no entry,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,no entry,
IDE06010-MAS00106,Driving profile history data 4-Year,2000, yr
IDE06010-MAS00107,Driving profile history data 4-Month,0, m
IDE06010-MAS00108,Driving profile history data 4-Day,0, d
IDE06010-MAS00109,Driving profile history data 4-Hours,0, H
IDE06010-MAS00110,Driving profile history data 4-Minutes,0, min
IDE06010-MAS00111,Driving profile history data 4-Seconds,0, s
IDE06010-MAS00711,Driving profile history data 4-kilometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG136071,Selected driving profile-driving_profile_1,Profile 1,
IDE06011-ENG136072,Selected driving profile-driving_profile_2,not working,
IDE06011-ENG136073,Selected driving profile-driving_profile_3,not working,
IDE06011-ENG136074,Selected driving profile-driving_profile_4,not working,
IDE06011-ENG136075,Selected driving profile-driving_profile_5,not working,
IDE06011-ENG136076,Selected driving profile-driving_profile_6,not working,
IDE06011-ENG136077,Selected driving profile-driving_profile_7,not working,
IDE06011-ENG136078,Selected driving profile-driving_profile_8,not working,
IDE06165-ENG118695,Driving profile selection statistics-Profile_1,133014, min
IDE06165-ENG126249,Driving profile selection statistics-profile_10,12, min
IDE06165-ENG126250,Driving profile selection statistics-profile_11,0, min
IDE06165-ENG127921,Driving profile selection statistics-profile_12,0, min
IDE06165-ENG135288,Driving profile selection statistics-profile_13,0, min
IDE06165-ENG135289,Driving profile selection statistics-profile_14,0, min
IDE06165-ENG135290,Driving profile selection statistics-profile_15,0, min
IDE06165-ENG118696,Driving profile selection statistics-Profile_2,41848, min
IDE06165-ENG118697,Driving profile selection statistics-Profile_3,3444, min
IDE06165-ENG118698,Driving profile selection statistics-Profile_4,2276, min
IDE06165-ENG118699,Driving profile selection statistics-Profile_5,506, min
IDE06165-ENG118700,Driving profile selection statistics-Profile_6,3814, min
IDE06165-ENG118701,Driving profile selection statistics-Profile_7,61, min
IDE06165-ENG118702,Driving profile selection statistics-Profile_8,11, min
IDE06165-ENG126248,Driving profile selection statistics-profile_9,3, min
IDE06230-MAS00106,Break recommend.: last message-Year,2025, yr
IDE06230-MAS00107,Break recommend.: last message-Month,7, m
IDE06230-MAS00108,Break recommend.: last message-Day,2, d
IDE06230-MAS00109,Break recommend.: last message-Hours,12, H
IDE06230-MAS00110,Break recommend.: last message-Minutes,14, min
IDE06230-MAS00111,Break recommend.: last message-Seconds,26, s
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,Stage 2,
IDE06264-IDE09057,Deep discharge protection-HV battery charge state,Malfunction,
IDE06264-MAS04721,Deep discharge protection-Minimum charge level,Malfunction,
IDE06264-MAS13070,Deep discharge protection-High-voltage energy management shut-down stage,not active,
IDE06307-MAS00106,Stop prevention history data-Year,2026,
IDE06307-MAS00107,Stop prevention history data-Month,9,
IDE06307-MAS00108,Stop prevention history data-Day,18,
IDE06307-MAS00109,Stop prevention history data-Hours,14,
IDE06307-MAS00110,Stop prevention history data-Minutes,6,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307,Stop prevention history data,not active,
IDE06307,Stop prevention history data,Battery state of charge too low,
IDE06308-MAS00106,Start request history data-Year,2026,
IDE06308-MAS00107,Start request history data-Month,9,
IDE06308-MAS00108,Start request history data-Day,17,
IDE06308-MAS00109,Start request history data-Hours,6,
IDE06308-MAS00110,Start request history data-Minutes,59,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308,Start request history data,not active,
IDE06308,Start request history data,Charge contingency,
IDE06522,Temperature of phone unit,41, °C
IDE06577,Supplier Identification,Conti Temic microelectronic GmbH,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,33,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Actual value,0,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,5,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Actual value,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,34,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Actual value,2,
IDE07427-IDE04447,Status: driving profile selection for power steering-Function status,engaged,
IDE07427-IDE06260,Status: driving profile selection for power steering-ID number,18,
IDE07427-MAS01156,Status: driving profile selection for power steering-Communication status,OK,
IDE07427-MAS01447,Status: driving profile selection for power steering-Actual value,2,
IDE07428-IDE04447,Status: driving profile selection for damping adjustment-Function status,engaged,
IDE07428-IDE06260,Status: driving profile selection for damping adjustment-ID number,9,
IDE07428-MAS01156,Status: driving profile selection for damping adjustment-Communication status,OK,
IDE07428-MAS01447,Status: driving profile selection for damping adjustment-Actual value,1,
IDE07429-IDE04447,Status: driving profile selection for A/C-Function status,engaged,
IDE07429-IDE06260,Status: driving profile selection for A/C-ID number,0,
IDE07429-MAS01156,Status: driving profile selection for A/C-Communication status,OK,
IDE07429-MAS01447,Status: driving profile selection for A/C-Actual value,2,
IDE07430-IDE04447,Status: driving profile selection for adaptive cruise control-Function status,engaged,
IDE07430-IDE06260,Status: driving profile selection for adaptive cruise control-ID number,46,
IDE07430-MAS01156,Status: driving profile selection for adaptive cruise control-Communication status,OK,
IDE07430-MAS01447,Status: driving profile selection for adaptive cruise control-Actual value,1,
IDE07431-IDE04447,Status: driv prof.select.for corn.light & headlamp range ctrl-Function status,engaged,
IDE07431-IDE06260,Status: driv prof.select.for corn.light & headlamp range ctrl-ID number,14,
IDE07431-MAS01156,Status: driv prof.select.for corn.light & headlamp range ctrl-Communication status,OK,
IDE07431-MAS01447,Status: driv prof.select.for corn.light & headlamp range ctrl-Actual value,0,
IDE07432-IDE04447,Status: driving profile selection for structure-borne noise-Function status,not engaged,
IDE07432-IDE06260,Status: driving profile selection for structure-borne noise-ID number,0,
IDE07432-MAS01156,Status: driving profile selection for structure-borne noise-Communication status,OK,
IDE07432-MAS01447,Status: driving profile selection for structure-borne noise-Actual value,0,
IDE07433-IDE04447,Status: driving profile selection for ambient lighting-Function status,not engaged,
IDE07433-IDE06260,Status: driving profile selection for ambient lighting-ID number,0,
IDE07433-MAS01156,Status: driving profile selection for ambient lighting-Communication status,OK,
IDE07433-MAS01447,Status: driving profile selection for ambient lighting-Actual value,2,
IDE07434-IDE04447,Status: driving profile selection for belt tensioner-Function status,engaged,
IDE07434-IDE06260,Status: driving profile selection for belt tensioner-ID number,0,
IDE07434-MAS01156,Status: driving profile selection for belt tensioner-Communication status,OK,
IDE07434-MAS01447,Status: driving profile selection for belt tensioner-Actual value,0,
IDE07436-IDE04447,Status: driving profile selection for free-running hub-Function status,engaged,
IDE07436-IDE06260,Status: driving profile selection for free-running hub-ID number,0,
IDE07436-MAS01156,Status: driving profile selection for free-running hub-Communication status,OK,
IDE07436-MAS01447,Status: driving profile selection for free-running hub-Actual value,0,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,5, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.90, V
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognised,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognised,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.40, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.50, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,448, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,568, A
IDE07847-MAS00976,Start stop requests without reason-Counter,0,
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Comfort,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,AUTO,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Dynamic,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Offroad,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,ECONOMY,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,INDIVIDUAL,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,Electric driving,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,Hybrid Automatic,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,Stop hybrid loading,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Hybrid load,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07873-MAS08879,Driving mode selection activated profiles-Profile 13,Not Used,
IDE07873-MAS08880,Driving mode selection activated profiles-Profile 14,Not Used,
IDE07873-MAS08881,Driving mode selection activated profiles-Profile 15,Not Used,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,257,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08251-MAS01483,Configuration immobilizer-Software version,0E 03 00,
IDE08251-MAS02832,Configuration immobilizer-Malfunction status,3C,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,05,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,B6,
IDE08251-MAS06850,Configuration immobilizer-Supported power class 2,00,
IDE08251-MAS06851,Configuration immobilizer-Supported power class 3,00,
IDE08251-MAS06852,Configuration immobilizer-Supported power class 4,00,
IDE08251-MAS06853,Configuration immobilizer-Supported power class 5,00,
IDE08343,Immobilizer Challenge,56 67 FA 23,
IDE08355-IDE04447,Status: driving profile selection for external noise actuator-Function status,not engaged,
IDE08355-IDE06260,Status: driving profile selection for external noise actuator-ID number,0,
IDE08355-MAS01156,Status: driving profile selection for external noise actuator-Communication status,OK,
IDE08355-MAS01447,Status: driving profile selection for external noise actuator-Actual value,0,
IDE08490,Activation of diagnosis via ethernet,not active,
IDE08530-MAS07130,Connection status online basic services-Number of ID steps,14,
IDE08530,Connection status online basic services,|ID steps,Code status
IDE08531-MAS07133,Connection status online license services-No. of license serv.,14,
IDE08531,Connection status online license services,|ID services,Code status
Elapsed Time: 07:15
;SW:4M1-959-793-D HW:4M1-959-793-D --- 42: Door Elect, Driver
;Component:TSG FS001 0188, Coding:003F9B00DE00048200093092
;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHKLO_VW27.rod
;Monday,21,September,2026,19:17:22:25381
;VCDS Version: 26.9.0.3 (arm64) Data version: 20260918 DS378.0
;VCID: C0D2AE50FA05715A270-8094
Group,Description,Actual
IDE00310,Outside temperature,22.00, °C
IDE01766-MAS02248,Distance impulses-Signal status,OK,
