- Jan 25, 2025
- 2
- 2
- Durham, NC, USA
- C?ID=157156
Posting per the sticky. Not requesting an exception, SFD Service is active on this interface (order #20311997).
Version note, please read first. All of this was captured with VCDS Release 26.9.0 (x64), data version 20260828 DS378.0, not the Beta. My HEX-V2's Beta 26.7.2 long serial was rejected at the store with "SFD Service is not available for this Interface", and the Release 26.3.0 long serial was rejected as too old. The store page indicated there was no current Beta at that time, and the 26.9.0 Release serial is what went through. My
Vehicle 2022 VW Golf GTI, chassis CD-VW38 (5WA), DQ381 transmission, MQB37W Interface: HEX-V2, short serial H17-010495
Work this was captured around 12V battery replacement and registration to the J367 battery monitoring module, an SRI reset, and diagnosis of a back-up camera ethernet fault (U1643 in gateway 19, C135B in module 6C). The battery adaptation is what forced the SFD requirement, since the write is refused with a security access error while 19 is locked.
What is included Locked adaptation and measuring value maps for all eight SFD-gated modules on this car, plus locked and unlocked pairs for two of the four modules I unlocked (09 and 19).
Glad to unlock and re-map the other four if that is useful, my SFD Service runs to 2026-10-01.
Observation 1: locked maps omit gated content with no indication
Gated measuring value groups are absent from a locked map rather than present and flagged.. On gateway 19, 25 measuring value groups simply do not appear in the locked block map, and on 09 it is 307 (832 groups locked against 1137 unlocked).
The practical consequence is that a locked map gives no indication it is incomplete. I was taking maps as a pre-coding backup, and I only discovered the gap by diffing against the unlocked capture afterwards. Some marker along the lines of "channel exists but is SFD-gated" would make locked maps trustworthy for that purpose.
Observation 2: gating is not uniform across modules or map types
On 09 the locked and unlocked adaptation maps carry the same channel set. Diffing them name to value showed exactly one differing value, and that was a change I made myself between the two captures. So SFD hid nothing on the adaptation side of that module, while 19 hid 25 measuring groups on the block side.
Observation 3: module 09 is consistently slower to unlock
Challenge and token sizes are identical every time (583 bytes and 852 bytes), but elapsed time from challenge retrieval to
Consistent across sessions a day apart. Not a problem, just noting it in case it is unexpected.
Observation 4: possible logging bug in SFDLog.CSV
while these three populate it normally:
All seven were on the same vehicle in the same physical session set.
Relatedly, in AdpLog.CSV the battery adaptation attempt at 20:45:37, made before the SFD session started, is logged with an empty control module part number field, while the successful write at 20:47:54 after unlocking carries
Observation 5: SRI reset did not require SFD, battery adaptation did
Both are on your example list, so the scope difference may be worth documenting. Timestamps from SRILog and SFDLog:
The SRI reset completed on module 17 more than seventeen minutes before that module was ever unlocked. The battery adaptation on 19, by contrast, was refused with a security access error until SFD was live.
Note on the log files
AdpLog and SRILog are trimmed to this vehicle. CodingLog and GESLog contain no entries for this car at all, so I have not posted them. Happy to supply anything further by PM.
SFDLog.CSV
SRILog.txt (trimmed to this vehicle)
AdpLog.CSV (trimmed to this vehicle)
Auto-Scan
The Auto-Scan below was run at the end of the session and its 49 faults are almost entirely residue from the 12V battery disconnect and from modules being woken and dropped repeatedly during the SFD unlocks, left uncleared so the scan matches the exact state the maps were captured in.
Maps
C:\Ross-Tech\VCDS-Beta\Debug folder is empty, so there is nothing to contribute from the Beta side. Happy to re-run any of this on Beta if you would rather have it from that build, just point me at the download.Vehicle 2022 VW Golf GTI, chassis CD-VW38 (5WA), DQ381 transmission, MQB37W Interface: HEX-V2, short serial H17-010495
| Module | Part number | Locked | Unlocked |
| 03 ABS Brakes | 5WA 614 517 BL | yes | no |
| 09 Cent. Elect. | 5WA 937 086 AE | yes | yes |
| 15 Airbags | 5WA 959 655 M | yes | no |
| 17 Instruments | 5H0 920 340 B | yes | no |
| 19 CAN Gateway | 5WA 907 530 Q | yes | yes |
| 23 Brake Booster | 5WA 909 059 K | yes | no |
| 5F Information Electr. | 5H0 035 871 | yes | no |
| 75 Telematics | 5WA 035 285 A | yes | no |
Unlock_successful is not:| Module | Unlock time |
| 17 Instruments | 3 s, 4 s, 3 s |
| 19 CAN Gateway | 5 s |
| 5F Information Electr. | 5 s, 6 s, 5 s |
| 09 Cent. Elect. | 11 s, 9 s |
Start SFD Session rows are inconsistent about recording the VIN. These four have an empty first field:
20:46:48 (09-01), 22:46:30 (09-01), 18:58:46 (09-02), 19:04:13 (09-02)
23:16:20 (09-01), 23:38:49 (09-01), 00:07:23 (09-02)
5WA 907 530 Q normally.Observation 5: SRI reset did not require SFD, battery adaptation did
20:37:44 SRI reset opened on 17 Instruments
20:38:36 Reset ESI/OIL written, "saved successfully"
20:39:07 Verified: distance 7700 km to 0, time 121 d to 0, thermal load 10100 km to 0
20:46:48 First SFD session started
20:55:52 Module 17 SFD-unlocked for the first time
SFDLog.CSV
,,,Start SFD Session,Tuesday,01,September,2026,20:46:48,H17-010495,SFD session start successful
WVWG87CD9NW139014,Address 0x19,5WA 907 530 Q,Online SFD,Tuesday,01,September,2026,20:47:27,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x19,5WA 907 530 Q,Online SFD,Tuesday,01,September,2026,20:47:29,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x19,5WA 907 530 Q,Online SFD,Tuesday,01,September,2026,20:47:29,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x19,5WA 907 530 Q,Online SFD,Tuesday,01,September,2026,20:47:32,H17-010495,Unlock_successful
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,20:55:52,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,20:55:54,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,20:55:54,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,20:55:55,H17-010495,Unlock_successful
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,21:01:18,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,21:01:20,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,21:01:20,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,21:01:23,H17-010495,Unlock_successful
,,,Start SFD Session,Tuesday,01,September,2026,22:46:30,H17-010495,SFD session start successful
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,22:46:57,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,22:46:59,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,22:46:59,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Tuesday,01,September,2026,22:47:03,H17-010495,Unlock_successful
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Tuesday,01,September,2026,22:59:11,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Tuesday,01,September,2026,22:59:13,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Tuesday,01,September,2026,22:59:13,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Tuesday,01,September,2026,22:59:22,H17-010495,Unlock_successful
WVWG87CD9NW139014,,,Start SFD Session,Tuesday,01,September,2026,23:16:20,H17-010495,SFD session start successful
WVWG87CD9NW139014,,,Start SFD Session,Tuesday,01,September,2026,23:38:49,H17-010495,SFD session start successful
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,23:43:54,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,23:43:56,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,23:43:56,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Tuesday,01,September,2026,23:43:58,H17-010495,Unlock_successful
WVWG87CD9NW139014,,,Start SFD Session,Wednesday,02,September,2026,00:07:23,H17-010495,SFD session start successful
,,,Start SFD Session,Wednesday,02,September,2026,18:58:46,H17-010495,SFD session start successful
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Wednesday,02,September,2026,18:59:16,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Wednesday,02,September,2026,18:59:18,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Wednesday,02,September,2026,18:59:18,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x5F,5H0 035 871 ,Online SFD,Wednesday,02,September,2026,18:59:21,H17-010495,Unlock_successful
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Wednesday,02,September,2026,18:59:52,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Wednesday,02,September,2026,18:59:54,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Wednesday,02,September,2026,18:59:54,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x17,5H0 920 340 B,Online SFD,Wednesday,02,September,2026,18:59:55,H17-010495,Unlock_successful
,,,Start SFD Session,Wednesday,02,September,2026,19:04:13,H17-010495,SFD session start successful
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Wednesday,02,September,2026,19:09:45,H17-010495,SFD challenge retrieval success, 583 bytes
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Wednesday,02,September,2026,19:09:47,H17-010495,SFD unlock token retrieval success, 852 bytes
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Wednesday,02,September,2026,19:09:47,H17-010495,SFD unlock token transmitted to controller
WVWG87CD9NW139014,Address 0x09,5WA 937 086 AE,Online SFD,Wednesday,02,September,2026,19:09:54,H17-010495,Unlock_successful
Tuesday,01,September,2026,20:37:44:51924
VCDS Release 26.9.0: SRI Reset-SRI2.CLB -- Data version: 20260828 DS378.0
WVWG87CD9NW139014
Control Module Part Number: 5H0 920 340 B Labels: .*5H0-920-KOM-V1.clb-SRI2
Component:KOMBI 220 5350, Coding:08BC0442638CCF050280220B2000000820300400
Operation: Please select an operation -- 1/3
Channel Description Current val. New val.
IDE12960-Resetting oil service ESI: Service Status no warning ---
IDE12964-Oil: driven distance since last oil service ESI: Distance SINCE last Oil Service 7700 km ---
IDE12965-Oil: time since last oil service ESI: Time SINCE last Oil Service 121 d ---
IDE12966-Oil: min distance until next oil service (flexible interval) ESI: Minimum Distance to Oil Service(s) 15000 km ---
IDE12967-Oil: max. distance until next oil service (flexible interval) ESI: Maximum Distance to Oil Service(s) 30000 km ---
IDE12968-Oil: min time until next oil service (flexible interval) ESI: Minimum Time to Oil Service(s) 365 d ---
IDE12969-Oil: max time until next oil service (flexible interval) ESI: Maximum Time to Oil Service(s) 730 d ---
IDE12980-Inspection: distance driven since the last inspection FIX: Distance SINCE last mileage-dependent Inspection 7700 km ---
IDE12981-Inspection: time since the last inspection FIX: Time SINCE last time-dependent Inspection 121 d ---
IDE12978-Inspection: distance until next inspection FIX: Max. Distance to mileage-dependent Inspection(s) 32200 km ---
IDE12979-Inspection: time until next inspection FIX: Max. Time to time-dependent Inspection(s) 365 d ---
IDE12970-Oil: distance until next oil service (fixed interval) SIA/SID: Maximum Distance to Service/Inspection 16100 km ---
IDE12971-Oil: time until next oil service (fixed interval) SIA/SID: Maximum Time to Service/Inspection 365 d ---
*IDE12972-Oil: theoretical service interval ESI/INFO: Theoretical Oil Service Interval 38100.00 km ---
*IDE12975-Oil: remaining driving distance ESI/INFO: Remaining Distance to Oil Service 8320 km ---
*IDE12976-Oil: remaining running time ESI/INFO: Remaining Time to Oil Service 244 d ---
*IDE12973-Oil: service interval exceeded in km ESI/INFO: Oil Service Exceedance 0 km ---
*IDE12974-Oil service interval exceeded in days ESI/INFO: Oil Service Exceedance 0 d ---
IDE00819-Day counter INFO: Day Counter (since Delivery Inspection) 1722 d ---
IDE00301-Distance INFO: Vehicle/Odomoter Mileage 30926 km ---
IDE11086-Service notification Service Notification (Early Warning/Prediction) 30 d ---
IDE12962-Oil: soot entry ESI/INFO: Soot Entry 0 km ---
IDE12963-Oil: thermal loading ESI/INFO: Thermal Load 10100 km ---
IDE12961-Oil quality ESI/INFO: Oil Quality poor oil quality ---
Tuesday,01,September,2026,20:38:36:51924
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later) -- 2/3
IDE12960-Resetting oil service ESI: Service Status no warning 0
The new values have been saved successfully, SRI reset complete!
Tuesday,01,September,2026,20:39:07:51924
Operation: Reset ESI / OIL,(North America) or (Rest of World second service and later) -- 3/3
IDE12960-Resetting oil service ESI: Service Status Resetting ---
IDE12964-Oil: driven distance since last oil service ESI: Distance SINCE last Oil Service 0 km ---
IDE12965-Oil: time since last oil service ESI: Time SINCE last Oil Service 0 d ---
*IDE12972-Oil: theoretical service interval ESI/INFO: Theoretical Oil Service Interval 37800.00 km ---
*IDE12975-Oil: remaining driving distance ESI/INFO: Remaining Distance to Oil Service 16100 km ---
*IDE12976-Oil: remaining running time ESI/INFO: Remaining Time to Oil Service 365 d ---
IDE12963-Oil: thermal loading ESI/INFO: Thermal Load 0 km ---
Address A9,5H0 907 159 ,channel IDE04472-Volume of structure-borne noise actuator,adapted from,100.0 %,to,40.0 %,Sunday,09,August,2026,22:50:09:51924,WVWG87CD9NW139014
Address A9,5H0 907 159 ,channel IDE04472-Volume of structure-borne noise actuator,adapted from,100.0 %,to,40.0 %,Sunday,09,August,2026,22:51:00:51924,WVWG87CD9NW139014
Address A9,5H0 907 159 ,channel IDE04472-Volume of structure-borne noise actuator,adapted from,100.0 %,to,40 %,Sunday,09,August,2026,22:51:18:51924,WVWG87CD9NW139014
Address A9,5H0 907 159 ,channel IDE04472-Volume of structure-borne noise actuator,adapted from,100.0 %,to,40 %,Sunday,09,August,2026,22:52:26:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,adapted from,active ,to,not active ,Sunday,09,August,2026,23:08:16:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE12960-Resetting oil service,adapted from,no warning ,to,Resetting ,Tuesday,01,September,2026,20:38:38:51924,WVWG87CD9NW139014
Address 19,,channel IDE03256-MAS06105-Battery adaptation-Rated battery capacity,adapted from,68 Ah,to,70 Ah,Tuesday,01,September,2026,20:45:37:51924,WVWG87CD9NW139014
Address 19,5WA 907 530 Q,channel IDE03256-MAS06105-Battery adaptation-Rated battery capacity,adapted from,68 Ah,to,70 Ah,Tuesday,01,September,2026,20:47:54:51924,WVWG87CD9NW139014
Address 19,5WA 907 530 Q,channel IDE03256-MAS06107-Battery adaptation-Battery manufacturer,adapted from, ,to,Interstate ,Tuesday,01,September,2026,20:48:38:51924,WVWG87CD9NW139014
Address 19,5WA 907 530 Q,channel IDE03256-MAS06108-Battery adaptation-Battery Serial Number,adapted from, ,to,6DKJ21 ,Tuesday,01,September,2026,20:48:55:51924,WVWG87CD9NW139014
Address 5F,5H0 035 871 ,channel IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,adapted from,not activated ,to,activated ,Tuesday,01,September,2026,21:02:41:51924,WVWG87CD9NW139014
Address 5F,5H0 035 871 ,channel IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,adapted from,not activated ,to,activated ,Tuesday,01,September,2026,21:02:53:51924,WVWG87CD9NW139014
Address 5F,5H0 035 871 ,channel IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,adapted from,not activated ,to,activated ,Tuesday,01,September,2026,21:03:10:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,adapted from,No display ,to,Display ,Tuesday,01,September,2026,21:05:05:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:01:03:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:18:01:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,adapted from,not active ,to,Daytime running lights ,Tuesday,01,September,2026,23:23:07:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,adapted from,not active ,to,Daytime running lights ,Tuesday,01,September,2026,23:23:18:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:33:19:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:34:16:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE03867-Deactivate seat belt warning,adapted from,No ,to,Yes ,Tuesday,01,September,2026,23:44:16:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19491-Activation of views-View 9,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:44:40:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14123-MAS05866-Design variant activation-lock,adapted from,Yes ,to,No ,Tuesday,01,September,2026,23:47:40:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14123-MAS05866-Design variant activation-lock,adapted from,Yes ,to,No ,Tuesday,01,September,2026,23:47:49:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14123-MAS01129-Design variant activation-Variant 1,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:47:59:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_4 ,to,logo_1 ,Tuesday,01,September,2026,23:49:29:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_1 ,to,kein_logo ,Tuesday,01,September,2026,23:49:37:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,kein_logo ,to,logo_2 ,Tuesday,01,September,2026,23:49:44:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_2 ,to,logo_3 ,Tuesday,01,September,2026,23:49:53:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_3 ,to,logo_5 ,Tuesday,01,September,2026,23:50:00:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_5 ,to,logo_11 ,Tuesday,01,September,2026,23:50:06:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_11 ,to,logo_5 ,Tuesday,01,September,2026,23:50:13:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_5 ,to,logo_6 ,Tuesday,01,September,2026,23:50:22:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_6 ,to,logo_9 ,Tuesday,01,September,2026,23:50:29:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE15080-Logo,adapted from,logo_9 ,to,logo_4 ,Tuesday,01,September,2026,23:50:35:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE02489-Display depiction,adapted from,Variant 1 ,to,Variant 2 ,Tuesday,01,September,2026,23:51:37:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE02489-Display depiction,adapted from,Variant 1 ,to,Variant 3 ,Tuesday,01,September,2026,23:51:42:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19485-Activation of views-View 3,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:54:19:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19485-Activation of views-View 3,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:54:44:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19483-Activation of views-View 1,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:54:59:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19483-Activation of views-View 1,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:55:15:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19486-Activation of views-View 4,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:55:36:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19488-Activation of views-View 6,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:56:06:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19492-Activation of views-View 10,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:56:35:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19492-Activation of views-View 10,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:56:55:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19493-Activation of views-View 12,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:57:04:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19493-Activation of views-View 12,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:57:31:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19494-Activation of views-View 11,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:57:40:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19494-Activation of views-View 11,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:57:56:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19496-Activation of views-View 14,adapted from,not active ,to,not active ,Tuesday,01,September,2026,23:58:30:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19496-Activation of views-View 14,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:58:50:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19496-Activation of views-View 14,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:59:06:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19497-Activation of views-View 15,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:59:16:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19497-Activation of views-View 15,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:59:31:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19495-Activation of views-View 13,adapted from,active ,to,not active ,Tuesday,01,September,2026,23:59:40:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19498-Activation of views-View 16,adapted from,not active ,to,active ,Tuesday,01,September,2026,23:59:49:51924,WVWG87CD9NW139014
Address 17,5H0 920 340 B,channel IDE14875-MAS19498-Activation of views-View 16,adapted from,active ,to,not active ,Wednesday,02,September,2026,00:00:04:51924,WVWG87CD9NW139014
Address 09,5WA 937 086 AE,channel MAS09325-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,adapted from,not active ,to,active ,Wednesday,02,September,2026,19:10:18:51924,WVWG87CD9NW139014
Auto-Scan
Wednesday,02,September,2026,00:17:59:51924
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.5
VIN: WVWG87CD9NW139014 License Plate:
Chassis Type: CD-VW38 (5WA)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 32 3C 42 44 52 5F 6C
75 A5 A9 D6 D7 C002 C003
VIN: WVWG87CD9NW139014 Mileage: 30988km-19255miles
32-Differential Locks -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-DRNA) Labels: Redir Fail!
Part No SW: 8Y0 906 264 A HW: 06K 907 425 N
Component: R4 2.0l TFS H08 0003
Dataset Number: 06Q909102F 0007 CVN: 1D01938C
Coding: 092500122464010F30000000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0208Y0906264A 001005
ROD: EV_ECM20TFS0208Y0906264A.rod
VCID: 3D20E670CDFD03A2CC6-8068
VINID: 9E69D72074D425E9C10C90011022F34486
21654 - No Communication with Transmission Control Module
U0101 00 [00100000] - -
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:42
Engine speed: 0.00 /min
Coolant temperature: 88 C
Intake air temperature: 72 C
Voltage terminal 30: 12.460 V
LF_MVB_PDU_INTC_DIAG_1: 0
LF_MVB_PDU_INTC_DIAG_2: 1024
LF_MVB_PDU_INTC_DIAG_3: 1
LF_MVB_PDU_INTC_DIAG_4: 0
LF_MVB_PDU_INTC_DIAG_5: 0
LF_MVB_PDU_INTC_DIAG_6: 0
LF_MVB_BUS_INTC_DIAG: 256
15187 - Park/Neutral Switch Input Circuit
P0850 00 [01100000] - Open or Short to Plus
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:39
Coolant temperature: 87 C
Voltage terminal 30: 12.441 V
FAC_TPS_1_SAE: 16.4705885 %
FUP_H_SAE: 27470 kPa
MAP_MES_SAE: 100 kPa
Engine status: Stop
TAA: 41.000 C
T_AST_SAE: 0 s
Oxygen sensor 1 bank 1: voltage raw value O2 signal: 1.997 V
Readiness: 1010 1101
Part No SW: 0GC 906 557 AT HW: 0GC 300 020 Q
Component: GSG DQ381 H06 5080
CVN: A2262031
ASAM Dataset: EV_TCMDQ381062 001020
ROD: EV_TCMDQ381062_VW38.rod
VCID: 0F7C6CB8B7D1C1326EA-805A
Subsystem 1 - Part No SW: 5WA 713 033 BB HW: 610 5
Component: ZSB_SB_AUTO H08 1034
Serial number: 20210916000069250645
Subsystem 2 - Part No SW: 5H0 713 059 R HW: 5H0 713 059 R
Component: ZSB_SB_Mono H01 0014
Serial number: 92478UKA00823
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810500003244833
Address 03: ABS Brakes (J104) Labels: 5WA-614-517-V1.clb
Part No SW: 5WA 614 517 BL HW: 5WA 614 517 N
Component: ESC H13 0133
Serial number: 63191000001773 Dataset Number: V03935359XB 0001 CVN: 7ED01246
Coding: 36FC6C9056236A759377600106C760064A5258505A88030820B4B831018FF100002814
ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
ROD: EV_Brake1ESCEPBMQB37W_013_VW38.rod
VCID: 137460C89BF925D24A2-8046 SFD [x]
8222 - No Communication with Transmission Control Module
[CCan_getriebe_11_timeout]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:42
Vehlicle_speed: 0.0 km/h
Resolution Mileage: 624 m
Voltage_value_KL.30_ESC_V: 12.4 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_transverse_accleration: not completed successfully
Comparison_yaw_rate_sensor: completed successfully
LWS_comparison: completed successfully
Internal_failure_code: 00 6B
00 00 40 00 04 08 10 08 40 00 00 00 80 00 00 40 30 00 21 00 04
8226 - No Communication with Transmission Control Module
[CCan_Getriebe_14_Timeout]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
Internal_failure_code: 00 6C
8538 - No Communication with Transmission Control Module
[CCan_Getriebe_17_Timeout]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
Internal_failure_code: 00 6F
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 H HW: 5WA 959 436 H
Component: Kessy IOBOX 100 0722
Serial number: --------------- Dataset Number: V03935341VY 0001
ASAM Dataset: EV_Kessy37w 004023
ROD: EV_Kessy37w_004.rod
VCID: 59E852E03995DF82C0E-800C
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 5WA 907 007 P HW: 5WA 907 007 P
Component: AC Automat H30 3440
Serial number: --------------- Dataset Number: V03935358HE 0001
Coding: 002000010211000000100010111110010000011000000000000000000000
ASAM Dataset: EV_ACClimaPREVW38X 001100
ROD: EV_ACClimaPREVW38X_VW38.rod
VCID: 54F6A3D45E77E2EA138-8000
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00002270721044853510
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 086 AE HW: 5WA 937 086 L
Component: BCM37w_M028 0175
Serial number: BXJ53F151121940 Dataset Number: V03935359RJ 0001
ASAM Dataset: EV_BCM37w 007001
ROD: EV_BCM37w_007_VW38.rod
VCID: 147663D49EF722EA538-8040 SFD [ ]
Subsystem 1 - Part No SW: 5H1 955 119 A HW: 5H1 955 119 A
Component: FWISCHER_MYJT 003 0051
Serial number: 907453F0402118108707
Subsystem 2 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S3Y21M11D29H20M45S32
Subsystem 3 - Part No SW: 5H0 941 193 AP HW: 5H0 941 193 AP
Component: LiSi H06 0008
Serial number: 92471UHP00160
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471UH5000YX
Subsystem 5 - Part No SW: 5H0 959 561 AP HW: 5H0 959 561 AP
Component: DACHKONSOLE 006 0007
Serial number: 92661UIM00240-------
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GB HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000017112108491250
15403264 - Release / Enable Active
B184C 00 [00101111] - -
[Freischaltung aktiv]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:32:35
Terminal 15 status: On
Terminal 50 status: OFF
Engine run: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.4 V
Outside temperature: 38.0 C
Light switch position: automatic
Role of vehicle diagnostic to be protected: Basic
Type of vehicle diagnostic to be protected: Short: time-controlled
Status of vehicle diagnostic to be protected: SFD individualization feature set
Duration of vehicle diagnostic to be protected: 89 minutes
587797 - Databus
U1121 00 [00101110] - Missing Message
[WBA_03 Datenbus fehlende Botschaft]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:42
Engine run: OFF
Voltage: 12.6 V
Outside temperature: 41.0 C
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5WA 919 294 C HW: 5WA 919 294
Component: PDC 08 Kanal H04 0577
Serial number: 000024102194630 Dataset Number: V03935346DB 0001
Coding: 0040014011
ASAM Dataset: EV_EPHBO18VW3800000 002029
ROD: EV_EPHBO18VW3800000_VW38.rod
VCID: 52FAA5CC6463ECDA014-8006
12648721 - Databus
U1121 00 [00101000] - Missing Message
[Getriebesteuerger t - Getriebe_11 - kein Signal/keine Kommunikation]
Reset counter: 32
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
13637426 - Databus
U1123 00 [00101000] - Received Error Message
Reset counter: 28
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:21
13647889 - Databus
[Bremsensteuerger t - VMM_02.VZM_Systemstatus - Fehlerspeicher auslesen]
Reset counter: 28
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
13688835 - Databus
[Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 28
Mileage: 30926 km
Date: 2026.09.01
Time: 00:40:22
Address 13: Auto Dist. Reg (J428) Labels:| 5WA-907-572.clb
Part No SW: 5WA 907 572 B HW: 5WA 907 572
Component: ACC Bosch MQB H20 0395
Dataset Number: V03935351MD 0001
Coding: 0D22009E507680451247400000004004AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW380 004017
ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
VCID: 4DC0B6B07D5DB3225C6-8018
17 Faults Found:
1064 - Databus
U1121 00 [00100000] - Missing Message
[FAULT_TIMEOUT_MOTOR_14]
1139 - Databus
[FAULT_TIMEOUT_TSK_Ausrollkurve_01]
1552 - Databus
U1122 00 [00101000] - Implausible Message
[FAULT_GETRIEBE_11_OBSOLETE_DATA]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
1553 - Databus
[FAULT_GETRIEBE_14_OBSOLETE_DATA]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
1554 - Databus
U1122 00 [00100000] - Implausible Message
[FAULT_MOTOR_12_OBSOLETE_DATA]
2055 - Databus
[FAULT_ALP_STEERING_WHEEL_INIT]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
2065 - Databus
[FAULT_TSK_HANDSHAKE]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:12:48
2068 - Databus
[FAULT_TSK_IRREV_ERROR]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
209153 - Databus
[FAULT_KAMERA_HIGH_SYSTEMZUSTAND_ERROR]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:29
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM_ERROR]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:21
0528 - Databus
[FAULT_TIMEOUT_MOTOR_51]
0530 - Databus
[FAULT_TIMEOUT_MOTOR_54]
0567 - Databus
[FAULT_HMS_FAILURE_STATUS_ERROR]
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:21
0577 - Databus
[FAULT_VZM_SYSTEM_STATUS_ERROR]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:21
0723 - Databus
[FAULT_BV_RELEVANT_ERROR]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:29
0790 - Databus
[FAULT_RB_PER_HV_OOS_SERVICE]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
Address 15: Airbags (J234) Labels:* 5WA-959-655.clb
Part No SW: 5WA 959 655 M HW: 5WA 959 655 M
Component: AirbagVW40 007 0636
Serial number: 000000003C0J3R7 Dataset Number: V03935356JR 0001
Coding: 8CCC000000FCC00000000000000000005100000000000000000036F800130065
ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
ROD: EV_AirbaVW40SMEVW38X.rod
VCID: 61987A0011C5074288E-8034 SFD [x]
Component: ------------- H16 0022
Serial number: IBH00000000000H3C710
Subsystem 2 - Part No SW: ----------- HW: 480 402 411 21
Component: SideSensor_Dr 003 6149
Serial number: 35100019EC69F96292DU
Subsystem 3 - Part No SW: ----------- HW: 480 402 411 21
Component: SideSensor_Pr 003 6149
Serial number: 35200019EC69F96196F-
Subsystem 4 - Part No SW: ----------- HW: 480 000 411 21
Serial number: 35700000000E20299B5O
Subsystem 5 - Part No SW: ----------- HW: 480 000 611 21
Serial number: 35800000000C812D095N
Subsystem 6 - Part No SW: ----------- HW: 480 401 911 21
Component: FrontSensor_D 003 614A
Serial number: 3550001C6C6850B7916B
Subsystem 7 - Part No SW: ----------- HW: 480 401 911 21
Component: FrontSensor_P 003 614A
Serial number: 3560001C6C6850B2F17E
Address 17: Instruments (J285) Labels:| 5H0-920-KOM-V1.clb-SRI2
Part No SW: 5H0 920 340 B HW: 5H0 920 340 B
Component: KOMBI 220 5350
Dataset Number: V03935353UH 0001
Coding: 08BC0442638CCF050280220B2000000820300400
ASAM Dataset: EV_DashBoardVDDMQB37W 003033
ROD: EV_DashBoardVDDMQB37W_003_VW38.rod
VCID: 21183A0051454742C8E-8074 SFD [ ]
16711684 - Release / Enable Active
B184C 00 [00001001] - -
Reset counter: 149
Mileage: 30926 km
Date: 2026.09.01
Time: 00:29:08
Part No SW: 5WA 907 530 Q HW: 5WA 907 530 G
Component: GW2020 High 756 7099
Revision: -------- Serial number: 771049050021319 Dataset Number: V03935364D 0001
Coding: 0000808D0F00000000000000010303327302600902000301030100000001010000000000000000000000000000000000
GVL: 3D400000020840CC80008002C800004004004000004000000000000000000044
ASAM Dataset: EV_GatewMQB2020 005011
ROD: EV_GatewMQB2020_004_VW38.rod
VCID: 56F259DC488BF0FAEDC-8002 SFD [x]
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5WA 915 181 C HW: 5WA 915 181 C
Component: J367-BDMHella H11 9080
Serial number: 6557178405
Subsystem 3 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218131172300190
Subsystem 4 - Part No SW: 5H0 959 542 N HW: 5H0 959 542 N
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA23344410402
2494569 - Ethernet Module for Back-Up Cam
U1643 00 [00101110] - No Communication
[Rearview_camera_system_control_module_no_communication_vlan]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:39
8472065 - Databus
[function_error_PaCo_Timeout_CANMessage]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:44
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 K HW: 3Q0 909 059 D
Component: EBKV H09 0307
Serial number: BPA085220921013 Dataset Number: V03935361KK 0001
Coding: 5003C5009F00007BEFBDF7DE000049922449922400
ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
VCID: 58EE57E4429FC68AFF0-800C SFD [x]
107008 - No Communication with Transmission Control Module
U0101 00 [00101100] - -
[ComScl_Getriebe_11_Timeout]
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
107024 - Transmission Control Module
U14E4 00 [00100000] - Received Malfunction Value
[Scl_Getriebe_11_GE_Fahrstufe_Error]
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 21000269338014 Dataset Number: V03935336NF 0001
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW38.rod
VCID: 323AC54C04A3CCDA214-8066
12666386 - Databus
[Timeout Getriebe_11_alt]
Reset counter: 189
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Remote Start: not active
Driver door: Open
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd true
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: Yes
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 11.7 V
UMotorBridge: 6.4 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition met
Lock condition timeout vehicle speed: Condition met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition not met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition met
Address 32: Differential Locks (-----) Labels:| 0CQ-907-554-V2.clb
Part No SW: 5WA 907 554 B HW: 5WA 525 130
Component: Quersperre H65 8640
Serial number: HH3-00003.08.21
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 005001
ROD: EV_LockElectHA1VW37X_005.rod
16652 - Databus
[Getriebe - TO -- Get_11]
Reset counter: 8
Mileage: 30988 km
Date: 2026.09.01
Time: 02:14:43
Voltage terminal 30: 12.6 V
Haldex clutch pump: current: 0.000 A
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 E HW: 2Q0 907 686 E
Component: HRE_Master H25 0284
Serial number: 00000588196440 Dataset Number: V03935346QB 0001
Coding: 569945D0
ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
ROD: EV_HREntryHellaGen3Mstr_VW38.rod
VCID: 3C26EB74D6E70AAAFB8-8068
Subsystem 1 - Part No SW: 2Q0 907 685 E HW: 2Q0 907 685 E
Component: HRE_Slave H25 0284
Serial number: 00000588192198
Lane change assistance display left:
Subsystem 2 - Part No SW: 5H1 949 145 HW: 5H1 949 145
Component: SWA LED VL H05 0005
Serial number: 00000000000016909060
Lane change assistance display right:
Subsystem 3 - Part No SW: 5H1 949 146 HW: 5H1 949 146
Component: SWA LED VR H05 0005
2236426 - Databus
[databus unreasonable message - LWI_Lenkradwinkel]
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
2236417 - Databus
[databus unreasonable message - LWI_QBit_Lenkradwinkel]
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
2236437 - Databus
[databus error value received - Parkhilfe_04 - APSOPS_PaCo_MainState]
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:27
2252891 - Databus
[databus error value received - VMM_02 - VZM_Systemstatus]
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q0 959 593 L HW: 5Q0 959 593 F
Component: TSG FS003 0350
Serial number: YE007UKU04569 Dataset Number: V03935342BG 0001
Coding: 003B03208000040000000000
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 4ACABDAC8C33A41A794-801E
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000054185840
Coding: 111000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 5WA 907 145 G HW: 5WA 907 145 C
Component: BASGEN1MQB37 502 1040
Serial number: 00701671 Dataset Number: V03935357WX 0001
Coding: 0000000000000001000102010100010000000101010101
ROD: EV_SteerAssisBASGEN1MQB37_007.rod
VCID: 4EC2B1BC705B883A25C-801A
5407 - Terminal 30
U140A 00 [00100000] - Open Circuit
[DTC_RESET_SDK]
5423 - Steering Angle Sensor
B1168 F2 [00101000] - Not Initialized
[DTC_RACKPOS_NOINIT]
Reset counter: 29
MonitorId: 01 1F
HybridDriveReady: 00000000
IgnitionEnabled: 00000000
Communication control: 00000000
Diagnostic session: 00000001
ComM_ModeType: 00000000
NM_Signal_Fahrbereit: 00000000
NM Signal V gr 7: 00000000
System status: 1
ECU Status: 0
HWLib Status: 0
Support power reduction: 0.0 %
Voltage terminal 30: 12.438 V
Temperature circuit board: 47 C
Output stage temperature: 46 C
Rackposition: 0.00 mm
Rackspeed: 0.00 mm/s
pinion angle dependent amplitude factor: 0
Steering wheel angle: 0.125 /s
SupplierFreezeFrameData: 50 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Part No SW: 5Q0 959 592 L HW: 5Q0 959 592 F
Component: TSG BFS003 0350
Serial number: YE007UL11430D Dataset Number: V03935342BD 0001
Coding: 003B03208C00040000800000
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 49C882A08935AF0270E-801C
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000055363183
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 5H0 035 871 HW: 5H0 035 871
Component: MU-E--US 099 1805
Serial number: CVRV59N0AEB0000 Dataset Number: V03935358LC 0001
Coding: 23800000000200000000000000000000000000000000000000
ASAM Dataset: EV_MUEIMQB37w 001003
ROD: EV_MUEIMQB37w_VW38.rod
VCID: 65906E1005ED6B62746-8030 SFD [x]
U1400 00 [00001000] - -
[Function restriction due to insufficient voltage - lower limit value not reached]
Reset counter: 39
Mileage: 30926 km
Date: 2026.09.01
Time: 20:11:17
Voltage terminal 30: 8.2 V
B201A 00 [00001001] - -
Mileage: 30921 km
Date: 2026.09.01
Time: 19:48:09
Voltage terminal 30: 12.4 V
module_name:
4112 - Release / Enable Active
B184C 00 [00001000] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Mileage: 30926 km
Date: 2026.09.01
Time: 00:34:37
Voltage terminal 30: 12.1 V
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 C HW: 5WA 980 556 B
Component: RV eCompact H26 0314
Serial number: FCLK20210921000 Dataset Number: V03935342HG 0001
Coding: 02030004E42800
ASAM Dataset: EV_CamSysRVCCompaFicos 009023
ROD: EV_CamSysRVCCompaFicos_009_VW38.rod
VCID: 51F8AAC0616597C238E-8004
282656 - Cable for Video Signal to Display
C135B 01 [00101111] - Electrical Failure
[Video link to display unit - connection error]
13706006 - Databus
[Errorvalue-monitoring VMM_02.VZM_Systemstatus]
Reset counter: 30
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:22
Address 75: Telematics (J949) Labels:* Redir Fail!
Part No SW: 5WA 035 285 A HW: 5WA 035 285 A
Component: OCU3HMQB37W H12 0015
Serial number: 0000000109VIAX8 Dataset Number: V03935360VY 0001
Coding: 02380020906828208005460070102607
ASAM Dataset: EV_OCU3HMQB37W 002012
ROD: EV_OCU3HMQB37W_002_VW38.rod
VCID: 45D08E90A52D4B62946-8010 SFD [x]
[Functional restrictiondue to insufficient voltage]
Reset counter: 38
Mileage: 30926 km
Date: 2026.09.01
Time: 20:11:17
Voltage terminal 30: 5.5 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 5WA 980 653 C HW: 5WA 980 653
Component: MQB MFK 3.0 H09 3302
Serial number: E82645704213260 Dataset Number: V03935357JG 0001
Coding: 00000A88006C4040109F40001020002000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 005050
ROD: EV_MFK3ValeoMQB_005_VW38.rod
VCID: 4FFCACB8775181322EA-801A
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 2
Mileage: 30926 km
Date: 2026.09.01
Time: 00:07:25
1124417 - Development code 1
B2F01 00 [00001001] - -
[Wrong_formating_rem_data]
Fault Priority: 9
Reset counter: 0
Mileage: 30923 km
Date: 2026.09.01
Time: 20:05:21
Part No SW: 5H0 907 159 HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 210817290427
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
VCID: 6C861B34E6075A2A2B8-8038
Part No SW: 992 941 591 DE HW: 992 941 591 D
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 6A8A1D2CECF3441A594-803E
Component: LED1R H08 9202
End----------(Elapsed Time: 01:36, VBatt start/end: 12.4V/12.3V)-----------
------------------------------49 Faults Found------------------------------
Maps
;SW:5WA-907-530-Q HW:5WA-907-530-G --- 19: CAN Gateway
;Component:GW2020 High 756 7099, Coding:0000808D0F00000000000000010303327302600902000301030100000001010000000000000000000000000000000000
;EV_GatewMQB2020,005011,EV_GatewMQB2020_004_VW38.rod
;Tuesday,01,September,2026,18:46:55:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 56F259DC488BF0FAEDC-8002 SFD [x]
IDE00001-MAS00170-Production mode-OBD,Deactivating ,3
IDE00001-MAS01490-Production mode-Energy management,Deactivating ,3
IDE00001-MAS21169-Production mode-Park coordinator,Deactivating ,3
IDE00820-ENG259915-Activating and deactivating all development messages-BAP-Debug_Cmd_CAN-Messages,not active ,5
IDE00820-ENG259081-Activating and deactivating all development messages-BCmE_development_CAN_messages,not active ,5
IDE00820-ENG258247-Activating and deactivating all development messages-eASS_development_CAN_messages,not active ,5
IDE00820-ENG261332-Activating and deactivating all development messages-EHR_development_CAN_messages,not active ,5
IDE00820-ENG260014-Activating and deactivating all development messages-FoD_development_CAN_messages,not active ,5
IDE00820-ENG260247-Activating and deactivating all development messages-FPA_development_CAN_messages,not active ,5
IDE00820-ENG260571-Activating and deactivating all development messages-GW_development_CAN_messages,not active ,5
IDE00820-ENG259210-Activating and deactivating all development messages-HD_development_CAN_messages,not active ,5
IDE00820-ENG259946-Activating and deactivating all development messages-HV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259153-Activating and deactivating all development messages-IDS_development_CAN_messages,not active ,5
IDE00820-ENG258853-Activating and deactivating all development messages-KS_development_CAN_messages,not active ,5
IDE00820-ENG258958-Activating and deactivating all development messages-MFL_development_CAN_messages,not active ,5
IDE00820-ENG258567-Activating and deactivating all development messages-MKE_development_CAN_messages,not active ,5
IDE00820-ENG260849-Activating and deactivating all development messages-MV-EM_development_CAN_messages,not active ,5
IDE00820-ENG259788-Activating and deactivating all development messages-NV-EM_development_CAN_messages,not active ,5
IDE00820-ENG260650-Activating and deactivating all development messages-OBDC_development_CAN_messages,not active ,5
IDE00820-ENG261321-Activating and deactivating all development messages-PaCo_development_CAN_messages,not active ,5
IDE00820-ENG261353-Activating and deactivating all development messages-RWB_development_CAN_messages,not active ,5
IDE00820-ENG258585-Activating and deactivating all development messages-SDA_development_CAN_messages,not active ,5
IDE00820-ENG258798-Activating and deactivating all development messages-SK1a_development_CAN_messages,not active ,5
IDE00820-ENG260530-Activating and deactivating all development messages-SK3_development_CAN_messages,not active ,5
IDE00820-ENG259285-Activating and deactivating all development messages-SOK_development_CAN_messages,not active ,5
IDE00820-ENG258316-Activating and deactivating all development messages-SWaP_development_CAN_messages,not active ,5
IDE00820-ENG259637-Activating and deactivating all development messages-VDC_development_CAN_messages,not active ,5
IDE00820-ENG259338-Activating and deactivating all development messages-VKMS_development_CAN_messages,not active ,5
IDE00820-ENG259833-Activating and deactivating all development messages-WUM_development_CAN_messages,not active ,5
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer, ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number, ,15
IDE03903-Production process data 1,00 00 ,2
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07139-Normal bus behavior during diagnosis,active ,1
IDE07160-Control module switch-off: switch-off time,20 min,2
IDE08220-Vehicle production mode,not active ,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,0 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,-15000 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,150 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,150 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,10 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,4.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,0.0 l/100km,48
IDE10351-MAS10460-Message mirroring-Target bus,not active ,2
IDE10351-MAS21167-Message mirroring-Source bus,Powertrain data bus ,2
IDE10735-Number requests autonomous recharging,9 ,1
IDE11689-48V-System: locking,regular operation ,1
IDE13844-Distance left for deactivation of production mode,200 km,1
IDE14154-MAS17900-Route-based range calculation adjustment-Classified consumption,0.0 kWh/100 km,40
IDE14154-MAS17901-Route-based range calculation adjustment-Classified consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17902-Route-based range calculation adjustment-Classified consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17903-Route-based range calculation adjustment-Classified consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17904-Route-based range calculation adjustment-Classified consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17905-Route-based range calculation adjustment-Classified consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17906-Route-based range calculation adjustment-Classified consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17907-Route-based range calculation adjustment-Classified consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17908-Route-based range calculation adjustment-Classified consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17909-Route-based range calculation adjustment-Classified consumption 10,0.0 kWh/100 km,40
IDE14154-MAS17910-Route-based range calculation adjustment-Calculated consumption,0.0 kWh/100 km,40
IDE14154-MAS17911-Route-based range calculation adjustment-Calculated consumption 2,0.0 kWh/100 km,40
IDE14154-MAS17912-Route-based range calculation adjustment-Calculated consumption 3,0.0 kWh/100 km,40
IDE14154-MAS17913-Route-based range calculation adjustment-Calculated consumption 4,0.0 kWh/100 km,40
IDE14154-MAS17914-Route-based range calculation adjustment-Calculated consumption 5,0.0 kWh/100 km,40
IDE14154-MAS17915-Route-based range calculation adjustment-Calculated consumption 6,0.0 kWh/100 km,40
IDE14154-MAS17916-Route-based range calculation adjustment-Calculated consumption 7,0.0 kWh/100 km,40
IDE14154-MAS17917-Route-based range calculation adjustment-Calculated consumption 8,0.0 kWh/100 km,40
IDE14154-MAS17918-Route-based range calculation adjustment-Calculated consumption 9,0.0 kWh/100 km,40
IDE14154-MAS17919-Route-based range calculation adjustment-Calculated consumption 10,0.0 kWh/100 km,40
IDE14750-Deactivate all development messages,0 ,5
IDE15316-FoD Partner,Available ,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
IDE15756-Ethernet port 3 VLAN configuration,VLAN_Komfort ,1
IDE15853-Report system for deviations: coding,0 ,3
MAS08072-ENG172204-Driving profile selection-FPA_BAP_Display,active ,5
MAS08072-ENG172364-Driving profile selection-FPA_BAP_Start_aktiv,active ,5
MAS08072-ENG172201-Driving profile selection-FPA_Funktion,active ,5
MAS08072-ENG172220-Driving profile selection-FPA_Funktion_ACC,active ,5
MAS08072-ENG172217-Driving profile selection-FPA_Funktion_AFS,not active ,5
MAS08072-ENG172366-Driving profile selection-FPA_Funktion_AGA,not active ,5
MAS08072-ENG173595-Driving profile selection-FPA_Funktion_AGK,active ,5
MAS08072-ENG172224-Driving profile selection-FPA_Funktion_ALR,not active ,5
MAS08072-ENG172223-Driving profile selection-FPA_Funktion_AMB,active ,5
MAS08072-ENG172229-Driving profile selection-FPA_Funktion_DR,not active ,5
MAS08072-ENG172590-Driving profile selection-FPA_Funktion_eBKV,active ,5
MAS08072-ENG173592-Driving profile selection-FPA_Funktion_EDS,not active ,5
MAS08072-ENG172219-Driving profile selection-FPA_Funktion_EPS,active ,5
MAS08072-ENG258261-Driving profile selection-FPA_Funktion_ESH,active ,5
MAS08072-ENG172225-Driving profile selection-FPA_Funktion_ESP,not active ,5
MAS08072-ENG174239-Driving profile selection-FPA_Funktion_FMA,not active ,5
MAS08072-ENG172226-Driving profile selection-FPA_Funktion_Freilauf,not active ,5
MAS08072-ENG246827-Driving profile selection-FPA_Funktion_Freilauf_DefaultON,not active ,5
MAS08072-ENG172228-Driving profile selection-FPA_Funktion_GE,active ,5
MAS08072-ENG172522-Driving profile selection-FPA_Funktion_HDC,not active ,5
MAS08072-ENG173593-Driving profile selection-FPA_Funktion_HHC,not active ,5
MAS08072-ENG172519-Driving profile selection-FPA_Funktion_HSP,not active ,5
MAS08072-ENG172214-Driving profile selection-FPA_Funktion_IVB,not active ,5
MAS08072-ENG172215-Driving profile selection-FPA_Funktion_KL,active ,5
MAS08072-ENG246828-Driving profile selection-FPA_Funktion_mFDR,active ,5
MAS08072-ENG172227-Driving profile selection-FPA_Funktion_MO,active ,5
MAS08072-ENG172523-Driving profile selection-FPA_Funktion_MO_BZS,not active ,5
MAS08072-ENG172222-Driving profile selection-FPA_Funktion_MO_StSt,active ,5
MAS08072-ENG173594-Driving profile selection-FPA_Funktion_PDC,not active ,5
MAS08072-ENG172218-Driving profile selection-FPA_Funktion_RGS,not active ,5
MAS08072-ENG172521-Driving profile selection-FPA_Funktion_RWB,not active ,5
MAS08072-ENG172221-Driving profile selection-FPA_Funktion_SAK,active ,5
MAS08072-ENG259013-Driving profile selection-FPA_Funktion_ToS_L,not active ,5
MAS08072-ENG260985-Driving profile selection-FPA_Funktion_ToS_Q,not active ,5
MAS08072-ENG172365-Driving profile selection-FPA_Funktion_VAQ,active ,5
MAS08072-ENG172205-Driving profile selection-FPA_Kombi_Anzeige,active ,5
MAS08072-ENG273644-Driving profile selection-FPA_Kombi_Status_Unterdruecken,not active ,5
MAS08072-ENG172202-Driving profile selection-FPA_Personalisierung,active ,5
MAS08072-ENG172206-Driving profile selection-FPA_Taster_Auswertung,Rising slope ,5
MAS12667-SFT271901-Specified installation of sub-bus users-Generator,Yes ,4
MAS12667-SFT271921-Specified installation of sub-bus users-Multi-function steering wheel control module,Yes ,4
MAS12667-SFT271927-Specified installation of sub-bus users-Battery Monitoring Control Module,Yes ,4
MAS12667-SFT271977-Specified installation of sub-bus users-Inverter for socket,No ,4
MAS12667-SFT271986-Specified installation of sub-bus users-Analog clock,No ,4
MAS12667-SFT272175-Specified installation of sub-bus users-Control head driving profile,No ,4
MAS12667-SFT272190-Specified installation of sub-bus users-Steering Wheel Touch Recognition Control Module,Yes ,4
MAS16743-Alternator gear ratio,59 ,1
SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,installed ,3
SFT271921-IDE07856-Multi-function steering wheel control module-Terminal status,active with terminal 58 ,3
SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,active ,3
SFT271921-MAS06614-Multi-function steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,installed ,3
SFT271921-MAS10720-Multi-function steering wheel control module-Speed limiter,not active ,3
SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB2020 ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS21171-Multi-function steering wheel control module-Distance regulation function query (FoD),activated ,3
SFT271921-MAS21172-Multi-function steering wheel control module-Travel Assist function query (FoD),activated ,3
SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,invalid ,3
ENG253073-Diagnostic_filter_permanent_deactivation,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG253088-EM_function_variant_EM-HLR,0 ,1
ENG279934-ENG280094-Engress_filter-packet_based_/_port_shaper_burst_size_configuration,2000 ,10
ENG279934-ENG280095-Engress_filter-packet_based_/_port_shaper_shaping_rate_configuration,2000 packets/s,10
ENG279934-ENG280098-Engress_filter-port_shaper_bucket_count_select,packet_based ,10
ENG279934-ENG280099-Engress_filter-port_shaper_enabling,enable_shaper ,10
ENG253271-ENG259280-GW_Content_list-Bus_ID,00 ,48
ENG253271-ENG253458-GW_Content_list-Node_address,00 00 ,48
ENG253382-ENG258827-IDS_critical_PDUs_list_mqb2020-Airbag_01_can-id_0x040,On ,8
ENG253382-ENG259901-IDS_critical_PDUs_list_mqb2020-Airbag_02_can-id_0x520,On ,8
ENG253382-ENG259106-IDS_critical_PDUs_list_mqb2020-Airbag_03_can-id_0x041,On ,8
ENG253382-ENG261312-IDS_critical_PDUs_list_mqb2020-APS_Master_can-id_0x380,On ,8
ENG253382-ENG259066-IDS_critical_PDUs_list_mqb2020-ARA_02_can-id_0x2A5,On ,8
ENG253382-ENG260221-IDS_critical_PDUs_list_mqb2020-BMS_NV_01_can-id_0x1F3,On ,8
ENG253382-ENG258308-IDS_critical_PDUs_list_mqb2020-Bremse_EV_02_can-id_0x387,On ,8
ENG253382-ENG258444-IDS_critical_PDUs_list_mqb2020-EA_01_can-id_0x1A4,On ,8
ENG253382-ENG259736-IDS_critical_PDUs_list_mqb2020-EA_02_can-id_0x1F0,On ,8
ENG253382-ENG258228-IDS_critical_PDUs_list_mqb2020-EPB_03_can-id_0x1F7,On ,8
ENG253382-ENG258443-IDS_critical_PDUs_list_mqb2020-ESP_10_can-id_0x116,On ,8
ENG253382-ENG258403-IDS_critical_PDUs_list_mqb2020-ESP_14_can-id_0x08A,On ,8
ENG253382-ENG259539-IDS_critical_PDUs_list_mqb2020-ESP_20_can-id_0x65D,On ,8
ENG253382-ENG258752-IDS_critical_PDUs_list_mqb2020-ESP_21_can-id_0x0FD,On ,8
ENG253382-ENG258803-IDS_critical_PDUs_list_mqb2020-ESP_24_can-id_0x31B,On ,8
ENG253382-ENG259454-IDS_critical_PDUs_list_mqb2020-GRA_ACC_01_can-id_0x12B,On ,8
ENG253382-ENG260975-IDS_critical_PDUs_list_mqb2020-HCA_01_can-id_0x126,On ,8
ENG253382-ENG258427-IDS_critical_PDUs_list_mqb2020-IPA_01_can-id_0x138,On ,8
ENG253382-ENG259431-IDS_critical_PDUs_list_mqb2020-Klemmen_Status_01_can-id_0x3C0,On ,8
ENG253382-ENG258280-IDS_critical_PDUs_list_mqb2020-Klemmen_Steuerung_01_can-id_0x58C,On ,8
ENG253382-ENG259354-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_L_can-id_0x56B,On ,8
ENG253382-ENG258318-IDS_critical_PDUs_list_mqb2020-LCM_Feh_LM_R_can-id_0x56C,On ,8
ENG253382-ENG260165-IDS_critical_PDUs_list_mqb2020-LCM_Soll_Fkt_can-id_0x193,On ,8
ENG253382-ENG259048-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_L_can-id_0x19B,On ,8
ENG253382-ENG259708-IDS_critical_PDUs_list_mqb2020-LCM_Sta_LM_R_can-id_0x19D,On ,8
ENG253382-ENG259220-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_L_03_can-id_0x16A95416,On ,8
ENG253382-ENG259096-IDS_critical_PDUs_list_mqb2020-LED_Feh_LM_R_03_can-id_0x16A95417,On ,8
ENG253382-ENG260883-IDS_critical_PDUs_list_mqb2020-LH_EPS_01_can-id_0x32A,On ,8
ENG253382-ENG261199-IDS_critical_PDUs_list_mqb2020-LH_EPS_02_can-id_0x11D,On ,8
ENG253382-ENG259434-IDS_critical_PDUs_list_mqb2020-LH_EPS_03_can-id_0x09F,On ,8
ENG253382-ENG258969-IDS_critical_PDUs_list_mqb2020-Licht_Anf_01_can-id_0x3D5,On ,8
ENG253382-ENG259107-IDS_critical_PDUs_list_mqb2020-LWI_01_can-id_0x086,On ,8
ENG253382-ENG259990-IDS_critical_PDUs_list_mqb2020-MFG_02_can-id_0x48D,On ,8
ENG253382-ENG260730-IDS_critical_PDUs_list_mqb2020-Motor_14_can-id_0x3BE,On ,8
ENG253382-ENG258115-IDS_critical_PDUs_list_mqb2020-Motor_Code_01_can-id_0x641,On ,8
ENG253382-ENG258876-IDS_critical_PDUs_list_mqb2020-PreCrash_02_can-id_0x13F,On ,8
ENG253382-ENG261021-IDS_critical_PDUs_list_mqb2020-Q_Diode_01_can-id_0x298,On ,8
ENG253382-ENG260760-IDS_critical_PDUs_list_mqb2020-RCTA_01_can-id_0x2B7,On ,8
ENG253382-ENG259993-IDS_critical_PDUs_list_mqb2020-TSG_FT_02_can-id_0x3E5,On ,8
ENG253382-ENG260263-IDS_critical_PDUs_list_mqb2020-WBA_03_can-id_0x394,On ,8
ENG253192-MAS01898-IDS_white_list_features-Drive train,On ,1
ENG253192-MAS16574-IDS_white_list_features-Infotainment,On ,1
ENG253396-Mirroring_LIN3_to_LIN4,No ,1
ENG137850-MVK_Warning,regular operation ,1
ENG253252-ENG260330-Node_to_cluster_list-NCL_element_1,00 00 00 00 00 ,160
ENG253252-ENG260846-Node_to_cluster_list-NCL_element_10,00 00 00 00 00 ,160
ENG253252-ENG258686-Node_to_cluster_list-NCL_element_11,00 00 00 00 00 ,160
ENG253252-ENG259563-Node_to_cluster_list-NCL_element_12,00 00 00 00 00 ,160
ENG253252-ENG259135-Node_to_cluster_list-NCL_element_13,00 00 00 00 00 ,160
ENG253252-ENG261302-Node_to_cluster_list-NCL_element_14,00 00 00 00 00 ,160
ENG253252-ENG259590-Node_to_cluster_list-NCL_element_15,00 00 00 00 00 ,160
ENG253252-ENG261163-Node_to_cluster_list-NCL_element_16,00 00 00 00 00 ,160
ENG253252-ENG258229-Node_to_cluster_list-NCL_element_17,00 00 00 00 00 ,160
ENG253252-ENG259389-Node_to_cluster_list-NCL_element_18,00 00 00 00 00 ,160
ENG253252-ENG260540-Node_to_cluster_list-NCL_element_19,00 00 00 00 00 ,160
ENG253252-ENG259624-Node_to_cluster_list-NCL_element_2,00 00 00 00 00 ,160
ENG253252-ENG258136-Node_to_cluster_list-NCL_element_20,00 00 00 00 00 ,160
ENG253252-ENG261360-Node_to_cluster_list-NCL_element_21,00 00 00 00 00 ,160
ENG253252-ENG260775-Node_to_cluster_list-NCL_element_22,00 00 00 00 00 ,160
ENG253252-ENG259077-Node_to_cluster_list-NCL_element_23,00 00 00 00 00 ,160
ENG253252-ENG259062-Node_to_cluster_list-NCL_element_24,00 00 00 00 00 ,160
ENG253252-ENG260421-Node_to_cluster_list-NCL_element_25,00 00 00 00 00 ,160
ENG253252-ENG261354-Node_to_cluster_list-NCL_element_26,00 00 00 00 00 ,160
ENG253252-ENG258201-Node_to_cluster_list-NCL_element_27,00 00 00 00 00 ,160
ENG253252-ENG260110-Node_to_cluster_list-NCL_element_28,00 00 00 00 00 ,160
ENG253252-ENG258645-Node_to_cluster_list-NCL_element_29,00 00 00 00 00 ,160
ENG253252-ENG261260-Node_to_cluster_list-NCL_element_3,00 00 00 00 00 ,160
ENG253252-ENG259078-Node_to_cluster_list-NCL_element_30,00 00 00 00 00 ,160
ENG253252-ENG260192-Node_to_cluster_list-NCL_element_31,00 00 00 00 00 ,160
ENG253252-ENG259747-Node_to_cluster_list-NCL_element_32,00 00 00 00 00 ,160
ENG253252-ENG259375-Node_to_cluster_list-NCL_element_4,00 00 00 00 00 ,160
ENG253252-ENG259916-Node_to_cluster_list-NCL_element_5,00 00 00 00 00 ,160
ENG253252-ENG260559-Node_to_cluster_list-NCL_element_6,00 00 00 00 00 ,160
ENG253252-ENG259415-Node_to_cluster_list-NCL_element_7,00 00 00 00 00 ,160
ENG253252-ENG260302-Node_to_cluster_list-NCL_element_8,00 00 00 00 00 ,160
ENG253252-ENG259224-Node_to_cluster_list-NCL_element_9,00 00 00 00 00 ,160
ENG253340-SFD_Testmode,not active ,1
ENG253268-MAS03173-TCR_bus_can-Powertrain data bus,00 00 03 ,24
ENG253268-MAS03174-TCR_bus_can-Comfort data bus,00 00 30 ,24
ENG253268-MAS03177-TCR_bus_can-Infotainment data bus,00 01 C0 ,24
ENG253268-MAS03178-TCR_bus_can-Suspension data bus,00 00 04 ,24
ENG253268-MAS05686-TCR_bus_can-Data bus diagnostics,00 00 00 ,24
ENG253268-MAS12185-TCR_bus_can-Hybrid data bus,00 00 02 ,24
ENG253268-MAS16909-TCR_bus_can-Data bus driver assistance systems,00 00 08 ,24
ENG253268-MAS16910-TCR_bus_can-Migration data bus,00 00 01 ,24
ENG253184-MAS03179-TCR_bus_lin-Local data bus 2,00 01 C0 ,12
ENG253184-MAS03180-TCR_bus_lin-Local data bus,00 00 00 ,12
ENG253184-MAS05972-TCR_bus_lin-Local data bus 3,00 00 00 ,12
ENG253184-MAS06525-TCR_bus_lin-Local data bus 4,00 00 00 ,12
ENG253199-MAS16912-TCR_bus_vlan-VLAN_FAS,00 04 00 ,24
ENG253199-MAS16913-TCR_bus_vlan-VLAN_Infotainment,00 20 00 ,24
ENG253199-MAS16915-TCR_bus_vlan-VLAN_Komfort,00 08 00 ,24
ENG253199-MAS16916-TCR_bus_vlan-VLAN_Powertrain,00 02 00 ,24
ENG253199-MAS18934-TCR_bus_vlan-VLAN Connect,00 10 00 ,24
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,10
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,10
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,10
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,10
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,10
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,10
ENG118773-ENG260551-WakeUpMonitor_Configuration-WakeUpMonitor_Start_WakeUp_Delay,1800 s,10
Elapsed Time: 00:25
;Tuesday,01,September,2026,20:54:36:51924
;VCID: 56F259DC488BF0FAEDC-8002 SFD [ ]
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,70 Ah,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,Int ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,6DKJ21 ,15
ENG253073-Diagnostic_filter_permanent_deactivation,Security access required,3
Elapsed Time: 00:24
;Tuesday,01,September,2026,18:45:59:51924
Group,Description,Actual
IDE00019,Voltage terminal 30,12.5, V
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,6,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,4,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,13,
IDE00634,Vehicle electric system current,10.291, A
IDE00767-ENG280618,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG280619,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG280620,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG280621,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,22,
IDE00767-ENG280656,No. of unscheduled ECU resets-Muc_Reset_Counter,0,
IDE00767-ENG280678,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG280679,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG280680,No. of unscheduled ECU resets-Reason_of_4th_last_reset,4,
IDE00767-ENG280681,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG280682,No. of unscheduled ECU resets-Reason_of_latest_reset,0,
IDE00767-ENG280768,No. of unscheduled ECU resets-Watchdog_Reset_Counter,2,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.3, H
IDE01807-MAS00106,History data 21-Year,2026,
IDE01807-MAS00107,History data 21-Month,6,
IDE01807-MAS00108,History data 21-Day,19,
IDE01807-MAS00109,History data 21-Hours,20, H
IDE01807-MAS00110,History data 21-Minutes,39, min
IDE01807-MAS14375,History data 21-Cycle counter,3494,
IDE01807-MAS14376,History data 21-ECU 1,00 0E,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.3, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG159905,History data 21-Bus_ECU_1,Comfort data bus,
IDE01807-ENG159908,History data 21-Bus_ECU_2,Unknown,
IDE01807-ENG159911,History data 21-Bus_ECU_3,Unknown,
IDE01807-ENG159914,History data 21-Bus_ECU_4,Unknown,
IDE01807-ENG159917,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.2, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.7, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.8, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG255497,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG255498,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG255499,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG255500,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG255501,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.3, H
IDE01810-MAS00106,History data 24-Year,2021,
IDE01810-MAS00107,History data 24-Month,12,
IDE01810-MAS00108,History data 24-Day,9,
IDE01810-MAS00109,History data 24-Hours,16, H
IDE01810-MAS00110,History data 24-Minutes,54, min
IDE01810-MAS14375,History data 24-Cycle counter,12,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,1,
IDE01810-MAS14393,History data 24-ID of the alerting message,17 F0 00 31,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Comfort data bus,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,31,
IDE01810-MAS20473,History data 24-Alerting message counter,23,
IDE01812-MAS01468,History data 26-Terminal 15,3814,
IDE01812-MAS03173,History data 26-Powertrain data bus,111,
IDE01812-MAS03174,History data 26-Comfort data bus,5326,
IDE01812-MAS03177,History data 26-Infotainment data bus,201,
IDE01812-MAS03178,History data 26-Suspension data bus,7,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,4,
IDE01812-MAS14374,History data 26-Totals,5718,
IDE01812-MAS16910,History data 26-Migration data bus,30,
IDE01813-MAS03173,History data 27-Powertrain data bus,734,
IDE01813-MAS03174,History data 27-Comfort data bus,947,
IDE01813-MAS03177,History data 27-Infotainment data bus,5,
IDE01813-MAS03178,History data 27-Suspension data bus,0,
IDE01813-MAS12185,History data 27-Hybrid data bus,4839,
IDE01813-MAS14374,History data 27-Totals,6525,
IDE01814-MAS03173,History data 28-Powertrain data bus,333,
IDE01814-MAS03174,History data 28-Comfort data bus,37333,
IDE01814-MAS03177,History data 28-Infotainment data bus,127,
IDE01814-MAS03178,History data 28-Suspension data bus,0,
IDE01814-MAS14374,History data 28-Totals,37992,
IDE01814-MAS16910,History data 28-Migration data bus,199,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.1, H
IDE01816-MAS00106,History data 30-Year,2026,
IDE01816-MAS00107,History data 30-Month,3,
IDE01816-MAS00108,History data 30-Day,9,
IDE01816-MAS00109,History data 30-Hours,13, H
IDE01816-MAS00110,History data 30-Minutes,34, min
IDE01816-MAS14375,History data 30-Cycle counter,3302,
IDE01816-ENG151642,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG151644,History data 30-Bus_2,Infotainment data bus,
IDE01816-ENG151646,History data 30-Bus_3,Migration data bus,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,3.3, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,1.2, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.1, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.3, H
IDE01817-MAS00106,History data 31-Year,2026,
IDE01817-MAS00107,History data 31-Month,6,
IDE01817-MAS00108,History data 31-Day,19,
IDE01817-MAS00109,History data 31-Hours,20, H
IDE01817-MAS00110,History data 31-Minutes,39, min
IDE01817-MAS14375,History data 31-Cycle counter,3494,
IDE01817-MAS14376,History data 31-ECU 1,00 0E,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.3, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG159905,History data 31-Bus_ECU_1,Comfort data bus,
IDE01817-ENG159908,History data 31-Bus_ECU_2,Unknown,
IDE01817-ENG159911,History data 31-Bus_ECU_3,Unknown,
IDE01817-ENG159914,History data 31-Bus_ECU_4,Unknown,
IDE01817-ENG159917,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.3, H
IDE01819-MAS00106,History data 33-Year,2021,
IDE01819-MAS00107,History data 33-Month,12,
IDE01819-MAS00108,History data 33-Day,9,
IDE01819-MAS00109,History data 33-Hours,16, H
IDE01819-MAS00110,History data 33-Minutes,54, min
IDE01819-MAS14375,History data 33-Cycle counter,12,
IDE01819-MAS14393,History data 33-ID of the alerting message,17 F0 00 31,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2026,
IDE01820-MAS00107,History data 34-Month,9,
IDE01820-MAS00108,History data 34-Day,1,
IDE01820-MAS00109,History data 34-Hours,18, H
IDE01820-MAS00110,History data 34-Minutes,37, min
IDE01820-MAS14375,History data 34-Cycle counter,3813,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 0E,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,3814,
IDE01823-MAS14429,History data 37-Time in current cycle,0.1, H
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82A - 140A,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,0,
IDE01831-MAS06312,Generator variant-ASIC variant,4,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Duration of last driving cycle,0.0, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,15 D5 B0 15,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1,ECU present Bit 2,ECU present Bit 3,ECU present Bit 4,ECU present Bit 5,ECU present Bit 6,ECU present Bit 7|reachable,not reachable,reachable,reachable,reachable,reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,reachable,reachable,not reachable,not reachable,reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable|not reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,reachable,not reachable,not reachable,reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,reachable,not reachable,not reachable,not reachable,reachable,not reachable|,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0,TP 1.6,K Line,Ethernet|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|,
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1,ECU Dtc Bit 2,ECU Dtc Bit 3,ECU Dtc Bit 4,ECU Dtc Bit 5,ECU Dtc Bit 6,ECU Dtc Bit 7|Malfunction,OK,OK,OK,Malfunction,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,Malfunction,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,Malfunction|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,Malfunction,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,Malfunction,OK|,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-request idle speed increase,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Extractable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG299090,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1,Sleep-Bit 2,Sleep-Bit 3,Sleep-Bit 4,Sleep-Bit 5,Sleep-Bit 6,Sleep-Bit 7|System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep,System_not_ready_to_sleep,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|10 00 03 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 00 01 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 02 0E 00,Available,No,valid,Condition met,OK,Available,Condition met|10 02 0F 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 00 11 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 00 13 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 00 15 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 00 17 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 01 01 00,Available,No,valid,Condition met,OK,Available,Condition met|10 01 02 00,Available,No,valid,Condition met,OK,Available,Condition met|10 01 04 00,Available,No,valid,Condition met,OK,Available,Condition met|10 01 05 00,Available,No,valid,Condition met,OK,Available,Condition met|10 0E 16 00,Available,No,valid,Condition met,OK,Available,Condition met|10 02 08 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 03 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 06 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 07 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 08 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 09 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 0A 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 0E 0F 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0,Bus master|0,Bus master|3,CAN|3,CAN|1,CAN|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|0,CAN|0,Bus master|3,CAN|2,CAN|0,Bus master|0,Bus master|0,Bus master|1,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|0,Bus master|0,Bus master|1,CAN|1,CAN|1,CAN|1,CAN|1,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|3,CAN|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|5,CAN|0,Bus master|0,Bus master|5,CAN|0,Bus master|1,CAN|1,CAN|0,Bus master|0,Bus master|1,CAN|1,CAN|1,CAN|1,CAN|16,CAN|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|2,CAN|0,Bus master|16,CAN|2,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,VLAN|0,Bus master|1,CAN|3,CAN|2,CAN|0,Bus master|0,Bus master|0,CAN|17,CAN|0,Bus master|0,Bus master|0,Bus master|5,CAN|17,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|5,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|2,VLAN|0,Bus master|0,Bus master|0,Bus master|0,VLAN|0,Bus master|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|1,VLAN|0,Bus master|0,Bus master|5,CAN|0,Bus master|2,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|2,CAN|0,Bus master|1,VLAN|0,Bus master|0,Bus master|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|5,CAN|0,Bus master|0,CAN|0,Bus master|2,VLAN|0,Bus master|0,Bus master|0,Bus master|3,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,VLAN|0,Bus master|0,Bus master|3,CAN|3,CAN|0,Bus master|0,Bus master|0,Bus master|3,VLAN|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|3,CAN|2,CAN|0,Bus master|0,Bus master|1,CAN|3,CAN|,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,A3 D5 D4 EF 3C,
IDE05960-IDE01827,Generator-Specified generator voltage,10.6, V
IDE05960-IDE01828,Generator-Generator DF Signal,0.025, %
IDE05960-IDE01829,Generator-Generator exciter current,0.000, A
IDE05960-IDE01830,Generator-Generator Status,OFF,
IDE05960-IDE01855,Generator-Generator current,0.0, A
IDE05960-MAS06306,Generator-Status generator release by engine,no request,
IDE05960-MAS06307,Generator-Status of battery charging function,not active,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,0, W
IDE05960-MAS21174,Generator-Generator reserve current,0.0, A
IDE05960-MAS21325,Generator-Ramp time,6, s
IDE06011-ENG118665,Selected driving profile-driving_profile,Dynamic,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0),
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,2315, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,30116, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,4465, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,579, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06592-MAS31502,Status: special functions-Luggage compartment remote control via mobile online services,locked,
IDE06592-MAS31503,Status: special functions-Sunroof remote control via mobile online services.,locked,
IDE06592-MAS31504,Status: special functions-Ventilation remote control via mobile online services,locked,
IDE06592-MAS31505,Status: special functions-Window and sunroof remote control via mobile online services,locked,
IDE06592-MAS31506,Status: special functions-Remote vehicle start via mobile online services,locked,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,9.60,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognised,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognised,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,2.80, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,2.85, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,720, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,712, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,87 E4 C7 39,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.5, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,76, C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,100, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Neck heating,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,not enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heating,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Seat heating: front,not enabled,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.9, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,184, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,184, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,184, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,115,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,115,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,14.9, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS23872,Extended battery diagnosis-Available extractable charge,11, Ah
IDE10674-ENG98590,Extended battery diagnosis-ERROR,---,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,21,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Actual value,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No error recognized,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No error recognized,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,0,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,good: link available,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,1,
IDE11739,Ethernet counter connection interruptions: branch 4,1,
IDE11740,Ethernet counter connection interruptions: branch 5,1,
IDE11741,Ethernet counter connection interruptions: branch 6,1,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 19|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,2429,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,168,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 36 F8 64 77 19|,
IDE11762-IDE02766,Information break recommendation-Malfunction status,not installed,
IDE11762-MAS03095,Information break recommendation-Function status,not installed,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|EC 65 CC 71 D1 DB,FE 80 00 00 00 00 00 00 EE 65 CC FF FE 71 D1 DB,0|,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 13 73 E2|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,|MAC address|EC 65 CC 71 D1 DB|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|30 B4 B8 C7 D4 09|,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key,Query message,Variant,Authorization status,Prioritisation|00 15,stored,Sent,KS Slave,valid authentication,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|14 17,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Sent,Component protection participant of the extended Start authentication,valid authentication,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 6D,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|73 13,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,not stored,Sent,Component protection participant of the extended Start authentication,not authenticated,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 8A,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|2C 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Sent,Component protection participant of the extended Start authentication,not authenticated,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 7B,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|6F 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 10,not stored,Sent,Component protection participant of the extended Start authentication,not authenticated,Not prioritized|20 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|,
IDE12133-MAS01896,Freewheel - energy-Free run,25, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,No enabling,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Activation,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Activation,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|5|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|5|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|3|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,173,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 BA,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,Test not yet carried out|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 1B,Test not yet carried out|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 C9,Test not yet carried out|,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,0,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12625,IP network: current link deceleration: branch 1,65535, s
IDE12626,IP network: current link deceleration: branch 2,65535, s
IDE12627,IP network: current link deceleration: branch 3,65535, s
IDE12628,IP network: current link deceleration: branch 4,65535, s
IDE12629,IP network: current link deceleration: branch 5,65535, s
IDE12630,IP network: current link deceleration: branch 6,65535, s
IDE12633,IP Network maximum correction of the synchronized clock,-1, s
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1,Diag_path Bit 2,Diag_path Bit 3,Diag_path Bit 4,Diag_path Bit 5,Diag_path Bit 6,Diag_path Bit 7|Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|,
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1,Ecu_authentication Bit 2,Ecu_authentication Bit 3,Ecu_authentication Bit 4,Ecu_authentication Bit 5,Ecu_authentication Bit 6,Ecu_authentication Bit 7|Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|,
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name,ECU ID|00 10,Data Bus OBD Interface,25|,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG255704,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnostic filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnostic filter: status-Mileage recorder,20, km
IDE13754-MAS16867,Diagnostic filter: status-Reason for deactivation,hood open,
IDE13754-MAS16875,Diagnostic filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00030921*2026-09-01-18:37:46*1*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00030921*2026-09-01-18:34:18*1*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00030921*2026-09-01-18:33:58*1*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00030911*2026-09-01-17:51:10*1*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00030911*2026-09-01-10:17:17*1*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Malfunction,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,126,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,150,
IDE14260-ENG255502,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG255503,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 76 0A 29 8C 5F F7 BE,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,not active,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
MAS00464-MAS00106,Standard - ambient data 1-Year,2083,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,14,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,46,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,30921, km
MAS00769-IDE02717,Multi-function steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multi-function steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multi-function steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multi-function steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multi-function steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multi-function steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multi-function steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multi-function steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multi-function steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multi-function steering wheel control module-MFL message counter,9,
MAS00769-MAS06030,Multi-function steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multi-function steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multi-function steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,All releases are present,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,25, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS05129,Engine running status-Motor,Engine off,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,not active,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D,Generator|00 37,Battery Monitoring Control Module|00 69,Inverter for socket|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 31,Multi-function steering wheel control module|01 3E,Steering Wheel Touch Recognition Control Module|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 72,Analog clock|01 2F,Control head driving profile|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|,
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1,SubSystem present Bit 2,SubSystem present Bit 3,SubSystem present Bit 4,SubSystem present Bit 5,SubSystem present Bit 6,SubSystem present Bit 7|reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|,
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|83|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12-volt battery-Battery current,-10.150, A
MAS16744-IDE01837,12-volt battery-Temperature of battery sensor,51, C
MAS16744-IDE01838,12-volt battery-Battery temperature,51, C
MAS16744-IDE01839,12-volt battery-Battery charge status,70, %
MAS16744-IDE01841,12-volt battery-Battery internal resistance,4.2, mOhm
MAS16744-IDE01842,12-volt battery-Usable battery charge,40, Ah
MAS16744-IDE01948,12-volt battery-Battery internal resistance not normed,4.0, mOhm
MAS16744-IDE04186,12-volt battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12-volt battery-adapted battery capacity,75, Ah
MAS16744-MAS00362,12-volt battery-Battery voltage,12.663, V
MAS16744-MAS06086,12-volt battery-Total re-charge,3824.8, Ah
MAS16744-MAS06087,12-volt battery-Entire energy throughput,3661.0, Ah
MAS16744-MAS22232,12-volt battery-Battery aging: charge-related,92, %
MAS16744-MAS22233,12-volt battery-Battery aging: performance-related,85, %
MAS16744,12-volt battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge status,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.4, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.992, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 03 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,Available,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,21,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,00,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,Available,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,00 00 00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,61 B1 B4 14,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,3809,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG254617-ENG299125,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu,DoIP_Status_TCP_Connections|03 01,00,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|14 00,not active,No,not active,00||34 58,02,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|00 00,not active,No,not active,00||01 00,67,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|34 00,not active,No,not active,00||58 02,00,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|01 00,not active,No,not active,00||00 73,34,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|58 00,not active,No,not active,00||02 00,00,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|00 00,not active,No,not active,00||,
ENG254617-ENG280661,DoIP_Status-number_of_total_ecu,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognised,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognised,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Terminal 15 on,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG254621-ENG255502,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG254621-ENG255503,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG254621-ENG255504,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG254621-ENG255545,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG254621-ENG255551,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,150,
ENG254621-ENG255553,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,126,
ENG254621-ENG255557,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,-10.137, A
ENG254621-ENG255558,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG254621-ENG255559,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG254621-ENG256044,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,720, A
ENG254621-ENG256064,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,9.60,
ENG254621-ENG256101,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG254621-ENG256097,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG254621-ENG256098,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG254621-ENG256099,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG254621-ENG256100,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG254621-ENG256270,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG254621-ENG256620,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,12.662, V
ENG254622-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG254622-MAS21179,Energy_management_dashboard_display-Energy generator reports,1,
ENG254622-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG254622-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG299130,Gateway app. software identification-Gateway_applikation_software_identifikation,|nf_name,SW_VERSION|routing_gateway,9073|fpa,1410|NVEM,7702|HID,0802|KS,----|eASS,3001|MFL,0204|sk1a,0100|rwb,F001|SWaP,0821|wum,0100|BCmE,1036|mke,3579|hv-em,2400|routing_gateway,|Ehr,2011|mvem,2301|Klr,----|routing_gateway,|vmks,1300|paco,0362|ids,3201|routing_gateway,|FoD,2007|sda,----|SOK-FM,1400|routing_gateway,|,
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG254725-ENG256045,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG254725-ENG152043,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG254725-ENG255205,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG254727-ENG152029,HV-EM_energy_specification-High_voltage_battery_energy_information,102350,
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,102300, Wh
ENG254727-ENG152039,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG254728-ENG152030,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG254728-ENG152033,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG152037,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,0, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,0, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,OFF,
ENG254730-ENG152028,HV-EM_operation_limitation-High_voltage_battery_current_limitation,0, A
ENG254730-ENG255206,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,127.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,0, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG254777,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0),
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG151187-ENG256301,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188,MV-EM_48V_overvoltage_check,---,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,0.0, A
ENG151192,MV-EM_dc_power_desired,0, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,0, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG254783-ENG246261,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG254783-ENG274259,NVEM_12V_Rekuperation-Batterie_Ladezustand,0,
ENG254783-ENG274260,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG254783-ENG274261,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG254783-ENG274262,NVEM_12V_Rekuperation-Batterie_Temperatur,1,
ENG254783-ENG255379,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG254783-ENG255380,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG254783-ENG255700,NVEM_12V_Rekuperation-Energienetz,1,
ENG254783-ENG255703,NVEM_12V_Rekuperation-Entnehmbare_Ladung,1,
ENG254783-ENG255737,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG254783-ENG255738,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG254783-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG254783-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG254783-ENG252593,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG254783-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,1,
ENG254783-ENG256076,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,Neutral,
ENG254783-ENG256106,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG254783-ENG255165,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG254783-ENG256273,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG254783-ENG256306,NVEM_12V_Rekuperation-Saeureschichtung,1,
ENG254783-ENG101873,NVEM_12V_Rekuperation-Sonderveto,1,
ENG254783-ENG256364,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG254783-ENG256365,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG254783-ENG256366,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG254783-ENG256367,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG254783-ENG256368,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG254783-ENG256369,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG254783-ENG256399,NVEM_12V_Rekuperation-Status_Rekuperation,not active,
ENG254783-ENG256400,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG254784-ENG255286,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG254784-ENG255298,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG254784-ENG255179,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG254784-ENG255754,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG254784-ENG256398,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG254784-ENG256720,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG250370,NVEM_Grund_BEM_falsch_codiert,0,
ENG254786-ENG255308,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG254786-ENG255209,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG254787-ENG255299,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG254787-ENG255300,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG254787-ENG255779,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG254787-ENG255780,NVEM_HLR_Master-Heizleistungskontingent_Stufe,not active,
ENG254788-ENG255369,NVEM_Zustand_HLR-BA2_ZuendungEin,1,
ENG254788-ENG255370,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG254788-ENG256423,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG254788-ENG256424,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG254788-ENG256425,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG254788-ENG256426,NVEM_Zustand_HLR-TabE_Crash,0,
ENG254788-ENG256427,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG254788-ENG256428,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG254788-ENG256429,NVEM_Zustand_HLR-TabNQ,0,
ENG280376,Reason_nvem_vehicle_electrical_system_state_diagnosis,0,
ENG280381-ENG280515,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_emergency_strategy,0,
ENG280381-ENG280516,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_failure_warning,not active,
ENG280381-ENG280517,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operating_quadrant,Standard mode,
ENG280381-ENG280518,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operational_restriction,not active,
ENG280381-ENG280519,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_service_information,OK,
Elapsed Time: 00:54
;SW:5WA-907-530-Q HW:5WA-907-530-G --- 19: CAN Gateway
;Component:GW2020 High 756 7099, Coding:0000808D0F00000000000000010303327302600902000301030100000001010000000000000000000000000000000000
;EV_GatewMQB2020,005011,EV_GatewMQB2020_004_VW38.rod
;Tuesday,01,September,2026,20:53:21:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 56F259DC488BF0FAEDC-8002 SFD [ ]
Group,Description,Actual
IDE00019,Voltage terminal 30,12.0, V
IDE00056,History data 1,000*2026-05-07-14:07*0021*02**,
IDE00056,History data 1,000*2026-07-15-21:04*0000*02**,
IDE00056,History data 1,000*2000-01-01-00:00*0000*00*00000**,
IDE00056,History data 1,000*2026-08-30-11:14*0008*02*00000**,
IDE00056,History data 1,000*2026-05-09-16:47*0064*02**,
IDE00056,History data 1,000*2000-01-01-00:00*0000*00**,
IDE00056,History data 1,000*2026-08-29-22:39*0000*02**,
IDE00056,History data 1,000*2026-05-12-08:13*0055*02*00000**,
IDE00057,History data 2,000*2000-01-01-00:00*000*000*+0.000*0-0-0-0-0-0-0*0*00**,
IDE00057,History data 2,000*2021-12-09-14:55*001*055*-0.279*0-0-0-0-0-0-0*0*01*00001**,
IDE00058,History data 3,000*2000-01-01-00:00*0*0*000*000*0-0-0-0-0-0-0*0*0*00.0*00.0**,
IDE00058,History data 3,000*2026-05-08-16:30*1*0*047*006*0-0-1-1-1-0-0*0*0*00.0*00.0**,
IDE00058,History data 3,000*2026-02-21-07:33*1*0*039*006*0-0-0-0-0-0-0*0*0*00.0*00.1**,
IDE00059,History data 4,000*2026-09-01-00:21*04*070*Int**10000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,000*2026-09-01-00:21*03*070***10000*00000*000.0*000.0*000.0**,
IDE00059,History data 4,000*2026-09-01-00:22*05*070*Int*6DKJ21*10000*00000*000.0*000.0*000.0**,
IDE00060,History data 5,000*2000-01-01-00:00*0*+0.000*13.50*000*00*+00.0*00000*00000*000000*0-0-0-0-0-0-0*0*0*0*00.0*00.0*000.0*00*00*00*00*00**,
IDE00061,History data 6,000*2026-09-01-17:51*044*+48*+001.1*00.20*0.00*000**,
IDE00061,History data 6,000*2026-09-01-20:00*037*+50*+002.7*00.10*0.00*000**,
IDE00061,History data 6,000*2026-09-01-08:55*040*+43*+000.8*00.10*0.00*000**,
IDE00061,History data 6,000*2026-09-01-09:58*039*+46*+001.2*00.20*0.00*000**,
IDE00061,History data 6,000*2026-08-31-21:16*038*+49*+002.4*00.10*0.00*000**,
IDE00061,History data 6,000*2026-09-01-19:51*034*+49*+001.7*00.00*0.00*000**,
IDE00061,History data 6,000*2026-08-31-22:11*039*+49*+001.3*00.40*0.00*000**,
IDE00061,History data 6,000*2026-08-31-21:15*037*+49*-000.1*00.00*0.00*000**,
IDE00061,History data 6,000*2026-08-31-20:32*039*+49*+001.3*00.10*0.00*000**,
IDE00061,History data 6,000*2026-08-31-21:25*039*+49*+001.5*00.40*0.00*000**,
IDE00062,History data 7,000*2026-08-31-21:15*036*+000.2*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-08-31-20:41*037*+002.3*000.0*00.1*00.0**,
IDE00062,History data 7,000*2026-09-01-18:05*032*+010.7*001.2*01.2*01.1**,
IDE00062,History data 7,000*2026-08-31-21:52*038*+000.8*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-08-31-21:25*038*+000.1*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-08-31-20:25*038*+000.8*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-08-31-22:39*038*+001.1*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-01-10:12*043*+001.0*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-01-19:53*034*+000.5*000.0*00.0*00.0**,
IDE00062,History data 7,000*2026-09-01-09:04*038*+000.9*000.0*00.0*00.0**,
IDE00063,History data 8,000*2026-09-01-19:49*1*04*00*00*08*-------------:--*02**,
IDE00063,History data 8,000*2000-01-01-00:00*4*03*00*00*07*2026-02-16-08:31*02**,
IDE00063,History data 8,000*2025-04-03-00:51*1*03*00*00*06*-------------:--*02**,
IDE00064,History data 9,000*2022-03-05-00:57*100*100*100*100*00001*15.00*-40*00*02*00.00*00000*00000**,
IDE00064,History data 9,000*2026-07-19-12:08*089*084*079*045*03460*12.50*+48*04*02*02.80*00000*00000**,
IDE00064,History data 9,000*2026-06-17-12:04*096*086*084*050*03195*12.60*+42*04*02*02.75*00000*00000**,
IDE00064,History data 9,000*2026-07-20-15:45*093*084*078*045*03479*12.50*+49*04*02*02.85*00000*00000**,
IDE00064,History data 9,000*2026-03-30-11:02*069*068*049*016*03023*12.10*+24*05*02*03.55*00000*00000**,
IDE00064,History data 9,000*2026-06-01-07:46*100*100*100*100*03097*15.00*-40*00*02*00.00*00000*00000**,
IDE00064,History data 9,000*2026-07-13-21:41*094*085*075*045*03384*12.50*+57*04*02*02.85*00000*00000**,
IDE00064,History data 9,000*2026-06-27-14:03*097*086*087*053*03315*12.60*+46*04*02*02.75*00000*00007**,
IDE00064,History data 9,000*2026-08-16-16:45*092*085*074*043*03608*12.40*+47*04*02*02.80*00000*00000**,
IDE00064,History data 9,000*2026-04-30-12:46*062*063*047*013*03061*12.10*+24*05*02*03.65*00000*00000**,
IDE00064,History data 9,000*2026-07-17-19:42*085*083*077*042*03434*12.50*+45*04*02*02.80*00000*00000**,
IDE00064,History data 9,000*2026-06-01-07:47*085*089*067*033*03097*12.30*+35*04*02*02.90*00000*00000**,
IDE00065,History data 10,000*2000-01-01-00:00*00*00.0*13.50*000.0**,
IDE00065,History data 10,000*2000-01-01-00:00*0*000.0*0000.0*0*000.0*0000.0*00.00*0000000**,
IDE00066,History data 11,000*2026-09-01-17:51*000*000*000*000*0000*014*00.0*00.0*076*043*077*044*01*00000*00000*00000*00000*03166**,
IDE00066,History data 11,000*2026-09-01-08:55*000*000*000*000*0000*008*00.0*00.0*070*039*071*040*01**,
IDE00066,History data 11,000*2026-08-31-20:32*000*000*000*000*0000*008*00.0*00.0*070*038*071*039*01**,
IDE00066,History data 11,000*2026-08-31-09:37*000*000*000*000*0000*012*00.0*00.0*077*042*078*043*01**,
IDE00066,History data 11,000*2026-08-31-18:10*000*000*000*000*0000*014*00.0*00.0*075*039*077*043*01**,
IDE00067,History data 12,000*2000-01-01-00:00*0-0-0-0-0-0-0-0**,
IDE00067,History data 12,000*2026-04-22-08:03*2*059*019*+32*05*025*+19.10*12.6*1**,
IDE00067,History data 12,000*2026-02-16-11:37*2*059*018*+32*06*025*+32.70*14.1*1**,
IDE00067,History data 12,00000*00000*00000*00000*00000*00000*00000*00000**,
IDE00067,History data 12,000*2026-03-11-16:08*2*059*020*+30*05*025*+77.92*12.1*1**,
IDE00067,History data 12,00000*00000*00000**,
IDE00067,History data 12,000*2026-03-11-15:19*2*060*020*+24*05*025*+18.50*12.7*1**,
IDE00067,History data 12,000*2026-03-10-10:07*2*059*018*+30*05*025*+08.00*12.5*1**,
IDE00068,History data 13,000*2000-01-01-00:00*0-0-0-0-0*000.0*00000**,
IDE00068,History data 13,000*2000-01-01-00:00*0-0-0-0-0*000.0**,
IDE00069,History data 14,000*2026-09-01-19:53*2*00000*0096*0000*00.00*131088*+49**,
IDE00069,History data 14,000*2026-09-01-10:12*2*00047*0172*0000*00.20*000016*+46**,
IDE00069,History data 14,000*2026-09-01-09:04*2*00000*0169*0000*00.10*000016*+43**,
IDE00069,History data 14,000*2026-09-01-20:09*2*00090*0245*0000*00.10*131088*+50*0010.4*0059.5*0000.0**,
IDE00069,History data 14,000*2000-01-01-00:00*000.0*20.0*20.0**,
IDE00069,History data 14,000*2026-09-01-18:05*2*00516*0336*0000*00.20*131152*+48**,
IDE00069,History data 14,00705*19774*00784*00000*00000**,
IDE00069,History data 14,000*2026-09-01-20:09*000.0*04.0*04.0*0000.0**,
IDE00071,History data 16,02341*00980*00183**,
IDE00071,History data 16,00101*00023*00002**,
IDE00071,History data 16,00001*00002*00000**,
IDE00071,History data 16,0030926km**,
IDE00071,History data 16,00000*00000*00000**,
IDE00071,History data 16,03581*02039*00091*00004**,
IDE00071,History data 16,00000*00000*00000*00000**,
IDE00071,History data 16,00799*01399*00941*00369**,
IDE00071,History data 16,00000*00000*00000*00000*00000**,
IDE00071,History data 16,00000*00000*00000*00000*00000*00000*00000*00000*00000*00001*00000**,
IDE00071,History data 16,00025*00093*00035*00010**,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,6,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,15,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,136,
IDE00634,Vehicle electric system current,0.000, A
IDE00767-ENG280618,No. of unscheduled ECU resets-FCCU_RF_S0_Status,00 00 00 80,
IDE00767-ENG280619,No. of unscheduled ECU resets-FCCU_RF_S1_Status,00 00 00 00,
IDE00767-ENG280620,No. of unscheduled ECU resets-FCCU_RF_S2_Status,00 00 00 00,
IDE00767-ENG280621,No. of unscheduled ECU resets-FCCU_RF_S3_Status,00 00 00 00,
IDE00767-ENG136152,No. of unscheduled ECU resets-KL30_Reset_Counter,24,
IDE00767-ENG280656,No. of unscheduled ECU resets-Muc_Reset_Counter,0,
IDE00767-ENG280678,No. of unscheduled ECU resets-Reason_of_2th_last_reset,0,
IDE00767-ENG280679,No. of unscheduled ECU resets-Reason_of_3th_last_reset,0,
IDE00767-ENG280680,No. of unscheduled ECU resets-Reason_of_4th_last_reset,4,
IDE00767-ENG280681,No. of unscheduled ECU resets-Reason_of_5th_last_reset,0,
IDE00767-ENG280682,No. of unscheduled ECU resets-Reason_of_latest_reset,0,
IDE00767-ENG280768,No. of unscheduled ECU resets-Watchdog_Reset_Counter,2,
IDE01803,History data 17,000*2000-01-01-00:00*00*0*000*15.0*+00*00.0*000*000**,
IDE01803,History data 17,000*2000-01-01-00:00*00*0*000*15.0*+00*00.0**,
IDE01803,History data 17,000*2000-01-01-00:00*0*00.0*000*+00*000*000**,
IDE01803,History data 17,000*2000-01-01-00:00*0*00.0*000*+00**,
IDE01803,History data 17,00000*00000*00000*00000*00000*00000**,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.3, H
IDE01807-MAS00106,History data 21-Year,2026,
IDE01807-MAS00107,History data 21-Month,6,
IDE01807-MAS00108,History data 21-Day,19,
IDE01807-MAS00109,History data 21-Hours,20, H
IDE01807-MAS00110,History data 21-Minutes,39, min
IDE01807-MAS14375,History data 21-Cycle counter,3494,
IDE01807-MAS14376,History data 21-ECU 1,00 0E,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.3, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 00,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-ENG159905,History data 21-Bus_ECU_1,Comfort data bus,
IDE01807-ENG159908,History data 21-Bus_ECU_2,Unknown,
IDE01807-ENG159911,History data 21-Bus_ECU_3,Unknown,
IDE01807-ENG159914,History data 21-Bus_ECU_4,Unknown,
IDE01807-ENG159917,History data 21-Bus_ECU_5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.2, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.7, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS12185,History data 22-Hybrid data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.8, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2000,
IDE01809-MAS00107,History data 23-Month,1,
IDE01809-MAS00108,History data 23-Day,1,
IDE01809-MAS00109,History data 23-Hours,0, H
IDE01809-MAS00110,History data 23-Minutes,0, min
IDE01809-MAS14375,History data 23-Cycle counter,0,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Unknown,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,0,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 00,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,0,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-ENG255497,History data 23-Bus_Waking_ECU_1,Unknown,
IDE01809-ENG255498,History data 23-Bus_Waking_ECU_2,Unknown,
IDE01809-ENG255499,History data 23-Bus_Waking_ECU_3,Unknown,
IDE01809-ENG255500,History data 23-Bus_Waking_ECU_4,Unknown,
IDE01809-ENG255501,History data 23-Bus_Waking_ECU_5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.3, H
IDE01810-MAS00106,History data 24-Year,2021,
IDE01810-MAS00107,History data 24-Month,12,
IDE01810-MAS00108,History data 24-Day,9,
IDE01810-MAS00109,History data 24-Hours,16, H
IDE01810-MAS00110,History data 24-Minutes,54, min
IDE01810-MAS14375,History data 24-Cycle counter,12,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,1,
IDE01810-MAS14393,History data 24-ID of the alerting message,17 F0 00 31,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Comfort data bus,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,31,
IDE01810-MAS20473,History data 24-Alerting message counter,23,
IDE01812-MAS01468,History data 26-Terminal 15,3822,
IDE01812-MAS03173,History data 26-Powertrain data bus,111,
IDE01812-MAS03174,History data 26-Comfort data bus,5329,
IDE01812-MAS03177,History data 26-Infotainment data bus,201,
IDE01812-MAS03178,History data 26-Suspension data bus,7,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,4,
IDE01812-MAS14374,History data 26-Totals,5722,
IDE01812-MAS16910,History data 26-Migration data bus,31,
IDE01813-MAS03173,History data 27-Powertrain data bus,734,
IDE01813-MAS03174,History data 27-Comfort data bus,948,
IDE01813-MAS03177,History data 27-Infotainment data bus,5,
IDE01813-MAS03178,History data 27-Suspension data bus,0,
IDE01813-MAS12185,History data 27-Hybrid data bus,4842,
IDE01813-MAS14374,History data 27-Totals,6529,
IDE01814-MAS03173,History data 28-Powertrain data bus,334,
IDE01814-MAS03174,History data 28-Comfort data bus,37370,
IDE01814-MAS03177,History data 28-Infotainment data bus,127,
IDE01814-MAS03178,History data 28-Suspension data bus,0,
IDE01814-MAS14374,History data 28-Totals,38030,
IDE01814-MAS16910,History data 28-Migration data bus,199,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,0.1, H
IDE01816-MAS00106,History data 30-Year,2026,
IDE01816-MAS00107,History data 30-Month,3,
IDE01816-MAS00108,History data 30-Day,9,
IDE01816-MAS00109,History data 30-Hours,13, H
IDE01816-MAS00110,History data 30-Minutes,34, min
IDE01816-MAS14375,History data 30-Cycle counter,3302,
IDE01816-ENG151642,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG151644,History data 30-Bus_2,Infotainment data bus,
IDE01816-ENG151646,History data 30-Bus_3,Migration data bus,
IDE01816-ENG151648,History data 30-Bus_4,Unknown,
IDE01816-ENG151650,History data 30-Bus_5,Unknown,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,3.3, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,1.2, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.1, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.0, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.3, H
IDE01817-MAS00106,History data 31-Year,2026,
IDE01817-MAS00107,History data 31-Month,6,
IDE01817-MAS00108,History data 31-Day,19,
IDE01817-MAS00109,History data 31-Hours,20, H
IDE01817-MAS00110,History data 31-Minutes,39, min
IDE01817-MAS14375,History data 31-Cycle counter,3494,
IDE01817-MAS14376,History data 31-ECU 1,00 0E,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.3, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 00,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-ENG159905,History data 31-Bus_ECU_1,Comfort data bus,
IDE01817-ENG159908,History data 31-Bus_ECU_2,Unknown,
IDE01817-ENG159911,History data 31-Bus_ECU_3,Unknown,
IDE01817-ENG159914,History data 31-Bus_ECU_4,Unknown,
IDE01817-ENG159917,History data 31-Bus_ECU_5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2000,
IDE01818-MAS00107,History data 32-Month,1,
IDE01818-MAS00108,History data 32-Day,1,
IDE01818-MAS00109,History data 32-Hours,0, H
IDE01818-MAS00110,History data 32-Minutes,0, min
IDE01818-MAS14375,History data 32-Cycle counter,0,
IDE01818-MAS14391,History data 32-Alerting ECU,00 00,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 00,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.3, H
IDE01819-MAS00106,History data 33-Year,2021,
IDE01819-MAS00107,History data 33-Month,12,
IDE01819-MAS00108,History data 33-Day,9,
IDE01819-MAS00109,History data 33-Hours,16, H
IDE01819-MAS00110,History data 33-Minutes,54, min
IDE01819-MAS14375,History data 33-Cycle counter,12,
IDE01819-MAS14393,History data 33-ID of the alerting message,17 F0 00 31,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,0.0, H
IDE01820-MAS00106,History data 34-Year,2026,
IDE01820-MAS00107,History data 34-Month,9,
IDE01820-MAS00108,History data 34-Day,1,
IDE01820-MAS00109,History data 34-Hours,0, H
IDE01820-MAS00110,History data 34-Minutes,7, min
IDE01820-MAS14375,History data 34-Cycle counter,3821,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4A,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,3822,
IDE01823-MAS14429,History data 37-Time in current cycle,0.3, H
IDE01831-MAS03159,Generator variant-Manufacturer,Robert Bosch GmbH,
IDE01831-MAS06310,Generator variant-Generator identifier,82A - 140A,
IDE01831-MAS06311,Generator variant-ASIC manufacturer,0,
IDE01831-MAS06312,Generator variant-ASIC variant,4,
IDE01831-MAS21176,Generator variant-Generator model,5,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,70, min
IDE01848,Energy balance of last driving cycle,0.0, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Duration of last driving cycle,0.0, H
IDE01985-MAS06855,FAZIT identification test sum-Test sum,15 D5 B0 15,
IDE01992-ENG100904,Installation list: current installations-ECUs present,|ECU present Bit 0,ECU present Bit 1,ECU present Bit 2,ECU present Bit 3,ECU present Bit 4,ECU present Bit 5,ECU present Bit 6,ECU present Bit 7|reachable,not reachable,reachable,reachable,reachable,reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,reachable,reachable,not reachable,not reachable,reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable|not reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,reachable,not reachable,not reachable,reachable,reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,reachable,not reachable,not reachable,not reachable,reachable,not reachable|,
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0,TP 1.6,K Line,Ethernet|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|,
IDE02384-ENG102478,Status of event memory-ECU Dtcs,|ECU Dtc Bit 0,ECU Dtc Bit 1,ECU Dtc Bit 2,ECU Dtc Bit 3,ECU Dtc Bit 4,ECU Dtc Bit 5,ECU Dtc Bit 6,ECU Dtc Bit 7|Malfunction,OK,Malfunction,Malfunction,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,Malfunction,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,Malfunction,Malfunction|OK,OK,OK,OK,OK,OK,OK,Malfunction|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,Malfunction|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,Malfunction,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,Malfunction,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,OK,OK,OK,OK,OK,OK|OK,OK,Malfunction,OK,OK,OK,OK,OK|,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-request idle speed increase,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Extractable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03150-ENG299090,Readiness for bus sleep mode-ECU_Sleepindication,|Sleep-Bit 0,Sleep-Bit 1,Sleep-Bit 2,Sleep-Bit 3,Sleep-Bit 4,Sleep-Bit 5,Sleep-Bit 6,Sleep-Bit 7|System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep,System_not_ready_to_sleep,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_not_ready_to_sleep|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping|System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_ready_to_sleep_or_sleeping,System_not_ready_to_sleep,System_ready_to_sleep_or_sleeping|,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|10 00 03 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 00 01 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 02 0E 00,Available,No,valid,Condition met,OK,Available,Condition met|10 02 0F 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 00 11 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 00 13 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 00 15 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 00 17 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 01 01 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 01 02 00,Available,No,valid,Condition met,OK,Not available,Condition met|10 01 04 00,Available,No,valid,Condition met,OK,Available,Condition met|10 01 05 00,Available,No,valid,Condition met,OK,Available,Condition met|10 0E 16 00,Available,No,valid,Condition met,OK,Available,Condition met|10 01 06 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 07 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 08 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 09 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 01 0A 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|10 0E 0F 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0,Bus master|0,Bus master|3,CAN|3,CAN|1,CAN|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|0,CAN|0,Bus master|3,CAN|2,CAN|0,Bus master|0,Bus master|0,Bus master|1,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|0,Bus master|0,Bus master|1,CAN|1,CAN|1,CAN|1,CAN|1,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|3,CAN|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|5,CAN|0,Bus master|0,Bus master|5,CAN|0,Bus master|1,CAN|1,CAN|0,Bus master|0,Bus master|1,CAN|1,CAN|1,CAN|1,CAN|16,CAN|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|2,CAN|0,Bus master|16,CAN|2,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,VLAN|0,Bus master|1,CAN|3,CAN|2,CAN|0,Bus master|0,Bus master|0,CAN|17,CAN|0,Bus master|0,Bus master|0,Bus master|5,CAN|17,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|5,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|2,VLAN|0,Bus master|0,Bus master|0,Bus master|0,VLAN|0,Bus master|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|1,VLAN|0,Bus master|0,Bus master|5,CAN|0,Bus master|2,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|2,CAN|0,Bus master|1,VLAN|0,Bus master|0,Bus master|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|5,CAN|0,Bus master|0,CAN|0,Bus master|2,VLAN|0,Bus master|0,Bus master|0,Bus master|3,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,VLAN|0,Bus master|0,Bus master|3,CAN|3,CAN|0,Bus master|0,Bus master|0,Bus master|3,VLAN|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|3,CAN|2,CAN|0,Bus master|0,Bus master|1,CAN|3,CAN|,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,A3 D5 D4 EF 3C,
IDE05960-IDE01827,Generator-Specified generator voltage,10.6, V
IDE05960-IDE01828,Generator-Generator DF Signal,0.025, %
IDE05960-IDE01829,Generator-Generator exciter current,0.000, A
IDE05960-IDE01830,Generator-Generator Status,OFF,
IDE05960-IDE01855,Generator-Generator current,0.0, A
IDE05960-MAS06306,Generator-Status generator release by engine,no request,
IDE05960-MAS06307,Generator-Status of battery charging function,not active,
IDE05960-MAS11758,Generator-Identification,Yes,
IDE05960-MAS14589,Generator-mechanical power,0, W
IDE05960-MAS21174,Generator-Generator reserve current,0.0, A
IDE05960-MAS21325,Generator-Ramp time,6, s
IDE06011-ENG118665,Selected driving profile-driving_profile,Dynamic,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0),
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,2315, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,30209, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,4465, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,579, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06230-MAS00106,Break recommend.: last message-Year,2001,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,1,
IDE06230-MAS00109,Break recommend.: last message-Hours,0,
IDE06230-MAS00110,Break recommend.: last message-Minutes,0,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,Initialization,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,No message,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06592-MAS31502,Status: special functions-Luggage compartment remote control via mobile online services,locked,
IDE06592-MAS31503,Status: special functions-Sunroof remote control via mobile online services.,locked,
IDE06592-MAS31504,Status: special functions-Ventilation remote control via mobile online services,locked,
IDE06592-MAS31505,Status: special functions-Window and sunroof remote control via mobile online services,locked,
IDE06592-MAS31506,Status: special functions-Remote vehicle start via mobile online services,locked,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,04,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07628,Status power receptacle,---,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,14.3, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,0, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,0, A
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,14.65,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognised,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognised,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,0.00, V
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,0.00, V
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,1, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,1, A
IDE07640,Analysis of start voltage behavior,---,
IDE08343,Immobilizer Challenge,D7 9E 60 5D,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,12.0, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,564, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,68, C
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,100, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE08794,Battery cell analysis,---,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Neck heating,not enabled,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,not enabled,
IDE09058-MAS01564,Energy management: consumer releases-Windshield defogger,not enabled,
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,not enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,not enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heating,not enabled,
IDE09058-MAS05887,Energy management: consumer releases-Battery cut out relay 2,not enabled,
IDE09058-MAS06551,Energy management: consumer releases-Seat ventilation,not enabled,
IDE09058-MAS06552,Energy management: consumer releases-Seat heating: front,not enabled,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Conventional combustion engine,
IDE09074-MAS08256,Vehicle properties-Max energy content,327400, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),14.0, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,7.9, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,13.0, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,33.8, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,400, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,197, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,0, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,13, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,197, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,197, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,0, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,2047, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,120,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,120,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,2045,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,5.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,5.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,5.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,13.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,13.0, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,13.0, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,13.0, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,13.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,13.0, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,16.0, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,0, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10674-MAS23872,Extended battery diagnosis-Available extractable charge,11, Ah
IDE10674-ENG98590,Extended battery diagnosis-ERROR,---,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,21,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Actual value,0,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11673-MAS02246,Battery Management 2: prohibition on turning-on 48V-Timeout,not active,
IDE11673-MAS03123,Battery Management 2: prohibition on turning-on 48V-Reduced performance,not active,
IDE11673-MAS09519,Battery Management 2: prohibition on turning-on 48V-Message error,not active,
IDE11673-MAS09541,Battery Management 2: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11673-MAS09542,Battery Management 2: prohibition on turning-on 48V-Error status init. error,not active,
IDE11673-MAS09543,Battery Management 2: prohibition on turning-on 48V-Operating mode error,not active,
IDE11673-MAS09544,Battery Management 2: prohibition on turning-on 48V-No component function,not active,
IDE11673-MAS09545,Battery Management 2: prohibition on turning-on 48V-Sequence error,not active,
IDE11674-MAS02246,Voltage transformer: prohibition on turning-on 48V-Timeout,not active,
IDE11674-MAS09519,Voltage transformer: prohibition on turning-on 48V-Message error,not active,
IDE11674-MAS09541,Voltage transformer: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11674-MAS09542,Voltage transformer: prohibition on turning-on 48V-Error status init. error,not active,
IDE11674-MAS09543,Voltage transformer: prohibition on turning-on 48V-Operating mode error,not active,
IDE11674-MAS09544,Voltage transformer: prohibition on turning-on 48V-No component function,not active,
IDE11674-MAS09545,Voltage transformer: prohibition on turning-on 48V-Sequence error,not active,
IDE11676-MAS00799,Airbag: prohibition on turning-on 48V-Airbag control module,not active,
IDE11676-MAS02246,Airbag: prohibition on turning-on 48V-Timeout,not active,
IDE11676-MAS09519,Airbag: prohibition on turning-on 48V-Message error,not active,
IDE11676-MAS09521,Airbag: prohibition on turning-on 48V-Light accident detected,not active,
IDE11676-MAS09522,Airbag: prohibition on turning-on 48V-Severe accident detected,not active,
IDE11678-MAS02246,Engine electronics: prohibition on turning-on 48V-Timeout,not active,
IDE11678-MAS09519,Engine electronics: prohibition on turning-on 48V-Message error,not active,
IDE11678-MAS09541,Engine electronics: prohibition on turning-on 48V-Act. mode init. error,not active,
IDE11678-MAS09545,Engine electronics: prohibition on turning-on 48V-Sequence error,not active,
IDE11678-MAS09547,Engine electronics: prohibition on turning-on 48V-Error status drive motor: init. error,not active,
IDE11678-MAS09548,Engine electronics: prohibition on turning-on 48V-Error status drive: init. error,not active,
IDE11678-MAS09549,Engine electronics: prohibition on turning-on 48V-Drive condition: init. error,not active,
IDE11678-MAS09554,Engine electronics: prohibition on turning-on 48V-no component function drive,not active,
IDE11678-MAS13413,Engine electronics: prohibition on turning-on 48V-No component function of starter generator,not active,
IDE11678-MAS13415,Engine electronics: prohibition on turning-on 48V-48 V shut-down due to operating strategy,not active,
IDE11681-MAS03182,Monitoring line disconnection: prohibition on turning-on 48V-Branch 1,not active,
IDE11681-MAS03183,Monitoring line disconnection: prohibition on turning-on 48V-Branch 2,not active,
IDE11683-MAS13705,Engine electronics: status of 48V network-Error status of starter generator,No error recognized,
IDE11683-MAS13716,Engine electronics: status of 48V network-Error status of drive,No error recognized,
IDE11683-MAS13717,Engine electronics: status of 48V network-State of drive,OFF,
IDE11683-MAS13718,Engine electronics: status of 48V network-Handshake,0,
IDE11684-MAS02832,Battery management 2: status for 48V power-Malfunction status,Initialization,
IDE11684-MAS03001,Battery management 2: status for 48V power-Mode,Initialization,
IDE11685-MAS02832,Voltage converter: status for 48V power-Malfunction status,Initialization,
IDE11685-MAS03001,Voltage converter: status for 48V power-Mode,Initialization,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,good: link available,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11732,Ethernet signal quality: branch 5,good: link available,
IDE11733,Ethernet signal quality: branch 6,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,3,
IDE11739,Ethernet counter connection interruptions: branch 4,3,
IDE11740,Ethernet counter connection interruptions: branch 5,3,
IDE11741,Ethernet counter connection interruptions: branch 6,3,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11748,Ethernet counter checksum error: branch 5,0,
IDE11749,Ethernet counter checksum error: branch 6,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 19|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1D|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 1A|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,6138,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,524,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 36 F8 64 77 19|,
IDE11762-IDE02766,Information break recommendation-Malfunction status,not installed,
IDE11762-MAS03095,Information break recommendation-Function status,not installed,
IDE11762-MAS04622,Information break recommendation-Break recommend. message,No message,
IDE11762-MAS13162,Information break recommendation-Icon deactivated,No,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|EC 65 CC 71 D1 DB,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,0|,
IDE11911-MAS00799,48V activation restriction-Airbag control module,not active,
IDE11911-MAS09516,48V activation restriction-Engine Electronics,not active,
IDE11911-MAS13411,48V activation restriction-48 V activation restriction due to open circuit,not active,
IDE11911-MAS13412,48V activation restriction-48 V activation restriction due to deactivation,not active,
IDE11911-SFT00033,48V activation restriction-Battery management 2,not active,
IDE11911-SFT00196,48V activation restriction-Voltage converter,not active,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,Write only channel,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|44 3C 88 13 73 E2|,
IDE11992-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 5-MAC address,|MAC address|EC 65 CC 71 D1 DB|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|30 B4 B8 C7 D4 09|,
IDE12084-IDE02185,Component protection participant status-IKA key,stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,Generation 2,
IDE12084-MAS13795,Component protection participant status-Node address,00 0E,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key,Query message,Variant,Authorization status,Prioritisation|00 15,stored,Sent,KS Slave,valid authentication,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|14 17,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Sent,Component protection participant of the extended Start authentication,valid authentication,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 6D,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|73 13,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,not stored,Sent,Component protection participant of the extended Start authentication,not authenticated,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 8A,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|2C 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Sent,Component protection participant of the extended Start authentication,not authenticated,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 7B,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|6F 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 10,not stored,Sent,Component protection participant of the extended Start authentication,not authenticated,Not prioritized|20 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|,
IDE12133-MAS01896,Freewheel - energy-Free run,30, A
IDE12133-MAS14352,Freewheel - energy-Auxiliary store current,0, A
IDE12133-MAS14353,Freewheel - energy-Loading release for additional memory,No enabling,
IDE12133-MAS14357,Freewheel - energy-Generator start mode,First start,
IDE12133-MAS14362,Freewheel - energy-Voltage limit boost mode,6.0, V
IDE12134-MAS14344,Freewheel - condition-Status of coasting release,Activation,
IDE12134-MAS14348,Freewheel - condition-Status of freewheel engine off release,Activation,
IDE12134-MAS14349,Freewheel - condition-Freewheel engine off block,0,
IDE12134-MAS14350,Freewheel - condition-Store request,no request,
IDE12134-MAS14351,Freewheel - condition-Freewheel engine off restart,0,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,Write only channel,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|5|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|5|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12234-MAS14856,IP network: VLANs of Ethernet switch ports branch 5-VLAN,|VLAN|3|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,528,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 BA,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,Test not yet carried out|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 1B,Test not yet carried out|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 C9,Test not yet carried out|,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,0,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,0,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,0,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12625,IP network: current link deceleration: branch 1,65535, s
IDE12626,IP network: current link deceleration: branch 2,65535, s
IDE12627,IP network: current link deceleration: branch 3,65535, s
IDE12628,IP network: current link deceleration: branch 4,65535, s
IDE12629,IP network: current link deceleration: branch 5,65535, s
IDE12630,IP network: current link deceleration: branch 6,65535, s
IDE12633,IP Network maximum correction of the synchronized clock,-1, s
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1,Diag_path Bit 2,Diag_path Bit 3,Diag_path Bit 4,Diag_path Bit 5,Diag_path Bit 6,Diag_path Bit 7|Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|,
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1,Ecu_authentication Bit 2,Ecu_authentication Bit 3,Ecu_authentication Bit 4,Ecu_authentication Bit 5,Ecu_authentication Bit 6,Ecu_authentication Bit 7|Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface not authentic|Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface not authentic,Control module/bus interface not authentic,Control module/bus interface authentic,Control module/bus interface authentic|,
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name,ECU ID|00 10,Data Bus OBD Interface,25|,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13679-MAS01461,Power generator status-Electrical malfunction,electrically OK,
IDE13679-MAS01574,Power generator status-Mechanical malfunction,Mechanical OK,
IDE13679-MAS06304,Power generator status-Status overvoltage diagnosis,not active,
IDE13679-MAS06305,Power generator status-Status of diagnosis for energy balance,not active,
IDE13679-MAS21175,Power generator status-Generator temperature error,Thermal OK,
IDE13679-ENG255704,Power generator status-error_primary_circuit,not active,
IDE13754-IDE04447,Diagnostic filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnostic filter: status-Mileage recorder,20, km
IDE13754-MAS16867,Diagnostic filter: status-Reason for deactivation,hood open,
IDE13754-MAS16875,Diagnostic filter: status-Filter status,Filter is not active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00030926*2026-09-01-00:06:46*1*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00030926*2026-09-01-00:03:43*1*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00030926*2026-09-01-00:00:00*1*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00030926*2026-09-01-20:10:37*1*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00030921*2026-09-01-20:00:12*1*,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13845,Production mode status,not active,
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,650, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,0,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,30.0, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,22.5, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,20.0, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,17.0, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,16.5, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.0, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,17.5, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,18.0, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,20.0, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,22.0, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,30.0, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,22.5, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,20.0, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,17.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,16.5, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,17.0, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,17.5, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.0, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,20.0, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,22.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,650, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,65532,
