Golf 2023 SFD unlocked, autoscan and channel maps
datodaco
Slovenia
C?ID=393757
Hi,
SFD chanells unlocked. I am posting autoscan, measuring blocks and also adaptation maps for golf model year 2023,
Thursday,03,September,2026,18:13:17:29755
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: WVWZZZCD6RW123439   License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 6C 75 A5
          CA D6 D7 8107 811E 811F 8120 8121
VIN: WVWZZZCD6RW123439   Mileage: 18974km-11789miles
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: OK 0000
811F-Burglary Protection FR -- Status: Malfunction 0010
Address 01: Engine (2D2D2-DLAA)       Labels: Redir Fail!
   Part No SW: 05C 906 032 AF    HW: 05C 907 394 C
   Component: R3 1.0l TFS   H03 3738
   Revision: 42003001
   Coding: 0119001223640D0830080000000000000000000000000000
   ASAM Dataset: EV_ECM10TFS03005C906032AF 002009
   ROD: EV_ECM10TFS03005C906032AF_002_VW38.rod
   VCID: 6393A9A4FBD2FBA29A2-8036 SFD [ ]
   VINID: 9E69EAAAA4D41A29C1083103249E05C2F1
43185 - Release / Enable Active
          B184C 00 [00100111] - -
          [Activation active]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:39:15
                    Engine speed: 948.50 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 92  C
                    Intake air temperature: 43  C
                    Voltage terminal 30: 14.281 V
                    Ignition timing adjustment cylinder 1: -7.0 Degrees
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
                    Primary injection: quantity setpoint: 8.47 mg/stroke
                    Fuel high pressure sensor: actual value: 225.7 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.705 V
                    IN_Injection_speed: 950.00 /min
                    Camshaft adjustment: exhaust: bank 1: actual value: -0.5
                    Camshaft adjustment intake bank 1: actual value: 0.0
                    Throttle valve position (absolute): 13.7 %
                    Setpoint generation interior torque: 26.3 Nm
                    Battery voltage: 14.289 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Control Module temperature: 43.5  C
                    Engine oil temperature: 53.6  C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 92143000002272  Dataset Number: V03935397FY 0001 CVN: 83FF7D8B
   Coding: 34FC2C902222446F527B50030ACC61862DB458F542D067C0219CA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 0E45A81040D026CA65C-805A SFD [ ]
590080 - Release / Enable Active
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:42:25
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 348 m
                    Voltage_value_KL.30_ESC_V: 14.1 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: completed successfully
                    LWS_comparison: completed successfully
                    Internal_failure_code: 01 AE
                    00 02 40 00 04 0C 10 08 80 00 00 00 7F 00 00 40 30 00 21 00 04
197408 - Front Right Wheel Speed Sensor
          C101B 11 [00101111] - Short to Ground
          [Wh2_dia_asr_short_to_low]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 10:11:30
                    Resolution Mileage: 308 m
                    Voltage_value_KL.30_ESC_V: 12.2 V
                    Internal_failure_code: 02 11
                    00 E0 40 00 04 0C 00 10 80 00 00 00 00 00 00 08 02 00 21 00 04
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935341VY 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 629DACA0E4C8F2AA914-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 AB    HW: 5WA 907 007 AB
   Component: AC Automat    H30 3623
   Serial number: --------------- Dataset Number: V03935358HE 0001
   Coding: 002000119011000000100010111010010000011000000000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001102
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 074B9D342FAA7782A6A-8052
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002150723122346504
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BM    HW: 5WA 937 086 AT
   Component: BCM37w_M134 0182
   Serial number: BXJ53F290723940 Dataset Number: V03935400FM 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW38.rod
   VCID: 1D67DF5C9D368D52EC6-8048 SFD [ ]
   Subsystem 1 - Part No SW: 5H1 955 119 B    HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0061
   Serial number: 907453F0302320502772
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS            054 0206
   Serial number: S6Y23M08D18H08M30S18
   Subsystem 3 - Part No SW: 5H0 941 193 AK    HW: 5H0 941 193 AK
   Component: LiSi           H06 0008
   Serial number: 92471WGR000GQ
   Subsystem 4 - Part No SW: 5H0 925 200 T    HW: 5H0 925 200 T
   Component: DiETa          H07 0008
   Serial number: 92471WH1000VY
   Subsystem 5 - Part No SW: 5H0 959 561 BQ    HW: 5H0 959 561 BQ
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND04082300010040
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Serial number: 00000024072304220048
15403264 - Release / Enable Active
          B184C 00 [00101111] - -
          [Freischaltung aktiv]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:43:32
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: On
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 14.1 V
                    Outside temperature: 30.0  C
                    Light switch position: automatic
                    Role of vehicle diagnostic to be protected: Basic
                    Type of vehicle diagnostic to be protected: Short: time-controlled
                    Status of vehicle diagnostic to be protected: SFD individualization feature set
                    Duration of vehicle diagnostic to be protected: 89 minutes
   Part No SW: 5R3 919 294     HW: 5R3 919 294
   Component: PDC 08 Kanal  H05 1550
   Serial number: 000995460323206 Dataset Number: V03935375FW 0001
   Coding: 0040010001
   ASAM Dataset: EV_EPHVA18VW3800000 002036
   ROD: EV_EPHVA18VW3800000_VW38.rod
   VCID: 7CA1F2D8666C245ABB8-8028
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935392FC 0001
   Coding: 010310F5000740451247400800C040C44E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4EC56810805066CA25C-801A
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 L    HW: 5WA 959 655 L
   Component: AirbagVW40    010 0636
   Serial number: 000000003C0J2RA Dataset Number: V03935376EV 0001
   Coding: 88CC008000F0C000000000000000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 6099A6A8EAC4E0BA870-8034 SFD [ ]
   Subsystem 1 - Part No SW: -----------    HW: 480 052 108 23
   Component: SideSensor_Dr  000 0149
   Serial number: 3510000A6C86458743D9
   Subsystem 2 - Part No SW: -----------    HW: 480 052 208 23
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000BEC8F640FE68.
   Subsystem 3 - Part No SW: -----------    HW: 480 001 907 23
   Serial number: 35700000000BA66DE964
   Subsystem 4 - Part No SW: -----------    HW: 480 001 907 23
   Serial number: 35800000000105458A6C
   Subsystem 5 - Part No SW: -----------    HW: 480 051 908 23
   Component: FrontSensor_D  000 014A
   Serial number: 3550000C8C74C151898E
9980928 - Release / Enable Active
          B184C 00 [00001001] - -
          [ECU unlocked]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:44:23
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 C    HW: 5H0 920 340 C
   Component: KOMBI         310 7380
   Dataset Number: V03935364SX 0001
   Coding: 04A4000063840008018062032000080800300800
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 221DECA0A448B2AAD14-8076 SFD [ ]
16777020 - Control unit for information electronics 1
          U1054 00 [00001000] - No Communication
          [TEL_0x28 communication error bap_error_timeout heartbeat]
                    Reset counter: 119
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:49
16711684 - Release / Enable Active
                    Reset counter: 79
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:44:47
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110023180 Dataset Number: V03935393AA 0001
   Coding: 0000808D0F00000000000000012303305301600902000300030100000001010000000000000000000000000000000000
   GVL: 3D0000000208409C800080024800104004004000004400000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 08499E0822B478FAAF0-805C SFD [ ]
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 5311322606
   Subsystem 3 - Part No SW: 3G0 959 442 AF    HW: 3G0 959 442 AF
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440079186230036
   Subsystem 4 - Part No SW: 5H0 959 542 L    HW: 5H0 959 542 L
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA23226131503
                    Mileage: 18974 km
                    Date: 2026.09.02
                    Time: 20:53:14
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 C
   Component: EBKV          H09 0372
   Serial number: BPA085260723013 Dataset Number: V03935367RC 0001
   Coding: 1002C140730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 1079B6685AE4303A770-8044 SFD [ ]
1024304 - Release / Enable Active
          [SECDIAG_ROLE_UNLOCKED]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:45:32
1024368 - Brake Booster
          C1187 F6 [00101100] - Function Limitation due to External Brake Pressure Build-Up
          [ActiveRestrictionDetected]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 10:11:53
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 23000165506010 Dataset Number: V03935336NF 0001
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323D1CE0F4A8222A214-8066
   Part No SW: 5QS 959 760 H    HW: 5QS 959 760 H
   Component: MEM-FS        011 0372
   Serial number: 24B3001KA00813 Dataset Number: V03935451WL 0001
   Coding: 01589A400000B0508803010101010000000000212100000000000000215000
   VCID: 6597B7BCF5E68592746-8030
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007WGV16556 Dataset Number: V03935387Z  0001
   Coding: 003B13208200040008001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 4ACD64007C384AEA794-801E
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000073597272
   Coding: 110000
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 03070569 Dataset Number: V03935358SR 0001
   Coding: 0000000000000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007WH20786A Dataset Number: V03935386XH 0001
   Coding: 003B11208E00040000801000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 49CF5B0C793E41F270E-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000073352136
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 820 P    HW: 5H0 035 820
   Component: MU-O-ND-EU    H61 1989
   Serial number: WG8LGM190823000 Dataset Number: V03935431DH 0001
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW38.rod
   VCID: 2F3B1594E79A0FC24EA-807A SFD [ ]
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H44 3080
   Serial number: VDD02411082312210379
   Subsystem 2 - Part No SW: V03 959 820 GB    HW: -----------
   Component: EUR 2023/24    --- 9085
4112 - Release / Enable Active
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:47:18
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20200723010 Dataset Number: V03935359FC 0001
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52FD7C609468022A014-8006
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0144
   Serial number: 0000000305VICLG Dataset Number: V03935447ZH 0001
   Coding: 023800109068AC209405460071002E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 49CF5B0C793E41F270E-801C SFD [ ]
1592320 - Release / Enable Active
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:47:49
                    Voltage terminal 30: 12.7 V
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590904232010 Dataset Number: V03935412E  0001
   Coding: 00000888114C4040109E00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 50F976689A64703A370-8004
   Part No SW: 4K1 907 594 CB    HW: 4K1 907 594
   Component: SAD_STG_1     006 0040
   Dataset Number: V03935402SS 0001
   Coding: 408000738001
   VCID: 77ABEDF45F4A0702D6A-8022
   Part No SW: 992 941 571 AH    HW: 992 941 571 A
   Component: LED1L         H25 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6889BE8802F498FA4F0-803C
   Component: LED1R         H25 9204
   Dataset Number: V03935402VJ 0001
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0083
   Serial number: 0000000303VIZC5 Dataset Number: V03935364CE 0001
   Coding: 02380011440080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
   VCID: 43D349245B129BA2BA2-8016 SFD [x]
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 F    HW: 5WA 962 133 F
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 4BC36104734253E2422-801E
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
10487042 - Control Module not Adapted
          B2019 00 [00001001] - -
          [Ecu_not_learned]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:46
1081345 - VKMS
          B18B0 F0 [00001001] - Missing Adaptation
          [VKMS_new_download_container_required_due_to_vehicle_change]
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:46
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 21:10, VBatt start/end: 12.9V/12.9V)-----------
------------------------------14 Faults Found-----------------------
datodaco
Slovenia
C?ID=393757
AutoScan: WVWZZZCD6RW123439
Thursday,03,September,2026,17:50:01:29755
   Revision: 42003001
   VCID: 6393A9A4FBD2FBA29A2-8036 SFD { }
          B184C 00 {00100111} - -
          {Activation active}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:39:15
                    Coolant temperature: 92 °C
                    Intake air temperature: 43 °C
                    Camshaft adjustment: exhaust: bank 1: actual value: -0.5 °
                    Camshaft adjustment intake bank 1: actual value: 0.0 °
                    Control Module temperature: 43.5 °C
                    Engine oil temperature: 53.6 °C
Readiness: N/A
   VCID: 0E45A81040D026CA65C-805A SFD { }
          {Unlock_protection_of_vehicle_diagnosis_active}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:42:25
          C101B 11 {00101111} - Short to Ground
          {Wh2_dia_asr_short_to_low}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 10:11:30
   VCID: 1D67DF5C9D368D52EC6-8048 SFD { }
          B184C 00 {00101111} - -
          {Freischaltung aktiv}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:43:32
                    Engine run: On
                    Voltage: 14.1 V
                    Outside temperature: 30.0 °C
   Coding: 0040010001
   VCID: 6099A6A8EAC4E0BA870-8034 SFD { }
          B184C 00 {00001001} - -
          {ECU unlocked}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:44:23
   VCID: 221DECA0A448B2AAD14-8076 SFD { }
          U1054 00 {00001000} - No Communication
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Reset counter: 119
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:49
                    Reset counter: 79
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:44:47
   VCID: 08499E0822B478FAAF0-805C SFD { }
   Generator:
                    Mileage: 18974 km
                    Date: 2026.09.02
                    Time: 20:53:14
   VCID: 1079B6685AE4303A770-8044 SFD { }
          {SECDIAG_ROLE_UNLOCKED}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:45:32
          C1187 F6 {00101100} - Function Limitation due to External Brake Pressure Build-Up
          {ActiveRestrictionDetected}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 10:11:53
   Coding: 110000
   Coding: 090000
   VCID: 2F3B1594E79A0FC24EA-807A SFD { }
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:47:18
   VCID: 49CF5B0C793E41F270E-801C SFD { }
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:47:49
   VCID: 43D349245B129BA2BA2-8016 SFD {x}
          B2019 00 {00001001} - -
          {Ecu_not_learned}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:46
1081345 - VKMS
          B18B0 F0 {00001001} - Missing Adaptation
          {VKMS_new_download_container_required_due_to_vehicle_change}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:46
End----------(Elapsed Time: 01:34, VBatt start/end: 12.9V/12.9V)-----------
------------------------------14 Faults Found------------------------------
blockmap-01-05C-906-032-AF_WVWZZZCD6RW123439-20260903-1754.CSV
;SW:05C-906-032-AF   HW:05C-907-394-C ---  01: Engine
;Component:R3 1.0l TFS   H03 3738, Coding:0119001223640D0830080000000000000000000000000000
;EV_ECM10TFS03005C906032AF,002009,EV_ECM10TFS03005C906032AF_002_VW38.rod
;Thursday,03,September,2026,17:54:56:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 6393A9A4FBD2FBA29A2-8036 SFD { }
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),||WVWZZZCD6RW123439|,
IDE00018,Voltage terminal 15,12.660, V
IDE00019,Voltage terminal 30,13.017, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,948, /min
IDE00025,Coolant temperature,90, °C
IDE00078,Time since engine start,1387, s
IDE00083,Throttle valve position (absolute),14.1, %
IDE00084,Absolute load value,32, %
IDE00085,Normed load value,27.8, %
IDE00086,Accelerator pedal position,14.1, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00102,Control Module temperature,57.2, °C
IDE00145,Clutch status,Open,
IDE00151,Oil fill level,74, mm
IDE00155,Ignition timing angle retard cylinder 1,0.00, °
IDE00156,Ignition timing angle retard cylinder 2,0.00, °
IDE00157,Ignition timing angle retard cylinder 3,0.00, °
IDE00167,Exhaust temperature 1 bank 1,411.2, °C
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,0.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-0.2, °
IDE00178,Camshaft adjustment intake bank 1: specified value,0.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,-0.3, °
IDE00187,Coolant temperature at engine start,32.2, °C
IDE00188,Fuel high-pressure: actual value,228.0, bar
IDE00191,Charge air pressure: actual value,0.977, bar
IDE00192,Coolant temperature at radiator outlet: actual value,50.2, °C
IDE00196,Engine oil temperature,81.4, °C
IDE00201,Fuel high-pressure: specified value,227.4, bar
IDE00252,Vacuum pump for brakes,Pump off,
IDE00304,Fuel level,5, l
IDE00348,Intake air temperature,52, °C
IDE00349,Throttle valve position: normed,3.5, %
IDE00351,Main injection: start of activation,180.00, °
IDE00355,Cruise Control System (CCS): status,main switch off,
IDE00358,Limitation: torque,95.6, Nm
IDE00371,Fuel consumption,0.93, l/h
IDE00375,Generator: load signal,45.14, %
IDE00380,Coolant fan 1: activation,60.00, %
IDE00381,Coolant fan 2: activation,0.00, %
IDE00404,Throttle valve: activation,0.00, %
IDE00405,Crankshaft speed (RPM),949, /min
IDE00406,Camshaft RPM,946, /min
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,not active,
IDE00416-MAS07386,Starter control: terminal 50 feedback-Terminal 50 on CAN,not active,
IDE00416-MAS09390,Starter control: terminal 50 feedback-Terminal 50 CAN valid,not active,
IDE00416-MAS09391,Starter control: terminal 50 feedback-Terminal 50 via cable,not active,
IDE00416-MAS09392,Starter control: terminal 50 feedback-Starter relay,not active,
IDE00416-MAS09394,Starter control: terminal 50 feedback-Starter operation read back wire T50Ret,not active,
IDE00416,Starter control: terminal 50 feedback,0,
IDE00436,Particle filter: kilometers since last regeneration,6553.5,
IDE00445,Unlearning counter according OBD,2,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,9, mg/stroke
IDE00474,Ambient air pressure,97, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,21.6, Nm
IDE00495,Calculated oil temperature,89.5, °C
IDE00541,Acceleration,0.000, m/s²
IDE00554,Absolute vapor pressure in tank ventilation system,97810, kPa abs
IDE00556,Outside temperature,30, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.991 Lambda / -0.020 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.680, V
IDE00560-MAS04122,Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation,0.0, %
IDE00582,Specified value of equivalence ratio,1.000, Lambda
IDE00583,Throttle valve specified value,4.7, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00588,Fuel tank fill level,11.8, %
IDE00590,Terminal 87 status,On,
IDE00592,Status of oxygen sensor control,Closed loop,  / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,-6.0, Degrees
IDE00594,Absolute intake pressure,47, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,1.6, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,2,
IDE00604,Short term adaptation of mixture formation bank 1,0.8, %
IDE00608,Fuel type,Gasoline,
IDE00609-ENG103365,Communication status of data bus 1-CAN Communication Status,|Control module,Communication status|Engine Electronics
IDE00612,Target position of EVAP canister valve,15.3, %
IDE01076-MAS00109,Time since ignition off-Hours,6, H
IDE01076-MAS00110,Time since ignition off-Minutes,31, min
IDE01076-MAS00111,Time since ignition off-Seconds,9, s
IDE01267,Height correction,31534,
IDE01405-MAS05513,Starter activation: status-Bit 0,OK,
IDE01405-MAS05514,Starter activation: status-Bit 1,Before starter activation,
IDE01405-MAS05515,Starter activation: status-Bit 2,Before starter activation,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.683, V
IDE01649,Throttle valve position 1,65.535, V
IDE01650,Throttle valve position 2,14, %
IDE01652,Opening degree Evap. Emission (EVAP) Canister Purge Reg. Valve,15, %
IDE01671,Starter control: clutch switch,not depressed,
IDE01774,Status misfire recognition,active,
IDE01834,Battery voltage,13.023, V
IDE01869,Long-term fuel trim bank 1 at idle,1.01, %
IDE01878,Adaptation of throttle valve,Adaptation and testing of the lower mechanical stop,
IDE01880,Accelerator pedal position 2,14.1, %
IDE01881,Adaptation of kick-down shifting point,3.420, V
IDE01884,Camshaft adjustment intake bank 1: activation,0.00, %
IDE01893,Fuel pump: specified value,51.49, %
IDE01922,Vehicle distance driven,18974, km
IDE01923,Control module distance driven,18944, km
IDE01928,Close cam shaft angle at quantity control valve,61.0, °
IDE01975,Numb.of misfir.: cylinder 1,8437,
IDE01976,Numb.of misfir.: cylinder 2,10111,
IDE01977,Numb.of misfir.: cylinder 3,17819,
IDE02116,Exhaust gas temperature before catalytic converter,339.0, °C
IDE02117,Relative load value,32.26, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02742,Oil pressure actual value,2.506, bar
IDE02756,Number of manual engine starts,3885,
IDE02757,Number of automatic engine starts,1043,
IDE03008-ENG118016,Stop process prevented-StartStopProhibitionReason_1,OFF,
IDE03008-ENG249273,Stop process prevented-StartStopProhibitionReason_10,OFF,
IDE03008-ENG249274,Stop process prevented-StartStopProhibitionReason_11,OFF,
IDE03008-ENG249275,Stop process prevented-StartStopProhibitionReason_12,OFF,
IDE03008-ENG249276,Stop process prevented-StartStopProhibitionReason_13,OFF,
IDE03008-ENG249277,Stop process prevented-StartStopProhibitionReason_14,OFF,
IDE03008-ENG249278,Stop process prevented-StartStopProhibitionReason_15,OFF,
IDE03008-ENG249279,Stop process prevented-StartStopProhibitionReason_16,OFF,
IDE03008-ENG118017,Stop process prevented-StartStopProhibitionReason_2,OFF,
IDE03008-ENG118018,Stop process prevented-StartStopProhibitionReason_3,On,
IDE03008-ENG118019,Stop process prevented-StartStopProhibitionReason_4,OFF,
IDE03008-ENG118020,Stop process prevented-StartStopProhibitionReason_5,On,
IDE03008-ENG249269,Stop process prevented-StartStopProhibitionReason_6,OFF,
IDE03008-ENG249270,Stop process prevented-StartStopProhibitionReason_7,OFF,
IDE03008-ENG249271,Stop process prevented-StartStopProhibitionReason_8,OFF,
IDE03008-ENG249272,Stop process prevented-StartStopProhibitionReason_9,OFF,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,6,
IDE03010-MAS01627,Number of prevented stop processes-Steering,14,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,18,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,8,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,2,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,11,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03235,Neutral position sensor: current transmission angle,-1.45, °
IDE03236,Neutral position sensor: adapted transmission angle,-1.45, °
IDE03246,Neutral position sensor: upper adaptation value,2.851, V
IDE03247,Neutral position sensor: lower adaptation value,1.289, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.525, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.465, V
IDE03328,Transmission neutral position sensor voltage,1.835, V
IDE03375,Adaptation status of neutral position sensor,62,
IDE03583-MAS04416,Engine shut-down overrides-Sporadic function prevention,On,
IDE03583-MAS04417,Engine shut-down overrides-Poor start detection,OFF,
IDE03583-MAS04590,Engine shut-down overrides-Mixture adaptation,OFF,
IDE03583-MAS06089,Engine shut-down overrides-Brake vacuum,OFF,
IDE03583-MAS06602,Engine shut-down overrides-Engine temperature,OFF,
IDE03583-MAS06603,Engine shut-down overrides-Ambient pressure,OFF,
IDE03583-MAS06604,Engine shut-down overrides-Start/stop sensors:,On,
IDE03583-MAS06605,Engine shut-down overrides-Regeneration Mode,OFF,
IDE03584-MAS04369,Engine starting requirements-Engine temperature too high,OFF,
IDE03584-MAS04370,Engine starting requirements-Engine temperature too low,OFF,
IDE03584-MAS06606,Engine starting requirements-Brake under pressure too low,OFF,
IDE03584-MAS06607,Engine starting requirements-SCR System requires restart,OFF,
IDE03584,Engine starting requirements,OFF,
IDE03584-ENG154330,Engine starting requirements-Reserved_5,OFF,
IDE03584-ENG154188,Engine starting requirements-Reserved_6,OFF,
IDE03584-ENG154256,Engine starting requirements-Reserved_7,OFF,
IDE03585,System status for the start/stop function master,active: no release by coordinator,
IDE03586-ENG118093,Starting requirements for active participants-Active_Member_1,OFF,
IDE03586-ENG118102,Starting requirements for active participants-Active_Member_10,OFF,
IDE03586-ENG118103,Starting requirements for active participants-Active_Member_11,OFF,
IDE03586-ENG118104,Starting requirements for active participants-Active_Member_12,OFF,
IDE03586-ENG118105,Starting requirements for active participants-Active_Member_13,OFF,
IDE03586-ENG118106,Starting requirements for active participants-Active_Member_14,OFF,
IDE03586-ENG118107,Starting requirements for active participants-Active_Member_15,OFF,
IDE03586-ENG118108,Starting requirements for active participants-Active_Member_16,OFF,
IDE03586-ENG118094,Starting requirements for active participants-Active_Member_2,OFF,
IDE03586-ENG118095,Starting requirements for active participants-Active_Member_3,OFF,
IDE03586-ENG118096,Starting requirements for active participants-Active_Member_4,OFF,
IDE03586-ENG118097,Starting requirements for active participants-Active_Member_5,OFF,
IDE03586-ENG118098,Starting requirements for active participants-Active_Member_6,OFF,
IDE03586-ENG118099,Starting requirements for active participants-Active_Member_7,OFF,
IDE03586-ENG118100,Starting requirements for active participants-Active_Member_8,OFF,
IDE03586-ENG118101,Starting requirements for active participants-Active_Member_9,OFF,
IDE03587-ENG118093,Stopping prohibitions for active participants-Active_Member_1,OFF,
IDE03587-ENG118102,Stopping prohibitions for active participants-Active_Member_10,OFF,
IDE03587-ENG118103,Stopping prohibitions for active participants-Active_Member_11,OFF,
IDE03587-ENG118104,Stopping prohibitions for active participants-Active_Member_12,OFF,
IDE03587-ENG118105,Stopping prohibitions for active participants-Active_Member_13,OFF,
IDE03587-ENG118106,Stopping prohibitions for active participants-Active_Member_14,OFF,
IDE03587-ENG118107,Stopping prohibitions for active participants-Active_Member_15,OFF,
IDE03587-ENG118108,Stopping prohibitions for active participants-Active_Member_16,OFF,
IDE03587-ENG118094,Stopping prohibitions for active participants-Active_Member_2,On,
IDE03587-ENG118095,Stopping prohibitions for active participants-Active_Member_3,OFF,
IDE03587-ENG118096,Stopping prohibitions for active participants-Active_Member_4,OFF,
IDE03587-ENG118097,Stopping prohibitions for active participants-Active_Member_5,OFF,
IDE03587-ENG118098,Stopping prohibitions for active participants-Active_Member_6,OFF,
IDE03587-ENG118099,Stopping prohibitions for active participants-Active_Member_7,OFF,
IDE03587-ENG118100,Stopping prohibitions for active participants-Active_Member_8,OFF,
IDE03587-ENG118101,Stopping prohibitions for active participants-Active_Member_9,OFF,
IDE03588-ENG118093,System malfunctions for active participants start/stop-Active_Member_1,OFF,
IDE03588-ENG118102,System malfunctions for active participants start/stop-Active_Member_10,OFF,
IDE03588-ENG118103,System malfunctions for active participants start/stop-Active_Member_11,OFF,
IDE03588-ENG118104,System malfunctions for active participants start/stop-Active_Member_12,OFF,
IDE03588-ENG118105,System malfunctions for active participants start/stop-Active_Member_13,OFF,
IDE03588-ENG118106,System malfunctions for active participants start/stop-Active_Member_14,OFF,
IDE03588-ENG118107,System malfunctions for active participants start/stop-Active_Member_15,OFF,
IDE03588-ENG118108,System malfunctions for active participants start/stop-Active_Member_16,OFF,
IDE03588-ENG118094,System malfunctions for active participants start/stop-Active_Member_2,OFF,
IDE03588-ENG118095,System malfunctions for active participants start/stop-Active_Member_3,OFF,
IDE03588-ENG118096,System malfunctions for active participants start/stop-Active_Member_4,OFF,
IDE03588-ENG118097,System malfunctions for active participants start/stop-Active_Member_5,OFF,
IDE03588-ENG118098,System malfunctions for active participants start/stop-Active_Member_6,OFF,
IDE03588-ENG118099,System malfunctions for active participants start/stop-Active_Member_7,OFF,
IDE03588-ENG118100,System malfunctions for active participants start/stop-Active_Member_8,OFF,
IDE03588-ENG118101,System malfunctions for active participants start/stop-Active_Member_9,OFF,
IDE03589-ENG118109,Error status for start-stop related sensors-Sensor_1,OFF,
IDE03589-ENG118110,Error status for start-stop related sensors-Sensor_2,On,
IDE03589-ENG118111,Error status for start-stop related sensors-Sensor_3,OFF,
IDE03589-ENG118112,Error status for start-stop related sensors-Sensor_4,OFF,
IDE03589-ENG118113,Error status for start-stop related sensors-Sensor_5,OFF,
IDE03589-ENG118114,Error status for start-stop related sensors-Sensor_6,OFF,
IDE03589-ENG118115,Error status for start-stop related sensors-Sensor_7,OFF,
IDE03589-ENG118116,Error status for start-stop related sensors-Sensor_8,OFF,
IDE03711,Mass flow through throttle valve,11, kg/h
IDE03712,Engine diagnostic status in curr driving cycle (end-of-line),4294967295,
IDE03767,Engine status,Idle,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.00, %
IDE03932,Charge pressure actuator: specified position,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,1.001, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.98, %
IDE03966,Transmission neutral position sensor PWM signal,36.50, %
IDE03998,Clutch Position Sensor,10.00, %
IDE04002,Charge air pressure control,BP_A act:97.8, kPa
IDE04003,Charge air temperature sensor,B1S1:51, °C
IDE04008,Fuel consumption per hour,1.10, L/h
IDE04010,Engine torque: normalized,11.0, %
IDE04011,Nominal torque,250, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:22720/--- kPa,
IDE04045,Exhaust gas pressure,EP1:98.68, kPa
IDE04083,Coolant temperatures,ECT 1:90 °C / ECT 2:50 °C,
IDE04086,Turbocharger guide vane adjustment,VGT_A cmd/act:0.0/0.0 % / VGT_B cmd/act:---/--- %,
IDE04110,Additional inputs and outputs,GEAR_RCMD: N  / MT_GEAR:GEAR   ,
IDE04409,Intake manifold pressure: corrected,0.485, bar
IDE04410,Intake manifold pressure: specified value,0.480, bar
IDE04468,Air mass at air mass meter 1,11.4, kg/h
IDE04623,Kick-down threshold,3.420, V
IDE04637,Engine temperature control actuator,0.00, %
IDE04651,Torque request: A/C compressor,14.3, Nm
IDE04654,CAN status - engine control module,0,
IDE04685,Setpoint generation interior torque,27.3, Nm
IDE04694,Engine diagnostic status 2 in curr driving cycle (end-of-line),4294967295,
IDE04713,Active brake system status,Not operated,
IDE04858,Brake booster low pressure actual value,0.0, hPa
IDE04937,Sensor for engine block temperature: raw value,90.7, °C
IDE05138,Shut-off timer: last engine shut-off time,0, s
IDE05139,Shut-off timer: last ECM after-run time,23135, s
IDE05140,Intake manifold pressure raw value,0.483, bar
IDE05438,Rear cat conv temp main cat conv model value,411.5, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05441,ESI: Wear equivalent 2 calculated from wear index,0.00000024,
IDE05625,Speed regulation requested torque,-3276.8, Nm
IDE05694,Environmental pressure sensor gross voltage,3.836, V
IDE06049,Pressure in brake booster: raw value,970.0, hPa
IDE06159,Coolant temperature model value,90.75, °C
IDE06195,Knock sensor: cylinder 1: voltage,0.042, V
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06393,Oil level: dynamic average value,0, mm
IDE06567,Frequency counter deactivate start/stop function,0,
IDE06568,Stop prevention by driver frequency counter,5793,
IDE06569,Frequency counter vehicle standstill,6546,
IDE06610,Frequency counter vehicle standstill with stop,364,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system malfunction,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,ACC operating unit,
IDE06708-MAS00322,Cruise control switch actuation-Engaged OFF,No,
IDE06708-MAS00323,Cruise control switch actuation-Tap delay,No,
IDE06708-MAS00324,Cruise control switch actuation-Tap acceleration,No,
IDE06708-MAS00325,Cruise control switch actuation-Set,No,
IDE06708-MAS00326,Cruise control switch actuation-Resume,No,
IDE06708-MAS14965,Cruise control switch actuation-Plausibility check of main switch,No,
IDE06708-MAS14966,Cruise control switch actuation-Tip acceleration/deceleration second level,No,
IDE06708-MAS14967,Cruise control switch actuation-Operating error,No,
IDE06708-MAS14972,Cruise control switch actuation-Hardware signal main switch,No,
IDE06708-MAS14973,Cruise control switch actuation-Operating lever: Implausible coding,No,
IDE06708-MAS14974,Cruise control switch actuation-Limiter button pressed,No,
IDE06708-MAS14975,Cruise control switch actuation-Main switch off via CAN,No,
IDE06708-MAS14976,Cruise control switch actuation-variance adapted successfully,No,
IDE06709,ACC variants (coding),ACC with braking until at standstill/Stop & Go,
IDE06710,Cruise control system: permanent deactivation,Implausible control switch signals,
IDE06758,Air mass since engine start,327.67, g
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,not active,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,49.8, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,6590, km
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE07051,Engaged gear: raw signal,0,
IDE07164,Number injections,33907,
IDE07233-MAS07412,Bit string for status of oil level-Oil level OK,not active,
IDE07233-MAS07413,Bit string for status of oil level-Checking oil level,not active,
IDE07233-MAS07414,Bit string for status of oil level-Oil level monitoring,not active,
IDE07233-MAS07415,Bit string for status of oil level-Top up oil,not active,
IDE07233-MAS07416,Bit string for status of oil level-Top up oil immediately,not active,
IDE07233-MAS07417,Bit string for status of oil level-Reduce oil level,not active,
IDE07233-MAS07418,Bit string for status of oil level-Oil level not available,not active,
IDE07233-MAS07419,Bit string for status of oil level-Measmnt. not possible while engine running,not active,
IDE07233-MAS07420,Bit string for status of oil level-Engine not at oper. temp.,not active,
IDE07233-MAS07421,Bit string for status of oil level-Vehicle not in level position,not active,
IDE07233-MAS07422,Bit string for status of oil level-Oil level display,not active,
IDE07233-MAS07423,Bit string for status of oil level-Sensor faulty,not active,
IDE07234,Status bid for valid static oil level,Condition met,
IDE07235,Status bid for dynamic oil level,Condition not met,
IDE07374-MAS05852,Cylinder mass flow: act. value calculated-Mass flow,11.5, kg/h
IDE07375,Charge pressure before throttle valve: calculated actual value,0.976, bar
IDE07475,Throttle valve position 2,65.535, V
IDE07528-MAS12283,Coordinator releases for particulate filter regeneration-Components and systems fault-free,Condition met,
IDE07528-MAS12284,Coordinator releases for particulate filter regeneration-Tank level > Min. limit,Condition met,
IDE07528-MAS12285,Coordinator releases for particulate filter regeneration-Time after engine start: start driving > Min. the limit,Condition met,
IDE07528-MAS12286,Coordinator releases for particulate filter regeneration-Min. limit < driving speed < max. limit,Condition met,
IDE07528-MAS12287,Coordinator releases for particulate filter regeneration-Traction,Condition met,
IDE07528-MAS12288,Coordinator releases for particulate filter regeneration-Lowest gear: no gear shifting,Condition met,
IDE07528-MAS12289,Coordinator releases for particulate filter regeneration-Oxygen sensor before NSC operational and fault-free,Condition met,
IDE07528-MAS12290,Coordinator releases for particulate filter regeneration-Oxygen sensor after NSC operational and fault-free,Condition met,
IDE07528-MAS12291,Coordinator releases for particulate filter regeneration-Ambient pressure > Min. limit,Condition met,
IDE07528-MAS12292,Coordinator releases for particulate filter regeneration-Min. limit < ambient temperature < max. limit,Condition met,
IDE07528-MAS12293,Coordinator releases for particulate filter regeneration-Control module temp. < Max. limit,Condition met,
IDE07528-MAS12294,Coordinator releases for particulate filter regeneration-Fuel temp. < Max. limit,Condition met,
IDE07528-MAS12295,Coordinator releases for particulate filter regeneration-DPF fault-free,Condition met,
IDE07528-MAS12296,Coordinator releases for particulate filter regeneration-Metering release for SCR,Condition met,
IDE07528-MAS12297,Coordinator releases for particulate filter regeneration-Smoke limit inactive,Condition met,
IDE07528-MAS12298,Coordinator releases for particulate filter regeneration-Soot mass < Max. limit_1,Condition met,
IDE07528-MAS12299,Coordinator releases for particulate filter regeneration-Soot mass < Max. limit_2,Condition met,
IDE07528-MAS12300,Coordinator releases for particulate filter regeneration-Min. limit < engine speed < max. limit,Condition met,
IDE07528-MAS12301,Coordinator releases for particulate filter regeneration-Water quantity in charge air cooler < Max. limit,Condition met,
IDE07528-MAS12302,Coordinator releases for particulate filter regeneration-Internal torque < Max. limit,Condition met,
IDE07528-MAS12303,Coordinator releases for particulate filter regeneration-Internal torque > Min. limit,Condition met,
IDE07528-MAS12304,Coordinator releases for particulate filter regeneration-Min. limit < internal torque < max. limit,Condition met,
IDE07528-MAS12305,Coordinator releases for particulate filter regeneration-Dynamic internal torque < Max. limit,Condition met,
IDE07528-MAS12306,Coordinator releases for particulate filter regeneration-Positive control deviation motor filling < Max. limit,Condition met,
IDE07528-MAS12307,Coordinator releases for particulate filter regeneration-Negative control deviation motor filling > Min. limit,Condition met,
IDE07528-MAS12308,Coordinator releases for particulate filter regeneration-Min. limit < temperature after charge air cooler < max. limit,Condition met,
IDE07528-MAS12309,Coordinator releases for particulate filter regeneration-Min. limit < engine temperature < max. limit,Condition met,
IDE07528-MAS12310,Coordinator releases for particulate filter regeneration-Min. limit < combustion chamber temp. < max. limit,Condition met,
IDE07528-MAS12311,Coordinator releases for particulate filter regeneration-Combustion chamber temp. < Max. limit,Condition met,
IDE07528-MAS12312,Coordinator releases for particulate filter regeneration-Temperature before turbine < Max. limit,Condition met,
IDE07528-MAS12313,Coordinator releases for particulate filter regeneration-Temperature after DPF < Max. limit,Condition met,
IDE07528-MAS12314,Coordinator releases for particulate filter regeneration-Temperature after oxi cat. < Max. limit,Condition met,
IDE07528-MAS12315,Coordinator releases for particulate filter regeneration-Temperature after oxi cat. < Min. limit,Condition met,
IDE07528-MAS12316,Coordinator releases for particulate filter regeneration-NSC temperature < Max. limit,Condition met,
IDE07528-MAS12317,Coordinator releases for particulate filter regeneration-NSC temperature < Min. limit,Condition met,
IDE07528-MAS12318,Coordinator releases for particulate filter regeneration-Virtual temperature,Condition met,
IDE07528-MAS12611,Coordinator releases for particulate filter regeneration-Value,4294967295,
IDE07528,Coordinator releases for particulate filter regeneration,4294967295,
IDE07529-MAS12283,Coordinator releases: standard-Components and systems fault-free,Condition not met,
IDE07529-MAS12284,Coordinator releases: standard-Tank level > Min. limit,Condition not met,
IDE07529-MAS12285,Coordinator releases: standard-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07529-MAS12286,Coordinator releases: standard-Min. limit < driving speed < max. limit,Condition not met,
IDE07529-MAS12287,Coordinator releases: standard-Traction,Condition not met,
IDE07529-MAS12288,Coordinator releases: standard-Lowest gear: no gear shifting,Condition not met,
IDE07529-MAS12289,Coordinator releases: standard-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07529-MAS12290,Coordinator releases: standard-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07529-MAS12291,Coordinator releases: standard-Ambient pressure > Min. limit,Condition not met,
IDE07529-MAS12292,Coordinator releases: standard-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07529-MAS12293,Coordinator releases: standard-Control module temp. < Max. limit,Condition not met,
IDE07529-MAS12294,Coordinator releases: standard-Fuel temp. < Max. limit,Condition not met,
IDE07529-MAS12295,Coordinator releases: standard-DPF fault-free,Condition not met,
IDE07529-MAS12296,Coordinator releases: standard-Metering release for SCR,Condition not met,
IDE07529-MAS12297,Coordinator releases: standard-Smoke limit inactive,Condition not met,
IDE07529-MAS12298,Coordinator releases: standard-Soot mass < Max. limit_1,Condition not met,
IDE07529-MAS12299,Coordinator releases: standard-Soot mass < Max. limit_2,Condition not met,
IDE07529-MAS12300,Coordinator releases: standard-Min. limit < engine speed < max. limit,Condition not met,
IDE07529-MAS12301,Coordinator releases: standard-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07529-MAS12302,Coordinator releases: standard-Internal torque < Max. limit,Condition not met,
IDE07529-MAS12303,Coordinator releases: standard-Internal torque > Min. limit,Condition not met,
IDE07529-MAS12304,Coordinator releases: standard-Min. limit < internal torque < max. limit,Condition not met,
IDE07529-MAS12305,Coordinator releases: standard-Dynamic internal torque < Max. limit,Condition not met,
IDE07529-MAS12306,Coordinator releases: standard-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07529-MAS12307,Coordinator releases: standard-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07529-MAS12308,Coordinator releases: standard-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07529-MAS12309,Coordinator releases: standard-Min. limit < engine temperature < max. limit,Condition not met,
IDE07529-MAS12310,Coordinator releases: standard-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07529-MAS12311,Coordinator releases: standard-Combustion chamber temp. < Max. limit,Condition not met,
IDE07529-MAS12312,Coordinator releases: standard-Temperature before turbine < Max. limit,Condition not met,
IDE07529-MAS12313,Coordinator releases: standard-Temperature after DPF < Max. limit,Condition not met,
IDE07529-MAS12314,Coordinator releases: standard-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07529-MAS12315,Coordinator releases: standard-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07529-MAS12316,Coordinator releases: standard-NSC temperature < Max. limit,Condition not met,
IDE07529-MAS12317,Coordinator releases: standard-NSC temperature < Min. limit,Condition not met,
IDE07529-MAS12318,Coordinator releases: standard-Virtual temperature,Condition not met,
IDE07529-MAS12611,Coordinator releases: standard-Value,0,
IDE07529,Coordinator releases: standard,0,
IDE07532-MAS12283,Coordinator releases for short trip-Components and systems fault-free,Condition not met,
IDE07532-MAS12284,Coordinator releases for short trip-Tank level > Min. limit,Condition not met,
IDE07532-MAS12285,Coordinator releases for short trip-Time after engine start: start driving > Min. the limit,Condition not met,
IDE07532-MAS12286,Coordinator releases for short trip-Min. limit < driving speed < max. limit,Condition not met,
IDE07532-MAS12287,Coordinator releases for short trip-Traction,Condition not met,
IDE07532-MAS12288,Coordinator releases for short trip-Lowest gear: no gear shifting,Condition not met,
IDE07532-MAS12289,Coordinator releases for short trip-Oxygen sensor before NSC operational and fault-free,Condition not met,
IDE07532-MAS12290,Coordinator releases for short trip-Oxygen sensor after NSC operational and fault-free,Condition not met,
IDE07532-MAS12291,Coordinator releases for short trip-Ambient pressure > Min. limit,Condition not met,
IDE07532-MAS12292,Coordinator releases for short trip-Min. limit < ambient temperature < max. limit,Condition not met,
IDE07532-MAS12293,Coordinator releases for short trip-Control module temp. < Max. limit,Condition not met,
IDE07532-MAS12294,Coordinator releases for short trip-Fuel temp. < Max. limit,Condition not met,
IDE07532-MAS12295,Coordinator releases for short trip-DPF fault-free,Condition not met,
IDE07532-MAS12296,Coordinator releases for short trip-Metering release for SCR,Condition not met,
IDE07532-MAS12297,Coordinator releases for short trip-Smoke limit inactive,Condition not met,
IDE07532-MAS12298,Coordinator releases for short trip-Soot mass < Max. limit_1,Condition not met,
IDE07532-MAS12299,Coordinator releases for short trip-Soot mass < Max. limit_2,Condition not met,
IDE07532-MAS12300,Coordinator releases for short trip-Min. limit < engine speed < max. limit,Condition not met,
IDE07532-MAS12301,Coordinator releases for short trip-Water quantity in charge air cooler < Max. limit,Condition not met,
IDE07532-MAS12302,Coordinator releases for short trip-Internal torque < Max. limit,Condition not met,
IDE07532-MAS12303,Coordinator releases for short trip-Internal torque > Min. limit,Condition not met,
IDE07532-MAS12304,Coordinator releases for short trip-Min. limit < internal torque < max. limit,Condition not met,
IDE07532-MAS12305,Coordinator releases for short trip-Dynamic internal torque < Max. limit,Condition not met,
IDE07532-MAS12306,Coordinator releases for short trip-Positive control deviation motor filling < Max. limit,Condition not met,
IDE07532-MAS12307,Coordinator releases for short trip-Negative control deviation motor filling > Min. limit,Condition not met,
IDE07532-MAS12308,Coordinator releases for short trip-Min. limit < temperature after charge air cooler < max. limit,Condition not met,
IDE07532-MAS12309,Coordinator releases for short trip-Min. limit < engine temperature < max. limit,Condition not met,
IDE07532-MAS12310,Coordinator releases for short trip-Min. limit < combustion chamber temp. < max. limit,Condition not met,
IDE07532-MAS12311,Coordinator releases for short trip-Combustion chamber temp. < Max. limit,Condition not met,
IDE07532-MAS12312,Coordinator releases for short trip-Temperature before turbine < Max. limit,Condition not met,
IDE07532-MAS12313,Coordinator releases for short trip-Temperature after DPF < Max. limit,Condition not met,
IDE07532-MAS12314,Coordinator releases for short trip-Temperature after oxi cat. < Max. limit,Condition not met,
IDE07532-MAS12315,Coordinator releases for short trip-Temperature after oxi cat. < Min. limit,Condition not met,
IDE07532-MAS12316,Coordinator releases for short trip-NSC temperature < Max. limit,Condition not met,
IDE07532-MAS12317,Coordinator releases for short trip-NSC temperature < Min. limit,Condition not met,
IDE07532-MAS12318,Coordinator releases for short trip-Virtual temperature,Condition not met,
IDE07532-MAS12611,Coordinator releases for short trip-Value,0,
IDE07532,Coordinator releases for short trip,0,
IDE07534,Target operating mode for engine,16846880,
IDE07535,Current operating mode of engine,16846880,
IDE07536,Next requested operating mode for engine,16846880,
IDE07548,Engine temp. mangmt. actuator: specified value of angle,70.21, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,70.14, °
IDE07550,Engine temp. management actuator: raw value,664,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Start,
IDE07553,Engine temperature management actuator: after-run stop,0,
IDE07554,Engine temperature management actuator: stop open,133,
IDE07571,Engine torque,27.0, Nm
IDE07605,Cruise control system: temporary deactivation,ESP/ASR set to passive during ACC without brake intervention,
IDE07608,Standard test of current section,0,
IDE07706,Outside temperature sensor 1: B1: raw value,30.0, °C
IDE07710,Charge air cooler output: temp. sensor 1: B1: raw value,51.2, °C
IDE07724,Coolant temperature at engine outlet: calculated,90.5, °C
IDE07725,Coolant temperature sensor 1: B1: on cylinder head: raw value,90.5, °C
IDE07726,Coolant temperature sensor 1: B1: on cylinder head: raw voltage,0.972, V
IDE07727,Coolant temperature sensor 1: B1: on radiator output: raw value,50.5, °C
IDE07733,Ambient air pressure sensor 1 bank 1: raw value,0.974, bar
IDE07738,Charge air cooler inlet: pressure sensor 1 bank 1: raw value,482, mbar
IDE07739,Charge air cooler inlet: press.sensor 1 bank 1: uncnd. voltage,0.705, V
IDE07768,Throttle valve adapter 1 bank 1: activation,-10.67, %
IDE07769,Throttle valve adapter 1 bank 1: position feedback  uncnd. voltage,0.715, V
IDE07770,Throttle valve adapter 1 bank 1: position feedback  specified value,4.81, %
IDE07771,Throttle valve adapter 1 bank 1: position feedback  actual value,4.86, %
IDE07783,Turbine actuator 1 bank 1: position feedback  uncnd. voltage,3.855, V
IDE07784,Turbine actuator 1 bank 1: position feedback  specified value,0.00, %
IDE07785,Turbine actuator 1 bank 1: position feedback  actual value,0.00, %
IDE07786,Turbine actuator 1 bank 1: position feedback  offset closed,0.00, %
IDE07787,Turbine actuator 1 bank 1: position feedback  mechanical stops,0,
IDE07788,Turbine actuator 1 bank 1: position feedback  breakaway attempts,0,
IDE07789,Turbine actuator 1 bank 1: activation,3.09, %
IDE07796-ENG114825,Turbocharger 1 turbine bypass valve 1 bank 1: position feedback  breakaway attempts-Ident_32,0,
IDE07798,Heater support pump 1 bank 1 second.circuit: activat.,10.00, %
IDE07812,Transmission neutral position sensor 1: raw value,36.54, %
IDE07815-MAS09445,Transmission neutral position sensor: adaptation status-Release of neutral gear output stage,not active,
IDE07815-MAS09446,Transmission neutral position sensor: adaptation status-Neutral gear detected,active,
IDE07815-MAS09447,Transmission neutral position sensor: adaptation status-Neutral gear sensor - stop override,active,
IDE07815-MAS09448,Transmission neutral position sensor: adaptation status-Neutral gear sensor adaptation completed for neutral gear,active,
IDE07815-MAS09449,Transmission neutral position sensor: adaptation status-Neutral gear sensor adaption,active,
IDE07815,Transmission neutral position sensor: adaptation status,0,
IDE07818,Fuel high pressure sensor: actual value,227.7, bar
IDE07819,Fuel high pressure sensor: unconditioned voltage,2.324, V
IDE07826,Accelerator pedal travel: raw value,0.00, %
IDE07827,Accelerator pedal: sensor voltage 1,0.718, V
IDE07828,Accelerator pedal: sensor voltage 2,0.361, V
IDE07832,Coolant fan 1: activation,60.00, %
IDE07833,Coolant fan 2: activation,0.00, %
IDE07834-MAS09443,Status of starter activation relay-Relay 1 activated,not active,
IDE07834-MAS09444,Status of starter activation relay-Relay 2 activated,not active,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07916,Oxygen sensor bank 1 after oxi cat: exhaust temperat.calculated,411.7, °C
IDE07936,Oxyg.sens.bank 1 before oxi cat:act.-integr.pump curr.adapt.,0.000, A
IDE08064,Mass airflow sensor 1 bank 1 temperature sensor: raw value,30.0, °C
IDE08065,Mass airflow sensor 1 bank 1 temperature sensor: raw value,0.000, V
IDE08562,Basic correction factor: Injector cyl. 1: filtered,1,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,1,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,1,
IDE09340,Primary injection: quantity setpoint,9.17, mg/stroke
IDE09842,Delete engine diagnostic stat. since error memory (end-of-line),4294967295,
IDE09843,Delete engine diagn. stat. 2 since error memory (end-of-line),4294967295,
IDE09878,O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value,0.683, V
IDE09879,O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current,0.000, A
IDE09880,O2 sens. 1 bank 1 upstrm oxi cat: raw value,1.003, counts
IDE09881,O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value,65.535, V
IDE09984,Torque limit due to knock regulation,100.00, %
IDE09990,Amount of fuel in engine oil,2, g
IDE10049,Ignition angle cyl. 1,5.6, °
IDE10050,Ignition angle cyl. 2,5.7, °
IDE10051,Ignition angle cyl. 3,6.4, °
IDE10063-MAS00666,Engine oil level: current value-Warning,no warning,
IDE10063-MAS00900,Engine oil level: current value-Oil level,111.80, %
IDE10063-MAS09802,Engine oil level: current value-Odometer reading at entry,18917, km
IDE10063-MAS09803,Engine oil level: current value-Odometer reading when determining oil level,18917, km
IDE10063-MAS09804,Engine oil level: current value-Test method 1,On,
IDE10063-MAS09805,Engine oil level: current value-Test method 2,On,
IDE10063-MAS09806,Engine oil level: current value-Test method 3,OFF,
IDE10063-MAS09807,Engine oil level: current value-Qualification,512,
IDE10064-MAS00666,Engine oil level: history 1-Warning,no warning,
IDE10064-MAS00900,Engine oil level: history 1-Oil level,118.40, %
IDE10064-MAS09802,Engine oil level: history 1-Odometer reading at entry,18378, km
IDE10064-MAS09803,Engine oil level: history 1-Odometer reading when determining oil level,18362, km
IDE10064-MAS09804,Engine oil level: history 1-Test method 1,On,
IDE10064-MAS09805,Engine oil level: history 1-Test method 2,On,
IDE10064-MAS09806,Engine oil level: history 1-Test method 3,OFF,
IDE10064-MAS09807,Engine oil level: history 1-Qualification,1792,
IDE10065-MAS00666,Engine oil level: history 2-Warning,no warning,
IDE10065-MAS00900,Engine oil level: history 2-Oil level,109.90, %
IDE10065-MAS09802,Engine oil level: history 2-Odometer reading at entry,17701, km
IDE10065-MAS09803,Engine oil level: history 2-Odometer reading when determining oil level,17653, km
IDE10065-MAS09804,Engine oil level: history 2-Test method 1,On,
IDE10065-MAS09805,Engine oil level: history 2-Test method 2,On,
IDE10065-MAS09806,Engine oil level: history 2-Test method 3,OFF,
IDE10065-MAS09807,Engine oil level: history 2-Qualification,1792,
IDE10066-MAS00666,Engine oil level: history 3-Warning,no warning,
IDE10066-MAS00900,Engine oil level: history 3-Oil level,111.50, %
IDE10066-MAS09802,Engine oil level: history 3-Odometer reading at entry,17082, km
IDE10066-MAS09803,Engine oil level: history 3-Odometer reading when determining oil level,17043, km
IDE10066-MAS09804,Engine oil level: history 3-Test method 1,On,
IDE10066-MAS09805,Engine oil level: history 3-Test method 2,On,
IDE10066-MAS09806,Engine oil level: history 3-Test method 3,OFF,
IDE10066-MAS09807,Engine oil level: history 3-Qualification,1792,
IDE10067-MAS00666,Engine oil level: history 4-Warning,no warning,
IDE10067-MAS00900,Engine oil level: history 4-Oil level,116.50, %
IDE10067-MAS09802,Engine oil level: history 4-Odometer reading at entry,16410, km
IDE10067-MAS09803,Engine oil level: history 4-Odometer reading when determining oil level,16332, km
IDE10067-MAS09804,Engine oil level: history 4-Test method 1,On,
IDE10067-MAS09805,Engine oil level: history 4-Test method 2,On,
IDE10067-MAS09806,Engine oil level: history 4-Test method 3,OFF,
IDE10067-MAS09807,Engine oil level: history 4-Qualification,1792,
IDE10068-MAS00666,Engine oil level: history 5-Warning,no warning,
IDE10068-MAS00900,Engine oil level: history 5-Oil level,115.00, %
IDE10068-MAS09802,Engine oil level: history 5-Odometer reading at entry,15790, km
IDE10068-MAS09803,Engine oil level: history 5-Odometer reading when determining oil level,15771, km
IDE10068-MAS09804,Engine oil level: history 5-Test method 1,On,
IDE10068-MAS09805,Engine oil level: history 5-Test method 2,On,
IDE10068-MAS09806,Engine oil level: history 5-Test method 3,OFF,
IDE10068-MAS09807,Engine oil level: history 5-Qualification,1792,
IDE10069-MAS00666,Engine oil level: history 6-Warning,no warning,
IDE10069-MAS00900,Engine oil level: history 6-Oil level,121.90, %
IDE10069-MAS09802,Engine oil level: history 6-Odometer reading at entry,15122, km
IDE10069-MAS09803,Engine oil level: history 6-Odometer reading when determining oil level,15055, km
IDE10069-MAS09804,Engine oil level: history 6-Test method 1,On,
IDE10069-MAS09805,Engine oil level: history 6-Test method 2,On,
IDE10069-MAS09806,Engine oil level: history 6-Test method 3,OFF,
IDE10069-MAS09807,Engine oil level: history 6-Qualification,1792,
IDE10070-MAS00666,Engine oil level: history 7-Warning,no warning,
IDE10070-MAS00900,Engine oil level: history 7-Oil level,118.00, %
IDE10070-MAS09802,Engine oil level: history 7-Odometer reading at entry,14502, km
IDE10070-MAS09803,Engine oil level: history 7-Odometer reading when determining oil level,14482, km
IDE10070-MAS09804,Engine oil level: history 7-Test method 1,On,
IDE10070-MAS09805,Engine oil level: history 7-Test method 2,On,
IDE10070-MAS09806,Engine oil level: history 7-Test method 3,OFF,
IDE10070-MAS09807,Engine oil level: history 7-Qualification,1792,
IDE10071-MAS00666,Engine oil level: history 8-Warning,no warning,
IDE10071-MAS00900,Engine oil level: history 8-Oil level,112.10, %
IDE10071-MAS09802,Engine oil level: history 8-Odometer reading at entry,13860, km
IDE10071-MAS09803,Engine oil level: history 8-Odometer reading when determining oil level,13811, km
IDE10071-MAS09804,Engine oil level: history 8-Test method 1,On,
IDE10071-MAS09805,Engine oil level: history 8-Test method 2,On,
IDE10071-MAS09806,Engine oil level: history 8-Test method 3,OFF,
IDE10071-MAS09807,Engine oil level: history 8-Qualification,1792,
IDE10072-MAS00666,Engine oil level: history 9-Warning,no warning,
IDE10072-MAS00900,Engine oil level: history 9-Oil level,117.50, %
IDE10072-MAS09802,Engine oil level: history 9-Odometer reading at entry,13166, km
IDE10072-MAS09803,Engine oil level: history 9-Odometer reading when determining oil level,13160, km
IDE10072-MAS09804,Engine oil level: history 9-Test method 1,On,
IDE10072-MAS09805,Engine oil level: history 9-Test method 2,On,
IDE10072-MAS09806,Engine oil level: history 9-Test method 3,OFF,
IDE10072-MAS09807,Engine oil level: history 9-Qualification,1792,
IDE10223-MAS09705,Install. list for actuators bank 1-High press. turbocharger actuator,Not supported,
IDE10223-MAS09706,Install. list for actuators bank 1-Low press. turbocharger actuator,Not supported,
IDE10223-MAS09707,Install. list for actuators bank 1-High press. turbocharger bypass valve,Not supported,
IDE10223-MAS09708,Install. list for actuators bank 1-Throttle valve,Not supported,
IDE10223-MAS09709,Install. list for actuators bank 1-High press. exh. gas recirc. actuator,Not supported,
IDE10223-MAS09710,Install. list for actuators bank 1-Low press. exh. gas recirc. actuator,Not supported,
IDE10223-MAS09711,Install. list for actuators bank 1-Exhaust flap,Not supported,
IDE10223-MAS09712,Install. list for actuators bank 1-Coolant pump,Not supported,
IDE10223-MAS09713,Install. list for actuators bank 1-Coolant pump load charge cooler,Not supported,
IDE10223-MAS09714,Install. list for actuators bank 1-Swirl flap,Not supported,
IDE10223-MAS09715,Install. list for actuators bank 1-Variable valve operation actuator,Not supported,
IDE10223-MAS09716,Install. list for actuators bank 1-Radiator shutter,Not supported,
IDE10223-MAS09717,Install. list for actuators bank 1-Coolant pump: short circuit,Not supported,
IDE10223-MAS09718,Install. list for actuators bank 1-Valve for exh. gas recirc. cooler HP,Not supported,
IDE10223,Install. list for actuators bank 1,0,
IDE10224-MAS09678,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm of air filter,Not supported,
IDE10224-MAS09679,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm. of turbocharger LP,Not supported,
IDE10224-MAS09680,Install. list for pressure and O2 sensors bank 1-Press. sens. upstrm. of charg. air cool.,Not supported,
IDE10224-MAS09681,Install. list for pressure and O2 sensors bank 1-Pressure sensor above particulate filter,Not supported,
IDE10224-MAS09682,Install. list for pressure and O2 sensors bank 1-Press. sensor above exh. gas recirc. LP,Not supported,
IDE10224-MAS09684,Install. list for pressure and O2 sensors bank 1-Oxygen sensor upstrm. of oxidation cat.,Not supported,
IDE10224-MAS09685,Install. list for pressure and O2 sensors bank 1-Oxygen sensor dwnstrm. of oxidation cat.,Not supported,
IDE10224-MAS09686,Install. list for pressure and O2 sensors bank 1-Knox sensor upstrm. of SCAR cat.,Not supported,
IDE10224-MAS09687,Install. list for pressure and O2 sensors bank 1-NOx sensor dwnstrm. of SCR cat.,Not supported,
IDE10224-MAS09688,Install. list for pressure and O2 sensors bank 1-Cylinder press. sensor,Not supported,
IDE10224-MAS09689,Install. list for pressure and O2 sensors bank 1-Particulate sensor,Not supported,
IDE10224-MAS09690,Install. list for pressure and O2 sensors bank 1-Knock Sensor (KS),Not supported,
IDE10224-MAS09691,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm of air filter (SENT),Not supported,
IDE10224-MAS09692,Install. list for pressure and O2 sensors bank 1-Press. sens. dwnstrm. of turbocharger LP (SENT),Not supported,
IDE10224-MAS09693,Install. list for pressure and O2 sensors bank 1-Press. sens. upstrm. of charg. air cool. (SENT),Not supported,
IDE10224-MAS09694,Install. list for pressure and O2 sensors bank 1-Press. sens. above particulate filter (SENT),Not supported,
IDE10224-MAS09695,Install. list for pressure and O2 sensors bank 1-Press. sensor above exh. gas recirc. LP (SENT),Not supported,
IDE10224-MAS09697,Install. list for pressure and O2 sensors bank 1-Oxygen sensor upstrm. of oxidation cat. (SENT),Not supported,
IDE10224-MAS09698,Install. list for pressure and O2 sensors bank 1-Oxygen sensor dwnstrm. of oxidation cat. (SENT),Not supported,
IDE10224-MAS09699,Install. list for pressure and O2 sensors bank 1-NOx sensor upstrm. of SCAR cat. (SENT),Not supported,
IDE10224-MAS09700,Install. list for pressure and O2 sensors bank 1-NOx sensor dwnstrm. of SCAR cat. (SENT),Not supported,
IDE10224-MAS09701,Install. list for pressure and O2 sensors bank 1-Cylinder press. sensor (SENT),Not supported,
IDE10224-MAS09702,Install. list for pressure and O2 sensors bank 1-Particle sensor (SENT),Not supported,
IDE10224-MAS09703,Install. list for pressure and O2 sensors bank 1-Knock sensor (SENT),Not supported,
IDE10224,Install. list for pressure and O2 sensors bank 1,0,
IDE10225-MAS08988,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. upstrm of turbocharger,Not supported,
IDE10225-MAS08989,Install. list for temperature sensors bank 1-Exh. gas temperature sensor upstrm. of oxidation cat.,Not supported,
IDE10225-MAS08990,Install. list for temperature sensors bank 1-Exh. gas temperature sensor dwnstrm. of oxidation cat.,Not supported,
IDE10225-MAS09653,Install. list for temperature sensors bank 1-Exhaust gas temperature sensor upstream of particulate filter,Not supported,
IDE10225-MAS09654,Install. list for temperature sensors bank 1-Exhaust gas temperature sensor downstream of particulate filter,Not supported,
IDE10225-MAS09655,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. LP,Not supported,
IDE10225-MAS09656,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. HP,Not supported,
IDE10225-MAS09657,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of radiator,Not supported,
IDE10225-MAS09658,Install. list for temperature sensors bank 1-Coolant temp. sensor dwnstrm. of radiator,Not supported,
IDE10225-MAS09659,Install. list for temperature sensors bank 1-Coolant temp. sensor in cylinder head,Not supported,
IDE10225-MAS09660,Install. list for temperature sensors bank 1-Intake air temperature sensor in mass airflow sensor,Not supported,
IDE10225-MAS09661,Install. list for temperature sensors bank 1-Intake air temp. sensor upstrm. of charge air cooler,Not supported,
IDE10225-MAS09662,Install. list for temperature sensors bank 1-Intake air temp. sensor dwnstrm. of charge air cooler,Not supported,
IDE10225-MAS09663,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of exh.gas recirc. cooler HP,Not supported,
IDE10225-MAS09664,Install. list for temperature sensors bank 1-Exh. gas temp. sens. upstrm. of turbocharger (SENT),Not supported,
IDE10225-MAS09665,Install. list for temperature sensors bank 1-Exhaust gas temp. sensor upstrm. of oxidation cat. (SENT),Not supported,
IDE10225-MAS09666,Install. list for temperature sensors bank 1-Exhaust gas temp. sensor dwnstrm. of oxidation cat. (SENT),Not supported,
IDE10225-MAS09667,Install. list for temperature sensors bank 1-Exhaust gas temperature sensor upstream of particulate filter (SENT),Not supported,
IDE10225-MAS09668,Install. list for temperature sensors bank 1-Exhaust gas temperature sensor downstream of particulate filter (SENT),Not supported,
IDE10225-MAS09669,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. LP (SENT),Not supported,
IDE10225-MAS09670,Install. list for temperature sensors bank 1-Sensor for exh. gas temp. exh. gas recirc. HP (SENT),Not supported,
IDE10225-MAS09671,Install. list for temperature sensors bank 1-Coolant temp. sensor upstrm. of radiator (SENT),Not supported,
IDE10225-MAS09672,Install. list for temperature sensors bank 1-Coolant temp. sensor dwnstrm. of radiator (SENT),Not supported,
IDE10225-MAS09673,Install. list for temperature sensors bank 1-Coolant temp. sensor in cylinder head (SENT),Not supported,
IDE10225-MAS09674,Install. list for temperature sensors bank 1-Intake air temperature sensor in mass airflow sensor (SENT),Not supported,
IDE10225-MAS09675,Install. list for temperature sensors bank 1-Intake air temp. sensor upstrm. of charge air cooler (SENT),Not supported,
IDE10225-MAS09676,Install. list for temperature sensors bank 1-Intake air temp. sensor dwnstrm. of charge air cooler (SENT),Not supported,
IDE10225-MAS09677,Install. list for temperature sensors bank 1-Coolant temperature sensor upstream of radiator exhaust gas recirculation high pressure (SENT),Not supported,
IDE10225,Install. list for temperature sensors bank 1,0,
IDE10302,Time since engine start,1418, s
IDE10316-IDE11376,Turbine actuator 1 bank 1: monitoring - status-Recognition of actuator closed or jammed open 2,not active,
IDE10316-MAS09413,Turbine actuator 1 bank 1: monitoring - status-open mech. stop approached,not active,
IDE10316-MAS09414,Turbine actuator 1 bank 1: monitoring - status-closed mech. stop approached,not active,
IDE10316-MAS09415,Turbine actuator 1 bank 1: monitoring - status-Adaptations met for offset on the mechan. stops,not active,
IDE10316-MAS09416,Turbine actuator 1 bank 1: monitoring - status-Learning function active,not active,
IDE10316-MAS09417,Turbine actuator 1 bank 1: monitoring - status-open mech. stop adapted properly in current drive cycle,not active,
IDE10316-MAS09418,Turbine actuator 1 bank 1: monitoring - status-closed mech. stop adapted properly in current drive cycle,not active,
IDE10316-MAS09419,Turbine actuator 1 bank 1: monitoring - status-Adapt. funct. success.: duration active until next adaptation,not active,
IDE10316-MAS09420,Turbine actuator 1 bank 1: monitoring - status-Ctrl. dev. detect. after contact bounce suppr.,not active,
IDE10316-MAS09421,Turbine actuator 1 bank 1: monitoring - status-Ctrl. dev. detected after after breakaway function,not active,
IDE10316-MAS09422,Turbine actuator 1 bank 1: monitoring - status-Valve/actuator active: eng. running,active,
IDE10316-MAS09423,Turbine actuator 1 bank 1: monitoring - status-Valve/actuator active: eng. off,not active,
IDE10316-MAS09424,Turbine actuator 1 bank 1: monitoring - status-Breakaway function active,not active,
IDE10316-MAS09425,Turbine actuator 1 bank 1: monitoring - status-Effective current limit. limited at controller output,not active,
IDE10316-MAS09426,Turbine actuator 1 bank 1: monitoring - status-Actuator in shut-off position,not active,
IDE10316-MAS09427,Turbine actuator 1 bank 1: monitoring - status-Breakaway function unsuccessful: actuator control deactivated,not active,
IDE10316-MAS09428,Turbine actuator 1 bank 1: monitoring - status-Error in limit setter: position control is deactivated,not active,
IDE10316-MAS09429,Turbine actuator 1 bank 1: monitoring - status-Breakaway function is lowered,not active,
IDE10316-MAS09433,Turbine actuator 1 bank 1: monitoring - status-higher voltage should press valve closed when at mech. stop,not active,
IDE10316-MAS09434,Turbine actuator 1 bank 1: monitoring - status-Positioner detected as closed or jammed in open pos.,not active,
IDE10316-MAS09435,Turbine actuator 1 bank 1: monitoring - status-Resetting of adaptation values,not active,
IDE10316-MAS09436,Turbine actuator 1 bank 1: monitoring - status-Ambient air temperature permits adaptation,active,
IDE10316-MAS09437,Turbine actuator 1 bank 1: monitoring - status-Exh. gas temp. permits adaptation,active,
IDE10316-MAS09438,Turbine actuator 1 bank 1: monitoring - status-Engine temp. permits adaptation,active,
IDE10316-MAS09439,Turbine actuator 1 bank 1: monitoring - status-Battery voltage permits adaptation,active,
IDE10316-MAS09440,Turbine actuator 1 bank 1: monitoring - status-Ambient press. permits adaptation,active,
IDE10316-MAS09441,Turbine actuator 1 bank 1: monitoring - status-Eng. run. time permits adaptation,active,
IDE10316-MAS09442,Turbine actuator 1 bank 1: monitoring - status-Brake function active,not active,
IDE10316,Turbine actuator 1 bank 1: monitoring - status,1056966656,
IDE10560,Adaption of radiator shutters: status,not completed successfully,
IDE10580,Engine oil level: test method 1,195.20, %
IDE10581,Engine oil level: test method 2,109.30, %
IDE10582,Engine oil level: test method 3,102.30, %
IDE10633,Clutch protection function: reduced torque,3276.0, Nm
IDE10634,Clutch protection function: slip speed of the clutch,-1, /min
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10732,Engine oil level: factor volume,45.00,
IDE10968,Activation radiator shutter result,0.00, %
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,4,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11067,Index of next requested engine mode,1,
IDE11068,Index of current engine mode,1,
IDE11069,Index of engine target mode,1,
IDE11112,Fuel pres.sens.1 bank 1 upstr from HD pump: act.val. filtered,0.000, bar
IDE11115,Start/stop driver request: counter restart by starter,40,
IDE11116,Start/stop driver request: counter internal-motor restart,12,
IDE11267,Oil level: max. value: relative,148.20, %
IDE11268,Oil level: min. value: relative,85.90, %
IDE11302-MAS05513,Engine oil level: test method 1 qualification-Bit 0,1,
IDE11302,Engine oil level: test method 1 qualification,NO VALUE AVAILABLE,
IDE11303-MAS05513,Engine oil level: test method 3 qualification-Bit 0,2,
IDE11303,Engine oil level: test method 3 qualification,Engine hood was open,
IDE11330,Oil press. control valve: activation pulse duty factor,31.00, %
IDE11331-MAS03057,Torque reduction: clutch protection history 1-Kilometres,0, km
IDE11331-MAS10499,Torque reduction: clutch protection history 1-Torque,0, Nm
IDE11332-MAS03057,Torque reduction: clutch protection history 2-Kilometres,0, km
IDE11332-MAS10499,Torque reduction: clutch protection history 2-Torque,0, Nm
IDE11333-MAS03057,Torque reduction: clutch protection history 3-Kilometres,0, km
IDE11333-MAS10499,Torque reduction: clutch protection history 3-Torque,0, Nm
IDE11334-MAS03057,Torque reduction: clutch protection history 4-Kilometres,0, km
IDE11334-MAS10499,Torque reduction: clutch protection history 4-Torque,0, Nm
IDE11335-MAS03057,Torque reduction: clutch protection history 5-Kilometres,0, km
IDE11335-MAS10499,Torque reduction: clutch protection history 5-Torque,0, Nm
IDE11336-MAS03057,Torque reduction: clutch protection history 6-Kilometres,0, km
IDE11336-MAS10499,Torque reduction: clutch protection history 6-Torque,0, Nm
IDE11337-MAS03057,Torque reduction: clutch protection history 7-Kilometres,0, km
IDE11337-MAS10499,Torque reduction: clutch protection history 7-Torque,0, Nm
IDE11338-MAS03057,Torque reduction: clutch protection history 8-Kilometres,0, km
IDE11338-MAS10499,Torque reduction: clutch protection history 8-Torque,0, Nm
IDE11339-MAS03057,Torque reduction: clutch protection history 9-Kilometres,0, km
IDE11339-MAS10499,Torque reduction: clutch protection history 9-Torque,0, Nm
IDE11340-MAS03057,Torque reduction: clutch protection history 10-Kilometres,0, km
IDE11340-MAS10499,Torque reduction: clutch protection history 10-Torque,0, Nm
IDE11392,Activation of radiator shutter 2,0.00, %
IDE11574,Status max. oil level dynamically exceeded,No,
IDE11575,Status max. oil level permanently exceeded,No,
IDE11576,Oil level: last valid dynamic value overfilling,0.0, mm
IDE11577-MAS04415,Stop process prevented 2-Ambient air pressure,not active,
IDE11577-MAS04416,Stop process prevented 2-Sporadic function prevention,active,
IDE11577-MAS04417,Stop process prevented 2-Poor start detection,not active,
IDE11577-MAS04589,Stop process prevented 2-Diagnosis of exhaust system,not active,
IDE11577-MAS04590,Stop process prevented 2-Mixture adaptation,not active,
IDE11577-MAS04591,Stop process prevented 2-Air system diagnosis,not active,
IDE11577-MAS04870,Stop process prevented 2-Thermostat testing not completed,not active,
IDE11577-MAS06602,Stop process prevented 2-Engine temperature,not active,
IDE11577-MAS06604,Stop process prevented 2-Start/stop sensors:,active,
IDE11577-MAS06605,Stop process prevented 2-Regeneration Mode,not active,
IDE11577-MAS06606,Stop process prevented 2-Brake under pressure too low,not active,
IDE11577-MAS08032,Stop process prevented 2-DTC memory entry in engine control module,not active,
IDE11577-MAS09416,Stop process prevented 2-Learning function active,not active,
IDE11577-MAS13644,Stop process prevented 2-Engine protection active,not active,
IDE11577-MAS13645,Stop process prevented 2-Fuel gelling protection active,not active,
IDE11577-MAS13661,Stop process prevented 2-Exhaust treatment diagnosis,not active,
IDE11577-MAS16918,Stop process prevented 2-Restriction in start system,not active,
IDE11635,Radiator shutter 1: status referencing,completed successfully,
IDE12044,Crankshaft Position adapt.: write attempt counter,2,
IDE12074,Position adapt. of intake camshaft bank 1: counter,2,
IDE12077,Position adapt. of outlet camshaft bank 1: counter,2,
IDE12078,Position adapt. of camshafts cyl: individual bank 1: counter,2,
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,-0.86, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,1.30, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,0.76, %
IDE12355,ESI: consumption equivalent of the engine control module,0.00000024,
IDE12456,Turbocharger 1 positioner 1 bank 1 position feedback  adaption value,1.001, V
IDE12459,Turbocharger 1 positioner 1 bank 1 position feedback  initial teach-in,0, counts
IDE12468,Login counter of the simulation interface,0,
IDE12748,Oil level: amount added MIN to MAX,1000, ml
IDE13845,Production mode status,not active,
IDE13867-IDE02697,Stopping requirements for active participant 2-Multifunction unit control module,not active,
IDE13867-MAS00124,Stopping requirements for active participant 2-A/C system,not active,
IDE13867-MAS00127,Stopping requirements for active participant 2-Brake,not active,
IDE13867-MAS00506,Stopping requirements for active participant 2-Adaptive Cruise Control,not active,
IDE13867-MAS00832,Stopping requirements for active participant 2-Convertible top control module,not active,
IDE13867-MAS01090,Stopping requirements for active participant 2-Gearbox,not active,
IDE13867-MAS01106,Stopping requirements for active participant 2-Level control system,not active,
IDE13867-MAS01490,Stopping requirements for active participant 2-Energy management,not active,
IDE13867-MAS01627,Stopping requirements for active participant 2-Steering,not active,
IDE13867-MAS02237,Stopping requirements for active participant 2-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE13867-MAS02569,Stopping requirements for active participant 2-All-wheel drive electronics,not active,
IDE13867-MAS03757,Stopping requirements for active participant 2-Quattro Sport,not active,
IDE13867-MAS05129,Stopping requirements for active participant 2-Motor,active,
IDE13867-MAS06709,Stopping requirements for active participant 2-Keyless operation,not active,
IDE13867-MAS08785,Stopping requirements for active participant 2-Parking aid,not active,
IDE13867-MAS10687,Stopping requirements for active participant 2-Front Axle Lift System,not active,
IDE13867-MAS13018,Stopping requirements for active participant 2-Front sensor for driver assistance systems,not active,
IDE13868-IDE02697,System malfunctions for active participants start/stop 2-Multifunction unit control module,not active,
IDE13868-MAS00124,System malfunctions for active participants start/stop 2-A/C system,not active,
IDE13868-MAS00127,System malfunctions for active participants start/stop 2-Brake,not active,
IDE13868-MAS00506,System malfunctions for active participants start/stop 2-Adaptive Cruise Control,not active,
IDE13868-MAS00832,System malfunctions for active participants start/stop 2-Convertible top control module,not active,
IDE13868-MAS01090,System malfunctions for active participants start/stop 2-Gearbox,not active,
IDE13868-MAS01106,System malfunctions for active participants start/stop 2-Level control system,not active,
IDE13868-MAS01490,System malfunctions for active participants start/stop 2-Energy management,not active,
IDE13868-MAS01627,System malfunctions for active participants start/stop 2-Steering,not active,
IDE13868-MAS02237,System malfunctions for active participants start/stop 2-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE13868-MAS02569,System malfunctions for active participants start/stop 2-All-wheel drive electronics,not active,
IDE13868-MAS03757,System malfunctions for active participants start/stop 2-Quattro Sport,not active,
IDE13868-MAS05129,System malfunctions for active participants start/stop 2-Motor,not active,
IDE13868-MAS06709,System malfunctions for active participants start/stop 2-Keyless operation,not active,