IDE01992-MAS12276,Installation list: current installations-Front door control module,reachable,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,reachable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Left rear door control module,
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.70, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Bus sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Right,
IDE04216-MAS01458,Mirror heater-Operating State,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,not installed,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,49, %
IDE04539-MAS02229,Mirror memory-Y coordinate,61, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Center position,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,100, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator lamp in button,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,Open,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,16, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator lamp in button,OFF,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,Not operated,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,96.50, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle state,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,Not operated,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,Not operated,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,Not operated,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,78.00, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,8.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,17.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,9.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,43.00, %
IDE07405-MAS02447,Enable driver front window regulator relay-Activation,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,19, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,Not operated,
IDE08205-MAS01453,Closing aid-Blocking detection,not active,
IDE08205-MAS02103,Closing aid-Signal from door lock: catch,Not operated,
IDE08205-MAS05370,Closing aid-Direction of movement,Not operated,
IDE08205-MAS08613,Closing aid-Return contact,closed,
IDE08205-MAS08614,Closing aid-Closing assist motor current,0.00, A
IDE08205-MAS09346,Closing aid-Door position,Open,
IDE08205-MAS09347,Closing aid-Redundant door contact,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08795,Rear shade button,not installed,
IDE09071-MAS00030,Seat belt positioner-Seat occupant detection,not active,
IDE09071-MAS02666,Seat belt positioner-Seat belt buckle scan,Open,
IDE09071-MAS05370,Seat belt positioner-Direction of movement,Not available,
IDE09071-MAS08502,Seat belt positioner-Standardized belt feeder,No,
IDE09071-MAS08503,Seat belt positioner-End stop of Hall sensor,not recognised,
IDE09071-MAS08504,Seat belt positioner-Position of belt feeder,Not available,
IDE09071-MAS08505,Seat belt positioner-Motor current of belt feeder,Not available,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatic dimming outside mirror-Status,not active,
IDE10164-MAS03691,Automatic dimming outside mirror-Dimming,0, %
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
IDE12336-MAS03095,Door heating element 2-Function status,not installed,
IDE12336-MAS04136,Door heating element 2-Current,not installed,
IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,Not operated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,Not operated,
IDE12422-IDE04411,Driver side front door control head-Child safety button,Not operated,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y direction),bottom position,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,Not operated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,Not operated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,Driving setting,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,Not operated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,operated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,Not operated,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,Not operated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,Not operated,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,Not operated,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,Not operated,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,Not operated,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,Not operated,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,Implausible,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,Implausible,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6)
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,30,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,0,
IDE14109,Excess temperature shutdown of close assist,not active,
MAS01872,Rear lid remote release button,Not operated,
MAS02101,Child safety,not active,
MAS06010,Ambient light,100, %
Elapsed Time: 00:10
;SW:3Q0-035-466-E HW:3Q0-035-466-E --- 47: Sound System
;Component:MIB2_amp_P_VW H50 0330, Coding:1235060001AAAA2AAA0000000000
;EV_AMPMst16CFGen2ALPI,001001,EV_AMPMst16CFGen2ALPI_VW53.rod
;Monday,21,September,2026,19:18:04:25381
;VCID: B134FB9441AFE8D2D8E-80E4
IDE00019,Voltage terminal 30,12.9, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,631.50, /min
IDE00767,No. of unscheduled ECU resets,4, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE01351,Terminal 75 status,On,
IDE01716,Terminal 50 status,OFF,
IDE02070-IDE02060,Wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE02070-IDE04544,Wake-up cause-Media type in optical drive,No,
IDE02070-MAS03177,Wake-up cause-Infotainment data bus,No,
IDE02070-MAS03180,Wake-up cause-Local data bus,No,
IDE02070-MAS03690,Wake-up cause-Telephone,No,
IDE02070-MAS03782,Wake-up cause-WLAN,No,
IDE02070-MAS03833,Wake-up cause-Optical data bus,Yes,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,47,
IDE03880-MAS03425,MOST address-Physical address,04 03,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,40, min
IDE04317-MAS00108,Total system run time-Day,139, d
IDE04317-MAS00109,Total system run time-Hours,13, H
IDE04317-MAS00110,Total system run time-Minutes,48, min
IDE04639-IDE02060,Last wake-up cause-Eject optical medium\ (CD/DVD Eject),No,
IDE04639-IDE04544,Last wake-up cause-Media type in optical drive,No,
IDE04639-MAS03177,Last wake-up cause-Infotainment data bus,No,
IDE04639-MAS03180,Last wake-up cause-Local data bus,No,
IDE04639-MAS03690,Last wake-up cause-Telephone,No,
IDE04639-MAS03782,Last wake-up cause-WLAN,No,
IDE04639-MAS03833,Last wake-up cause-Optical data bus,Yes,
IDE04640,Over-temperature protection for amplifier,no restriction,
IDE04641,Speed-dependent volume adjustment,0.0, dB
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,3512, /min
IDE04749-ENG117444,Mute-am_fm_tuner,No,
IDE04749-ENG117443,Mute-audiomanager,No,
IDE04749-ENG117447,Mute-component_protection,No,
IDE04749-ENG117445,Mute-dab_sdars_tuner,No,
IDE04749-ENG117446,Mute-drm_hd_tuner,No,
IDE04749-ENG113342,Mute-Hardware,No,
IDE05704-MAS02646,Key for digital transmission protection (DTCP)-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,2,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,60,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE06055,Invalid authentication (DTCP),5F,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,71, °C
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,-15, °C
IDE06519-MAS02238,Temperature of MOST transceiver-Current,33, °C
IDE09935-MAS01424,Temperature of inductor-max.value,79, °C
IDE09935-MAS01425,Temperature of inductor-min.value,6, °C
IDE09935-MAS02238,Temperature of inductor-Current,44, °C
IDE10545-MAS01188,Speaker status-Left front bass speaker,Condition not met,
IDE10545-MAS01189,Speaker status-Left Front Midrange Speaker,Condition not met,
IDE10545-MAS01190,Speaker status-Left front treble speaker,Condition not met,
IDE10545-MAS01191,Speaker status-Right front bass speaker,Condition not met,
IDE10545-MAS01192,Speaker status-Right Front Midrange Speaker,Condition not met,
IDE10545-MAS01193,Speaker status-Right front treble speaker,Condition not met,
IDE10545-MAS01194,Speaker status-Left rear bass speaker,Condition not met,
IDE10545-MAS01195,Speaker status-Left rear treble speaker,Condition not met,
IDE10545-MAS01196,Speaker status-Right rear bass speaker,Condition not met,
IDE10545-MAS01197,Speaker status-Right rear treble speaker,Condition not met,
IDE10545-MAS01198,Speaker status-Center speaker,Condition not met,
IDE10545-MAS01199,Speaker status-Left effect speaker,Condition not met,
IDE10545-MAS01200,Speaker status-Right effect speaker,Condition not met,
IDE10545-MAS04506,Speaker status-Double subwoofer speaker 1,Condition not met,
IDE10545-MAS04507,Speaker status-Double subwoofer speaker 2,Condition not met,
IDE10545-ENG117415,Speaker status-loudspeaker_channel_12,Measuring value not available,
IDE10545-ENG126180,Speaker status-loudspeaker_channel_17,Measuring value not available,
IDE10545-ENG126181,Speaker status-loudspeaker_channel_18,Measuring value not available,
IDE10545-ENG126182,Speaker status-loudspeaker_channel_19,Measuring value not available,
IDE10545-ENG126183,Speaker status-loudspeaker_channel_20,Measuring value not available,
IDE10545-ENG126184,Speaker status-loudspeaker_channel_21,Measuring value not available,
IDE10545-ENG126185,Speaker status-loudspeaker_channel_22,Measuring value not available,
IDE10545-ENG126186,Speaker status-loudspeaker_channel_23,Measuring value not available,
IDE10545-ENG126187,Speaker status-loudspeaker_channel_24,Measuring value not available,
IDE10657-MAS01424,Temperature switching power supply-max.value,81, °C
IDE10657-MAS01425,Temperature switching power supply-min.value,6, °C
IDE10657-MAS02238,Temperature switching power supply-Current,44, °C
IDE10659-MAS01424,Temperature switching power supply 2-max.value,59, °C
IDE10659-MAS01425,Temperature switching power supply 2-min.value,12, °C
IDE10659-MAS02238,Temperature switching power supply 2-Current,38, °C
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,21,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,18,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,4,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,215,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,139851, km
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,dont care,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,OK,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,OK,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
ENG117857-MAS00109,Last_System_Operating_Time-Hours,0, H
ENG117857-MAS00110,Last_System_Operating_Time-Minutes,0, min
ENG117856-MAS00106,Last_System_Operating_Time/Mins.-Year,26, yr
ENG117856-MAS00107,Last_System_Operating_Time/Mins.-Month,9, Months
ENG117856-MAS00108,Last_System_Operating_Time/Mins.-Day,21, d
ENG117856-MAS00109,Last_System_Operating_Time/Mins.-Hours,18, H
ENG117856-MAS00110,Last_System_Operating_Time/Mins.-Minutes,37, min
ENG117856-MAS00111,Last_System_Operating_Time/Mins.-Seconds,2, s
Elapsed Time: 00:08
;SW:4M1-959-792-D HW:4M1-959-792-D --- 52: Door Elect, Pass.
