Saturday,29,August,2026,17:25:21:40929
VCDS Version: Release 26.3.0.0 HEX-V2 CB: 0.4713.4
www.ross-tech.com
Dealer Name: goman yannick
VIN: VSSZZZ5FZLR009628 License Plate: GW151MR
Mileage: 91429km Repair Order:
Chassis Type: 5F-SE37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 2B 32 42 44 47 4B 52
5F A5 A9 BB BC D6 D7
VIN: VSSZZZ5FZLR009628 Mileage: 91429km
10-Park Assist -- Status: Malfunction 0010
22-AWD -- Status: Cannot be reached 0100
32-Differential Lock -- Status: Cannot be reached 0100
42-Door Elect, Drv -- Status: OK 0000
52-Door Elect, Pass -- Status: Malfunction 0010
A5-Front Sens. Drv. Assist -- Status: Malfunction 0010
A9-Structure Borne Sound -- Status: OK 0000
Address 01: Engine (J623-DNUC) Labels:. 06K-907-425-V1.clb
Control Module Part Number: 8V0 906 259 R HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0003
Revision: --H13--- CVN: 2F7D4557
Coding: 0B2540122464010B3000
Shop #: WSC 00049 770 00127
ASAM Dataset: EV_ECM20TFS0208V0906259R 001003
ROD: EV_ECM20TFS0208V0906259R.rod
VCID: 4FFB617DC754D262069-801A
VINID: 9A38EAAAA156A9C88000918220B174EC1F
17178 - ESP
U0416 00 [00100111] - Implausible Signal
Intermittent - Not Confirmed - Tested since memory clear
Mileage: 91429 km
Date: 2026.08.28
Time: 00:42:55
Engine RPM: 0.00 /min
Vehicle Speed: 0 km/h
Coolant temperature: 34 °C
Intake air temperature: 36 °C
Terminal 30 voltage: 11.582 V
Powertrain coordinator: fault statuses ACC-ACC active despite EPB deceleration: no
Powertrain coordinator: fault statuses ACC-ACC active although TSK passive: no
Powertrain coordinator: fault statuses ACC-Start or stop request at undefined stop speed: no
Powertrain coordinator: fault statuses ACC-Start and stop requests sent simultaneously: no
Powertrain coordinator: fault statuses ACC-ACC active although limiter active: no
Powertrain coordinator: fault statuses ACC-ACC reactivates after blocking: no
Powertrain coordinator: fault statuses ACC-ACC sends undefined signals: no
Powertrain coordinator: fault statuses ACC-ACC active although main switch off: no
Powertrain coordinator: fault statuses ACC-ACC active despite driver braking: no
Powertrain coordinator: fault statuses ACC-ACC active despite ESP/ASR deactivation: no
Powertrain coordinator: brake fault statuses-Deceleration governor unavailable: no
Powertrain coordinator: brake fault statuses-Deceleration governor fault: no
Powertrain coordinator: brake fault statuses-ESP system fault: no
Powertrain coordinator: brake fault statuses-ESP system fault due to engine torque inaccuracy: no
Powertrain coordinator: brake fault statuses-ESP signals TSK message consistency fault: no
Powertrain coordinator: brake fault statuses-TSK/ESP Handshake fault: no
Powertrain coordinator: brake fault statuses-Defective forced ESP activation: no
Powertrain coordinator: brake fault statuses-Implausible brake light: no
Readiness: 1110 0001
Control Module Part Number: 0GC 300 020 L HW: 0GC 927 711 H
Component: GSG DQ381 H06 2401
Revision: 00H06V15 CVN: 1F295D3D
ROD: EV_TCMDQ381061.rod
VCID: 2B0315ED938CCE424A1-807E
No Subsystems found.