IDE13868-MAS08785,System malfunctions for active participants start/stop 2-Parking aid,not active,
IDE13868-MAS10687,System malfunctions for active participants start/stop 2-Front Axle Lift System,not active,
IDE13868-MAS13018,System malfunctions for active participants start/stop 2-Front sensor for driver assistance systems,not active,
IDE14753,Particulate filter: loading stage,0, counts
IDE14755,Particulate filter: blockage ratio calculated: relative,45.1, %
IDE14756,Particulate filter: blockage ratio calculated: absolute,0.0, %
IDE14760,Particulate filter: oil ash load measured,0.0, %
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.0, %
IDE14765,Particulate filter: soot load measured,6.3, %
IDE14767,Particulate filter: soot load calculated,6.3, %
IDE14789-ENG252532,Currently selected and last used starter device-active start device selection - belt starter generator,not selected,
IDE14789-ENG252533,Currently selected and last used starter device-active start device selection - electrical machine,not selected,
IDE14789-ENG252534,Currently selected and last used starter device-active start device selection - pinion starter,selected,
IDE14789-ENG252584,Currently selected and last used starter device-last used start device - belt starter generator,not active,
IDE14789-ENG252585,Currently selected and last used starter device-last used start device - electrical machine,not active,
IDE14789-ENG252586,Currently selected and last used starter device-last used start device - pinion starter,active,
IDE15721,Piston cooling nozzles: relative tolerance counter,100, %
IDE15722,Piston cooling nozzles: relative defect counter,0, %
IDE15976-ENG275973,Particulate filter regeneration history-Endkilometer 1,0, km
IDE15976-ENG275974,Particulate filter regeneration history-Endkilometer 2,0, km
IDE15976-ENG275975,Particulate filter regeneration history-Endkilometer 3,0, km
IDE15976-ENG275971,Particulate filter regeneration history-Startkilometer 1,0, km
IDE15976-ENG275970,Particulate filter regeneration history-Startkilometer 2,0, km
IDE15976-ENG275972,Particulate filter regeneration history-Startkilometer 3,0, km
IDE16075,Engine oil: calculated water quantity,0, g
MAS13794,Name of control module,|ECU,ECUNAME|ECM
MAS16222,Heated oxygen sensor bank 1 probe 1: status 2G,1, no unit
MAS16223,Heated oxygen sensor bank 1 probe 2: status 2G,1, no unit
MAS16299,Heated oxygen sensor 1 probe 1: status dew point end,detected,
MAS16300,Heated oxygen sensor 1 probe 2: status dew point end,detected,
MAS17031,Radiator shutter 1: actual position,0, %
MAS17032,Radiator shutter 2: actual position,0, %
MAS17189,Exhaust pressure sensor 1: raw value,1027, mbar
MAS17190,Exhaust back pressure sensor 1: voltage raw value,0.884, V
MAS17236,Adaptation of radiator shutter 2: status,not completed successfully,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,73 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
ENG130449-ENG130482,A flag to indicate the voltage vailidity-Bool type,Yes,
ENG275636-ENG274433,Absolute Exhaust pressure (EXHP)-Exhaust Pressure BIN6 Kilo-Pascal,99.03, kPa
ENG127344,Acceleration demand state for VLC,0,
ENG139262,ACM Operating Mode Higher Bytes,00000000 00000000 ,
ENG139263,ACM Operating Mode Lower Bytes,00000000 00000001 ,
ENG125964,Alternator mechanically absorbed power,0.765, kW
ENG139293-ENG139302,APS Crank state-Delphi APS Crank State,P_L_APS_GAP_CONFIRMED,
ENG130440-ENG130480,Atmospheric pressure used by the brake vacuum model-Pressure 0 500 BIN6 kPa,97.48, kPa
ENG275637-ENG274915,Auxiliary water pump 1 PWM signal-PWM BIN7 Per Cent,90.000, %
ENG275638-ENG274586,Average of compounded knock intensity in acquisition window 2 index 0-Linear 2 Bytes,1,
ENG275639-ENG274586,Average of compounded knock intensity in acquisition window 2 index 1-Linear 2 Bytes,1,
ENG275640-ENG274586,Average of compounded knock intensity in acquisition window 2 index 2-Linear 2 Bytes,0,
ENG275641-ENG274397,Base spark angle for slow torque delivery: without knock healing correction-Engine Degree BIN6 Signed,9.5938, °
ENG125969,Boost pressure demand,48, kPa
ENG275642-ENG274592,Calculated osc mass based on time stamp measurement-Mass BIN12 Gram,0.000000, g
ENG101413,Calibration Identifications,||05C032AF3738CEAD|,
ENG99697,Calibration Verification Numbers,||31 4F 4C 04|,
ENG275643-ENG130482,Catalyst light off is active-Bool type,No,
ENG105535,Code Checksum,3B 70 8B 5A,
ENG105751,Data Checksum,62 72 1F 3C,
ENG275644-ENG274584,Desired intrusive lambda sent to fuel logic to provide correct mixture for diagnostic test-Lambda Value BIN11,0.99219,
ENG130456-ENG130482,Dew point passed at the wraf location-Bool type,Yes,
ENG130436-ENG246093,Diagnostic data acquired from VSEP over SPI-Delphi PWM DG A,P_L_PWM_DG_A_NO_ERROR,
ENG105980,Duration of the FAN dutycycle gap,0, s
ENG247045,Engine Exhaust Flow Rate,12.4, kg/h
ENG151174,Engine Friction - Percent Torque,4.0, %
ENG98582-ENG130485,Engine running time-Pressure BIN10 bar,1428, s
ENG277540-ENG275646,ESM ADC fault table state 0-ESM ADC fault table state,00000000 ,
ENG277662-ENG275646,ESM ADC fault table state 1-ESM ADC fault table state,00000000 ,
ENG139288-ENG130482,ESM background pfc fail fault-Bool type,No,
ENG275647-ENG276025,ESM Lock monitor state-State Value 2 Bytes,0,
ENG139290-ENG139300,ESM memory test status-Delphi ESM Memory Test Status,ESM_TESTING_CODE,
ENG275648-ENG276024,ESM MIC config fault state-State Value 1 Byte,0,
ENG275649-ENG276024,ESM MIC flash fault state-State Value 1 Byte,0,
ENG275650-ENG276024,ESM MIC RAM fault state-State Value 1 Byte,0,
ENG275651-ENG275976,ESM query period max-1 Byte  milli-second,37, ms
ENG275652-ENG276024,ESM scheduler monitoring fault state-State Value 1 Byte,0,
ENG275653-ENG276024,ESM shut of path tests CAN state-State Value 1 Byte,0,
ENG275654-ENG276024,ESM shut of path tests fuel pump state-State Value 1 Byte,0,
ENG275655-ENG276024,ESM shut of path tests OUTEN state-State Value 1 Byte,0,
ENG275656-ENG276024,ESM shut of path tests starter state-State Value 1 Byte,4,
ENG275657-ENG276024,ESM shut of path tests throttle state-State Value 1 Byte,0,
ENG275658-ENG276024,ESM shut off path test injector error during FC test-State Value 1 Byte,0,
ENG275659-ENG276024,ESM shut off path test injector error during MM test-State Value 1 Byte,0,
ENG275660,ESM URAM Spy Permitted injection time for the acceleration monitoring,00000000 ,
ENG113730-ENG113667,ESM_0_dmnd_idle_ext_active-Counter_in_seconds,0, s
ENG113731,ESM_0_dmnd_idle_ext_limit,0.00, /min
ENG113704-ENG113658,ESM_Amon_ctrl_acc_error-Control_deviation,0.000, m/s²
ENG113705-ENG113658,ESM_Amon_ctrl_n_error-Control_deviation,0.0, /min
ENG113710-ENG113659,ESM_Amon_pedal_position-Pedal_position,0, %
ENG113711-ENG113658,ESM_Amon_set_veh_acc-Control_deviation,0.000, m/s²
ENG113712-ENG113658,ESM_Amon_veh_acc_raw-Control_deviation,0.000, m/s²
ENG113713-ENG100973,ESM_Amon_veh_spd_raw-Vehicle_speed,0.00, km/h
ENG113714-ENG99033,ESM_Battery_voltage-Voltage,13.01, V
ENG125974,ESM_Crankless_active,OFF,
ENG113715,ESM_Eng_spd_l1l2_diff,8.50, /min
ENG113717,ESM_Eng_spd_unchecked_cam,947.75, /min
ENG113718,ESM_Eng_spd_unchecked_crk,950.75, /min
ENG113719,ESM_Engine_speed,950.75, /min
ENG113732-ENG113662,ESM_L2_a_ext_int_ofs-MSR_correction,0.000, m/s²
ENG113720,ESM_L3_stop_comms,OFF,
ENG113721,ESM_Memory_rst_dmnd,OFF,
ENG113722-ENG113659,ESM_Pedal_nominal_value-Pedal_position,0, %
ENG113723,ESM_Pedal_test_allowed,OFF,
ENG113724,ESM_Plausibility_fault_detected,OFF,
ENG289052-ENG113658,ESM_Spy_aps_came1_spd-Control_deviation,0.0, /min
ENG289053-ENG113658,ESM_Spy_aps_cami1_spd-Control_deviation,0.0, /min
ENG289054-ENG113658,ESM_Spy_aps_crankshaft_spd-Control_deviation,0.0, /min
ENG289055-ENG282198,ESM_Spy_bsg_dsd_op_mode-DEC UBYTE,0,
ENG282105-ENG282201,ESM_Spy_c_i_drive_axes_prim_trq-ESM Spy SWORD,0,
ENG282106-ENG282201,ESM_Spy_c_i_pt_summar_tq_dmnd-ESM Spy SWORD,0,
ENG282107-ENG275990,ESM_Spy_c_i_ptc_rcp_lim_whl_trq-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG282108-ENG282198,ESM_Spy_c_i_ptc_safe_chk_whl_tq-DEC UBYTE,0,
ENG289056-ENG274205,ESM_Spy_came_data_last-Absolute Time,0, µs
ENG289057-ENG274205,ESM_Spy_cami_data_last-Absolute Time,0, µs
ENG289058-ENG274205,ESM_Spy_crk_data_last-Absolute Time,0, µs
ENG289059-ENG113658,ESM_Spy_eng_spd_unchecked_came-Control_deviation,0.0, /min
ENG289060-ENG113658,ESM_Spy_eng_spd_unchecked_cami-Control_deviation,0.0, /min
ENG289061-ENG282198,ESM_Spy_eng_speed_01-DEC UBYTE,0,
ENG289062-ENG113658,ESM_Spy_engine_speed_raw-Control_deviation,0.0, /min
ENG289063-ENG282198,ESM_Spy_mda_pt_acv_fail_sts_6-DEC UBYTE,0,
ENG289064-ENG274587,ESM_Spy_mdasi_sys_flt_sts_3-Linear 4 Bytes,0,
ENG289065-ENG274587,ESM_Spy_mdasi_sys_flt_sts_4-Linear 4 Bytes,0,
ENG289066-ENG275990,ESM_Spy_mdda_acc_wheel_tq_req-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG282109-ENG275990,ESM_Spy_mddc_tq_whl_rcp_wot_brk-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG289067-ENG289144,ESM_Spy_melma_tq_elm_act-Torque Signed BIN4 Newton Meter,0.0, Nm
ENG282110-ENG282199,ESM_Spy_mptc_1-DEC UWORD,0,
ENG282111-ENG282198,ESM_Spy_mptc_2-DEC UBYTE,0,
ENG282112-ENG282198,ESM_Spy_mptc_st_tq_whl_ax1_lvl1-DEC UBYTE,0,
ENG282113-ENG275990,ESM_Spy_mptc_tq_whl_act_min_lim-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG282114-ENG275990,ESM_Spy_mptc_tq_whl_dece_des-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG282115-ENG275990,ESM_Spy_mptc_tq_whl_rcp_lim-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG282116-ENG282198,ESM_Spy_mptc_tq_whl_state-DEC UBYTE,0,
ENG289068-ENG289144,ESM_Spy_msc_01-Torque Signed BIN4 Newton Meter,0.0, Nm
ENG289069-ENG113658,ESM_Spy_msc_02-Control_deviation,0.0, /min
ENG289070-ENG113658,ESM_Spy_msc_03-Control_deviation,0.0, /min
ENG289071-ENG113658,ESM_Spy_msc_04-Control_deviation,0.0, /min
ENG289072-ENG289144,ESM_Spy_msc_05-Torque Signed BIN4 Newton Meter,0.0, Nm
ENG289073-ENG289138,ESM_Spy_msc_06-ESM Status Of Speed Controller Coordination,C_I_VKM_DT_CTRL_VKM,
ENG289074-ENG289144,ESM_Spy_msc_dsrd_eng_tq_sctr-Torque Signed BIN4 Newton Meter,0.0, Nm
ENG286572-ENG274587,ESM_Spy_mtqe_01-Linear 4 Bytes,0,
ENG286573-ENG274587,ESM_Spy_mtqe_02-Linear 4 Bytes,0,
ENG286574-ENG274587,ESM_Spy_mtqe_03-Linear 4 Bytes,0,
ENG286575-ENG274587,ESM_Spy_mtqe_04-Linear 4 Bytes,0,
ENG286576-ENG274587,ESM_Spy_mtqe_05-Linear 4 Bytes,0,
ENG286577-ENG274587,ESM_Spy_mtqe_06-Linear 4 Bytes,0,
ENG286578-ENG274587,ESM_Spy_mtqe_07-Linear 4 Bytes,0,
ENG286579-ENG274587,ESM_Spy_mtqe_08-Linear 4 Bytes,0,
ENG289075-ENG289144,ESM_Spy_mtqip_elm_lvl1_tq_req-Torque Signed BIN4 Newton Meter,0.0, Nm
ENG282117-ENG282198,ESM_Spy_pptop_st_qly_tq_whl_act-DEC UBYTE,0,
ENG282118-ENG282198,ESM_Spy_sig_act_spd_prim_el-DEC UBYTE,0,
ENG282119-ENG282198,ESM_Spy_sig_act_tq_prim_el-DEC UBYTE,0,
ENG113726,ESM_Synchronization_lost,OFF,
ENG113727-ENG113660,ESM_Vext_raw-ESM_sensor_voltage,0.0234, V
ENG113729-ENG113666,ESM_Zpls_trq_relevant_pulses_nbr-Torque_relevant_pulses_in_buffer,0.000,
ENG275661-ENG275012,Estimated cylinder head oil temperature-Temperature BIN2 Degree Celsius,93.000, °C
ENG275662-ENG275012,Estimated intake plenum temperature-Temperature BIN2 Degree Celsius,45.500, °C
ENG275663-ENG275012,Estimated intercooler out temperature-Temperature BIN2 Degree Celsius,47.750, °C
ENG275664-ENG274323,EVAP Factor of correlation as result of diagnosis for suction purge line-Correlation Factor BIN15,0,
ENG275665-ENG274323,EVAP Factor of correlation as result of diagnosis for turbo purge line-Correlation Factor BIN15,0,
ENG275666-ENG274326,EVAP Maximum engine speed gradient during canister purge valve check-Cycle Speed BIN2,0.00, /min
ENG275667-ENG274913,EVAP Maximum gradient of the modeled intake manifold pressure during canister purge valve check-Pressure BIN6 kilo-pascal,0.0000, kPa
ENG275668-ENG274926,EVAP Ratio between measured and estimated pressure difference of cansister purge valve-Ratio DEC2,0.00,
ENG275669-ENG130482,Exhaust cam phaser position initial offset learned-Bool type,Yes,
ENG275632-ENG275012,Exhaust gas temperature: in front of turbocharger-Temperature BIN2 Degree Celsius,479.250, °C
ENG275670-ENG275012,Exhaust pressure sensor (P3) temperature-Temperature BIN2 Degree Celsius,93.250, °C
ENG130435-ENG130482,Fan PWM driver diagnostics inhibit request-Bool type,No,
ENG275671-ENG274584,Filtered lambda value using IN_Wraf_lambda-Lambda Value BIN11,1.00732,
ENG275672-ENG275127,Filtered rear O2 voltage-Voltage BIN10 Volt,0.680664, V
ENG106571,Flag to det.if dur.of FAN dutycyc.gap is above min.thresh.,OFF,
ENG106572,Flag to det.if dur.of FAN dutycyc.pulse is above min.thresh.,On,
ENG106573,Flag to det.if dur.of FAN dutycyc.pulse is below max.thresh.,OFF,
ENG275673-ENG274891,Front O2 sensor delay during lean to rich transition-Param to DOP_10827,0, ms
ENG275674-ENG274891,Front O2 sensor delay during rich to lean transition-Param to DOP_10827,0, ms
ENG275675-ENG274891,Front O2 transition time calculated from gradient lean-to-rich-Param to DOP_10827,0, ms
ENG275676-ENG274891,Front O2 transition time calculated from gradient rich-to-lean-Param to DOP_10827,0, ms
ENG130457-ENG130482,Fuel cut-off at the Wraf sensor location: taking into account the exhaust mass flow-Bool type,No,
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.20, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.20, g/s
ENG130438-ENG130482,Generic lamp output-Bool type,No,
ENG106787,Global Checksum,31 4F 4C 04,
ENG139294,Hard reset count,0,
ENG126050,HWI_Aps_cam_index,8,
ENG126011,HWI_Aps_crank_events_betwen_cams,00 15,
ENG125999,HWI_Aps_crank_rotat_direc_enable,On,
ENG126037-ENG126090,HWI_Aps_crank_rotation_direction-APS crank rotation,HWI_APS_CRANK_ROTATION_FORWARD,
ENG125996,HWI_Aps_gap_event_misplaced,OFF,
ENG125995,HWI_Aps_gap_event_missed,OFF,
ENG125997,HWI_Aps_gap_period_detected,OFF,
ENG126036-ENG126090,HWI_Aps_hw_crank_direction-APS crank rotation,HWI_APS_CRANK_ROTATION_FORWARD,
ENG126038,HWI_Aps_hw_crank_pulse_width,2B,
ENG275678-ENG275991,IC RAM ECC error max value during a driving cycle-Error 4 Bytes,0,
ENG130454,ID of the last object which HWI_Nvm_Write return an error,0,
ENG275679-ENG130482,Idle is running-Bool type,Yes,
ENG106932,Immobilizer Snapshot 001 Byte 1,00,
ENG106933,Immobilizer Snapshot 001 Byte 2,00,
ENG106934,Immobilizer Snapshot 001 Byte 3,00,
ENG106935,Immobilizer Snapshot 001 Byte 4,00,
ENG106936,Immobilizer Snapshot 001 Byte 5,00,
ENG106937,Immobilizer Snapshot 001 Byte 6,00,
ENG106938,Immobilizer Snapshot 002 Byte 1,00,
ENG106939,Immobilizer Snapshot 002 Byte 2,00,
ENG106940,Immobilizer Snapshot 002 Byte 3,00,
ENG106941,Immobilizer Snapshot 002 Byte 4,00,
ENG106942,Immobilizer Snapshot 002 Byte 5,00,
ENG106943,Immobilizer Snapshot 002 Byte 6,00,
ENG106944,Immobilizer Snapshot 004 Byte 1,00,
ENG106945,Immobilizer Snapshot 004 Byte 2,00,
ENG106946,Immobilizer Snapshot 004 Byte 3,00,
ENG106947,Immobilizer Snapshot 004 Byte 4,00,
ENG106948,Immobilizer Snapshot 004 Byte 5,00,
ENG106949,Immobilizer Snapshot 004 Byte 6,00,
ENG106950,Immobilizer Snapshot 005 Byte 1,00,
ENG106951,Immobilizer Snapshot 005 Byte 2,00,
ENG106952,Immobilizer Snapshot 005 Byte 3,00,
ENG106953,Immobilizer Snapshot 005 Byte 4,00,
ENG106954,Immobilizer Snapshot 005 Byte 5,00,
ENG106955,Immobilizer Snapshot 005 Byte 6,00,
ENG126000,IN_Injection_speed,949.50, /min
ENG126008,IN_Injection_speed_injector{0},950.75, /min
ENG126009,IN_Injection_speed_injector{1},952.25, /min
ENG126010,IN_Injection_speed_injector{2},949.25, /min
ENG126004,IN_Latest_inj_spd_table{0},949.75, /min
ENG126005,IN_Latest_inj_spd_table{1},948.50, /min
ENG126006,IN_Latest_inj_spd_table{2},951.00, /min
ENG126007,IN_Latest_inj_spd_table{3},952.75, /min
ENG275680-ENG130482,Intake cam phaser position initial offset learned-Bool type,Yes,
ENG100634-ENG299122,In-use Performance Tracking: 16 or 20 counters-Counters 3-EOP,|Completion Condition Counts,Conditions Encountered Counts|193
ENG100634-ENG102823,In-use Performance Tracking: 16 or 20 counters-Ignition Cycle Counter,0, counts
ENG100634-ENG99988,In-use Performance Tracking: 16 or 20 counters-OBD Monitoring Conditions Encountered Counts,0, counts
ENG100634-ENG250449,In-use Performance Tracking: 16 or 20 counters-Raw Data,00,
ENG130451,Last error returned by HWI_Nvm_Read for P_L_Nvm_write_obj_index object,0,
ENG130453,Last error returned by HWI_Nvm_Write for P_L_Nvm_write_obj_index object,0,
ENG275681-ENG275994,Last query before reset sent by the Monitor module-Low Bytes,00000000 00000000 ,
ENG275682-ENG275994,Last reply before reset sent by the Function Controller-Low Bytes,00000000 00000000 ,
ENG275683-ENG275980,Last reset root cause-Delphi Status Last Reset 0,P_L_NO_RESET,
ENG275683-ENG275981,Last reset root cause-Delphi Status Last Reset 1,P_L_NO_RESET,
ENG275683-ENG275982,Last reset root cause-Delphi Status Last Reset 2,P_L_NO_RESET,
ENG275683-ENG275983,Last reset root cause-Delphi Status Last Reset 3,P_L_NO_RESET,
ENG275683-ENG275984,Last reset root cause-Delphi Status Last Reset 4,P_L_NO_RESET,
ENG275683-ENG275985,Last reset root cause-Delphi Status Last Reset 5,P_L_NO_RESET,
ENG275683-ENG275986,Last reset root cause-Delphi Status Last Reset 6,P_L_NO_RESET,
ENG275683-ENG275987,Last reset root cause-Delphi Status Last Reset 7,P_L_NO_RESET,
ENG275683-ENG275988,Last reset root cause-Delphi Status Last Reset 8,P_L_NO_RESET,
ENG275683-ENG275989,Last reset root cause-Delphi Status Last Reset 9,P_L_NO_RESET,
ENG275684-ENG274891,Learnt filter time constant deviation from nominal-Param to DOP_10827,122, ms
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG130445-ENG130480,Linearised atmospheric pressure sensor data-Pressure 0 500 BIN6 kPa,97.48, kPa
ENG103817,Main Timing demand,-6.078, °
ENG275685-ENG275012,Manifold air temperature-Temperature BIN2 Degree Celsius,53.250, °C
ENG130450-ENG130483,Manifold pressure offset-P_L Manifold abs pres offset nvv,-0.688, kPa
ENG127343,Maximum allowed vehicle velocity,202.0, km/h
ENG275686-ENG274433,Maximum of the raw exhaust pressure signal (P3) for each segment-Exhaust Pressure BIN6 Kilo-Pascal,109.59, kPa
ENG275687-ENG275991,MIC FLASH ECC error max value during a driving cycle-Error 4 Bytes,0,
ENG275688-ENG275991,MIC FLASH ECC error total value-Error 4 Bytes,0,
ENG275689-ENG275991,MIC RAM ECC error total value-Error 4 Bytes,0,
ENG275690-ENG274433,Minimum of the raw exhaust pressure signal (P3) for each segment-Exhaust Pressure BIN6 Kilo-Pascal,95.50, kPa
ENG107850,number of NEF refresh that have been performed,1429, counts
ENG275715-ENG275979,Number of times ESM_Sequence is detected lower than nominal min value-Counter 1 Byte,0, counts
ENG107873,OBD Driver demand indicated torque,10.0, %
ENG107876-ENG127366,OBD maximum indicated torque-Torque 0 65535 BIN0 Nm,250, Nm
ENG275716-ENG274235,Offset from long-term learning derived from integral part-Air Fuel Control Trim Value,-0.000305,
ENG275717-ENG274235,Offset from long-term learning derived from integral part during lambda split operation-Air Fuel Control Trim Value,0.000000,
ENG130437,Oil pump PWM signal duty cycle,29.289, %
ENG127345-ENG127354,Operation mode cruise control and speed limiter-Cruise control 10km/h steps allowed,Yes,
ENG127345-ENG127353,Operation mode cruise control and speed limiter-Cruise control break intervention allowed,Yes,
ENG127345-ENG127355,Operation mode cruise control and speed limiter-Cruise control with display velocity setpoint,Yes,
ENG127345-ENG98891,Operation mode cruise control and speed limiter-Reserved,Yes,
ENG127345-ENG101416,Operation mode cruise control and speed limiter-Reserved_1,Yes,
ENG127345-ENG99458,Operation mode cruise control and speed limiter-Reserved_2,Yes,
ENG127345-ENG99668,Operation mode cruise control and speed limiter-Reserved_3,Yes,
ENG127345-ENG154261,Operation mode cruise control and speed limiter-Reserved_4,Yes,
ENG275718-ENG274890,Operation states of the parallelization diagnostics-Parallelization Diagnostics States,PRL_WAITING,
ENG275719-ENG274234,Overall Proportional term of rear trim control-Air Fuel Control Trim Proportional BIN11,0.000000,
ENG125998,P_L_Aps_cam_edge_window_end,OFF,
ENG125994,P_L_Aps_cam_index_confirmed,On,
ENG126035-ENG126089,P_L_Aps_cam_state-APS cam state,P_L_APS_PATTERN_CONFIRMED,
ENG113760,P_L_Aps_camless_active,OFF,
ENG126043-ENG126092,P_L_Aps_camshaft_drift_angle-Camshaft target wheel drift angle,1022.91, °
ENG126003,P_L_Aps_crank_event_num,3A,
ENG113759,P_L_Aps_crankless_active,OFF,
ENG126001,P_L_Aps_crankshaft_speed,950.25, /min
ENG113758,P_L_Aps_injection_speed,948.75, /min
ENG125993,P_L_Aps_learning_done_nvv,On,
ENG126034-ENG126088,P_L_Aps_mode-APS working mode,P_L_APS_NORMAL,
ENG113755,P_L_Aps_no_sync_speed,943.25, /min
ENG113749-ENG99000,P_L_Aps_sync_cnt_total-Value,1,
ENG113750,P_L_Aps_sync_lost,OFF,
ENG113751-ENG113669,P_L_Aps_sync_lost_origin-Sync_lost_status,Unknown (18)
ENG113752,P_L_Aps_sync_tasks_enabled,On,
ENG113753,P_L_Aps_synchronised,On,
ENG113754-ENG113670,P_L_Aps_synchronised_origin-Sync_origin,P_L_APS_SYNC_TCAM_TCAM,
ENG113756-ENG113661,P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value,354.122, °
ENG113757,P_L_Aps_timeout_detected,OFF,
ENG125978,P_L_Cds_p_class_selected,01,
ENG125976,P_L_Cds_vc_bit3_wr_valid_nvv,OFF,
ENG125977,P_L_Cds_vc_bit6_wr_valid_nvv,OFF,
ENG274741,P_L_EHOOKS_A2L_NAME_CPV,0,
ENG274741-ENG274742,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (10),0,
ENG274741-ENG274743,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (100),0,
ENG274741-ENG274744,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (101),0,
ENG274741-ENG274745,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (102),0,
ENG274741-ENG274746,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (103),0,
ENG274741-ENG274747,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (104),0,
ENG274741-ENG274748,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (105),0,
ENG274741-ENG274749,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (106),0,
ENG274741-ENG274750,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (107),0,
ENG274741-ENG274751,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (108),0,
ENG274741-ENG274752,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (109),0,
ENG274741-ENG274753,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (11),0,
ENG274741-ENG274754,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (110),0,
ENG274741-ENG274755,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (111),0,
ENG274741-ENG274756,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (112),0,
ENG274741-ENG274757,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (113),0,
ENG274741-ENG274758,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (114),0,
ENG274741-ENG274759,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (115),0,
ENG274741-ENG274760,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (116),0,
ENG274741-ENG274761,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (117),0,
ENG274741-ENG274762,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (118),0,
ENG274741-ENG274763,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (119),0,
ENG274741-ENG274764,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (12),0,
ENG274741-ENG274765,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (120),0,
ENG274741-ENG274766,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (121),0,
ENG274741-ENG274767,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (122),0,
ENG274741-ENG274768,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (123),0,
ENG274741-ENG274769,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (124),0,
ENG274741-ENG274770,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (125),0,
ENG274741-ENG274771,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (126),0,
ENG274741-ENG274772,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (127),0,
ENG274741-ENG274773,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (128),0,
ENG274741-ENG274774,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (13),0,
ENG274741-ENG274775,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (14),0,
ENG274741-ENG274776,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (15),0,
ENG274741-ENG274777,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (16),0,
ENG274741-ENG274778,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (17),0,
ENG274741-ENG274779,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (18),0,
ENG274741-ENG274780,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (19),0,
ENG274741-ENG274781,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (2),0,
ENG274741-ENG274782,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (20),0,
ENG274741-ENG274783,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (21),0,
ENG274741-ENG274784,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (22),0,
ENG274741-ENG274785,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (23),0,
ENG274741-ENG274786,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (24),0,
ENG274741-ENG274787,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (25),0,
ENG274741-ENG274788,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (26),0,
ENG274741-ENG274789,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (27),0,
ENG274741-ENG274790,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (28),0,
ENG274741-ENG274791,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (29),0,
ENG274741-ENG274792,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (3),0,
ENG274741-ENG274793,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (30),0,
ENG274741-ENG274794,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (31),0,
ENG274741-ENG274795,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (32),0,
ENG274741-ENG274796,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (33),0,
ENG274741-ENG274797,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (34),0,
ENG274741-ENG274798,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (35),0,
ENG274741-ENG274799,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (36),0,
ENG274741-ENG274800,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (37),0,
ENG274741-ENG274801,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (38),0,
ENG274741-ENG274802,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (39),0,
ENG274741-ENG274803,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (4),0,
ENG274741-ENG274804,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (40),0,
ENG274741-ENG274805,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (41),0,
ENG274741-ENG274806,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (42),0,
ENG274741-ENG274807,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (43),0,
ENG274741-ENG274808,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (44),0,
ENG274741-ENG274809,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (45),0,
ENG274741-ENG274810,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (46),0,
ENG274741-ENG274811,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (47),0,
ENG274741-ENG274812,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (48),0,
ENG274741-ENG274813,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (49),0,
ENG274741-ENG274814,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (5),0,
ENG274741-ENG274815,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (50),0,
ENG274741-ENG274816,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (51),0,
ENG274741-ENG274817,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (52),0,
ENG274741-ENG274818,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (53),0,
ENG274741-ENG274819,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (54),0,
ENG274741-ENG274820,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (55),0,
ENG274741-ENG274821,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (56),0,
ENG274741-ENG274822,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (57),0,
ENG274741-ENG274823,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (58),0,
ENG274741-ENG274824,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (59),0,
ENG274741-ENG274825,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (6),0,
ENG274741-ENG274826,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (60),0,
ENG274741-ENG274827,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (61),0,
ENG274741-ENG274828,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (62),0,
ENG274741-ENG274829,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (63),0,
ENG274741-ENG274830,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (64),0,
ENG274741-ENG274831,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (65),0,
ENG274741-ENG274832,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (66),0,
ENG274741-ENG274833,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (67),0,
ENG274741-ENG274834,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (68),0,
ENG274741-ENG274835,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (69),0,
ENG274741-ENG274836,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (7),0,
ENG274741-ENG274837,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (70),0,
ENG274741-ENG274838,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (71),0,
ENG274741-ENG274839,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (72),0,
ENG274741-ENG274840,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (73),0,
ENG274741-ENG274841,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (74),0,
ENG274741-ENG274842,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (75),0,
ENG274741-ENG274843,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (76),0,
ENG274741-ENG274844,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (77),0,
ENG274741-ENG274845,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (78),0,
ENG274741-ENG274846,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (79),0,
ENG274741-ENG274847,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (8),0,
ENG274741-ENG274848,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (80),0,
ENG274741-ENG274849,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (81),0,
ENG274741-ENG274850,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (82),0,
ENG274741-ENG274851,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (83),0,
ENG274741-ENG274852,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (84),0,
ENG274741-ENG274853,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (85),0,
ENG274741-ENG274854,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (86),0,
ENG274741-ENG274855,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (87),0,
ENG274741-ENG274856,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (88),0,
ENG274741-ENG274857,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (89),0,
ENG274741-ENG274858,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (9),0,
ENG274741-ENG274859,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (90),0,
ENG274741-ENG274860,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (91),0,
ENG274741-ENG274861,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (92),0,
ENG274741-ENG274862,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (93),0,
ENG274741-ENG274863,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (94),0,
ENG274741-ENG274864,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (95),0,
ENG274741-ENG274865,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (96),0,
ENG274741-ENG274866,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (97),0,
ENG274741-ENG274867,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (98),0,
ENG274741-ENG274868,P_L_EHOOKS_A2L_NAME_CPV-P_L_EHOOKS_A2L_NAME_CPV (99),0,
ENG275720,P_L_EHOOKS_MANIP_BIT,0,
ENG130582,P_L_Pedal_switch_case,USE_MIN,
ENG113740-ENG98489,P_L_Rail_pres_sample_cnts-counts,1023, counts
ENG113762-ENG113664,P_L_Wraf_back_pressure_estimate-Back_pressure_estimate,0.978, bar
ENG113761-ENG113663,P_L_Wraf_ip_temp_compensation-Compensation_value,-0.0000, mA
ENG108255,Power Latch counter,4583, counts
ENG275721-ENG274587,Previous operating mode demand-Linear 4 Bytes,1,
ENG139296-ENG130482,PT dfco 0 torque request-Bool type,No,
ENG275722-ENG274925,Ratio of air scavenged from intake to exhaust during the valves overlap-Ratio BIN15,0,
ENG130446-ENG130481,Raw battery voltage reading-Voltage BIN7 V,12.8281, V
ENG275723-ENG274891,Rear O2 sensor delay during lean to rich transition-Param to DOP_10827,0, ms
ENG275724-ENG274891,Rear O2 sensor delay during rich to lean transition-Param to DOP_10827,0, ms
ENG275725-ENG274891,Rear O2 transition time calculated from gradient lean-to-rich-Param to DOP_10827,0, ms
ENG275726-ENG274891,Rear O2 transition time calculated from gradient rich-to-lean-Param to DOP_10827,0, ms
ENG275727-ENG274340,Requested wheel torque from driver assistance system-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG139292,Reset detection pattern,6,
ENG130447-ENG130481,Scaled sensor value before validation for pbatt-Voltage BIN7 V,12.9688, V
ENG275728-ENG274395,Slow spark retard induced by knock detection 0-Engine Degree BIN10,0.000000, °
ENG275729-ENG274395,Slow spark retard induced by knock detection 1-Engine Degree BIN10,0.000000, °
ENG275730-ENG274395,Slow spark retard induced by knock detection 2-Engine Degree BIN10,0.000000, °
ENG157424-ENG161131,SMC_Power_state-Param Delphi SMC Power State,SMC_SYSTEM_RUNNING,
ENG139295,Soft reset count,0,
ENG275731-ENG274396,Spark retard induced by knock detection 0-Engine Degree BIN6,0.0000, °
ENG275732-ENG274396,Spark retard induced by knock detection 1-Engine Degree BIN6,0.0000, °
ENG275733-ENG274396,Spark retard induced by knock detection 2-Engine Degree BIN6,0.0000, °
ENG127342-ENG127352,State ACC Cruise Control Variant Correct Code-ACC Cruise variant code,ACC Stop and Go,
ENG275734-ENG274424,State of the shut off path tests-ESM Shut Off State,ESM_SHUT_OFF_ENDED,
ENG127339-ENG127350,Status cruise control and speed limiter-Status velocity destination,OFF,
ENG127341-ENG98933,Status irriversible shutoff condition cruise control and limiter-Status,0,
ENG127348-ENG127363,Status powertrain VLC and VehFRstn-Automatic transmission reduced torque intervention,Yes,
ENG127348-ENG127362,Status powertrain VLC and VehFRstn-Automatic transmission shift,Yes,
ENG127348-ENG127359,Status powertrain VLC and VehFRstn-Clutch long open,Yes,
ENG127348-ENG112437,Status powertrain VLC and VehFRstn-Clutch open,Yes,
ENG127348-ENG127360,Status powertrain VLC and VehFRstn-Extended neutral gear detection manual switch v/n drift,Yes,
ENG127348-ENG127361,Status powertrain VLC and VehFRstn-Exteneded neutral gear detection only at Torque demand manual switch,Yes,
ENG127348-ENG127358,Status powertrain VLC and VehFRstn-Gear level position N/Intermediate position or Manual switch neutral gear,Yes,
ENG127348-ENG127357,Status powertrain VLC and VehFRstn-Gear lever position P,Yes,
ENG127348-ENG127356,Status powertrain VLC and VehFRstn-Manual switch first gear,Yes,
ENG127348-ENG127364,Status powertrain VLC and VehFRstn-Maximum engine speed not debounced regulation,Yes,
ENG127348-ENG101416,Status powertrain VLC and VehFRstn-Reserved_1,Yes,
ENG127348-ENG99458,Status powertrain VLC and VehFRstn-Reserved_2,Yes,
ENG127348-ENG99668,Status powertrain VLC and VehFRstn-Reserved_3,Yes,
ENG127348-ENG154261,Status powertrain VLC and VehFRstn-Reserved_4,Yes,
ENG127348-ENG98894,Status powertrain VLC and VehFRstn-Reverse gear,Yes,
ENG127348-ENG127365,Status powertrain VLC and VehFRstn-Vehicle speed dependent engine speed limit only for automatic transmission,Yes,
ENG127340-ENG127351,Status reversible shutoff condition cruise control and limiter-Stau,16990272,
ENG275735-ENG274992,Stimulation Interface Usage History-Stimualtion Activation Time Stamp Day,1,
ENG275735-ENG274993,Stimulation Interface Usage History-Stimualtion Activation Time Stamp Hour,0,
ENG275735-ENG274994,Stimulation Interface Usage History-Stimualtion Activation Time Stamp Minute,0,
ENG275735-ENG274995,Stimulation Interface Usage History-Stimualtion Activation Time Stamp Month,1,
ENG275735-ENG274996,Stimulation Interface Usage History-Stimualtion Activation Time Stamp Second,0,
ENG275735-ENG274997,Stimulation Interface Usage History-Stimualtion Activation Time Stamp Year,0,
ENG275735-ENG274998,Stimulation Interface Usage History-Stimualtion Deactivation Time Stamp Day,0,
ENG275735-ENG274999,Stimulation Interface Usage History-Stimualtion Deactivation Time Stamp Hour,0,
ENG275735-ENG275000,Stimulation Interface Usage History-Stimualtion Deactivation Time Stamp Minute,0,
ENG275735-ENG275001,Stimulation Interface Usage History-Stimualtion Deactivation Time Stamp Second,0,
ENG275735-ENG275002,Stimulation Interface Usage History-Stimualtion Deactivation Time Stamp Year,0,
ENG275735-ENG275003,Stimulation Interface Usage History-Stimualtion Dectivation Time Stamp Month,1,
ENG275735-ENG275004,Stimulation Interface Usage History-Stimualtion Total Time Active,0,
ENG275735-ENG275005,Stimulation Interface Usage History-Stimulation Reserved,0,
ENG127347-ENG119265,Target velocity LMVCtl function-Velocity,0.0, km/h
ENG275736-ENG274586,Total number of OSC tests-Linear 2 Bytes,396,
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG125973,Turbocharger actuator HP bit field status 2,00000000 00000000 00000000 01000000 ,
ENG275737-ENG274442,Turbocharger turbine flow estimate (sum of air flow and fuel flow)-Flow BIN5 gram per second,3.438, g/s
ENG275738-ENG275012,TWC outlet temperature-Temperature BIN2 Degree Celsius,412.750, °C
ENG275739-ENG274340,URAM ESM Spy Actual combustion engine torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275742-ENG274340,URAM ESM Spy Actual slow indicated torque minus pumping and rubbing losses-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275743-ENG274326,URAM ESM Spy Actual speed from primary electric machine-Cycle Speed BIN2,0.00, /min
ENG275744-ENG274340,URAM ESM Spy Actual torque of primary electric machine-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275746-ENG130481,URAM ESM Spy Battery voltage-Voltage BIN7 V,0.0000, V
ENG275748-ENG130482,URAM ESM Spy brake light switch-Bool type,No,
ENG275749-ENG130482,URAM ESM Spy Brake light switch data signal-Bool type,No,
ENG275750-ENG130482,URAM ESM Spy Brake safety switch data signal-Bool type,No,
ENG275751-ENG130482,URAM ESM Spy Brake switch rec fault after plausibility check-Bool type,No,
ENG275753-ENG130482,URAM ESM Spy Buffer on bank 1 has exceeded its maximum size and buffer rollover was triggered-Bool type,No,
ENG275754-ENG130482,URAM ESM Spy Buffer on bank 2 has exceeded its maximum size and buffer rollover was triggered-Bool type,No,
ENG275755-ENG130482,URAM ESM Spy Buffer on bank 3 has exceeded its maximum size and buffer rollover was triggered-Bool type,No,
ENG275756-ENG274205,URAM ESM Spy buffer that contains absolute time detection of falling edge camshaft signal-Absolute Time,0, µs
ENG275757-ENG130482,URAM ESM Spy Conditions were no injections should occur are present-Bool type,No,
ENG275758-ENG130482,URAM ESM Spy confirmed drift test debounced fault for contactless sensor (several detection)-Bool type,No,
ENG275759-ENG130482,URAM ESM Spy Consistence bit of brake pedal state in function level-Bool type,No,
ENG275760-ENG130482,URAM ESM Spy control flow indicating that a vehicle crash has been detected-Bool type,No,
ENG275761-ENG275012,URAM ESM Spy Coolant temperature-Temperature BIN2 Degree Celsius,0.000, °C
ENG275762,URAM ESM Spy Core 0 Trap Class,00000000 00000000 00000000 00000000 ,
ENG275763,URAM ESM Spy Core 1 Trap Class,00000000 00000000 00000000 00000000 ,
ENG275764,URAM ESM Spy Core 2 Trap Class,00000000 00000000 00000000 00000000 ,
ENG275765-ENG130482,URAM ESM Spy correlation error has occured between tracks 1 and 2 (debounced)-Bool type,No,
ENG275766,URAM ESM Spy Counter for the detection of implausible injections,00000000 ,
ENG275767-ENG274218,URAM ESM Spy counts for potentiometer 2 of the pedal position sensor as measured by the ADC-ADC Measurement,0, counts
ENG275769-ENG274419,URAM ESM Spy Crash detection-ESM CAN Crash Intensity,ESM_NO_CRASH,
ENG275770-ENG274421,URAM ESM Spy current state of the move fault detection-ESM Pedal Move State,ESM_MAPS_PDL_DRIFT_CHK_START,
ENG275771,URAM ESM Spy Debounce counter of ESM_Flt_driver_trq_conf fault,00000000 ,
ENG275772-ENG274340,URAM ESM Spy Delta torque for electrical machine intervention-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275773-ENG274340,URAM ESM Spy Delta torque for engine lead path intervention-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275774-ENG274340,URAM ESM Spy Delta torque for engine set path intervention-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275775-ENG274340,URAM ESM Spy Desired torque for additional aggregates including torque losses of electrical machine in U-Mode or Failure-Mode-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275776-ENG274340,URAM ESM Spy desired torque of medium voltage belt-driven starter generator-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275782-ENG130482,URAM ESM Spy drift error for double potentiometer sensor is confirmed-Bool type,No,
ENG275783,URAM ESM Spy Driver assistance system deactivated reversible by level 2,00000000 00000000 ,
ENG275784-ENG274340,URAM ESM Spy Driver demand wheel torque request-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275785-ENG274340,URAM ESM Spy Driver torque request without inertia compensation-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275786-ENG274398,URAM ESM Spy Engine cycle speed calculated over one engine cycle (two crank flywheel revolutions)-Engine Speed BIN2 rpm,0.00, /min
ENG275787-ENG130482,URAM ESM Spy engine limp home active: ICO-Bool type,No,
ENG275792,URAM ESM Spy Error detected in diagnosis of external torque demands,00000000 00000000 ,
ENG275793,URAM ESM Spy Error flag caused by momentum error to trigger an injection 1,00000000 00000000 ,
ENG275794,URAM ESM Spy Error flag caused by momentum error to trigger an injection 2,00000000 00000000 ,
ENG275797,URAM ESM Spy Error in air system detected,00000000 00000000 ,
ENG275798,URAM ESM Spy Error in level 1 detected,00000000 00000000 ,
ENG275799-ENG130482,URAM ESM Spy Error reaction engine limp home request to supplier-Bool type,No,
ENG275800-ENG274340,URAM ESM Spy ESM engine internal set torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275801-ENG275990,URAM ESM Spy ESM Torque: The limited wheel torque as defined by the active (engine or acceleration) governor: defined in the acceleration monitor.-Delphi Torque 4 Bytes BIN4 Newton Meter,0.000, Nm
ENG275802-ENG274340,URAM ESM Spy ESM_Spy_mtqcd_min_tq_sec_ax-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275803,URAM ESM Spy Failure status of the Q-Diode,00000000 ,
ENG275804-ENG274340,URAM ESM Spy Filtered maximum allowed torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275805-ENG274340,URAM ESM Spy Filtered minimum allowed torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275808-ENG130482,URAM ESM Spy flag indicating lift pump shall be switched off-Bool type,No,
ENG275809,URAM ESM Spy Flag indicating that a failure is confirmed on ESM Cruise control 1,00000000 00000000 00000000 00000000 ,
ENG275810,URAM ESM Spy Flag indicating that a failure is confirmed on ESM Cruise control 2,00000000 00000000 00000000 00000000 ,
ENG275811-ENG130482,URAM ESM Spy Flag indicating that an engine stop was detected-Bool type,No,
ENG275813-ENG130482,URAM ESM Spy flag to indicate whether the reduced torque demand is active or not-Bool type,No,
ENG275814-ENG274915,URAM ESM Spy Fuel pump duty cycle-PWM BIN7 Per Cent,0.000, %
ENG275815-ENG130482,URAM ESM Spy Fuel pump flat signal detected-Bool type,No,
ENG275816-ENG275046,URAM ESM Spy global 1ms-Time Millli Second 4 Bytes,0, ms
ENG275817-ENG130482,URAM ESM Spy global variable containing crash info bit-Bool type,No,
ENG275818-ENG130482,URAM ESM Spy Hardware main brake signal high threshold-Bool type,No,
ENG275819-ENG130482,URAM ESM Spy Hardware main brake signal low threshold-Bool type,No,
ENG275820-ENG130482,URAM ESM Spy high impedance state is detected on track 1-Bool type,No,
ENG275821-ENG130482,URAM ESM Spy high impedance state is detected on track 2-Bool type,No,
ENG275823-ENG130482,URAM ESM Spy ICO mode from lvl1-Bool type,No,
ENG275824-ENG130482,URAM ESM Spy Ignition switch-Bool type,No,
ENG275825-ENG274340,URAM ESM Spy indicated torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275827-ENG130482,URAM ESM Spy indicates if there is a brake fault. Should be initialized to TRUE.-Bool type,No,
ENG275828,URAM ESM Spy Irreversible failure flag primary electric machine,00000000 00000000 ,
ENG275829-ENG274420,URAM ESM Spy key position signal validated-ESM Key Position,ESM_KEY_POSITION_OFF,
ENG275831-ENG130482,URAM ESM Spy learnt value for track 2 idle position in drift test (double potentiometer)-Bool type,No,
ENG275832-ENG130482,URAM ESM Spy level 1 and 2 are plausible on bank 1-Bool type,No,
ENG275833-ENG130482,URAM ESM Spy level 1 and 2 are plausible on bank 2-Bool type,No,
ENG275834-ENG130482,URAM ESM Spy level 1 and 2 are plausible on bank 3-Bool type,No,
ENG275835-ENG130482,URAM ESM Spy Level 2 brake safety switch pin state after processing-Bool type,No,
ENG275838-ENG274915,URAM ESM Spy Lift pump PWM-PWM BIN7 Per Cent,0.000, %
ENG275839-ENG274915,URAM ESM Spy Lift pump PWM demand from FuSly_Lp VW object code (FuSLp_rDem_VW)-PWM BIN7 Per Cent,0.000, %
ENG275840,URAM ESM Spy Limitation of drive torque request after coordination of driver demand and drive assistance,00000000 ,
ENG275841-ENG274218,URAM ESM Spy Lower stop for sensor 1 throttle voltage from level 1-ADC Measurement,0, counts
ENG275842-ENG274218,URAM ESM Spy Lower stop for sensor 2 throttle voltage from level 1-ADC Measurement,0, counts
ENG277613-ENG277895,URAM ESM Spy Lvl1 Injection event counter 0-GDI Diagnostic Pulse Count,0, counts
ENG277705-ENG277895,URAM ESM Spy Lvl1 Injection event counter 1-GDI Diagnostic Pulse Count,0, counts
ENG277634-ENG277895,URAM ESM Spy Lvl1 Injection event counter 2-GDI Diagnostic Pulse Count,0, counts
ENG275844-ENG274340,URAM ESM Spy Maximal allowed torque comparison-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275845-ENG274340,URAM ESM Spy Maximum actual torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275846-ENG275977,URAM ESM Spy Maximum allowed acceleration for driver assistance system-Acceleartion BIN10 m/s2,0.00000, m/s²
ENG275847-ENG274340,URAM ESM Spy Maximum allowed torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275848-ENG274340,URAM ESM Spy Maximum allowed torque after external interventions-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275849-ENG274340,URAM ESM Spy Maximum allowed torque after external interventions for limitation in function level: message value-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275850-ENG274340,URAM ESM Spy Maximum allowed torque primary axle-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275851-ENG274340,URAM ESM Spy Maximum torque limitation primary electric machine-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275852-ENG274340,URAM ESM Spy Minimal allowed torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275853-ENG274340,URAM ESM Spy Minimum actual torque-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275854-ENG274340,URAM ESM Spy Minimum allowed torque after external interventions-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275855-ENG274340,URAM ESM Spy Minimum allowed torque after external interventions for limitation in function level: message value-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275856-ENG274340,URAM ESM Spy minimum allowed torque from drag control-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275857-ENG274340,URAM ESM Spy Minimum allowed torque of electrical machine because of load point shift limitation-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275858-ENG274340,URAM ESM Spy Minimum allowed torque primary axle-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275859-ENG274340,URAM ESM Spy Minimum engine torque at clutch-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275860-ENG274340,URAM ESM Spy Minimum torque engine lead path intervention-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275861-ENG274340,URAM ESM Spy Minimum torque for set path resulting from a powertrain intervention-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275862-ENG274340,URAM ESM Spy Minimum torque limitation primary electric machine-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275863,URAM ESM Spy Monitoring failure belt starter generator starts unauthorised 1,00000000 00000000 ,
ENG275864,URAM ESM Spy Monitoring failure belt starter generator starts unauthorised 2,00000000 00000000 ,
ENG275865,URAM ESM Spy Monitoring failure engine runs unauthorised 1,00000000 00000000 ,
ENG275866,URAM ESM Spy Monitoring failure engine runs unauthorised 2,00000000 ,
ENG275867,URAM ESM Spy Monitoring failure engine runs unauthorised 3,00000000 ,
ENG275868,URAM ESM Spy Monitoring failure engine runs unauthorised 4,00000000 ,
ENG275869,URAM ESM Spy Monitoring failure engine runs unauthorised 5,00000000 ,
ENG275870,URAM ESM Spy Monitoring failure engine starts unauthorised 1,00000000 00000000 ,
ENG275871,URAM ESM Spy Monitoring failure engine starts unauthorised 2,00000000 00000000 ,
ENG275872,URAM ESM Spy Monitoring failure engine starts unauthorised 3,00000000 00000000 ,
ENG275873,URAM ESM Spy Monitoring failure for sending of powertrain active on bus 1,00000000 00000000 ,
ENG275874,URAM ESM Spy Monitoring failure for sending of powertrain active on bus 2,00000000 00000000 ,
ENG275875,URAM ESM Spy Monitoring failure for sending of powertrain active on bus 3,00000000 ,
ENG275876,URAM ESM Spy Monitoring failure for sending of powertrain active on bus 4,00000000 ,
ENG275877,URAM ESM Spy Monitoring failure for sending of powertrain active on bus 5,00000000 00000000 ,
ENG275878,URAM ESM Spy Monitoring failure for sending of powertrain active on bus 6,00000000 ,
ENG275879,URAM ESM Spy Monitoring failure level 1 torque limitation transfered,00000000 00000000 ,
ENG275880,URAM ESM Spy Monitoring failure maximal torque comparison,00000000 ,
ENG275881,URAM ESM Spy Monitoring failure maximum requested torque,00000000 00000000 ,
ENG275882,URAM ESM Spy Monitoring failure minimum requested torque,00000000 00000000 ,
ENG275883,URAM ESM Spy Monitoring failure minimum torque comparison,00000000 ,
ENG275884,URAM ESM Spy Monitoring failure requested level one torque exceeds limitations or desired operation mode not plausible,00000000 00000000 ,
ENG275885,URAM ESM Spy Monitoring failure speed controller,00000000 ,
ENG275886,URAM ESM Spy Monitoring failure stability control or recuperation intervention not plausible,00000000 ,
ENG275887-ENG276026,URAM ESM Spy Not plausible precontrol torque part of speed controller-Torque Signed BIN0 Newton Meter,0, Nm
ENG275888-ENG274340,URAM ESM Spy Not plausible torque of drive of controller-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275889-ENG274340,URAM ESM Spy Not plausible torque part of auxiliary speed controller-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275890-ENG274340,URAM ESM Spy Not plausible torque part of I-part of speed controller-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275891-ENG274340,URAM ESM Spy Not plausible torque part of P-part of speed controller-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275892,URAM ESM Spy Number of torque relevant pulses detected within the last 40 ms,00000000 ,
ENG275893-ENG274422,URAM ESM Spy Pedal arbitration currently used-ESM Pedal Track Arbitation Mode,ESM_MAPP_PEDAL_USE_TRACK1,
ENG275894-ENG274896,URAM ESM Spy pedal position information from the Level 1-Pedal Position BIN7 Per Cent,0.000, %
ENG275895-ENG130482,URAM ESM Spy Pedal range check fault on track 1 or 2 (debounced)-Bool type,No,
ENG275896-ENG274896,URAM ESM Spy Pedal value rescaled-Pedal Position BIN7 Per Cent,0.000, %
ENG275897-ENG276021,URAM ESM Spy Pressure in intake manifold from level 1-Pressure BIN5 hecto pascal,0.000, hPa
ENG275898-ENG130482,URAM ESM Spy Pulse feedback buffer is frozen on bank1-Bool type,No,
ENG275899-ENG130482,URAM ESM Spy Pulse feedback buffer is frozen on bank2-Bool type,No,
ENG275900-ENG130482,URAM ESM Spy Pulse feedback buffer is frozen on bank3-Bool type,No,
ENG275901-ENG274423,URAM ESM Spy Pulse monitoring callback counter to tell when pulses were read-ESM Pulse Monitiring Callbacks,0, counts
ENG275902-ENG130482,URAM ESM Spy Quality bit for clutch pedal duty cycle signal-Bool type,No,
ENG275903-ENG274398,URAM ESM Spy raw engine speed value recalculated by ESM based on the camshaft signal-Engine Speed BIN2 rpm,0.00, /min
ENG275904-ENG274398,URAM ESM Spy raw engine speed value recalculated by ESM based on the crankshaft signal-Engine Speed BIN2 rpm,0.00, /min
ENG275905-ENG274341,URAM ESM Spy Raw information signal from Pedal track 1 in voltage-Delphi Voltage BIN12 V,0.00000, V
ENG275906-ENG274341,URAM ESM Spy Raw information signal from Pedal track 2 in voltage-Delphi Voltage BIN12 V,0.00000, V
ENG275907-ENG274398,URAM ESM Spy recalculated engine speed value by ESM function-Engine Speed BIN2 rpm,0.00, /min
ENG275908-ENG274340,URAM ESM Spy Recuperation part of brake torque setpoint for driver-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275909-ENG275978,URAM ESM Spy Relative air charge from level 1-Air Charge BIN 7 Per Cent,0.0000, %
ENG275910-ENG274340,URAM ESM Spy Requested level one torque of combustion engine-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275911-ENG274340,URAM ESM Spy Requested speed limiter wheel torque from driver assistance systems-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275912-ENG130482,URAM ESM Spy requested state of the starter relay-Bool type,No,
ENG275913,URAM ESM Spy Requested status of the 12V belt starter generator,00000000 ,
ENG275914-ENG130482,URAM ESM Spy Reversible error reaction engine limp home request to supplier-Bool type,No,
ENG275915-ENG130482,URAM ESM Spy Ring buffer containing time of tooth detection-Bool type,No,
ENG275916-ENG130482,URAM ESM Spy Secured cut off flag-Bool type,No,
ENG275917-ENG274339,URAM ESM Spy Signal corresponding to duty cycle of the PWM of clutch pedal-Delphi Position BIN4 Per Cent,0.000, %
ENG275919-ENG274326,URAM ESM Spy Speed at clutch-Cycle Speed BIN2,0.00, /min
ENG275920-ENG130482,URAM ESM Spy State auxiliary brake switch not valid-Bool type,No,
ENG275921-ENG130482,URAM ESM Spy State main brake switch not valid-Bool type,No,
ENG275922,URAM ESM Spy State of error signal for MonDrvModSwt 1,00000000 00000000 ,
ENG275923,URAM ESM Spy State of error signal for MonDrvModSwt 2,00000000 00000000 ,
ENG275924,URAM ESM Spy State of error signal for MonDrvModSwt 3,00000000 00000000 ,
ENG275925,URAM ESM Spy State of error signal for MonDrvModSwt 4,00000000 00000000 ,
ENG275926,URAM ESM Spy State of error signal for MonDrvModSwt 5,00000000 00000000 ,
ENG275927,URAM ESM Spy State of error signal for MonDrvModSwt 6,00000000 00000000 ,
ENG275928-ENG274425,URAM ESM Spy Status for activation of overrun monitoring-ESM Spy Status for activation of overrun,00000000 00000000 ,
ENG275929,URAM ESM Spy Status message for bus value 12V belt starter generator,00000000 ,
ENG275930,URAM ESM Spy Status message for bus value of the Q-Diode,00000000 ,
ENG275931-ENG130482,URAM ESM Spy Status message for signal corresponding to duty cycle of the PWM of clutch pedal-Bool type,No,
ENG275933-ENG161131,URAM ESM Spy System state-Param Delphi SMC Power State,SMC_FAULT_DETECTION,
ENG275934-ENG274218,URAM ESM Spy The counts for potentiometer 1 of the pedal position sensor as measured by the ADC-ADC Measurement,0, counts
ENG275935-ENG130482,URAM ESM Spy THROT valve shut off (deenergized) from level 1-Bool type,No,
ENG275936-ENG130482,URAM ESM Spy throttle off active-Bool type,No,
ENG275937-ENG274218,URAM ESM Spy Throttle voltage from sensor 1-ADC Measurement,0, counts
ENG275938-ENG274218,URAM ESM Spy Throttle voltage from sensor 2-ADC Measurement,0, counts
ENG275939-ENG274340,URAM ESM Spy Torque of global increasing intervention by gearbox control unit permitted by monitoring-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275940-ENG274340,URAM ESM Spy Torque offset maximal torque comparison-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275941-ENG274340,URAM ESM Spy Torque offset minimal torque comparison-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275942-ENG274359,URAM ESM Spy total distance in km travelled by the vehicle-Driving Distance 4 Bytes Kilo Meter,0, km
ENG275943,URAM ESM Spy Tram Identification Number for Core 0,00000000 00000000 00000000 00000000 ,
ENG275944,URAM ESM Spy Tram Identification Number for Core 1,00000000 00000000 00000000 00000000 ,
ENG275945,URAM ESM Spy Tram Identification Number for Core 2,00000000 00000000 00000000 00000000 ,
ENG275946-ENG276022,URAM ESM Spy Transmission ratio from clutch to wheel-Ratio BIN10 Volt,0.000000, °
ENG275947-ENG130482,URAM ESM Spy undebouced ESM Secured cut off flag-Bool type,No,
ENG275950-ENG274338,URAM ESM Spy value for the current gear ratio-Delphi Gear Ratio,0,
ENG275951,URAM ESM Spy variable to hold the ECS return address of Core 0 in case of Trap,00000000 00000000 00000000 00000000 ,
ENG275952,URAM ESM Spy variable to hold the ECS return address of Core 1 in case of Trap,00000000 00000000 00000000 00000000 ,
ENG275953,URAM ESM Spy variable to hold the ECS return address of Core 2 in case of Trap,00000000 00000000 00000000 00000000 ,
ENG275954-ENG275109,URAM ESM Spy Vehicle speed (BIN7)-Vehicle Speed BIN7 kmh,0.0000, km/h
ENG275955-ENG276023,URAM ESM Spy Vehicle speed (signed value)-Speed DEC1 Kilo-Meter Per Hour,0.00,
ENG275956-ENG274340,URAM ESM Spy wheel torque request for brake system-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275957-ENG274340,URAM ESP Spy reduced torque value applied to limit the brake torque when reduced torque mode is active-Delphi Torque BIN4 Newton Meter,0.000, Nm
ENG275958-ENG275977,URAM Spy Vehicle acceleration-Acceleartion BIN10 m/s2,0.00000, m/s²
ENG275959-ENG274294,Variable cam phaser control final duty cycle demand-Cam Phaser Demand BIN7 percent,0.000, %
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG127346-ENG127349,Velocity limitation requested by driver-Velocity driver requested speed limit,500.0, km/h
ENG125967-ENG98842,Vgt valve position for OBD Mode $02-Position,76.9, %
ENG275960-ENG274235,Wraf closed loop control integral error-Air Fuel Control Trim Value,1.019287,
ENG130459-ENG130484,Wraf pump cell offset-Wraf pump cell offset current,0.00000, mA
ENG130455,Wraf pure air deviation correction factor,0.9374,
ENG130464-ENG130484,Wraf second sensor pump cell offset-Wraf pump cell offset current,0.00000, mA
ENG139267,Wraf sensor learning count,1906,
ENG130461-ENG130455,Wraf2 correction factor-Wraf pure air deviation correction factor,1.0000,
ENG139274,Wrf2 sensor learning count,0,
Elapsed Time: 01:18
blockmap-03-5WA-614-517-CF_WVWZZZCD6RW123439-20260903-1756.CSV
;SW:5WA-614-517-CF   HW:5WA-614-517-N ---  03: ABS Brakes
;Component:ESC           H13 0135, Coding:34FC2C902222446F527B50030ACC61862DB458F542D067C0219CA231018FF100002814
;EV_Brake1ESCEPBMQB37W,013058,EV_Brake1ESCEPBMQB37W_013_VW38.rod
;Thursday,03,September,2026,17:56:22:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 0E45A81040D026CA65C-805A SFD { }
Group,Description,Actual
IDE00019,Voltage terminal 30,12.851, V
IDE00021,Engine speed,952.75, /min
IDE00025,Coolant temperature,91.0, °C
IDE00085,Normed load value,27.8431, %
IDE00086,Accelerator pedal position,14.1, %
IDE00097,OBD - requirements for which this vehicle is designed,EOBD,
IDE00601-ENG161107,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG161129,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG161142,Monitoring status since erasing DTC memory-Readiness_State,00000000 ,
IDE00601-ENG161227,Monitoring status since erasing DTC memory-Supported_Info,00000000 ,
IDE00601-ENG161228,Monitoring status since erasing DTC memory-Supported_Info_Readiness,00000100 ,
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,Not operated,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,CD6RW123439,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,not active,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,OFF,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,194,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.braking,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,1,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,96,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,7,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,18455,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,1,
IDE03011-MAS02515,Number of requested start processes-System malfunction,182,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,7,
IDE03310,Brake lamp,OFF,
IDE03310-MAS01167,Brake lamp-Actuation time,0 s,
IDE03310-ENG170421,Brake lamp-IoReached Status,Output diagnostic test not active,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,4.9, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,12.9, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.8, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,12.7, V
IDE03680-MAS01468,Supply voltages-Terminal 15,On,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.01, bar
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,10.1, %
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,forward,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,forward,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.58860, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-0.38259, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,0.29430, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,-0.18750, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,0.051, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-4.856, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-1.794, °
IDE04446-IDE14988,Hill descent control-Incline,1, %
IDE04446-MAS01299,Hill descent control-Offroad,Off-road deactivated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04446-MAS05585,Hill descent control-Standby,not active,
IDE04446-MAS12601,Hill descent control-HDC intervention,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,18858, km
IDE04461-MAS01481,Internal measured values-Temperature in control module,55.4, °C
IDE04461-MAS10973,Internal measured values-Hardware reset,65535,
IDE04461-MAS10974,Internal measured values-Software reset,65535,
IDE04461-MAS15830,Internal measured values-Data block description,Block 2,
IDE04461-MAS17870,Internal measured values-Number of resets,65535,
IDE04461-ENG264503,Internal measured values-C1 Idle Task,42, %
IDE04461-ENG264509,Internal measured values-Ct mainloop,40, %
IDE04461-ENG264510,Internal measured values-Ct prc task,64, %
IDE04461-ENG264511,Internal measured values-Ct valve task,64, %
IDE04461-ENG126445,Internal measured values-Idle Task,38, %
IDE04461-ENG264549,Internal measured values-Idp Task,33, %
IDE04461-ENG264551,Internal measured values-Ipb main task,22, %
IDE04461-ENG264552,Internal measured values-Ipb safety task,75, %
IDE04461-ENG264663,Internal measured values-Task BAP 10ms,44, %
IDE04461-ENG264664,Internal measured values-Task C0 Com task 5ms AsilD,0, %
IDE04461-ENG264665,Internal measured values-Task C1 10ms AsilB,39, %
IDE04461-ENG264666,Internal measured values-Task C1 1ms AsilB,36, %
IDE04461-ENG264667,Internal measured values-Task Com task1 5ms AsilD,41, %
IDE04461-ENG264668,Internal measured values-Task Com task1 5ms Qm,47, %
IDE04461-ENG264669,Internal measured values-Task Com task2 5ms Qm,14, %
IDE04461-ENG264670,Internal measured values-Task mFDR 5ms_AsilD,59, %
IDE04461-ENG264671,Internal measured values-Task mFDR 5ms_Qm,64, %
IDE04461-ENG264672,Internal measured values-Task TPI 20ms,50, %
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,0, m/s²
IDE04765-IDE02955,Counter steer support-System status,Not available due to specific system,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04772,Indicator light in the button for electromech. parking brake,On,
IDE04772-MAS01167,Indicator light in the button for electromech. parking brake-Actuation time,Without time limit,
IDE04772-ENG170421,Indicator light in the button for electromech. parking brake-IoReached Status,Output diagnostic test not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02763,Tire Pressure Monitoring System (TPMS)-System malfunction lamp: status,OFF,
IDE04939-IDE02765,Tire Pressure Monitoring System (TPMS)-Pressure warning lamp: status,OFF,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,4294967295, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,18974, km
IDE04939-IDE09286,Tire Pressure Monitoring System (TPMS)-Software version of tire monitoring display,R1906A26,
IDE04939-IDE09287,Tire Pressure Monitoring System (TPMS)-Param. set version tire press monitoring display,0,
IDE04939-IDE09288,Tire Pressure Monitoring System (TPMS)-Param. set tire press monitor display: checksum,48,
IDE04939-IDE09289,Tire Pressure Monitoring System (TPMS)-Tire press monitor.display: diagnosis status,00 00 30 00 00 00 98 99 A9 22,
IDE04939-IDE11039,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: le. frt,255,
IDE04939-IDE11040,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,255,
IDE04939-IDE11041,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,255,
IDE04939-IDE11042,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,255,
IDE04939-IDE11043,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. frt,255,
IDE04939-IDE11044,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,255,
IDE04939-IDE11045,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,255,
IDE04939-IDE11046,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,255,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2026,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,7,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,8,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,6,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,31,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,15,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,14,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,9,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,8,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,26,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,10,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,17,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,19,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,20,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,16,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,6,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,50,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,44,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,3,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,1,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,18,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,9,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,49,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,10,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,20,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,59,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,14,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,37,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,12,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,4,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,58,
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,18930, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,18929, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,18924, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,18974, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,18974, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,18974, km
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,02 22 00 00 00 00 00 00 00 10,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,01 21 00 00 00 00 98 99 A9 22,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,02 25 00 00 00 00 98 99 A9 22,
IDE04939-MAS18039,Tire Pressure Monitoring System (TPMS)-Odometer reading at fifth most recent configuration,18920, km
IDE04939-MAS18041,Tire Pressure Monitoring System (TPMS)-Analysis data from fifth most recent configuration,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS18042,Tire Pressure Monitoring System (TPMS)-Temperature at time of most recent warning,27, °C
IDE04939-MAS18066,Tire Pressure Monitoring System (TPMS)-Temperature at time of second to last warning,27, °C
IDE04939-MAS18067,Tire Pressure Monitoring System (TPMS)-Temperature at time of third most recent warning,27, °C
IDE04939-MAS18069,Tire Pressure Monitoring System (TPMS)-Temperature at time of fourth most recent warning,28, °C
IDE04939-MAS18070,Tire Pressure Monitoring System (TPMS)-Odometer reading of fifth most recent warning,18974, km
IDE04939-MAS18072,Tire Pressure Monitoring System (TPMS)-Temperature at time of fifth most recent warning,28, °C
IDE04939-MAS18073,Tire Pressure Monitoring System (TPMS)-Analysis data of fifth most recent warning,02 25 00 00 00 00 00 00 00 10,
IDE04939-MAS18074,Tire Pressure Monitoring System (TPMS)-Tire control display parameter set info,195,
IDE04939-MAS18076,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during most recent warning,27, °C
IDE04939-MAS18077,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during second most recent warning,27, °C
IDE04939-MAS18078,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during third most recent warning,27, °C
IDE04939-MAS18079,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fourth most recent warning,28, °C
IDE04939-MAS18080,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fifth most recent warning,28, °C
IDE04939-ENG135557,Tire Pressure Monitoring System (TPMS)-RKA_Config_Info,0,
IDE05053,Right parking brake motor: close gradually,Open,
IDE05053-MAS01167,Right parking brake motor: close gradually-Actuation time,Without time limit,
IDE05053-ENG170421,Right parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05054,Left parking brake motor: close gradually,Open,
IDE05054-MAS01167,Left parking brake motor: close gradually-Actuation time,Without time limit,
IDE05054-ENG170421,Left parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05333,Indicator light in AUTO HOLD button,On,
IDE05333-MAS01167,Indicator light in AUTO HOLD button-Actuation time,Without time limit,
IDE05333-ENG170421,Indicator light in AUTO HOLD button-IoReached Status,Output diagnostic test not active,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06422-ENG103176,IUMPR_1-General Denominator,190,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,3782,
IDE06422-ENG100120,IUMPR_1-Milage,18100,
IDE06422-ENG101622,IUMPR_1-Record Number,41,
IDE06423-ENG101817,IUMPR_2-Denominator,190,
IDE06423-ENG103772,IUMPR_2-DFCC Value,00 8B,
IDE06423-ENG99150,IUMPR_2-Numerator,3080,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,190,
IDE06424-ENG103772,IUMPR_3-DFCC Value,10 BD,
IDE06424-ENG99150,IUMPR_3-Numerator,3080,
IDE06424-ENG101622,IUMPR_3-Record Number,2,
IDE07183,Parking brake motors: close incrementally,Open,
IDE07183-MAS01167,Parking brake motors: close incrementally-Actuation time,Without time limit,
IDE07183-ENG170421,Parking brake motors: close incrementally-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,active,
IDE13239-IDE04947,Loose wheel warning system-Odometer reading of last warning,0, km
IDE13239-MAS00106,Loose wheel warning system-Year,2000,
IDE13239-MAS00107,Loose wheel warning system-Month,0,
IDE13239-MAS00108,Loose wheel warning system-Day,0,
IDE13239-MAS00109,Loose wheel warning system-Hours,0,
IDE13239-MAS00110,Loose wheel warning system-Minutes,0,
IDE13239-MAS00111,Loose wheel warning system-Seconds,0,
IDE13239-MAS04541,Loose wheel warning system-Odometer reading of next-to-last warning,0, km
IDE13239-MAS04542,Loose wheel warning system-Odometer reading of third-to-last warning,0, km
IDE13239-MAS16487,Loose wheel warning system-Wheels affected by the latest warning,no warning,
IDE13239-MAS16489,Loose wheel warning system-Wheels affected by the penultimate warning,no warning,
IDE13239-MAS16491,Loose wheel warning system-Wheels affected by the third last warning,no warning,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,Available,
IDE14227-MAS18085,modular vehicle dynamic controller-Electronic Stability Program function status,mFDR_not_active_by_failure,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_controlled,
IDE14227-MAS18087,modular vehicle dynamic controller-Haldex function status,mFDR_active_haldex_not_configured,
IDE14227-MAS18088,modular vehicle dynamic controller-Min Haldex target locking rate,0.0, %
IDE14227-MAS18089,modular vehicle dynamic controller-Max Haldex target locking rate,50.0, %
IDE14227-ENG264561,modular vehicle dynamic controller-mFDR Sollfaktor DCC HL,100, %
IDE14227-ENG264562,modular vehicle dynamic controller-mFDR Sollfaktor DCC HR,100, %
IDE14227-ENG264563,modular vehicle dynamic controller-mFDR Sollfaktor DCC VL,100, %
IDE14227-ENG264564,modular vehicle dynamic controller-mFDR Sollfaktor DCC VR,100, %
IDE14479-IDE02657,Parking brake system status-Cut-off current: left: reached,0.00, A
IDE14479-IDE02658,Parking brake system status-Cut-off current: right: reached,0.00, A
IDE14479-IDE04496,Parking brake system status-Left parking brake motor: status,closed,
IDE14479-IDE04497,Parking brake system status-Right parking brake motor: status,closed,
IDE14479-IDE04506,Parking brake system status-Calculated left rear brake temperature,42.0, °C
IDE14479-IDE04507,Parking brake system status-Calculated right rear brake temperature,42.0, °C
IDE14479-IDE04647,Parking brake system status-Left parking brake motor: current,0.00, A
IDE14479-IDE04648,Parking brake system status-Right parking brake motor: current,0.00, A
IDE14479-IDE05048,Parking brake system status-Left parking brake motor: actuation counter,792,
IDE14479-IDE05049,Parking brake system status-Right parking brake motor: actuation counter,791,
IDE14623,Commutation test status,not active,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,30.0, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,30.0, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,30.0, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,30.0, °C
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Not available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Not available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,56,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,31,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,18974, km
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Not open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Not available due to specific system,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver´s door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02286-MAS01167,Hydraulic pump-Actuation time,0 s,
MAS02286-MAS06857,Hydraulic pump-Speed,0, /min
MAS02286-ENG170421,Hydraulic pump-IoReached Status,Output diagnostic test not active,
MAS02426-MAS01167,Text display in instrument cluster-Actuation time,Without time limit,
MAS02426,Text display in instrument cluster,0,
MAS02426-ENG170421,Text display in instrument cluster-IoReached Status,Output diagnostic test not active,
MAS04012-IDE03297,Intake valves-Left front ABS inlet valve,OFF,
MAS04012-IDE03299,Intake valves-Right front ABS inlet valve,OFF,
MAS04012-IDE03301,Intake valves-left rear ABS intake valve,OFF,
MAS04012-IDE03303,Intake valves-right rear ABS intake valve,OFF,
MAS04012-MAS01167,Intake valves-Actuation time,0 s,
MAS04012-ENG170421,Intake valves-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,75 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
ENG101413,Calibration Identifications,5WA517CF01350210,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,83 FF 7D 8B,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG264438,Entwicklermesswert_01,A3 32 38 35 31 36 34 35 37 36 32 33 30 30 30 30 39 32 33 38 30 32 30 30 38 45 30 2F 02 1C 1E 45 19 E4 00 3A 00 00 07 52 07 56 07 51 07 06 07 02 07 50 01 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 81 40 00 70 24 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 3A CC 7E 41 00 00 00 00 00 00 00 00 3A CC 7E 41 00 00 00 00 EE EE EE 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2E 00 00 2E 00 00 07 A5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3E 4A 5D FA FB FF FF 03 86 35 00 01 EA 02 07 01 FC AD 0F 0F 00 11 AE 0A 8C 09 F0 01 90 FF BC 00 00 FF F7 00 14 F7 68 AD 0F 0F 00 11 AE 0A 8C 09 F0 01 90 FF BC 00 00 FF F7 00 14 F7 68 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 33 35 32 38 D4 00 35 24 25 27 27 1E 22 24 23 12 11 2A F0 3D 12 F9 49 6D 04 07 04 04 00 00 1D 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C 7D 00 00 02 C0 80 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B2 01 AA 01 3A 8C 06 00 00 55 F0 04 00 EE 00 83 00 01 00 00 00 09 00 01 01 00 00 02 01 00 01 00 01 00 01 00 00 00 03 00 01 01 00 02 02 01 01 02 02 02 03 00 00 00 01 01 02 02 00 01 00 02 01 01 00 00 00 00 1E 00 14 02 FF 02 0D 00 00 00 00 80 00 00 00 34 2C 22 44 52 50 0A 61 86 2D B4 58 F5 42 D0 67 C0 21 9C A2 31 01 8F F1 00 00 28 14 E6 C0 3E FB E4 00 32 00 52 CC 00 40 00 00 00 00 12 F0 6A 06 78 04 80 01 BA 19 00 64 00 00 00 00 57 56 57 5A 5A 5A 43 44 36 52 57 31 32 33 34 33 39 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG264440,Entwicklermesswert_03,0,
ENG264441,Entwicklermesswert_04,0,
ENG264442-MAS00106,Entwicklermesswert_05-Year,2000,
ENG264442-MAS00107,Entwicklermesswert_05-Month,0,
ENG264442-MAS00108,Entwicklermesswert_05-Day,0,
ENG264442-MAS00109,Entwicklermesswert_05-Hours,0,
ENG264442-MAS00110,Entwicklermesswert_05-Minutes,0,
ENG264442-MAS00111,Entwicklermesswert_05-Seconds,0,
ENG264442-ENG127707,Entwicklermesswert_05-level_1_OFF_actuation_n_distance,0, km
ENG264442-ENG264557,Entwicklermesswert_05-level_1_ON_actuation_distance,0, km
ENG264442-ENG264558,Entwicklermesswert_05-level_2_OFF_actuation_distance,0, km
ENG264442-ENG264559,Entwicklermesswert_05-level_2_ON_actuation_distance,0, km
ENG264443-ENG264593,Entwicklermesswert_06-PCU,Texas_Instruments,
ENG264445,Entwicklermesswert_08,|VZM_function_request,VZM_Participant
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,792,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,791,
ENG264448,Entwicklermesswert_12,40081D,
ENG264449-ENG135765,Entwicklermesswert_13-Input_Signal_A_Belt_Error,No malfunction,
ENG264449-ENG135764,Entwicklermesswert_13-Input_Signal_A_Belt_Status,not selected,
ENG264449-ENG135767,Entwicklermesswert_13-Input_Signal_B_Door_Error,No malfunction,
ENG264449-ENG135766,Entwicklermesswert_13-Input_Signal_B_Door_Status,closed,
ENG264450-MAS01167,Entwicklerstellglied_01_status-Actuation time,0 s,
ENG264450-MAS11641,Entwicklerstellglied_01_status-OBD lamp,OFF,
ENG264450-ENG170421,Entwicklerstellglied_01_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 00:19
blockmap-05-5WA-959-436-Q_WVWZZZCD6RW123439-20260903-1757.CSV
;SW:5WA-959-436-Q   HW:5WA-959-436-Q ---  05: Acc/Start Auth.