;Component:TSG BFS001 0188, Coding:003F9B00DE00048200093090
;EV_DCU2PasseSideMAXHKLO,001010,EV_DCU2PasseSideMAXHKLO_VW27.rod
;Monday,21,September,2026,19:18:19:25381
;VCID: BFD0ADAC87FB0EA25EA-80EA
IDE00310,Outside temperature,21.50, °C
IDE01766-MAS02248,Distance impulses-Signal status,Not available,
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Right rear door control module,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.80, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,53, %
IDE04539-MAS02229,Mirror memory-Y coordinate,53, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Top position,
IDE06872,Front passenger power window button,Not operated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,71.00, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,59.00, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,39.00, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,37.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,79.00, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Activation,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,21, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE08205-MAS02103,Closing aid-Signal from door lock: catch,operated,
IDE08205-MAS09346,Closing aid-Door position,closed,
Elapsed Time: 00:08
;SW:4M0-907-777-R HW:4M0-907-777-B --- 74: Chassis Control
;Component:Fahrwerk-SG H37 1252, Coding:B0505150F8
;EV_ChassContrContiAU426,001004,EV_ChassContrContiAU426.rod
;Monday,21,September,2026,19:22:18:25381
;VCID: C8C2B670D235491AEF0-809C
IDE00018,Voltage terminal 15,12.00, V
IDE00019,Voltage terminal 30,13.00, V
IDE00106,Internal DTC,0,
IDE00303-IDE08198,Status: doors/lids 1-Activation status anti-theft warning system,not active,
IDE00303-MAS00218,Status: doors/lids 1-Driver´s door,Open,
IDE00303-MAS00219,Status: doors/lids 1-Passenger´s door,closed,
IDE00303-MAS00220,Status: doors/lids 1-Rear left door,closed,
IDE00303-MAS00221,Status: doors/lids 1-Rear right door,closed,
IDE00303-MAS06522,Status: doors/lids 1-Rear lid: Status,closed,
IDE00303-MAS08523,Status: doors/lids 1-All doors and rear lid closed,Condition not met,
IDE00541-IDE02543,Acceleration-Body acceleration sensor,9.82, m/s²
IDE00541-IDE02545,Acceleration-Body acceleration sensor: status,valid,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,B5 BC 9B 43,
IDE02542,Transverse acceleration sensor 2: temperature,-327.68, °C
IDE02544,Body acceleration sensor: temperature,32.82, °C
IDE02547,Roll rate sensor: temperature,40.21, °C
IDE02550,Pitch rate sensor: temperature,32.90, °C
IDE02556,Yaw rate sensor 2: temperature,-327.68, °C
IDE02940-MAS03034,System pressure-Pressure,1.00, bar
IDE02940-MAS10469,System pressure-Raw value,0.50, V
IDE02941,Compressor temperature,36, °C
IDE02946-MAS01374,Status MMI operation-Trailer,not active,
IDE02946-MAS03024,Status MMI operation-Car jack mode,not active,
IDE02946-MAS08486,Status MMI operation-Lift mode,not active,
IDE03008-MAS01746,Stop process prevented-Control active,not active,
IDE03010-MAS01746,Number of prevented stop processes-Control active,182,
IDE03011-MAS01746,Number of requested start processes-Control active,16,
IDE03038,Control position: specified value,Normal level,
IDE03050,Voltage supply for Solen.val. block,1.05, V
IDE03051,Voltage supply for right sensor for level control system,4.98, V
IDE03052,Voltage supply for left sensor for level control system,4.98, V
IDE03053,Voltage supply of sensor for system pressure,4.98, V
IDE03064,Accumulator pressure,13.80, bar
IDE03208-MAS01390,Software version for suppliers-Block 1,71091252,
IDE03208-MAS01391,Software version for suppliers-Block 2,71091252,
IDE03208-MAS01392,Software version for suppliers-Block 3,71049A00,
IDE03208-MAS01393,Software version for suppliers-Block 4,71014804,
IDE03208-MAS01394,Software version for suppliers-Block 5,71089726,
IDE03208-MAS01395,Software version for suppliers-Block 6,7100AR91,
IDE03208-MAS01396,Software version for suppliers-Block 7,710798G0,
IDE03208-MAS01397,Software version for suppliers-Block 8,71059U56,
IDE03208-MAS01398,Software version for suppliers-Block 9,71069800,
IDE03208-MAS01399,Software version for suppliers-Block 10,--------,
IDE03208-MAS01400,Software version for suppliers-Block 11,71029H01,
IDE03208-MAS01401,Software version for suppliers-Block 12,71039800,
IDE03208-MAS01402,Software version for suppliers-Block 13,--------,
IDE03208-MAS01403,Software version for suppliers-Block 14,--------,
IDE03208-MAS01404,Software version for suppliers-Block 15,--------,
IDE03661-IDE02546,Rotation rate-Roll rate sensor,0.00, rad/s
IDE03661-IDE02548,Rotation rate-Roll rate sensor: status,valid,
IDE03661-IDE02549,Rotation rate-Pitch rate sensor,-0.01, rad/s
IDE03661-IDE02551,Rotation rate-Pitch rate sensor: status,valid,
IDE04018-MAS00106,Pressure test time stamp: current-Year,2026,
IDE04018-MAS00107,Pressure test time stamp: current-Month,9,
IDE04018-MAS00108,Pressure test time stamp: current-Day,21,
IDE04018-MAS00109,Pressure test time stamp: current-Hours,19,
IDE04018-MAS00110,Pressure test time stamp: current-Minutes,22,
IDE04018-MAS00111,Pressure test time stamp: current-Seconds,16,
IDE04781-MAS11602,Microprocessor malfunction type-Group,00,
IDE04781-MAS11758,Microprocessor malfunction type-Identification,00,
IDE04781-MAS11759,Microprocessor malfunction type-Saving,00 00 00 00,
IDE05163-MAS01221,Air Suspension Compressor-Compressor main status,OFF,
IDE05163-MAS01442,Air Suspension Compressor-Compressor speed,0, /min
IDE05163-MAS02194,Air Suspension Compressor-Temperature 1,32, °C
IDE05163-MAS02195,Air Suspension Compressor-Temperature 2,36, °C
IDE05163-MAS02196,Air Suspension Compressor-Temperature 3,-40, °C
IDE05163-MAS02832,Air Suspension Compressor-Malfunction status,No malfunction,
IDE05163-MAS04121,Air Suspension Compressor-Voltage,13.00, V
IDE05163-MAS04136,Air Suspension Compressor-Current,0.00, A
IDE05163-ENG145284,Air Suspension Compressor-compressor_temperature_2_Textual,numerical value: no text,
IDE05163-ENG145285,Air Suspension Compressor-compressor_temperature_3_Textual,numerical value: no text,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,No,
IDE06307-MAS00108,Stop prevention history data-Day,19,
IDE06307-MAS00109,Stop prevention history data-Hours,10,
IDE06307-MAS00110,Stop prevention history data-Minutes,44,
IDE06307-MAS00111,Stop prevention history data-Seconds,56,
IDE06307-MAS01746,Stop prevention history data-Control active,active,
IDE06308-MAS00107,Start request history data-Month,7,
IDE06308-MAS00108,Start request history data-Day,28,
IDE06308-MAS00109,Start request history data-Hours,20,
IDE06308-MAS00110,Start request history data-Minutes,24,
IDE06308-MAS00111,Start request history data-Seconds,23,
IDE06308-MAS01746,Start request history data-Control active,active,
IDE06487-MAS04887,Run-time of the level-level 1,181, km
IDE06487-MAS05353,Run-time of the level-level 2,4422, km
IDE06487-MAS05490,Run-time of the level-level 3,0, km
IDE06487-MAS05491,Run-time of the level-Level 4,16384, km
IDE06487-MAS05760,Run-time of the level-Level 5,32630, km
IDE06487-MAS05761,Run-time of the level-Level 6,19, km
IDE06487-MAS05762,Run-time of the level-level 7,0, km
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,01,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,05,
IDE07151-IDE03849,Vehicle level sensor: raw value-Left front level control system sensor: raw value,48.40, %
IDE07151-IDE03857,Vehicle level sensor: raw value-Right front level control system sensor: raw value,51.45, %
IDE07151-IDE03865,Vehicle level sensor: raw value-Left rear level control system sensor: raw value,45.90, %
IDE07151-IDE04147,Vehicle level sensor: raw value-Right rear level control system sensor: raw value,51.64, %
IDE08343,Immobilizer Challenge,C7 40 2D 82,
IDE08605-IDE02955,Status drive profile for level control system-System status,Available,
IDE08605-IDE06419,Status drive profile for level control system-Driving profile switchover,will be performed.,
