A3, 2016, Comfort Turn Signal Coding - Fail – Security Code Required
Chaz
C?ID=252897
...as the title states. How do I make the change? Any ideas?
Thanks,
Chaz
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WAUB8GFFXG1036768   License Plate:
Mileage: 984km-611mi   Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C
VIN: WAUB8GFFXG1036768   Mileage: 984km-611miles
Address 01: Engine (J623-CNTC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1D00124426000F3000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS0205G0906259D_AU37.rod
   VCID: 2F43E43376B49546D7-807A
   Part No SW: 0D9 300 013 B    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serial number: TFK01508191522
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 160D31D7E92E448EB4-8042
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 92275000008168
   Coding: 13FF6A9234230A72017E030681CB29C8562C5080C08194B6024100548208
   VCID: 79D71A6BF8708BF639-802C
   Revision: 00021000    Serial number: 0377566252
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A55C567BDF640EE70-806E
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000718089
   Coding: 03000014010000000000000000001400
   VCID: 334BE8439A9CB1A6B3-8066
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 085 AH    HW: 5Q0 937 085 AE
   Component: BCM MQBAB MNA H24 0175
   Serial number: 01061523901093
   Coding: 04151A46C04122F541C04004511007000800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7F23F473E654A5C607-802A
   Slave 1:
   Component: WWS371 150721  042 0585
   Serial number:         150808004518
   Coding: 0A47F7
   Slave 2:
   Serial number: 20560377
   Coding: 00006C
   Slave 3:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 25 06 2015  00000392
   Serial number: 00000000000063398600
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000H6D1100000
   Coding: 101F00
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Revision: --------    Serial number: 39331524106920
   Coding: 0010150011
   ROD: EV_EPHVA18AU3700000_AU37.rod
   VCID: 43ABB883CA3C012623-8016
   Serial number: 003GCR03ALW
   VCID: 47B3AC93FE042D06FF-8012
   Seat belt tensioner; left:
   Serial number: 34230167A07091540713
   Coding: 333135
   Seat belt tensioner; right:
   Serial number: 34230168A07091540856
   Coding: 333135
   Seat occupant detection; front passenger side:
   Serial number: 694000000000001E3GNX
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 002 608 15
   Serial number: 35700000000F7A48661T
   Subsystem 5 - Part No SW: -----------    HW: 480 002 608 15
   Serial number: 35800000000C6A48661Q
   Subsystem 6 - Part No SW: -----------    HW: 480 402 408 15
   Serial number: 3510002B71CF1D33E24B
   Subsystem 7 - Part No SW: -----------    HW: 480 402 808 15
   Serial number: 3520002B11C1EFA5F19L
   Subsystem 8 - Part No SW: -----------    HW: 480 400 705 15
   Serial number: 3550002C71A878726142
   Subsystem 9 - Part No SW: -----------    HW: 480 400 705 15
   Serial number: 3560002C51A87872322/
   Part No SW: 8V0 953 521 FH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 27081508490861
   Coding: A018
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 052F669B8488FF164D-8050
   Part No SW: 8V0 920 960 M    HW: 8V0 920 960 M
   Component: KOMBI         H03 6420
   Coding: 0BE518192B80D7050200AA001800000000000000
   VCID: 45AFA69BC4083F160D-8010
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 29081510802622
   Coding: 0101000830085A005B00020C180B00000001010000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 75CF165BD468EF965D-8020
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 06 08 2015  B0015107
   Serial number: HA1-00014.07.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4AB595A7ED16D06EE0-801E
   Revision: 00000000    Serial number: 15000188545010
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3449EB5F9F92B69EAA-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 110715BGA19147
   Coding: 00101B204000048000000002
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 41A7B28BD020133631-8014
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 0102
   ROD: EV_SteerAssisMQB.rod
   VCID: 44A9BB9FCF32061E1A-8010
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 180715BGH19574
   Coding: 001013204000048000000002
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 40A1B78FDB2A1A3E3E-8014
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 012A000101000000
   ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
   Part No SW: 8V0 035 844 C    HW: 8V0 035 844
   Component: MU-S-S-US     013 0660
   Serial number: A7A02408150931
   Coding: 01730100FF0A000011220001001A00002F0001440100010002
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE_AU37.rod
   VCID: 3957DA6BB8F04BF679-806C
   Seat Adjustment Driver Side:
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30CLC5
   Sound System:
   Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Component: ControlUnit_B  H41 0054
   Serial number: C1000019061500040051
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Coding: 027300010201000300
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 3041E74F6B8A8ABECE-8064
End-------------------------(Elapsed Time: 03:28)--------------------------
Below is a link showing VCDS screen shots during the process.
Chaz
C?ID=252897
DJAlix
Thanks for the reply, I'll check again, however, don't remember seeing a field to enter a security code. As I'm new to VCDS is there a "global" security code entry location or would it be a pop up entry box?
After I clicked the OK on security, it just failed with a condition of, "security code required - failed", no request for a code entry.
Regards
golfi_vend
Tartu, Estonia
C?ID=195131
Check under the button where you press Coding and Adaption.
DJAlix
London, United Kingdom
C?ID=238277
Not a problem :)
There is no "global" security access field as each control module can have it's own individual (some times multiple) code. To enter a code do the following:
- Enter the needed control module
- Select the "Security Access - 16 Button"
- In the new box that pops up enter your code and select Do It!
- Proceed to Adaptations or Coding
The security code you entered will be valid until you exit / disconnect from the control module. If you need to go back in to the module to continuing modification just repeat the above process.
Something to note, 9 times out of 10 if the code in question is known to Ross-Tech it will be shown within a "tooltip bubble" on mousing over the security access code enter box.
Chaz
C?ID=252897
DJAlix,
I followed your instructions and it worked as described, the change was accepted. Thank you!
Regards,
Chaz
Chaz
C?ID=252897
DJAlix,
Nice professional document you're cobbling together there, nicer than a lot of “manufacturers” documents Ive see. More importantly it should contain a valuable quantity of information as it progresses.
Keep up the good work!
Chaz
DJAlix
C?ID=238277
DJAlix,
Chaz
Thanks Chaz! Is a major update coming very soon :)