;Component:Kessy IOBOX   100 0725, Coding:
;EV_Kessy37w,004024,EV_Kessy37w_004.rod
;Thursday,03,September,2026,17:57:01:29755
;VCID: 629DACA0E4C8F2AA914-8036
IDE00019,Voltage terminal 30,12.912, V
IDE02413,Door handle touch sensor: last operation,Driver´s door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,24,
IDE02419,Proximity sensor frt.pass. door: number of triggers,0,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,32,
IDE02422-MAS01483,Driver door handle: version information-Software version,43,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,34,
IDE02422,Driver door handle: version information,CA 00 17 00 1E,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,32,
IDE02423-MAS01483,ass. door handle: version information-Software version,43,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,34,
IDE02423,ass. door handle: version information,DB 00 17 A3 A1,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,0,
IDE02466,Play protection activation counter driver door,not active,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02469,Play protection activation counter right rear door,not active,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.9, V
IDE07359,Dimming of starter button lighting,10000,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver´s door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Passenger´s door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Rear left door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Rear right door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver´s door,Enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Passenger´s door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Rear left door,not enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Rear right door,not enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14933,Trunk control section: play protection counter,not active,
IDE14933,Trunk control section: play protection counter,0,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Power_On_Reset,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Power_On_Reset,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Power_On_Reset,
ENG254757-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG254757-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG254757-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG254757-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG254757-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG254757-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG254757-ENG255615,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG254758-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG254758-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG254758-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG254758-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG254758-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG254758-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG254758-ENG255615,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG254759-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG254759-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG254759-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG254759-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG254759-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG254759-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG254759-ENG255615,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG254760-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG254760-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG254760-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG254760-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG254760-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG254760-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG254760-ENG255615,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG254761-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG254761-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG254761-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG254761-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG254761-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG254761-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG254761-ENG255615,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG254762-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG254762-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG254762-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG254762-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG254762-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG254762-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG254762-ENG255615,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG254763-MAS00106,Lf_antenna_three_detune_counter-Year,2026,
ENG254763-MAS00107,Lf_antenna_three_detune_counter-Month,9,
ENG254763-MAS00108,Lf_antenna_three_detune_counter-Day,3,
ENG254763-MAS00109,Lf_antenna_three_detune_counter-Hours,10,
ENG254763-MAS00110,Lf_antenna_three_detune_counter-Minutes,49,
ENG254763-MAS00111,Lf_antenna_three_detune_counter-Seconds,10,
ENG254763-ENG255615,Lf_antenna_three_detune_counter-Detune_counter,2,
ENG254764-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG254764-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG254764-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG254764-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG254764-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG254764-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG254764-ENG255615,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG254789-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG254789-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG254789-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG254789-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG254789-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG254789-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG254789-ENG256116,Over_temperature_counter_lf_driver-Over_temperature_counter,0, counts
ENG108452,Reset_counter,50,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,0,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,2006232112,
ENG254855-MAS19582,WUP_measurement_historie-Learned wake pattern,1007119206,
ENG254855-ENG103063,WUP_measurement_historie-Mileage,0, km
ENG254855-ENG103063,WUP_measurement_historie-Mileage,16777215, km
Elapsed Time: 00:07
blockmap-08-5WA-907-007-AB_WVWZZZCD6RW123439-20260903-1757.CSV
;SW:5WA-907-007-AB   HW:5WA-907-007-AB ---  08: Auto HVAC
;Component:AC Automat    H30 3623, Coding:002000119011000000100010111010010000011000000000000000000000
;EV_ACClimaPREVW38X,001102,EV_ACClimaPREVW38X_VW38.rod
;Thursday,03,September,2026,17:57:17:29755
;VCID: 074B9D342FAA7782A6A-8052
IDE00019,Voltage terminal 30,12.8, V
IDE00021,Engine speed,951.00, /min
IDE00025,Coolant temperature,90, °C
IDE00198,Refrigerant pressure,14.4, bar
IDE00323-ENG127697,Security Access: Number of invalid keys-Counter_2,0,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not active,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not active,
IDE00767,No. of unscheduled ECU resets,16,
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.440, A
IDE00967,Compressor current: specified value,0.440, A
IDE00968,Compressor speed,1100, /min
IDE00969,Compressor load,14.2, Nm
IDE00970,Coolant fan activation: actual value,60.0, %
IDE00971,Coolant fan activation: specified value,64.0, %
IDE00973,Outside temperature,30.0, °C
IDE00974,Outside air temperature internally calculated,30.0, °C
IDE00976,Left front vent temperature,13.5, °C
IDE00981,Footwell vent temperature,12.5, °C
IDE00982,Temperature downstream of evaporator,6.8, °C
IDE00983,Inside temperature,27.0, °C
IDE00984,Sun intensity left,20,
IDE00985,Sun intensity right,20,
IDE00987,Blower voltage: specified value,7.9, V
IDE00989,Blower status,active,
IDE00992,Recirculation flap specified value,Fresh air,
IDE00998,Left temperature flap - actual value,106,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00999,Temperature door left - Specified value,0,
IDE01040,Left Temperature Control Door - cold stop,101,
IDE01041,Left temperature flap: warm stop,922,
IDE01059,Air distribution flap: actual value,66.5, %
IDE01059,Air distribution flap: actual value,651,
IDE01060,Air distribution flap: specified value,Time reference,
IDE01063,Status of recirculation air,Fresh air,
IDE01066,Convertible top status,Closed,
IDE01076,Time since ignition off,254, min
IDE01226,Blower voltage: actual value,7.9, V
IDE01227,Blower current,8.25, A
IDE01232,Supply voltage for external components,4.9, V
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,6616,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,0,
IDE01419,Compressor shut-off condition: last,Shut-off of engine control module via CAN (T > 15 sec.),
IDE01420,Compressor shut-off requirement: penultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off of engine control module via CAN (T > 15 sec.),
IDE01433,Air quality status,Measuring value not available,
IDE01442-MAS01533,Pressing a button-Defrost,not active,
IDE01442-MAS01534,Pressing a button-Recirculating air,not active,
IDE01442-MAS01535,Pressing a button-Rear window defogger,not active,
IDE01442-MAS01550,Pressing a button-AC,not active,
IDE01442-MAS01554,Pressing a button-Left heated seat,not active,
IDE01442-MAS01556,Pressing a button-Right heated seat,not active,
IDE01442-MAS01560,Pressing a button-OFF,not active,
IDE01442-MAS01564,Pressing a button-Windshield defogger,not active,
IDE01442-MAS01577,Pressing a button-Auxiliary heating,not active,
IDE01442-MAS02015,Pressing a button-AUTO,not active,
IDE01442-MAS02192,Pressing a button-SYNC,not active,
IDE01442-MAS03196,Pressing a button-Menu,not active,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,not active,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,not active,
IDE01442-MAS03832,Pressing a button-Air distribution up,not active,
IDE01442-MAS04605,Pressing a button-AC MAX,not active,
IDE01448,Actual value of heated front window,not coded / not installed,
IDE01449-IDE01011,Personalization 1 for climate control-Data record,active,
IDE01449-MAS01533,Personalization 1 for climate control-Defrost,0,
IDE01449-MAS01534,Personalization 1 for climate control-Recirculating air,0,
IDE01449-MAS01550,Personalization 1 for climate control-AC,1,
IDE01449-MAS01552,Personalization 1 for climate control-Left specified temperature,22.0,
IDE01449-MAS01553,Personalization 1 for climate control-Right specified temperature,22.0,
IDE01449-MAS01554,Personalization 1 for climate control-Left heated seat,0,
IDE01449-MAS01555,Personalization 1 for climate control-Left seat ventilation,0,
IDE01449-MAS01556,Personalization 1 for climate control-Right heated seat,0,
IDE01449-MAS01557,Personalization 1 for climate control-Right seat ventilation,0,
IDE01449-MAS01560,Personalization 1 for climate control-OFF,0,
IDE01449-MAS01562,Personalization 1 for climate control-Air quality sensor,0,
IDE01449-MAS01563,Personalization 1 for climate control-Auxiliary Air Heater,0,
IDE01449-MAS01566,Personalization 1 for climate control-Style,1,
IDE01449-MAS01567,Personalization 1 for climate control-Synchronization,0,
IDE01449-MAS02015,Personalization 1 for climate control-AUTO,0,
IDE01449-MAS02804,Personalization 1 for climate control-Manual fan speed increase,not installed,
IDE01449-MAS03830,Personalization 1 for climate control-Footwell air distribution,1,
IDE01449-MAS03831,Personalization 1 for climate control-Upper body vent air distribution,0,
IDE01449-MAS03832,Personalization 1 for climate control-Air distribution up,1,
IDE01449-MAS04620,Personalization 1 for climate control-Fan setting: absolute,3,
IDE01449-MAS04621,Personalization 1 for climate control-Left neck heater,not installed,
IDE01449-MAS04648,Personalization 1 for climate control-Right neck heater,not installed,
IDE01449-MAS06077,Personalization 1 for climate control-Manual blower stage during defrost active,5,
IDE01449-MAS06366,Personalization 1 for climate control-Display blower levels,00000001 ,
IDE01450-IDE01011,Personalization 2 for climate control-Data record,not active,
IDE01450-MAS01533,Personalization 2 for climate control-Defrost,0,
IDE01450-MAS01534,Personalization 2 for climate control-Recirculating air,0,
IDE01450-MAS01550,Personalization 2 for climate control-AC,1,
IDE01450-MAS01552,Personalization 2 for climate control-Left specified temperature,22.0,
IDE01450-MAS01553,Personalization 2 for climate control-Right specified temperature,22.0,
IDE01450-MAS01554,Personalization 2 for climate control-Left heated seat,0,
IDE01450-MAS01555,Personalization 2 for climate control-Left seat ventilation,0,
IDE01450-MAS01556,Personalization 2 for climate control-Right heated seat,0,
IDE01450-MAS01557,Personalization 2 for climate control-Right seat ventilation,0,
IDE01450-MAS01560,Personalization 2 for climate control-OFF,0,
IDE01450-MAS01562,Personalization 2 for climate control-Air quality sensor,0,
IDE01450-MAS01563,Personalization 2 for climate control-Auxiliary Air Heater,1,
IDE01450-MAS01566,Personalization 2 for climate control-Style,1,
IDE01450-MAS01567,Personalization 2 for climate control-Synchronization,0,
IDE01450-MAS02015,Personalization 2 for climate control-AUTO,1,
IDE01450-MAS02804,Personalization 2 for climate control-Manual fan speed increase,not installed,
IDE01450-MAS03830,Personalization 2 for climate control-Footwell air distribution,0,
IDE01450-MAS03831,Personalization 2 for climate control-Upper body vent air distribution,0,
IDE01450-MAS03832,Personalization 2 for climate control-Air distribution up,0,
IDE01450-MAS04620,Personalization 2 for climate control-Fan setting: absolute,3,
IDE01450-MAS04621,Personalization 2 for climate control-Left neck heater,not installed,
IDE01450-MAS04648,Personalization 2 for climate control-Right neck heater,not installed,
IDE01450-MAS06077,Personalization 2 for climate control-Manual blower stage during defrost active,0,
IDE01450-MAS06366,Personalization 2 for climate control-Display blower levels,00000000 ,
IDE01451-IDE01011,Personalization 3 for climate control-Data record,not active,
IDE01451-MAS01533,Personalization 3 for climate control-Defrost,0,
IDE01451-MAS01534,Personalization 3 for climate control-Recirculating air,0,
IDE01451-MAS01550,Personalization 3 for climate control-AC,1,
IDE01451-MAS01552,Personalization 3 for climate control-Left specified temperature,22.0,
IDE01451-MAS01553,Personalization 3 for climate control-Right specified temperature,29.5,
IDE01451-MAS01554,Personalization 3 for climate control-Left heated seat,0,
IDE01451-MAS01555,Personalization 3 for climate control-Left seat ventilation,0,
IDE01451-MAS01556,Personalization 3 for climate control-Right heated seat,0,
IDE01451-MAS01557,Personalization 3 for climate control-Right seat ventilation,0,
IDE01451-MAS01560,Personalization 3 for climate control-OFF,0,
IDE01451-MAS01562,Personalization 3 for climate control-Air quality sensor,0,
IDE01451-MAS01563,Personalization 3 for climate control-Auxiliary Air Heater,1,
IDE01451-MAS01566,Personalization 3 for climate control-Style,0,
IDE01451-MAS01567,Personalization 3 for climate control-Synchronization,0,
IDE01451-MAS02015,Personalization 3 for climate control-AUTO,1,
IDE01451-MAS02804,Personalization 3 for climate control-Manual fan speed increase,not installed,
IDE01451-MAS03830,Personalization 3 for climate control-Footwell air distribution,0,
IDE01451-MAS03831,Personalization 3 for climate control-Upper body vent air distribution,0,
IDE01451-MAS03832,Personalization 3 for climate control-Air distribution up,0,
IDE01451-MAS04620,Personalization 3 for climate control-Fan setting: absolute,3,
IDE01451-MAS04621,Personalization 3 for climate control-Left neck heater,not installed,
IDE01451-MAS04648,Personalization 3 for climate control-Right neck heater,not installed,
IDE01451-MAS06077,Personalization 3 for climate control-Manual blower stage during defrost active,0,
IDE01451-MAS06366,Personalization 3 for climate control-Display blower levels,00000000 ,
IDE01452-IDE01011,Personalization 4 for climate control-Data record,not active,
IDE01452-MAS01533,Personalization 4 for climate control-Defrost,0,
IDE01452-MAS01534,Personalization 4 for climate control-Recirculating air,0,
IDE01452-MAS01550,Personalization 4 for climate control-AC,1,
IDE01452-MAS01552,Personalization 4 for climate control-Left specified temperature,22.0,
IDE01452-MAS01553,Personalization 4 for climate control-Right specified temperature,29.5,
IDE01452-MAS01554,Personalization 4 for climate control-Left heated seat,0,
IDE01452-MAS01555,Personalization 4 for climate control-Left seat ventilation,0,
IDE01452-MAS01556,Personalization 4 for climate control-Right heated seat,0,
IDE01452-MAS01557,Personalization 4 for climate control-Right seat ventilation,0,
IDE01452-MAS01560,Personalization 4 for climate control-OFF,0,
IDE01452-MAS01562,Personalization 4 for climate control-Air quality sensor,0,
IDE01452-MAS01563,Personalization 4 for climate control-Auxiliary Air Heater,1,
IDE01452-MAS01566,Personalization 4 for climate control-Style,0,
IDE01452-MAS01567,Personalization 4 for climate control-Synchronization,0,
IDE01452-MAS02015,Personalization 4 for climate control-AUTO,1,
IDE01452-MAS02804,Personalization 4 for climate control-Manual fan speed increase,not installed,
IDE01452-MAS03830,Personalization 4 for climate control-Footwell air distribution,0,
IDE01452-MAS03831,Personalization 4 for climate control-Upper body vent air distribution,0,
IDE01452-MAS03832,Personalization 4 for climate control-Air distribution up,0,
IDE01452-MAS04620,Personalization 4 for climate control-Fan setting: absolute,3,
IDE01452-MAS04621,Personalization 4 for climate control-Left neck heater,not installed,
IDE01452-MAS04648,Personalization 4 for climate control-Right neck heater,not installed,
IDE01452-MAS06077,Personalization 4 for climate control-Manual blower stage during defrost active,0,
IDE01452-MAS06366,Personalization 4 for climate control-Display blower levels,00000000 ,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,0, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,OFF,
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,OFF,
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,32.5, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,32.5, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,58.57, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,58.57, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,99, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,not coded / not installed,
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,not coded / not installed,
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not active,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,not coded / not installed,
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),0.0, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.0, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,0, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,OFF,
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,OFF,
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,29.8, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,29.8, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,65.11, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,65.11, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,99, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,not coded / not installed,
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,not coded / not installed,
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not active,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not active,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,not coded / not installed,
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),0.0, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.0, A
IDE01544-MAS05377,Auxiliary Air Heater-Low heat output relay,OFF,
IDE01544-MAS05378,Auxiliary Air Heater-High heat output relay,OFF,
IDE01544-MAS07914,Auxiliary Air Heater-Heating stage: spec value,OFF,
IDE01544-MAS12633,Auxiliary Air Heater-Relay for small heater output: current draw (effective value),0, mA
IDE01544-MAS12634,Auxiliary Air Heater-Relay for large heater output: current draw (effective value),0, mA
IDE01694-MAS01767,Left rear seat heater-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear seat heater-Left rear seat heater specified temperature,77.5, °C
IDE01694-MAS01769,Left rear seat heater-Left rear seat heater actual temperature,77.5, °C
IDE01694-MAS01770,Left rear seat heater-Left rear seat heater current,25.5, A
IDE01695-MAS01771,Right rear seat heater-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear seat heater-Right rear seat heater specified temperature,77.5, °C
IDE01695-MAS01773,Right rear seat heater-Right rear seat heater actual temperature,77.5, °C
IDE01695-MAS01774,Right rear seat heater-Right rear seat heater current,25.5, A
IDE02270-IDE01268,CAN input signal(s) status-Front windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management: shut-off stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE03008-IDE80251,Stop process prevented-Neck heating,not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS05009,Stop process prevented-A/C request: auxiliary heat mode,not active,
IDE03008-MAS05046,Stop process prevented-Evaporator temperature difference from setting,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03010-IDE80251,Number of prevented stop processes-Neck heating,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05009,Number of prevented stop processes-A/C request: auxiliary heat mode,0,
IDE03010-MAS05046,Number of prevented stop processes-Evaporator temperature difference from setting,0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-IDE80251,Number of requested start processes-Neck heating,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS03904,Number of requested start processes-Maximum permissible stop duration reached,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05009,Number of requested start processes-A/C request: auxiliary heat mode,0,
IDE03011-MAS05046,Number of requested start processes-Evaporator temperature difference from setting,0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03488,Driving time remaining for basic setting of compressor run in,60, s
IDE03527-ENG119301,CAN signals-BCM_01: BCM1_Rueckfahrlicht_Schalter,Not operated,
IDE03527-ENG119298,CAN signals-Dimmung_01: DI_KL_58xd,253,
IDE03527-ENG119297,CAN signals-Dimmung_01: DI_KL_58xs,100, %
IDE03527-ENG119296,CAN signals-Gateway_71: ESP_v_Signal,0.00, km/h
IDE03527-ENG119295,CAN signals-Gateway_73: MO_Drehzahl_01,949.25, /min
IDE03527-ENG119293,CAN signals-Klima_Sensor_02: BCM1_Aussen_Temp_ungef,30.0, °C
IDE03527-ENG119292,CAN signals-Kombi_02: KBI_Standzeit,23468, s
IDE03527-ENG119346,CAN signals-Motor_07: MO_Absperrventil_oeffnen,n/anicht_verfuegbar,
IDE03527-ENG128338,CAN signals-Motor_07: MO_Heizungspumpenansteuerung,80, %
IDE03527-ENG119291,CAN signals-Motor_07: MO_Kuehlmittel_Temp,90.75, °C
IDE03527-ENG119349,CAN signals-Motor_14: MO_Klima_Eingr,no intervention,
IDE03527-ENG119348,CAN signals-Motor_14: MO_StartStopp_Fahrerwunsch,Stoppverbot_durch_Fahrer,
IDE03527-ENG119289,CAN signals-Motor_14: MO_StartStopp_Motorstopp,Motor_Stop_inaktiv,
IDE03527-ENG119347,CAN signals-Motor_14: MO_StartStopp_Status,System_aktiv_keine_Freigabe_durch_StartStop_Koordinator,
IDE03527-ENG119290,CAN signals-Motor_14: MO_StartStopp_Wiederstart,Wiederstart_inaktiv,
IDE03527-ENG119287,CAN signals-Wischer_01: Waschen_vorne_aktiv,not active,
IDE03527-ENG119288,CAN signals-Wischer_01: Wischer_vorne_aktiv,not active,
IDE03527-ENG128339,CAN signals-ZV_02: ZV_Schluessel_Zugang,aktive_Funkschluessel_Nr_01,
IDE03537-MAS01482,Ionizer: status-Hardware version,not coded / not installed,
IDE03537-MAS01483,Ionizer: status-Software version,not coded / not installed,
IDE03537-MAS02829,Ionizer: status-High voltage,not coded / not installed,
IDE03537-MAS02830,Ionizer: status-Ionizer button,not coded / not installed,
IDE03537-MAS02831,Ionizer: status-Ionizer check light,not coded / not installed,
IDE03538-MAS01632,Ionizer: diagnosis-Status,No malfunction,
IDE03538-MAS02830,Ionizer: diagnosis-Ionizer button,not coded / not installed,
IDE03538-MAS02831,Ionizer: diagnosis-Ionizer check light,not coded / not installed,
IDE03538-MAS13074,Ionizer: diagnosis-Error validity status,not coded / not installed,
IDE04312-IDE04095,System run time-Engine running time,253, s
IDE04312-MAS00084,System run time-Terminal 15 on,14, s
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,not calculated,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,62.7, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,87.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,Malfunction,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,62.7, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,Initialization,
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,Initialization,
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,Initialization,
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,62.2, °C
IDE06219-IDE01011,Personalization 1 for climate control: top open-Data record,not active,
IDE06219-MAS01533,Personalization 1 for climate control: top open-Defrost,0,
IDE06219-MAS01534,Personalization 1 for climate control: top open-Recirculating air,0,
IDE06219-MAS01550,Personalization 1 for climate control: top open-AC,1,
IDE06219-MAS01552,Personalization 1 for climate control: top open-Left specified temperature,22.0,
IDE06219-MAS01553,Personalization 1 for climate control: top open-Right specified temperature,22.0,
IDE06219-MAS01554,Personalization 1 for climate control: top open-Left heated seat,0,
IDE06219-MAS01555,Personalization 1 for climate control: top open-Left seat ventilation,0,
IDE06219-MAS01556,Personalization 1 for climate control: top open-Right heated seat,0,
IDE06219-MAS01557,Personalization 1 for climate control: top open-Right seat ventilation,0,
IDE06219-MAS01560,Personalization 1 for climate control: top open-OFF,0,
IDE06219-MAS01562,Personalization 1 for climate control: top open-Air quality sensor,0,
IDE06219-MAS01563,Personalization 1 for climate control: top open-Auxiliary Air Heater,1,
IDE06219-MAS01566,Personalization 1 for climate control: top open-Style,1,
IDE06219-MAS01567,Personalization 1 for climate control: top open-Synchronization,0,
IDE06219-MAS02015,Personalization 1 for climate control: top open-AUTO,1,
IDE06219-MAS02804,Personalization 1 for climate control: top open-Manual fan speed increase,not installed,
IDE06219-MAS03830,Personalization 1 for climate control: top open-Footwell air distribution,0,
IDE06219-MAS03831,Personalization 1 for climate control: top open-Upper body vent air distribution,0,
IDE06219-MAS03832,Personalization 1 for climate control: top open-Air distribution up,0,
IDE06219-MAS04620,Personalization 1 for climate control: top open-Fan setting: absolute,3,
IDE06219-MAS04621,Personalization 1 for climate control: top open-Left neck heater,not installed,
IDE06219-MAS04648,Personalization 1 for climate control: top open-Right neck heater,not installed,
IDE06219-MAS06077,Personalization 1 for climate control: top open-Manual blower stage during defrost active,0,
IDE06219-MAS06366,Personalization 1 for climate control: top open-Display blower levels,00000000 ,
IDE06220-IDE01011,Personalization 2 for climate control: top open-Data record,not active,
IDE06220-MAS01533,Personalization 2 for climate control: top open-Defrost,0,
IDE06220-MAS01534,Personalization 2 for climate control: top open-Recirculating air,0,
IDE06220-MAS01550,Personalization 2 for climate control: top open-AC,1,
IDE06220-MAS01552,Personalization 2 for climate control: top open-Left specified temperature,22.0,
IDE06220-MAS01553,Personalization 2 for climate control: top open-Right specified temperature,29.5,
IDE06220-MAS01554,Personalization 2 for climate control: top open-Left heated seat,0,
IDE06220-MAS01555,Personalization 2 for climate control: top open-Left seat ventilation,0,
IDE06220-MAS01556,Personalization 2 for climate control: top open-Right heated seat,0,
IDE06220-MAS01557,Personalization 2 for climate control: top open-Right seat ventilation,0,
IDE06220-MAS01560,Personalization 2 for climate control: top open-OFF,0,
IDE06220-MAS01562,Personalization 2 for climate control: top open-Air quality sensor,0,
IDE06220-MAS01563,Personalization 2 for climate control: top open-Auxiliary Air Heater,1,
IDE06220-MAS01566,Personalization 2 for climate control: top open-Style,0,
IDE06220-MAS01567,Personalization 2 for climate control: top open-Synchronization,0,
IDE06220-MAS02015,Personalization 2 for climate control: top open-AUTO,1,
IDE06220-MAS02804,Personalization 2 for climate control: top open-Manual fan speed increase,not installed,
IDE06220-MAS03830,Personalization 2 for climate control: top open-Footwell air distribution,0,
IDE06220-MAS03831,Personalization 2 for climate control: top open-Upper body vent air distribution,0,
IDE06220-MAS03832,Personalization 2 for climate control: top open-Air distribution up,0,
IDE06220-MAS04620,Personalization 2 for climate control: top open-Fan setting: absolute,3,
IDE06220-MAS04621,Personalization 2 for climate control: top open-Left neck heater,not installed,
IDE06220-MAS04648,Personalization 2 for climate control: top open-Right neck heater,not installed,
IDE06220-MAS06077,Personalization 2 for climate control: top open-Manual blower stage during defrost active,0,
IDE06220-MAS06366,Personalization 2 for climate control: top open-Display blower levels,00000000 ,
IDE06221-IDE01011,Personalization 3 for climate control: top open-Data record,not active,
IDE06221-MAS01533,Personalization 3 for climate control: top open-Defrost,0,
IDE06221-MAS01534,Personalization 3 for climate control: top open-Recirculating air,0,
IDE06221-MAS01550,Personalization 3 for climate control: top open-AC,1,
IDE06221-MAS01552,Personalization 3 for climate control: top open-Left specified temperature,22.0,
IDE06221-MAS01553,Personalization 3 for climate control: top open-Right specified temperature,29.5,
IDE06221-MAS01554,Personalization 3 for climate control: top open-Left heated seat,0,
IDE06221-MAS01555,Personalization 3 for climate control: top open-Left seat ventilation,0,
IDE06221-MAS01556,Personalization 3 for climate control: top open-Right heated seat,0,
IDE06221-MAS01557,Personalization 3 for climate control: top open-Right seat ventilation,0,
IDE06221-MAS01560,Personalization 3 for climate control: top open-OFF,0,
IDE06221-MAS01562,Personalization 3 for climate control: top open-Air quality sensor,0,
IDE06221-MAS01563,Personalization 3 for climate control: top open-Auxiliary Air Heater,1,
IDE06221-MAS01566,Personalization 3 for climate control: top open-Style,0,
IDE06221-MAS01567,Personalization 3 for climate control: top open-Synchronization,0,
IDE06221-MAS02015,Personalization 3 for climate control: top open-AUTO,1,
IDE06221-MAS02804,Personalization 3 for climate control: top open-Manual fan speed increase,not installed,
IDE06221-MAS03830,Personalization 3 for climate control: top open-Footwell air distribution,0,
IDE06221-MAS03831,Personalization 3 for climate control: top open-Upper body vent air distribution,0,
IDE06221-MAS03832,Personalization 3 for climate control: top open-Air distribution up,0,
IDE06221-MAS04620,Personalization 3 for climate control: top open-Fan setting: absolute,3,
IDE06221-MAS04621,Personalization 3 for climate control: top open-Left neck heater,not installed,
IDE06221-MAS04648,Personalization 3 for climate control: top open-Right neck heater,not installed,
IDE06221-MAS06077,Personalization 3 for climate control: top open-Manual blower stage during defrost active,0,
IDE06221-MAS06366,Personalization 3 for climate control: top open-Display blower levels,00000000 ,
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Actual value,0,
IDE06234-MAS01448,Auxiliary heater: in stages-Specified value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE06279-IDE00707,Parking heater: customer setting-Operating mode,Comfort function,
IDE06279-MAS00106,Parking heater: customer setting-Year,2000,
IDE06279-MAS00107,Parking heater: customer setting-Month,0,
IDE06279-MAS00108,Parking heater: customer setting-Day,0,
IDE06279-MAS00109,Parking heater: customer setting-Hours,0,
IDE06279-MAS00110,Parking heater: customer setting-Minutes,0,
IDE06279-MAS01379,Parking heater: customer setting-Operating time,30, min
IDE06279,Parking heater: customer setting,Time 1,
IDE06279,Parking heater: customer setting,Time 3,
IDE06279,Parking heater: customer setting,not active,
IDE06279,Parking heater: customer setting,Time 2,
IDE06307-MAS00106,Stop prevention history data-Year,2000, yr
IDE06307-MAS00107,Stop prevention history data-Month,0, m
IDE06307-MAS00108,Stop prevention history data-Day,0, d
IDE06307-MAS00109,Stop prevention history data-Hours,0, H
IDE06307-MAS00110,Stop prevention history data-Minutes,0, min
IDE06307-MAS00111,Stop prevention history data-Seconds,0, s
IDE06307-MAS01517,Stop prevention history data-Defrost active,not active,
IDE06307-MAS01564,Stop prevention history data-Windshield defogger,not active,
IDE06307-MAS02802,Stop prevention history data-Interior temperature difference to specifications,not active,
IDE06307-MAS02803,Stop prevention history data-Interior vent difference to setting,not active,
IDE06307-MAS02804,Stop prevention history data-Manual fan speed increase,not active,
IDE06307-MAS04353,Stop prevention history data-Fogging hazard (humidity sensor),not active,
IDE06307-MAS04354,Stop prevention history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06307-MAS05009,Stop prevention history data-A/C request: auxiliary heat mode,not active,
IDE06307-MAS05046,Stop prevention history data-Evaporator temperature difference from setting,not active,
IDE06307-MAS05047,Stop prevention history data-Maximum cooling and heating set,not active,
IDE06307-MAS06551,Stop prevention history data-Seat ventilation,not active,
IDE06307-MAS09538,Stop prevention history data-max A/C,not active,
IDE06308-MAS00106,Start request history data-Year,2127, yr
IDE06308-MAS00107,Start request history data-Month,15, m
IDE06308-MAS00108,Start request history data-Day,31, d
IDE06308-MAS00109,Start request history data-Hours,31, H
IDE06308-MAS00110,Start request history data-Minutes,63, min
IDE06308-MAS00111,Start request history data-Seconds,63, s
IDE06308-MAS01517,Start request history data-Defrost active,not active,
IDE06308-MAS01564,Start request history data-Windshield defogger,not active,
IDE06308-MAS02802,Start request history data-Interior temperature difference to specifications,not active,
IDE06308-MAS02803,Start request history data-Interior vent difference to setting,not active,
IDE06308-MAS02804,Start request history data-Manual fan speed increase,not active,
IDE06308-MAS03904,Start request history data-Maximum permissible stop duration reached,not active,
IDE06308-MAS04353,Start request history data-Fogging hazard (humidity sensor),not active,
IDE06308-MAS04354,Start request history data-Interior comfort humidity too high (humidity sensor),not active,
IDE06308-MAS05009,Start request history data-A/C request: auxiliary heat mode,not active,
IDE06308-MAS05046,Start request history data-Evaporator temperature difference from setting,not active,
IDE06308-MAS05047,Start request history data-Maximum cooling and heating set,not active,
IDE06308-MAS06551,Start request history data-Seat ventilation,not active,
IDE06308-MAS09538,Start request history data-max A/C,not active,
IDE06545,Blower voltage for production routines,6.0, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,No effect,
IDE06593,Air recirculation for production routines,No effect,
IDE06750-IDE01011,Last customer settings-Data record,active,
IDE06750-MAS01533,Last customer settings-Defrost,0,
IDE06750-MAS01534,Last customer settings-Recirculating air,0,
IDE06750-MAS01550,Last customer settings-AC,1,
IDE06750-MAS01552,Last customer settings-Left specified temperature,22.0,
IDE06750-MAS01553,Last customer settings-Right specified temperature,22.0,
IDE06750-MAS01554,Last customer settings-Left heated seat,0,
IDE06750-MAS01555,Last customer settings-Left seat ventilation,0,
IDE06750-MAS01556,Last customer settings-Right heated seat,0,
IDE06750-MAS01557,Last customer settings-Right seat ventilation,0,
IDE06750-MAS01560,Last customer settings-OFF,0,
IDE06750-MAS01562,Last customer settings-Air quality sensor,0,
IDE06750-MAS01563,Last customer settings-Auxiliary Air Heater,0,
IDE06750-MAS01566,Last customer settings-Style,1,
IDE06750-MAS01567,Last customer settings-Synchronization,0,
IDE06750-MAS02015,Last customer settings-AUTO,0,
IDE06750-MAS02804,Last customer settings-Manual fan speed increase,not installed,
IDE06750-MAS03830,Last customer settings-Footwell air distribution,1,
IDE06750-MAS03831,Last customer settings-Upper body vent air distribution,0,
IDE06750-MAS03832,Last customer settings-Air distribution up,1,
IDE06750-MAS04620,Last customer settings-Fan setting: absolute,3,
IDE06750-MAS04621,Last customer settings-Left neck heater,not installed,
IDE06750-MAS04648,Last customer settings-Right neck heater,not installed,
IDE06750-MAS06077,Last customer settings-Manual blower stage during defrost active,5,
IDE06750-MAS06366,Last customer settings-Display blower levels,00000001 ,
IDE07991-MAS04446,A/C clutch-Relay activation status,active,
IDE08500-MAS07921,Left front seat ventilation setting-Balance setting,Not available,
IDE08500-MAS07928,Left front seat ventilation setting-Ventilation stage,not coded / not installed,
IDE08500-MAS07929,Left front seat ventilation setting-Power quota setting by energy management,Not available,
IDE08501-MAS07921,Right front seat ventilation setting-Balance setting,Not available,
IDE08501-MAS07928,Right front seat ventilation setting-Ventilation stage,not coded / not installed,
IDE08501-MAS07929,Right front seat ventilation setting-Power quota setting by energy management,Not available,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Parallel activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Parallel activation of backrest and seat cushion,
IDE10300,OBD Driving Cycle detected,active,
IDE11648-MAS01482,Driver side ionizer: status-Hardware version,not coded / not installed,
IDE11648-MAS01483,Driver side ionizer: status-Software version,not coded / not installed,
IDE11648-MAS02829,Driver side ionizer: status-High voltage,not coded / not installed,
IDE11648-MAS02830,Driver side ionizer: status-Ionizer button,not coded / not installed,
IDE11648-MAS02831,Driver side ionizer: status-Ionizer check light,not coded / not installed,
IDE11649-MAS01632,Driver side ionizer: diagnosis-Status,No malfunction,
IDE11649-MAS02830,Driver side ionizer: diagnosis-Ionizer button,not coded / not installed,
IDE11649-MAS02831,Driver side ionizer: diagnosis-Ionizer check light,not coded / not installed,
IDE11649-MAS13074,Driver side ionizer: diagnosis-Error validity status,not coded / not installed,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,0.0, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,not coded / not installed,
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,not coded / not installed,
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,not coded / not installed,
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,not coded / not installed,
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,not coded / not installed,
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,not coded / not installed,
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,not coded / not installed,
IDE11795,Supply voltage 2 for external components,3.2, V
IDE12141,History memory: parking heater,Write only channel,
IDE12141-MAS02526,History memory: parking heater-Activation,Write only channel,
IDE12141-MAS04390,History memory: parking heater-Active source,Write only channel,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine is running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13845,Production mode status,not active,
IDE16797,Pre-ventilation: total elapsed time of the function,0, s
IDE16798,Pre-ventilation: number of functions performed,0,
IDE16799,Pre-ventilation: remaining time,1460, d
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,57,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,33,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,79,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,18974, km
MAS11295,Refrigerant temperature,Measuring value not available,
ENG263724-ENG159700,Analysedaten Stellmotoren-saved_action_speed_control_motor_air_distribution_flap,8,
ENG263724-ENG119283,Analysedaten Stellmotoren-saved_action_speed_control_motor_air_recirculation_flap,16,
ENG263724-ENG159871,Analysedaten Stellmotoren-saved_action_speed_control_motor_defroster_flap,Measuring value not available,
ENG263724-ENG159698,Analysedaten Stellmotoren-saved_action_speed_control_motor_temperature_flap_left,13,
ENG263724-ENG159699,Analysedaten Stellmotoren-saved_action_speed_control_motor_temperature_flap_right,Measuring value not available,
ENG263725-MAS00106,Buzzer für Standheizung /Standlüftung-Year,2001,
ENG263725-MAS00107,Buzzer für Standheizung /Standlüftung-Month,0,
ENG263725-MAS00108,Buzzer für Standheizung /Standlüftung-Day,0,
ENG263725-MAS00109,Buzzer für Standheizung /Standlüftung-Hours,0,
ENG263725-MAS00110,Buzzer für Standheizung /Standlüftung-Minutes,0,
ENG263725-ENG161507,Buzzer für Standheizung /Standlüftung-buzzer_state,not active,
ENG263726-ENG119358,CAN Signale Standheizungsfunktion-Klima_03: STH_aktiv,0,
ENG263726-ENG119357,CAN Signale Standheizungsfunktion-Klima_03: STH_Ansteuerung,0,
ENG263726-ENG119359,CAN Signale Standheizungsfunktion-Klima_03: STL_aktiv,0,
ENG263726-ENG119355,CAN Signale Standheizungsfunktion-STH_01: STH_Fehlerstatus,0,
ENG263726-ENG119352,CAN Signale Standheizungsfunktion-STH_01: STH_Funk_aus,0,
ENG263726-ENG119351,CAN Signale Standheizungsfunktion-STH_01: STH_Funk_ein,0,
ENG263726-ENG119354,CAN Signale Standheizungsfunktion-STH_01: STH_Geblaese,0,
ENG263726-ENG119353,CAN Signale Standheizungsfunktion-STH_01: STH_LED,0,
ENG263726-ENG119356,CAN Signale Standheizungsfunktion-STH_01: STH_Texte,0,
ENG263727-ENG128249,CAN Signale Standklimatisierung 1-HVEM_04: HVEM_FreigabeKlimatisierung,0,
ENG263727-ENG128248,CAN Signale Standklimatisierung 1-HVEM_04: HVEM_KlimaMaxHVStrom,0,
ENG263727-ENG263812,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_Standklima_Timer_Status,0,
ENG263727-ENG128251,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_VK_Anf,0,
ENG263727-ENG128252,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_VK_Modus,0,
ENG263727-ENG128250,CAN Signale Standklimatisierung 1-HVLM_05: HVLM_VK_STH_Einsatz,6,
ENG263727-ENG128253,CAN Signale Standklimatisierung 1-Motor_14: MO_HYB_Fahrbereitschaft,0,
ENG263727-ENG128254,CAN Signale Standklimatisierung 1-Motor_EV_01: HV_Bordnetz_aktiv,0,
ENG263728-ENG128287,CAN Signale Standklimatisierung 2-Klima_EV_03: KL_EKK_Strom,1.5, A
ENG263728-ENG128288,CAN Signale Standklimatisierung 2-Klima_EV_03: KL_HV_Heizer_Strom,1.5, A
ENG263728-ENG128283,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_Standklima_RemoteModus,0,
ENG263728-ENG128282,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_Standklima_Status_02,0,
ENG263728-ENG128286,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_VK_Anf,6,
ENG263728-ENG128284,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_VK_Betriebsdauer,0, min
ENG263728-ENG128285,CAN Signale Standklimatisierung 2-Klima_EV_04: KL_Vorkond_Strategie,14,
ENG263747-IDE01352,Speicherdaten allgemein-Temperature unit,°C,
ENG263747-MAS02289,Speicherdaten allgemein-Outside temperature,30.0, °C
Elapsed Time: 00:19
blockmap-09-5WA-937-086-BM_WVWZZZCD6RW123439-20260903-1758.CSV
;SW:5WA-937-086-BM   HW:5WA-937-086-AT ---  09: Cent. Elect.
;Component:BCM37w_M134 0182, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_VW38.rod
;Thursday,03,September,2026,17:58:10:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 1D67DF5C9D368D52EC6-8048 SFD { }
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00301,Distance,18976, km
IDE00322,Status of basic setting,is running,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,active,
IDE01992-SFT33054,Installation list: current installations-Burglary protection control module 1 VL,active,
IDE01992-SFT33055,Installation list: current installations-Burglary protection control module 2 VR,active,
IDE01992-SFT33056,Installation list: current installations-Burglary protection control module 3 HL,active,
IDE01992-SFT33057,Installation list: current installations-Burglary protection control module 4 HR,active,
IDE01992-SFT33058,Installation list: current installations-Burglary protection control module 5 vehicle interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,active,
IDE01996-SFT33054,Installation list: specified installations-Burglary protection control module 1 VL,active,
IDE01996-SFT33055,Installation list: specified installations-Burglary protection control module 2 VR,active,
IDE01996-SFT33056,Installation list: specified installations-Burglary protection control module 3 HL,active,
IDE01996-SFT33057,Installation list: specified installations-Burglary protection control module 4 HR,active,
IDE01996-SFT33058,Installation list: specified installations-Burglary protection control module 5 vehicle interior,not active,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,Signal from door lock: engaged,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlock button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded / not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded / not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded / not installed,
IDE02495,Service-Key: Number of activations,1,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02515,Low beams,|Connector number,Connector terminal number
IDE02614-MAS02788,Reversing light switch-CAN,not coded / not installed,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02743,Main beam,|Connector number,Connector terminal number
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Initialization,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,60, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE02957,Ambient lighting,|Channel,Connector number
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,0,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127,Prevented stop processes (ring memory),|Last prohibited stop,Year
IDE03128,Requested start processes (ring memory),|,Year
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,not ready for sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary protection control module 1 VL,not ready for sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary protection control module 2 VR,not ready for sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary protection control module 3 HL,not ready for sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary protection control module 4 HR,not ready for sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary protection control module 5 vehicle interior,Ready For Sleep,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,System malfunction,
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,19.9, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,0.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,0.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638,Static cornering light,|Connector number,Connector terminal number
IDE03788,Status of basic headlamp setting,no request,
IDE04213,Central locking button,not coded / not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded / not installed,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking,not active,
IDE04254-MAS06465,Play protection for central locking-Fuel tank cover via button,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,30.0, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.9, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,On,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Comfort data bus,
IDE04925,Daytime running lamps,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,16.5, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,33100,
IDE05045-MAS05878,Front wiper module-level,not coded / not installed,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05725-MAS01634,Dimmer terminal 58xs-Supply voltage,100.0, %
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beams,not coded / not installed,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded / not installed,
IDE05742-MAS00063,Light switch position-OFF,not coded / not installed,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not coded / not installed,
IDE05742-MAS03835,Light switch position-Position lamps,not coded / not installed,
IDE05742-MAS03836,Light switch position-Rear fog lamp,not coded / not installed,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded / not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded / not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded / not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded / not installed,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Year
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,1600, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,1170, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,Additional information
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,not coded / not installed,
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,not coded / not installed,
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,not coded / not installed,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,not coded / not installed,
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0,
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,100.0,
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,100.0,
IDE06096-MAS01634,Interior lights-Supply voltage,active,
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded / not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded / not installed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded / not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE06864,Daytime running lights,|Connector number,Connector terminal number
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07159-MAS01155,Control module switch-off: counter-Control module,10,
IDE07293,History data of panic alarm,|Cause for alarm activation,Month
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Contact switch in lock cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,closed,
IDE08162-MAS06432,TSG driver side: signals for central locking-Interior lock switch,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Contact switch in lock cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Interior lock switch,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Interior lock switch,not coded / not installed,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Interior lock switch,not coded / not installed,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09895,Central locking-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG263791,Central locking-Cabin/Cargo lock,not active,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,not coded / not installed,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,not coded / not installed,
IDE08185,Counter for play protection of central locking,not active,
IDE08211-MAS03129,History data control module reset-Reset counter,0,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,AA B2 3E B1,
IDE08240,Transponder ID Key 2,C6 60 3E B1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,73 F2 40 CB,
IDE08343,Immobilizer Challenge,BD B6 01 A8,
IDE08516-IDE02743,LED headlights: light distribution requirement-Main beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,both sides,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,both sides,
IDE08516-MAS02946,LED headlights: light distribution requirement-Static cornering light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,105, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,85, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,143, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,117, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,116, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,18, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,135, mA
IDE10285-MAS02447,Release of rear lid exterior button-Activation,Enabled,
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10662-MAS17838,Light switch (button module)-Exterior lighting: global shutoff,OFF,
IDE10662,Light switch (button module),not active,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beams,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-Main beam,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Static cornering light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,Installed: not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,Installed: not active,
IDE11134-MAS04422,Light sequence HU test result-Brake light signal via CAN,Installed: not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,not coded / not installed,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,not coded / not installed,
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,6,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,6,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12263,Virtual radio key: vehicle ID,BD 4C AB BF 07 F8 3B F6 7B 62 57 97 0B 0B 5D 49,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,99 F7 7F 86,
IDE12466,Unlocking central locking system history data,|Control-section / cause,Key number
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded / not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded / not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded / not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded / not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCD6RW123439,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device not installed,
IDE13956-MAS01493,Key position replication: input signals-Engine is running,active,
IDE13956-MAS02248,Key position replication: input signals-Signal status,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14337-MAS01853,Vehicle inclination sensor: rotation angle-Left front,Not installed due to specific system,
IDE14337-MAS01855,Vehicle inclination sensor: rotation angle-Left rear,197.9, °
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,2,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 07,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 02 CD C1 F3 2A E5,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14665-IDE01097,Control unit for driving and comfort functions: status-Front passenger airbag -disabled- indicator lamp,OFF,
IDE14665-IDE04213,Control unit for driving and comfort functions: status-Central locking button,Initialization/not installed,
IDE14665-MAS01118,Control unit for driving and comfort functions: status-Air Conditioning,Not operated,
IDE14665-MAS01533,Control unit for driving and comfort functions: status-Defrost,Initialization/not installed,
IDE14665-MAS01535,Control unit for driving and comfort functions: status-Rear window defogger,Initialization/not installed,
IDE14665-MAS01564,Control unit for driving and comfort functions: status-Windshield defogger,Initialization/not installed,
IDE14665-MAS03834,Control unit for driving and comfort functions: status-Emergency signal flashing,Not operated,
IDE14665-MAS08072,Control unit for driving and comfort functions: status-Driving profile selection,Initialization/not installed,
IDE14665-MAS15376,Control unit for driving and comfort functions: status-Front passenger airbag indicator lamp on,OFF,
IDE14665-MAS18688,Control unit for driving and comfort functions: status-Parking,Not operated,
IDE14665-MAS18689,Control unit for driving and comfort functions: status-Parking: function display,OFF,
IDE14665-MAS18690,Control unit for driving and comfort functions: status-Driving mode selection: function lighting,OFF,
IDE14665-MAS18691,Control unit for driving and comfort functions: status-Emergency signal flashing: function lighting,OFF,
IDE14665-MAS18692,Control unit for driving and comfort functions: status-Car menu,Initialization/not installed,
IDE14665-MAS18693,Control unit for driving and comfort functions: status-Car menu: function lighting,OFF,
IDE14665-MAS18694,Control unit for driving and comfort functions: status-Windshield defogger: function lighting,OFF,
IDE14665-MAS18695,Control unit for driving and comfort functions: status-Driver assistance systems,Not operated,
IDE14665-MAS18696,Control unit for driving and comfort functions: status-Rear window heating: function lighting,OFF,
IDE14665-MAS18697,Control unit for driving and comfort functions: status-Defrost: function lighting,OFF,
IDE14665-MAS18698,Control unit for driving and comfort functions: status-Front passenger airbag indicator lamp on: inverted,OFF,
IDE14665-MAS18699,Control unit for driving and comfort functions: status-Front passenger airbag -Disabled- indicator lamp: inverted,OFF,
IDE14665-MAS18700,Control unit for driving and comfort functions: status-Central locking button: function lighting,OFF,
IDE14731-MAS01853,Vehicle inclination sensor: adaptation value (deflected)-Left front,Not installed due to specific system,
IDE14731-MAS01855,Vehicle inclination sensor: adaptation value (deflected)-Left rear,205.5, °
IDE14754-IDE08167,Anti-Theft Alarm System: cause of level 1 emergency activation-Sunroof: status standardization,Yes,
IDE14754-MAS06509,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module driver side: Timeout,not active,
IDE14754-MAS06510,Anti-Theft Alarm System: cause of level 1 emergency activation-Door ctrl. module frt.pass.side: Timeout,not active,
IDE14754-MAS06511,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module driver side rear: Timeout,not active,
IDE14754-MAS06512,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module frt. pass. side rear: Timeout,not active,
IDE14754-MAS19082,Anti-Theft Alarm System: cause of level 1 emergency activation-Trunk lid electronics: timeout,active,
IDE14754-MAS19083,Anti-Theft Alarm System: cause of level 1 emergency activation-Sunroof Control Module: no communication,not active,
IDE14754-MAS19092,Anti-Theft Alarm System: cause of level 1 emergency activation-A/C/heating electronics: timeout,active,
IDE14754-MAS20679,Anti-Theft Alarm System: cause of level 1 emergency activation-Front window regulator: driver side: status normalization,Yes,
IDE14754-MAS20680,Anti-Theft Alarm System: cause of level 1 emergency activation-Front window regulator: passenger side: status normalization,Yes,
IDE14754-MAS20681,Anti-Theft Alarm System: cause of level 1 emergency activation-Rear window regulator: driver side: status normalization,Yes,
IDE14754-MAS20682,Anti-Theft Alarm System: cause of level 1 emergency activation-Rear window regulator: passenger side: status normalization,Yes,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,not recognised,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not recognised,
IDE14958-SFT00008,Recognized actual fitting list: adapt-HVAC electronics,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not recognised,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not recognised,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not recognised,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not recognised,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not recognised,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not recognised,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not recognised,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for driver assistance systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,detected,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary protection control module 1 VL,detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary protection control module 2 VR,detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary protection control module 3 HL,detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary protection control module 4 HR,detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary protection control module 5 vehicle interior,not recognised,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Left rear door control module,detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Right rear door control module,detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not recognised,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not recognised,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 41,
IDE14993,Software composition list identification data,|Software Composition ID,System designation
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
IDE15114,Supply voltage for ambient lighting,|Connector number,Connector terminal number
IDE15848-MAS14747,DWA for interior monitoring: deactivation softkey-MIB softkey,operated,
IDE15848-MAS21162,DWA for interior monitoring: deactivation softkey-Signal: status deactivation,active,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.95, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.85, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.90, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.90, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,16.55, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,F5,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,17,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,59,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,5,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,79,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,18974, km
MAS01281,Back-up lamps,|Connector number,Connector terminal number
MAS02101-MAS07806,Child safety-Specified status,not coded / not installed,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS08228-MAS01632,Light sensor-Status,not coded / not installed,
MAS08228-MAS02851,Light sensor-Brightness,not coded / not installed,
MAS08228-MAS04121,Light sensor-Voltage,not coded / not installed,
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-Left taillight 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Power rear lid opening control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left neck heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right neck heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-Left taillight 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right taillight 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right taillight 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver's side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger's side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-Left taillight 1,Not available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left neck heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right neck heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-Left taillight 2,Not available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right taillight 1,Not available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right taillight 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-Left taillight 1,Not available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left neck heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right neck heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-Left taillight 2,Not available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right taillight 1,Not available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right taillight 2,Not available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-Left taillight 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271950,Bus identification of sub-bus users-Power rear lid opening control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left neck heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right neck heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-Left taillight 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right taillight 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right taillight 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver's side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger's side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,74 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
MAS18844,Number of repetition attempts for radio via low frequency range,|Function,Channel: ultra-high-frequency band
MAS18845,Number of repetition attempts for radio via ultra-high frequency range,|Function,Channel: ultra-high-frequency band
MAS18846,Suppression of passive unlocking: locking: engine start,|Reason for low pressure,Year
MAS18847,Authentication status for ID sensor 1,No response,
MAS18848,Authentication status for ID sensor 2,No response,
MAS18849,Authentication status for ID sensor 3,No response,
MAS18850,Authentication status for ID sensor 4,No response,
MAS18851,Authentication status for ID sensor 5,No response,
MAS18852,Authentication status for ID sensor 6,No response,
MAS18853,Authentication status for ID sensor 7,No response,
MAS18854,Authentication status for ID sensor 8,No response,
MAS18855-MAS02282,Radio data information from ID sensor 1 in low frequency range (LF)-Position,Unknown,
MAS18855-MAS19524,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18855-MAS19525,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18855-MAS19526,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18855-MAS19527,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18856-MAS02282,Radio data information from ID sensor 2 in low frequency range (LF)-Position,Unknown,
MAS18856-MAS19524,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18856-MAS19525,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18856-MAS19526,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18856-MAS19527,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18857-MAS02282,Radio data information from ID sensor 3 in low frequency range (LF)-Position,Unknown,
MAS18857-MAS19524,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18857-MAS19525,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18857-MAS19526,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18857-MAS19527,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18858-MAS02282,Radio data information from ID sensor 4 in low frequency range (LF)-Position,Unknown,
MAS18858-MAS19524,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18858-MAS19525,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18858-MAS19526,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18858-MAS19527,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18859-MAS02282,Radio data information from ID sensor 5 in low frequency range (LF)-Position,Unknown,
MAS18859-MAS19524,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18859-MAS19525,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18859-MAS19526,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18859-MAS19527,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18860-MAS02282,Radio data information from ID sensor 6 in low frequency range (LF)-Position,Unknown,
MAS18860-MAS19524,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18860-MAS19525,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18860-MAS19526,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18860-MAS19527,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18861-MAS02282,Radio data information from ID sensor 7 in low frequency range (LF)-Position,Unknown,
MAS18861-MAS19524,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18861-MAS19525,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18861-MAS19526,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18861-MAS19527,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18862-MAS02282,Radio data information from ID sensor 8 in low frequency range (LF)-Position,Unknown,
MAS18862-MAS19524,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18862-MAS19525,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18862-MAS19526,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18862-MAS19527,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18863,Run time measurement positive for relay attacks: radio communication,|ID sensor used,Time measurement trigger
MAS18864,Run time measurement negative for relay attacks: radio communication,|ID sensor used,Time measurement trigger
MAS18865,adapted allocation numbers between vehicle and ID sensor,|Learned wake pattern,Mileage|1718290236
MAS18866,Non-volatile memory access status,|Reason for access,kilometer reading|Default
MAS18867,Direction of movement record,|ID sensor 1,ID sensor 2
MAS18868-ENG129148,Number of shutdowns performed-Easy_close_function_counter,0,
MAS18869,Number of function cancellations,0,
MAS18870,Cause of last function cancellation,none,
MAS18893-ENG129135,Service Key status data-checksum_comparison_service_key1,not OK.,
MAS18893-ENG289723,Service Key status data-Day_sk_rte,3,
MAS18893-ENG289717,Service Key status data-Day_sk_uhf,0,
MAS18893-ENG289706,Service Key status data-Hour_sk_rte,17,
MAS18893-ENG289715,Service Key status data-Hour_sk_uhf,0,
MAS18893-ENG289710,Service Key status data-Minute_sk_rte,32,
MAS18893-ENG289721,Service Key status data-Minute_sk_uhf,0,
MAS18893-ENG289709,Service Key status data-Month_sk_rte,9,
MAS18893-ENG289705,Service Key status data-Month_sk_uhf,0,
MAS18893-ENG289708,Service Key status data-Seconds_sk_rte,28,
MAS18893-ENG289714,Service Key status data-Seconds_sk_uhf,0,
MAS18893-ENG289713,Service Key status data-Year_sk_rte,2026,
MAS18893-ENG289712,Service Key status data-Year_sk_uhf,2001,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,not active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
MAS19775-MAS06430,Status of sliding door rear driver side-Main notch contact of rotary latch,not coded / not installed,
MAS19775-MAS15328,Status of sliding door rear driver side-Interior door handle switch,Not available,
MAS19775-MAS19404,Status of sliding door rear driver side-Rear Driver Side Exterior Door Handle Switch: status,Not available,
MAS19775-MAS21226,Status of sliding door rear driver side-Mechanical separation door inside handle: status,not coded / not installed,
MAS19775-MAS21227,Status of sliding door rear driver side-Motor for safe: child safety: and crash activation,not coded / not installed,
MAS19775-MAS21228,Status of sliding door rear driver side-Rotary motor: activation,not coded / not installed,
MAS19775-MAS21237,Status of sliding door rear driver side-Virtual crash redundancy sensor: sliding door,not coded / not installed,
MAS19777-MAS06430,Status of sliding door passenger side rear-Main notch contact of rotary latch,not coded / not installed,
MAS19777-MAS15328,Status of sliding door passenger side rear-Interior door handle switch,Not available,
MAS19777-MAS19403,Status of sliding door passenger side rear-Rear Passenger Exterior Door Handle Switch: status,Not available,
MAS19777-MAS21226,Status of sliding door passenger side rear-Mechanical separation door inside handle: status,not coded / not installed,
MAS19777-MAS21227,Status of sliding door passenger side rear-Motor for safe: child safety: and crash activation,not coded / not installed,
MAS19777-MAS21228,Status of sliding door passenger side rear-Rotary motor: activation,not coded / not installed,
MAS19777-MAS21237,Status of sliding door passenger side rear-Virtual crash redundancy sensor: sliding door,not coded / not installed,
MAS25323,Ambient lighting: error locations,not installed,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,41,
ENG277599,ASIL_relevante_RDIDs,|Adapted values/adaptation,Status of adaptation|0A 72
ENG254556-MAS09527,Control_voltage_actual_value-Activation voltage: act. value,0.0, V
ENG254556-MAS10074,Control_voltage_actual_value-Supply voltage: actual value,0.0, V
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,PIN A16_A17 Komfort CAN,
ENG263729,Dataset_download_written_rdids,|ID data set,Number
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,240, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,154, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,11.1689, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,33100,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,21622,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Authentication
ENG254754,Kessy_deactivation_at_oru_access,|Duration_kessy_deactivation,Year
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,Communication,
ENG116909-ENG256024,LIN activity-LIN 11,not coded / not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded / not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded / not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded / not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,not coded / not installed,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG256030,LIN activity-LIN 7,not coded / not installed,
ENG116909-ENG256031,LIN activity-LIN 8,not coded / not installed,
ENG116909-ENG256032,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,33100,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,648.6297, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,655.22, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,655.22, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,655.22, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,12.96, V
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command
ENG263737,Play_Protection_Counter_Automatic_Function,not active,
ENG263737,Play_Protection_Counter_Automatic_Function,0,
ENG116792,Power up history,|Funktionsanforderung|0|0|0|0|0|0|0|0|0|0|,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,1,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,19, s
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,24, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,-0.06, km/(hs)
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,51,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,22,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,255,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,0,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,13.2, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,27, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,644.5754, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,50,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,3,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,72,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,33,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,12.2, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,14, °C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,188.7578, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,34,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,2,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,64,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,15,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,12.5, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,31, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,643.4092, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,31,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,140,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,64,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,255,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,12.6, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,21, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,633.0800, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,52,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,4,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,0,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,0,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,12.2, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,20, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,629.7480, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,35,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,31,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,80,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,14.7, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,16, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,622.9174, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,32,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,3,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,80,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,28,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,13.3, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,21, °C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,613.2546, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,29,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,24,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,208,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,28,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,9.3, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,21, °C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,613.2546, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,27,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,87,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,11,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,120,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,14.6, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,12, °C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,611.0888, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,36,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,1,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,192,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,255,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,12.2, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,17, °C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,350.1932, min
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254822,Status_automatic_function,Conditions_cyclic_scan_not_fullfilled,
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-kilometer reading,14925, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,16.1, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.6, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.9, V
ENG254842,UWB_box2box_measure_history,|Box2box_measurement_reason,Checked_rsad_node_box2box_measurement
ENG254843-ENG256296,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_hl,8,
ENG254843-ENG256297,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_hr,8,
ENG254843-ENG256298,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_in,0,
ENG254843-ENG256299,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_vl,14,
ENG254843-ENG256300,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_vr,2,
ENG122921-ENG121628,values_motorloads-mod_temp_fast,37, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,43, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,38, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),33164,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,12.9520, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,6553.4, °
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,2332516.049, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,49873.114, °C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1348101225,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,6553.4, °
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, °
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260, °
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,6553.4, °
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,51,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, °
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,2319291.287, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,163.7, °
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,13.1848, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,27.092, °C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,24.0, °
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,AB 66 CE 68 22 0B 2D 87 D6 4B A2 32,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,30,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 37 34 35 33 46 30 33 30 32 33 32 30 35 30 32 37 37 32,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,9252,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,21188,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,357,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,1923,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,23208,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,2517,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,1348,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,1236,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,884,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,602,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,1446,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,7695.703942, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,12462.527959, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,697.017314, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, °C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,4111,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,6195,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-80, °C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,112, °C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.5, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,0,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,12467,
Elapsed Time: 01:38
blockmap-10-5R3-919-294_WVWZZZCD6RW123439-20260903-1803.CSV
;SW:5R3-919-294   HW:5R3-919-294 ---  10: Park/Steer Assist
;Component:PDC 08 Kanal  H05 1550, Coding:0040010001
;EV_EPHVA18VW3800000,002036,EV_EPHVA18VW3800000_VW38.rod
;Thursday,03,September,2026,18:03:25:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 7CA1F2D8666C245ABB8-8028
Group,Description,Actual
IDE00018,Voltage terminal 15,12.9, V
IDE00957-MAS01632,Resulting distance of front sensors-Status,23, cm
IDE00958-MAS01632,Resulting distance of rear sensors-Status,83, cm
IDE00973,Outside temperature,30.00, °
IDE00974,Outside air temperature internally calculated,30.00, °
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,84, cm
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,63, cm
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,24, cm
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,29, cm
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,1.248, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,1.136, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,1.136, ms
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,1.136, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,1.136, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,1.120, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,1.168, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,1.104, ms
IDE01165,Park assist activation tone,OFF,
IDE01166,Supply voltage for park assist sensor,12.9, V
IDE01169,Audio lowering request,No,
IDE01588,Direction of travel,not recognised,
IDE02329,Allowance for vehicle fittings (width),0, cm
IDE03008-IDE03726,Stop process prevented-Parallel Parking Assistance,passive,
IDE03008-MAS00825,Stop process prevented-Parking Aid Control Module,passive,
IDE03010-IDE03726,Number of prevented stop processes-Parallel Parking Assistance,0,
IDE03010-MAS00825,Number of prevented stop processes-Parking Aid Control Module,0,
IDE03011-IDE03726,Number of requested start processes-Parallel Parking Assistance,0,
IDE03011-MAS00825,Number of requested start processes-Parking Aid Control Module,0,
IDE03684,Vehicle stopped,Yes,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307,Stop prevention history data,Parallel Parking Assistance,
IDE06307,Stop prevention history data,active,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308,Start request history data,Parallel Parking Assistance,
IDE06308,Start request history data,active,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,0, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,0, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,0, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,0, mm
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,8, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,185, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,0, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,169, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,11, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,28, bar
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2000,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2013,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2005,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,0,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,6,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,4,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,10,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,0,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,20,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,26,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,1,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,2,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,0,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,19,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,16,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,28,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,4,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,33,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,30,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,24,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,1,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,56,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,52,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,24.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-20.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,4.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-15.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,not active,
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-5.0, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-3.4, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-2.5, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-4.9, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-5.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-3.4, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-4.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-3.3, m
Elapsed Time: 00:05
blockmap-13-5WA-907-572-C_WVWZZZCD6RW123439-20260903-1803.CSV
;SW:5WA-907-572-C   HW:5WA-907-572-A ---  13: Auto Dist. Reg
;Component:ACC BOSCH MQB H45 0461, Coding:010310F5000740451247400800C040C44E4020000000000000000000000000
;EV_FRONTRADARBOSCHVW380,004021,EV_FRONTRADARBOSCHVW380_004_VW38.rod
;Thursday,03,September,2026,18:03:37:29755
;VCID: 4EC56810805066CA25C-801A
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,12.6, V
IDE00102,Control Module temperature,59, °C
IDE00310,Outside temperature,30.0, °C
IDE00391,Adaptive distance regulation: status,ACC_Off_MainSwitch_Off,
IDE00924,Steering angle,-1.800, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Front windshield wiper-Wiper active,not active,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,03 05 6D A1,
IDE02057-MAS02356,Dynamic calibration: status-Type of calibration,static,
IDE02057-MAS05634,Dynamic calibration: status-Progress,0, %
IDE02057-ENG279299,Dynamic calibration: status-Absolute_driving_distance,0, m
IDE02057-ENG279303,Dynamic calibration: status-Acceleration_out_of_range,Framework conditions currently not met,
IDE02057-ENG98465,Dynamic calibration: status-Calibration status,not started,
IDE02057-ENG279396,Dynamic calibration: status-Effective_driving_distance,0, m
IDE02057-ENG279410,Dynamic calibration: status-Fault_signal_active,Framework conditions currently not met,
IDE02057-ENG279411,Dynamic calibration: status-Few_locations,Framework conditions currently not met,
IDE02057-ENG279533,Dynamic calibration: status-Speed_out_of_range,Framework conditions currently not met,
IDE02057-ENG279572,Dynamic calibration: status-Yaw_rate_out_of_range,Framework conditions currently not met,
IDE02068-MAS00106,Time stamp-Year,2026,
IDE02068-MAS00107,Time stamp-Month,9,
IDE02068-MAS00108,Time stamp-Day,3,
IDE02068-MAS00109,Time stamp-Hours,18,
IDE02068-MAS00110,Time stamp-Minutes,3,
IDE02068-MAS00111,Time stamp-Seconds,38,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead approaching: ACC passive,100,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead approaching: ACC OFF,759,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead approaching: ACC passive,18,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead approaching: ACC OFF,123,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01447,Driving profile selection-Actual value,4,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE08343,Immobilizer Challenge,82 B1 63 79,
IDE08936,Misalignment angle: horiz,0.472, °
IDE09906,Vertical deadjustment,4.024, °
IDE10902-IDE00018,Expanded ambient data 1-Voltage terminal 15,12.7, V
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,59, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,30.0, °C
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS01632,Expanded ambient data 1-Status,ACC_Off_MainSwitch_Off,
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,-1.800, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.000, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Front windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.472, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,4.024, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2026,
IDE10903-MAS00107,Expanded ambient data 2-Month,9,
IDE10903-MAS00108,Expanded ambient data 2-Day,3,
IDE10903-MAS00109,Expanded ambient data 2-Hours,18,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,3,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,40,
IDE10903-MAS00711,Expanded ambient data 2-kilometer reading,18974, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.360, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,4.020, °
IDE10903-ENG255471,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,100, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,100, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,98, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,0.00, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|2|2|2|2|2|2|2|2|2|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|02 7D FA 00 57 00|,
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.360, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,4.020, °