IDE08605-MAS01447,Status drive profile for level control system-Actual value,2,
IDE08605-MAS01448,Status drive profile for level control system-Specified value,2,
IDE08605-MAS05058,Status drive profile for level control system-Compatibility,Yes,
IDE08667-IDE02955,Drive profile selec. for damper adjustment-System status,Available,
IDE08667-IDE06419,Drive profile selec. for damper adjustment-Driving profile switchover,will be performed.,
IDE08667-MAS01447,Drive profile selec. for damper adjustment-Actual value,1,
IDE08667-MAS01448,Drive profile selec. for damper adjustment-Specified value,1,
IDE08667-MAS05058,Drive profile selec. for damper adjustment-Compatibility,Yes,
IDE09236,Replacement strategy damper,0, bit
IDE09237-MAS03002,Damper control status-Driving program,Profile 1,
IDE09237-MAS04188,Damper control status-Transport mode,not active,
IDE09237-MAS06797,Damper control status-Status configuration,Damper control,
IDE09237-MAS08446,Damper control status-Control position adapted,Yes,
IDE09237-MAS08447,Damper control status-Loading mode,not active,
IDE09238-IDE03056,Damper valve: actual current-Damper valve current: left front,0.38, A
IDE09238-IDE03058,Damper valve: actual current-Damper valve current: right front,0.38, A
IDE09238-IDE03060,Damper valve: actual current-Left rear shock absorber valve current,0.32, A
IDE09238-IDE03062,Damper valve: actual current-Right rear shock absorber valve current,0.40, A
IDE09239-IDE03057,Damper valve: PWM value-Left front damper: PWM signal value,13.18, %
IDE09239-IDE03059,Damper valve: PWM value-Right front damper: PWM signal value,13.82, %
IDE09239-IDE03061,Damper valve: PWM value-Left rear damper: PWM signal value,9.33, %
IDE09239-IDE03063,Damper valve: PWM value-Right rear damper: PWM signal value,0.00, %
IDE09240-IDE03056,Damper valve: target current-Damper valve current: left front,0.40, A
IDE09240-IDE03058,Damper valve: target current-Damper valve current: right front,0.40, A
IDE09240-IDE03060,Damper valve: target current-Left rear shock absorber valve current,0.40, A
IDE09240-IDE03062,Damper valve: target current-Right rear shock absorber valve current,0.40, A
IDE09241-MAS01853,Calculated damper temperature-Left front,20, °C
IDE09241-MAS01854,Calculated damper temperature-Right front,20, °C
IDE09241-MAS01855,Calculated damper temperature-Left rear,20, °C
IDE09241-MAS01856,Calculated damper temperature-Right rear,20, °C
IDE09242-MAS08451,Damper output stage temperature-Front axle,35, °C
IDE09242-MAS08452,Damper output stage temperature-Rear axle,34, °C
IDE09248-MAS03024,Control prevention detection-Car jack mode,not active,
IDE09248-MAS04501,Control prevention detection-Lift,not active,
IDE09248-MAS08454,Control prevention detection-Locked position diagnosis,not active,
IDE09248-MAS08455,Control prevention detection-Locked position snow wedge,not active,
IDE09248-MAS08456,Control prevention detection-Locked position wheel change,not active,
IDE09248-MAS08457,Control prevention detection-Limited due to doors/flaps,active,
IDE09249-IDE03451,Control limitation detection-Transverse acceleration,not active,
IDE09249-IDE03660,Control limitation detection-Longitudinal acceleration,not active,
IDE09249-IDE04928,Control limitation detection-Anti-theft protection,not active,
IDE09249-MAS05179,Control limitation detection-ABS intervention,not active,
IDE09249-MAS05180,Control limitation detection-ESP intervention,active,
IDE09249-MAS08458,Control limitation detection-Limited due to vehicle entanglement,not active,
IDE09249-MAS08459,Control limitation detection-Limited due to system error reaction,not active,
IDE09261-IDE03037,Level control: internal status-Level controller conditions,Stand mode 2: engine running and door open,
IDE09261-IDE03065,Level control: internal status-Control from accumulator possible,Yes,
IDE09261-MAS01106,Level control: internal status-Level control system,active,
IDE09261-MAS08446,Level control: internal status-Control position adapted,Yes,
IDE09261-MAS08486,Level control: internal status-Lift mode,not active,
IDE09261-MAS08490,Level control: internal status-Control demand,not recognised,
IDE09261-MAS08491,Level control: internal status-Extreme level,not recognised,
IDE09261-MAS08492,Level control: internal status-Control possible with compressor,No,
IDE09262-MAS03002,Level control: external status-Driving program,2,
IDE09262-MAS03024,Level control: external status-Car jack mode,not active,
IDE09262-MAS04188,Level control: external status-Transport mode,not active,
IDE09262-MAS08447,Level control: external status-Loading mode,not active,
IDE09262-MAS08493,Level control: external status-Locked position,not active,
IDE09263,Level control system error reaction,00 00 00 00 00 00 00 00 00,
IDE09264-MAS01299,Driving program running times-Offroad,8509, km
IDE09264-MAS02014,Driving program running times-Comfort,0, km
IDE09264-MAS02015,Driving program running times-AUTO,32768, km
IDE09264-MAS02016,Driving program running times-Dynamic,3507, km
IDE09264-MAS05471,Driving program running times-Efficiency,0, km
IDE09264-MAS08486,Driving program running times-Lift mode,181, km
IDE09265-IDE05164,No. activations of Solen.val. block-Air suspension valve: left front,128022, counts
IDE09265-IDE05165,No. activations of Solen.val. block-Air suspension valve: right front,126891, counts
IDE09265-IDE05166,No. activations of Solen.val. block-Air suspension valve: left rear,105628, counts
IDE09265-IDE05167,No. activations of Solen.val. block-Air suspension valve: right rear,104750, counts
IDE09265-MAS05733,No. activations of Solen.val. block-Level control accumulator valve,91839, counts
IDE09266-IDE03219,No. activations of level control valves-Relief valve,220163, counts
IDE09266-IDE03667,No. activations of level control valves-Electrical switching valve 1,129, counts
IDE09266-IDE03668,No. activations of level control valves-Electrical switching valve 2,0, counts
IDE09266-MAS10770,No. activations of level control valves-Valve 1 for aux. vol. of air suspensions,0, counts
IDE09266-MAS10771,No. activations of level control valves-Valve 2 for aux. vol. of air suspensions,0, counts
IDE09266-MAS10772,No. activations of level control valves-Valve 3 for aux. vol. of air suspensions,0, counts
IDE09266-MAS10773,No. activations of level control valves-Valve 4 for aux. vol. of air suspensions,0, counts
IDE09267-MAS08494,Number of control cycles-Number of automatic target level changes,13877, counts
IDE09267-MAS08495,Number of control cycles-Number of correction controls,58322, counts
IDE09267-MAS08496,Number of control cycles-Number of manual target level changes when standing,353, counts
IDE09267-MAS08497,Number of control cycles-Number of manual target level changes when driving,1116, counts
IDE09268-MAS08498,Switch on occurrences of compressor-shorter as time duration 1,629, counts
IDE09268-MAS08499,Switch on occurrences of compressor-between time duration 1 and 2,3633, counts
IDE09268-MAS08500,Switch on occurrences of compressor-between time duration 2 and 3,8800, counts
IDE09268-MAS08506,Switch on occurrences of compressor-between time duration 3 and 4,3097, counts
IDE09268-MAS08507,Switch on occurrences of compressor-between time duration 4 and 5,236, counts
IDE09268-MAS08508,Switch on occurrences of compressor-longer as time duration 5,31, counts
IDE09269-MAS08509,Running times of compressor-counter pressure less than pressure value 1,29853, s
IDE09269-MAS08510,Running times of compressor-counter pressure between pressure value 1 and 2,26768, s
IDE09269-MAS08511,Running times of compressor-counter pressure between pressure value 2 and 3,26549, s
IDE09269-MAS08512,Running times of compressor-counter pressure larger than pressure value 3,59358, s
IDE09270-MAS08514,No. of compressor activations-for control process,4477, counts
IDE09270-MAS08515,No. of compressor activations-for accumulator filling,11722, counts
IDE09270-MAS08972,No. of compressor activations-at temperature small temperature value 1,0, counts