IDE14151-MAS17930,Route-based range calculation-Range from destination,65532,
IDE14151-MAS17931,Route-based range calculation-Route-based range,65532,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,no request,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,Malfunction,
IDE14260-MAS12984,12V lead battery test pulse: low-voltage energy management-Reason for rejection,0,
IDE14260-MAS21182,12V lead battery test pulse: low-voltage energy management-Bad counter,0,
IDE14260-MAS21183,12V lead battery test pulse: low-voltage energy management-Test pulse counter not OK,122,
IDE14260-MAS21184,12V lead battery test pulse: low-voltage energy management-Counter increase not OK,150,
IDE14260-ENG255502,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_request,3,
IDE14260-ENG255503,12V lead battery test pulse: low-voltage energy management-BZE_test_pulse_result,3,
IDE14265,Battery display: source of initiation,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 5F 32 40 07 55 73 C1,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2E,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15027-MAS21296,Low-voltage EM on middle-voltage EM signals-48V electrical system charging approval,No,
IDE15027-MAS21297,Low-voltage EM on middle-voltage EM signals-Low-voltage energy management status,not active,
IDE15027-MAS21328,Low-voltage EM on middle-voltage EM signals-Low-voltage EM request for lowering medium-voltage EM,No,
IDE15027-MAS21329,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,Yes,
IDE15027-MAS21330,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approval for increasing medium-voltage EM,No,
IDE15027-MAS21331,Low-voltage EM on middle-voltage EM signals-Low-voltage EM approved charge capacity for medium-voltage EM,0, W
IDE15101,Status of lithium-ion battery,OK,
IDE15854-MAS21195,Report system for deviations: blacklist data bus infotainment-CAN identifier invalid,00 00 00 00,
IDE15854-MAS21196,Report system for deviations: blacklist data bus infotainment-Event counter,0,
IDE15855-MAS21195,Report system for deviations: blacklist data bus drive-CAN identifier invalid,00 00 00 0F,
IDE15855-MAS21196,Report system for deviations: blacklist data bus drive-Event counter,2,
IDE15856-MAS21195,Report system for deviations: violation of time specifications-CAN identifier invalid,00 00 00 00,
IDE15856-MAS21196,Report system for deviations: violation of time specifications-Event counter,0,
IDE15857-MAS21195,Report system for deviations: violations during signal change-CAN identifier invalid,00 00 00 00,
IDE15857-MAS21196,Report system for deviations: violations during signal change-Event counter,0,
MAS00464-MAS00106,Standard - ambient data 1-Year,2019,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,3,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,2,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,17,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,30926, km
MAS00769-IDE02717,Multi-function steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multi-function steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multi-function steering wheel control module-MFL Variant code,10,
MAS00769-MAS01065,Multi-function steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multi-function steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multi-function steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multi-function steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multi-function steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multi-function steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multi-function steering wheel control module-MFL message counter,13,
MAS00769-MAS06030,Multi-function steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multi-function steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multi-function steering wheel control module-MFL M button,Not operated,
MAS02672-IDE03212,Start-stop-Start/stop conditions,Stop release,
MAS02672-IDE03213,Start-stop-Start/stop enable,All releases are present,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE07621,Start-stop-Permitted engine stop time,max.value,
MAS02672-IDE07622,Start-stop-Power consumption during idle phase,30, A
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS03023,Engine running status-Driving mode,not active,
MAS04447-MAS05129,Engine running status-Motor,Engine off,
MAS04447-MAS20972,Engine running status-Redundant supply target mode,not active,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 1D,Generator|00 37,Battery Monitoring Control Module|00 69,Inverter for socket|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 31,Multi-function steering wheel control module|01 3E,Steering Wheel Touch Recognition Control Module|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 72,Analog clock|01 2F,Control head driving profile|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|,
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1,SubSystem present Bit 2,SubSystem present Bit 3,SubSystem present Bit 4,SubSystem present Bit 5,SubSystem present Bit 6,SubSystem present Bit 7|reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|reachable,reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable,not reachable|,
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|81|0|0|0|0|0|82|82|0|0|0|0|0|0|83|83|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
MAS16744-IDE01836,12-volt battery-Battery current,0.000, A
MAS16744-IDE01837,12-volt battery-Temperature of battery sensor,0, C
MAS16744-IDE01838,12-volt battery-Battery temperature,-40, C
MAS16744-IDE01839,12-volt battery-Battery charge status,100, %
MAS16744-IDE01841,12-volt battery-Battery internal resistance,2.0, mOhm
MAS16744-IDE01842,12-volt battery-Usable battery charge,100, Ah
MAS16744-IDE01948,12-volt battery-Battery internal resistance not normed,2.0, mOhm
MAS16744-IDE04186,12-volt battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12-volt battery-adapted battery capacity,130, Ah
MAS16744-MAS00362,12-volt battery-Battery voltage,12.277, V
MAS16744-MAS06086,12-volt battery-Total re-charge,0.0, Ah
MAS16744-MAS06087,12-volt battery-Entire energy throughput,0.0, Ah
MAS16744-MAS22232,12-volt battery-Battery aging: charge-related,100, %
MAS16744-MAS22233,12-volt battery-Battery aging: performance-related,100, %
MAS16744,12-volt battery,---,
MAS16745-IDE01839,Quiescent current management-Battery charge status,140,
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,15.0, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,4094, mA
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07623,Quiescent current management-Open-circuit voltage gateway,invalid,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,0.000, A
MAS16745,Quiescent current management,Initialization,
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,Not available,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,invalid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 00 03 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,Available,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition not met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition not met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,19,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,00,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,Available,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,00 00 00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,61 B1 B4 14,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,5,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,1,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,14,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 09,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,83 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,3817,
ENG186123-ENG255560,Authentic_time_last_client_response-Current_time_ used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG254617-ENG299125,DoIP_Status-DoIP_Status_ECU,|Node_address,number_tcp_connections_ecu,DoIP_Status_TCP_Connections|03 01,00,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|14 00,not active,No,not active,00||34 58,02,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|00 00,not active,No,not active,00||01 00,67,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|34 00,not active,No,not active,00||58 02,00,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|01 00,not active,No,not active,00||00 73,34,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|58 00,not active,No,not active,00||02 00,00,|source_port,tcp_connection_established,vehicle_announcement_identification_response_received,routing_activation_status,RoutingActivation Response Code|00 00,not active,No,not active,00||,
ENG254617-ENG280661,DoIP_Status-number_of_total_ecu,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognised,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognised,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Terminal 15 on,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG254621-ENG255502,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_request,3,
ENG254621-ENG255503,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_result,3,
ENG254621-ENG255504,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-BZE_test_pulse_status,3,
ENG254621-ENG255545,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Consumer_test_pulse_request,0,
ENG254621-ENG255551,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_increase_not_ok,150,
ENG254621-ENG255553,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Counter_test_pulse_not_ok,122,
ENG254621-ENG255557,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_battery_BEM,0.000, A
ENG254621-ENG255558,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_DcDc_test_pulse_actual,0, A
ENG254621-ENG255559,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Current_test_pulse_target_value,0, A
ENG254621-ENG256044,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Max_current_last_start,1, A
ENG254621-ENG256064,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Min_voltage_last_start,14.65,
ENG254621-ENG256101,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV_EM_test_pulse_status,3,
ENG254621-ENG256097,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_enabled,3,
ENG254621-ENG256098,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_HV-EM_test_pulse_request,3,
ENG254621-ENG256099,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_enabled,0,
ENG254621-ENG256100,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-NV-EM_/_MV-EM_test_pulse_request,3,
ENG254621-ENG256270,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Reduction_internal_fan_by_request_test_pulse,0,
ENG254621-ENG256620,EMHLR_extended_measurement_value_12V_lead_battery_test_pulse-Voltage_battery_BEM,12.285, V
ENG254622-MAS21178,Energy_management_dashboard_display-Battery reports,0,
ENG254622-MAS21179,Energy_management_dashboard_display-Energy generator reports,1,
ENG254622-MAS21180,Energy_management_dashboard_display-Battery service,0,
ENG254622-MAS21181,Energy_management_dashboard_display-Vehicle system diagnostic,0,
ENG118782-ENG299130,Gateway app. software identification-Gateway_applikation_software_identifikation,|nf_name,SW_VERSION|routing_gateway,9073|fpa,1410|NVEM,7702|HID,0802|KS,----|eASS,3001|MFL,0204|sk1a,0100|rwb,F001|SWaP,0821|wum,0100|BCmE,1036|mke,3579|hv-em,2400|routing_gateway,|Ehr,2011|mvem,2301|Klr,----|routing_gateway,|vmks,1300|paco,0362|ids,3201|routing_gateway,|FoD,2007|sda,----|SOK-FM,1400|routing_gateway,|,
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,No enabling,
ENG254725-ENG256045,HV-EM_consumer_contingent-max_power_climate_aggregates,0, A
ENG254725-ENG152043,HV-EM_consumer_contingent-RWV_reduction_level,no request,
ENG254725-ENG255205,HV-EM_consumer_contingent-shutdown_request_low_voltage_systems,none,
ENG254727-ENG152029,HV-EM_energy_specification-High_voltage_battery_energy_information,102350,
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,102300, Wh
ENG254727-ENG152039,HV-EM_energy_specification-NV_energy_requirement,2550, W
ENG254728-ENG152030,HV-EM_high_voltage_activation-HV_system_error,No malfunction,
ENG254728-ENG152033,HV-EM_high_voltage_activation-HV-EM_HV_requirement,no request,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG152037,HV-EM_high_voltage_activation-HV-LM_HV_requirement,not_requested,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,0, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,0, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,OFF,
ENG254730-ENG152028,HV-EM_operation_limitation-High_voltage_battery_current_limitation,0, A
ENG254730-ENG255206,HV-EM_operation_limitation-High_voltge_battery_state_of_charge,127.0, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,No enabling,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,0, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG254743-ENG255799,Intrusion_detection_system_disable_time-ids_disable_timeslot,0, ms
ENG254777,Middle_voltage_energy_management_to_low_voltage_energy_management_function_support,Unknown (0),
ENG118666,MKE_HFC_filtrated,1.0,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60054,
ENG151185-ENG140446,MV-EM_48V_electrical_system_components-48V_Rsg_installed,not installed,
ENG151185-ENG140442,MV-EM_48V_electrical_system_components-DcDc_installed,not installed,
ENG151185-ENG140441,MV-EM_48V_electrical_system_components-LiIon_battery_installed,not installed,
ENG151185-ENG140440,MV-EM_48V_electrical_system_components-sCap_installed,not installed,
ENG151186-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_1-Measurement,not OK.,
ENG151186,MV-EM_48V_electrical_system_diagnosis_typ_1,---,
ENG151186-ENG140420,MV-EM_48V_electrical_system_diagnosis_typ_1-48V_electrical_system_diagnosis_request,not requested,
ENG151186-ENG140421,MV-EM_48V_electrical_system_diagnosis_typ_1-Bms_48V_actual_current,0, A
ENG151187-MAS01867,MV-EM_48V_electrical_system_diagnosis_typ_2-Measurement,not OK.,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,Initialization,
ENG151187,MV-EM_48V_electrical_system_diagnosis_typ_2,---,
ENG151187-ENG140423,MV-EM_48V_electrical_system_diagnosis_typ_2-48V_electrical_system_active,not active,
ENG151187-ENG140416,MV-EM_48V_electrical_system_diagnosis_typ_2-Bms_48V_actual_voltage,0.00, V
ENG151187-ENG140424,MV-EM_48V_electrical_system_diagnosis_typ_2-DcDc_48V_actual_voltage,63.50, V
ENG151187-ENG256301,MV-EM_48V_electrical_system_diagnosis_typ_2-Rsg_48V_actual_voltage,1023.50, mV
ENG151188-MAS01867,MV-EM_48V_overvoltage_check-Measurement,not OK.,
ENG151188,MV-EM_48V_overvoltage_check,---,
ENG151188-ENG140416,MV-EM_48V_overvoltage_check-Bms_48V_actual_voltage,0.00, V
ENG151188-ENG140417,MV-EM_48V_overvoltage_check-Bms_48V_Soc,0, %
ENG151189-MAS11874,MV-EM_48V_Zero_potential_status-Overall status,Initialization,
ENG151190-ENG140438,MV-EM_coldstart_requirement_engine-requirement_12V_start,not active,
ENG151190-ENG140439,MV-EM_coldstart_requirement_engine-requirement_48V_start,not active,
ENG151191,MV-EM_dc_current_Mv,0.0, A
ENG151192,MV-EM_dc_power_desired,0, W
ENG151193,MV-EM_DC_voltage_desired,0.00, V
ENG151194,MV-EM_dc_voltage_Mv,0.00, V
ENG151195-ENG140270,MV-EM_Derating_voltage-Derating_group_A,0.00, V
ENG151195-ENG140271,MV-EM_Derating_voltage-Derating_group_B,0.00, V
ENG151195-ENG140272,MV-EM_Derating_voltage-Derating_group_C,0.00, V
ENG151195-ENG140409,MV-EM_Derating_voltage-Derating_Umax_feedback,0.00, V
ENG151196,MV-EM_EMG_level_of_capacity,0.025, %
ENG151197,MV-EM_Mv_current,0, A
ENG151198-ENG140414,MV-EM_recommendation_Dcdc-Dcdc_boost_mode,active,
ENG151198-ENG140415,MV-EM_recommendation_Dcdc-Dcdc_buck_mode,not active,
ENG151199-ENG140410,MV-EM_release-12V_coldstart_release,No enabling,
ENG151199-ENG140411,MV-EM_release-12V_warmstart_release,No enabling,
ENG151199-ENG140412,MV-EM_release-48V_coldstart_release,No enabling,
ENG151199-ENG140413,MV-EM_release-start_stopp_support_release,No enabling,
ENG151200,MV-EM_RSG_maximal_current,0, A
ENG151201,MV-EM_RSG_maximal_voltage,0.00, V
ENG254783-ENG246261,NVEM_12V_Rekuperation-48V_emergency_run,0,
ENG254783-ENG274259,NVEM_12V_Rekuperation-Batterie_Ladezustand,0,
ENG254783-ENG274260,NVEM_12V_Rekuperation-Batterie_Regeneration,1,
ENG254783-ENG274261,NVEM_12V_Rekuperation-Batterie_Spannung,1,
ENG254783-ENG274262,NVEM_12V_Rekuperation-Batterie_Temperatur,0,
ENG254783-ENG255379,NVEM_12V_Rekuperation-Batteriealterung_Ladung,1,
ENG254783-ENG255380,NVEM_12V_Rekuperation-Batteriealterung_Leistung,1,
ENG254783-ENG255700,NVEM_12V_Rekuperation-Energienetz,1,
ENG254783-ENG255703,NVEM_12V_Rekuperation-Entnehmbare_Ladung,0,
ENG254783-ENG255737,NVEM_12V_Rekuperation-Freigabe_KFG,1,
ENG254783-ENG255738,NVEM_12V_Rekuperation-Freigabe_Klima,1,
ENG254783-ENG99756,NVEM_12V_Rekuperation-Generatordiagnose,1,
ENG254783-ENG100106,NVEM_12V_Rekuperation-Leerlaufanhebung,1,
ENG254783-ENG252593,NVEM_12V_Rekuperation-limited_by_48V_consumer,0,
ENG254783-ENG104009,NVEM_12V_Rekuperation-LIN-Kommunikation,0,
ENG254783-ENG256076,NVEM_12V_Rekuperation-Modus_Rekuperation_Motor,Neutral,
ENG254783-ENG256106,NVEM_12V_Rekuperation-opening_recuperation_by_BCM,Yes,
ENG254783-ENG255165,NVEM_12V_Rekuperation-Parallel Parking Assistance,0,
ENG254783-ENG256273,NVEM_12V_Rekuperation-Rekuperation_light,0,
ENG254783-ENG256306,NVEM_12V_Rekuperation-Saeureschichtung,0,
ENG254783-ENG101873,NVEM_12V_Rekuperation-Sonderveto,1,
ENG254783-ENG256364,NVEM_12V_Rekuperation-Spannungsanforderung_BCM,0,
ENG254783-ENG256365,NVEM_12V_Rekuperation-Spannungsanforderung_Bremse,0,
ENG254783-ENG256366,NVEM_12V_Rekuperation-Spannungsanforderung_KFG,0,
ENG254783-ENG256367,NVEM_12V_Rekuperation-Spannungsanforderung_Klima,0,
ENG254783-ENG256368,NVEM_12V_Rekuperation-Spannungsanforderung_Lenkung,0,
ENG254783-ENG256369,NVEM_12V_Rekuperation-Spannungsanforderung_Motor,0,
ENG254783-ENG256399,NVEM_12V_Rekuperation-Status_Rekuperation,not active,
ENG254783-ENG256400,NVEM_12V_Rekuperation-Status_Stromregelung,not active,
ENG254784-ENG255286,NVEM_Analoge_Batterieueberwachung-Aktuelle_Differenzspannung,0.000, V
ENG254784-ENG255298,NVEM_Analoge_Batterieueberwachung-Analoge_Batteriespannung,0.000, V
ENG254784-ENG255179,NVEM_Analoge_Batterieueberwachung-Difference limit voltage,0.00, V
ENG254784-ENG255754,NVEM_Analoge_Batterieueberwachung-Gefilterte_Batteriespannung,13.500, V
ENG254784-ENG256398,NVEM_Analoge_Batterieueberwachung-Status_internes_BatterieAb,connected,
ENG254784-ENG256720,NVEM_Analoge_Batterieueberwachung-Zaehler_BatterieAb,0,
ENG250370,NVEM_Grund_BEM_falsch_codiert,0,
ENG254786-ENG255308,NVEM_HLR_Kurzstreckenprofil-Anteil_Entladung_aktuelle Fahrt,0, %
ENG254786-ENG255209,NVEM_HLR_Kurzstreckenprofil-Number_of_short_tracks,0,
ENG254787-ENG255299,NVEM_HLR_Master-Anforderung_Leerlaufanhebung,no request,
ENG254787-ENG255300,NVEM_HLR_Master-Anforderung_Reduzierung_Innengeblaese,no request,
ENG254787-ENG255779,NVEM_HLR_Master-Heizleistungskontingent,1000, W
ENG254787-ENG255780,NVEM_HLR_Master-Heizleistungskontingent_Stufe,not active,
ENG254788-ENG255369,NVEM_Zustand_HLR-BA2_ZuendungEin,1,
ENG254788-ENG255370,NVEM_Zustand_HLR-BA3_ZuendungAus,0,
ENG254788-ENG256423,NVEM_Zustand_HLR-TabA_StartStopp,0,
ENG254788-ENG256424,NVEM_Zustand_HLR-TabB_Fahrtbetrieb,0,
ENG254788-ENG256425,NVEM_Zustand_HLR-TabD_Kurzzeitverbraucher,0,
ENG254788-ENG256426,NVEM_Zustand_HLR-TabE_Crash,0,
ENG254788-ENG256427,NVEM_Zustand_HLR-TabK_Kontingent_geregelt,0,
ENG254788-ENG256428,NVEM_Zustand_HLR-TabM_Leistungsgefuehrt_praediktiv,0,
ENG254788-ENG256429,NVEM_Zustand_HLR-TabNQ,0,
ENG280376,Reason_nvem_vehicle_electrical_system_state_diagnosis,0,
ENG280381-ENG280515,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_emergency_strategy,0,
ENG280381-ENG280516,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_failure_warning,not active,
ENG280381-ENG280517,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operating_quadrant,Standard mode,
ENG280381-ENG280518,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_operational_restriction,not active,
ENG280381-ENG280519,Status_12V_lithium_ion_starter_battery-12V_LiIon_starter_battery_service_information,OK,
Elapsed Time: 01:13
;SW:5WA-937-086-AE HW:5WA-937-086-L --- 09: Cent. Elect.
;Component:BCM37w_M028 0175, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_VW38.rod
;Tuesday,01,September,2026,18:59:17:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 147663D49EF722EA538-8040 SFD [x]
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG281100-Production mode-Remotestart_Pmode,not active ,3
IDE00301-Distance,0 km,4
IDE01550-Service position,163.802035 ,2
IDE02455-ENG116601-Light function "Coming/Leaving Home"-Coming Home Verbaustatus,automatic ,2
IDE02455-ENG260981-Light function "Coming/Leaving Home"-Darstellung Coming-home Verlauf,not active ,2
IDE02455-ENG261352-Light function "Coming/Leaving Home"-Darstellung Leaving-home Verlauf,not active ,2
IDE02455-ENG115657-Light function "Coming/Leaving Home"-Leaving-Home Verbausstatus,Enabled ,2
IDE02455-ENG115863-Light function "Coming/Leaving Home"-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,2
IDE02455-ENG116602-Light function "Coming/Leaving Home"-Menuesteuerung Coming Home Werkseinstellung,active ,2
IDE02455-ENG116606-Light function "Coming/Leaving Home"-Menuesteuerung Leaving-home Freischaltung per BAP,active ,2
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,2
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE03787-Activate left/right hand drive switch-over,Unknown (255),1
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,7
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,7
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beams ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,Main beam ,4
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,255 min,2
IDE07161-temporary VIN,Conditions not correct or request sequence error,2
IDE07356-Position during interval mode,20.010969 ,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,present ,9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmen ,not active ,9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverf gbarkeit ,7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten,klemmenabhaengig ,7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert,not active ,7
IDE09767-ENG126816-Position lamps-Standlicht aus,active ,7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht,not active ,7
IDE09767-ENG133383-Position lamps-Standlicht-Verf gbarkeit,24 s,7
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7
IDE10298-Alternating park position 1,0.010989 ,2
IDE10299-Alternating park position 2,22.010967 ,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE10844-Control module rear lid opening: duration status query,0 ms,2
IDE10845-Control module rear lid opening: vehicle type-,00 ,12
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,0 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schl sselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,0 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,0 km/h,12
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12
IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-Left taillight 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Power rear lid opening control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-Left taillight 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right taillight 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right taillight 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver's side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger's side,old ,6
IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6
IDE12489-Antenna 2 for short-range communication,No Response From Subnet Component,6
IDE13065-Left tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13066-Left tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13067-Right tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13068-Right tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf,0 ms,16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten,Low beams ,16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis,Ignition On ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,600 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,1200 lx,16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome,10 seconds ,16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag,10 seconds ,16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag,10 seconds ,16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO,not active ,16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO,not active ,16
IDE15901-Direct entry keys,installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,No ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,4
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,4
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,4
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,4
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,4
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,4
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,4
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,4
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,4
IDE80016-Analysis 16,No Response From Subnet Component,4
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,4
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,4
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,4
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,4
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,4
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,4
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,4
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,4
IDE80017-ENG289601-Analysis 17-Offset_PP1,No Response From Subnet Component,4
IDE80017-ENG289602-Analysis 17-Offset_PP2,No Response From Subnet Component,4
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,4
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,4
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,4
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,4
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,4
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,4
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,4
IDE80017-ENG289603-Analysis 17-Offset_T1,No Response From Subnet Component,4
IDE80017-ENG289604-Analysis 17-Offset_T2,No Response From Subnet Component,4
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,4
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,4
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,4
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,4
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,4
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,4
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,4
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,4
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,4
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,4
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,4
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,4
IDE80018-ENG289601-Analysis 18-Offset_PP1,No Response From Subnet Component,4
IDE80018-ENG289602-Analysis 18-Offset_PP2,No Response From Subnet Component,4
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,4
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,4
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,4
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,4
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,4
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,4
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,4
IDE80018-ENG289603-Analysis 18-Offset_T1,No Response From Subnet Component,4
IDE80018-ENG289604-Analysis 18-Offset_T2,No Response From Subnet Component,4
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,4
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,4
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,4
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,4
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,4
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,4
MAS05055-lower turn position,24.010965 ,2
MAS05056-upper turn position,163.802035 ,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),OFF ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),On ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),OFF ,3
MAS05807-ENG264071-Coding-APS f r 100 Zyklen deaktiv (1bit),On ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),On ,3
MAS05807-ENG264178-Coding-ger usch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus m glich (1bit),On ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung ber Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsr ckschaltung (1bit),OFF ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),OFF ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tr nenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abh ngige Wischstufenr ckschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),OFF ,3
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,0 ms,4
MAS07146-MAS13125-Button 1-Function of button 1,not coded / not installed ,1
MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1
MAS07147-MAS13129-Button 2-Function of button 2,not coded / not installed ,1
MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1
MAS07148-MAS13132-Button 3-Function of button 3,not coded / not installed ,1
MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8
MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,active ,8
MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8
MAS09325-ENG142193-Daytime running lights-Geschwindigkeitsabhaengiges TFL,0 km/h,8
MAS09325-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,8
MAS09325-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,8
MAS09325-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,8
MAS09325-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,8
MAS09325-ENG142192-Daytime running lights-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,8
MAS09325-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbest tugung,active ,8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links,active ,8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts,active ,8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken,not active ,8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2,active ,8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links,active ,8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts,active ,8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links,active ,8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts,active ,8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS,active ,8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN,active ,8
MAS13139-MAS13135-Button 4-Function of button 4,not coded / not installed ,1
MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,No Response From Subnet Component,1
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,No Response From Subnet Component,1
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,No Response From Subnet Component,1
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,No Response From Subnet Component,1
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,No Response From Subnet Component,1
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,No Response From Subnet Component,1
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,No Response From Subnet Component,1
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,No Response From Subnet Component,1
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,No Response From Subnet Component,1
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,No Response From Subnet Component,1
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,No Response From Subnet Component,1
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,No Response From Subnet Component,1
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,No Response From Subnet Component,1
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,No Response From Subnet Component,1
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,No Response From Subnet Component,1
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,No Response From Subnet Component,1
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,No Response From Subnet Component,1
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,No Response From Subnet Component,1
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,No Response From Subnet Component,1
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,No Response From Subnet Component,1
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,No Response From Subnet Component,1
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,No Response From Subnet Component,1
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,No Response From Subnet Component,1
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,No Response From Subnet Component,1
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,No Response From Subnet Component,1
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,No Response From Subnet Component,1
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,No Response From Subnet Component,1
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,No Response From Subnet Component,1
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,No Response From Subnet Component,1
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,No Response From Subnet Component,1
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,No Response From Subnet Component,1
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,No Response From Subnet Component,1
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,No Response From Subnet Component,1
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,No Response From Subnet Component,1
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,No Response From Subnet Component,1
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,No Response From Subnet Component,1
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,No Response From Subnet Component,1
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,No Response From Subnet Component,1
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,No Response From Subnet Component,1
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,No Response From Subnet Component,1
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,No Response From Subnet Component,1
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,No Response From Subnet Component,1
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,No Response From Subnet Component,1
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,No Response From Subnet Component,1
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,No Response From Subnet Component,1
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,No Response From Subnet Component,1
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,No Response From Subnet Component,1
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,No Response From Subnet Component,1
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,No Response From Subnet Component,1
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,No Response From Subnet Component,1
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,No Response From Subnet Component,1
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,No Response From Subnet Component,1
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,No Response From Subnet Component,1
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,No Response From Subnet Component,1
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,No Response From Subnet Component,1
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,No Response From Subnet Component,1
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,No Response From Subnet Component,1
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,No Response From Subnet Component,1
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,No Response From Subnet Component,1
MAS14140-IDE15905-Flashing function-Travel Assist,not active ,4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken_Bremsblinken ,4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz,active ,4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz,active ,4
MAS18831-IDE80001-Control module for optical rear lid opening: dataset-Analysis 1,No Response From Subnet Component,4
MAS18831-IDE80002-Control module for optical rear lid opening: dataset-Analysis 2,No Response From Subnet Component,4
MAS18831-IDE80003-Control module for optical rear lid opening: dataset-Analysis 3,No Response From Subnet Component,4
MAS18831-IDE80004-Control module for optical rear lid opening: dataset-Analysis 4,No Response From Subnet Component,4
MAS18831-IDE80005-Control module for optical rear lid opening: dataset-Analysis 5,No Response From Subnet Component,4
MAS18831-IDE80006-Control module for optical rear lid opening: dataset-Analysis 6,No Response From Subnet Component,4
MAS18831-IDE80007-Control module for optical rear lid opening: dataset-Analysis 7,No Response From Subnet Component,4
MAS18831-IDE80008-Control module for optical rear lid opening: dataset-Analysis 8,No Response From Subnet Component,4
MAS18831-IDE80009-Control module for optical rear lid opening: dataset-Analysis 9,No Response From Subnet Component,4
MAS18831-IDE80010-Control module for optical rear lid opening: dataset-Analysis 10,No Response From Subnet Component,4
MAS18831-IDE80011-Control module for optical rear lid opening: dataset-Analysis 11,No Response From Subnet Component,4
MAS18831-IDE80012-Control module for optical rear lid opening: dataset-Analysis 12,No Response From Subnet Component,4
MAS18831-IDE80013-Control module for optical rear lid opening: dataset-Analysis 13,No Response From Subnet Component,4
MAS18831-IDE80014-Control module for optical rear lid opening: dataset-Analysis 14,No Response From Subnet Component,4
MAS18831-IDE80015-Control module for optical rear lid opening: dataset-Analysis 15,No Response From Subnet Component,4
MAS18831-IDE80016-Control module for optical rear lid opening: dataset-Analysis 16,No Response From Subnet Component,4
MAS18831-IDE80017-Control module for optical rear lid opening: dataset-Analysis 17,No Response From Subnet Component,4
MAS18831-IDE80018-Control module for optical rear lid opening: dataset-Analysis 18,No Response From Subnet Component,4
MAS18831-IDE80019-Control module for optical rear lid opening: dataset-Analysis 19,No Response From Subnet Component,4
MAS18831-IDE80020-Control module for optical rear lid opening: dataset-Analysis 20,No Response From Subnet Component,4
MAS18831-IDE80021-Control module for optical rear lid opening: dataset-Analysis 21,No Response From Subnet Component,4
MAS18831-IDE80022-Control module for optical rear lid opening: dataset-Analysis 22,No Response From Subnet Component,4
MAS18831-IDE80023-Control module for optical rear lid opening: dataset-Analysis 23,No Response From Subnet Component,4
MAS18831-IDE80024-Control module for optical rear lid opening: dataset-Analysis 24,No Response From Subnet Component,4
MAS18831-IDE80025-Control module for optical rear lid opening: dataset-Analysis 25,No Response From Subnet Component,4
MAS18831-IDE80026-Control module for optical rear lid opening: dataset-Analysis 26,No Response From Subnet Component,4
MAS18831-IDE80027-Control module for optical rear lid opening: dataset-Analysis 27,No Response From Subnet Component,4
MAS18831-IDE80028-Control module for optical rear lid opening: dataset-Analysis 28,No Response From Subnet Component,4
MAS18831-IDE80029-Control module for optical rear lid opening: dataset-Analysis 29,No Response From Subnet Component,4
MAS18831-IDE80030-Control module for optical rear lid opening: dataset-Analysis 30,No Response From Subnet Component,4
MAS18831-IDE80031-Control module for optical rear lid opening: dataset-Analysis 31,No Response From Subnet Component,4
MAS18831-IDE80032-Control module for optical rear lid opening: dataset-Analysis 32,No Response From Subnet Component,4
MAS18831-IDE80033-Control module for optical rear lid opening: dataset-Analysis 33,No Response From Subnet Component,4
MAS18831-IDE80034-Control module for optical rear lid opening: dataset-Analysis 34,No Response From Subnet Component,4
MAS18831-IDE80035-Control module for optical rear lid opening: dataset-Analysis 35,No Response From Subnet Component,4
MAS18831-IDE80036-Control module for optical rear lid opening: dataset-Analysis 36,No Response From Subnet Component,4
MAS18831-IDE80037-Control module for optical rear lid opening: dataset-Analysis 37,No Response From Subnet Component,4
MAS18831-IDE80038-Control module for optical rear lid opening: dataset-Analysis 38,No Response From Subnet Component,4
MAS18831-IDE80039-Control module for optical rear lid opening: dataset-Analysis 39,No Response From Subnet Component,4
MAS18831-IDE80040-Control module for optical rear lid opening: dataset-Analysis 40,No Response From Subnet Component,4
MAS18831-IDE80041-Control module for optical rear lid opening: dataset-Analysis 41,No Response From Subnet Component,4
MAS18831-IDE80042-Control module for optical rear lid opening: dataset-Analysis 42,No Response From Subnet Component,4
MAS18831-IDE80043-Control module for optical rear lid opening: dataset-Analysis 43,No Response From Subnet Component,4
MAS18831-IDE80044-Control module for optical rear lid opening: dataset-Analysis 44,No Response From Subnet Component,4
MAS18831-IDE80045-Control module for optical rear lid opening: dataset-Analysis 45,No Response From Subnet Component,4
MAS18831-IDE80046-Control module for optical rear lid opening: dataset-Analysis 46,No Response From Subnet Component,4
MAS18831-IDE80047-Control module for optical rear lid opening: dataset-Analysis 47,No Response From Subnet Component,4
MAS18831-IDE80048-Control module for optical rear lid opening: dataset-Analysis 48,No Response From Subnet Component,4
MAS18831-IDE80049-Control module for optical rear lid opening: dataset-Analysis 49,No Response From Subnet Component,4
MAS18831-IDE80050-Control module for optical rear lid opening: dataset-Analysis 50,No Response From Subnet Component,4
MAS18831-IDE80051-Control module for optical rear lid opening: dataset-Analysis 51,No Response From Subnet Component,4
MAS18831-IDE80052-Control module for optical rear lid opening: dataset-Analysis 52,No Response From Subnet Component,4
MAS18831-IDE80053-Control module for optical rear lid opening: dataset-Analysis 53,No Response From Subnet Component,4
MAS18831-IDE80054-Control module for optical rear lid opening: dataset-Analysis 54,No Response From Subnet Component,4
MAS18831-IDE80055-Control module for optical rear lid opening: dataset-Analysis 55,No Response From Subnet Component,4
MAS18831-IDE80056-Control module for optical rear lid opening: dataset-Analysis 56,No Response From Subnet Component,4
MAS18831-IDE80057-Control module for optical rear lid opening: dataset-Analysis 57,No Response From Subnet Component,4
MAS18831-IDE80058-Control module for optical rear lid opening: dataset-Analysis 58,No Response From Subnet Component,4
MAS18831-IDE80059-Control module for optical rear lid opening: dataset-Analysis 59,No Response From Subnet Component,4
MAS18831-IDE80060-Control module for optical rear lid opening: dataset-Analysis 60,No Response From Subnet Component,4
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,10 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,119 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,2055 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,24.2 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR,00 ,270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG,00 ,270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit,0 ms,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,not active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,600.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Pr fung,active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,Yes ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,limited ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,not activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,not activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,not activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verz gerungs_zeit,60 s,8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P,Alle Fahrstufen ,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer f r Ausf hrung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verf gbarkeit Komfortabschaltung,Available ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Z ndungsabschaltung ber Energiemanagement,Available ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG253018-Clamp_Control,Driver s door ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,100 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,200 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,100 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,100 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253350-ENG258402-Coding_seat_pneumatics_driver_side-Function_easy_entry,No Response From Subnet Component,40
ENG253350-ENG260372-Coding_seat_pneumatics_driver_side-Function_massage,No Response From Subnet Component,40
ENG253350-ENG260893-Coding_seat_pneumatics_driver_side-Function_memory,No Response From Subnet Component,40
ENG253350-ENG261225-Coding_seat_pneumatics_driver_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253350-ENG259055-Coding_seat_pneumatics_driver_side-Function_off_delay,No Response From Subnet Component,40
ENG253350-ENG259290-Coding_seat_pneumatics_driver_side-Function_personalisation,No Response From Subnet Component,40
ENG253350-ENG259372-Coding_seat_pneumatics_driver_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253350-ENG259654-Coding_seat_pneumatics_driver_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253350-ENG259159-Coding_seat_pneumatics_driver_side-Function_race_mode,No Response From Subnet Component,40
ENG253350-ENG261329-Coding_seat_pneumatics_driver_side-Function_side_support,No Response From Subnet Component,40
ENG253350-ENG258695-Coding_seat_pneumatics_driver_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253175-ENG258402-Coding_seat_pneumatics_passenger_side-Function_easy_entry,No Response From Subnet Component,40
ENG253175-ENG260372-Coding_seat_pneumatics_passenger_side-Function_massage,No Response From Subnet Component,40
ENG253175-ENG260893-Coding_seat_pneumatics_passenger_side-Function_memory,No Response From Subnet Component,40
ENG253175-ENG261225-Coding_seat_pneumatics_passenger_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253175-ENG259055-Coding_seat_pneumatics_passenger_side-Function_off_delay,No Response From Subnet Component,40
ENG253175-ENG259290-Coding_seat_pneumatics_passenger_side-Function_personalisation,No Response From Subnet Component,40
ENG253175-ENG259372-Coding_seat_pneumatics_passenger_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253175-ENG259654-Coding_seat_pneumatics_passenger_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253175-ENG259159-Coding_seat_pneumatics_passenger_side-Function_race_mode,No Response From Subnet Component,40
ENG253175-ENG261329-Coding_seat_pneumatics_passenger_side-Function_side_support,No Response From Subnet Component,40
ENG253175-ENG258695-Coding_seat_pneumatics_passenger_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253229-ENG258467-Define_Const-Dimm2Bin,1 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv,activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,not activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,not activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,not activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,not activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,not activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering assignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schlie verhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,not activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,not activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,not activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,not activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebet r,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-Diebstahlschutz.Modulsoftware-,not active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,10_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,21
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,21
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,21
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,21
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,21
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,21
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,21
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,21
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,21
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,21
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,21
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,21
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,21
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,21
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,21
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,21
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,21
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,21
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,21
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,21
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,21
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,21
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,21
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,21
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,21
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,21
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,21
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,21
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,21
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,21
ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,21
ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,21
ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,21
ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,21
ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,21
ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,21
ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,21
ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,21
ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,21
ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,21
ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,21
ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,21
ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,21
ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,21
ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,21
ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,21
ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,21
ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,21
ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,21
ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,21
ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,21
ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,21
ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,21
ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,21
ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,21
ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,21
ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,21
ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,21
ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,21
ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,21
ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,21
ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,21
ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,21
ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,21
ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,21
ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,21
ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,21
ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,21
ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,21
ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,21
ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,21
ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,21
ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,21
ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,21
ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,21
ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,21
ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,21
ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,21
ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,21
ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,21
ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,21
ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,21
ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,21
ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,21
ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,21
ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,21
ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,21
ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,21
ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,21
ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,21
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,21
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,21
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,21
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,21
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,21
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,21
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,21
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,21
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,21
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,21
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,21
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,21
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,21
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,21
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,21
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,21
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,21
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,21
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,21
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,21
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,21
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,21
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,21
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,21
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,21
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,21
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,21
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,21
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,21
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,21
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,21
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,21
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,21
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,21
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,21
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,21
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,21
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,21
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,21
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,21
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,21
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,21
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,21
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,21
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,21
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,21
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,21
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,21
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,21
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,21
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,21
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,21
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,21
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,21
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,21
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,21
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,21
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,21
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21
ENG253243-ENG286261-Easy Open-p_a_Schiebet rentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,not active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,not active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebet ren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebet ren_Aktiv_Kl_S,not active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebet ren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,15 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,50 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,00 00 ,2
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not available ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,Not available ,6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,LIN ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Keine_Spannungsanforderung ,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,immer Wischerstopp ,6
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,40 ,2
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,Always ,8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,not installed ,8
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,not installed ,8
ENG253080-IAA Nutzermanagement,installed ,1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,not activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area,active ,23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area,active ,23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung,0.00 m,23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung,0.00 m,23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung,active ,23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer,10 ms,23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle,-16.00000 m/s ,23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch,not active ,23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv,not active ,23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv,not active ,23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv,not active ,23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel,4000 lx,23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch,50000 lx,23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto,not active ,23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus,0 ,23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein,0 ,23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch,not active ,23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung,20 km/h,23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung,10 km/h,23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus,60 km/h,23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein,75 km/h,23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4
ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-Left taillight 1,not installed ,4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-Left taillight 2,not installed ,4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right taillight 1,not installed ,4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right taillight 2,not installed ,4
ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,not active ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,02 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,11 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,11 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,100 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,50 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,50 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,50 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,50 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,50 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,50 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,01 ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,00 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,01 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,00 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,00 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,00 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,00 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,00 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,00 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,00 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,00 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,00 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,01 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,00 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,00 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,00 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,00 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,00 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,00 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,00 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,00 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,00 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,00 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,01 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,00 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,00 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,00 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,00 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,00 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,00 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,00 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,00 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,00 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,00 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,00 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,00 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,00 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,00 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,00 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,00 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,00 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,00 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,00 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,00 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,01 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,00 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,00 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,00 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,00 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,00 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,00 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,00 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,00 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,00 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,00 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,00 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,00 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,00 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,00 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,00 ,96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,not active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,not active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,not active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 1C 00 00 00 00 60 00 00 00 10 00 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 1C 70 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,64 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,00 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,03 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,00 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,02 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,00 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,03 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,02 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,03 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,00 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,02 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,00 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,02 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,03 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,03 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,00 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,03 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,00 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,03 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,03 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,00 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,00 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,00 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,00 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,00 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,00 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,00 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,5 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,01 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,13 ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,07 ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,15 ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,05 ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1,00 ,51
ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10,00 ,51
ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11,8A ,51
ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12,8C ,51
ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13,00 ,51
ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14,00 ,51
ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15,00 ,51
ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2,00 ,51
ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3,1F ,51
ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4,29 ,51
ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5,00 ,51
ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6,00 ,51
ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7,00 ,51
ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8,4D ,51
ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9,57 ,51
ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1,00 ,51
ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10,00 ,51
ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11,89 ,51
ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12,8B ,51
ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13,00 ,51
ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14,00 ,51
ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15,00 ,51
ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2,00 ,51
ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3,08 ,51
ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4,12 ,51
ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5,00 ,51
ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6,00 ,51
ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7,00 ,51
ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8,36 ,51
ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9,40 ,51
ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1,00 ,51
ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10,00 ,51
ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11,00 ,51
ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12,00 ,51
ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13,00 ,51
ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14,00 ,51
ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15,00 ,51
ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2,6D ,51
ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3,6E ,51
ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4,00 ,51
ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5,00 ,51
ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6,79 ,51
ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7,00 ,51
ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8,00 ,51
ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9,00 ,51
ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1,Offset_0 ,51
ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10,Offset_0 ,51
ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11,Offset_0 ,51
ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12,Offset_0 ,51
ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13,Offset_0 ,51
ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14,Offset_0 ,51
ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15,Offset_0 ,51
ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2,Offset_0 ,51
ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3,Offset_0 ,51
ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4,Offset_0 ,51
ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5,Offset_0 ,51
ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6,Offset_0 ,51
ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7,Offset_0 ,51
ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8,Offset_0 ,51
ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9,Offset_0 ,51
ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1,Offset_0 ,51
ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10,Offset_0 ,51
ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11,Offset_0 ,51
ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12,Offset_0 ,51
ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13,Offset_0 ,51
ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14,Offset_0 ,51
ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15,Offset_0 ,51
ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2,Offset_0 ,51
ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3,Offset_0 ,51
ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4,Offset_0 ,51
ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5,Offset_0 ,51
ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6,Offset_0 ,51
ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7,Offset_0 ,51
ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8,Offset_0 ,51
ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9,Offset_0 ,51
ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1,Offset_0 ,51
ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10,Offset_0 ,51
ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11,Offset_0 ,51
ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12,Offset_0 ,51
ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13,Offset_0 ,51
ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14,Offset_0 ,51
ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15,Offset_0 ,51
ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2,Offset_0 ,51
ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3,Offset_0 ,51
ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4,Offset_0 ,51
ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5,Offset_0 ,51
ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6,Offset_0 ,51
ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7,Offset_0 ,51
ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8,Offset_0 ,51
ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9,Offset_0 ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,00 ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,04 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,05 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,09 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,0A ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,19 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,1A ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,04 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,05 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,07 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,08 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,00 ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,17 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,18 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,0D ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,0E ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,12 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,FF ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,FF ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,FF ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,FF ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,FF ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,FF ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,00 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,00 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93
ENG276127-Interior_Monitoring_Data_Set2,No Response From Subnet Component,93
ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock,10_ms ,4
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG248300-Kessyfunktion-reunlock_beep,not active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG172886-MAS10514-lcm-Expanded high beam control,High beam assistant ,4
ENG172886-ENG142185-lcm-LCM_blinker,true ,4
ENG172886-ENG142034-lcm-Light_Control_Module,direkt verbaut ,4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,100 ,20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,14 ,20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,34 ,20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,Blinkleuchten ,20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,Blinken links Hellphase ,20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,100 ,20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,15 ,20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,3E ,20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,Blinkleuchten ,20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,Blinken rechts Hellphase ,20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,00 ,20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,00 ,20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,127 ,20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,38 ,20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,Nebellicht links ,20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,not active ,20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,127 ,20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,42 ,20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,Nebellicht rechts ,20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,not active ,20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,0 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,00 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,00 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,not_active ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,not active ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,0 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,00 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,00 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,not_active ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,not active ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,minimize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,127 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,127 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,08 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,Quittierungsfunktion1 ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,Blinken links aktiv ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,Blinken links Hellphase ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,minimize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,127 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,127 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,18 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,18 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,Quittierungsfunktion1 ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,Blinken rechts aktiv ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,Blinken rechts Hellphase ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,minimize ,20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,127 ,20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,0 ,20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,31 ,20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,0B ,20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,Rueckfahrlicht ,20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,not active ,20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,not active ,20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,minimize ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,maximize ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,127 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,0 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,09 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,LED_Bremsleuchten ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Brake lamp ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,Blinken links aktiv ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,minimize ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,maximize ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,127 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,0 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,19 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,LED_Bremsleuchten ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Brake lamp ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,Blinken rechts aktiv ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,29 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,maximize ,20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,127 ,20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,29 ,20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,0A ,20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,Position lamps ,20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,Parking light left ,20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,not active ,20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,maximize ,20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,127 ,20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,1A ,20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,Position lamps ,20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,Parking light right ,20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,not active ,20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,0 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,28 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,not active ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,0 ,20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,00 ,20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,not_active ,20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,not active ,20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,00 ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,127 ,20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,35 ,20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,0A ,20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,Position lamps ,20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,Parking light left ,20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,127 ,20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,36 ,20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,1A ,20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Position lamps ,20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,Parking light right ,20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,minimize ,20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,127 ,20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,0 ,20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,32 ,20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,1B ,20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,Rueckfahrlicht ,20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,not active ,20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,not active ,20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,100 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,00 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,Footwell lamp ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,0 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,00 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,not_active ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,not active ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,00 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,00 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,00 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,100 ,20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,0 ,20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,00 ,20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,00 ,20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,00 ,20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,00 ,20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,00 ,20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,00 ,20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,00 ,20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,00 ,20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,00 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,00 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,0 ,20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,0 ,20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,00 ,20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,00 ,20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,not_active ,20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,not active ,20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,not active ,20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,not active ,20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,not active ,20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,not active ,20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,00 ,20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,00 ,20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,00 ,20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,00 ,20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,00 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,00 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,00 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,00 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,85 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,00 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,aktiv100prozent ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,89 ,20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,00 ,20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,0 ,20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,0 ,20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,00 ,20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,00 ,20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,not_active ,20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,not active ,20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,not active ,20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,not active ,20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,not active ,20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,not active ,20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,0 ,20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,00 ,20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,00 ,20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,not_active ,20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,not active ,20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,not active ,20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,not active ,20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,maximize ,20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,0 ,20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,00 ,20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,00 ,20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,not_active ,20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,not active ,20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,not active ,20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,not active ,20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,0 ,20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,00 ,20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,not_active ,20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,not active ,20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,not active ,20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,0 ,20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,00 ,20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,not_active ,20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,not active ,20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,not active ,20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20
ENG253237-IDE03311-Licht Konfig-Abh ngig-Emergency braking display,not active ,4
ENG253237-IDE07470-Licht Konfig-Abh ngig-After-run for park light,No_sidelights_delay ,4
ENG253237-ENG142020-Licht Konfig-Abh ngig-All-weather light,not installed ,4
ENG253237-ENG258575-Licht Konfig-Abh ngig-Diskrete_SBBR_links,installed ,4
ENG253237-ENG259588-Licht Konfig-Abh ngig-Diskrete_SBBR_rechts,installed ,4
ENG253237-ENG142191-Licht Konfig-Abh ngig-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,4
ENG253237-ENG142190-Licht Konfig-Abh ngig-Signaturlicht_verbaut,not installed ,4
ENG253374-ENG246963-Licht_bedienung-Anzeigezeit_LTM_PopUp1,4.0 s,12
ENG253374-ENG246964-Licht_bedienung-Anzeigezeit_LTM_PopUp1_lang,4 s,12
ENG253374-ENG246965-Licht_bedienung-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
ENG253374-ENG246966-Licht_bedienung-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
ENG253374-ENG246978-Licht_bedienung-Licht_anforderung_FAS,not installed ,12
ENG253374-ENG246979-Licht_bedienung-Licht_anforderung_Pilopark,not active ,12
ENG253374-ENG246980-Licht_bedienung-Licht_Reaktivierungs_grenze,95 m,12
ENG253374-ENG246981-Licht_bedienung-Lichttastermodul,LTM_Zentraltaste ,12
ENG253374-ENG246982-Licht_bedienung-LTM_Anzeige_Config,02 ,12
ENG253374-ENG246983-Licht_bedienung-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
ENG253374-ENG246984-Licht_bedienung-LTM_BGL_Geschwindigkeitsabh ngig,active ,12
ENG253374-ENG246985-Licht_bedienung-LTM_BGL_Geschwindigkeitsabh ngig_Parameter,active ,12
ENG253374-ENG246986-Licht_bedienung-LTM_BGL_Wegabh ngig,active ,12
ENG253374-ENG246987-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabh ngig,active ,12
ENG253374-ENG246988-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabh ngig_Parameter,active ,12
ENG253374-ENG246989-Licht_bedienung-LTM_GlobalOFF_Wegabh ngig,active ,12
ENG253374-ENG246990-Licht_bedienung-LTM_GlobalOFF_Z ndungsabh ngig,not active ,12
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,INDIVIDUAL ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,installed ,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,not active ,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Rocker sw. ,2
ENG253158-LWR Basissoftware,15 %,16
ENG253042-IDE03638-LWR Konfiguration-Static cornering light,Deactivated ,8
ENG253042-IDE03644-LWR Konfiguration-Highway light,not activated ,8
ENG253042-MAS02922-LWR Konfiguration-City light,not activated ,8
ENG253042-MAS07013-LWR Konfiguration-All-weather light,not activated ,8
ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Mehrlenkerhinterachse Frontantrieb ,8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,activated ,8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,activated ,8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,CAN HMI ,8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,2_sensors ,8
ENG253042-ENG171501-LWR Konfiguration-Market,NAR ,8
ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8
ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value,BCM ,8
ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8
ENG253084-MDK,00 ,4
ENG249798-MDK_coding-,00 ,8
ENG249798-ENG253476-MDK_coding-MDK_bBtle_COV,00 ,8
ENG249798-ENG253477-MDK_coding-MDK_bExtendedScActivation_COV,00 ,8
ENG253387-mdk_locking_coding,not installed ,3
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG122979-ENG141953-Networking-Getriebesteuergeraet,Monostable selector lever ,8
ENG153902-NFC_FS_debug_switch,No Response From Subnet Component,8
ENG153904-NFC_MiKo_debug_switch,No Response From Subnet Component,8
ENG253222-NFC_MiKo_WLC_Functions-,No Response From Subnet Component,8
ENG253222-ENG253104-NFC_MiKo_WLC_Functions-NFC_MiKo_Attenuation_internal_BTLE_antenna,No Response From Subnet Component,8
ENG124714-ENG142044-OCU-DWA_push,active ,10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10
ENG124714-OCU-,installed ,10
ENG124714-ENG259569-OCU-Remote HuF,active ,10
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausf hrungsdauer,30 s,10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,10
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,50 dB,27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,2 s,27
ENG253220-Par_Bedienstellen,2 ,7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,255 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschlie en,3200 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,345 cm,20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 ,20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,18
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,18
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125667-Passenger_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125666-Passenger_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125668-Passenger_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125673-Passenger_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125672-Passenger_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125674-Passenger_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125670-Passenger_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125669-Passenger_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125671-Passenger_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125676-Passenger_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125675-Passenger_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125677-Passenger_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125664-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125663-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125665-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125667-Passenger_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125666-Passenger_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125668-Passenger_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125673-Passenger_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125672-Passenger_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125674-Passenger_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125670-Passenger_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125669-Passenger_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125671-Passenger_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125676-Passenger_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125675-Passenger_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125677-Passenger_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125664-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125663-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125665-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125667-Passenger_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125666-Passenger_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125668-Passenger_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125673-Passenger_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125672-Passenger_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125674-Passenger_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125670-Passenger_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125669-Passenger_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125671-Passenger_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125676-Passenger_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125675-Passenger_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125677-Passenger_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125664-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125663-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125665-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,18
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,18
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,18
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,18
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,18
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,18
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,18
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,18
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,18
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,18
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,18
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,18
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,18
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,18
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,18
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,18
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,18
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,18
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,18
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,18
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,18
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,18
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,18
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,18
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,18
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,18
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,18
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,18
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,18
ENG286146-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,18
ENG286146-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,18
ENG286146-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,18
ENG286146-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,18
ENG286146-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,18
ENG286146-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,18
ENG286146-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,18
ENG286146-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,18
ENG286146-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,18
ENG286146-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,18
ENG286146-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,18
ENG286146-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,18
ENG286146-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,18
ENG286146-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,18
ENG286146-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,18
ENG286146-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,18
ENG286146-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,18
ENG286146-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,18
ENG286146-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,18
ENG286146-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,18
ENG286146-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,18
ENG286146-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,18
ENG286146-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,18
ENG286146-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,18
ENG286146-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,18
ENG286146-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,18
ENG286146-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,18
ENG286146-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,18
ENG286146-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,18
ENG286146-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,18
ENG286146-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,18
ENG286146-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,18
ENG286146-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,18
ENG286146-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,18
ENG286146-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,18
ENG286146-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,18
ENG286146-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,18
ENG286146-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,18
ENG286146-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,18
ENG286146-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,18
ENG286146-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,18
ENG286146-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,18
ENG286146-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,18
ENG286146-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,18
ENG286146-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,18
ENG286146-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,18
ENG286146-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,18
ENG286146-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,18
ENG286146-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,18
ENG286146-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,18
ENG286146-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,18
ENG286146-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,18
ENG286146-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,18
ENG286146-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,18
ENG286146-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,18
ENG286146-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,18
ENG286146-IDE80057-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,18
ENG286146-IDE80058-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,18
ENG286146-IDE80059-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,18
ENG286146-IDE80060-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,18
ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,18
ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,18
ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,18
ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,18
ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,18
ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,18
ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,18
ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,18
ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,18
ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,18
ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,18
ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,18
ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,18
ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,18
ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,18
ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,18
ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,18
ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,18
ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,18
ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,18
ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,18
ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,18
ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,18
ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,18
ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,18
ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,18
ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,18
ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,18
ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,18
ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,18
ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,18
ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,18
ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,18
ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,18
ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,18
ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,18
ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,18
ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,18
ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,18
ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,18
ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,18
ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,18
ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,18
ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,18
ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,18
ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,18
ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,18
ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,18
ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,18
ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,18
ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,18
ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,18
ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,18
ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,18
ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,18
ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,18
ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,18
ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,18
ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,18
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,not activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,not activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,not activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,not activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,not activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,not activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,not activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,not activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,not activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,not activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12
ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12
ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12
ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12
ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,Customization coded 2.x ,12
ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12
ENG253109-PSI5 Konfiguration,02 ,16
ENG253310-PSI5 Sensoren,not installed ,1
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,8
ENG141646-ENG281077-Querschnitts_funktionen-SubCAN weckt nur den BusMaster,not active ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG244881-ENG286173-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286174-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286175-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286176-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286177-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286178-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286179-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286180-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange[0],No Response From Subnet Component,8
ENG244881-ENG286181-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange[1],No Response From Subnet Component,8
ENG244881-ENG286182-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange[0],No Response From Subnet Component,8
ENG244881-ENG286183-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange[1],No Response From Subnet Component,8
ENG244881-ENG286184-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation[0],No Response From Subnet Component,8
ENG244881-ENG286185-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation[1],No Response From Subnet Component,8
ENG244881-ENG289577-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289578-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286188-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289579-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289580-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289581-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289582-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289583-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289584-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286195-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286196-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286197-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange[0],No Response From Subnet Component,8
ENG244881-ENG286198-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange[1],No Response From Subnet Component,8
ENG244881-ENG286199-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286200-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286201-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange[0],No Response From Subnet Component,8
ENG244881-ENG286202-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange[1],No Response From Subnet Component,8
ENG244881-ENG286203-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange[0],No Response From Subnet Component,8
ENG244881-ENG286204-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange[1],No Response From Subnet Component,8
ENG244881-ENG286205-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange[0],No Response From Subnet Component,8
ENG244881-ENG286206-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange[1],No Response From Subnet Component,8
ENG244881-ENG286207-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange[0],No Response From Subnet Component,8
ENG244881-ENG286208-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange[1],No Response From Subnet Component,8
ENG244881-ENG286209-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usCRC,No Response From Subnet Component,8
ENG244881-ENG289585-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289586-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286212-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286213-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286214-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286215-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286216-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286217-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286218-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286219-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286220-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286221-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange[0],No Response From Subnet Component,8
ENG244881-ENG286222-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange[1],No Response From Subnet Component,8
ENG244881-ENG286223-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange[0],No Response From Subnet Component,8
ENG244881-ENG286224-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange[1],No Response From Subnet Component,8
ENG244881-ENG286225-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation[0],No Response From Subnet Component,8
ENG244881-ENG286226-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation[1],No Response From Subnet Component,8
ENG244881-ENG289587-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289588-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286229-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289589-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289590-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289591-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289592-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289593-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289594-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286236-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286237-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286238-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange[0],No Response From Subnet Component,8
ENG244881-ENG286239-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange[1],No Response From Subnet Component,8
ENG244881-ENG286240-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286241-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286242-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange[0],No Response From Subnet Component,8
ENG244881-ENG286243-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange[1],No Response From Subnet Component,8
ENG244881-ENG286244-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange[0],No Response From Subnet Component,8
ENG244881-ENG286245-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange[1],No Response From Subnet Component,8
ENG244881-ENG286246-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange[0],No Response From Subnet Component,8
ENG244881-ENG286247-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange[1],No Response From Subnet Component,8
ENG244881-ENG286248-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange[0],No Response From Subnet Component,8
ENG244881-ENG286249-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange[1],No Response From Subnet Component,8
ENG244881-ENG286250-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usCRC,No Response From Subnet Component,8
ENG244881-ENG289595-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289596-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286253-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286254-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286262-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-padding,No Response From Subnet Component,8
ENG244881-ENG286271-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286272-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286273-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286274-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_[1],No Response From Subnet Component,8
ENG244881-ENG289612-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_High,No Response From Subnet Component,8
ENG244881-ENG289613-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_Low,No Response From Subnet Component,8
ENG244881-ENG286278-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_1_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286279-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286280-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286281-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio1_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286282-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286283-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286284-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[0],No Response From Subnet Component,8
ENG244881-ENG286285-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[1],No Response From Subnet Component,8
ENG244881-ENG286286-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[10],No Response From Subnet Component,8
ENG244881-ENG286287-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[11],No Response From Subnet Component,8
ENG244881-ENG286288-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[12],No Response From Subnet Component,8
ENG244881-ENG286289-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[13],No Response From Subnet Component,8
ENG244881-ENG286290-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[14],No Response From Subnet Component,8
ENG244881-ENG286291-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[15],No Response From Subnet Component,8
ENG244881-ENG286292-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[16],No Response From Subnet Component,8
ENG244881-ENG286293-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[17],No Response From Subnet Component,8
ENG244881-ENG286294-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[18],No Response From Subnet Component,8
ENG244881-ENG286295-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[19],No Response From Subnet Component,8
ENG244881-ENG286296-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[2],No Response From Subnet Component,8
ENG244881-ENG286297-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[20],No Response From Subnet Component,8
ENG244881-ENG286298-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[21],No Response From Subnet Component,8
ENG244881-ENG286299-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[22],No Response From Subnet Component,8
ENG244881-ENG286300-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[23],No Response From Subnet Component,8
ENG244881-ENG286301-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[24],No Response From Subnet Component,8
ENG244881-ENG286302-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[25],No Response From Subnet Component,8
ENG244881-ENG286303-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[26],No Response From Subnet Component,8
ENG244881-ENG286304-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[27],No Response From Subnet Component,8
ENG244881-ENG286305-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[28],No Response From Subnet Component,8
ENG244881-ENG286306-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[29],No Response From Subnet Component,8
ENG244881-ENG286307-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[3],No Response From Subnet Component,8
ENG244881-ENG286308-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[30],No Response From Subnet Component,8
ENG244881-ENG286309-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[31],No Response From Subnet Component,8
ENG244881-ENG286310-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[32],No Response From Subnet Component,8
ENG244881-ENG286311-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[33],No Response From Subnet Component,8
ENG244881-ENG286312-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[34],No Response From Subnet Component,8
ENG244881-ENG286313-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[35],No Response From Subnet Component,8
ENG244881-ENG286314-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[36],No Response From Subnet Component,8
ENG244881-ENG286315-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[37],No Response From Subnet Component,8
ENG244881-ENG286316-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[38],No Response From Subnet Component,8
ENG244881-ENG286317-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[39],No Response From Subnet Component,8
ENG244881-ENG286318-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[4],No Response From Subnet Component,8
ENG244881-ENG286319-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[40],No Response From Subnet Component,8
ENG244881-ENG286320-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[41],No Response From Subnet Component,8
ENG244881-ENG286321-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[42],No Response From Subnet Component,8
ENG244881-ENG286322-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[43],No Response From Subnet Component,8
ENG244881-ENG286323-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[44],No Response From Subnet Component,8
ENG244881-ENG286324-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[45],No Response From Subnet Component,8
ENG244881-ENG286325-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[46],No Response From Subnet Component,8
ENG244881-ENG286326-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[47],No Response From Subnet Component,8
ENG244881-ENG286327-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[48],No Response From Subnet Component,8
ENG244881-ENG286328-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[49],No Response From Subnet Component,8
ENG244881-ENG286329-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[5],No Response From Subnet Component,8
ENG244881-ENG286330-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[50],No Response From Subnet Component,8
ENG244881-ENG286331-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[51],No Response From Subnet Component,8
ENG244881-ENG286332-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[52],No Response From Subnet Component,8
ENG244881-ENG286333-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[53],No Response From Subnet Component,8
ENG244881-ENG286334-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[54],No Response From Subnet Component,8
ENG244881-ENG286335-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[55],No Response From Subnet Component,8
ENG244881-ENG286336-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[56],No Response From Subnet Component,8
ENG244881-ENG286337-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[57],No Response From Subnet Component,8
ENG244881-ENG286338-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[58],No Response From Subnet Component,8
ENG244881-ENG286339-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[59],No Response From Subnet Component,8
ENG244881-ENG286340-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[6],No Response From Subnet Component,8
ENG244881-ENG286341-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[60],No Response From Subnet Component,8
ENG244881-ENG286342-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[61],No Response From Subnet Component,8
ENG244881-ENG286343-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[62],No Response From Subnet Component,8
ENG244881-ENG286344-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[63],No Response From Subnet Component,8
ENG244881-ENG286345-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[64],No Response From Subnet Component,8
ENG244881-ENG286346-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[65],No Response From Subnet Component,8
ENG244881-ENG286347-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[7],No Response From Subnet Component,8
ENG244881-ENG286348-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[8],No Response From Subnet Component,8
ENG244881-ENG286349-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[9],No Response From Subnet Component,8
ENG244881-ENG289614-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Retry_Timeout,No Response From Subnet Component,8
ENG244881-ENG289615-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Sent_Time,No Response From Subnet Component,8
ENG244881-ENG286353-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Algo_Time_Out,No Response From Subnet Component,8
ENG244881-ENG286354-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_1,No Response From Subnet Component,8
ENG244881-ENG289616-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_2,No Response From Subnet Component,8
ENG244881-ENG286355-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_1,No Response From Subnet Component,8
ENG244881-ENG286356-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_2,No Response From Subnet Component,8
ENG244881-ENG286357-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_3,No Response From Subnet Component,8
ENG244881-ENG286358-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_4,No Response From Subnet Component,8
ENG244881-ENG286359-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Fahrzeugtyp,No Response From Subnet Component,8
ENG244881-ENG286360-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Padding,No Response From Subnet Component,8
ENG244881-ENG286361-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[0],No Response From Subnet Component,8
ENG244881-ENG286362-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[01],No Response From Subnet Component,8
ENG244881-ENG286363-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[2],No Response From Subnet Component,8
ENG244881-ENG286364-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[3],No Response From Subnet Component,8
ENG244881-ENG286365-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[4],No Response From Subnet Component,8
ENG244881-ENG286366-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[5],No Response From Subnet Component,8
ENG244881-ENG286367-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[6],No Response From Subnet Component,8
ENG244881-ENG286368-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[7],No Response From Subnet Component,8
ENG244881-ENG286369-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[8],No Response From Subnet Component,8
ENG244881-ENG286370-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[9],No Response From Subnet Component,8
ENG244881-ENG286371-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286372-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286373-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286374-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286375-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286376-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286377-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ucPoly_FeatureNumber,No Response From Subnet Component,8
ENG244881-ENG286378-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ul_CRC,No Response From Subnet Component,8
ENG244881-ENG286380-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_0,No Response From Subnet Component,8
ENG244881-ENG286381-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_1,No Response From Subnet Component,8
ENG244881-ENG286382-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa Time_Diff_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286383-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa_Time_Diff_Range_[0],No Response From Subnet Component,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,not installed ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,not installed ,3
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,3
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,3
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,3
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an ber Geschwindigkeit,Master steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,On ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,80% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,80% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,LIN ,3
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,5
ENG253157-roof_module,installed ,1
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,not installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,not installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG116647-Schiebedach_ZV-SAD Komfort oeffnen,not active ,6
ENG253336-ENG289611-Schiebedach_ZV-SAD Komfort_oeffnungs_modus,Open ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,not active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schl sselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schl sselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schl sselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG277093-Schl sselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31
ENG253118-ENG126945-Schl sselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31
ENG253118-ENG129003-Schl sselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schl sselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG126939-Schl sselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31
ENG253118-ENG126946-Schl sselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schl sselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schl sselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253264-Seat_cushion_fan,not installed ,1
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,not installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,not installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,3 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,3 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,100 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,50 ms,48
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,60 s,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,not active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,not active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,not active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,not active ,3
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,0 C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,0 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,-100 C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-100 C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG253353-ENG260527-St rungsmeldungen Licht/Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG253353-ENG260368-St rungsmeldungen Licht/Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG253353-ENG260726-St rungsmeldungen Licht/Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,6.9 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,1.8 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,100.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,100.0 ,8
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,100.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10
ENG249751-Two_keys,active ,3
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG252991-Vehicle configuration,activated ,1
ENG253245-ENG261297-verbauliste_subcan-Digitale Dachantenne,not installed ,4
ENG253245-ENG260575-verbauliste_subcan-nfc_miko,not installed ,4
ENG253245-ENG260904-verbauliste_subcan-nfc_tgs,not installed ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6
ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlie en,active ,6
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlie en via Funkfernbedienung,active ,6
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlie en via Kessy,active ,6
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlie en via Schlie zylinder,active ,6
ENG253327-ENG277083-Verlassenswarnung und Standlichtnachlauf-Ausgabedauer Wegrollwarnung,10 s,8
ENG253327-ENG261189-Verlassenswarnung und Standlichtnachlauf-Ausgabeverhalten Verlassenswarnung,VLW mit VLK2.2 Kriterien ,8
ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverz gerung der Verlassenswarnung,1.4 s,8
ENG253327-ENG277084-Verlassenswarnung und Standlichtnachlauf-Ausgabeverz gerung der Wegrollwarnung,1.0 s,8
ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8
ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8
ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8
ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8
ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verf gbarkeit Standlichtnachlauf,active ,8
ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verf gbarkeit Verlassenswarnung,equippt ,8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,not installed ,8
ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,not installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,not active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,not active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,not active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,0 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,not installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,not installed ,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,not installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,not installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,0 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,00 00 00 00 ,4
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG281049-ENG263583-Z ndungswarnung und Antrieb-Aktiv-Warnung-Ausgabe MoLaWa_AAW,active ,8
ENG281049-ENG263581-Z ndungswarnung und Antrieb-Aktiv-Warnung-Entprellung_MoLaWa,1.5 ,8
ENG281049-ENG263504-Z ndungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.8 s,8
ENG281049-ENG281097-Z ndungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswecsel nicht Belegt zu Belegt,0.0 s,8
ENG281049-ENG263576-Z ndungswarnung und Antrieb-Aktiv-Warnung-Freigabeentprellung Abschaltung nach EM,60 s,8
ENG281049-ENG263531-Z ndungswarnung und Antrieb-Aktiv-Warnung-Unterdr ckung der Z ndungswarnung,active ,8
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,not active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschlie funktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,not active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,not active ,6
ENG141653-ENG258544-ZV Heck-eingeschr nkte_Freigabe_HD_Innentaste,active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,not installed ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschlie en_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schlie en,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,not active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,not active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.0 s,7
ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,none ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,No ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,none ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,No ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5
ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5
ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,not installed ,5
ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,not installed ,5
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,active ,6
ENG141652-ENG258598-ZV T rkonfiguration-Fzg_mit_Vier_Tueren,Yes ,2
ENG141652-ENG260173-ZV T rkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2
ENG141652-ENG142000-ZV T rkonfiguration-Schlosstyp_NAR,Yes ,2
ENG141652-ENG258913-ZV T rkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263484-ENG263546-ZV_HW_Router-PIN_A11,T r HL verriegeln oder Laderaumabdeckung links ,5
ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenr ckmeldung ,5
ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5
ENG263484-ENG263567-ZV_HW_Router-PIN_A33,T r HR Verriegelung/Safe oder Verdeck zu ,5
ENG263484-ENG263596-ZV_HW_Router-PIN_A35,T r HL Verriegelung/Safe ,5
ENG263484-ENG263575-ZV_HW_Router-PIN_A48,T r HR TK-Signal ,5
ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Taste Heckdeckelentriegelung ,5
ENG263484-ENG263547-ZV_HW_Router-PIN_A50,T r HL TK-Signal ,5
ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5
ENG263484-ENG263545-ZV_HW_Router-PIN_A7,T r HR verriegeln oder Laderaumabdeckung rechts ,5
ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Funktions-LED Taste3 ,5
ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Funktions-LED Taste4 ,5
ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Cockpit-Taste 3 ,5
ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,No ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,not active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,not active ,5
ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,not active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 03:51
;SW:5WA-937-086-AE HW:5WA-937-086-L --- 09: Cent. Elect.