IDE12062,Counter for terminal 15 reset,4216,
IDE12238,I network: discarded messages counter,0,
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,9,
IDE14998,Number of events: misalignment,0,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,0.260, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,1.000, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,0.20, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2023,
IDE15000-MAS00107,History data sensor calibration-Month,9,
IDE15000-MAS00108,History data sensor calibration-Day,4,
IDE15000-MAS00109,History data sensor calibration-Hours,12,
IDE15000-MAS00110,History data sensor calibration-Minutes,32,
IDE15000-MAS00111,History data sensor calibration-Seconds,4,
IDE15000-MAS00711,History data sensor calibration-kilometer reading,0, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,0.250, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,0.990, °
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE16615,Control module internal information,00 00 00,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,10,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 02 01 02 00 00 03 03 00 00 00 00 00 00 00 F4 00 00 00 00 03 00 00 00 14 00 00 00 00 00 00 3A 98 00 02 BF 20 00 00 01 F4 00 0A 02 0F 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,51,
MAS00370,Vehicle speed,0.00, m/s
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
ENG302951,DTCCodeRef_for_FAULT_CS520_TIMESTAMP,00 00 00,
ENG302952,DTCCodeRef_for_FAULT_MMIC_TIMESTAMP,00 00 00,
ENG302953,DTCCodeRef_for_FAULT_RIF_TIMESTAMP,00 00 00,
ENG302954,DTCCodeRef_for_FAULT_SPU_TIMESTAMP,00 00 00,
ENG302955,DTCCodeRef_for_FAULT_UC_TIMESTAMP,00 00 00,
ENG254718-MAS17521,Function_On_Demand_Unlock_ID_Status_Dev-Unlockable functions: activation status,|ID number,Release code for a SWaP function
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,10,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG139832,Sw_version_supplier,EV_FRONTRADARBOSCHVW38000402100µ©Ø=04615WA907572C SysC_37w_MOPF_0461_RC2000,
Elapsed Time: 00:18
blockmap-15-5WA-959-655-L_WVWZZZCD6RW123439-20260903-1804.CSV
;SW:5WA-959-655-L   HW:5WA-959-655-L ---  15: Airbags
;Component:AirbagVW40    010 0636, Coding:88CC008000F0C000000000000000000051540000205400004000F68000130065
;EV_AirbaVW40SMEVW38X,001032,EV_AirbaVW40SMEVW38X.rod
;Thursday,03,September,2026,18:04:05:29755
;VCID: 6099A6A8EAC4E0BA870-8034 SFD { }
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,not connected,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,476.0, Ohm
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,not connected,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,472.0, Ohm
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,not connected,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,476.0, Ohm
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,not installed,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,no measured value present,
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,not installed,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,no measured value present,
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Rear driver head curtain airbag igniter-Status,not installed,
IDE00947-MAS05030,Rear driver head curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Rear passenger head curtain airbag igniter-Status,not installed,
IDE00948-MAS05030,Rear passenger head curtain airbag igniter-Resistance,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,no measured value present,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,no measured value present,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01555,Number of frontal crashes,1,
IDE01557,Number of side crashes frt.pass. side,1,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,not installed,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,no measured value present,
IDE03800-MAS01632,Driver airbag release valve igniter-Status,no measured value present,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,no measured value present,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,not installed,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,not installed,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,255,
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,no measured value present,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,not installed,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Front driver side third row seat belt tensioner igniter-Status,not installed,
IDE08436-MAS05030,Front driver side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,not installed,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,not installed,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,not installed,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,correct,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,2.5, Ohm
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,0,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,0,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,0,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,not installed,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,not installed,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,no measured value present,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.2, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,not installed,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger front airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger front airbag igniter-Resistance,2.1, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,no measured value present,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,no measured value present,
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.5, Ohm
MAS00006-MAS01632,Front passenger thorax airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger thorax airbag igniter-Resistance,2.4, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,no measured value present,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,no measured value present,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.4, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.7, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,not installed,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,no measured value present,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver seat belt tension igniter-Resistance,2.4, Ohm
MAS00014-MAS01632,Front passenger seat belt tensioner igniter-Status,correct,
MAS00014-MAS05030,Front passenger seat belt tensioner igniter-Resistance,2.3, Ohm
MAS00015-MAS01632,Driver seat belt tensioner igniter 2-Status,correct,
MAS00015-MAS05030,Driver seat belt tensioner igniter 2-Resistance,2.6, Ohm
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,correct,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,2.6, Ohm
MAS00017-MAS01632,Igniter for Driver Belt Force Limiter-Status,no measured value present,
MAS00017-MAS05030,Igniter for Driver Belt Force Limiter-Resistance,no measured value present,
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,no measured value present,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,no measured value present,
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.7, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.5, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,not installed,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,not installed,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver active head restraint igniter/trigger-Status,not installed,
MAS00023-MAS05030,Driver active head restraint igniter/trigger-Resistance,no measured value present,
MAS00024-MAS01632,Front passenger active head restraint igniter/trigger-Status,not installed,
MAS00024-MAS05030,Front passenger active head restraint igniter/trigger-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,not connected,
MAS00025-MAS05030,Driver seat belt switch-Resistance,0.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,0.0, Ohm
MAS00031,Airbag deactivation status,On,
MAS00032-MAS01632,Key switch terminal 1-Status,On,
MAS00032-MAS05030,Key switch terminal 1-Resistance,720.0, Ohm
MAS00033-MAS01632,Key switch terminal 2-Status,On,
MAS00033-MAS05030,Key switch terminal 2-Resistance,1500.0, Ohm
MAS00035-MAS01632,Seat position sensor: driver side-Status,not installed,
MAS00035-MAS04136,Seat position sensor: driver side-Current,no measured value present,
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,not installed,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,no measured value present,
MAS00038-MAS01632,Seat occupied recognition rear  driver side-Status,Not assigned,
MAS00038-MAS05030,Seat occupied recognition rear  driver side-Resistance,no measured value present,
MAS00039-MAS01632,Seat occupied recognition rear  passenger side-Status,Not assigned,
MAS00039-MAS05030,Seat occupied recognition rear  passenger side-Resistance,no measured value present,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,Not assigned,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,no measured value present,
MAS00231-MAS01632,Seat occupant detection passenger side-Status,Not assigned,
MAS00231-MAS05030,Seat occupant detection passenger side-Resistance,412.0, Ohm
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,12.7, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,12.9, V
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,70 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:18
blockmap-17-5H0-920-340-C_WVWZZZCD6RW123439-20260903-1752.CSV
;SW:5H0-920-340-C   HW:5H0-920-340-C ---  17: Instruments
;Component:KOMBI         310 7380, Coding:04A4000063840008018062032000080800300800
;EV_DashBoardVDDMQB37W,003035,EV_DashBoardVDDMQB37W_003_VW38.rod
;Thursday,03,September,2026,17:52:11:29755
;VCID: 221DECA0A448B2AAD14-8076 SFD { }
IDE00019,Voltage terminal 30,12.7, V
IDE00021,Engine speed,948.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00196,Engine oil temperature,80, °C
IDE00316-IDE00500,Time-Hour,17, H
IDE00316-IDE00501,Time-Minute,52, min
IDE00316-MAS00111,Time-Seconds,11, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,9, Months
IDE00317-IDE00504,Date-Day,3, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,1957, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2035, mm
IDE01076,Time since ignition off,23469, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,0E 17 0D BB,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,30.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,253,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,100,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,100,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,253,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03471-ENG164384,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG174709,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,19.9, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,19.9, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,23.9, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,23.7, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,20.2, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,20.2, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,24.3, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,23.8, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,20.4, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,20.4, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,24.3, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,24.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,24.6, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,24.6, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,23.9, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,19.2, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,1890.0, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,1890.0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,1890.0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,1890.0, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,268, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,1, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,32767, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32767, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32767, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,2353,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,1102,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,270,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,73,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,5.9, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,267, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,6.6, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-IDE00802,Calculated volume-Full volume,45.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,6.6, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,3276.7, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,3276.7, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,3276.7, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,6.6, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,3276.7, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,3276.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,3276.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,6.6, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,6.6, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,6.6, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.18750, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-11.93750, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,6.5, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99683,Calculated volume-version_of_application,120,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0000000,
IDE03477-IDE00500,GPS time-Hour,17, H
IDE03477-IDE00501,GPS time-Minute,52, min
IDE03477-IDE00501,GPS time-Minute,37, min
IDE03477-IDE00502,GPS time-Year,2026, yr
IDE03477-IDE00503,GPS time-Month,9, Months
IDE03477-IDE00504,GPS time-Day,3, d
IDE03477-MAS00111,GPS time-Seconds,14, s
IDE03477-MAS00111,GPS time-Seconds,50, s
IDE03477-MAS03493,GPS time-last synchronization year,2026, yr
IDE03506,Distance: high resolution,01 21 88 0C,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 0E,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 06,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 06,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 0E,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,7F F0 01 F9,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,CF F0 02 E6,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,4F F0 02 FA,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 2F 6A,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 2F 6A,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,8F F0 2F 6A,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,CF F0 02 FA,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-ENG263219,Service -interval- display: history 1-Block_16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-ENG263219,Service -interval- display: history 2-Block_16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-ENG263219,Service -interval- display: history 3-Block_16,FF FF FF FF,
IDE03914-ENG263219,Service -interval- display: history 4-Block_16,FF FF FF FF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06592-MAS31502,Status: special functions-Luggage compartment remote control via mobile online services,locked,
IDE06592-MAS31503,Status: special functions-Sunroof remote control via mobile online services.,locked,
IDE06592-MAS31504,Status: special functions-Ventilation remote control via mobile online services,locked,
IDE06592-MAS31505,Status: special functions-Window and sunroof remote control via mobile online services,locked,
IDE06592-MAS31506,Status: special functions-Remote vehicle start via mobile online services,locked,
IDE06924,Performance display,0,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08343,Immobilizer Challenge,42 EF B3 B9,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,3099,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12972,Oil: theoretical service interval,25600.00, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,18810, km
IDE12976,Oil: remaining running time,328, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,Kilometres,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,18900,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of distance traveled,Kilometres,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,23200,
IDE12977-MAS07273,Oil status-Inspection: time,434,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,328,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,22,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCD6RW123439,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,11,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Unknown (0)
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG261531,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14126-MAS01167,Other function lights status-Actuation time,Unknown (0)
IDE14126-MAS01168,Other function lights status-Start parameter,00 00 00,
IDE14126-ENG261531,Other function lights status-IO Reached Status,Output diagnostic test not active,
IDE14127-MAS01167,Lights status-Actuation time,Unknown (0)
IDE14127-MAS01168,Lights status-Start parameter,00 00 00,
IDE14127-ENG261531,Lights status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Unknown (0)
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Unknown (0)
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0)
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Unknown (0)
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Distance,0, km
IDE14185-IDE00502,Gas systems test-Year,2001, yr
IDE14185-IDE00503,Gas systems test-Month,1, Months
IDE14185-IDE00504,Gas systems test-Day,1, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0, d
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14213-ENG103300,Service Key Master current data-Service_Data,FF EB 04 24 C8 D0 1A 09 03 11 20 1D 1E 4A 00 00 BD 10 48 11 E8 10 B2 11 08 DF 22 A2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0E FF FF 00 00 40 08,
IDE14214-ENG263244,Service Key Master write counter-Counter_current_clamp_15,1,
IDE14214-ENG263245,Service Key Master write counter-Counter_current_total,4534,
IDE14214-ENG263246,Service Key Master write counter-Counter_daily_clamp_15,0,
IDE14214-ENG263247,Service Key Master write counter-Counter_daily_total,3395,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,0,
IDE14214-ENG263298,Service Key Master write counter-state_current,Wait_Trigger,
IDE14214-ENG263299,Service Key Master write counter-State_daily,Wait_Speedlimit_Exceed,
IDE14214-ENG263221,Service Key Master write counter-transponder_id,00 00 00 00,
IDE14214-ENG263220,Service Key Master write counter-Transponder_type,00 00,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2026, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,7, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,9, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,14, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,9, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,40, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0, H
IDE14237-MAS00106,Authentic time: actual time-Year,1970, yr
IDE14237-MAS00107,Authentic time: actual time-Month,1, Months
IDE14237-MAS00108,Authentic time: actual time-Day,1, d
IDE14237-MAS00109,Authentic time: actual time-Hours,0, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,0, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,0, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0, H
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,00,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,|Verification failed|00 00|,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,|failed signature creation|00 00|,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,00,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,00,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,00,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 02 CD C1 F3 1B 88,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,00,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-ENG103935,Secure Onboard Communication: Freshness Values information-Parameter,|SOC PDU ID to which this freshness information is assigned,Freshness Value query status
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,|Missing key|00 00|,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,00,
IDE15081,Authentic time: status of distribution signal trigger,0,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,not active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,22, km
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,82 minutes,
ENG186121,Authentic_time_current_counter_kl15_since_last_sync,105,
ENG262946,Authentic_time_last_backend_response,|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||,
ENG186123,Authentic_time_last_client_response,2026-07-09T14:09:40Z,
ENG186123,Authentic_time_last_client_response,1970-01-01T00:00:00Z,
ENG186123,Authentic_time_last_client_response,105,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0.0,
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0.0,
ENG105830-ENG263248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG263249,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0.0,
ENG105830-ENG263250,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,0.0,
ENG105830-ENG263251,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,0.0,
ENG105830-ENG263252,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,0.0,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,71, %
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,194,
ENG99439,Instrument_recorder,07 73 80 00 4D 51 42 32 30 32 30 32 32 53 31 46 41 43 47 32 62 65 65 66 64 64 5F 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 05 06 05 06 05 06 05 06 05 00 00 20 00 C4 00 97 02 00 00 01 00 00 00 AF 56 06 00 08 A8 C6 63 1F 00 D6 00 8A 02 00 00 02 00 00 00 AF 56 06 00 08 A8 C6 63 1F 00 CA 00 B1 03 00 00 00 00 00 00 86 56 06 00 40 30 69 E3 20 00 C6 00 92 01 00 00 00 00 00 00 36 56 06 00 28 A2 4F 76 1F 00 CD 00 33 02 00 00 13 00 00 00 E0 44 06 00 F8 84 51 92 12 00 3B 01 66 02 00 00 00 00 00 00 C2 2E 06 00 78 2A 01 92 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 22 00 03 00 00 00 04 00 04 00 02 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 02 00 8C FF B7 00 00 10 1B 00 8C FF FF FF 00 00 C8 8F C8 C8 C8 C8 43 B7 00 00 00 13 2A 6B FF B7 00 00 00 00 00 00 54 41 A8 48 80 00 40 00 19 34 11 00 00 00 00,
ENG128745,Instrument_recorder_graphic,05 73 80 00 4D 51 42 32 30 32 30 32 32 53 31 46 47 43 5F 56 57 83 5A 06 00 24 8F 3B B5 84 00 00 00 06 00 00 00 00 01 0F 00 00 00 00 00 A8 2F 00 00 F7 0A 00 00 02 00 00 00 6E 53 06 00 C4 5B 97 06 BD 04 00 00 66 00 00 00 55 01 01 00 00 00 00 00 DD 27 00 00 01 00 00 00 02 00 00 00 83 5A 06 00 9C 97 B9 EA 0C 01 00 00 0E 00 00 00 0E 04 00 00 01 00 00 00 A8 2F 00 00 2C 00 00 00 02 00 00 00 85 5A 06 00 1C A3 E4 35 7D 00 00 00 06 00 00 00 46 01 0F 00 00 00 00 00 AF 2F 00 00 02 00 00 80 02 00 00 00 EC 08 06 00 48 7F 14 A5 C7 03 00 00 4D 00 00 00 14 06 00 00 02 04 00 00 26 01 00 00 00 00 00 00 02 00 00 00 23 0B 06 00 89 10 64 CA E8 01 00 00 18 00 00 00 B4 01 00 00 00 00 00 00 77 02 00 00 00 00 00 00 04 00 00 00 9C 3E 06 00 E2 DD A3 13 74 04 00 00 5D 00 00 00 33 01 00 00 8B 02 00 00 B5 1C 00 00 06 00 00 00 02 00 00 00 87 0F 06 00 5A 6C 3B C6 63 04 00 00 28 00 00 00 35 03 00 00 48 59 A5 5A 5B 05 00 00 00 00 00 00 04 00 00 00 FC 21 06 00 0D D4 7F 86 82 02 00 00 2F 00 00 00 E8 00 00 00 00 00 00 00 13 10 00 00 B5 00 00 00 04 00 00 00 D0 27 06 00 8C 20 E8 AE 63 04 00 00 28 00 00 00 35 03 00 00 B6 5E A5 5A 39 12 00 00 00 00 00 00 04 00 00 00 C2 2E 06 00 33 E0 FA 91 63 04 00 00 28 00 00 00 35 03 00 00 BB 5E A5 5A 6D 14 00 00 00 00 00 00 04 00 00 00 8B 34 06 00 7C D8 28 A2 63 04 00 00 28 00 00 00 35 03 00 00 7C 59 A5 5A B7 17 00 00 00 00 00 00 04 00 00 00 84 5A 06 00 04 DA 77 60 A4 02 00 00 37 00 00 00 E8 00 00 00 00 00 00 00 AC 2F 00 00 01 00 00 00 02 00 00 00 36 56 06 00 87 37 4C 76 EA 02 00 00 41 00 00 00 B1 03 00 00 00 00 00 00 C3 28 00 00 02 00 00 00 04 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 7E 00 00 00 9D 01 00 00 62 11 13 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 66 61 34 63 65 39 78 02 00 00 00 B5 2F 00 00 02 00 00 00 71 CD FF FF 00 00 00 00 D1 C4 FF FF 0E 00 00 00 03 5C F1 AE 01 FF FF FF,
ENG264452,Instrument_recorder_graphic_3,||05|73|80|00|4D|51|42|32|30|32|30|32|32|53|31|46|47|43|5F|56|57|83|5A|06|00|24|8F|3B|B5|84|00|00|00|06|00|00|00|00|01|0F|00|00|00|00|00|A8|2F|00|00|F7|0A|00|00|02|00|00|00|6E|53|06|00|C4|5B|97|06|BD|04|00|00|66|00|00|00|55|01|01|00|00|00|00|00|DD|27|00|00|01|00|00|00|02|00|00|00|83|5A|06|00|9C|97|B9|EA|0C|01|00|00|0E|00|00|00|0E|04|00|00|01|00|00|00|A8|2F|00|00|2C|00|00|00|02|00|00|00|85|5A|06|00|1C|A3|E4|35|7D|00|00|00|06|00|00|00|46|01|0F|00|00|00|00|00|AF|2F|00|00|02|00|00|80|02|00|00|00|EC|08|06|00|48|7F|14|A5|C7|03|00|00|4D|00|00|00|14|06|00|00|02|04|00|00|26|01|00|00|00|00|00|00|02|00|00|00|23|0B|06|00|89|10|64|CA|E8|01|00|00|18|00|00|00|B4|01|00|00|00|00|00|00|77|02|00|00|00|00|00|00|04|00|00|00|9C|3E|06|00|E2|DD|A3|13|74|04|00|00|5D|00|00|00|33|01|00|00|8B|02|00|00|B5|1C|00|00|06|00|00|00|02|00|00|00|87|0F|06|00|5A|6C|3B|C6|63|04|00|00|28|00|00|00|35|03|00|00|48|59|A5|5A|5B|05|00|00|00|00|00|00|04|00|00|00|FC|21|06|00|0D|D4|7F|86|82|02|00|00|2F|00|00|00|E8|00|00|00|00|00|00|00|13|10|00|00|B5|00|00|00|04|00|00|00|D0|27|06|00|8C|20|E8|AE|63|04|00|00|28|00|00|00|35|03|00|00|B6|5E|A5|5A|39|12|00|00|00|00|00|00|04|00|00|00|C2|2E|06|00|33|E0|FA|91|63|04|00|00|28|00|00|00|35|03|00|00|BB|5E|A5|5A|6D|14|00|00|00|00|00|00|04|00|00|00|8B|34|06|00|7C|D8|28|A2|63|04|00|00|28|00|00|00|35|03|00|00|7C|59|A5|5A|B7|17|00|00|00|00|00|00|04|00|00|00|84|5A|06|00|04|DA|77|60|A4|02|00|00|37|00|00|00|E8|00|00|00|00|00|00|00|AC|2F|00|00|01|00|00|00|02|00|00|00|36|56|06|00|87|37|4C|76|EA|02|00|00|41|00|00|00|B1|03|00|00|00|00|00|00|C3|28|00|00|02|00|00|00|04|00|00|00|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|00|00|00|00|7E|00|00|00|9D|01|00|00|62|11|16|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|61|66|61|34|63|65|39|78|02|00|00|00|B4|2F|00|00|02|00|00|00|72|CD|FF|FF|00|00|00|00|D1|C4|FF|FF|0E|00|00|00|03|5C|F1|AE|02|FF|FF|FF|,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,160,
Elapsed Time: 00:17
blockmap-19-5WA-907-530-AB_WVWZZZCD6RW123439-20260903-1753.CSV
;SW:5WA-907-530-AB   HW:5WA-907-530-L ---  19: CAN Gateway
;Component:GW2020 High   778 7105, Coding:0000808D0F00000000000000012303305301600902000300030100000001010000000000000000000000000000000000
;EV_GatewMQB2020,006012,EV_GatewMQB2020_006_VW38.rod
;Thursday,03,September,2026,17:53:14:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 08499E0822B478FAAF0-805C SFD { }
Group,Description,Actual
IDE00019,Voltage terminal 30,12.8, V
IDE00056,History data 1,000*2026-09-03-10:11*0000*00**,
IDE00056,History data 1,000*2000-01-01-00:00*0000*00*00000**,
IDE00056,History data 1,000*2000-01-01-00:00*0000*00**,
IDE00056,History data 1,000*2026-09-02-13:32*0009*00**,
IDE00056,History data 1,000*2026-09-03-17:31*0000*00*00198**,
IDE00057,History data 2,000*2026-08-25-19:45*000*009*+0.000*0-0-0-0-0-0-0*_*00**,
IDE00057,History data 2,000*2026-08-24-20:09*000*007*+0.000*0-0-0-0-0-0-0*_*00**,
IDE00057,History data 2,000*2026-09-02-19:06*000*000*+0.000*0-0-0-0-0-0-0*_*00*00000**,
IDE00057,History data 2,000*2026-08-27-11:10*000*006*+0.000*0-0-0-0-0-0-0*_*00**,
IDE00057,History data 2,000*2026-07-24-16:43*000*001*+0.000*0-0-0-0-0-0-0*_*00**,
IDE00058,History data 3,000*2026-09-02-19:26*1*1*040*000*0-0-1-0-1-0-0*_*0*01.0*02.1**,
IDE00058,History data 3,000*2026-08-27-11:09*1*0*039*017*0-0-0-0-0-0-0*_*0*00.0*00.0**,
IDE00058,History data 3,000*2026-09-02-19:06*3*0*019*000*0-0-0-0-0-0-0*_*0*01.0*02.1**,
IDE00058,History data 3,000*2026-09-02-18:56*3*0*020*000*0-0-1-0-1-0-0*_*0*01.0*02.0**,
IDE00058,History data 3,000*2026-09-02-18:55*1*0*028*010*0-0-1-0-1-0-0*_*0*01.0*01.9**,
IDE00058,History data 3,000*2026-09-02-20:05*1*1*069*000*0-0-1-0-1-0-0*_*0*01.1*02.1**,
IDE00058,History data 3,000*2026-09-02-20:04*1*1*066*000*0-0-1-1-1-0-0*_*0*01.1*02.1**,
IDE00058,History data 3,000*2026-09-02-20:03*1*1*066*000*0-0-1-1-1-0-0*_*0*01.1*02.1**,
IDE00058,History data 3,000*2026-09-02-19:05*1*0*019*000*0-0-0-0-0-0-0*_*0*01.0*02.1**,
IDE00058,History data 3,000*2026-08-27-11:10*3*0*023*006*0-0-0-0-0-0-0*_*0*00.0*00.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*---*----------*00000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,000*2000-01-01-00:00*00*000*---*----------*09962*02568*000.0*000.0*000.0**,
IDE00060,History data 5,000*2026-09-02-19:46*3*+0.000*13.19*000*05*-21.2*02560*09966*018974*0-1-0-0-1-0-0*_*1*0*01.0*02.1*000.0*02*08*00*00*02**,
IDE00060,History data 5,000*2026-09-02-20:02*3*+0.000*13.30*000*05*-21.5*02560*09966*018974*0-1-0-0-0-0-0*_*1*0*01.0*02.1*000.0*02*08*00*00*02**,
IDE00060,History data 5,000*2026-09-02-19:46*3*+0.000*13.12*000*05*-21.4*02560*09966*018974*0-1-0-0-0-0-0*_*1*0*01.0*02.1*000.0*02*08*00*00*02**,
IDE00061,History data 6,000*2026-09-03-10:58*036*+23*+000.7*00.00*0.00*000**,
IDE00061,History data 6,000*2026-09-01-10:44*036*+26*+000.2*00.00*0.00*000**,
IDE00061,History data 6,000*2026-09-02-20:08*041*+29*+000.5*00.20*0.00*000**,
IDE00061,History data 6,000*2026-08-31-20:43*041*+36*-000.2*00.10*0.00*000**,
IDE00061,History data 6,000*2026-09-02-20:53*034*+29*-000.1*00.00*0.00*000**,
IDE00061,History data 6,000*2026-09-01-13:22*036*+27*+000.1*00.00*0.00*000**,
IDE00061,History data 6,000*2026-09-02-15:44*038*+26*+000.4*00.00*0.00*000**,
IDE00061,History data 6,000*2026-09-03-10:11*039*+23*+000.1*00.00*0.00*000**,
IDE00061,History data 6,000*2026-09-02-20:37*039*+29*-000.3*00.20*0.00*000**,
IDE00061,History data 6,000*2026-08-31-20:19*041*+35*+002.9*00.30*0.00*000**,
IDE00062,History data 7,000*2026-09-03-11:00*037*+000.4*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-02-20:26*036*+002.2*000.1*00.1*00.1**,
IDE00062,History data 7,000*2026-09-02-15:49*000*+022.9*000.1*02.2*01.1**,
IDE00062,History data 7,000*2026-09-02-20:53*040*+000.5*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-08-31-20:49*036*+000.9*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-02-20:51*035*+000.7*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-01-10:45*036*+000.3*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-03-10:12*037*+001.7*000.1*00.3*00.0**,
IDE00062,History data 7,000*2026-09-01-13:23*039*+000.5*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-08-31-20:42*040*+000.3*000.0*00.0*00.0**,
IDE00063,History data 8,000*2000-01-01-00:00*0*00*00*00*00*-------------:--*00**,
IDE00063,History data 8,000*2026-09-02-20:08*1*01*00*00*00*-------------:--*00**,
IDE00064,History data 9,000*2000-01-01-00:00*000*000*000*000*00000*15.00*+00*00*00*00.00*00000*00000**,
IDE00065,History data 10,000*2000-01-01-00:00*00*00.0*13.50*000.0**,
IDE00065,History data 10,000*2026-09-02-20:38*1*000.0*0003.9*0*000.0*0000.0*00.20*0000034**,
IDE00066,History data 11,000*2026-08-31-20:39*000*000*000*000*0000*022*00.0*00.0*075*040*076*041*01**,
IDE00066,History data 11,000*2026-08-31-20:43*000*000*000*000*0000*006*00.0*00.0*075*040*074*041*01**,
IDE00066,History data 11,000*2026-08-27-00:00*000*000*000*000*0000*000*00.0*00.0*084*047*084*045*01**,
IDE00066,History data 11,000*2026-09-02-15:44*000*000*000*000*0000*004*00.0*00.0*071*038*072*038*01**,
IDE00066,History data 11,000*2026-09-03-10:11*000*000*000*000*0000*000*00.0*00.0*070*040*070*039*01*00000*00004*00000*00000*00021**,
IDE00067,History data 12,000*2000-01-01-00:00*0-0-0-0-0-0-0-0**,
IDE00067,History data 12,000*2000-01-01-00:00*0*000*000*-40*00*000*+00.00*13.5*0**,
IDE00067,History data 12,00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00067,History data 12,00000*00000*00000**,
IDE00068,History data 13,000*2000-01-01-00:00*0-0-0-0-0*000.0*00000**,
IDE00068,History data 13,000*2000-01-01-00:00*0-0-0-0-0*000.0**,
IDE00069,History data 14,000*2000-01-01-00:00*000.0*20.0*20.0**,
IDE00069,History data 14,000*2026-08-26-17:49*1*00000*0000*0000*00.00*131073*+33**,
IDE00069,History data 14,000*2026-08-26-17:40*1*00242*0000*0000*00.00*000064*+32**,
IDE00069,History data 14,000*2026-08-26-18:34*0*01834*0000*0000*00.70*131072*+38**,
IDE00069,History data 14,000*2026-08-26-19:33*000.0*04.0*04.0*0000.0**,
IDE00069,History data 14,000*2026-08-26-19:33*0*00000*0000*0000*00.00*131072*+42*0001.1*0000.0*0000.0**,
IDE00069,History data 14,000*2026-08-26-17:49*1*00337*0000*0000*00.00*131136*+33**,
IDE00069,History data 14,00033*00001*00011*00000*00000**,
IDE00071,History data 16,00028*00007*00002**,
IDE00071,History data 16,00024*00027*00007*00000**,
IDE00071,History data 16,00000*00000*00000**,
IDE00071,History data 16,00003*00003*00003*00011**,
IDE00071,History data 16,00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00071,History data 16,00000*00000*00000*00000**,
IDE00071,History data 16,00000*00001*00027*00014*00015**,
IDE00071,History data 16,0018974km**,
IDE00071,History data 16,00015*00002*00001**,
IDE00071,History data 16,00040*00000*00000*00001**,
IDE00071,History data 16,00001*00000*00000**,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,6,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,52,
IDE00634,Vehicle electric system current,43.997, A
IDE00767-ENG280618,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG280619,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG280620,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG280621,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,239,
IDE00767-ENG280656,No. of unscheduled ECU resets-Muc_Reset_Counter,1,
IDE00767-ENG280678,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG280679,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG280680,No. of unscheduled ECU resets-Reason_of_4th_last_reset,14,
IDE00767-ENG280681,No. of unscheduled ECU resets-Reason_of_5th_last_reset,1,
IDE00767-ENG280682,No. of unscheduled ECU resets-Reason_of_latest_reset,1,
IDE00767-ENG280768,No. of unscheduled ECU resets-Watchdog_Reset_Counter,23,
IDE01803,History data 17,000*2000-01-01-00:00*00*0*000*15.0*+00*00.0**,
IDE01803,History data 17,000*2000-01-01-00:00*00*0*000*15.0*+00*00.0*000*000**,
IDE01803,History data 17,000*2000-01-01-00:00*0*00.0*000*+00**,
IDE01803,History data 17,000*2000-01-01-00:00*0*00.0*000*+00*000*000**,
IDE01803,History data 17,00000*00000*00000*00000*00000*00000**,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.5, H
IDE01807-MAS00106,History data 21-Year,2026,
IDE01807-MAS00107,History data 21-Month,7,
IDE01807-MAS00108,History data 21-Day,8,
IDE01807-MAS00109,History data 21-Hours,16, H
IDE01807-MAS00110,History data 21-Minutes,20, min
IDE01807-MAS14375,History data 21-Cycle counter,4171,
IDE01807-MAS14376,History data 21-ECU 1,00 0E,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.5, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG159905,History data 21-Bus_ECU_1,Comfort data bus,
IDE01807-ENG159908,History data 21-Bus_ECU_2,Unknown,
IDE01807-ENG159911,History data 21-Bus_ECU_3,Unknown,
IDE01807-ENG159914,History data 21-Bus_ECU_4,Unknown,
IDE01807-ENG159917,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.0, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.3, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.3, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16910,History data 22-Migration data bus,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS18934,History data 22-VLAN Connect,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG255497,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG255498,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG255499,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG255500,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG255501,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.8, H
IDE01810-MAS00106,History data 24-Year,2026,
IDE01810-MAS00107,History data 24-Month,8,
IDE01810-MAS00108,History data 24-Day,27,
IDE01810-MAS00109,History data 24-Hours,17, H
IDE01810-MAS00110,History data 24-Minutes,16, min
IDE01810-MAS14375,History data 24-Cycle counter,4261,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,1B 00 00 0E,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Comfort data bus,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,23,
IDE01810-MAS20473,History data 24-Alerting message counter,1,
IDE01812-MAS01468,History data 26-Terminal 15,4334,
IDE01812-MAS03173,History data 26-Powertrain data bus,294,
IDE01812-MAS03174,History data 26-Comfort data bus,12599,
IDE01812-MAS03177,History data 26-Infotainment data bus,277,
IDE01812-MAS03178,History data 26-Suspension data bus,238,
IDE01812-MAS03180,History data 26-Local data bus,47,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12185,History data 26-Hybrid data bus,0,
IDE01812-MAS14374,History data 26-Totals,13455,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,0,
IDE01812-MAS16910,History data 26-Migration data bus,0,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,1,
IDE01813-MAS03174,History data 27-Comfort data bus,3807,
IDE01813-MAS03177,History data 27-Infotainment data bus,7044,
IDE01813-MAS03178,History data 27-Suspension data bus,316,
IDE01813-MAS12185,History data 27-Hybrid data bus,0,
IDE01813-MAS14374,History data 27-Totals,11168,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,0,
IDE01813-MAS16910,History data 27-Migration data bus,0,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,0,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS18934,History data 27-VLAN Connect,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,6916,
IDE01814-MAS03174,History data 28-Comfort data bus,1144,
IDE01814-MAS03177,History data 28-Infotainment data bus,710,
IDE01814-MAS03178,History data 28-Suspension data bus,5,
IDE01814-MAS12185,History data 28-Hybrid data bus,25408,
IDE01814-MAS14374,History data 28-Totals,5361,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,4144,
IDE01814-MAS16910,History data 28-Migration data bus,570,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS18934,History data 28-VLAN Connect,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.9, H
IDE01816-MAS00106,History data 30-Year,2026,
IDE01816-MAS00107,History data 30-Month,8,
IDE01816-MAS00108,History data 30-Day,27,
IDE01816-MAS00109,History data 30-Hours,9, H
IDE01816-MAS00110,History data 30-Minutes,46, min
IDE01816-MAS14375,History data 30-Cycle counter,4258,
IDE01816-ENG151642,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG151644,History data 30-Bus_2,Unknown,
IDE01816-ENG151646,History data 30-Bus_3,Unknown,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,3.1, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.0, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.0, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.5, H
IDE01817-MAS00106,History data 31-Year,2026,
IDE01817-MAS00107,History data 31-Month,7,
IDE01817-MAS00108,History data 31-Day,8,
IDE01817-MAS00109,History data 31-Hours,16, H
IDE01817-MAS00110,History data 31-Minutes,20, min
IDE01817-MAS14375,History data 31-Cycle counter,4171,
IDE01817-MAS14376,History data 31-ECU 1,00 0E,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.5, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG159905,History data 31-Bus_ECU_1,Comfort data bus,
IDE01817-ENG159908,History data 31-Bus_ECU_2,Unknown,
IDE01817-ENG159911,History data 31-Bus_ECU_3,Unknown,
IDE01817-ENG159914,History data 31-Bus_ECU_4,Unknown,
IDE01817-ENG159917,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.8, H
IDE01819-MAS00106,History data 33-Year,2026,
IDE01819-MAS00107,History data 33-Month,8,
IDE01819-MAS00108,History data 33-Day,27,
IDE01819-MAS00109,History data 33-Hours,17, H
IDE01819-MAS00110,History data 33-Minutes,16, min
IDE01819-MAS14375,History data 33-Cycle counter,4261,
IDE01819-MAS14393,History data 33-ID of the alerting message,1B 00 00 0E,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2026,
IDE01820-MAS00107,History data 34-Month,9,
IDE01820-MAS00108,History data 34-Day,3,
IDE01820-MAS00109,History data 34-Hours,17, H
IDE01820-MAS00110,History data 34-Minutes,31, min
IDE01820-MAS14375,History data 34-Cycle counter,4297,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 67,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,4298,
IDE01823-MAS14429,History data 37-Time in current cycle,0.3, H
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82A - 140A,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,0,
IDE01831-MAS06312,Generator variant-ASIC variant,4,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,1.9, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Duration of last driving cycle,0.3, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,39 43 BF 71,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-request idle speed increase,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Extractable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG299090,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,not active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,not engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,not engaged,
IDE05814,Individualization characteristic,18 62 E6 F9 A0,
IDE05960-IDE01827,Generator-Specified generator voltage,13.1, V
IDE05960-IDE01828,Generator-Generator DF Signal,45.175, %
IDE05960-IDE01829,Generator-Generator exciter current,2.250, A
IDE05960-IDE01830,Generator-Generator Status,On,
IDE05960-IDE01855,Generator-Generator current,44.6, A
IDE05960-MAS06306,Generator-Status generator release by engine,Request by Engine Control Module,
IDE05960-MAS06307,Generator-Status of battery charging function,not active,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,800, W
IDE05960-MAS21174,Generator-Generator reserve current,111.7, A
IDE05960-MAS21325,Generator-Ramp time,3, s
IDE06011-ENG118665,Selected driving profile-driving_profile,without_function,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0)
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,8.10,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognised,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognised,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,3.85, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,3.75, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,712, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,696, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,EB 04 91 85,
IDE08346-MAS06117,Generator Analysis-Specified voltage,16.0, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,13.0, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.1, V
IDE08346-MAS06866,Generator Analysis-Generator speed,2285, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,60, °C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,0, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Neck heating,Enabling stage 3,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,Enabled,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,Enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,Enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,Enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heating,Enabling stage 3,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,Enabling stage 3,
IDE09058-MAS06552,Energy management: consumer releases-Seat heating: front,Enabling stage 3,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,5.1, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,67, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,67, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,67, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,70,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,70,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometres,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,3.3, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery:  RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS23872,Extended battery diagnosis-Available extractable charge,26, Ah
IDE10674-ENG98590,Extended battery diagnosis-ERROR,---,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,0,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Actual value,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No component function,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No error recognized,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,0,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,1,
IDE11740,Ethernet counter connection interruptions: branch 5,0,
IDE11741,Ethernet counter connection interruptions: branch 6,1,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 19|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,68,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,1517,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|D8 18 2B E6 ED D4|,
IDE11762-IDE02766,Information break recommendation-Malfunction status,No malfunction,
IDE11762-MAS03095,Information break recommendation-Function status,Initialization,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 3D C6 DD|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,|MAC address|F8 38 69 CC 15 1F|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|F8 38 69 AD 62 4C|F8 38 69 E2 A7 C1|,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,Maximum charge DC/DC converter,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Activation,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Activation,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|5|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|5|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|3|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,1525,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,0,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12625,IP network: current link deceleration: branch 1,65535, µs
IDE12626,IP network: current link deceleration: branch 2,65535, µs
IDE12627,IP network: current link deceleration: branch 3,65535, µs
IDE12628,IP network: current link deceleration: branch 4,65535, µs
IDE12629,IP network: current link deceleration: branch 5,65535, µs
IDE12630,IP network: current link deceleration: branch 6,65535, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1, µs
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG255704,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnostic filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnostic filter: status-Mileage recorder,20, km
IDE13754-MAS16867,Diagnostic filter: status-Reason for deactivation,hood open,
IDE13754-MAS16875,Diagnostic filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00018974*2026-09-03-17:31:29*1*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00018974*2026-09-03-10:58:44*1*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00018974*2026-09-03-10:49:10*1*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00018974*2026-09-03-10:49:10*1*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00018974*2026-09-03-10:48:37*1*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCD6RW123439,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Malfunction,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,129,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,150,
IDE14260-ENG255502,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG255503,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 02 CD C1 F3 1F C8,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,System active: driving mode,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
IDE15854-MAS21195,Report system for deviations: blacklist data bus infotainment-CAN identifier invalid,00 00 00 00,
IDE15854-MAS21196,Report system for deviations: blacklist data bus infotainment-Event counter,0,
IDE15855-MAS21195,Report system for deviations: blacklist data bus drive-CAN identifier invalid,00 00 00 00,
IDE15855-MAS21196,Report system for deviations: blacklist data bus drive-Event counter,0,
IDE15856-MAS21195,Report system for deviations: violation of time specifications-CAN identifier invalid,00 00 00 00,
IDE15856-MAS21196,Report system for deviations: violation of time specifications-Event counter,0,
IDE15857-MAS21195,Report system for deviations: violations during signal change-CAN identifier invalid,00 00 00 00,
IDE15857-MAS21196,Report system for deviations: violations during signal change-Event counter,0,
IDE16801-ENG352080,Medium-voltage energy management: error data in the safety zone-Mvem_active_Drive_session,not active,
IDE16801-ENG355113,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_EnergyReserve_Limitation,not active,
IDE16801-ENG353935,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_EnergyReserve_Status_Qualification,1,
IDE16801-ENG357199,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_MV_EnergyReserve,3,
IDE16801-ENG355681,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_MV_FehlerNotfallreserve_CommunicationError,active,
IDE16801-ENG354958,Medium-voltage energy management: error data in the safety zone-Mvem_BMS_MV_FehlerNotfallreserve_Init_Failure,active,
IDE16936-IDE01834,Low-voltage energy management: key figures of the lead battery-Battery voltage,14.300, V
IDE16936-IDE01836,Low-voltage energy management: key figures of the lead battery-Battery current,0, A
IDE16936-IDE12072,Low-voltage energy management: key figures of the lead battery-Warning displays,no warning,
IDE16936-IDE17292,Low-voltage energy management: key figures of the lead battery-Charge indicator,53.750,
IDE16936-MAS04059,Low-voltage energy management: key figures of the lead battery-Battery temperature,-40, °C
IDE16936-MAS05030,Low-voltage energy management: key figures of the lead battery-Resistance,2.2, mOhm
IDE16936-MAS23197,Low-voltage energy management: key figures of the lead battery-Reason for warning display,0,
IDE16936-MAS23866,Low-voltage energy management: key figures of the lead battery-Limit resistance,8.6, mOhm
IDE16936-MAS23867,Low-voltage energy management: key figures of the lead battery-Escalation counter for battery alerts,1,
MAS00464-MAS00106,Standard - ambient data 1-Year,2083,
MAS00464-MAS00107,Standard - ambient data 1-Month,6,
MAS00464-MAS00108,Standard - ambient data 1-Day,7,
MAS00464-MAS00109,Standard - ambient data 1-Hours,6,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,32,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,79,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,18974, km
MAS00769-IDE02717,Multi-function steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multi-function steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multi-function steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multi-function steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multi-function steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multi-function steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multi-function steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multi-function steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multi-function steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multi-function steering wheel control module-MFL message counter,9,
MAS00769-MAS06030,Multi-function steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multi-function steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multi-function steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,No release by coordinator,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,25, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,active,
MAS04447-MAS05129,Engine running status-Motor,Engine is running,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,active,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|83|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12-volt battery-Battery current,0.641, A
MAS16744-IDE01837,12-volt battery-Temperature of battery sensor,48, °C
MAS16744-IDE01838,12-volt battery-Battery temperature,33, °C
MAS16744-IDE01839,12-volt battery-Battery charge status,75, %
MAS16744-IDE01841,12-volt battery-Battery internal resistance,5.2, mOhm
MAS16744-IDE01842,12-volt battery-Usable battery charge,39, Ah
MAS16744-IDE01948,12-volt battery-Battery internal resistance not normed,4.8, mOhm
MAS16744-IDE04186,12-volt battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12-volt battery-adapted battery capacity,102, Ah
MAS16744-MAS00362,12-volt battery-Battery voltage,12.961, V
MAS16744-MAS06086,12-volt battery-Total re-charge,2536.4, Ah
MAS16744-MAS06087,12-volt battery-Entire energy throughput,2555.2, Ah
MAS16744-MAS22232,12-volt battery-Battery aging: charge-related,68, %
MAS16744-MAS22233,12-volt battery-Battery aging: performance-related,74, %
MAS16744,12-volt battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge status,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.5, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.017, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,valid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 03 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,Available,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,25,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,03,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,Available,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,18 62 E6 F9 A0 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,64 F2 3B A2,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,74 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,105,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2026-07-09T14:09:40Z,
ENG254617-ENG299125,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu
ENG254617-ENG280661,DoIP_Status-number_of_total_ecu,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognised,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognised,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,12,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,not active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG254621-ENG255502,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG254621-ENG255503,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG254621-ENG255504,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG254621-ENG255545,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG254621-ENG255551,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,150,
ENG254621-ENG255553,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,129,
ENG254621-ENG255557,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,0.588, A
ENG254621-ENG255558,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG254621-ENG255559,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG254621-ENG256044,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,712, A
ENG254621-ENG256064,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,8.10,
ENG254621-ENG256101,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG254621-ENG256097,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG254621-ENG256098,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG254621-ENG256099,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG254621-ENG256100,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG254621-ENG256270,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG254621-ENG256620,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,12.959, V
ENG254622-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG254622-MAS21179,Energy_management_dashboard_display-Energy generator reports,0,
ENG254622-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG254622-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG299130,Gateway app. software identification-Gateway_applikation_software_identifikation,|nf_name,SW_VERSION|routing_gateway
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG254725-ENG256045,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG254725-ENG152043,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG254725-ENG255205,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG254727-ENG152029,HV-EM_energy_specification-High_voltage_battery_energy_information,102350,
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,102300, Wh
ENG254727-ENG152039,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG254728-ENG152030,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG254728-ENG152033,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG152037,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,0, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,0, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,OFF,
ENG254730-ENG152028,HV-EM_operation_limitation-High_voltage_battery_current_limitation,0, A
ENG254730-ENG255206,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,0.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,0, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG254743-ENG255799,Intrusion_detection_system_disable_time-ids_disable_timeslot,0, ms
ENG254777,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0)
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG151187-ENG256301,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188,MV-EM_48V_overvoltage_check,---,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,0.0, A
ENG151192,MV-EM_dc_power_desired,0, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,0, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG254783-ENG246261,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG254783-ENG274259,NVEM_12V_Rekuperation-Batterie_Ladezustand,1,
ENG254783-ENG274260,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG254783-ENG274261,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG254783-ENG274262,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG254783-ENG255379,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG254783-ENG255380,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG254783-ENG255700,NVEM_12V_Rekuperation-Energienetz,1,
ENG254783-ENG255703,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG254783-ENG255737,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG254783-ENG255738,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG254783-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG254783-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG254783-ENG252593,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG254783-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG254783-ENG256076,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,Neutral,
ENG254783-ENG256106,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG254783-ENG255165,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG254783-ENG256273,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG254783-ENG256306,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG254783-ENG101873,NVEM_12V_Rekuperation-Sonderveto,1,
ENG254783-ENG256364,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG254783-ENG256365,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG254783-ENG256366,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG254783-ENG256367,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG254783-ENG256368,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG254783-ENG256369,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG254783-ENG256399,NVEM_12V_Rekuperation-Status_Rekuperation,active,
ENG254783-ENG256400,NVEM_12V_Rekuperation-Status_Stromregelung,active,
ENG254784-ENG255286,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG254784-ENG255298,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG254784-ENG255179,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG254784-ENG255754,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG254784-ENG256398,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG254784-ENG256720,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG250370,NVEM_Grund_BEM_falsch_codiert,0,
ENG254786-ENG255308,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG254786-ENG255209,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG254787-ENG255299,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG254787-ENG255300,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG254787-ENG255779,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG254787-ENG255780,NVEM_HLR_Master-Heizleistungskontingent_Stufe,Stage 1,
ENG254788-ENG255369,NVEM_Zustand_HLR-BA2_ZuendungEin,0,
ENG254788-ENG255370,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG254788-ENG256423,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG254788-ENG256424,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG254788-ENG256425,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG254788-ENG256426,NVEM_Zustand_HLR-TabE_Crash,0,
ENG254788-ENG256427,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG254788-ENG256428,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG254788-ENG256429,NVEM_Zustand_HLR-TabNQ,0,
ENG280376,Reason_nvem_vehicle_electrical_system_state_diagnosis,0,
ENG280381-ENG280515,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_emergency_strategy,0,
ENG280381-ENG280516,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_failure_warning,not active,
ENG280381-ENG280517,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operating_quadrant,Standard mode,
ENG280381-ENG280518,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operational_restriction,not active,
ENG280381-ENG280519,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_service_information,OK,
Elapsed Time: 01:14
blockmap-23-5WA-909-059-AB_WVWZZZCD6RW123439-20260903-1804.CSV
;SW:5WA-909-059-AB   HW:3Q0-909-059-C ---  23: Brake Booster
;Component:EBKV          H09 0372, Coding:1002C140730000CE39E79C73000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016_VW38.rod
;Thursday,03,September,2026,18:04:39:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 1079B6685AE4303A770-8044 SFD { }
Group,Description,Actual
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,36.000, km/h
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,1.50000, bar
IDE05816-IDE09696,Input signals from data bus-Charisma driving program: CAN output value,No program,
IDE05816-MAS01078,Input signals from data bus-Vehicle model,Combustion engine,
IDE05816-MAS02357,Input signals from data bus-Vehicle identification,00 32 33 34 33 39,
IDE05816-MAS08111,Input signals from data bus-OBD std.,EOBD,
IDE05816-MAS19863,Input signals from data bus-Status of parking brake: electromechanical,Bremse_geschl_(Spannkraft_voll/reduziert),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08588-IDE00020,Sensor signals for electromechanical power brake-Terminal 15 status,Terminal 15 on,
IDE08588-IDE00102,Sensor signals for electromechanical power brake-Control Module temperature,56.0, °C
IDE08588-IDE02222,Sensor signals for electromechanical power brake-Driver brakes: qualification,OFF,
IDE08588-IDE02713,Sensor signals for electromechanical power brake-Brake lamp switch,OFF,
IDE08588-IDE02714,Sensor signals for electromechanical power brake-Brake test switch,On,
IDE08588-IDE11037,Sensor signals for electromechanical power brake-Brake light switch: qualification,On,
IDE08588-MAS00043,Sensor signals for electromechanical power brake-Terminal 30 power supply,12.9, V
IDE08588-MAS05192,Sensor signals for electromechanical power brake-Driver braking,OFF,
IDE08588-MAS06928,Sensor signals for electromechanical power brake-Supply voltage pedal travel sensor,4.9, V
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.0312500000, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.00000, Nm
IDE08588-MAS11639,Sensor signals for electromechanical power brake-Input rod travel,0.000000, mm
IDE08588-MAS18095,Sensor signals for electromechanical power brake-Output rod,0.000000, mm
IDE08588-MAS18096,Sensor signals for electromechanical power brake-Brake pedal travel,Initialization,
IDE08588-MAS18097,Sensor signals for electromechanical power brake-Brake test switch: qualification,On,
IDE08588-MAS18098,Sensor signals for electromechanical power brake-Driver brakes clearly,OFF,
IDE08623-MAS02163,OBD configuration-coded,EOBD,
IDE08623-MAS08097,OBD configuration-Status: OBD lamp,OFF,
IDE08623-MAS14472,OBD configuration-calculated,EOBD,
IDE08623-MAS19862,OBD configuration-Status of generic scan tool,OFF,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00000, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00000000000, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,Open,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.0000000, mm
IDE14229-MAS18099,Brake booster control status-Control mode,No activation,
IDE14229-MAS18101,Brake booster control status-Actuator Position,0.03124, mm
IDE14229-MAS18102,Brake booster control status-Actuator torque,0.00000, Nm
IDE14229-MAS18103,Brake booster control status-Actuator speed,0.00781, mm/s
IDE14229-MAS18104,Brake booster control status-Remaining hold time,0, s
IDE14696-MAS03458,Leak test-Differential pressure,0.0000, bar
IDE14696-MAS19863,Leak test-Status of parking brake: electromechanical,Open,
IDE14696-MAS19864,Leak test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leak test-Brake pressure 2,0, bar
IDE80221-ENG252453,Analysis 221-Driver On Pedal,false,
IDE80221-ENG252454,Analysis 221-iBooster Ready for Actuation,OFF,
IDE80221-ENG252457,Analysis 221-iBooster System Mode,ready,
IDE80221-ENG252455,Analysis 221-Pedal Apply Recognition HW Output,false,
IDE80221-ENG252458,Analysis 221-Thermal Limitation,not_active,
IDE80221-ENG252452,Analysis 221-Wakeup Information HW,On,
IDE80221-ENG252456,Analysis 221-Wakeup Information NET,On,
IDE80222,Analysis 222,00 40 99,
IDE80223,Analysis 223,1.7578125, mm/s
IDE80223,Analysis 223,0.0000000, mm
IDE80223,Analysis 223,102.8750000, mm/s
IDE80223,Analysis 223,0.00000000000, Nm
IDE80223,Analysis 223,40.7421875, mm
IDE80223,Analysis 223,1.78027343750, Nm
IDE80225,Analysis 225,4,
IDE80225,Analysis 225,0,
IDE80225,Analysis 225,not active,
IDE80226-ENG249302,Analysis 226-Umgesetztes Charisma-Fahrprogramm_Wert,0,
MAS10409-MAS00106,Time stamp-Year,2026,
MAS10409-MAS00107,Time stamp-Month,9,
MAS10409-MAS00108,Time stamp-Day,3,
MAS10409-MAS00109,Time stamp-Hours,18,
MAS10409-MAS00110,Time stamp-Minutes,4,
MAS10409-MAS00111,Time stamp-Seconds,40,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,70 minutes,
Elapsed Time: 00:02
blockmap-2B-2Q0-905-861-B_WVWZZZCD6RW123439-20260903-1804.CSV
;SW:2Q0-905-861-B   HW:2Q0-905-861-B ---  2B: Steer. Col. Lock
;Component:ELV-MQBB      H10 0040, Coding:0000000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW38.rod
;Thursday,03,September,2026,18:04:52:29755
;VCID: 323D1CE0F4A8222A214-8066
IDE00019,Voltage terminal 30,12.8,
IDE00021,Engine speed,947.50, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-outdated,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,Yes,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,Not available,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,7,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,not locked,
IDE02580,Number of unlocks,3617,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Closed,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,4,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,53,
MAS00464-ENG279797,Standard - ambient data 1-time indication,00,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
ENG128822-ENG255750,functional_check-Functional_Check_VW_EOL,Confirmed,
Elapsed Time: 00:04
blockmap-36-5QS-959-760-H_WVWZZZCD6RW123439-20260903-1805.CSV
;SW:5QS-959-760-H   HW:5QS-959-760-H ---  36: Seat Mem. Drvr
;Component:MEM-FS        011 0372, Coding:01589A400000B0508803010101010000000000212100000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW38.rod
;Thursday,03,September,2026,18:05:01:29755
;VCID: 6597B7BCF5E68592746-8030
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,12.90, V
IDE00102,Control Module temperature,52,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management: shut-off stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34342,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32759,
IDE06510-MAS02282,Adjustment for backrest angle-Position,33024,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,1,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,1,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Standardization,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,32788,
IDE06511-MAS01391,Seat height adjustment-Block 2,32210,
IDE06511-MAS02282,Seat height adjustment-Position,32777,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,0,
IDE06511-MAS04160,Seat height adjustment-Load change,0,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Standardization,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,578,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33182,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32520,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,33160,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,96,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,96,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Standardization,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,662,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,32922,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32648,
IDE06683-MAS02282,Seat inclination adjustment-Position,32914,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,0,
IDE06683-MAS04160,Seat inclination adjustment-Load change,0,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Standardization,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,274,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,31958,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,33028,
IDE06684-MAS02282,Lumbar support height adjustment-Position,31956,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,25, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,1,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,3,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Standardization,standardized,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,1070,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,standardized,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,32751,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,33226,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,32955,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,25, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,1,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,1,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Standardization,standardized,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,475,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,standardized,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,256,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,33036,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,32456,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,32580,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,32733,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,32022,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,32759,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,33036,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,32456,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,32580,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,32733,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,32022,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,32759,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,33024,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,32777,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,33100,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,32914,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,31958,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,32955,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,33074,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,32777,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,32830,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,32914,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,32022,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,32903,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,33129,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,32235,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,32849,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,32761,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,32022,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,32903,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Standardization,not standardized,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Standardization,not standardized,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Standardization,not standardized,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Rocker,Not operated,
IDE09082,Massage function button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,standardized,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,standardized,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not standardized,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not standardized,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not standardized,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not standardized,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not standardized,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not standardized,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not standardized,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,standardized,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not standardized,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Standardization,not standardized,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,31958,
IDE11025-MAS01391,Headrest length adjustment-Block 2,33028,
IDE11025-MAS02282,Headrest length adjustment-Position,31956,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,25, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,1,
IDE11025-MAS04160,Headrest length adjustment-Load change,3,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Standardization,standardized,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,1070,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,standardized,
IDE11957-MAS01390,Display unit adjustment-Block 1,31958,
IDE11957-MAS01391,Display unit adjustment-Block 2,33028,
IDE11957-MAS02282,Display unit adjustment-Position,31956,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,25, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,1,
IDE11957-MAS04160,Display unit adjustment-Load change,3,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Standardization,standardized,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,1070,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,standardized,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,32751,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,33226,
IDE11969-MAS02282,Adjustment of foot rest-Position,32955,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,25, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,1,
IDE11969-MAS04160,Adjustment of foot rest-Load change,1,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Standardization,standardized,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,475,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,standardized,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,32751,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,33226,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,32955,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,25, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,1,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,1,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Standardization,standardized,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,475,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,standardized,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,standardized,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,standardized,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,standardized,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,33024,
ENG139951-IDE06511,Account_1-Seat height adjustment,32777,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,33100,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,32914,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,31958,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,32955,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,33074,
ENG139952-IDE06511,Account_2-Seat height adjustment,32777,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,32830,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,32914,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,32022,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,32903,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,33129,
ENG139953-IDE06511,Account_3-Seat height adjustment,32235,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,32849,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,32761,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,32022,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,32903,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Normierroutine,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Normierroutine,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,81 88 7F 08 81 9E 00 07 81 00 7F F7 86 26 00 07 80 09 7D D2 80 14 00 07 80 92 7F 88 80 9A 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 BB 7F EF 81 CA 00 07 7C D4 7C D6 81 04 00 07,
ENG247801-ENG248078,info_developer-gl_lo,35 51 53 39 35 39 37 36 30 48 20 00 00 00 00 00 30 33 37 30 00 00 00 00 32 35 34 31 00 00 00 00 53 43 58 58 4D 51 42 56 57 33 38 58 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 2A 00 3D 03 00 00 03 00 04 04 02 01 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,06 01 00 00 00 00 00 00 94 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,662,
ENG157282-ENG161451,Maximum travel-Axis_1_last,0,
ENG157282-ENG161452,Maximum travel-Axis_10_current,1070,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,578,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,274,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,475,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG247932,missing_pre_conditions-_reserviert,0,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG100589,missing_pre_conditions-Reserviert 2,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,554,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32955,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,31956,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,31956,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32955,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,33024,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,31956,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32955,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,32777,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,33160,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,32914,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 2,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,Key 1,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:21
blockmap-42-5Q0-959-593-L_WVWZZZCD6RW123439-20260903-1805.CSV
;SW:5Q0-959-593-L   HW:5Q0-959-593-F ---  42: Door Elect, Driver
;Component:TSG FS004 0350, Coding:003B13208200040008001000
;EV_DCU2DriveSideMAXHKLO,001018,EV_DCU2DriveSideMAXHKLO_VW27.rod
;Thursday,03,September,2026,18:05:44:29755
;VCID: 4ACD64007C384AEA794-801E
IDE00310,Outside temperature,31.00, °C
IDE01766-MAS02248,Distance impulses-Signal status,OK,
IDE01992-MAS12276,Installation list: current installations-Front door control module,reachable,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,not reachable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Not assigned,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.80, V
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.60, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Bus sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating State,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,Not assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,57, %
IDE04539-MAS02229,Mirror memory-Y coordinate,55, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Center position,
IDE04580,Dimming of inside door handle lighting,0, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not installed,
IDE05071-MAS02594,Lane change assistance button-Indicator lamp in button,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,Implausible,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,100, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator lamp in button,not coded / not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded / not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,97.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle state,
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,Not available,
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Top position,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,BM06,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,17.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,0.00, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,0.00, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,0.00, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,0.00, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,not active,
IDE07405-MAS02447,Enable driver front window regulator relay-Activation,Yes,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Activation,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,26, °C
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,Not available,
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07543,Vehicle speed,0.00, km/h
IDE08205-MAS01453,Closing aid-Blocking detection,not active,
IDE08205-MAS02103,Closing aid-Signal from door lock: catch,Implausible,
IDE08205-MAS05370,Closing aid-Direction of movement,Not available,
IDE08205-MAS08613,Closing aid-Return contact,closed,
IDE08205-MAS08614,Closing aid-Closing assist motor current,Not available,
IDE08205-MAS09346,Closing aid-Door position,closed,
IDE08205-MAS09347,Closing aid-Redundant door contact,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08795,Rear shade button,not installed,
IDE09071-MAS00030,Seat belt positioner-Seat occupant detection,not active,
IDE09071-MAS02666,Seat belt positioner-Seat belt buckle scan,Open,
IDE09071-MAS05370,Seat belt positioner-Direction of movement,Not available,
IDE09071-MAS08502,Seat belt positioner-Standardized belt feeder,No,
IDE09071-MAS08503,Seat belt positioner-End stop of Hall sensor,not recognised,
IDE09071-MAS08504,Seat belt positioner-Position of belt feeder,Not available,
IDE09071-MAS08505,Seat belt positioner-Motor current of belt feeder,Not available,
IDE09335,Mirror fold-in: current consumption,Not available,
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatic dimming outside mirror-Status,not installed,
IDE10164-MAS03691,Automatic dimming outside mirror-Dimming,0, %
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
IDE12336-MAS03095,Door heating element 2-Function status,not installed,
IDE12336-MAS04136,Door heating element 2-Current,not installed,
IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,Not operated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,Not operated,
IDE12422-IDE04411,Driver side front door control head-Child safety button,Not operated,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y direction),bottom position,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,Not operated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,Not operated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,not installed,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,Not operated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,Not operated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,not installed,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,Not operated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,Not operated,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,not installed,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,not installed,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,not installed,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,not installed,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6)
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,Not available,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,Not available,
IDE14109,Excess temperature shutdown of close assist,not active,
IDE15336,Light output 1 pin D8 target brightness on front driver side,0, %
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,0, %
IDE15339,Light output 4 pin D16 target brightness on front driver side,Not available,
IDE15636,Light output 2 pin D3 target brightness on front driver side,0, %
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location,Driver side exterior door handle lamp,
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location,Driver side exterior door handle lamp,
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location,Mirror welcome light on driver side,
IDE16392-MAS25781,Front ambient Lighting configuration - light output 4-Malfunction location,Unknown (255)
MAS01872,Rear lid remote release button,not installed,
MAS02101,Child safety,not active,
MAS06010,Ambient light,0, %
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J926 ,
Elapsed Time: 00:09
blockmap-44-5WA-907-145-G_WVWZZZCD6RW123439-20260903-1806.CSV
;SW:5WA-907-145-G   HW:5WA-907-145-C ---  44: Steering Assist
;Component:BASGEN1MQB37  502 1040, Coding:0000000000000000000102010100010000000101010101
;EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007.rod
;Thursday,03,September,2026,18:06:04:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 4EC56810805066CA25C-801A
Group,Description,Actual
IDE00019,Voltage terminal 30,12.87, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,954, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,0,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Not blocked,
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,0,
IDE02202,End stage temperature,52, °C
IDE02955,System status,Driving mode,
IDE03682-IDE04457,motor position sensor-Speed of electric drive motor,-18000.1, /min
IDE03682-MAS02961,motor position sensor-Engine angle,1, °
IDE03735,Steering torque,0.0, Nm
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,100, %
IDE04448,Steering angle sensor: angle,-4.19999, °
IDE04454,Steering angle sensor: angle speed,0, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,161.2, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,-1.7, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,detected,
IDE05155,Power steering current consumption,0.0, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,80.66, mm
IDE05162-MAS11514,Software end stop-End stop right,-80.55, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,not performed,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,not performed,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE07543,Vehicle speed,0, km/h
IDE10300,OBD Driving Cycle detected,active,
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Preconditions met,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,no restriction,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Preconditions met,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,2,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,no restriction,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,100.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine speed,Met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,Met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,not active,
ENG157712,Current_gradient_limiting,11.9, %
ENG157713,Current_limiting,0.0, %
Elapsed Time: 00:07
blockmap-52-5Q0-959-592-L_WVWZZZCD6RW123439-20260903-1806.CSV
;SW:5Q0-959-592-L   HW:5Q0-959-592-F ---  52: Door Elect, Pass.
;Component:TSG BFS004 0350, Coding:003B11208E00040000801000
;EV_DCU2PasseSideMAXHKLO,001018,EV_DCU2PasseSideMAXHKLO_VW27.rod
;Thursday,03,September,2026,18:06:20:29755
;VCID: 49CF5B0C793E41F270E-801C
IDE00310,Outside temperature,33.00, °C
IDE01766-MAS02248,Distance impulses-Signal status,Not available,
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.80, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.70, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,40, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Top position,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,not active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.50, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,Not available,
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Idle state,
IDE06872,Front passenger power window button,Not operated,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,BM06,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,15.00, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE06941,Rear window regulator child lock: frt.pass. side,not active,
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Activation,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Activation,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,27, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,Not available,
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,0.00, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,0.00, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,0.00, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE10930-IDE02266,Window regulator control unit: front passenger side-Passenger side rear power window button,not installed,
IDE10930-IDE04220,Window regulator control unit: front passenger side-Driver power window button,not installed,
IDE10930-IDE06621,Window regulator control unit: front passenger side-Driver side rear power window button,not installed,
IDE10930-IDE06872,Window regulator control unit: front passenger side-Front passenger power window button,not installed,
IDE15340,Light output 1 pin D8 target brightness on front passenger side,0, %
IDE15341,Light output 2 pin D3 target brightness on front passenger side,0, %
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,0, %
IDE15343,Light output 4 pin D16 target brightness on front passenger side,Not available,
IDE16389-MAS25781,Front ambient Lighting configuration - light output 1-Malfunction location,Front passenger side exterior door handle lamp,
IDE16390-MAS25781,Front ambient Lighting configuration - light output 2-Malfunction location,Front passenger side exterior door handle lamp,
IDE16391-MAS25781,Front ambient Lighting configuration - light output 3-Malfunction location,Mirror welcome light on front passenger side,
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J927 ,
Elapsed Time: 00:07
blockmap-5F-5H0-035-820-P_WVWZZZCD6RW123439-20260903-1806.CSV
;SW:5H0-035-820-P   HW:5H0-035-820 ---  5F: Information Electr.