IDE09270-MAS08973,No. of compressor activations-at temperature between temperature value 1 and 2,13974, counts
IDE09270-MAS08974,No. of compressor activations-at temperature between temperature value 2 and 3,2444, counts
IDE09270-MAS08975,No. of compressor activations-at temp. higher than temperature value 3,8, counts
IDE09271-IDE02951,Absolute vehicle height-Absolute left front vehicle height,459, mm
IDE09271-IDE02952,Absolute vehicle height-Absolute right front vehicle height,456, mm
IDE09271-IDE02953,Absolute vehicle height-Absolute left rear vehicle height,453, mm
IDE09271-IDE02954,Absolute vehicle height-Absolute right rear vehicle height,451, mm
IDE09271-ENG145283,Absolute vehicle height-vehicle_level_absolute_front_left_Textual,numerical value: no text,
IDE09272-IDE03123,Last measd pressur in air spring bellows-Last measured pressure in left front pneumatic spring bellows,8.00, bar
IDE09272-IDE03124,Last measd pressur in air spring bellows-Last measured pressure in right front pneumatic spring bellows,8.00, bar
IDE09272-IDE03125,Last measd pressur in air spring bellows-Last measured pressure in left rear pneumatic spring bellows,6.60, bar
IDE09272-IDE03126,Last measd pressur in air spring bellows-Last measured pressure in right rear pneumatic spring bellows,6.80, bar
IDE09273-IDE02947,Height deviation from adapted vehicle height-Left front height deviation from adapted vehicle height,0, mm
IDE09273-IDE02948,Height deviation from adapted vehicle height-Right front height deviation from adapted vehicle height,-3, mm
IDE09273-IDE02949,Height deviation from adapted vehicle height-Left rear height deviation from adapted vehicle height,2, mm
IDE09273-IDE02950,Height deviation from adapted vehicle height-Right rear height deviation from adapted vehicle height,-2, mm
IDE09274-IDE03042,Height deviation from control pos-Height deviation of control position: left front,0, mm
IDE09274-IDE03043,Height deviation from control pos-Height deviation of control position: right front,-3, mm
IDE09274-IDE03044,Height deviation from control pos-Height deviation of control position: left rear,1, mm
IDE09274-IDE03045,Height deviation from control pos-Height deviation of control position: right rear,-2, mm
IDE09275-IDE04447,Loading function operating condition-Function status,not active,
IDE09275-IDE05288,Loading function operating condition-Load level button: raise,not active,
IDE09275-IDE05289,Loading function operating condition-Load level button: lower,not active,
IDE09275-IDE05290,Loading function operating condition-Load level button: redundant signal path,not active,
IDE09275-IDE05291,Loading function operating condition-Indicator light in button for load level,OFF,
IDE09275-MAS07052,Loading function operating condition-Setting,automatic,
IDE09275-MAS08526,Loading function operating condition-Button position neutral,active,
IDE09275-MAS08976,Loading function operating condition-Precondition:doors closed,Condition not met,
IDE09275-MAS08977,Loading function operating condition-Precondition:Tailgate open,Condition not met,
IDE09275-MAS08978,Loading function operating condition-Precondition:no ctrl. process active,Condition met,
IDE09275-MAS08979,Loading function operating condition-Precondition:level control active,Condition met,
IDE09275-MAS08980,Loading function operating condition-Precondition:no relevant error on the rear axle components,Condition met,
IDE09455,Number of wake-up processes via level ctrl.,46006, counts
IDE09457-MAS00106,Time of stored pressure test 1-Year,2000,
IDE09457-MAS00107,Time of stored pressure test 1-Month,1,
IDE09457-MAS00108,Time of stored pressure test 1-Day,1,
IDE09457-MAS00109,Time of stored pressure test 1-Hours,0,
IDE09457-MAS00110,Time of stored pressure test 1-Minutes,0,
IDE09457-MAS00111,Time of stored pressure test 1-Seconds,0,
IDE09458-MAS00106,Time of stored pressure test 2-Year,2000,
IDE09458-MAS00107,Time of stored pressure test 2-Month,1,
IDE09458-MAS00108,Time of stored pressure test 2-Day,1,
IDE09458-MAS00109,Time of stored pressure test 2-Hours,0,
IDE09458-MAS00110,Time of stored pressure test 2-Minutes,0,
IDE09458-MAS00111,Time of stored pressure test 2-Seconds,0,
IDE09459-IDE04024,Result of stored pressure test 1-Pressure test: saved front left strut pressure,0.00, bar
IDE09459-IDE04025,Result of stored pressure test 1-Pressure test: saved front right strut pressure,0.00, bar
IDE09459-IDE04026,Result of stored pressure test 1-Pressure test: saved rear left strut pressure,0.00, bar
IDE09459-IDE04027,Result of stored pressure test 1-Pressure test: saved rear right strut pressure,0.00, bar
IDE09459-IDE04028,Result of stored pressure test 1-Pressure test: saved accumulator pressure,0.00, bar
IDE09460-IDE04024,Result of stored pressure test 2-Pressure test: saved front left strut pressure,0.00, bar
IDE09460-IDE04025,Result of stored pressure test 2-Pressure test: saved front right strut pressure,0.00, bar
IDE09460-IDE04026,Result of stored pressure test 2-Pressure test: saved rear left strut pressure,0.00, bar
IDE09460-IDE04027,Result of stored pressure test 2-Pressure test: saved rear right strut pressure,0.00, bar
IDE09460-IDE04028,Result of stored pressure test 2-Pressure test: saved accumulator pressure,0.00, bar
IDE09461-IDE02942,Vehicle trim position-Left front vehicle height: PWM signal value,48.38, %
IDE09461-IDE02943,Vehicle trim position-Right front vehicle height: PWM signal value,51.62, %
IDE09461-IDE02944,Vehicle trim position-Left rear vehicle height: PWM signal value,48.10, %
IDE09461-IDE02945,Vehicle trim position-Right rear vehicle height: PWM signal value,51.90, %
IDE09461-MAS01853,Vehicle trim position-Left front,459, mm
IDE09461-MAS01854,Vehicle trim position-Right front,459, mm
IDE09461-MAS01855,Vehicle trim position-Left rear,452, mm
IDE09461-MAS01856,Vehicle trim position-Right rear,452, mm
IDE09464-IDE03219,Valve status air suspension-Relief valve,OFF,
IDE09464-IDE03667,Valve status air suspension-Electrical switching valve 1,OFF,
IDE09464-IDE05164,Valve status air suspension-Air suspension valve: left front,OFF,
IDE09464-IDE05165,Valve status air suspension-Air suspension valve: right front,OFF,
IDE09464-IDE05166,Valve status air suspension-Air suspension valve: left rear,OFF,
IDE09464-IDE05167,Valve status air suspension-Air suspension valve: right rear,OFF,
IDE09464-MAS05733,Valve status air suspension-Level control accumulator valve,OFF,
IDE10557-MAS05790,Inclination display: calculated wrong alignment-Estimated installation error in direction of roll angle,00 00 00 00,
IDE10557-MAS05791,Inclination display: calculated wrong alignment-Estimated installation error in direction of pitch angle,00 00 00 00,
IDE10558-MAS05292,Inclination display: input signals inertial sensors-Estimated offset fault of rotation rate sensor,BB 17 AA F4,
IDE10558-MAS05293,Inclination display: input signals inertial sensors-Estimated offset fault of longitudinal acceleration sensor,BE 04 66 58,
IDE10558-MAS11832,Inclination display: input signals inertial sensors-Sensor system status: current,00,
IDE10558-MAS11833,Inclination display: input signals inertial sensors-Sensor system status: previous,00,
IDE10559-MAS02465,Inclination display: input signals GPS-Speed in y-direction,3A 40 76 86,
IDE10559-MAS02469,Inclination display: input signals GPS-Speed in x-direction,BD A2 F7 E5,
IDE10598-MAS09214,Compressor for air suspension: number of shut-offs-due to excessive temp. during ctrl. process,2, counts
IDE10598-MAS09215,Compressor for air suspension: number of shut-offs-due to excessive temp. during accumulator filling,4, counts
IDE10599-IDE04561,Actuator test: release status-Switch-on and shut-off conditions,Boundary conditions met,
IDE10599-MAS06528,Actuator test: release status-Release status,All releases are present,
IDE10611-IDE02923,Actuator test: release status 2-Lower vehicle at left front,Enabled,
IDE10611-IDE02924,Actuator test: release status 2-Lower vehicle at right front,Enabled,
IDE10611-IDE02925,Actuator test: release status 2-Lower vehicle at left rear,Enabled,