;Component:BCM37w_M028 0175, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_VW38.rod
;Tuesday,01,September,2026,23:07:13:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 147663D49EF722EA538-8040 SFD [ ]
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG259333-Production mode-pa_ambiente_aussenlicht_pmode,not active ,3
IDE00001-ENG258242-Production mode-pa_auto_abschaltung_pmode,not active ,3
IDE00001-ENG263594-Production mode-pa_klemme_15_pmode,not active ,3
IDE00001-ENG263561-Production mode-pa_klemme_50_pmode,not active ,3
IDE00001-ENG260387-Production mode-pa_sitzpneumatik_pmode,not active ,3
IDE00001-ENG281100-Production mode-Remotestart_Pmode,not active ,3
IDE00301-Distance,0 km,4
IDE01550-Service position,163.802035 ,2
IDE02455-ENG116601-Light function "Coming/Leaving Home"-Coming Home Verbaustatus,automatic ,2
IDE02455-ENG260981-Light function "Coming/Leaving Home"-Darstellung Coming-home Verlauf,not active ,2
IDE02455-ENG261352-Light function "Coming/Leaving Home"-Darstellung Leaving-home Verlauf,not active ,2
IDE02455-ENG115657-Light function "Coming/Leaving Home"-Leaving-Home Verbausstatus,Enabled ,2
IDE02455-ENG115863-Light function "Coming/Leaving Home"-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,2
IDE02455-ENG116602-Light function "Coming/Leaving Home"-Menuesteuerung Coming Home Werkseinstellung,active ,2
IDE02455-ENG116606-Light function "Coming/Leaving Home"-Menuesteuerung Leaving-home Freischaltung per BAP,active ,2
IDE02488-Anti-theft system interior monitoring,No Response From Subnet Component,2
IDE02711-ENG112304-Rear wiper-Heckwischer,1Draht_Heckwischer ,8
IDE02711-ENG258487-Rear wiper-Heckwischer_Kaltstart,Heckwischerstopp bei Wiederstart und Erststart ,8
IDE02711-ENG289598-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall LSS AUS,10 s,8
IDE02711-ENG261056-Rear wiper-Modus_Heckintervall,statische Intervallpausenzeit ,8
IDE02711-ENG259069-Rear wiper-Rueckfahrwischen_Temp,OFF ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE03787-Activate left/right hand drive switch-over,Unknown (255),1
IDE05534-ENG116609-Headlamp washer system-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,7
IDE05534-ENG115769-Headlamp washer system-SRA bei Waschwassermangel,active ,7
IDE05534-ENG115767-Headlamp washer system-SRA Einweichpausenzeit,0 ms,7
IDE05534-ENG115768-Headlamp washer system-SRA Nachwaschzeit,0 ms,7
IDE05534-ENG116611-Headlamp washer system-SRA Pausenzeit,10000 ms,7
IDE05534-ENG258416-Headlamp washer system-SRA Untersetzung Init,0 ,7
IDE05534-ENG116610-Headlamp washer system-SRA Verzoegerungszeit,0 ms,7
IDE05534-ENG115766-Headlamp washer system-SRA Waschzeit,2000 ms,7
IDE05822-Anti-theft alarm system vehicle inclination sensor,No Response From Subnet Component,7
IDE05823-DWA Interior monitoring parameter set,No Response From Subnet Component,7
IDE06274-MAS05958-Light functions for special-purpose vehicle-intermittent low beam,Low beams ,4
IDE06274-MAS05960-Light functions for special-purpose vehicle-intermittent high beam,Main beam ,4
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,255 min,2
IDE07161-temporary VIN,Conditions not correct or request sequence error,2
IDE07356-Position during interval mode,20.010969 ,2
IDE08577-Garage door opener: use of GPS data,No Response From Subnet Component,2
IDE08578-Garage door opener: bi-directional communic.,No Response From Subnet Component,2
IDE08579-Garage door opener: drift adapt.,No Response From Subnet Component,2
IDE08580-Garage door opener: increasing transm. power,No Response From Subnet Component,2
IDE08583-Garage door opener: no. of channels,No Response From Subnet Component,2
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,No Response From Subnet Component,2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,No Response From Subnet Component,2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,No Response From Subnet Component,2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,No Response From Subnet Component,2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,No Response From Subnet Component,2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,No Response From Subnet Component,2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,No Response From Subnet Component,2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,No Response From Subnet Component,2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,No Response From Subnet Component,2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,No Response From Subnet Component,2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,No Response From Subnet Component,2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,No Response From Subnet Component,2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,No Response From Subnet Component,2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,No Response From Subnet Component,2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,No Response From Subnet Component,2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,No Response From Subnet Component,2
IDE08585-Garage door opener: activation via remote key,No Response From Subnet Component,2
IDE08778-Garage door opener: surround. target area,No Response From Subnet Component,2
IDE08786-MAS13782-Assistance light functions-Will Beam assistant: responsivity adjustable via BAP,present ,9
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,500 ms,9
IDE08786-ENG259537-Assistance light functions-Maskierung_Regenlichtmen ,not active ,9
IDE09377-IDE00761-Multi-contour seat driver's side-Run-on time,No Response From Subnet Component,9
IDE09377-IDE03006-Multi-contour seat driver's side-Running time of massage function,No Response From Subnet Component,9
IDE09377-IDE03007-Multi-contour seat driver's side-Component location,No Response From Subnet Component,9
IDE09377-IDE03099-Multi-contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09377-IDE03100-Multi-contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09378-IDE00761-Multi-contour seat passenger side-Run-on time,No Response From Subnet Component,9
IDE09378-IDE03006-Multi-contour seat passenger side-Running time of massage function,No Response From Subnet Component,9
IDE09378-IDE03007-Multi-contour seat passenger side-Component location,No Response From Subnet Component,9
IDE09378-IDE03099-Multi-contour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,9
IDE09378-IDE03100-Multi-contour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,9
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,9
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,9
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,9
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,9
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE09767-ENG133381-Position lamps-Bedingungen zur Parklichtbegrenzung,Switch-off due to energy management ,7
IDE09767-ENG133380-Position lamps-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverf gbarkeit ,7
IDE09767-ENG137034-Position lamps-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,7
IDE09767-ENG115862-Position lamps-Lichtwarnungsverhalten,klemmenabhaengig ,7
IDE09767-ENG115859-Position lamps-Parklicht ueber LSS aktiviert,not active ,7
IDE09767-ENG126816-Position lamps-Standlicht aus,active ,7
IDE09767-ENG115829-Position lamps-Standlichtreduzierung mit beidseitigem Parklicht,not active ,7
IDE09767-ENG133383-Position lamps-Standlicht-Verf gbarkeit,24 s,7
IDE10283-Key identification: transponder ID,Conditions not correct or request sequence error,7
IDE10298-Alternating park position 1,0.010989 ,2
IDE10299-Alternating park position 2,22.010967 ,2
IDE10308-Garage door opener: support door name,No Response From Subnet Component,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,No Response From Subnet Component,2
IDE10844-Control module rear lid opening: duration status query,0 ms,2
IDE10845-Control module rear lid opening: vehicle type-,00 ,12
IDE10845-ENG258964-Control module rear lid opening: vehicle type-p_a_p_mode_aktivieren_vip,00 ,12
IDE10845-ENG259328-Control module rear lid opening: vehicle type-p_t_delay_VIP_Freigabe_ZV_Ansteuerung,0 s,12
IDE10845-ENG260538-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell,0 ms,12
IDE10845-ENG259913-Control module rear lid opening: vehicle type-p_t_VIP_Bremslicht_hell_offen,0 ms,12
IDE10845-ENG260941-Control module rear lid opening: vehicle type-p_t_VIP_Sperrzeit_Schl sselsuche,0 s,12
IDE10845-ENG259196-Control module rear lid opening: vehicle type-p_t_VIP_Verzoegerung,0 ms,12
IDE10845-ENG259996-Control module rear lid opening: vehicle type-p_v_VIP_aktiv,0 km/h,12
IDE10845-ENG261214-Control module rear lid opening: vehicle type-p_v_VIP_deaktiv,0 km/h,12
IDE12119-Garage door opener: frequency range of bi-directional communication,No Response From Subnet Component,12
IDE12120-Garage door opener: piloted parking,No Response From Subnet Component,12
IDE12121-Garage door opener: vehicle variant,No Response From Subnet Component,12
IDE12122-Garage door opener: continuous transmission mode for level measurement,No Response From Subnet Component,12
IDE12302-SFT00022-Identification of sub-bus participant-Steering Column Electronics,old ,6
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,old ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,old ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,old ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,old ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,old ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,old ,6
IDE12302-SFT271909-Identification of sub-bus participant-Left taillight 1,old ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,old ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,old ,6
IDE12302-SFT271950-Identification of sub-bus participant-Power rear lid opening control module,New ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,old ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,old ,6
IDE12302-SFT272014-Identification of sub-bus participant-Control head for driving and comfort functions,New ,6
IDE12302-SFT272057-Identification of sub-bus participant-Valve block 1 in front seat driver side,old ,6
IDE12302-SFT272061-Identification of sub-bus participant-Valve block 1 in front seat passenger side,old ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,old ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,old ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,old ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,old ,6
IDE12302-SFT272121-Identification of sub-bus participant-Control unit 2 for driving and convenience functions,old ,6
IDE12302-SFT272142-Identification of sub-bus participant-Left taillight 2,old ,6
IDE12302-SFT272143-Identification of sub-bus participant-Right taillight 1,old ,6
IDE12302-SFT272144-Identification of sub-bus participant-Right taillight 2,old ,6
IDE12302-SFT272221-Identification of sub-bus participant-Radio receiver for remote start,old ,6
IDE12302-SFT272238-Identification of sub-bus participant-Wiper motor control unit 2,old ,6
IDE12302-SFT272272-Identification of sub-bus participant-Virtual pedal door opening: rear driver's side,old ,6
IDE12302-SFT272286-Identification of sub-bus participant-Virtual pedal door opening: rear passenger's side,old ,6
IDE12488-Antenna 1 for short-range communication,No Response From Subnet Component,6
IDE12489-Antenna 2 for short-range communication,No Response From Subnet Component,6
IDE13065-Left tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13066-Left tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13067-Right tail lamp 1: parameter set,No Response From Subnet Component,6
IDE13068-Right tail lamp 2: parameter set,No Response From Subnet Component,6
IDE13391-ENG246968-BAP function status-CHo_LHo_Nachlauf,0 ms,16
IDE13391-ENG115656-BAP function status-Coming Home Leuchten,Low beams ,16
IDE13391-ENG116604-BAP function status-Coming-home Einschaltereignis,Ignition On ,16
IDE13391-ENG116608-BAP function status-Helligkeitsschwelle Forward-Messung,600 lx,16
IDE13391-ENG116605-BAP function status-Helligkeitsschwelle Infrarot-Messung,1200 lx,16
IDE13391-ENG116603-BAP function status-Menueeinstellung Cominghome,10 seconds ,16
IDE13391-ENG258918-BAP function status-Menueeinstellung Cominghome bei Tag,10 seconds ,16
IDE13391-ENG259258-BAP function status-Menueeinstellung Leaving-home bei Tag,10 seconds ,16
IDE13391-ENG116607-BAP function status-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,16
IDE13391-ENG258405-BAP function status-Tagfahrlicht mit CHO bei Tag in Stellung AUTO,not active ,16
IDE13391-ENG259717-BAP function status-Tagfahrlicht mit LHO bei Tag in Stellung AUTO,not active ,16
IDE15901-Direct entry keys,installed ,2
IDE15902-MAS10541-rotary light switch-Light rotary switch with fog light,Yes ,4
IDE15902-MAS10542-rotary light switch-Light rotary switch with fog tail light,No ,4
IDE15902-MAS10543-rotary light switch-Light rotary sw. with AFL,Yes ,4
IDE15902-MAS10544-rotary light switch-Light rotary switch with park. light pos.,Yes ,4
IDE80001-ENG125667-Analysis 1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125666-Analysis 1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125668-Analysis 1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125673-Analysis 1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125672-Analysis 1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125674-Analysis 1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125670-Analysis 1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125669-Analysis 1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125671-Analysis 1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125676-Analysis 1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125675-Analysis 1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125677-Analysis 1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125664-Analysis 1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125663-Analysis 1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80001-ENG125665-Analysis 1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125667-Analysis 2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125666-Analysis 2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125668-Analysis 2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125673-Analysis 2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125672-Analysis 2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125674-Analysis 2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125670-Analysis 2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125669-Analysis 2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125671-Analysis 2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125676-Analysis 2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125675-Analysis 2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125677-Analysis 2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125664-Analysis 2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125663-Analysis 2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80002-ENG125665-Analysis 2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125667-Analysis 3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125666-Analysis 3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125668-Analysis 3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125673-Analysis 3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125672-Analysis 3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125674-Analysis 3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125670-Analysis 3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125669-Analysis 3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125671-Analysis 3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125676-Analysis 3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125675-Analysis 3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125677-Analysis 3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125664-Analysis 3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125663-Analysis 3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80003-ENG125665-Analysis 3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125667-Analysis 4-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125666-Analysis 4-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125668-Analysis 4-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125673-Analysis 4-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125672-Analysis 4-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125674-Analysis 4-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125670-Analysis 4-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125669-Analysis 4-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125671-Analysis 4-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125676-Analysis 4-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125675-Analysis 4-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125677-Analysis 4-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125664-Analysis 4-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125663-Analysis 4-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80004-ENG125665-Analysis 4-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125667-Analysis 5-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125666-Analysis 5-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125668-Analysis 5-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125673-Analysis 5-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125672-Analysis 5-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125674-Analysis 5-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125670-Analysis 5-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125669-Analysis 5-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125671-Analysis 5-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125676-Analysis 5-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125675-Analysis 5-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125677-Analysis 5-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125664-Analysis 5-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125663-Analysis 5-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80005-ENG125665-Analysis 5-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125667-Analysis 6-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125666-Analysis 6-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125668-Analysis 6-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125673-Analysis 6-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125672-Analysis 6-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125674-Analysis 6-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125670-Analysis 6-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125669-Analysis 6-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125671-Analysis 6-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125676-Analysis 6-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125675-Analysis 6-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125677-Analysis 6-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125664-Analysis 6-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125663-Analysis 6-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80006-ENG125665-Analysis 6-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80007-ENG125682-Analysis 7-s_GrobleckerkennungDauer,No Response From Subnet Component,4
IDE80007-ENG125680-Analysis 7-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80007-ENG125681-Analysis 7-s_Leckageerkennung,No Response From Subnet Component,4
IDE80007-ENG125678-Analysis 7-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80007-ENG125679-Analysis 7-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80008-ENG125684-Analysis 8-s_DruckschwelleNachlauf,No Response From Subnet Component,4
IDE80008-ENG126855-Analysis 8-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126854-Analysis 8-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126856-Analysis 8-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG126857-Analysis 8-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG126863-Analysis 8-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80008-ENG126862-Analysis 8-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,No Response From Subnet Component,4
IDE80008-ENG126859-Analysis 8-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80008-ENG126858-Analysis 8-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80008-ENG126860-Analysis 8-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80008-ENG259691-Analysis 8-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80008-ENG126864-Analysis 8-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80008-ENG126861-Analysis 8-s_MinimaldruckSitzlehnenwangen,No Response From Subnet Component,4
IDE80008-ENG125683-Analysis 8-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80009-ENG125687-Analysis 9-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80009-ENG125689-Analysis 9-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125685-Analysis 9-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80009-ENG125688-Analysis 9-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80009-ENG125686-Analysis 9-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80011-ENG125667-Analysis 11-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125666-Analysis 11-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125668-Analysis 11-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125673-Analysis 11-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125672-Analysis 11-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125674-Analysis 11-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125670-Analysis 11-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125669-Analysis 11-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125671-Analysis 11-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125676-Analysis 11-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125675-Analysis 11-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125677-Analysis 11-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125664-Analysis 11-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125663-Analysis 11-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,4
IDE80011-ENG125665-Analysis 11-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,4
IDE80012-ENG125693-Analysis 12-s_DauerFuerGrobleckerkennung,No Response From Subnet Component,4
IDE80012-ENG125680-Analysis 12-s_LatenzzeitHaengenderTaster,No Response From Subnet Component,4
IDE80012-ENG125681-Analysis 12-s_Leckageerkennung,No Response From Subnet Component,4
IDE80012-ENG125678-Analysis 12-s_UeberspannungsSschwelle,No Response From Subnet Component,4
IDE80012-ENG125679-Analysis 12-s_UnterspannungsSchwelle,No Response From Subnet Component,4
IDE80013-ENG126871-Analysis 13-s_Druckschwelle_Nachlauf,No Response From Subnet Component,4
IDE80013-ENG126855-Analysis 13-s_Maximaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126854-Analysis 13-s_Maximaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126856-Analysis 13-s_Maximaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG126857-Analysis 13-s_Maximaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG126863-Analysis 13-s_Maximaldruck_Ueberlastschutz,No Response From Subnet Component,4
IDE80013-ENG126870-Analysis 13-s_Maximaler_Differenzdruck_LRD_VorZurueck,No Response From Subnet Component,4
IDE80013-ENG126859-Analysis 13-s_Minimaldruck_LRD_m,No Response From Subnet Component,4
IDE80013-ENG126858-Analysis 13-s_Minimaldruck_LRD_o,No Response From Subnet Component,4
IDE80013-ENG126860-Analysis 13-s_Minimaldruck_LRD_u,No Response From Subnet Component,4
IDE80013-ENG259691-Analysis 13-s_Minimaldruck_LRD_vertikal,No Response From Subnet Component,4
IDE80013-ENG126864-Analysis 13-s_Minimaldruck_Massage,No Response From Subnet Component,4
IDE80013-ENG126869-Analysis 13-s_Minimaldruck_Sitzlehnenwangen,No Response From Subnet Component,4
IDE80013-ENG125683-Analysis 13-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,No Response From Subnet Component,4
IDE80014-ENG125687-Analysis 14-s_AnzahlDruckmessungenIntervallerhoehung,No Response From Subnet Component,4
IDE80014-ENG125689-Analysis 14-s_AussendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125685-Analysis 14-s_BasismessintervallNachregelung,No Response From Subnet Component,4
IDE80014-ENG125688-Analysis 14-s_BlasendruckschwelleNachregelung,No Response From Subnet Component,4
IDE80014-ENG125686-Analysis 14-s_ErhoehungsintervallNachregelung,No Response From Subnet Component,4
IDE80015-ENG126865-Analysis 15-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126867-Analysis 15-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG126866-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,4
IDE80015-ENG126868-Analysis 15-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,4
IDE80015-ENG125690-Analysis 15-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,4
IDE80016-Analysis 16,No Response From Subnet Component,4
IDE80017-ENG133471-Analysis 17-Offset_PB1_LM,No Response From Subnet Component,4
IDE80017-ENG133470-Analysis 17-Offset_PB1_LO,No Response From Subnet Component,4
IDE80017-ENG133472-Analysis 17-Offset_PB1_LU,No Response From Subnet Component,4
IDE80017-ENG133473-Analysis 17-Offset_PB1_SH,No Response From Subnet Component,4
IDE80017-ENG133475-Analysis 17-Offset_PB2_LM,No Response From Subnet Component,4
IDE80017-ENG133474-Analysis 17-Offset_PB2_LO,No Response From Subnet Component,4
IDE80017-ENG133476-Analysis 17-Offset_PB2_LU,No Response From Subnet Component,4
IDE80017-ENG133477-Analysis 17-Offset_PB2_SH,No Response From Subnet Component,4
IDE80017-ENG289601-Analysis 17-Offset_PP1,No Response From Subnet Component,4
IDE80017-ENG289602-Analysis 17-Offset_PP2,No Response From Subnet Component,4
IDE80017-ENG133483-Analysis 17-Offset_PV1_LM,No Response From Subnet Component,4
IDE80017-ENG133482-Analysis 17-Offset_PV1_LO,No Response From Subnet Component,4
IDE80017-ENG133484-Analysis 17-Offset_PV1_LU,No Response From Subnet Component,4
IDE80017-ENG133485-Analysis 17-Offset_PV1_SH,No Response From Subnet Component,4
IDE80017-ENG133486-Analysis 17-Offset_PV2_LO,No Response From Subnet Component,4
IDE80017-ENG133488-Analysis 17-Offset_PV2_LU,No Response From Subnet Component,4
IDE80017-ENG133489-Analysis 17-Offset_PV2_SH,No Response From Subnet Component,4
IDE80017-ENG289603-Analysis 17-Offset_T1,No Response From Subnet Component,4
IDE80017-ENG289604-Analysis 17-Offset_T2,No Response From Subnet Component,4
IDE80017-ENG133487-Analysis 17-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80017-ENG133490-Analysis 17-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80017-ENG133491-Analysis 17-p_longpush_time,No Response From Subnet Component,4
IDE80017-ENG133497-Analysis 17-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133498-Analysis 17-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133494-Analysis 17-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80017-ENG133492-Analysis 17-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80017-ENG133496-Analysis 17-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80017-ENG133495-Analysis 17-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80017-ENG133493-Analysis 17-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80017-ENG133458-Analysis 17-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80017-ENG133460-Analysis 17-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80017-ENG133459-Analysis 17-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80017-ENG133469-Analysis 17-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80017-ENG133464-Analysis 17-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80017-ENG133465-Analysis 17-s_MaxIntervall,No Response From Subnet Component,4
IDE80017-ENG133461-Analysis 17-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80017-ENG133462-Analysis 17-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133463-Analysis 17-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80017-ENG133468-Analysis 17-s_Sitzvariante,No Response From Subnet Component,4
IDE80017-ENG133467-Analysis 17-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80017-ENG133466-Analysis 17-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80017-ENG133457-Analysis 17-s_Uebernahmedruck_P_u,No Response From Subnet Component,4
IDE80017-ENG133456-Analysis 17-s_Uebernahmedruck_PUe_o,No Response From Subnet Component,4
IDE80018-ENG133471-Analysis 18-Offset_PB1_LM,No Response From Subnet Component,4
IDE80018-ENG133472-Analysis 18-Offset_PB1_LU,No Response From Subnet Component,4
IDE80018-ENG133473-Analysis 18-Offset_PB1_SH,No Response From Subnet Component,4
IDE80018-ENG133475-Analysis 18-Offset_PB2_LM,No Response From Subnet Component,4
IDE80018-ENG133474-Analysis 18-Offset_PB2_LO,No Response From Subnet Component,4
IDE80018-ENG133476-Analysis 18-Offset_PB2_LU,No Response From Subnet Component,4
IDE80018-ENG133477-Analysis 18-Offset_PB2_SH,No Response From Subnet Component,4
IDE80018-ENG289601-Analysis 18-Offset_PP1,No Response From Subnet Component,4
IDE80018-ENG289602-Analysis 18-Offset_PP2,No Response From Subnet Component,4
IDE80018-ENG133483-Analysis 18-Offset_PV1_LM,No Response From Subnet Component,4
IDE80018-ENG133482-Analysis 18-Offset_PV1_LO,No Response From Subnet Component,4
IDE80018-ENG133484-Analysis 18-Offset_PV1_LU,No Response From Subnet Component,4
IDE80018-ENG133485-Analysis 18-Offset_PV1_SH,No Response From Subnet Component,4
IDE80018-ENG133486-Analysis 18-Offset_PV2_LO,No Response From Subnet Component,4
IDE80018-ENG133488-Analysis 18-Offset_PV2_LU,No Response From Subnet Component,4
IDE80018-ENG133489-Analysis 18-Offset_PV2_SH,No Response From Subnet Component,4
IDE80018-ENG289603-Analysis 18-Offset_T1,No Response From Subnet Component,4
IDE80018-ENG289604-Analysis 18-Offset_T2,No Response From Subnet Component,4
IDE80018-ENG133534-Analysis 18-OffsetPB1_LO,No Response From Subnet Component,4
IDE80018-ENG133487-Analysis 18-OffsetPV2_LMy,No Response From Subnet Component,4
IDE80018-ENG133490-Analysis 18-p_function_feedback_timeout,No Response From Subnet Component,4
IDE80018-ENG133491-Analysis 18-p_longpush_time,No Response From Subnet Component,4
IDE80018-ENG133497-Analysis 18-p_stoesselSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133498-Analysis 18-p_stoesselSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133494-Analysis 18-p_tasterSchaltschwelle_drei,No Response From Subnet Component,4
IDE80018-ENG133492-Analysis 18-p_tasterSchaltschwelle_eins,No Response From Subnet Component,4
IDE80018-ENG133496-Analysis 18-p_tasterSchaltschwelle_fuenf,No Response From Subnet Component,4
IDE80018-ENG133495-Analysis 18-p_tasterSchaltschwelle_vier,No Response From Subnet Component,4
IDE80018-ENG133493-Analysis 18-p_tasterSchaltschwelle_zwei,No Response From Subnet Component,4
IDE80018-ENG133458-Analysis 18-s_Beruhigungszeit_Befuellen,No Response From Subnet Component,4
IDE80018-ENG133460-Analysis 18-s_Beruhigungszeit_Druckmessung,No Response From Subnet Component,4
IDE80018-ENG133459-Analysis 18-s_Beruhigungszeit_Entlueften,No Response From Subnet Component,4
IDE80018-ENG133469-Analysis 18-s_Faktor_Druck_Entlueftung_Seitenhalt,No Response From Subnet Component,4
IDE80018-ENG133464-Analysis 18-s_IntervallUmgebungsbedingungen,No Response From Subnet Component,4
IDE80018-ENG133465-Analysis 18-s_MaxIntervall,No Response From Subnet Component,4
IDE80018-ENG133461-Analysis 18-s_Messdauer_Initialisierung,No Response From Subnet Component,4
IDE80018-ENG133462-Analysis 18-s_Messdauer_Kurzzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133463-Analysis 18-s_Messdauer_Langzeitmessung,No Response From Subnet Component,4
IDE80018-ENG133468-Analysis 18-s_Sitzvariante,No Response From Subnet Component,4
IDE80018-ENG133467-Analysis 18-s_Timeout_Befuell_Linearbereich,No Response From Subnet Component,4
IDE80018-ENG133466-Analysis 18-s_Timeout_Befuell_Startbereich,No Response From Subnet Component,4
IDE80018-ENG133532-Analysis 18-s_Uebernahmedruck_PUe_u,No Response From Subnet Component,4
IDE80018-ENG133533-Analysis 18-s_UebernahmedruckP_u,No Response From Subnet Component,4
MAS05055-lower turn position,24.010965 ,2
MAS05056-upper turn position,163.802035 ,2
MAS05807-ENG264052-Coding-Abparken nach Stop Haubenkontak (1bit),On ,3
MAS05807-ENG264068-Coding-adaptive Nachwischzyklen SRA (1bit),OFF ,3
MAS05807-ENG264069-Coding-APS bei Abparken (1bit),On ,3
MAS05807-ENG264070-Coding-APS bei Klemme 15 Wechsel (1bit),OFF ,3
MAS05807-ENG264071-Coding-APS f r 100 Zyklen deaktiv (1bit),On ,3
MAS05807-ENG264072-Coding-APS2 Verlassen bei Geschwindigkeit (1bit),On ,3
MAS05807-ENG264178-Coding-ger usch optimierte Wischkennlinie (1bit),OFF ,3
MAS05807-ENG264181-Coding-langsames Abparken (1bit),OFF ,3
MAS05807-ENG264190-Coding-Produktionsmodus m glich (1bit),On ,3
MAS05807-ENG264192-Coding-Regensensoraktivierung ber Fahrfreigabe (1bit),On ,3
MAS05807-ENG264194-Coding-Schleppfunktion Poti (1bit),On ,3
MAS05807-ENG264195-Coding-schnelles Tippwischen (1bit),On ,3
MAS05807-ENG264271-Coding-softe Geschwindigkeitsr ckschaltung (1bit),OFF ,3
MAS05807-ENG264272-Coding-Start bei Klemme 15 EIN (1bit),OFF ,3
MAS05807-ENG264274-Coding-Stop bei Haubenkontakt (1bit),OFF ,3
MAS05807-ENG264275-Coding-Stop bei Klemme 15 AUS (1bit),On ,3
MAS05807-ENG264276-Coding-Tr nenwischen (1bit),On ,3
MAS05807-ENG264279-Coding-v-abh ngige Wischstufenr ckschaltung (1bit),On ,3
MAS05807-ENG264280-Coding-variable Intervallwischgeschwindigkeit (1bit),OFF ,3
MAS05894-IDE13022-Engine run on-Function activation,not active ,4
MAS05894-MAS13391-Engine run on-Delay time timer,0 ms,4
MAS07146-MAS13125-Button 1-Function of button 1,not coded / not installed ,1
MAS07146-MAS13128-Button 1-Indicator lamp button 1,installed ,1
MAS07147-MAS13129-Button 2-Function of button 2,not coded / not installed ,1
MAS07147-MAS13131-Button 2-Indicator lamp button 2,installed ,1
MAS07148-MAS13132-Button 3-Function of button 3,not coded / not installed ,1
MAS07148-MAS13134-Button 3-Indicator lamp button 3,installed ,1
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,2000 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 1E ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,3500 lx,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,Medium ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,3800 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,3500 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,1400 mV,24
MAS09325-IDE13878-Daytime running lights-Activation: daytime running lights,Daytime running lights ,8
MAS09325-MAS09335-Daytime running lights-Daytime running lights/parking light,active ,8
MAS09325-MAS16273-Daytime running lights-Speed warning active: rear fog lamps,0 km/h,8
MAS09325-MAS21314-Daytime running lights-Daytime running indicator lamp,not active ,8
MAS09325-ENG142193-Daytime running lights-Geschwindigkeitsabhaengiges TFL,0 km/h,8
MAS09325-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,not active ,8
MAS09325-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,8
MAS09325-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,8
MAS09325-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,8
MAS09325-ENG142192-Daytime running lights-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,8
MAS09325-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,8
MAS12382-MAS06760-Dynamic turn signal control-Emergency flashers in roll mode,active ,8
MAS12382-MAS07029-Dynamic turn signal control-Crash flashing,active ,8
MAS12382-MAS07032-Dynamic turn signal control-Emergency flashing,active ,8
MAS12382-MAS07033-Dynamic turn signal control-Panic flashing,active ,8
MAS12382-MAS07034-Dynamic turn signal control-Theft flashing,active ,8
MAS12382-MAS07036-Dynamic turn signal control-Garage door opener adaptation flashing,active ,8
MAS12382-MAS07041-Dynamic turn signal control-Taxi alarm flashing,active ,8
MAS12382-MAS07044-Dynamic turn signal control-Rear lid opening angle adaptation flashing,active ,8
MAS12382-MAS12781-Dynamic turn signal control-Telematic blinking or blinking by positioning assistant,active ,8
MAS12382-MAS14169-Dynamic turn signal control-Confirmation flashing of the central locking system when unlocking,active ,8
MAS12382-MAS14170-Dynamic turn signal control-Confirmation flashing of the central locking system when locking,active ,8
MAS12382-ENG122206-Dynamic turn signal control-DWA_Schaerfungsquittung,active ,8
MAS12382-ENG142195-Dynamic turn signal control-Dynamische_Blink_Delay,50 ms,8
MAS12382-ENG261058-Dynamic turn signal control-IPA_RPA_Blinkbest tugung,active ,8
MAS12382-ENG260850-Dynamic turn signal control-IPA_RPA_blinken_links,active ,8
MAS12382-ENG258687-Dynamic turn signal control-IPA_RPA_blinken_rechts,active ,8
MAS12382-ENG260708-Dynamic turn signal control-Multikollisions_blinken,not active ,8
MAS12382-ENG122209-Dynamic turn signal control-Notwarn_blinken_NBA_Phase_2,active ,8
MAS12382-ENG122211-Dynamic turn signal control-Richtungs_blinken_links,active ,8
MAS12382-ENG122210-Dynamic turn signal control-Richtungs_blinken_rechts,active ,8
MAS12382-ENG260812-Dynamic turn signal control-SWA_blinken_links,active ,8
MAS12382-ENG260466-Dynamic turn signal control-SWA_blinken_rechts,active ,8
MAS12382-ENG122214-Dynamic turn signal control-Warnblinken_Zuendung_AUS,active ,8
MAS12382-ENG122213-Dynamic turn signal control-Warnblinken_Zuendung_EIN,active ,8
MAS13139-MAS13135-Button 4-Function of button 4,not coded / not installed ,1
MAS13139-MAS13136-Button 4-Indicator lamp button 4,installed ,1
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,No Response From Subnet Component,1
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,No Response From Subnet Component,1
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,No Response From Subnet Component,1
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,No Response From Subnet Component,1
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,No Response From Subnet Component,1
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,No Response From Subnet Component,1
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,No Response From Subnet Component,1
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,No Response From Subnet Component,1
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,No Response From Subnet Component,1
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,No Response From Subnet Component,1
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,No Response From Subnet Component,1
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,No Response From Subnet Component,1
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,No Response From Subnet Component,1
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,No Response From Subnet Component,1
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,No Response From Subnet Component,1
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,No Response From Subnet Component,1
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,No Response From Subnet Component,1
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,No Response From Subnet Component,1
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,No Response From Subnet Component,1
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,No Response From Subnet Component,1
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,No Response From Subnet Component,1
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,No Response From Subnet Component,1
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,No Response From Subnet Component,1
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,No Response From Subnet Component,1
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,No Response From Subnet Component,1
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,No Response From Subnet Component,1
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,No Response From Subnet Component,1
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,No Response From Subnet Component,1
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,No Response From Subnet Component,1
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,No Response From Subnet Component,1
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,No Response From Subnet Component,1
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,No Response From Subnet Component,1
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,No Response From Subnet Component,1
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,No Response From Subnet Component,1
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,No Response From Subnet Component,1
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,No Response From Subnet Component,1
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,No Response From Subnet Component,1
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,No Response From Subnet Component,1
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,No Response From Subnet Component,1
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,No Response From Subnet Component,1
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,No Response From Subnet Component,1
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,No Response From Subnet Component,1
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,No Response From Subnet Component,1
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,No Response From Subnet Component,1
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,No Response From Subnet Component,1
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,No Response From Subnet Component,1
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,No Response From Subnet Component,1
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,No Response From Subnet Component,1
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,No Response From Subnet Component,1
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,No Response From Subnet Component,1
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,No Response From Subnet Component,1
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,No Response From Subnet Component,1
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,No Response From Subnet Component,1
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,No Response From Subnet Component,1
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,No Response From Subnet Component,1
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,No Response From Subnet Component,1
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,No Response From Subnet Component,1
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle model,No Response From Subnet Component,1
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,No Response From Subnet Component,1
MAS14140-IDE15905-Flashing function-Travel Assist,not active ,4
MAS14140-ENG154601-Flashing function-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken_Bremsblinken ,4
MAS14140-ENG259090-Flashing function-Hupen_durch_Fahrerassistenz,active ,4
MAS14140-ENG142029-Flashing function-Warnblinken_durch_Fahrerassistenz,active ,4
MAS18831-IDE80001-Control module for optical rear lid opening: dataset-Analysis 1,No Response From Subnet Component,4
MAS18831-IDE80002-Control module for optical rear lid opening: dataset-Analysis 2,No Response From Subnet Component,4
MAS18831-IDE80003-Control module for optical rear lid opening: dataset-Analysis 3,No Response From Subnet Component,4
MAS18831-IDE80004-Control module for optical rear lid opening: dataset-Analysis 4,No Response From Subnet Component,4
MAS18831-IDE80005-Control module for optical rear lid opening: dataset-Analysis 5,No Response From Subnet Component,4
MAS18831-IDE80006-Control module for optical rear lid opening: dataset-Analysis 6,No Response From Subnet Component,4
MAS18831-IDE80007-Control module for optical rear lid opening: dataset-Analysis 7,No Response From Subnet Component,4
MAS18831-IDE80008-Control module for optical rear lid opening: dataset-Analysis 8,No Response From Subnet Component,4
MAS18831-IDE80009-Control module for optical rear lid opening: dataset-Analysis 9,No Response From Subnet Component,4
MAS18831-IDE80010-Control module for optical rear lid opening: dataset-Analysis 10,No Response From Subnet Component,4
MAS18831-IDE80011-Control module for optical rear lid opening: dataset-Analysis 11,No Response From Subnet Component,4
MAS18831-IDE80012-Control module for optical rear lid opening: dataset-Analysis 12,No Response From Subnet Component,4
MAS18831-IDE80013-Control module for optical rear lid opening: dataset-Analysis 13,No Response From Subnet Component,4
MAS18831-IDE80014-Control module for optical rear lid opening: dataset-Analysis 14,No Response From Subnet Component,4
MAS18831-IDE80015-Control module for optical rear lid opening: dataset-Analysis 15,No Response From Subnet Component,4
MAS18831-IDE80016-Control module for optical rear lid opening: dataset-Analysis 16,No Response From Subnet Component,4
MAS18831-IDE80017-Control module for optical rear lid opening: dataset-Analysis 17,No Response From Subnet Component,4
MAS18831-IDE80018-Control module for optical rear lid opening: dataset-Analysis 18,No Response From Subnet Component,4
MAS18831-IDE80019-Control module for optical rear lid opening: dataset-Analysis 19,No Response From Subnet Component,4
MAS18831-IDE80020-Control module for optical rear lid opening: dataset-Analysis 20,No Response From Subnet Component,4
MAS18831-IDE80021-Control module for optical rear lid opening: dataset-Analysis 21,No Response From Subnet Component,4
MAS18831-IDE80022-Control module for optical rear lid opening: dataset-Analysis 22,No Response From Subnet Component,4
MAS18831-IDE80023-Control module for optical rear lid opening: dataset-Analysis 23,No Response From Subnet Component,4
MAS18831-IDE80024-Control module for optical rear lid opening: dataset-Analysis 24,No Response From Subnet Component,4
MAS18831-IDE80025-Control module for optical rear lid opening: dataset-Analysis 25,No Response From Subnet Component,4
MAS18831-IDE80026-Control module for optical rear lid opening: dataset-Analysis 26,No Response From Subnet Component,4
MAS18831-IDE80027-Control module for optical rear lid opening: dataset-Analysis 27,No Response From Subnet Component,4
MAS18831-IDE80028-Control module for optical rear lid opening: dataset-Analysis 28,No Response From Subnet Component,4
MAS18831-IDE80029-Control module for optical rear lid opening: dataset-Analysis 29,No Response From Subnet Component,4
MAS18831-IDE80030-Control module for optical rear lid opening: dataset-Analysis 30,No Response From Subnet Component,4
MAS18831-IDE80031-Control module for optical rear lid opening: dataset-Analysis 31,No Response From Subnet Component,4
MAS18831-IDE80032-Control module for optical rear lid opening: dataset-Analysis 32,No Response From Subnet Component,4
MAS18831-IDE80033-Control module for optical rear lid opening: dataset-Analysis 33,No Response From Subnet Component,4
MAS18831-IDE80034-Control module for optical rear lid opening: dataset-Analysis 34,No Response From Subnet Component,4
MAS18831-IDE80035-Control module for optical rear lid opening: dataset-Analysis 35,No Response From Subnet Component,4
MAS18831-IDE80036-Control module for optical rear lid opening: dataset-Analysis 36,No Response From Subnet Component,4
MAS18831-IDE80037-Control module for optical rear lid opening: dataset-Analysis 37,No Response From Subnet Component,4
MAS18831-IDE80038-Control module for optical rear lid opening: dataset-Analysis 38,No Response From Subnet Component,4
MAS18831-IDE80039-Control module for optical rear lid opening: dataset-Analysis 39,No Response From Subnet Component,4
MAS18831-IDE80040-Control module for optical rear lid opening: dataset-Analysis 40,No Response From Subnet Component,4
MAS18831-IDE80041-Control module for optical rear lid opening: dataset-Analysis 41,No Response From Subnet Component,4
MAS18831-IDE80042-Control module for optical rear lid opening: dataset-Analysis 42,No Response From Subnet Component,4
MAS18831-IDE80043-Control module for optical rear lid opening: dataset-Analysis 43,No Response From Subnet Component,4
MAS18831-IDE80044-Control module for optical rear lid opening: dataset-Analysis 44,No Response From Subnet Component,4
MAS18831-IDE80045-Control module for optical rear lid opening: dataset-Analysis 45,No Response From Subnet Component,4
MAS18831-IDE80046-Control module for optical rear lid opening: dataset-Analysis 46,No Response From Subnet Component,4
MAS18831-IDE80047-Control module for optical rear lid opening: dataset-Analysis 47,No Response From Subnet Component,4
MAS18831-IDE80048-Control module for optical rear lid opening: dataset-Analysis 48,No Response From Subnet Component,4
MAS18831-IDE80049-Control module for optical rear lid opening: dataset-Analysis 49,No Response From Subnet Component,4
MAS18831-IDE80050-Control module for optical rear lid opening: dataset-Analysis 50,No Response From Subnet Component,4
MAS18831-IDE80051-Control module for optical rear lid opening: dataset-Analysis 51,No Response From Subnet Component,4
MAS18831-IDE80052-Control module for optical rear lid opening: dataset-Analysis 52,No Response From Subnet Component,4
MAS18831-IDE80053-Control module for optical rear lid opening: dataset-Analysis 53,No Response From Subnet Component,4
MAS18831-IDE80054-Control module for optical rear lid opening: dataset-Analysis 54,No Response From Subnet Component,4
MAS18831-IDE80055-Control module for optical rear lid opening: dataset-Analysis 55,No Response From Subnet Component,4
MAS18831-IDE80056-Control module for optical rear lid opening: dataset-Analysis 56,No Response From Subnet Component,4
MAS18831-IDE80057-Control module for optical rear lid opening: dataset-Analysis 57,No Response From Subnet Component,4
MAS18831-IDE80058-Control module for optical rear lid opening: dataset-Analysis 58,No Response From Subnet Component,4
MAS18831-IDE80059-Control module for optical rear lid opening: dataset-Analysis 59,No Response From Subnet Component,4
MAS18831-IDE80060-Control module for optical rear lid opening: dataset-Analysis 60,No Response From Subnet Component,4
MAS20279-WFS transponder gateway coding,Transponder GW in Kessy OK box ,4
SFT00061-MAS10520-Special Function-Special function 1,not installed ,4
SFT00061-SFT00048-Special Function-Special Function 2,not enabled ,4
SFT00061-ENG260472-Special Function-Blinkerueberwachug_Sonderfunktions_SG,not installed ,4
ENG253311-IDE01058-604 UGDO Sender-Country coding,No Response From Subnet Component,4
ENG253311-MAS07183-604 UGDO Sender-Oper. concept,No Response From Subnet Component,4
ENG253311-MAS07186-604 UGDO Sender-Multimedia system,No Response From Subnet Component,4
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,0 ,9
ENG253358-ENG258212-Anpassungen_Exterior_Light-Delay_Max,10 ms,270
ENG253358-ENG259279-Anpassungen_Exterior_Light-Events_Szene_1,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260085-Anpassungen_Exterior_Light-Events_Szene_10,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260997-Anpassungen_Exterior_Light-Events_Szene_11,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258638-Anpassungen_Exterior_Light-Events_Szene_12,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259456-Anpassungen_Exterior_Light-Events_Szene_13,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260535-Anpassungen_Exterior_Light-Events_Szene_14,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259560-Anpassungen_Exterior_Light-Events_Szene_15,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259132-Anpassungen_Exterior_Light-Events_Szene_16,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260337-Anpassungen_Exterior_Light-Events_Szene_17,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259462-Anpassungen_Exterior_Light-Events_Szene_18,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258627-Anpassungen_Exterior_Light-Events_Szene_19,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260067-Anpassungen_Exterior_Light-Events_Szene_2,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259484-Anpassungen_Exterior_Light-Events_Szene_20,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260587-Anpassungen_Exterior_Light-Events_Szene_21,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260042-Anpassungen_Exterior_Light-Events_Szene_22,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259549-Anpassungen_Exterior_Light-Events_Szene_23,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260635-Anpassungen_Exterior_Light-Events_Szene_24,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258179-Anpassungen_Exterior_Light-Events_Szene_25,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259599-Anpassungen_Exterior_Light-Events_Szene_26,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260140-Anpassungen_Exterior_Light-Events_Szene_27,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258932-Anpassungen_Exterior_Light-Events_Szene_28,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258855-Anpassungen_Exterior_Light-Events_Szene_29,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259951-Anpassungen_Exterior_Light-Events_Szene_3,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259306-Anpassungen_Exterior_Light-Events_Szene_30,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260976-Anpassungen_Exterior_Light-Events_Szene_31,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260284-Anpassungen_Exterior_Light-Events_Szene_32,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260168-Anpassungen_Exterior_Light-Events_Szene_4,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259646-Anpassungen_Exterior_Light-Events_Szene_5,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260432-Anpassungen_Exterior_Light-Events_Szene_6,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259181-Anpassungen_Exterior_Light-Events_Szene_7,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG258154-Anpassungen_Exterior_Light-Events_Szene_8,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG260860-Anpassungen_Exterior_Light-Events_Szene_9,FF FF FF FF FF FF FF FF ,270
ENG253358-ENG259092-Anpassungen_Exterior_Light-MappingArray,119 ,270
ENG253358-ENG263521-Anpassungen_Exterior_Light-MappingArray_Umfeld,2055 ,270
ENG253358-ENG258812-Anpassungen_Exterior_Light-p_Abstand_IDG_Inszenierung,24.2 m,270
ENG253358-ENG258950-Anpassungen_Exterior_Light-p_Kessy_ID,not active ,270
ENG253358-ENG289605-Anpassungen_Exterior_Light-p_vip30_Dimmung_SalR,00 ,270
ENG253358-ENG289606-Anpassungen_Exterior_Light-p_vip30_Dimmung_TSG,00 ,270
ENG253358-ENG289607-Anpassungen_Exterior_Light-p_vip30_Dimmzeit,0 ms,270
ENG253358-ENG259215-Anpassungen_Exterior_Light-pa_ambExtLight_Installation,not active ,270
ENG253358-ENG258160-Anpassungen_Exterior_Light-pa_ext_Ambiente,not active ,270
ENG253358-ENG260968-Anpassungen_Exterior_Light-Passive_Timeout,600.00 s,270
ENG253358-ENG258460-Anpassungen_Exterior_Light-PSO_active_participant_ambient_lighting_exterieur_enabled,active ,270
ENG253358-ENG261089-Anpassungen_Exterior_Light-Verzoegerung_Blinken,not active ,270
ENG253146-ENG141986-Aussenlicht-SG-Architektur-Abblendlicht_Leuchtentyp,H7 ,8
ENG253146-ENG258089-Aussenlicht-SG-Architektur-Abschaltung Redundanzpfad Pr fung,active ,8
ENG253146-ENG141987-Aussenlicht-SG-Architektur-Bremslicht_ist_auch_Blinklicht,Yes ,8
ENG253146-ENG259743-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_1,FF ,8
ENG253146-ENG260787-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_2,FF ,8
ENG253146-ENG259890-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT55_3,FF ,8
ENG253146-ENG260564-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_1,FF ,8
ENG253146-ENG258294-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_2,FF ,8
ENG253146-ENG259373-Aussenlicht-SG-Architektur-Lichtfunktion_OL_Diagnose_LT56_3,FF ,8
ENG253146-ENG115861-Aussenlicht-SG-Architektur-Lichthupe bei Zuendung aus moeglich,not active ,8
ENG253146-ENG115832-Aussenlicht-SG-Architektur-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,8
ENG253146-ENG115831-Aussenlicht-SG-Architektur-Schlusslicht mit Bremslichtfunktion,not active ,8
ENG253146-ENG115860-Aussenlicht-SG-Architektur-Zahl der aktiven Scheinwerfer auf 2 limitieren,limited ,8
ENG253356-ENG258933-Automatische_Funktionen-Automatik_Funktionen_Warnungen_aktiv,not activated ,4
ENG253356-ENG258835-Automatische_Funktionen-Automatik_Funktionen_WarnungWenn_AusserhalbExitBereich_aktiv,not activated ,4
ENG253356-ENG260748-Automatische_Funktionen-AutomatikFunktionen_WarnungWenn_VerlassenBeiHautNichtGeschlossen_aktiv,not activated ,4
ENG253356-ENG281101-Automatische_Funktionen-AutomatikFunktionen_WarnungWennIDGeberImInnenraum_aktiv,not activated ,4
ENG253356-ENG258145-Automatische_Funktionen-AutomatischeFunktionen_Beschleunigtes_Entry_aktiv,not activated ,4
ENG253356-ENG260562-Automatische_Funktionen-Automatisches_Entriegeln_aktiv,not activated ,4
ENG253356-ENG260693-Automatische_Funktionen-Automatisches_Verriegeln_aktiv,not activated ,4
ENG253240-ENG263541-Automatisierte Abschaltungen-Abschalt_verz gerungs_zeit,60 s,8
ENG253240-ENG263514-Automatisierte Abschaltungen-Abschalt_wunsch_entprellung,1.0 s,8
ENG253240-ENG259987-Automatisierte Abschaltungen-Abschaltung nur in P,Alle Fahrstufen ,8
ENG253240-ENG277086-Automatisierte Abschaltungen-Dauer f r Ausf hrung des Abschaltwunsch an SPN,2.0 s,8
ENG253240-ENG277087-Automatisierte Abschaltungen-Dauer Hinweistext Komfortabschaltung,10.0 s,8
ENG253240-ENG259819-Automatisierte Abschaltungen-Signalisierungsdauer Automatische Abschaltung erfolgt,5.0 s,8
ENG253240-ENG258392-Automatisierte Abschaltungen-Stillstandsdrehzahlschwelle Verbrennungsmotor,400 ,8
ENG253240-ENG258639-Automatisierte Abschaltungen-Verf gbarkeit Komfortabschaltung,Available ,8
ENG253240-ENG258110-Automatisierte Abschaltungen-Z ndungsabschaltung ber Energiemanagement,Available ,8
ENG253240-ENG126843-Automatisierte Abschaltungen-ZV verriegeln bei Klemme 15 Ein,active ,8
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,No Response From Subnet Component,8
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,No Response From Subnet Component,8
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,8
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,No Response From Subnet Component,8
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,No Response From Subnet Component,8
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,No Response From Subnet Component,8
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,No Response From Subnet Component,8
ENG253018-Clamp_Control,Driver s door ,1
ENG253221-ENG259820-Clamp_Coordinator-Clamp_Coordinator_priority_AAA,100 ,40
ENG253221-ENG260325-Clamp_Coordinator-Clamp_Coordinator_priority_DIAG,200 ,40
ENG253221-ENG260088-Clamp_Coordinator-Clamp_Coordinator_priority_MWS,10 ,40
ENG253221-ENG259040-Clamp_Coordinator-Clamp_Coordinator_priority_ORU,1 ,40
ENG253221-ENG259149-Clamp_Coordinator-Clamp_Coordinator_priority_PHP,100 ,40
ENG253221-ENG261099-Clamp_Coordinator-Clamp_Coordinator_priority_RPA,100 ,40
ENG253221-ENG258680-Clamp_Coordinator-Clamp_Coordinator_priority_RWK,100 ,40
ENG253221-ENG260388-Clamp_Coordinator-Clamp_Coordinator_priority_SPN,10 ,40
ENG253221-ENG259706-Clamp_Coordinator-Clamp_Coordinator_priority_ZAS,10 ,40
ENG253350-ENG258402-Coding_seat_pneumatics_driver_side-Function_easy_entry,No Response From Subnet Component,40
ENG253350-ENG260372-Coding_seat_pneumatics_driver_side-Function_massage,No Response From Subnet Component,40
ENG253350-ENG260893-Coding_seat_pneumatics_driver_side-Function_memory,No Response From Subnet Component,40
ENG253350-ENG261225-Coding_seat_pneumatics_driver_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253350-ENG259055-Coding_seat_pneumatics_driver_side-Function_off_delay,No Response From Subnet Component,40
ENG253350-ENG259290-Coding_seat_pneumatics_driver_side-Function_personalisation,No Response From Subnet Component,40
ENG253350-ENG259372-Coding_seat_pneumatics_driver_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253350-ENG259654-Coding_seat_pneumatics_driver_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253350-ENG259159-Coding_seat_pneumatics_driver_side-Function_race_mode,No Response From Subnet Component,40
ENG253350-ENG261329-Coding_seat_pneumatics_driver_side-Function_side_support,No Response From Subnet Component,40
ENG253350-ENG258695-Coding_seat_pneumatics_driver_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253175-ENG258402-Coding_seat_pneumatics_passenger_side-Function_easy_entry,No Response From Subnet Component,40
ENG253175-ENG260372-Coding_seat_pneumatics_passenger_side-Function_massage,No Response From Subnet Component,40
ENG253175-ENG260893-Coding_seat_pneumatics_passenger_side-Function_memory,No Response From Subnet Component,40
ENG253175-ENG261225-Coding_seat_pneumatics_passenger_side-Function_off_autocorrection,No Response From Subnet Component,40
ENG253175-ENG259055-Coding_seat_pneumatics_passenger_side-Function_off_delay,No Response From Subnet Component,40
ENG253175-ENG259290-Coding_seat_pneumatics_passenger_side-Function_personalisation,No Response From Subnet Component,40
ENG253175-ENG259372-Coding_seat_pneumatics_passenger_side-Function_pre_crash_lordosis,No Response From Subnet Component,40
ENG253175-ENG259654-Coding_seat_pneumatics_passenger_side-Function_precrash_side_support,No Response From Subnet Component,40
ENG253175-ENG259159-Coding_seat_pneumatics_passenger_side-Function_race_mode,No Response From Subnet Component,40
ENG253175-ENG261329-Coding_seat_pneumatics_passenger_side-Function_side_support,No Response From Subnet Component,40
ENG253175-ENG258695-Coding_seat_pneumatics_passenger_side-Level_self_diagnostics,No Response From Subnet Component,40
ENG253229-ENG258467-Define_Const-Dimm2Bin,1 %,4
ENG253229-ENG259386-Define_Const-Dimmzeit_SAL_Umfeld,1.00 s,4
ENG253229-ENG253468-Define_Const-Gamma,2.0 ,4
ENG253142-ENG258099-Design_switching-Display_Nachtdesign-Umschaltung,Standlicht/Fahrlicht_u_RLS ,5
ENG253142-ENG261004-Design_switching-RLS_Nachtdesign_Schwelle,20 ,5
ENG253142-ENG260371-Design_switching-RLS_Tagdesign_Schwelle,100 ,5
ENG253142-ENG258254-Design_switching-Werteanzahl_Mittelwert,100 ,5
ENG253142-ENG260585-Design_switching-Werteanzahl_Mittelwert_Start-,05 ,5
ENG253216-MAS18908-DevCod_Automatische_Verriegelung-Terminal 15: behavior of the automatic locking function,Function only allowed for terminal 15 off ,6
ENG253216-ENG261088-DevCod_Automatische_Verriegelung-AutomatikFunktionen_HVLaden_EigenerBereich_aktiv,not activated ,6
ENG253216-ENG258169-DevCod_Automatische_Verriegelung-AutomatikFunktionen_Sonderfall_ZyklischeSucheBeiKlemme15_aktiv,not_activated ,6
ENG253216-ENG277085-DevCod_Automatische_Verriegelung-Automatische_FunktionBeiAnnaeherung_Entfernung_aktiv,activated ,6
ENG253028-DevCod_Bedienstellen,not activated ,1
ENG253195-IDE04159-DevCod_Dienste_Byte1-Deactivation of start/stop function,not active ,6
ENG253195-ENG281096-DevCod_Dienste_Byte1-Entry_Deaktivierung_aktiv,not activated ,6
ENG253195-ENG258846-DevCod_Dienste_Byte1-Entry_GoDeaktivierung_Aktivierungs_Variante,not activated ,6
ENG253195-ENG258351-DevCod_Dienste_Byte1-ErkennungFahrzeug_Verlassen_aktiv,activated ,6
ENG253195-ENG261030-DevCod_Dienste_Byte1-ErkennungFahrzeug_Zugang_aktiv,activated ,6
ENG253195-ENG260255-DevCod_Dienste_Byte1-ErkennungFahrzeugZugang_bei_Remotestart,activated ,6
ENG253195-ENG259070-DevCod_Dienste_Byte1-ErkennungFahrzeugZugangVerlassen_Triggerung_aktiv,activated ,6
ENG253102-ENG258819-DevCod_Dienste_Byte2-BereichsueberwachungPilotiertesParken_Variante,not activated ,6
ENG253102-ENG259756-DevCod_Dienste_Byte2-BewussteGesamtEntriegelung_aktiv,not activated ,6
ENG253102-ENG261309-DevCod_Dienste_Byte2-Paketbotenmodus_aktiv,not activated ,6
ENG253102-ENG277103-DevCod_Dienste_Byte2-RSAD_Krypto_Checks_aktivieren,activated ,6
ENG253102-ENG259641-DevCod_Dienste_Byte2-RSADMassnahme_aussen_aktiv,not activated ,6
ENG253102-ENG259949-DevCod_Dienste_Byte2-RSADMassnahme_innen_aktiv,not activated ,6
ENG253102-ENG260061-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_aktiv,not activated ,6
ENG253102-ENG259459-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_NichtKessyEntr_aktiv,not activated ,6
ENG253102-ENG259282-DevCod_Dienste_Byte2-ScanFuerPersonalisierungUndSitzmemory_OeffnenFT_aktiv,not activated ,6
ENG253202-ENG259475-DevCod_Dienste_Byte3-VIT_close,not activated ,6
ENG253202-ENG259049-DevCod_Dienste_Byte3-VIT_KESSY_Inversbit,not activated ,6
ENG253296-ENG259208-DevCod_Fahrzeugkonfiguration_Byte1-BEM_verbaut,activated ,6
ENG253296-ENG174999-DevCod_Fahrzeugkonfiguration_Byte1-Convertible,not activated ,6
ENG253296-ENG259388-DevCod_Fahrzeugkonfiguration_Byte1-HBFS_Schiebetuer,not activated ,6
ENG253296-ENG259603-DevCod_Fahrzeugkonfiguration_Byte1-HFS_Schiebetuer,not activated ,6
ENG253296-ENG260764-DevCod_Fahrzeugkonfiguration_Byte1-NFZ_mit_2Zonen,not activated ,6
ENG253296-ENG259616-DevCod_Fahrzeugkonfiguration_Byte1-Reaktivierung_all_Tueren_VK2,not activated ,6
ENG253183-ENG259579-DevCod_Fahrzeugkonfiguration_Byte2-Softtouch_verbaut,installed ,6
ENG253183-ENG277104-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_1_aktiv,not activated ,6
ENG253183-ENG277105-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_2_aktiv,not activated ,6
ENG253183-ENG277106-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_3_aktiv,not activated ,6
ENG253183-ENG277107-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_4_aktiv,not activated ,6
ENG253183-ENG277108-DevCod_Fahrzeugkonfiguration_Byte2-Sonderfunktion_5_aktiv,not activated ,6
ENG253183-ENG141964-DevCod_Fahrzeugkonfiguration_Byte2-Steering assignment,Left ,6
ENG253369-ENG260810-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Fahrertuer,activated ,6
ENG253369-ENG258777-DevCod_IDGeber_Suche-Innenraumsuche_Kl15_bei_Verdeck_offen,not activated ,6
ENG253369-ENG258088-DevCod_IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_Schlie verhinderung,activated ,6
ENG253369-ENG258863-DevCod_IDGeber_Suche-InnenraumsucheMitEEAuth_Variante,not activated ,6
ENG253369-ENG281080-DevCod_IDGeber_Suche-Unterdrueckung_zyklischer _Suchen_bei_entriegeltem_Fahrzeug_aktiv,activated ,6
ENG253170-ENG281102-DevCod_Nutzerkonfigurationen-HMIMenue_Aktivierung_Nah_Mittel_Fern_aktiv,not activated ,6
ENG253170-ENG259272-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_Advanced_aktiv,not activated ,6
ENG253170-ENG258478-DevCod_Nutzerkonfigurationen-HMIMenue_Keyless_aktiv,not activated ,6
ENG253170-ENG281078-DevCod_Nutzerkonfigurationen-HMIMenue_Nutzer_Warnung_AutomatikFunktion_aktiv,not activated ,6
ENG253247-IDE02474-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive entry exit function,Function only allowed for terminal 15 off ,7
ENG253247-MAS18909-DevCod_Passive_EntryExit_Toggle-Terminal 15: behavior of the unlock/lock button function,not activated ,7
ENG253247-MAS18910-DevCod_Passive_EntryExit_Toggle-Terminal 15 characteristics of passive exit function,Function only allowed for terminal 15 off ,7
ENG253247-ENG260696-DevCod_Passive_EntryExit_Toggle-FunkkommunikationFuerPassiveEntryExit_Wiederholung_aktiv,not activated ,7
ENG253247-ENG261245-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offenen_Tueren,activated ,7
ENG253247-ENG261070-DevCod_Passive_EntryExit_Toggle-Passive_Exit_bei_offener_Zugangstuer,not activated ,7
ENG253247-ENG258791-DevCod_Passive_EntryExit_Toggle-Passive_Toggle_bei_offenen_Tueren,not activated ,7
ENG253247-ENG260751-DevCod_Passive_EntryExit_Toggle-PassiveEntryExit_aktiv,not activated ,7
ENG253117-ENG260289-DevCod_Passive_Go-Innenraumsuche_IDGeberFreigeben_bei_Remotestart,not activated ,6
ENG253117-ENG259313-DevCod_Passive_Go-PassiveGo_bei_offener_Heckklappe,activated ,6
ENG253117-ENG261220-DevCod_Passive_Go-PassiveGo_bei_offener_Schiebet r,activated ,6
ENG253197-ENG260990-Diebstahlschutz Schnittstelle-DWA_HSB_HSK_ueberwachung_aktiv,not active ,6
ENG253197-ENG258293-Diebstahlschutz Schnittstelle-DWA_mit_Einfachhorn,not installed ,6
ENG253197-ENG258890-Diebstahlschutz Schnittstelle-DWA_mit_NGS,not active ,6
ENG253197-ENG258731-Diebstahlschutz Schnittstelle-DWA_ohne_Thatcham,limited ,6
ENG253197-ENG258944-Diebstahlschutz Schnittstelle-DWA_Scheinwerferueberwachung_aktiv,not active ,6
ENG253197-ENG258663-Diebstahlschutz Schnittstelle-DWA_verbaut,installed ,6
ENG253197-ENG258162-Diebstahlschutz Schnittstelle-IRUE_NGS_Deaktivierung_via_MMI,not active ,6
ENG253197-ENG261022-Diebstahlschutz Schnittstelle-Irue_verbaut,not installed ,6
ENG253197-ENG261072-Diebstahlschutz Schnittstelle-Sirene_alarmzahl,10_Alarme ,6
ENG253197-ENG260442-Diebstahlschutz Schnittstelle-Verbau_Deaktivierungstaster_DWA_Sensor,not active ,6
ENG253244-MAS10115-Diebstahlschutz.Modulsoftware-Anti-theft blinkers by inter. door handle activ.,OFF ,6
ENG253244-Diebstahlschutz.Modulsoftware-,not active ,6
ENG253244-ENG258423-Diebstahlschutz.Modulsoftware-Akustischer Alarm ueber Hupe,active ,6
ENG253244-ENG258401-Diebstahlschutz.Modulsoftware-Anhaengerueberwachung_aktiv,not active ,6
ENG253244-ENG146510-Diebstahlschutz.Modulsoftware-beeptime,10_ms ,6
ENG253244-ENG260066-Diebstahlschutz.Modulsoftware-dwa_alarm_ton,frequency_modulated ,6
ENG253244-ENG258606-Diebstahlschutz.Modulsoftware-DWA_campermode,not active ,6
ENG253244-ENG260322-Diebstahlschutz.Modulsoftware-DWA_Verdeckoeffnungsueberwachung_aktiv,not active ,6
ENG253244-ENG261182-Diebstahlschutz.Modulsoftware-IRUE_NGS_bewusst_entschaerfen,active ,6
ENG253365-ENG260723-Dienste-BeeinflussungStartStopp_aktiv,not activated ,4
ENG253365-ENG258656-Dienste-BereichsueberwachungPilotiertesParken_aktiv,not activated ,4
ENG253365-ENG259029-Dienste-EntryGoDeaktivierung_Nutzerkonfiguration_aktiv,activated ,4
ENG253365-ENG260489-Dienste-EntryGoDeaktivierung_Quittierung_aktiv,not activated ,4
ENG253365-ENG258571-Dienste-GenerischeOrtung_aktiv,not activated ,4
ENG253365-ENG260124-Dienste-Keyfinder_Aussen_aktiv,not activated ,4
ENG253365-ENG259116-Dienste-Keyfinder_Innen_aktiv,not activated ,4
ENG253144-ENG259520-Dimmung (der Suchbeleuchtung Kl. 58)-p_delta_KL58D_min,3.0 %,21
ENG253144-ENG253461-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xd,160 %,21
ENG253144-ENG253462-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xs,160 %,21
ENG253144-ENG253463-Dimmung (der Suchbeleuchtung Kl. 58)-p_Fehlerwert_Kl_58xt,160 %,21
ENG253144-ENG259127-Dimmung (der Suchbeleuchtung Kl. 58)-p_Kl_58xk_Schrittanzahl_kurzer_Tastendruck,10 ,21
ENG253144-ENG261206-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_max,90.0 %,21
ENG253144-ENG258780-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_min,10.0 %,21
ENG253144-ENG259198-Dimmung (der Suchbeleuchtung Kl. 58)-p_kl58d_poti_uin_tol,5.0 %,21
ENG253144-ENG261308-Dimmung (der Suchbeleuchtung Kl. 58)-p_langer_Tastendruck,1.0 s,21
ENG253144-ENG260197-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xs_Nachlauf_lang,900 s,21
ENG253144-ENG261144-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Kl_58xt_Nachlauf_kurz,30 s,21
ENG253144-ENG258180-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Master,10 min,21
ENG253144-ENG253464-Dimmung (der Suchbeleuchtung Kl. 58)-p_timer_Netz_Nachlauf_Slave,12 min,21
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,No Response From Subnet Component,21
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,No Response From Subnet Component,21
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,No Response From Subnet Component,21
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,21
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,21
ENG133364-ENG133507-Driver_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,21
ENG133364-ENG133526-Driver_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,21
ENG133364-ENG133528-Driver_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,21
ENG133364-ENG133500-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133499-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,21
ENG133364-ENG133502-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133501-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,21
ENG133364-ENG133504-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133503-Driver_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,21
ENG133364-ENG133511-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,21
ENG133364-ENG133508-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,21
ENG133364-ENG133509-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,21
ENG133364-ENG133510-Driver_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,21
ENG133364-ENG133524-Driver_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,21
ENG133364-ENG133525-Driver_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,21
ENG133364-ENG133506-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,21
ENG133364-ENG133505-Driver_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,21
ENG133364-ENG133531-Driver_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,21
ENG133364-ENG133512-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,21
ENG133364-ENG133515-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,21
ENG133364-ENG133518-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,21
ENG133364-ENG133521-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,21
ENG133364-ENG133513-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,21
ENG133364-ENG133516-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,21
ENG133364-ENG133519-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,21
ENG133364-ENG133522-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,21
ENG133364-ENG133514-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,21
ENG133364-ENG133517-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,21
ENG133364-ENG133520-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,21
ENG133364-ENG133523-Driver_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,21
ENG133364-ENG133529-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,21
ENG133364-ENG133530-Driver_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,21
ENG133364-ENG133527-Driver_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,21
ENG286142-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,21
ENG286142-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,21
ENG286142-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,21
ENG286142-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,21
ENG286142-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,21
ENG286142-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,21
ENG286142-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,21
ENG286142-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,21
ENG286142-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,21
ENG286142-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,21
ENG286142-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,21
ENG286142-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,21
ENG286142-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,21
ENG286142-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,21
ENG286142-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,21
ENG286142-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,21
ENG286142-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,21
ENG286142-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,21
ENG286142-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,21
ENG286142-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,21
ENG286142-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,21
ENG286142-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,21
ENG286142-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,21
ENG286142-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,21
ENG286142-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,21
ENG286142-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,21
ENG286142-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,21
ENG286142-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,21
ENG286142-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,21
ENG286142-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,21
ENG286142-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,21
ENG286142-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,21
ENG286142-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,21
ENG286142-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,21
ENG286142-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,21
ENG286142-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,21
ENG286142-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,21
ENG286142-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,21
ENG286142-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,21
ENG286142-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,21
ENG286142-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,21
ENG286142-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,21
ENG286142-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,21
ENG286142-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,21
ENG286142-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,21
ENG286142-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,21
ENG286142-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,21
ENG286142-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,21
ENG286142-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,21
ENG286142-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,21
ENG286142-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,21
ENG286142-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,21
ENG286142-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,21
ENG286142-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,21
ENG286142-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,21
ENG286142-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,21
ENG286142-IDE80057-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,21
ENG286142-IDE80058-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,21
ENG286142-IDE80059-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,21
ENG286142-IDE80060-drivers_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,21
ENG286143-IDE00047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,21
ENG286143-IDE80001-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,21
ENG286143-IDE80002-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,21
ENG286143-IDE80003-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,21
ENG286143-IDE80004-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,21
ENG286143-IDE80005-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,21
ENG286143-IDE80006-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,21
ENG286143-IDE80007-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,21
ENG286143-IDE80008-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,21
ENG286143-IDE80009-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,21
ENG286143-IDE80010-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,21
ENG286143-IDE80011-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,21
ENG286143-IDE80012-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,21
ENG286143-IDE80013-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,21
ENG286143-IDE80014-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,21
ENG286143-IDE80015-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,21
ENG286143-IDE80016-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,21
ENG286143-IDE80017-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,21
ENG286143-IDE80018-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,21
ENG286143-IDE80019-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,21
ENG286143-IDE80020-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,21