;Component:MU-O-ND-EU    H61 1989, Coding:23800000000000000000000000000000000000000000000000
;EV_MUOIMQB37w,001002,EV_MUOIMQB37w_001_VW38.rod
;Thursday,03,September,2026,18:06:39:29755
;VCID: 2F3B1594E79A0FC24EA-807A SFD { }
IDE00019,Voltage terminal 30,12.70, V
IDE00021,Engine speed,948.50, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,66, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-2, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,46, °C
IDE00767,No. of unscheduled ECU resets,0,
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Right rear speaker,
IDE00916-ENG249480,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG249518,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG249486,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG249341,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG249407,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG249456,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG249515,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG249507,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG249452,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG249466,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Right front speaker,
IDE00916-ENG249434,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG249416,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG249527,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG249489,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG249520,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Left front speaker,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Left rear speaker,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Not available,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Not available,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Not available,
IDE00916-ENG249470,Speaker status-loudspeaker_config_channel_9,Not available,
IDE00916-ENG249411,Speaker status-loudspeaker_state_channel_1,Condition not met,
IDE00916-ENG249429,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG249464,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG249451,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG249436,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG249447,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG249426,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG249317,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG249528,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG249492,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG249409,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG249305,Speaker status-loudspeaker_state_channel_2,Condition not met,
IDE00916-ENG249435,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG249417,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG249404,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG249319,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG249408,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG249290,Speaker status-loudspeaker_state_channel_3,Condition not met,
IDE00916-ENG249312,Speaker status-loudspeaker_state_channel_4,Condition not met,
IDE00916-ENG249303,Speaker status-loudspeaker_state_channel_5,Measuring value not available,
IDE00916-ENG249399,Speaker status-loudspeaker_state_channel_6,Measuring value not available,
IDE00916-ENG249508,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG249335,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG249382,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,On,
IDE01627-MAS01167,Search for Bluetooth devices-Actuation time,0 s,
IDE01627-ENG170421,Search for Bluetooth devices-IoReached Status,Output diagnostic test not active,
IDE01628-MAS01167,Establish connection to last Bluetooth device-Actuation time,0 s,
IDE01628-ENG170421,Establish connection to last Bluetooth device-IoReached Status,Output diagnostic test not active,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Field intensity,70,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not active,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,215072,
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,MPEG4 HE AAC v2,
IDE01700-MAS06242,Status of tuner for digital radio (DAB)-Signal quality,89,
IDE01700-MAS19004,Status of tuner for digital radio (DAB)-DAB bit rate malfunction FIC,0.00,
IDE01700-MAS19005,Status of tuner for digital radio (DAB)-DAB bit rate malfunction NET,0.45,
IDE01700-MAS19006,Status of tuner for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE01700-MAS19007,Status of tuner for digital radio (DAB)-TP traffic data,available (service),
IDE01700-MAS19010,Status of tuner for digital radio (DAB)-TPEG,Not available,
IDE01700-MAS19011,Status of tuner for digital radio (DAB)-Ensemble ID,37376,
IDE01700-MAS19012,Status of tuner for digital radio (DAB)-Ensemble Label,SLO DAB+ R1     ð`äBRadio 1 DAB                                     à@cY,
IDE01700-MAS19013,Status of tuner for digital radio (DAB)-Ensemble label mask,61536,
IDE01700-MAS19014,Status of tuner for digital radio (DAB)-Ensemble country code,228,
IDE01700-MAS19018,Status of tuner for digital radio (DAB)-Bit rate,64,
IDE01700-MAS19019,Status of tuner for digital radio (DAB)-Sample Rate,24,
IDE01700-MAS19020,Status of tuner for digital radio (DAB)-Audio mode,00,
IDE01700-MAS19022,Status of tuner for digital radio (DAB)-DAB transfer mode,1,
IDE01700-MAS19023,Status of tuner for digital radio (DAB)-SYNC / OFDM Lock,active,
IDE01700-MAS19024,Status of tuner for digital radio (DAB)-Audio quality,99,
IDE01700-MAS19041,Status of tuner for digital radio (DAB)-Protection level,3_A_equal_protection_level,
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG249430,Status of tuner for digital radio (DAB)-Count_Audio_Services,16,
IDE01700-ENG249296,Status of tuner for digital radio (DAB)-Count_Services,16,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,                à@cY,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,37954,
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,0,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,Radio 1 DAB                                     à@cY,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,07 E0,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,7,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,                                à@cY,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,16,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,16,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,OK,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,121, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,47, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,Not available,
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,55, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,3A 78 A4 71,
IDE02178-MAS01167,Status remote control-Actuation time,0 s,
IDE02178-ENG170421,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,0 s,
IDE02179-ENG170421,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,0 s,
IDE02180-ENG170421,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,0 s,
IDE02181-ENG170421,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,0,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,63, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,63, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,63, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,63, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,0,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,0,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,0,
IDE02449-MAS01167,Remote control for satellite radio station selection-Actuation time,0 s,
IDE02449-ENG170421,Remote control for satellite radio station selection-IoReached Status,Output diagnostic test not active,
IDE02452-IDE02451,Satellite radio tuner status-Satellite radio antenna status,electrically OK,
IDE02452-IDE02453,Satellite radio tuner status-Channel selection for satellite radio,0,
IDE02452-MAS01765,Satellite radio tuner status-Audio Signal,Not available,
IDE02452-MAS01808,Satellite radio tuner status-Antenna current,0, mA
IDE02452-MAS02573,Satellite radio tuner status-Reception quality,No signal,
IDE02452-MAS13343,Satellite radio tuner status-Satellite radio tuner: pre-activation status,factory_activation_successful,
IDE02452-MAS13344,Satellite radio tuner status-Satellite radio tuner: pre-activation value,00,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,0 s,
IDE02454-ENG170421,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,0 s,
IDE02470-ENG170421,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,0 s,
IDE02501-ENG170421,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02505-MAS01763,Status of tuner 2 for digital radio (DAB)-Field intensity,107,
IDE02505-MAS02949,Status of tuner 2 for digital radio (DAB)-Frequency,211648,
IDE02505-MAS06242,Status of tuner 2 for digital radio (DAB)-Signal quality,0,
IDE02505-MAS19004,Status of tuner 2 for digital radio (DAB)-DAB bit rate malfunction FIC,0.00,
IDE02505-MAS19005,Status of tuner 2 for digital radio (DAB)-DAB bit rate malfunction NET,Not available,
IDE02505-MAS19006,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate MSC,Not available,
IDE02505-MAS19011,Status of tuner 2 for digital radio (DAB)-Ensemble ID,00 00 00 00,
IDE02505-MAS19012,Status of tuner 2 for digital radio (DAB)-Ensemble Label,
IDE02505-MAS19023,Status of tuner 2 for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth available,
IDE02766,Malfunction status,00 00,
IDE02766-ENG249300,Malfunction status-amount_communication_errors,0,
IDE03477-MAS00106,GPS time-Year,2026,
IDE03477-MAS00107,GPS time-Month,9,
IDE03477-MAS00108,GPS time-Day,3,
IDE03477-MAS00109,GPS time-Hours,16,
IDE03477-MAS00110,GPS time-Minutes,5,
IDE03477-MAS00111,GPS time-Seconds,54,
IDE03477-MAS01632,GPS time-Status,valid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,0, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,0, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,35, min
IDE04317-MAS00108,Total system run time-Day,22, d
IDE04317-MAS00109,Total system run time-Hours,21, H
IDE04317-MAS00110,Total system run time-Minutes,27, min
IDE04546-IDE00301,Calibration of navigation-Distance,560.72, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04548-MAS00106,Electronic toll collection-Year,2000,
IDE04548-MAS00107,Electronic toll collection-Month,0,
IDE04548-MAS00108,Electronic toll collection-Day,OFF,
IDE04548-MAS00109,Electronic toll collection-Hours,0,
IDE04548-MAS00110,Electronic toll collection-Minutes,0,
IDE04548-MAS00111,Electronic toll collection-Seconds,0,
IDE04548-MAS01156,Electronic toll collection-Communication status,not OK,
IDE04548-MAS01161,Electronic toll collection-Communication errors,0,
IDE04548-MAS01758,Electronic toll collection-Date / time,invalid,
IDE04548-MAS04385,Electronic toll collection-Authorization,not OK,
IDE04548-MAS04386,Electronic toll collection-Write card,not OK,
IDE04548-MAS04387,Electronic toll collection-Read card,not OK,
IDE04548-MAS04388,Electronic toll collection-Card type,no card available,
IDE04548-MAS04389,Electronic toll collection-Number of repeat attempts,0,
IDE04548-MAS04394,Electronic toll collection-Connection status,not connected,
IDE04548-MAS04460,Electronic toll collection-Validity,not OK,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,4440, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,invalid,
IDE04767-MAS02112,Update software via medium-Programmability,Waiting for data transmission,
IDE04768,Bluetooth: device address,2C D1 C6 83 B5 4D,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG170421,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05535-MAS01632,Traffic data antenna-Status,not OK,
IDE05570-MAS01632,DSRC antenna-Status,Unknown (0)
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05596-MAS00106,Last time GPS position outside map-Year,2026,
IDE05596-MAS00107,Last time GPS position outside map-Month,9,
IDE05596-MAS00108,Last time GPS position outside map-Day,3,
IDE05596-MAS00109,Last time GPS position outside map-Hours,16,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,5,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,53,
IDE05602-IDE03615,Bluetooth: connected device 1-Variant,
IDE05602-IDE04768,Bluetooth: connected device 1-Bluetooth: device address,00 00 00 00 00 00,
IDE05602-MAS01483,Bluetooth: connected device 1-Software version,
IDE05602-MAS02159,Bluetooth: connected device 1-Remote SIM Access Profile (rSAP),0,
IDE05602-MAS02160,Bluetooth: connected device 1-Hands free profile (HFP),0,
IDE05602-MAS03159,Bluetooth: connected device 1-Manufacturer,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,
IDE05602-MAS17538,Bluetooth: connected device 1-Received Signal Strength Indicator (RSSI),0,
IDE05602-MAS17539,Bluetooth: connected device 1-Determining the existing profile (SDAP),0,
IDE05602-MAS17540,Bluetooth: connected device 1-Serial data transfer (SPP),0,
IDE05602-MAS17541,Bluetooth: connected device 1-Streaming audio data (A2DP),0,
IDE05602-MAS17542,Bluetooth: connected device 1-Remote control for audio/video (AVRCP),0,
IDE05602-MAS17543,Bluetooth: connected device 1-Network connections (PAN),0,
IDE05602-MAS17544,Bluetooth: connected device 1-Message exchange between devices (MAP),0,
IDE05602-MAS17545,Bluetooth: connected device 1-Generic data transfer between two devices (OBEX),0,
IDE05602-MAS17546,Bluetooth: connected device 1-Sending individual files (OPP),0,
IDE05602-MAS17547,Bluetooth: connected device 1-File transfer (FTP),0,
IDE05602-MAS17548,Bluetooth: connected device 1-Read-only access to telephone directory (PBAP),0,
IDE05602-MAS17549,Bluetooth: connected device 1-Telephone directory download (AT),0,
IDE05602-MAS17550,Bluetooth: connected device 1-Sharing calendars or notes between two devices (CTN),0,
IDE05602-MAS17551,Bluetooth: connected device 1-iAP protocol (iAP),0,
IDE05603-IDE03615,Bluetooth: connected device 2-Variant,
IDE05603-IDE04768,Bluetooth: connected device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05603-MAS01483,Bluetooth: connected device 2-Software version,
IDE05603-MAS02159,Bluetooth: connected device 2-Remote SIM Access Profile (rSAP),0,
IDE05603-MAS02160,Bluetooth: connected device 2-Hands free profile (HFP),0,
IDE05603-MAS03159,Bluetooth: connected device 2-Manufacturer,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,
IDE05603-MAS17538,Bluetooth: connected device 2-Received Signal Strength Indicator (RSSI),0,
IDE05603-MAS17539,Bluetooth: connected device 2-Determining the existing profile (SDAP),0,
IDE05603-MAS17540,Bluetooth: connected device 2-Serial data transfer (SPP),0,
IDE05603-MAS17541,Bluetooth: connected device 2-Streaming audio data (A2DP),0,
IDE05603-MAS17542,Bluetooth: connected device 2-Remote control for audio/video (AVRCP),0,
IDE05603-MAS17543,Bluetooth: connected device 2-Network connections (PAN),0,
IDE05603-MAS17544,Bluetooth: connected device 2-Message exchange between devices (MAP),0,
IDE05603-MAS17545,Bluetooth: connected device 2-Generic data transfer between two devices (OBEX),0,
IDE05603-MAS17546,Bluetooth: connected device 2-Sending individual files (OPP),0,
IDE05603-MAS17547,Bluetooth: connected device 2-File transfer (FTP),0,
IDE05603-MAS17548,Bluetooth: connected device 2-Read-only access to telephone directory (PBAP),0,
IDE05603-MAS17549,Bluetooth: connected device 2-Telephone directory download (AT),0,
IDE05603-MAS17550,Bluetooth: connected device 2-Sharing calendars or notes between two devices (CTN),0,
IDE05603-MAS17551,Bluetooth: connected device 2-iAP protocol (iAP),0,
IDE05604-IDE03615,Bluetooth: connected device 3-Variant,
IDE05604-IDE04768,Bluetooth: connected device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05604-MAS01483,Bluetooth: connected device 3-Software version,
IDE05604-MAS02159,Bluetooth: connected device 3-Remote SIM Access Profile (rSAP),0,
IDE05604-MAS02160,Bluetooth: connected device 3-Hands free profile (HFP),0,
IDE05604-MAS03159,Bluetooth: connected device 3-Manufacturer,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,
IDE05604-MAS17538,Bluetooth: connected device 3-Received Signal Strength Indicator (RSSI),0,
IDE05604-MAS17539,Bluetooth: connected device 3-Determining the existing profile (SDAP),0,
IDE05604-MAS17540,Bluetooth: connected device 3-Serial data transfer (SPP),0,
IDE05604-MAS17541,Bluetooth: connected device 3-Streaming audio data (A2DP),0,
IDE05604-MAS17542,Bluetooth: connected device 3-Remote control for audio/video (AVRCP),0,
IDE05604-MAS17543,Bluetooth: connected device 3-Network connections (PAN),0,
IDE05604-MAS17544,Bluetooth: connected device 3-Message exchange between devices (MAP),0,
IDE05604-MAS17545,Bluetooth: connected device 3-Generic data transfer between two devices (OBEX),0,
IDE05604-MAS17546,Bluetooth: connected device 3-Sending individual files (OPP),0,
IDE05604-MAS17547,Bluetooth: connected device 3-File transfer (FTP),0,
IDE05604-MAS17548,Bluetooth: connected device 3-Read-only access to telephone directory (PBAP),0,
IDE05604-MAS17549,Bluetooth: connected device 3-Telephone directory download (AT),0,
IDE05604-MAS17550,Bluetooth: connected device 3-Sharing calendars or notes between two devices (CTN),0,
IDE05604-MAS17551,Bluetooth: connected device 3-iAP protocol (iAP),0,
IDE05605-IDE03615,Bluetooth: connected device 4-Variant,
IDE05605-IDE04768,Bluetooth: connected device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05605-MAS01483,Bluetooth: connected device 4-Software version,
IDE05605-MAS02159,Bluetooth: connected device 4-Remote SIM Access Profile (rSAP),0,
IDE05605-MAS02160,Bluetooth: connected device 4-Hands free profile (HFP),0,
IDE05605-MAS03159,Bluetooth: connected device 4-Manufacturer,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,
IDE05605-MAS17538,Bluetooth: connected device 4-Received Signal Strength Indicator (RSSI),0,
IDE05605-MAS17539,Bluetooth: connected device 4-Determining the existing profile (SDAP),0,
IDE05605-MAS17540,Bluetooth: connected device 4-Serial data transfer (SPP),0,
IDE05605-MAS17541,Bluetooth: connected device 4-Streaming audio data (A2DP),0,
IDE05605-MAS17542,Bluetooth: connected device 4-Remote control for audio/video (AVRCP),0,
IDE05605-MAS17543,Bluetooth: connected device 4-Network connections (PAN),0,
IDE05605-MAS17544,Bluetooth: connected device 4-Message exchange between devices (MAP),0,
IDE05605-MAS17545,Bluetooth: connected device 4-Generic data transfer between two devices (OBEX),0,
IDE05605-MAS17546,Bluetooth: connected device 4-Sending individual files (OPP),0,
IDE05605-MAS17547,Bluetooth: connected device 4-File transfer (FTP),0,
IDE05605-MAS17548,Bluetooth: connected device 4-Read-only access to telephone directory (PBAP),0,
IDE05605-MAS17549,Bluetooth: connected device 4-Telephone directory download (AT),0,
IDE05605-MAS17550,Bluetooth: connected device 4-Sharing calendars or notes between two devices (CTN),0,
IDE05605-MAS17551,Bluetooth: connected device 4-iAP protocol (iAP),0,
IDE05606-IDE03615,Bluetooth: connected device 5-Variant,
IDE05606-IDE04768,Bluetooth: connected device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05606-MAS01483,Bluetooth: connected device 5-Software version,
IDE05606-MAS02159,Bluetooth: connected device 5-Remote SIM Access Profile (rSAP),0,
IDE05606-MAS02160,Bluetooth: connected device 5-Hands free profile (HFP),0,
IDE05606-MAS03159,Bluetooth: connected device 5-Manufacturer,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,
IDE05606-MAS17538,Bluetooth: connected device 5-Received Signal Strength Indicator (RSSI),0,
IDE05606-MAS17539,Bluetooth: connected device 5-Determining the existing profile (SDAP),0,
IDE05606-MAS17540,Bluetooth: connected device 5-Serial data transfer (SPP),0,
IDE05606-MAS17541,Bluetooth: connected device 5-Streaming audio data (A2DP),0,
IDE05606-MAS17542,Bluetooth: connected device 5-Remote control for audio/video (AVRCP),0,
IDE05606-MAS17543,Bluetooth: connected device 5-Network connections (PAN),0,
IDE05606-MAS17544,Bluetooth: connected device 5-Message exchange between devices (MAP),0,
IDE05606-MAS17545,Bluetooth: connected device 5-Generic data transfer between two devices (OBEX),0,
IDE05606-MAS17546,Bluetooth: connected device 5-Sending individual files (OPP),0,
IDE05606-MAS17547,Bluetooth: connected device 5-File transfer (FTP),0,
IDE05606-MAS17548,Bluetooth: connected device 5-Read-only access to telephone directory (PBAP),0,
IDE05606-MAS17549,Bluetooth: connected device 5-Telephone directory download (AT),0,
IDE05606-MAS17550,Bluetooth: connected device 5-Sharing calendars or notes between two devices (CTN),0,
IDE05606-MAS17551,Bluetooth: connected device 5-iAP protocol (iAP),0,
IDE05700-MAS01456,USB connection-Speed,Low speed,
IDE05700-MAS01632,USB connection-Status,not OK.,
IDE05700-MAS03159,USB connection-Manufacturer,0,
IDE05700-MAS04393,USB connection-USB device class,0,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,0,
IDE05700-MAS06173,USB connection-Protocol,0,
IDE05700-MAS06174,USB connection-Product ID,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05726,Dimmer terminal 58xd,99.94, %
IDE06028-MAS02317,Control head button operation-Button code 1,0,
IDE06028-MAS02318,Control head button operation-Button code 2,0,
IDE06028-MAS04151,Control head button operation-Joystick,0,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,-127,
IDE06028-MAS04414,Control head button operation-Volume control,-127,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Current,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,71, °C
IDE06517-MAS01425,Temperature: audio amplifier-min.value,0, °C
IDE06517-MAS02238,Temperature: audio amplifier-Current,50, °C
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,Not available,
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,Not available,
IDE06519-MAS02238,Temperature of MOST transceiver-Current,Not available,
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,69, °C
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,-2, °C
IDE06521-MAS02238,Temperature of MMX PC boards-Current,52, °C
IDE06522-MAS01424,Temperature of phone unit-max.value,69, °C
IDE06522-MAS01425,Temperature of phone unit-min.value,-4, °C
IDE06522-MAS02238,Temperature of phone unit-Current,50, °C
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE08531-MAS07133,Connection status online license services-No. of license serv.,0,
IDE08531-ENG98502,Connection status online license services-Data,|ID services,Activation status
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG170421,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10300,OBD Driving Cycle detected,not active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG170421,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG98502,Status of the navigation database-Data,|Country Code,Region Code
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,Available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11034-MAS01482,Satellite radio: module information-Hardware version,
IDE11034-MAS11961,Satellite radio: module information-Serial number,
IDE11034-MAS11962,Satellite radio: module information-Pre-activation key,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE11034-MAS11963,Satellite radio: module information-Firmware version,
IDE11034-MAS11964,Satellite radio: module information-Satellite Module Services Version,
IDE11034-MAS11965,Satellite radio: module information-SiriusXM Interconnect Version,
IDE11034-MAS11966,Satellite radio: module information-Database Version,
IDE11034-ENG249454,Satellite radio: module information-apogee_traffic,
IDE11034-ENG249326,Satellite radio: module information-canadian_fuel,
IDE11034-ENG249344,Satellite radio: module information-channel_arts,
IDE11034-ENG249291,Satellite radio: module information-ev_stations,
IDE11034-ENG249490,Satellite radio: module information-fuel_stations,
IDE11034-ENG249493,Satellite radio: module information-internal_sxm,
IDE11034-ENG249368,Satellite radio: module information-movies,
IDE11034-ENG249268,Satellite radio: module information-Parking,
IDE11034-ENG249458,Satellite radio: module information-phonetics,
IDE11034-ENG249496,Satellite radio: module information-safety_alerts,
IDE11034-ENG176820,Satellite radio: module information-States,
IDE11034-ENG249463,Satellite radio: module information-stocks,
IDE11034-ENG249431,Satellite radio: module information-sxm_pics,
IDE11034-ENG249499,Satellite radio: module information-tabular_weather,
IDE11034-ENG249467,Satellite radio: module information-weather_alerts,
IDE11504,Satellite radio tuner: pre-activated subscription,No,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,no link,
IDE11731,Ethernet signal quality: branch 4,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 FA 38 69 FF FE CC 15 1F|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 FA 38 69 FF FE CC 15 1F|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 FA 38 69 FF FE CC 15 1F|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|4|5|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,159,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|F8 38 69 E2 A7 C1|D8 18 2B E6 ED D4|D8 18 2B E6 ED D4|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|3|3|3|3|3|3|3|3|3|3|,
IDE12238,I network: discarded messages counter,159,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10
IDE12625,IP network: current link deceleration: branch 1,5026, ns
IDE12626,IP network: current link deceleration: branch 2,0, ns
IDE12627,IP network: current link deceleration: branch 3,5026, ns
IDE12628,IP network: current link deceleration: branch 4,5026, ns
IDE12633,IP Network maximum correction of the synchronized clock,-224253645, ns
IDE13323-MAS13737,Acceleration sensor for navigation-Acceleration on the X axis,0.00, m/s²
IDE13323-MAS13738,Acceleration sensor for navigation-Acceleration on the Y axis,0.00, m/s²
IDE13323-MAS13739,Acceleration sensor for navigation-Acceleration on the Z axis,0.00, m/s²
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13737-MAS01763,Status of tuner for digital radio 1b (DAB)-Field intensity,Not available,
IDE13737-MAS19004,Status of tuner for digital radio 1b (DAB)-DAB bit rate malfunction FIC,Not available,
IDE13737-MAS19005,Status of tuner for digital radio 1b (DAB)-DAB bit rate malfunction NET,Not available,
IDE13737-MAS19006,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate MSC,Not available,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCD6RW123439,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,10,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,0 s,
IDE14128-ENG170421,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14344,Automotive audio bus (A2B): status,|Node number,Node name
IDE14344-ENG249700,Automotive audio bus (A2B): status-amount_of_nodes,2,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,1,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 31,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
IDE14733-MAS00106,SDARS subscription status-Year,2000,
IDE14733-MAS00107,SDARS subscription status-Month,0, Months
IDE14733-MAS00108,SDARS subscription status-Day,Not available,
IDE14733-MAS00109,SDARS subscription status-Hours,0, H
IDE14733-MAS00110,SDARS subscription status-Minutes,0, min
IDE14733-MAS00111,SDARS subscription status-Seconds,0, s
IDE14733-MAS10690,SDARS subscription status-Activation condition,not active,
IDE14733-MAS19035,SDARS subscription status-Procedure status,not expired,
IDE14733-MAS19036,SDARS subscription status-Expiration warning,0,
IDE14734-MAS01766,SDARS Service Status-Traffic data,not active,
IDE14734-MAS19037,SDARS Service Status-Audio Service,not active,
IDE14734-MAS19040,SDARS Service Status-Travel link,not active,
MAS00778-IDE03619,Multimedia display unit 1-System condition,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,528, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,3, min
MAS00778-MAS01634,Multimedia display unit 1-Supply voltage,13.00, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,78, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,58, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Digital,
MAS01760-MAS02949,Radio Tuner 1-Frequency,106.20, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,62,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,62,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),0,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,0, %
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Field intensity,35,
MAS03782-MAS17355,WLAN-MAC address 2: tethering,2E D1 C6 43 84 15,
MAS03782-MAS17356,WLAN-MAC address 1,2C D1 C6 83 84 15,
MAS03782-MAS17357,WLAN-MAC address 2,00 00 00 00 00 00,
MAS03782-MAS17559,WLAN-MAC address 1: tethering,2E D1 C6 23 84 15,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,00 06 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,8,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,70 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,99, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,87, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-IDE04332,Function_On_Demand_Freischalt_ID_Status_Dev-Release code for a SWaP function,Not available,
ENG179902-IDE05814,Function_On_Demand_Freischalt_ID_Status_Dev-Individualization characteristic,invalid,
ENG179902-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,00 06 01 00,
ENG179902-MAS01340,Function_On_Demand_Freischalt_ID_Status_Dev-Functions,Available,
ENG179902-MAS01903,Function_On_Demand_Freischalt_ID_Status_Dev-Configuration,OK,
ENG179902-MAS02934,Function_On_Demand_Freischalt_ID_Status_Dev-Preconditions met,Condition not met,
ENG179902-MAS05616,Function_On_Demand_Freischalt_ID_Status_Dev-Cancellation,No,
ENG179902-MAS05617,Function_On_Demand_Freischalt_ID_Status_Dev-Authentication,Condition not met,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,8,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG249161-MAS01167,Operating_Unit_Simulation_Keys_status-Actuation time,0 s,
ENG249161-ENG170421,Operating_Unit_Simulation_Keys_status-IoReached Status,Output diagnostic test not active,
ENG249164-MAS09154,Proximity_Sensor_slider_1-Proximity sensor 1,No object in sector,
ENG249168-MAS01167,Remote_Seek_Activation_status-Actuation time,0 s,
ENG249168-ENG170421,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249169-MAS01167,Remote_Set_AF_status-Actuation time,0 s,
ENG249169-ENG170421,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG249170-MAS01167,Remote_Set_Concealment_Level_status-Actuation time,0 s,
ENG249170-ENG170421,Remote_Set_Concealment_Level_status-IoReached Status,Output diagnostic test not active,
ENG249171-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,0 s,
ENG249171-ENG170421,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG249172-MAS01167,Remote_Set_DAB_Default_status-Actuation time,0 s,
ENG249172-ENG170421,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG249173-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,0 s,
ENG249173-ENG170421,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG249174-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,0 s,
ENG249174-ENG170421,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG249175-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,0 s,
ENG249175-ENG170421,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG249176-MAS01167,Remote_Set_IBOC_Service_status-Actuation time,0 s,
ENG249176-ENG170421,Remote_Set_IBOC_Service_status-IoReached Status,Output diagnostic test not active,
ENG249177-MAS01167,Remote_Set_TP_status-Actuation time,0 s,
ENG249177-ENG170421,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG249178-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,0 s,
ENG249178-ENG170421,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249179-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,0 s,
ENG249179-ENG170421,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249180-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,0 s,
ENG249180-ENG170421,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249197-MAS01167,set_amfm_measurement_mode_status-Actuation time,0 s,
ENG249197-ENG170421,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG249198-MAS01167,set_tuner_mode_status-Actuation time,0 s,
ENG249198-ENG170421,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
ENG249205-MAS01632,Status_Position_Touch_Slider_1-Status,operated,
ENG249205-ENG117402,Status_Position_Touch_Slider_1-calibrate_delta_x,0,
ENG249205-ENG117396,Status_Position_Touch_Slider_1-position_x1,0,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,0,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,0,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,507,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,0,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,0,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,389,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,0,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,0,
ENG117870-MAS00106,VICS_Infrared_Beacon_State-Year,2000,
ENG117870-MAS00107,VICS_Infrared_Beacon_State-Month,0,
ENG117870-MAS00108,VICS_Infrared_Beacon_State-Day,OFF,
ENG117870-MAS00109,VICS_Infrared_Beacon_State-Hours,0,
ENG117870-MAS00110,VICS_Infrared_Beacon_State-Minutes,0,
ENG117870-MAS00111,VICS_Infrared_Beacon_State-Seconds,0,
ENG117870-MAS01632,VICS_Infrared_Beacon_State-Status,Not available,
ENG117870-ENG117771,VICS_Infrared_Beacon_State-vics_id,0,
ENG117871-MAS00106,VICS_Radio_Beacon_State-Year,2000,
ENG117871-MAS00107,VICS_Radio_Beacon_State-Month,0,
ENG117871-MAS00108,VICS_Radio_Beacon_State-Day,0,
ENG117871-MAS00109,VICS_Radio_Beacon_State-Hours,0,
ENG117871-MAS00110,VICS_Radio_Beacon_State-Minutes,0,
ENG117871-MAS00111,VICS_Radio_Beacon_State-Seconds,0,
ENG117871-MAS01632,VICS_Radio_Beacon_State-Status,Not available,
ENG117871-ENG117771,VICS_Radio_Beacon_State-vics_id,0,
Elapsed Time: 00:41
blockmap-6C-5WA-980-556-D_WVWZZZCD6RW123439-20260903-1808.CSV
;SW:5WA-980-556-D   HW:5WA-980-556-B ---  6C: Back-up Cam.
;Component:RV eCompact   H30 0344, Coding:02030004E43000
;EV_CamSysRVCCompaFicos,010024,EV_CamSysRVCCompaFicos_010_VW38.rod
;Thursday,03,September,2026,18:08:28:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 52FD7C609468022A014-8006
Group,Description,Actual
IDE00019,Voltage terminal 30,12.86, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,not recognised,
IDE00924-IDE08941,Steering angle-Rack position,0.00,
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,1.8,
IDE00924,Steering angle,0.0625,
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.00,
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,0, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,calibrated,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07402-MAS10858,External activation-Rear camera,not active,
IDE10589-MAS10858,Temperature of the camera-Rear camera,80, °C
IDE10740-IDE03619,System state area view-System condition,active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780-MAS11932,Ethernet counter connection interruptions-Counter open circuit,0, dB
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,0, dB
IDE11010-MAS00106,Rear camera: calibration time-Year,2023, yr
IDE11010-MAS00107,Rear camera: calibration time-Month,14, Months
IDE11010-MAS00108,Rear camera: calibration time-Day,4, d
IDE11010-MAS00109,Rear camera: calibration time-Hours,12, H
IDE11010-MAS00110,Rear camera: calibration time-Minutes,33, min
IDE11010-MAS00111,Rear camera: calibration time-Seconds,0, s
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1e+007,
IDE13845,Production mode status,No function restriction,
MAS02356-MAS10858,Type of calibration-Rear camera,TopView: calibration with calibration panel,
Elapsed Time: 00:05
blockmap-75-5WA-035-284-F_WVWZZZCD6RW123439-20260903-1808.CSV
;SW:5WA-035-284-F   HW:5WA-035-284-C ---  75: Telematics
;Component:OCU3HMQB37W   H14 0144, Coding:023800109068AC209405460071002E07
;EV_OCU3HMQB37W,002012,EV_OCU3HMQB37W_002_VW38.rod
;Thursday,03,September,2026,18:08:39:29755
;VCID: 49CF5B0C793E41F270E-801C SFD { }
IDE00019,Voltage terminal 30,12.7, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,44, °C
IDE00608,Fuel type,Petrol,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00767,No. of unscheduled ECU resets,9,
IDE01215,Dimmer terminal 58d,Measuring value not available,
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Direction of travel,0, °
IDE01588-MAS01632,Direction of travel-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS02230,GPS Position-Height,278, m
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01971,Lowest recorded control module temperature,-1, °C
IDE01972,Highest recorded control module temperature,69, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,37, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,5,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,12,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,14,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,15,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,34, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,33, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,45, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,41, dBµV
IDE03477-MAS00110,GPS time-Minutes,8,
IDE03477-MAS00111,GPS time-Seconds,42,
IDE04293,Operating state for emer call module,registerstate_searching,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,901280081182249,
IDE04750-MAS04226,SIM card-Telephone number,               ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89882390000623693358,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000028013709426,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,357898162859249,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG170421,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG170421,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,9,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2026,
IDE07589-MAS00107,Update programming: status-Month,7,
IDE07589-MAS00108,Update programming: status-Day,2,
IDE07589-MAS00109,Update programming: status-Hours,12,
IDE07589-MAS00110,Update programming: status-Minutes,49,
IDE07589-MAS00111,Update programming: status-Seconds,32,
IDE07589-MAS10948,Update programming: status-control,Others,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG170421,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG170421,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 F5 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,64 18 CA 0B,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,39, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,100, %
IDE09602-MAS01167,Locale hazard warning-Actuation time,0 s,
IDE09602-ENG170421,Locale hazard warning-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge status,91, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 FA 38 69 FF FE E2 A7 C1|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF E2 A7 C1|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|7|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,65535,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|F8 38 69 E2 A7 C1|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|D8 18 2B E6 ED D4|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|F8 38 69 AD 62 4C|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|4|7|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,65535,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Speaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Speaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,17,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2026, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,8, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,31, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,18, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,2, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,43, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2026, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),8, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),31, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),18, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),2, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),43, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,activated,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2053, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,10, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,5, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 00 00 00 00 00 00 00,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2F,
IDE15695,Front radar-based localization,not active,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,F5,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,8,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,58,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,79,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,18974, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,1000, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,3021,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,293,
MAS04394-IDE07699,Connection status-Mobile network operator,40,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,Not available,
MAS04394-MAS08407,Connection status-Data connection,not active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,14141,
MAS04394-ENG123308,Connection status-TCP_Connection_State,not active,
MAS08178-IDE05253,Crash information-Front crash,Yes,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,Yes,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG170421,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS10430,Indicator light for emerg. call,Emergency call function available,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 19,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,68 minutes,
MAS18223-ENG299118,History of sent driver assistance data-beginn array,|ID,Number|0
MAS18223-ENG104031,History of sent driver assistance data-Number,0,
MAS18224-ENG299118,History of causes for sent driver assistance data-beginn array,|ID,Number|0
MAS18224-ENG104031,History of causes for sent driver assistance data-Number,0,
MAS18225-ENG98987,Transmission delay for driver assistance data-Time,0, ms
MAS18226-MAS01167,Sending the driver assistance data-Actuation time,0 s,
MAS18226-ENG170421,Sending the driver assistance data-IoReached Status,Output diagnostic test not active,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,W101,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest#              ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description
MAS19273,Shadow drive metadata,|User ID,Year
MAS19295,Historical memory for synchronization,|Year,Month
MAS19313,BAP historical memory,|Year,Month
MAS19326,CAN signals for OCU customization,|Year,Month
ENG123206,Antenna_Switch,LTE antenna 1,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,105,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2026-07-09T14:09:40Z,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,74.833,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,2582, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,79,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,78,
ENG247784-ENG118139,Hazard_Information-function_state,State_0,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,0.0.0.0,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11568,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,14128,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4100, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12601,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14900,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,0,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12336,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,12346,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14896,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,12336,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11568,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,0,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,12628,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,57,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12334,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,12378,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23040, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,805306368, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,26880,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808333358, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,Malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,37, m
ENG247810-ENG248070,REM_Available_Transmission_Buffer-Buffer,0, KByte
ENG247811-ENG98502,REM_Development_Interface-Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 18 03 00 00 62 16 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG157421-MAS04460,Scan_Network_List-Validity,valid,
ENG157421-MAS04460,Scan_Network_List-Validity,invalid,
ENG157421-MAS08406,Scan_Network_List-Network type,LTE,
ENG157421-MAS08406,Scan_Network_List-Network type,GSM,
ENG157421-MAS08406,Scan_Network_List-Network type,UMTS,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,293,
ENG157421-ENG159652,Scan_Network_List-Mobile_Country_Code,65535,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,41,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,64,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,70,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,40,
ENG157421-ENG159760,Scan_Network_List-Mobile_Network_Code,65535,
ENG247812-ENG159329,Second_Last_Position-Latitude,--------------,
ENG247812-ENG159328,Second_Last_Position-Longitude,--------------,
ENG247822-ENG159329,Third_Last_Position-Latitude,--------------,
ENG247822-ENG159328,Third_Last_Position-Longitude,--------------,
ENG254851-MAS01779,VTT_First_GPS_fix-Length,---           ,
ENG254851-MAS01780,VTT_First_GPS_fix-Width,---           ,
ENG254851-MAS02230,VTT_First_GPS_fix-Height,65034, m
Elapsed Time: 01:18
blockmap-A5-5WA-980-653-D_WVWZZZCD6RW123439-20260903-1810.CSV
;SW:5WA-980-653-D   HW:5WA-980-653 ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H12 3405, Coding:00000888114C4040109E00001020002000418000000000000000000000000000
;EV_MFK3ValeoMQB,005055,EV_MFK3ValeoMQB_005_VW38.rod
;Thursday,03,September,2026,18:10:35:29755
;VCID: 50F976689A64703A370-8004
IDE00018,Voltage terminal 15,12.9, V
IDE00767,No. of unscheduled ECU resets,0,
IDE00973,Outside temperature,30.0, °C
IDE01968,Dynamic calibration: yaw angle offset,0.000, °
IDE01969,Dynamic calibration: pitch angle offset,0.000, °
IDE01970,Dynamic calibration: roll angle offset,0.032, °
IDE01971,Lowest recorded control module temperature,-8, °C
IDE01972,Highest recorded control module temperature,80, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,Write only channel,
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Write only channel,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,Write only channel,
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Write only channel,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,Write only channel,
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Write only channel,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,Write only channel,
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Write only channel,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02486,Data logger triggering,not initialized,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,Write only channel,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Write only channel,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,6863, km
IDE03948-MAS01167,High beam recommendation-Actuation time,Write only channel,
IDE03948-MAS08863,High beam recommendation-Status of actuator test,Write only channel,
IDE04036-MAS01632,High beam assistant: status-Status,not active,
IDE04036-MAS17492,High beam assistant: status-Switching state,OFF,
IDE04036-MAS17493,High beam assistant: status-Sensor view,Not assigned,
IDE04036-MAS17494,High beam assistant: status-Higher sensitivity active,No,
IDE04123-MAS01480,High beam: reason for shut-off-excessive temperature,No,
IDE04123-MAS06833,High beam: reason for shut-off-Ambient brightness too high,No,
IDE04123-MAS06846,High beam: reason for shut-off-Location detected,No,
IDE04123-MAS14875,High beam: reason for shut-off-Fog detected,No,
IDE04123-MAS17489,High beam: reason for shut-off-Oncoming vehicle detected,No,
IDE04123-MAS17490,High beam: reason for shut-off-Vehicle ahead detected,No,
IDE04123-MAS17491,High beam: reason for shut-off-Speed not achieved,Yes,
IDE04123,High beam: reason for shut-off,0,
IDE04123,High beam: reason for shut-off,4,
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Lane assist deactivated in steering,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.00, Nm
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,Write only channel,
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Write only channel,
IDE06592-MAS00478,Status: special functions-Reserved,00,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,used,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07214,Dynamic calibration: camera height offset,2, mm
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1023, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1023, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,25.650001, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,25.650001, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,35.150001, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,35.150001, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,51.15, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,51.15, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,Not available,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,Not available,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,Not available,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,Not available,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE09492-MAS11790,Temperatures-Control Module temperature,65, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,70, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,68, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0,
IDE10406-MAS00106,Last initial calibrations: details-Year,2023,
IDE10406-MAS00107,Last initial calibrations: details-Month,9,
IDE10406-MAS00108,Last initial calibrations: details-Day,4,
IDE10406-MAS00109,Last initial calibrations: details-Hours,12,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,32,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,9,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2023,
IDE10664-MAS00107,Current initial calibration: details-Month,9,
IDE10664-MAS00108,Current initial calibration: details-Day,4,
IDE10664-MAS00109,Current initial calibration: details-Hours,12,
IDE10664-MAS00110,Current initial calibration: details-Minutes,32,
IDE10664-MAS00111,Current initial calibration: details-Seconds,9,
IDE10664-MAS00711,Current initial calibration: details-kilometer reading,0,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WVWZZZCD6RW123439,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,0.782, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,0.285, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-0.460, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1315, mm
IDE11752-ENG277500,IP network: IPv6-addresses-Ip_ipv6_addresses_list,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|, hex
IDE11753-ENG277501,IP network: IPv6-multicast-addresses-Ip_ipv6_multicast_addresses_list,|IPv6 Multicast address|FF 14 00 00 00 0B|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11755-ENG277505,IP network: VLANs-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,256,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-ENG277502,IP network: MAC addresses-Ip_mac_addresses_list,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11869-ENG277503,IP network: NDP cache-Ip_ndp_cache_list,|MAC address,IPv6 address
IDE11988-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 1-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|74 90 50 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11989-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 2-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11990-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 3-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11991-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 4-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11992-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 5-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11993-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 6-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11994-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 7-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE11995-ENG299132,IP network: MAC addresses of Ethernet switch ports branch 8-IP_network_MAC_adresses_ethernet_switch_port_array,|MAC address|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|, hex
IDE12230-ENG277505,IP network: VLANs of Ethernet switch ports branch 1-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE12231-ENG277505,IP network: VLANs of Ethernet switch ports branch 2-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12232-ENG277505,IP network: VLANs of Ethernet switch ports branch 3-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12233-ENG277505,IP network: VLANs of Ethernet switch ports branch 4-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12234-ENG277505,IP network: VLANs of Ethernet switch ports branch 5-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12235-ENG277505,IP network: VLANs of Ethernet switch ports branch 6-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12236-ENG277505,IP network: VLANs of Ethernet switch ports branch 7-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12237-ENG277505,IP network: VLANs of Ethernet switch ports branch 8-Ip_vlans_list,|VLAN|0|0|0|0|0|0|0|0|0|0|,
IDE12239-ENG277504,IP network: test feedback value of communications relationships-Ip_return_value_test_communication_connection,|IPv6 address,Result|02 FD 53 7C B8 03 83 02 00 00 00 00 00 00 00 00
IDE12626,IP network: current link deceleration: branch 2,0, µs
IDE12627,IP network: current link deceleration: branch 3,0, µs
IDE12628,IP network: current link deceleration: branch 4,0, µs
IDE12629,IP network: current link deceleration: branch 5,0, µs
IDE12630,IP network: current link deceleration: branch 6,0, µs
IDE12631,IP network: current link deceleration: branch 7,0, µs
IDE12632,IP network: current link deceleration: branch 8,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,Not available,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,655.38, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,539.07, px
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1462.14, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1462.14, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.000468891,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.000363679,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.000638848,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.00,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2460.00, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,742.00, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1397.00, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2460.00, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-742.00, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1397.00, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2460.00, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,742.00, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,803.00, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2460.00, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-742.00, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,803.00, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,-2.0, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,0.0, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,686.00, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,686.00, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,692.00, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,693.00, mm
IDE13998,Distance to calibration field: stored values,1500.00, mm
IDE14000,Windshield defogger camera: activation status,OFF,
MAS01634-MAS09193,Supply voltage-PLA,13.0, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.1, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.7, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.2, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,4.1, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17473,Functional state and lane boundary information,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Not available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 0E 0F 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition not met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,2,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS19593-MAS01167,Upload for expanded static navigation data activation-Actuation time,Write only channel,
MAS19593-MAS08863,Upload for expanded static navigation data activation-Status of actuator test,Write only channel,
MAS19594-MAS01167,Upload for expanded dynamic navigation data activation-Actuation time,Write only channel,
MAS19594-MAS08863,Upload for expanded dynamic navigation data activation-Status of actuator test,Write only channel,
ENG152732-MAS06854,CRC32 Checksum of FAZIT Identification String-Version,81,
ENG152732-MAS06855,CRC32 Checksum of FAZIT Identification String-Test sum,09 65 CB EB,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,2,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,2,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902-ENG247044,Function_On_Demand_Freischalt_ID_Status_Dev-Function_On_Demand_Freischalt_ID_Status,|Authentication,Functions
ENG106922,Immobilizer - Challenge,3D DB 92 02,
ENG185847-MAS01167,Light_assist_blockage_detection-Actuation time,Write only channel,
ENG185847-MAS08863,Light_assist_blockage_detection-Status of actuator test,Write only channel,
ENG185858-MAS01167,Light_assist_self_glare_detection-Actuation time,Write only channel,
ENG185858-MAS08863,Light_assist_self_glare_detection-Status of actuator test,Write only channel,
ENG185848-MAS01167,Main_beam_defect_message-Actuation time,Write only channel,
ENG185848-MAS08863,Main_beam_defect_message-Status of actuator test,Write only channel,
ENG251654-MAS01167,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Actuation time,Write only channel,
ENG251654-MAS08863,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Status of actuator test,Write only channel,
ENG251655-MAS01167,REM_Static_EyeQ_Data_Test_Trigger_status-Actuation time,Write only channel,
ENG251655-MAS08863,REM_Static_EyeQ_Data_Test_Trigger_status-Status of actuator test,Write only channel,
ENG185865-MAS01167,SAE_mode_activation-Actuation time,Write only channel,
ENG185865-MAS08863,SAE_mode_activation-Status of actuator test,Write only channel,
Elapsed Time: 00:47
blockmap-CA-4K1-907-594-CB_WVWZZZCD6RW123439-20260903-1811.CSV
;SW:4K1-907-594-CB   HW:4K1-907-594 ---  CA: Sunroof
;Component:SAD_STG_1     006 0040, Coding:408000738001
;EV_SunRoofCONTIAU736,009015,EV_SunRoofCONTIAU736_009_VW27.rod
;Thursday,03,September,2026,18:11:39:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 77ABEDF45F4A0702D6A-8022
Group,Description,Actual
IDE03114-MAS02447,Comfort function-Activation,Not available,
IDE03114-MAS08867,Comfort function-Request open sliding sunroof,not active,
IDE03114-MAS08868,Comfort function-Request close sliding sunroof,not active,
IDE03114-MAS08869,Comfort function-Request open sunroof shade,Not available,
IDE03114-MAS08870,Comfort function-Request close sunroof shade,Not available,
IDE03421-MAS09452,Hall sensors for position detection-Hall sensor for sunroof motor,operated,
IDE03421-MAS09453,Hall sensors for position detection-Sunroof motor Hall sensor 2,operated,
IDE03421-MAS09454,Hall sensors for position detection-Hall sensor for roof blind motor,not installed,
IDE03421-MAS09455,Hall sensors for position detection-Hall sensor 2 for roof blind motor,not installed,
IDE09422-MAS02282,Roof shade-Position,not installed,
IDE09422-MAS05370,Roof shade-Direction of movement,not installed,
IDE09422-MAS05563,Roof shade-Standardization,not installed,
IDE09422-MAS08536,Roof shade-Excessive temperature protection,not installed,
IDE09422-MAS08862,Roof shade-Reversing,not installed,
IDE09422-MAS08866,Roof shade-Adaption depth,not installed,
IDE09423-MAS02282,Sunroof-Position,0, %
IDE09423-MAS05370,Sunroof-Direction of movement,Not moving,
IDE09423-MAS05563,Sunroof-Standardization,standardized,
IDE09423-MAS05737,Sunroof-Position,Tilt out posi.,
IDE09423-MAS08536,Sunroof-Excessive temperature protection,not active,
IDE09423-MAS08862,Sunroof-Reversing,not active,
IDE09423-MAS08866,Sunroof-Adaption depth,not installed,
IDE09427-MAS08536,Control module counter readings-Excessive temperature protection,0,
IDE09427-MAS08872,Control module counter readings-Resets due to interruption of supply voltage,82,
IDE09427-MAS08873,Control module counter readings-Resets to hardware watchdog,5,
IDE09427-MAS08874,Control module counter readings-Resets due to software watchdog,0,
IDE09428-MAS05563,Sunroof counter readings-Standardization,4,
IDE09428-MAS08536,Sunroof counter readings-Excessive temperature protection,0,
IDE09428-MAS08862,Sunroof counter readings-Reversing,54,
IDE09428-MAS10406,Sunroof counter readings-Opening runs: sliding pos.,51,
IDE09428-MAS10407,Sunroof counter readings-Opening runs: tilted pos.,665,
IDE09428-MAS10408,Sunroof counter readings-Closing runs,713,
IDE09429-MAS05563,Sunroof shade counter readings-Standardization,not installed,
IDE09429-MAS08536,Sunroof shade counter readings-Excessive temperature protection,not installed,
IDE09429-MAS08862,Sunroof shade counter readings-Reversing,not installed,
IDE09429-MAS08871,Sunroof shade counter readings-Opening cycles,not installed,
IDE09430,History data sunroof reversing,|Year,Month
IDE09492-MAS01155,Temperatures-Control module,35.00, °C
IDE09492-MAS06997,Temperatures-Outside temperature: filtered,30.00, °C
IDE09492-MAS09033,Temperatures-Motor for sunroof,39.00, °C
IDE09492-MAS09047,Temperatures-Roof shade motor,not installed,
IDE09515-MAS08884,Controls-Sunroof button,Not operated,
IDE09515-MAS08932,Controls-Sunroof shade button,not installed,
IDE09515-MAS08992,Controls-Button for sliding roof,Not operated,
IDE09515-MAS12701,Controls-Background lighting,Current cannot be measured,
IDE09516-MAS04194,Status of child safety-Driver side,not active,
IDE09516-MAS04195,Status of child safety-Front passenger side,not active,
IDE09517-IDE00075,Control module-Vehicle speed,0.00, km/h
IDE09517-MAS02447,Control module-Activation,present,
IDE09517-MAS07376,Control module-Terminal 58xd,Not available,
IDE09517-MAS07720,Control module-Terminal 15 via CAN,On,
IDE09517-MAS08536,Control module-Excessive temperature protection,not active,
IDE09517-MAS09820,Control module-Terminal 58xt,100, %
IDE09517-MAS11498,Control module-Search illumination for control elements,100, %
IDE09517-MAS11499,Control module-Indicator lamp for rear sunroof,not installed,
IDE09518-MAS01634,Voltages and currents-Supply voltage,12.80, V
IDE09518-MAS09048,Voltages and currents-Motor current consumption for sun roof,0.00, A
IDE09518-MAS09049,Voltages and currents-Motor current consumption for roof blind,not installed,
IDE09844,History data sunroof standardization,|Year,Month
IDE09846,History data sunroof control point,|Year,Month
IDE11840-MAS13333,Operating signals for sunroof/tilt roof and roof blind-Operating signals of roof shade,Not operated,
IDE11840-MAS13334,Operating signals for sunroof/tilt roof and roof blind-Front operating signals: rear roof shade,Not operated,
IDE11840-MAS13335,Operating signals for sunroof/tilt roof and roof blind-Rear operating signals: rear roof shade,Unknown (255)
IDE11840-MAS13364,Operating signals for sunroof/tilt roof and roof blind-Operating signal sliding/tilting roof,Not operated,
IDE12985-MAS15419,Operating signals: rear door control modules-Operating signal: rear: driver side sliding/tilting sunroof,Not operated,
IDE12985-MAS15420,Operating signals: rear door control modules-Operating signal: rear: passenger side sliding/tilting sunroof,Not operated,
IDE12985-MAS15421,Operating signals: rear door control modules-Operating signal: rear: driver side roof shade,Not operated,
IDE12985-MAS15422,Operating signals: rear door control modules-Operating signal: rear: passenger side roof shade,Not operated,
IDE14139-MAS01161,Wind deflector control module: status-Communication errors,not installed,
IDE14139-MAS02282,Wind deflector control module: status-Position,not installed,
IDE14139-MAS04183,Wind deflector control module: status-Position error,not installed,
IDE14139-MAS08536,Wind deflector control module: status-Excessive temperature protection,not installed,
IDE14139-MAS17855,Wind deflector control module: status-Wagon message,Not available,
IDE14139-MAS17856,Wind deflector control module: status-Forced connection requirement,Not available,
IDE14139-MAS17857,Wind deflector control module: status-Position,not installed,
IDE14139-MAS17858,Wind deflector control module: status-Drive initializing,not installed,
IDE14139-MAS17859,Wind deflector control module: status-Adaptation run successful,not installed,
IDE14139-MAS17860,Wind deflector control module: status-Function canceled,not installed,
IDE14140-IDE02021,Wind deflector control module: reception signal-Comfort closing,Not available,
IDE14140-IDE02022,Wind deflector control module: reception signal-Comfort opening,Not available,
IDE14140-IDE14099,Wind deflector control module: reception signal-Wind deflector: denormalization,Not available,
IDE14140-MAS00370,Wind deflector control module: reception signal-Vehicle speed,Not available,
IDE14140-MAS01468,Wind deflector control module: reception signal-Terminal 15,Not available,
IDE14140-MAS02447,Wind deflector control module: reception signal-Activation,Not available,
IDE14140-MAS05563,Wind deflector control module: reception signal-Standardization,Not available,
IDE14140-MAS05737,Wind deflector control module: reception signal-Position,Not available,
IDE14140-MAS17871,Wind deflector control module: reception signal-Teaching-in run,Not available,
IDE14231-IDE09422,Power sunroof control module: absolute position values-Roof shade,not installed,
IDE14231-IDE09423,Power sunroof control module: absolute position values-Sunroof,5.0000,
IDE16400,Sunroof control module: function restriction,00NoReasonToStop                 ,
IDE16403-IDE16399,Reason for sunroof basic setting restriction-Reason for restriction,not active,
Elapsed Time: 00:04
blockmap-D6-992-941-571-AH_WVWZZZCD6RW123439-20260903-1811.CSV
;SW:992-941-571-AH   HW:992-941-571-A ---  D6: Light Ctrl Left 2
;Component:LED1L         H25 9204, Coding:
;EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Thursday,03,September,2026,18:11:49:29755
;VCID: 6889BE8802F498FA4F0-803C
IDE00102-MAS02201,Control Module temperature-Temperature,59, °C
IDE08742-MAS07015,Operating time-Running light,0.00, H
IDE08742-MAS07234,Operating time-Eco mode 1,0.00, H
IDE08742-MAS07235,Operating time-Eco mode 2,0.00, H
IDE08742-MAS13654,Operating time-Additional main beam,0.01, H
IDE08742-MAS14159,Operating time-Coming Home,0.00, H
IDE08742-MAS14160,Operating time-Leaving Home,0.00, H
IDE08742-MAS18763,Operating time-Headlight contour light,0.00, H
IDE08742,Operating time,0.08, H
IDE08742,Operating time,0.00, H
IDE08742,Operating time,15.45, H
IDE08742,Operating time,1.44, H
IDE08742,Operating time,0.40, H
IDE08742,Operating time,1.15, H
IDE08742,Operating time,0.61, H
IDE08742,Operating time,10.81, H
IDE08742-ENG187666,Operating time-cornerlight,0.05, H
IDE08742-ENG255609,Operating time-designlight 2,0.00, H
IDE08742-ENG274345,Operating time-designlight 3,0.00, H
IDE08742-ENG351726,Operating time-designlight 4,0.00, H
IDE08742-ENG351657,Operating time-designlight 5,0.00, H
IDE08742-ENG247934,Operating time-Express light,0.00, H
IDE08742-ENG186523,Operating time-Highbeam,0.00, H
IDE08742-ENG186491,Operating time-Low beam,8.87, H
IDE08742-ENG166761,Operating time-Sidemarker,0.00, H
IDE08742-ENG166116,Operating time-Turn_indicator,0.02, H
IDE09770-MAS04136,High-side channel 1-Current,0, mA
IDE09770-MAS09022,High-side channel 1-PWM value,0.0, %
IDE09770-MAS09326,High-side channel 1-Function,no function,
IDE09770-ENG186571,High-side channel 1-Output,ERROR,
IDE09771-MAS04136,High-side channel 2-Current,0, mA
IDE09771-MAS09022,High-side channel 2-PWM value,0.0, %
IDE09771-MAS09326,High-side channel 2-Function,no function,
IDE09771-ENG186571,High-side channel 2-Output,ERROR,
IDE09772-MAS04136,High-side channel 3-Current,0, mA
IDE09772-MAS09022,High-side channel 3-PWM value,0.0, %
IDE09772-MAS09326,High-side channel 3-Function,no function,
IDE09772-ENG186571,High-side channel 3-Output,ERROR,
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS07015,Number of activations-Running light,0,
IDE09774-MAS07234,Number of activations-Eco mode 1,0,
IDE09774-MAS07235,Number of activations-Eco mode 2,0,
IDE09774-MAS13654,Number of activations-Additional main beam,84,
IDE09774-MAS14159,Number of activations-Coming Home,0,
IDE09774-MAS14160,Number of activations-Leaving Home,0,
IDE09774-ENG186684,Number of activations-All weather light,12,
IDE09774-ENG108961,Number of activations-Camera lock,0,
IDE09774-ENG186410,Number of activations-City light,10,
IDE09774-ENG186757,Number of activations-daytimerunning light,128,
IDE09774-ENG187759,Number of activations-design light,0,
IDE09774-ENG255609,Number of activations-designlight 2,0,
IDE09774-ENG274345,Number of activations-designlight 3,0,
IDE09774-ENG351726,Number of activations-designlight 4,0,
IDE09774-ENG351657,Number of activations-designlight 5,0,
IDE09774-ENG247934,Number of activations-Express light,0,
IDE09774-ENG187761,Number of activations-higbeam,1,
IDE09774-ENG186491,Number of activations-Low beam,1515,
IDE09774-ENG186411,Number of activations-Parking light,5,
IDE09774-ENG186853,Number of activations-position light,724,
IDE09774-ENG166761,Number of activations-Sidemarker,0,
IDE09774-ENG186659,Number of activations-Static cornering light,40,
IDE09774-ENG186553,Number of activations-Tourist light,0,
IDE09774-ENG187378,Number of activations-turn indicator,54,
IDE09828,Head lamp variant,E0,
IDE09828-MAS16183,Head lamp variant-Headlamp coding variant via bus,E0,
IDE09828-MAS18770,Head lamp variant-Country version via data bus,ECE,
IDE09828-MAS18771,Head lamp variant-Headlamp coding variant 2 via bus,AB,
IDE09828-MAS18772,Head lamp variant-Headlamp coding variant 2 via control module,AB,
IDE09828-MAS23141,Head lamp variant-Country version via data record,ECE,
IDE09828-MAS30455,Head lamp variant-Variant comparison status,Finished and OK,
IDE10048-IDE00019,Supply information-Voltage terminal 30,12.7, V
IDE10048-MAS18767,Supply information-Voltage terminal 30G,0.0, V
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,64, °C
IDE10165-MAS04121,LED channel 1: Master 1-Voltage,8.67, V
IDE10165-MAS04136,LED channel 1: Master 1-Current,180, mA
IDE10165-MAS04625,LED channel 1: Master 1-Power: actual value,2, W
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,46.0, %
IDE10165-MAS09326,LED channel 1: Master 1-Function,cornerlight,
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,LK1,
IDE10165-ENG186571,LED channel 1: Master 1-Output,LED,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,200, °C
IDE10167-MAS04121,LED channel 1: Slave-Voltage,0.00, V
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS04625,LED channel 1: Slave-Power: actual value,0, W
IDE10167-MAS09022,LED channel 1: Slave-PWM value,0.0, %
IDE10167-MAS09326,LED channel 1: Slave-Function,no function,
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,Not Used,
IDE10167-ENG186571,LED channel 1: Slave-Output,ERROR,
IDE10168-MAS02201,LED channel 2: Master-Temperature,72, °C
IDE10168-MAS04121,LED channel 2: Master-Voltage,1.67, V
IDE10168-MAS04136,LED channel 2: Master-Current,0, mA
IDE10168-MAS04625,LED channel 2: Master-Power: actual value,0, W
IDE10168-MAS09022,LED channel 2: Master-PWM value,0.0, %
IDE10168-MAS09326,LED channel 2: Master-Function,Highbeam,
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,LK1,
IDE10168-ENG186571,LED channel 2: Master-Output,LED,
IDE10169-MAS02201,LED channel 2: Slave-Temperature,200, °C
IDE10169-MAS04121,LED channel 2: Slave-Voltage,0.00, V
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS04625,LED channel 2: Slave-Power: actual value,0, W
IDE10169-MAS09022,LED channel 2: Slave-PWM value,0.0, %
IDE10169-MAS09326,LED channel 2: Slave-Function,no function,
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,Not Used,
IDE10169-ENG186571,LED channel 2: Slave-Output,ERROR,
IDE10170-MAS02201,LED channel 3: Master-Temperature,53, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,9.00, V
IDE10170-MAS04136,LED channel 3: Master-Current,36, mA
IDE10170-MAS04625,LED channel 3: Master-Power: actual value,0, W
IDE10170-MAS09022,LED channel 3: Master-PWM value,10.0, %
IDE10170-MAS09326,LED channel 3: Master-Function,DRL & PO,
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,LK3,
IDE10170-ENG186571,LED channel 3: Master-Output,LED,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,53, °C
IDE10171-MAS04121,LED channel 3: Slave-Voltage,8.67, V
IDE10171-MAS04136,LED channel 3: Slave-Current,30, mA
IDE10171-MAS04625,LED channel 3: Slave-Power: actual value,0, W
IDE10171-MAS09022,LED channel 3: Slave-PWM value,8.0, %
IDE10171-MAS09326,LED channel 3: Slave-Function,DRL & PO,
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,LK3,
IDE10171-ENG186571,LED channel 3: Slave-Output,LED,
IDE10173,Operating times in temperature ranges,15.45, H
IDE10173,Operating times in temperature ranges,0.00, H
IDE10205,Control module version,MIN_MQB,
IDE11123-MAS04136,High-side channel 4-Current,0, mA
IDE11123-MAS09022,High-side channel 4-PWM value,0.0, %
IDE11123-MAS09326,High-side channel 4-Function,no function,
IDE11123-ENG186571,High-side channel 4-Output,ERROR,
IDE11124-ENG188404,Left Headlamp Beam Adjustment Motor-LWR__speed_adjustment,warm,
IDE11124-ENG188356,Left Headlamp Beam Adjustment Motor-LWR_fault_position,not active,
IDE11124-ENG187101,Left Headlamp Beam Adjustment Motor-LWR_motor_position_in_mm,0.00, mm
IDE11124-ENG187107,Left Headlamp Beam Adjustment Motor-LWR_motor_position_in_percent,63.5, %
IDE11124-ENG188443,Left Headlamp Beam Adjustment Motor-LWR_reference_run,erfolgt,
IDE11918-MAS03378,Headlights production data-Supplier,              ,
IDE11918-ENG187298,Headlights production data-partnumber headlamp,              ,
IDE11918-ENG186473,Headlights production data-production date,              ,
IDE11918-ENG98897,Headlights production data-Serial number,              ,
IDE13678-MAS02201,LED channel 4: Master-Temperature,72, °C
IDE13678-MAS04121,LED channel 4: Master-Voltage,17.33, V
IDE13678-MAS04136,LED channel 4: Master-Current,762, mA
IDE13678-MAS04625,LED channel 4: Master-Power: actual value,13, W
IDE13678-MAS09022,LED channel 4: Master-PWM value,100.0, %
IDE13678-MAS09326,LED channel 4: Master-Function,lowbeam,
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,LK1,
IDE13678-ENG186571,LED channel 4: Master-Output,LED,
IDE13897-MAS18765,Headlamp identification-Identification,ERROR,
IDE13898-MAS02201,LED channel 5: Master-Temperature,53, °C
IDE13898-MAS04121,LED channel 5: Master-Voltage,1.67, V
IDE13898-MAS04136,LED channel 5: Master-Current,0, mA
IDE13898-MAS04625,LED channel 5: Master-Power: actual value,0, W
IDE13898-MAS09022,LED channel 5: Master-PWM value,0.0, %
IDE13898-MAS09326,LED channel 5: Master-Function,turn indicator,
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK3,
IDE13898-ENG186571,LED channel 5: Master-Output,LED,
IDE13899-MAS02201,LED channel 6: Master-Temperature,46, °C
IDE13899-MAS04121,LED channel 6: Master-Voltage,1.67, V
IDE13899-MAS04136,LED channel 6: Master-Current,0, mA
IDE13899-MAS04625,LED channel 6: Master-Power: actual value,0, W
IDE13899-MAS09022,LED channel 6: Master-PWM value,0.0, %
IDE13899-MAS09326,LED channel 6: Master-Function,Highbeam,
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,LK1,
IDE13899-ENG186571,LED channel 6: Master-Output,LED,
IDE13900-MAS02201,LED channel 7: Master-Temperature,200, °C
IDE13900-MAS04121,LED channel 7: Master-Voltage,0.00, V
IDE13900-MAS04136,LED channel 7: Master-Current,0, mA
IDE13900-MAS04625,LED channel 7: Master-Power: actual value,0, W
IDE13900-MAS09022,LED channel 7: Master-PWM value,0.0, %
IDE13900-MAS09326,LED channel 7: Master-Function,no function,
IDE13900-MAS09327,LED channel 7: Master-LED brightness class,Not Used,
IDE13900-ENG186571,LED channel 7: Master-Output,ERROR,
IDE13901-MAS02201,LED channel 8: Master-Temperature,200, °C
IDE13901-MAS04121,LED channel 8: Master-Voltage,0.00, V
IDE13901-MAS04136,LED channel 8: Master-Current,0, mA
IDE13901-MAS04625,LED channel 8: Master-Power: actual value,0, W
IDE13901-MAS09022,LED channel 8: Master-PWM value,0.0, %
IDE13901-MAS09326,LED channel 8: Master-Function,no function,
IDE13901-MAS09327,LED channel 8: Master-LED brightness class,Not Used,
IDE13901-ENG186571,LED channel 8: Master-Output,ERROR,
IDE13902-MAS02201,LED channel 9: Master-Temperature,200, °C
IDE13902-MAS04121,LED channel 9: Master-Voltage,0.00, V
IDE13902-MAS04136,LED channel 9: Master-Current,0, mA
IDE13902-MAS04625,LED channel 9: Master-Power: actual value,0, W
IDE13902-MAS09022,LED channel 9: Master-PWM value,0.0, %
IDE13902-MAS09326,LED channel 9: Master-Function,no function,
IDE13902-MAS09327,LED channel 9: Master-LED brightness class,Not Used,
IDE13902-ENG186571,LED channel 9: Master-Output,ERROR,
IDE13903-MAS02201,LED channel 10: Master-Temperature,200, °C
IDE13903-MAS04121,LED channel 10: Master-Voltage,0.00, V
IDE13903-MAS04136,LED channel 10: Master-Current,0, mA
IDE13903-MAS04625,LED channel 10: Master-Power: actual value,0, W
IDE13903-MAS09022,LED channel 10: Master-PWM value,0.0, %
IDE13903-MAS09326,LED channel 10: Master-Function,no function,
IDE13903-MAS09327,LED channel 10: Master-LED brightness class,Not Used,
IDE13903-ENG186571,LED channel 10: Master-Output,ERROR,
IDE13904-MAS02201,LED channel 11: Master-Temperature,200, °C
IDE13904-MAS04121,LED channel 11: Master-Voltage,0.00, V
IDE13904-MAS04136,LED channel 11: Master-Current,0, mA
IDE13904-MAS04625,LED channel 11: Master-Power: actual value,0, W
IDE13904-MAS09022,LED channel 11: Master-PWM value,0.0, %
IDE13904-MAS09326,LED channel 11: Master-Function,no function,
IDE13904-MAS09327,LED channel 11: Master-LED brightness class,Not Used,
IDE13904-ENG186571,LED channel 11: Master-Output,ERROR,
IDE13905-MAS02201,LED channel 12: Master-Temperature,200, °C
IDE13905-MAS04121,LED channel 12: Master-Voltage,0.00, V
IDE13905-MAS04136,LED channel 12: Master-Current,0, mA
IDE13905-MAS04625,LED channel 12: Master-Power: actual value,0, W
IDE13905-MAS09022,LED channel 12: Master-PWM value,0.0, %
IDE13905-MAS09326,LED channel 12: Master-Function,no function,
IDE13905-MAS09327,LED channel 12: Master-LED brightness class,Not Used,
IDE13905-ENG186571,LED channel 12: Master-Output,ERROR,
IDE13906-MAS09833,PWM values channel 1-LED 1,0.0, %
IDE13906-MAS09834,PWM values channel 1-LED 2,0.0, %
IDE13906-MAS09835,PWM values channel 1-LED 3,0.0, %
IDE13906-MAS09836,PWM values channel 1-LED 4,0.0, %
IDE13906-MAS09837,PWM values channel 1-LED 5,0.0, %
IDE13906-MAS09838,PWM values channel 1-LED 6,0.0, %
IDE13906-MAS09839,PWM values channel 1-LED 7,0.0, %
IDE13906-MAS09840,PWM values channel 1-LED 8,0.0, %
IDE13906-MAS09841,PWM values channel 1-LED 9,0.0, %
IDE13906-MAS09842,PWM values channel 1-LED 10,0.0, %
IDE13906-MAS09843,PWM values channel 1-LED 11,0.0, %
IDE13906-MAS09844,PWM values channel 1-LED 12,0.0, %
IDE13907-MAS09833,PWM values channel 2-LED 1,0.0, %
IDE13907-MAS09834,PWM values channel 2-LED 2,0.0, %
IDE13907-MAS09835,PWM values channel 2-LED 3,0.0, %
IDE13907-MAS09836,PWM values channel 2-LED 4,0.0, %
IDE13907-MAS09837,PWM values channel 2-LED 5,0.0, %
IDE13907-MAS09838,PWM values channel 2-LED 6,0.0, %
IDE13907-MAS09839,PWM values channel 2-LED 7,0.0, %
IDE13907-MAS09840,PWM values channel 2-LED 8,0.0, %
IDE13907-MAS09841,PWM values channel 2-LED 9,0.0, %
IDE13907-MAS09842,PWM values channel 2-LED 10,0.0, %
IDE13907-MAS09843,PWM values channel 2-LED 11,0.0, %
IDE13907-MAS09844,PWM values channel 2-LED 12,0.0, %
IDE13908-MAS09833,PWM values channel 3-LED 1,0.0, %
IDE13908-MAS09834,PWM values channel 3-LED 2,0.0, %
IDE13908-MAS09835,PWM values channel 3-LED 3,0.0, %
IDE13908-MAS09836,PWM values channel 3-LED 4,0.0, %
IDE13908-MAS09837,PWM values channel 3-LED 5,0.0, %
IDE13908-MAS09838,PWM values channel 3-LED 6,0.0, %
IDE13908-MAS09839,PWM values channel 3-LED 7,0.0, %
IDE13908-MAS09840,PWM values channel 3-LED 8,0.0, %
IDE13908-MAS09841,PWM values channel 3-LED 9,0.0, %
IDE13908-MAS09842,PWM values channel 3-LED 10,0.0, %
IDE13908-MAS09843,PWM values channel 3-LED 11,0.0, %
IDE13908-MAS09844,PWM values channel 3-LED 12,0.0, %
IDE13909-MAS09833,PWM values channel 4-LED 1,0.0, %
IDE13909-MAS09834,PWM values channel 4-LED 2,0.0, %
IDE13909-MAS09835,PWM values channel 4-LED 3,0.0, %
IDE13909-MAS09836,PWM values channel 4-LED 4,0.0, %
IDE13909-MAS09837,PWM values channel 4-LED 5,0.0, %
IDE13909-MAS09838,PWM values channel 4-LED 6,0.0, %
IDE13909-MAS09839,PWM values channel 4-LED 7,0.0, %
IDE13909-MAS09840,PWM values channel 4-LED 8,0.0, %
IDE13909-MAS09841,PWM values channel 4-LED 9,0.0, %
IDE13909-MAS09842,PWM values channel 4-LED 10,0.0, %
IDE13909-MAS09843,PWM values channel 4-LED 11,0.0, %
IDE13909-MAS09844,PWM values channel 4-LED 12,0.0, %
IDE13910-MAS09833,PWM values channel 5-LED 1,0.0, %
IDE13910-MAS09834,PWM values channel 5-LED 2,0.0, %
IDE13910-MAS09835,PWM values channel 5-LED 3,0.0, %
IDE13910-MAS09836,PWM values channel 5-LED 4,0.0, %
IDE13910-MAS09837,PWM values channel 5-LED 5,0.0, %
IDE13910-MAS09838,PWM values channel 5-LED 6,0.0, %
IDE13910-MAS09839,PWM values channel 5-LED 7,0.0, %
IDE13910-MAS09840,PWM values channel 5-LED 8,0.0, %
IDE13910-MAS09841,PWM values channel 5-LED 9,0.0, %
IDE13910-MAS09842,PWM values channel 5-LED 10,0.0, %
IDE13910-MAS09843,PWM values channel 5-LED 11,0.0, %
IDE13910-MAS09844,PWM values channel 5-LED 12,0.0, %
IDE13911-MAS09833,PWM values channel 6-LED 1,0.0, %
IDE13911-MAS09834,PWM values channel 6-LED 2,0.0, %
IDE13911-MAS09835,PWM values channel 6-LED 3,0.0, %
IDE13911-MAS09836,PWM values channel 6-LED 4,0.0, %
IDE13911-MAS09837,PWM values channel 6-LED 5,0.0, %
IDE13911-MAS09838,PWM values channel 6-LED 6,0.0, %
IDE13911-MAS09839,PWM values channel 6-LED 7,0.0, %
IDE13911-MAS09840,PWM values channel 6-LED 8,0.0, %
IDE13911-MAS09841,PWM values channel 6-LED 9,0.0, %
IDE13911-MAS09842,PWM values channel 6-LED 10,0.0, %
IDE13911-MAS09843,PWM values channel 6-LED 11,0.0, %
IDE13911-MAS09844,PWM values channel 6-LED 12,0.0, %
IDE13912-MAS09833,PWM values channel 7-LED 1,0.0, %
IDE13912-MAS09834,PWM values channel 7-LED 2,0.0, %
IDE13912-MAS09835,PWM values channel 7-LED 3,0.0, %
IDE13912-MAS09836,PWM values channel 7-LED 4,0.0, %
IDE13912-MAS09837,PWM values channel 7-LED 5,0.0, %
IDE13912-MAS09838,PWM values channel 7-LED 6,0.0, %
IDE13912-MAS09839,PWM values channel 7-LED 7,0.0, %
IDE13912-MAS09840,PWM values channel 7-LED 8,0.0, %
IDE13912-MAS09841,PWM values channel 7-LED 9,0.0, %
IDE13912-MAS09842,PWM values channel 7-LED 10,0.0, %
IDE13912-MAS09843,PWM values channel 7-LED 11,0.0, %
IDE13912-MAS09844,PWM values channel 7-LED 12,0.0, %
IDE13913-MAS09833,PWM values channel 8-LED 1,0.0, %
IDE13913-MAS09834,PWM values channel 8-LED 2,0.0, %
IDE13913-MAS09835,PWM values channel 8-LED 3,0.0, %
IDE13913-MAS09836,PWM values channel 8-LED 4,0.0, %
IDE13913-MAS09837,PWM values channel 8-LED 5,0.0, %
IDE13913-MAS09838,PWM values channel 8-LED 6,0.0, %
IDE13913-MAS09839,PWM values channel 8-LED 7,0.0, %
IDE13913-MAS09840,PWM values channel 8-LED 8,0.0, %
IDE13913-MAS09841,PWM values channel 8-LED 9,0.0, %
IDE13913-MAS09842,PWM values channel 8-LED 10,0.0, %
IDE13913-MAS09843,PWM values channel 8-LED 11,0.0, %
IDE13913-MAS09844,PWM values channel 8-LED 12,0.0, %
IDE13914-MAS09833,PWM values channel 9-LED 1,0.0, %
IDE13914-MAS09834,PWM values channel 9-LED 2,0.0, %
IDE13914-MAS09835,PWM values channel 9-LED 3,0.0, %
IDE13914-MAS09836,PWM values channel 9-LED 4,0.0, %
IDE13914-MAS09837,PWM values channel 9-LED 5,0.0, %
IDE13914-MAS09838,PWM values channel 9-LED 6,0.0, %
IDE13914-MAS09839,PWM values channel 9-LED 7,0.0, %
IDE13914-MAS09840,PWM values channel 9-LED 8,0.0, %
IDE13914-MAS09841,PWM values channel 9-LED 9,0.0, %
IDE13914-MAS09842,PWM values channel 9-LED 10,0.0, %
IDE13914-MAS09843,PWM values channel 9-LED 11,0.0, %
IDE13914-MAS09844,PWM values channel 9-LED 12,0.0, %
IDE13915-MAS09833,PWM values channel 10-LED 1,0.0, %
IDE13915-MAS09834,PWM values channel 10-LED 2,0.0, %
IDE13915-MAS09835,PWM values channel 10-LED 3,0.0, %
IDE13915-MAS09836,PWM values channel 10-LED 4,0.0, %
IDE13915-MAS09837,PWM values channel 10-LED 5,0.0, %
IDE13915-MAS09838,PWM values channel 10-LED 6,0.0, %
IDE13915-MAS09839,PWM values channel 10-LED 7,0.0, %
IDE13915-MAS09840,PWM values channel 10-LED 8,0.0, %
IDE13915-MAS09841,PWM values channel 10-LED 9,0.0, %
IDE13915-MAS09842,PWM values channel 10-LED 10,0.0, %
IDE13915-MAS09843,PWM values channel 10-LED 11,0.0, %
IDE13915-MAS09844,PWM values channel 10-LED 12,0.0, %
IDE13916-MAS09833,PWM values channel 11-LED 1,0.0, %
IDE13916-MAS09834,PWM values channel 11-LED 2,0.0, %
IDE13916-MAS09835,PWM values channel 11-LED 3,0.0, %
IDE13916-MAS09836,PWM values channel 11-LED 4,0.0, %
IDE13916-MAS09837,PWM values channel 11-LED 5,0.0, %
IDE13916-MAS09838,PWM values channel 11-LED 6,0.0, %
IDE13916-MAS09839,PWM values channel 11-LED 7,0.0, %
IDE13916-MAS09840,PWM values channel 11-LED 8,0.0, %
IDE13916-MAS09841,PWM values channel 11-LED 9,0.0, %
IDE13916-MAS09842,PWM values channel 11-LED 10,0.0, %
IDE13916-MAS09843,PWM values channel 11-LED 11,0.0, %
IDE13916-MAS09844,PWM values channel 11-LED 12,0.0, %
IDE13917-MAS09833,PWM values channel 12-LED 1,0.0, %
IDE13917-MAS09834,PWM values channel 12-LED 2,0.0, %
IDE13917-MAS09835,PWM values channel 12-LED 3,0.0, %
IDE13917-MAS09836,PWM values channel 12-LED 4,0.0, %
IDE13917-MAS09837,PWM values channel 12-LED 5,0.0, %
IDE13917-MAS09838,PWM values channel 12-LED 6,0.0, %
IDE13917-MAS09839,PWM values channel 12-LED 7,0.0, %
IDE13917-MAS09840,PWM values channel 12-LED 8,0.0, %
IDE13917-MAS09841,PWM values channel 12-LED 9,0.0, %
IDE13917-MAS09842,PWM values channel 12-LED 10,0.0, %
IDE13917-MAS09843,PWM values channel 12-LED 11,0.0, %
IDE13917-MAS09844,PWM values channel 12-LED 12,0.0, %
MAS00468,Unlearning counter,79,
Elapsed Time: 00:09
blockmap-D7-992-941-571-AH_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:992-941-571-AH   HW:992-941-571-A ---  D7: Light Ctrl Right 2
;Component:LED1R         H25 9204, Coding:
;EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Thursday,03,September,2026,18:12:03:29755
IDE00102-MAS02201,Control Module temperature-Temperature,57, °C
IDE08742-MAS13654,Operating time-Additional main beam,0.00, H
IDE08742-MAS14159,Operating time-Coming Home,0.27, H
IDE08742-MAS14160,Operating time-Leaving Home,0.21, H
IDE08742,Operating time,0.65, H
IDE08742,Operating time,442.02, H
IDE08742,Operating time,203.85, H
IDE08742,Operating time,157.94, H
IDE08742-ENG187666,Operating time-cornerlight,0.01, H
IDE08742-ENG186523,Operating time-Highbeam,3.17, H
IDE08742-ENG186491,Operating time-Low beam,159.26, H
IDE08742-ENG166116,Operating time-Turn_indicator,13.24, H
IDE09770-ENG186571,High-side channel 1-Output,16,
IDE09771-ENG186571,High-side channel 2-Output,16,
IDE09772-ENG186571,High-side channel 3-Output,16,
IDE09774-IDE03638,Number of activations-Static cornering light,3,
IDE09774-IDE05723,Number of activations-Clearance light,4979,
IDE09774-MAS07249,Number of activations-Main beam,730,
IDE09774-MAS09325,Number of activations-Daytime running lights,5462,
IDE09774-MAS13654,Number of activations-Additional main beam,9,
IDE09774-MAS14159,Number of activations-Coming Home,275,
IDE09774-MAS14160,Number of activations-Leaving Home,78,
IDE09774-MAS25532,Number of activations-Headlights: contour lighting,0,
IDE09774-ENG186684,Number of activations-All weather light,0,
IDE09774-ENG186491,Number of activations-Low beam,2214,
IDE09774-ENG186411,Number of activations-Parking light,2,
IDE09774-ENG187378,Number of activations-turn indicator,9332,
IDE09828-MAS16182,Head lamp variant-Headlamp coding variant via control module,E0,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,63, °C
IDE10165-MAS04136,LED channel 1: Master 1-Current,156, mA
IDE10165-MAS04625,LED channel 1: Master 1-Power: actual value,1, W
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,40.0, %
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,LK2,
IDE10167-ENG186571,LED channel 1: Slave-Output,16,
IDE10168-MAS02201,LED channel 2: Master-Temperature,74, °C
IDE10169-ENG186571,LED channel 2: Slave-Output,16,
IDE10170-MAS02201,LED channel 3: Master-Temperature,56, °C
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,LK1,
IDE10171-MAS02201,LED channel 3: Slave-Temperature,56, °C
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,LK1,
IDE10173,Operating times in temperature ranges,442.02, H
IDE11123-ENG186571,High-side channel 4-Output,16,
IDE11124-ENG188255,Left Headlamp Beam Adjustment Motor-LWR_speed_adjustment,warm,
IDE13678-MAS02201,LED channel 4: Master-Temperature,74, °C
IDE13897-MAS18765,Headlamp identification-Identification,16,
IDE13898-MAS02201,LED channel 5: Master-Temperature,56, °C
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK1,
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,LK2,
IDE13900-ENG186571,LED channel 7: Master-Output,16,
IDE13901-ENG186571,LED channel 8: Master-Output,16,
IDE13902-ENG186571,LED channel 9: Master-Output,16,
IDE13903-ENG186571,LED channel 10: Master-Output,16,
IDE13904-ENG186571,LED channel 11: Master-Output,16,
IDE13905-ENG186571,LED channel 12: Master-Output,16,
Elapsed Time: 00:09
blockmap-8107-5WA-035-741-B_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-035-741-B   HW:5WA-035-741-B ---  8107: Antenna
;Component:TrxModulHigh  H10 0083, Coding:02380011440080
;EV_TrxMLGEMQB37W,005006,EV_TrxMLGEMQB37W.rod
;Thursday,03,September,2026,18:12:17:29755
;VCID: 43D349245B129BA2BA2-8016 SFD {x}
IDE00019,Voltage terminal 30,12.80, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,51, °C
IDE00767,No. of unscheduled ECU resets,68,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS02230,GPS Position-Height,322, m
IDE03477-MAS00106,GPS time-Year,2026,
IDE03477-MAS00107,GPS time-Month,9,
IDE03477-MAS00108,GPS time-Day,3,
IDE03477-MAS00109,GPS time-Hours,16,
IDE03477-MAS00110,GPS time-Minutes,12,
IDE03477-MAS00111,GPS time-Seconds,18,
IDE03477-MAS01632,GPS time-Status,valid,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,254,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS00106,Update programming: status-Year,2000,
IDE07589-MAS00107,Update programming: status-Month,0,
IDE07589-MAS00108,Update programming: status-Day,0,
IDE07589-MAS00109,Update programming: status-Hours,0,
IDE07589-MAS00110,Update programming: status-Minutes,0,
IDE07589-MAS00111,Update programming: status-Seconds,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE10300,OBD Driving Cycle detected,active,
IDE10779,Ethernet signal quality,good: link available,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 BA|FD 30 E0 8E C0 31 00 10 00 00 00 00 00 00 00 02|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 02 00 00 00 00 00 00 00 00 00 01 FF AD 62 4C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 BA|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 01 FF B0 E8 BC|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,65535,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|F8 38 69 AD 62 4C|,
IDE11869-IDE09467,IP network: NDP cache-MAC address,Write only channel,
IDE12238,I network: discarded messages counter,65535,
IDE12239-IDE09469,IP network: test feedback value of communications relationships-IPv6 address,|IPv6 address,Result|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,Status of vehicle identification number,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZCD6RW123439,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,16,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 47,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 51 02 CD C1 F3 4A 5F,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 08,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,12,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,22,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,79,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,18974, km
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18253-MAS01167,Status of control loop test for antenna performance-Actuation time,Unknown (0)
MAS18253-ENG170421,Status of control loop test for antenna performance-IoReached Status,Output diagnostic test not active,
MAS18259-MAS01167,Status of Bluetooth/WLAN sending power test-Actuation time,Unknown (0)
MAS18259-ENG170421,Status of Bluetooth/WLAN sending power test-IoReached Status,Output diagnostic test not active,
MAS18424,List of last unscheduled control module resets,||Watchdog_AP|Watchdog_AP|Watchdog_MCU|Watchdog_AP|Watchdog_MCU|Watchdog_AP|Watchdog_AP|Watchdog_AP|Watchdog_AP|Watchdog_AP|,
MAS18425-IDE00690,5GHz WLAN antenna in roof module-Connection to antenna,electrically OK,
MAS18425-MAS01808,5GHz WLAN antenna in roof module-Antenna current,2, mA
MAS18425-MAS18426,5GHz WLAN antenna in roof module-WLAN p reception power,-92.0, dBm
MAS18425-MAS18427,5GHz WLAN antenna in roof module-WLAN n/ac reception power,0.0, dBm
MAS18425-MAS18428,5GHz WLAN antenna in roof module-WLAN p transmitting power,1.0, dBm
MAS18425-MAS18429,5GHz WLAN antenna in roof module-WLAN n/ac transmitting power,0.0, dBm
MAS18425-MAS18430,5GHz WLAN antenna in roof module-WLAN p communication channel,180,
MAS18425-MAS18431,5GHz WLAN antenna in roof module-WLAN n/ac communication channel,0,
MAS18432-IDE00690,5Ghz WLAN backup antenna-Connection to antenna,electrically OK,
MAS18432-MAS01808,5Ghz WLAN backup antenna-Antenna current,30, mA
MAS18432-MAS18426,5Ghz WLAN backup antenna-WLAN p reception power,-95.0, dBm
MAS18432-MAS18428,5Ghz WLAN backup antenna-WLAN p transmitting power,0.0, dBm
MAS18432-MAS18430,5Ghz WLAN backup antenna-WLAN p communication channel,180,
MAS19409-MAS19367,Local Hazard Warning systems-Car2X stack mode,IEEE 802.11p,
MAS19409-MAS19370,Local Hazard Warning systems-Send Car2X message,Wait,
MAS19409-MAS19373,Local Hazard Warning systems-Car2X message received,Wait,
MAS19409-MAS19378,Local Hazard Warning systems-Certificate check,Certificates valid,
MAS19409-MAS19383,Local Hazard Warning systems-Software update,Wait,
MAS19409-MAS19389,Local Hazard Warning systems-Privacy mode,OFF,
MAS19409-MAS19390,Local Hazard Warning systems-MIB configuration,OFF,
MAS19409-MAS19410,Local Hazard Warning systems-Local hazard warning status,active,
MAS19409-MAS19412,Local Hazard Warning systems-Digital Command Control transmission power,0.00,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,105,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2026-07-09T14:09:40Z,
ENG254576-IDE01760,C2X_Basic_Service-Street category,not active,
ENG254576-MAS14749,C2X_Basic_Service-Traffic side,not active,
ENG254576-ENG255505,C2X_Basic_Service-C2X_Basic_Service_State,error_EGO_data_processing,
ENG254576-ENG255506,C2X_Basic_Service-C2X_EGO_Lane,Not available,
ENG254576-ENG255507,C2X_Basic_Service-C2X_Input_Interface,Wait,
ENG254576-ENG255508,C2X_Basic_Service-C2X_LGW_Interface_Object_Available,No,
ENG254576-ENG255509,C2X_Basic_Service-C2X_Object_Interface_Available,No,
ENG254576-ENG255510,C2X_Basic_Service-C2X_Objectlist_Object_Available,No,
ENG254576-ENG255511,C2X_Basic_Service-C2X_Position_Accuracy,not active,
ENG254576-ENG255512,C2X_Basic_Service-C2X_PSD,Not available,
ENG254576-ENG255513,C2X_Basic_Service-C2X_Road_Environment,not active,
ENG254576-ENG255514,C2X_Basic_Service-C2X_Speed_Class,Not available,
ENG254765-ENG255869,LGW_detection_enviroment_and_systems-LGW_Det_AdverseWaether_Fog_Rain,fog_sensor,
ENG254765-ENG255870,LGW_detection_enviroment_and_systems-LGW_Det_AdverseWeather_State,not activated,
ENG254765-ENG255871,LGW_detection_enviroment_and_systems-LGW_Det_AdwerseWaether_Acceleration,loss_of_traction_acceleration,
ENG254765-ENG255872,LGW_detection_enviroment_and_systems-LGW_Det_EASS_State,Malfunction,
ENG254765-ENG255873,LGW_detection_enviroment_and_systems-LGW_Det_EASS_Use_Case,Wait,
ENG254765-ENG255880,LGW_detection_enviroment_and_systems-LGW_Det_TrafficJam_Messages,Wait,
ENG254765-ENG255881,LGW_detection_enviroment_and_systems-LGW_Det_TrafficJam_State,Malfunction,
ENG254765-ENG255882,LGW_detection_enviroment_and_systems-LGW_Det_TrafficJam_Use_Case,Wait,
ENG254766-ENG255874,LGW_Detection_Vehicles-LGW_Det_EmergencyVehicle_Dynamic,Wait,
ENG254766-ENG255875,LGW_Detection_Vehicles-LGW_Det_EmergencyVehicle_State,not activated,
ENG254766-ENG255876,LGW_Detection_Vehicles-LGW_Det_EmergencyVehicle_Stationary,Wait,
ENG254766-ENG255877,LGW_Detection_Vehicles-LGW_Det_StationaryVehicle_Breakdown,Wait,
ENG254766-ENG255878,LGW_Detection_Vehicles-LGW_Det_StationaryVehicle_Crash,Wait,
ENG254766-ENG255879,LGW_Detection_Vehicles-LGW_Det_StationaryVehicle_State,error_irreversible_Restraint_system,
ENG254767-ENG255883,LGW_Display_Control-LGW_Display_State,ERROR,
ENG254768-ENG255610,LGW_Functions-Det_AdverseWeather,not activated,
ENG254768-ENG255611,LGW_Functions-Det_EASS,Malfunction,
ENG254768-ENG255612,LGW_Functions-Det_EmergencyVehicle,not activated,
ENG254768-ENG255613,LGW_Functions-Det_StationaryVehicle,Malfunction,
ENG254768-ENG255614,LGW_Functions-Det_TrafficJam,Malfunction,
ENG254768-ENG255805,LGW_Functions-Int_Dyn_EmergencyVehicle,Wait,
ENG254768-ENG255806,LGW_Functions-Int_PLS_Event,Wait,
ENG254769-ENG255884,LGW_Interpretation_Dyn_EmergencyVehicle-LGW_Int_Dyn_EmergencyVehicle_AlongTraffic,Wait,
ENG254769-ENG255885,LGW_Interpretation_Dyn_EmergencyVehicle-LGW_Int_Dyn_EmergencyVehicle_CrossTraffic,Wait,
ENG254769-ENG255886,LGW_Interpretation_Dyn_EmergencyVehicle-LGW_Int_Dyn_EmergencyVehicle_EventRelevance,Wait,
ENG254769-ENG255887,LGW_Interpretation_Dyn_EmergencyVehicle-LGW_Int_Dyn_EmergencyVehicle_State,Wait,
ENG254769-ENG255888,LGW_Interpretation_Dyn_EmergencyVehicle-LGW_Int_Dyn_EmergencyVehicle_Warning,Wait,
ENG254770-ENG255889,LGW_Interpretation_Punctual_LargeScale_Event-LGW_Int_PLS_Event_Information,Wait,
ENG254770-ENG255890,LGW_Interpretation_Punctual_LargeScale_Event-LGW_Int_PLS_Event_Relevance,Wait,
ENG254770-ENG255891,LGW_Interpretation_Punctual_LargeScale_Event-LGW_Int_PLS_Event_State,Wait,
ENG254770-ENG255892,LGW_Interpretation_Punctual_LargeScale_Event-LGW_Int_PLS_Event_Warning,Wait,
ENG254771-ENG256246,LGW_Personalisierung-PSO_Adwerse_Weather,OFF,
ENG254771-ENG256247,LGW_Personalisierung-PSO_Breakdown,OFF,
ENG254771-ENG256248,LGW_Personalisierung-PSO_Crash,OFF,
ENG254771-ENG256249,LGW_Personalisierung-PSO_Dynamic_Emergency_Vehicle,OFF,
ENG254771-ENG256250,LGW_Personalisierung-PSO_EASS,OFF,
ENG254771-ENG256251,LGW_Personalisierung-PSO_End_of_Traffic_Jam,OFF,
ENG254771-ENG256252,LGW_Personalisierung-PSO_Generic_dynamic_Emergency_Vehicle,OFF,
ENG254771-ENG256253,LGW_Personalisierung-PSO_Generic_Punctual_Event,OFF,
ENG254771-ENG256254,LGW_Personalisierung-PSO_LGW_State,not active,
ENG254771-ENG256255,LGW_Personalisierung-PSO_Loss_of_Traction,OFF,
ENG254771-ENG256256,LGW_Personalisierung-PSO_Roadworks,OFF,
ENG254771-ENG256257,LGW_Personalisierung-PSO_Stationary_Emergency_Vehicle,OFF,
ENG254771-ENG256258,LGW_Personalisierung-PSO_Stationary_Vehicle,OFF,
ENG254771-ENG256259,LGW_Personalisierung-PSO_Userprofile_Change,OFF,
ENG254771-ENG256260,LGW_Personalisierung-PSO_Userprofile_Change_CL15_on,OFF,
ENG254796-ENG255277,Power_Control_Feedback_WLAN-Adjustment_State,not_adjusted,
ENG254796-ENG255278,Power_Control_Feedback_WLAN-Aerial_Power,0, dB
ENG254815-ENG255489,Signal_Noise_Ratio-BTLE_SNR,0, dB
ENG254815-ENG256713,Signal_Noise_Ratio-WLAN_2_4_GHz_SNR,0, dB
ENG254815-ENG256714,Signal_Noise_Ratio-WLAN_5_GHz_SNR,0, dB
Elapsed Time: 00:10
blockmap-811E-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  811E: Burglary Protection FL
;Component:Kessy RSAD    070 0636, Coding:
;EV_RSADVL37w,002013,EV_RSADVL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:36:29755
;VCID: 4BC36104734253E2422-801E
IDE00019,Voltage terminal 30,12962, mV
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.9, V
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,2,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Power_On_Reset,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Power_On_Reset,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Unexpected_Watchdog_Reset,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Power_On_Reset,
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_front_driver_side,
ENG108452,Reset_counter,54,
Elapsed Time: 00:01
blockmap-811F-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  811F: Burglary Protection FR
;EV_RSADVR37w,002013,EV_RSADHL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:42:29755
IDE00019,Voltage terminal 30,12970, mV
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,-----------------,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 00,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,2,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 00,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,1,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Power_On_Reset,
ENG254755-ENG276707,Learned_state-Learned_position_in_car,no_installation,
ENG108452,Reset_counter,28,
Elapsed Time: 00:01
blockmap-8120-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  8120: Burglary Protection RL
;EV_RSADHL37w,002013,EV_RSADHL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:48:29755
IDE00019,Voltage terminal 30,12990, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_rear_driver_side,
Elapsed Time: 00:01
blockmap-8121-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  8121: Burglary Protection RR
;EV_RSADHR37w,002013,EV_RSADHL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:53:29755
IDE00019,Voltage terminal 30,12919, mV
ENG254755-ENG276707,Learned_state-Learned_position_in_car,Position_rear_codriver_side,
Elapsed Time: 00:01
blockmap-OBD_WVWZZZCD6RW123439-20260903-1813.CSV
;33-OBD2
;Thursday,03,September,2026,18:13:03:29755
03,Fuel system 1/2 status,Closed loop
04,Calculated load value,25.5 %
05,Engine coolant temperature,91 °C
06,Short Term Trim - Bank 1,0.8 %
07,Long Term Trim - Bank 1,1.6 %
0B,Intake Manifold Absolute Pressure,43 kPa abs
0C,Engine RPM,951 /min
0D,Vehicle speed,0 km/h
0E,Ignition timing advance for cyl #1,-6.5 Degrees
0F,Intake air temperature,55 °C
11,Absolute Throttle Position,13.3 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.660 V,0.00 %()
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,2474 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,15.3 %
2F,Fuel Level Input,11.8 %
30,Warm-ups since DTC cleared,2
31,Distance since DTC cleared,0 km
33,Barometric pressure,97 kPa abs
34,Bank 1 Sensor 1 Status,1.000 Lambda,0.000 mA
3C,B1S1 Cat. Temp.,396.5 °C
42,Control module voltage,13.025 V
43,Absolute Load Value,28 %
44,Commanded Equivalence Ratio,1.000 Lambda
45,Relative Throttle Position,3.1 %
46,Ambient Air Temp,30 °C
47,Absolute Throttle Position B,14 %
49,Accelerator Pedal Position D,14.1 %
4A,Accelerator Pedal Position E,14.1 %
4C,Commanded Throttle Actuator Control,3.9 %
51,Fuel type,Gasoline
53,Abs. evap. vapour press.,99640 kPa abs
56,Long term sec. O2 trim bank 1/3,0.0 %
5E,Engine Fuel Rate,0.95 L/h
62,Torque actual,8.0 %
63,Torque Reference,250 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N,MT_GEAR:GEAR
67,Engine Coolant Temp,ECT 1:91 °C,ECT 2:51 °C
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:22080/--- kPa
70,Boost Press Ctrl A/B,BP_A act:97.7 kPa
71,Var. Geom. Turb. Ctrl A/B,VGT_A cmd/act:0.0/0.0 %,VGT_B cmd/act:---/--- %
73,Exhaust Press 1/2,EP1:96.34 kPa
77,Charge Air Temp.,B1S1:52 °C
8B,Aftertreatment status,PF_Regen:Status:N,PF_Load: 49.8 %
8E,Eng. friction %torque,3.0 %
9D,Fuel rate,Engine: 0.18 g/s,Vehicle: 0.18 g/s
9E,Exhaust flow rate,10.8 kg/h
A4,Transm gear,N
Type 02 - VIN : WVWZZZCD6RW123439 (Address E8)
Type 04 - Calibration ID : 05C032AF3738CEAD (Address E8)
Type 06 - Calibration Verification Number : 314F4C04 (Address E8)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 111
    Ignition cycle count : 1807
         Catalyst monitor bank 1 : 193 / 111
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 191 / 111
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 1170 / 111
         AIR monitor : 0 / 0
         EVAP monitor : 0 / 0
         Secondary O2 Sensor monitor bank 1 : 179 / 111
         Secondary O2 Sensor monitor bank 2 : 0 / 0
         Air Fuel Ratio Imbalance Monitor bank 1 : 0 / 0
         Air Fuel Ratio Imbalance Monitor bank 2 : 0 / 0
         Particulate Filter Monitor bank 1 : 0 / 0
         Particulate Filter Monitor bank 2 : 0 / 0
Type 17 - Vehicle Operation Data - Distance-Fuel Used, Recent/Lifetime:
         Total Distance Traveled : -0.1 km / 18967.5 km
         Total Fuel Consumed : -0.01 L / 1157.29 L
datodaco
Slovenia
C?ID=393757
AutoScan: WVWZZZCD6RW123439
Thursday,03,September,2026,17:50:01:29755
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: WVWZZZCD6RW123439   License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 36 42 44 52 5F 6C 75 A5
          CA D6 D7 8107 811E 811F 8120 8121
VIN: WVWZZZCD6RW123439   Mileage: 18974km-11789miles
CA-Sunroof -- Status: OK 0000
8107-Antenna -- Status: OK 0000
811F-Burglary Protection FR -- Status: Malfunction 0010
Address 01: Engine (2D2D2-DLAA)       Labels: Redir Fail!