IDE10611-IDE02926,Actuator test: release status 2-Lower vehicle at right rear,Enabled,
IDE10611-IDE08716,Actuator test: release status 2-System check for boost function,Enabled,
IDE10611-IDE09462,Actuator test: release status 2-Checking pressure reservoir and compressor,Enabled,
IDE10611-MAS10770,Actuator test: release status 2-Valve 1 for aux. vol. of air suspensions,not enabled,
IDE10611-MAS10771,Actuator test: release status 2-Valve 2 for aux. vol. of air suspensions,not enabled,
IDE10611-MAS10772,Actuator test: release status 2-Valve 3 for aux. vol. of air suspensions,not enabled,
IDE10611-MAS10773,Actuator test: release status 2-Valve 4 for aux. vol. of air suspensions,not enabled,
IDE10801-MAS03095,Calibration of level control for determining axle load: status-Function status,calibrated,
IDE10801-MAS08451,Calibration of level control for determining axle load: status-Front axle,9, kg
IDE10801-MAS08452,Calibration of level control for determining axle load: status-Rear axle,2, kg
IDE10805-MAS01853,Valves for add. volume of air suspension: status-Left front,OFF,
IDE10805-MAS01854,Valves for add. volume of air suspension: status-Right front,OFF,
IDE10805-MAS01855,Valves for add. volume of air suspension: status-Left rear,OFF,
IDE10805-MAS01856,Valves for add. volume of air suspension: status-Right rear,OFF,
IDE10807-IDE00123,Signal processing adapted values-Travel reinforcement of disc set regulation,0, m
IDE10807-MAS02453,Signal processing adapted values-Steering wheel angle offset,0.00, rad
IDE10807-MAS11340,Signal processing adapted values-Correction factor for left front wheel,1.00,
IDE10807-MAS11341,Signal processing adapted values-Correction factor for right front wheel,0.90,
IDE10807-MAS11342,Signal processing adapted values-Correction factor for left rear wheel,0.90,
IDE10807-MAS11343,Signal processing adapted values-Correction factor for right rear wheel,1.00,
IDE10807-MAS11344,Signal processing adapted values-Permissible steering angle offset deviation,0.00, rad
IDE10941-MAS05290,Inclination display: input signals inertial sensors 2-Estimated offset fault of roll rate sensor,B9 AC 9B 9E,
IDE10941-MAS05295,Inclination display: input signals inertial sensors 2-Estimated offset fault of vertical acceleration sensor,3C D0 0F EE,
IDE10941-MAS11832,Inclination display: input signals inertial sensors 2-Sensor system status: current,00,
IDE10941-MAS11833,Inclination display: input signals inertial sensors 2-Sensor system status: previous,00,
IDE10971-MAS02465,Inclination display: calculated values-Speed in y-direction,39 75 9A 88,
IDE10971-MAS02469,Inclination display: calculated values-Speed in x-direction,BD 9D A6 0F,
IDE10971-MAS05282,Inclination display: calculated values-Status: longitudinal speed: input,00,
IDE10971-MAS05758,Inclination display: calculated values-Driving situation,01,
IDE10971-MAS11840,Inclination display: calculated values-Status of incline angles and speeds,0F,
IDE10971-MAS11841,Inclination display: calculated values-Status of calculation algorithm,00,
IDE10971-MAS11842,Inclination display: calculated values-Calculation algorithm initialized,00,
IDE10971-MAS11843,Inclination display: calculated values-Status of rotation rate filter,00,
IDE10972-MAS05282,Inclination display: input signals: signal processing-Status: longitudinal speed: input,00,
IDE10972-MAS05298,Inclination display: input signals: signal processing-Longitudinal acceleration: input,00 00 00 00,
IDE10972-MAS11838,Inclination display: input signals: signal processing-Status of tire radius scale factor,00,
IDE10972-MAS11839,Inclination display: input signals: signal processing-Tire radius scale factor,3F 80 00 00,
IDE12658-MAS15233,Learned height deviations-Height deviation of empty position: left front,1, mm
IDE12658-MAS15235,Learned height deviations-Height deviation of empty position: right front,-4, mm
IDE12658-MAS15237,Learned height deviations-Height deviation of empty position: left rear,8, mm
IDE12658-MAS15239,Learned height deviations-Height deviation of empty position: right rear,3, mm
IDE12885-IDE00326,Damper control: input signal from steering-Steering wheel angle,18.90, °
IDE12885-IDE02219,Damper control: input signal from steering-Steering wheel angle: sign,Negative,
IDE12885-MAS02981,Damper control: input signal from steering-Overlay angle,0.00, °
IDE12885-MAS04455,Damper control: input signal from steering-Active steering internal status,operational,
IDE12885-MAS13750,Damper control: input signal from steering-Overlay angle: sign,Positive,
IDE12885-ENG145287,Damper control: input signal from steering-SCU_superpositon_angle_ADS_Textual,numerical value: no text,
IDE13061-MAS15232,Learned height deviations fully extended-Maximum suspension travel front left,128, mm
IDE13061-MAS15234,Learned height deviations fully extended-Maximum suspension travel front right,128, mm
IDE13061-MAS15236,Learned height deviations fully extended-Maximum suspension travel rear left,113, mm
IDE13061-MAS15238,Learned height deviations fully extended-Maximum suspension travel rear right,107, mm
ENG144274,Current_Fuel_Volume,950, kg
ENG144274,Current_Fuel_Volume,62, kg
ENG144274,Current_Fuel_Volume,55, l
ENG144274,Current_Fuel_Volume,1080, kg
ENG101549,FIBEX_implementation,MLBevo_FlexRay_Cluster_V8.11.00F_20151105_BP.xml,
ENG144011-IDE03602,initialisation_status-Left front level control system sensor,1,
ENG144011-IDE03603,initialisation_status-Right front level control sensor,1,
ENG144011-IDE03604,initialisation_status-Left rear level control system sensor,1,
ENG144011-IDE03605,initialisation_status-Right rear level control system sensor,1,
ENG144011-MAS18050,initialisation_status-Left front level control system sensor value range: deflected,1,
ENG144011-MAS18051,initialisation_status-Right front level control system sensor value range: deflected,1,
ENG144011-MAS18052,initialisation_status-Left rear level control system sensor value range: deflected,1,
ENG144011-MAS18053,initialisation_status-Right rear level control system sensor value range: deflected,1,
ENG144011-MAS18056,initialisation_status-Left front level control system sensor value range: decompressed,0,
ENG144011-MAS18058,initialisation_status-Right front level control system sensor value range: decompressed,0,
ENG144011-MAS18061,initialisation_status-Left rear level control system sensor value range: decompressed,0,
ENG144011-MAS18064,initialisation_status-Right rear level control system sensor value range: decompressed,0,
ENG144011-MAS18065,initialisation_status-Function activation: deflected,0,
ENG144010-IDE00556,Input_signals-Outside temperature,21.50, °C
ENG144009-ENG102896,Input_signals_engine-engine_moment_driver_command,2, Nm
ENG144009-ENG145288,Input_signals_engine-engine_moment_driver_command_Textual,numerical value: no text,
ENG144009-ENG144703,Input_signals_engine-Engine_RPM,627.00, /min
ENG144009-ENG100233,Input_signals_engine-MO_brake_light_switch,Not braking,
ENG144009-ENG99648,Input_signals_engine-MO_driver_brakes,Not braking,
ENG144009-ENG145177,Input_signals_engine-momentum_factor,Factor 1,
ENG144007-IDE02211,Input_signals_ESP-Brake pressure,0.00, bar
ENG144007-ENG99480,Input_signals_ESP-ESP_coding_ADS,Initial value,
ENG144007-ENG102099,Input_signals_ESP-ESP_HBA_active,not active,
ENG144007-ENG101918,Input_signals_ESP-ESP_prefill_triggered,No,
ENG144007-ENG101915,Input_signals_ESP-ESP_request_distribution_of_rolling_moment,-1.00,
ENG144007-ENG101844,Input_signals_ESP-ESP_standstill_flag,standstill detected,
ENG144007-ENG103106,Input_signals_ESP-ESP_system_state,No malfunction,
Elapsed Time: 00:19
;SW:4N0-035-502-A HW:4N0-035-502-A --- DE: Charger 1 for mobile dev
;Component:WLC Front H10 0057, Coding:800000
;EV_Charg1MobilDevicAU651,004001,EV_Charg1MobilDevicAU651.rod
;Monday,21,September,2026,19:23:43:25381
;VCID: A21604D81449434A514-80F6
IDE00019,Voltage terminal 30,12.90, V
IDE00690-MAS03939,Connection to antenna-Connection between antenna amplifier and antenna,electrically OK,