ENG286143-IDE80021-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,21
ENG286143-IDE80022-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,21
ENG286143-IDE80023-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,21
ENG286143-IDE80024-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,21
ENG286143-IDE80025-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,21
ENG286143-IDE80026-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,21
ENG286143-IDE80027-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,21
ENG286143-IDE80028-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,21
ENG286143-IDE80029-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,21
ENG286143-IDE80030-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,21
ENG286143-IDE80031-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,21
ENG286143-IDE80032-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,21
ENG286143-IDE80033-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,21
ENG286143-IDE80034-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,21
ENG286143-IDE80035-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,21
ENG286143-IDE80036-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,21
ENG286143-IDE80037-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,21
ENG286143-IDE80038-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,21
ENG286143-IDE80039-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,21
ENG286143-IDE80040-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,21
ENG286143-IDE80041-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,21
ENG286143-IDE80042-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,21
ENG286143-IDE80043-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,21
ENG286143-IDE80044-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,21
ENG286143-IDE80045-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,21
ENG286143-IDE80046-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,21
ENG286143-IDE80047-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,21
ENG286143-IDE80048-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,21
ENG286143-IDE80049-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,21
ENG286143-IDE80050-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,21
ENG286143-IDE80051-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,21
ENG286143-IDE80052-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,21
ENG286143-IDE80053-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,21
ENG286143-IDE80054-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,21
ENG286143-IDE80055-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,21
ENG286143-IDE80056-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,21
ENG286143-MAS01078-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,21
ENG286143-MAS14087-drivers_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,21
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,No Response From Subnet Component,21
ENG253243-ENG286261-Easy Open-p_a_Schiebet rentriegelung_durch_VIP_bei_Tankklappe_offen,not active ,4
ENG253243-ENG258420-Easy Open-p_a_VIP_Freigabeentzug_bei_Anhaenger,not active ,4
ENG253243-ENG258644-Easy Open-Virtuelles_Pedal_Aktiv_Kl_15,not active ,4
ENG253243-ENG259016-Easy Open-Virtuelles_Pedal_Aktiv_Kl_S,not active ,4
ENG253243-ENG260097-Easy Open-Virtuelles_Pedal_Aktiv_Motorlauf,not active ,4
ENG253243-ENG286386-Easy Open-Virtuelles_Pedal_Schiebet ren_Aktiv_Kl_15,not active ,4
ENG253243-ENG286387-Easy Open-Virtuelles_Pedal_Schiebet ren_Aktiv_Kl_S,not active ,4
ENG253243-ENG286388-Easy Open-Virtuelles_Pedal_Schiebet ren_Aktiv_Motorlauf,not active ,4
ENG129029-ENG258264-Easy_close_alignment-delta_rssi_hysterese,15 ,15
ENG129029-ENG260847-Easy_close_alignment-min_HD_Oeffungswinkel,50 %,15
ENG129029-ENG259133-Easy_close_alignment-min_HD_Oeffungswinkel_Rev,10 %,15
ENG129029-ENG259801-Easy_close_alignment-VIT_AktivTasteB,2.0 s,15
ENG129029-ENG259762-Easy_close_alignment-VIT_RSSI_Verlassensscans,20.0 s,15
ENG129029-ENG260687-Easy_close_alignment-VIT_RSSI_Wiedereintrittscans,7.0 s,15
ENG166045-ENG258452-EASYCLOSE-EasyCloseAktiv,not activated ,4
ENG166045-ENG260520-EASYCLOSE-ECL_ext_verriegeln,not activated ,4
ENG166045-ENG248655-EASYCLOSE-ECL_Start_ueber_ViP,not activated ,4
ENG122934-erase_error_table,00 00 00 ,3
ENG122933-error_mask,00 00 ,2
ENG253250-ENG130581-Fahrlichthinweis-Fahrlicht_Hinweis_mehrfach,active ,4
ENG253250-ENG126818-Fahrlichthinweis-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,4
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,not active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,Not available ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,Not available ,6
ENG141682-ENG260711-Front_wiper-cp_tipwischen_Kl_15_aus,OFF ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,keine Abtaupostition ,6
ENG141682-ENG260480-Front_wiper-Frontwischer_typ,LIN ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,active ,6
ENG141682-ENG258360-Front_wiper-pa_2_Motorsystem,not active ,6
ENG141682-ENG259770-Front_wiper-Regensensor aktiv Fahrfreigabe,not active ,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,active ,6
ENG141682-ENG260083-Front_wiper-Spannungsanforderung_konfig_Frontwischer,Keine_Spannungsanforderung ,6
ENG141682-ENG259232-Front_wiper-tipwischen_Kl_15_aus,not active ,6
ENG141682-ENG122991-Front_wiper-Wischer stop bei Motorstart,immer Wischerstopp ,6
ENG117283-ENG122998-Frontwaschfunktion-factor_washing_delay,10 ,2
ENG117283-ENG263535-Frontwaschfunktion-Waschfrequenz_bei_LSS_aus,40 ,2
ENG171911-ENG263558-Funk-FFB Batteriewarnung unterdruecken,not active ,4
ENG171911-ENG141957-Funk-Radio freq.,MQB37w: 434 MHz RdW + NAR (2-kanalig) ,4
ENG253288-Grundparameter SPN-,10000 ms,30
ENG253288-ENG126955-Grundparameter SPN-duration_to_ZAT_continuous_actuation_detection,1000 ms,30
ENG253288-ENG129005-Grundparameter SPN-duration_to_ZAT_multi_actuation_detection,3000 ms,30
ENG253288-ENG126950-Grundparameter SPN-duration_ZAT_debounce,50 ms,30
ENG253288-ENG260569-Grundparameter SPN-Speed_ threshold_for_start_wish_plausibilisation,10 km/h,30
ENG253288-ENG129008-Grundparameter SPN-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,30
ENG253288-ENG126954-Grundparameter SPN-time_to_ZAT_Open_circuit_detection,1000 ms,30
ENG253288-ENG126951-Grundparameter SPN-time_to_ZAT_Short_circuit_fault_detection,60 s,30
ENG253288-ENG126952-Grundparameter SPN-time_ZAT_lock_after emergency_shutoff,1000 ms,30
ENG253288-ENG126953-Grundparameter SPN-time_ZAT_lock_after_normal_shutoff,500 ms,30
ENG253288-ENG253449-Grundparameter SPN-time_ZAT_one_switch_actuation_detection,3000 ms,30
ENG253178-ENG126630-Heckdeckelsteuerung-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
ENG253178-ENG125652-Heckdeckelsteuerung-Servoheck Schlossansteuerung,Always ,8
ENG253178-ENG126838-Heckdeckelsteuerung-Softtouch-Betaetigung senden,Always ,8
ENG253178-ENG142011-Heckdeckelsteuerung-trunk_lid_conrol_unit,not installed ,8
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG260128-HW_Verbau-Kontaktfritten,OFF ,8
ENG141645-ENG152427-HW_Verbau-Rear window defogger,not installed ,8
ENG253080-IAA Nutzermanagement,installed ,1
ENG253173-ENG259645-IDGeber_Suche-Innenraumsuche_Kl15_aktiv,activated ,4
ENG253173-ENG261236-IDGeber_Suche-Innenraumsuche_Kl15_Triggerung_aktiv,activated ,4
ENG253173-ENG260685-IDGeber_Suche-Innenraumsuche_Kl15_TuerenKlappenFenster_auch_vor_erstem_Anfahren,activated ,4
ENG253173-ENG258195-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Heck_aktiv,activated ,4
ENG253173-ENG260525-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_aktiv,activated ,4
ENG253173-ENG258977-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_NFZ_aktiv,not activated ,4
ENG253173-ENG258651-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_TriggerVariante,activated ,4
ENG253173-ENG261351-IDGeber_Suche-Innenraumsuche_Wiederentriegelung_Tueren_aktiv,activated ,4
ENG253070-MAS14172-Intelligente Heckleuchte-Parametierung-Brake light larger area,active ,23
ENG253070-MAS14173-Intelligente Heckleuchte-Parametierung-Brake light smaller area,active ,23
ENG253070-ENG259403-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Aktivierung,0.00 m,23
ENG253070-ENG260952-Intelligente Heckleuchte-Parametierung-p_Abstand_BRL_Deaktivierung,0.00 m,23
ENG253070-ENG259366-Intelligente Heckleuchte-Parametierung-p_adaptive_helligkeitsanpassung,active ,23
ENG253070-ENG260454-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_dauer,10 ms,23
ENG253070-ENG260199-Intelligente Heckleuchte-Parametierung-p_beschleunigung_BRL_schwelle,-16.00000 m/s ,23
ENG253070-ENG260962-Intelligente Heckleuchte-Parametierung-p_CHO_LHO_statisch,not active ,23
ENG253070-ENG259731-Intelligente Heckleuchte-Parametierung-p_LH_Diag_LED_def_inaktiv,not active ,23
ENG253070-ENG259241-Intelligente Heckleuchte-Parametierung-p_LH_Diag_Status_def_inaktiv,not active ,23
ENG253070-ENG260043-Intelligente Heckleuchte-Parametierung-p_LH_zusatzschlussl_def_deaktiv,not active ,23
ENG253070-ENG260406-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_dunkel,4000 lx,23
ENG253070-ENG260839-Intelligente Heckleuchte-Parametierung-p_LS_helligkeit_schwelle_hoch,50000 lx,23
ENG253070-ENG258451-Intelligente Heckleuchte-Parametierung-p_SHL_Anim_LTM_Auto,not active ,23
ENG253070-ENG259407-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15aus,0 ,23
ENG253070-ENG260457-Intelligente Heckleuchte-Parametierung-p_SHL_AnimDimm_Freigabe_KL15ein,0 ,23
ENG253070-ENG259766-Intelligente Heckleuchte-Parametierung-p_SHL_dynamisch,not active ,23
ENG253070-ENG258437-Intelligente Heckleuchte-Parametierung-p_v_BRL_Aktivierung,20 km/h,23
ENG253070-ENG258439-Intelligente Heckleuchte-Parametierung-p_v_BRL_Deaktivierung,10 km/h,23
ENG253070-ENG261315-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_aus,60 km/h,23
ENG253070-ENG259510-Intelligente Heckleuchte-Parametierung-p_v_SHL_dynamisch_level_ein,75 km/h,23
ENG253039-MAS06614-Intelligente Heckleuchte-Verbau-Variant,0 ,4
ENG253039-MAS21321-Intelligente Heckleuchte-Verbau-Audi parking system installed,not installed ,4
ENG253039-SFT271909-Intelligente Heckleuchte-Verbau-Left taillight 1,not installed ,4
ENG253039-SFT272142-Intelligente Heckleuchte-Verbau-Left taillight 2,not installed ,4
ENG253039-SFT272143-Intelligente Heckleuchte-Verbau-Right taillight 1,not installed ,4
ENG253039-SFT272144-Intelligente Heckleuchte-Verbau-Right taillight 2,not installed ,4
ENG253039-ENG261019-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_KZL_iSBBR,not active ,4
ENG253039-ENG260486-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_NSL_iSBBR,not active ,4
ENG253039-ENG260357-Intelligente Heckleuchte-Verbau-pa_Deaktivierung_RFL_iSBBR,not active ,4
ENG253265-ENG260602-Interior_light_default_values-Default_value_active_profile,02 ,96
ENG253265-ENG258400-Interior_light_default_values-Default_value_ambient_color,11 ,96
ENG253265-ENG259067-Interior_light_default_values-Default_value_ambient_color_fod,11 ,96
ENG253265-ENG258906-Interior_light_default_values-Default_value_brightness_profile_1,100 %,96
ENG253265-ENG260896-Interior_light_default_values-Default_value_brightness_profile_2,50 %,96
ENG253265-ENG259361-Interior_light_default_values-Default_value_brightness_profile_3,50 %,96
ENG253265-ENG259248-Interior_light_default_values-Default_value_brightness_profile_4,50 %,96
ENG253265-ENG259191-Interior_light_default_values-Default_value_brightness_profile_5,50 %,96
ENG253265-ENG259315-Interior_light_default_values-Default_value_brightness_profile_6,50 %,96
ENG253265-ENG260148-Interior_light_default_values-Default_value_brightness_profile_7,50 %,96
ENG253265-ENG259491-Interior_light_default_values-Default_value_brightness_profile_8,0 %,96
ENG253265-ENG258409-Interior_light_default_values-Default_value_brightness_set_1,50 %,96
ENG253265-ENG260620-Interior_light_default_values-Default_value_brightness_set_2,50 %,96
ENG253265-ENG259395-Interior_light_default_values-Default_value_brightness_set_3,50 %,96
ENG253265-ENG260548-Interior_light_default_values-Default_value_brightness_set_4,50 %,96
ENG253265-ENG261071-Interior_light_default_values-Default_value_brightness_set_5,50 %,96
ENG253265-ENG259147-Interior_light_default_values-Default_value_brightness_set_6,50 %,96
ENG253265-ENG259714-Interior_light_default_values-Default_value_brightness_set_7,50 %,96
ENG253265-ENG260350-Interior_light_default_values-Default_value_brightness_set_8,50 %,96
ENG253265-ENG260494-Interior_light_default_values-Default_value_contour_color,01 ,96
ENG253265-ENG259828-Interior_light_default_values-Default_value_contour_color_fod,01 ,96
ENG253265-ENG258473-Interior_light_default_values-Default_value_door_contact,active ,96
ENG253265-ENG261059-Interior_light_default_values-Default_value_functional_ambient_lighting,active ,96
ENG253265-ENG258185-Interior_light_default_values-Default_value_play_of_colors,00 ,96
ENG253265-ENG260118-Interior_light_default_values-Status_functional_ambient_lighting_function_0,00 ,96
ENG253265-ENG260033-Interior_light_default_values-Status_functional_ambient_lighting_function_1,01 ,96
ENG253265-ENG260515-Interior_light_default_values-Status_functional_ambient_lighting_function_10,00 ,96
ENG253265-ENG261126-Interior_light_default_values-Status_functional_ambient_lighting_function_11,00 ,96
ENG253265-ENG260982-Interior_light_default_values-Status_functional_ambient_lighting_function_12,00 ,96
ENG253265-ENG258716-Interior_light_default_values-Status_functional_ambient_lighting_function_13,00 ,96
ENG253265-ENG258745-Interior_light_default_values-Status_functional_ambient_lighting_function_14,00 ,96
ENG253265-ENG258773-Interior_light_default_values-Status_functional_ambient_lighting_function_15,00 ,96
ENG253265-ENG261349-Interior_light_default_values-Status_functional_ambient_lighting_function_16,00 ,96
ENG253265-ENG258101-Interior_light_default_values-Status_functional_ambient_lighting_function_17,00 ,96
ENG253265-ENG258275-Interior_light_default_values-Status_functional_ambient_lighting_function_18,00 ,96
ENG253265-ENG258192-Interior_light_default_values-Status_functional_ambient_lighting_function_19,00 ,96
ENG253265-ENG260897-Interior_light_default_values-Status_functional_ambient_lighting_function_2,01 ,96
ENG253265-ENG260194-Interior_light_default_values-Status_functional_ambient_lighting_function_20,00 ,96
ENG253265-ENG258332-Interior_light_default_values-Status_functional_ambient_lighting_function_21,00 ,96
ENG253265-ENG259651-Interior_light_default_values-Status_functional_ambient_lighting_function_22,00 ,96
ENG253265-ENG261294-Interior_light_default_values-Status_functional_ambient_lighting_function_23,00 ,96
ENG253265-ENG259414-Interior_light_default_values-Status_functional_ambient_lighting_function_24,00 ,96
ENG253265-ENG258573-Interior_light_default_values-Status_functional_ambient_lighting_function_25,00 ,96
ENG253265-ENG258495-Interior_light_default_values-Status_functional_ambient_lighting_function_26,00 ,96
ENG253265-ENG260792-Interior_light_default_values-Status_functional_ambient_lighting_function_27,00 ,96
ENG253265-ENG261350-Interior_light_default_values-Status_functional_ambient_lighting_function_28,00 ,96
ENG253265-ENG259636-Interior_light_default_values-Status_functional_ambient_lighting_function_29,00 ,96
ENG253265-ENG259360-Interior_light_default_values-Status_functional_ambient_lighting_function_3,01 ,96
ENG253265-ENG260163-Interior_light_default_values-Status_functional_ambient_lighting_function_30,00 ,96
ENG253265-ENG260013-Interior_light_default_values-Status_functional_ambient_lighting_function_31,00 ,96
ENG253265-ENG260816-Interior_light_default_values-Status_functional_ambient_lighting_function_32,00 ,96
ENG253265-ENG258823-Interior_light_default_values-Status_functional_ambient_lighting_function_33,00 ,96
ENG253265-ENG258362-Interior_light_default_values-Status_functional_ambient_lighting_function_34,00 ,96
ENG253265-ENG258252-Interior_light_default_values-Status_functional_ambient_lighting_function_35,00 ,96
ENG253265-ENG261196-Interior_light_default_values-Status_functional_ambient_lighting_function_36,00 ,96
ENG253265-ENG260391-Interior_light_default_values-Status_functional_ambient_lighting_function_37,00 ,96
ENG253265-ENG259418-Interior_light_default_values-Status_functional_ambient_lighting_function_38,00 ,96
ENG253265-ENG259523-Interior_light_default_values-Status_functional_ambient_lighting_function_39,00 ,96
ENG253265-ENG258165-Interior_light_default_values-Status_functional_ambient_lighting_function_4,00 ,96
ENG253265-ENG259088-Interior_light_default_values-Status_functional_ambient_lighting_function_40,00 ,96
ENG253265-ENG258142-Interior_light_default_values-Status_functional_ambient_lighting_function_41,00 ,96
ENG253265-ENG259166-Interior_light_default_values-Status_functional_ambient_lighting_function_42,00 ,96
ENG253265-ENG258220-Interior_light_default_values-Status_functional_ambient_lighting_function_43,00 ,96
ENG253265-ENG259935-Interior_light_default_values-Status_functional_ambient_lighting_function_44,00 ,96
ENG253265-ENG260916-Interior_light_default_values-Status_functional_ambient_lighting_function_45,00 ,96
ENG253265-ENG258884-Interior_light_default_values-Status_functional_ambient_lighting_function_46,00 ,96
ENG253265-ENG260167-Interior_light_default_values-Status_functional_ambient_lighting_function_47,00 ,96
ENG253265-ENG259709-Interior_light_default_values-Status_functional_ambient_lighting_function_48,00 ,96
ENG253265-ENG258367-Interior_light_default_values-Status_functional_ambient_lighting_function_49,00 ,96
ENG253265-ENG261268-Interior_light_default_values-Status_functional_ambient_lighting_function_5,01 ,96
ENG253265-ENG260926-Interior_light_default_values-Status_functional_ambient_lighting_function_50,00 ,96
ENG253265-ENG258790-Interior_light_default_values-Status_functional_ambient_lighting_function_51,00 ,96
ENG253265-ENG259976-Interior_light_default_values-Status_functional_ambient_lighting_function_52,00 ,96
ENG253265-ENG260404-Interior_light_default_values-Status_functional_ambient_lighting_function_53,00 ,96
ENG253265-ENG258371-Interior_light_default_values-Status_functional_ambient_lighting_function_54,00 ,96
ENG253265-ENG259284-Interior_light_default_values-Status_functional_ambient_lighting_function_55,00 ,96
ENG253265-ENG260285-Interior_light_default_values-Status_functional_ambient_lighting_function_56,00 ,96
ENG253265-ENG258600-Interior_light_default_values-Status_functional_ambient_lighting_function_57,00 ,96
ENG253265-ENG260626-Interior_light_default_values-Status_functional_ambient_lighting_function_58,00 ,96
ENG253265-ENG260773-Interior_light_default_values-Status_functional_ambient_lighting_function_59,00 ,96
ENG253265-ENG259316-Interior_light_default_values-Status_functional_ambient_lighting_function_6,00 ,96
ENG253265-ENG261109-Interior_light_default_values-Status_functional_ambient_lighting_function_60,00 ,96
ENG253265-ENG258106-Interior_light_default_values-Status_functional_ambient_lighting_function_61,00 ,96
ENG253265-ENG260286-Interior_light_default_values-Status_functional_ambient_lighting_function_62,00 ,96
ENG253265-ENG260233-Interior_light_default_values-Status_functional_ambient_lighting_function_63,00 ,96
ENG253265-ENG260974-Interior_light_default_values-Status_functional_ambient_lighting_function_7,00 ,96
ENG253265-ENG259492-Interior_light_default_values-Status_functional_ambient_lighting_function_8,00 ,96
ENG253265-ENG260578-Interior_light_default_values-Status_functional_ambient_lighting_function_9,00 ,96
ENG253069-ENG259642-Interior_light_external_events-External_event_activation_69,not active ,16
ENG253069-ENG259453-Interior_light_external_events-External_event_activation_of_ready_to_drive_visualization,not active ,16
ENG253069-ENG258384-Interior_light_external_events-External_event_ready_to_drive_visualization_with_sound,not active ,16
ENG253344-ENG253469-Interior_light_functions_1_to_70-Light_function_1,active ,9
ENG253344-ENG260993-Interior_light_functions_1_to_70-Light_function_10,active ,9
ENG253344-ENG261210-Interior_light_functions_1_to_70-Light_function_11,active ,9
ENG253344-ENG259885-Interior_light_functions_1_to_70-Light_function_12,active ,9
ENG253344-ENG258428-Interior_light_functions_1_to_70-Light_function_13,active ,9
ENG253344-ENG260468-Interior_light_functions_1_to_70-Light_function_14,active ,9
ENG253344-ENG259544-Interior_light_functions_1_to_70-Light_function_15,active ,9
ENG253344-ENG261129-Interior_light_functions_1_to_70-Light_function_16,active ,9
ENG253344-ENG259775-Interior_light_functions_1_to_70-Light_function_17,active ,9
ENG253344-ENG259446-Interior_light_functions_1_to_70-Light_function_18,active ,9
ENG253344-ENG259229-Interior_light_functions_1_to_70-Light_function_19,active ,9
ENG253344-ENG253470-Interior_light_functions_1_to_70-Light_function_2,active ,9
ENG253344-ENG259487-Interior_light_functions_1_to_70-Light_function_20,active ,9
ENG253344-ENG259385-Interior_light_functions_1_to_70-Light_function_21,active ,9
ENG253344-ENG259785-Interior_light_functions_1_to_70-Light_function_22,active ,9
ENG253344-ENG258581-Interior_light_functions_1_to_70-Light_function_23,active ,9
ENG253344-ENG260265-Interior_light_functions_1_to_70-Light_function_24,active ,9
ENG253344-ENG261256-Interior_light_functions_1_to_70-Light_function_25,active ,9
ENG253344-ENG260361-Interior_light_functions_1_to_70-Light_function_26,active ,9
ENG253344-ENG259100-Interior_light_functions_1_to_70-Light_function_27,active ,9
ENG253344-ENG260930-Interior_light_functions_1_to_70-Light_function_28,active ,9
ENG253344-ENG259955-Interior_light_functions_1_to_70-Light_function_29,active ,9
ENG253344-ENG253471-Interior_light_functions_1_to_70-Light_function_3,active ,9
ENG253344-ENG259370-Interior_light_functions_1_to_70-Light_function_30,active ,9
ENG253344-ENG261130-Interior_light_functions_1_to_70-Light_function_31,active ,9
ENG253344-ENG258748-Interior_light_functions_1_to_70-Light_function_32,active ,9
ENG253344-ENG260955-Interior_light_functions_1_to_70-Light_function_33,active ,9
ENG253344-ENG259496-Interior_light_functions_1_to_70-Light_function_34,active ,9
ENG253344-ENG258588-Interior_light_functions_1_to_70-Light_function_35,active ,9
ENG253344-ENG259600-Interior_light_functions_1_to_70-Light_function_36,active ,9
ENG253344-ENG259095-Interior_light_functions_1_to_70-Light_function_37,active ,9
ENG253344-ENG260346-Interior_light_functions_1_to_70-Light_function_38,active ,9
ENG253344-ENG259274-Interior_light_functions_1_to_70-Light_function_39,active ,9
ENG253344-ENG260499-Interior_light_functions_1_to_70-Light_function_4,active ,9
ENG253344-ENG258529-Interior_light_functions_1_to_70-Light_function_40,active ,9
ENG253344-ENG258505-Interior_light_functions_1_to_70-Light_function_41,active ,9
ENG253344-ENG258603-Interior_light_functions_1_to_70-Light_function_42,active ,9
ENG253344-ENG259158-Interior_light_functions_1_to_70-Light_function_43,active ,9
ENG253344-ENG260244-Interior_light_functions_1_to_70-Light_function_44,active ,9
ENG253344-ENG260634-Interior_light_functions_1_to_70-Light_function_45,active ,9
ENG253344-ENG258174-Interior_light_functions_1_to_70-Light_function_46,active ,9
ENG253344-ENG260984-Interior_light_functions_1_to_70-Light_function_47,active ,9
ENG253344-ENG258949-Interior_light_functions_1_to_70-Light_function_48,active ,9
ENG253344-ENG259994-Interior_light_functions_1_to_70-Light_function_49,active ,9
ENG253344-ENG258326-Interior_light_functions_1_to_70-Light_function_5,active ,9
ENG253344-ENG259724-Interior_light_functions_1_to_70-Light_function_50,active ,9
ENG253344-ENG259989-Interior_light_functions_1_to_70-Light_function_51,active ,9
ENG253344-ENG259580-Interior_light_functions_1_to_70-Light_function_52,active ,9
ENG253344-ENG258381-Interior_light_functions_1_to_70-Light_function_53,active ,9
ENG253344-ENG259438-Interior_light_functions_1_to_70-Light_function_54,active ,9
ENG253344-ENG261290-Interior_light_functions_1_to_70-Light_function_55,active ,9
ENG253344-ENG259516-Interior_light_functions_1_to_70-Light_function_56,active ,9
ENG253344-ENG261086-Interior_light_functions_1_to_70-Light_function_57,active ,9
ENG253344-ENG260704-Interior_light_functions_1_to_70-Light_function_58,active ,9
ENG253344-ENG258566-Interior_light_functions_1_to_70-Light_function_59,active ,9
ENG253344-ENG261278-Interior_light_functions_1_to_70-Light_function_6,active ,9
ENG253344-ENG260248-Interior_light_functions_1_to_70-Light_function_60,active ,9
ENG253344-ENG260845-Interior_light_functions_1_to_70-Light_function_61,active ,9
ENG253344-ENG258817-Interior_light_functions_1_to_70-Light_function_62,active ,9
ENG253344-ENG260488-Interior_light_functions_1_to_70-Light_function_63,active ,9
ENG253344-ENG259000-Interior_light_functions_1_to_70-Light_function_64,active ,9
ENG253344-ENG260181-Interior_light_functions_1_to_70-Light_function_65,active ,9
ENG253344-ENG259146-Interior_light_functions_1_to_70-Light_function_66,active ,9
ENG253344-ENG258530-Interior_light_functions_1_to_70-Light_function_67,active ,9
ENG253344-ENG261172-Interior_light_functions_1_to_70-Light_function_68,active ,9
ENG253344-ENG258454-Interior_light_functions_1_to_70-Light_function_69,active ,9
ENG253344-ENG259680-Interior_light_functions_1_to_70-Light_function_7,active ,9
ENG253344-ENG260506-Interior_light_functions_1_to_70-Light_function_70,active ,9
ENG253344-ENG258912-Interior_light_functions_1_to_70-Light_function_8,active ,9
ENG253344-ENG258633-Interior_light_functions_1_to_70-Light_function_9,active ,9
ENG253391-ENG258190-Interior_light_general_settings-Automatic_ambiance_lighting_with_fpa,active ,14
ENG253391-ENG259555-Interior_light_general_settings-Crash_color,01 ,14
ENG253391-ENG259741-Interior_light_general_settings-Door_warning_light,not active ,14
ENG253391-ENG258939-Interior_light_general_settings-Door_warning_light_brightness,100 %,14
ENG253391-ENG258181-Interior_light_general_settings-Door_warning_light_color,01 ,14
ENG253391-ENG259296-Interior_light_general_settings-Innenlicht_durch_Fahrerassistenz,active ,14
ENG253391-ENG261240-Interior_light_general_settings-Interior_light_activation_by_opening_trunk,not active ,14
ENG253391-ENG261275-Interior_light_general_settings-Interior_light_alternative_clamp_control_entry,not active ,14
ENG253391-ENG260888-Interior_light_general_settings-Interior_light_alternative_clamp_control_exit,not active ,14
ENG253391-ENG258268-Interior_light_general_settings-interior_light_color,01 ,14
ENG253391-ENG260936-Interior_light_general_settings-Interior_light_dependency_on_key_or_belt_buckle,02 ,14
ENG253391-ENG259666-Interior_light_general_settings-Interior_light_function,active ,14
ENG253391-ENG260600-Interior_light_general_settings-Interior_light_trunk_light,active ,14
ENG253391-ENG259259-Interior_light_general_settings-Kl30alm,active ,14
ENG253391-ENG259746-Interior_light_general_settings-Kl30G_activation_by_opening_trunk,active ,14
ENG253391-ENG260275-Interior_light_general_settings-Kl30G_wake_up_behaviour,not active ,14
ENG253391-ENG259384-Interior_light_general_settings-Kl30G_without_pwm,not active ,14
ENG253391-ENG258730-Interior_light_general_settings-Kl58_color,01 ,14
ENG253391-ENG260492-Interior_light_general_settings-Mapping_fpa_profile_1,1 ,14
ENG253391-ENG261042-Interior_light_general_settings-Mapping_fpa_profile_2,5 ,14
ENG253391-ENG258453-Interior_light_general_settings-Mapping_fpa_profile_3,3 ,14
ENG253391-ENG260820-Interior_light_general_settings-Mapping_fpa_profile_4,4 ,14
ENG253391-ENG258889-Interior_light_general_settings-Mapping_fpa_profile_5,2 ,14
ENG253391-ENG260732-Interior_light_general_settings-Mapping_fpa_profile_6,7 ,14
ENG253391-ENG260062-Interior_light_general_settings-Mfg_interior_light_color,01 ,14
ENG253391-ENG260638-Interior_light_general_settings-Pso_active_participant_ambient_lighting_interior_enabled,active ,14
ENG253391-ENG258979-Interior_light_general_settings-roof_console_installed,active ,14
ENG253391-ENG258685-Interior_light_general_settings-Trunk_light_brightness,100 %,14
ENG253391-ENG260452-Interior_light_general_settings-Trunk_light_color,01 ,14
ENG253223-ENG260423-Interior_light_hmi_config-Bytes 25-60,00 1C 00 00 00 00 60 00 00 00 10 00 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C 1C 70 00 ,100
ENG253223-ENG259513-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_1,64 ,100
ENG253223-ENG260783-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_2,64 ,100
ENG253223-ENG260290-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_3,64 ,100
ENG253223-ENG258130-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_4,64 ,100
ENG253223-ENG259034-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_5,64 ,100
ENG253223-ENG259728-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_6,64 ,100
ENG253223-ENG258649-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_7,64 ,100
ENG253223-ENG258756-Interior_light_hmi_config-Hmi_adaption_customer_wish_IlluminationSet_8,64 ,100
ENG253223-ENG260831-Interior_light_hmi_config-Hmi_ambient_color,active ,100
ENG253223-ENG258324-Interior_light_hmi_config-Hmi_ambient_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG258789-Interior_light_hmi_config-Hmi_ambient_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260180-Interior_light_hmi_config-Hmi_ambient_profile_1,active ,100
ENG253223-ENG258163-Interior_light_hmi_config-Hmi_ambient_profile_2,active ,100
ENG253223-ENG258800-Interior_light_hmi_config-Hmi_ambient_profile_3,active ,100
ENG253223-ENG258761-Interior_light_hmi_config-Hmi_ambient_profile_4,active ,100
ENG253223-ENG259948-Interior_light_hmi_config-Hmi_ambient_profile_5,active ,100
ENG253223-ENG261117-Interior_light_hmi_config-Hmi_ambient_profile_6,active ,100
ENG253223-ENG258601-Interior_light_hmi_config-Hmi_ambient_profile_7,active ,100
ENG253223-ENG259615-Interior_light_hmi_config-Hmi_ambient_profile_8,active ,100
ENG253223-ENG258875-Interior_light_hmi_config-Hmi_config_fixed_color_play_of_colors,00 ,100
ENG253223-ENG260154-Interior_light_hmi_config-Hmi_config_hmi_preview,active ,100
ENG253223-ENG258806-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_1,00 ,100
ENG253223-ENG260370-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_2,00 ,100
ENG253223-ENG261327-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_3,00 ,100
ENG253223-ENG260102-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_4,00 ,100
ENG253223-ENG259550-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_5,00 ,100
ENG253223-ENG258870-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_6,00 ,100
ENG253223-ENG260001-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_7,00 ,100
ENG253223-ENG259068-Interior_light_hmi_config-Hmi_config_linked_zone_illumination_set_8,00 ,100
ENG253223-ENG259772-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_1,03 ,100
ENG253223-ENG259687-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_2,00 ,100
ENG253223-ENG259129-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_3,02 ,100
ENG253223-ENG260699-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_4,00 ,100
ENG253223-ENG259317-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_5,00 ,100
ENG253223-ENG258480-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_6,03 ,100
ENG253223-ENG261090-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_7,00 ,100
ENG253223-ENG258664-Interior_light_hmi_config-Hmi_config_member_bottom_color_scheme_8,02 ,100
ENG253223-ENG261119-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_1,03 ,100
ENG253223-ENG259685-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_2,00 ,100
ENG253223-ENG260690-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_3,02 ,100
ENG253223-ENG259252-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_4,00 ,100
ENG253223-ENG258904-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_5,00 ,100
ENG253223-ENG260909-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_6,02 ,100
ENG253223-ENG258840-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_7,00 ,100
ENG253223-ENG260828-Interior_light_hmi_config-Hmi_config_member_center_bottom_color_scheme_8,03 ,100
ENG253223-ENG259535-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_1,03 ,100
ENG253223-ENG259249-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_2,00 ,100
ENG253223-ENG258349-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_3,03 ,100
ENG253223-ENG260458-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_4,00 ,100
ENG253223-ENG258285-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_5,00 ,100
ENG253223-ENG258936-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_6,03 ,100
ENG253223-ENG260143-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_7,00 ,100
ENG253223-ENG259986-Interior_light_hmi_config-Hmi_config_member_center_color_scheme_8,03 ,100
ENG253223-ENG260694-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_1,00 ,100
ENG253223-ENG259604-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_2,00 ,100
ENG253223-ENG258410-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_3,00 ,100
ENG253223-ENG261012-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_4,00 ,100
ENG253223-ENG259932-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_5,00 ,100
ENG253223-ENG260104-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_6,00 ,100
ENG253223-ENG260125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_7,00 ,100
ENG253223-ENG259125-Interior_light_hmi_config-Hmi_config_member_center_top_color_scheme_8,00 ,100
ENG253223-ENG260419-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_1,00 ,100
ENG253223-ENG261132-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_2,00 ,100
ENG253223-ENG260056-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_3,00 ,100
ENG253223-ENG259330-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_4,00 ,100
ENG253223-ENG258990-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_5,00 ,100
ENG253223-ENG259936-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_6,00 ,100
ENG253223-ENG258422-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_7,00 ,100
ENG253223-ENG258463-Interior_light_hmi_config-Hmi_config_member_top_color_scheme_8,00 ,100
ENG253223-ENG258418-Interior_light_hmi_config-Hmi_config_timer_hmi_preview,5 s,100
ENG253223-ENG259957-Interior_light_hmi_config-Hmi_contour_color,active ,100
ENG253223-ENG259365-Interior_light_hmi_config-Hmi_contour_colors_bitmask,04 51 40 AD ,100
ENG253223-ENG259211-Interior_light_hmi_config-Hmi_contour_colors_fod_bitmask,3F FF FF FF ,100
ENG253223-ENG260051-Interior_light_hmi_config-Hmi_Display_Color_light_function,01 ,100
ENG253223-ENG258352-Interior_light_hmi_config-Hmi_door_contact,not active ,100
ENG253223-ENG258250-Interior_light_hmi_config-Hmi_fpa_dependency,active ,100
ENG253223-ENG260229-Interior_light_hmi_config-Hmi_functional_ambiance_lighting_list,active ,100
ENG253223-ENG258930-Interior_light_hmi_config-Hmi_functional_ambience_lighting,active ,100
ENG253223-ENG258483-Interior_light_hmi_config-Hmi_menu_ambient_lighting,active ,100
ENG253223-ENG261116-Interior_light_hmi_config-Hmi_play_of_colors,active ,100
ENG253223-ENG260969-Interior_light_hmi_config-Hmi_setup_set_1,13 ,100
ENG253223-ENG260367-Interior_light_hmi_config-Hmi_setup_set_2,07 ,100
ENG253223-ENG259030-Interior_light_hmi_config-Hmi_setup_set_3,15 ,100
ENG253223-ENG260913-Interior_light_hmi_config-Hmi_setup_set_4,05 ,100
ENG253223-ENG258666-Interior_light_hmi_config-Hmi_setup_set_5,FF ,100
ENG253223-ENG259988-Interior_light_hmi_config-Hmi_setup_set_6,FF ,100
ENG253223-ENG258907-Interior_light_hmi_config-Hmi_setup_set_7,FF ,100
ENG253223-ENG258492-Interior_light_hmi_config-Hmi_setup_set_8,FF ,100
ENG253223-ENG259126-Interior_light_hmi_config-roof_console_door_contact,active ,100
ENG253355-Interior_light_interface_function,No_voltage_requirement ,1
ENG253312-ENG297177-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_1,00 ,51
ENG253312-ENG297178-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_10,00 ,51
ENG253312-ENG297179-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_11,8A ,51
ENG253312-ENG297180-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_12,8C ,51
ENG253312-ENG297181-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_13,00 ,51
ENG253312-ENG297182-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_14,00 ,51
ENG253312-ENG297183-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_15,00 ,51
ENG253312-ENG297184-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_2,00 ,51
ENG253312-ENG297185-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_3,1F ,51
ENG253312-ENG297186-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_4,29 ,51
ENG253312-ENG297187-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_5,00 ,51
ENG253312-ENG297188-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_6,00 ,51
ENG253312-ENG297189-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_7,00 ,51
ENG253312-ENG297190-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_8,4D ,51
ENG253312-ENG297191-Interior_light_lin_slaves_config-List_item_failure_location_lin10_slave_9,57 ,51
ENG253312-ENG297192-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_1,00 ,51
ENG253312-ENG297193-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_10,00 ,51
ENG253312-ENG297194-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_11,89 ,51
ENG253312-ENG297195-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_12,8B ,51
ENG253312-ENG297196-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_13,00 ,51
ENG253312-ENG297197-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_14,00 ,51
ENG253312-ENG297198-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_15,00 ,51
ENG253312-ENG297199-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_2,00 ,51
ENG253312-ENG297200-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_3,08 ,51
ENG253312-ENG297201-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_4,12 ,51
ENG253312-ENG297202-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_5,00 ,51
ENG253312-ENG297203-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_6,00 ,51
ENG253312-ENG297204-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_7,00 ,51
ENG253312-ENG297205-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_8,36 ,51
ENG253312-ENG297206-Interior_light_lin_slaves_config-List_item_failure_location_lin5_slave_9,40 ,51
ENG253312-ENG297207-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_1,00 ,51
ENG253312-ENG297208-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_10,00 ,51
ENG253312-ENG297209-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_11,00 ,51
ENG253312-ENG297210-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_12,00 ,51
ENG253312-ENG297211-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_13,00 ,51
ENG253312-ENG297212-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_14,00 ,51
ENG253312-ENG297213-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_15,00 ,51
ENG253312-ENG297214-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_2,6D ,51
ENG253312-ENG297215-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_3,6E ,51
ENG253312-ENG297216-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_4,00 ,51
ENG253312-ENG297217-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_5,00 ,51
ENG253312-ENG297218-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_6,79 ,51
ENG253312-ENG297219-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_7,00 ,51
ENG253312-ENG297220-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_8,00 ,51
ENG253312-ENG297221-Interior_light_lin_slaves_config-List_item_failure_location_lin9_slave_9,00 ,51
ENG253312-ENG297222-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_1,Offset_0 ,51
ENG253312-ENG297223-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_10,Offset_0 ,51
ENG253312-ENG297224-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_11,Offset_0 ,51
ENG253312-ENG297225-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_12,Offset_0 ,51
ENG253312-ENG297226-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_13,Offset_0 ,51
ENG253312-ENG297227-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_14,Offset_0 ,51
ENG253312-ENG297228-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_15,Offset_0 ,51
ENG253312-ENG297229-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_2,Offset_0 ,51
ENG253312-ENG297230-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_3,Offset_0 ,51
ENG253312-ENG297231-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_4,Offset_0 ,51
ENG253312-ENG297232-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_5,Offset_0 ,51
ENG253312-ENG297233-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_6,Offset_0 ,51
ENG253312-ENG297234-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_7,Offset_0 ,51
ENG253312-ENG297235-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_8,Offset_0 ,51
ENG253312-ENG297236-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin10_slave_9,Offset_0 ,51
ENG253312-ENG297237-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_1,Offset_0 ,51
ENG253312-ENG297238-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_10,Offset_0 ,51
ENG253312-ENG297239-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_11,Offset_0 ,51
ENG253312-ENG297240-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_12,Offset_0 ,51
ENG253312-ENG297241-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_13,Offset_0 ,51
ENG253312-ENG297242-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_14,Offset_0 ,51
ENG253312-ENG297243-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_15,Offset_0 ,51
ENG253312-ENG297244-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_2,Offset_0 ,51
ENG253312-ENG297245-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_3,Offset_0 ,51
ENG253312-ENG297246-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_4,Offset_0 ,51
ENG253312-ENG297247-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_5,Offset_0 ,51
ENG253312-ENG297248-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_6,Offset_0 ,51
ENG253312-ENG297249-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_7,Offset_0 ,51
ENG253312-ENG297250-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_8,Offset_0 ,51
ENG253312-ENG297251-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin5_slave_9,Offset_0 ,51
ENG253312-ENG297252-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_1,Offset_0 ,51
ENG253312-ENG297253-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_10,Offset_0 ,51
ENG253312-ENG297254-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_11,Offset_0 ,51
ENG253312-ENG297255-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_12,Offset_0 ,51
ENG253312-ENG297256-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_13,Offset_0 ,51
ENG253312-ENG297257-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_14,Offset_0 ,51
ENG253312-ENG297258-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_15,Offset_0 ,51
ENG253312-ENG297259-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_2,Offset_0 ,51
ENG253312-ENG297260-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_3,Offset_0 ,51
ENG253312-ENG297261-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_4,Offset_0 ,51
ENG253312-ENG297262-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_5,Offset_0 ,51
ENG253312-ENG297263-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_6,Offset_0 ,51
ENG253312-ENG297264-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_7,Offset_0 ,51
ENG253312-ENG297265-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_8,Offset_0 ,51
ENG253312-ENG297266-Interior_light_lin_slaves_config-Offset_list_item_failure_location_lin9_slave_9,Offset_0 ,51
ENG253400-ENG259423-Interior_light_router_config-Output_bcm_amb1_light_function,00 ,93
ENG253400-ENG258209-Interior_light_router_config-Output_bcm_amb2_light_function,00 ,93
ENG253400-ENG261174-Interior_light_router_config-Output_bcm_amb3_light_function,00 ,93
ENG253400-ENG259810-Interior_light_router_config-Output_bcm_amb4_light_function,00 ,93
ENG253400-ENG261141-Interior_light_router_config-Output_bcm_frl_light_function,00 ,93
ENG253400-ENG258669-Interior_light_router_config-Output_BCM_interiorlight,00 ,93
ENG253400-ENG260789-Interior_light_router_config-Output_bcm_krl_light_function,FE ,93
ENG253400-ENG263574-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_left,00 ,93
ENG253400-ENG263530-Interior_light_router_config-Output_interior_light_master_door_warning_lights_front_right,00 ,93
ENG253400-ENG263557-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_left,00 ,93
ENG253400-ENG263579-Interior_light_router_config-Output_interior_light_master_door_warning_lights_rear_right,00 ,93
ENG253400-ENG259911-Interior_light_router_config-Output_lin10_light_function_slave_1,00 ,93
ENG253400-ENG261157-Interior_light_router_config-Output_lin10_light_function_slave_10,00 ,93
ENG253400-ENG259627-Interior_light_router_config-Output_lin10_light_function_slave_11,04 ,93
ENG253400-ENG260063-Interior_light_router_config-Output_lin10_light_function_slave_12,05 ,93
ENG253400-ENG260392-Interior_light_router_config-Output_lin10_light_function_slave_13,00 ,93
ENG253400-ENG261033-Interior_light_router_config-Output_lin10_light_function_slave_14,00 ,93
ENG253400-ENG260756-Interior_light_router_config-Output_lin10_light_function_slave_15,00 ,93
ENG253400-ENG259504-Interior_light_router_config-Output_lin10_light_function_slave_2,00 ,93
ENG253400-ENG259442-Interior_light_router_config-Output_lin10_light_function_slave_3,09 ,93
ENG253400-ENG260805-Interior_light_router_config-Output_lin10_light_function_slave_4,0A ,93
ENG253400-ENG258266-Interior_light_router_config-Output_lin10_light_function_slave_5,00 ,93
ENG253400-ENG259364-Interior_light_router_config-Output_lin10_light_function_slave_6,00 ,93
ENG253400-ENG258390-Interior_light_router_config-Output_lin10_light_function_slave_7,00 ,93
ENG253400-ENG259292-Interior_light_router_config-Output_lin10_light_function_slave_8,19 ,93
ENG253400-ENG258719-Interior_light_router_config-Output_lin10_light_function_slave_9,1A ,93
ENG253400-ENG259289-Interior_light_router_config-Output_lin5_light_function_slave_1,00 ,93
ENG253400-ENG260386-Interior_light_router_config-Output_lin5_light_function_slave_10,00 ,93
ENG253400-ENG259124-Interior_light_router_config-Output_lin5_light_function_slave_11,04 ,93
ENG253400-ENG259695-Interior_light_router_config-Output_lin5_light_function_slave_12,05 ,93
ENG253400-ENG260422-Interior_light_router_config-Output_lin5_light_function_slave_13,00 ,93
ENG253400-ENG261133-Interior_light_router_config-Output_lin5_light_function_slave_14,00 ,93
ENG253400-ENG258921-Interior_light_router_config-Output_lin5_light_function_slave_15,00 ,93
ENG253400-ENG260665-Interior_light_router_config-Output_lin5_light_function_slave_2,00 ,93
ENG253400-ENG260238-Interior_light_router_config-Output_lin5_light_function_slave_3,07 ,93
ENG253400-ENG260068-Interior_light_router_config-Output_lin5_light_function_slave_4,08 ,93
ENG253400-ENG260774-Interior_light_router_config-Output_lin5_light_function_slave_5,00 ,93
ENG253400-ENG258506-Interior_light_router_config-Output_lin5_light_function_slave_6,00 ,93
ENG253400-ENG259536-Interior_light_router_config-Output_lin5_light_function_slave_7,00 ,93
ENG253400-ENG260354-Interior_light_router_config-Output_lin5_light_function_slave_8,17 ,93
ENG253400-ENG261251-Interior_light_router_config-Output_lin5_light_function_slave_9,18 ,93
ENG253400-ENG259104-Interior_light_router_config-Output_lin9_light_function_slave_1,00 ,93
ENG253400-ENG260459-Interior_light_router_config-Output_lin9_light_function_slave_10,00 ,93
ENG253400-ENG259020-Interior_light_router_config-Output_lin9_light_function_slave_11,00 ,93
ENG253400-ENG260441-Interior_light_router_config-Output_lin9_light_function_slave_12,00 ,93
ENG253400-ENG260308-Interior_light_router_config-Output_lin9_light_function_slave_13,00 ,93
ENG253400-ENG258226-Interior_light_router_config-Output_lin9_light_function_slave_14,00 ,93
ENG253400-ENG259889-Interior_light_router_config-Output_lin9_light_function_slave_15,00 ,93
ENG253400-ENG259254-Interior_light_router_config-Output_lin9_light_function_slave_2,0D ,93
ENG253400-ENG258737-Interior_light_router_config-Output_lin9_light_function_slave_3,0E ,93
ENG253400-ENG260120-Interior_light_router_config-Output_lin9_light_function_slave_4,00 ,93
ENG253400-ENG258661-Interior_light_router_config-Output_lin9_light_function_slave_5,00 ,93
ENG253400-ENG260829-Interior_light_router_config-Output_lin9_light_function_slave_6,12 ,93
ENG253400-ENG260402-Interior_light_router_config-Output_lin9_light_function_slave_7,00 ,93
ENG253400-ENG261173-Interior_light_router_config-Output_lin9_light_function_slave_8,00 ,93
ENG253400-ENG260176-Interior_light_router_config-Output_lin9_light_function_slave_9,00 ,93
ENG253400-ENG258236-Interior_light_router_config-Output_roof_console_1,FF ,93
ENG253400-ENG258284-Interior_light_router_config-Output_roof_console_2,FF ,93
ENG253400-ENG260269-Interior_light_router_config-Output_roof_console_3,FF ,93
ENG253400-ENG261203-Interior_light_router_config-Output_roof_console_4,FF ,93
ENG253400-ENG258705-Interior_light_router_config-Output_roof_console_5,FF ,93
ENG253400-ENG258805-Interior_light_router_config-Output_roof_console_6,FF ,93
ENG253400-ENG260327-Interior_light_router_config-Output_tsg_bfs_1,00 ,93
ENG253400-ENG259694-Interior_light_router_config-Output_tsg_bfs_2,00 ,93
ENG253400-ENG261276-Interior_light_router_config-Output_tsg_bfs_3,00 ,93
ENG253400-ENG258178-Interior_light_router_config-Output_tsg_bfs_4,00 ,93
ENG253400-ENG260821-Interior_light_router_config-Output_tsg_bfsh_1,00 ,93
ENG253400-ENG260853-Interior_light_router_config-Output_tsg_bfsh_2,00 ,93
ENG253400-ENG258859-Interior_light_router_config-Output_tsg_bfsh_3,00 ,93
ENG253400-ENG261258-Interior_light_router_config-Output_tsg_bfsh_4,00 ,93
ENG253400-ENG260340-Interior_light_router_config-Output_tsg_fs_1,00 ,93
ENG253400-ENG258105-Interior_light_router_config-Output_tsg_fs_2,00 ,93
ENG253400-ENG260046-Interior_light_router_config-Output_tsg_fs_3,00 ,93
ENG253400-ENG258946-Interior_light_router_config-Output_tsg_fs_4,00 ,93
ENG253400-ENG259611-Interior_light_router_config-Output_tsg_fsh_1,00 ,93
ENG253400-ENG258415-Interior_light_router_config-Output_tsg_fsh_2,00 ,93
ENG253400-ENG260438-Interior_light_router_config-Output_tsg_fsh_3,00 ,93
ENG253400-ENG259398-Interior_light_router_config-Output_tsg_fsh_4,00 ,93
ENG276127-Interior_Monitoring_Data_Set2,No Response From Subnet Component,93
ENG253388-ENG247388-Kessyfunktion-beeptime_reunlock,10_ms ,4
ENG253388-ENG174170-Kessyfunktion-central_locking_system_selective_sigle_door_kessy_NAR,active ,4
ENG253388-ENG259401-Kessyfunktion-Gesamtoeffnung_ueber_Kessy,active ,4
ENG253388-ENG258623-Kessyfunktion-Heck_wiederentriegelung_ohne_Auswurf,active ,4
ENG253388-ENG259486-Kessyfunktion-Komfortbedienung_fh_oeffnen_ueber_kessy,not active ,4
ENG253388-ENG258699-Kessyfunktion-Komfortbedienung_fh_schliessen_ueber_kessy,active ,4
ENG253388-ENG248300-Kessyfunktion-reunlock_beep,not active ,4
ENG253388-ENG259448-Kessyfunktion-Verriegeln_ueber_Toggle_nur_bei_Aussenhaut_geschlossen,not active ,4
ENG253388-ENG259117-Kessyfunktion-Wiederentriegelung_komplett,not_active ,4
ENG253388-ENG260947-Kessyfunktion-ZV_Kessy_Toggle_Taster_aktiv,not active ,4
ENG172886-MAS10514-lcm-Expanded high beam control,High beam assistant ,4
ENG172886-ENG142185-lcm-LCM_blinker,true ,4
ENG172886-ENG142034-lcm-Light_Control_Module,direkt verbaut ,4
ENG253068-ENG261092-Leuchte 0 BLK VL B24-Dimming Direction DEF 0,maximize ,20
ENG253068-ENG259139-Leuchte 0 BLK VL B24-Dimming Direction GHI 0,maximize ,20
ENG253068-ENG259025-Leuchte 0 BLK VL B24-Dimming Direction JKL 0,maximize ,20
ENG253068-ENG259443-Leuchte 0 BLK VL B24-Dimmwert ABC 0,100 ,20
ENG253068-ENG260613-Leuchte 0 BLK VL B24-Dimmwert DEF 0,0 ,20
ENG253068-ENG259327-Leuchte 0 BLK VL B24-Dimmwert GHI 0,0 ,20
ENG253068-ENG261252-Leuchte 0 BLK VL B24-Dimmwert JKL 0,0 ,20
ENG253068-ENG115875-Leuchte 0 BLK VL B24-Fehlerort mittleres Byte DTC-DFCC 0,14 ,20
ENG253068-ENG116547-Leuchte 0 BLK VL B24-Lampendefektbit Position 0,34 ,20
ENG253068-ENG258269-Leuchte 0 BLK VL B24-Lasttyp_0,Blinkleuchten ,20
ENG253068-ENG260373-Leuchte 0 BLK VL B24-Lichtansteuerung HD ABC 0,Always ,20
ENG253068-ENG115876-Leuchte 0 BLK VL B24-Lichtfunktion A 0,Blinken links Hellphase ,20
ENG253068-ENG115877-Leuchte 0 BLK VL B24-Lichtfunktion B 0,not active ,20
ENG253068-ENG115880-Leuchte 0 BLK VL B24-Lichtfunktion C 0,not active ,20
ENG253068-ENG115881-Leuchte 0 BLK VL B24-Lichtfunktion D 0,not active ,20
ENG253068-ENG115884-Leuchte 0 BLK VL B24-Lichtfunktion E 0,not active ,20
ENG253068-ENG115885-Leuchte 0 BLK VL B24-Lichtfunktion F 0,not active ,20
ENG253068-ENG115888-Leuchte 0 BLK VL B24-Lichtfunktion G 0,not active ,20
ENG253068-ENG115889-Leuchte 0 BLK VL B24-Lichtfunktion H 0,not active ,20
ENG253068-ENG258703-Leuchte 0 BLK VL B24-Lichtfunktion I 0,not active ,20
ENG253068-ENG261318-Leuchte 0 BLK VL B24-Lichtfunktion J 0,not active ,20
ENG253068-ENG258291-Leuchte 0 BLK VL B24-Lichtfunktion K 0,not active ,20
ENG253068-ENG258466-Leuchte 0 BLK VL B24-Lichtfunktion L 0,not active ,20
ENG263470-ENG261125-Leuchte 1 BLK VR B9-Dimming Direction DEF 1,maximize ,20
ENG263470-ENG259203-Leuchte 1 BLK VR B9-Dimming Direction GHI 1,maximize ,20
ENG263470-ENG259792-Leuchte 1 BLK VR B9-Dimming Direction JKL 1,maximize ,20
ENG263470-ENG259773-Leuchte 1 BLK VR B9-Dimmwert ABC 1,100 ,20
ENG263470-ENG259452-Leuchte 1 BLK VR B9-Dimmwert DEF 1,0 ,20
ENG263470-ENG258945-Leuchte 1 BLK VR B9-Dimmwert GHI 1,0 ,20
ENG263470-ENG260514-Leuchte 1 BLK VR B9-Dimmwert JKL 1,0 ,20
ENG263470-ENG115894-Leuchte 1 BLK VR B9-Fehlerort mittleres Byte DTC-DFCC 1,15 ,20
ENG263470-ENG116548-Leuchte 1 BLK VR B9-Lampendefektbitposition 1,3E ,20
ENG263470-ENG115892-Leuchte 1 BLK VR B9-Lasttyp 1,Blinkleuchten ,20
ENG263470-ENG258732-Leuchte 1 BLK VR B9-Lichtansteuerung HD ABC 1,Always ,20
ENG263470-ENG115895-Leuchte 1 BLK VR B9-Lichtfunktion A 1,Blinken rechts Hellphase ,20
ENG263470-ENG115896-Leuchte 1 BLK VR B9-Lichtfunktion B 1,not active ,20
ENG263470-ENG115899-Leuchte 1 BLK VR B9-Lichtfunktion C 1,not active ,20
ENG263470-ENG115900-Leuchte 1 BLK VR B9-Lichtfunktion D 1,not active ,20
ENG263470-ENG115903-Leuchte 1 BLK VR B9-Lichtfunktion E 1,not active ,20
ENG263470-ENG115904-Leuchte 1 BLK VR B9-Lichtfunktion F 1,not active ,20
ENG263470-ENG115907-Leuchte 1 BLK VR B9-Lichtfunktion G 1,not active ,20
ENG263470-ENG116549-Leuchte 1 BLK VR B9-Lichtfunktion H 1,not active ,20
ENG263470-ENG258834-Leuchte 1 BLK VR B9-Lichtfunktion I 1,not active ,20
ENG263470-ENG259586-Leuchte 1 BLK VR B9-Lichtfunktion J 1,not active ,20
ENG263470-ENG260282-Leuchte 1 BLK VR B9-Lichtfunktion K 1,not active ,20
ENG263470-ENG260467-Leuchte 1 BLK VR B9-Lichtfunktion L 1,not active ,20
ENG263477-ENG260590-Leuchte 10 SHUTTER L B23-Dimming Direction DEF 10,maximize ,20
ENG263477-ENG260408-Leuchte 10 SHUTTER L B23-Dimming Direction GHI 10,maximize ,20
ENG263477-ENG258321-Leuchte 10 SHUTTER L B23-Dimming Direction JKL 10,maximize ,20
ENG263477-ENG260576-Leuchte 10 SHUTTER L B23-Dimmwert ABC 10,0 ,20
ENG263477-ENG258223-Leuchte 10 SHUTTER L B23-Dimmwert DEF 10,0 ,20
ENG263477-ENG260725-Leuchte 10 SHUTTER L B23-Dimmwert GHI 10,0 ,20
ENG263477-ENG258779-Leuchte 10 SHUTTER L B23-Dimmwert JKL 10,0 ,20
ENG263477-ENG116064-Leuchte 10 SHUTTER L B23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,20
ENG263477-ENG116560-Leuchte 10 SHUTTER L B23-Lampendefektbitposition 10,00 ,20
ENG263477-ENG116062-Leuchte 10 SHUTTER L B23-Lasttyp 10,not_active ,20
ENG263477-ENG260677-Leuchte 10 SHUTTER L B23-Lichtansteuerung HD ABC 10,Always ,20
ENG263477-ENG116065-Leuchte 10 SHUTTER L B23-Lichtfunktion A 10,not active ,20
ENG263477-ENG116066-Leuchte 10 SHUTTER L B23-Lichtfunktion B 10,not active ,20
ENG263477-ENG116069-Leuchte 10 SHUTTER L B23-Lichtfunktion C 10,not active ,20
ENG263477-ENG116070-Leuchte 10 SHUTTER L B23-Lichtfunktion D 10,not active ,20
ENG263477-ENG116073-Leuchte 10 SHUTTER L B23-Lichtfunktion E 10,not active ,20
ENG263477-ENG116074-Leuchte 10 SHUTTER L B23-Lichtfunktion F 10,not active ,20
ENG263477-ENG116077-Leuchte 10 SHUTTER L B23-Lichtfunktion G 10,not active ,20
ENG263477-ENG116078-Leuchte 10 SHUTTER L B23-Lichtfunktion H 10,not active ,20
ENG263477-ENG261127-Leuchte 10 SHUTTER L B23-Lichtfunktion I 10,not active ,20
ENG263477-ENG259264-Leuchte 10 SHUTTER L B23-Lichtfunktion J 10,not active ,20
ENG263477-ENG258792-Leuchte 10 SHUTTER L B23-Lichtfunktion K 10,not active ,20
ENG263477-ENG260117-Leuchte 10 SHUTTER L B23-Lichtfunktion L 10,not active ,20
ENG263480-ENG260377-Leuchte 11 SHUTTER R B22-Dimming Direction DEF 11,maximize ,20
ENG263480-ENG261238-Leuchte 11 SHUTTER R B22-Dimming Direction GHI 11,maximize ,20
ENG263480-ENG258509-Leuchte 11 SHUTTER R B22-Dimming Direction JKL 11,maximize ,20
ENG263480-ENG259362-Leuchte 11 SHUTTER R B22-Dimmwert ABC 11,0 ,20
ENG263480-ENG259167-Leuchte 11 SHUTTER R B22-Dimmwert DEF 11,0 ,20
ENG263480-ENG259831-Leuchte 11 SHUTTER R B22-Dimmwert GHI 11,0 ,20
ENG263480-ENG259729-Leuchte 11 SHUTTER R B22-Dimmwert JKL 11,0 ,20
ENG263480-ENG116083-Leuchte 11 SHUTTER R B22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,20
ENG263480-ENG116561-Leuchte 11 SHUTTER R B22-Lampendefektbitposition 11,00 ,20
ENG263480-ENG116081-Leuchte 11 SHUTTER R B22-Lasttyp 11,not_active ,20
ENG263480-ENG259732-Leuchte 11 SHUTTER R B22-Lichtansteuerung HD ABC 11,Always ,20
ENG263480-ENG116084-Leuchte 11 SHUTTER R B22-Lichtfunktion A 11,not active ,20
ENG263480-ENG116085-Leuchte 11 SHUTTER R B22-Lichtfunktion B 11,not active ,20
ENG263480-ENG116088-Leuchte 11 SHUTTER R B22-Lichtfunktion C 11,not active ,20
ENG263480-ENG116089-Leuchte 11 SHUTTER R B22-Lichtfunktion D 11,not active ,20
ENG263480-ENG116092-Leuchte 11 SHUTTER R B22-Lichtfunktion E 11,not active ,20
ENG263480-ENG116093-Leuchte 11 SHUTTER R B22-Lichtfunktion F 11,not active ,20
ENG263480-ENG116096-Leuchte 11 SHUTTER R B22-Lichtfunktion G 11,not active ,20
ENG263480-ENG116097-Leuchte 11 SHUTTER R B22-Lichtfunktion H 11,not active ,20
ENG263480-ENG260510-Leuchte 11 SHUTTER R B22-Lichtfunktion I 11,not active ,20
ENG263480-ENG258304-Leuchte 11 SHUTTER R B22-Lichtfunktion J 11,not active ,20
ENG263480-ENG260059-Leuchte 11 SHUTTER R B22-Lichtfunktion K 11,not active ,20
ENG263480-ENG260686-Leuchte 11 SHUTTER R B22-Lichtfunktion L 11,not active ,20
ENG263462-ENG259122-Leuchte 12 NL L B45-Dimming Direction DEF 12,maximize ,20
ENG263462-ENG260186-Leuchte 12 NL L B45-Dimming Direction GHI 12,maximize ,20
ENG263462-ENG258138-Leuchte 12 NL L B45-Dimming Direction JKL 12,maximize ,20
ENG263462-ENG261305-Leuchte 12 NL L B45-Dimmwert ABC 12,127 ,20
ENG263462-ENG258909-Leuchte 12 NL L B45-Dimmwert DEF 12,0 ,20
ENG263462-ENG261043-Leuchte 12 NL L B45-Dimmwert GHI 12,0 ,20
ENG263462-ENG261121-Leuchte 12 NL L B45-Dimmwert JKL 12,0 ,20
ENG263462-ENG116102-Leuchte 12 NL L B45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,20
ENG263462-ENG116562-Leuchte 12 NL L B45-Lampendefektbitposition 12,38 ,20
ENG263462-ENG116100-Leuchte 12 NL L B45-Lasttyp 12,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263462-ENG258775-Leuchte 12 NL L B45-Lichtansteuerung HD ABC 12,Always ,20
ENG263462-ENG116103-Leuchte 12 NL L B45-Lichtfunktion A 12,Nebellicht links ,20
ENG263462-ENG116104-Leuchte 12 NL L B45-Lichtfunktion B 12,not active ,20
ENG263462-ENG116107-Leuchte 12 NL L B45-Lichtfunktion C 12,not active ,20
ENG263462-ENG116108-Leuchte 12 NL L B45-Lichtfunktion D 12,not active ,20
ENG263462-ENG116111-Leuchte 12 NL L B45-Lichtfunktion E 12,not active ,20
ENG263462-ENG116112-Leuchte 12 NL L B45-Lichtfunktion F 12,not active ,20
ENG263462-ENG116115-Leuchte 12 NL L B45-Lichtfunktion G 12,not active ,20
ENG263462-ENG116116-Leuchte 12 NL L B45-Lichtfunktion H 12,not active ,20
ENG263462-ENG261188-Leuchte 12 NL L B45-Lichtfunktion I 12,not active ,20
ENG263462-ENG260482-Leuchte 12 NL L B45-Lichtfunktion J 12,not active ,20
ENG263462-ENG258107-Leuchte 12 NL L B45-Lichtfunktion K 12,not active ,20
ENG263462-ENG259735-Leuchte 12 NL L B45-Lichtfunktion L 12,not active ,20
ENG263429-ENG258235-Leuchte 13 NL R B5-Dimming Direction DEF 13,maximize ,20
ENG263429-ENG258860-Leuchte 13 NL R B5-Dimming Direction GHI 13,maximize ,20
ENG263429-ENG261185-Leuchte 13 NL R B5-Dimming Direction JKL 13,maximize ,20
ENG263429-ENG260614-Leuchte 13 NL R B5-Dimmwert ABC 13,127 ,20
ENG263429-ENG258948-Leuchte 13 NL R B5-Dimmwert DEF 13,0 ,20
ENG263429-ENG261076-Leuchte 13 NL R B5-Dimmwert GHI 13,0 ,20
ENG263429-ENG260048-Leuchte 13 NL R B5-Dimmwert JKL 13,0 ,20
ENG263429-ENG116121-Leuchte 13 NL R B5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,20
ENG263429-ENG116563-Leuchte 13 NL R B5-Lampendefektbitposition 13,42 ,20
ENG263429-ENG116119-Leuchte 13 NL R B5-Lasttyp 13,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263429-ENG259297-Leuchte 13 NL R B5-Lichtansteuerung HD ABC 13,Always ,20
ENG263429-ENG116122-Leuchte 13 NL R B5-Lichtfunktion A 13,Nebellicht rechts ,20
ENG263429-ENG116123-Leuchte 13 NL R B5-Lichtfunktion B 13,not active ,20
ENG263429-ENG116564-Leuchte 13 NL R B5-Lichtfunktion C 13,not active ,20
ENG263429-ENG116127-Leuchte 13 NL R B5-Lichtfunktion D 13,not active ,20
ENG263429-ENG116130-Leuchte 13 NL R B5-Lichtfunktion E 13,not active ,20
ENG263429-ENG116131-Leuchte 13 NL R B5-Lichtfunktion F 13,not active ,20
ENG263429-ENG116134-Leuchte 13 NL R B5-Lichtfunktion G 13,not active ,20
ENG263429-ENG116135-Leuchte 13 NL R B5-Lichtfunktion H 13,not active ,20
ENG263429-ENG259477-Leuchte 13 NL R B5-Lichtfunktion I 13,not active ,20
ENG263429-ENG259138-Leuchte 13 NL R B5-Lichtfunktion J 13,not active ,20
ENG263429-ENG258127-Leuchte 13 NL R B5-Lichtfunktion K 13,not active ,20
ENG263429-ENG259174-Leuchte 13 NL R B5-Lichtfunktion L 13,not active ,20
ENG263460-ENG260021-Leuchte 16 BLK SL B42_C31-Dimming Direction DEF 16,maximize ,20
ENG263460-ENG258735-Leuchte 16 BLK SL B42_C31-Dimming Direction GHI 16,maximize ,20
ENG263460-ENG260912-Leuchte 16 BLK SL B42_C31-Dimming Direction JKL 16,maximize ,20
ENG263460-ENG260010-Leuchte 16 BLK SL B42_C31-Dimmwert ABC 16,0 ,20
ENG263460-ENG258276-Leuchte 16 BLK SL B42_C31-Dimmwert DEF 16,0 ,20
ENG263460-ENG259552-Leuchte 16 BLK SL B42_C31-Dimmwert GHI 16,0 ,20
ENG263460-ENG260945-Leuchte 16 BLK SL B42_C31-Dimmwert JKL 16,0 ,20
ENG263460-ENG116178-Leuchte 16 BLK SL B42_C31-Fehlerort mittleres Byte DTC-DFCC 16,00 ,20
ENG263460-ENG116567-Leuchte 16 BLK SL B42_C31-Lampendefektbitposition 16,00 ,20
ENG263460-ENG116176-Leuchte 16 BLK SL B42_C31-Lasttyp 16,not_active ,20
ENG263460-ENG258626-Leuchte 16 BLK SL B42_C31-Lichtansteuerung HD ABC 16,Always ,20
ENG263460-ENG116179-Leuchte 16 BLK SL B42_C31-Lichtfunktion A 16,not active ,20
ENG263460-ENG116180-Leuchte 16 BLK SL B42_C31-Lichtfunktion B 16,not active ,20
ENG263460-ENG116183-Leuchte 16 BLK SL B42_C31-Lichtfunktion C 16,not active ,20
ENG263460-ENG116184-Leuchte 16 BLK SL B42_C31-Lichtfunktion D 16,not active ,20
ENG263460-ENG116187-Leuchte 16 BLK SL B42_C31-Lichtfunktion E 16,not active ,20
ENG263460-ENG116188-Leuchte 16 BLK SL B42_C31-Lichtfunktion F 16,not active ,20
ENG263460-ENG116191-Leuchte 16 BLK SL B42_C31-Lichtfunktion G 16,not active ,20
ENG263460-ENG116192-Leuchte 16 BLK SL B42_C31-Lichtfunktion H 16,not active ,20
ENG263460-ENG261052-Leuchte 16 BLK SL B42_C31-Lichtfunktion I 16,not active ,20
ENG263460-ENG258938-Leuchte 16 BLK SL B42_C31-Lichtfunktion J 16,not active ,20
ENG263460-ENG258710-Leuchte 16 BLK SL B42_C31-Lichtfunktion K 16,not active ,20
ENG263460-ENG259847-Leuchte 16 BLK SL B42_C31-Lichtfunktion L 16,not active ,20
ENG253179-ENG258693-Leuchte 17 BLK_SR B4_A61-Dimming Direction DEF 17,maximize ,20
ENG253179-ENG259225-Leuchte 17 BLK_SR B4_A61-Dimming Direction GHI 17,maximize ,20
ENG253179-ENG260036-Leuchte 17 BLK_SR B4_A61-Dimming Direction JKL 17,maximize ,20
ENG253179-ENG259305-Leuchte 17 BLK_SR B4_A61-Dimmwert ABC 17,0 ,20
ENG253179-ENG260736-Leuchte 17 BLK_SR B4_A61-Dimmwert DEF 17,0 ,20
ENG253179-ENG261209-Leuchte 17 BLK_SR B4_A61-Dimmwert GHI 17,0 ,20
ENG253179-ENG260649-Leuchte 17 BLK_SR B4_A61-Dimmwert JKL 17,0 ,20
ENG253179-ENG116197-Leuchte 17 BLK_SR B4_A61-Fehlerort mittleres Byte DTC-DFCC 17,00 ,20
ENG253179-ENG116568-Leuchte 17 BLK_SR B4_A61-Lampendefektbitposition 17,00 ,20
ENG253179-ENG116195-Leuchte 17 BLK_SR B4_A61-Lasttyp 17,not_active ,20
ENG253179-ENG259860-Leuchte 17 BLK_SR B4_A61-Lichtansteuerung HD ABC 17,Always ,20
ENG253179-ENG116198-Leuchte 17 BLK_SR B4_A61-Lichtfunktion A 17,not active ,20
ENG253179-ENG116569-Leuchte 17 BLK_SR B4_A61-Lichtfunktion B 17,not active ,20
ENG253179-ENG116202-Leuchte 17 BLK_SR B4_A61-Lichtfunktion C 17,not active ,20
ENG253179-ENG116203-Leuchte 17 BLK_SR B4_A61-Lichtfunktion D 17,not active ,20
ENG253179-ENG116206-Leuchte 17 BLK_SR B4_A61-Lichtfunktion E 17,not active ,20
ENG253179-ENG116207-Leuchte 17 BLK_SR B4_A61-Lichtfunktion F 17,not active ,20
ENG253179-ENG116210-Leuchte 17 BLK_SR B4_A61-Lichtfunktion G 17,not active ,20
ENG253179-ENG116211-Leuchte 17 BLK_SR B4_A61-Lichtfunktion H 17,not active ,20
ENG253179-ENG258378-Leuchte 17 BLK_SR B4_A61-Lichtfunktion I 17,not active ,20
ENG253179-ENG259950-Leuchte 17 BLK_SR B4_A61-Lichtfunktion J 17,not active ,20
ENG253179-ENG259363-Leuchte 17 BLK_SR B4_A61-Lichtfunktion K 17,not active ,20
ENG253179-ENG259816-Leuchte 17 BLK_SR B4_A61-Lichtfunktion L 17,not active ,20
ENG263478-ENG260141-Leuchte 18 BLK HL A60-Dimming Direction DEF 18,minimize ,20
ENG263478-ENG258397-Leuchte 18 BLK HL A60-Dimming Direction GHI 18,maximize ,20
ENG263478-ENG259980-Leuchte 18 BLK HL A60-Dimming Direction JKL 18,maximize ,20
ENG263478-ENG261250-Leuchte 18 BLK HL A60-Dimmwert ABC 18,127 ,20
ENG263478-ENG258343-Leuchte 18 BLK HL A60-Dimmwert DEF 18,0 ,20
ENG263478-ENG258799-Leuchte 18 BLK HL A60-Dimmwert GHI 18,127 ,20
ENG263478-ENG259813-Leuchte 18 BLK HL A60-Dimmwert JKL 18,0 ,20
ENG263478-ENG116216-Leuchte 18 BLK HL A60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,20
ENG263478-ENG116570-Leuchte 18 BLK HL A60-Lampendefektbitposition 18,08 ,20
ENG263478-ENG116214-Leuchte 18 BLK HL A60-Lasttyp 18,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263478-ENG258246-Leuchte 18 BLK HL A60-Lichtansteuerung HD ABC 18,Always ,20
ENG263478-ENG116217-Leuchte 18 BLK HL A60-Lichtfunktion A 18,Quittierungsfunktion1 ,20
ENG263478-ENG116218-Leuchte 18 BLK HL A60-Lichtfunktion B 18,not active ,20
ENG263478-ENG116221-Leuchte 18 BLK HL A60-Lichtfunktion C 18,not active ,20
ENG263478-ENG116222-Leuchte 18 BLK HL A60-Lichtfunktion D 18,Blinken links aktiv ,20
ENG263478-ENG116225-Leuchte 18 BLK HL A60-Lichtfunktion E 18,not active ,20
ENG263478-ENG116226-Leuchte 18 BLK HL A60-Lichtfunktion F 18,not active ,20
ENG263478-ENG116229-Leuchte 18 BLK HL A60-Lichtfunktion G 18,Blinken links Hellphase ,20
ENG263478-ENG116230-Leuchte 18 BLK HL A60-Lichtfunktion H 18,not active ,20
ENG263478-ENG259904-Leuchte 18 BLK HL A60-Lichtfunktion I 18,not active ,20
ENG263478-ENG260450-Leuchte 18 BLK HL A60-Lichtfunktion J 18,not active ,20
ENG263478-ENG258383-Leuchte 18 BLK HL A60-Lichtfunktion K 18,not active ,20
ENG263478-ENG261100-Leuchte 18 BLK HL A60-Lichtfunktion L 18,not active ,20
ENG263431-ENG258368-Leuchte 19 BLK HR C27-Dimming Direction DEF 19,minimize ,20
ENG263431-ENG260517-Leuchte 19 BLK HR C27-Dimming Direction GHI 19,maximize ,20
ENG263431-ENG260100-Leuchte 19 BLK HR C27-Dimming Direction JKL 19,maximize ,20
ENG263431-ENG259136-Leuchte 19 BLK HR C27-Dimmwert ABC 19,127 ,20
ENG263431-ENG260521-Leuchte 19 BLK HR C27-Dimmwert DEF 19,0 ,20
ENG263431-ENG260131-Leuchte 19 BLK HR C27-Dimmwert GHI 19,127 ,20
ENG263431-ENG259140-Leuchte 19 BLK HR C27-Dimmwert JKL 19,0 ,20
ENG263431-ENG116235-Leuchte 19 BLK HR C27-Fehlerort mittleres Byte DTC-DFCC 19,18 ,20
ENG263431-ENG116571-Leuchte 19 BLK HR C27-Lampendefektbitposition 19,18 ,20
ENG263431-ENG116233-Leuchte 19 BLK HR C27-Lasttyp 19,LED_Blinkleuchten_mit_Ueberspg_absch ,20
ENG263431-ENG258684-Leuchte 19 BLK HR C27-Lichtansteuerung HD ABC 19,Always ,20
ENG263431-ENG116236-Leuchte 19 BLK HR C27-Lichtfunktion A 19,Quittierungsfunktion1 ,20
ENG263431-ENG116237-Leuchte 19 BLK HR C27-Lichtfunktion B 19,not active ,20
ENG263431-ENG116240-Leuchte 19 BLK HR C27-Lichtfunktion C 19,not active ,20
ENG263431-ENG116241-Leuchte 19 BLK HR C27-Lichtfunktion D 19,Blinken rechts aktiv ,20
ENG263431-ENG116244-Leuchte 19 BLK HR C27-Lichtfunktion E 19,not active ,20
ENG263431-ENG116245-Leuchte 19 BLK HR C27-Lichtfunktion F 19,not active ,20
ENG263431-ENG116248-Leuchte 19 BLK HR C27-Lichtfunktion G 19,Blinken rechts Hellphase ,20
ENG263431-ENG116249-Leuchte 19 BLK HR C27-Lichtfunktion H 19,not active ,20
ENG263431-ENG258386-Leuchte 19 BLK HR C27-Lichtfunktion I 19,not active ,20
ENG263431-ENG261194-Leuchte 19 BLK HR C27-Lichtfunktion J 19,not active ,20
ENG263431-ENG260240-Leuchte 19 BLK HR C27-Lichtfunktion K 19,not active ,20
ENG263431-ENG258090-Leuchte 19 BLK HR C27-Lichtfunktion L 19,not active ,20
ENG263453-ENG259538-Leuchte 2 SL VL B20-Dimming Direction DEF 2,minimize ,20
ENG263453-ENG259039-Leuchte 2 SL VL B20-Dimming Direction GHI 2,maximize ,20
ENG263453-ENG261192-Leuchte 2 SL VL B20-Dimming Direction JKL 2,maximize ,20
ENG263453-ENG260561-Leuchte 2 SL VL B20-Dimmwert ABC 2,127 ,20
ENG263453-ENG259420-Leuchte 2 SL VL B20-Dimmwert DEF 2,0 ,20
ENG263453-ENG258177-Leuchte 2 SL VL B20-Dimmwert GHI 2,0 ,20
ENG263453-ENG260473-Leuchte 2 SL VL B20-Dimmwert JKL 2,0 ,20
ENG263453-ENG115912-Leuchte 2 SL VL B20-Fehlerort mittleres Byte DTC-DFCC 2,31 ,20
ENG263453-ENG116550-Leuchte 2 SL VL B20-Lampendefektbitposition 2,0B ,20
ENG263453-ENG115910-Leuchte 2 SL VL B20-Lasttyp 2,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263453-ENG259674-Leuchte 2 SL VL B20-Lichtansteuerung HD ABC 2,Always ,20
ENG263453-ENG115913-Leuchte 2 SL VL B20-Lichtfunktion A 2,Rueckfahrlicht ,20
ENG263453-ENG115914-Leuchte 2 SL VL B20-Lichtfunktion B 2,not active ,20
ENG263453-ENG115917-Leuchte 2 SL VL B20-Lichtfunktion C 2,not active ,20
ENG263453-ENG115918-Leuchte 2 SL VL B20-Lichtfunktion D 2,not active ,20
ENG263453-ENG115921-Leuchte 2 SL VL B20-Lichtfunktion E 2,not active ,20
ENG263453-ENG115922-Leuchte 2 SL VL B20-Lichtfunktion F 2,not active ,20
ENG263453-ENG115925-Leuchte 2 SL VL B20-Lichtfunktion G 2,not active ,20
ENG263453-ENG115926-Leuchte 2 SL VL B20-Lichtfunktion H 2,not active ,20
ENG263453-ENG261008-Leuchte 2 SL VL B20-Lichtfunktion I 2,not active ,20
ENG263453-ENG259089-Leuchte 2 SL VL B20-Lichtfunktion J 2,not active ,20
ENG263453-ENG259764-Leuchte 2 SL VL B20-Lichtfunktion K 2,not active ,20
ENG263453-ENG261215-Leuchte 2 SL VL B20-Lichtfunktion L 2,not active ,20
ENG263476-ENG258998-Leuchte 20 BR L A71-Dimming Direction DEF 20,minimize ,20
ENG263476-ENG260228-Leuchte 20 BR L A71-Dimming Direction GHI 20,maximize ,20
ENG263476-ENG258824-Leuchte 20 BR L A71-Dimming Direction JKL 20,maximize ,20
ENG263476-ENG261006-Leuchte 20 BR L A71-Dimmwert ABC 20,127 ,20
ENG263476-ENG260784-Leuchte 20 BR L A71-Dimmwert DEF 20,0 ,20
ENG263476-ENG260188-Leuchte 20 BR L A71-Dimmwert GHI 20,0 ,20
ENG263476-ENG258358-Leuchte 20 BR L A71-Dimmwert JKL 20,0 ,20
ENG263476-ENG116254-Leuchte 20 BR L A71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,20
ENG263476-ENG116572-Leuchte 20 BR L A71-Lampendefektbitposition 20,09 ,20
ENG263476-ENG116252-Leuchte 20 BR L A71-Lasttyp 20,LED_Bremsleuchten ,20
ENG263476-ENG259045-Leuchte 20 BR L A71-Lichtansteuerung HD ABC 20,Always ,20
ENG263476-ENG116255-Leuchte 20 BR L A71-Lichtfunktion A 20,Brake lamp ,20
ENG263476-ENG116256-Leuchte 20 BR L A71-Lichtfunktion B 20,not active ,20
ENG263476-ENG116259-Leuchte 20 BR L A71-Lichtfunktion C 20,not active ,20
ENG263476-ENG116260-Leuchte 20 BR L A71-Lichtfunktion D 20,Blinken links aktiv ,20
ENG263476-ENG116263-Leuchte 20 BR L A71-Lichtfunktion E 20,not active ,20
ENG263476-ENG116264-Leuchte 20 BR L A71-Lichtfunktion F 20,not active ,20
ENG263476-ENG116267-Leuchte 20 BR L A71-Lichtfunktion G 20,not active ,20
ENG263476-ENG116268-Leuchte 20 BR L A71-Lichtfunktion H 20,not active ,20
ENG263476-ENG259111-Leuchte 20 BR L A71-Lichtfunktion I 20,not active ,20
ENG263476-ENG259768-Leuchte 20 BR L A71-Lichtfunktion J 20,not active ,20
ENG263476-ENG260741-Leuchte 20 BR L A71-Lichtfunktion K 20,not active ,20
ENG263476-ENG258272-Leuchte 20 BR L A71-Lichtfunktion L 20,not active ,20
ENG263446-ENG259371-Leuchte 21 BR R C8-Dimming Direction DEF 21,minimize ,20
ENG263446-ENG261222-Leuchte 21 BR R C8-Dimming Direction GHI 21,maximize ,20
ENG263446-ENG260449-Leuchte 21 BR R C8-Dimming Direction JKL 21,maximize ,20
ENG263446-ENG260142-Leuchte 21 BR R C8-Dimmwert ABC 21,127 ,20
ENG263446-ENG259169-Leuchte 21 BR R C8-Dimmwert DEF 21,0 ,20
ENG263446-ENG258330-Leuchte 21 BR R C8-Dimmwert GHI 21,0 ,20
ENG263446-ENG260224-Leuchte 21 BR R C8-Dimmwert JKL 21,0 ,20
ENG263446-ENG116273-Leuchte 21 BR R C8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,20
ENG263446-ENG116573-Leuchte 21 BR R C8-Lampendefektbitposition 21,19 ,20
ENG263446-ENG116271-Leuchte 21 BR R C8-Lasttyp 21,LED_Bremsleuchten ,20
ENG263446-ENG259749-Leuchte 21 BR R C8-Lichtansteuerung HD ABC 21,Always ,20
ENG263446-ENG116274-Leuchte 21 BR R C8-Lichtfunktion A 21,Brake lamp ,20
ENG263446-ENG116275-Leuchte 21 BR R C8-Lichtfunktion B 21,not active ,20
ENG263446-ENG116278-Leuchte 21 BR R C8-Lichtfunktion C 21,not active ,20
ENG263446-ENG116279-Leuchte 21 BR R C8-Lichtfunktion D 21,Blinken rechts aktiv ,20
ENG263446-ENG116282-Leuchte 21 BR R C8-Lichtfunktion E 21,not active ,20
ENG263446-ENG116283-Leuchte 21 BR R C8-Lichtfunktion F 21,not active ,20
ENG263446-ENG116286-Leuchte 21 BR R C8-Lichtfunktion G 21,not active ,20
ENG263446-ENG116287-Leuchte 21 BR R C8-Lichtfunktion H 21,not active ,20
ENG263446-ENG260531-Leuchte 21 BR R C8-Lichtfunktion I 21,not active ,20
ENG263446-ENG258267-Leuchte 21 BR R C8-Lichtfunktion J 21,not active ,20
ENG263446-ENG261265-Leuchte 21 BR R C8-Lichtfunktion K 21,not active ,20
ENG263446-ENG261356-Leuchte 21 BR R C8-Lichtfunktion L 21,not active ,20
ENG263487-ENG261009-Leuchte 22 BR M A57-Dimming Direction DEF 22,maximize ,20
ENG263487-ENG259558-Leuchte 22 BR M A57-Dimming Direction GHI 22,maximize ,20
ENG263487-ENG258098-Leuchte 22 BR M A57-Dimming Direction JKL 22,maximize ,20
ENG263487-ENG260824-Leuchte 22 BR M A57-Dimmwert ABC 22,127 ,20
ENG263487-ENG261330-Leuchte 22 BR M A57-Dimmwert DEF 22,0 ,20
ENG263487-ENG260249-Leuchte 22 BR M A57-Dimmwert GHI 22,0 ,20
ENG263487-ENG260794-Leuchte 22 BR M A57-Dimmwert JKL 22,0 ,20
ENG263487-ENG116292-Leuchte 22 BR M A57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,20
ENG263487-ENG116574-Leuchte 22 BR M A57-Lampendefektbitposition 22,29 ,20
ENG263487-ENG116290-Leuchte 22 BR M A57-Lasttyp 22,LED_dritte_Bremsleuchte ,20
ENG263487-ENG259134-Leuchte 22 BR M A57-Lichtansteuerung HD ABC 22,Always ,20
ENG263487-ENG116293-Leuchte 22 BR M A57-Lichtfunktion A 22,Brake lamp ,20
ENG263487-ENG116294-Leuchte 22 BR M A57-Lichtfunktion B 22,not active ,20
ENG263487-ENG116297-Leuchte 22 BR M A57-Lichtfunktion C 22,not active ,20
ENG263487-ENG116298-Leuchte 22 BR M A57-Lichtfunktion D 22,not active ,20
ENG263487-ENG116301-Leuchte 22 BR M A57-Lichtfunktion E 22,not active ,20
ENG263487-ENG116302-Leuchte 22 BR M A57-Lichtfunktion F 22,not active ,20
ENG263487-ENG116305-Leuchte 22 BR M A57-Lichtfunktion G 22,not active ,20
ENG263487-ENG116306-Leuchte 22 BR M A57-Lichtfunktion H 22,not active ,20
ENG263487-ENG261266-Leuchte 22 BR M A57-Lichtfunktion I 22,not active ,20
ENG263487-ENG259294-Leuchte 22 BR M A57-Lichtfunktion J 22,not active ,20
ENG263487-ENG258164-Leuchte 22 BR M A57-Lichtfunktion K 22,not active ,20
ENG263487-ENG259578-Leuchte 22 BR M A57-Lichtfunktion L 22,not active ,20
ENG263433-ENG259710-Leuchte 23 SL HL C10-Dimming Direction DEF 32,maximize ,20
ENG263433-ENG258905-Leuchte 23 SL HL C10-Dimming Direction GHI 32,maximize ,20
ENG263433-ENG260532-Leuchte 23 SL HL C10-Dimming Direction JKL 32,maximize ,20
ENG263433-ENG259737-Leuchte 23 SL HL C10-Dimmwert ABC 32,127 ,20
ENG263433-ENG259346-Leuchte 23 SL HL C10-Dimmwert DEF 32,0 ,20
ENG263433-ENG260258-Leuchte 23 SL HL C10-Dimmwert GHI 32,0 ,20
ENG263433-ENG260382-Leuchte 23 SL HL C10-Dimmwert JKL 32,0 ,20
ENG263433-ENG116482-Leuchte 23 SL HL C10-Fehlerort mittleres Byte DTC-DFCC 32,29 ,20
ENG263433-ENG116584-Leuchte 23 SL HL C10-Lampendefektbitposition 32,0A ,20
ENG263433-ENG116480-Leuchte 23 SL HL C10-Lasttyp 32,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263433-ENG259035-Leuchte 23 SL HL C10-Lichtansteuerung HD ABC 32,Always ,20
ENG263433-ENG116483-Leuchte 23 SL HL C10-Lichtfunktion A 32,Position lamps ,20
ENG263433-ENG116484-Leuchte 23 SL HL C10-Lichtfunktion B 32,Parking light left ,20
ENG263433-ENG116487-Leuchte 23 SL HL C10-Lichtfunktion C 32,not active ,20
ENG263433-ENG116488-Leuchte 23 SL HL C10-Lichtfunktion D 32,not active ,20
ENG263433-ENG116491-Leuchte 23 SL HL C10-Lichtfunktion E 32,not active ,20
ENG263433-ENG116492-Leuchte 23 SL HL C10-Lichtfunktion F 32,not active ,20
ENG263433-ENG116495-Leuchte 23 SL HL C10-Lichtfunktion G 32,not active ,20
ENG263433-ENG116496-Leuchte 23 SL HL C10-Lichtfunktion H 32,not active ,20
ENG263433-ENG258763-Leuchte 23 SL HL C10-Lichtfunktion I 32,not active ,20
ENG263433-ENG259842-Leuchte 23 SL HL C10-Lichtfunktion J 32,not active ,20
ENG263433-ENG258857-Leuchte 23 SL HL C10-Lichtfunktion K 32,not active ,20
ENG263433-ENG260175-Leuchte 23 SL HL C10-Lichtfunktion L 32,not active ,20
ENG263475-ENG260709-Leuchte 24 SL HR A65-Dimming Direction DEF 24,maximize ,20
ENG263475-ENG258518-Leuchte 24 SL HR A65-Dimming Direction GHI 24,maximize ,20
ENG263475-ENG258189-Leuchte 24 SL HR A65-Dimming Direction JKL 24,maximize ,20
ENG263475-ENG259150-Leuchte 24 SL HR A65-Dimmwert ABC 24,127 ,20
ENG263475-ENG259120-Leuchte 24 SL HR A65-Dimmwert DEF 24,0 ,20
ENG263475-ENG259774-Leuchte 24 SL HR A65-Dimmwert GHI 24,0 ,20
ENG263475-ENG259393-Leuchte 24 SL HR A65-Dimmwert JKL 24,0 ,20
ENG263475-ENG116330-Leuchte 24 SL HR A65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,20
ENG263475-ENG116576-Leuchte 24 SL HR A65-Lampendefektbitposition 24,1A ,20
ENG263475-ENG116328-Leuchte 24 SL HR A65-Lasttyp 24,allgemeine_LED_mit_Open_Load_Diagnose_12W ,20
ENG263475-ENG258842-Leuchte 24 SL HR A65-Lichtansteuerung HD ABC 24,Always ,20
ENG263475-ENG116331-Leuchte 24 SL HR A65-Lichtfunktion A 24,Position lamps ,20
ENG263475-ENG116332-Leuchte 24 SL HR A65-Lichtfunktion B 24,Parking light right ,20
ENG263475-ENG116335-Leuchte 24 SL HR A65-Lichtfunktion C 24,not active ,20
ENG263475-ENG116336-Leuchte 24 SL HR A65-Lichtfunktion D 24,not active ,20
ENG263475-ENG116339-Leuchte 24 SL HR A65-Lichtfunktion E 24,not active ,20
ENG263475-ENG116340-Leuchte 24 SL HR A65-Lichtfunktion F 24,not active ,20
ENG263475-ENG116343-Leuchte 24 SL HR A65-Lichtfunktion G 24,not active ,20
ENG263475-ENG116344-Leuchte 24 SL HR A65-Lichtfunktion H 24,not active ,20
ENG263475-ENG260865-Leuchte 24 SL HR A65-Lichtfunktion I 24,not active ,20
ENG263475-ENG260414-Leuchte 24 SL HR A65-Lichtfunktion J 24,not active ,20
ENG263475-ENG260577-Leuchte 24 SL HR A65-Lichtfunktion K 24,not active ,20
ENG263475-ENG260598-Leuchte 24 SL HR A65-Lichtfunktion L 24,not active ,20
ENG263447-ENG260768-Leuchte 25 KZL H A59-Dimming Direction DEF 25,maximize ,20
ENG263447-ENG259422-Leuchte 25 KZL H A59-Dimming Direction GHI 25,maximize ,20
ENG263447-ENG258848-Leuchte 25 KZL H A59-Dimming Direction JKL 25,maximize ,20
ENG263447-ENG258210-Leuchte 25 KZL H A59-Dimmwert ABC 25,127 ,20
ENG263447-ENG260749-Leuchte 25 KZL H A59-Dimmwert DEF 25,0 ,20
ENG263447-ENG258574-Leuchte 25 KZL H A59-Dimmwert GHI 25,0 ,20
ENG263447-ENG259896-Leuchte 25 KZL H A59-Dimmwert JKL 25,0 ,20
ENG263447-ENG116349-Leuchte 25 KZL H A59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,20
ENG263447-ENG116577-Leuchte 25 KZL H A59-Lampendefektbitposition 25,28 ,20
ENG263447-ENG116347-Leuchte 25 KZL H A59-Lasttyp 25,allg_LED_mit_Open_Load_Diagnose_ohne_PWM ,20
ENG263447-ENG259553-Leuchte 25 KZL H A59-Lichtansteuerung HD ABC 25,Always ,20
ENG263447-ENG116350-Leuchte 25 KZL H A59-Lichtfunktion A 25,Position lamps ,20
ENG263447-ENG116351-Leuchte 25 KZL H A59-Lichtfunktion B 25,not active ,20