   Part No SW: 05C 906 032 AF    HW: 05C 907 394 C
   Component: R3 1.0l TFS   H03 3738
   Revision: 42003001
   Coding: 0119001223640D0830080000000000000000000000000000
   ASAM Dataset: EV_ECM10TFS03005C906032AF 002009
   ROD: EV_ECM10TFS03005C906032AF_002_VW38.rod
   VCID: 6393A9A4FBD2FBA29A2-8036 SFD { }
   VINID: 9E69EAAAA4D41A29C1083103249E05C2F1
43185 - Release / Enable Active
          B184C 00 {00100111} - -
          {Activation active}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:39:15
                    Engine speed: 948.50 /min
                    Normed load value: 28.2 %
                    Coolant temperature: 92 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 14.281 V
                    Ignition timing adjustment cylinder 1: -7.0 Degrees
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.000 counts
                    Primary injection: quantity setpoint: 8.47 mg/stroke
                    Fuel high pressure sensor: actual value: 225.7 bar
                    O2 sen. bank 1 dwnstrm oxi cat: elec. corrected Urie sen. value: 0.705 V
                    IN_Injection_speed: 950.00 /min
                    Camshaft adjustment: exhaust: bank 1: actual value: -0.5 °
                    Camshaft adjustment intake bank 1: actual value: 0.0 °
                    Throttle valve position (absolute): 13.7 %
                    Setpoint generation interior torque: 26.3 Nm
                    Battery voltage: 14.289 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Control Module temperature: 43.5 °C
                    Engine oil temperature: 53.6 °C
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 92143000002272  Dataset Number: V03935397FY 0001 CVN: 83FF7D8B
   Coding: 34FC2C902222446F527B50030ACC61862DB458F542D067C0219CA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
   VCID: 0E45A81040D026CA65C-805A SFD { }
590080 - Release / Enable Active
          {Unlock_protection_of_vehicle_diagnosis_active}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:42:25
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 348 m
                    Voltage_value_KL.30_ESC_V: 14.1 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: completed successfully
                    LWS_comparison: completed successfully
                    Internal_failure_code: 01 AE
                    00 02 40 00 04 0C 10 08 80 00 00 00 7F 00 00 40 30 00 21 00 04
197408 - Front Right Wheel Speed Sensor
          C101B 11 {00101111} - Short to Ground
          {Wh2_dia_asr_short_to_low}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 10:11:30
                    Resolution Mileage: 308 m
                    Voltage_value_KL.30_ESC_V: 12.2 V
                    Internal_failure_code: 02 11
                    00 E0 40 00 04 0C 00 10 80 00 00 00 00 00 00 08 02 00 21 00 04
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 Q    HW: 5WA 959 436 Q
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935341VY 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 629DACA0E4C8F2AA914-8036
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 007 AB    HW: 5WA 907 007 AB
   Component: AC Automat    H30 3623
   Serial number: --------------- Dataset Number: V03935358HE 0001
   Coding: 002000119011000000100010111010010000011000000000000000000000
   ASAM Dataset: EV_ACClimaPREVW38X 001102
   ROD: EV_ACClimaPREVW38X_VW38.rod
   VCID: 074B9D342FAA7782A6A-8052
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002150723122346504
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BM    HW: 5WA 937 086 AT
   Component: BCM37w_M134 0182
   Serial number: BXJ53F290723940 Dataset Number: V03935400FM 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VW38.rod
   VCID: 1D67DF5C9D368D52EC6-8048 SFD { }
   Subsystem 1 - Part No SW: 5H1 955 119 B    HW: 5H1 955 119
   Component: FWISCHER_MYJT  003 0061
   Serial number: 907453F0302320502772
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS            054 0206
   Serial number: S6Y23M08D18H08M30S18
   Subsystem 3 - Part No SW: 5H0 941 193 AK    HW: 5H0 941 193 AK
   Component: LiSi           H06 0008
   Serial number: 92471WGR000GQ
   Subsystem 4 - Part No SW: 5H0 925 200 T    HW: 5H0 925 200 T
   Component: DiETa          H07 0008
   Serial number: 92471WH1000VY
   Subsystem 5 - Part No SW: 5H0 959 561 BQ    HW: 5H0 959 561 BQ
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND04082300010040
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Serial number: 00000024072304220048
15403264 - Release / Enable Active
          B184C 00 {00101111} - -
          {Freischaltung aktiv}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:43:32
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: On
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Voltage: 14.1 V
                    Outside temperature: 30.0 °C
                    Light switch position: automatic
                    Role of vehicle diagnostic to be protected: Basic
                    Type of vehicle diagnostic to be protected: Short: time-controlled
                    Status of vehicle diagnostic to be protected: SFD individualization feature set
                    Duration of vehicle diagnostic to be protected: 89 minutes
   Part No SW: 5R3 919 294     HW: 5R3 919 294
   Component: PDC 08 Kanal  H05 1550
   Serial number: 000995460323206 Dataset Number: V03935375FW 0001
   Coding: 0040010001
   ASAM Dataset: EV_EPHVA18VW3800000 002036
   ROD: EV_EPHVA18VW3800000_VW38.rod
   VCID: 7CA1F2D8666C245ABB8-8028
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H45 0461
   Dataset Number: V03935392FC 0001
   Coding: 010310F5000740451247400800C040C44E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4EC56810805066CA25C-801A
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 L    HW: 5WA 959 655 L
   Component: AirbagVW40    010 0636
   Serial number: 000000003C0J2RA Dataset Number: V03935376EV 0001
   Coding: 88CC008000F0C000000000000000000051540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 6099A6A8EAC4E0BA870-8034 SFD { }
   Subsystem 1 - Part No SW: -----------    HW: 480 052 108 23
   Component: SideSensor_Dr  000 0149
   Serial number: 3510000A6C86458743D9
   Subsystem 2 - Part No SW: -----------    HW: 480 052 208 23
   Component: SideSensor_Pr  000 0149
   Serial number: 3520000BEC8F640FE68.
   Subsystem 3 - Part No SW: -----------    HW: 480 001 907 23
   Serial number: 35700000000BA66DE964
   Subsystem 4 - Part No SW: -----------    HW: 480 001 907 23
   Serial number: 35800000000105458A6C
   Subsystem 5 - Part No SW: -----------    HW: 480 051 908 23
   Component: FrontSensor_D  000 014A
   Serial number: 3550000C8C74C151898E
9980928 - Release / Enable Active
          B184C 00 {00001001} - -
          {ECU unlocked}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:44:23
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 C    HW: 5H0 920 340 C
   Component: KOMBI         310 7380
   Dataset Number: V03935364SX 0001
   Coding: 04A4000063840008018062032000080800300800
   ASAM Dataset: EV_DashBoardVDDMQB37W 003035
   ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
   VCID: 221DECA0A448B2AAD14-8076 SFD { }
16777020 - Control unit for information electronics 1
          U1054 00 {00001000} - No Communication
          {TEL_0x28 communication error bap_error_timeout heartbeat}
                    Reset counter: 119
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:49
16711684 - Release / Enable Active
                    Reset counter: 79
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:44:47
   Part No SW: 5WA 907 530 AB    HW: 5WA 907 530 L
   Component: GW2020 High   778 7105
   Revision: --------    Serial number: 771049110023180 Dataset Number: V03935393AA 0001
   Coding: 0000808D0F00000000000000012303305301600902000300030100000001010000000000000000000000000000000000
   GVL: 3D0000000208409C800080024800104004004000004400000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 08499E0822B478FAAF0-805C SFD { }
   Generator:
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 5311322606
   Subsystem 3 - Part No SW: 3G0 959 442 AF    HW: 3G0 959 442 AF
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440079186230036
   Subsystem 4 - Part No SW: 5H0 959 542 L    HW: 5H0 959 542 L
   Component: KLR_JSS_1Zone  089 0023
   Serial number: 3136188AA23226131503
                    Mileage: 18974 km
                    Date: 2026.09.02
                    Time: 20:53:14
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 C
   Component: EBKV          H09 0372
   Serial number: BPA085260723013 Dataset Number: V03935367RC 0001
   Coding: 1002C140730000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 1079B6685AE4303A770-8044 SFD { }
1024304 - Release / Enable Active
          {SECDIAG_ROLE_UNLOCKED}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:45:32
1024368 - Brake Booster
          C1187 F6 {00101100} - Function Limitation due to External Brake Pressure Build-Up
          {ActiveRestrictionDetected}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 10:11:53
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 23000165506010 Dataset Number: V03935336NF 0001
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323D1CE0F4A8222A214-8066
   Part No SW: 5QS 959 760 H    HW: 5QS 959 760 H
   Component: MEM-FS        011 0372
   Serial number: 24B3001KA00813 Dataset Number: V03935451WL 0001
   Coding: 01589A400000B0508803010101010000000000212100000000000000215000
   VCID: 6597B7BCF5E68592746-8030
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 L    HW: 5Q0 959 593 F
   Component: TSG FS004 0350
   Serial number: YE007WGV16556 Dataset Number: V03935387Z  0001
   Coding: 003B13208200040008001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
   VCID: 4ACD64007C384AEA794-801E
   Subsystem 1 - Part No SW: 5Q0 959 408 G    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000073597272
   Coding: 110000
   Part No SW: 5WA 907 145 G    HW: 5WA 907 145 C
   Component: BASGEN1MQB37  502 1040
   Serial number: 03070569 Dataset Number: V03935358SR 0001
   Coding: 0000000000000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   Part No SW: 5Q0 959 592 L    HW: 5Q0 959 592 F
   Component: TSG BFS004 0350
   Serial number: YE007WH20786A Dataset Number: V03935386XH 0001
   Coding: 003B11208E00040000801000
   ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
   VCID: 49CF5B0C793E41F270E-801C
   Subsystem 1 - Part No SW: 5Q0 959 407 G    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000073352136
   Coding: 090000
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5H0 035 820 P    HW: 5H0 035 820
   Component: MU-O-ND-EU    H61 1989
   Serial number: WG8LGM190823000 Dataset Number: V03935431DH 0001
   Coding: 23800000000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VW38.rod
   VCID: 2F3B1594E79A0FC24EA-807A SFD { }
   Subsystem 1 - Part No SW: 5H0 919 605 B    HW: 5H0 919 605 B
   Component: ABT_W_10       H44 3080
   Serial number: VDD02411082312210379
   Subsystem 2 - Part No SW: V03 959 820 GB    HW: -----------
   Component: EUR 2023/24    --- 9085
4112 - Release / Enable Active
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:47:18
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20200723010 Dataset Number: V03935359FC 0001
   Coding: 02030004E43000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52FD7C609468022A014-8006
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0144
   Serial number: 0000000305VICLG Dataset Number: V03935447ZH 0001
   Coding: 023800109068AC209405460071002E07
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 49CF5B0C793E41F270E-801C SFD { }
1592320 - Release / Enable Active
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:47:49
                    Voltage terminal 30: 12.7 V
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H12 3405
   Serial number: EB7590904232010 Dataset Number: V03935412E  0001
   Coding: 00000888114C4040109E00001020002000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VW38.rod
   VCID: 50F976689A64703A370-8004
   Part No SW: 4K1 907 594 CB    HW: 4K1 907 594
   Component: SAD_STG_1     006 0040
   Dataset Number: V03935402SS 0001
   Coding: 408000738001
   VCID: 77ABEDF45F4A0702D6A-8022
   Part No SW: 992 941 571 AH    HW: 992 941 571 A
   Component: LED1L         H25 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6889BE8802F498FA4F0-803C
   Component: LED1R         H25 9204
   Dataset Number: V03935402VJ 0001
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 5WA 035 741 B    HW: 5WA 035 741 B
   Component: TrxModulHigh  H10 0083
   Serial number: 0000000303VIZC5 Dataset Number: V03935364CE 0001
   Coding: 02380011440080
   ASAM Dataset: EV_TrxMLGEMQB37W 005006
   ROD: EV_TrxMLGEMQB37W.rod
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 F    HW: 5WA 962 133 F
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
10487042 - Control Module not Adapted
          B2019 00 {00001001} - -
          {Ecu_not_learned}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:46
1081345 - VKMS
          B18B0 F0 {00001001} - Missing Adaptation
          {VKMS_new_download_container_required_due_to_vehicle_change}
                    Mileage: 18974 km
                    Date: 2026.09.03
                    Time: 17:37:46
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
End----------(Elapsed Time: 01:34, VBatt start/end: 12.9V/12.9V)-----------
------------------------------14 Faults Found------------------------------
adpmap-01-05C-906-032-AF_WVWZZZCD6RW123439-20260903-1756.CSV
;SW:05C-906-032-AF   HW:05C-907-394-C ---  01: Engine
;Component:R3 1.0l TFS   H03 3738, Coding:0119001223640D0830080000000000000000000000000000
;EV_ECM10TFS03005C906032AF,002009,EV_ECM10TFS03005C906032AF_002_VW38.rod
;Thursday,03,September,2026,17:56:15:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 6393A9A4FBD2FBA29A2-8036 SFD { }
IDE04158-Activation of start/stop function,active ,1
IDE05120-Turbocharger offset correction,04 E2 FB 1E ,4
IDE07903-Adaptation of ash mass,0.36 g,2
IDE12045-MAS13895-Adaptation of correction angle position detection bank 1 intake-Error angle sensor,17.19 °,4
IDE12045-MAS13896-Adaptation of correction angle position detection bank 1 intake-Error angle sensor wheel,0.78 °,4
IDE12048-MAS13895-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor,-104.69 °,4
IDE12048-MAS13896-Adaptation of correction angle position detection bank 1 outlet-Error angle sensor wheel,11.72 °,4
IDE12080-MAS13895-Adaptation of correction angle of crankshaft position detection-Error angle sensor,-13.28 °,4
IDE12080-MAS13896-Adaptation of correction angle of crankshaft position detection-Error angle sensor wheel,0.00 °,4
IDE12081-MAS13897-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 1,2.34 °,32
IDE12081-MAS13898-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 2,18.75 °,32
IDE12081-MAS13899-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 3,4.69 °,32
IDE12081-MAS13900-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 4,0.00 °,32
IDE12081-MAS13901-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 5,0.00 °,32
IDE12081-MAS13902-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 6,0.00 °,32
IDE12081-MAS13903-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 7,0.00 °,32
IDE12081-MAS13904-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction inlet cylinder 8,0.00 °,32
IDE12081-MAS13905-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 1,-10.94 °,32
IDE12081-MAS13906-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 2,25.78 °,32
IDE12081-MAS13907-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 3,-3.13 °,32
IDE12081-MAS13908-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 4,0.00 °,32
IDE12081-MAS13909-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 5,0.00 °,32
IDE12081-MAS13910-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 6,0.00 °,32
IDE12081-MAS13911-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 7,0.00 °,32
IDE12081-MAS13912-Adaptation of individual cylinder correction angles camshafts cylinder bank 1-Correction outlet cylinder 8,0.00 °,32
IDE12846-Selection of the start system,Automatic status selection ,1
IDE15794-ENG264196-Radiator shutter: target value-Setpoint radiator shutter 1,0 %,4
IDE15794-ENG264197-Radiator shutter: target value-Setpoint radiator shutter 1 - no reaction,no reaction ,4
IDE15794-ENG264198-Radiator shutter: target value-Setpoint radiator shutter 2,0 %,4
IDE15794-ENG264199-Radiator shutter: target value-Setpoint radiator shutter 2 - no reaction,no reaction ,4
IDE15794-ENG264200-Radiator shutter: target value-Setpoint radiator shutter 3,0 %,4
IDE15794-ENG264201-Radiator shutter: target value-Setpoint radiator shutter 3 - no reaction,no reaction ,4
IDE15794-ENG264202-Radiator shutter: target value-Setpoint radiator shutter 4,0 %,4
IDE15794-ENG264203-Radiator shutter: target value-Setpoint radiator shutter 4 - no reaction,no reaction ,4
Elapsed Time: 00:03
adpmap-03-5WA-614-517-CF_WVWZZZCD6RW123439-20260903-1756.CSV
;SW:5WA-614-517-CF   HW:5WA-614-517-N ---  03: ABS Brakes
;Component:ESC           H13 0135, Coding:34FC2C902222446F527B50030ACC61862DB458F542D067C0219CA231018FF100002814
;EV_Brake1ESCEPBMQB37W,013058,EV_Brake1ESCEPBMQB37W_013_VW38.rod
;Thursday,03,September,2026,17:56:42:29755
;VCID: 0E45A81040D026CA65C-805A SFD { }
IDE00820-ENG264053-Activating and deactivating all development messages-Activation of Development Message EPB00,not activated ,3
IDE00820-ENG264054-Activating and deactivating all development messages-Activation of Development Message EPB01,not activated ,3
IDE00820-ENG264055-Activating and deactivating all development messages-Activation of Development Message EPB02,not activated ,3
IDE00820-ENG264056-Activating and deactivating all development messages-Activation of Development Message ESC00,not activated ,3
IDE00820-ENG264057-Activating and deactivating all development messages-Activation of Development Message ESC01,not activated ,3
IDE00820-ENG264058-Activating and deactivating all development messages-Activation of Development Message ESC02,not activated ,3
IDE00820-ENG264059-Activating and deactivating all development messages-Activation of Development Message ESC03,not activated ,3
IDE00820-ENG264060-Activating and deactivating all development messages-Activation of Development Message ESC04,not activated ,3
IDE00820-ENG264061-Activating and deactivating all development messages-Activation of Development Message ESC05,not activated ,3
IDE00820-ENG264062-Activating and deactivating all development messages-Activation of Development Message ESC06,not activated ,3
IDE00820-ENG264063-Activating and deactivating all development messages-Activation of Development Message ESC07,not activated ,3
IDE00820-ENG264064-Activating and deactivating all development messages-Activation of Development Message ESC08,not activated ,3
IDE00820-ENG264065-Activating and deactivating all development messages-Activation of Development Message ESC10,not activated ,3
IDE00820-ENG264066-Activating and deactivating all development messages-Activation of Development Message FDR01,not activated ,3
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04765-Counter steer support,Strong ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE07292-Brake pre-filling,ended ,1
IDE07565-ABS in lower speed range,activated ,1
IDE11985-Expected OBD requirements,EOBD ,1
IDE12030-Rough road optimization,activated ,1
IDE14225-IDE07280-Delay and hold management-Multiple collision brake,activated ,2
IDE14225-MAS00919-Delay and hold management-Pedestrian protection,not activated ,2
IDE14225-MAS05087-Delay and hold management-ACC,activated ,2
IDE14225-MAS05506-Delay and hold management-Stopping distance reduction,activated ,2
IDE14225-MAS10858-Delay and hold management-Rear camera,not activated ,2
IDE14225-MAS12321-Delay and hold management-Trailer maneuvering system,not activated ,2
IDE14225-MAS15696-Delay and hold management-Rear cross traffic assistant,not activated ,2
IDE14225-MAS15806-Delay and hold management-Parking assist,activated ,2
IDE14225-MAS18082-Delay and hold management-Emergency assistant,activated ,2
IDE14226-Electronic engine braking torque reduction,activated ,1
IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,525.0 kg,4
IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,767.0 kg,4
MAS03691-Dimming,activated ,1
MAS09595-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
MAS09595-IDE02939-Production mode-Activate/lock control,Deactivating ,3
MAS09595-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
MAS09595-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
MAS09595-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
MAS09595-Production mode-,not active ,3
MAS14035-Precondition,0 ,3
MAS16144-Wheel loose detection: warning threshold,normal ,1
ENG264022-Developer_Function_01,00 00 ,2
ENG264037-Developer_Function_02,Security access required,2
ENG264035-ENG264163-Developer_Function_03-Developer_Function_03_Bremsdrucksensor,Security access required,2
ENG264035-ENG264164-Developer_Function_03-Developer_Function_03_PYA,Security access required,2
ENG264021-Developer_Function_10,Security access required,2
ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,0.04 s,20
ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,20
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,20
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,20
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,20
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,20
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,20
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,20
ENG122844-ENG99777-dimming_characteristic_1-Y1,2.0 %,20
ENG122844-ENG100480-dimming_characteristic_1-Y2,2.0 %,20
ENG122844-ENG100773-dimming_characteristic_1-Y3,5.0 %,20
ENG122844-ENG100631-dimming_characteristic_1-Y4,10.0 %,20
ENG122844-ENG102174-dimming_characteristic_1-Y5,80.0 %,20
ENG122844-ENG113993-dimming_characteristic_1-Y6,100.0 %,20
ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,0.04 s,20
ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,20
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,20
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,20
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,20
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,20
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,20
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,20
ENG122845-ENG99777-dimming_characteristic_2-Y1,2.0 %,20
ENG122845-ENG100480-dimming_characteristic_2-Y2,2.0 %,20
ENG122845-ENG100773-dimming_characteristic_2-Y3,5.0 %,20
ENG122845-ENG100631-dimming_characteristic_2-Y4,10.0 %,20
ENG122845-ENG102174-dimming_characteristic_2-Y5,80.0 %,20
ENG122845-ENG113993-dimming_characteristic_2-Y6,100.0 %,20
ENG264029-ENG264073-Dynamic_Developer_Function_01-ASAP_Address_0,00 00 00 00 ,182
ENG264029-ENG264074-Dynamic_Developer_Function_01-ASAP_Address_1,00 00 00 00 ,182
ENG264029-ENG264075-Dynamic_Developer_Function_01-ASAP_Address_10,00 00 00 00 ,182
ENG264029-ENG264076-Dynamic_Developer_Function_01-ASAP_Address_100,00 00 00 00 ,182
ENG264029-ENG264077-Dynamic_Developer_Function_01-ASAP_Address_11,00 00 00 00 ,182
ENG264029-ENG264078-Dynamic_Developer_Function_01-ASAP_Address_12,00 00 00 00 ,182
ENG264029-ENG264079-Dynamic_Developer_Function_01-ASAP_Address_13,00 00 00 00 ,182
ENG264029-ENG264080-Dynamic_Developer_Function_01-ASAP_Address_14,00 00 00 00 ,182
ENG264029-ENG264081-Dynamic_Developer_Function_01-ASAP_Address_15,00 00 00 00 ,182
ENG264029-ENG264082-Dynamic_Developer_Function_01-ASAP_Address_2,00 00 00 00 ,182
ENG264029-ENG264083-Dynamic_Developer_Function_01-ASAP_Address_3,00 00 00 00 ,182
ENG264029-ENG264084-Dynamic_Developer_Function_01-ASAP_Address_4,00 00 00 00 ,182
ENG264029-ENG264085-Dynamic_Developer_Function_01-ASAP_Address_5,00 00 00 00 ,182
ENG264029-ENG264086-Dynamic_Developer_Function_01-ASAP_Address_6,00 00 00 00 ,182
ENG264029-ENG264087-Dynamic_Developer_Function_01-ASAP_Address_7,00 00 00 00 ,182
ENG264029-ENG264088-Dynamic_Developer_Function_01-ASAP_Address_8,00 00 00 00 ,182
ENG264029-ENG264089-Dynamic_Developer_Function_01-ASAP_Address_81,00 00 00 00 ,182
ENG264029-ENG264090-Dynamic_Developer_Function_01-ASAP_Address_82,00 00 00 00 ,182
ENG264029-ENG264091-Dynamic_Developer_Function_01-ASAP_Address_83,00 00 00 00 ,182
ENG264029-ENG264092-Dynamic_Developer_Function_01-ASAP_Address_84,00 00 00 00 ,182
ENG264029-ENG264093-Dynamic_Developer_Function_01-ASAP_Address_85,00 00 00 00 ,182
ENG264029-ENG264094-Dynamic_Developer_Function_01-ASAP_Address_86,00 00 00 00 ,182
ENG264029-ENG264095-Dynamic_Developer_Function_01-ASAP_Address_87,00 00 00 00 ,182
ENG264029-ENG264096-Dynamic_Developer_Function_01-ASAP_Address_88,00 00 00 00 ,182
ENG264029-ENG264097-Dynamic_Developer_Function_01-ASAP_Address_89,00 00 00 00 ,182
ENG264029-ENG264098-Dynamic_Developer_Function_01-ASAP_Address_9,00 00 00 00 ,182
ENG264029-ENG264099-Dynamic_Developer_Function_01-ASAP_Address_90,00 00 00 00 ,182
ENG264029-ENG264100-Dynamic_Developer_Function_01-ASAP_Address_91,00 00 00 00 ,182
ENG264029-ENG264101-Dynamic_Developer_Function_01-ASAP_Address_92,00 00 00 00 ,182
ENG264029-ENG264102-Dynamic_Developer_Function_01-ASAP_Address_93,00 00 00 00 ,182
ENG264029-ENG264103-Dynamic_Developer_Function_01-ASAP_Address_94,00 00 00 00 ,182
ENG264029-ENG264104-Dynamic_Developer_Function_01-ASAP_Address_95,00 00 00 00 ,182
ENG264029-ENG264105-Dynamic_Developer_Function_01-ASAP_Address_96,00 00 00 00 ,182
ENG264029-ENG264106-Dynamic_Developer_Function_01-ASAP_Address_97,00 00 00 00 ,182
ENG264029-ENG264107-Dynamic_Developer_Function_01-ASAP_Address_98,00 00 00 00 ,182
ENG264029-ENG264108-Dynamic_Developer_Function_01-ASAP_Address_99,00 00 00 00 ,182
ENG264029-ENG264109-Dynamic_Developer_Function_01-ASAP_Data_Type_100,undefined ,182
ENG264029-ENG264110-Dynamic_Developer_Function_01-ASAP_Data_Type_81,undefined ,182
ENG264029-ENG264111-Dynamic_Developer_Function_01-ASAP_Data_Type_82,undefined ,182
ENG264029-ENG264112-Dynamic_Developer_Function_01-ASAP_Data_Type_83,undefined ,182
ENG264029-ENG264113-Dynamic_Developer_Function_01-ASAP_Data_Type_84,undefined ,182
ENG264029-ENG264114-Dynamic_Developer_Function_01-ASAP_Data_Type_85,undefined ,182
ENG264029-ENG264115-Dynamic_Developer_Function_01-ASAP_Data_Type_86,undefined ,182
ENG264029-ENG264116-Dynamic_Developer_Function_01-ASAP_Data_Type_87,undefined ,182
ENG264029-ENG264117-Dynamic_Developer_Function_01-ASAP_Data_Type_88,undefined ,182
ENG264029-ENG264118-Dynamic_Developer_Function_01-ASAP_Data_Type_89,undefined ,182
ENG264029-ENG264119-Dynamic_Developer_Function_01-ASAP_Data_Type_90,undefined ,182
ENG264029-ENG264120-Dynamic_Developer_Function_01-ASAP_Data_Type_91,undefined ,182
ENG264029-ENG264121-Dynamic_Developer_Function_01-ASAP_Data_Type_92,undefined ,182
ENG264029-ENG264122-Dynamic_Developer_Function_01-ASAP_Data_Type_93,undefined ,182
ENG264029-ENG264123-Dynamic_Developer_Function_01-ASAP_Data_Type_94,undefined ,182
ENG264029-ENG264124-Dynamic_Developer_Function_01-ASAP_Data_Type_95,undefined ,182
ENG264029-ENG264125-Dynamic_Developer_Function_01-ASAP_Data_Type_96,undefined ,182
ENG264029-ENG264126-Dynamic_Developer_Function_01-ASAP_Data_Type_97,undefined ,182
ENG264029-ENG264127-Dynamic_Developer_Function_01-ASAP_Data_Type_98,undefined ,182
ENG264029-ENG264128-Dynamic_Developer_Function_01-ASAP_Data_Type_99,undefined ,182
ENG264029-ENG264131-Dynamic_Developer_Function_01-Data_position_0_Bit_position,0 ,182
ENG264029-ENG264132-Dynamic_Developer_Function_01-Data_position_0_Byte_position,0 ,182
ENG264029-ENG264133-Dynamic_Developer_Function_01-Data_position_1_Bit_position,0 ,182
ENG264029-ENG264134-Dynamic_Developer_Function_01-Data_position_1_Byte_position,0 ,182
ENG264029-ENG264135-Dynamic_Developer_Function_01-Data_position_10_Bit_position,0 ,182
ENG264029-ENG264136-Dynamic_Developer_Function_01-Data_position_10_Byte_position,0 ,182
ENG264029-ENG264137-Dynamic_Developer_Function_01-Data_position_11_Bit_position,0 ,182
ENG264029-ENG264138-Dynamic_Developer_Function_01-Data_position_11_Byte_position,0 ,182
ENG264029-ENG264139-Dynamic_Developer_Function_01-Data_position_12_Bit_position,0 ,182
ENG264029-ENG264140-Dynamic_Developer_Function_01-Data_position_12_Byte_position,0 ,182
ENG264029-ENG264141-Dynamic_Developer_Function_01-Data_position_13_Bit_position,0 ,182
ENG264029-ENG264142-Dynamic_Developer_Function_01-Data_position_13_Byte_position,0 ,182
ENG264029-ENG264143-Dynamic_Developer_Function_01-Data_position_14_Bit_position,0 ,182
ENG264029-ENG264144-Dynamic_Developer_Function_01-Data_position_14_Byte_position,0 ,182
ENG264029-ENG264145-Dynamic_Developer_Function_01-Data_position_15_Bit_position,0 ,182
ENG264029-ENG264146-Dynamic_Developer_Function_01-Data_position_15_Byte_position,0 ,182
ENG264029-ENG264147-Dynamic_Developer_Function_01-Data_position_2_Bit_position,0 ,182
ENG264029-ENG264148-Dynamic_Developer_Function_01-Data_position_2_Byte_position,0 ,182
ENG264029-ENG264149-Dynamic_Developer_Function_01-Data_position_3_Bit_position,0 ,182
ENG264029-ENG264150-Dynamic_Developer_Function_01-Data_position_3_Byte_position,0 ,182
ENG264029-ENG264151-Dynamic_Developer_Function_01-Data_position_4_Bit_position,0 ,182
ENG264029-ENG264152-Dynamic_Developer_Function_01-Data_position_4_Byte_position,0 ,182
ENG264029-ENG264153-Dynamic_Developer_Function_01-Data_position_5_Bit_position,0 ,182
ENG264029-ENG264154-Dynamic_Developer_Function_01-Data_position_5_Byte_position,0 ,182
ENG264029-ENG264155-Dynamic_Developer_Function_01-Data_position_6_Bit_position,0 ,182
ENG264029-ENG264156-Dynamic_Developer_Function_01-Data_position_6_Byte_position,0 ,182
ENG264029-ENG264157-Dynamic_Developer_Function_01-Data_position_7_Bit_position,0 ,182
ENG264029-ENG264158-Dynamic_Developer_Function_01-Data_position_7_Byte_position,0 ,182
ENG264029-ENG264159-Dynamic_Developer_Function_01-Data_position_8_Bit_position,0 ,182
ENG264029-ENG264160-Dynamic_Developer_Function_01-Data_position_8_Byte_position,0 ,182
ENG264029-ENG264161-Dynamic_Developer_Function_01-Data_position_9_Bit_position,0 ,182
ENG264029-ENG264162-Dynamic_Developer_Function_01-Data_position_9_Byte_position,0 ,182
ENG264029-ENG264166-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_1,1 ,182
ENG264029-ENG264167-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_2,2 ,182
ENG264027-ENG264073-Dynamic_Developer_Function_02-ASAP_Address_0,00 00 00 00 ,182
ENG264027-ENG264074-Dynamic_Developer_Function_02-ASAP_Address_1,00 00 00 00 ,182
ENG264027-ENG264075-Dynamic_Developer_Function_02-ASAP_Address_10,00 00 00 00 ,182
ENG264027-ENG264076-Dynamic_Developer_Function_02-ASAP_Address_100,00 00 00 00 ,182
ENG264027-ENG264077-Dynamic_Developer_Function_02-ASAP_Address_11,00 00 00 00 ,182
ENG264027-ENG264078-Dynamic_Developer_Function_02-ASAP_Address_12,00 00 00 00 ,182
ENG264027-ENG264079-Dynamic_Developer_Function_02-ASAP_Address_13,00 00 00 00 ,182
ENG264027-ENG264080-Dynamic_Developer_Function_02-ASAP_Address_14,00 00 00 00 ,182
ENG264027-ENG264081-Dynamic_Developer_Function_02-ASAP_Address_15,00 00 00 00 ,182
ENG264027-ENG264082-Dynamic_Developer_Function_02-ASAP_Address_2,00 00 00 00 ,182
ENG264027-ENG264083-Dynamic_Developer_Function_02-ASAP_Address_3,00 00 00 00 ,182
ENG264027-ENG264084-Dynamic_Developer_Function_02-ASAP_Address_4,00 00 00 00 ,182
ENG264027-ENG264085-Dynamic_Developer_Function_02-ASAP_Address_5,00 00 00 00 ,182
ENG264027-ENG264086-Dynamic_Developer_Function_02-ASAP_Address_6,00 00 00 00 ,182
ENG264027-ENG264087-Dynamic_Developer_Function_02-ASAP_Address_7,00 00 00 00 ,182
ENG264027-ENG264088-Dynamic_Developer_Function_02-ASAP_Address_8,00 00 00 00 ,182
ENG264027-ENG264089-Dynamic_Developer_Function_02-ASAP_Address_81,00 00 00 00 ,182
ENG264027-ENG264090-Dynamic_Developer_Function_02-ASAP_Address_82,00 00 00 00 ,182
ENG264027-ENG264091-Dynamic_Developer_Function_02-ASAP_Address_83,00 00 00 00 ,182
ENG264027-ENG264092-Dynamic_Developer_Function_02-ASAP_Address_84,00 00 00 00 ,182
ENG264027-ENG264093-Dynamic_Developer_Function_02-ASAP_Address_85,00 00 00 00 ,182
ENG264027-ENG264094-Dynamic_Developer_Function_02-ASAP_Address_86,00 00 00 00 ,182
ENG264027-ENG264095-Dynamic_Developer_Function_02-ASAP_Address_87,00 00 00 00 ,182
ENG264027-ENG264096-Dynamic_Developer_Function_02-ASAP_Address_88,00 00 00 00 ,182
ENG264027-ENG264097-Dynamic_Developer_Function_02-ASAP_Address_89,00 00 00 00 ,182
ENG264027-ENG264098-Dynamic_Developer_Function_02-ASAP_Address_9,00 00 00 00 ,182
ENG264027-ENG264099-Dynamic_Developer_Function_02-ASAP_Address_90,00 00 00 00 ,182
ENG264027-ENG264100-Dynamic_Developer_Function_02-ASAP_Address_91,00 00 00 00 ,182
ENG264027-ENG264101-Dynamic_Developer_Function_02-ASAP_Address_92,00 00 00 00 ,182
ENG264027-ENG264102-Dynamic_Developer_Function_02-ASAP_Address_93,00 00 00 00 ,182
ENG264027-ENG264103-Dynamic_Developer_Function_02-ASAP_Address_94,00 00 00 00 ,182
ENG264027-ENG264104-Dynamic_Developer_Function_02-ASAP_Address_95,00 00 00 00 ,182
ENG264027-ENG264105-Dynamic_Developer_Function_02-ASAP_Address_96,00 00 00 00 ,182
ENG264027-ENG264106-Dynamic_Developer_Function_02-ASAP_Address_97,00 00 00 00 ,182
ENG264027-ENG264107-Dynamic_Developer_Function_02-ASAP_Address_98,00 00 00 00 ,182
ENG264027-ENG264108-Dynamic_Developer_Function_02-ASAP_Address_99,00 00 00 00 ,182
ENG264027-ENG264109-Dynamic_Developer_Function_02-ASAP_Data_Type_100,undefined ,182
ENG264027-ENG264110-Dynamic_Developer_Function_02-ASAP_Data_Type_81,undefined ,182
ENG264027-ENG264111-Dynamic_Developer_Function_02-ASAP_Data_Type_82,undefined ,182
ENG264027-ENG264112-Dynamic_Developer_Function_02-ASAP_Data_Type_83,undefined ,182
ENG264027-ENG264113-Dynamic_Developer_Function_02-ASAP_Data_Type_84,undefined ,182
ENG264027-ENG264114-Dynamic_Developer_Function_02-ASAP_Data_Type_85,undefined ,182
ENG264027-ENG264115-Dynamic_Developer_Function_02-ASAP_Data_Type_86,undefined ,182
ENG264027-ENG264116-Dynamic_Developer_Function_02-ASAP_Data_Type_87,undefined ,182
ENG264027-ENG264117-Dynamic_Developer_Function_02-ASAP_Data_Type_88,undefined ,182
ENG264027-ENG264118-Dynamic_Developer_Function_02-ASAP_Data_Type_89,undefined ,182
ENG264027-ENG264119-Dynamic_Developer_Function_02-ASAP_Data_Type_90,undefined ,182
ENG264027-ENG264120-Dynamic_Developer_Function_02-ASAP_Data_Type_91,undefined ,182
ENG264027-ENG264121-Dynamic_Developer_Function_02-ASAP_Data_Type_92,undefined ,182
ENG264027-ENG264122-Dynamic_Developer_Function_02-ASAP_Data_Type_93,undefined ,182
ENG264027-ENG264123-Dynamic_Developer_Function_02-ASAP_Data_Type_94,undefined ,182
ENG264027-ENG264124-Dynamic_Developer_Function_02-ASAP_Data_Type_95,undefined ,182
ENG264027-ENG264125-Dynamic_Developer_Function_02-ASAP_Data_Type_96,undefined ,182
ENG264027-ENG264126-Dynamic_Developer_Function_02-ASAP_Data_Type_97,undefined ,182
ENG264027-ENG264127-Dynamic_Developer_Function_02-ASAP_Data_Type_98,undefined ,182
ENG264027-ENG264128-Dynamic_Developer_Function_02-ASAP_Data_Type_99,undefined ,182
ENG264027-ENG264131-Dynamic_Developer_Function_02-Data_position_0_Bit_position,0 ,182
ENG264027-ENG264132-Dynamic_Developer_Function_02-Data_position_0_Byte_position,0 ,182
ENG264027-ENG264133-Dynamic_Developer_Function_02-Data_position_1_Bit_position,0 ,182
ENG264027-ENG264134-Dynamic_Developer_Function_02-Data_position_1_Byte_position,0 ,182
ENG264027-ENG264135-Dynamic_Developer_Function_02-Data_position_10_Bit_position,0 ,182
ENG264027-ENG264136-Dynamic_Developer_Function_02-Data_position_10_Byte_position,0 ,182
ENG264027-ENG264137-Dynamic_Developer_Function_02-Data_position_11_Bit_position,0 ,182
ENG264027-ENG264138-Dynamic_Developer_Function_02-Data_position_11_Byte_position,0 ,182
ENG264027-ENG264139-Dynamic_Developer_Function_02-Data_position_12_Bit_position,0 ,182
ENG264027-ENG264140-Dynamic_Developer_Function_02-Data_position_12_Byte_position,0 ,182
ENG264027-ENG264141-Dynamic_Developer_Function_02-Data_position_13_Bit_position,0 ,182
ENG264027-ENG264142-Dynamic_Developer_Function_02-Data_position_13_Byte_position,0 ,182
ENG264027-ENG264143-Dynamic_Developer_Function_02-Data_position_14_Bit_position,0 ,182
ENG264027-ENG264144-Dynamic_Developer_Function_02-Data_position_14_Byte_position,0 ,182
ENG264027-ENG264145-Dynamic_Developer_Function_02-Data_position_15_Bit_position,0 ,182
ENG264027-ENG264146-Dynamic_Developer_Function_02-Data_position_15_Byte_position,0 ,182
ENG264027-ENG264147-Dynamic_Developer_Function_02-Data_position_2_Bit_position,0 ,182
ENG264027-ENG264148-Dynamic_Developer_Function_02-Data_position_2_Byte_position,0 ,182
ENG264027-ENG264149-Dynamic_Developer_Function_02-Data_position_3_Bit_position,0 ,182
ENG264027-ENG264150-Dynamic_Developer_Function_02-Data_position_3_Byte_position,0 ,182
ENG264027-ENG264151-Dynamic_Developer_Function_02-Data_position_4_Bit_position,0 ,182
ENG264027-ENG264152-Dynamic_Developer_Function_02-Data_position_4_Byte_position,0 ,182
ENG264027-ENG264153-Dynamic_Developer_Function_02-Data_position_5_Bit_position,0 ,182
ENG264027-ENG264154-Dynamic_Developer_Function_02-Data_position_5_Byte_position,0 ,182
ENG264027-ENG264155-Dynamic_Developer_Function_02-Data_position_6_Bit_position,0 ,182
ENG264027-ENG264156-Dynamic_Developer_Function_02-Data_position_6_Byte_position,0 ,182
ENG264027-ENG264157-Dynamic_Developer_Function_02-Data_position_7_Bit_position,0 ,182
ENG264027-ENG264158-Dynamic_Developer_Function_02-Data_position_7_Byte_position,0 ,182
ENG264027-ENG264159-Dynamic_Developer_Function_02-Data_position_8_Bit_position,0 ,182
ENG264027-ENG264160-Dynamic_Developer_Function_02-Data_position_8_Byte_position,0 ,182
ENG264027-ENG264161-Dynamic_Developer_Function_02-Data_position_9_Bit_position,0 ,182
ENG264027-ENG264162-Dynamic_Developer_Function_02-Data_position_9_Byte_position,0 ,182
ENG264027-ENG264166-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_1,1 ,182
ENG264027-ENG264167-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_2,2 ,182
ENG264028-ENG264073-Dynamic_Developer_Function_03-ASAP_Address_0,Security access required,182
ENG264028-ENG264074-Dynamic_Developer_Function_03-ASAP_Address_1,Security access required,182
ENG264028-ENG264075-Dynamic_Developer_Function_03-ASAP_Address_10,Security access required,182
ENG264028-ENG264076-Dynamic_Developer_Function_03-ASAP_Address_100,Security access required,182
ENG264028-ENG264077-Dynamic_Developer_Function_03-ASAP_Address_11,Security access required,182
ENG264028-ENG264078-Dynamic_Developer_Function_03-ASAP_Address_12,Security access required,182
ENG264028-ENG264079-Dynamic_Developer_Function_03-ASAP_Address_13,Security access required,182
ENG264028-ENG264080-Dynamic_Developer_Function_03-ASAP_Address_14,Security access required,182
ENG264028-ENG264081-Dynamic_Developer_Function_03-ASAP_Address_15,Security access required,182
ENG264028-ENG264082-Dynamic_Developer_Function_03-ASAP_Address_2,Security access required,182
ENG264028-ENG264083-Dynamic_Developer_Function_03-ASAP_Address_3,Security access required,182
ENG264028-ENG264084-Dynamic_Developer_Function_03-ASAP_Address_4,Security access required,182
ENG264028-ENG264085-Dynamic_Developer_Function_03-ASAP_Address_5,Security access required,182
ENG264028-ENG264086-Dynamic_Developer_Function_03-ASAP_Address_6,Security access required,182
ENG264028-ENG264087-Dynamic_Developer_Function_03-ASAP_Address_7,Security access required,182
ENG264028-ENG264088-Dynamic_Developer_Function_03-ASAP_Address_8,Security access required,182
ENG264028-ENG264089-Dynamic_Developer_Function_03-ASAP_Address_81,Security access required,182
ENG264028-ENG264090-Dynamic_Developer_Function_03-ASAP_Address_82,Security access required,182
ENG264028-ENG264091-Dynamic_Developer_Function_03-ASAP_Address_83,Security access required,182
ENG264028-ENG264092-Dynamic_Developer_Function_03-ASAP_Address_84,Security access required,182
ENG264028-ENG264093-Dynamic_Developer_Function_03-ASAP_Address_85,Security access required,182
ENG264028-ENG264094-Dynamic_Developer_Function_03-ASAP_Address_86,Security access required,182
ENG264028-ENG264095-Dynamic_Developer_Function_03-ASAP_Address_87,Security access required,182
ENG264028-ENG264096-Dynamic_Developer_Function_03-ASAP_Address_88,Security access required,182
ENG264028-ENG264097-Dynamic_Developer_Function_03-ASAP_Address_89,Security access required,182
ENG264028-ENG264098-Dynamic_Developer_Function_03-ASAP_Address_9,Security access required,182
ENG264028-ENG264099-Dynamic_Developer_Function_03-ASAP_Address_90,Security access required,182
ENG264028-ENG264100-Dynamic_Developer_Function_03-ASAP_Address_91,Security access required,182
ENG264028-ENG264101-Dynamic_Developer_Function_03-ASAP_Address_92,Security access required,182
ENG264028-ENG264102-Dynamic_Developer_Function_03-ASAP_Address_93,Security access required,182
ENG264028-ENG264103-Dynamic_Developer_Function_03-ASAP_Address_94,Security access required,182
ENG264028-ENG264104-Dynamic_Developer_Function_03-ASAP_Address_95,Security access required,182
ENG264028-ENG264105-Dynamic_Developer_Function_03-ASAP_Address_96,Security access required,182
ENG264028-ENG264106-Dynamic_Developer_Function_03-ASAP_Address_97,Security access required,182
ENG264028-ENG264107-Dynamic_Developer_Function_03-ASAP_Address_98,Security access required,182
ENG264028-ENG264108-Dynamic_Developer_Function_03-ASAP_Address_99,Security access required,182
ENG264028-ENG264109-Dynamic_Developer_Function_03-ASAP_Data_Type_100,Security access required,182
ENG264028-ENG264110-Dynamic_Developer_Function_03-ASAP_Data_Type_81,Security access required,182
ENG264028-ENG264111-Dynamic_Developer_Function_03-ASAP_Data_Type_82,Security access required,182
ENG264028-ENG264112-Dynamic_Developer_Function_03-ASAP_Data_Type_83,Security access required,182
ENG264028-ENG264113-Dynamic_Developer_Function_03-ASAP_Data_Type_84,Security access required,182
ENG264028-ENG264114-Dynamic_Developer_Function_03-ASAP_Data_Type_85,Security access required,182
ENG264028-ENG264115-Dynamic_Developer_Function_03-ASAP_Data_Type_86,Security access required,182
ENG264028-ENG264116-Dynamic_Developer_Function_03-ASAP_Data_Type_87,Security access required,182
ENG264028-ENG264117-Dynamic_Developer_Function_03-ASAP_Data_Type_88,Security access required,182
ENG264028-ENG264118-Dynamic_Developer_Function_03-ASAP_Data_Type_89,Security access required,182
ENG264028-ENG264119-Dynamic_Developer_Function_03-ASAP_Data_Type_90,Security access required,182
ENG264028-ENG264120-Dynamic_Developer_Function_03-ASAP_Data_Type_91,Security access required,182
ENG264028-ENG264121-Dynamic_Developer_Function_03-ASAP_Data_Type_92,Security access required,182
ENG264028-ENG264122-Dynamic_Developer_Function_03-ASAP_Data_Type_93,Security access required,182
ENG264028-ENG264123-Dynamic_Developer_Function_03-ASAP_Data_Type_94,Security access required,182
ENG264028-ENG264124-Dynamic_Developer_Function_03-ASAP_Data_Type_95,Security access required,182
ENG264028-ENG264125-Dynamic_Developer_Function_03-ASAP_Data_Type_96,Security access required,182
ENG264028-ENG264126-Dynamic_Developer_Function_03-ASAP_Data_Type_97,Security access required,182
ENG264028-ENG264127-Dynamic_Developer_Function_03-ASAP_Data_Type_98,Security access required,182
ENG264028-ENG264128-Dynamic_Developer_Function_03-ASAP_Data_Type_99,Security access required,182
ENG264028-ENG264131-Dynamic_Developer_Function_03-Data_position_0_Bit_position,Security access required,182
ENG264028-ENG264132-Dynamic_Developer_Function_03-Data_position_0_Byte_position,Security access required,182
ENG264028-ENG264133-Dynamic_Developer_Function_03-Data_position_1_Bit_position,Security access required,182
ENG264028-ENG264134-Dynamic_Developer_Function_03-Data_position_1_Byte_position,Security access required,182
ENG264028-ENG264135-Dynamic_Developer_Function_03-Data_position_10_Bit_position,Security access required,182
ENG264028-ENG264136-Dynamic_Developer_Function_03-Data_position_10_Byte_position,Security access required,182
ENG264028-ENG264137-Dynamic_Developer_Function_03-Data_position_11_Bit_position,Security access required,182
ENG264028-ENG264138-Dynamic_Developer_Function_03-Data_position_11_Byte_position,Security access required,182
ENG264028-ENG264139-Dynamic_Developer_Function_03-Data_position_12_Bit_position,Security access required,182
ENG264028-ENG264140-Dynamic_Developer_Function_03-Data_position_12_Byte_position,Security access required,182
ENG264028-ENG264141-Dynamic_Developer_Function_03-Data_position_13_Bit_position,Security access required,182
ENG264028-ENG264142-Dynamic_Developer_Function_03-Data_position_13_Byte_position,Security access required,182
ENG264028-ENG264143-Dynamic_Developer_Function_03-Data_position_14_Bit_position,Security access required,182
ENG264028-ENG264144-Dynamic_Developer_Function_03-Data_position_14_Byte_position,Security access required,182
ENG264028-ENG264145-Dynamic_Developer_Function_03-Data_position_15_Bit_position,Security access required,182
ENG264028-ENG264146-Dynamic_Developer_Function_03-Data_position_15_Byte_position,Security access required,182
ENG264028-ENG264147-Dynamic_Developer_Function_03-Data_position_2_Bit_position,Security access required,182
ENG264028-ENG264148-Dynamic_Developer_Function_03-Data_position_2_Byte_position,Security access required,182
ENG264028-ENG264149-Dynamic_Developer_Function_03-Data_position_3_Bit_position,Security access required,182
ENG264028-ENG264150-Dynamic_Developer_Function_03-Data_position_3_Byte_position,Security access required,182
ENG264028-ENG264151-Dynamic_Developer_Function_03-Data_position_4_Bit_position,Security access required,182
ENG264028-ENG264152-Dynamic_Developer_Function_03-Data_position_4_Byte_position,Security access required,182
ENG264028-ENG264153-Dynamic_Developer_Function_03-Data_position_5_Bit_position,Security access required,182
ENG264028-ENG264154-Dynamic_Developer_Function_03-Data_position_5_Byte_position,Security access required,182
ENG264028-ENG264155-Dynamic_Developer_Function_03-Data_position_6_Bit_position,Security access required,182
ENG264028-ENG264156-Dynamic_Developer_Function_03-Data_position_6_Byte_position,Security access required,182
ENG264028-ENG264157-Dynamic_Developer_Function_03-Data_position_7_Bit_position,Security access required,182
ENG264028-ENG264158-Dynamic_Developer_Function_03-Data_position_7_Byte_position,Security access required,182
ENG264028-ENG264159-Dynamic_Developer_Function_03-Data_position_8_Bit_position,Security access required,182
ENG264028-ENG264160-Dynamic_Developer_Function_03-Data_position_8_Byte_position,Security access required,182
ENG264028-ENG264161-Dynamic_Developer_Function_03-Data_position_9_Bit_position,Security access required,182
ENG264028-ENG264162-Dynamic_Developer_Function_03-Data_position_9_Byte_position,Security access required,182
ENG264028-ENG264166-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_1,Security access required,182
ENG264028-ENG264167-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_2,Security access required,182
Elapsed Time: 00:15
adpmap-05-5WA-959-436-Q_WVWZZZCD6RW123439-20260903-1757.CSV
;SW:5WA-959-436-Q   HW:5WA-959-436-Q ---  05: Acc/Start Auth.