IDE00690-MAS14478,Connection to antenna-Connection between control module and antenna amplifier,electrically OK,
IDE00690-MAS14624,Connection to antenna-Antenna amplifier: status,electrically OK,
IDE12451-MAS14479,Mobile device: status-Power category of the mobile terminal device,Not available,
IDE12582-MAS01481,Mobile device charger: status-Temperature in control module,28, °C
IDE12582-MAS14480,Mobile device charger: status-Object recognition: status,No object detected,
IDE12582-MAS14484,Mobile device charger: status-Charging process: status,not active,
IDE12582-MAS14485,Mobile device charger: status-Charging technology used,1,
IDE12582-ENG177058,Mobile device charger: status-Charging_power,0.00, W
Elapsed Time: 00:00
blockmap-OBD_WVGZZZCRZKD020971-20260921-1923.CSV
;33-OBD2
;Monday,21,September,2026,19:23:52:25381
04,Calculated load value,32.9 %,32.9 %
05,Engine coolant temperature,74 °C,74 °C
0C,Engine RPM,635 /min,634 /min
0D,Vehicle speed,0 km/h,0 km/h
0F,Intake air temperature,27 °C
10,Mass Air Flow,6.72 g/s
11,Absolute Throttle Position,33.7 %
13,Location of O2 sensors,B1S1
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,2784 s
21,Distance travelled with MIL on,0 km
30,Warm-ups since DTC cleared,1
31,Distance since DTC cleared,67 km
33,Barometric pressure,102 kPa abs
34,Bank 1 Sensor 1 Status,0.181 Lambda,0.844 mA
3C,B1S1 Cat. Temp.,120.9 °C
3E,B1S2 Cat. Temp.,114.9 °C
42,Control module voltage,12.840 V,12.774 V
45,Relative Throttle Position,71.4 %
46,Ambient Air Temp,22 °C
49,Accelerator Pedal Position D,14.9 %,14.9 %
4A,Accelerator Pedal Position E,14.9 %
4C,Commanded Throttle Actuator Control,71.4 %
4F,Conversion factors,Max eq. ratio 32,Max V O2s 0 V
51,Fuel type,Diesel
5C,Engine Oil Temp,78 °C
5D,Fuel Injection Timing,-3.98 °
5E,Engine Fuel Rate,0.65 L/h
65,Auxiliary Input/Output,GPL_STAT:OFF
67,Engine Coolant Temp,ECT 1:74 °C
69,EGR Command/Actual/Error,EGR A:75/75/0 %,EGR B:---/---/--- %
6B,EGR Temperature,EGRTemp 11/12:108/--- °C,EGRTemp 21/22:---/--- °C
6D,Fuel Press. Control A/B,FRP CMD:25060/--- kPa,FRP ACT:24930/--- kPa
70,Boost Press Ctrl A/B,BP_A cmd/act:102.0/102.4 kPa
71,Var. Geom. Turb. Ctrl A/B,VGT_A cmd/act:80.0/79.6 %,VGT_B cmd/act:---/--- %
78,EGT B1-S1-4,S1/S2/S3/S4:,136/123/120/--- °C
7A,DPF Bank 1 Delta/In/Out,0.60/---/--- kPa
83,NOx Sensor Bank 1/2,NOx11:43 ppm,NOx21:0 ppm
85,NOx Control System,ReAg Rate/Demand:0.1/0.07 L/h,Reag Tnk Lvl:51.8 %
8B,Aftertreatment status,PF_Regen:Status:N,Typ:Pass.
8F,PM sensor output,B1S1:ACT:NO;REGN:NO,B1S1:-0.01 %
Type 02 - VIN : WVGZZZCRZKD020971 (Address E8)
Type 04 - Calibration ID : 760401N 0002BEABSCR355D00061CR00NOX00907807 0034NOX00907807 0034NOX0000000000000PMS00906261 A200 (Address E8)
Type 04 - Calibration ID : 760158B 10031 (Address E9)
Type 06 - Calibration Verification Number : 9CCCCE8F (Address E8)
Type 06 - Calibration Verification Number : FA9EEAC7 (Address E8)
Type 06 - Calibration Verification Number : B866C2AD (Address E8)
Type 06 - Calibration Verification Number : 00000000 (Address E8)
Type 06 - Calibration Verification Number : D6C3ECFE (Address E8)
Type 06 - Calibration Verification Number : 4559B166 (Address E9)
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0B - In-use performance tracking :
OBD Monitoring Conditions Encountered count : 2419
Ignition cycle count : 12738
NMHC Catalyst : 1469 / 2419
NOx/SCR Catalyst : 978 / 2419
NOx Adsorber : 1469 / 2419
PM Filter : 612 / 136
Exhaust Gas Sensor : 948 / 2417
EGR and/or VVT : 5399 / 2419
Boost Pressure : 2687 / 2419
Fuel : 0 / 0
;SW:760-953-507-B HW:760-953-507-B --- 16: Steering wheel
;Component:Lenks.Modul H03 0006, Coding:
;EV_SMLSKLOAU736,007012,EV_SMLSKLOAU736_VW53.rod
;Monday,21,September,2026,19:17:00:25381
;VCID: 9C6A3A20362D75BA9B8-80C8
IDE00820-IDE80001-Activating and deactivating all development messages-Analysis 1,OFF ,1
IDE00820-IDE80002-Activating and deactivating all development messages-Analysis 2,OFF ,1
IDE00820-IDE80003-Activating and deactivating all development messages-Analysis 3,OFF ,1
IDE00820-IDE80004-Activating and deactivating all development messages-Analysis 4,OFF ,1
IDE00820-IDE80005-Activating and deactivating all development messages-Analysis 5,OFF ,1
IDE02744-MAS02194-Steering wheel heating-Temperature 1,39 °C,3
IDE02744-MAS02195-Steering wheel heating-Temperature 2,43 °C,3
IDE02744-MAS02196-Steering wheel heating-Temperature 3,47 °C,3
IDE12365-Switching off the MFL buttons during dynamic driving,On ,1
Elapsed Time: 00:01
;SW:80A-907-397-D HW:80A-907-397-D --- 29: Left Light
;Component:LCM_MLBevo H07 0022, Coding:
;EV_LCMLeftCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW53.rod
;Monday,21,September,2026,19:17:09:25381
;VCID: B032FE904AA5E1DAD70-80E4
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not activated ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not activated ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not activated ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not activated ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not activated ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not activated ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not activated ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not activated ,1
IDE01550-Service position,not active ,1
Elapsed Time: 00:01
;SW:80A-907-397-D HW:80A-907-397-D --- 39: Right Light
;EV_LCMRightCONTIAU426,001009,EV_LCMLeftCONTIAU426_VW53.rod
;Monday,21,September,2026,19:17:17:25381
;VCDS Version: 26.9.0.3 (arm64) Data version: 20260918 DS378.0
Elapsed Time: 00:01
;SW:4M1-959-793-D HW:4M1-959-793-D --- 42: Door Elect, Driver
;Component:TSG FS001 0188, Coding:003F9B00DE00048200093092
;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHKLO_VW27.rod
;Monday,21,September,2026,19:17:32:25381
;VCID: C0D2AE50FA05715A270-8094
IDE09067-Side window shade: service mode,Deactivating ,1
Elapsed Time: 00:03
;SW:4N0-909-144-D HW:4N0-909-144-A --- 44: Steering Assist
;Component:EPS_MLBEVO2BS H21 0504, Coding:B2150101000100
;EV_EPSVWBSAU426,009015,EV_EPSVWBSAU426_009.rod
;Monday,21,September,2026,19:17:58:25381
IDE00820-ENG135538-Activating and deactivating all development messages-DEV_EPS_01,not activated ,1
IDE00820-ENG135535-Activating and deactivating all development messages-DEV_EPS_S100,not activated ,1
IDE00820-ENG135536-Activating and deactivating all development messages-DEV_EPS_S101,not activated ,1
IDE00820-ENG135537-Activating and deactivating all development messages-DEV_EPS_S102,not activated ,1
IDE00820-ENG111917-Activating and deactivating all development messages-Dev_Messages_Test_1,not activated ,1
IDE00820-ENG135539-Activating and deactivating all development messages-DEV_X_03,not activated ,1
IDE00820-ENG99057-Activating and deactivating all development messages-XCP,not activated ,1
IDE04555-MAS05425-Activation of pwr steering asst without engine running-100%,not activated ,5
IDE04555-MAS05427-Activation of pwr steering asst without engine running-80%,not activated ,5
IDE04555-MAS11217-Activation of pwr steering asst without engine running-20%,not activated ,5
IDE04555-MAS11219-Activation of pwr steering asst without engine running-40%,not activated ,5
IDE04555-MAS11221-Activation of pwr steering asst without engine running-60%,not activated ,5
ENG110582-Activation_update_programming_without_rest_bus_simulation,not activated ,1
ENG153795-deactivation_characteristic_curves_flash_via_data_set,not activated ,1
ENG153796-Deactivation_of_Assistenz_System_Monitor_message,not activated ,1
ENG110746-V_limit_kL30_disconnect,18.00 km/h,2
Elapsed Time: 00:02
;Monday,21,September,2026,19:18:13:25381
IDE10493-MAS03001-Electrical test 2 of loudspeakers-Mode,automatic ,73
IDE10493-ENG117360-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,73
IDE10493-ENG117361-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,60 ,73
IDE10493-ENG117378-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,73
IDE10493-ENG117379-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,60 ,73