ENG263447-ENG116354-Leuchte 25 KZL H A59-Lichtfunktion C 25,not active ,20
ENG263447-ENG116355-Leuchte 25 KZL H A59-Lichtfunktion D 25,not active ,20
ENG263447-ENG116358-Leuchte 25 KZL H A59-Lichtfunktion E 25,not active ,20
ENG263447-ENG259247-Leuchte 25 KZL H A59-Lichtfunktion F25,not active ,20
ENG263447-ENG116362-Leuchte 25 KZL H A59-Lichtfunktion G 25,not active ,20
ENG263447-ENG116363-Leuchte 25 KZL H A59-Lichtfunktion H 25,not active ,20
ENG263447-ENG260931-Leuchte 25 KZL H A59-Lichtfunktion I 25,not active ,20
ENG263447-ENG258654-Leuchte 25 KZL H A59-Lichtfunktion J 25,not active ,20
ENG263447-ENG260798-Leuchte 25 KZL H A59-Lichtfunktion K 25,not active ,20
ENG263447-ENG258935-Leuchte 25 KZL H A59-Lichtfunktion L 25,not active ,20
ENG263489-ENG259412-Leuchte 26 NSL L A72-Dimming Direction DEF 26,maximize ,20
ENG263489-ENG259883-Leuchte 26 NSL L A72-Dimming Direction GHI 26,maximize ,20
ENG263489-ENG260584-Leuchte 26 NSL L A72-Dimming Direction JKL 26,maximize ,20
ENG263489-ENG261357-Leuchte 26 NSL L A72-Dimmwert ABC 26,0 ,20
ENG263489-ENG260958-Leuchte 26 NSL L A72-Dimmwert DEF 26,0 ,20
ENG263489-ENG258546-Leuchte 26 NSL L A72-Dimmwert GHI 26,0 ,20
ENG263489-ENG259662-Leuchte 26 NSL L A72-Dimmwert JKL 26,0 ,20
ENG263489-ENG116368-Leuchte 26 NSL L A72-Fehlerort mittleres Byte DTC-DFCC 26,00 ,20
ENG263489-ENG116578-Leuchte 26 NSL L A72-Lampendefektbitposition 26,00 ,20
ENG263489-ENG116366-Leuchte 26 NSL L A72-Lasttyp 26,not_active ,20
ENG263489-ENG260640-Leuchte 26 NSL L A72-Lichtansteuerung HD ABC 26,Always ,20
ENG263489-ENG116369-Leuchte 26 NSL L A72-Lichtfunktion A 26,not active ,20
ENG263489-ENG116370-Leuchte 26 NSL L A72-Lichtfunktion B 26,not active ,20
ENG263489-ENG116373-Leuchte 26 NSL L A72-Lichtfunktion C 26,not active ,20
ENG263489-ENG116374-Leuchte 26 NSL L A72-Lichtfunktion D 26,not active ,20
ENG263489-ENG116377-Leuchte 26 NSL L A72-Lichtfunktion E 26,not active ,20
ENG263489-ENG116378-Leuchte 26 NSL L A72-Lichtfunktion F 26,not active ,20
ENG263489-ENG116381-Leuchte 26 NSL L A72-Lichtfunktion G 26,not active ,20
ENG263489-ENG116382-Leuchte 26 NSL L A72-Lichtfunktion H 26,not active ,20
ENG263489-ENG258650-Leuchte 26 NSL L A72-Lichtfunktion I 26,not active ,20
ENG263489-ENG258937-Leuchte 26 NSL L A72-Lichtfunktion J 26,not active ,20
ENG263489-ENG259765-Leuchte 26 NSL L A72-Lichtfunktion K 26,not active ,20
ENG263489-ENG260970-Leuchte 26 NSL L A72-Lichtfunktion L 26,not active ,20
ENG263468-ENG259400-Leuchte 27 NSL R C6-Dimming Direction DEF 27,maximize ,20
ENG263468-ENG260627-Leuchte 27 NSL R C6-Dimming Direction GHI 27,maximize ,20
ENG263468-ENG260547-Leuchte 27 NSL R C6-Dimming Direction JKL 27,maximize ,20
ENG263468-ENG259742-Leuchte 27 NSL R C6-Dimmwert ABC 27,0 ,20
ENG263468-ENG258926-Leuchte 27 NSL R C6-Dimmwert DEF 27,0 ,20
ENG263468-ENG259009-Leuchte 27 NSL R C6-Dimmwert GHI 27,0 ,20
ENG263468-ENG260084-Leuchte 27 NSL R C6-Dimmwert JKL 27,0 ,20
ENG263468-ENG116387-Leuchte 27 NSL R C6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,20
ENG263468-ENG116579-Leuchte 27 NSL R C6-Lampendefektbitposition 27,00 ,20
ENG263468-ENG116385-Leuchte 27 NSL R C6-Lasttyp 27,not_active ,20
ENG263468-ENG258715-Leuchte 27 NSL R C6-Lichtansteuerung HD ABC 27,Always ,20
ENG263468-ENG116388-Leuchte 27 NSL R C6-Lichtfunktion A 27,not active ,20
ENG263468-ENG116389-Leuchte 27 NSL R C6-Lichtfunktion B 27,not active ,20
ENG263468-ENG116392-Leuchte 27 NSL R C6-Lichtfunktion C 27,not active ,20
ENG263468-ENG116393-Leuchte 27 NSL R C6-Lichtfunktion D 27,not active ,20
ENG263468-ENG116396-Leuchte 27 NSL R C6-Lichtfunktion E 27,not active ,20
ENG263468-ENG116397-Leuchte 27 NSL R C6-Lichtfunktion F 27,not active ,20
ENG263468-ENG116400-Leuchte 27 NSL R C6-Lichtfunktion G 27,not active ,20
ENG263468-ENG116401-Leuchte 27 NSL R C6-Lichtfunktion H 27,not active ,20
ENG263468-ENG258753-Leuchte 27 NSL R C6-Lichtfunktion I 27,not active ,20
ENG263468-ENG258206-Leuchte 27 NSL R C6-Lichtfunktion J 27,not active ,20
ENG263468-ENG260268-Leuchte 27 NSL R C6-Lichtfunktion K 27,not active ,20
ENG263468-ENG259071-Leuchte 27 NSL R C6-Lichtfunktion L 27,not active ,20
ENG263472-ENG258565-Leuchte 28 RFL L C11-Dimming Direction DEF 28,maximize ,20
ENG263472-ENG258532-Leuchte 28 RFL L C11-Dimming Direction GHI 28,maximize ,20
ENG263472-ENG259396-Leuchte 28 RFL L C11-Dimming Direction JKL 28,maximize ,20
ENG263472-ENG259919-Leuchte 28 RFL L C11-Dimmwert ABC 28,127 ,20
ENG263472-ENG258647-Leuchte 28 RFL L C11-Dimmwert DEF 28,0 ,20
ENG263472-ENG261179-Leuchte 28 RFL L C11-Dimmwert GHI 28,0 ,20
ENG263472-ENG260446-Leuchte 28 RFL L C11-Dimmwert JKL 28,0 ,20
ENG263472-ENG116406-Leuchte 28 RFL L C11-Fehlerort mittleres Byte DTC-DFCC 28,35 ,20
ENG263472-ENG116580-Leuchte 28 RFL L C11-Lampendefektbitposition 28,0A ,20
ENG263472-ENG116404-Leuchte 28 RFL L C11-Lasttyp 28,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263472-ENG258804-Leuchte 28 RFL L C11-Lichtansteuerung HD ABC 28,Always ,20
ENG263472-ENG116407-Leuchte 28 RFL L C11-Lichtfunktion A 28,Position lamps ,20
ENG263472-ENG116408-Leuchte 28 RFL L C11-Lichtfunktion B 28,Parking light left ,20
ENG263472-ENG116411-Leuchte 28 RFL L C11-Lichtfunktion C 28,not active ,20
ENG263472-ENG116412-Leuchte 28 RFL L C11-Lichtfunktion D 28,not active ,20
ENG263472-ENG116415-Leuchte 28 RFL L C11-Lichtfunktion E 28,not active ,20
ENG263472-ENG116416-Leuchte 28 RFL L C11-Lichtfunktion F 28,not active ,20
ENG263472-ENG116419-Leuchte 28 RFL L C11-Lichtfunktion G 28,not active ,20
ENG263472-ENG116420-Leuchte 28 RFL L C11-Lichtfunktion H 28,not active ,20
ENG263472-ENG260485-Leuchte 28 RFL L C11-Lichtfunktion I 28,not active ,20
ENG263472-ENG260652-Leuchte 28 RFL L C11-Lichtfunktion J 28,not active ,20
ENG263472-ENG258363-Leuchte 28 RFL L C11-Lichtfunktion K 28,not active ,20
ENG263472-ENG260174-Leuchte 28 RFL L C11-Lichtfunktion L 28,not active ,20
ENG263492-ENG261198-Leuchte 29 RFL R A64-Dimming Direction DEF 29,maximize ,20
ENG263492-ENG259250-Leuchte 29 RFL R A64-Dimming Direction GHI 29,maximize ,20
ENG263492-ENG260299-Leuchte 29 RFL R A64-Dimming Direction JKL 29,maximize ,20
ENG263492-ENG259879-Leuchte 29 RFL R A64-Dimmwert ABC 29,127 ,20
ENG263492-ENG260443-Leuchte 29 RFL R A64-Dimmwert DEF 29,0 ,20
ENG263492-ENG260415-Leuchte 29 RFL R A64-Dimmwert GHI 29,0 ,20
ENG263492-ENG260684-Leuchte 29 RFL R A64-Dimmwert JKL 29,0 ,20
ENG263492-ENG116425-Leuchte 29 RFL R A64-Fehlerort mittleres Byte DTC-DFCC 29,36 ,20
ENG263492-ENG116581-Leuchte 29 RFL R A64-Lampendefektbitposition 29,1A ,20
ENG263492-ENG116423-Leuchte 29 RFL R A64-Lasttyp 29,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263492-ENG260077-Leuchte 29 RFL R A64-Lichtansteuerung HD ABC 29,Always ,20
ENG263492-ENG116426-Leuchte 29 RFL R A64-Lichtfunktion A 29,Position lamps ,20
ENG263492-ENG116427-Leuchte 29 RFL R A64-Lichtfunktion B 29,Parking light right ,20
ENG263492-ENG116429-Leuchte 29 RFL R A64-Lichtfunktion C 29,not active ,20
ENG263492-ENG116431-Leuchte 29 RFL R A64-Lichtfunktion D 29,not active ,20
ENG263492-ENG116434-Leuchte 29 RFL R A64-Lichtfunktion E 29,not active ,20
ENG263492-ENG116435-Leuchte 29 RFL R A64-Lichtfunktion F 29,not active ,20
ENG263492-ENG116438-Leuchte 29 RFL R A64-Lichtfunktion G 29,not active ,20
ENG263492-ENG116439-Leuchte 29 RFL R A64-Lichtfunktion H 29,not active ,20
ENG263492-ENG260646-Leuchte 29 RFL R A64-Lichtfunktion I 29,not active ,20
ENG263492-ENG259712-Leuchte 29 RFL R A64-Lichtfunktion J 29,not active ,20
ENG263492-ENG259236-Leuchte 29 RFL R A64-Lichtfunktion K 29,not active ,20
ENG263492-ENG259606-Leuchte 29 RFL R A64-Lichtfunktion L 29,not active ,20
ENG263454-ENG260476-Leuchte 3 SL VR B32-Dimming Direction DEF 3,minimize ,20
ENG263454-ENG259703-Leuchte 3 SL VR B32-Dimming Direction GHI 3,maximize ,20
ENG263454-ENG259508-Leuchte 3 SL VR B32-Dimming Direction JKL 3,maximize ,20
ENG263454-ENG258539-Leuchte 3 SL VR B32-Dimmwert ABC 3,127 ,20
ENG263454-ENG259082-Leuchte 3 SL VR B32-Dimmwert DEF 3,0 ,20
ENG263454-ENG260713-Leuchte 3 SL VR B32-Dimmwert GHI 3,0 ,20
ENG263454-ENG261150-Leuchte 3 SL VR B32-Dimmwert JKL 3,0 ,20
ENG263454-ENG115931-Leuchte 3 SL VR B32-Fehlerort mittleres Byte DTC-DFCC 3,32 ,20
ENG263454-ENG116551-Leuchte 3 SL VR B32-Lampendefektbitposition 3,1B ,20
ENG263454-ENG115929-Leuchte 3 SL VR B32-Lasttyp 3,allgemeine_LED_mit_Open_Load_Diagnose 12 W ,20
ENG263454-ENG260316-Leuchte 3 SL VR B32-Lichtansteuerung HD ABC 3,Always ,20
ENG263454-ENG115932-Leuchte 3 SL VR B32-Lichtfunktion A 3,Rueckfahrlicht ,20
ENG263454-ENG115933-Leuchte 3 SL VR B32-Lichtfunktion B 3,not active ,20
ENG263454-ENG115936-Leuchte 3 SL VR B32-Lichtfunktion C 3,not active ,20
ENG263454-ENG115937-Leuchte 3 SL VR B32-Lichtfunktion D 3,not active ,20
ENG263454-ENG115940-Leuchte 3 SL VR B32-Lichtfunktion E 3,not active ,20
ENG263454-ENG116552-Leuchte 3 SL VR B32-Lichtfunktion F 3,not active ,20
ENG263454-ENG115944-Leuchte 3 SL VR B32-Lichtfunktion G 3,not active ,20
ENG263454-ENG115945-Leuchte 3 SL VR B32-Lichtfunktion H 3,not active ,20
ENG263454-ENG260399-Leuchte 3 SL VR B32-Lichtfunktion I 3,not active ,20
ENG263454-ENG260155-Leuchte 3 SL VR B32-Lichtfunktion J 3,not active ,20
ENG263454-ENG260622-Leuchte 3 SL VR B32-Lichtfunktion K 3,not active ,20
ENG263454-ENG258091-Leuchte 3 SL VR B32-Lichtfunktion L 3,not active ,20
ENG263428-ENG260857-Leuchte 30 FR L C72-Dimming Direction DEF 30,maximize ,20
ENG263428-ENG258841-Leuchte 30 FR L C72-Dimming Direction GHI 30,maximize ,20
ENG263428-ENG259433-Leuchte 30 FR L C72-Dimming Direction JKL 30,maximize ,20
ENG263428-ENG259620-Leuchte 30 FR L C72-Dimmwert ABC 30,100 ,20
ENG263428-ENG260960-Leuchte 30 FR L C72-Dimmwert DEF 30,0 ,20
ENG263428-ENG260191-Leuchte 30 FR L C72-Dimmwert GHI 30,0 ,20
ENG263428-ENG259143-Leuchte 30 FR L C72-Dimmwert JKL 30,0 ,20
ENG263428-ENG116444-Leuchte 30 FR L C72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,20
ENG263428-ENG116582-Leuchte 30 FR L C72-Lampendefektbitposition 30,00 ,20
ENG263428-ENG116442-Leuchte 30 FR L C72-Lasttyp 30,allgemeine_Gluehlampe_27W_auch_H15_TFL ,20
ENG263428-ENG261067-Leuchte 30 FR L C72-Lichtansteuerung HD ABC 30,Always ,20
ENG263428-ENG116445-Leuchte 30 FR L C72-Lichtfunktion A 30,Footwell lamp ,20
ENG263428-ENG116446-Leuchte 30 FR L C72-Lichtfunktion B 30,not active ,20
ENG263428-ENG116449-Leuchte 30 FR L C72-Lichtfunktion C 30,not active ,20
ENG263428-ENG116450-Leuchte 30 FR L C72-Lichtfunktion D 30,not active ,20
ENG263428-ENG116453-Leuchte 30 FR L C72-Lichtfunktion E 30,not active ,20
ENG263428-ENG116454-Leuchte 30 FR L C72-Lichtfunktion F 30,not active ,20
ENG263428-ENG116457-Leuchte 30 FR L C72-Lichtfunktion G 30,not active ,20
ENG263428-ENG116458-Leuchte 30 FR L C72-Lichtfunktion H 30,not active ,20
ENG263428-ENG260108-Leuchte 30 FR L C72-Lichtfunktion I 30,not active ,20
ENG263428-ENG260034-Leuchte 30 FR L C72-Lichtfunktion J 30,not active ,20
ENG263428-ENG259668-Leuchte 30 FR L C72-Lichtfunktion K 30,not active ,20
ENG263428-ENG258691-Leuchte 30 FR L C72-Lichtfunktion L 30,not active ,20
ENG263445-ENG260925-Leuchte 31 AMBL 1 C61-Dimming Direction DEF 31,maximize ,20
ENG263445-ENG259991-Leuchte 31 AMBL 1 C61-Dimming Direction GHI 31,maximize ,20
ENG263445-ENG259114-Leuchte 31 AMBL 1 C61-Dimming Direction JKL 31,maximize ,20
ENG263445-ENG261277-Leuchte 31 AMBL 1 C61-Dimmwert ABC 31,0 ,20
ENG263445-ENG259981-Leuchte 31 AMBL 1 C61-Dimmwert DEF 31,0 ,20
ENG263445-ENG260837-Leuchte 31 AMBL 1 C61-Dimmwert GHI 31,0 ,20
ENG263445-ENG258112-Leuchte 31 AMBL 1 C61-Dimmwert JKL 31,0 ,20
ENG263445-ENG116463-Leuchte 31 AMBL 1 C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,20
ENG263445-ENG116583-Leuchte 31 AMBL 1 C61-Lampendefektbitposition 31,00 ,20
ENG263445-ENG116461-Leuchte 31 AMBL 1 C61-Lasttyp 31,not_active ,20
ENG263445-ENG260205-Leuchte 31 AMBL 1 C61-Lichtansteuerung HD ABC 31,Always ,20
ENG263445-ENG116464-Leuchte 31 AMBL 1 C61-Lichtfunktion A 31,not active ,20
ENG263445-ENG116465-Leuchte 31 AMBL 1 C61-Lichtfunktion B 31,not active ,20
ENG263445-ENG116468-Leuchte 31 AMBL 1 C61-Lichtfunktion C 31,not active ,20
ENG263445-ENG116469-Leuchte 31 AMBL 1 C61-Lichtfunktion D 31,not active ,20
ENG263445-ENG116472-Leuchte 31 AMBL 1 C61-Lichtfunktion E 31,not active ,20
ENG263445-ENG116473-Leuchte 31 AMBL 1 C61-Lichtfunktion F 31,not active ,20
ENG263445-ENG116476-Leuchte 31 AMBL 1 C61-Lichtfunktion G 31,not active ,20
ENG263445-ENG116477-Leuchte 31 AMBL 1 C61-Lichtfunktion H 31,not active ,20
ENG263445-ENG260861-Leuchte 31 AMBL 1 C61-Lichtfunktion I 31,not active ,20
ENG263445-ENG260553-Leuchte 31 AMBL 1 C61-Lichtfunktion J 31,not active ,20
ENG263445-ENG259999-Leuchte 31 AMBL 1 C61-Lichtfunktion K 31,not active ,20
ENG263445-ENG260353-Leuchte 31 AMBL 1 C61-Lichtfunktion L 31,not active ,20
ENG263449-ENG259710-Leuchte 32 AMBL 2 C35-Dimming Direction DEF 32,maximize ,20
ENG263449-ENG258905-Leuchte 32 AMBL 2 C35-Dimming Direction GHI 32,maximize ,20
ENG263449-ENG260532-Leuchte 32 AMBL 2 C35-Dimming Direction JKL 32,maximize ,20
ENG263449-ENG259737-Leuchte 32 AMBL 2 C35-Dimmwert ABC 32,0 ,20
ENG263449-ENG259346-Leuchte 32 AMBL 2 C35-Dimmwert DEF 32,0 ,20
ENG263449-ENG260258-Leuchte 32 AMBL 2 C35-Dimmwert GHI 32,0 ,20
ENG263449-ENG260382-Leuchte 32 AMBL 2 C35-Dimmwert JKL 32,0 ,20
ENG263449-ENG116482-Leuchte 32 AMBL 2 C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,20
ENG263449-ENG116584-Leuchte 32 AMBL 2 C35-Lampendefektbitposition 32,00 ,20
ENG263449-ENG116480-Leuchte 32 AMBL 2 C35-Lasttyp 32,not_active ,20
ENG263449-ENG259035-Leuchte 32 AMBL 2 C35-Lichtansteuerung HD ABC 32,Always ,20
ENG263449-ENG116483-Leuchte 32 AMBL 2 C35-Lichtfunktion A 32,not active ,20
ENG263449-ENG116484-Leuchte 32 AMBL 2 C35-Lichtfunktion B 32,not active ,20
ENG263449-ENG116487-Leuchte 32 AMBL 2 C35-Lichtfunktion C 32,not active ,20
ENG263449-ENG116488-Leuchte 32 AMBL 2 C35-Lichtfunktion D 32,not active ,20
ENG263449-ENG116491-Leuchte 32 AMBL 2 C35-Lichtfunktion E 32,not active ,20
ENG263449-ENG116492-Leuchte 32 AMBL 2 C35-Lichtfunktion F 32,not active ,20
ENG263449-ENG116495-Leuchte 32 AMBL 2 C35-Lichtfunktion G 32,not active ,20
ENG263449-ENG116496-Leuchte 32 AMBL 2 C35-Lichtfunktion H 32,not active ,20
ENG263449-ENG258763-Leuchte 32 AMBL 2 C35-Lichtfunktion I 32,not active ,20
ENG263449-ENG259842-Leuchte 32 AMBL 2 C35-Lichtfunktion J 32,not active ,20
ENG263449-ENG258857-Leuchte 32 AMBL 2 C35-Lichtfunktion K 32,not active ,20
ENG263449-ENG260175-Leuchte 32 AMBL 2 C35-Lichtfunktion L 32,not active ,20
ENG263439-ENG258755-Leuchte 33 AMBL 3 C36-Dimming Direction DEF 33,maximize ,20
ENG263439-ENG258237-Leuchte 33 AMBL 3 C36-Dimming Direction GHI 33,maximize ,20
ENG263439-ENG259038-Leuchte 33 AMBL 3 C36-Dimming Direction JKL 33,maximize ,20
ENG263439-ENG259476-Leuchte 33 AMBL 3 C36-Dimmwert ABC 33,0 ,20
ENG263439-ENG260461-Leuchte 33 AMBL 3 C36-Dimmwert DEF 33,0 ,20
ENG263439-ENG261181-Leuchte 33 AMBL 3 C36-Dimmwert GHI 33,0 ,20
ENG263439-ENG258425-Leuchte 33 AMBL 3 C36-Dimmwert JKL 33,0 ,20
ENG263439-ENG116501-Leuchte 33 AMBL 3 C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,20
ENG263439-ENG116585-Leuchte 33 AMBL 3 C36-Lampendefektbitposition 33,00 ,20
ENG263439-ENG116499-Leuchte 33 AMBL 3 C36-Lasttyp 33,not_active ,20
ENG263439-ENG259471-Leuchte 33 AMBL 3 C36-Lichtansteuerung HD ABC 33,Always ,20
ENG263439-ENG116502-Leuchte 33 AMBL 3 C36-Lichtfunktion A 33,not active ,20
ENG263439-ENG116503-Leuchte 33 AMBL 3 C36-Lichtfunktion B 33,not active ,20
ENG263439-ENG116506-Leuchte 33 AMBL 3 C36-Lichtfunktion C 33,not active ,20
ENG263439-ENG116507-Leuchte 33 AMBL 3 C36-Lichtfunktion D 33,not active ,20
ENG263439-ENG116510-Leuchte 33 AMBL 3 C36-Lichtfunktion E 33,not active ,20
ENG263439-ENG116511-Leuchte 33 AMBL 3 C36-Lichtfunktion F 33,not active ,20
ENG263439-ENG116514-Leuchte 33 AMBL 3 C36-Lichtfunktion G 33,not active ,20
ENG263439-ENG116515-Leuchte 33 AMBL 3 C36-Lichtfunktion H 33,not active ,20
ENG263439-ENG260403-Leuchte 33 AMBL 3 C36-Lichtfunktion I 33,not active ,20
ENG263439-ENG261239-Leuchte 33 AMBL 3 C36-Lichtfunktion J 33,not active ,20
ENG263439-ENG260953-Leuchte 33 AMBL 3 C36-Lichtfunktion K 33,not active ,20
ENG263439-ENG261234-Leuchte 33 AMBL 3 C36-Lichtfunktion L 33,not active ,20
ENG263434-ENG259648-Leuchte 34 AMBL 4 C37-Dimming Direction DEF 34,maximize ,20
ENG263434-ENG259188-Leuchte 34 AMBL 4 C37-Dimming Direction GHI 34,maximize ,20
ENG263434-ENG260464-Leuchte 34 AMBL 4 C37-Dimming Direction JKL 34,maximize ,20
ENG263434-ENG259524-Leuchte 34 AMBL 4 C37-Dimmwert ABC 34,0 ,20
ENG263434-ENG260705-Leuchte 34 AMBL 4 C37-Dimmwert DEF 34,0 ,20
ENG263434-ENG258677-Leuchte 34 AMBL 4 C37-Dimmwert GHI 34,0 ,20
ENG263434-ENG259924-Leuchte 34 AMBL 4 C37-Dimmwert JKL 34,0 ,20
ENG263434-ENG116520-Leuchte 34 AMBL 4 C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,20
ENG263434-ENG116586-Leuchte 34 AMBL 4 C37-Lampendefektbitposition 34,00 ,20
ENG263434-ENG116518-Leuchte 34 AMBL 4 C37-Lasttyp 34,not_active ,20
ENG263434-ENG259804-Leuchte 34 AMBL 4 C37-Lichtansteuerung HD ABC 34,Always ,20
ENG263434-ENG116521-Leuchte 34 AMBL 4 C37-Lichtfunktion A 34,not active ,20
ENG263434-ENG116522-Leuchte 34 AMBL 4 C37-Lichtfunktion B 34,not active ,20
ENG263434-ENG116525-Leuchte 34 AMBL 4 C37-Lichtfunktion C 34,not active ,20
ENG263434-ENG116526-Leuchte 34 AMBL 4 C37-Lichtfunktion D 34,not active ,20
ENG263434-ENG116529-Leuchte 34 AMBL 4 C37-Lichtfunktion E 34,not active ,20
ENG263434-ENG116530-Leuchte 34 AMBL 4 C37-Lichtfunktion F 34,not active ,20
ENG263434-ENG116533-Leuchte 34 AMBL 4 C37-Lichtfunktion G 34,not active ,20
ENG263434-ENG116534-Leuchte 34 AMBL 4 C37-Lichtfunktion H 34,not active ,20
ENG263434-ENG259061-Leuchte 34 AMBL 4 C37-Lichtfunktion I 34,not active ,20
ENG263434-ENG258125-Leuchte 34 AMBL 4 C37-Lichtfunktion J 34,not active ,20
ENG263434-ENG259670-Leuchte 34 AMBL 4 C37-Lichtfunktion K 34,not active ,20
ENG263434-ENG260771-Leuchte 34 AMBL 4 C37-Lichtfunktion L 34,not active ,20
ENG141657-ENG258314-Leuchte 35 LED Warnblinktaster C48-Dimming Direction DEF 35,maximize ,20
ENG141657-ENG260208-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GHI 35,maximize ,20
ENG141657-ENG260869-Leuchte 35 LED Warnblinktaster C48-Dimming Direction JKL 35,maximize ,20
ENG141657-ENG259780-Leuchte 35 LED Warnblinktaster C48-Dimmwert ABC 35,100 ,20
ENG141657-ENG258175-Leuchte 35 LED Warnblinktaster C48-Dimmwert DEF 35,0 ,20
ENG141657-ENG259257-Leuchte 35 LED Warnblinktaster C48-Dimmwert GHI 35,0 ,20
ENG141657-ENG260977-Leuchte 35 LED Warnblinktaster C48-Dimmwert JKL 35,0 ,20
ENG141657-ENG258758-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 35,00 ,20
ENG141657-ENG258551-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 35,00 ,20
ENG141657-ENG259566-Leuchte 35 LED Warnblinktaster C48-Lasttyp 35,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG141657-ENG260595-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD ABC 35,Always ,20
ENG141657-ENG260217-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 35,Warnblink Taster Suchbeleuchtung ,20
ENG141657-ENG259017-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 35,not active ,20
ENG141657-ENG259618-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 35,not active ,20
ENG141657-ENG259584-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 35,not active ,20
ENG141657-ENG259128-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 35,not active ,20
ENG141657-ENG258995-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 35,not active ,20
ENG141657-ENG258137-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 35,not active ,20
ENG141657-ENG259014-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 35,not active ,20
ENG141657-ENG258258-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion I 35,not active ,20
ENG141657-ENG260608-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion J 35,not active ,20
ENG141657-ENG260082-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion K 35,not active ,20
ENG141657-ENG261046-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion L 35,not active ,20
ENG253037-ENG259399-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction DEF 36,maximize ,20
ENG253037-ENG260703-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction GHI 36,maximize ,20
ENG253037-ENG260112-Leuchte 36 LEDNL_PWM_L_B37-Dimming Direction JKL 36,maximize ,20
ENG253037-ENG258344-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert ABC 36,0 ,20
ENG253037-ENG258426-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert DEF 36,0 ,20
ENG253037-ENG260039-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert GHI 36,0 ,20
ENG253037-ENG259503-Leuchte 36 LEDNL_PWM_L_B37-Dimmwert JKL 36,0 ,20
ENG253037-ENG260858-Leuchte 36 LEDNL_PWM_L_B37-Fehlerort mittleres Byte DTC-DFCC 36,00 ,20
ENG253037-ENG258523-Leuchte 36 LEDNL_PWM_L_B37-Lampendefektbitposition 36,00 ,20
ENG253037-ENG261341-Leuchte 36 LEDNL_PWM_L_B37-Lasttyp 36,not_active ,20
ENG253037-ENG259878-Leuchte 36 LEDNL_PWM_L_B37-Lichtansteuerung HD ABC 36,Always ,20
ENG253037-ENG258899-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion A 36,not active ,20
ENG253037-ENG260362-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion B 36,not active ,20
ENG253037-ENG258356-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion C 36,not active ,20
ENG253037-ENG258388-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion D 36,not active ,20
ENG253037-ENG258248-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion E 36,not active ,20
ENG253037-ENG260017-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion F 36,not active ,20
ENG253037-ENG260071-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion G 36,not active ,20
ENG253037-ENG259734-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion H 36,not active ,20
ENG253037-ENG260720-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion I 36,not active ,20
ENG253037-ENG259525-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion J 36,not active ,20
ENG253037-ENG259972-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion K 36,not active ,20
ENG253037-ENG259404-Leuchte 36 LEDNL_PWM_L_B37-Lichtfunktion L 36,not active ,20
ENG253226-ENG260671-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction DEF 37,maximize ,20
ENG253226-ENG258552-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction GHI 37,maximize ,20
ENG253226-ENG260966-Leuchte 37 LEDNL_PWM_R_B38-Dimming Direction JKL 37,maximize ,20
ENG253226-ENG260262-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert ABC 37,0 ,20
ENG253226-ENG258498-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert DEF 37,0 ,20
ENG253226-ENG258952-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert GHI 37,0 ,20
ENG253226-ENG260588-Leuchte 37 LEDNL_PWM_R_B38-Dimmwert JKL 37,0 ,20
ENG253226-ENG258708-Leuchte 37 LEDNL_PWM_R_B38-Fehlerort mittleres Byte DTC-DFCC 37,00 ,20
ENG253226-ENG260786-Leuchte 37 LEDNL_PWM_R_B38-Lampendefektbitposition 37,00 ,20
ENG253226-ENG259218-Leuchte 37 LEDNL_PWM_R_B38-Lasttyp 37,not_active ,20
ENG253226-ENG260323-Leuchte 37 LEDNL_PWM_R_B38-Lichtansteuerung HD ABC 37,Always ,20
ENG253226-ENG259995-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion A 37,not active ,20
ENG253226-ENG259686-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion B 37,not active ,20
ENG253226-ENG259495-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion C 37,not active ,20
ENG253226-ENG258914-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion D 37,not active ,20
ENG253226-ENG258741-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion E 37,not active ,20
ENG253226-ENG261001-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion F 37,not active ,20
ENG253226-ENG259796-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion G 37,not active ,20
ENG253226-ENG258391-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion H 37,not active ,20
ENG253226-ENG260757-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion I 37,not active ,20
ENG253226-ENG261282-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion J 37,not active ,20
ENG253226-ENG258097-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion K 37,not active ,20
ENG253226-ENG261120-Leuchte 37 LEDNL_PWM_R_B38-Lichtfunktion L 37,not active ,20
ENG253185-ENG260594-Leuchte 38 Sidemarker_V_B21-Dimming Direction DEF 38,maximize ,20
ENG253185-ENG259176-Leuchte 38 Sidemarker_V_B21-Dimming Direction GHI 38,maximize ,20
ENG253185-ENG258361-Leuchte 38 Sidemarker_V_B21-Dimming Direction JKL 38,maximize ,20
ENG253185-ENG258271-Leuchte 38 Sidemarker_V_B21-Dimmwert ABC 38,0 ,20
ENG253185-ENG258593-Leuchte 38 Sidemarker_V_B21-Dimmwert DEF 38,0 ,20
ENG253185-ENG259740-Leuchte 38 Sidemarker_V_B21-Dimmwert GHI 38,0 ,20
ENG253185-ENG260375-Leuchte 38 Sidemarker_V_B21-Dimmwert JKL 38,0 ,20
ENG253185-ENG259110-Leuchte 38 Sidemarker_V_B21-Fehlerort mittleres Byte DTC-DFCC 38,00 ,20
ENG253185-ENG259339-Leuchte 38 Sidemarker_V_B21-Lampendefektbitposition 38,00 ,20
ENG253185-ENG258774-Leuchte 38 Sidemarker_V_B21-Lasttyp 38,not_active ,20
ENG253185-ENG259319-Leuchte 38 Sidemarker_V_B21-Lichtansteuerung HD ABC 38,Always ,20
ENG253185-ENG258971-Leuchte 38 Sidemarker_V_B21-Lichtfunktion A 38,not active ,20
ENG253185-ENG260328-Leuchte 38 Sidemarker_V_B21-Lichtfunktion B 38,not active ,20
ENG253185-ENG258602-Leuchte 38 Sidemarker_V_B21-Lichtfunktion C 38,not active ,20
ENG253185-ENG260130-Leuchte 38 Sidemarker_V_B21-Lichtfunktion D 38,not active ,20
ENG253185-ENG260126-Leuchte 38 Sidemarker_V_B21-Lichtfunktion E 38,not active ,20
ENG253185-ENG260093-Leuchte 38 Sidemarker_V_B21-Lichtfunktion F 38,not active ,20
ENG253185-ENG258515-Leuchte 38 Sidemarker_V_B21-Lichtfunktion G 38,not active ,20
ENG253185-ENG259657-Leuchte 38 Sidemarker_V_B21-Lichtfunktion H 38,not active ,20
ENG253185-ENG259428-Leuchte 38 Sidemarker_V_B21-Lichtfunktion I 38,not active ,20
ENG253185-ENG258516-Leuchte 38 Sidemarker_V_B21-Lichtfunktion J 38,not active ,20
ENG253185-ENG260994-Leuchte 38 Sidemarker_V_B21-Lichtfunktion K 38,not active ,20
ENG253185-ENG259179-Leuchte 38 Sidemarker_V_B21-Lichtfunktion L 38,not active ,20
ENG253171-ENG259501-Leuchte 39 Sidemarker_H C26-Dimming Direction DEF 39,maximize ,20
ENG253171-ENG260533-Leuchte 39 Sidemarker_H C26-Dimming Direction GHI 39,maximize ,20
ENG253171-ENG259331-Leuchte 39 Sidemarker_H C26-Dimming Direction JKL 39,maximize ,20
ENG253171-ENG259663-Leuchte 39 Sidemarker_H C26-Dimmwert ABC 39,0 ,20
ENG253171-ENG260625-Leuchte 39 Sidemarker_H C26-Dimmwert DEF 39,0 ,20
ENG253171-ENG258607-Leuchte 39 Sidemarker_H C26-Dimmwert GHI 39,0 ,20
ENG253171-ENG259031-Leuchte 39 Sidemarker_H C26-Dimmwert JKL 39,0 ,20
ENG253171-ENG260272-Leuchte 39 Sidemarker_H C26-Fehlerort mittleres Byte DTC-DFCC 39,00 ,20
ENG253171-ENG261342-Leuchte 39 Sidemarker_H C26-Lampendefektbitposition 39,00 ,20
ENG253171-ENG258910-Leuchte 39 Sidemarker_H C26-Lasttyp 39,not_active ,20
ENG253171-ENG261145-Leuchte 39 Sidemarker_H C26-Lichtansteuerung HD ABC 39,Always ,20
ENG253171-ENG259436-Leuchte 39 Sidemarker_H C26-Lichtfunktion A 39,not active ,20
ENG253171-ENG260471-Leuchte 39 Sidemarker_H C26-Lichtfunktion B 39,not active ,20
ENG253171-ENG260554-Leuchte 39 Sidemarker_H C26-Lichtfunktion C 39,not active ,20
ENG253171-ENG258988-Leuchte 39 Sidemarker_H C26-Lichtfunktion D 39,not active ,20
ENG253171-ENG259727-Leuchte 39 Sidemarker_H C26-Lichtfunktion E 39,not active ,20
ENG253171-ENG258355-Leuchte 39 Sidemarker_H C26-Lichtfunktion F 39,not active ,20
ENG253171-ENG261095-Leuchte 39 Sidemarker_H C26-Lichtfunktion G 39,not active ,20
ENG253171-ENG258577-Leuchte 39 Sidemarker_H C26-Lichtfunktion H 39,not active ,20
ENG253171-ENG259902-Leuchte 39 Sidemarker_H C26-Lichtfunktion I 39,not active ,20
ENG253171-ENG260202-Leuchte 39 Sidemarker_H C26-Lichtfunktion J 39,not active ,20
ENG253171-ENG260436-Leuchte 39 Sidemarker_H C26-Lichtfunktion K 39,not active ,20
ENG253171-ENG259237-Leuchte 39 Sidemarker_H C26-Lichtfunktion L 39,not active ,20
ENG263459-ENG258414-Leuchte 4 TFL L B3-Dimming Direction DEF 4,maximize ,20
ENG263459-ENG260894-Leuchte 4 TFL L B3-Dimming Direction GHI 4,maximize ,20
ENG263459-ENG259900-Leuchte 4 TFL L B3-Dimming Direction JKL 4,maximize ,20
ENG263459-ENG259665-Leuchte 4 TFL L B3-Dimmwert ABC 4,0 ,20
ENG263459-ENG260507-Leuchte 4 TFL L B3-Dimmwert DEF 4,0 ,20
ENG263459-ENG258447-Leuchte 4 TFL L B3-Dimmwert GHI 4,0 ,20
ENG263459-ENG258461-Leuchte 4 TFL L B3-Dimmwert JKL 4,0 ,20
ENG263459-ENG115950-Leuchte 4 TFL L B3-Fehlerort mittleres Byte DTC-DFCC 4,00 ,20
ENG263459-ENG116553-Leuchte 4 TFL L B3-Lampendefektbitposition 4,00 ,20
ENG263459-ENG115948-Leuchte 4 TFL L B3-Lasttyp 4,not_active ,20
ENG263459-ENG259234-Leuchte 4 TFL L B3-Lichtansteuerung HD ABC 4,Always ,20
ENG263459-ENG115951-Leuchte 4 TFL L B3-Lichtfunktion A 4,not active ,20
ENG263459-ENG115952-Leuchte 4 TFL L B3-Lichtfunktion B 4,not active ,20
ENG263459-ENG115955-Leuchte 4 TFL L B3-Lichtfunktion C 4,not active ,20
ENG263459-ENG115956-Leuchte 4 TFL L B3-Lichtfunktion D 4,not active ,20
ENG263459-ENG115959-Leuchte 4 TFL L B3-Lichtfunktion E 4,not active ,20
ENG263459-ENG115960-Leuchte 4 TFL L B3-Lichtfunktion F 4,not active ,20
ENG263459-ENG115963-Leuchte 4 TFL L B3-Lichtfunktion G 4,not active ,20
ENG263459-ENG115964-Leuchte 4 TFL L B3-Lichtfunktion H 4,not active ,20
ENG263459-ENG258442-Leuchte 4 TFL L B3-Lichtfunktion I 4,not active ,20
ENG263459-ENG258629-Leuchte 4 TFL L B3-Lichtfunktion J 4,not active ,20
ENG263459-ENG259468-Leuchte 4 TFL L B3-Lichtfunktion K 4,not active ,20
ENG263459-ENG258421-Leuchte 4 TFL L B3-Lichtfunktion L 4,not active ,20
ENG263465-ENG260616-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction DEF 40,maximize ,20
ENG263465-ENG259877-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction GHI v,maximize ,20
ENG263465-ENG258734-Leuchte 40 Zusatz_hecklicht_HL C9-Dimming Direction JKL 40,maximize ,20
ENG263465-ENG258702-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert ABC 40,0 ,20
ENG263465-ENG259888-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert DEF 40,0 ,20
ENG263465-ENG258927-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert GHI 40,0 ,20
ENG263465-ENG258852-Leuchte 40 Zusatz_hecklicht_HL C9-Dimmwert JKL 40,0 ,20
ENG263465-ENG260246-Leuchte 40 Zusatz_hecklicht_HL C9-Fehlerort mittleres Byte DTC-DFCC 40,00 ,20
ENG263465-ENG259652-Leuchte 40 Zusatz_hecklicht_HL C9-Lampendefektbitposition 40,00 ,20
ENG263465-ENG260978-Leuchte 40 Zusatz_hecklicht_HL C9-Lasttyp 40,not_active ,20
ENG263465-ENG259185-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtansteuerung HD ABC 40,Always ,20
ENG263465-ENG259008-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion A 40,not active ,20
ENG263465-ENG258714-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion B 40,not active ,20
ENG263465-ENG258586-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion C 40,not active ,20
ENG263465-ENG258768-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion D 40,not active ,20
ENG263465-ENG259573-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion E 40,not active ,20
ENG263465-ENG258923-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion F 40,not active ,20
ENG263465-ENG258928-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion G 40,not active ,20
ENG263465-ENG259450-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion H 40,not active ,20
ENG263465-ENG260309-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion I 40,not active ,20
ENG263465-ENG258499-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion J 40,not active ,20
ENG263465-ENG261065-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion K 40,not active ,20
ENG263465-ENG259658-Leuchte 40 Zusatz_hecklicht_HL C9-Lichtfunktion L 40,not active ,20
ENG263486-ENG259814-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction DEF 41,maximize ,20
ENG263486-ENG259194-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction GHI 41,maximize ,20
ENG263486-ENG258697-Leuchte 41 Zusatz_hecklicht_HR A67-Dimming Direction JKL 41,maximize ,20
ENG263486-ENG260405-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert ABC 41,0 ,20
ENG263486-ENG261284-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert DEF 41,0 ,20
ENG263486-ENG259351-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert GHI 41,0 ,20
ENG263486-ENG258887-Leuchte 41 Zusatz_hecklicht_HR A67-Dimmwert JKL 41,0 ,20
ENG263486-ENG258329-Leuchte 41 Zusatz_hecklicht_HR A67-Fehlerort mittleres Byte DTC-DFCC 41,00 ,20
ENG263486-ENG258960-Leuchte 41 Zusatz_hecklicht_HR A67-Lampendefektbitposition 41,00 ,20
ENG263486-ENG261015-Leuchte 41 Zusatz_hecklicht_HR A67-Lasttyp 41,not_active ,20
ENG263486-ENG260435-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtansteuerung HD ABC 41,Always ,20
ENG263486-ENG260996-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion A 41,not active ,20
ENG263486-ENG259966-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion B 41,not active ,20
ENG263486-ENG258450-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion C 41,not active ,20
ENG263486-ENG259570-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion D 41,not active ,20
ENG263486-ENG260906-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion E 41,not active ,20
ENG263486-ENG260838-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion F 41,not active ,20
ENG263486-ENG258108-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion G 41,not active ,20
ENG263486-ENG258430-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion H 41,not active ,20
ENG263486-ENG260615-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion I 41,not active ,20
ENG263486-ENG260918-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion J 41,not active ,20
ENG263486-ENG258150-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion K 41,not active ,20
ENG263486-ENG258739-Leuchte 41 Zusatz_hecklicht_HR A67-Lichtfunktion L 41,not active ,20
ENG253110-ENG261024-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction DEF 42,maximize ,20
ENG253110-ENG258668-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction GHI 42,maximize ,20
ENG253110-ENG258123-Leuchte 42 Wischblinksignal_li C30_B35-Dimming Direction JKL 42,maximize ,20
ENG253110-ENG258370-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert ABC 42,0 ,20
ENG253110-ENG258109-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert DEF 42,0 ,20
ENG253110-ENG261169-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert GHI 42,0 ,20
ENG253110-ENG259028-Leuchte 42 Wischblinksignal_li C30_B35-Dimmwert JKL 42,0 ,20
ENG253110-ENG259381-Leuchte 42 Wischblinksignal_li C30_B35-Fehlerort mittleres Byte DTC-DFCC 42,00 ,20
ENG253110-ENG259973-Leuchte 42 Wischblinksignal_li C30_B35-Lampendefektbitposition 42,00 ,20
ENG253110-ENG258662-Leuchte 42 Wischblinksignal_li C30_B35-Lasttyp 42,not_active ,20
ENG253110-ENG258290-Leuchte 42 Wischblinksignal_li C30_B35-Lichtansteuerung HD ABC 42,Always ,20
ENG253110-ENG258895-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion A 42,not active ,20
ENG253110-ENG260384-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion B 42,not active ,20
ENG253110-ENG261085-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion C 42,not active ,20
ENG253110-ENG260667-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion D 42,not active ,20
ENG253110-ENG260232-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion E 42,not active ,20
ENG253110-ENG258671-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion F 42,not active ,20
ENG253110-ENG259243-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion G 42,not active ,20
ENG253110-ENG259518-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion H 42,not active ,20
ENG253110-ENG259526-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion I 42,not active ,20
ENG253110-ENG259239-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion J 42,not active ,20
ENG253110-ENG258327-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion K 42,not active ,20
ENG253110-ENG260944-Leuchte 42 Wischblinksignal_li C30_B35-Lichtfunktion L 42,not active ,20
ENG253212-ENG261135-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction DEF 43,maximize ,20
ENG253212-ENG258953-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction GHI 43,maximize ,20
ENG253212-ENG260351-Leuchte 43 Wischblinksignal_re C33_B36-Dimming Direction JKL 43,maximize ,20
ENG253212-ENG259567-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert ABC 43,0 ,20
ENG253212-ENG259435-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert DEF 43,0 ,20
ENG253212-ENG260024-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert GHI 43,0 ,20
ENG253212-ENG259623-Leuchte 43 Wischblinksignal_re C33_B36-Dimmwert JKL 43,0 ,20
ENG253212-ENG258411-Leuchte 43 Wischblinksignal_re C33_B36-Fehlerort mittleres Byte DTC-DFCC 43,00 ,20
ENG253212-ENG261311-Leuchte 43 Wischblinksignal_re C33_B36-Lampendefektbitposition 43,00 ,20
ENG253212-ENG259612-Leuchte 43 Wischblinksignal_re C33_B36-Lasttyp 43,not_active ,20
ENG253212-ENG261054-Leuchte 43 Wischblinksignal_re C33_B36-Lichtansteuerung HD ABC 43,Always ,20
ENG253212-ENG258146-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion A 43,not active ,20
ENG253212-ENG258144-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion B 43,not active ,20
ENG253212-ENG258171-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion C 43,not active ,20
ENG253212-ENG259397-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion D 43,not active ,20
ENG253212-ENG260658-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion E 43,not active ,20
ENG253212-ENG260002-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion F 43,not active ,20
ENG253212-ENG260698-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion G 43,not active ,20
ENG253212-ENG261082-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion H 43,not active ,20
ENG253212-ENG260261-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion I 43,not active ,20
ENG253212-ENG259097-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion J 43,not active ,20
ENG253212-ENG260203-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion K 43,not active ,20
ENG253212-ENG258986-Leuchte 43 Wischblinksignal_re C33_B36-Lichtfunktion L 43,not active ,20
ENG253108-ENG258231-Leuchte 44 ALV C70-Dimming Direction DEF 44,maximize ,20
ENG253108-ENG260416-Leuchte 44 ALV C70-Dimming Direction GHI 44,maximize ,20
ENG253108-ENG260409-Leuchte 44 ALV C70-Dimming Direction JKL 44,maximize ,20
ENG253108-ENG261347-Leuchte 44 ALV C70-Dimmwert ABC 44,127 ,20
ENG253108-ENG260630-Leuchte 44 ALV C70-Dimmwert DEF 44,0 ,20
ENG253108-ENG259610-Leuchte 44 ALV C70-Dimmwert GHI 44,0 ,20
ENG253108-ENG261335-Leuchte 44 ALV C70-Dimmwert JKL 44,0 ,20
ENG253108-ENG260566-Leuchte 44 ALV C70-Fehlerort mittleres Byte DTC-DFCC 44,85 ,20
ENG253108-ENG261036-Leuchte 44 ALV C70-Lampendefektbitposition 44,00 ,20
ENG253108-ENG258970-Leuchte 44 ALV C70-Lasttyp 44,LED Lichtmodul ohne Open Load Diagnose ,20
ENG253108-ENG258540-Leuchte 44 ALV C70-Lichtansteuerung HD ABC 44,Always ,20
ENG253108-ENG260079-Leuchte 44 ALV C70-Lichtfunktion A 44,Ambientelichtmodul Versorgung ,20
ENG253108-ENG260296-Leuchte 44 ALV C70-Lichtfunktion B 44,aktiv100prozent ,20
ENG253108-ENG261154-Leuchte 44 ALV C70-Lichtfunktion C 44,not active ,20
ENG253108-ENG259507-Leuchte 44 ALV C70-Lichtfunktion D 44,not active ,20
ENG253108-ENG258260-Leuchte 44 ALV C70-Lichtfunktion E 44,not active ,20
ENG253108-ENG260714-Leuchte 44 ALV C70-Lichtfunktion F 44,not active ,20
ENG253108-ENG260064-Leuchte 44 ALV C70-Lichtfunktion G 44,not active ,20
ENG253108-ENG259720-Leuchte 44 ALV C70-Lichtfunktion H 44,not active ,20
ENG253108-ENG258947-Leuchte 44 ALV C70-Lichtfunktion I 44,not active ,20
ENG253108-ENG260429-Leuchte 44 ALV C70-Lichtfunktion J 44,not active ,20
ENG253108-ENG260305-Leuchte 44 ALV C70-Lichtfunktion K 44,not active ,20
ENG253108-ENG259925-Leuchte 44 ALV C70-Lichtfunktion L 44,not active ,20
ENG253209-ENG259161-Leuchte 45 KRL C56-Dimming Direction DEF 45,maximize ,20
ENG253209-ENG260000-Leuchte 45 KRL C56-Dimming Direction GHI 45,maximize ,20
ENG253209-ENG258382-Leuchte 45 KRL C56-Dimming Direction JKL 45,maximize ,20
ENG253209-ENG258536-Leuchte 45 KRL C56-Dimmwert ABC 45,100 ,20
ENG253209-ENG261049-Leuchte 45 KRL C56-Dimmwert DEF 45,0 ,20
ENG253209-ENG258646-Leuchte 45 KRL C56-Dimmwert GHI 45,0 ,20
ENG253209-ENG258455-Leuchte 45 KRL C56-Dimmwert JKL 45,0 ,20
ENG253209-ENG258548-Leuchte 45 KRL C56-Fehlerort mittleres Byte DTC-DFCC 45,89 ,20
ENG253209-ENG259186-Leuchte 45 KRL C56-Lampendefektbitposition 45,00 ,20
ENG253209-ENG259655-Leuchte 45 KRL C56-Lasttyp 45,LED_Kleinleistung_ohne_Open_Load_Diagnose ,20
ENG253209-ENG259881-Leuchte 45 KRL C56-Lichtansteuerung HD ABC 45,Always ,20
ENG253209-ENG258376-Leuchte 45 KRL C56-Lichtfunktion A 45,Luggage compartment light ,20
ENG253209-ENG260107-Leuchte 45 KRL C56-Lichtfunktion B 45,not active ,20
ENG253209-ENG259696-Leuchte 45 KRL C56-Lichtfunktion C 45,not active ,20
ENG253209-ENG258534-Leuchte 45 KRL C56-Lichtfunktion D 45,not active ,20
ENG253209-ENG258311-Leuchte 45 KRL C56-Lichtfunktion E 45,not active ,20
ENG253209-ENG259561-Leuchte 45 KRL C56-Lichtfunktion F 45,not active ,20
ENG253209-ENG258655-Leuchte 45 KRL C56-Lichtfunktion G 45,not active ,20
ENG253209-ENG258706-Leuchte 45 KRL C56-Lichtfunktion H 45,not active ,20
ENG253209-ENG260201-Leuchte 45 KRL C56-Lichtfunktion I 45,not active ,20
ENG253209-ENG259692-Leuchte 45 KRL C56-Lichtfunktion J 45,not active ,20
ENG253209-ENG259667-Leuchte 45 KRL C56-Lichtfunktion K 45,not active ,20
ENG253209-ENG259221-Leuchte 45 KRL C56-Lichtfunktion L 45,not active ,20
ENG263430-ENG259519-Leuchte 5 TFL R B4-Dimming Direction DEF 5,maximize ,20
ENG263430-ENG258873-Leuchte 5 TFL R B4-Dimming Direction GHI 5,maximize ,20
ENG263430-ENG260664-Leuchte 5 TFL R B4-Dimming Direction JKL 5,maximize ,20
ENG263430-ENG261164-Leuchte 5 TFL R B4-Dimmwert ABC 5,0 ,20
ENG263430-ENG259517-Leuchte 5 TFL R B4-Dimmwert DEF 5,0 ,20
ENG263430-ENG260636-Leuchte 5 TFL R B4-Dimmwert GHI 5,0 ,20
ENG263430-ENG258543-Leuchte 5 TFL R B4-Dimmwert JKL 5,0 ,20
ENG263430-ENG115969-Leuchte 5 TFL R B4-Fehlerort mittleres Byte DTC-DFCC 5,00 ,20
ENG263430-ENG116554-Leuchte 5 TFL R B4-Lampendefektbitposition 5,00 ,20
ENG263430-ENG115967-Leuchte 5 TFL R B4-Lasttyp 5,not_active ,20
ENG263430-ENG258404-Leuchte 5 TFL R B4-Lichtansteuerung HD ABC 5,Always ,20
ENG263430-ENG115970-Leuchte 5 TFL R B4-Lichtfunktion A 5,not active ,20
ENG263430-ENG115971-Leuchte 5 TFL R B4-Lichtfunktion B 5,not active ,20
ENG263430-ENG115974-Leuchte 5 TFL R B4-Lichtfunktion C 5,not active ,20
ENG263430-ENG115975-Leuchte 5 TFL R B4-Lichtfunktion D 5,not active ,20
ENG263430-ENG115978-Leuchte 5 TFL R B4-Lichtfunktion E 5,not active ,20
ENG263430-ENG116555-Leuchte 5 TFL R B4-Lichtfunktion F 5,not active ,20
ENG263430-ENG115982-Leuchte 5 TFL R B4-Lichtfunktion G 5,not active ,20
ENG263430-ENG115983-Leuchte 5 TFL R B4-Lichtfunktion H 5,not active ,20
ENG263430-ENG259352-Leuchte 5 TFL R B4-Lichtfunktion I 5,not active ,20
ENG263430-ENG260105-Leuchte 5 TFL R B4-Lichtfunktion J 5,not active ,20
ENG263430-ENG261301-Leuchte 5 TFL R B4-Lichtfunktion K 5,not active ,20
ENG263430-ENG258882-Leuchte 5 TFL R B4-Lichtfunktion L 5,not active ,20
ENG263442-ENG259123-Leuchte 6 ABL L C5-Dimming Direction DEF 6,maximize ,20
ENG263442-ENG258751-Leuchte 6 ABL L C5-Dimming Direction GHI 6,maximize ,20
ENG263442-ENG259402-Leuchte 6 ABL L C5-Dimming Direction JKL 6,maximize ,20
ENG263442-ENG260099-Leuchte 6 ABL L C5-Dimmwert ABC 6,0 ,20
ENG263442-ENG259481-Leuchte 6 ABL L C5-Dimmwert DEF 6,0 ,20
ENG263442-ENG258578-Leuchte 6 ABL L C5-Dimmwert GHI 6,0 ,20
ENG263442-ENG259931-Leuchte 6 ABL L C5-Dimmwert JKL 6,0 ,20
ENG263442-ENG115988-Leuchte 6 ABL L C5-Fehlerort mittleres Byte DTC-DFCC 6,00 ,20
ENG263442-ENG116556-Leuchte 6 ABL L C5-Lampendefektbitposition 6,00 ,20
ENG263442-ENG115986-Leuchte 6 ABL L C5-Lasttyp 6,not_active ,20
ENG263442-ENG260333-Leuchte 6 ABL L C5-Lichtansteuerung HD ABC 6,Always ,20
ENG263442-ENG115989-Leuchte 6 ABL L C5-Lichtfunktion A 6,not active ,20
ENG263442-ENG115990-Leuchte 6 ABL L C5-Lichtfunktion B 6,not active ,20
ENG263442-ENG115993-Leuchte 6 ABL L C5-Lichtfunktion C 6,not active ,20
ENG263442-ENG115994-Leuchte 6 ABL L C5-Lichtfunktion D 6,not active ,20
ENG263442-ENG115997-Leuchte 6 ABL L C5-Lichtfunktion E 6,not active ,20
ENG263442-ENG115998-Leuchte 6 ABL L C5-Lichtfunktion F 6,not active ,20
ENG263442-ENG116001-Leuchte 6 ABL L C5-Lichtfunktion G 6,not active ,20
ENG263442-ENG116002-Leuchte 6 ABL L C5-Lichtfunktion H 6,not active ,20
ENG263442-ENG259152-Leuchte 6 ABL L C5-Lichtfunktion I 6,not active ,20
ENG263442-ENG260123-Leuchte 6 ABL L C5-Lichtfunktion J 6,not active ,20
ENG263442-ENG258263-Leuchte 6 ABL L C5-Lichtfunktion K 6,not active ,20
ENG263442-ENG260915-Leuchte 6 ABL L C5-Lichtfunktion L 6,not active ,20
ENG263471-ENG258829-Leuchte 7 ABL R B1-Dimming Direction DEF 7,maximize ,20
ENG263471-ENG258643-Leuchte 7 ABL R B1-Dimming Direction GHI 7,maximize ,20
ENG263471-ENG260358-Leuchte 7 ABL R B1-Dimming Direction JKL 7,maximize ,20
ENG263471-ENG258757-Leuchte 7 ABL R B1-Dimmwert ABC 7,0 ,20
ENG263471-ENG260928-Leuchte 7 ABL R B1-Dimmwert DEF 7,0 ,20
ENG263471-ENG258547-Leuchte 7 ABL R B1-Dimmwert GHI 7,0 ,20
ENG263471-ENG260103-Leuchte 7 ABL R B1-Dimmwert JKL 7,0 ,20
ENG263471-ENG116007-Leuchte 7 ABL R B1-Fehlerort mittleres Byte DTC-DFCC 7,00 ,20
ENG263471-ENG116557-Leuchte 7 ABL R B1-Lampendefektbitposition 7,00 ,20
ENG263471-ENG116005-Leuchte 7 ABL R B1-Lasttyp 7,not_active ,20
ENG263471-ENG259256-Leuchte 7 ABL R B1-Lichtansteuerung HD ABC 7,Always ,20
ENG263471-ENG116008-Leuchte 7 ABL R B1-Lichtfunktion A 7,not active ,20
ENG263471-ENG116009-Leuchte 7 ABL R B1-Lichtfunktion B 7,not active ,20
ENG263471-ENG116012-Leuchte 7 ABL R B1-Lichtfunktion C 7,not active ,20
ENG263471-ENG116013-Leuchte 7 ABL R B1-Lichtfunktion D 7,not active ,20
ENG263471-ENG116016-Leuchte 7 ABL R B1-Lichtfunktion E 7,not active ,20
ENG263471-ENG116017-Leuchte 7 ABL R B1-Lichtfunktion F 7,not active ,20
ENG263471-ENG116020-Leuchte 7 ABL R B1-Lichtfunktion G 7,not active ,20
ENG263471-ENG116021-Leuchte 7 ABL R B1-Lichtfunktion H 7,not active ,20
ENG263471-ENG259451-Leuchte 7 ABL R B1-Lichtfunktion I 7,not active ,20
ENG263471-ENG259043-Leuchte 7 ABL R B1-Lichtfunktion J 7,not active ,20
ENG263471-ENG261166-Leuchte 7 ABL R B1-Lichtfunktion K 7,not active ,20
ENG263471-ENG258778-Leuchte 7 ABL R B1-Lichtfunktion L 7,not active ,20
ENG263437-ENG260885-Leuchte 8 FL L B39-Dimming Direction DEF 8,maximize ,20
ENG263437-ENG259591-Leuchte 8 FL L B39-Dimming Direction GHI 8,maximize ,20
ENG263437-ENG259283-Leuchte 8 FL L B39-Dimming Direction JKL 8,maximize ,20
ENG263437-ENG259944-Leuchte 8 FL L B39-Dimmwert ABC 8,0 ,20
ENG263437-ENG258915-Leuchte 8 FL L B39-Dimmwert DEF 8,0 ,20
ENG263437-ENG261200-Leuchte 8 FL L B39-Dimmwert GHI 8,0 ,20
ENG263437-ENG259325-Leuchte 8 FL L B39-Dimmwert JKL 8,0 ,20
ENG263437-ENG116026-Leuchte 8 FL L B39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,20
ENG263437-ENG116558-Leuchte 8 FL L B39-Lampendefektbitposition 8,00 ,20
ENG263437-ENG116024-Leuchte 8 FL L B39-Lasttyp 8,not_active ,20
ENG263437-ENG261218-Leuchte 8 FL L B39-Lichtansteuerung HD ABC 8,Always ,20
ENG263437-ENG116027-Leuchte 8 FL L B39-Lichtfunktion A 8,not active ,20
ENG263437-ENG116028-Leuchte 8 FL L B39-Lichtfunktion B 8,not active ,20
ENG263437-ENG116031-Leuchte 8 FL L B39-Lichtfunktion C 8,not active ,20
ENG263437-ENG116032-Leuchte 8 FL L B39-Lichtfunktion D 8,not active ,20
ENG263437-ENG116035-Leuchte 8 FL L B39-Lichtfunktion E 8,not active ,20
ENG263437-ENG116036-Leuchte 8 FL L B39-Lichtfunktion F 8,not active ,20
ENG263437-ENG116039-Leuchte 8 FL L B39-Lichtfunktion G 8,not active ,20
ENG263437-ENG116040-Leuchte 8 FL L B39-Lichtfunktion H 8,not active ,20
ENG263437-ENG261106-Leuchte 8 FL L B39-Lichtfunktion I 8,not active ,20
ENG263437-ENG259701-Leuchte 8 FL L B39-Lichtfunktion J 8,not active ,20
ENG263437-ENG260491-Leuchte 8 FL L B39-Lichtfunktion K 8,not active ,20
ENG263437-ENG260880-Leuchte 8 FL L B39-Lichtfunktion L 8,not active ,20
ENG263456-ENG260851-Leuchte 9 FL R B2-Dimming Direction DEF 9,maximize ,20
ENG263456-ENG260306-Leuchte 9 FL R B2-Dimming Direction GHI 9,maximize ,20
ENG263456-ENG261237-Leuchte 9 FL R B2-Dimming Direction JKL 9,maximize ,20
ENG263456-ENG260111-Leuchte 9 FL R B2-Dimmwert ABC 9,0 ,20
ENG263456-ENG260295-Leuchte 9 FL R B2-Dimmwert DEF 9,0 ,20
ENG263456-ENG259797-Leuchte 9 FL R B2-Dimmwert GHI 9,0 ,20
ENG263456-ENG260331-Leuchte 9 FL R B2-Dimmwert JKL 9,0 ,20
ENG263456-ENG116045-Leuchte 9 FL R B2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,20
ENG263456-ENG116559-Leuchte 9 FL R B2-Lampendefektbitposition 9,00 ,20
ENG263456-ENG116043-Leuchte 9 FL R B2-Lasttyp 9,not_active ,20
ENG263456-ENG258094-Leuchte 9 FL R B2-Lichtansteuerung HD ABC 9,Always ,20
ENG263456-ENG116046-Leuchte 9 FL R B2-Lichtfunktion A 9,not active ,20
ENG263456-ENG116047-Leuchte 9 FL R B2-Lichtfunktion B 9,not active ,20
ENG263456-ENG116050-Leuchte 9 FL R B2-Lichtfunktion C 9,not active ,20
ENG263456-ENG116051-Leuchte 9 FL R B2-Lichtfunktion D 9,not active ,20
ENG263456-ENG116054-Leuchte 9 FL R B2-Lichtfunktion E 9,not active ,20
ENG263456-ENG116055-Leuchte 9 FL R B2-Lichtfunktion F 9,not active ,20
ENG263456-ENG116058-Leuchte 9 FL R B2-Lichtfunktion G 9,not active ,20
ENG263456-ENG116059-Leuchte 9 FL R B2-Lichtfunktion H 9,not active ,20
ENG263456-ENG260691-Leuchte 9 FL R B2-Lichtfunktion I 9,not active ,20
ENG263456-ENG260334-Leuchte 9 FL R B2-Lichtfunktion J 9,not active ,20
ENG263456-ENG258156-Leuchte 9 FL R B2-Lichtfunktion K 9,not active ,20
ENG263456-ENG259184-Leuchte 9 FL R B2-Lichtfunktion L 9,not active ,20
ENG253237-IDE03311-Licht Konfig-Abh ngig-Emergency braking display,not active ,4
ENG253237-IDE07470-Licht Konfig-Abh ngig-After-run for park light,No_sidelights_delay ,4
ENG253237-ENG142020-Licht Konfig-Abh ngig-All-weather light,not installed ,4
ENG253237-ENG258575-Licht Konfig-Abh ngig-Diskrete_SBBR_links,installed ,4
ENG253237-ENG259588-Licht Konfig-Abh ngig-Diskrete_SBBR_rechts,installed ,4
ENG253237-ENG142191-Licht Konfig-Abh ngig-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,4
ENG253237-ENG142190-Licht Konfig-Abh ngig-Signaturlicht_verbaut,not installed ,4
ENG253374-ENG246963-Licht_bedienung-Anzeigezeit_LTM_PopUp1,4.0 s,12
ENG253374-ENG246964-Licht_bedienung-Anzeigezeit_LTM_PopUp1_lang,4 s,12
ENG253374-ENG246965-Licht_bedienung-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,12
ENG253374-ENG246966-Licht_bedienung-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,12
ENG253374-ENG246978-Licht_bedienung-Licht_anforderung_FAS,not installed ,12
ENG253374-ENG246979-Licht_bedienung-Licht_anforderung_Pilopark,not active ,12
ENG253374-ENG246980-Licht_bedienung-Licht_Reaktivierungs_grenze,95 m,12
ENG253374-ENG246981-Licht_bedienung-Lichttastermodul,LTM_Zentraltaste ,12
ENG253374-ENG246982-Licht_bedienung-LTM_Anzeige_Config,02 ,12
ENG253374-ENG246983-Licht_bedienung-LTM_Beleuchtung_Geschwindigkeits_Schwelle,10 km/h,12
ENG253374-ENG246984-Licht_bedienung-LTM_BGL_Geschwindigkeitsabh ngig,active ,12
ENG253374-ENG246985-Licht_bedienung-LTM_BGL_Geschwindigkeitsabh ngig_Parameter,active ,12
ENG253374-ENG246986-Licht_bedienung-LTM_BGL_Wegabh ngig,active ,12
ENG253374-ENG246987-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabh ngig,active ,12
ENG253374-ENG246988-Licht_bedienung-LTM_GlobalOFF_Geschwindigkeitsabh ngig_Parameter,active ,12
ENG253374-ENG246989-Licht_bedienung-LTM_GlobalOFF_Wegabh ngig,active ,12
ENG253374-ENG246990-Licht_bedienung-LTM_GlobalOFF_Z ndungsabh ngig,not active ,12
ENG253335-ENG259757-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_A,00 ,28
ENG253335-ENG261031-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_B,00 ,28
ENG253335-ENG259460-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_C,00 ,28
ENG253335-ENG261084-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_FSP_D,00 ,28
ENG253335-ENG260307-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_1,00 ,28
ENG253335-ENG258132-Lichtfunktion_Fehler_Eintrag-Lichtrouter_1_LF_2,00 ,28
ENG253335-ENG258256-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_A,00 ,28
ENG253335-ENG260342-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_B,00 ,28
ENG253335-ENG259281-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_C,00 ,28
ENG253335-ENG260011-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_FSP_D,00 ,28
ENG253335-ENG260245-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_1,00 ,28
ENG253335-ENG261364-Lichtfunktion_Fehler_Eintrag-Lichtrouter_2_LF_2,00 ,28
ENG253335-ENG260487-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_A,00 ,28
ENG253335-ENG260833-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_B,00 ,28
ENG253335-ENG261075-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_C,00 ,28
ENG253335-ENG260552-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_FSP_D,00 ,28
ENG253335-ENG260964-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_1,00 ,28
ENG253335-ENG260937-Lichtfunktion_Fehler_Eintrag-Lichtrouter_3_LF_2,00 ,28
ENG253335-ENG261254-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_A,00 ,28
ENG253335-ENG259240-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_B,00 ,28
ENG253335-ENG258653-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_C,00 ,28
ENG253335-ENG258931-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_FSP_D,00 ,28
ENG253335-ENG259853-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_1,00 ,28
ENG253335-ENG258582-Lichtfunktion_Fehler_Eintrag-Lichtrouter_4_LF_2,00 ,28
ENG174381-MAS00525-light_control-Trailer turn signal indicator lamp,INDIVIDUAL ,4
ENG174381-MAS07990-light_control-Comfort flasher,active ,4
ENG174381-MAS07991-light_control-Comfort flasher set point,3 ,4
ENG174381-MAS10538-light_control-Light rotary sw. connection,Data bus LIN 1 ,4
ENG174381-MAS12415-light_control-Parking lamp indicator lamp,INDIVIDUAL ,4
ENG174381-MAS21315-light_control-Convenience flashing cancellation,active ,4
ENG174381-ENG142188-light_control-bewusstes Standlicht,Aktive Begrenzung ,4
ENG174381-ENG154711-light_control-PreCrash_RECAS,active ,4
ENG174381-ENG126817-light_control-Umfeldleuchte als Manoevrierleuchte,not active ,4
ENG174381-ENG142004-light_control-Umgreifende_Heckklappe,not installed ,4
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,active ,2
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,active ,2
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,active ,2
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,active ,2
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,active ,2
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,active ,2
ENG126648-ENG260631-LIN-Mirrormode-LIN10,active ,2
ENG126648-ENG259894-LIN-Mirrormode-LIN11,active ,2
ENG126648-ENG260777-LIN-Mirrormode-LIN12,active ,2
ENG126648-ENG258456-LIN-Mirrormode-LIN13,active ,2
ENG126648-ENG259488-LIN-Mirrormode-LIN14,active ,2
ENG126648-ENG260898-LIN-Mirrormode-LIN7,active ,2
ENG126648-ENG259836-LIN-Mirrormode-LIN8,active ,2
ENG126648-ENG258319-LIN-Mirrormode-LIN9,active ,2
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,2
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,installed ,2
ENG153728-MAS02790-LIN-SMLS_konfig_2-Diagnosis,not active ,2
ENG153728-MAS03758-LIN-SMLS_konfig_2-Not assigned,not installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG253274-ENG260814-Lock Unlock Taster-Lock_Unlock_Taster_diskret,not active ,2
ENG253274-ENG258303-Lock Unlock Taster-Lock_Unlock_Taster_Logik,Rocker sw. ,2
ENG253158-LWR Basissoftware,15 %,16
ENG253042-IDE03638-LWR Konfiguration-Static cornering light,Deactivated ,8
ENG253042-IDE03644-LWR Konfiguration-Highway light,not activated ,8
ENG253042-MAS02922-LWR Konfiguration-City light,not activated ,8
ENG253042-MAS07013-LWR Konfiguration-All-weather light,not activated ,8
ENG253042-MAS07933-LWR Konfiguration-Eco mode,not activated ,8
ENG253042-ENG172238-LWR Konfiguration-chassis_unit,Mehrlenkerhinterachse Frontantrieb ,8
ENG253042-ENG260425-LWR Konfiguration-Function_activation_LWR,activated ,8
ENG253042-ENG174374-LWR Konfiguration-LED_Headlight,activated ,8
ENG253042-ENG259430-LWR Konfiguration-LWR_konfig,CAN HMI ,8
ENG253042-ENG172241-LWR Konfiguration-lwr_sensors,2_sensors ,8
ENG253042-ENG171501-LWR Konfiguration-Market,NAR ,8
ENG253042-ENG173009-LWR Konfiguration-offroad_light,not activated ,8
ENG253042-ENG172245-LWR Konfiguration-rain_light,not activated ,8
ENG253042-ENG174637-LWR Konfiguration-Source_height_value,BCM ,8
ENG253042-ENG172240-LWR Konfiguration-steering_curve,normal ,8
ENG253084-MDK,00 ,4
ENG249798-MDK_coding-,00 ,8
ENG249798-ENG253476-MDK_coding-MDK_bBtle_COV,00 ,8
ENG249798-ENG253477-MDK_coding-MDK_bExtendedScActivation_COV,00 ,8
ENG253387-mdk_locking_coding,not installed ,3
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,3
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,3
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,3
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,3
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,3
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,3
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,3
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,3
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,3
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,3
ENG122979-ENG141953-Networking-Getriebesteuergeraet,Monostable selector lever ,8
ENG153902-NFC_FS_debug_switch,No Response From Subnet Component,8
ENG153904-NFC_MiKo_debug_switch,No Response From Subnet Component,8
ENG253222-NFC_MiKo_WLC_Functions-,No Response From Subnet Component,8
ENG253222-ENG253104-NFC_MiKo_WLC_Functions-NFC_MiKo_Attenuation_internal_BTLE_antenna,No Response From Subnet Component,8
ENG124714-ENG142044-OCU-DWA_push,active ,10
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,10
ENG124714-OCU-,installed ,10
ENG124714-ENG259569-OCU-Remote HuF,active ,10
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,10
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,10
ENG124714-ENG260662-OCU-Remote HuF maximale Ausf hrungsdauer,30 s,10
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,10
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,10
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,10
ENG253051-ENG258966-Par_AutomatikFKT-AutomatikFunktion_Entfernungsschwelle_Wechsel_Zyklus_IDGeberAbwesenheit_Beschleunigtes_Entry,50 dB,27
ENG253051-ENG260817-Par_AutomatikFKT-AutomatikFunktion_Gueltigkeitsdauer_IDGeber_Authentifizierungsstatus_Beschleunigtes_Entry,5.00 s,27
ENG253051-ENG260526-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Inkrement,1 ,27
ENG253051-ENG261190-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle,60 ,27
ENG253051-ENG258545-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Schwelle_Offset,5 ,27
ENG253051-ENG258184-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Dekrement,60 s,27
ENG253051-ENG260053-Par_AutomatikFKT-AutomatikFunktionen_Spielschutz_Timeout_Inkrement,10 s,27
ENG253051-ENG258738-Par_AutomatikFKT-AutomatikFunktionen_WechselBeiIDGebernInRuhe_Timeout,30 s,27
ENG253051-ENG258350-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_FahrendesFzg,20 km/h,27
ENG253051-ENG260570-Par_AutomatikFKT-Automatisches_Verriegeln_Schwelle_StehendesFzg,10 km/h,27
ENG253051-ENG259977-Par_AutomatikFKT-TemporaereSperrungFuerAutomatikFunktionen_Dauer,2 s,27
ENG253220-Par_Bedienstellen,2 ,7
ENG253257-ENG259939-Par_Dienste-Beeinflussung_StartStopp_DauerWiederstart,500 ms,18
ENG253257-ENG259005-Par_Dienste-Beeinflussung_StartStopp_Timeout,500 ms,18
ENG253257-ENG259811-Par_Dienste-Bereichsueberwachung_Pilotiertes_Parken_Timeout,120 s,18
ENG253257-ENG261028-Par_Dienste-EntryGoDeaktivierung_ZweiteBedienhandlung_Timeout,5 s,18
ENG253257-ENG261102-Par_Dienste-Innenraumsuche_GueltigkeitFuerExterneFunktionen,10 s,18
ENG253257-ENG258558-Par_Dienste-Paketbotenmodus_Timeout,15 min,18
ENG253257-ENG259702-Par_Dienste-Signalisierungsdauer_Ergebnis_IDGebersuche_ext_Funktionen,500 ms,18
ENG253257-ENG260866-Par_Dienste-SpielschutzFuerDienste_Dekrement_Timeout,60 s,18
ENG253257-ENG260031-Par_Dienste-SpielschutzFuerDienste_Schwelle,10 ,18
ENG253257-ENG258560-Par_Dienste-VIT_Mindest_Empfangs_Dauer_Betaetigt_Start_Suche,10 ms,18
ENG253386-ENG259497-Par_IDGeberSuche-Innenraumsuche_Kl15_Pause,5000 ms,26
ENG253386-ENG258238-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FahrendesFzg,20 km/h,26
ENG253386-ENG260811-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_FensterGeschlossen,5.0 %,26
ENG253386-ENG258295-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_SADGeschlossen,255 %,26
ENG253386-ENG259267-Par_IDGeberSuche-Innenraumsuche_Kl15_Schwelle_StehendesFzg,10 km/h,26
ENG253386-ENG261289-Par_IDGeberSuche-Innenraumsuche_Kl15_Wiederholungen,5 ,26
ENG253386-ENG260801-Par_IDGeberSuche-Innenraumsuche_verzoegertFFBKomfortschlie en,3200 ms,26
ENG253386-ENG260447-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Heck_ZeitfensterFuerRasten,500 ms,26
ENG253386-ENG260184-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_FensterOffen,100.0 %,26
ENG253386-ENG260557-Par_IDGeberSuche-Innenraumsuche_Wiederentriegelung_Komfortschliessen_SchwelleFuer_SADOffen,5.0 %,26
ENG253386-ENG258851-Par_IDGeberSuche-SignalisierungFunkkommunikation_Vorlauf,0 ms,26
ENG253236-ENG260747-Par_Passive_EntryExit_Toggle-BewussteGesamtEntriegelung,5000 ms,6
ENG253236-ENG281088-Par_Passive_EntryExit_Toggle-TemporaereSperrungFuerExit_Dauer,0.0 s,6
ENG253236-ENG281089-Par_Passive_EntryExit_Toggle-Verriegelungskontrolle_Dauer,2.0 s,6
ENG253347-ENG258202-Par_RSAD-Box2Box_Zuordnung_RSAD_HL,3 ,20
ENG253347-ENG259350-Par_RSAD-Box2Box_Zuordnung_RSAD_HR,3 ,20
ENG253347-ENG260315-Par_RSAD-Box2Box_Zuordnung_RSAD_IN,1 ,20
ENG253347-ENG260967-Par_RSAD-Box2Box_Zuordnung_RSAD_VL,1 ,20
ENG253347-ENG260395-Par_RSAD-Box2Box_Zuordnung_RSAD_VR,1 ,20
ENG253347-ENG259213-Par_RSAD-maxAbstand_RSAD_innen_Referenzbox,600 cm,20
ENG253347-ENG258615-Par_RSAD-maxAbstand_RSAD_links_rechts,345 cm,20
ENG253347-ENG260439-Par_RSAD-maxAbstand_RSAD_vorne_hinten,600 cm,20
ENG253347-ENG281104-Par_RSAD-minAbstand_RSAD_innen_Referenzbox,210 cm,20
ENG253347-ENG281079-Par_RSAD-minAbstand_RSAD_links_rechts,105 cm,20
ENG253347-ENG281105-Par_RSAD-minAbstand_RSAD_vorne_hinten,210 cm,20
ENG253347-ENG259498-Par_RSAD-RSAD_UWB_aussen_Entfernung,600 cm,20
ENG253347-ENG260842-Par_RSAD-RSAD_UWB_innen_Entfernung,0 cm,20
ENG253347-ENG289610-Par_RSAD-RSAD_UWB_maxAbweichung,45 ,20
ENG253398-ENG261340-Par_ScanStrat_RetryHandling-anz_GesamtRetries,1 ,18
ENG253398-ENG260989-Par_ScanStrat_RetryHandling-anz_RetriesAuthentifizierung,2 ,18
ENG253398-ENG260903-Par_ScanStrat_RetryHandling-Dynamischer_Anteil_Registering,7 ms,18
ENG253398-ENG259602-Par_ScanStrat_RetryHandling-RetryAuthentifizierung_Entry_UWB,80 ms,18
ENG253398-ENG258787-Par_ScanStrat_RetryHandling-Timeout_Go_Authentifizierungsphase,160 ms,18
ENG253398-ENG260198-Par_ScanStrat_RetryHandling-Wartezeit_Challenge_Retry_Challenge_Entry,6 ms,18
ENG253398-ENG259374-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Entry,4 ms,18
ENG253398-ENG261047-Par_ScanStrat_RetryHandling-Wartezeit_Registering_Challenge_Go,35 ms,18
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,No Response From Subnet Component,18
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,No Response From Subnet Component,18
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125667-Passenger_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125666-Passenger_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125668-Passenger_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125673-Passenger_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125672-Passenger_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125674-Passenger_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125670-Passenger_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125669-Passenger_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125671-Passenger_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125676-Passenger_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125675-Passenger_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125677-Passenger_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125664-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125663-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179044-ENG125665-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125667-Passenger_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125666-Passenger_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125668-Passenger_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125673-Passenger_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125672-Passenger_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125674-Passenger_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125670-Passenger_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125669-Passenger_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125671-Passenger_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125676-Passenger_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125675-Passenger_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125677-Passenger_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125664-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125663-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179045-ENG125665-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125667-Passenger_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125666-Passenger_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125668-Passenger_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125673-Passenger_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125672-Passenger_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125674-Passenger_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125670-Passenger_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125669-Passenger_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125671-Passenger_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125676-Passenger_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125675-Passenger_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125677-Passenger_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125664-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125663-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,No Response From Subnet Component,18
ENG179046-ENG125665-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,No Response From Subnet Component,18
ENG133367-ENG133507-Passenger_multi-contour_seat_Error_Mask-ERROR_CODE_PIN,No Response From Subnet Component,18
ENG133367-ENG133526-Passenger_multi-contour_seat_Error_Mask-ERROR_EEPROM,No Response From Subnet Component,18
ENG133367-ENG133528-Passenger_multi-contour_seat_Error_Mask-ERROR_HW_VERSION,No Response From Subnet Component,18
ENG133367-ENG133500-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133499-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB1_LEAK,No Response From Subnet Component,18
ENG133367-ENG133502-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133501-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB2_LEAK,No Response From Subnet Component,18
ENG133367-ENG133504-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133503-Passenger_multi-contour_seat_Error_Mask-ERROR_LUMB3_LEAK,No Response From Subnet Component,18
ENG133367-ENG133511-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_BLOCK,No Response From Subnet Component,18
ENG133367-ENG133508-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_OPEN,No Response From Subnet Component,18
ENG133367-ENG133509-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_GND,No Response From Subnet Component,18
ENG133367-ENG133510-Passenger_multi-contour_seat_Error_Mask-ERROR_PUMP_SHORT_UB,No Response From Subnet Component,18
ENG133367-ENG133524-Passenger_multi-contour_seat_Error_Mask-ERROR_RAM,No Response From Subnet Component,18
ENG133367-ENG133525-Passenger_multi-contour_seat_Error_Mask-ERROR_ROM,No Response From Subnet Component,18
ENG133367-ENG133506-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_CTRL_LEAK,No Response From Subnet Component,18
ENG133367-ENG133505-Passenger_multi-contour_seat_Error_Mask-ERROR_SIDE_LEAK,No Response From Subnet Component,18
ENG133367-ENG133531-Passenger_multi-contour_seat_Error_Mask-ERROR_SIG_RESPONSE,No Response From Subnet Component,18
ENG133367-ENG133512-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_1,No Response From Subnet Component,18
ENG133367-ENG133515-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_2,No Response From Subnet Component,18
ENG133367-ENG133518-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_3,No Response From Subnet Component,18
ENG133367-ENG133521-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_BLOCK_4,No Response From Subnet Component,18
ENG133367-ENG133513-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_1,No Response From Subnet Component,18
ENG133367-ENG133516-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_2,No Response From Subnet Component,18
ENG133367-ENG133519-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_3,No Response From Subnet Component,18
ENG133367-ENG133522-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_SHORT_4,No Response From Subnet Component,18
ENG133367-ENG133514-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_1,No Response From Subnet Component,18
ENG133367-ENG133517-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_2,No Response From Subnet Component,18
ENG133367-ENG133520-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_3,No Response From Subnet Component,18
ENG133367-ENG133523-Passenger_multi-contour_seat_Error_Mask-ERROR_SWITCH_UNPLAUS_4,No Response From Subnet Component,18
ENG133367-ENG133529-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_HIGH,No Response From Subnet Component,18
ENG133367-ENG133530-Passenger_multi-contour_seat_Error_Mask-ERROR_VOLTAGE_LOW,No Response From Subnet Component,18
ENG133367-ENG133527-Passenger_multi-contour_seat_Error_Mask-ERROR_WDT,No Response From Subnet Component,18
ENG286146-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 1,No Response From Subnet Component,18
ENG286146-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 2,No Response From Subnet Component,18
ENG286146-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 3,No Response From Subnet Component,18
ENG286146-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 4,No Response From Subnet Component,18
ENG286146-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 5,No Response From Subnet Component,18
ENG286146-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 6,No Response From Subnet Component,18
ENG286146-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 7,No Response From Subnet Component,18
ENG286146-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 8,No Response From Subnet Component,18
ENG286146-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 9,No Response From Subnet Component,18
ENG286146-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 10,No Response From Subnet Component,18
ENG286146-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 11,No Response From Subnet Component,18
ENG286146-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 12,No Response From Subnet Component,18
ENG286146-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 13,No Response From Subnet Component,18
ENG286146-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 14,No Response From Subnet Component,18
ENG286146-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 15,No Response From Subnet Component,18
ENG286146-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 16,No Response From Subnet Component,18
ENG286146-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 17,No Response From Subnet Component,18
ENG286146-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 18,No Response From Subnet Component,18
ENG286146-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 19,No Response From Subnet Component,18
ENG286146-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 20,No Response From Subnet Component,18
ENG286146-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 21,No Response From Subnet Component,18
ENG286146-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 22,No Response From Subnet Component,18
ENG286146-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 23,No Response From Subnet Component,18
ENG286146-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 24,No Response From Subnet Component,18
ENG286146-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 25,No Response From Subnet Component,18
ENG286146-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 26,No Response From Subnet Component,18
ENG286146-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 27,No Response From Subnet Component,18
ENG286146-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 28,No Response From Subnet Component,18
ENG286146-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 29,No Response From Subnet Component,18
ENG286146-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 30,No Response From Subnet Component,18
ENG286146-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 31,No Response From Subnet Component,18
ENG286146-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 32,No Response From Subnet Component,18
ENG286146-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 33,No Response From Subnet Component,18
ENG286146-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 34,No Response From Subnet Component,18
ENG286146-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 35,No Response From Subnet Component,18
ENG286146-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 36,No Response From Subnet Component,18
ENG286146-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 37,No Response From Subnet Component,18
ENG286146-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 38,No Response From Subnet Component,18
ENG286146-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 39,No Response From Subnet Component,18
ENG286146-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 40,No Response From Subnet Component,18
ENG286146-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 41,No Response From Subnet Component,18
ENG286146-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 42,No Response From Subnet Component,18
ENG286146-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 43,No Response From Subnet Component,18
ENG286146-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 44,No Response From Subnet Component,18
ENG286146-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 45,No Response From Subnet Component,18
ENG286146-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 46,No Response From Subnet Component,18
ENG286146-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 47,No Response From Subnet Component,18
ENG286146-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 48,No Response From Subnet Component,18
ENG286146-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 49,No Response From Subnet Component,18
ENG286146-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 50,No Response From Subnet Component,18
ENG286146-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 51,No Response From Subnet Component,18
ENG286146-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 52,No Response From Subnet Component,18
ENG286146-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 53,No Response From Subnet Component,18
ENG286146-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 54,No Response From Subnet Component,18
ENG286146-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 55,No Response From Subnet Component,18
ENG286146-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 56,No Response From Subnet Component,18
ENG286146-IDE80057-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 57,No Response From Subnet Component,18
ENG286146-IDE80058-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 58,No Response From Subnet Component,18
ENG286146-IDE80059-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 59,No Response From Subnet Component,18
ENG286146-IDE80060-passenger_side_sliding_door_power_opening_control_unit_data_set_upload-Analysis 60,No Response From Subnet Component,18
ENG286147-IDE00047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Parameter set version,No Response From Subnet Component,18
ENG286147-IDE80001-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 1,No Response From Subnet Component,18
ENG286147-IDE80002-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 2,No Response From Subnet Component,18
ENG286147-IDE80003-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 3,No Response From Subnet Component,18
ENG286147-IDE80004-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 4,No Response From Subnet Component,18
ENG286147-IDE80005-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 5,No Response From Subnet Component,18
ENG286147-IDE80006-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 6,No Response From Subnet Component,18
ENG286147-IDE80007-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 7,No Response From Subnet Component,18
ENG286147-IDE80008-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 8,No Response From Subnet Component,18
ENG286147-IDE80009-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 9,No Response From Subnet Component,18
ENG286147-IDE80010-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 10,No Response From Subnet Component,18
ENG286147-IDE80011-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 11,No Response From Subnet Component,18
ENG286147-IDE80012-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 12,No Response From Subnet Component,18
ENG286147-IDE80013-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 13,No Response From Subnet Component,18
ENG286147-IDE80014-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 14,No Response From Subnet Component,18
ENG286147-IDE80015-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 15,No Response From Subnet Component,18
ENG286147-IDE80016-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 16,No Response From Subnet Component,18
ENG286147-IDE80017-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 17,No Response From Subnet Component,18
ENG286147-IDE80018-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 18,No Response From Subnet Component,18
ENG286147-IDE80019-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 19,No Response From Subnet Component,18
ENG286147-IDE80020-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 20,No Response From Subnet Component,18
ENG286147-IDE80021-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 21,No Response From Subnet Component,18
ENG286147-IDE80022-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 22,No Response From Subnet Component,18
ENG286147-IDE80023-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 23,No Response From Subnet Component,18
ENG286147-IDE80024-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 24,No Response From Subnet Component,18
ENG286147-IDE80025-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 25,No Response From Subnet Component,18
ENG286147-IDE80026-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 26,No Response From Subnet Component,18
ENG286147-IDE80027-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 27,No Response From Subnet Component,18
ENG286147-IDE80028-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 28,No Response From Subnet Component,18
ENG286147-IDE80029-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 29,No Response From Subnet Component,18
ENG286147-IDE80030-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 30,No Response From Subnet Component,18
ENG286147-IDE80031-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 31,No Response From Subnet Component,18
