Issues with turbo mode (when computer is "hot")
burpod
Cape Cod, MA, USA
C?ID=18755
keep meaning to post this and procrastinating. but i've noticed that with my vcds-mobile, when trying to log data in TURBO mode, when the computer feels like it's running a bit hot (summer temps, sun shining on it thru the car window, etc) when i try to engage turbo mode, vcds will often hang up or crash completely, and when it does work, it's often kinda spotty, keeps cutting out. when things are cool, i rarely have this issue. anyone else have had this happen to them?
the vcds-mobile in question is a replacement one i got a year or two ago, because my old one which i had for quite a few years developed in issue with the usb connection or something. trying to figure out if this is a known issue or has a reasonable explanation, or perhaps i have a buggy unit. i've also noticed on this unit, connection seems to be kinda flaky in general. i'm wondering if it just has a problem and needs to be checked out/replaced again. my usb port itself seems fine - i use mpps ALL the time and never have any issues there with connection dropping out.
Shaun
Are you connected via USB or WIFI? What type of computer is this? What control module are you talking to, turbo mode can also highly depend on the module in the vehicle. Do you have an autoscan of this vehicle?
burpod
Cape Cod, MA, USA
C?ID=18755
- connected via USB using VCDS, using vcds version 26 iirc, just updated it earlier this summer/spring
- happens in both edc16 PD cars i have - a BEW mk4 and a BHW b5.5 passat
- engine module - turbo mode for logging basic engine data :)
- laptop is dell latitude 5480. i don't think there's anything wrong with the usb, as i've used mpps countless times with it in the same temp conditions and never a problem. if usb were flaky mpps would crap out and likely leave the ecu bricked. any interruption in USB mpps software will just up and quit
i have not done an autoscan, but can get one...
like i said, when temps are cooler, aside from being a bit flaky (in general with staying connected to USB), it works in turbo mode fine. it's only when its warm out and the computer
Shaun
If you can, the next time this happens pay attention to the LEDs on the interface and see if it looks like the interface resets.
You also might want to try looking into a utility like hwinfo or cpu-z that can display real time processor frequencies and check if your cpu is throttling when it is hot, you should be able to see temperatures and clock rates with those tools. If you see that the cpu temp is very high and the clock rate is dropping, that might point to an issue with the PC overheating.
burpod
Cape Cod, MA, USA
C?ID=18755
thanks i'll check that stuff out. actually, forgot my wife has the same laptop (but less beat up than mine since i'm constantly dragging mine around in the car). i'll try hers on a hot day too, just to see