;Component:Kessy IOBOX   100 0725, Coding:
;EV_Kessy37w,004024,EV_Kessy37w_004.rod
;Thursday,03,September,2026,17:57:08:29755
;VCID: 629DACA0E4C8F2AA914-8036
ENG253038-ENG258893-DevCod_ Search lights-Suchbeleuchtung_ZAT_bei_KL58_aktiv,activated ,5
ENG253038-ENG258265-DevCod_ Search lights-Suchbeleuchtung_ZAT_Beleuchtung_SES_Variante_aktiv,not activated ,5
ENG253038-ENG260629-DevCod_ Search lights-Suchbeleuchtung_ZAT_Normierung_aktiv,activated ,5
ENG253038-ENG259779-DevCod_ Search lights-Suchbeleuchtung_ZAT_OpenLoadErkennung_aktiv,not activated ,5
ENG253038-ENG260681-DevCod_ Search lights-Suchbeleuchtung_ZAT_SES_Mode,not activated ,5
ENG253096-DevCod_AutomatischeFunktionen,not activated ,6
ENG253395-ENG141964-DevCod_Fahrzeugkonfiguration-Steering assignment,Left ,5
ENG253395-ENG273785-DevCod_Fahrzeugkonfiguration-Transponding_Antennen_Strom_reduziert_aktiv,not active ,5
ENG253143-ENG258965-DevCod_Passive_EntryExit-Toggle-Datalogging_LFDebug_aktiv,not activated ,5
ENG253143-ENG258844-DevCod_Passive_EntryExit-Toggle-Gleichzeitiges_Senden_Innenraumantennen_aktiv,activated ,5
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,6
ENG129029-ENG259793-Easy_close_alignment-VIT_AktivTasteB_Zyklus,1.0 s,6
ENG253331-ENG258816-Par_Automatische_Funktionen-AutomatikFunktionen_Timeout,4320 min,10
ENG253331-ENG260182-Par_Automatische_Funktionen-AutomatikFunktionen_Zyklus_IDGeber_Anwesenheit,300 ms,10
ENG253220-IDE15282-Par_Bedienstellen-Door: driver control section: installation variant,0 ,36
ENG253220-IDE15283-Par_Bedienstellen-Door: front passenger control section: installation variant,0 ,36
ENG253220-IDE15284-Par_Bedienstellen-5th control section: installation variant,5 ,36
ENG253220-IDE15285-Par_Bedienstellen-Fuel filler cap control section: installation variant,5 ,36
ENG253220-IDE15286-Par_Bedienstellen-Rear driver side control section: installation variant,5 ,36
ENG253220-IDE15287-Par_Bedienstellen-Rear passenger side control section: installation variant,5 ,36
ENG253220-ENG259190-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_5teT,4320 min,36
ENG253220-ENG259838-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_BT,4320 min,36
ENG253220-ENG260574-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_FT,0 min,36
ENG253220-ENG261264-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HBFS,4320 min,36
ENG253220-ENG258369-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_HFS,4320 min,36
ENG253220-ENG258148-Par_Bedienstellen-Bedienstelle_Abschaltung_Timeout_Tank,3600 min,36
ENG253220-ENG261229-Par_Bedienstellen-Bedienstelle_Aktivierungsschwelle_Spielschutzzaehler,80 ,36
ENG253220-ENG259917-Par_Bedienstellen-Bedienstelle_Ausschaltzeit_Spielschutz_aktiv,1800 s,36
ENG253220-ENG261227-Par_Bedienstellen-Bedienstelle_Deaktivierung_SchwelleFahrendesFzg,20 km/h,36
ENG253220-ENG261134-Par_Bedienstellen-Bedienstelle_Deaktivierungsschwelle_Spielschutzzaehler,60 ,36
ENG253220-ENG258448-Par_Bedienstellen-Bedienstelle_MaxBetaetigung,120 s,36
ENG253220-ENG259922-Par_Bedienstellen-Bedienstelle_MaxKomfortUnterbrechung,10 ms,36
ENG253220-ENG261271-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_5teT,500 ms,36
ENG253220-ENG259320-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_BT,500 ms,36
ENG253220-ENG259918-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_FT,1500 ms,36
ENG253220-ENG260179-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HBFS,500 ms,36
ENG253220-ENG260090-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_HFS,500 ms,36
ENG253220-ENG260565-Par_Bedienstellen-Bedienstelle_MinAbschaltzeit_Reset_Tank,500 ms,36
ENG253220-ENG261322-Par_Bedienstellen-Bedienstelle_MinBetaetigung_ToggleTaster,140 ms,36
ENG253220-ENG259707-Par_Bedienstellen-Bedienstelle_MinBetaetigung_Verriegelungssensor,140 ms,36
ENG253220-ENG258814-Par_Bedienstellen-Bedienstelle_Reaktivierung_SchwelleStehendesFzg,10 km/h,36
ENG253220-ENG258395-Par_Bedienstellen-Bedienstelle_Reduzierung_Zaehlerstand_Spielschutzzaehler,60 s,36
ENG253190-ENG258772-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Diagnose,71 ms,35
ENG253190-ENG258701-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Entry,10400 µs,35
ENG253190-ENG261026-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Exit,40400 µs,35
ENG253190-ENG258968-Par_Näherungssensoren-Naeherungssensor_MaxImpulslaenge_Naeherung,20400 µs,35
ENG253190-ENG259906-Par_Näherungssensoren-Naeherungssensor_MaxPausenlaenge,10 ms,35
ENG253190-ENG260803-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Diagnose,42 ms,35
ENG253190-ENG259643-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Entry,6200 µs,35
ENG253190-ENG259840-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Exit,24200 µs,35
ENG253190-ENG259205-Par_Näherungssensoren-Naeherungssensor_MinImpulslaenge_Naeherung,12200 µs,35
ENG253190-ENG260098-Par_Näherungssensoren-Verzoegerung_PowerOn_Reset,1960 ms,35
ENG253285-ENG260495-Par_PassiveKomfort-Delay_Reichweitenbegrenzung_Start,0 ms,10
ENG253285-ENG260385-Par_PassiveKomfort-KomfortReichweitenbegr_Timout,75 s,10
ENG253285-ENG261013-Par_PassiveKomfort-PassiveKomfortFunktionen_MaxSignalisierungsdauer,60 s,10
ENG253285-ENG263587-Par_PassiveKomfort-PassiveKomfortFunktionen_Zeitfenster_fuer_Bedienhandlung,800 ms,10
ENG253285-ENG261279-Par_PassiveKomfort-Reichweitenbegrenzung_Zyklus,90 ms,10
ENG253106-ENG258919-Par_ScanStrategie_RetryHandling-anz_RetriesRegistering,1 Num,22
ENG253106-ENG259329-Par_ScanStrategie_RetryHandling-Erste_Warnschwelle_thermische_Überlast,45 °C,22
ENG253106-ENG259473-Par_ScanStrategie_RetryHandling-P2_Pause_zwischen_Transponding_Telegrammen,200 ms,22
ENG253106-ENG259392-Par_ScanStrategie_RetryHandling-Sperrzeit_LFTreiber_nach_thermischer_Ueberlast,5.0 s,22
ENG253106-ENG263515-Par_ScanStrategie_RetryHandling-t_CANSignalDelayAfterSleep,30 ms,22
ENG253106-ENG258479-Par_ScanStrategie_RetryHandling-t_LFDebug_Nachsignaslisierung,100 ms,22
ENG253106-ENG263591-Par_ScanStrategie_RetryHandling-Temperaturschaltschwelle_LF_Wavetable,100 °C,22
ENG253106-ENG276176-Par_ScanStrategie_RetryHandling-Timeout_Grundwert_RetryRegistering,52 ms,22
ENG253106-ENG276194-Par_ScanStrategie_RetryHandling-Timeout_Inkrementwert_RetryRegistering,7 ms,22
ENG253106-ENG261110-Par_ScanStrategie_RetryHandling-Verzoegerung_LFSenden_nach_Weckleitungziehen,0 ms,22
ENG253106-ENG260133-Par_ScanStrategie_RetryHandling-Zweite_Warnschwelle_thermische_Überlast,65 °C,22
ENG253086-MAS18911-Passive_Komfort-Convenience closing by locking using door handle active,activated ,5
ENG253086-ENG280093-Passive_Komfort-Noise_filter_aktiv,activated ,5
ENG253086-ENG261176-Passive_Komfort-Passive_Komfort_Oeffnen_aktiv,not activated ,5
ENG253086-ENG259864-Passive_Komfort-Passive_Komfort_Togglen_aktiv,not activated ,5
ENG253352-ENG259594-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Abdimmen,1.0 ,30
ENG253352-ENG259617-Suchbeleuchtung_StartStop_Taster-PWM_Daempfung_Aufdimmen,2.0 ,30
ENG253352-ENG261228-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ausschalten_KL15,10 min,30
ENG253352-ENG258605-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_0Prozent_Dimmkurve,0.0 %,30
ENG253352-ENG258785-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Deltawert_50Prozent_Dimmkurve,50.0 %,30
ENG253352-ENG263542-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Fehlerdimmwert,100 %,30
ENG253352-ENG260556-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_Nennspannung,13.0 V,30
ENG253352-ENG258781-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_OffsetDimmwert,1.0 ,30
ENG253352-ENG259791-Suchbeleuchtung_StartStop_Taster-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Deltawert_100Prozent_Dimmkurve,100.0 %,30
ENG253287-ENG261242-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES1,10.0 %,32
ENG253287-ENG260274-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_DritteStuetzstelle_Wert50_Dimmkurve_SES2,3.0 %,32
ENG253287-ENG258981-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260137-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ErsteStuetzstelle_Wert1_Dimmkurve_SES2,2.0 %,32
ENG253287-ENG259846-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES1,80.0 %,32
ENG253287-ENG261362-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_FuenfteStuetzstelle_Wert220_Dimmkurve_SES2,20.0 %,32
ENG253287-ENG258809-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_1,0 %,32
ENG253287-ENG258501-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Offset_2,0 %,32
ENG253287-ENG260497-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_1,80 %,32
ENG253287-ENG258157-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_Peak_Max_2,100 %,32
ENG253287-ENG261138-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES1,100.0 %,32
ENG253287-ENG258211-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SechsteStuetzstelle_Wert253_Dimmkurve_SES2,30.0 %,32
ENG253287-ENG261183-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_faktor,0.1 ,32
ENG253287-ENG259175-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_SEs_2_Offset,2.0 Num,32
ENG253287-ENG261051-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Fall_OFF,740 ms,32
ENG253287-ENG260479-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_OFF,0 ms,32
ENG253287-ENG258704-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Pause_ON,0 ms,32
ENG253287-ENG260922-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t1_Rise_ON,100 ms,32
ENG253287-ENG260304-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Fall_OFF,1600 ms,32
ENG253287-ENG258413-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_OFF,0 ms,32
ENG253287-ENG260729-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Pause_ON,0 ms,32
ENG253287-ENG258296-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_t2_Rise_ON,100 ms,32
ENG253287-ENG258477-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES1,15.0 %,32
ENG253287-ENG259506-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_VierteStuetzstelle_Wert100_Dimmkurve_SES2,4.0 %,32
ENG253287-ENG258902-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES1,5.0 %,32
ENG253287-ENG260830-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_ZweiteStuetzstelle_Wert10_Dimmkurve_SES2,2.0 %,32
Elapsed Time: 00:06
adpmap-08-5WA-907-007-AB_WVWZZZCD6RW123439-20260903-1757.CSV
;SW:5WA-907-007-AB   HW:5WA-907-007-AB ---  08: Auto HVAC
;Component:AC Automat    H30 3623, Coding:002000119011000000100010111010010000011000000000000000000000
;EV_ACClimaPREVW38X,001102,EV_ACClimaPREVW38X_VW38.rod
;Thursday,03,September,2026,17:57:37:29755
;VCID: 074B9D342FAA7782A6A-8052
IDE00001-ENG128289-Production mode-Air_condition_compressor_deactivate,not active ,3
IDE00001-ENG128290-Production mode-Battery_cooling_and_heating_deactivate,not active ,3
IDE00001-ENG128291-Production mode-ClearResetEmissionRelated-DiagnosticInformation_Mode$04,not active ,3
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,Service life-dependent store ,1
IDE01477-Store manual fan setting for terminal 15 off,Do not store ,1
IDE01479-Gear ratio of engine - A/C compressor,1.18 ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01490-Fresh air blower voltage offset,Default ,1
IDE01491-Offset for temperature in summer mode,Default ,1
IDE01492-Offset for temperature in winter mode,Default ,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01503-Running time of basic setting for compressor break-in,60 s,1
IDE01505-Tolerance range for basic setting of flap end stops,32 °C,1
IDE01506-Tolerance range for flap end stops,10 °C,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE02371-Time until seat heating performance is reduced from stage 3 to stage 2,0 min,1
IDE02372-Time until seat heating performance is reduced from stage 2 to stage 1,0 min,1
IDE02744-Steering wheel heating,long_push ,1
IDE03176-Duration of compressor run in,60 s,1
IDE03252-Window condensation parameter for start/stop function,5 ,1
IDE03253-A/C comfort parameter for start/stop function,5 ,1
IDE04074-Driving program,not installed ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,10
IDE04927-MAS12610-Window heater-Activation of wiper arm heater,-2.0 °C,10
IDE04927-ENG263527-Window heater-Config_heating_voltage_request,No_set_point_voltage ,10
IDE04927-ENG263525-Window heater-Heating_rear_window_activation_time,320 s,10
IDE04927-ENG263512-Window heater-Heating_rear_window_cutoff_temperature,35.0 °C,10
IDE04927-ENG263556-Window heater-Heating_rear_window_temperature_activation_time,active ,10
IDE04927-ENG263570-Window heater-Window_heating_front_activation_time_pause,320 s,10
IDE04927-ENG263505-Window heater-Window_heating_front_cutoff_temperature,35.0 °C,10
IDE04927-ENG263589-Window heater-Window_heating_front_maximum_temperature_activation_time,1200 s,10
IDE04927-ENG263529-Window heater-Window_heating_front_temperature_activation_time,active ,10
IDE06089-ENG263584-Seat heater level current consumption allocation-Config_seat_heating_high_voltage_request,Set_point_voltage_14.7V ,17
IDE06089-ENG263533-Seat heater level current consumption allocation-Config_seat_heating_low_voltage_request,No_set_point_voltage ,17
IDE06089-ENG263526-Seat heater level current consumption allocation-Seat_heating_correction_of_temperature_regulation_on_heat_flow,0.00 °C,17
IDE06089-ENG263552-Seat heater level current consumption allocation-Seat_heating_filter_constant_for_heat_flow,1 s,17
IDE06089-ENG263578-Seat heater level current consumption allocation-Seat_heating_offset_voltage,15.7 V,17
IDE06089-ENG263544-Seat heater level current consumption allocation-Seat_heating_stage_1_lower_threshold,22.00 °C,17
IDE06089-ENG263507-Seat heater level current consumption allocation-Seat_heating_stage_1_upper_threshold,23.00 °C,17
IDE06089-ENG263592-Seat heater level current consumption allocation-Seat_heating_stage_2_lower_threshold,22.00 °C,17
IDE06089-ENG263559-Seat heater level current consumption allocation-Seat_heating_stage_2_upper_threshold,23.00 °C,17
IDE06089-ENG263539-Seat heater level current consumption allocation-Seat_heating_stage_3_lower_threshold,35.50 °C,17
IDE06089-ENG263554-Seat heater level current consumption allocation-Seat_heating_stage_3_upper_threshold,36.00 °C,17
IDE06089-ENG263536-Seat heater level current consumption allocation-Seat_heating_stage_4_lower_threshold,35.50 °C,17
IDE06089-ENG263549-Seat heater level current consumption allocation-Seat_heating_stage_4_upper_threshold,36.00 °C,17
IDE06089-ENG263566-Seat heater level current consumption allocation-Seat_heating_stage_5_lower_threshold,52.50 °C,17
IDE06089-ENG263597-Seat heater level current consumption allocation-Seat_heating_stage_5_upper_threshold,53.00 °C,17
IDE06089-ENG263562-Seat heater level current consumption allocation-Seat_heating_stage_6_lower_threshold,52.50 °C,17
IDE06089-ENG263524-Seat heater level current consumption allocation-Seat_heating_stage_6_upper_threshold,53.00 °C,17
IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
IDE06326-Tolerance: compressor speed during compressor run-in,300 /min,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE07108-A/C styles,No display ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,15 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,15 min,2
IDE07301-Remote start function: activation of seat heating,Without seat heater and ventilation ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07304-Remote start function: activation of seat ventilation,not activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,25 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,32 °C,1
IDE07307-Remote start function: activation stage of seat heating,0 ,1
IDE07308-Remote start function: activation stage of seat ventilation,0 ,1
IDE07398-Blower logic with manual adjustment,Fan setting: absolute ,1
IDE07418-Additional filter,not installed ,1
IDE07585-Hand heater function during cold start,not active ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,active ,1
IDE07948-Retention of frt.pass. seat heater level,active for 10 minutes ,1
IDE08356-ENG125698-Left seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08356-ENG125700-Left seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08356-ENG125697-Left seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08356-ENG125699-Left seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08356-ENG125701-Left seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08356-ENG134731-Left seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08356-ENG125695-Left seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08356-ENG125696-Left seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08357-ENG125698-Left seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08357-ENG125700-Left seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08357-ENG125697-Left seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08357-ENG125699-Left seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08357-ENG125701-Left seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08357-ENG134731-Left seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08357-ENG125695-Left seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08357-ENG125696-Left seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08358-ENG125698-Left seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08358-ENG125700-Left seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08358-ENG125697-Left seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08358-ENG125699-Left seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08358-ENG125701-Left seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08358-ENG134731-Left seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08358-ENG125695-Left seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08358-ENG125696-Left seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08359-ENG125698-Left seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08359-ENG125700-Left seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08359-ENG125697-Left seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08359-ENG125699-Left seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08359-ENG125701-Left seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08359-ENG134731-Left seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08359-ENG125695-Left seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08359-ENG125696-Left seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE08360-ENG125698-Right seat backrest fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08360-ENG125700-Right seat backrest fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08360-ENG125697-Right seat backrest fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08360-ENG125699-Right seat backrest fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08360-ENG125701-Right seat backrest fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08360-ENG134731-Right seat backrest fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08360-ENG125695-Right seat backrest fan 1-Overvoltage_treshold,16 V,10
IDE08360-ENG125696-Right seat backrest fan 1-Undervoltage_treshold,9 V,10
IDE08361-ENG125698-Right seat backrest fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08361-ENG125700-Right seat backrest fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08361-ENG125697-Right seat backrest fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08361-ENG125699-Right seat backrest fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08361-ENG125701-Right seat backrest fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08361-ENG134731-Right seat backrest fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08361-ENG125695-Right seat backrest fan 2-Overvoltage_treshold,16 V,10
IDE08361-ENG125696-Right seat backrest fan 2-Undervoltage_treshold,9 V,10
IDE08362-ENG125698-Right seat cushion fan 1-Counter_For_Blockage_Validation,5 counts,10
IDE08362-ENG125700-Right seat cushion fan 1-Critical_Temperature_Treshold,70 °C,10
IDE08362-ENG125697-Right seat cushion fan 1-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08362-ENG125699-Right seat cushion fan 1-Latency_For_Blockage_Validation,5 s,10
IDE08362-ENG125701-Right seat cushion fan 1-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08362-ENG134731-Right seat cushion fan 1-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08362-ENG125695-Right seat cushion fan 1-Overvoltage_treshold,16 V,10
IDE08362-ENG125696-Right seat cushion fan 1-Undervoltage_treshold,9 V,10
IDE08363-ENG125698-Right seat cushion fan 2-Counter_For_Blockage_Validation,5 counts,10
IDE08363-ENG125700-Right seat cushion fan 2-Critical_Temperature_Treshold,70 °C,10
IDE08363-ENG125697-Right seat cushion fan 2-Hysteresis_Treshold_For_Undervoltage,5 V,10
IDE08363-ENG125699-Right seat cushion fan 2-Latency_For_Blockage_Validation,5 s,10
IDE08363-ENG125701-Right seat cushion fan 2-Maximum_Blower_Rotation_Speed,1500 /min,10
IDE08363-ENG134731-Right seat cushion fan 2-Minimum_Blower_Rotation_Speed,200 /min,10
IDE08363-ENG125695-Right seat cushion fan 2-Overvoltage_treshold,16 V,10
IDE08363-ENG125696-Right seat cushion fan 2-Undervoltage_treshold,9 V,10
IDE10118-Fan speed reduction for telephony,activated ,1
IDE10278-Behavior of compressor during moderate outside temperatures,inactive ,1
IDE11935-Personalization,activated ,1
IDE12229-Filtering of interior air: store,not active ,1
IDE13371-Interior humidity sensor: sensitivity,Medium ,1
IDE13676-Remote start function: rear window defogger,activated ,1
IDE13677-Remote start function: seat climate control takeover,activated ,1
IDE14087-Time until seat heat recovery within the maximum level,120 min,1
IDE15635-Number of interruptions permitted during compressor run-in,10 ,1
IDE16800-Pre-ventilation: coding override,not active ,1
MAS06414-Temperature tuning,normal tuning ,1
MAS06415-Blower adjustment,normal tuning ,1
MAS06416-Blower display in auto operation,not activated ,1
MAS06417-Amplified overshoots heater operation,not activated ,1
MAS14860-Remote start function: windshield defogger takeover,not activated ,1
MAS14861-Remote start function: windshield defogger,not activated ,1
MAS19885-Remote start function: rear windshield heater transfer,activated ,1
MAS19886-Interior temperature sensor: after-run time,180 s,2
ENG263483-AC_evaporator_temperature_offset,-0.7 K,1
ENG276128-air_recirculation_deactivate_at_open_sunroof,not activated ,1
ENG263479-Auto-Toggle,not activated ,1
ENG153885-Knockout_test_mode,0 ,1
ENG263490-manuel_air_recirculation_deacivate_AUTO_mode,activated ,1
ENG279929-ENG280096-pms_data_to_hmi-papam_pms_inside,No display ,2
ENG279929-ENG280097-pms_data_to_hmi-papam_pms_outside,No display ,2
ENG125614-Reset_Blower_1_Backrest_Left,inactive ,1
ENG125615-Reset_Blower_1_Backrest_Right,inactive ,1
ENG125613-Reset_Blower_1_Cushion_Left,inactive ,1
ENG125616-Reset_Blower_1_Cushion_Right,inactive ,1
ENG125623-Reset_Blower_2_Backrest_Left,inactive ,1
ENG125624-Reset_Blower_2_Backrest_Right,inactive ,1
ENG125621-Reset_Blower_2_Cushion_Left,inactive ,1
ENG125622-Reset_Blower_2_Cushion_Right,inactive ,1
ENG263450-seat_dependent_climatisation,not activated ,1
ENG263443-seatheatin_function_switch,AUTO_seatheating_function ,1
ENG263458-winterfunction,not installed ,1
Elapsed Time: 00:27
adpmap-09-5WA-937-086-BM_WVWZZZCD6RW123439-20260903-1759.CSV
;SW:5WA-937-086-BM   HW:5WA-937-086-AT ---  09: Cent. Elect.
;Component:BCM37w_M134 0182, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_VW38.rod
;Thursday,03,September,2026,17:59:49:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 1D67DF5C9D368D52EC6-8048 SFD { }
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG281100-Production mode-Remotestart_Pmode,not active ,3
IDE00301-Distance,0 km,4
IDE01550-Service position,163.802035 °,2
IDE02455-ENG116601-Light function "Coming/Leaving Home"-Coming Home Verbaustatus,automatic ,2
IDE02455-ENG260981-Light function "Coming/Leaving Home"-Darstellung Coming-home Verlauf,not active ,2
IDE02455-ENG261352-Light function "Coming/Leaving Home"-Darstellung Leaving-home Verlauf,not active ,2
IDE02455-ENG115657-Light function "Coming/Leaving Home"-Leaving-Home Verbausstatus,Enabled ,2
IDE02455-ENG115863-Light function "Coming/Leaving Home"-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,2
IDE02455-ENG116602-Light function "Coming/Leaving Home"-Menuesteuerung Coming Home Werkseinstellung,active ,2
IDE02455-ENG116606-Light function "Coming/Leaving Home"-Menuesteuerung Leaving-home Freischaltung per BAP,active ,2
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,2
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,7
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,7
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beams ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,Main beam ,4
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,255 min,2
IDE07161-temporary VIN,Conditions not correct or request sequence error,2
IDE07356-Position during interval mode,20.010969 °,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,present ,9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmenü,not active ,9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten,klemmenabhaengig ,7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert,One-sided ,7
IDE09767-ENG126816-Position lamps-Standlicht aus,active ,7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht,active ,7
IDE09767-ENG133383-Position lamps-Standlicht-Verfügbarkeit,24 s,7
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7
IDE10298-Alternating park position 1,0.010989 °,2
IDE10299-Alternating park position 2,22.010967 °,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE10844-Control module rear lid opening: duration status query,0 ms,2
IDE10845-Control module rear lid opening: vehicle type-,00 ,12
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,0 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schlüsselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,0 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,0 km/h,12
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12
IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-Left taillight 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Power rear lid opening control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-Left taillight 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right taillight 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right taillight 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver's side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger's side,old ,6
IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6
IDE12489-Antenna 2 for short-range communication,No Response From Subnet Component,6
IDE13065-Left tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13066-Left tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13067-Right tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13068-Right tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf,0 ms,16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten,Low beams ,16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis,Ignition On ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,600 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,1200 lx,16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome,10 seconds ,16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag,10 seconds ,16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag,10 seconds ,16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO,not active ,16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO,not active ,16
IDE15901-Direct entry keys,installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,Yes ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,4
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,4
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,4
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,4
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,4
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,4
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,4
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,4
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,4
IDE80016-Analysis 16,No Response From Subnet Component,4
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,4
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,4
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,4
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,4
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,4
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,4
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,4
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,4
IDE80017-ENG289601-Analysis 17-Offset_PP1,No Response From Subnet Component,4
IDE80017-ENG289602-Analysis 17-Offset_PP2,No Response From Subnet Component,4
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,4
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,4
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,4
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,4
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,4
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,4
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,4
IDE80017-ENG289603-Analysis 17-Offset_T1,No Response From Subnet Component,4
IDE80017-ENG289604-Analysis 17-Offset_T2,No Response From Subnet Component,4
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,4
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,4
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,4
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,4
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,4
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,4
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,4
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,4
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,4
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,4
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,4
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,4
IDE80018-ENG289601-Analysis 18-Offset_PP1,No Response From Subnet Component,4
IDE80018-ENG289602-Analysis 18-Offset_PP2,No Response From Subnet Component,4
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,4
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,4
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,4
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,4
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,4
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,4
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,4
IDE80018-ENG289603-Analysis 18-Offset_T1,No Response From Subnet Component,4
IDE80018-ENG289604-Analysis 18-Offset_T2,No Response From Subnet Component,4
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,4
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,4
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,4
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,4
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,4
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,4
MAS05055-lower turn position,24.010965 °,2
MAS05056-upper turn position,163.802035 °,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),OFF ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),On ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),OFF ,3
MAS05807-ENG264071-Coding-APS für 100 Zyklen deaktiv (1bit),On ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),On ,3
MAS05807-ENG264178-Coding-geräusch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus möglich (1bit),On ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung über Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsrückschaltung (1bit),OFF ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),OFF ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tränenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abhängige Wischstufenrückschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),OFF ,3
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,0 ms,4
MAS07146-MAS13125-Button 1-Function of button 1,not coded / not installed ,1
MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1
MAS07147-MAS13129-Button 2-Function of button 2,not coded / not installed ,1
MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1
MAS07148-MAS13132-Button 3-Function of button 3,not coded / not installed ,1
MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8
MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,not active ,8
MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8
MAS09325-ENG142193-Daytime running lights-Geschwindigkeitsabhaengiges TFL,0 km/h,8
MAS09325-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,8
MAS09325-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,8
MAS09325-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,active ,8
MAS09325-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,8
MAS09325-ENG142192-Daytime running lights-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,8
MAS09325-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbestätugung,active ,8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links,active ,8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts,active ,8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken,not active ,8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2,active ,8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links,active ,8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts,active ,8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links,active ,8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts,active ,8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS,active ,8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN,active ,8
MAS13139-MAS13135-Button 4-Function of button 4,not coded / not installed ,1
MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,No Response From Subnet Component,1
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,No Response From Subnet Component,1
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,No Response From Subnet Component,1
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,No Response From Subnet Component,1
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,No Response From Subnet Component,1
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,No Response From Subnet Component,1
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,No Response From Subnet Component,1
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,No Response From Subnet Component,1
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,No Response From Subnet Component,1
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,No Response From Subnet Component,1
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,No Response From Subnet Component,1
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,No Response From Subnet Component,1
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,No Response From Subnet Component,1
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,No Response From Subnet Component,1
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,No Response From Subnet Component,1
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,No Response From Subnet Component,1
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,No Response From Subnet Component,1
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,No Response From Subnet Component,1
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,No Response From Subnet Component,1
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,No Response From Subnet Component,1
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,No Response From Subnet Component,1
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,No Response From Subnet Component,1
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,No Response From Subnet Component,1
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,No Response From Subnet Component,1
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,No Response From Subnet Component,1
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,No Response From Subnet Component,1
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,No Response From Subnet Component,1
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,No Response From Subnet Component,1
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,No Response From Subnet Component,1
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,No Response From Subnet Component,1
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,No Response From Subnet Component,1
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,No Response From Subnet Component,1
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,No Response From Subnet Component,1
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,No Response From Subnet Component,1
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,No Response From Subnet Component,1
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,No Response From Subnet Component,1
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,No Response From Subnet Component,1
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,No Response From Subnet Component,1
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,No Response From Subnet Component,1
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,No Response From Subnet Component,1
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,No Response From Subnet Component,1
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,No Response From Subnet Component,1
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,No Response From Subnet Component,1
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,No Response From Subnet Component,1
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,No Response From Subnet Component,1
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,No Response From Subnet Component,1
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,No Response From Subnet Component,1
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,No Response From Subnet Component,1
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,No Response From Subnet Component,1
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,No Response From Subnet Component,1
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,No Response From Subnet Component,1
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,No Response From Subnet Component,1
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,No Response From Subnet Component,1
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,No Response From Subnet Component,1
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,No Response From Subnet Component,1
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,No Response From Subnet Component,1
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,No Response From Subnet Component,1
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,No Response From Subnet Component,1
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,No Response From Subnet Component,1
MAS14140-IDE15905-Flashing function-Travel Assist,active ,4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz,active ,4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz,not active ,4
MAS18831-IDE80001-Control module for optical rear lid opening: dataset-Analysis 1,No Response From Subnet Component,4
MAS18831-IDE80002-Control module for optical rear lid opening: dataset-Analysis 2,No Response From Subnet Component,4
MAS18831-IDE80003-Control module for optical rear lid opening: dataset-Analysis 3,No Response From Subnet Component,4
MAS18831-IDE80004-Control module for optical rear lid opening: dataset-Analysis 4,No Response From Subnet Component,4
MAS18831-IDE80005-Control module for optical rear lid opening: dataset-Analysis 5,No Response From Subnet Component,4
MAS18831-IDE80006-Control module for optical rear lid opening: dataset-Analysis 6,No Response From Subnet Component,4
MAS18831-IDE80007-Control module for optical rear lid opening: dataset-Analysis 7,No Response From Subnet Component,4
MAS18831-IDE80008-Control module for optical rear lid opening: dataset-Analysis 8,No Response From Subnet Component,4
MAS18831-IDE80009-Control module for optical rear lid opening: dataset-Analysis 9,No Response From Subnet Component,4
MAS18831-IDE80010-Control module for optical rear lid opening: dataset-Analysis 10,No Response From Subnet Component,4
MAS18831-IDE80011-Control module for optical rear lid opening: dataset-Analysis 11,No Response From Subnet Component,4
MAS18831-IDE80012-Control module for optical rear lid opening: dataset-Analysis 12,No Response From Subnet Component,4
MAS18831-IDE80013-Control module for optical rear lid opening: dataset-Analysis 13,No Response From Subnet Component,4
MAS18831-IDE80014-Control module for optical rear lid opening: dataset-Analysis 14,No Response From Subnet Component,4
MAS18831-IDE80015-Control module for optical rear lid opening: dataset-Analysis 15,No Response From Subnet Component,4
MAS18831-IDE80016-Control module for optical rear lid opening: dataset-Analysis 16,No Response From Subnet Component,4
MAS18831-IDE80017-Control module for optical rear lid opening: dataset-Analysis 17,No Response From Subnet Component,4
MAS18831-IDE80018-Control module for optical rear lid opening: dataset-Analysis 18,No Response From Subnet Component,4
MAS18831-IDE80019-Control module for optical rear lid opening: dataset-Analysis 19,No Response From Subnet Component,4
MAS18831-IDE80020-Control module for optical rear lid opening: dataset-Analysis 20,No Response From Subnet Component,4
MAS18831-IDE80021-Control module for optical rear lid opening: dataset-Analysis 21,No Response From Subnet Component,4
MAS18831-IDE80022-Control module for optical rear lid opening: dataset-Analysis 22,No Response From Subnet Component,4
MAS18831-IDE80023-Control module for optical rear lid opening: dataset-Analysis 23,No Response From Subnet Component,4
MAS18831-IDE80024-Control module for optical rear lid opening: dataset-Analysis 24,No Response From Subnet Component,4
MAS18831-IDE80025-Control module for optical rear lid opening: dataset-Analysis 25,No Response From Subnet Component,4
MAS18831-IDE80026-Control module for optical rear lid opening: dataset-Analysis 26,No Response From Subnet Component,4
MAS18831-IDE80027-Control module for optical rear lid opening: dataset-Analysis 27,No Response From Subnet Component,4
MAS18831-IDE80028-Control module for optical rear lid opening: dataset-Analysis 28,No Response From Subnet Component,4
MAS18831-IDE80029-Control module for optical rear lid opening: dataset-Analysis 29,No Response From Subnet Component,4
MAS18831-IDE80030-Control module for optical rear lid opening: dataset-Analysis 30,No Response From Subnet Component,4
MAS18831-IDE80031-Control module for optical rear lid opening: dataset-Analysis 31,No Response From Subnet Component,4
MAS18831-IDE80032-Control module for optical rear lid opening: dataset-Analysis 32,No Response From Subnet Component,4
MAS18831-IDE80033-Control module for optical rear lid opening: dataset-Analysis 33,No Response From Subnet Component,4
MAS18831-IDE80034-Control module for optical rear lid opening: dataset-Analysis 34,No Response From Subnet Component,4
MAS18831-IDE80035-Control module for optical rear lid opening: dataset-Analysis 35,No Response From Subnet Component,4
MAS18831-IDE80036-Control module for optical rear lid opening: dataset-Analysis 36,No Response From Subnet Component,4
MAS18831-IDE80037-Control module for optical rear lid opening: dataset-Analysis 37,No Response From Subnet Component,4
MAS18831-IDE80038-Control module for optical rear lid opening: dataset-Analysis 38,No Response From Subnet Component,4
MAS18831-IDE80039-Control module for optical rear lid opening: dataset-Analysis 39,No Response From Subnet Component,4
MAS18831-IDE80040-Control module for optical rear lid opening: dataset-Analysis 40,No Response From Subnet Component,4
MAS18831-IDE80041-Control module for optical rear lid opening: dataset-Analysis 41,No Response From Subnet Component,4
MAS18831-IDE80042-Control module for optical rear lid opening: dataset-Analysis 42,No Response From Subnet Component,4
MAS18831-IDE80043-Control module for optical rear lid opening: dataset-Analysis 43,No Response From Subnet Component,4
MAS18831-IDE80044-Control module for optical rear lid opening: dataset-Analysis 44,No Response From Subnet Component,4
MAS18831-IDE80045-Control module for optical rear lid opening: dataset-Analysis 45,No Response From Subnet Component,4
MAS18831-IDE80046-Control module for optical rear lid opening: dataset-Analysis 46,No Response From Subnet Component,4
MAS18831-IDE80047-Control module for optical rear lid opening: dataset-Analysis 47,No Response From Subnet Component,4
MAS18831-IDE80048-Control module for optical rear lid opening: dataset-Analysis 48,No Response From Subnet Component,4
MAS18831-IDE80049-Control module for optical rear lid opening: dataset-Analysis 49,No Response From Subnet Component,4
MAS18831-IDE80050-Control module for optical rear lid opening: dataset-Analysis 50,No Response From Subnet Component,4
MAS18831-IDE80051-Control module for optical rear lid opening: dataset-Analysis 51,No Response From Subnet Component,4
MAS18831-IDE80052-Control module for optical rear lid opening: dataset-Analysis 52,No Response From Subnet Component,4
MAS18831-IDE80053-Control module for optical rear lid opening: dataset-Analysis 53,No Response From Subnet Component,4
MAS18831-IDE80054-Control module for optical rear lid opening: dataset-Analysis 54,No Response From Subnet Component,4
MAS18831-IDE80055-Control module for optical rear lid opening: dataset-Analysis 55,No Response From Subnet Component,4
MAS18831-IDE80056-Control module for optical rear lid opening: dataset-Analysis 56,No Response From Subnet Component,4
MAS18831-IDE80057-Control module for optical rear lid opening: dataset-Analysis 57,No Response From Subnet Component,4
MAS18831-IDE80058-Control module for optical rear lid opening: dataset-Analysis 58,No Response From Subnet Component,4
MAS18831-IDE80059-Control module for optical rear lid opening: dataset-Analysis 59,No Response From Subnet Component,4
MAS18831-IDE80060-Control module for optical rear lid opening: dataset-Analysis 60,No Response From Subnet Component,4
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,10 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,119 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,2055 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,24.2 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR,00 ,270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG,00 ,270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit,0 ms,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,not active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,600.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Prüfung,active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,No ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,not activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verzögerungs_zeit,60 s,8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P,Alle Fahrstufen ,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer für Ausführung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verfügbarkeit Komfortabschaltung,Available ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Zündungsabschaltung über Energiemanagement,Available ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG253018-Clamp_Control,Driver´s door ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,100 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,200 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,100 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,100 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253350-ENG258402-Coding_seat_pneumatics_driver_side-Function_easy_entry,No Response From Subnet Component,40
ENG253350-ENG260372-Coding_seat_pneumatics_driver_side-Function_massage,No Response From Subnet Component,40
ENG253350-ENG260893-Coding_seat_pneumatics_driver_side-Function_memory,No Response From Subnet Component,40
ENG253350-ENG261225-Coding_seat_pneumatics_driver_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253350-ENG259055-Coding_seat_pneumatics_driver_side-Function_off_delay,No Response From Subnet Component,40
ENG253350-ENG259290-Coding_seat_pneumatics_driver_side-Function_personalisation,No Response From Subnet Component,40
ENG253350-ENG259372-Coding_seat_pneumatics_driver_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253350-ENG259654-Coding_seat_pneumatics_driver_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253350-ENG259159-Coding_seat_pneumatics_driver_side-Function_race_mode,No Response From Subnet Component,40
ENG253350-ENG261329-Coding_seat_pneumatics_driver_side-Function_side_support,No Response From Subnet Component,40
ENG253350-ENG258695-Coding_seat_pneumatics_driver_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253175-ENG258402-Coding_seat_pneumatics_passenger_side-Function_easy_entry,No Response From Subnet Component,40
ENG253175-ENG260372-Coding_seat_pneumatics_passenger_side-Function_massage,No Response From Subnet Component,40
ENG253175-ENG260893-Coding_seat_pneumatics_passenger_side-Function_memory,No Response From Subnet Component,40
ENG253175-ENG261225-Coding_seat_pneumatics_passenger_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253175-ENG259055-Coding_seat_pneumatics_passenger_side-Function_off_delay,No Response From Subnet Component,40
ENG253175-ENG259290-Coding_seat_pneumatics_passenger_side-Function_personalisation,No Response From Subnet Component,40
ENG253175-ENG259372-Coding_seat_pneumatics_passenger_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253175-ENG259654-Coding_seat_pneumatics_passenger_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253175-ENG259159-Coding_seat_pneumatics_passenger_side-Function_race_mode,No Response From Subnet Component,40
ENG253175-ENG261329-Coding_seat_pneumatics_passenger_side-Function_side_support,No Response From Subnet Component,40
ENG253175-ENG258695-Coding_seat_pneumatics_passenger_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253229-ENG258467-Define_Const-Dimm2Bin,1 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv,activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,not activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering assignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schließverhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,not activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 on or off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebetür,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,not installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-Diebstahlschutz.Modulsoftware-,not active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,not active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,10_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,21
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,21
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,21
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,21
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,21
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,21
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,21
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,21
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,21
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,21
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,21
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,21
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,21
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,21
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,21
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,21
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,21
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,21
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,21
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,21
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,21
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,21
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,21
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,21
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,21
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,21
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,21
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,21
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,21
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,21
ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,21
ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,21
ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,21
ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,21
ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,21
ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,21
ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,21
ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,21
ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,21
ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,21
ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,21
ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,21
ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,21
ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,21
ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,21
ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,21
ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,21
ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,21
ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,21
ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,21
ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,21
ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,21
ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,21
ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,21
ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,21
ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,21
ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,21
ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,21
ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,21
ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,21
ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,21
ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,21
ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,21
ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,21
ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,21
ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,21
ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,21
ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,21
ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,21
ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,21
ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,21
ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,21
ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,21
ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,21
ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,21
ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,21
ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,21
ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,21
ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,21
ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,21
ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,21
ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,21
ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,21
ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,21
ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,21
ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,21
ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,21
ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,21
ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,21
ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,21
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,21
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,21
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,21
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,21
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,21
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,21
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,21
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,21
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,21
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,21
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,21
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,21
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,21
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,21
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,21
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,21
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,21
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,21
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,21
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,21
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,21
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,21
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,21
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,21
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,21
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,21
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,21
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,21
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,21
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,21
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,21
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,21
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,21
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,21
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,21
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,21
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,21
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,21
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,21
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,21
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,21
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,21
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,21
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,21
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,21
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,21
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,21
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,21
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,21
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,21
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,21
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,21
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,21
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,21
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,21
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,21
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,21
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,21
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21
ENG253243-ENG286261-Easy Open-p_a_Schiebetürentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,not active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,not active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Kl_S,not active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebetüren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,15 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,50 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,00 00 ,2
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not available ,6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,LIN ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Keine_Spannungsanforderung ,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,immer Wischerstopp ,6
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,40 ,2
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,Always ,8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,not installed ,8
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,not installed ,8
ENG253080-IAA Nutzermanagement,installed ,1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,not activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area,active ,23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area,active ,23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung,0.00 m,23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung,0.00 m,23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung,active ,23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer,10 ms,23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle,-16.00000 m/s²,23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch,not active ,23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv,not active ,23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv,not active ,23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv,not active ,23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel,4000 lx,23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch,50000 lx,23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto,not active ,23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus,0 ,23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein,0 ,23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch,not active ,23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung,20 km/h,23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung,10 km/h,23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus,60 km/h,23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein,75 km/h,23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4
ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-Left taillight 1,not installed ,4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-Left taillight 2,not installed ,4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right taillight 1,not installed ,4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right taillight 2,not installed ,4
ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,not active ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,01 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,11 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,11 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,100 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,50 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,50 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,50 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,50 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,50 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,50 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,01 ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,00 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,01 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,00 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,00 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,00 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,00 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,00 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,00 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,00 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,00 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,00 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,01 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,00 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,00 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,00 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,00 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,00 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,00 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,00 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,00 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,00 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,00 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,01 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,00 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,00 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,00 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,00 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,00 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,00 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,00 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,00 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,00 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,00 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,00 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,00 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,00 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,00 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,00 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,00 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,00 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,00 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,00 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,00 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,00 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,00 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,00 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,00 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,00 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,00 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,00 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,00 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,00 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,00 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,00 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,00 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,00 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,00 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,00 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,00 ,96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,not active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,not active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,not active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 1C 00 00 00 00 60 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C 60 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,64 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,not active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,00 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,00 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,00 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,00 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,00 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,00 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,00 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,03 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,00 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,02 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,00 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,00 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,00 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,03 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,00 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,03 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,00 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,00 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,00 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,00 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,00 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,00 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,00 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,00 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,00 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,00 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,5 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,01 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,not active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,13 ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,07 ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,FF ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,FF ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1,00 ,51
ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10,00 ,51
ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11,00 ,51
ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12,00 ,51
ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13,00 ,51
ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14,00 ,51
ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15,00 ,51
ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2,00 ,51
ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3,1F ,51
ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4,29 ,51
ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5,00 ,51
ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6,00 ,51
ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7,00 ,51
ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8,4D ,51
ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9,57 ,51
ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1,00 ,51
ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10,00 ,51
ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11,00 ,51
ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12,00 ,51
ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13,00 ,51
ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14,00 ,51
ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15,00 ,51
ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2,00 ,51
ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3,08 ,51
ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4,12 ,51
ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5,00 ,51
ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6,00 ,51
ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7,00 ,51
ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8,36 ,51
ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9,40 ,51
ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1,00 ,51
ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10,00 ,51
ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11,00 ,51
ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12,00 ,51
ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13,00 ,51
ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14,00 ,51
ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15,00 ,51
ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2,6D ,51
ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3,6E ,51
ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4,00 ,51
ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5,00 ,51
ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6,00 ,51
ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7,00 ,51
ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8,00 ,51
ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9,00 ,51
ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1,Offset_0 ,51
ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10,Offset_0 ,51
ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11,Offset_0 ,51
ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12,Offset_0 ,51
ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13,Offset_0 ,51
ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14,Offset_0 ,51
ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15,Offset_0 ,51
ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2,Offset_0 ,51
ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3,Offset_0 ,51
ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4,Offset_0 ,51
ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5,Offset_0 ,51
ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6,Offset_0 ,51
ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7,Offset_0 ,51
ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8,Offset_0 ,51
ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9,Offset_0 ,51
ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1,Offset_0 ,51
ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10,Offset_0 ,51
ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11,Offset_0 ,51
ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12,Offset_0 ,51
ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13,Offset_0 ,51
ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14,Offset_0 ,51
ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15,Offset_0 ,51
ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2,Offset_0 ,51
ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3,Offset_0 ,51
ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4,Offset_0 ,51
ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5,Offset_0 ,51
ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6,Offset_0 ,51
ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7,Offset_0 ,51
ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8,Offset_0 ,51
ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9,Offset_0 ,51
ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1,Offset_0 ,51
ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10,Offset_0 ,51
ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11,Offset_0 ,51
ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12,Offset_0 ,51
ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13,Offset_0 ,51
ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14,Offset_0 ,51
ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15,Offset_0 ,51
ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2,Offset_0 ,51
ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3,Offset_0 ,51
ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4,Offset_0 ,51
ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5,Offset_0 ,51
ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6,Offset_0 ,51
ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7,Offset_0 ,51
ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8,Offset_0 ,51
ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9,Offset_0 ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,00 ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,00 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,00 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,09 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,0A ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,19 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,1A ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,00 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,00 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,07 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,08 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,00 ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,17 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,18 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,0D ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,0E ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,00 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,FF ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,FF ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,FF ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,FF ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,FF ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,FF ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,00 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,00 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93
ENG276127-Interior_Monitoring_Data_Set2,No Response From Subnet Component,93
ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock,10_ms ,4
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG248300-Kessyfunktion-reunlock_beep,not active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG172886-MAS10514-lcm-Expanded high beam control,High beam assistant ,4
ENG172886-ENG142185-lcm-LCM_blinker,false ,4
ENG172886-ENG142034-lcm-Light_Control_Module,direkt verbaut ,4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,0 ,20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,00 ,20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,00 ,20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,not_active ,20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,not active ,20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,0 ,20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,00 ,20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,00 ,20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,not_active ,20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,not active ,20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,00 ,20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,00 ,20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,0 ,20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,00 ,20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,00 ,20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,not_active ,20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,not active ,20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,not active ,20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,0 ,20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,00 ,20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,00 ,20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,not_active ,20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,not active ,20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,not active ,20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,0 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,00 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,00 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,not_active ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,not active ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,0 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,00 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,00 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,not_active ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,not active ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,minimize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,127 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,127 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,08 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,Quittierungsfunktion1 ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,Blinken links aktiv ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,Blinken links Hellphase ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,minimize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,127 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,127 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,18 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,18 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,Quittierungsfunktion1 ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,Blinken rechts aktiv ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,Blinken rechts Hellphase ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,minimize ,20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,127 ,20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,0 ,20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,31 ,20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,0B ,20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,Rueckfahrlicht ,20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,not active ,20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,maximize ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,maximize ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,127 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,0 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,09 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,LED_Bremsleuchten ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Brake lamp ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,not active ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,maximize ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,maximize ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,127 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,0 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,19 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,LED_Bremsleuchten ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Brake lamp ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,not active ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,29 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,maximize ,20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,127 ,20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,29 ,20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,0A ,20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,Position lamps ,20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,Parking light left ,20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,not active ,20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,maximize ,20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,127 ,20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,1A ,20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,Position lamps ,20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,Parking light right ,20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,not active ,20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,0 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,28 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,not active ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,127 ,20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,0C ,20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,00 ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,127 ,20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,35 ,20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,0A ,20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,Position lamps ,20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,Parking light left ,20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,127 ,20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,36 ,20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,1A ,20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Position lamps ,20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,Parking light right ,20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,minimize ,20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,127 ,20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,0 ,20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,32 ,20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,1B ,20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,Rueckfahrlicht ,20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,not active ,20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr ,20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,100 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,00 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,Footwell lamp ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,0 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,00 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,not_active ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,not active ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,00 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,00 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,00 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,100 ,20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,0 ,20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,00 ,20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,00 ,20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,00 ,20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,00 ,20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,00 ,20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,00 ,20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,00 ,20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,00 ,20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,00 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,00 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,0 ,20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,0 ,20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,00 ,20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,00 ,20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,not_active ,20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,not active ,20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,not active ,20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,not active ,20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,not active ,20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,not active ,20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,00 ,20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,00 ,20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,00 ,20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,00 ,20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,00 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,00 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,00 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,00 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,85 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,00 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,aktiv100prozent ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,89 ,20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,00 ,20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,0 ,20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,0 ,20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,00 ,20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,00 ,20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,not_active ,20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,not active ,20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,not active ,20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,not active ,20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,not active ,20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,not active ,20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,0 ,20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,00 ,20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,00 ,20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,not_active ,20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,not active ,20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,not active ,20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,not active ,20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,maximize ,20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,0 ,20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,00 ,20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,00 ,20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,not_active ,20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,not active ,20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,not active ,20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,not active ,20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,0 ,20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,00 ,20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,not_active ,20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,not active ,20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,not active ,20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,0 ,20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,00 ,20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,not_active ,20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,not active ,20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,not active ,20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20
ENG253237-IDE03311-Licht Konfig-Abhängig-Emergency braking display,active ,4
ENG253237-IDE07470-Licht Konfig-Abhängig-After-run for park light,No_sidelights_delay ,4
ENG253237-ENG142020-Licht Konfig-Abhängig-All-weather light,installed ,4
ENG253237-ENG258575-Licht Konfig-Abhängig-Diskrete_SBBR_links,installed ,4
ENG253237-ENG259588-Licht Konfig-Abhängig-Diskrete_SBBR_rechts,installed ,4
ENG253237-ENG142191-Licht Konfig-Abhängig-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,4
ENG253237-ENG142190-Licht Konfig-Abhängig-Signaturlicht_verbaut,not installed ,4
ENG253374-ENG246963-Licht_bedienung-Anzeigezeit_LTM_PopUp1,4.0 s,12
ENG253374-ENG246964-Licht_bedienung-Anzeigezeit_LTM_PopUp1_lang,4 s,12
ENG253374-ENG246965-Licht_bedienung-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
ENG253374-ENG246966-Licht_bedienung-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
ENG253374-ENG246978-Licht_bedienung-Licht_anforderung_FAS,not installed ,12
ENG253374-ENG246979-Licht_bedienung-Licht_anforderung_Pilopark,not active ,12
ENG253374-ENG246980-Licht_bedienung-Licht_Reaktivierungs_grenze,95 m,12
ENG253374-ENG246981-Licht_bedienung-Lichttastermodul,LTM_Zentraltaste ,12
ENG253374-ENG246982-Licht_bedienung-LTM_Anzeige_Config,02 ,12
ENG253374-ENG246983-Licht_bedienung-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
ENG253374-ENG246984-Licht_bedienung-LTM_BGL_Geschwindigkeitsabhängig,active ,12
ENG253374-ENG246985-Licht_bedienung-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,12
ENG253374-ENG246986-Licht_bedienung-LTM_BGL_Wegabhängig,active ,12
ENG253374-ENG246987-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabhängig,active ,12
ENG253374-ENG246988-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,12
ENG253374-ENG246989-Licht_bedienung-LTM_GlobalOFF_Wegabhängig,active ,12
ENG253374-ENG246990-Licht_bedienung-LTM_GlobalOFF_Zündungsabhängig,not active ,12
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,INDIVIDUAL ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,installed ,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,not active ,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Rocker sw. ,2
ENG253158-LWR Basissoftware,15 %,16
ENG253042-IDE03638-LWR Konfiguration-Static cornering light,ECE R119 ,8
ENG253042-IDE03644-LWR Konfiguration-Highway light,activated ,8
ENG253042-MAS02922-LWR Konfiguration-City light,activated ,8
ENG253042-MAS07013-LWR Konfiguration-All-weather light,activated ,8
ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Verbundlenkerhinterachse ,8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,activated ,8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,activated ,8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,CAN automatic ,8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,1_sensor ,8
ENG253042-ENG171501-LWR Konfiguration-Market,ECE ,8
ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8
ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value,BCM ,8
ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8
ENG253084-MDK,00 ,4
ENG249798-MDK_coding-,00 ,8
ENG249798-ENG253476-MDK_coding-MDK_bBtle_COV,00 ,8
ENG249798-ENG253477-MDK_coding-MDK_bExtendedScActivation_COV,00 ,8
ENG253387-mdk_locking_coding,not installed ,3
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
ENG153902-NFC_FS_debug_switch,No Response From Subnet Component,8
ENG153904-NFC_MiKo_debug_switch,No Response From Subnet Component,8
ENG253222-NFC_MiKo_WLC_Functions-,No Response From Subnet Component,8
ENG253222-ENG253104-NFC_MiKo_WLC_Functions-NFC_MiKo_Attenuation_internal_BTLE_antenna,No Response From Subnet Component,8
ENG124714-ENG142044-OCU-DWA_push,active ,10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10
ENG124714-OCU-,installed ,10
ENG124714-ENG259569-OCU-Remote HuF,active ,10
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausführungsdauer,30 s,10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,10
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,50 dB,27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,2 s,27
ENG253220-Par_Bedienstellen,2 ,7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,255 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschließen,3200 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,345 cm,20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 ,20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,18
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,18
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125667-Passenger_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125666-Passenger_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125668-Passenger_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125673-Passenger_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125672-Passenger_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125674-Passenger_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125670-Passenger_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125669-Passenger_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125671-Passenger_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125676-Passenger_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125675-Passenger_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125677-Passenger_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125664-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125663-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125665-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125667-Passenger_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125666-Passenger_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125668-Passenger_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125673-Passenger_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125672-Passenger_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125674-Passenger_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125670-Passenger_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125669-Passenger_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125671-Passenger_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125676-Passenger_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125675-Passenger_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125677-Passenger_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125664-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125663-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125665-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125667-Passenger_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125666-Passenger_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125668-Passenger_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125673-Passenger_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125672-Passenger_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125674-Passenger_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125670-Passenger_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125669-Passenger_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125671-Passenger_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125676-Passenger_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125675-Passenger_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125677-Passenger_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125664-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125663-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125665-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,18
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,18
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,18
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,18
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,18
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,18
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,18
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,18
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,18
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,18
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,18
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,18
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,18
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,18
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,18
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,18
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,18
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,18
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,18
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,18
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,18
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,18
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,18
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,18
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,18
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,18
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,18
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,18
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,18
ENG286146-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,18
ENG286146-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,18
ENG286146-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,18
ENG286146-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,18
ENG286146-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,18
ENG286146-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,18
ENG286146-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,18
ENG286146-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,18
ENG286146-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,18
ENG286146-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,18
ENG286146-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,18
ENG286146-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,18
ENG286146-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,18
ENG286146-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,18
ENG286146-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,18
ENG286146-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,18
ENG286146-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,18
ENG286146-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,18
ENG286146-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,18
ENG286146-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,18
ENG286146-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,18
ENG286146-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,18
ENG286146-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,18
ENG286146-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,18
ENG286146-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,18
ENG286146-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,18
ENG286146-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,18
ENG286146-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,18
ENG286146-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,18
ENG286146-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,18
ENG286146-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,18
ENG286146-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,18
ENG286146-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,18
ENG286146-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,18
ENG286146-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,18
ENG286146-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,18
ENG286146-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,18
ENG286146-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,18
ENG286146-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,18
ENG286146-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,18
ENG286146-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,18
ENG286146-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,18
ENG286146-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,18
ENG286146-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,18
ENG286146-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,18
ENG286146-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,18
ENG286146-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,18
ENG286146-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,18
ENG286146-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,18
ENG286146-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,18
ENG286146-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,18
ENG286146-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,18
ENG286146-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,18
ENG286146-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,18
ENG286146-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,18
ENG286146-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,18
ENG286146-IDE80057-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,18
ENG286146-IDE80058-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,18
ENG286146-IDE80059-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,18
ENG286146-IDE80060-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,18
ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,18
ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,18
ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,18
ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,18
ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,18
ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,18
ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,18
ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,18
ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,18
ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,18
ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,18
ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,18
ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,18
ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,18
ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,18
ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,18
ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,18
ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,18
ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,18
ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,18
ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,18
ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,18
ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,18
ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,18
ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,18
ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,18
ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,18
ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,18
ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,18
ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,18
ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,18
ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,18
ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,18
ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,18
ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,18
ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,18
ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,18
ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,18
ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,18
ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,18
ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,18
ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,18
ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,18
ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,18
ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,18
ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,18
ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,18
ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,18
ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,18
ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,18
ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,18
ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,18
ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,18
ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,18
ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,18
ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,18
ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,18
ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,18
ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,18
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,not activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,not activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,not activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,not activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,not activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12
ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12
ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12
ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12
ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,Customization coded 2.x ,12
ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12
ENG253109-PSI5 Konfiguration,02 ,16
ENG253310-PSI5 Sensoren,Rear ,1
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,8
ENG141646-ENG281077-Querschnitts_funktionen-SubCAN weckt nur den BusMaster,not active ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG244881-ENG286173-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286174-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286175-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286176-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286177-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286178-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286179-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286180-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange{0},No Response From Subnet Component,8
ENG244881-ENG286181-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange{1},No Response From Subnet Component,8
ENG244881-ENG286182-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange{0},No Response From Subnet Component,8
ENG244881-ENG286183-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange{1},No Response From Subnet Component,8
ENG244881-ENG286184-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation{0},No Response From Subnet Component,8
ENG244881-ENG286185-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation{1},No Response From Subnet Component,8
ENG244881-ENG289577-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289578-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286188-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289579-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289580-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289581-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289582-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289583-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289584-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286195-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286196-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286197-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange{0},No Response From Subnet Component,8
ENG244881-ENG286198-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange{1},No Response From Subnet Component,8
ENG244881-ENG286199-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286200-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286201-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange{0},No Response From Subnet Component,8
ENG244881-ENG286202-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange{1},No Response From Subnet Component,8
ENG244881-ENG286203-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange{0},No Response From Subnet Component,8
ENG244881-ENG286204-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange{1},No Response From Subnet Component,8
ENG244881-ENG286205-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange{0},No Response From Subnet Component,8
ENG244881-ENG286206-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange{1},No Response From Subnet Component,8
ENG244881-ENG286207-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange{0},No Response From Subnet Component,8
ENG244881-ENG286208-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange{1},No Response From Subnet Component,8
ENG244881-ENG286209-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usCRC,No Response From Subnet Component,8
ENG244881-ENG289585-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289586-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286212-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286213-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286214-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286215-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286216-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286217-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286218-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange{0},No Response From Subnet Component,8
ENG244881-ENG286219-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange{1},No Response From Subnet Component,8
ENG244881-ENG286220-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286221-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange{0},No Response From Subnet Component,8
ENG244881-ENG286222-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange{1},No Response From Subnet Component,8
ENG244881-ENG286223-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange{0},No Response From Subnet Component,8
ENG244881-ENG286224-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange{1},No Response From Subnet Component,8
ENG244881-ENG286225-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation{0},No Response From Subnet Component,8
ENG244881-ENG286226-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation{1},No Response From Subnet Component,8
ENG244881-ENG289587-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289588-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286229-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289589-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289590-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289591-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289592-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289593-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289594-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286236-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286237-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286238-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange{0},No Response From Subnet Component,8
ENG244881-ENG286239-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange{1},No Response From Subnet Component,8
ENG244881-ENG286240-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange{0},No Response From Subnet Component,8
ENG244881-ENG286241-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange{1},No Response From Subnet Component,8
ENG244881-ENG286242-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange{0},No Response From Subnet Component,8
ENG244881-ENG286243-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange{1},No Response From Subnet Component,8
ENG244881-ENG286244-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange{0},No Response From Subnet Component,8
ENG244881-ENG286245-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange{1},No Response From Subnet Component,8
ENG244881-ENG286246-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange{0},No Response From Subnet Component,8
ENG244881-ENG286247-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange{1},No Response From Subnet Component,8
ENG244881-ENG286248-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange{0},No Response From Subnet Component,8
ENG244881-ENG286249-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange{1},No Response From Subnet Component,8
ENG244881-ENG286250-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usCRC,No Response From Subnet Component,8
ENG244881-ENG289595-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289596-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286253-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286254-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286262-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-padding,No Response From Subnet Component,8
ENG244881-ENG286271-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286272-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286273-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286274-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_{1},No Response From Subnet Component,8
ENG244881-ENG289612-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_High,No Response From Subnet Component,8
ENG244881-ENG289613-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_Low,No Response From Subnet Component,8
ENG244881-ENG286278-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_1_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286279-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286280-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286281-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio1_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286282-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286283-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286284-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{0},No Response From Subnet Component,8
ENG244881-ENG286285-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{1},No Response From Subnet Component,8
ENG244881-ENG286286-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{10},No Response From Subnet Component,8
ENG244881-ENG286287-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{11},No Response From Subnet Component,8
ENG244881-ENG286288-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{12},No Response From Subnet Component,8
ENG244881-ENG286289-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{13},No Response From Subnet Component,8
ENG244881-ENG286290-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{14},No Response From Subnet Component,8
ENG244881-ENG286291-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{15},No Response From Subnet Component,8
ENG244881-ENG286292-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{16},No Response From Subnet Component,8
ENG244881-ENG286293-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{17},No Response From Subnet Component,8
ENG244881-ENG286294-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{18},No Response From Subnet Component,8
ENG244881-ENG286295-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{19},No Response From Subnet Component,8
ENG244881-ENG286296-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{2},No Response From Subnet Component,8
ENG244881-ENG286297-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{20},No Response From Subnet Component,8
ENG244881-ENG286298-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{21},No Response From Subnet Component,8
ENG244881-ENG286299-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{22},No Response From Subnet Component,8
ENG244881-ENG286300-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{23},No Response From Subnet Component,8
ENG244881-ENG286301-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{24},No Response From Subnet Component,8
ENG244881-ENG286302-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{25},No Response From Subnet Component,8
ENG244881-ENG286303-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{26},No Response From Subnet Component,8
ENG244881-ENG286304-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{27},No Response From Subnet Component,8
ENG244881-ENG286305-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{28},No Response From Subnet Component,8
ENG244881-ENG286306-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{29},No Response From Subnet Component,8
ENG244881-ENG286307-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{3},No Response From Subnet Component,8
ENG244881-ENG286308-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{30},No Response From Subnet Component,8
ENG244881-ENG286309-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{31},No Response From Subnet Component,8
ENG244881-ENG286310-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{32},No Response From Subnet Component,8
ENG244881-ENG286311-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{33},No Response From Subnet Component,8