Control Module Part Number: 5Q0 614 517 ES HW: 5Q0 614 517 BP
Component: ESC H35 0190
Revision: 00000000 Serial number: 61989000000815
Coding: 20EE6B9250202175877D060240CB6904D60A84E160029677384250F5D2264B010000000012121212B835351919323200
Shop #: WSC 99999 999 2097151
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 0655845968AED32AF5F-8052
8292 - Control Module Incorrectly Coded
U1014 00 [10001001] - -
[FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
MIL ON - Confirmed - Tested since memory clear
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:40:21
8331 - Databus
U1121 00 [10001001] - Missing Message
[FCAN: Quersperre_03 message is not received]
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:40:21
Control Module Part Number: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0524103508 UDS Data:: V03935283KP 0001
Coding: 132C0C0707
ROD: EV_KessyHellaMQBAB_004_AU37.rod
VCID: 45D7435515281832BC5-8010
Control Module Part Number: 5F0 907 044 BF HW: 5F0 907 044 BF
Component: Climatronic H06 2201
Revision: 00001K10
Coding: 00000014200114011105000000101024
Shop #: WSC 00049 770 00229
ASAM Dataset: EV_ACClimaBHBVW37X 006150
VCID: 6B83D5ED530C0E420A1-803E
Fresh Air Blower Control Module (Front):
Refrigerant Pressure/Temperature Sensor:
Air Quality Sensor:
1048838 - Function Limitation due to Energy Management
B10CD 00 [00001001] - -
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:41:51
Terminal 30 voltage: 11.3 V
CAN Input Signal Status-Transport Mode: Active
CAN Input Signal Status-Quiescent Current Setting Mode: Deactivated
CAN Input Signal Status-Front Wiper: Deactivated
CAN Input Signal Status-Energy Management: Shut-off Level: Shut-off Level 1
CAN Input Signal Status-Wipe/Wash: Deactivated
CAN Input Signal Status-Rear Window Defogger Actual Value: Deactivated
CAN Input Signal Status-Reverse Gear: Deactivated
CAN Input Signal Status-Windshield Defogger Actual Value: Deactivated
Control Module Part Number: 5Q0 937 084 DH HW: 5Q0 937 084 CG
Component: BCM MQBAB H H40 0312
Serial number: 01001919202405 UDS Data:: V03935300F 0001
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_AU27.rod
VCID: 015F97454180F412C0D-8054
Wiper Motor Control Module:
Subsystem 1 - Control Module Part Number: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 190620 041 0574
Serial number: 190627081623
Coding: 0BC5FD
Rain and Light Sensor:
Subsystem 2 - Control Module Part Number: 81A 955 555 A HW: 81A 955 555
Serial number: 23305317X81A955555A0
Coding: 00005D
Sliding Sunroof Control Module:
Subsystem 3 - Control Module Part Number: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.405 H04 0005
Serial number: 0000FST002DFK5J00000
Coding: 180102
Steering Column Switch:
Subsystem 4 - Control Module Part Number: 5Q1 953 507 BQ HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000028071904400717
Address 10: Park Assist (J446) Labels:| 5Q0-919-294.clb
Control Module Part Number: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058019201 UDS Data:: V03935290RL 0002
Coding: 0471151011
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50F96201DA6ACD9A1F3-8004
13637426 - Databus
U1123 00 [00001001] - Received Fault Value
[ESP - ESP_21.ESP_Systemstatus - Read out fault memory]
Fault Frequency: 8
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:41:02
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Control Module Part Number: 5Q0 907 572 P HW: 5Q0 907 572 J
UDS Data:: V03935269FJ 0001
Coding: 350067C15DFFC728949C814580400600000000000000000000
VCID: 44D15E511E12213AABB-8010
0803 - Databus
[FAULT_BV1_FEHLER]
Fault Frequency: 9
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:40:31
Control Module Temperature: 44 °C
Terminal 15 Voltage: 11.3 V
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:40:31
0928 - Databus
[FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:40:31
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:40:31
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Control Module Part Number: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 25061941350788 UDS Data:: V03935286WC 0001
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38293AA152DA75DA373-806C
Control Module Part Number: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PDAMQMT UDS Data:: V03935263XZ 0001
Coding: 98CCC000000000005C0000CC000800000065
ROD: EV_AirbaVW21TS6VW48X_VW41.rod
VCID: 0B43B56D73CCAE42AA1-805E
Crash Sensor Side Airbag Driver Side:
Subsystem 1 - Control Module Part Number: ----------- HW: 454 001 606 19
Serial number: 35700000000890205C3B
Crash Sensor Side Airbag Passenger Side:
Subsystem 2 - Control Module Part Number: ----------- HW: 454 001 806 19
Serial number: 35800000000B70405B3E
Crash Sensor Rear Side Airbag Driver Side:
Subsystem 3 - Control Module Part Number: ----------- HW: 454 801 406 19
Serial number: 35100EF0AEC18000000/
Crash Sensor Rear Side Airbag Passenger Side:
Subsystem 4 - Control Module Part Number: ----------- HW: 454 800 706 19
Serial number: 3520087B9E718000000W
Crash Sensor Front Airbag Driver Side:
Subsystem 5 - Control Module Part Number: ----------- HW: 454 800 807 19
Serial number: 35500CC443F19000000U
Control Module Part Number: 5F0 920 790 A HW: 5F0 920 790 A
Component: KOMBI 610 1703
Coding: 04AC29187F840008008862031001000080000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001031
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 270BE9DD8F64EA22AE9-8072
Control Module Part Number: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 13081910521311 UDS Data:: V03935302EM 0001
Coding: 030100F42F085900EB108279980F00010001070000000000000000000000
GVL: 01C63C7000000600408C80000000CC0000000000000200000000000000000000
ROD: EV_GatewNF_SE37.rod
VCID: 70B9C2817A2AED9A3F3-8024
Generator:
Component: 4-01-13-01-04
Multifunction Steering Wheel Control Module:
Subsystem 2 - Control Module Part Number: 5F0 959 537 D HW: 5F0 959 537 D
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000H1727280619
Coding: 012000
Subsystem 3 - Control Module Part Number: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 758860030019071001BE
131613 - Control Module Not Defined
U1126 00 [00001001] - No Communication
[Timeout Knoten 0x1D]
Supply Voltage Terminal 30: 11.6 V
Immo-Slaves Status / Terminal 15: active
131614 - Control Module for Differential Lock
U1040 00 [00001001] - No Communication
[Timeout Knoten 0x1E / 32 - Control Module for Differential Lock]
8526361 - LV Energy Management
B1802 F1 [00001001] - Warning Triggered
Supply Voltage Terminal 30: 11.4 V
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Control Module Part Number: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00021.08.17 UDS Data:: v1260x015G0 0000
Coding: 0001
VCID: 4CC176713642E97A63B-8018
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Control Module Part Number: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000146248004
Coding: 5D00000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F0785B1A0A49270D-8064
Address 32: Differential Lock
Address 42: Door Elect, Drv (J386) Labels:* Redir Fail!