ENG286147-IDE80032-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 32,No Response From Subnet Component,18
ENG286147-IDE80033-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 33,No Response From Subnet Component,18
ENG286147-IDE80034-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 34,No Response From Subnet Component,18
ENG286147-IDE80035-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 35,No Response From Subnet Component,18
ENG286147-IDE80036-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 36,No Response From Subnet Component,18
ENG286147-IDE80037-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 37,No Response From Subnet Component,18
ENG286147-IDE80038-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 38,No Response From Subnet Component,18
ENG286147-IDE80039-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 39,No Response From Subnet Component,18
ENG286147-IDE80040-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 40,No Response From Subnet Component,18
ENG286147-IDE80041-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 41,No Response From Subnet Component,18
ENG286147-IDE80042-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 42,No Response From Subnet Component,18
ENG286147-IDE80043-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 43,No Response From Subnet Component,18
ENG286147-IDE80044-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 44,No Response From Subnet Component,18
ENG286147-IDE80045-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 45,No Response From Subnet Component,18
ENG286147-IDE80046-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 46,No Response From Subnet Component,18
ENG286147-IDE80047-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 47,No Response From Subnet Component,18
ENG286147-IDE80048-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 48,No Response From Subnet Component,18
ENG286147-IDE80049-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 49,No Response From Subnet Component,18
ENG286147-IDE80050-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 50,No Response From Subnet Component,18
ENG286147-IDE80051-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 51,No Response From Subnet Component,18
ENG286147-IDE80052-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 52,No Response From Subnet Component,18
ENG286147-IDE80053-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 53,No Response From Subnet Component,18
ENG286147-IDE80054-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 54,No Response From Subnet Component,18
ENG286147-IDE80055-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 55,No Response From Subnet Component,18
ENG286147-IDE80056-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Analysis 56,No Response From Subnet Component,18
ENG286147-MAS01078-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-Vehicle model,No Response From Subnet Component,18
ENG286147-MAS14087-passenger_side_sliding_door_power_opening_control_unit_data_set_upload_two-time delay activation,No Response From Subnet Component,18
ENG253136-IDE02456-Passive_EntryExit_Toggle-Passive entry right rear door handle,not activated ,8
ENG253136-IDE02457-Passive_EntryExit_Toggle-Passive entry left rear door handle,not activated ,8
ENG253136-IDE02458-Passive_EntryExit_Toggle-Passive entry frt.pass. door handle,not activated ,8
ENG253136-IDE02459-Passive_EntryExit_Toggle-Passive entry driver door handle,not activated ,8
ENG253136-IDE02460-Passive_EntryExit_Toggle-Passive exit right rear door handle,not activated ,8
ENG253136-IDE02461-Passive_EntryExit_Toggle-Passive exit left rear door handle,not activated ,8
ENG253136-IDE02462-Passive_EntryExit_Toggle-Passive exit frt. pass. door handle,not activated ,8
ENG253136-IDE02463-Passive_EntryExit_Toggle-Passive exit driver door handle,not activated ,8
ENG253136-IDE03178-Passive_EntryExit_Toggle-Unlocking by electr. sliding door,not activated ,8
ENG253136-MAS18905-Passive_EntryExit_Toggle-Passive entry via control section rear,not activated ,8
ENG253136-MAS18906-Passive_EntryExit_Toggle-Passive entry by rear sensor,not activated ,8
ENG253136-MAS18907-Passive_EntryExit_Toggle-Monitoring of locking by pulling door handle,activated ,8
ENG253136-MAS18912-Passive_EntryExit_Toggle-Passive exit door handle control section rear,not activated ,8
ENG253136-MAS18913-Passive_EntryExit_Toggle-Lock/unlock button on driver door active,not activated ,8
ENG253136-MAS18914-Passive_EntryExit_Toggle-Lock/unlock button on front passenger door active,not activated ,8
ENG253136-MAS18915-Passive_EntryExit_Toggle-Lock/unlock button on rear driver side active,not activated ,8
ENG253136-MAS18916-Passive_EntryExit_Toggle-Lock/unlock button on front passenger side active,not activated ,8
ENG253136-MAS18917-Passive_EntryExit_Toggle-Lock/unlock button control section rear active,not activated ,8
ENG253136-ENG259242-Passive_EntryExit_Toggle-TemporaerSperrungFuerExit_aktiv,not activated ,8
ENG253136-ENG260214-Passive_EntryExit_Toggle-Verriegelungskontrolle_Heck_aktiv,not activated ,8
ENG129043-PASSIVE_GO,activated ,4
ENG253210-ENG260453-Personalisierung_2_0-Active_Participant_Doorlocking_Enabled,Deactivated ,12
ENG253210-ENG259841-Personalisierung_2_0-Active_Participant_ExteriorLight_Enabled,activated ,12
ENG253210-ENG260445-Personalisierung_2_0-Active_Participant_InteriorLight_Enabled,activated ,12
ENG253210-ENG259660-Personalisierung_2_0-Active_Participant_Mirror_Enabled,activated ,12
ENG253210-ENG259827-Personalisierung_2_0-Active_Participant_WiperComfort_Enabled,activated ,12
ENG253210-ENG258609-Personalisierung_2_0-PSO_Setup_1,not_active ,12
ENG253210-ENG260679-Personalisierung_2_0-PSO_Setup_2,not_active ,12
ENG253210-ENG259992-Personalisierung_2_0-PSO_Setup_Bereich_1,0 ms,12
ENG253210-ENG260317-Personalisierung_2_0-PSO_Setup_Bereich_2,0 ms,12
ENG253210-ENG260178-Personalisierung_2_0-Version_ Personalisierung,Customization coded 2.x ,12
ENG253210-ENG247653-Personalisierung_2_0-Wait_for_IAA_Slot_Info,150 ms,12
ENG253109-PSI5 Konfiguration,02 ,16
ENG253310-PSI5 Sensoren,not installed ,1
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,8
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,8
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,not active ,8
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,8
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,8
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,8
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,8
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,8
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,8
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,8
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,8
ENG141646-ENG281077-Querschnitts_funktionen-SubCAN weckt nur den BusMaster,not active ,8
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,8
ENG244881-ENG286173-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286174-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaDiffMaxRawHeightPostMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286175-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286176-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaNegSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286177-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286178-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssaPosSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286179-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286180-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange[0],No Response From Subnet Component,8
ENG244881-ENG286181-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaFillFactorRange[1],No Response From Subnet Component,8
ENG244881-ENG286182-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange[0],No Response From Subnet Component,8
ENG244881-ENG286183-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaLowVarCountRange[1],No Response From Subnet Component,8
ENG244881-ENG286184-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation[0],No Response From Subnet Component,8
ENG244881-ENG286185-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucaRelOscillation[1],No Response From Subnet Component,8
ENG244881-ENG289577-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289578-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286188-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289579-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289580-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289581-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289582-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289583-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289584-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286195-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286196-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286197-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange[0],No Response From Subnet Component,8
ENG244881-ENG286198-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaMaxHeightRange[1],No Response From Subnet Component,8
ENG244881-ENG286199-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286200-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRawVarMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286201-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange[0],No Response From Subnet Component,8
ENG244881-ENG286202-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRelPostKickVarRange[1],No Response From Subnet Component,8
ENG244881-ENG286203-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange[0],No Response From Subnet Component,8
ENG244881-ENG286204-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaRiseTimeRange[1],No Response From Subnet Component,8
ENG244881-ENG286205-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange[0],No Response From Subnet Component,8
ENG244881-ENG286206-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaTimeDiffRange[1],No Response From Subnet Component,8
ENG244881-ENG286207-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange[0],No Response From Subnet Component,8
ENG244881-ENG286208-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usaVarMaxRange[1],No Response From Subnet Component,8
ENG244881-ENG286209-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usCRC,No Response From Subnet Component,8
ENG244881-ENG289585-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289586-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usHMinEstim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286212-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286213-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_1_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286214-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286215-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaDiffMaxRawHeightPostMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286216-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286217-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaNegSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286218-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange[0],No Response From Subnet Component,8
ENG244881-ENG286219-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssaPosSlopeRange[1],No Response From Subnet Component,8
ENG244881-ENG286220-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ssSlopeThreshold,No Response From Subnet Component,8
ENG244881-ENG286221-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange[0],No Response From Subnet Component,8
ENG244881-ENG286222-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaFillFactorRange[1],No Response From Subnet Component,8
ENG244881-ENG286223-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange[0],No Response From Subnet Component,8
ENG244881-ENG286224-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaLowVarCountRange[1],No Response From Subnet Component,8
ENG244881-ENG286225-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation[0],No Response From Subnet Component,8
ENG244881-ENG286226-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucaRelOscillation[1],No Response From Subnet Component,8
ENG244881-ENG289587-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289588-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucBaseline_Samples,No Response From Subnet Component,8
ENG244881-ENG286229-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucDebounce,No Response From Subnet Component,8
ENG244881-ENG289589-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay,No Response From Subnet Component,8
ENG244881-ENG289590-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Delay_Low_Power,No Response From Subnet Component,8
ENG244881-ENG289591-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Low_Power_SAH_Length,No Response From Subnet Component,8
ENG244881-ENG289592-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucHMin_Estim_Width,No Response From Subnet Component,8
ENG244881-ENG289593-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Mean_Width,No Response From Subnet Component,8
ENG244881-ENG289594-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucPost_Kick_Var_Delay,No Response From Subnet Component,8
ENG244881-ENG286236-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ucStdDevOnRawWidth,No Response From Subnet Component,8
ENG244881-ENG286237-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_ulMinHeightSquaredMax,No Response From Subnet Component,8
ENG244881-ENG286238-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange[0],No Response From Subnet Component,8
ENG244881-ENG286239-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaMaxHeightRange[1],No Response From Subnet Component,8
ENG244881-ENG286240-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange[0],No Response From Subnet Component,8
ENG244881-ENG286241-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRawVarMeanRange[1],No Response From Subnet Component,8
ENG244881-ENG286242-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange[0],No Response From Subnet Component,8
ENG244881-ENG286243-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRelPostKickVarRange[1],No Response From Subnet Component,8
ENG244881-ENG286244-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange[0],No Response From Subnet Component,8
ENG244881-ENG286245-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaRiseTimeRange[1],No Response From Subnet Component,8
ENG244881-ENG286246-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange[0],No Response From Subnet Component,8
ENG244881-ENG286247-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaTimeDiffRange[1],No Response From Subnet Component,8
ENG244881-ENG286248-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange[0],No Response From Subnet Component,8
ENG244881-ENG286249-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usaVarMaxRange[1],No Response From Subnet Component,8
ENG244881-ENG286250-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usCRC,No Response From Subnet Component,8
ENG244881-ENG289595-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Default_Squared_Val,No Response From Subnet Component,8
ENG244881-ENG289596-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usHMin_Estim_Squared_Factor,No Response From Subnet Component,8
ENG244881-ENG286253-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usRawVarMax,No Response From Subnet Component,8
ENG244881-ENG286254-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-chnl_2_usVarianceThr,No Response From Subnet Component,8
ENG244881-ENG286262-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-padding,No Response From Subnet Component,8
ENG244881-ENG286271-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286272-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Start_12_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286273-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286274-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-sca_Time_Diff_Stop_12_Range_[1],No Response From Subnet Component,8
ENG244881-ENG289612-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_High,No Response From Subnet Component,8
ENG244881-ENG289613-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-slBuffer_Proba_Threshold_Low,No Response From Subnet Component,8
ENG244881-ENG286278-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_1_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286279-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286280-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio_2_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286281-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Height_Ratio1_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286282-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286283-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssa_Delta_Rise_Time_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286284-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[0],No Response From Subnet Component,8
ENG244881-ENG286285-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[1],No Response From Subnet Component,8
ENG244881-ENG286286-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[10],No Response From Subnet Component,8
ENG244881-ENG286287-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[11],No Response From Subnet Component,8
ENG244881-ENG286288-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[12],No Response From Subnet Component,8
ENG244881-ENG286289-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[13],No Response From Subnet Component,8
ENG244881-ENG286290-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[14],No Response From Subnet Component,8
ENG244881-ENG286291-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[15],No Response From Subnet Component,8
ENG244881-ENG286292-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[16],No Response From Subnet Component,8
ENG244881-ENG286293-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[17],No Response From Subnet Component,8
ENG244881-ENG286294-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[18],No Response From Subnet Component,8
ENG244881-ENG286295-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[19],No Response From Subnet Component,8
ENG244881-ENG286296-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[2],No Response From Subnet Component,8
ENG244881-ENG286297-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[20],No Response From Subnet Component,8
ENG244881-ENG286298-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[21],No Response From Subnet Component,8
ENG244881-ENG286299-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[22],No Response From Subnet Component,8
ENG244881-ENG286300-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[23],No Response From Subnet Component,8
ENG244881-ENG286301-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[24],No Response From Subnet Component,8
ENG244881-ENG286302-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[25],No Response From Subnet Component,8
ENG244881-ENG286303-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[26],No Response From Subnet Component,8
ENG244881-ENG286304-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[27],No Response From Subnet Component,8
ENG244881-ENG286305-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[28],No Response From Subnet Component,8
ENG244881-ENG286306-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[29],No Response From Subnet Component,8
ENG244881-ENG286307-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[3],No Response From Subnet Component,8
ENG244881-ENG286308-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[30],No Response From Subnet Component,8
ENG244881-ENG286309-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[31],No Response From Subnet Component,8
ENG244881-ENG286310-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[32],No Response From Subnet Component,8
ENG244881-ENG286311-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[33],No Response From Subnet Component,8
ENG244881-ENG286312-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[34],No Response From Subnet Component,8
ENG244881-ENG286313-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[35],No Response From Subnet Component,8
ENG244881-ENG286314-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[36],No Response From Subnet Component,8
ENG244881-ENG286315-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[37],No Response From Subnet Component,8
ENG244881-ENG286316-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[38],No Response From Subnet Component,8
ENG244881-ENG286317-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[39],No Response From Subnet Component,8
ENG244881-ENG286318-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[4],No Response From Subnet Component,8
ENG244881-ENG286319-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[40],No Response From Subnet Component,8
ENG244881-ENG286320-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[41],No Response From Subnet Component,8
ENG244881-ENG286321-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[42],No Response From Subnet Component,8
ENG244881-ENG286322-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[43],No Response From Subnet Component,8
ENG244881-ENG286323-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[44],No Response From Subnet Component,8
ENG244881-ENG286324-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[45],No Response From Subnet Component,8
ENG244881-ENG286325-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[46],No Response From Subnet Component,8
ENG244881-ENG286326-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[47],No Response From Subnet Component,8
ENG244881-ENG286327-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[48],No Response From Subnet Component,8
ENG244881-ENG286328-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[49],No Response From Subnet Component,8
ENG244881-ENG286329-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[5],No Response From Subnet Component,8
ENG244881-ENG286330-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[50],No Response From Subnet Component,8
ENG244881-ENG286331-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[51],No Response From Subnet Component,8
ENG244881-ENG286332-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[52],No Response From Subnet Component,8
ENG244881-ENG286333-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[53],No Response From Subnet Component,8
ENG244881-ENG286334-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[54],No Response From Subnet Component,8
ENG244881-ENG286335-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[55],No Response From Subnet Component,8
ENG244881-ENG286336-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[56],No Response From Subnet Component,8
ENG244881-ENG286337-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[57],No Response From Subnet Component,8
ENG244881-ENG286338-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[58],No Response From Subnet Component,8
ENG244881-ENG286339-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[59],No Response From Subnet Component,8
ENG244881-ENG286340-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[6],No Response From Subnet Component,8
ENG244881-ENG286341-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[60],No Response From Subnet Component,8
ENG244881-ENG286342-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[61],No Response From Subnet Component,8
ENG244881-ENG286343-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[62],No Response From Subnet Component,8
ENG244881-ENG286344-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[63],No Response From Subnet Component,8
ENG244881-ENG286345-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[64],No Response From Subnet Component,8
ENG244881-ENG286346-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[65],No Response From Subnet Component,8
ENG244881-ENG286347-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[7],No Response From Subnet Component,8
ENG244881-ENG286348-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[8],No Response From Subnet Component,8
ENG244881-ENG286349-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ssaPoly_Coeff[9],No Response From Subnet Component,8
ENG244881-ENG289614-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Retry_Timeout,No Response From Subnet Component,8
ENG244881-ENG289615-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-stAlgoParams.ucActivation_Sent_Time,No Response From Subnet Component,8
ENG244881-ENG286353-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Algo_Time_Out,No Response From Subnet Component,8
ENG244881-ENG286354-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_1,No Response From Subnet Component,8
ENG244881-ENG289616-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_param_2,No Response From Subnet Component,8
ENG244881-ENG286355-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_1,No Response From Subnet Component,8
ENG244881-ENG286356-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_2,No Response From Subnet Component,8
ENG244881-ENG286357-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_3,No Response From Subnet Component,8
ENG244881-ENG286358-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Data_set_version_4,No Response From Subnet Component,8
ENG244881-ENG286359-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Fahrzeugtyp,No Response From Subnet Component,8
ENG244881-ENG286360-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uc_Padding,No Response From Subnet Component,8
ENG244881-ENG286361-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[0],No Response From Subnet Component,8
ENG244881-ENG286362-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[01],No Response From Subnet Component,8
ENG244881-ENG286363-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[2],No Response From Subnet Component,8
ENG244881-ENG286364-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[3],No Response From Subnet Component,8
ENG244881-ENG286365-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[4],No Response From Subnet Component,8
ENG244881-ENG286366-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[5],No Response From Subnet Component,8
ENG244881-ENG286367-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[6],No Response From Subnet Component,8
ENG244881-ENG286368-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[7],No Response From Subnet Component,8
ENG244881-ENG286369-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[8],No Response From Subnet Component,8
ENG244881-ENG286370-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Feat_Selection_[9],No Response From Subnet Component,8
ENG244881-ENG286371-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286372-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Max_Height_12_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286373-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286374-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_1_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286375-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_[0],No Response From Subnet Component,8
ENG244881-ENG286376-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-uca_Time_Diff_Ratio_2_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286377-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ucPoly_FeatureNumber,No Response From Subnet Component,8
ENG244881-ENG286378-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-ul_CRC,No Response From Subnet Component,8
ENG244881-ENG286380-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_0,No Response From Subnet Component,8
ENG244881-ENG286381-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-us_CRC_1,No Response From Subnet Component,8
ENG244881-ENG286382-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa Time_Diff_Range_[1],No Response From Subnet Component,8
ENG244881-ENG286383-Rear_lid_power_opening_control_unit_data_set_upload_iee_supplier-usa_Time_Diff_Range_[0],No Response From Subnet Component,8
ENG263432-ENG142229-Regensensorik_Verbauund_ABT_Steuerung-HMI_Wiper_Comfort_Rain_Sensor_OFF,active ,3
ENG263432-ENG141956-Regensensorik_Verbauund_ABT_Steuerung-Humidity sensor,not installed ,3
ENG263432-ENG253444-Regensensorik_Verbauund_ABT_Steuerung-Light sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG253437-Regensensorik_Verbauund_ABT_Steuerung-rain sensor,LIN_REGEN_LICHT_SENSOR ,3
ENG263432-ENG124476-Regensensorik_Verbauund_ABT_Steuerung-Sunlight photo sensor,not installed ,3
ENG125614-Reset_Blower_1_Backrest_Left,No Response From Subnet Component,3
ENG125615-Reset_Blower_1_Backrest_Right,No Response From Subnet Component,3
ENG125613-Reset_Blower_1_Cushion_Left,No Response From Subnet Component,3
ENG125616-Reset_Blower_1_Cushion_Right,No Response From Subnet Component,3
ENG264033-ENG264176-RLFS_RLS Codierung (KII05)-Filterleerung bei Poti-Verstellung,On ,3
ENG264033-ENG264051-RLFS_RLS Codierung (KII05)-Licht an bei Regen,Master steuert ,3
ENG264033-ENG264182-RLFS_RLS Codierung (KII05)-Licht an ber Geschwindigkeit,Master steuert ,3
ENG264033-ENG264183-RLFS_RLS Codierung (KII05)-Lichtschaltschwellen Kalibrierung,0% (Standard) ,3
ENG264033-ENG159332-RLFS_RLS Codierung (KII05)-Parameter set,Parametersatz I ,3
ENG264033-ENG264191-RLFS_RLS Codierung (KII05)-Regenerkennung bei Kl.15 aus,OFF ,3
ENG264033-ENG264193-RLFS_RLS Codierung (KII05)-Regensensorbetrieb,On ,3
ENG264033-ENG264273-RLFS_RLS Codierung (KII05)-Start-Up-Wipe,On ,3
ENG264033-ENG264277-RLFS_RLS Codierung (KII05)-Transmission 550nm,80% Transmission ,3
ENG264033-ENG264278-RLFS_RLS Codierung (KII05)-Transmission 880nm,80% Transmission ,3
ENG264033-ENG264282-RLFS_RLS Codierung (KII05)-Wischeranlagentyp,LIN ,3
ENG179054-ENG179160-RLFS_ZF_TRW-p_n_1st_wipe_threshold,100 %,12
ENG179054-ENG179161-RLFS_ZF_TRW-p_n_highspeed_wipe_threshold,100 %,12
ENG179054-ENG179162-RLFS_ZF_TRW-p_n_interval_wipe_threshold,100 %,12
ENG179054-ENG179163-RLFS_ZF_TRW-p_n_LIN_Filter,3 ,12
ENG179054-ENG179164-RLFS_ZF_TRW-p_n_permanent_wipe_threshold,100 %,12
ENG179054-ENG179165-RLFS_ZF_TRW-p_n_RsEmergencyReducePercent,10 %,12
ENG179054-ENG179166-RLFS_ZF_TRW-p_t_ParkPosition_SpeedReset,1300 ms,12
ENG179054-ENG179167-RLFS_ZF_TRW-p_t_ParkPosition_WipeTimeout,1000 ms,12
ENG179054-ENG263513-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Cycle,2.0 s,12
ENG179054-ENG263511-RLFS_ZF_TRW-p_t_RsEmergencyReduce_Delay,4.0 s,12
ENG179054-ENG179170-RLFS_ZF_TRW-p_t_tunnel_wipe_delay,6 s,12
ENG179054-ENG179171-RLFS_ZF_TRW-p_t_tunnel_wipe_window,15 s,12
ENG179054-ENG179172-RLFS_ZF_TRW-pa_lx_tunnel_light_on,1100 ,12
ENG179054-ENG179173-RLFS_ZF_TRW-pa_n_wisch_max_2,2 ,12
ENG179054-ENG179174-RLFS_ZF_TRW-pa_t_tunnel_delay_decrement,30 s,12
ENG179054-ENG179175-RLFS_ZF_TRW-pa_t_tunnel_delay_max,120 s,12
ENG179054-ENG179176-RLFS_ZF_TRW-Pa_t_tunnel_delay_on,1800 ms,12
ENG179054-ENG179177-RLFS_ZF_TRW-pa_t_tunnel_delay_step,5 s,12
ENG179054-ENG179178-RLFS_ZF_TRW-pa_v_RsActivationSpeed,5 km/h,12
ENG179054-ENG179179-RLFS_ZF_TRW-pa_v_wisch_max_1,20 km/h,12
ENG179054-ENG179180-RLFS_ZF_TRW-pa_v_wisch_max_2,4 km/h,12
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,5
ENG253157-roof_module,installed ,1
ENG253336-MAS10512-Schiebedach_ZV-Sunroof module MD1,not installed ,6
ENG253336-ENG260428-Schiebedach_ZV-dachrollo_2_verbaut,not installed ,6
ENG253336-ENG258762-Schiebedach_ZV-dachrollo_verbaut,not installed ,6
ENG253336-ENG261040-Schiebedach_ZV-Komfortbedienung_reichweitenbegrenzung_verdeck,not active ,6
ENG253336-ENG259091-Schiebedach_ZV-Komfortbedienung_verdecktaste_aktiv,not active ,6
ENG253336-ENG116647-Schiebedach_ZV-SAD Komfort oeffnen,not active ,6
ENG253336-ENG289611-Schiebedach_ZV-SAD Komfort_oeffnungs_modus,Open ,6
ENG253336-ENG149216-Schiebedach_ZV-SAD_Komfort_schliessen,not active ,6
ENG253336-ENG259548-Schiebedach_ZV-SAD_MD3,not active ,6
ENG253336-ENG259227-Schiebedach_ZV-SAD_t_Freigabe_eFH,600 s,6
ENG253336-ENG258522-Schiebedach_ZV-schiebedach_2_verbaut,not installed ,6
ENG253238-ENG258554-Schluesselkonfiguration-Fahrzeugplattform_MEB_aktiv,not activated ,1
ENG253238-ENG258470-Schluesselkonfiguration-Kessy_UWB_Frequenzband_a_aktiv,activated ,1
ENG253238-ENG259650-Schluesselkonfiguration-Kessy_UWB_Frequenzband_b_aktiv,activated ,1
ENG253238-ENG261161-Schluesselkonfiguration-Kessy_UWB_Frequenzband_c_aktiv,activated ,1
ENG253118-IDE02851-Schl sselpositionsnachbildung (SPN)-S-contact shut-off after timeout,Yes ,31
ENG253118-ENG126943-Schl sselpositionsnachbildung (SPN)-Display_duration_emergency_off,3000 ms,31
ENG253118-ENG126944-Schl sselpositionsnachbildung (SPN)-Display_duration_error_mode_2_SPN,10 s,31
ENG253118-ENG277093-Schl sselpositionsnachbildung (SPN)-Evaluation_Klemmenkoordinator,Yes ,31
ENG253118-ENG126945-Schl sselpositionsnachbildung (SPN)-min_time_for_Terminal_50_request,300 ms,31
ENG253118-ENG129003-Schl sselpositionsnachbildung (SPN)-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,31
ENG253118-ENG253448-Schl sselpositionsnachbildung (SPN)-Number_of_ZAT_activations_to_fault,10 ,31
ENG253118-ENG126939-Schl sselpositionsnachbildung (SPN)-rpm_threshold_engine_runnning,100 /min,31
ENG253118-ENG126946-Schl sselpositionsnachbildung (SPN)-Terminal_S_Timeout,30 min,31
ENG253118-ENG258251-Schl sselpositionsnachbildung (SPN)-time_to_ignore_clampcoordinator_trigger,1000 ms,31
ENG253118-ENG126947-Schl sselpositionsnachbildung (SPN)-time_to_ignore_ignition_trigger,35 s,31
ENG253264-Seat_cushion_fan,not installed ,1
ENG253224-ENG258215-Seat_pneumatics-Bcm_response_timer,350 ms,8
ENG253224-ENG259532-Seat_pneumatics-Installation_seat_pneumatics,not installed ,8
ENG253224-ENG260752-Seat_pneumatics-Installation_side_support,not installed ,8
ENG253224-ENG259164-Seat_pneumatics-Massage_intensity_level,3 ,8
ENG253224-ENG259581-Seat_pneumatics-Massage_programs,3 ,8
ENG253224-ENG259920-Seat_pneumatics-occupancy_passenger_side,5 ,8
ENG253224-ENG259260-Seat_pneumatics-Popup_knockout_time,25 min,8
ENG253224-ENG259408-Seat_pneumatics-Seat_pneumatics_adjustment_passenger_side,not installed ,8
ENG253224-ENG259024-Seat_pneumatics-Velocity_limit,10 km/h,8
ENG253224-ENG260841-Seat_pneumatics-Velocity_min,10 km/h,8
ENG253090-ENG261034-Seat_pneumatics_massage_program_allocation-massage_program_allocation_01,1 ,6
ENG253090-ENG258845-Seat_pneumatics_massage_program_allocation-massage_program_allocation_02,2 ,6
ENG253090-ENG258718-Seat_pneumatics_massage_program_allocation-massage_program_allocation_03,5 ,6
ENG253090-ENG260661-Seat_pneumatics_massage_program_allocation-massage_program_allocation_04,1 ,6
ENG253090-ENG258113-Seat_pneumatics_massage_program_allocation-massage_program_allocation_05,2 ,6
ENG253090-ENG259726-Seat_pneumatics_massage_program_allocation-massage_program_allocation_06,5 ,6
ENG253283-ENG258595-Signal_mapping_tsg-verzoegerung_swc_signale,100 ms,4
ENG253283-ENG260734-Signal_mapping_tsg-Zeitbasis_0,50 ms,4
ENG253283-ENG260177-Signal_mapping_tsg-Zeitbasis_1,250 ms,4
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG289599-SMLS_konfig_entw-lrh_taster_haengt_aus,50 ms,48
ENG153742-ENG289600-SMLS_konfig_entw-lrh_taster_haengt_ein,60 s,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG141635-ENG260621-Spiegelverstellung-cp_Komfortbedienung_Spiegel_anklappen,not active ,3
ENG141635-ENG149222-Spiegelverstellung-Menuesteuerung_Funk_Spiegel_anklappen,not active ,3
ENG141635-ENG258306-Spiegelverstellung-Menuesteuerung_Spiegelabsenkung,active ,3
ENG141635-ENG259505-Spiegelverstellung-Menuesteuerung_synchrone_Spiegelverstellung,not active ,3
ENG141635-ENG149218-Spiegelverstellung-Spiegelabsenkung_bei_Rueckwaertsfahrt,active ,3
ENG141635-ENG260424-Spiegelverstellung-Spiegelanklappen_bei_Verriegelung,not active ,3
ENG141635-ENG260252-Spiegelverstellung-Spiegelverstellung_Synchron,not active ,3
ENG253125-ENG260641-SRA-p_sra_bcm_temperaturgrenze,0 C,8
ENG253125-ENG260115-SRA-p_sra_geschwindigkeitsgrenze,0 km/h,8
ENG253125-ENG259607-SRA-p_sra_nach_t_frontwaschendauer,0 ms,8
ENG253125-ENG259677-SRA-p_sra_obere_aussentemperaturgrenze,-100 C,8
ENG253125-ENG261148-SRA-p_sra_untere_aussentemperaturgrenze,-100 C,8
ENG253125-ENG260015-SRA-p_t_sra_ueberlast,0 s,8
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG253353-ENG260527-St rungsmeldungen Licht/Wischwasch-p_Lichtrouter_meldung_ausmaskiert,00 ,15
ENG253353-ENG260368-St rungsmeldungen Licht/Wischwasch-p_t_LDS_defekt_meldung,10 s,15
ENG253353-ENG260726-St rungsmeldungen Licht/Wischwasch-p_t_RLS_Meldung,2000 ms,15
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.04 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.04 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.04 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.08 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.08 s,21
ENG141663-ENG258796-Suchbeleuchtung_allgemein-Eingabemedium Suchbeleuchtung von ALM,not active ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,6.9 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,1.8 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.08 s,21
ENG141663-ENG260116-Suchbeleuchtung_allgemein-Suchbeleuchtung PSO2.0 Teilnehmer,active ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 ,21
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 lx,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 lx,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 lx,22
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 ,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 ,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 ,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 ,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 ,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,3.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,3.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,11.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,40.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,82.0 %,12
ENG153969-ENG115658-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-x0,0.0 ,10
ENG153969-ENG101574-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X1,8.0 ,10
ENG153969-ENG99557-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X2,50.0 ,10
ENG153969-ENG102140-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X3,80.0 ,10
ENG153969-ENG102936-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-X4,100.0 ,10
ENG153969-ENG115659-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-y0,6.0 %,10
ENG153969-ENG99777-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y1,6.0 %,10
ENG153969-ENG100480-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y2,20.0 %,10
ENG153969-ENG100773-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y3,50.0 %,10
ENG153969-ENG100631-Suchbeleuchtung_KL_58xs_Bus_Kennlinie-Y4,100.0 %,10
ENG253155-ENG115658-Suchbeleuchtung_KL_58xs_max-x0,0 lx,8
ENG253155-ENG101574-Suchbeleuchtung_KL_58xs_max-X1,8 lx,8
ENG253155-ENG99557-Suchbeleuchtung_KL_58xs_max-X2,50 lx,8
ENG253155-ENG102140-Suchbeleuchtung_KL_58xs_max-X3,500 lx,8
ENG253155-ENG115659-Suchbeleuchtung_KL_58xs_max-y0,100.0 ,8
ENG253155-ENG99777-Suchbeleuchtung_KL_58xs_max-Y1,100.0 ,8
ENG253155-ENG100480-Suchbeleuchtung_KL_58xs_max-Y2,100.0 ,8
ENG253155-ENG100773-Suchbeleuchtung_KL_58xs_max-Y3,100.0 ,8
ENG253251-ENG115658-Suchbeleuchtung_KL_58xs_min-x0,0 lx,8
ENG253251-ENG101574-Suchbeleuchtung_KL_58xs_min-X1,8 lx,8
ENG253251-ENG99557-Suchbeleuchtung_KL_58xs_min-X2,50 lx,8
ENG253251-ENG102140-Suchbeleuchtung_KL_58xs_min-X3,500 lx,8
ENG253251-ENG115659-Suchbeleuchtung_KL_58xs_min-y0,6.0 ,8
ENG253251-ENG99777-Suchbeleuchtung_KL_58xs_min-Y1,6.0 ,8
ENG253251-ENG100480-Suchbeleuchtung_KL_58xs_min-Y2,100.0 ,8
ENG253251-ENG100773-Suchbeleuchtung_KL_58xs_min-Y3,100.0 ,8
ENG153970-ENG115658-Suchbeleuchtung_KL_58xs_PWM-x0,0.0 ,6
ENG153970-ENG101574-Suchbeleuchtung_KL_58xs_PWM-X1,50.0 ,6
ENG153970-ENG99557-Suchbeleuchtung_KL_58xs_PWM-X2,100.0 ,6
ENG153970-ENG115659-Suchbeleuchtung_KL_58xs_PWM-y0,0.0 %,6
ENG153970-ENG99777-Suchbeleuchtung_KL_58xs_PWM-Y1,50.0 %,6
ENG153970-ENG100480-Suchbeleuchtung_KL_58xs_PWM-Y2,100.0 %,6
ENG153971-ENG115658-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-x0,0.0 ,10
ENG153971-ENG101574-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X1,8.0 ,10
ENG153971-ENG99557-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X2,50.0 ,10
ENG153971-ENG102140-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X3,80.0 ,10
ENG153971-ENG102936-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-X4,100.0 ,10
ENG153971-ENG115659-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-y0,6.0 %,10
ENG153971-ENG99777-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y1,6.0 %,10
ENG153971-ENG100480-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y2,20.0 %,10
ENG153971-ENG100773-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y3,50.0 %,10
ENG153971-ENG100631-Suchbeleuchtung_KL_58xt_Bus_Kennlinie-Y4,100.0 %,10
ENG253314-ENG115658-Suchbeleuchtung_KL_58xt_min-x0,0 lx,8
ENG253314-ENG101574-Suchbeleuchtung_KL_58xt_min-X1,8 lx,8
ENG253314-ENG99557-Suchbeleuchtung_KL_58xt_min-X2,50 lx,8
ENG253314-ENG102140-Suchbeleuchtung_KL_58xt_min-X3,500 lx,8
ENG253314-ENG115659-Suchbeleuchtung_KL_58xt_min-y0,6.0 ,8
ENG253314-ENG99777-Suchbeleuchtung_KL_58xt_min-Y1,6.0 ,8
ENG253314-ENG100480-Suchbeleuchtung_KL_58xt_min-Y2,100.0 ,8
ENG253314-ENG100773-Suchbeleuchtung_KL_58xt_min-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 ,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 ,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 ,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,24
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,24
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,24
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,24
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,800 lx,24
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1021 lx,24
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,24
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,160 ,24
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,300 ,24
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,380 ,24
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,440 ,24
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,24
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,100 ,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,150 ,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,200 ,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,255 ,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,0.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 %,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 %,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 %,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 %,10
ENG249751-Two_keys,active ,3
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG252991-Vehicle configuration,activated ,1
ENG253245-ENG261297-verbauliste_subcan-Digitale Dachantenne,not installed ,4
ENG253245-ENG260575-verbauliste_subcan-nfc_miko,not installed ,4
ENG253245-ENG260904-verbauliste_subcan-nfc_tgs,not installed ,4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,6
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,6
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,6
ENG141634-ENG116655-Verdecksteuergeraet-Kessy Komfortbedienung Reichweitenbegrenzung,active ,6
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,6
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,6
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlie en,active ,6
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,6
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,6
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,6
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,6
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,6
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlie en via Funkfernbedienung,active ,6
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlie en via Kessy,active ,6
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlie en via Schlie zylinder,active ,6
ENG253327-ENG277083-Verlassenswarnung und Standlichtnachlauf-Ausgabedauer Wegrollwarnung,10 s,8
ENG253327-ENG261189-Verlassenswarnung und Standlichtnachlauf-Ausgabeverhalten Verlassenswarnung,VLW mit VLK2.2 Kriterien ,8
ENG253327-ENG261016-Verlassenswarnung und Standlichtnachlauf-Ausgabeverz gerung der Verlassenswarnung,1.4 s,8
ENG253327-ENG277084-Verlassenswarnung und Standlichtnachlauf-Ausgabeverz gerung der Wegrollwarnung,1.0 s,8
ENG253327-ENG261326-Verlassenswarnung und Standlichtnachlauf-Entprellung Degradierte Verlassenswarnung,1.6 s,8
ENG253327-ENG259356-Verlassenswarnung und Standlichtnachlauf-Entprellung Verlassenswarnung,5 min,8
ENG253327-ENG258196-Verlassenswarnung und Standlichtnachlauf-Fahrzeuggeschwindigkeit zur Stillstandserkennung,3 km/h,8
ENG253327-ENG116720-Verlassenswarnung und Standlichtnachlauf-Standlicht-Nachlaufzeit,30 min,8
ENG253327-ENG277124-Verlassenswarnung und Standlichtnachlauf-Verf gbarkeit Standlichtnachlauf,active ,8
ENG253327-ENG277125-Verlassenswarnung und Standlichtnachlauf-Verf gbarkeit Verlassenswarnung,equippt ,8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 00 00 ,28
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 00 00 ,28
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 00 00 ,28
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 00 00 ,28
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,28
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,28
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,28
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,28
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,28
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,28
ENG159625-ENG142259-Virtual pedal-Kick_and_close,not installed ,8
ENG159625-ENG286258-Virtual pedal-Kick_and_close_HBFS,not installed ,8
ENG159625-ENG286259-Virtual pedal-Kick_and_close_HFS,not installed ,8
ENG159625-ENG115869-Virtual pedal-Virtuelles_Pedal,not active ,8
ENG159625-ENG259761-Virtual pedal-Virtuelles_Pedal_HMI_Auswahl,not active ,8
ENG159625-ENG126611-Virtual pedal-virtuelles_pedal_HMI_einstellbar,not active ,8
ENG253214-ENG261193-Virtuelles_Pedal_Global-Bremslichtquittierung,not active ,4
ENG253214-ENG261115-Virtuelles_Pedal_Global-Bremslichtquittierung bei offenem Heckdeckel bzw. -klappe,not active ,4
ENG253214-ENG259151-Virtuelles_Pedal_Global-Quittierungslicht_Max,0 ms,4
ENG253214-ENG273673-Virtuelles_Pedal_Global-Sperrzeit_Bewertung_Spotlight,0 ms,4
ENG253214-ENG286384-Virtuelles_Pedal_Global-Virtuelles_Pedal_HBFS_Verbau,not installed ,4
ENG253214-ENG286385-Virtuelles_Pedal_Global-Virtuelles_Pedal_HFS_Verbau,not installed ,4
ENG253214-ENG142257-Virtuelles_Pedal_Global-Virtuelles_Pedal_Verbau,not installed ,4
ENG154424-IDE05534-Waschen-Headlamp washer system,not installed ,8
ENG154424-ENG154706-Waschen-Mindestwaschzeit_Frontwischer,0 ms,8
ENG154424-ENG249933-Waschen-RVC_Speed_Hysteresis,5 km/h,8
ENG154424-ENG249934-Waschen-RVC_Speed_max,50 km/h,8
ENG154424-ENG260022-Waschen-RVC_Waschen,not installed ,8
ENG154424-ENG249936-Waschen-RVC_Waschen_HMI,not active ,8
ENG154424-ENG260162-Waschen-Time_RVC_cleaning_Pumpe_active_BCM,1.5 s,8
ENG154424-ENG281090-Waschen-Transportmodus_SRA,not active ,8
ENG154424-ENG258116-Waschen-Waschen_ohne_KL15,not active ,8
ENG154424-ENG260669-Waschen-Wiederstart_Restfunktionen,not active ,8
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG261175-Waschen_Parameter-pa_t_wasch_min_heck,1200 ms,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG253306-ENG259934-Wascher_pumpe-p_n_Spielschutz_Wascherpumpen,10 ,4
ENG253306-ENG258230-Wascher_pumpe-p_t_Delay_Frontwaschen,0 ms,4
ENG253306-ENG260892-Wascher_pumpe-p_t_DWP_Blockiererkennung,100 ms,4
ENG253306-ENG259530-Wascher_pumpe-p_t_Wascherpumpe_max,10 s,4
ENG253279-ENG126852-Wisch_geschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG253279-ENG126853-Wisch_geschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG253279-ENG116699-Wisch_geschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,00 00 00 00 ,4
ENG253287-ENG261269-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_defined_rpm,500.00 ,11
ENG253287-ENG258373-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOSignal_Timer1,3000 ms,11
ENG253287-ENG258259-ZAT_Beleuchtung_Seat-Suchbeleuchtung_ZAT_MOsignal_Timer2,3000 ms,11
ENG281049-ENG263583-Z ndungswarnung und Antrieb-Aktiv-Warnung-Ausgabe MoLaWa_AAW,active ,8
ENG281049-ENG263581-Z ndungswarnung und Antrieb-Aktiv-Warnung-Entprellung_MoLaWa,1.5 ,8
ENG281049-ENG263504-Z ndungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswechsel Belegt zu nicht Belegt,0.8 s,8
ENG281049-ENG281097-Z ndungswarnung und Antrieb-Aktiv-Warnung-Entprellzeit Statuswecsel nicht Belegt zu Belegt,0.0 s,8
ENG281049-ENG263576-Z ndungswarnung und Antrieb-Aktiv-Warnung-Freigabeentprellung Abschaltung nach EM,60 s,8
ENG281049-ENG263531-Z ndungswarnung und Antrieb-Aktiv-Warnung-Unterdr ckung der Z ndungswarnung,active ,8
ENG141651-ENG258596-ZV allgemein-abgesichertes_Safen_aktiv,not active ,6
ENG141651-ENG260901-ZV allgemein-Bedienstellen_tankklappenentriegelung,via_ZV ,6
ENG141651-ENG173067-ZV allgemein-central_locking_system_deadlock_mechanism,safe_function_not_active ,6
ENG141651-ENG259465-ZV allgemein-Funk_bei_Kl15_ein,active ,6
ENG141651-ENG260878-ZV allgemein-kein_Safe_bei_IRUE_Abwahl,not active ,6
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,6
ENG141651-ENG115755-ZV allgemein-Notschlie funktion,active ,6
ENG141651-ENG261270-ZV allgemein-rollsicherung_ZV_plausibilisierung,not active ,6
ENG141651-ENG260049-ZV allgemein-Rueckmeldung_TKL,not active ,6
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,6
ENG141651-ENG258274-ZV allgemein-ZV_Verriegelung_ueber_SZ_bei_offener_FT_zulassen,not active ,6
ENG141653-ENG258843-ZV Heck-Direktauswurf_heckdeckel,not active ,6
ENG141653-ENG258544-ZV Heck-eingeschr nkte_Freigabe_HD_Innentaste,active ,6
ENG141653-ENG260874-ZV Heck-Elektrische_Laderaumabdeckung_Aktiviert,not installed ,6
ENG141653-ENG259200-ZV Heck-Elektrische_Laderaumabdeckung_verbaut,not installed ,6
ENG141653-ENG263593-ZV Heck-HD_Innentaster_bei_ext_verriegelt,not active ,6
ENG141653-ENG259391-ZV Heck-HDF_IT_direkt,not installed ,6
ENG141653-ENG260877-ZV Heck-Heck_autolock,active ,6
ENG141653-ENG259349-ZV Heck-Heck_ohne_softtouch,not active ,6
ENG141653-ENG260581-ZV Heck-Heckschloss_mit_VR,Yes ,6
ENG141653-ENG260712-ZV Heck-Heckschloss_rastengesteuert,contact_control ,6
ENG141653-ENG259467-ZV Heck-Heckschloss_Typ,1 or 2 notch rear actuator ,6
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,6
ENG141653-ENG248302-ZV Heck-unlocking_trunk_lid_via_double_actuation,not active ,6
ENG141653-ENG140934-ZV Heck-valet_parking,not active ,6
ENG141653-ENG258713-ZV Heck-ZV_entriegelt_heckdeckel,active ,6
ENG253049-ENG260834-ZV Komfort_Fensterheber-Ausstiegspanel_Automatiklauf,not active ,8
ENG253049-ENG261010-ZV Komfort_Fensterheber-BAP_komfortschlie en_brasilien,not active ,8
ENG253049-ENG259807-ZV Komfort_Fensterheber-el_fh_hinten,installed ,8
ENG253049-ENG116663-ZV Komfort_Fensterheber-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG253049-ENG259968-ZV Komfort_Fensterheber-Fensterheber_freigabnachlauf_busruhe,active ,8
ENG253049-ENG258141-ZV Komfort_Fensterheber-Freigabenachlauf_abbruch_bei_tueroeffnen,active ,8
ENG253049-ENG260611-ZV Komfort_Fensterheber-KL_15_aus_fh_freigabenachlauf,active ,8
ENG253049-ENG159639-ZV Komfort_Fensterheber-Komfort_oeffnen,active ,8
ENG253049-ENG273538-ZV Komfort_Fensterheber-Komfort_schlie en,active ,8
ENG253049-ENG258991-ZV Komfort_Fensterheber-Komfortbedienung_ffb_aktiv,active ,8
ENG253049-ENG258982-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_funk,active ,8
ENG253049-ENG260329-ZV Komfort_Fensterheber-Komfortbedienung_fh_oeffnen_ueber_sz,not active ,8
ENG253049-ENG259463-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_fh_taster,not active ,8
ENG253049-ENG259865-ZV Komfort_Fensterheber-Komfortbedienung_fh_schliessen_ueber_funk,not active ,8
ENG253049-ENG149198-ZV Komfort_Fensterheber-Komfortbedienung_global,active ,8
ENG253049-ENG260481-ZV Komfort_Fensterheber-komfortbedienung_global_hmi,adjustable ,8
ENG253049-ENG259275-ZV Komfort_Fensterheber-Komfortfunktion_im_Transportmodus,not active ,8
ENG253049-ENG116642-ZV Komfort_Fensterheber-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG253049-ENG155244-ZV Komfort_Fensterheber-Komfortschliessen_Brasilien,not active ,8
ENG263451-ENG252093-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abbruchblinken_Heck,not active ,7
ENG263451-ENG248659-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_frei,120 cm,7
ENG263451-ENG248660-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Abstand_Umfeld_Nahbereich,20 cm,7
ENG263451-ENG248661-ZV NFZ - Elektronische Rueckwandklappe-eRWK_bei_eingeschraenkter_Oeffnungsweite,not active ,7
ENG263451-ENG248662-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Heck_sperren_bei_Hindernis,not active ,7
ENG263451-ENG263534-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Oeffnungsblinken_Heckauswurf,not active ,7
ENG263451-ENG248664-ZV NFZ - Elektronische Rueckwandklappe-eRWK_ohne_FFB_HDF,not active ,7
ENG263451-ENG252079-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Pruefung_Umfelderkennung,1.6 s,7
ENG263451-ENG252068-ZV NFZ - Elektronische Rueckwandklappe-eRWK_Start_Umfelderkennung,2.0 s,7
ENG263451-ENG281092-ZV NFZ - Elektronische Rueckwandklappe-pa_eRWK_KST_Sonderzustand_Anf,not active ,7
ENG263491-ENG263568-ZV NFZ - Tueren HBFS-Schiebetuer HBFS,none ,2
ENG263491-ENG258359-ZV NFZ - Tueren HBFS-Schlosstyp HBFS,No ,2
ENG263491-ENG263538-ZV NFZ - Tueren HBFS-Tuerkontaktmodul HBFS,No ,2
ENG263438-ENG263586-ZV NFZ - Tueren HFS-Schiebetuer HFS,none ,2
ENG263438-ENG258315-ZV NFZ - Tueren HFS-Schlosstyp HFS,No ,2
ENG263438-ENG263572-ZV NFZ - Tueren HFS-Tuerkontaktmodul HFS,No ,2
ENG253123-ENG259042-ZV Nutzfahrzeuge-SBT_Schloss_direkt,not installed ,5
ENG253123-ENG142041-ZV Nutzfahrzeuge-Schiebetueren_Crafter,not installed ,5
ENG253123-ENG260914-ZV Nutzfahrzeuge-TKM_BFS_verbaut,not installed ,5
ENG253123-ENG258445-ZV Nutzfahrzeuge-TKM_FS_verbaut,not installed ,5
ENG252999-ENG258724-ZV Quittierungen-Komfort_quittung,active ,6
ENG252999-ENG260606-ZV Quittierungen-Quittierton_beim_zweiten_ZV_AUF_Befehl,not active ,6
ENG252999-ENG258550-ZV Quittierungen-Quittierton_beim_zweiten_ZV_ZU_Befehl,active ,6
ENG252999-ENG260511-ZV Quittierungen-Quittierton_global,active ,6
ENG252999-ENG258336-ZV Quittierungen-Quittierungston_bei_entriegeln,not active ,6
ENG252999-ENG263543-ZV Quittierungen-Quittungs_blinken_bei_verriegeln,DELAY ,6
ENG252999-ENG263595-ZV Quittierungen-Quittungs_ton_bei_verriegeln,active ,6
ENG252999-ENG259470-ZV Quittierungen-Quittungston_hmi_einstellbar,active ,6
ENG252999-ENG260257-ZV Quittierungen-Quittungston_ueber_hupe,active ,6
ENG141652-ENG258598-ZV T rkonfiguration-Fzg_mit_Vier_Tueren,Yes ,2
ENG141652-ENG260173-ZV T rkonfiguration-Schloesser_direkt_gesteuert,vordere via CAN angeschlossen: hinten diskre ,2
ENG141652-ENG142000-ZV T rkonfiguration-Schlosstyp_NAR,Yes ,2
ENG141652-ENG258913-ZV T rkonfiguration-ZV Schlosstyp,Einmotorenschloss ohne Safe ,2
ENG253276-ENG173074-ZV_Autolock-automatic_unlock_nar,active ,2
ENG253276-ENG116621-ZV_Autolock-automatisches Entriegeln,active ,2
ENG253276-ENG115756-ZV_Autolock-automatisches Verriegeln bei Geschwindigkeit,active ,2
ENG253276-ENG260929-ZV_Autolock-ZV_autolock_autounlock_hmi,not active ,2
ENG253027-ENG173641-ZV_Crash-central_locking_system_emergency_assist,active ,2
ENG253027-ENG259575-ZV_Crash-Verzoegerung_ZV_Entriegelung_bei_Seitencrash,active ,2
ENG263484-ENG263546-ZV_HW_Router-PIN_A11,T r HL verriegeln oder Laderaumabdeckung links ,5
ENG263484-ENG263569-ZV_HW_Router-PIN_A31,LuT zentral oder Tankklappenr ckmeldung ,5
ENG263484-ENG263532-ZV_HW_Router-PIN_A32,Softtouch Heckdeckel ,5
ENG263484-ENG263567-ZV_HW_Router-PIN_A33,T r HR Verriegelung/Safe oder Verdeck zu ,5
ENG263484-ENG263596-ZV_HW_Router-PIN_A35,T r HL Verriegelung/Safe ,5
ENG263484-ENG263575-ZV_HW_Router-PIN_A48,T r HR TK-Signal ,5
ENG263484-ENG263528-ZV_HW_Router-PIN_A49,Taste Heckdeckelentriegelung ,5
ENG263484-ENG263547-ZV_HW_Router-PIN_A50,T r HL TK-Signal ,5
ENG263484-ENG263598-ZV_HW_Router-PIN_A51,IRUE/NGS aus oder Heckscheibenbruch ,5
ENG263484-ENG263545-ZV_HW_Router-PIN_A7,T r HR verriegeln oder Laderaumabdeckung rechts ,5
ENG263484-ENG263590-ZV_HW_Router-PIN_C21,Funktions-LED Taste3 ,5
ENG263484-ENG263523-ZV_HW_Router-PIN_C22,Funktions-LED Taste4 ,5
ENG263484-ENG263565-ZV_HW_Router-PIN_C34,Cockpit-Taste 3 ,5
ENG263484-ENG263571-ZV_HW_Router-PIN_C59,Cockpit-Taste 4 ,5
ENG263427-ENG252063-zv_router_global-Deaktivierung_LS_mit_ext_Ver_Entriegelung,not active ,5
ENG263427-ENG263506-zv_router_global-Elektrischer_SBT_Feststeller_verbaut,not installed ,5
ENG263427-ENG263563-zv_router_global-Elektronische_Kindersicherung_eKiSi,No ,5
ENG263427-ENG263551-zv_router_global-FFB_Schiebetuer_entriegelt,No ,5
ENG263427-ENG248688-zv_router_global-Freischaltung_der_Kisi_Auswurffunktion,not active ,5
ENG263427-ENG248689-zv_router_global-Freischaltung_KiSi_Taster_bei_extern_verriegeltem_Fahrzeug,not active ,5
ENG263427-ENG248698-zv_router_global-HD_Innentaster_im_Heck,not installed ,5
ENG263427-ENG263588-zv_router_global-Laderaumschliessung_Taster_togglen,not active ,5
ENG263427-ENG263582-zv_router_global-Laderaumtaster_verbaut,not installed ,5
ENG263427-ENG248768-zv_router_global-NFZ_Schliessung,not active ,5
ENG263427-ENG263555-zv_router_global-Schiebetuer_Auswurffunkion_bei_intern_verriegelt,not active ,5
ENG263427-ENG259542-zv_router_global-Schiebetuer_verriegeln_bei_offenem_tank,not active ,5
ENG263427-ENG263553-zv_router_global-Schiebetuertaste_Armaturentafel_bei extern_verriegelt,not active ,5
ENG263427-ENG133390-zv_router_global-Wiederverriegelung_Laderaum,not installed ,5
Elapsed Time: 06:49
;SW:5WA-937-086-AE HW:5WA-937-086-L --- 09: Cent. Elect.
;Component:BCM37w_M028 0175, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_VW38.rod
;Tuesday,01,September,2026,18:57:53:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 147663D49EF722EA538-8040 SFD [x]
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00301,Distance,30913, km
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE00973,Outside temperature,36.0, C
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary protection control module 1 VL,not active,
IDE01992-SFT33055,Installation list: current installations-Burglary protection control module 2 VR,not active,
IDE01992-SFT33056,Installation list: current installations-Burglary protection control module 3 HL,not active,
IDE01992-SFT33057,Installation list: current installations-Burglary protection control module 4 HR,not active,
IDE01992-SFT33058,Installation list: current installations-Burglary protection control module 5 vehicle interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary protection control module 1 VL,not active,
IDE01996-SFT33055,Installation list: specified installations-Burglary protection control module 2 VR,not active,
IDE01996-SFT33056,Installation list: specified installations-Burglary protection control module 3 HL,not active,
IDE01996-SFT33057,Installation list: specified installations-Burglary protection control module 4 HR,not active,
IDE01996-SFT33058,Installation list: specified installations-Burglary protection control module 5 vehicle interior,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Selector lever in position P,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Ready For Sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary protection control module 1 VL,Ready For Sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary protection control module 2 VR,Ready For Sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary protection control module 3 HL,Ready For Sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary protection control module 4 HR,Ready For Sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary protection control module 5 vehicle interior,Ready For Sleep,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,0,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,36.0, C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.7, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,OFF,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Comfort data bus,
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,11.5, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,10100,
IDE05045-MAS05878,Front wiper module-level,not coded / not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded / not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,not coded / not installed,
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,not coded / not installed,
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,not coded / not installed,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,not coded / not installed,
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE08211-MAS03129,History data control module reset-Reset counter,3,
IDE08211,History data control module reset,|last cause of reset,Year,Month,Day,Hours,Minutes|Analysis 1,2026,5,13,0,0|Analysis 1,2026,5,13,16,31|Analysis 1,2026,5,13,0,0|,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,8B 80 C3 B0,
IDE08240,Transponder ID Key 2,48 1A C3 B0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,06 27 55 CE,
IDE08343,Immobilizer Challenge,9A CD D8 51,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,1, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,137, mA
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,not coded / not installed,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,not coded / not installed,
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,6,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,6,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,29 FC C4 EB,
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 2,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded / not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded / not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded / not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded / not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13845,Production mode status,not active,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device not installed,
IDE13956-MAS01493,Key position replication: input signals-Engine is running,not active,
IDE13956-MAS02248,Key position replication: input signals-Signal status,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,0.0,
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 76 0A 29 8C 60 13 72,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not recognised,
IDE14958-SFT00008,Recognized actual fitting list: adapt-HVAC electronics,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not recognised,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,not recognised,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not recognised,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not recognised,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not recognised,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not recognised,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not recognised,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not recognised,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for driver assistance systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not recognised,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not recognised,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary protection control module 1 VL,not recognised,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary protection control module 2 VR,not recognised,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary protection control module 3 HL,not recognised,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary protection control module 4 HR,not recognised,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary protection control module 5 vehicle interior,not recognised,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Left rear door control module,detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Right rear door control module,detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not recognised,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not recognised,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 41,
IDE14993,Software composition list identification data,|Software Composition ID,System designation,Supplier ID,VW/Audi part number,Primary version number,Secondary version number,Patch version number|30 30 30 30 30 30 33 43,ZKA,30 36,F1870000000,0000,0001,0000|30 30 30 30 30 30 33 43,ZvAct,30 36,F1870000000,0000,0001,0001|00 00 00 00 00 00 00 71,HeckWischWash,00 08,V04007001BJ,0020,0009,0040|30 30 30 30 30 30 36 36,SounderAct,30 36,F1870000000,0000,0001,0000|00 00 00 00 00 00 00 59,LWR ,00 20,00000000000,0006,0001,0000|00 00 00 00 00 00 00 3E,Kessy ,00 0D,V04007001J ,000P,0720,0000|00 00 00 00 00 00 00 00,0000000000000,00 00,00000000000,0000,0000,0000|00 00 00 00 00 00 00 51,IuAModul ,00 08,V04007001S ,0020,0009,0035|00 00 00 00 00 00 00 52,EventGen ,00 70,V04007001Q ,0008,0007,0000|00 00 00 00 00 00 00 6A,Azk ,00 0E,V04007001SB,0004,0000,0000|00 00 00 00 00 02 00 A3,AmbiAct ,00 08,-----------,0020,0009,0000|00 00 00 00 00 00 00 6C,Cockpittaster,00 08,V04007001BD,0020,0009,0015|00 00 00 00 00 00 00 60,0000000000000,00 07,V04007001L ,2230,0004,0000|00 00 00 00 00 00 00 60,Di58 Sensor ,00 08,V04007001A ,0020,0009,0000|00 00 00 00 00 00 00 55,Dimmung ,00 08,V04007001T ,0020,0009,0000|00 00 00 00 00 00 00 6D,DiETasten ,00 08,V04007001BE,0020,0009,0000|00 00 00 00 00 02 00 A4,DwpHewiAct ,00 08,-----------,0020,0009,0025|00 00 00 00 00 00 00 52,Output ,00 70,V04007001Q ,0008,0007,0000|00 00 00 00 00 00 00 52,ExAmb ,00 70,V04007001Q ,0008,0007,0000|00 00 00 00 00 00 00 53, FBS_BREMSL,00 06, V04007001P,,,|30 30 30 30 30 30 36 46,FdH,30 36,V04007001BG,0001,0002,0001|00 00 00 00 00 02 00 A1,FwAct ,00 08,-----------,0020,0009,0010|00 00 00 00 00 00 00 00,xOb ,30 30,2000090025,,qH,eckW|69 73 63 68 20 20 20 20,-----------,30 30,2000090040,002,0000,9002|,
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.60, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.60, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.60, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.60, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,17.10, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,0D,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle,Configuration SHE,Mobile key configuration|Yes,No,Yes,Yes|No,No,No,No|,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,1,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,58,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,7,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,30921, km
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-Left taillight 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Power rear lid opening control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left neck heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right neck heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-Left taillight 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right taillight 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right taillight 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver's side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger's side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-Left taillight 1,Not available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left neck heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right neck heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-Left taillight 2,Not available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right taillight 1,Not available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right taillight 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-Left taillight 1,Not available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left neck heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right neck heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-Left taillight 2,Not available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right taillight 1,Not available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right taillight 2,Not available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-Left taillight 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271950,Bus identification of sub-bus users-Power rear lid opening control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left neck heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right neck heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-Left taillight 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right taillight 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right taillight 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver's side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger's side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference,kilometer reading,Year,Month,Day,Hours,Minutes|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,active,
MAS25323,Ambient lighting: error locations,not installed,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,41,
ENG277599,ASIL_relevante_RDIDs,|Adapted values/adaptation,Status of adaptation|0A 72,RDID_written|11 E3,RDID_written|11 E4,RDID_written|11 E5,RDID_written|11 E6,RDID_written|11 E7,RDID_written|11 01,RDID_written|11 20,RDID_written|0A 30,RDID_written|13 26,RDID_written|11 0A,RDID_written|11 0C,RDID_written|13 20,RDID_written|13 21,RDID_written|13 23,RDID_written|13 2F,RDID_written|13 3A,RDID_written|11 21,RDID_not_written|05 50,RDID_written|05 51,RDID_written|05 52,RDID_written|05 53,RDID_written|05 54,RDID_written|05 55,RDID_written|05 56,RDID_written|05 57,RDID_written|05 58,RDID_written|05 59,RDID_written|05 5A,RDID_written|05 5B,RDID_written|05 62,RDID_written|05 63,RDID_written|05 64,RDID_written|05 65,RDID_written|05 66,RDID_written|05 67,RDID_written|05 68,RDID_written|05 69,RDID_written|05 5F,RDID_written|12 01,RDID_not_written|0A 61,RDID_not_written|,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,PIN A16_A17 Komfort CAN,
ENG263729,Dataset_download_written_rdids,|ID data set,Number,Record Data Identifier|72 00,6,0A 72 11 E3 11 E4 11 E5 11 E6 11 E7 00 00 00 00 00 00 00 00|72 02,2,11 01 11 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 03,12,05 50 05 51 05 52 05 53 05 54 05 55 05 56 05 57 05 58 05 59|72 04,8,05 62 05 63 05 64 05 65 05 66 05 67 05 68 05 69 00 00 00 00|72 05,3,13 51 13 53 13 58 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 06,7,13 40 13 41 12 E2 12 E3 12 E4 12 E5 12 EC 00 00 00 00 00 00|72 07,1,12 E6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 08,1,12 E7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 09,1,12 E8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 0A,6,13 60 12 E9 12 EA 12 EB 12 ED 12 EF 00 00 00 00 00 00 00 00|72 0B,20,0A 64 05 10 05 11 05 12 05 13 05 14 05 15 05 16 05 17 05 18|72 0C,5,11 EA 11 E0 11 E8 11 E9 11 EB 00 00 00 00 00 00 00 00 00 00|72 0E,1,11 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 12,1,11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 27,2,0D 20 11 E2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 2B,3,13 52 13 50 13 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 35,1,10 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 36,2,0A 30 13 26 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 37,8,11 0C 11 0A 05 5F 13 20 13 21 13 2F 13 23 13 3A 00 00 00 00|,
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,493, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,92, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,4.0008, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,10100,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,62008,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Authentication,Functions,Configuration,Preconditions met,Individualization characteristic,Cancellation,Release code for a SWaP function|10 02 0E 00,Condition met,Not available,not OK,Condition met,valid,No,Available|10 02 0F 00,Condition met,Not available,not OK,Condition met,valid,Yes,Available|10 02 08 00,Condition met,Not available,not OK,Condition met,valid,Yes,Available|,
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,Communication,
ENG116909-ENG256024,LIN activity-LIN 11,not coded / not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded / not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded / not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded / not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,not coded / not installed,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG256030,LIN activity-LIN 7,not coded / not installed,
ENG116909-ENG256031,LIN activity-LIN 8,not coded / not installed,
ENG116909-ENG256032,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,10100,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,799.9933, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,0.00,
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,0.00,
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,0.00,
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,12.63, V
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command,Perso_Steuerungs_parameter,Status of personalization,Control point customization,Enable customization adjustment,Month,Day,Hours,Minutes|Personalization of user account 1,no control,No user account,Customization coded 2.x,Initial value,Enabled,0,0,0,0|Personalization of user account 1,no control,No user account,no customization,Initial value,Enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|,
ENG116792,Power up history,|Funktionsanforderung|1|10|10|13|2|10|10|10|13|1|,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,12, s
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,16, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,-0.04, km/(h s)
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,37,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,1,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,64,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,15,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,14.7, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,23, C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,795.6816, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,31,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,76,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,64,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,255,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,12.2, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,22, C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,795.6816, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,27,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,19,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,11,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,112,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,13.1, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,29, C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,767.5262, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,36,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,2,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,160,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,0,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,11.5, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,34, C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,662.9014, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,52,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,4,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,64,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,14.6, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,22, C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,505.2978, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,51,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,14,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,255,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,12.5, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,18, C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,325.3698, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,34,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,5,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,64,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,12,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,14.3, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,19, C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,7.6636, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-kilometer reading,17651, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.9, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.5, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.6, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,40, C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,44, C
ENG122921-ENG121629,values_motorloads-temp_pcb,41, C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),10187,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,12.6222, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,6553.5,
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,2876905.091, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,49104.143, C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1348101225,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,6553.5,
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210,
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260,
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,6553.5,
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,37,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0,
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,2863274.736, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,163.7,
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,14.6980, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,23.123, C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,24.0,
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,63 7F 94 4C 19 4A 14 BD A1 67 A7 9D,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,40,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 37 34 35 33 46 30 34 30 32 31 31 38 31 30 38 37 30 37,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,5886,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,5886,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,640,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,240,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,7640,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,176,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,114,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,194,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,96,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,110,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,1617,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,23078.832557, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,23091.760471, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,596.026425, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,3802,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,6397,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-60, C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,126, C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.5, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,0,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,5340,
Elapsed Time: 01:19
;SW:5WA-937-086-AE HW:5WA-937-086-L --- 09: Cent. Elect.