ENG244881-ENG286312-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{34},No Response From Subnet Component,8
ENG244881-ENG286313-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{35},No Response From Subnet Component,8
ENG244881-ENG286314-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{36},No Response From Subnet Component,8
ENG244881-ENG286315-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{37},No Response From Subnet Component,8
ENG244881-ENG286316-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{38},No Response From Subnet Component,8
ENG244881-ENG286317-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{39},No Response From Subnet Component,8
ENG244881-ENG286318-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{4},No Response From Subnet Component,8
ENG244881-ENG286319-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{40},No Response From Subnet Component,8
ENG244881-ENG286320-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{41},No Response From Subnet Component,8
ENG244881-ENG286321-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{42},No Response From Subnet Component,8
ENG244881-ENG286322-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{43},No Response From Subnet Component,8
ENG244881-ENG286323-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{44},No Response From Subnet Component,8
ENG244881-ENG286324-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{45},No Response From Subnet Component,8
ENG244881-ENG286325-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{46},No Response From Subnet Component,8
ENG244881-ENG286326-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{47},No Response From Subnet Component,8
ENG244881-ENG286327-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{48},No Response From Subnet Component,8
ENG244881-ENG286328-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{49},No Response From Subnet Component,8
ENG244881-ENG286329-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{5},No Response From Subnet Component,8
ENG244881-ENG286330-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{50},No Response From Subnet Component,8
ENG244881-ENG286331-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{51},No Response From Subnet Component,8
ENG244881-ENG286332-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{52},No Response From Subnet Component,8
ENG244881-ENG286333-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{53},No Response From Subnet Component,8
ENG244881-ENG286334-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{54},No Response From Subnet Component,8
ENG244881-ENG286335-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{55},No Response From Subnet Component,8
ENG244881-ENG286336-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{56},No Response From Subnet Component,8
ENG244881-ENG286337-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{57},No Response From Subnet Component,8
ENG244881-ENG286338-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{58},No Response From Subnet Component,8
ENG244881-ENG286339-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{59},No Response From Subnet Component,8
ENG244881-ENG286340-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{6},No Response From Subnet Component,8
ENG244881-ENG286341-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{60},No Response From Subnet Component,8
ENG244881-ENG286342-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{61},No Response From Subnet Component,8
ENG244881-ENG286343-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{62},No Response From Subnet Component,8
ENG244881-ENG286344-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{63},No Response From Subnet Component,8
ENG244881-ENG286345-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{64},No Response From Subnet Component,8
ENG244881-ENG286346-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{65},No Response From Subnet Component,8
ENG244881-ENG286347-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{7},No Response From Subnet Component,8
ENG244881-ENG286348-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{8},No Response From Subnet Component,8
ENG244881-ENG286349-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff{9},No Response From Subnet Component,8
ENG244881-ENG289614-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Retry_Timeout,No Response From Subnet Component,8
ENG244881-ENG289615-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Sent_Time,No Response From Subnet Component,8
ENG244881-ENG286353-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Algo_Time_Out,No Response From Subnet Component,8
ENG244881-ENG286354-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_1,No Response From Subnet Component,8
ENG244881-ENG289616-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_2,No Response From Subnet Component,8
ENG244881-ENG286355-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_1,No Response From Subnet Component,8
ENG244881-ENG286356-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_2,No Response From Subnet Component,8
ENG244881-ENG286357-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_3,No Response From Subnet Component,8
ENG244881-ENG286358-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_4,No Response From Subnet Component,8
ENG244881-ENG286359-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Fahrzeugtyp,No Response From Subnet Component,8
ENG244881-ENG286360-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Padding,No Response From Subnet Component,8
ENG244881-ENG286361-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{0},No Response From Subnet Component,8
ENG244881-ENG286362-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{01},No Response From Subnet Component,8
ENG244881-ENG286363-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{2},No Response From Subnet Component,8
ENG244881-ENG286364-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{3},No Response From Subnet Component,8
ENG244881-ENG286365-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{4},No Response From Subnet Component,8
ENG244881-ENG286366-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{5},No Response From Subnet Component,8
ENG244881-ENG286367-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{6},No Response From Subnet Component,8
ENG244881-ENG286368-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{7},No Response From Subnet Component,8
ENG244881-ENG286369-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{8},No Response From Subnet Component,8
ENG244881-ENG286370-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_{9},No Response From Subnet Component,8
ENG244881-ENG286371-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286372-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286373-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286374-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286375-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_{0},No Response From Subnet Component,8
ENG244881-ENG286376-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286377-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ucPoly_FeatureNumber,No Response From Subnet Component,8
ENG244881-ENG286378-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ul_CRC,No Response From Subnet Component,8
ENG244881-ENG286380-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_0,No Response From Subnet Component,8
ENG244881-ENG286381-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_1,No Response From Subnet Component,8
ENG244881-ENG286382-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa Time_Diff_Range_{1},No Response From Subnet Component,8
ENG244881-ENG286383-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa_Time_Diff_Range_{0},No Response From Subnet Component,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,not installed ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,not installed ,3
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,3
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,3
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,3
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an über Geschwindigkeit,Master steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,On ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,80% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,80% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,LIN ,3
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,5
ENG253157-roof_module,installed ,1
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,not installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG116647-Schiebedach_ZV-SAD Komfort oeffnen,active ,6
ENG253336-ENG289611-Schiebedach_ZV-SAD Komfort_oeffnungs_modus,tilting ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schlüsselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schlüsselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schlüsselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG277093-Schlüsselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31
ENG253118-ENG126945-Schlüsselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31
ENG253118-ENG129003-Schlüsselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schlüsselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG126939-Schlüsselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31
ENG253118-ENG126946-Schlüsselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schlüsselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253264-Seat_cushion_fan,not installed ,1
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,not installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,not installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,3 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,3 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,100 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,50 ms,48
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,60 s,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,not active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,not active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,active ,3
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,0 °C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,0 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,-100 °C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-100 °C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG253353-ENG260527-Störungsmeldungen Licht/Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG253353-ENG260368-Störungsmeldungen Licht/Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG253353-ENG260726-Störungsmeldungen Licht/Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,6.9 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,1.8 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,100.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,100.0 ,8
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,100.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10
ENG249751-Two_keys,active ,3
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG252991-Vehicle configuration,activated ,1
ENG253245-ENG261297-verbauliste_subcan-Digitale Dachantenne,installed ,4
ENG253245-ENG260575-verbauliste_subcan-nfc_miko,not installed ,4
ENG253245-ENG260904-verbauliste_subcan-nfc_tgs,not installed ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6
ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,6
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,6
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,6
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,6
ENG253327-ENG277083-Verlassenswarnung und Standlichtnachlauf-Ausgabedauer Wegrollwarnung,10 s,8
ENG253327-ENG261189-Verlassenswarnung und Standlichtnachlauf-Ausgabeverhalten Verlassenswarnung,VLW mit VLK2.2 Kriterien ,8
ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Verlassenswarnung,1.4 s,8
ENG253327-ENG277084-Verlassenswarnung und Standlichtnachlauf-Ausgabeverzögerung der Wegrollwarnung,1.0 s,8
ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8
ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8
ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8
ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8
ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Standlichtnachlauf,active ,8
ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verfügbarkeit Verlassenswarnung,not equippt ,8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,not installed ,8
ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,not installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,not active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,not active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,not active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,0 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,not installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,not installed ,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,not installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,not installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,0 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,00 00 00 00 ,4
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG281049-ENG263583-Zündungswarnung und Antrieb-Aktiv-Warnung-Ausgabe MoLaWa_AAW,active ,8
ENG281049-ENG263581-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellung_MoLaWa,1.5 ,8
ENG281049-ENG263504-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.8 s,8
ENG281049-ENG281097-Zündungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswecsel nicht Belegt zu Belegt,0.0 s,8
ENG281049-ENG263576-Zündungswarnung und Antrieb-Aktiv-Warnung-Freigabeentprellung Abschaltung nach EM,60 s,8
ENG281049-ENG263531-Zündungswarnung und Antrieb-Aktiv-Warnung-Unterdrückung der Zündungswarnung,active ,8
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,not active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale_Entriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,not active ,6
ENG141653-ENG258544-ZV Heck-eingeschränkte_Freigabe_HD_Innentaste,not active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,not installed ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschließen_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,not active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schließen,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.0 s,7
ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,none ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,No ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,none ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,No ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5
ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5
ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,not installed ,5
ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,not installed ,5
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,not active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,not active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,not active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,active ,6
ENG141652-ENG258598-ZV Türkonfiguration-Fzg_mit_Vier_Tueren,Yes ,2
ENG141652-ENG260173-ZV Türkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,2
ENG141652-ENG258913-ZV Türkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,not active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263484-ENG263546-ZV_HW_Router-PIN_A11,Tür HL verriegeln oder Laderaumabdeckung links ,5
ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenrückmeldung ,5
ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5
ENG263484-ENG263567-ZV_HW_Router-PIN_A33,Tür HR Verriegelung/Safe oder Verdeck zu ,5
ENG263484-ENG263596-ZV_HW_Router-PIN_A35,Tür HL Verriegelung/Safe ,5
ENG263484-ENG263575-ZV_HW_Router-PIN_A48,Tür HR TK-Signal ,5
ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Taste Heckdeckelentriegelung ,5
ENG263484-ENG263547-ZV_HW_Router-PIN_A50,Tür HL TK-Signal ,5
ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5
ENG263484-ENG263545-ZV_HW_Router-PIN_A7,Tür HR verriegeln oder Laderaumabdeckung rechts ,5
ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Funktions-LED Taste3 ,5
ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Funktions-LED Taste4 ,5
ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Cockpit-Taste 3 ,5
ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,No ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,not active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,not active ,5
ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,not active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 03:34
adpmap-10-5R3-919-294_WVWZZZCD6RW123439-20260903-1803.CSV
;SW:5R3-919-294   HW:5R3-919-294 ---  10: Park/Steer Assist
;Component:PDC 08 Kanal  H05 1550, Coding:0040010001
;EV_EPHVA18VW3800000,002036,EV_EPHVA18VW3800000_VW38.rod
;Thursday,03,September,2026,18:03:31:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 7CA1F2D8666C245ABB8-8028
IDE00845-Wheel circumference,1970 mm,2
IDE01165-Park assist activation tone,OFF ,1
IDE01167-Convertible offset for volume level 1,22 ,1
IDE02329-Allowance for vehicle fittings (width),0 cm,1
IDE02333-Allowance for vehicle fittings (length),0 cm,1
IDE14666-Parking aid: personalization,activated ,1
MAS05448-Vehicle path display,activated ,1
MAS07110-Muting of audio sources,Security access required,1
MAS12843-Maneuvering brake function,Security access required,1
MAS21139-MAS21140-Manually determined wheel sizes-Manually determined tire size front left,1932 mm,8
MAS21139-MAS21141-Manually determined wheel sizes-Manually determined tire size front right,1932 mm,8
MAS21139-MAS21142-Manually determined wheel sizes-Manually determined tire size rear left,1940 mm,8
MAS21139-MAS21143-Manually determined wheel sizes-Manually determined tire size rear right,1941 mm,8
Elapsed Time: 00:03
adpmap-13-5WA-907-572-C_WVWZZZCD6RW123439-20260903-1803.CSV
;SW:5WA-907-572-C   HW:5WA-907-572-A ---  13: Auto Dist. Reg
;Component:ACC BOSCH MQB H45 0461, Coding:010310F5000740451247400800C040C44E4020000000000000000000000000
;EV_FRONTRADARBOSCHVW380,004021,EV_FRONTRADARBOSCHVW380_004_VW38.rod
;Thursday,03,September,2026,18:03:55:29755
;VCID: 4EC56810805066CA25C-801A
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,Security access required,3
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,Security access required,3
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,Security access required,3
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,Security access required,3
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,Security access required,3
IDE01949-Distance basic setting option,On ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,On ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE12516-Predictive speed limit regulation,activated ,1
IDE15695-Front radar-based localization,activated ,1
MAS19336-Active participant function activated,Deactivated ,1
ENG253321-Monitoring_and_FRKL_masking,General reject,1
Elapsed Time: 00:04
adpmap-15-5WA-959-655-L_WVWZZZCD6RW123439-20260903-1804.CSV
;SW:5WA-959-655-L   HW:5WA-959-655-L ---  15: Airbags
;Component:AirbagVW40    010 0636, Coding:88CC008000F0C000000000000000000051540000205400004000F68000130065
;EV_AirbaVW40SMEVW38X,001032,EV_AirbaVW40SMEVW38X.rod
;Thursday,03,September,2026,18:04:24:29755
;VCID: 6099A6A8EAC4E0BA870-8034 SFD { }
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE05178-Conclude start of operation,locked ,1
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,activated ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE00947-Airbag adaptations-Rear driver head curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Rear passenger head curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Front driver side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Front passenger active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch installed ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection passenger side,activated ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:11
adpmap-17-5H0-920-340-C_WVWZZZCD6RW123439-20260903-1752.CSV
;SW:5H0-920-340-C   HW:5H0-920-340-C ---  17: Instruments
;Component:KOMBI         310 7380, Coding:04A4000063840008018062032000080800300800
;EV_DashBoardVDDMQB37W,003035,EV_DashBoardVDDMQB37W_003_VW38.rod
;Thursday,03,September,2026,17:52:28:29755
;VCID: 221DECA0A448B2AAD14-8076 SFD { }
IDE00301-Distance,18974 km,3
IDE00343-Language variant,slovenian ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1052 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02332-Disable Production Mode,0 ,3
IDE02489-Display depiction,Variant 1 ,1
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,30 ,2
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,OFF ,5
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12722-Configuration of displayable contents-Driving profile display,No display ,4
IDE11472-MAS01833-Configuration of displayable contents-Charge air pressure,not active ,4
IDE11472-MAS03555-Configuration of displayable contents-Lap counter,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS05757-Configuration of displayable contents-Engine torque,not active ,4
IDE11472-MAS14767-Configuration of displayable contents-Convenience tire pressure warning display,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE11472-MAS19327-Configuration of displayable contents-Engine performance,not active ,4
IDE11472-MAS19328-Configuration of displayable contents-Transmission temperature,not active ,4
IDE11472-MAS19329-Configuration of displayable contents-G-meter,not active ,4
IDE11472-MAS19330-Configuration of displayable contents-Torque distribution,not active ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12792-IDE00301-Personalization of user account 1-Distance,Kilometres ,70
IDE12792-MAS01230-Personalization of user account 1-Date,dd_mm_yy ,70
IDE12792-MAS01456-Personalization of user account 1-Speed,Kilometers per hour ,70
IDE12792-MAS02201-Personalization of user account 1-Temperature,°C ,70
IDE12792-MAS02957-Personalization of user account 1-Time,24h ,70
IDE12792-MAS03032-Personalization of user account 1-Volume,litre ,70
IDE12792-MAS03034-Personalization of user account 1-Pressure,bar ,70
IDE12792-MAS05637-Personalization of user account 1-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12792-MAS05638-Personalization of user account 1-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12792-MAS05875-Personalization of user account 1-Average consumption: electric drive,kWh per 100 km ,70
IDE12792-Personalization of user account 1-,not active ,70
IDE12792-ENG154881-Personalization of user account 1-Active_design,0 ,70
IDE12792-ENG154882-Personalization of user account 1-Active_view,0 ,70
IDE12792-ENG155000-Personalization of user account 1-DC_aktiverSpeicherplatz,0 ,70
IDE12792-ENG155001-Personalization of user account 1-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12792-ENG155002-Personalization of user account 1-DC_linkeTubeninformation,00 ,70
IDE12792-ENG155003-Personalization of user account 1-DC_rechteTubeninformation,00 ,70
IDE12792-ENG155004-Personalization of user account 1-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155005-Personalization of user account 1-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155006-Personalization of user account 1-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155007-Personalization of user account 1-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155008-Personalization of user account 1-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155009-Personalization of user account 1-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155051-Personalization of user account 1-Display_Average_Consumption,active ,70
IDE12792-ENG155052-Personalization of user account 1-Display_Average_Speed,active ,70
IDE12792-ENG155053-Personalization of user account 1-Display_ComfortPowerConsumption,not active ,70
IDE12792-ENG155054-Personalization of user account 1-Display_ConsumerList,not active ,70
IDE12792-ENG155055-Personalization of user account 1-Display_CoolantTemperature,not active ,70
IDE12792-ENG155056-Personalization of user account 1-Display_CurrentConsumption,active ,70
IDE12792-ENG155057-Personalization of user account 1-Display_DigitalSpeedometer,active ,70
IDE12792-ENG155058-Personalization of user account 1-Display_Distance,active ,70
IDE12792-ENG155059-Personalization of user account 1-Display_DrivingTime,active ,70
IDE12792-ENG155060-Personalization of user account 1-Display_DualSpeedometer,not active ,70
IDE12792-ENG155061-Personalization of user account 1-Display_Laptimer,not active ,70
IDE12792-ENG155062-Personalization of user account 1-Display_LiveTips,not active ,70
IDE12792-ENG155063-Personalization of user account 1-Display_Nachtankmenge,not active ,70
IDE12792-ENG155064-Personalization of user account 1-Display_OilTemperature,active ,70
IDE12792-ENG155065-Personalization of user account 1-Display_Range,active ,70
IDE12792-ENG155066-Personalization of user account 1-Display_ResetTime,not active ,70
IDE12792-ENG155067-Personalization of user account 1-Display_SpeedWarning,not active ,70
IDE12792-ENG155068-Personalization of user account 1-Display_VZA,active ,70
IDE12792-ENG155069-Personalization of user account 1-Display_ZeroEmission_Distance,not active ,70
IDE12792-ENG155070-Personalization of user account 1-Display_ZeroEmission_Time,not active ,70
IDE12792-ENG155246-Personalization of user account 1-LastMode_HMI_global_active_layout,0 ,70
IDE12792-ENG155247-Personalization of user account 1-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12792-ENG155248-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12792-ENG155249-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12792-ENG155250-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12792-ENG155251-Personalization of user account 1-LastMode_HMI_HistoryState_main,0 ,70
IDE12792-ENG155252-Personalization of user account 1-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12792-ENG155253-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12792-ENG155254-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12792-ENG155255-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12792-ENG155256-Personalization of user account 1-LastMode_HMI_HistoryState_sport,0 ,70
IDE12792-ENG155257-Personalization of user account 1-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12792-ENG155258-Personalization of user account 1-LastMode_HMI_MFA_store,0 ,70
IDE12792-ENG155259-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12792-ENG155260-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12792-ENG155261-Personalization of user account 1-LastMode_v_Kunde_aktiv,not active ,70
IDE12792-ENG155262-Personalization of user account 1-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12792-ENG155263-Personalization of user account 1-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12792-ENG262859-Personalization of user account 1-speed_value,0 ,70
IDE12792-ENG263509-Personalization of user account 1-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12794-IDE00301-Personalization of user account 2-Distance,Kilometres ,70
IDE12794-MAS01230-Personalization of user account 2-Date,dd_mm_yy ,70
IDE12794-MAS01456-Personalization of user account 2-Speed,Kilometers per hour ,70
IDE12794-MAS02201-Personalization of user account 2-Temperature,°C ,70
IDE12794-MAS02957-Personalization of user account 2-Time,24h ,70
IDE12794-MAS03032-Personalization of user account 2-Volume,litre ,70
IDE12794-MAS03034-Personalization of user account 2-Pressure,bar ,70
IDE12794-MAS05637-Personalization of user account 2-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12794-MAS05638-Personalization of user account 2-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12794-MAS05875-Personalization of user account 2-Average consumption: electric drive,kWh per 100 km ,70
IDE12794-Personalization of user account 2-,not active ,70
IDE12794-ENG154881-Personalization of user account 2-Active_design,0 ,70
IDE12794-ENG154882-Personalization of user account 2-Active_view,0 ,70
IDE12794-ENG155000-Personalization of user account 2-DC_aktiverSpeicherplatz,0 ,70
IDE12794-ENG155001-Personalization of user account 2-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12794-ENG155002-Personalization of user account 2-DC_linkeTubeninformation,00 ,70
IDE12794-ENG155003-Personalization of user account 2-DC_rechteTubeninformation,00 ,70
IDE12794-ENG155004-Personalization of user account 2-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155005-Personalization of user account 2-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155006-Personalization of user account 2-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155007-Personalization of user account 2-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155008-Personalization of user account 2-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155009-Personalization of user account 2-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155051-Personalization of user account 2-Display_Average_Consumption,active ,70
IDE12794-ENG155052-Personalization of user account 2-Display_Average_Speed,active ,70
IDE12794-ENG155053-Personalization of user account 2-Display_ComfortPowerConsumption,not active ,70
IDE12794-ENG155054-Personalization of user account 2-Display_ConsumerList,not active ,70
IDE12794-ENG155055-Personalization of user account 2-Display_CoolantTemperature,not active ,70
IDE12794-ENG155056-Personalization of user account 2-Display_CurrentConsumption,active ,70
IDE12794-ENG155057-Personalization of user account 2-Display_DigitalSpeedometer,active ,70
IDE12794-ENG155058-Personalization of user account 2-Display_Distance,active ,70
IDE12794-ENG155059-Personalization of user account 2-Display_DrivingTime,active ,70
IDE12794-ENG155060-Personalization of user account 2-Display_DualSpeedometer,not active ,70
IDE12794-ENG155061-Personalization of user account 2-Display_Laptimer,not active ,70
IDE12794-ENG155062-Personalization of user account 2-Display_LiveTips,not active ,70
IDE12794-ENG155063-Personalization of user account 2-Display_Nachtankmenge,not active ,70
IDE12794-ENG155064-Personalization of user account 2-Display_OilTemperature,active ,70
IDE12794-ENG155065-Personalization of user account 2-Display_Range,active ,70
IDE12794-ENG155066-Personalization of user account 2-Display_ResetTime,not active ,70
IDE12794-ENG155067-Personalization of user account 2-Display_SpeedWarning,not active ,70
IDE12794-ENG155068-Personalization of user account 2-Display_VZA,active ,70
IDE12794-ENG155069-Personalization of user account 2-Display_ZeroEmission_Distance,not active ,70
IDE12794-ENG155070-Personalization of user account 2-Display_ZeroEmission_Time,not active ,70
IDE12794-ENG155246-Personalization of user account 2-LastMode_HMI_global_active_layout,0 ,70
IDE12794-ENG155247-Personalization of user account 2-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12794-ENG155248-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12794-ENG155249-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12794-ENG155250-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12794-ENG155251-Personalization of user account 2-LastMode_HMI_HistoryState_main,0 ,70
IDE12794-ENG155252-Personalization of user account 2-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12794-ENG155253-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12794-ENG155254-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12794-ENG155255-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12794-ENG155256-Personalization of user account 2-LastMode_HMI_HistoryState_sport,0 ,70
IDE12794-ENG155257-Personalization of user account 2-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12794-ENG155258-Personalization of user account 2-LastMode_HMI_MFA_store,0 ,70
IDE12794-ENG155259-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12794-ENG155260-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12794-ENG155261-Personalization of user account 2-LastMode_v_Kunde_aktiv,not active ,70
IDE12794-ENG155262-Personalization of user account 2-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12794-ENG155263-Personalization of user account 2-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12794-ENG262859-Personalization of user account 2-speed_value,0 ,70
IDE12794-ENG263509-Personalization of user account 2-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12796-IDE00301-Personalization of user account 3-Distance,Kilometres ,70
IDE12796-MAS01230-Personalization of user account 3-Date,dd_mm_yy ,70
IDE12796-MAS01456-Personalization of user account 3-Speed,Kilometers per hour ,70
IDE12796-MAS02201-Personalization of user account 3-Temperature,°C ,70
IDE12796-MAS02957-Personalization of user account 3-Time,24h ,70
IDE12796-MAS03032-Personalization of user account 3-Volume,litre ,70
IDE12796-MAS03034-Personalization of user account 3-Pressure,bar ,70
IDE12796-MAS05637-Personalization of user account 3-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12796-MAS05638-Personalization of user account 3-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12796-MAS05875-Personalization of user account 3-Average consumption: electric drive,kWh per 100 km ,70
IDE12796-Personalization of user account 3-,not active ,70
IDE12796-ENG154881-Personalization of user account 3-Active_design,0 ,70
IDE12796-ENG154882-Personalization of user account 3-Active_view,0 ,70
IDE12796-ENG155000-Personalization of user account 3-DC_aktiverSpeicherplatz,0 ,70
IDE12796-ENG155001-Personalization of user account 3-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12796-ENG155002-Personalization of user account 3-DC_linkeTubeninformation,00 ,70
IDE12796-ENG155003-Personalization of user account 3-DC_rechteTubeninformation,00 ,70
IDE12796-ENG155004-Personalization of user account 3-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155005-Personalization of user account 3-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155006-Personalization of user account 3-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155007-Personalization of user account 3-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155008-Personalization of user account 3-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155009-Personalization of user account 3-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155051-Personalization of user account 3-Display_Average_Consumption,active ,70
IDE12796-ENG155052-Personalization of user account 3-Display_Average_Speed,active ,70
IDE12796-ENG155053-Personalization of user account 3-Display_ComfortPowerConsumption,not active ,70
IDE12796-ENG155054-Personalization of user account 3-Display_ConsumerList,not active ,70
IDE12796-ENG155055-Personalization of user account 3-Display_CoolantTemperature,not active ,70
IDE12796-ENG155056-Personalization of user account 3-Display_CurrentConsumption,active ,70
IDE12796-ENG155057-Personalization of user account 3-Display_DigitalSpeedometer,active ,70
IDE12796-ENG155058-Personalization of user account 3-Display_Distance,active ,70
IDE12796-ENG155059-Personalization of user account 3-Display_DrivingTime,active ,70
IDE12796-ENG155060-Personalization of user account 3-Display_DualSpeedometer,not active ,70
IDE12796-ENG155061-Personalization of user account 3-Display_Laptimer,not active ,70
IDE12796-ENG155062-Personalization of user account 3-Display_LiveTips,not active ,70
IDE12796-ENG155063-Personalization of user account 3-Display_Nachtankmenge,not active ,70
IDE12796-ENG155064-Personalization of user account 3-Display_OilTemperature,active ,70
IDE12796-ENG155065-Personalization of user account 3-Display_Range,active ,70
IDE12796-ENG155066-Personalization of user account 3-Display_ResetTime,not active ,70
IDE12796-ENG155067-Personalization of user account 3-Display_SpeedWarning,not active ,70
IDE12796-ENG155068-Personalization of user account 3-Display_VZA,active ,70
IDE12796-ENG155069-Personalization of user account 3-Display_ZeroEmission_Distance,not active ,70
IDE12796-ENG155070-Personalization of user account 3-Display_ZeroEmission_Time,not active ,70
IDE12796-ENG155246-Personalization of user account 3-LastMode_HMI_global_active_layout,0 ,70
IDE12796-ENG155247-Personalization of user account 3-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12796-ENG155248-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12796-ENG155249-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12796-ENG155250-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12796-ENG155251-Personalization of user account 3-LastMode_HMI_HistoryState_main,0 ,70
IDE12796-ENG155252-Personalization of user account 3-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12796-ENG155253-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12796-ENG155254-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12796-ENG155255-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12796-ENG155256-Personalization of user account 3-LastMode_HMI_HistoryState_sport,0 ,70
IDE12796-ENG155257-Personalization of user account 3-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12796-ENG155258-Personalization of user account 3-LastMode_HMI_MFA_store,0 ,70
IDE12796-ENG155259-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12796-ENG155260-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12796-ENG155261-Personalization of user account 3-LastMode_v_Kunde_aktiv,not active ,70
IDE12796-ENG155262-Personalization of user account 3-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12796-ENG155263-Personalization of user account 3-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12796-ENG262859-Personalization of user account 3-speed_value,0 ,70
IDE12796-ENG263509-Personalization of user account 3-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12798-IDE00301-Personalization of user account 4-Distance,Kilometres ,70
IDE12798-MAS01230-Personalization of user account 4-Date,dd_mm_yy ,70
IDE12798-MAS01456-Personalization of user account 4-Speed,Kilometers per hour ,70
IDE12798-MAS02201-Personalization of user account 4-Temperature,°C ,70
IDE12798-MAS02957-Personalization of user account 4-Time,24h ,70
IDE12798-MAS03032-Personalization of user account 4-Volume,litre ,70
IDE12798-MAS03034-Personalization of user account 4-Pressure,bar ,70
IDE12798-MAS05637-Personalization of user account 4-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12798-MAS05638-Personalization of user account 4-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12798-MAS05875-Personalization of user account 4-Average consumption: electric drive,kWh per 100 km ,70
IDE12798-Personalization of user account 4-,not active ,70
IDE12798-ENG154881-Personalization of user account 4-Active_design,0 ,70
IDE12798-ENG154882-Personalization of user account 4-Active_view,0 ,70
IDE12798-ENG155000-Personalization of user account 4-DC_aktiverSpeicherplatz,0 ,70
IDE12798-ENG155001-Personalization of user account 4-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12798-ENG155002-Personalization of user account 4-DC_linkeTubeninformation,00 ,70
IDE12798-ENG155003-Personalization of user account 4-DC_rechteTubeninformation,00 ,70
IDE12798-ENG155004-Personalization of user account 4-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155005-Personalization of user account 4-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155006-Personalization of user account 4-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155007-Personalization of user account 4-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155008-Personalization of user account 4-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155009-Personalization of user account 4-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155051-Personalization of user account 4-Display_Average_Consumption,active ,70
IDE12798-ENG155052-Personalization of user account 4-Display_Average_Speed,active ,70
IDE12798-ENG155053-Personalization of user account 4-Display_ComfortPowerConsumption,not active ,70
IDE12798-ENG155054-Personalization of user account 4-Display_ConsumerList,not active ,70
IDE12798-ENG155055-Personalization of user account 4-Display_CoolantTemperature,not active ,70
IDE12798-ENG155056-Personalization of user account 4-Display_CurrentConsumption,active ,70
IDE12798-ENG155057-Personalization of user account 4-Display_DigitalSpeedometer,active ,70
IDE12798-ENG155058-Personalization of user account 4-Display_Distance,active ,70
IDE12798-ENG155059-Personalization of user account 4-Display_DrivingTime,active ,70
IDE12798-ENG155060-Personalization of user account 4-Display_DualSpeedometer,not active ,70
IDE12798-ENG155061-Personalization of user account 4-Display_Laptimer,not active ,70
IDE12798-ENG155062-Personalization of user account 4-Display_LiveTips,not active ,70
IDE12798-ENG155063-Personalization of user account 4-Display_Nachtankmenge,not active ,70
IDE12798-ENG155064-Personalization of user account 4-Display_OilTemperature,active ,70
IDE12798-ENG155065-Personalization of user account 4-Display_Range,active ,70
IDE12798-ENG155066-Personalization of user account 4-Display_ResetTime,not active ,70
IDE12798-ENG155067-Personalization of user account 4-Display_SpeedWarning,not active ,70
IDE12798-ENG155068-Personalization of user account 4-Display_VZA,active ,70
IDE12798-ENG155069-Personalization of user account 4-Display_ZeroEmission_Distance,not active ,70
IDE12798-ENG155070-Personalization of user account 4-Display_ZeroEmission_Time,not active ,70
IDE12798-ENG155246-Personalization of user account 4-LastMode_HMI_global_active_layout,0 ,70
IDE12798-ENG155247-Personalization of user account 4-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12798-ENG155248-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12798-ENG155249-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12798-ENG155250-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12798-ENG155251-Personalization of user account 4-LastMode_HMI_HistoryState_main,0 ,70
IDE12798-ENG155252-Personalization of user account 4-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12798-ENG155253-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12798-ENG155254-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12798-ENG155255-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12798-ENG155256-Personalization of user account 4-LastMode_HMI_HistoryState_sport,0 ,70
IDE12798-ENG155257-Personalization of user account 4-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12798-ENG155258-Personalization of user account 4-LastMode_HMI_MFA_store,0 ,70
IDE12798-ENG155259-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12798-ENG155260-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12798-ENG155261-Personalization of user account 4-LastMode_v_Kunde_aktiv,not active ,70
IDE12798-ENG155262-Personalization of user account 4-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12798-ENG155263-Personalization of user account 4-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12798-ENG262859-Personalization of user account 4-speed_value,0 ,70
IDE12798-ENG263509-Personalization of user account 4-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12800-IDE00301-Personalization of user account 5-Distance,Kilometres ,70
IDE12800-MAS01230-Personalization of user account 5-Date,dd_mm_yy ,70
IDE12800-MAS01456-Personalization of user account 5-Speed,Kilometers per hour ,70
IDE12800-MAS02201-Personalization of user account 5-Temperature,°C ,70
IDE12800-MAS02957-Personalization of user account 5-Time,24h ,70
IDE12800-MAS03032-Personalization of user account 5-Volume,litre ,70
IDE12800-MAS03034-Personalization of user account 5-Pressure,bar ,70
IDE12800-MAS05637-Personalization of user account 5-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12800-MAS05638-Personalization of user account 5-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12800-MAS05875-Personalization of user account 5-Average consumption: electric drive,kWh per 100 km ,70
IDE12800-Personalization of user account 5-,not active ,70
IDE12800-ENG154881-Personalization of user account 5-Active_design,0 ,70
IDE12800-ENG154882-Personalization of user account 5-Active_view,0 ,70
IDE12800-ENG155000-Personalization of user account 5-DC_aktiverSpeicherplatz,0 ,70
IDE12800-ENG155001-Personalization of user account 5-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12800-ENG155002-Personalization of user account 5-DC_linkeTubeninformation,00 ,70
IDE12800-ENG155003-Personalization of user account 5-DC_rechteTubeninformation,00 ,70
IDE12800-ENG155004-Personalization of user account 5-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155005-Personalization of user account 5-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155006-Personalization of user account 5-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155007-Personalization of user account 5-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155008-Personalization of user account 5-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155009-Personalization of user account 5-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155051-Personalization of user account 5-Display_Average_Consumption,active ,70
IDE12800-ENG155052-Personalization of user account 5-Display_Average_Speed,active ,70
IDE12800-ENG155053-Personalization of user account 5-Display_ComfortPowerConsumption,not active ,70
IDE12800-ENG155054-Personalization of user account 5-Display_ConsumerList,not active ,70
IDE12800-ENG155055-Personalization of user account 5-Display_CoolantTemperature,not active ,70
IDE12800-ENG155056-Personalization of user account 5-Display_CurrentConsumption,active ,70
IDE12800-ENG155057-Personalization of user account 5-Display_DigitalSpeedometer,active ,70
IDE12800-ENG155058-Personalization of user account 5-Display_Distance,active ,70
IDE12800-ENG155059-Personalization of user account 5-Display_DrivingTime,active ,70
IDE12800-ENG155060-Personalization of user account 5-Display_DualSpeedometer,not active ,70
IDE12800-ENG155061-Personalization of user account 5-Display_Laptimer,not active ,70
IDE12800-ENG155062-Personalization of user account 5-Display_LiveTips,not active ,70
IDE12800-ENG155063-Personalization of user account 5-Display_Nachtankmenge,not active ,70
IDE12800-ENG155064-Personalization of user account 5-Display_OilTemperature,active ,70
IDE12800-ENG155065-Personalization of user account 5-Display_Range,active ,70
IDE12800-ENG155066-Personalization of user account 5-Display_ResetTime,not active ,70
IDE12800-ENG155067-Personalization of user account 5-Display_SpeedWarning,not active ,70
IDE12800-ENG155068-Personalization of user account 5-Display_VZA,active ,70
IDE12800-ENG155069-Personalization of user account 5-Display_ZeroEmission_Distance,not active ,70
IDE12800-ENG155070-Personalization of user account 5-Display_ZeroEmission_Time,not active ,70
IDE12800-ENG155246-Personalization of user account 5-LastMode_HMI_global_active_layout,0 ,70
IDE12800-ENG155247-Personalization of user account 5-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12800-ENG155248-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12800-ENG155249-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12800-ENG155250-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12800-ENG155251-Personalization of user account 5-LastMode_HMI_HistoryState_main,0 ,70
IDE12800-ENG155252-Personalization of user account 5-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12800-ENG155253-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12800-ENG155254-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12800-ENG155255-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12800-ENG155256-Personalization of user account 5-LastMode_HMI_HistoryState_sport,0 ,70
IDE12800-ENG155257-Personalization of user account 5-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12800-ENG155258-Personalization of user account 5-LastMode_HMI_MFA_store,0 ,70
IDE12800-ENG155259-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12800-ENG155260-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12800-ENG155261-Personalization of user account 5-LastMode_v_Kunde_aktiv,not active ,70
IDE12800-ENG155262-Personalization of user account 5-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12800-ENG155263-Personalization of user account 5-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12800-ENG262859-Personalization of user account 5-speed_value,0 ,70
IDE12800-ENG263509-Personalization of user account 5-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12802-IDE00301-Personalization of user account 6-Distance,Kilometres ,70
IDE12802-MAS01230-Personalization of user account 6-Date,dd_mm_yy ,70
IDE12802-MAS01456-Personalization of user account 6-Speed,Kilometers per hour ,70
IDE12802-MAS02201-Personalization of user account 6-Temperature,°C ,70
IDE12802-MAS02957-Personalization of user account 6-Time,24h ,70
IDE12802-MAS03032-Personalization of user account 6-Volume,litre ,70
IDE12802-MAS03034-Personalization of user account 6-Pressure,bar ,70
IDE12802-MAS05637-Personalization of user account 6-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12802-MAS05638-Personalization of user account 6-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12802-MAS05875-Personalization of user account 6-Average consumption: electric drive,kWh per 100 km ,70
IDE12802-Personalization of user account 6-,not active ,70
IDE12802-ENG154881-Personalization of user account 6-Active_design,0 ,70
IDE12802-ENG154882-Personalization of user account 6-Active_view,0 ,70
IDE12802-ENG155000-Personalization of user account 6-DC_aktiverSpeicherplatz,0 ,70
IDE12802-ENG155001-Personalization of user account 6-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12802-ENG155002-Personalization of user account 6-DC_linkeTubeninformation,00 ,70
IDE12802-ENG155003-Personalization of user account 6-DC_rechteTubeninformation,00 ,70
IDE12802-ENG155004-Personalization of user account 6-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155005-Personalization of user account 6-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155006-Personalization of user account 6-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155007-Personalization of user account 6-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155008-Personalization of user account 6-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155009-Personalization of user account 6-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155051-Personalization of user account 6-Display_Average_Consumption,active ,70
IDE12802-ENG155052-Personalization of user account 6-Display_Average_Speed,active ,70
IDE12802-ENG155053-Personalization of user account 6-Display_ComfortPowerConsumption,not active ,70
IDE12802-ENG155054-Personalization of user account 6-Display_ConsumerList,not active ,70
IDE12802-ENG155055-Personalization of user account 6-Display_CoolantTemperature,not active ,70
IDE12802-ENG155056-Personalization of user account 6-Display_CurrentConsumption,active ,70
IDE12802-ENG155057-Personalization of user account 6-Display_DigitalSpeedometer,active ,70
IDE12802-ENG155058-Personalization of user account 6-Display_Distance,active ,70
IDE12802-ENG155059-Personalization of user account 6-Display_DrivingTime,active ,70
IDE12802-ENG155060-Personalization of user account 6-Display_DualSpeedometer,not active ,70
IDE12802-ENG155061-Personalization of user account 6-Display_Laptimer,not active ,70
IDE12802-ENG155062-Personalization of user account 6-Display_LiveTips,not active ,70
IDE12802-ENG155063-Personalization of user account 6-Display_Nachtankmenge,not active ,70
IDE12802-ENG155064-Personalization of user account 6-Display_OilTemperature,active ,70
IDE12802-ENG155065-Personalization of user account 6-Display_Range,active ,70
IDE12802-ENG155066-Personalization of user account 6-Display_ResetTime,not active ,70
IDE12802-ENG155067-Personalization of user account 6-Display_SpeedWarning,not active ,70
IDE12802-ENG155068-Personalization of user account 6-Display_VZA,active ,70
IDE12802-ENG155069-Personalization of user account 6-Display_ZeroEmission_Distance,not active ,70
IDE12802-ENG155070-Personalization of user account 6-Display_ZeroEmission_Time,not active ,70
IDE12802-ENG155246-Personalization of user account 6-LastMode_HMI_global_active_layout,0 ,70
IDE12802-ENG155247-Personalization of user account 6-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12802-ENG155248-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12802-ENG155249-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12802-ENG155250-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12802-ENG155251-Personalization of user account 6-LastMode_HMI_HistoryState_main,0 ,70
IDE12802-ENG155252-Personalization of user account 6-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12802-ENG155253-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12802-ENG155254-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12802-ENG155255-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12802-ENG155256-Personalization of user account 6-LastMode_HMI_HistoryState_sport,0 ,70
IDE12802-ENG155257-Personalization of user account 6-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12802-ENG155258-Personalization of user account 6-LastMode_HMI_MFA_store,0 ,70
IDE12802-ENG155259-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12802-ENG155260-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12802-ENG155261-Personalization of user account 6-LastMode_v_Kunde_aktiv,not active ,70
IDE12802-ENG155262-Personalization of user account 6-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12802-ENG155263-Personalization of user account 6-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12802-ENG262859-Personalization of user account 6-speed_value,0 ,70
IDE12802-ENG263509-Personalization of user account 6-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12804-IDE00301-Personalization of user account 7-Distance,Kilometres ,70
IDE12804-MAS01230-Personalization of user account 7-Date,dd_mm_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Kilometers per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature,°C ,70
IDE12804-MAS02957-Personalization of user account 7-Time,24h ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,litre ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,bar ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,0 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG262859-Personalization of user account 7-speed_value,0 ,70
IDE12804-ENG263509-Personalization of user account 7-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,good oil quality ,1
IDE12962-Oil: soot entry,0 km,2
IDE12963-Oil: thermal loading,13200 km,2
IDE12964-Oil: driven distance since last oil service,6800 km,3
IDE12965-Oil: time since last oil service,296 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),15000 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,30000 km,3
IDE12979-Inspection: time until next inspection,730 d,2
IDE12980-Inspection: distance driven since the last inspection,6800 km,3
IDE12981-Inspection: time since the last inspection,296 d,2
IDE12982-Inspection: distance reset value,30000 km,2
IDE12983-Inspection: time reset value,365 d,2
IDE13031-MAS03935-Long-term store-Driving time,0 min,44
IDE13031-MAS15517-Long-term store-Travel distance,0 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,0 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,0 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,0 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,0 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.000 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.000 kWh,44
IDE13094-Tachometer end value,Variant 0 ,1
IDE13275-IDE00301-Personalization default value-Distance,Kilometres ,70
IDE13275-MAS01230-Personalization default value-Date,dd_mm_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Kilometers per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature,°C ,70
IDE13275-MAS02957-Personalization default value-Time,24h ,70
IDE13275-MAS03032-Personalization default value-Volume,litre ,70
IDE13275-MAS03034-Personalization default value-Pressure,bar ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,not active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,not active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,not active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,not active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,not active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,0 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,5 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG262859-Personalization default value-speed_value,30 ,70
IDE13275-ENG263509-Personalization default value-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE13441-Secondary speed in case of unit replacement,No display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1443 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,90 s,1
IDE14222-Test number length: authentic time,16 B,1
IDE14875-MAS19483-Activation of views-View 1,active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,active ,2
IDE14875-MAS19486-Activation of views-View 4,active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,not active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,not active ,2
IDE14875-MAS19494-Activation of views-View 11,not active ,2
IDE14875-MAS19495-Activation of views-View 13,active ,2
IDE14875-MAS19496-Activation of views-View 14,not active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,kein_logo ,1
IDE15909-Removable seats,Layout normal ,1
IDE17327-MAS01877-Tachometer color setting-Red,0 ,3
IDE17327-MAS01878-Tachometer color setting-Green,0 ,3
IDE17327-MAS01879-Tachometer color setting-Blue,0 ,3
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,No ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01083-IDE18009-Country Variant-Canada variant,No ,2
MAS01758-IDE00500-Date / time-Hour,17 H,6
MAS01758-IDE00501-Date / time-Minute,52 min,6
MAS01758-IDE00502-Date / time-Year,2026 yr,6
MAS01758-IDE00503-Date / time-Month,9 Months,6
MAS01758-IDE00504-Date / time-Day,3 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG262830-Correction_factor_consumption_and_operating_range_electric,100 %,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,12 ,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,12 ,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,20 ,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,70 ,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,500 ,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.0 %,24
ENG251650-GPS_speed,active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4.0 °C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6.0 °C,16
ENG135292-phev_stat_intervall-,1.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.0 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.0 s,7
ENG135292-phev_stat_intervall-,00000000 00010000  ,7
ENG262832-Switching_Networking,Ethernet ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:39
adpmap-19-5WA-907-530-AB_WVWZZZCD6RW123439-20260903-1754.CSV
;SW:5WA-907-530-AB   HW:5WA-907-530-L ---  19: CAN Gateway
;Component:GW2020 High   778 7105, Coding:0000808D0F00000000000000012303305301600902000300030100000001010000000000000000000000000000000000
;EV_GatewMQB2020,006012,EV_GatewMQB2020_006_VW38.rod
;Thursday,03,September,2026,17:54:29:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 08499E0822B478FAAF0-805C SFD { }
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,not active ,5
IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,not active ,5
IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,not active ,5
IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,not active ,5
IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,not active ,5
IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,not active ,5
IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,not active ,5
IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,not active ,5
IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,not active ,5
IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,not active ,5
IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,not active ,5
IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,not active ,5
IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,not active ,5
IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,not active ,5
IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,not active ,5
IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,not active ,5
IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,not active ,5
IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,not active ,5
IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,not active ,5
IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,not active ,5
IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,not active ,5
IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,not active ,5
IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,not active ,5
IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,not active ,5
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,59 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB+ ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,000 ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,0 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,-15000 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,150 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,150 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,10 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,4.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,0.0 l/100km,48
IDE10351-MAS10460-Message mirroring-Target bus,not active ,2
IDE10351-MAS21167-Message mirroring-Source bus,Powertrain data bus ,2
IDE10735-Number requests autonomous recharging,9 ,1
IDE11689-48V-System: locking,regular operation ,1
IDE13844-Distance left for deactivation of production mode,100 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,0.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,0.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,0.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,0.0 kWh/100 km,40
IDE14750-Deactivate all development messages,0 ,5
IDE15316-FoD Partner,Available ,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
IDE15756-Ethernet port 3 VLAN configuration,VLAN_Komfort ,1
IDE15853-Report system for deviations: coding,0 ,3
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,not active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,not active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,not active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,not active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,not active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,not active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,not active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,not active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,not active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,not active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Rising slope ,5
MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Yes ,4
MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,No ,4
MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,Yes ,4
MAS16743-Alternator gear ratio,57 ,1
SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,not installed ,3
SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multi-function steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,installed ,3
SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,not active ,3
SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB2020 ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),activated ,3
SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),activated ,3
SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,invalid ,3
ENG253073-Diagnostic_filter_permanent_deactivation,Security access required,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG331085-ENG280094-Egress_filter-packet_based_/_port_shaper_burst_size_configuration,2000 ,10
ENG331085-ENG280095-Egress_filter-packet_based_/_port_shaper_shaping_rate_configuration,2000 packets/s,10
ENG331085-ENG280098-Egress_filter-port_shaper_bucket_count_select,packet_based ,10
ENG331085-ENG280099-Egress_filter-port_shaper_enabling,enable_shaper ,10
ENG253088-EM_function_variant_EM-HLR,0 ,1
ENG253271-ENG259280-GW_Content_list-Bus_ID,00 ,48
ENG253271-ENG253458-GW_Content_list-Node_address,00 00 ,48
ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,On ,8
ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,On ,8
ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,On ,8
ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,On ,8
ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,On ,8
ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,On ,8
ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,On ,8
ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,On ,8
ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,On ,8
ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,On ,8
ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,On ,8
ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,On ,8
ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,On ,8
ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,On ,8
ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,On ,8
ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,On ,8
ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,On ,8
ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,On ,8
ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,On ,8
ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,On ,8
ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,On ,8
ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,On ,8
ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,On ,8
ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,On ,8
ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,On ,8
ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,On ,8
ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,On ,8
ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,On ,8
ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,On ,8
ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,On ,8
ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,On ,8
ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,On ,8
ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,On ,8
ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,On ,8
ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,On ,8
ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,On ,8
ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,On ,8
ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,On ,8
ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,On ,8
ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,On ,8
ENG253192-MAS01898-IDS_white_list_features-Drive train,On ,1
ENG253192-MAS16574-IDS_white_list_features-Infotainment,On ,1
ENG253396-Mirroring_LIN3_to_LIN4,No ,1
ENG137850-MVK_Warning,regular operation ,1
ENG253252-ENG260330-Node_to_cluster_list-NCL_element_1,00 00 00 00 00 ,160
ENG253252-ENG260846-Node_to_cluster_list-NCL_element_10,00 00 00 00 00 ,160
ENG253252-ENG258686-Node_to_cluster_list-NCL_element_11,00 00 00 00 00 ,160
ENG253252-ENG259563-Node_to_cluster_list-NCL_element_12,00 00 00 00 00 ,160
ENG253252-ENG259135-Node_to_cluster_list-NCL_element_13,00 00 00 00 00 ,160
ENG253252-ENG261302-Node_to_cluster_list-NCL_element_14,00 00 00 00 00 ,160
ENG253252-ENG259590-Node_to_cluster_list-NCL_element_15,00 00 00 00 00 ,160
ENG253252-ENG261163-Node_to_cluster_list-NCL_element_16,00 00 00 00 00 ,160
ENG253252-ENG258229-Node_to_cluster_list-NCL_element_17,00 00 00 00 00 ,160
ENG253252-ENG259389-Node_to_cluster_list-NCL_element_18,00 00 00 00 00 ,160
ENG253252-ENG260540-Node_to_cluster_list-NCL_element_19,00 00 00 00 00 ,160
ENG253252-ENG259624-Node_to_cluster_list-NCL_element_2,00 00 00 00 00 ,160
ENG253252-ENG258136-Node_to_cluster_list-NCL_element_20,00 00 00 00 00 ,160
ENG253252-ENG261360-Node_to_cluster_list-NCL_element_21,00 00 00 00 00 ,160
ENG253252-ENG260775-Node_to_cluster_list-NCL_element_22,00 00 00 00 00 ,160
ENG253252-ENG259077-Node_to_cluster_list-NCL_element_23,00 00 00 00 00 ,160
ENG253252-ENG259062-Node_to_cluster_list-NCL_element_24,00 00 00 00 00 ,160
ENG253252-ENG260421-Node_to_cluster_list-NCL_element_25,00 00 00 00 00 ,160
ENG253252-ENG261354-Node_to_cluster_list-NCL_element_26,00 00 00 00 00 ,160
ENG253252-ENG258201-Node_to_cluster_list-NCL_element_27,00 00 00 00 00 ,160
ENG253252-ENG260110-Node_to_cluster_list-NCL_element_28,00 00 00 00 00 ,160
ENG253252-ENG258645-Node_to_cluster_list-NCL_element_29,00 00 00 00 00 ,160
ENG253252-ENG261260-Node_to_cluster_list-NCL_element_3,00 00 00 00 00 ,160
ENG253252-ENG259078-Node_to_cluster_list-NCL_element_30,00 00 00 00 00 ,160
ENG253252-ENG260192-Node_to_cluster_list-NCL_element_31,00 00 00 00 00 ,160
ENG253252-ENG259747-Node_to_cluster_list-NCL_element_32,00 00 00 00 00 ,160
ENG253252-ENG259375-Node_to_cluster_list-NCL_element_4,00 00 00 00 00 ,160
ENG253252-ENG259916-Node_to_cluster_list-NCL_element_5,00 00 00 00 00 ,160
ENG253252-ENG260559-Node_to_cluster_list-NCL_element_6,00 00 00 00 00 ,160
ENG253252-ENG259415-Node_to_cluster_list-NCL_element_7,00 00 00 00 00 ,160
ENG253252-ENG260302-Node_to_cluster_list-NCL_element_8,00 00 00 00 00 ,160
ENG253252-ENG259224-Node_to_cluster_list-NCL_element_9,00 00 00 00 00 ,160
ENG253340-SFD_Testmode,not active ,1
ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,00 00 01 ,24
ENG253268-MAS03174-TCR_bus_can-Comfort data bus,00 00 30 ,24
ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,00 01 C0 ,24
ENG253268-MAS03178-TCR_bus_can-Suspension data bus,00 00 04 ,24
ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,00 00 00 ,24
ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,00 00 02 ,24
ENG253268-MAS16909-TCR_bus_can-Data bus driver assistance systems,00 00 08 ,24
ENG253268-MAS16910-TCR_bus_can-Migration data bus,00 00 01 ,24
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,00 01 C0 ,12
ENG253184-MAS03180-TCR_bus_lin-Local data bus,00 00 00 ,12
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,00 00 00 ,12
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,00 00 00 ,12
ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,00 04 00 ,24
ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,00 20 00 ,24
ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,00 08 00 ,24
ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,00 02 00 ,24
ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,00 10 00 ,24
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,10
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,10
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,1800 s,10
Elapsed Time: 00:20
adpmap-23-5WA-909-059-AB_WVWZZZCD6RW123439-20260903-1804.CSV
;SW:5WA-909-059-AB   HW:3Q0-909-059-C ---  23: Brake Booster
;Component:EBKV          H09 0372, Coding:1002C140730000CE39E79C73000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016_VW38.rod
;Thursday,03,September,2026,18:04:42:29755
;VCID: 1079B6685AE4303A770-8044 SFD { }
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,20 min,2
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements-,EOBD ,2
IDE11985-Expected OBD requirements-,Combustion engine ,2
IDE14698-Parameters of leak test-,14.0000000 mm,20
IDE14698-Parameters of leak test-,30.0000000 mm/s,20
IDE14698-Parameters of leak test-,4 ,20
IDE14698-Parameters of leak test-,0.5 s,20
IDE14698-Parameters of leak test-,0.0 s,20
IDE14698-Parameters of leak test-,10.0000000 mm/s,20
IDE14698-Parameters of leak test-,15.0 s,20
IDE14698-Parameters of leak test-,10.0 s,20
IDE14698-Parameters of leak test-,65 bar,20
IDE14698-Parameters of leak test-,6.0000000 mm,20
IDE14698-Parameters of leak test-,12.0000000 mm,20
IDE14699-Parameters of heaviness test-,12.0000000 mm,13
IDE14699-Parameters of heaviness test-,30.0000000 mm/s,13
IDE14699-Parameters of heaviness test-,0 ,13
IDE14699-Parameters of heaviness test-,0.5 s,13
IDE14699-Parameters of heaviness test-,0.0 s,13
IDE14699-Parameters of heaviness test-,1.29980468750 Nm,13
IDE14699-Parameters of heaviness test-,50.0000000 mm/s,13
IDE14700-Parameters of ventilation routine-,21.0000000 mm,18
IDE14700-Parameters of ventilation routine-,180.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,25 ,18
IDE14700-Parameters of ventilation routine-,50.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,0.0 s,18
IDE14700-Parameters of ventilation routine-,30.0000000 mm,18
IDE14700-Parameters of ventilation routine-,5.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,5 ,18
IDE14700-Parameters of ventilation routine-,1.7968750 mm/s,18
IDE14700-Parameters of ventilation routine-,1.0 s,18
IDE80111-Analysis 111,active ,1
IDE80121-Analysis 121-,80 s,2
IDE80121-Analysis 121-,0 ,2
IDE80122-Analysis 122-,10 s,2
IDE80122-Analysis 122-,0 ,2
IDE80123-Analysis 123,OFF ,1
IDE80124-Analysis 124-,00 ,2
IDE80124-Analysis 124-,0 ,2
IDE80125-Analysis 125-,0 ,2
IDE80126-Analysis 126,0 ,2
IDE80131-MAS05513-Analysis 131-Bit 0,OFF ,1
IDE80131-MAS05514-Analysis 131-Bit 1,OFF ,1
IDE80131-MAS05515-Analysis 131-Bit 2,OFF ,1
IDE80131-MAS05516-Analysis 131-Bit 3,OFF ,1
IDE80131-MAS05517-Analysis 131-Bit 4,OFF ,1
IDE80131-MAS05518-Analysis 131-Bit 5,OFF ,1
IDE80131-MAS05519-Analysis 131-Bit 6,OFF ,1
IDE80131-MAS05520-Analysis 131-Bit 7,OFF ,1
IDE80134-Analysis 134-,00 00 00 00 ,40
IDE80134-Analysis 134-,00 ,40
IDE80135-Analysis 135-,00 00 00 00 ,40
IDE80135-Analysis 135-,00 ,40
IDE80136-Analysis 136-,00 00 00 00 ,40
IDE80136-Analysis 136-,00 ,40
IDE80137-Analysis 137-,00 00 00 00 ,40
IDE80137-Analysis 137-,00 ,40
MAS00194----,00 00 ,2
Elapsed Time: 00:07
adpmap-2B-2Q0-905-861-B_WVWZZZCD6RW123439-20260903-1804.CSV
;SW:2Q0-905-861-B   HW:2Q0-905-861-B ---  2B: Steer. Col. Lock
;Component:ELV-MQBB      H10 0040, Coding:0000000000000000
;EV_ELVMarqMQBA0,002004,EV_ELVMarqMQBA0_VW38.rod
;Thursday,03,September,2026,18:04:56:29755
;VCID: 323D1CE0F4A8222A214-8066
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,not tested ,1
Elapsed Time: 00:01
adpmap-36-5QS-959-760-H_WVWZZZCD6RW123439-20260903-1805.CSV
;SW:5QS-959-760-H   HW:5QS-959-760-H ---  36: Seat Mem. Drvr
;Component:MEM-FS        011 0372, Coding:01589A400000B0508803010101010000000000212100000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW38.rod
;Thursday,03,September,2026,18:05:23:29755
;VCID: 6597B7BCF5E68592746-8030
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS18842-Production mode-Assembly mode,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE02854-Reset standardization,all ,3
IDE03066-Reset counter for compressor for multicontour seat,Activate ,1
IDE06869-installation position,Memory seat driver side ,1
ENG123066-vehicle_velocity_monitoring,active ,1
Elapsed Time: 00:18
adpmap-42-5Q0-959-593-L_WVWZZZCD6RW123439-20260903-1805.CSV
;SW:5Q0-959-593-L   HW:5Q0-959-593-F ---  42: Door Elect, Driver
;Component:TSG FS004 0350, Coding:003B13208200040008001000
;EV_DCU2DriveSideMAXHKLO,001018,EV_DCU2DriveSideMAXHKLO_VW27.rod
;Thursday,03,September,2026,18:05:54:29755
;VCID: 4ACD64007C384AEA794-801E
IDE09067-Side window shade: service mode,Deactivating ,1
ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,00 00 ,128
ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,00 00 14 03 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 06 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 05 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF FF FF 10 00 00 0A 01 00 00 00 ,128
ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,36 0A ,128
ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,02 BC 02 58 14 EC 02 02 02 0A 00 00 00 00 05 3C 02 23 14 0E 00 05 F6 32 1E 12 00 02 FE 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 01 19 1E 20 1E FA D8 C4 F6 FB 28 1E 32 05 1E 00 00 32 03 20 12 12 10 FA E7 EC F6 FB 16 12 28 01 0C 1E 00 FA 02 23 10 12 10 FA E7 EC F6 FB 19 14 28 01 0C 1E 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,64 1D ,128
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 1E 19 00 32 32 01 90 00 00 00 00 00 00 00 7D 00 C8 32 3C C8 00 4E 00 4D 79 64 64 32 60 CD 6D C7 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 42 4D 30 36 01 00 00 00 00 00 00 00 00 00 B9 BA ,88
Elapsed Time: 00:07
adpmap-44-5WA-907-145-G_WVWZZZCD6RW123439-20260903-1806.CSV
;SW:5WA-907-145-G   HW:5WA-907-145-C ---  44: Steering Assist
;Component:BASGEN1MQB37  502 1040, Coding:0000000000000000000102010100010000000101010101
;EV_SteerAssisBASGEN1MQB37,007046,EV_SteerAssisBASGEN1MQB37_007.rod
;Thursday,03,September,2026,18:06:12:29755
;VCID: 4EC56810805066CA25C-801A
IDE03724-Straight line running,Active: with learned value ,1
IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
IDE06657-Steering angle: calculated,not active ,1
IDE06678-Pull compensation,Active: without learned value ,1
IDE09571-RPM monitoring,active ,1
IDE14345-Lateral assistant coordinator: parking assist,not active ,1
IDE14346-Lateral assistant coordinator: reduced stopping distance,active ,1
IDE14347-Lateral assistance coordinator: lane assist,active ,1
IDE14348-Lateral assistant coordination: counter-steering assist,active ,1
IDE15619-Maneuvering assistant lateral control coordinator,not active ,1
MAS09008-Plausibility check,not active ,1
Elapsed Time: 00:04
adpmap-52-5Q0-959-592-L_WVWZZZCD6RW123439-20260903-1806.CSV
;SW:5Q0-959-592-L   HW:5Q0-959-592-F ---  52: Door Elect, Pass.
;Component:TSG BFS004 0350, Coding:003B11208E00040000801000
;EV_DCU2PasseSideMAXHKLO,001018,EV_DCU2PasseSideMAXHKLO_VW27.rod
;Thursday,03,September,2026,18:06:28:29755
;VCID: 49CF5B0C793E41F270E-801C
ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,00 00 ,128
ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,00 00 14 03 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 06 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 05 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 C0 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF FF FF 10 00 00 0A 01 00 00 00 ,128
ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,65 82 ,128
ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,02 BC 02 58 14 EC 02 02 02 0A 00 00 00 00 05 3C 02 23 14 0E 00 05 F6 32 1E 12 00 02 FE 0A 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 01 19 1E 20 1E FA D8 C4 F6 FB 28 1E 32 05 1E 00 00 32 03 20 12 12 10 FA E7 EC F6 FB 16 12 28 01 0C 1E 00 FA 02 23 10 12 10 FA E7 EC F6 FB 19 14 28 01 0C 1E 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,64 1D ,128
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 1E 19 00 32 32 01 90 00 00 00 00 00 00 00 7D 00 C8 32 3C C8 00 4E 00 4D 79 00 00 32 60 CD 6D C7 64 14 32 0A 0A 60 E6 6D D9 64 14 32 0A 0A 14 00 00 42 4D 30 36 01 00 00 00 00 00 00 00 00 00 B4 3C ,88
Elapsed Time: 00:07
adpmap-5F-5H0-035-820-P_WVWZZZCD6RW123439-20260903-1807.CSV
;SW:5H0-035-820-P   HW:5H0-035-820 ---  5F: Information Electr.
;Component:MU-O-ND-EU    H61 1989, Coding:23800000000000000000000000000000000000000000000000
;EV_MUOIMQB37w,001002,EV_MUOIMQB37w_001_VW38.rod
;Thursday,03,September,2026,18:07:21:29755
;VCID: 2F3B1594E79A0FC24EA-807A SFD { }
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,Europe ,1
IDE00768-Country identification: country of sale,AT ,2
IDE00769-Call number 1 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,28 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,26 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,28 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,26 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,28 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,26 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,28 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,26 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,28 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,26 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,28 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,26 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,28 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,26 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,28 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,26 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,28 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,26 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,28 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,26 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,28 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,26 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,28 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,26 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,28 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,26 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,28 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,26 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,28 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,26 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,28 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,26 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,28 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,26 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,28 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,26 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,28 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,26 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,28 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,26 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,28 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,26 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,28 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,26 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,28 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,26 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,28 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,26 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,27 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,27 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,27 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,27 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,27 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,27 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,27 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,27 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,121
IDE02502-Confirmation of installation change,2C 00 ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,not activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,not activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,not activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,not activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,not activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,not activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,CAB_2 ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Infotainment data bus ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,Terminal 15 ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,CAB_5 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,not activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Infotainment data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,CAB_5 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,CAB_5 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Infotainment data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Powertrain data bus ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Infotainment data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,CAB_5 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,Comfort data bus ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Powertrain data bus ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Infotainment data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,CAB_6 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,Infotainment data bus ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Infotainment data bus ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,Comfort data bus ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Terminal 15 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,CAN_FAS ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,CAB_5 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,-128 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-GNSS: refresh rate,10 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10604-Menu entries for mobile online services,activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,36 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,35 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11122-Country identification: country of sale HMI,AT ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,slave ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG248413-alphabetic_scrollbar,On ,1
ENG253302-ENG260724-audio_zone_configuration-zone_1_direction,Left ,6
ENG253302-ENG259844-audio_zone_configuration-zone_1_position,front_row ,6
ENG253302-ENG260273-audio_zone_configuration-zone_2_direction,Right ,6
ENG253302-ENG259809-audio_zone_configuration-zone_2_position,front_row ,6
ENG253302-ENG261136-audio_zone_configuration-zone_3_direction,none ,6
ENG253302-ENG260623-audio_zone_configuration-zone_3_position,none ,6
ENG253302-ENG259382-audio_zone_configuration-zone_4_direction,none ,6
ENG253302-ENG259681-audio_zone_configuration-zone_4_position,none ,6
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG252010-Car_net,we_connect ,1
ENG248423-channel_band_width_802_11ac,40MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,Yes ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,1 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,IP_streaming ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,BAP ,8
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,18
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,18
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,18
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,18
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,18
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,18
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1.0 %,18
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1.0 %,18
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3.0 %,18
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6.0 %,18
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44.0 %,18
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100.0 %,18
ENG253228-ENG101574-Dimming_Illumination_for_Display_Unit_day_design-X1,0 ,18
ENG253228-ENG99557-Dimming_Illumination_for_Display_Unit_day_design-X2,10 ,18
ENG253228-ENG102140-Dimming_Illumination_for_Display_Unit_day_design-X3,50 ,18
ENG253228-ENG102936-Dimming_Illumination_for_Display_Unit_day_design-X4,100 ,18
ENG253228-ENG103548-Dimming_Illumination_for_Display_Unit_day_design-X5,150 ,18
ENG253228-ENG113992-Dimming_Illumination_for_Display_Unit_day_design-X6,253 ,18
ENG253228-ENG99777-Dimming_Illumination_for_Display_Unit_day_design-Y1,0.6 %,18
ENG253228-ENG100480-Dimming_Illumination_for_Display_Unit_day_design-Y2,0.6 %,18
ENG253228-ENG100773-Dimming_Illumination_for_Display_Unit_day_design-Y3,1.0 %,18
ENG253228-ENG100631-Dimming_Illumination_for_Display_Unit_day_design-Y4,3.0 %,18
ENG253228-ENG102174-Dimming_Illumination_for_Display_Unit_day_design-Y5,30.0 %,18
ENG253228-ENG113993-Dimming_Illumination_for_Display_Unit_day_design-Y6,100.0 %,18
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,0 ms,2
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG331821-function_configuration_a2b_topology-External_sound_system,Not_present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG302728-function_configuration_a2b_topology-InnenSound_Unit,Not_present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,25 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_IP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,OFF ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,On ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,On ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,On ,6
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,On ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,EU ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,On ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,On ,4
ENG248433-ENG248828-function_configuration_navigation-vza,activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,Deactivated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,activated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,activated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,1 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,No_Brand_Sound ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,no_country ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,no_region ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,On ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,OFF ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG244879-ENG297725-function_configuration_sw_update-UOTA_T_Box,Not available ,1
ENG248440-function_configuration_swap_fod,swap_not_active_fod_slave_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,Ethernet ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,do_not_create ,1
ENG248443-geocoordinate_show,do_not show ,1
ENG253056-gestures_room,01 01 46 02 82 02 82 02 46 02 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 02 02 0A 05 98 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,60
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248454-ENG248814-ipv4_address_of_subnet_4_on_ccu-segment_1,10 ,4
ENG248454-ENG248815-ipv4_address_of_subnet_4_on_ccu-segment_2,175 ,4
ENG248454-ENG248816-ipv4_address_of_subnet_4_on_ccu-segment_3,202 ,4
ENG248454-ENG248817-ipv4_address_of_subnet_4_on_ccu-segment_4,1 ,4
ENG248455-ENG248814-ipv4_address_of_subnet_4_on_mib-segment_1,10 ,4
ENG248455-ENG248815-ipv4_address_of_subnet_4_on_mib-segment_2,175 ,4
ENG248455-ENG248816-ipv4_address_of_subnet_4_on_mib-segment_3,202 ,4
ENG248455-ENG248817-ipv4_address_of_subnet_4_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248463-ENG248814-ipv6_address_of_subnet_4_on_ccu-segment_1,64816 ,8
ENG248463-ENG248815-ipv6_address_of_subnet_4_on_ccu-segment_2,57486 ,8
ENG248463-ENG248816-ipv6_address_of_subnet_4_on_ccu-segment_3,49201 ,8
ENG248463-ENG248817-ipv6_address_of_subnet_4_on_ccu-segment_4,512 ,8
ENG248464-ENG248814-ipv6_address_of_subnet_4_on_mib-segment_1,64816 ,8
ENG248464-ENG248815-ipv6_address_of_subnet_4_on_mib-segment_2,57486 ,8
ENG248464-ENG248816-ipv6_address_of_subnet_4_on_mib-segment_3,49201 ,8
ENG248464-ENG248817-ipv6_address_of_subnet_4_on_mib-segment_4,512 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG278389-Market_and_brand_specific_preInstSet_of_webapps,preinstallation_set_0 ,1
ENG253300-nearby_detection_room,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,60
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG273498-parkingsystem_video_input,1392x656 ,3
ENG252007-ENG297686-Privacy_mode-globe_icon,not activated ,2
ENG252007-ENG252075-Privacy_mode-supress_privacy_mode,not activated ,2
ENG253201-proximity_room,01 01 46 02 82 02 82 02 82 02 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 02 02 02 0A 05 D4 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,60
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG117912-ENG117775-Select_Remote_Test_DAB_Service-Parameter_Adaption_Service_ID,Conditions not correct or request sequence error,1
ENG117912-ENG117776-Select_Remote_Test_DAB_Service-Parameter_Adaption_Subservice_ID,Conditions not correct or request sequence error,1
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,1
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,1
ENG117909-Shift_Remote_Test_Frequency_DAB,Conditions not correct or request sequence error,1
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,1
ENG253230-slider_parameter,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,20
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
Elapsed Time: 01:03
adpmap-6C-5WA-980-556-D_WVWZZZCD6RW123439-20260903-1808.CSV
;SW:5WA-980-556-D   HW:5WA-980-556-B ---  6C: Back-up Cam.
;Component:RV eCompact   H30 0344, Coding:02030004E43000
;EV_CamSysRVCCompaFicos,010024,EV_CamSysRVCCompaFicos_010_VW38.rod
;Thursday,03,September,2026,18:08:33:29755
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 52FD7C609468022A014-8006
IDE00001-IDE15846-Production mode-Camera cleaning,not active ,3
IDE00001-MAS03384-Production mode-Blindness detection,not active ,3
IDE00001-MAS21952-Production mode-online calibration,not active ,3
IDE00820-Activating and deactivating all development messages,not activated ,1
IDE07159-MAS01155-Control module switch-off: counter-Control module,0 ,2
IDE07159-MAS05583-Control module switch-off: counter-Data bus,0 ,2
IDE07160-IDE15110-Control module switch-off: switch-off time-Coupling shut-off time: data bus with low-voltage energy management,0 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,63 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,71 min,2
ENG153885-Knockout_test_mode,0 ,1
Elapsed Time: 00:03
adpmap-75-5WA-035-284-F_WVWZZZCD6RW123439-20260903-1809.CSV
;SW:5WA-035-284-F   HW:5WA-035-284-C ---  75: Telematics
;Component:OCU3HMQB37W   H14 0144, Coding:023800109068AC209405460071002E07
;EV_OCU3HMQB37W,002012,EV_OCU3HMQB37W_002_VW38.rod
;Thursday,03,September,2026,18:09:59:29755
;VCID: 49CF5B0C793E41F270E-801C SFD { }
IDE00608-MAS00713-Fuel type-Petrol,installed ,1
IDE00608-MAS00716-Fuel type-Diesel,not installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,not installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE02330-Call number 2 for info call,+4312511919450  ,15
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane departure warning,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,not activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Auxiliary heating,not activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,not activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS07249-Vehicle function list BAP-Main beam,activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,not activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,Ethernet ,11
IDE04307-MAS23125-Vehicle function list BAP-BAP distance RemonteStartOnline_0x70,not activated ,11
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,255 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,60 min,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,not activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,40 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,10 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14170-Timeout for service key query,10 ,1
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 2 ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic settings not detected guest: services,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with balancing of interests,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with consent,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15695-Front radar-based localization-,activated ,1
IDE15695-ENG263520-Front radar-based localization-Front_radar_rem_data_output,activated ,1
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://mod3vkmsmbbreg-0.prd.eu.dp.vwg-connect.com/mbb/vehicles/v2/deviceRegistered ,86
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,86
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,86
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Normal/Hybrid ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,0 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-GNSS: data transmission rate,10 Hz ,2
MAS13841-GNSS: minimum height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Rear left door,installed ,1
MAS17427-MAS00221-Door configuration-Rear right door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,not installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,not installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,400 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19240-Authorization level after-run time,0 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG113413-a2b_data_streams-reserved_01,0 ,10
ENG253242-ENG261390-a2b_data_streams-reserved_02,0 ,10
ENG253242-ENG261450-a2b_data_streams-reserved_03,0 ,10
ENG253242-ENG261451-a2b_data_streams-reserved_04,0 ,10
ENG253242-ENG261386-a2b_data_streams-Reserved_05,0 ,10
ENG253242-ENG261387-a2b_data_streams-Reserved_06,0 ,10
ENG253242-ENG261388-a2b_data_streams-Reserved_07,0 ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG261370-Airbag_Signal_Setting,100 ms ,1
ENG275595-IDE01762-BAP_Connection_Control-Doors,automatic ,25
ENG275595-IDE03031-BAP_Connection_Control-Seat adjustment,automatic ,25
ENG275595-IDE03111-BAP_Connection_Control-Interior lighting,automatic ,25
ENG275595-MAS00688-BAP_Connection_Control-Multi-function display,automatic ,25
ENG275595-MAS01118-BAP_Connection_Control-Air Conditioning,automatic ,25
ENG275595-MAS01282-BAP_Connection_Control-Wiper,automatic ,25
ENG275595-MAS01891-BAP_Connection_Control-Lane departure warning,OFF ,25
ENG275595-MAS02444-BAP_Connection_Control-Central locking,OFF ,25
ENG275595-MAS03385-BAP_Connection_Control-Lane change assistance,OFF ,25
ENG275595-MAS03420-BAP_Connection_Control-Head-Up-Display,OFF ,25
ENG275595-MAS03853-BAP_Connection_Control-Road sign detection,OFF ,25
ENG275595-MAS05087-BAP_Connection_Control-ACC,OFF ,25
ENG275595-MAS05506-BAP_Connection_Control-Stopping distance reduction,OFF ,25
ENG275595-MAS07249-BAP_Connection_Control-Main beam,automatic ,25
ENG275595-MAS08072-BAP_Connection_Control-Driving profile selection,OFF ,25
ENG275595-MAS08785-BAP_Connection_Control-Parking aid,automatic ,25
ENG275595-MAS20539-BAP_Connection_Control-BAP distance PaCo_0x55,automatic ,25
ENG275595-MAS20545-BAP_Connection_Control-BAP distance doors2_0x63,automatic ,25
ENG275595-MAS20550-BAP_Connection_Control-BAP distance infotainment_settings_0x50,automatic ,25
ENG275595-MAS20553-BAP_Connection_Control-BAP distance mirror_0x0E,automatic ,25
ENG275595-MAS20556-BAP_Connection_Control-BAP distance unit_master_0x13,automatic ,25
ENG275595-ENG98891-BAP_Connection_Control-Reserved,OFF ,25
ENG275595-ENG113413-BAP_Connection_Control-reserved_01,OFF ,25
ENG275595-ENG261390-BAP_Connection_Control-reserved_02,OFF ,25
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG253218-ENG113413-function_configuration_a2b_topology-reserved_01,0 ,5
ENG253218-ENG261390-function_configuration_a2b_topology-reserved_02,0 ,5
ENG253218-ENG261450-function_configuration_a2b_topology-reserved_03,0 ,5
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Direction of travel,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,not activated ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:32
adpmap-A5-5WA-980-653-D_WVWZZZCD6RW123439-20260903-1811.CSV
;SW:5WA-980-653-D   HW:5WA-980-653 ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H12 3405, Coding:00000888114C4040109E00001020002000418000000000000000000000000000
;EV_MFK3ValeoMQB,005055,EV_MFK3ValeoMQB_005_VW38.rod
;Thursday,03,September,2026,18:11:23:29755
;VCID: 50F976689A64703A370-8004
IDE04733-Road sign detection fusion mode-,0 ,2
IDE04733-Road sign detection fusion mode-,Road sign fusion ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07358-Distance to calibration field,1500.00 mm,2
IDE09375-IDE05717-Axle offset-Front axle transverse position,-2.0 mm,4
IDE09375-IDE05718-Axle offset-Rear axle transverse position,0.0 mm,4
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,686.00 mm,8
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,686.00 mm,8
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,692.00 mm,8
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,693.00 mm,8
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460.00 mm,24
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742.00 mm,24
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1397.00 mm,24
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460.00 mm,24
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742.00 mm,24
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1397.00 mm,24
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460.00 mm,24
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742.00 mm,24
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,803.00 mm,24
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460.00 mm,24
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742.00 mm,24
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,803.00 mm,24
IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
IDE10873-BAP personalization,activated ,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.000 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.000 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.000 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,0 mm,8
IDE12097-Menu for roadside fusion persistency,activated ,1
ENG114742-ENG130919-Activation of Development Messages-Activation_of_development_messages_EHR,not active ,2
ENG114742-ENG185756-Activation of Development Messages-Activation_of_development_messages_HCA_01,not active ,2
ENG114742-ENG185757-Activation of Development Messages-Activation_of_development_messages_HCA_02,not active ,2
ENG114742-ENG130922-Activation of Development Messages-Activation_of_development_messages_internal,not active ,2
ENG114742-ENG185758-Activation of Development Messages-Activation_of_development_messages_lane_1,not active ,2
ENG114742-ENG185759-Activation of Development Messages-Activation_of_development_messages_lane_2,not active ,2
ENG114742-ENG130915-Activation of Development Messages-Activation_of_development_messages_reserved,not active ,2
ENG114742-ENG185760-Activation of Development Messages-Activation_of_development_messages_RFD,not active ,2
ENG114742-ENG185761-Activation of Development Messages-Activation_of_development_messages_TSF,not_active ,2
ENG114742-ENG185762-Activation of Development Messages-Activation_of_development_messages_VZF_TSR1,not_active ,2
ENG114742-ENG185763-Activation of Development Messages-Activation_of_development_messages_VZF_TSR2,not active ,2
ENG114742-ENG130917-Activation of Development Messages-Activation_of_development_messages_WLA,not active ,2
ENG114742-ENG185770-Activation of Development Messages-Dev_messages_vd_deaktivation,not active ,2
ENG185678-Activation_OCAL,activated ,1
ENG130776-ENG185767-Adaptation_tsr-country_code_RSR,0 ,2
ENG130776-ENG185809-Adaptation_tsr-relevance_mode,Enabled ,2
ENG185690-ENG185780-HCA_Development-HCA_Development_1,00 00 00 00 ,24
ENG185690-ENG185781-HCA_Development-HCA_Development_2,00 00 00 00 ,24
ENG185690-ENG185782-HCA_Development-HCA_Development_3,00 00 00 00 ,24
ENG185690-ENG185783-HCA_Development-HCA_Development_4,00 00 00 00 ,24
ENG185690-ENG185784-HCA_Development-HCA_Development_5,00 00 00 00 ,24
ENG185690-ENG185785-HCA_Development-HCA_Development_6,00 00 00 00 ,24
ENG185698-HiL_Funktionsdeaktivierung,4294967295 ,4
ENG185694-Hil_init_mode,not active ,1
ENG120319-Mask_error_reactions_for_development,not_activated ,1
ENG107577-ENG185789-Masked_fault_classes-Masked_fault_classes_1,255 ,4
ENG107577-ENG185790-Masked_fault_classes-Masked_fault_classes_2,255 ,4
ENG107577-ENG185791-Masked_fault_classes-Masked_fault_classes_3,255 ,4
ENG107577-ENG185792-Masked_fault_classes-Masked_fault_classes_4,255 ,4
ENG185706-Reset_eyeq_mode,not active ,1
ENG130777-standstill_mode,not active ,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,30.0 ,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,40.0 ,5
ENG130781-ENG185819-WLA_adjustment-WLA_Object_type_extended,Object_extended_off ,5
ENG130779-Xcp_interface,not activated ,1
Elapsed Time: 00:13
adpmap-CA-4K1-907-594-CB_WVWZZZCD6RW123439-20260903-1811.CSV
;SW:4K1-907-594-CB   HW:4K1-907-594 ---  CA: Sunroof
;Component:SAD_STG_1     006 0040, Coding:408000738001
;EV_SunRoofCONTIAU736,009015,EV_SunRoofCONTIAU736_009_VW27.rod
;Thursday,03,September,2026,18:11:43:29755
;VCID: 77ABEDF45F4A0702D6A-8022
IDE02104-IDE03633-Temperature dependent activation-Close sunroof,not active ,1
IDE02104-MAS09030-Temperature dependent activation-Open sun roof,active ,1
IDE02104-MAS09031-Temperature dependent activation-Open roof blind,not active ,1
IDE02104-MAS09032-Temperature dependent activation-Close roof blind,not active ,1
IDE09435-IDE03633-Speed dependent activation-Close sunroof,not active ,2
IDE09435-MAS09030-Speed dependent activation-Open sun roof,active ,2
IDE09435-MAS09031-Speed dependent activation-Open roof blind,not active ,2
IDE09435-MAS09032-Speed dependent activation-Close roof blind,not active ,2
IDE09435-MAS16806-Speed dependent activation-Reduce sunroof tilt,active ,2
IDE09439-MAS08884-Logic switch-over: controls-Sunroof button,not active ,1
IDE09439-MAS08932-Logic switch-over: controls-Sunroof shade button,not active ,1
IDE09439-MAS08992-Logic switch-over: controls-Button for sliding roof,not active ,1
IDE09439-MAS10443-Logic switch-over: controls-Button for sunroof/tilt roof: rear,not active ,1
IDE09439-MAS10444-Logic switch-over: controls-Sunroof shade button: rear,not active ,1
IDE09451-MAS08936-Travel path-Tilted position: max. opening width,not active ,1
IDE09451-MAS08937-Travel path-Sliding position: intermed. pos.,active ,1
IDE09451-MAS08991-Travel path-Sliding position: reduc. opening width,not active ,1
IDE09451-MAS10725-Travel path-Sunroof shade: interm. position open,not active ,1
IDE09451-MAS10726-Travel path-Sunroof shade: interm. position close,not active ,1
IDE12616-IDE09434-Power sunroof control module - convenience function-Target position for comfort opening,Tilt out posi. ,2
IDE12616-MAS06696-Power sunroof control module - convenience function-Comfort opening sunroof,active ,2
IDE12616-MAS13329-Power sunroof control module - convenience function-Comfort opening of roof shade,not active ,2
IDE12616-MAS13330-Power sunroof control module - convenience function-Comfort closing of roof shade,not active ,2
IDE12616-MAS14142-Power sunroof control module - convenience function-Private sphere mode,not active ,2
IDE12616-MAS16807-Power sunroof control module - convenience function-Comfort closing sunroof,active ,2
ENG146366-Applikationmode deactivate,Deactivating ,1
Elapsed Time: 00:02
adpmap-D6-992-941-571-AH_WVWZZZCD6RW123439-20260903-1811.CSV
;SW:992-941-571-AH   HW:992-941-571-A ---  D6: Light Ctrl Left 2
;Component:LED1L         H25 9204, Coding:
;EV_LLPGen3LKEBODPO68X,002003,EV_LLPGen3LKEBODPO68X_002_VW27.rod
;Thursday,03,September,2026,18:11:59:29755
;VCID: 6889BE8802F498FA4F0-803C
IDE00820-Activating and deactivating all development messages,No ,1
Elapsed Time: 00:00
adpmap-D7-992-941-571-AH_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:992-941-571-AH   HW:992-941-571-A ---  D7: Light Ctrl Right 2
;Component:LED1R         H25 9204, Coding:
;EV_LLPGen3RKEBODPO68X,002003,EV_LLPGen3RKEBODPO68X_002_VW27.rod
;Thursday,03,September,2026,18:12:13:29755
Elapsed Time: 00:00
adpmap-8107-5WA-035-741-B_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-035-741-B   HW:5WA-035-741-B ---  8107: Antenna
;Component:TrxModulHigh  H10 0083, Coding:02380011440080
;EV_TrxMLGEMQB37W,005006,EV_TrxMLGEMQB37W.rod
;Thursday,03,September,2026,18:12:27:29755
;VCID: 43D349245B129BA2BA2-8016 SFD {x}
IDE02122-Developer mode-,not activated ,1
IDE02122-ENG259763-Developer mode-dTLS_state,activated ,1
IDE02122-ENG260134-Developer mode-SOK_state,activated ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,0 min,2
IDE14831-IDE14832-Car2X noise level reduction-Drop during warning,not activated ,1
IDE14831-IDE14833-Car2X noise level reduction-Setback in information,not activated ,1
IDE14834-Car2X units,meter ,1
IDE14836-MAS19394-Car2X vehicle parameters-Accelerator pedal position,30 %,15
IDE14836-MAS19395-Car2X vehicle parameters-Maximum acceleration,5.0 m/s²,15
IDE14836-MAS19396-Car2X vehicle parameters-Maximum brake pressure,40.0 bar,15
IDE14836-MAS19397-Car2X vehicle parameters-Maximum delay,10.0 m/s²,15
IDE14836-MAS19399-Car2X vehicle parameters-Vehicle length,425 cm,15
IDE14836-MAS19400-Car2X vehicle parameters-Vehicle width,180 cm,15
IDE14836-MAS19446-Car2X vehicle parameters-Reference distance,353 cm,15
IDE14836-ENG260979-Car2X vehicle parameters-Vehicle_LongitudinalAxis_ReferencePoint,0 cm,15
MAS18420-MAS18421-Performance compensation: WLAN 5 GHz main antenna-Lower threshold,0 dBm,4
MAS18420-MAS18422-Performance compensation: WLAN 5 GHz main antenna-Upper threshold,21 dBm,4
MAS18423-MAS18421-Performance compensation: WLAN 5 GHz auxiliary antenna-Lower threshold,11 dBm,4
MAS18423-MAS18422-Performance compensation: WLAN 5 GHz auxiliary antenna-Upper threshold,20 dBm,4
MAS19391-MAS19419-Car2X detection functions-EASS Detection,activated ,2
MAS19391-MAS19420-Car2X detection functions-Bad weather detection,not activated ,2
MAS19391-MAS19421-Car2X detection functions-Traction loss detection,not activated ,2
MAS19391-MAS19422-Car2X detection functions-Stopper detection,activated ,2
MAS19391-MAS19423-Car2X detection functions-Breakdown detection,activated ,2
MAS19391-MAS19424-Car2X detection functions-Crash detection,activated ,2
MAS19391-MAS19425-Car2X detection functions-Traffic jam detection,activated ,2
MAS19391-MAS19426-Car2X detection functions-End of tailback detection,activated ,2
MAS19391-MAS19427-Car2X detection functions-SEF detection emergency drive,not activated ,2
MAS19391-MAS19428-Car2X detection functions-Detection SEF protection hazardous area,not activated ,2
MAS19392-MAS19429-Car2X Interpretation-EASS interpretation,activated ,2
MAS19392-MAS19430-Car2X Interpretation-Breakdown interpretation,activated ,2
MAS19392-MAS19431-Car2X Interpretation-Standing vehicle interpretation,activated ,2
MAS19392-MAS19432-Car2X Interpretation-Stationary SEF interpretation,activated ,2
MAS19392-MAS19433-Car2X Interpretation-Construction site interpretation,activated ,2
MAS19392-MAS19434-Car2X Interpretation-Crash interpretation,activated ,2
MAS19392-MAS19435-Car2X Interpretation-End of tailback interpretation,activated ,2
MAS19392-MAS19436-Car2X Interpretation-Obstructed view interpretation,not activated ,2
MAS19392-MAS19437-Car2X Interpretation-Interpretation,not activated ,2
MAS19392-MAS19438-Car2X Interpretation-Interpretation of generic point event,not activated ,2
MAS19392-MAS19439-Car2X Interpretation-Interpretation of generic SEF,not activated ,2
MAS19392-MAS19440-Car2X Interpretation-Dynamic SEF interpretation,activated ,2
MAS19392-MAS19441-Car2X Interpretation-Basic service,activated ,2
MAS19393-IDE02096-Car2X display-Warning sound,activated ,13
MAS19393-IDE02096-Car2X display-Warning sound,not activated ,13
MAS19393-IDE14819-Car2X display-Infotone,activated ,13
MAS19393-IDE14819-Car2X display-Infotone,not activated ,13
MAS19393-IDE14820-Car2X display-Danger level information,not activated ,13
MAS19393-IDE14820-Car2X display-Danger level information,activated ,13
MAS19393-IDE14821-Car2X display-Danger level warning,activated ,13
MAS19393-IDE14821-Car2X display-Danger level warning,not activated ,13
MAS19393-IDE14830-Car2X display-Function display,activated ,13
MAS19393-MAS07135-Car2X display-Activation status,activated ,13
MAS19393-MAS07135-Car2X display-Activation status,not activated ,13
ENG244879-function_configuration_sw_update,OFF ,1
Elapsed Time: 00:06
adpmap-811E-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  811E: Burglary Protection FL
;Component:Kessy RSAD    070 0636, Coding:
;EV_RSADVL37w,002013,EV_RSADVL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:38:29755
;VCID: 4BC36104734253E2422-801E
ENG253318-Par_Fahrzeugkonfiguration,255 dBµA/m,5
Elapsed Time: 00:01
adpmap-811F-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  811F: Burglary Protection FR
;EV_RSADVR37w,002013,EV_RSADHL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:44:29755
Elapsed Time: 00:01
adpmap-8120-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  8120: Burglary Protection RL
;EV_RSADHL37w,002013,EV_RSADHL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:49:29755
Elapsed Time: 00:01
adpmap-8121-5WA-962-133-F_WVWZZZCD6RW123439-20260903-1812.CSV
;SW:5WA-962-133-F   HW:5WA-962-133-F ---  8121: Burglary Protection RR
;EV_RSADHR37w,002013,EV_RSADHL37w_002_VW38.rod
;Thursday,03,September,2026,18:12:55:29755
Elapsed Time: 00:01
datodaco
Slovenia
C?ID=393757
WVWZZZCD6RW123439,Address 0x19,5WA 907 530 AB,Online SFD,Thursday,03,September,2026,17:38:56,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x19,5WA 907 530 AB,Online SFD,Thursday,03,September,2026,17:38:59,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x19,5WA 907 530 AB,Online SFD,Thursday,03,September,2026,17:38:59,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x19,5WA 907 530 AB,Online SFD,Thursday,03,September,2026,17:39:02,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x01,05C 906 032 AF,Online SFD,Thursday,03,September,2026,17:39:14,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x01,05C 906 032 AF,Online SFD,Thursday,03,September,2026,17:39:16,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x01,05C 906 032 AF,Online SFD,Thursday,03,September,2026,17:39:16,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x01,05C 906 032 AF,Online SFD,Thursday,03,September,2026,17:39:17,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x03,5WA 614 517 CF,Online SFD,Thursday,03,September,2026,17:42:24,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x03,5WA 614 517 CF,Online SFD,Thursday,03,September,2026,17:42:26,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x03,5WA 614 517 CF,Online SFD,Thursday,03,September,2026,17:42:26,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x03,5WA 614 517 CF,Online SFD,Thursday,03,September,2026,17:42:28,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x09,5WA 937 086 BM,Online SFD,Thursday,03,September,2026,17:43:25,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x09,5WA 937 086 BM,Online SFD,Thursday,03,September,2026,17:43:27,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x09,5WA 937 086 BM,Online SFD,Thursday,03,September,2026,17:43:27,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x09,5WA 937 086 BM,Online SFD,Thursday,03,September,2026,17:43:34,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x15,5WA 959 655 L,Online SFD,Thursday,03,September,2026,17:44:20,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x15,5WA 959 655 L,Online SFD,Thursday,03,September,2026,17:44:22,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x15,5WA 959 655 L,Online SFD,Thursday,03,September,2026,17:44:22,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x15,5WA 959 655 L,Online SFD,Thursday,03,September,2026,17:44:25,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x17,5H0 920 340 C,Online SFD,Thursday,03,September,2026,17:44:46,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x17,5H0 920 340 C,Online SFD,Thursday,03,September,2026,17:44:48,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x17,5H0 920 340 C,Online SFD,Thursday,03,September,2026,17:44:48,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x17,5H0 920 340 C,Online SFD,Thursday,03,September,2026,17:44:50,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x23,5WA 909 059 AB,Online SFD,Thursday,03,September,2026,17:45:27,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x23,5WA 909 059 AB,Online SFD,Thursday,03,September,2026,17:45:33,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x23,5WA 909 059 AB,Online SFD,Thursday,03,September,2026,17:45:33,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x23,5WA 909 059 AB,Online SFD,Thursday,03,September,2026,17:45:34,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x5F,5H0 035 820 P,Online SFD,Thursday,03,September,2026,17:47:16,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x5F,5H0 035 820 P,Online SFD,Thursday,03,September,2026,17:47:19,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x5F,5H0 035 820 P,Online SFD,Thursday,03,September,2026,17:47:19,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x5F,5H0 035 820 P,Online SFD,Thursday,03,September,2026,17:47:21,H11-031216,Unlock_successful
WVWZZZCD6RW123439,Address 0x75,5WA 035 284 F,Online SFD,Thursday,03,September,2026,17:47:47,H11-031216,SFD challenge retrieval success, 583 bytes
WVWZZZCD6RW123439,Address 0x75,5WA 035 284 F,Online SFD,Thursday,03,September,2026,17:47:50,H11-031216,SFD unlock token retrieval success, 852 bytes
WVWZZZCD6RW123439,Address 0x75,5WA 035 284 F,Online SFD,Thursday,03,September,2026,17:47:50,H11-031216,SFD unlock token transmitted to controller
WVWZZZCD6RW123439,Address 0x75,5WA 035 284 F,Online SFD,Thursday,03,September,2026,17:47:51,H11-031216,Unlock_successful