Control Module Part Number: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0480
Serial number: 0000382319839 UDS Data:: V03935298XN 0001
Coding: 00141320D000020000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 4DC77B75CD58E072745-8018
Rear Door Control Module Driver Side:
Subsystem 1 - Control Module Part Number: 5Q0 959 407 A HW: 5Q0 959 163 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000031937425
Coding: 310000
Control Module Part Number: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
UDS Data:: V03935283CZ 0001
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C2126B166E259FAD3B-8068
11776 - Supply Voltage
U1011 00 [00001001] - Voltage Too Low
[Warning of permanently too low supply voltage Undervoltage display]
Engine Status: 00
Supply Voltage: 10.25 V
Temperature: 41.0 °C
KFC: 2E
KFA: 00 00
Environmental conditions: 5F
uioUdNotFilt_xdu16: 10.50 V
uAdSensI_SwitchedKl30_xdu16: 10.47 V
RP_VALCNTSAV: Not Active
RP_DIAGJOB: Not Active
RP_RPS: Not Active
RP_KMN_RACKPOS_SET: Not Active
RP_STARTUP: Not Active
RP_L2PLAUSI: Not Active
RP_INDEXPLAUSI: Not Active
RP_WHLSPDPLAUSI: Not Active
RP_RUKUCNTR: Not Active
RP_UNDERVOLT: Not Active
RP_CNTERR: Not Active
Address 47: Sound System
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Control Module Part Number: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 10071910800912 UDS Data:: V03935270EA 0004
Coding: 000000070900094A07000940000000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372B399D5FC47AA23E9-8062
Address 52: Door Elect, Pass (J387) Labels:| 5QX-959-X92-52.clb
Control Module Part Number: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000383503535 UDS Data:: V03935298XQ 0001
Coding: 00141120DE00020000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
Rear Door Control Module Passenger Side:
Subsystem 1 - Control Module Part Number: 5Q0 959 408 A HW: 5Q0 959 164 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000032064584
Coding: 290000
1114133 - Rear Window Lifter Front Passenger Side
B1320 F5 [00001000] - Supply Voltage - Too Low
Intermittent - Confirmed - Tested since memory clear
Reset counter: 1
Mileage: 91429 km
Date: 2026.08.27
Time: 05:23:14
Address A5: Front Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 04071915P20420 UDS Data:: V03935281KD 0003
Coding: 0303070300000400012223448150890098000E20002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D952410A0A3D1A8F3-8014
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Fault Frequency: 8
Reset counter: 216
Mileage: 91429 km
Date: 2026.08.27
Time: 04:41:05
Control Module Temperature: 43 °C
Outside Temperature: 27.5 °C
Vehicle Speed: 0.00 km/h
System Run Time: 234.6 s
mid: 02 E0
Camera Status: Operational
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
Address A9: Structure Borne Sound (J869) Labels: 4H0-907-159.clb
Control Module Part Number: 5F0 907 159 E HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 190517201714
VCID: 2F3B01FDA794B262669-807A
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Control Module Part Number: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 025D98494486EF0AD97-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ROD: EV_LEDPLUSRightKEBODVW416_VW37.rod
End----(Elapsed Time: 02:01, VBatt start/end: 10.5V/10.2V. VIgn 10.3V)-----
--------------------------15 Faults Found--------------------------