IDE10493-ENG117380-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,73
IDE10493-ENG117381-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,60 ,73
IDE10493-ENG117382-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,73
IDE10493-ENG117383-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,60 ,73
IDE10493-ENG117384-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,73
IDE10493-ENG117385-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,60 ,73
IDE10493-ENG117386-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,73
IDE10493-ENG117387-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,60 ,73
IDE10493-ENG117388-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,73
IDE10493-ENG117389-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,60 ,73
IDE10493-ENG117390-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,73
IDE10493-ENG117391-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,60 ,73
IDE10493-ENG126164-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,73
IDE10493-ENG126165-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,60 ,73
IDE10493-ENG126166-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,73
IDE10493-ENG126167-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,60 ,73
IDE10493-ENG126168-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,73
IDE10493-ENG126169-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,60 ,73
IDE10493-ENG117362-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,73
IDE10493-ENG117363-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,60 ,73
IDE10493-ENG126170-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,73
IDE10493-ENG126171-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,60 ,73
IDE10493-ENG126172-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,73
IDE10493-ENG126173-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,60 ,73
IDE10493-ENG126174-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,73
IDE10493-ENG126175-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,60 ,73
IDE10493-ENG126176-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,73
IDE10493-ENG126177-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,60 ,73
IDE10493-ENG126178-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,73
IDE10493-ENG126179-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,60 ,73
IDE10493-ENG117364-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,73
IDE10493-ENG117365-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,60 ,73
IDE10493-ENG117366-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,73
IDE10493-ENG117367-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,60 ,73
IDE10493-ENG117368-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,73
IDE10493-ENG117369-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,60 ,73
IDE10493-ENG117370-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,73
IDE10493-ENG117371-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,60 ,73
IDE10493-ENG117372-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,73
IDE10493-ENG117373-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,60 ,73
IDE10493-ENG117374-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,73
IDE10493-ENG117375-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,60 ,73
IDE10493-ENG117376-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,73
IDE10493-ENG117377-Electrical test 2 of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,60 ,73
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
ENG141637-ENG142098-Sound_ID_Configuration-AMP_ID,--- ,4
ENG141637-ENG142170-Sound_ID_Configuration-terminator,0 ,4
Elapsed Time: 00:03
;Monday,21,September,2026,19:18:28:25381
Elapsed Time: 00:03
;Monday,21,September,2026,19:22:38:25381
IDE00001-Production mode,active ,3
IDE00820-IDE00106-Activating and deactivating all development messages-Internal DTC,0 ,3
IDE00820-MAS03504-Activating and deactivating all development messages-XCP,OFF ,3
IDE00820-ENG146557-Activating and deactivating all development messages-development_message_ECU_specific_01_02,OFF ,3
IDE00820-ENG100523-Activating and deactivating all development messages-development_message_ECU_specific_03_to_10,OFF ,3
IDE00820-ENG103002-Activating and deactivating all development messages-development_message_S100,OFF ,3
IDE00820-ENG102128-Activating and deactivating all development messages-development_message_S101,OFF ,3
IDE00820-ENG103295-Activating and deactivating all development messages-development_message_S102,OFF ,3
IDE02001-Body height left front wheel house edge,460.00 mm,2
IDE02002-Body height right front wheel house edge,455.00 mm,2
IDE02003-Body height left rear wheel house edge,460.00 mm,2
IDE02004-Body height right rear wheel house edge,455.00 mm,2
IDE04330-Transfer of release code for a SWaP function,Conditions not correct or request sequence error,3
IDE04331-Selection of release codes for a SWaP function,Conditions not correct or request sequence error,3
IDE08539-Constant pwr supply to all dampers,OFF ,1
IDE08997-IDE04195-Raw values: height sensors when deflected-Left front level ctrl sys sensor: adaptation value (deflected),12.54 %,8
IDE08997-IDE04198-Raw values: height sensors when deflected-Right front level ctrl sys sensor: adaptation value (deflected),86.74 %,8
IDE08997-IDE04201-Raw values: height sensors when deflected-Left rear level ctrl sys sensor: adaptation value (deflected),76.40 %,8
IDE08997-IDE04204-Raw values: height sensors when deflected-Right rear level ctrl sys sensor: adaptation value (deflected),21.27 %,8
IDE09244-Fuel tank volume,100 l,1
IDE09245-Deviation from empty weight in full state,61.60 kg,2
IDE09246-MAS08451-Height offset for prelim. stage: calibrat. produc.-Front axle,0 mm,2
IDE09246-MAS08452-Height offset for prelim. stage: calibrat. produc.-Rear axle,0 mm,2
IDE09247-MAS01853-Calibrated raw values of height sensor syst.-Left front,0 mm,4
IDE09247-MAS01854-Calibrated raw values of height sensor syst.-Right front,-3 mm,4
IDE09247-MAS01855-Calibrated raw values of height sensor syst.-Left rear,10 mm,4
IDE09247-MAS01856-Calibrated raw values of height sensor syst.-Right rear,-3 mm,4
IDE09260-MAS10785-Tight level control tolerance-Axle ctr. position: activation threshold,0 mm,4
IDE09260-MAS10786-Tight level control tolerance-Axke ctr. position: setpoint level limit,0 mm,4
IDE09260-MAS10787-Tight level control tolerance-Axle askew pos.: activation threshold,0 mm,4
IDE09260-MAS10788-Tight level control tolerance-Axle slanted position: tol. threshold,0 mm,4
ENG105619-Constant_damper_current_front_left,0.00 mA,2
ENG105620-Constant_damper_current_front_right,0.00 mA,2
ENG105621-Constant_damper_current_rear_left,0.00 mA,2
ENG105622-Constant_damper_current_rear_right,0.00 mA,2
ENG109010-speed_value_for_testing_mode,0.00 km/h,2
Elapsed Time: 00:07
;SW:4M1-959-795-D HW:4M1-959-795-D --- BB: Door Rear Drv
;Component:TSG HFS003 0188, Coding:003E93000000048000093080
;EV_DCU2RearDriveMAXHKLO,001010,EV_DCU2RearDriveMAXHKLO_VW38.rod
;Monday,21,September,2026,19:22:58:25381
;VCID: C2D6A458F409634A314-8096
Elapsed Time: 00:02
;SW:4M1-959-795-D HW:4M1-959-795-D --- BC: Door Rear Pass
;Component:TSG HBFS003 0188, Coding:003E93000000048000093080
;EV_DCU2RearPasseMAXHKLO,001010,EV_DCU2RearPasseMAXHKLO_VW38.rod
;Monday,21,September,2026,19:23:14:25381
Elapsed Time: 00:02
;Monday,21,September,2026,19:23:44:25381
Elapsed Time: 00:01
I did a search for "km" in your measuring values data and it looks very solid in the direction of the mileage being correct. Last measured oil levels and run distances in the suspension modes give especially good confidence. And it's a manual!?
I hope not, I don't wanna do eight gears forward manually
Thanks for the feedback! When I visited the car in Berlin I had a cold start and the engine started ok, the seats and steering wheel leather where in a good shape and not toally worn out.
Any thanks, Ill start looking in to some changes like the folding mirrors and so on.