;Component:BCM37w_M028 0175, Coding:
;EV_BCM37w,007001,EV_BCM37w_007_VW38.rod
;Tuesday,01,September,2026,23:05:32:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 147663D49EF722EA538-8040 SFD [ ]
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00301,Distance,30980, km
IDE00322,Status of basic setting,is running,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,none,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Initialization,
IDE00973,Outside temperature,38.0, C
IDE01943,Turn signal lamp,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Connector B,24,0.0,not active,normal|Connector B,9,0.0,not active,normal|Connector A,60,0.0,not active,normal|Plug C,27,0.0,not active,normal|,
IDE01992-SFT00009,Installation list: current installations-Electronic central electric,active,
IDE01992-SFT00183,Installation list: current installations-Interface for access/start system,active,
IDE01992-SFT00214,Installation list: current installations-Light Control Left 2,active,
IDE01992-SFT00215,Installation list: current installations-Light Control Right 2,active,
IDE01992-SFT33031,Installation list: current installations-Antenna module,not active,
IDE01992-SFT33054,Installation list: current installations-Burglary protection control module 1 VL,not active,
IDE01992-SFT33055,Installation list: current installations-Burglary protection control module 2 VR,not active,
IDE01992-SFT33056,Installation list: current installations-Burglary protection control module 3 HL,not active,
IDE01992-SFT33057,Installation list: current installations-Burglary protection control module 4 HR,not active,
IDE01992-SFT33058,Installation list: current installations-Burglary protection control module 5 vehicle interior,not active,
IDE01996-SFT00009,Installation list: specified installations-Electronic central electric,active,
IDE01996-SFT00183,Installation list: specified installations-Interface for access/start system,active,
IDE01996-SFT00214,Installation list: specified installations-Light Control Left 2,active,
IDE01996-SFT00215,Installation list: specified installations-Light Control Right 2,active,
IDE01996-SFT33031,Installation list: specified installations-Antenna module,not active,
IDE01996-SFT33054,Installation list: specified installations-Burglary protection control module 1 VL,not active,
IDE01996-SFT33055,Installation list: specified installations-Burglary protection control module 2 VR,not active,
IDE01996-SFT33056,Installation list: specified installations-Burglary protection control module 3 HL,not active,
IDE01996-SFT33057,Installation list: specified installations-Burglary protection control module 4 HR,not active,
IDE01996-SFT33058,Installation list: specified installations-Burglary protection control module 5 vehicle interior,not active,
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,Signal from door lock: engaged,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlock button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,not coded / not installed,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02092-MAS09072,Tailgate condition-Locking mechanism button in the rear lid,Not operated,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded / not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded / not installed,
IDE02495,Service-Key: Number of activations,0,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02515,Low beams,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711-IDE05228,Rear wiper-Operating hour counter,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02743,Main beam,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE02745-IDE00096,Ignition Switch Key Lock Solenoid-Selector lever position,Selector lever in position P,
IDE02745-MAS08205,Ignition Switch Key Lock Solenoid-CAN ESP valid speed,Qualified,
IDE02745-MAS08206,Ignition Switch Key Lock Solenoid-CAN ESP speed,0.00, km/h
IDE02857-IDE03111,Activation current-Interior lighting,14, mA
IDE02857-IDE06012,Activation current-Background lighting,46, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE02857-ENG126436,Activation current-signal_horn,Measuring value not available,
IDE02957,Ambient lighting,|Channel,Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Not available,not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,0,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127,Prevented stop processes (ring memory),|Last prohibited stop,Year,Month,Day,Hours,Minutes,Seconds|Missing from ECM,2026,9,1,2,12,46|Missing from ECM,2026,9,1,2,9,48|Missing from ECM,2026,9,1,1,46,47|Missing from ECM,2026,9,1,1,46,14|Missing from ECM,2026,9,1,1,45,58|,
IDE03128,Requested start processes (ring memory),|,Year,Month,Day,Hours,Minutes,Seconds|Empty,2000,0,0,0,0,0|Empty,2000,0,0,0,0,0|Empty,2000,0,0,0,0,0|Empty,2000,0,0,0,0,0|Empty,2000,0,0,0,0,0|,
IDE03150-SFT00009,Readiness for bus sleep mode-Electronic central electric,not ready for sleep,
IDE03150-SFT00183,Readiness for bus sleep mode-Interface for access/start system,not ready for sleep,
IDE03150-SFT00214,Readiness for bus sleep mode-Light Control Left 2,Ready For Sleep,
IDE03150-SFT00215,Readiness for bus sleep mode-Light Control Right 2,Ready For Sleep,
IDE03150-SFT33031,Readiness for bus sleep mode-Antenna module,Ready For Sleep,
IDE03150-SFT33054,Readiness for bus sleep mode-Burglary protection control module 1 VL,Ready For Sleep,
IDE03150-SFT33055,Readiness for bus sleep mode-Burglary protection control module 2 VR,Ready For Sleep,
IDE03150-SFT33056,Readiness for bus sleep mode-Burglary protection control module 3 HL,Ready For Sleep,
IDE03150-SFT33057,Readiness for bus sleep mode-Burglary protection control module 4 HR,Ready For Sleep,
IDE03150-SFT33058,Readiness for bus sleep mode-Burglary protection control module 5 vehicle interior,Ready For Sleep,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,System malfunction,
IDE03310,Brake lamp,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Connector A,71,0.0,not active,normal|Plug C,8,0.0,not active,normal|Connector A,57,0.0,not active,normal|,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,0.0, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,0.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,0.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638,Static cornering light,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE03788,Status of basic headlamp setting,no request,
IDE04213,Central locking button,not coded / not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded / not installed,
IDE04254-MAS00222,Play protection for central locking-Rear lid,not active,
IDE04254-MAS02444,Play protection for central locking-Central locking,not active,
IDE04254-MAS06465,Play protection for central locking-Fuel tank cover via button,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,38.0, C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,12.4, V
IDE04347-MAS09388,Expanded freeze frame conditions-Engine run,OFF,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04639,Last wake-up cause,Radio telegram: valid,
IDE04925,Daytime running lamps,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,12.0, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,10100,
IDE05045-MAS05878,Front wiper module-level,not coded / not installed,
IDE05323,Fog lamp,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Connector B,45,0.0,not active,normal|Connector B,5,0.0,not active,normal|,
IDE05434,Rear entry light,|Connector number,Side,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,Unknown (0),0,0.0,not coded / not installed,not coded / not installed|,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05725-MAS01634,Dimmer terminal 58xs-Supply voltage,56.0, %
IDE05730,Luggage compartment light,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Plug C,56,0.0,not active,normal|,
IDE05739,Footwell lamp,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Plug C,72,0.0,not active,normal|,
IDE05742-IDE02515,Light switch position-Low beams,not coded / not installed,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded / not installed,
IDE05742-MAS00063,Light switch position-OFF,not coded / not installed,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,not coded / not installed,
IDE05742-MAS03835,Light switch position-Position lamps,not coded / not installed,
IDE05742-MAS03836,Light switch position-Rear fog lamp,not coded / not installed,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded / not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded / not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded / not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded / not installed,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,Year,Month,Day,Hours,Minutes|Door contact driver door,2026,3,20,10,37|Door contact driver door,2024,5,3,7,50|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|Door contact driver door,2000,0,0,0,0|,
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded / not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,18, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839,Parking lamps,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Plug C,10,100.0,not active,normal|Connector A,65,100.0,not active,normal|Plug C,11,100.0,not active,normal|Connector A,64,100.0,not active,normal|,
IDE05841,Central locking history data,|Control-section / cause,Additional information,Month,Day,Hours,Minutes,Seconds|Remote control,Key 1,9,1,1,46,30|Remote control,Key 1,9,1,1,45,45|Auto lock,no key active,9,1,1,13,0|security_lock_tailgate,no key active,9,1,1,12,45|security_lock_tailgate,no key active,9,1,1,9,45|Auto lock,no key active,9,1,0,44,0|security_lock_tailgate,no key active,9,1,0,44,0|Auto lock,no key active,9,1,0,40,45|security_lock_tailgate,no key active,9,1,0,40,30|Auto lock,no key active,9,1,20,3,0|security_lock_tailgate,no key active,9,1,20,1,0|Remote control,Key 1,9,1,19,53,15|Auto lock,no key active,9,1,19,52,15|security_lock_tailgate,no key active,9,1,19,52,15|Remote control,Key 1,9,1,18,6,30|Auto lock,no key active,9,1,17,52,0|security_lock_tailgate,no key active,9,1,17,52,0|Remote control,Key 1,9,1,10,17,0|Auto lock,no key active,9,1,9,59,30|security_lock_tailgate,no key active,9,1,9,59,0|,
IDE05842,Comfort function history data,|Control-section / cause,Operating command,convertible top,Sun roof/tilt roof,Driver s door,Passenger s door,Rear left door,Rear right door,Month,Day,Hours|Key 1,Open,not active,not active,active,active,active,active,7,18,15|Key 1,Open,not active,not active,active,active,active,active,6,23,6|Key 1,Open,not active,not active,active,active,active,active,6,6,15|Key 1,Open,not active,not active,active,active,active,active,6,4,18|Key 2,Open,not active,not active,active,active,active,active,3,20,9|Key 2,Open,not active,not active,active,active,active,active,3,20,9|Key 1,Open,not active,not active,active,active,active,active,9,25,12|Key 1,Open,not active,not active,active,active,active,active,9,25,12|Key 1,Open,not active,not active,active,active,active,active,9,17,12|Key 1,Open,not active,not active,active,active,active,active,9,15,12|Key 1,Open,not active,not active,active,active,active,active,9,10,9|Key 1,Open,not active,not active,active,active,active,active,9,10,9|Key 1,Open,not active,not active,active,active,active,active,8,1,18|Key 1,Open,not active,not active,active,active,active,active,7,28,15|Key 1,Open,not active,not active,active,active,active,active,7,19,15|Key 1,Open,not active,not active,active,active,active,active,7,9,12|Key 1,Open,not active,not active,active,active,active,active,7,7,15|Key 1,Open,not active,not active,active,active,active,active,6,20,18|Key 1,Open,not active,not active,active,active,active,active,6,20,18|Key 1,Open,not active,not active,active,active,active,active,6,20,9|,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,not coded / not installed,
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,not coded / not installed,
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,not coded / not installed,
IDE06091-MAS04647,Humidity sensor: interior-Dew point,not coded / not installed,
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,53.0,
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,53.0,
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,9.0,
IDE06096-MAS01634,Interior lights-Supply voltage,active,
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,80, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded / not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded / not installed,
IDE06324-MAS10861,Tank cap lock-Fuel tank cap unlocked via ECM,not coded / not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE06864,Daytime running lights,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07293,History data of panic alarm,|Cause for alarm activation,Month,Day,Hour,Minute|Panic button,8,30,14,56|Panic button,8,30,14,54|Panic button,8,25,9,37|Panic button,6,23,8,17|,
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,unlocked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Contact switch in lock cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,Open,
IDE08162-MAS06432,TSG driver side: signals for central locking-Interior lock switch,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,unlocked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Contact switch in lock cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Interior lock switch,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Interior lock switch,not coded / not installed,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Interior lock switch,not coded / not installed,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,Open,
IDE08177-MAS09895,Central locking-Act. condition: Status central locking locked,active,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09899,Central locking-Act. condition: Status central locking individual door unlocked,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-ENG263791,Central locking-Cabin/Cargo lock,not active,
IDE08178-MAS06437,Valet parking service-Valet parking lock button,not coded / not installed,
IDE08178-MAS06438,Valet parking service-Valet parking indicator lamp,not coded / not installed,
IDE08185,Counter for play protection of central locking,not active,
IDE08211-MAS03129,History data control module reset-Reset counter,5,
IDE08211,History data control module reset,|last cause of reset,Year,Month,Day,Hours,Minutes|Analysis 1,2026,9,1,0,0|Analysis 1,2000,0,0,0,0|Analysis 1,2026,5,13,0,0|Analysis 1,2026,5,13,16,31|Analysis 1,2026,5,13,0,0|,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,F8,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,F8,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,8B 80 C3 B0,
IDE08240,Transponder ID Key 2,48 1A C3 B0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,06 27 55 CE,
IDE08343,Immobilizer Challenge,86 D2 DD C5,
IDE08516-IDE02743,LED headlights: light distribution requirement-Main beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,both sides,
IDE08516-MAS02946,LED headlights: light distribution requirement-Static cornering light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,0, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,0, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,0, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,2, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,0, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,0, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,111, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,107, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,142, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,119, mA
IDE08949-MAS07896,Operating current: light driver-Conn. pin 29,130, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,0, mA
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,0, mA
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,0, mA
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,0, mA
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,0, mA
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,0, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,0, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,0, mA
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,0, mA
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,318, mA
IDE10285-MAS02447,Release of rear lid exterior button-Activation,Enabled,
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE10662-MAS17838,Light switch (button module)-Exterior lighting: global shutoff,OFF,
IDE10662,Light switch (button module),not active,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beams,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-Main beam,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Static cornering light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,Installed: not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,not installed / not active,
IDE11134-MAS04422,Light sequence HU test result-Brake light signal via CAN,Installed: not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,not coded / not installed,
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,not coded / not installed,
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,6,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,6,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13128,Function of the central console button-Indicator lamp button 1,installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13131,Function of the central console button-Indicator lamp button 2,installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13134,Function of the central console button-Indicator lamp button 3,installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11727-MAS13136,Function of the central console button-Indicator lamp button 4,installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,0,
IDE12263,Virtual radio key: vehicle ID,74 75 C9 97 EB 17 AE 2F C8 F4 A4 0A 77 65 1A F9,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12466,Unlocking central locking system history data,|Control-section / cause,Key number,Year,Month,Day,Hour,Minute,Seconds|Unlocking button of the radio key,Key 1,2026,9,1,1,47,6|Unlocking button of the radio key,Key 1,2026,9,1,1,45,51|Auto unlock,no key active,2026,9,1,1,44,36|Unlocking button of the radio key,Key 1,2026,9,1,1,10,8|Auto unlock,no key active,2026,9,1,1,9,39|Auto unlock,no key active,2026,9,1,0,42,12|Auto unlock,no key active,2026,9,1,20,9,55|Unlocking button of the radio key,Key 1,2026,9,1,19,54,8|Auto unlock,no key active,2026,9,1,19,53,6|Release button in rear lid handle,no key active,2026,9,1,19,50,56|Unlocking button of the radio key,Key 1,2026,9,1,18,7,8|Auto unlock,no key active,2026,9,1,18,5,55|Unlocking button of the radio key,Key 1,2026,9,1,10,17,52|Auto unlock,no key active,2026,9,1,10,12,40|Unlocking button of the radio key,Key 1,2026,9,1,9,13,44|Unlocking button of the radio key,Key 1,2026,9,1,9,5,34|Auto unlock,no key active,2026,9,1,9,4,28|Unlocking button of the radio key,Key 1,2026,8,31,22,44,43|Unlocking button of the radio key,Key 1,2026,8,31,22,43,16|Auto unlock,no key active,2026,8,31,22,39,26|,
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 2,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE13750-IDE01351,Input signals: control of terminal-Terminal 75 status,On,
IDE13750-IDE01715,Input signals: control of terminal-Status terminal S,not coded / not installed,
IDE13750-IDE01716,Input signals: control of terminal-Terminal 50 status,OFF,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13750-MAS12787,Input signals: control of terminal-Terminal 15 ignition switch signal 1,not coded / not installed,
IDE13750-MAS12788,Input signals: control of terminal-Terminal 15 ignition switch signal 2,not coded / not installed,
IDE13750-MAS17227,Input signals: control of terminal-Starter button: error status,No malfunction detected,
IDE13750-MAS17233,Input signals: control of terminal-Terminal start command,not coded / not installed,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13751-ENG255221,Output signals: control of terminal-Terminal_50_CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13845,Production mode status,not active,
IDE13956-IDE00075,Key position replication: input signals-Vehicle speed,0.00, km/h
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device not installed,
IDE13956-MAS01493,Key position replication: input signals-Engine is running,not active,
IDE13956-MAS02248,Key position replication: input signals-Signal status,valid,
IDE13956-MAS03607,Key position replication: input signals-Engine stop active in Start/Stop mode,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,not active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS06793,Key position replication: input signals-Number of adapted keys,2,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,On,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG256242,Key position replication: input signals-Powertrain_activation_permitted,Yes,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG256551,Key position replication: input signals-Trigger_terminal_15_shutoff,No,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14238-MAS02282,Wiper arm position-Position,1.0,
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 2,
IDE14337-MAS01853,Vehicle inclination sensor: rotation angle-Left front,Not installed due to specific system,
IDE14337-MAS01855,Vehicle inclination sensor: rotation angle-Left rear,Not installed due to specific system,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 62 B8 BF 94 98 79 8F,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 07,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14665-IDE01097,Control unit for driving and comfort functions: status-Front passenger airbag -disabled- indicator lamp,On,
IDE14665-IDE04213,Control unit for driving and comfort functions: status-Central locking button,Initialization/not installed,
IDE14665-MAS01118,Control unit for driving and comfort functions: status-Air Conditioning,Not operated,
IDE14665-MAS01533,Control unit for driving and comfort functions: status-Defrost,Initialization/not installed,
IDE14665-MAS01535,Control unit for driving and comfort functions: status-Rear window defogger,Initialization/not installed,
IDE14665-MAS01564,Control unit for driving and comfort functions: status-Windshield defogger,Initialization/not installed,
IDE14665-MAS03834,Control unit for driving and comfort functions: status-Emergency signal flashing,Not operated,
IDE14665-MAS08072,Control unit for driving and comfort functions: status-Driving profile selection,Not operated,
IDE14665-MAS15376,Control unit for driving and comfort functions: status-Front passenger airbag indicator lamp on,OFF,
IDE14665-MAS18688,Control unit for driving and comfort functions: status-Parking,Not operated,
IDE14665-MAS18689,Control unit for driving and comfort functions: status-Parking: function display,OFF,
IDE14665-MAS18690,Control unit for driving and comfort functions: status-Driving mode selection: function lighting,On,
IDE14665-MAS18691,Control unit for driving and comfort functions: status-Emergency signal flashing: function lighting,OFF,
IDE14665-MAS18692,Control unit for driving and comfort functions: status-Car menu,Initialization/not installed,
IDE14665-MAS18693,Control unit for driving and comfort functions: status-Car menu: function lighting,OFF,
IDE14665-MAS18694,Control unit for driving and comfort functions: status-Windshield defogger: function lighting,OFF,
IDE14665-MAS18695,Control unit for driving and comfort functions: status-Driver assistance systems,Not operated,
IDE14665-MAS18696,Control unit for driving and comfort functions: status-Rear window heating: function lighting,OFF,
IDE14665-MAS18697,Control unit for driving and comfort functions: status-Defrost: function lighting,OFF,
IDE14665-MAS18698,Control unit for driving and comfort functions: status-Front passenger airbag indicator lamp on: inverted,OFF,
IDE14665-MAS18699,Control unit for driving and comfort functions: status-Front passenger airbag -Disabled- indicator lamp: inverted,On,
IDE14665-MAS18700,Control unit for driving and comfort functions: status-Central locking button: function lighting,OFF,
IDE14731-MAS01853,Vehicle inclination sensor: adaptation value (deflected)-Left front,Not installed due to specific system,
IDE14731-MAS01855,Vehicle inclination sensor: adaptation value (deflected)-Left rear,Not installed due to specific system,
IDE14754-IDE08167,Anti-Theft Alarm System: cause of level 1 emergency activation-Sunroof: status standardization,No,
IDE14754-MAS06509,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module driver side: Timeout,not active,
IDE14754-MAS06510,Anti-Theft Alarm System: cause of level 1 emergency activation-Door ctrl. module frt.pass.side: Timeout,not active,
IDE14754-MAS06511,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module driver side rear: Timeout,not active,
IDE14754-MAS06512,Anti-Theft Alarm System: cause of level 1 emergency activation-Door control module frt. pass. side rear: Timeout,not active,
IDE14754-MAS19082,Anti-Theft Alarm System: cause of level 1 emergency activation-Trunk lid electronics: timeout,active,
IDE14754-MAS19083,Anti-Theft Alarm System: cause of level 1 emergency activation-Sunroof Control Module: no communication,not active,
IDE14754-MAS19092,Anti-Theft Alarm System: cause of level 1 emergency activation-A/C/heating electronics: timeout,active,
IDE14754-MAS20679,Anti-Theft Alarm System: cause of level 1 emergency activation-Front window regulator: driver side: status normalization,Yes,
IDE14754-MAS20680,Anti-Theft Alarm System: cause of level 1 emergency activation-Front window regulator: passenger side: status normalization,Yes,
IDE14754-MAS20681,Anti-Theft Alarm System: cause of level 1 emergency activation-Rear window regulator: driver side: status normalization,Yes,
IDE14754-MAS20682,Anti-Theft Alarm System: cause of level 1 emergency activation-Rear window regulator: passenger side: status normalization,Yes,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not recognised,
IDE14958-SFT00008,Recognized actual fitting list: adapt-HVAC electronics,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not recognised,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,not recognised,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not recognised,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not recognised,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not recognised,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,not recognised,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not recognised,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,not recognised,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for driver assistance systems,detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not recognised,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not recognised,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary protection control module 1 VL,not recognised,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary protection control module 2 VR,not recognised,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary protection control module 3 HL,not recognised,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary protection control module 4 HR,not recognised,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary protection control module 5 vehicle interior,not recognised,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Left rear door control module,detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Right rear door control module,detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not recognised,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not recognised,
IDE14959,Tailgate opening: reason for non-availability,No release by access control,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 41,
IDE14993,Software composition list identification data,|Software Composition ID,System designation,Supplier ID,VW/Audi part number,Primary version number,Secondary version number,Patch version number|30 30 30 30 30 30 33 43,ZKA,30 36,F1870000000,0000,0001,0000|30 30 30 30 30 30 33 43,ZvAct,30 36,F1870000000,0000,0001,0001|00 00 00 00 00 00 00 71,HeckWischWash,00 08,V04007001BJ,0020,0009,0040|30 30 30 30 30 30 36 36,SounderAct,30 36,F1870000000,0000,0001,0000|00 00 00 00 00 00 00 59,LWR ,00 20,00000000000,0006,0001,0000|00 00 00 00 00 00 00 3E,Kessy ,00 0D,V04007001J ,000P,0720,0000|00 00 00 00 00 00 00 00,0000000000000,00 00,00000000000,0000,0000,0000|00 00 00 00 00 00 00 51,IuAModul ,00 08,V04007001S ,0020,0009,0035|00 00 00 00 00 00 00 52,EventGen ,00 70,V04007001Q ,0008,0007,0000|00 00 00 00 00 00 00 6A,Azk ,00 0E,V04007001SB,0004,0000,0000|00 00 00 00 00 02 00 A3,AmbiAct ,00 08,-----------,0020,0009,0000|00 00 00 00 00 00 00 6C,Cockpittaster,00 08,V04007001BD,0020,0009,0015|00 00 00 00 00 00 00 60,0000000000000,00 07,V04007001L ,2230,0004,0000|00 00 00 00 00 00 00 60,Di58 Sensor ,00 08,V04007001A ,0020,0009,0000|00 00 00 00 00 00 00 55,Dimmung ,00 08,V04007001T ,0020,0009,0000|00 00 00 00 00 00 00 6D,DiETasten ,00 08,V04007001BE,0020,0009,0000|00 00 00 00 00 02 00 A4,DwpHewiAct ,00 08,-----------,0020,0009,0025|00 00 00 00 00 00 00 52,Output ,00 70,V04007001Q ,0008,0007,0000|00 00 00 00 00 00 00 52,ExAmb ,00 70,V04007001Q ,0008,0007,0000|00 00 00 00 00 00 00 53, FBS_BREMSL,00 06, V04007001P,,,|30 30 30 30 30 30 36 46,FdH,30 36,V04007001BG,0001,0002,0001|00 00 00 00 00 02 00 A1,FwAct ,00 08,-----------,0020,0009,0010|00 00 00 00 00 00 00 00,xOb ,30 30,2000090025,,qH,eckW|69 73 63 68 20 20 20 20,-----------,30 30,2000090040,002,0000,9002|,
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,none,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,none,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,Initialization,
IDE15114,Supply voltage for ambient lighting,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Plug C,70,127.0,active,normal|,
IDE15848-MAS14747,DWA for interior monitoring: deactivation softkey-MIB softkey,not coded / not installed,
IDE15848-MAS21162,DWA for interior monitoring: deactivation softkey-Signal: status deactivation,not active,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,12.35, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,12.30, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,12.35, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,12.35, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,16.35, V
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,0D,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,15 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle,Configuration SHE,Mobile key configuration|Yes,No,Yes,Yes|No,No,No,No|,
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,1,
MAS00464-MAS00109,Standard - ambient data 1-Hours,2,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,41,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,149,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,30988, km
MAS01281,Back-up lamps,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Connector B,20,0.0,not active,normal|Connector B,32,0.0,not active,normal|,
MAS02101-MAS07806,Child safety-Specified status,not coded / not installed,
MAS03835,Position lamps,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|Plug C,10,100.0,active,normal|Connector A,65,100.0,active,normal|Connector A,59,127.0,active,normal|Plug C,11,100.0,active,normal|Connector A,64,100.0,active,normal|,
MAS03836,Rear fog lamp,|Connector number,Connector terminal number,Pulse duty factor,Signal status,Diagnosis|not coded / not installed,0,0.0,not coded / not installed,not coded / not installed|,
MAS08228-MAS01632,Light sensor-Status,not coded / not installed,
MAS08228-MAS02851,Light sensor-Brightness,not coded / not installed,
MAS08228-MAS04121,Light sensor-Voltage,not coded / not installed,
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-Left taillight 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Power rear lid opening control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left neck heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right neck heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-Left taillight 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right taillight 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right taillight 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver's side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger's side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,Available,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,Available,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-Left taillight 1,Not available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,Available,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271950,Specified installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left neck heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right neck heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-Left taillight 2,Not available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right taillight 1,Not available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right taillight 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,Available,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,Available,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,Available,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-Left taillight 1,Not available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,Available,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12668-SFT271950,Actual installation of sub-bus users-Power rear lid opening control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left neck heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right neck heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,Available,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,Not available,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,Not available,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-Left taillight 2,Not available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right taillight 1,Not available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right taillight 2,Not available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,Not available,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver's side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger's side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-Left taillight 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271950,Bus identification of sub-bus users-Power rear lid opening control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left neck heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right neck heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-Left taillight 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right taillight 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right taillight 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver's side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger's side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,Available,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,Available,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,Basic,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,82 minutes,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,Short: time-controlled,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference,kilometer reading,Year,Month,Day,Hours,Minutes|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|invalid,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0,2000,0,0,0,0|,
MAS18844,Number of repetition attempts for radio via low frequency range,|Function,Channel: ultra-high-frequency band,Retry_Count,Year,Month,Day,Hours,Minutes,Seconds|Interior search: re-locking,Channel 1,1,2026,9,1,1,46,35|Interior search: re-locking,Channel 1,1,2026,9,1,1,45,50|Interior search: terminal 15,Channel 1,1,2026,9,1,1,45,46|Interior search: terminal 15,Channel 1,1,2026,9,1,1,12,7|Interior search: terminal 15,Channel 1,1,2026,9,1,1,12,2|Interior search: terminal 15,Channel 1,1,2026,9,1,1,11,57|Interior search: terminal 15,Channel 1,1,2026,9,1,1,11,52|Interior search: terminal 15,Channel 1,1,2026,9,1,1,11,47|Interior search: terminal 15,Channel 1,1,2026,9,1,1,11,47|Interior search: terminal 15,Channel 1,1,2026,9,1,1,10,6|Interior search: terminal 15,Channel 1,1,2026,9,1,20,10,39|Interior search: re-locking,Channel 1,1,2026,9,1,19,53,28|Interior search: terminal 15,Channel 1,1,2026,9,1,19,53,23|Interior search: terminal 15,Channel 1,1,2026,9,1,19,16,55|Interior search: terminal 15,Channel 1,1,2026,9,1,19,16,54|Interior search: terminal 15,Channel 1,1,2026,9,1,19,13,53|Interior search: terminal 15,Channel 1,1,2026,9,1,19,13,48|Interior search: terminal 15,Channel 1,1,2026,9,1,19,13,43|Interior search: terminal 15,Channel 1,1,2026,9,1,19,13,38|Interior search: terminal 15,Channel 1,1,2026,9,1,19,13,33|,
MAS18845,Number of repetition attempts for radio via ultra-high frequency range,|Function,Channel: ultra-high-frequency band,Retry_Count,Year,Month,Day,Hours,Minutes,Seconds|Authentication: Kessy Go,Channel 1,1,2026,9,1,0,40,10|Authentication: Kessy Go,Channel 1,1,2026,9,1,19,50,33|Authentication: Kessy Go,Channel 1,1,2026,9,1,19,36,0|Authentication: Kessy Go,Channel 1,1,2026,8,28,9,43,7|Authentication: Kessy Go,Channel 1,1,2026,8,21,9,23,2|Authentication: Kessy Go,Channel 1,1,2026,8,19,17,58,37|Authentication: Kessy Go,Channel 1,1,2026,8,13,19,19,56|Authentication: Kessy Go,Channel 1,1,2026,7,27,9,49,47|Authentication: Kessy Go,Channel 1,1,2026,7,21,19,42,53|Authentication: Kessy Go,Channel 1,1,2026,7,18,15,13,5|Authentication: Kessy Go,Channel 1,1,2026,7,15,19,28,26|Authentication: Kessy Go,Channel 1,1,2026,7,13,14,12,57|Authentication: Kessy Go,Channel 1,1,2026,6,27,21,0,43|Authentication: Kessy Go,Channel 1,1,2026,6,27,21,0,3|Authentication: Kessy Go,Channel 1,1,2026,6,27,21,0,2|Authentication: Kessy Go,Channel 1,1,2026,6,24,12,1,46|Authentication: Kessy Go,Channel 1,1,2026,6,17,14,43,1|Authentication: Kessy Go,Channel 1,1,2026,6,9,20,59,13|Authentication: Kessy Go,Channel 1,1,2026,6,7,21,46,12|Authentication: Kessy Go,Channel 1,1,2026,6,6,12,54,41|,
MAS18846,Suppression of passive unlocking: locking: engine start,|Reason for low pressure,Year,Month,Day,Hours,Minutes,Seconds,Mileage_lf_shutdown|Kessy Go: conditions not met,2026,9,1,1,46,35,30988|Kessy Go: conditions not met,2026,9,1,1,45,50,30988|Kessy Go: conditions not met,2026,9,1,19,53,27,30921|Kessy Go: conditions not met,2026,9,1,18,6,37,30921|Kessy Go: conditions not met,2026,9,1,10,17,14,30911|Kessy Go: conditions not met,2026,9,1,9,13,13,30894|Kessy Go: conditions not met,2026,9,1,9,4,57,30894|Kessy Go: conditions not met,2026,8,31,22,43,22,30888|Kessy Go: conditions not met,2026,8,31,22,43,6,30888|Kessy Go: conditions not met,2026,8,31,20,26,31,30789|, km
MAS18847,Authentication status for ID sensor 1,Detected: not authenticated,
MAS18848,Authentication status for ID sensor 2,No response,
MAS18849,Authentication status for ID sensor 3,No response,
MAS18850,Authentication status for ID sensor 4,No response,
MAS18851,Authentication status for ID sensor 5,No response,
MAS18852,Authentication status for ID sensor 6,No response,
MAS18853,Authentication status for ID sensor 7,No response,
MAS18854,Authentication status for ID sensor 8,No response,
MAS18855-MAS02282,Radio data information from ID sensor 1 in low frequency range (LF)-Position,Unknown,
MAS18855-MAS19524,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18855-MAS19525,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18855-MAS19526,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18855-MAS19527,Radio data information from ID sensor 1 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18856-MAS02282,Radio data information from ID sensor 2 in low frequency range (LF)-Position,Unknown,
MAS18856-MAS19524,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18856-MAS19525,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18856-MAS19526,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18856-MAS19527,Radio data information from ID sensor 2 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18857-MAS02282,Radio data information from ID sensor 3 in low frequency range (LF)-Position,Unknown,
MAS18857-MAS19524,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18857-MAS19525,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18857-MAS19526,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18857-MAS19527,Radio data information from ID sensor 3 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18858-MAS02282,Radio data information from ID sensor 4 in low frequency range (LF)-Position,Unknown,
MAS18858-MAS19524,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18858-MAS19525,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18858-MAS19526,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18858-MAS19527,Radio data information from ID sensor 4 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18859-MAS02282,Radio data information from ID sensor 5 in low frequency range (LF)-Position,Unknown,
MAS18859-MAS19524,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18859-MAS19525,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18859-MAS19526,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18859-MAS19527,Radio data information from ID sensor 5 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18860-MAS02282,Radio data information from ID sensor 6 in low frequency range (LF)-Position,Unknown,
MAS18860-MAS19524,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18860-MAS19525,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18860-MAS19526,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18860-MAS19527,Radio data information from ID sensor 6 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18861-MAS02282,Radio data information from ID sensor 7 in low frequency range (LF)-Position,Unknown,
MAS18861-MAS19524,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18861-MAS19525,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18861-MAS19526,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18861-MAS19527,Radio data information from ID sensor 7 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18862-MAS02282,Radio data information from ID sensor 8 in low frequency range (LF)-Position,Unknown,
MAS18862-MAS19524,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 1,0,
MAS18862-MAS19525,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 2,0,
MAS18862-MAS19526,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 3,0,
MAS18862-MAS19527,Radio data information from ID sensor 8 in low frequency range (LF)-Reception field strength (RSSI): carrier 4,0,
MAS18863,Run time measurement positive for relay attacks: radio communication,|ID sensor used,Time measurement trigger,Control module used,Time_measurement,Position,kilometer reading,Year,Month,Day,Hours,Minutes,Seconds|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|,
MAS18864,Run time measurement negative for relay attacks: radio communication,|ID sensor used,Time measurement trigger,Control module used,Time_measurement,Position,kilometer reading,Year,Month,Day,Hours,Minutes,Seconds|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|Default,Default,Default,0,Unknown,0,2000,0,0,0,0,0|,
MAS18865,adapted allocation numbers between vehicle and ID sensor,|Learned wake pattern,Mileage|3890034810,0|0,0|0,0|, km
MAS18866,Non-volatile memory access status,|Reason for access,kilometer reading|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|Default,0|, km
MAS18867,Direction of movement record,|ID sensor 1,ID sensor 2,ID sensor 3,ID sensor 4,ID sensor 5,ID sensor 6,ID sensor 7,ID sensor 8|0,0,0,0,0,0,0,0|0,0,0,0,0,0,0,0|0,0,0,0,0,0,0,0|0,0,0,0,0,0,0,0|,
MAS18868-ENG129148,Number of shutdowns performed-Easy_close_function_counter,0,
MAS18869,Number of function cancellations,0,
MAS18870,Cause of last function cancellation,none,
MAS18893-ENG129135,Service Key status data-checksum_comparison_service_key1,not OK.,
MAS18893-ENG289723,Service Key status data-Day_sk_rte,0,
MAS18893-ENG289717,Service Key status data-Day_sk_uhf,0,
MAS18893-ENG289706,Service Key status data-Hour_sk_rte,0,
MAS18893-ENG289715,Service Key status data-Hour_sk_uhf,0,
MAS18893-ENG289710,Service Key status data-Minute_sk_rte,0,
MAS18893-ENG289721,Service Key status data-Minute_sk_uhf,0,
MAS18893-ENG289709,Service Key status data-Month_sk_rte,0,
MAS18893-ENG289705,Service Key status data-Month_sk_uhf,0,
MAS18893-ENG289708,Service Key status data-Seconds_sk_rte,0,
MAS18893-ENG289714,Service Key status data-Seconds_sk_uhf,0,
MAS18893-ENG289713,Service Key status data-Year_sk_rte,2000,
MAS18893-ENG289712,Service Key status data-Year_sk_uhf,2000,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,active,
MAS19775-MAS06430,Status of sliding door rear driver side-Main notch contact of rotary latch,not coded / not installed,
MAS19775-MAS15328,Status of sliding door rear driver side-Interior door handle switch,Not available,
MAS19775-MAS19404,Status of sliding door rear driver side-Rear Driver Side Exterior Door Handle Switch: status,Not available,
MAS19775-MAS21226,Status of sliding door rear driver side-Mechanical separation door inside handle: status,not coded / not installed,
MAS19775-MAS21227,Status of sliding door rear driver side-Motor for safe: child safety: and crash activation,not coded / not installed,
MAS19775-MAS21228,Status of sliding door rear driver side-Rotary motor: activation,not coded / not installed,
MAS19775-MAS21237,Status of sliding door rear driver side-Virtual crash redundancy sensor: sliding door,not coded / not installed,
MAS19777-MAS06430,Status of sliding door passenger side rear-Main notch contact of rotary latch,not coded / not installed,
MAS19777-MAS15328,Status of sliding door passenger side rear-Interior door handle switch,Not available,
MAS19777-MAS19403,Status of sliding door passenger side rear-Rear Passenger Exterior Door Handle Switch: status,Not available,
MAS19777-MAS21226,Status of sliding door passenger side rear-Mechanical separation door inside handle: status,not coded / not installed,
MAS19777-MAS21227,Status of sliding door passenger side rear-Motor for safe: child safety: and crash activation,not coded / not installed,
MAS19777-MAS21228,Status of sliding door passenger side rear-Rotary motor: activation,not coded / not installed,
MAS19777-MAS21237,Status of sliding door passenger side rear-Virtual crash redundancy sensor: sliding door,not coded / not installed,
MAS25323,Ambient lighting: error locations,not installed,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,41,
ENG277599,ASIL_relevante_RDIDs,|Adapted values/adaptation,Status of adaptation|0A 72,RDID_written|11 E3,RDID_written|11 E4,RDID_written|11 E5,RDID_written|11 E6,RDID_written|11 E7,RDID_written|11 01,RDID_written|11 20,RDID_written|0A 30,RDID_written|13 26,RDID_written|11 0A,RDID_written|11 0C,RDID_written|13 20,RDID_written|13 21,RDID_written|13 23,RDID_written|13 2F,RDID_written|13 3A,RDID_written|11 21,RDID_not_written|05 50,RDID_written|05 51,RDID_written|05 52,RDID_written|05 53,RDID_written|05 54,RDID_written|05 55,RDID_written|05 56,RDID_written|05 57,RDID_written|05 58,RDID_written|05 59,RDID_written|05 5A,RDID_written|05 5B,RDID_written|05 62,RDID_written|05 63,RDID_written|05 64,RDID_written|05 65,RDID_written|05 66,RDID_written|05 67,RDID_written|05 68,RDID_written|05 69,RDID_written|05 5F,RDID_written|12 01,RDID_not_written|0A 61,RDID_not_written|,
ENG254556-MAS09527,Control_voltage_actual_value-Activation voltage: act. value,0.0, V
ENG254556-MAS10074,Control_voltage_actual_value-Supply voltage: actual value,0.0, V
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG263729,Dataset_download_written_rdids,|ID data set,Number,Record Data Identifier|72 00,6,0A 72 11 E3 11 E4 11 E5 11 E6 11 E7 00 00 00 00 00 00 00 00|72 02,2,11 01 11 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 03,12,05 50 05 51 05 52 05 53 05 54 05 55 05 56 05 57 05 58 05 59|72 04,8,05 62 05 63 05 64 05 65 05 66 05 67 05 68 05 69 00 00 00 00|72 05,3,13 51 13 53 13 58 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 06,7,13 40 13 41 12 E2 12 E3 12 E4 12 E5 12 EC 00 00 00 00 00 00|72 07,1,12 E6 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 08,1,12 E7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 09,1,12 E8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 0A,6,13 60 12 E9 12 EA 12 EB 12 ED 12 EF 00 00 00 00 00 00 00 00|72 0B,20,0A 64 05 10 05 11 05 12 05 13 05 14 05 15 05 16 05 17 05 18|72 0C,5,11 EA 11 E0 11 E8 11 E9 11 EB 00 00 00 00 00 00 00 00 00 00|72 0E,1,11 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 12,1,11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 27,2,0D 20 11 E2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 2B,3,13 52 13 50 13 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 35,1,10 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 36,2,0A 30 13 26 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|72 37,8,11 0C 11 0A 05 5F 13 20 13 21 13 2F 13 23 13 3A 00 00 00 00|,
ENG286564,Easy_open_HBFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG286565,Easy_open_HFS_unavailable_reason,Sensor-controlled tailgate opening: not coded,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,493, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,94, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,4.0008, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,10100,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,62008,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|ID number,Authentication,Functions,Configuration,Preconditions met,Individualization characteristic,Cancellation,Release code for a SWaP function|10 02 0E 00,Condition met,Not available,not OK,Condition met,valid,No,Available|10 02 0F 00,Condition met,Not available,not OK,Condition met,valid,Yes,Available|10 02 08 00,Condition met,Not available,not OK,Condition met,valid,Yes,Available|,
ENG254754,Kessy_deactivation_at_oru_access,|Duration_kessy_deactivation,Year,Month,Day,Hours,Minutes,Seconds|0.0,2000,0,0,0,0,0|0.0,2000,0,0,0,0,0|0.0,2000,0,0,0,0,0|0.0,2000,0,0,0,0,0|0.0,2000,0,0,0,0,0|,
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 00 00 00 00 00 00,
ENG121906,Last_LIN_Message_Kessy,00 00 00 00 00 00 00 00,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 00 00 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 00 00 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 00 00 00 00,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,Communication,
ENG116909-ENG256024,LIN activity-LIN 11,not coded / not installed,
ENG116909-ENG256025,LIN activity-LIN 12,not coded / not installed,
ENG116909-ENG256026,LIN activity-LIN 13,not coded / not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded / not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,not coded / not installed,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Communication,
ENG116909-ENG256030,LIN activity-LIN 7,not coded / not installed,
ENG116909-ENG256031,LIN activity-LIN 8,not coded / not installed,
ENG116909-ENG256032,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,10100,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,803.3273, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,19.96,
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,19.96,
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,19.96,
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,12.37, V
ENG254795,Personalized_Signals_2_0,|Current profile slot number for customization,Customization control command,Perso_Steuerungs_parameter,Status of personalization,Control point customization,Enable customization adjustment,Month,Day,Hours,Minutes|Personalization of user account 1,no control,No user account,Customization coded 2.x,Initial value,Enabled,0,0,0,0|Personalization of user account 1,no control,No user account,no customization,Initial value,Enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|No user account,no control,No user account,no customization,Initial value,not enabled,0,0,0,0|,
ENG263737,Play_Protection_Counter_Automatic_Function,not active,
ENG263737,Play_Protection_Counter_Automatic_Function,0,
ENG116792,Power up history,|Funktionsanforderung|10|1|13|10|0|0|0|0|0|0|,
ENG116803-ENG115714,RLS_Incidence_Counter-counter_asic,0,
ENG116803-ENG115715,RLS_Incidence_Counter-counter_cpu,0,
ENG116803-ENG115718,RLS_Incidence_Counter-counter_dew,0,
ENG116803-ENG115719,RLS_Incidence_Counter-counter_dew_com,0,
ENG116803-ENG115717,RLS_Incidence_Counter-counter_hum,0,
ENG116803-ENG115709,RLS_Incidence_Counter-counter_light,0,
ENG116803-ENG115711,RLS_Incidence_Counter-counter_memory,0,
ENG116803-ENG115710,RLS_Incidence_Counter-counter_program_sequence,0,
ENG116803-ENG115708,RLS_Incidence_Counter-counter_rain,0,
ENG116803-ENG115716,RLS_Incidence_Counter-counter_temp,0,
ENG116803-ENG115712,RLS_Incidence_Counter-counter_voltage_supply,0,
ENG116803-ENG115713,RLS_Incidence_Counter-counter_wdg,0,
ENG116789-ENG115644,RLS_Rain_Sensor_Off_Justage-Achsenabschnitt,12, s
ENG116789-ENG115643,RLS_Rain_Sensor_Off_Justage-Intervallpause,16, s
ENG116789-ENG98937,RLS_Rain_Sensor_Off_Justage-Slope,-0.04, km/(h s)
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,51,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,17,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,255,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,0,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,12.4, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,39, C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,800.1798, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,37,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,1,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,64,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,15,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,14.7, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,23, C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,795.6816, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,31,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,76,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,64,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,255,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,12.2, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,22, C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,795.6816, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,27,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,19,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,11,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,112,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,13.1, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,29, C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,767.5262, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,36,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,2,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,160,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,11.5, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,34, C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,662.9014, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,52,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,4,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,64,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,14.6, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,22, C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,505.2978, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,34,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,5,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,64,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,12,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,14.3, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,19, C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,7.6636, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG254816,Snapshot_DTC_Notlaufpfad,No malfunction,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254822,Status_automatic_function,Conditions_cyclic_scan_not_fullfilled,
ENG254825,steuergeraetinterne_Messwert,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-kilometer reading,17651, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.9, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.6, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,12.4, V
ENG254842,UWB_box2box_measure_history,|Box2box_measurement_reason,Checked_rsad_node_box2box_measurement,Time_measurement,Year,Month,Day,Hours,Minutes,Seconds|Default,Default,0,2000,0,0,0,0,0|Default,Default,0,2000,0,0,0,0,0|Default,Default,0,2000,0,0,0,0,0|Default,Default,0,2000,0,0,0,0,0|Default,Default,0,2000,0,0,0,0,0|,
ENG254843-ENG256296,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_hl,0,
ENG254843-ENG256297,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_hr,0,
ENG254843-ENG256298,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_in,0,
ENG254843-ENG256299,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_vl,0,
ENG254843-ENG256300,UWB_number_of_box2box_measurements_rsad_nodes-RSAD_node_vr,0,
ENG122921-ENG121628,values_motorloads-mod_temp_fast,36, C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,40, C
ENG122921-ENG121629,values_motorloads-temp_pcb,37, C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),10187,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,12.3312, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,21.9,
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,2888979.005, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,52180.026, C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1348101225,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,21.9,
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210,
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.9936,
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,21.9,
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,51,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0,
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,2879508.485, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,163.7,
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,12.3894, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,39.146, C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,24.0,
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,63 7F 94 4C 19 4A 14 BD A1 67 A7 9D,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,40,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 37 34 35 33 46 30 34 30 32 31 31 38 31 30 38 37 30 37,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,5886,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,5886,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,640,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,240,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,7640,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,176,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,114,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,194,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,96,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,110,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,1617,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,23078.832557, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,23091.760471, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,596.026425, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,3815,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,6409,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-60, C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,126, C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.5, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,0,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,5344,
Elapsed Time: 01:37
;SW:5H0-920-340-B HW:5H0-920-340-B --- 17: Instruments
;Component:KOMBI 220 5350, Coding:08BC0442638CCF050280220B2000000820300400
;EV_DashBoardVDDMQB37W,003033,EV_DashBoardVDDMQB37W_003_VW38.rod
;Tuesday,01,September,2026,19:07:10:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 21183A0051454742C8E-8074 SFD [x]
IDE00301-Distance,30921 km,3
IDE00343-Language variant,US English ,1
IDE00711-Trip recorder,not installed ,1
IDE00819-Day counter,1722 d,2
IDE00820-ENG98466-Activating and deactivating all development messages-CAN,not active ,1
IDE00820-ENG148062-Activating and deactivating all development messages-Ethernet,not active ,1
IDE02332-Disable Production Mode,0 ,3
IDE02489-Display depiction,Variant 1 ,1
IDE03346-IDE00301-Units adjusted-Distance,miles ,3
IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
IDE03346-MAS02201-Units adjusted-Temperature, F ,3
IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
IDE03346-MAS03034-Units adjusted-Pressure,psi ,3
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
IDE03348-MAS01456-Speed warning-Speed,0 ,2
IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG262858-Service-key settings-p_deactivate_SK-Sub_Function_Current_Data,On ,5
IDE03568-ENG262855-Service-key settings-p_deactivate_SK-Sub_Function_Daily_Data,On ,5
IDE03568-ENG102019-Service-key settings-p_main_switch_basis,OFF ,5
IDE11472-IDE03360-Configuration of displayable contents-Upshift display in center panel,No display ,4
IDE11472-IDE12722-Configuration of displayable contents-Driving profile display,No display ,4
IDE11472-MAS01833-Configuration of displayable contents-Charge air pressure,active ,4
IDE11472-MAS03555-Configuration of displayable contents-Lap counter,not active ,4
IDE11472-MAS05424-Configuration of displayable contents-Natural gas quality,No display ,4
IDE11472-MAS05757-Configuration of displayable contents-Engine torque,not active ,4
IDE11472-MAS14767-Configuration of displayable contents-Convenience tire pressure warning display,No display ,4
IDE11472-MAS15298-Configuration of displayable contents-Night vision system automatic triggering,not active ,4
IDE11472-MAS18773-Configuration of displayable contents-Acceleration measurement,No display ,4
IDE11472-MAS18774-Configuration of displayable contents-Drag indicator,No display ,4
IDE11472-MAS19086-Configuration of displayable contents-Charge symbol color,Standard ,4
IDE11472-MAS19327-Configuration of displayable contents-Engine performance,active ,4
IDE11472-MAS19328-Configuration of displayable contents-Transmission temperature,active ,4
IDE11472-MAS19329-Configuration of displayable contents-G-meter,active ,4
IDE11472-MAS19330-Configuration of displayable contents-Torque distribution,not active ,4
IDE12050-Acoustic: drive position R,active ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
IDE12792-IDE00301-Personalization of user account 1-Distance,Kilometres ,70
IDE12792-MAS01230-Personalization of user account 1-Date,mm_dd_yy ,70
IDE12792-MAS01456-Personalization of user account 1-Speed,Miles per hour ,70
IDE12792-MAS02201-Personalization of user account 1-Temperature, F ,70
IDE12792-MAS02957-Personalization of user account 1-Time,12h AM_PM ,70
IDE12792-MAS03032-Personalization of user account 1-Volume,gallons (US) ,70
IDE12792-MAS03034-Personalization of user account 1-Pressure,psi ,70
IDE12792-MAS05637-Personalization of user account 1-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12792-MAS05638-Personalization of user account 1-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12792-MAS05875-Personalization of user account 1-Average consumption: electric drive,kWh per 100 km ,70
IDE12792-Personalization of user account 1-,not active ,70
IDE12792-ENG154881-Personalization of user account 1-Active_design,0 ,70
IDE12792-ENG154882-Personalization of user account 1-Active_view,0 ,70
IDE12792-ENG155000-Personalization of user account 1-DC_aktiverSpeicherplatz,0 ,70
IDE12792-ENG155001-Personalization of user account 1-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12792-ENG155002-Personalization of user account 1-DC_linkeTubeninformation,00 ,70
IDE12792-ENG155003-Personalization of user account 1-DC_rechteTubeninformation,00 ,70
IDE12792-ENG155004-Personalization of user account 1-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155005-Personalization of user account 1-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155006-Personalization of user account 1-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155007-Personalization of user account 1-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155008-Personalization of user account 1-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12792-ENG155009-Personalization of user account 1-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12792-ENG155051-Personalization of user account 1-Display_Average_Consumption,active ,70
IDE12792-ENG155052-Personalization of user account 1-Display_Average_Speed,active ,70
IDE12792-ENG155053-Personalization of user account 1-Display_ComfortPowerConsumption,not active ,70
IDE12792-ENG155054-Personalization of user account 1-Display_ConsumerList,not active ,70
IDE12792-ENG155055-Personalization of user account 1-Display_CoolantTemperature,not active ,70
IDE12792-ENG155056-Personalization of user account 1-Display_CurrentConsumption,active ,70
IDE12792-ENG155057-Personalization of user account 1-Display_DigitalSpeedometer,active ,70
IDE12792-ENG155058-Personalization of user account 1-Display_Distance,active ,70
IDE12792-ENG155059-Personalization of user account 1-Display_DrivingTime,active ,70
IDE12792-ENG155060-Personalization of user account 1-Display_DualSpeedometer,not active ,70
IDE12792-ENG155061-Personalization of user account 1-Display_Laptimer,not active ,70
IDE12792-ENG155062-Personalization of user account 1-Display_LiveTips,not active ,70
IDE12792-ENG155063-Personalization of user account 1-Display_Nachtankmenge,not active ,70
IDE12792-ENG155064-Personalization of user account 1-Display_OilTemperature,active ,70
IDE12792-ENG155065-Personalization of user account 1-Display_Range,active ,70
IDE12792-ENG155066-Personalization of user account 1-Display_ResetTime,not active ,70
IDE12792-ENG155067-Personalization of user account 1-Display_SpeedWarning,not active ,70
IDE12792-ENG155068-Personalization of user account 1-Display_VZA,active ,70
IDE12792-ENG155069-Personalization of user account 1-Display_ZeroEmission_Distance,not active ,70
IDE12792-ENG155070-Personalization of user account 1-Display_ZeroEmission_Time,not active ,70
IDE12792-ENG155246-Personalization of user account 1-LastMode_HMI_global_active_layout,3 ,70
IDE12792-ENG155247-Personalization of user account 1-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12792-ENG155248-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12792-ENG155249-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12792-ENG155250-Personalization of user account 1-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12792-ENG155251-Personalization of user account 1-LastMode_HMI_HistoryState_main,0 ,70
IDE12792-ENG155252-Personalization of user account 1-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12792-ENG155253-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12792-ENG155254-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12792-ENG155255-Personalization of user account 1-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12792-ENG155256-Personalization of user account 1-LastMode_HMI_HistoryState_sport,0 ,70
IDE12792-ENG155257-Personalization of user account 1-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12792-ENG155258-Personalization of user account 1-LastMode_HMI_MFA_store,0 ,70
IDE12792-ENG155259-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12792-ENG155260-Personalization of user account 1-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12792-ENG155261-Personalization of user account 1-LastMode_v_Kunde_aktiv,not active ,70
IDE12792-ENG155262-Personalization of user account 1-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12792-ENG155263-Personalization of user account 1-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12792-ENG262859-Personalization of user account 1-speed_value,0 ,70
IDE12792-ENG263509-Personalization of user account 1-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12794-IDE00301-Personalization of user account 2-Distance,Kilometres ,70
IDE12794-MAS01230-Personalization of user account 2-Date,mm_dd_yy ,70
IDE12794-MAS01456-Personalization of user account 2-Speed,Miles per hour ,70
IDE12794-MAS02201-Personalization of user account 2-Temperature, F ,70
IDE12794-MAS02957-Personalization of user account 2-Time,12h AM_PM ,70
IDE12794-MAS03032-Personalization of user account 2-Volume,gallons (US) ,70
IDE12794-MAS03034-Personalization of user account 2-Pressure,psi ,70
IDE12794-MAS05637-Personalization of user account 2-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12794-MAS05638-Personalization of user account 2-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12794-MAS05875-Personalization of user account 2-Average consumption: electric drive,kWh per 100 km ,70
IDE12794-Personalization of user account 2-,not active ,70
IDE12794-ENG154881-Personalization of user account 2-Active_design,0 ,70
IDE12794-ENG154882-Personalization of user account 2-Active_view,0 ,70
IDE12794-ENG155000-Personalization of user account 2-DC_aktiverSpeicherplatz,0 ,70
IDE12794-ENG155001-Personalization of user account 2-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12794-ENG155002-Personalization of user account 2-DC_linkeTubeninformation,00 ,70
IDE12794-ENG155003-Personalization of user account 2-DC_rechteTubeninformation,00 ,70
IDE12794-ENG155004-Personalization of user account 2-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155005-Personalization of user account 2-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155006-Personalization of user account 2-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155007-Personalization of user account 2-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155008-Personalization of user account 2-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12794-ENG155009-Personalization of user account 2-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12794-ENG155051-Personalization of user account 2-Display_Average_Consumption,active ,70
IDE12794-ENG155052-Personalization of user account 2-Display_Average_Speed,active ,70
IDE12794-ENG155053-Personalization of user account 2-Display_ComfortPowerConsumption,not active ,70
IDE12794-ENG155054-Personalization of user account 2-Display_ConsumerList,not active ,70
IDE12794-ENG155055-Personalization of user account 2-Display_CoolantTemperature,not active ,70
IDE12794-ENG155056-Personalization of user account 2-Display_CurrentConsumption,active ,70
IDE12794-ENG155057-Personalization of user account 2-Display_DigitalSpeedometer,active ,70
IDE12794-ENG155058-Personalization of user account 2-Display_Distance,active ,70
IDE12794-ENG155059-Personalization of user account 2-Display_DrivingTime,active ,70
IDE12794-ENG155060-Personalization of user account 2-Display_DualSpeedometer,not active ,70
IDE12794-ENG155061-Personalization of user account 2-Display_Laptimer,not active ,70
IDE12794-ENG155062-Personalization of user account 2-Display_LiveTips,not active ,70
IDE12794-ENG155063-Personalization of user account 2-Display_Nachtankmenge,not active ,70
IDE12794-ENG155064-Personalization of user account 2-Display_OilTemperature,active ,70
IDE12794-ENG155065-Personalization of user account 2-Display_Range,active ,70
IDE12794-ENG155066-Personalization of user account 2-Display_ResetTime,not active ,70
IDE12794-ENG155067-Personalization of user account 2-Display_SpeedWarning,not active ,70
IDE12794-ENG155068-Personalization of user account 2-Display_VZA,active ,70
IDE12794-ENG155069-Personalization of user account 2-Display_ZeroEmission_Distance,not active ,70
IDE12794-ENG155070-Personalization of user account 2-Display_ZeroEmission_Time,not active ,70
IDE12794-ENG155246-Personalization of user account 2-LastMode_HMI_global_active_layout,0 ,70
IDE12794-ENG155247-Personalization of user account 2-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12794-ENG155248-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12794-ENG155249-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12794-ENG155250-Personalization of user account 2-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12794-ENG155251-Personalization of user account 2-LastMode_HMI_HistoryState_main,0 ,70
IDE12794-ENG155252-Personalization of user account 2-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12794-ENG155253-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12794-ENG155254-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12794-ENG155255-Personalization of user account 2-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12794-ENG155256-Personalization of user account 2-LastMode_HMI_HistoryState_sport,0 ,70
IDE12794-ENG155257-Personalization of user account 2-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12794-ENG155258-Personalization of user account 2-LastMode_HMI_MFA_store,0 ,70
IDE12794-ENG155259-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12794-ENG155260-Personalization of user account 2-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12794-ENG155261-Personalization of user account 2-LastMode_v_Kunde_aktiv,not active ,70
IDE12794-ENG155262-Personalization of user account 2-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12794-ENG155263-Personalization of user account 2-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12794-ENG262859-Personalization of user account 2-speed_value,0 ,70
IDE12794-ENG263509-Personalization of user account 2-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12796-IDE00301-Personalization of user account 3-Distance,Kilometres ,70
IDE12796-MAS01230-Personalization of user account 3-Date,mm_dd_yy ,70
IDE12796-MAS01456-Personalization of user account 3-Speed,Miles per hour ,70
IDE12796-MAS02201-Personalization of user account 3-Temperature, F ,70
IDE12796-MAS02957-Personalization of user account 3-Time,12h AM_PM ,70
IDE12796-MAS03032-Personalization of user account 3-Volume,gallons (US) ,70
IDE12796-MAS03034-Personalization of user account 3-Pressure,psi ,70
IDE12796-MAS05637-Personalization of user account 3-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12796-MAS05638-Personalization of user account 3-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12796-MAS05875-Personalization of user account 3-Average consumption: electric drive,kWh per 100 km ,70
IDE12796-Personalization of user account 3-,not active ,70
IDE12796-ENG154881-Personalization of user account 3-Active_design,0 ,70
IDE12796-ENG154882-Personalization of user account 3-Active_view,0 ,70
IDE12796-ENG155000-Personalization of user account 3-DC_aktiverSpeicherplatz,0 ,70
IDE12796-ENG155001-Personalization of user account 3-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12796-ENG155002-Personalization of user account 3-DC_linkeTubeninformation,00 ,70
IDE12796-ENG155003-Personalization of user account 3-DC_rechteTubeninformation,00 ,70
IDE12796-ENG155004-Personalization of user account 3-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155005-Personalization of user account 3-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155006-Personalization of user account 3-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155007-Personalization of user account 3-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155008-Personalization of user account 3-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12796-ENG155009-Personalization of user account 3-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12796-ENG155051-Personalization of user account 3-Display_Average_Consumption,active ,70
IDE12796-ENG155052-Personalization of user account 3-Display_Average_Speed,active ,70
IDE12796-ENG155053-Personalization of user account 3-Display_ComfortPowerConsumption,not active ,70
IDE12796-ENG155054-Personalization of user account 3-Display_ConsumerList,not active ,70
IDE12796-ENG155055-Personalization of user account 3-Display_CoolantTemperature,not active ,70
IDE12796-ENG155056-Personalization of user account 3-Display_CurrentConsumption,active ,70
IDE12796-ENG155057-Personalization of user account 3-Display_DigitalSpeedometer,active ,70
IDE12796-ENG155058-Personalization of user account 3-Display_Distance,active ,70
IDE12796-ENG155059-Personalization of user account 3-Display_DrivingTime,active ,70
IDE12796-ENG155060-Personalization of user account 3-Display_DualSpeedometer,not active ,70
IDE12796-ENG155061-Personalization of user account 3-Display_Laptimer,not active ,70
IDE12796-ENG155062-Personalization of user account 3-Display_LiveTips,not active ,70
IDE12796-ENG155063-Personalization of user account 3-Display_Nachtankmenge,not active ,70
IDE12796-ENG155064-Personalization of user account 3-Display_OilTemperature,active ,70
IDE12796-ENG155065-Personalization of user account 3-Display_Range,active ,70
IDE12796-ENG155066-Personalization of user account 3-Display_ResetTime,not active ,70
IDE12796-ENG155067-Personalization of user account 3-Display_SpeedWarning,not active ,70
IDE12796-ENG155068-Personalization of user account 3-Display_VZA,active ,70
IDE12796-ENG155069-Personalization of user account 3-Display_ZeroEmission_Distance,not active ,70
IDE12796-ENG155070-Personalization of user account 3-Display_ZeroEmission_Time,not active ,70
IDE12796-ENG155246-Personalization of user account 3-LastMode_HMI_global_active_layout,0 ,70
IDE12796-ENG155247-Personalization of user account 3-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12796-ENG155248-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12796-ENG155249-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12796-ENG155250-Personalization of user account 3-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12796-ENG155251-Personalization of user account 3-LastMode_HMI_HistoryState_main,0 ,70
IDE12796-ENG155252-Personalization of user account 3-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12796-ENG155253-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12796-ENG155254-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12796-ENG155255-Personalization of user account 3-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12796-ENG155256-Personalization of user account 3-LastMode_HMI_HistoryState_sport,0 ,70
IDE12796-ENG155257-Personalization of user account 3-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12796-ENG155258-Personalization of user account 3-LastMode_HMI_MFA_store,0 ,70
IDE12796-ENG155259-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12796-ENG155260-Personalization of user account 3-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12796-ENG155261-Personalization of user account 3-LastMode_v_Kunde_aktiv,not active ,70
IDE12796-ENG155262-Personalization of user account 3-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12796-ENG155263-Personalization of user account 3-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12796-ENG262859-Personalization of user account 3-speed_value,0 ,70
IDE12796-ENG263509-Personalization of user account 3-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12798-IDE00301-Personalization of user account 4-Distance,Kilometres ,70
IDE12798-MAS01230-Personalization of user account 4-Date,mm_dd_yy ,70
IDE12798-MAS01456-Personalization of user account 4-Speed,Miles per hour ,70
IDE12798-MAS02201-Personalization of user account 4-Temperature, F ,70
IDE12798-MAS02957-Personalization of user account 4-Time,12h AM_PM ,70
IDE12798-MAS03032-Personalization of user account 4-Volume,gallons (US) ,70
IDE12798-MAS03034-Personalization of user account 4-Pressure,psi ,70
IDE12798-MAS05637-Personalization of user account 4-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12798-MAS05638-Personalization of user account 4-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12798-MAS05875-Personalization of user account 4-Average consumption: electric drive,kWh per 100 km ,70
IDE12798-Personalization of user account 4-,not active ,70
IDE12798-ENG154881-Personalization of user account 4-Active_design,0 ,70
IDE12798-ENG154882-Personalization of user account 4-Active_view,0 ,70
IDE12798-ENG155000-Personalization of user account 4-DC_aktiverSpeicherplatz,0 ,70
IDE12798-ENG155001-Personalization of user account 4-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12798-ENG155002-Personalization of user account 4-DC_linkeTubeninformation,00 ,70
IDE12798-ENG155003-Personalization of user account 4-DC_rechteTubeninformation,00 ,70
IDE12798-ENG155004-Personalization of user account 4-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155005-Personalization of user account 4-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155006-Personalization of user account 4-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155007-Personalization of user account 4-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155008-Personalization of user account 4-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12798-ENG155009-Personalization of user account 4-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12798-ENG155051-Personalization of user account 4-Display_Average_Consumption,active ,70
IDE12798-ENG155052-Personalization of user account 4-Display_Average_Speed,active ,70
IDE12798-ENG155053-Personalization of user account 4-Display_ComfortPowerConsumption,not active ,70
IDE12798-ENG155054-Personalization of user account 4-Display_ConsumerList,not active ,70
IDE12798-ENG155055-Personalization of user account 4-Display_CoolantTemperature,not active ,70
IDE12798-ENG155056-Personalization of user account 4-Display_CurrentConsumption,active ,70
IDE12798-ENG155057-Personalization of user account 4-Display_DigitalSpeedometer,active ,70
IDE12798-ENG155058-Personalization of user account 4-Display_Distance,active ,70
IDE12798-ENG155059-Personalization of user account 4-Display_DrivingTime,active ,70
IDE12798-ENG155060-Personalization of user account 4-Display_DualSpeedometer,not active ,70
IDE12798-ENG155061-Personalization of user account 4-Display_Laptimer,not active ,70
IDE12798-ENG155062-Personalization of user account 4-Display_LiveTips,not active ,70
IDE12798-ENG155063-Personalization of user account 4-Display_Nachtankmenge,not active ,70
IDE12798-ENG155064-Personalization of user account 4-Display_OilTemperature,active ,70
IDE12798-ENG155065-Personalization of user account 4-Display_Range,active ,70
IDE12798-ENG155066-Personalization of user account 4-Display_ResetTime,not active ,70
IDE12798-ENG155067-Personalization of user account 4-Display_SpeedWarning,not active ,70
IDE12798-ENG155068-Personalization of user account 4-Display_VZA,active ,70
IDE12798-ENG155069-Personalization of user account 4-Display_ZeroEmission_Distance,not active ,70
IDE12798-ENG155070-Personalization of user account 4-Display_ZeroEmission_Time,not active ,70
IDE12798-ENG155246-Personalization of user account 4-LastMode_HMI_global_active_layout,0 ,70
IDE12798-ENG155247-Personalization of user account 4-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12798-ENG155248-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12798-ENG155249-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12798-ENG155250-Personalization of user account 4-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12798-ENG155251-Personalization of user account 4-LastMode_HMI_HistoryState_main,0 ,70
IDE12798-ENG155252-Personalization of user account 4-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12798-ENG155253-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12798-ENG155254-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12798-ENG155255-Personalization of user account 4-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12798-ENG155256-Personalization of user account 4-LastMode_HMI_HistoryState_sport,0 ,70
IDE12798-ENG155257-Personalization of user account 4-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12798-ENG155258-Personalization of user account 4-LastMode_HMI_MFA_store,0 ,70
IDE12798-ENG155259-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12798-ENG155260-Personalization of user account 4-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12798-ENG155261-Personalization of user account 4-LastMode_v_Kunde_aktiv,not active ,70
IDE12798-ENG155262-Personalization of user account 4-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12798-ENG155263-Personalization of user account 4-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12798-ENG262859-Personalization of user account 4-speed_value,0 ,70
IDE12798-ENG263509-Personalization of user account 4-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12800-IDE00301-Personalization of user account 5-Distance,Kilometres ,70
IDE12800-MAS01230-Personalization of user account 5-Date,mm_dd_yy ,70
IDE12800-MAS01456-Personalization of user account 5-Speed,Miles per hour ,70
IDE12800-MAS02201-Personalization of user account 5-Temperature, F ,70
IDE12800-MAS02957-Personalization of user account 5-Time,12h AM_PM ,70
IDE12800-MAS03032-Personalization of user account 5-Volume,gallons (US) ,70
IDE12800-MAS03034-Personalization of user account 5-Pressure,psi ,70
IDE12800-MAS05637-Personalization of user account 5-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12800-MAS05638-Personalization of user account 5-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12800-MAS05875-Personalization of user account 5-Average consumption: electric drive,kWh per 100 km ,70
IDE12800-Personalization of user account 5-,not active ,70
IDE12800-ENG154881-Personalization of user account 5-Active_design,0 ,70
IDE12800-ENG154882-Personalization of user account 5-Active_view,0 ,70
IDE12800-ENG155000-Personalization of user account 5-DC_aktiverSpeicherplatz,0 ,70
IDE12800-ENG155001-Personalization of user account 5-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12800-ENG155002-Personalization of user account 5-DC_linkeTubeninformation,00 ,70
IDE12800-ENG155003-Personalization of user account 5-DC_rechteTubeninformation,00 ,70
IDE12800-ENG155004-Personalization of user account 5-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155005-Personalization of user account 5-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155006-Personalization of user account 5-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155007-Personalization of user account 5-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155008-Personalization of user account 5-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12800-ENG155009-Personalization of user account 5-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12800-ENG155051-Personalization of user account 5-Display_Average_Consumption,active ,70
IDE12800-ENG155052-Personalization of user account 5-Display_Average_Speed,active ,70
IDE12800-ENG155053-Personalization of user account 5-Display_ComfortPowerConsumption,not active ,70
IDE12800-ENG155054-Personalization of user account 5-Display_ConsumerList,not active ,70
IDE12800-ENG155055-Personalization of user account 5-Display_CoolantTemperature,not active ,70
IDE12800-ENG155056-Personalization of user account 5-Display_CurrentConsumption,active ,70
IDE12800-ENG155057-Personalization of user account 5-Display_DigitalSpeedometer,active ,70
IDE12800-ENG155058-Personalization of user account 5-Display_Distance,active ,70
IDE12800-ENG155059-Personalization of user account 5-Display_DrivingTime,active ,70
IDE12800-ENG155060-Personalization of user account 5-Display_DualSpeedometer,not active ,70
IDE12800-ENG155061-Personalization of user account 5-Display_Laptimer,not active ,70
IDE12800-ENG155062-Personalization of user account 5-Display_LiveTips,not active ,70
IDE12800-ENG155063-Personalization of user account 5-Display_Nachtankmenge,not active ,70
IDE12800-ENG155064-Personalization of user account 5-Display_OilTemperature,active ,70
IDE12800-ENG155065-Personalization of user account 5-Display_Range,active ,70
IDE12800-ENG155066-Personalization of user account 5-Display_ResetTime,not active ,70
IDE12800-ENG155067-Personalization of user account 5-Display_SpeedWarning,not active ,70
IDE12800-ENG155068-Personalization of user account 5-Display_VZA,active ,70
IDE12800-ENG155069-Personalization of user account 5-Display_ZeroEmission_Distance,not active ,70
IDE12800-ENG155070-Personalization of user account 5-Display_ZeroEmission_Time,not active ,70
IDE12800-ENG155246-Personalization of user account 5-LastMode_HMI_global_active_layout,0 ,70
IDE12800-ENG155247-Personalization of user account 5-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12800-ENG155248-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12800-ENG155249-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12800-ENG155250-Personalization of user account 5-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12800-ENG155251-Personalization of user account 5-LastMode_HMI_HistoryState_main,0 ,70
IDE12800-ENG155252-Personalization of user account 5-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12800-ENG155253-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12800-ENG155254-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12800-ENG155255-Personalization of user account 5-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12800-ENG155256-Personalization of user account 5-LastMode_HMI_HistoryState_sport,0 ,70
IDE12800-ENG155257-Personalization of user account 5-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12800-ENG155258-Personalization of user account 5-LastMode_HMI_MFA_store,0 ,70
IDE12800-ENG155259-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12800-ENG155260-Personalization of user account 5-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12800-ENG155261-Personalization of user account 5-LastMode_v_Kunde_aktiv,not active ,70
IDE12800-ENG155262-Personalization of user account 5-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12800-ENG155263-Personalization of user account 5-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12800-ENG262859-Personalization of user account 5-speed_value,0 ,70
IDE12800-ENG263509-Personalization of user account 5-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12802-IDE00301-Personalization of user account 6-Distance,Kilometres ,70
IDE12802-MAS01230-Personalization of user account 6-Date,mm_dd_yy ,70
IDE12802-MAS01456-Personalization of user account 6-Speed,Miles per hour ,70
IDE12802-MAS02201-Personalization of user account 6-Temperature, F ,70
IDE12802-MAS02957-Personalization of user account 6-Time,12h AM_PM ,70
IDE12802-MAS03032-Personalization of user account 6-Volume,gallons (US) ,70
IDE12802-MAS03034-Personalization of user account 6-Pressure,psi ,70
IDE12802-MAS05637-Personalization of user account 6-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12802-MAS05638-Personalization of user account 6-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12802-MAS05875-Personalization of user account 6-Average consumption: electric drive,kWh per 100 km ,70
IDE12802-Personalization of user account 6-,not active ,70
IDE12802-ENG154881-Personalization of user account 6-Active_design,0 ,70
IDE12802-ENG154882-Personalization of user account 6-Active_view,0 ,70
IDE12802-ENG155000-Personalization of user account 6-DC_aktiverSpeicherplatz,0 ,70
IDE12802-ENG155001-Personalization of user account 6-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12802-ENG155002-Personalization of user account 6-DC_linkeTubeninformation,00 ,70
IDE12802-ENG155003-Personalization of user account 6-DC_rechteTubeninformation,00 ,70
IDE12802-ENG155004-Personalization of user account 6-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155005-Personalization of user account 6-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155006-Personalization of user account 6-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155007-Personalization of user account 6-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155008-Personalization of user account 6-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12802-ENG155009-Personalization of user account 6-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12802-ENG155051-Personalization of user account 6-Display_Average_Consumption,active ,70
IDE12802-ENG155052-Personalization of user account 6-Display_Average_Speed,active ,70
IDE12802-ENG155053-Personalization of user account 6-Display_ComfortPowerConsumption,not active ,70
IDE12802-ENG155054-Personalization of user account 6-Display_ConsumerList,not active ,70
IDE12802-ENG155055-Personalization of user account 6-Display_CoolantTemperature,not active ,70
IDE12802-ENG155056-Personalization of user account 6-Display_CurrentConsumption,active ,70
IDE12802-ENG155057-Personalization of user account 6-Display_DigitalSpeedometer,active ,70
IDE12802-ENG155058-Personalization of user account 6-Display_Distance,active ,70
IDE12802-ENG155059-Personalization of user account 6-Display_DrivingTime,active ,70
IDE12802-ENG155060-Personalization of user account 6-Display_DualSpeedometer,not active ,70
IDE12802-ENG155061-Personalization of user account 6-Display_Laptimer,not active ,70
IDE12802-ENG155062-Personalization of user account 6-Display_LiveTips,not active ,70
IDE12802-ENG155063-Personalization of user account 6-Display_Nachtankmenge,not active ,70
IDE12802-ENG155064-Personalization of user account 6-Display_OilTemperature,active ,70
IDE12802-ENG155065-Personalization of user account 6-Display_Range,active ,70
IDE12802-ENG155066-Personalization of user account 6-Display_ResetTime,not active ,70
IDE12802-ENG155067-Personalization of user account 6-Display_SpeedWarning,not active ,70
IDE12802-ENG155068-Personalization of user account 6-Display_VZA,active ,70
IDE12802-ENG155069-Personalization of user account 6-Display_ZeroEmission_Distance,not active ,70
IDE12802-ENG155070-Personalization of user account 6-Display_ZeroEmission_Time,not active ,70
IDE12802-ENG155246-Personalization of user account 6-LastMode_HMI_global_active_layout,0 ,70
IDE12802-ENG155247-Personalization of user account 6-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12802-ENG155248-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12802-ENG155249-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12802-ENG155250-Personalization of user account 6-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12802-ENG155251-Personalization of user account 6-LastMode_HMI_HistoryState_main,0 ,70
IDE12802-ENG155252-Personalization of user account 6-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12802-ENG155253-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12802-ENG155254-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12802-ENG155255-Personalization of user account 6-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12802-ENG155256-Personalization of user account 6-LastMode_HMI_HistoryState_sport,0 ,70
IDE12802-ENG155257-Personalization of user account 6-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12802-ENG155258-Personalization of user account 6-LastMode_HMI_MFA_store,0 ,70
IDE12802-ENG155259-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12802-ENG155260-Personalization of user account 6-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12802-ENG155261-Personalization of user account 6-LastMode_v_Kunde_aktiv,not active ,70
IDE12802-ENG155262-Personalization of user account 6-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12802-ENG155263-Personalization of user account 6-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12802-ENG262859-Personalization of user account 6-speed_value,0 ,70
IDE12802-ENG263509-Personalization of user account 6-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12804-IDE00301-Personalization of user account 7-Distance,Kilometres ,70
IDE12804-MAS01230-Personalization of user account 7-Date,mm_dd_yy ,70
IDE12804-MAS01456-Personalization of user account 7-Speed,Miles per hour ,70
IDE12804-MAS02201-Personalization of user account 7-Temperature, F ,70
IDE12804-MAS02957-Personalization of user account 7-Time,12h AM_PM ,70
IDE12804-MAS03032-Personalization of user account 7-Volume,gallons (US) ,70
IDE12804-MAS03034-Personalization of user account 7-Pressure,psi ,70
IDE12804-MAS05637-Personalization of user account 7-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE12804-MAS05638-Personalization of user account 7-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE12804-MAS05875-Personalization of user account 7-Average consumption: electric drive,kWh per 100 km ,70
IDE12804-Personalization of user account 7-,not active ,70
IDE12804-ENG154881-Personalization of user account 7-Active_design,0 ,70
IDE12804-ENG154882-Personalization of user account 7-Active_view,0 ,70
IDE12804-ENG155000-Personalization of user account 7-DC_aktiverSpeicherplatz,0 ,70
IDE12804-ENG155001-Personalization of user account 7-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE12804-ENG155002-Personalization of user account 7-DC_linkeTubeninformation,00 ,70
IDE12804-ENG155003-Personalization of user account 7-DC_rechteTubeninformation,00 ,70
IDE12804-ENG155004-Personalization of user account 7-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155005-Personalization of user account 7-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155006-Personalization of user account 7-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155007-Personalization of user account 7-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155008-Personalization of user account 7-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE12804-ENG155009-Personalization of user account 7-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE12804-ENG155051-Personalization of user account 7-Display_Average_Consumption,active ,70
IDE12804-ENG155052-Personalization of user account 7-Display_Average_Speed,active ,70
IDE12804-ENG155053-Personalization of user account 7-Display_ComfortPowerConsumption,not active ,70
IDE12804-ENG155054-Personalization of user account 7-Display_ConsumerList,not active ,70
IDE12804-ENG155055-Personalization of user account 7-Display_CoolantTemperature,not active ,70
IDE12804-ENG155056-Personalization of user account 7-Display_CurrentConsumption,active ,70
IDE12804-ENG155057-Personalization of user account 7-Display_DigitalSpeedometer,active ,70
IDE12804-ENG155058-Personalization of user account 7-Display_Distance,active ,70
IDE12804-ENG155059-Personalization of user account 7-Display_DrivingTime,active ,70
IDE12804-ENG155060-Personalization of user account 7-Display_DualSpeedometer,not active ,70
IDE12804-ENG155061-Personalization of user account 7-Display_Laptimer,not active ,70
IDE12804-ENG155062-Personalization of user account 7-Display_LiveTips,not active ,70
IDE12804-ENG155063-Personalization of user account 7-Display_Nachtankmenge,not active ,70
IDE12804-ENG155064-Personalization of user account 7-Display_OilTemperature,active ,70
IDE12804-ENG155065-Personalization of user account 7-Display_Range,active ,70
IDE12804-ENG155066-Personalization of user account 7-Display_ResetTime,not active ,70
IDE12804-ENG155067-Personalization of user account 7-Display_SpeedWarning,not active ,70
IDE12804-ENG155068-Personalization of user account 7-Display_VZA,active ,70
IDE12804-ENG155069-Personalization of user account 7-Display_ZeroEmission_Distance,not active ,70
IDE12804-ENG155070-Personalization of user account 7-Display_ZeroEmission_Time,not active ,70
IDE12804-ENG155246-Personalization of user account 7-LastMode_HMI_global_active_layout,0 ,70
IDE12804-ENG155247-Personalization of user account 7-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE12804-ENG155248-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE12804-ENG155249-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE12804-ENG155250-Personalization of user account 7-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE12804-ENG155251-Personalization of user account 7-LastMode_HMI_HistoryState_main,0 ,70
IDE12804-ENG155252-Personalization of user account 7-LastMode_HMI_HistoryState_mfa,0 ,70
IDE12804-ENG155253-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE12804-ENG155254-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE12804-ENG155255-Personalization of user account 7-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE12804-ENG155256-Personalization of user account 7-LastMode_HMI_HistoryState_sport,0 ,70
IDE12804-ENG155257-Personalization of user account 7-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,0 ,70
IDE12804-ENG155258-Personalization of user account 7-LastMode_HMI_MFA_store,0 ,70
IDE12804-ENG155259-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE12804-ENG155260-Personalization of user account 7-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE12804-ENG155261-Personalization of user account 7-LastMode_v_Kunde_aktiv,not active ,70
IDE12804-ENG155262-Personalization of user account 7-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE12804-ENG155263-Personalization of user account 7-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE12804-ENG262859-Personalization of user account 7-speed_value,0 ,70
IDE12804-ENG263509-Personalization of user account 7-Speed_warning_unit_mph_/kmh,Kilometers per hour ,70
IDE12960-Resetting oil service,no warning ,1
IDE12961-Oil quality,poor oil quality ,1
IDE12962-Oil: soot entry,0 km,2
IDE12963-Oil: thermal loading,10100 km,2
IDE12964-Oil: driven distance since last oil service,7700 km,3
IDE12965-Oil: time since last oil service,121 d,2
IDE12966-Oil: min distance until next oil service (flexible interval),15000 km,2
IDE12967-Oil: max. distance until next oil service (flexible interval),30000 km,2
IDE12968-Oil: min time until next oil service (flexible interval),365 d,2
IDE12969-Oil: max time until next oil service (flexible interval),730 d,2
IDE12970-Oil: distance until next oil service (fixed interval),16100 km,2
IDE12971-Oil: time until next oil service (fixed interval),365 d,2
IDE12978-Inspection: distance until next inspection,32200 km,3
IDE12979-Inspection: time until next inspection,365 d,2
IDE12980-Inspection: distance driven since the last inspection,7700 km,3
IDE12981-Inspection: time since the last inspection,121 d,2
IDE12982-Inspection: distance reset value,32200 km,2
IDE12983-Inspection: time reset value,365 d,2
IDE13031-MAS03935-Long-term store-Driving time,0 min,44
IDE13031-MAS15517-Long-term store-Travel distance,0 m,44
IDE13031-MAS15549-Long-term store-Average speed distance,0 m,44
IDE13031-MAS15550-Long-term store-Time since average speed,0 min,44
IDE13031-MAS15551-Long-term store-Distance average consumption of VKM,0 m,44
IDE13031-MAS15552-Long-term store-Consumption average consumption of VKM,0 ml,44
IDE13031-MAS15553-Long-term store-Distance average consumption of gasoline,0 m,44
IDE13031-MAS15554-Long-term store-Consumption average consumption of gasoline,0 g,44
IDE13031-MAS15555-Long-term store-Distance average consumption of electricity,0 m,44
IDE13031-MAS15556-Long-term store-Consumption average consumption by individual electrics,0.000 kWh,44
IDE13031-MAS15557-Long-term store-Consumption average consumption by BMS electrics,0.000 kWh,44
IDE13094-Tachometer end value,Variant 1 ,1
IDE13275-IDE00301-Personalization default value-Distance,miles ,70
IDE13275-MAS01230-Personalization default value-Date,mm_dd_yy ,70
IDE13275-MAS01456-Personalization default value-Speed,Miles per hour ,70
IDE13275-MAS02201-Personalization default value-Temperature, F ,70
IDE13275-MAS02957-Personalization default value-Time,12h AM_PM ,70
IDE13275-MAS03032-Personalization default value-Volume,gallons (US) ,70
IDE13275-MAS03034-Personalization default value-Pressure,psi ,70
IDE13275-MAS05637-Personalization default value-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,70
IDE13275-MAS05638-Personalization default value-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,70
IDE13275-MAS05875-Personalization default value-Average consumption: electric drive,kWh per 100 km ,70
IDE13275-Personalization default value-,not active ,70
IDE13275-ENG154881-Personalization default value-Active_design,0 ,70
IDE13275-ENG154882-Personalization default value-Active_view,0 ,70
IDE13275-ENG155000-Personalization default value-DC_aktiverSpeicherplatz,0 ,70
IDE13275-ENG155001-Personalization default value-DC_Kombination_FPA_DisplayConfig,not active ,70
IDE13275-ENG155002-Personalization default value-DC_linkeTubeninformation,00 ,70
IDE13275-ENG155003-Personalization default value-DC_rechteTubeninformation,00 ,70
IDE13275-ENG155004-Personalization default value-DC_Speicherplatz_1_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155005-Personalization default value-DC_Speicherplatz_1_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155006-Personalization default value-DC_Speicherplatz_2_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155007-Personalization default value-DC_Speicherplatz_2_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155008-Personalization default value-DC_Speicherplatz_3_linke_Tube,00 00 00 00 ,70
IDE13275-ENG155009-Personalization default value-DC_Speicherplatz_3_rechte_Tube,00 00 00 00 ,70
IDE13275-ENG155051-Personalization default value-Display_Average_Consumption,active ,70
IDE13275-ENG155052-Personalization default value-Display_Average_Speed,active ,70
IDE13275-ENG155053-Personalization default value-Display_ComfortPowerConsumption,not active ,70
IDE13275-ENG155054-Personalization default value-Display_ConsumerList,not active ,70
IDE13275-ENG155055-Personalization default value-Display_CoolantTemperature,not active ,70
IDE13275-ENG155056-Personalization default value-Display_CurrentConsumption,active ,70
IDE13275-ENG155057-Personalization default value-Display_DigitalSpeedometer,active ,70
IDE13275-ENG155058-Personalization default value-Display_Distance,active ,70
IDE13275-ENG155059-Personalization default value-Display_DrivingTime,active ,70
IDE13275-ENG155060-Personalization default value-Display_DualSpeedometer,not active ,70
IDE13275-ENG155061-Personalization default value-Display_Laptimer,active ,70
IDE13275-ENG155062-Personalization default value-Display_LiveTips,active ,70
IDE13275-ENG155063-Personalization default value-Display_Nachtankmenge,not active ,70
IDE13275-ENG155064-Personalization default value-Display_OilTemperature,active ,70
IDE13275-ENG155065-Personalization default value-Display_Range,active ,70
IDE13275-ENG155066-Personalization default value-Display_ResetTime,not active ,70
IDE13275-ENG155067-Personalization default value-Display_SpeedWarning,not active ,70
IDE13275-ENG155068-Personalization default value-Display_VZA,active ,70
IDE13275-ENG155069-Personalization default value-Display_ZeroEmission_Distance,not active ,70
IDE13275-ENG155070-Personalization default value-Display_ZeroEmission_Time,not active ,70
IDE13275-ENG155246-Personalization default value-LastMode_HMI_global_active_layout,0 ,70
IDE13275-ENG155247-Personalization default value-LastMode_HMI_HistoryState_Fahrzeugreiter,0 ,70
IDE13275-ENG155248-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin0,0 ,70
IDE13275-ENG155249-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin1,0 ,70
IDE13275-ENG155250-Personalization default value-LastMode_HMI_HistoryState_leftTube_PHEV_Skin2,0 ,70
IDE13275-ENG155251-Personalization default value-LastMode_HMI_HistoryState_main,0 ,70
IDE13275-ENG155252-Personalization default value-LastMode_HMI_HistoryState_mfa,0 ,70
IDE13275-ENG155253-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin0,0 ,70
IDE13275-ENG155254-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin1,0 ,70
IDE13275-ENG155255-Personalization default value-LastMode_HMI_HistoryState_Nebenanzeige_Skin2,0 ,70
IDE13275-ENG155256-Personalization default value-LastMode_HMI_HistoryState_sport,0 ,70
IDE13275-ENG155257-Personalization default value-LastMode_HMI_HistoryState_Zusatzanzeige_Skin1,5 ,70
IDE13275-ENG155258-Personalization default value-LastMode_HMI_MFA_store,0 ,70
IDE13275-ENG155259-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_bigscreen,0 ,70
IDE13275-ENG155260-Personalization default value-LastMode_HMI_store_navi_preferred_rg_type_classic,0 ,70
IDE13275-ENG155261-Personalization default value-LastMode_v_Kunde_aktiv,not active ,70
IDE13275-ENG155262-Personalization default value-LastMode_v_Kunde_Einheit,Kilometers per hour ,70
IDE13275-ENG155263-Personalization default value-LastMode_v_Kunde_Sollgeschwindigkeit,0 ,70
IDE13275-ENG262859-Personalization default value-speed_value,0 ,70
IDE13275-ENG263509-Personalization default value-Speed_warning_unit_mph_/kmh,Miles per hour ,70
IDE13441-Secondary speed in case of unit replacement,Display ,1
IDE13607-MAS16706-Lock display contents-List time out,72000 s,9
IDE14112-Gas system test - warning reset,No ,1
IDE14116-Gas system test - warning time,1443 d,2
IDE14123-MAS01129-Design variant activation-Variant 1,not active ,2
IDE14123-MAS01130-Design variant activation-Variant 2,not active ,2
IDE14123-MAS01131-Design variant activation-Variant 3,not active ,2
IDE14123-MAS01339-Design variant activation-Variant 9,not active ,2
IDE14123-MAS03101-Design variant activation-Variant 4,not active ,2
IDE14123-MAS03102-Design variant activation-Variant 5,not active ,2
IDE14123-MAS03103-Design variant activation-Variant 6,not active ,2
IDE14123-MAS03104-Design variant activation-Variant 7,not active ,2
IDE14123-MAS03105-Design variant activation-Variant 8,not active ,2
IDE14123-MAS05866-Design variant activation-lock,Yes ,2
IDE14123-MAS06157-Design variant activation-Variant 10,not active ,2
IDE14123-MAS06158-Design variant activation-Variant 11,not active ,2
IDE14123-MAS06159-Design variant activation-Variant 12,not active ,2
IDE14123-MAS06160-Design variant activation-Variant 13,not active ,2
IDE14123-MAS06161-Design variant activation-Variant 14,not active ,2
IDE14123-MAS06162-Design variant activation-Variant 15,not active ,2
IDE14184-Active participant personalization,Yes ,1
IDE14188-Range indicator configuration,422 km,8
IDE14220-Vehicle speed warning for India-,90 s,1
IDE14222-Test number length: authentic time,16 B,1
IDE14875-MAS19483-Activation of views-View 1,active ,2
IDE14875-MAS19484-Activation of views-View 2,not active ,2
IDE14875-MAS19485-Activation of views-View 3,active ,2
IDE14875-MAS19486-Activation of views-View 4,active ,2
IDE14875-MAS19487-Activation of views-View 5,not active ,2
IDE14875-MAS19488-Activation of views-View 6,active ,2
IDE14875-MAS19489-Activation of views-View 7,not active ,2
IDE14875-MAS19490-Activation of views-View 8,active ,2
IDE14875-MAS19491-Activation of views-View 9,not active ,2
IDE14875-MAS19492-Activation of views-View 10,not active ,2
IDE14875-MAS19493-Activation of views-View 12,not active ,2
IDE14875-MAS19494-Activation of views-View 11,not active ,2
IDE14875-MAS19495-Activation of views-View 13,active ,2
IDE14875-MAS19496-Activation of views-View 14,not active ,2
IDE14875-MAS19497-Activation of views-View 15,not active ,2
IDE14875-MAS19498-Activation of views-View 16,not active ,2
IDE15080-Logo,logo_4 ,1
IDE15909-Removable seats,Layout normal ,1
MAS01083-IDE12211-Country Variant-China variant,No ,2
MAS01083-IDE14114-Country Variant-USA Variant,Yes ,2
MAS01083-IDE14115-Country Variant-Asian variant,No ,2
MAS01083-IDE18009-Country Variant-Canada variant,No ,2
MAS01758-IDE00500-Date / time-Hour,19 H,6
MAS01758-IDE00501-Date / time-Minute,7 min,6
MAS01758-IDE00502-Date / time-Year,2026 yr,6
MAS01758-IDE00503-Date / time-Month,9 Months,6
MAS01758-IDE00504-Date / time-Day,1 d,6
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,31
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,31
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,31
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,31
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,31
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,31
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,31
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,31
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,31
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,31
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,31
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,31
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,31
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,31
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,31
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,31
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,31
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,31
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,31
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,31
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,31
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,31
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,31
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,31
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,31
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,31
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,31
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,31
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,31
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,31
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,31
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,31
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,31
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,31
ENG119877-ENG126397-Configuration of Development CAN-Messages-Block 40,OFF ,31
ENG119877-ENG167465-Configuration of Development CAN-Messages-Block 41,OFF ,31
ENG119877-ENG167466-Configuration of Development CAN-Messages-Block 42,OFF ,31
ENG119877-ENG167467-Configuration of Development CAN-Messages-Block 43,OFF ,31
ENG119877-ENG167468-Configuration of Development CAN-Messages-Block 44,OFF ,31
ENG119877-ENG167469-Configuration of Development CAN-Messages-Block 45,OFF ,31
ENG119877-ENG167470-Configuration of Development CAN-Messages-Block 46,OFF ,31
ENG119877-ENG167471-Configuration of Development CAN-Messages-Block 47,OFF ,31
ENG119877-ENG167472-Configuration of Development CAN-Messages-Block 48,OFF ,31
ENG119877-ENG167473-Configuration of Development CAN-Messages-Block 49,OFF ,31
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,31
ENG119877-ENG167474-Configuration of Development CAN-Messages-Block 50,OFF ,31
ENG119877-ENG167475-Configuration of Development CAN-Messages-Block 51,OFF ,31
ENG119877-ENG167476-Configuration of Development CAN-Messages-Block 52,OFF ,31
ENG119877-ENG167477-Configuration of Development CAN-Messages-Block 53,OFF ,31
ENG119877-ENG167478-Configuration of Development CAN-Messages-Block 54,OFF ,31
ENG119877-ENG167479-Configuration of Development CAN-Messages-Block 55,OFF ,31
ENG119877-ENG167480-Configuration of Development CAN-Messages-Block 56,OFF ,31
ENG119877-ENG167481-Configuration of Development CAN-Messages-Block 57,OFF ,31
ENG119877-ENG167482-Configuration of Development CAN-Messages-Block 58,OFF ,31
ENG119877-ENG167483-Configuration of Development CAN-Messages-Block 59,OFF ,31
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,31
ENG119877-ENG167484-Configuration of Development CAN-Messages-Block 60,OFF ,31
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,31
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,31
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,31
ENG262830-Correction_factor_consumption_and_operating_range_electric,100 %,1
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,02 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,02 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,10 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,1E ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,3C ,12
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG153810-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X1,00 ,18
ENG153810-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X2,0A ,18
ENG153810-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X3,32 ,18
ENG153810-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X4,64 ,18
ENG153810-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X5,96 ,18
ENG153810-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-X6,FD ,18
ENG153810-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y1,12 ,18
ENG153810-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y2,12 ,18
ENG153810-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y3,20 ,18
ENG153810-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y4,70 ,18
ENG153810-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y5,500 ,18
ENG153810-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field_high_resolution-Y6,1000 ,18
ENG153811-ENG154946-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X1,0.20 s,24
ENG153811-ENG154947-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X2,0.40 s,24
ENG153811-ENG154948-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X3,0.60 s,24
ENG153811-ENG154949-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X4,0.80 s,24
ENG153811-ENG154950-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X5,1.00 s,24
ENG153811-ENG154951-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_X6,1.20 s,24
ENG153811-ENG154952-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y1,80.0 %,24
ENG153811-ENG154953-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y2,60.0 %,24
ENG153811-ENG154954-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y3,40.0 %,24
ENG153811-ENG154955-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y4,25.0 %,24
ENG153811-ENG154956-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y5,12.0 %,24
ENG153811-ENG154957-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Ausdimmen_Y6,0.0 %,24
ENG153811-ENG155080-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X1,0.20 s,24
ENG153811-ENG155081-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X2,0.40 s,24
ENG153811-ENG155082-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X3,0.60 s,24
ENG153811-ENG155083-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X4,0.80 s,24
ENG153811-ENG155084-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X5,1.00 s,24
ENG153811-ENG155085-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_X6,1.20 s,24
ENG153811-ENG155086-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y1,40.0 %,24
ENG153811-ENG155087-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y2,60.0 %,24
ENG153811-ENG155088-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y3,75.0 %,24
ENG153811-ENG155089-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y4,85.0 %,24
ENG153811-ENG155090-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y5,95.0 %,24
ENG153811-ENG155091-dimming_characteristic_curve_adjustment_startup_shutdown_backlight-Eindimmen_Y6,100.0 %,24
ENG251650-GPS_speed,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus ,1
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4.0 C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6.0 C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 C,16
ENG135292-phev_stat_intervall-,1.0 ,7
ENG135292-phev_stat_intervall-,100 m,7
ENG135292-phev_stat_intervall-,0 min,7
ENG135292-phev_stat_intervall-,5.0 km,7
ENG135292-phev_stat_intervall-,kein ,7
ENG135292-phev_stat_intervall-,1.0 s,7
ENG135292-phev_stat_intervall-,00000000 00010000 ,7
ENG262832-Switching_Networking,Ethernet ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,0.50 ,18
ENG153987-volume_offset,100 %,1
Elapsed Time: 00:35
;SW:5H0-920-340-B HW:5H0-920-340-B --- 17: Instruments
;Component:KOMBI 220 5350, Coding:08BC0442638CCF050280220B2000000820300400
;EV_DashBoardVDDMQB37W,003033,EV_DashBoardVDDMQB37W_003_VW38.rod
;Tuesday,01,September,2026,19:06:53:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 21183A0051454742C8E-8074 SFD [x]
Group,Description,Actual
IDE00019,Voltage terminal 30,12.4, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00196,Engine oil temperature,74, °C
IDE00310,Outside temperature,35.0, °C
IDE00316-IDE00500,Time-Hour,19, H
IDE00316-IDE00501,Time-Minute,6, min
IDE00316-MAS00111,Time-Seconds,25, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,9, Months
IDE00317-IDE00504,Date-Day,1, d
IDE00706,Fuel level gasoline,101.6, %
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,1957, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,1957, mm
IDE01076,Time since ignition off,3628, s
IDE01985-MAS06855,FAZIT identification test sum-Test sum,B0 2E 7A DB,
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,35.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,82,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,0,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,53,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,3,
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03471-ENG164384,Vehicle configuration-virtual_side_mirror,Correct coding,
IDE03471-ENG174709,Vehicle configuration-zFAS,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,33.4, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,49.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,51.5, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,34.2, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,22.8, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,49.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,51.5, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,23.0, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,30.7, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,49.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,51.5, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,31.8, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,20.4, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,49.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,51.5, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,20.5, l
IDE03472-MAS03822,Volume after refueling-Last error status,00,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,00,
IDE03472-MAS03824,Volume after refueling-Third-last error status,00,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,00,
IDE03472-MAS06153,Volume after refueling-Last distance,3050.0, km
IDE03472-MAS06154,Volume after refueling-Penultimate distance,3040.0, km
IDE03472-MAS06155,Volume after refueling-Third to last distance,3000.0, km
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,2980.0, km
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,201, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,2, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,32767, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,32767, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,32767, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,2067,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,1718,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,203,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,144,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,17.4, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,199, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,18.5, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-IDE00802,Calculated volume-Full volume,49.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,18.5, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,3276.7, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,3276.7, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,3276.7, l
IDE03474-MAS18153,Calculated volume-Calculated volume unlimited: sensor 1,18.5, l
IDE03474-MAS18154,Calculated volume-Calculated volume unlimited: sensor 2,3276.7, l
IDE03474-MAS18155,Calculated volume-Calculated volume unlimited: sensor 3,3276.7, l
IDE03474-MAS18156,Calculated volume-Calculated volume unlimited: sensor 4,3276.7, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,18.5, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,18.5, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,18.5, l
IDE03474-ENG126318,Calculated volume-gas_based_linking,1.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.00000, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-12.03125, m/s
IDE03474-ENG101623,Calculated volume-reference_volume,18.3, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99683,Calculated volume-version_of_application,117,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03477-IDE00500,GPS time-Hour,0, H
IDE03477-IDE00501,GPS time-Minute,0, min
IDE03477-IDE00502,GPS time-Year,2000, yr
IDE03477-IDE00503,GPS time-Month,1, Months
IDE03477-IDE00504,GPS time-Day,1, d
IDE03477-MAS00111,GPS time-Seconds,0, s
IDE03477-MAS03493,GPS time-last synchronization year,2000, yr
IDE03506,Distance: high resolution,01 D7 D3 9D,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 54,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0E,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0E,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 54,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,4F F0 01 C1,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,8F F0 13 E8,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,CF F0 01 CD,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 13 E8,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,AF F0 2F 5C,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,EF F0 03 1F,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,6F F0 03 1F,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,2F F0 2F 5C,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF F0 04 8C,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,7F F0 04 8C,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,AF F0 47 A2,
IDE03911-ENG263219,Service -interval- display: history 1-Block_16,EF F0 04 B7,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,6F F0 04 B7,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,2F F0 47 A2,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF F0 06 20,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,7F F0 06 20,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,6F F0 06 41,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,2F F0 5A 61,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,AF F0 5A 61,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,EF F0 06 41,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,6F F0 06 41,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,2F F0 5A 61,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-ENG263219,Service -interval- display: history 2-Block_16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-ENG263219,Service -interval- display: history 3-Block_16,FF FF FF FF,
IDE03914-ENG263219,Service -interval- display: history 4-Block_16,FF FF FF FF,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE06592-MAS31502,Status: special functions-Luggage compartment remote control via mobile online services,locked,
IDE06592-MAS31503,Status: special functions-Sunroof remote control via mobile online services.,locked,
IDE06592-MAS31504,Status: special functions-Ventilation remote control via mobile online services,locked,
IDE06592-MAS31505,Status: special functions-Window and sunroof remote control via mobile online services,locked,
IDE06592-MAS31506,Status: special functions-Remote vehicle start via mobile online services,locked,
IDE06924,Performance display,0,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08343,Immobilizer Challenge,05 95 C8 8E,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 14 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|00 36 F8 64 77 19,FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10,5|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0|,
IDE12238,I network: discarded messages counter,4291,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,Test not yet carried out|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 10,Test not yet carried out|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 1B,Test not yet carried out|,
IDE12972,Oil: theoretical service interval,37900.00, km
IDE12973,Oil: service interval exceeded in km,0, km
IDE12974,Oil service interval exceeded in days,0, d
IDE12975,Oil: remaining driving distance,8320, km
IDE12976,Oil: remaining running time,244, d
IDE12977-MAS07266,Oil status-Oil change: unit of dist. travelled,miles,
IDE12977-MAS07267,Oil status-Oil change: dist. travelled,5200,
IDE12977-MAS07268,Oil status-Oil change: stat. of dist. travelled,Service in,
IDE12977-MAS07269,Oil status-Oil change: stat. of time,Service in,
IDE12977-MAS07270,Oil status-Inspection: stat. of dist. travelled,Service in,
IDE12977-MAS07271,Oil status-Inspection: unit of distance traveled,miles,
IDE12977-MAS07272,Oil status-Inspection: dist. travelled,15200,
IDE12977-MAS07273,Oil status-Inspection: time,244,
IDE12977-MAS07274,Oil status-Oil change warning,no warning,
IDE12977-MAS07277,Oil status-Inspections warning,no warning,
IDE12977-MAS07305,Oil status-Oil change: time,244,
IDE12977-MAS07308,Oil status-Inspection: status time,Service in,
IDE12977-MAS10768,Oil status-Daily mileage,63,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,11,
IDE13845,Production mode status,not active,
IDE14124-IDE03840,Gong status-Volume of actuator test,0, %
IDE14124-MAS01167,Gong status-Actuation time,Unknown (0),
IDE14124-MAS05781,Gong status-Acoustics,all_acoustics,
IDE14124-ENG261531,Gong status-IO Reached Status,Output diagnostic test not active,
IDE14126-MAS01167,Other function lights status-Actuation time,Unknown (0),
IDE14126-MAS01168,Other function lights status-Start parameter,00 00 00,
IDE14126-ENG261531,Other function lights status-IO Reached Status,Output diagnostic test not active,
IDE14127-MAS01167,Lights status-Actuation time,Unknown (0),
IDE14127-MAS01168,Lights status-Start parameter,00 00 00,
IDE14127-ENG261531,Lights status-IO Reached Status,Output diagnostic test not active,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,Unknown (0),
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,Unknown (0),
IDE14130-MAS01168,Test image in center display status-Start parameter,Unknown (0),
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,Unknown (0),
IDE14132-MAS01168,Indicator lamp status-Start parameter,00 00 00,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE14185-IDE00301,Gas systems test-Distance,0, km
IDE14185-IDE00502,Gas systems test-Year,2001, yr
IDE14185-IDE00503,Gas systems test-Month,1, Months
IDE14185-IDE00504,Gas systems test-Day,1, d
IDE14185-MAS17869,Gas systems test-Time since last reset,0, d
IDE14185-MAS17870,Gas systems test-Number of resets,0,
IDE14212-ENG103300,Service Key Master daily data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14213-ENG103300,Service Key Master current data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14214-ENG263244,Service Key Master write counter-Counter_current_clamp_15,0,
IDE14214-ENG263245,Service Key Master write counter-Counter_current_total,2507,
IDE14214-ENG263246,Service Key Master write counter-Counter_daily_clamp_15,0,
IDE14214-ENG263247,Service Key Master write counter-Counter_daily_total,3292,
IDE14214-ENG119822,Service Key Master write counter-Error_Counter,0,
IDE14214-ENG263298,Service Key Master write counter-state_current,Engine_off,
IDE14214-ENG263299,Service Key Master write counter-State_daily,Engine_off,
IDE14214-ENG263221,Service Key Master write counter-transponder_id,00 00 00 00,
IDE14214-ENG263220,Service Key Master write counter-Transponder_type,00 00,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,1970, yr
IDE14236-MAS00107,Authentic time: last confirmed time-Month,1, Months
IDE14236-MAS00108,Authentic time: last confirmed time-Day,1, d
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,0, H
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,0, min
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,0, s
IDE14236-MAS03617,Authentic time: last confirmed time-Time zone,0, H
IDE14237-MAS00106,Authentic time: actual time-Year,1970, yr
IDE14237-MAS00107,Authentic time: actual time-Month,1, Months
IDE14237-MAS00108,Authentic time: actual time-Day,1, d
IDE14237-MAS00109,Authentic time: actual time-Hours,0, H
IDE14237-MAS00110,Authentic time: actual time-Minutes,0, min
IDE14237-MAS00111,Authentic time: actual time-Seconds,0, s
IDE14237-MAS03617,Authentic time: actual time-Time zone,0, H
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,00,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,|Verification failed|00 00|,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,|failed signature creation|00 00|,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,00,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,00,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,00,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 76 0A 29 8C 60 27 A9,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,00,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-ENG103935,Secure Onboard Communication: Freshness Values information-Parameter,|SOC PDU ID to which this freshness information is assigned,Freshness Value query status,SOC time of last successful verification,Current value of message counter,Bitfield with used counter values|00 04,Freshness Value was not queried,FF FF FF FF FF FF FF FF,255,11111111 11111111 |00 76,Freshness Value was queried,00 76 0A 29 8C 60 27 A7,0,00000000 00000001 |00 2E,Freshness Value was not queried,FF FF FF FF FF FF FF FF,255,11111111 11111111 |00 2F,Freshness Value was not queried,FF FF FF FF FF FF FF FF,255,11111111 11111111 |00 30,Freshness Value was not queried,FF FF FF FF FF FF FF FF,255,11111111 11111111 |00 31,Freshness Value was not queried,FF FF FF FF FF FF FF FF,255,11111111 11111111 |00 78,Freshness Value was queried,FF FF FF FF FF FF FF FF,255,11111111 11111111 |,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,|Missing key|00 00|,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,00,
IDE15081,Authentic time: status of distribution signal trigger,0,
MAS00902-ENG99140,Extended Service Intervals (ESI)-advance_warning_fixed_days,not active,
MAS00902-ENG100265,Extended Service Intervals (ESI)-advance_warning_fixed_km,not active,
MAS00902-ENG101600,Extended Service Intervals (ESI)-advance_warning_WIV_days,not active,
MAS00902-ENG102887,Extended Service Intervals (ESI)-advance_warning_WIV_km,not active,
MAS00902-ENG99971,Extended Service Intervals (ESI)-in_calculation,active,
MAS00902-ENG101015,Extended Service Intervals (ESI)-no_calculation_available,not active,
MAS00902-ENG101477,Extended Service Intervals (ESI)-service_warning_fixed_days,not active,
MAS00902-ENG101550,Extended Service Intervals (ESI)-service_warning_fixed_km,not active,
MAS00902-ENG101709,Extended Service Intervals (ESI)-service_warning_WIV_days,not active,
MAS00902-ENG102993,Extended Service Intervals (ESI)-service_warning_WIV_km,not active,
MAS10768,Daily mileage,63, km
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG186121,Authentic_time_current_counter_kl15_since_last_sync,3809,
ENG262946,Authentic_time_last_backend_response,|||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||,
ENG186123,Authentic_time_last_client_response,1970-01-01T00:00:00Z,
ENG186123,Authentic_time_last_client_response,3809,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0.0, ‰
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0.0, ‰
ENG105830-ENG263248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_night,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG263249,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_blue,0.0, ‰
ENG105830-ENG263250,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_green,0.0, ‰
ENG105830-ENG263251,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_red,0.0, ‰
ENG105830-ENG263252,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights_yellow,0.0, ‰
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,3, %
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,4085,
ENG99439,Instrument_recorder,07 23 50 00 4D 51 42 32 30 32 30 32 31 53 31 46 41 43 47 33 38 64 64 66 64 66 78 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 48 00 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 05 06 FF FF FF FF FF FF FF 00 00 28 00 1C 01 00 00 00 00 02 55 00 00 76 13 06 00 88 E8 96 68 20 00 C4 00 97 02 00 00 01 00 00 00 D4 E8 05 00 18 A1 51 50 1F 00 D6 00 8A 02 00 00 02 00 00 00 D4 E8 05 00 18 A1 51 50 1F 00 CD 00 33 02 00 00 13 00 00 00 C0 E5 05 00 28 97 DA 28 20 00 C1 00 D2 01 00 00 01 00 00 00 C0 E5 05 00 28 97 DA 28 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 23 00 03 00 00 00 04 00 04 00 02 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 02 00 8C FF B7 00 00 10 3B 00 8C FF FF FF 00 00 00 07 C8 25 1A 1A 01 09 00 00 00 1A 73 23 FF B7 00 00 00 00 00 00 54 41 A8 48 80 00 40 00 27 06 13 00 00 00 A8,
ENG128745,Instrument_recorder_graphic,05 23 50 00 4D 51 42 32 30 32 30 32 31 53 31 46 47 43 5F 56 57 50 53 06 00 56 41 8F 17 83 02 00 00 37 00 00 00 E8 00 00 00 00 00 00 00 6F 11 00 00 04 00 00 00 02 00 00 00 6E D9 05 00 D6 72 34 92 8A 04 00 00 64 00 00 00 CF 01 0A 00 00 00 00 00 75 00 00 00 00 00 00 00 02 00 00 00 85 D9 05 00 C5 01 FC 7A 41 04 00 00 28 00 00 00 35 03 00 00 F2 5F A5 5A 87 00 00 00 00 00 00 00 04 00 00 00 5D 5A 06 00 F8 DF 54 6C EB 00 00 00 0E 00 00 00 0E 04 00 00 01 00 00 00 80 13 00 00 91 00 00 80 02 00 00 00 EF FE 05 00 B0 CB 54 60 41 04 00 00 28 00 00 00 35 03 00 00 BD 5E A5 5A D0 04 00 00 00 00 00 00 04 00 00 00 45 36 06 00 BE A7 12 3E 9A 04 00 00 66 00 00 00 55 01 01 00 00 00 00 00 97 0D 00 00 03 00 00 00 02 00 00 00 3A 10 06 00 88 E1 D3 17 C7 01 00 00 18 00 00 00 AA 01 00 00 00 00 00 00 FF 07 00 00 00 00 00 00 04 00 00 00 DB 31 06 00 4C A3 D5 58 48 00 00 00 02 00 00 00 13 00 00 00 00 00 00 00 E1 0C 00 00 00 00 00 00 02 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 7E 00 00 00 9D 01 00 00 62 11 13 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 61 61 31 37 63 33 62 78 02 00 00 00 91 13 00 00 02 00 00 00 D0 E9 FF FF 00 00 00 00 57 C6 FF FF 08 00 00 00 41 FE 6A 2A 01 FF FF FF,
ENG264452,Instrument_recorder_graphic_3,||05|23|50|00|4D|51|42|32|30|32|30|32|31|53|31|46|47|43|5F|56|57|50|53|06|00|56|41|8F|17|83|02|00|00|37|00|00|00|E8|00|00|00|00|00|00|00|6F|11|00|00|04|00|00|00|02|00|00|00|6E|D9|05|00|D6|72|34|92|8A|04|00|00|64|00|00|00|CF|01|0A|00|00|00|00|00|75|00|00|00|00|00|00|00|02|00|00|00|85|D9|05|00|C5|01|FC|7A|41|04|00|00|28|00|00|00|35|03|00|00|F2|5F|A5|5A|87|00|00|00|00|00|00|00|04|00|00|00|5D|5A|06|00|F8|DF|54|6C|EB|00|00|00|0E|00|00|00|0E|04|00|00|01|00|00|00|80|13|00|00|91|00|00|80|02|00|00|00|EF|FE|05|00|B0|CB|54|60|41|04|00|00|28|00|00|00|35|03|00|00|BD|5E|A5|5A|D0|04|00|00|00|00|00|00|04|00|00|00|45|36|06|00|BE|A7|12|3E|9A|04|00|00|66|00|00|00|55|01|01|00|00|00|00|00|97|0D|00|00|03|00|00|00|02|00|00|00|3A|10|06|00|88|E1|D3|17|C7|01|00|00|18|00|00|00|AA|01|00|00|00|00|00|00|FF|07|00|00|00|00|00|00|04|00|00|00|DB|31|06|00|4C|A3|D5|58|48|00|00|00|02|00|00|00|13|00|00|00|00|00|00|00|E1|0C|00|00|00|00|00|00|02|00|00|00|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|00|00|00|00|7E|00|00|00|9D|01|00|00|62|11|16|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|FF|61|61|31|37|63|33|62|78|02|00|00|00|90|13|00|00|02|00|00|00|D1|E9|FF|FF|00|00|00|00|57|C6|FF|FF|08|00|00|00|41|FE|6A|2A|02|FF|FF|FF|,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,170,
Elapsed Time: 00:16
;SW:5H0-035-871 HW:5H0-035-871 --- 5F: Information Electr.
;Component:MU-E--US 099 1805, Coding:23800000000200000000000000000000000000000000000000
;EV_MUEIMQB37w,001003,EV_MUEIMQB37w_VW38.rod
;Tuesday,01,September,2026,18:54:39:51924
;VCID: 65906E1005ED6B62746-8030 SFD [x]
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,manually ,1
IDE00768-Country identification: country of sale,US ,2
IDE00769-Call number 1 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,255 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,255 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,255 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,255 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,255 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,255 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,255 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,255 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,255 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,255 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,255 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,255 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,255 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,255 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,255 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,255 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,255 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,255 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,255 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,255 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,255 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,255 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,255 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,255 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,255 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,255 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,255 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,255 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,255 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,255 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,255 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,255 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,255 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,255 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,255 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,255 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,255 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,255 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,255 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,255 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,255 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,255 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,255 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,255 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,255 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,255 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,255 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,255 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,30 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,30 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,30 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,30 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,30 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,30 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,30 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,30 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,30 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,30 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,30 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,30 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,30 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,30 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,30 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,30 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,30 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,30 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,30 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,30 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,30 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,30 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,30 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,30 ,121
IDE02502-Confirmation of installation change,84 84 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,not activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,not activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,not activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,not activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,not activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,not activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,not activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,not activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,not activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,not activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,not activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,not activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,not activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,not activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,not activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,not activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,not activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Terminal 15 ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Terminal 15 ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,not activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,CAB_2 ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,not activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Infotainment data bus ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,Terminal 15 ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,CAB_5 ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Infotainment data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,CAB_5 ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,CAB_5 ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,not activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,not activated ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,not activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,not activated ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Infotainment data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,Powertrain data bus ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Infotainment data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,CAB_5 ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,Comfort data bus ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,not activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Powertrain data bus ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Infotainment data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Terminal 15 ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,CAB_6 ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,Infotainment data bus ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,not activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Infotainment data bus ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,not activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,not activated ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,not activated ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,Comfort data bus ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Terminal 15 ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,not activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Terminal 15 ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,CAN_FAS ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,not activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,CAB_5 ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04550-Bluetooth: Sniff mode,On ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE10604-Menu entries for mobile online services,not activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dB V,28 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,32 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11105-Brand-specific display of connect application, ,1
IDE11122-Country identification: country of sale HMI,US ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,slave ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Deactivated ,2
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG248413-alphabetic_scrollbar,On ,1
ENG252010-Car_net,car_net_eu_nar ,1
ENG248423-channel_band_width_802_11ac,40MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,RLE ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,0 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,BAP ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG253062-Display_legal_text_MOD,On ,1
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248427-ENG248668-exit_screen_configuration-exit_screen,activated ,2
ENG248427-ENG248669-exit_screen_configuration-exit_screen_length_of_time,50000 ms,2
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG331821-function_configuration_a2b_topology-External_sound_system,Not_present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG302728-function_configuration_a2b_topology-InnenSound_Unit,Not_present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,not installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,not installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,25 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,OFF ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_IP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,No ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,usb_only ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,usb_only ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,usb_only ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,USA ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,OFF ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,OFF ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,OFF ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,OFF ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,OFF ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,OFF ,6
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,3 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,OFF ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,not installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,Deactivated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,not installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,OFF ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,Deactivated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,Deactivated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,Deactivated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,NAR ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,OFF ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,NAR ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,not activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,not activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,MRC ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,Deactivated ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,On ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,not activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,0 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,No_Brand_Sound ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248440-function_configuration_swap_fod,swap_active_fod_not_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,Ethernet ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG252007-ENG297686-Privacy_mode-globe_icon,not activated ,2
ENG252007-ENG252075-Privacy_mode-supress_privacy_mode,activated ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG248470-sortorder,sortorder_4 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,1 ,1
Elapsed Time: 01:39
;SW:5H0-035-871 HW:5H0-035-871 --- 5F: Information Electr.
;Component:MU-E--US 099 1805, Coding:23800000000200000000000000000000000000000000000000
;EV_MUEIMQB37w,001003,EV_MUEIMQB37w_VW38.rod
;Tuesday,01,September,2026,18:54:08:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
;VCID: 65906E1005ED6B62746-8030 SFD [x]
Group,Description,Actual
IDE00019,Voltage terminal 30,12.60, V
IDE00020,Terminal 15 status,On,
IDE00021,Engine speed,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,74, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,1, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,55, °C
IDE00767,No. of unscheduled ECU resets,0,
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Right rear speaker,
IDE00916-ENG249480,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG249518,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG249486,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG249341,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG249407,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG249456,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG249515,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG249507,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG249452,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG249466,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Right front speaker,
IDE00916-ENG249434,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG249416,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG249527,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG249489,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG249520,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Left front speaker,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Left rear speaker,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Not available,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Not available,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Not available,
IDE00916-ENG249470,Speaker status-loudspeaker_config_channel_9,Not available,
IDE00916-ENG249411,Speaker status-loudspeaker_state_channel_1,OK,
IDE00916-ENG249429,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG249464,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG249451,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG249436,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG249447,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG249426,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG249317,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG249528,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG249492,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG249409,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG249305,Speaker status-loudspeaker_state_channel_2,OK,
IDE00916-ENG249435,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG249417,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG249404,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG249319,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG249408,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG249290,Speaker status-loudspeaker_state_channel_3,OK,
IDE00916-ENG249312,Speaker status-loudspeaker_state_channel_4,OK,
IDE00916-ENG249303,Speaker status-loudspeaker_state_channel_5,Measuring value not available,
IDE00916-ENG249399,Speaker status-loudspeaker_state_channel_6,Measuring value not available,
IDE00916-ENG249508,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG249335,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG249382,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,On,
IDE01627-MAS01167,Search for Bluetooth devices-Actuation time,0 s,
IDE01627-ENG170421,Search for Bluetooth devices-IoReached Status,Output diagnostic test not active,
IDE01628-MAS01167,Establish connection to last Bluetooth device-Actuation time,Without time limit,
IDE01628-ENG170421,Establish connection to last Bluetooth device-IoReached Status,Output diagnostic test not active,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,70, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,48, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,0, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,Open circuit,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,Not available,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,07 2C 9D 18,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,0 s,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,0 s,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth not visible: connection possible,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,15, min
IDE04317-MAS00108,Total system run time-Day,27, d
IDE04317-MAS00109,Total system run time-Hours,14, H
IDE04317-MAS00110,Total system run time-Minutes,38, min
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|00 05 00 00,Available,No,valid,Condition met,OK,Available,Condition met|00 06 01 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|00 06 02 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|00 06 03 00,Available,No,valid,Condition met,OK,Available,Condition met|00 07 07 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|00 07 0D 00,Available,No,valid,Condition met,OK,Available,Condition met|00 07 0E 00,Available,No,valid,Condition met,OK,Available,Condition met|00 07 16 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|00 00 07 00,Not available,No,invalid,Condition not met,OK,Available,Condition not met|,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04541-MAS03621,Status of active media source at output 1-Video codec,--------------------,
IDE04541-MAS03622,Status of active media source at output 1-Horizontal video resolution,65535,
IDE04541-MAS03623,Status of active media source at output 1-Vertical video resolution,65535,
IDE04541-MAS03778,Status of active media source at output 1-Active media source,Card reader,
IDE04541-MAS03783,Status of active media source at output 1-Video Bitrate,65535, kbps
IDE04541-MAS03784,Status of active media source at output 1-Audio Bitrate,Not available,
IDE04541-MAS03785,Status of active media source at output 1-Digital rights management (DRM),Not available,
IDE04541-MAS03786,Status of active media source at output 1-Audio Codec,--------------------,
IDE04541-MAS03787,Status of active media source at output 1-Image format,--------------------,
IDE04541-MAS03788,Status of active media source at output 1-Horizontal image resolution,65535,
IDE04541-MAS03789,Status of active media source at output 1-Vertical image resolution,65535,
IDE04541-MAS03793,Status of active media source at output 1-Color depth,65535, bit
IDE04640,Over-temperature protection for amplifier,255,
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,no request,
IDE04768,Bluetooth: device address,E8 E8 B7 59 5E CF,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG170421,Test image display unit 1 for multimedia system-IoReached Status,Actuator test terminated due to client request,
IDE05602-IDE03615,Bluetooth: connected device 1-Variant,-ÿÿ-----------------,
IDE05602-IDE04768,Bluetooth: connected device 1-Bluetooth: device address,00 50 B7 59 5E CF,
IDE05602-MAS01483,Bluetooth: connected device 1-Software version,---ÿÿÿÿÿÿÿç´®”
iP˜d,
IDE05602-MAS02159,Bluetooth: connected device 1-Remote SIM Access Profile (rSAP),38331,
IDE05602-MAS02160,Bluetooth: connected device 1-Hands free profile (HFP),29570,
IDE05602-MAS03159,Bluetooth: connected device 1-Manufacturer,ÿ-------------------,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,---------------ÿÿÿÿÿ,
IDE05602-MAS17538,Bluetooth: connected device 1-Received Signal Strength Indicator (RSSI),-75,
IDE05602-MAS17539,Bluetooth: connected device 1-Determining the existing profile (SDAP),25436,
IDE05602-MAS17540,Bluetooth: connected device 1-Serial data transfer (SPP),49214,
IDE05602-MAS17541,Bluetooth: connected device 1-Streaming audio data (A2DP),11174,
IDE05602-MAS17542,Bluetooth: connected device 1-Remote control for audio/video (AVRCP),61304,
IDE05602-MAS17543,Bluetooth: connected device 1-Network connections (PAN),19130,
IDE05602-MAS17544,Bluetooth: connected device 1-Message exchange between devices (MAP),64029,
IDE05602-MAS17545,Bluetooth: connected device 1-Generic data transfer between two devices (OBEX),25431,
IDE05602-MAS17546,Bluetooth: connected device 1-Sending individual files (OPP),49700,
IDE05602-MAS17547,Bluetooth: connected device 1-File transfer (FTP),48595,
IDE05602-MAS17548,Bluetooth: connected device 1-Read-only access to telephone directory (PBAP),48584,
IDE05602-MAS17549,Bluetooth: connected device 1-Telephone directory download (AT),41057,
IDE05602-MAS17550,Bluetooth: connected device 1-Sharing calendars or notes between two devices (CTN),49966,
IDE05602-MAS17551,Bluetooth: connected device 1-iAP protocol (iAP),37561,
IDE05603-IDE03615,Bluetooth: connected device 2-Variant,-ÿÿ-----------------,
IDE05603-IDE04768,Bluetooth: connected device 2-Bluetooth: device address,00 50 B7 59 5E CF,
IDE05603-MAS01483,Bluetooth: connected device 2-Software version,---ÿÿÿÿÿÿÿç´®”
iP˜d,
IDE05603-MAS02159,Bluetooth: connected device 2-Remote SIM Access Profile (rSAP),38331,
IDE05603-MAS02160,Bluetooth: connected device 2-Hands free profile (HFP),29570,
IDE05603-MAS03159,Bluetooth: connected device 2-Manufacturer,ÿ-------------------,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,---------------ÿÿÿÿÿ,
IDE05603-MAS17538,Bluetooth: connected device 2-Received Signal Strength Indicator (RSSI),-75,
IDE05603-MAS17539,Bluetooth: connected device 2-Determining the existing profile (SDAP),25436,
IDE05603-MAS17540,Bluetooth: connected device 2-Serial data transfer (SPP),49214,
IDE05603-MAS17541,Bluetooth: connected device 2-Streaming audio data (A2DP),11174,
IDE05603-MAS17542,Bluetooth: connected device 2-Remote control for audio/video (AVRCP),61304,
IDE05603-MAS17543,Bluetooth: connected device 2-Network connections (PAN),19130,
IDE05603-MAS17544,Bluetooth: connected device 2-Message exchange between devices (MAP),64029,
IDE05603-MAS17545,Bluetooth: connected device 2-Generic data transfer between two devices (OBEX),25431,
IDE05603-MAS17546,Bluetooth: connected device 2-Sending individual files (OPP),49700,
IDE05603-MAS17547,Bluetooth: connected device 2-File transfer (FTP),48595,
IDE05603-MAS17548,Bluetooth: connected device 2-Read-only access to telephone directory (PBAP),48584,
IDE05603-MAS17549,Bluetooth: connected device 2-Telephone directory download (AT),41057,
IDE05603-MAS17550,Bluetooth: connected device 2-Sharing calendars or notes between two devices (CTN),49966,
IDE05603-MAS17551,Bluetooth: connected device 2-iAP protocol (iAP),37561,
IDE05604-IDE03615,Bluetooth: connected device 3-Variant,--------------------,
IDE05604-IDE04768,Bluetooth: connected device 3-Bluetooth: device address,2D 2D 2D 2D 2D 2D,
IDE05604-MAS01483,Bluetooth: connected device 3-Software version,--------------------,
IDE05604-MAS02159,Bluetooth: connected device 3-Remote SIM Access Profile (rSAP),11565,
IDE05604-MAS02160,Bluetooth: connected device 3-Hands free profile (HFP),11565,
IDE05604-MAS03159,Bluetooth: connected device 3-Manufacturer,--------------------,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,--------------------,
IDE05604-MAS17538,Bluetooth: connected device 3-Received Signal Strength Indicator (RSSI),45,
IDE05604-MAS17539,Bluetooth: connected device 3-Determining the existing profile (SDAP),11565,
IDE05604-MAS17540,Bluetooth: connected device 3-Serial data transfer (SPP),11565,
IDE05604-MAS17541,Bluetooth: connected device 3-Streaming audio data (A2DP),11565,
IDE05604-MAS17542,Bluetooth: connected device 3-Remote control for audio/video (AVRCP),11565,
IDE05604-MAS17543,Bluetooth: connected device 3-Network connections (PAN),11565,
IDE05604-MAS17544,Bluetooth: connected device 3-Message exchange between devices (MAP),11565,
IDE05604-MAS17545,Bluetooth: connected device 3-Generic data transfer between two devices (OBEX),11565,
IDE05604-MAS17546,Bluetooth: connected device 3-Sending individual files (OPP),11565,
IDE05604-MAS17547,Bluetooth: connected device 3-File transfer (FTP),11565,
IDE05604-MAS17548,Bluetooth: connected device 3-Read-only access to telephone directory (PBAP),11565,
IDE05604-MAS17549,Bluetooth: connected device 3-Telephone directory download (AT),11565,
IDE05604-MAS17550,Bluetooth: connected device 3-Sharing calendars or notes between two devices (CTN),11565,
IDE05604-MAS17551,Bluetooth: connected device 3-iAP protocol (iAP),11565,
IDE05605-IDE03615,Bluetooth: connected device 4-Variant,--------------------,
IDE05605-IDE04768,Bluetooth: connected device 4-Bluetooth: device address,2D 2D 2D 2D 2D 2D,
IDE05605-MAS01483,Bluetooth: connected device 4-Software version,--------------------,
IDE05605-MAS02159,Bluetooth: connected device 4-Remote SIM Access Profile (rSAP),11565,
IDE05605-MAS02160,Bluetooth: connected device 4-Hands free profile (HFP),11565,
IDE05605-MAS03159,Bluetooth: connected device 4-Manufacturer,--------------------,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,--------------------,
IDE05605-MAS17538,Bluetooth: connected device 4-Received Signal Strength Indicator (RSSI),45,
IDE05605-MAS17539,Bluetooth: connected device 4-Determining the existing profile (SDAP),11565,
IDE05605-MAS17540,Bluetooth: connected device 4-Serial data transfer (SPP),11565,
IDE05605-MAS17541,Bluetooth: connected device 4-Streaming audio data (A2DP),11565,
IDE05605-MAS17542,Bluetooth: connected device 4-Remote control for audio/video (AVRCP),11565,
IDE05605-MAS17543,Bluetooth: connected device 4-Network connections (PAN),11565,
IDE05605-MAS17544,Bluetooth: connected device 4-Message exchange between devices (MAP),11565,
IDE05605-MAS17545,Bluetooth: connected device 4-Generic data transfer between two devices (OBEX),11565,
IDE05605-MAS17546,Bluetooth: connected device 4-Sending individual files (OPP),11565,
IDE05605-MAS17547,Bluetooth: connected device 4-File transfer (FTP),11565,
IDE05605-MAS17548,Bluetooth: connected device 4-Read-only access to telephone directory (PBAP),11565,
IDE05605-MAS17549,Bluetooth: connected device 4-Telephone directory download (AT),11565,
IDE05605-MAS17550,Bluetooth: connected device 4-Sharing calendars or notes between two devices (CTN),11565,
IDE05605-MAS17551,Bluetooth: connected device 4-iAP protocol (iAP),11565,
IDE05606-IDE03615,Bluetooth: connected device 5-Variant,--------------------,
IDE05606-IDE04768,Bluetooth: connected device 5-Bluetooth: device address,2D 2D 2D 2D 2D 2D,
IDE05606-MAS01483,Bluetooth: connected device 5-Software version,--------------------,
IDE05606-MAS02159,Bluetooth: connected device 5-Remote SIM Access Profile (rSAP),11565,
IDE05606-MAS02160,Bluetooth: connected device 5-Hands free profile (HFP),11565,
IDE05606-MAS03159,Bluetooth: connected device 5-Manufacturer,--------------------,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,--------------------,
IDE05606-MAS17538,Bluetooth: connected device 5-Received Signal Strength Indicator (RSSI),45,
IDE05606-MAS17539,Bluetooth: connected device 5-Determining the existing profile (SDAP),11565,
IDE05606-MAS17540,Bluetooth: connected device 5-Serial data transfer (SPP),11565,
IDE05606-MAS17541,Bluetooth: connected device 5-Streaming audio data (A2DP),11565,
IDE05606-MAS17542,Bluetooth: connected device 5-Remote control for audio/video (AVRCP),11565,
IDE05606-MAS17543,Bluetooth: connected device 5-Network connections (PAN),11565,
IDE05606-MAS17544,Bluetooth: connected device 5-Message exchange between devices (MAP),11565,
IDE05606-MAS17545,Bluetooth: connected device 5-Generic data transfer between two devices (OBEX),11565,
IDE05606-MAS17546,Bluetooth: connected device 5-Sending individual files (OPP),11565,
IDE05606-MAS17547,Bluetooth: connected device 5-File transfer (FTP),11565,
IDE05606-MAS17548,Bluetooth: connected device 5-Read-only access to telephone directory (PBAP),11565,
IDE05606-MAS17549,Bluetooth: connected device 5-Telephone directory download (AT),11565,
IDE05606-MAS17550,Bluetooth: connected device 5-Sharing calendars or notes between two devices (CTN),11565,
IDE05606-MAS17551,Bluetooth: connected device 5-iAP protocol (iAP),11565,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,Not available,
IDE05700-MAS04393,USB connection-USB device class,Not available,
IDE05700-MAS04394,USB connection-Connection status,Not available,
IDE05700-MAS04436,USB connection-USB device sub-class,Not available,
IDE05700-MAS06173,USB connection-Protocol,Not available,
IDE05700-MAS06174,USB connection-Product ID,Not available,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,32.39, %
IDE05814,Individualization characteristic,8A 72 74 55 11,
IDE06028-MAS02317,Control head button operation-Button code 1,Not available,
IDE06028-MAS02318,Control head button operation-Button code 2,Not available,
IDE06028-MAS04151,Control head button operation-Joystick,Not available,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,Not available,
IDE06028-MAS04414,Control head button operation-Volume control,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,Not available,
IDE06517-MAS01425,Temperature: audio amplifier-min.value,Not available,
IDE06517-MAS02238,Temperature: audio amplifier-Current,Not available,
IDE06522-MAS01424,Temperature of phone unit-max.value,Not available,
IDE06522-MAS01425,Temperature of phone unit-min.value,Not available,
IDE06522-MAS02238,Temperature of phone unit-Current,Not available,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,0 s,
IDE09544-ENG170421,Locking information electronic 1 operation-IoReached Status,Actuator test terminated due to client request,
IDE10300,OBD Driving Cycle detected,active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10479-MAS01482,Interface for external media: identification-Hardware version,009,
IDE10479-MAS01483,Interface for external media: identification-Software version,0319,
IDE10479-MAS04970,Interface for external media: identification-Part Number,5NA035736,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,0 s,
IDE10481-ENG170421,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,1,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name,Hardware version,Bootloader version,Application version|emmc_device,itron_app.image,34,00 1B 77 40,00 1B 77 40|emmc_device,linux_app.image,34,00 1B 77 40,00 1B 77 40|emmc_device,hmi_app.image,34,00 1B 77 40,00 1B 77 40|nor_device,itron_boot.image,34,00 1B 77 40,00 1B 77 40|ScriptInstaller,script.module,34,00 0F 46 28,00 0F 46 28|securekey_device,itron_app.image:emmcd:p1:sig,34,00 0F 42 40,00 0F 42 40|securekey_device,itron_app.image:mima:p1:sig,34,00 0F 42 40,00 0F 42 40|securekey_device,linux_app.image:gd:p1:sig,34,00 0F 42 40,00 0F 42 40|securekey_device,linux_app.image:zImage:p1:sig,34,00 0F 42 40,00 0F 42 40|securekey_device,linux_app.image:lima:p1:sig,34,00 0F 42 40,00 0F 42 40|securekey_device,hmi_app.image:tima:p1:sig,34,00 0F 42 40,00 0F 42 40|securekey_device,itron_boot.image:nor:p1:sig,34,00 0F 42 40,00 0F 42 40|RH850_device,RH850.image,34,00 1B 77 40,00 1B 77 40|securekey_device,itron_app.imaÝObNÁage:m,105,6D 61 3A 70,32 3A 73 69|g"B@B@securekey_device,age:mima:p2:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,linux_app.image:gd:p2:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,linux_app.image:zImage:p2:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,linux_app.image:lima:p2:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,hmi_app.image:tima:p2:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,itron_boot.image:nor:p2:sig,0,22 00 0F 42,40 00 0F 42|@nor_emerg_device,itron_emrg.image,0,22 00 10 9A,00 00 10 9A|nor_emerg_device,linux_emrg.image,0,22 00 10 76,D9 00 10 76|Ùtnr_device,tnr_module,0,22 00 0F 46,28 00 0F 46|(securekey_device,itron_emrg.image:nobb:p0:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,itron_emrg.image:nobf:p0:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,itron_emrg.image:norb:p0:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,linux_emrg.image:dtb:p0:sig,0,22 00 0F 42,40 00 0F 42|@securekey_device,linux_emrg.image:lb:p0:sig,0,22 00 0F 42,40 00 0F 42|@securekey_deviceÝ¿bNÁ,linux_emrg.image:zIm,58,70 30 3A 73,69 67 00 00|"B@B@nor_devi,linux_emrg.image:zIm:p0:sig,0,00 22 00 0F,42 40 00 0F|B@nor_device,linux_boot.image,0,00 22 00 10,72 F1 00 10|rñsecurekey_device,linux_boot.image:nor:p1:sig,0,00 22 00 0F,42 40 00 0F|B@tunerdb_device,tunerdb,0,00 22 00 0F,B7 7A 00 0F|·zsaturn_device,saturn.image,0,00 22 00 00,00 09 00 00| amigo_device,amigo.image,0,00 22 00 6C,46 C0 00 6C|FÀsecurekey_device,linux_boot.image:nor:p2:sig,0,00 22 00 0F,42 40 00 0F|B@securekey_device,hmi_app:image:tima:p1:sig,0,00 22 00 0F,42 40 00 0F|B@filebased_device,updmng_oldkey,0,00 22 00 10,5F 68 00 10|_hhsm_device,rsdb_keys.image,0,00 22 00 0F,46 28 00 0F|F(securekey_device,hmi_app:image:tima:p2:sig,0,00 22 00 0F,42 40 00 0F|B@securekey_device,itron_app.image:emmct:p1:sig,0,00 22 00 0F,42 40 00 0F|B@securekey_device,itron_app.image:emmct:p2:sig,0,00 22 00 0F,42 40 00 0F|B@,,0,00 00 00 00,00 00 00 00|,
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,Available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,0,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 EE 65 CC FF FE 71 D1 DB|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 17|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 2D|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 02|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|3|0|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|EC 65 CC 71 D1 DB|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,0|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|EC 65 CC 71 D1 DB|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|2|3|0|0|0|0|0|0|0|0|,
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Test not yet carried out|,
IDE12554-IDE08145,Antenna status for local wireless network-Connection status antenna 1,electrically OK,
IDE12554-IDE08146,Antenna status for local wireless network-Connection status antenna 2,electrically OK,
IDE12625,IP network: current link deceleration: branch 1,3040, ns
IDE12633,IP Network maximum correction of the synchronized clock,3768, ns
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,0 s,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,4,
IDE14344,Automotive audio bus (A2B): status,|Node number,Node name,Node status|0,Information electronics control module 1,OK|1,Emergency call module and communication unit,OK|2,Microphone module in roof,OK|,
IDE14344-ENG249700,Automotive audio bus (A2B): status-amount_of_nodes,2,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,0,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,911.00, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,10,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,10,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),Not available,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,0, %
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Field intensity,11,
MAS03782-MAS17355,WLAN-MAC address 2: tethering,00 00 00 00 00 00,
MAS03782-MAS17356,WLAN-MAC address 1,00 00 00 00 00 00,
MAS03782-MAS17357,WLAN-MAC address 2,00 00 00 00 00 00,
MAS03782-MAS17559,WLAN-MAC address 1: tethering,00 00 00 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,61 B1 B4 14,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1639,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via SWaP,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,BF FF,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG249161-MAS01167,Operating_Unit_Simulation_Keys_status-Actuation time,0 s,
ENG249161-ENG170421,Operating_Unit_Simulation_Keys_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 00:29
;SW:5WA-614-517-BL HW:5WA-614-517-N --- 03: ABS Brakes
;Component:ESC H13 0133, Coding:36FC6C9056236A759377600106C760064A5258505A88030820B4B831018FF100002814
;EV_Brake1ESCEPBMQB37W,013056,EV_Brake1ESCEPBMQB37W_013_VW38.rod
;Tuesday,01,September,2026,18:57:02:51924
;VCID: 137460C89BF925D24A2-8046 SFD [x]
IDE00820-ENG264053-Activating and deactivating all development messages-Activation of Development Message EPB00,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264054-Activating and deactivating all development messages-Activation of Development Message EPB01,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264055-Activating and deactivating all development messages-Activation of Development Message EPB02,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264056-Activating and deactivating all development messages-Activation of Development Message ESC00,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264057-Activating and deactivating all development messages-Activation of Development Message ESC01,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264058-Activating and deactivating all development messages-Activation of Development Message ESC02,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264059-Activating and deactivating all development messages-Activation of Development Message ESC03,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264060-Activating and deactivating all development messages-Activation of Development Message ESC04,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264061-Activating and deactivating all development messages-Activation of Development Message ESC05,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264062-Activating and deactivating all development messages-Activation of Development Message ESC06,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264063-Activating and deactivating all development messages-Activation of Development Message ESC07,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264064-Activating and deactivating all development messages-Activation of Development Message ESC08,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264065-Activating and deactivating all development messages-Activation of Development Message ESC10,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE00820-ENG264066-Activating and deactivating all development messages-Activation of Development Message FDR01,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE03659-Roller test bench mode,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE04456-Brake disk drying,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE04765-Counter steer support,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE05055-Hydraulic brake assistant,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE05057-Brake prefill,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE05161-Straight ahead brake stabilization,Security access required;You should unlock SFD before attempting advanced functions.,3
IDE07292-Brake pre-filling,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE07565-ABS in lower speed range,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE11985-Expected OBD requirements,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE12030-Rough road optimization,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-IDE07280-Delay and hold management-Multiple collision brake,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS00919-Delay and hold management-Pedestrian protection,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS05087-Delay and hold management-ACC,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS05506-Delay and hold management-Stopping distance reduction,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS10858-Delay and hold management-Rear camera,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS12321-Delay and hold management-Trailer maneuvering system,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS15696-Delay and hold management-Rear cross traffic assistant,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS15806-Delay and hold management-Parking assist,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14225-MAS18082-Delay and hold management-Emergency assistant,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE14226-Electronic engine braking torque reduction,Security access required;You should unlock SFD before attempting advanced functions.,2
IDE15332-MAS17834-Vehicle curb weight-Curb weight of rear axle,564.0 kg,4
IDE15332-MAS17837-Vehicle curb weight-Curb weight of front axle,929.0 kg,4
MAS03691-Dimming,Security access required;You should unlock SFD before attempting advanced functions.,4
MAS09595-IDE01211-Production mode-Static current measuring mode,Deactivating ,3
MAS09595-IDE02939-Production mode-Activate/lock control,Deactivating ,3
MAS09595-IDE09543-Production mode-Vehicle holding function,Deactivating ,3
MAS09595-MAS16682-Production mode-Production mode after-run monitoring,Deactivating ,3
MAS09595-MAS18521-Production mode-Production mode: recuperation,Deactivating ,3
MAS09595-Production mode-,not active ,3
MAS14035-Precondition,Security access required;You should unlock SFD before attempting advanced functions.,3
MAS16144-Wheel loose detection: warning threshold,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264022-Developer_Function_01,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264037-Developer_Function_02,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264035-ENG264163-Developer_Function_03-Developer_Function_03_Bremsdrucksensor,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264035-ENG264164-Developer_Function_03-Developer_Function_03_PYA,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264021-Developer_Function_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG264130-dimming_characteristic_1-Daempfung_Abdimmen_KL_58xD_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG154584-dimming_characteristic_1-Daempfung_Aufdimmen_KL_58xd_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG101574-dimming_characteristic_1-X1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG99557-dimming_characteristic_1-X2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG102140-dimming_characteristic_1-X3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG102936-dimming_characteristic_1-X4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG103548-dimming_characteristic_1-X5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG113992-dimming_characteristic_1-X6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG99777-dimming_characteristic_1-Y1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG100480-dimming_characteristic_1-Y2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG100773-dimming_characteristic_1-Y3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG100631-dimming_characteristic_1-Y4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG102174-dimming_characteristic_1-Y5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122844-ENG113993-dimming_characteristic_1-Y6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG264130-dimming_characteristic_2-Daempfung_Abdimmen_KL_58xD_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG154584-dimming_characteristic_2-Daempfung_Aufdimmen_KL_58xd_PWM,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG101574-dimming_characteristic_2-X1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG99557-dimming_characteristic_2-X2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG102140-dimming_characteristic_2-X3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG102936-dimming_characteristic_2-X4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG103548-dimming_characteristic_2-X5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG113992-dimming_characteristic_2-X6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG99777-dimming_characteristic_2-Y1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG100480-dimming_characteristic_2-Y2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG100773-dimming_characteristic_2-Y3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG100631-dimming_characteristic_2-Y4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG102174-dimming_characteristic_2-Y5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG122845-ENG113993-dimming_characteristic_2-Y6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264073-Dynamic_Developer_Function_01-ASAP_Address_0,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264074-Dynamic_Developer_Function_01-ASAP_Address_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264075-Dynamic_Developer_Function_01-ASAP_Address_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264076-Dynamic_Developer_Function_01-ASAP_Address_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264077-Dynamic_Developer_Function_01-ASAP_Address_11,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264078-Dynamic_Developer_Function_01-ASAP_Address_12,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264079-Dynamic_Developer_Function_01-ASAP_Address_13,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264080-Dynamic_Developer_Function_01-ASAP_Address_14,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264081-Dynamic_Developer_Function_01-ASAP_Address_15,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264082-Dynamic_Developer_Function_01-ASAP_Address_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264083-Dynamic_Developer_Function_01-ASAP_Address_3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264084-Dynamic_Developer_Function_01-ASAP_Address_4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264085-Dynamic_Developer_Function_01-ASAP_Address_5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264086-Dynamic_Developer_Function_01-ASAP_Address_6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264087-Dynamic_Developer_Function_01-ASAP_Address_7,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264088-Dynamic_Developer_Function_01-ASAP_Address_8,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264089-Dynamic_Developer_Function_01-ASAP_Address_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264090-Dynamic_Developer_Function_01-ASAP_Address_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264091-Dynamic_Developer_Function_01-ASAP_Address_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264092-Dynamic_Developer_Function_01-ASAP_Address_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264093-Dynamic_Developer_Function_01-ASAP_Address_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264094-Dynamic_Developer_Function_01-ASAP_Address_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264095-Dynamic_Developer_Function_01-ASAP_Address_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264096-Dynamic_Developer_Function_01-ASAP_Address_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264097-Dynamic_Developer_Function_01-ASAP_Address_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264098-Dynamic_Developer_Function_01-ASAP_Address_9,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264099-Dynamic_Developer_Function_01-ASAP_Address_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264100-Dynamic_Developer_Function_01-ASAP_Address_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264101-Dynamic_Developer_Function_01-ASAP_Address_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264102-Dynamic_Developer_Function_01-ASAP_Address_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264103-Dynamic_Developer_Function_01-ASAP_Address_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264104-Dynamic_Developer_Function_01-ASAP_Address_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264105-Dynamic_Developer_Function_01-ASAP_Address_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264106-Dynamic_Developer_Function_01-ASAP_Address_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264107-Dynamic_Developer_Function_01-ASAP_Address_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264108-Dynamic_Developer_Function_01-ASAP_Address_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264109-Dynamic_Developer_Function_01-ASAP_Data_Type_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264110-Dynamic_Developer_Function_01-ASAP_Data_Type_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264111-Dynamic_Developer_Function_01-ASAP_Data_Type_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264112-Dynamic_Developer_Function_01-ASAP_Data_Type_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264113-Dynamic_Developer_Function_01-ASAP_Data_Type_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264114-Dynamic_Developer_Function_01-ASAP_Data_Type_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264115-Dynamic_Developer_Function_01-ASAP_Data_Type_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264116-Dynamic_Developer_Function_01-ASAP_Data_Type_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264117-Dynamic_Developer_Function_01-ASAP_Data_Type_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264118-Dynamic_Developer_Function_01-ASAP_Data_Type_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264119-Dynamic_Developer_Function_01-ASAP_Data_Type_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264120-Dynamic_Developer_Function_01-ASAP_Data_Type_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264121-Dynamic_Developer_Function_01-ASAP_Data_Type_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264122-Dynamic_Developer_Function_01-ASAP_Data_Type_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264123-Dynamic_Developer_Function_01-ASAP_Data_Type_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264124-Dynamic_Developer_Function_01-ASAP_Data_Type_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264125-Dynamic_Developer_Function_01-ASAP_Data_Type_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264126-Dynamic_Developer_Function_01-ASAP_Data_Type_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264127-Dynamic_Developer_Function_01-ASAP_Data_Type_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264128-Dynamic_Developer_Function_01-ASAP_Data_Type_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264131-Dynamic_Developer_Function_01-Data_position_0_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264132-Dynamic_Developer_Function_01-Data_position_0_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264133-Dynamic_Developer_Function_01-Data_position_1_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264134-Dynamic_Developer_Function_01-Data_position_1_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264135-Dynamic_Developer_Function_01-Data_position_10_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264136-Dynamic_Developer_Function_01-Data_position_10_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264137-Dynamic_Developer_Function_01-Data_position_11_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264138-Dynamic_Developer_Function_01-Data_position_11_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264139-Dynamic_Developer_Function_01-Data_position_12_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264140-Dynamic_Developer_Function_01-Data_position_12_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264141-Dynamic_Developer_Function_01-Data_position_13_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264142-Dynamic_Developer_Function_01-Data_position_13_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264143-Dynamic_Developer_Function_01-Data_position_14_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264144-Dynamic_Developer_Function_01-Data_position_14_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264145-Dynamic_Developer_Function_01-Data_position_15_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264146-Dynamic_Developer_Function_01-Data_position_15_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264147-Dynamic_Developer_Function_01-Data_position_2_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264148-Dynamic_Developer_Function_01-Data_position_2_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264149-Dynamic_Developer_Function_01-Data_position_3_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264150-Dynamic_Developer_Function_01-Data_position_3_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264151-Dynamic_Developer_Function_01-Data_position_4_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264152-Dynamic_Developer_Function_01-Data_position_4_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264153-Dynamic_Developer_Function_01-Data_position_5_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264154-Dynamic_Developer_Function_01-Data_position_5_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264155-Dynamic_Developer_Function_01-Data_position_6_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264156-Dynamic_Developer_Function_01-Data_position_6_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264157-Dynamic_Developer_Function_01-Data_position_7_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264158-Dynamic_Developer_Function_01-Data_position_7_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264159-Dynamic_Developer_Function_01-Data_position_8_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264160-Dynamic_Developer_Function_01-Data_position_8_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264161-Dynamic_Developer_Function_01-Data_position_9_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264162-Dynamic_Developer_Function_01-Data_position_9_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264166-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264029-ENG264167-Dynamic_Developer_Function_01-Dynamic_Developer_Function_Groupe_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264073-Dynamic_Developer_Function_02-ASAP_Address_0,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264074-Dynamic_Developer_Function_02-ASAP_Address_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264075-Dynamic_Developer_Function_02-ASAP_Address_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264076-Dynamic_Developer_Function_02-ASAP_Address_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264077-Dynamic_Developer_Function_02-ASAP_Address_11,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264078-Dynamic_Developer_Function_02-ASAP_Address_12,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264079-Dynamic_Developer_Function_02-ASAP_Address_13,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264080-Dynamic_Developer_Function_02-ASAP_Address_14,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264081-Dynamic_Developer_Function_02-ASAP_Address_15,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264082-Dynamic_Developer_Function_02-ASAP_Address_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264083-Dynamic_Developer_Function_02-ASAP_Address_3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264084-Dynamic_Developer_Function_02-ASAP_Address_4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264085-Dynamic_Developer_Function_02-ASAP_Address_5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264086-Dynamic_Developer_Function_02-ASAP_Address_6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264087-Dynamic_Developer_Function_02-ASAP_Address_7,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264088-Dynamic_Developer_Function_02-ASAP_Address_8,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264089-Dynamic_Developer_Function_02-ASAP_Address_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264090-Dynamic_Developer_Function_02-ASAP_Address_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264091-Dynamic_Developer_Function_02-ASAP_Address_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264092-Dynamic_Developer_Function_02-ASAP_Address_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264093-Dynamic_Developer_Function_02-ASAP_Address_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264094-Dynamic_Developer_Function_02-ASAP_Address_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264095-Dynamic_Developer_Function_02-ASAP_Address_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264096-Dynamic_Developer_Function_02-ASAP_Address_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264097-Dynamic_Developer_Function_02-ASAP_Address_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264098-Dynamic_Developer_Function_02-ASAP_Address_9,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264099-Dynamic_Developer_Function_02-ASAP_Address_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264100-Dynamic_Developer_Function_02-ASAP_Address_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264101-Dynamic_Developer_Function_02-ASAP_Address_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264102-Dynamic_Developer_Function_02-ASAP_Address_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264103-Dynamic_Developer_Function_02-ASAP_Address_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264104-Dynamic_Developer_Function_02-ASAP_Address_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264105-Dynamic_Developer_Function_02-ASAP_Address_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264106-Dynamic_Developer_Function_02-ASAP_Address_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264107-Dynamic_Developer_Function_02-ASAP_Address_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264108-Dynamic_Developer_Function_02-ASAP_Address_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264109-Dynamic_Developer_Function_02-ASAP_Data_Type_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264110-Dynamic_Developer_Function_02-ASAP_Data_Type_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264111-Dynamic_Developer_Function_02-ASAP_Data_Type_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264112-Dynamic_Developer_Function_02-ASAP_Data_Type_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264113-Dynamic_Developer_Function_02-ASAP_Data_Type_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264114-Dynamic_Developer_Function_02-ASAP_Data_Type_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264115-Dynamic_Developer_Function_02-ASAP_Data_Type_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264116-Dynamic_Developer_Function_02-ASAP_Data_Type_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264117-Dynamic_Developer_Function_02-ASAP_Data_Type_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264118-Dynamic_Developer_Function_02-ASAP_Data_Type_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264119-Dynamic_Developer_Function_02-ASAP_Data_Type_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264120-Dynamic_Developer_Function_02-ASAP_Data_Type_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264121-Dynamic_Developer_Function_02-ASAP_Data_Type_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264122-Dynamic_Developer_Function_02-ASAP_Data_Type_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264123-Dynamic_Developer_Function_02-ASAP_Data_Type_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264124-Dynamic_Developer_Function_02-ASAP_Data_Type_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264125-Dynamic_Developer_Function_02-ASAP_Data_Type_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264126-Dynamic_Developer_Function_02-ASAP_Data_Type_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264127-Dynamic_Developer_Function_02-ASAP_Data_Type_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264128-Dynamic_Developer_Function_02-ASAP_Data_Type_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264131-Dynamic_Developer_Function_02-Data_position_0_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264132-Dynamic_Developer_Function_02-Data_position_0_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264133-Dynamic_Developer_Function_02-Data_position_1_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264134-Dynamic_Developer_Function_02-Data_position_1_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264135-Dynamic_Developer_Function_02-Data_position_10_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264136-Dynamic_Developer_Function_02-Data_position_10_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264137-Dynamic_Developer_Function_02-Data_position_11_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264138-Dynamic_Developer_Function_02-Data_position_11_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264139-Dynamic_Developer_Function_02-Data_position_12_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264140-Dynamic_Developer_Function_02-Data_position_12_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264141-Dynamic_Developer_Function_02-Data_position_13_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264142-Dynamic_Developer_Function_02-Data_position_13_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264143-Dynamic_Developer_Function_02-Data_position_14_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264144-Dynamic_Developer_Function_02-Data_position_14_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264145-Dynamic_Developer_Function_02-Data_position_15_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264146-Dynamic_Developer_Function_02-Data_position_15_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264147-Dynamic_Developer_Function_02-Data_position_2_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264148-Dynamic_Developer_Function_02-Data_position_2_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264149-Dynamic_Developer_Function_02-Data_position_3_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264150-Dynamic_Developer_Function_02-Data_position_3_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264151-Dynamic_Developer_Function_02-Data_position_4_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264152-Dynamic_Developer_Function_02-Data_position_4_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264153-Dynamic_Developer_Function_02-Data_position_5_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264154-Dynamic_Developer_Function_02-Data_position_5_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264155-Dynamic_Developer_Function_02-Data_position_6_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264156-Dynamic_Developer_Function_02-Data_position_6_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264157-Dynamic_Developer_Function_02-Data_position_7_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264158-Dynamic_Developer_Function_02-Data_position_7_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264159-Dynamic_Developer_Function_02-Data_position_8_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264160-Dynamic_Developer_Function_02-Data_position_8_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264161-Dynamic_Developer_Function_02-Data_position_9_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264162-Dynamic_Developer_Function_02-Data_position_9_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264166-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264027-ENG264167-Dynamic_Developer_Function_02-Dynamic_Developer_Function_Groupe_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264073-Dynamic_Developer_Function_03-ASAP_Address_0,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264074-Dynamic_Developer_Function_03-ASAP_Address_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264075-Dynamic_Developer_Function_03-ASAP_Address_10,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264076-Dynamic_Developer_Function_03-ASAP_Address_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264077-Dynamic_Developer_Function_03-ASAP_Address_11,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264078-Dynamic_Developer_Function_03-ASAP_Address_12,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264079-Dynamic_Developer_Function_03-ASAP_Address_13,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264080-Dynamic_Developer_Function_03-ASAP_Address_14,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264081-Dynamic_Developer_Function_03-ASAP_Address_15,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264082-Dynamic_Developer_Function_03-ASAP_Address_2,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264083-Dynamic_Developer_Function_03-ASAP_Address_3,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264084-Dynamic_Developer_Function_03-ASAP_Address_4,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264085-Dynamic_Developer_Function_03-ASAP_Address_5,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264086-Dynamic_Developer_Function_03-ASAP_Address_6,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264087-Dynamic_Developer_Function_03-ASAP_Address_7,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264088-Dynamic_Developer_Function_03-ASAP_Address_8,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264089-Dynamic_Developer_Function_03-ASAP_Address_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264090-Dynamic_Developer_Function_03-ASAP_Address_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264091-Dynamic_Developer_Function_03-ASAP_Address_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264092-Dynamic_Developer_Function_03-ASAP_Address_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264093-Dynamic_Developer_Function_03-ASAP_Address_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264094-Dynamic_Developer_Function_03-ASAP_Address_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264095-Dynamic_Developer_Function_03-ASAP_Address_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264096-Dynamic_Developer_Function_03-ASAP_Address_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264097-Dynamic_Developer_Function_03-ASAP_Address_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264098-Dynamic_Developer_Function_03-ASAP_Address_9,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264099-Dynamic_Developer_Function_03-ASAP_Address_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264100-Dynamic_Developer_Function_03-ASAP_Address_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264101-Dynamic_Developer_Function_03-ASAP_Address_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264102-Dynamic_Developer_Function_03-ASAP_Address_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264103-Dynamic_Developer_Function_03-ASAP_Address_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264104-Dynamic_Developer_Function_03-ASAP_Address_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264105-Dynamic_Developer_Function_03-ASAP_Address_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264106-Dynamic_Developer_Function_03-ASAP_Address_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264107-Dynamic_Developer_Function_03-ASAP_Address_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264108-Dynamic_Developer_Function_03-ASAP_Address_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264109-Dynamic_Developer_Function_03-ASAP_Data_Type_100,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264110-Dynamic_Developer_Function_03-ASAP_Data_Type_81,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264111-Dynamic_Developer_Function_03-ASAP_Data_Type_82,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264112-Dynamic_Developer_Function_03-ASAP_Data_Type_83,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264113-Dynamic_Developer_Function_03-ASAP_Data_Type_84,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264114-Dynamic_Developer_Function_03-ASAP_Data_Type_85,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264115-Dynamic_Developer_Function_03-ASAP_Data_Type_86,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264116-Dynamic_Developer_Function_03-ASAP_Data_Type_87,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264117-Dynamic_Developer_Function_03-ASAP_Data_Type_88,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264118-Dynamic_Developer_Function_03-ASAP_Data_Type_89,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264119-Dynamic_Developer_Function_03-ASAP_Data_Type_90,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264120-Dynamic_Developer_Function_03-ASAP_Data_Type_91,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264121-Dynamic_Developer_Function_03-ASAP_Data_Type_92,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264122-Dynamic_Developer_Function_03-ASAP_Data_Type_93,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264123-Dynamic_Developer_Function_03-ASAP_Data_Type_94,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264124-Dynamic_Developer_Function_03-ASAP_Data_Type_95,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264125-Dynamic_Developer_Function_03-ASAP_Data_Type_96,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264126-Dynamic_Developer_Function_03-ASAP_Data_Type_97,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264127-Dynamic_Developer_Function_03-ASAP_Data_Type_98,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264128-Dynamic_Developer_Function_03-ASAP_Data_Type_99,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264131-Dynamic_Developer_Function_03-Data_position_0_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264132-Dynamic_Developer_Function_03-Data_position_0_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264133-Dynamic_Developer_Function_03-Data_position_1_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264134-Dynamic_Developer_Function_03-Data_position_1_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264135-Dynamic_Developer_Function_03-Data_position_10_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264136-Dynamic_Developer_Function_03-Data_position_10_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264137-Dynamic_Developer_Function_03-Data_position_11_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264138-Dynamic_Developer_Function_03-Data_position_11_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264139-Dynamic_Developer_Function_03-Data_position_12_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264140-Dynamic_Developer_Function_03-Data_position_12_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264141-Dynamic_Developer_Function_03-Data_position_13_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264142-Dynamic_Developer_Function_03-Data_position_13_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264143-Dynamic_Developer_Function_03-Data_position_14_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264144-Dynamic_Developer_Function_03-Data_position_14_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264145-Dynamic_Developer_Function_03-Data_position_15_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264146-Dynamic_Developer_Function_03-Data_position_15_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264147-Dynamic_Developer_Function_03-Data_position_2_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264148-Dynamic_Developer_Function_03-Data_position_2_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264149-Dynamic_Developer_Function_03-Data_position_3_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264150-Dynamic_Developer_Function_03-Data_position_3_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264151-Dynamic_Developer_Function_03-Data_position_4_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264152-Dynamic_Developer_Function_03-Data_position_4_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264153-Dynamic_Developer_Function_03-Data_position_5_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264154-Dynamic_Developer_Function_03-Data_position_5_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264155-Dynamic_Developer_Function_03-Data_position_6_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264156-Dynamic_Developer_Function_03-Data_position_6_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264157-Dynamic_Developer_Function_03-Data_position_7_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264158-Dynamic_Developer_Function_03-Data_position_7_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264159-Dynamic_Developer_Function_03-Data_position_8_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264160-Dynamic_Developer_Function_03-Data_position_8_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264161-Dynamic_Developer_Function_03-Data_position_9_Bit_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264162-Dynamic_Developer_Function_03-Data_position_9_Byte_position,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264166-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_1,Security access required;You should unlock SFD before attempting advanced functions.,3
ENG264028-ENG264167-Dynamic_Developer_Function_03-Dynamic_Developer_Function_Groupe_2,Security access required;You should unlock SFD before attempting advanced functions.,3
Elapsed Time: 00:14
;Tuesday,01,September,2026,18:56:45:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
Group,Description,Actual
IDE00019,Voltage terminal 30,12.539, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,82.0, °C
IDE00085,Normed load value,0, %
IDE00086,Accelerator pedal position,14.1, %
IDE00097,OBD - requirements for which this vehicle is designed,OBD and OBD II,
IDE00601-ENG161107,Monitoring status since erasing DTC memory-MIL_Status,OFF,
IDE00601-ENG161129,Monitoring status since erasing DTC memory-Number_of_errors_Mode$03,0,
IDE00601-ENG161142,Monitoring status since erasing DTC memory-Readiness_State,00000000 ,
IDE00601-ENG161227,Monitoring status since erasing DTC memory-Supported_Info,00000000 ,
IDE00601-ENG161228,Monitoring status since erasing DTC memory-Supported_Info_Readiness,00000100 ,
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,CD9NW139014,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,On,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS01299,Stop process prevented-Offroad,not active,
IDE03008-MAS01478,Stop process prevented-insufficient voltage,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,67,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.braking,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,1,
IDE03010-MAS01299,Number of prevented stop processes-Offroad,0,
IDE03010-MAS01478,Number of prevented stop processes-insufficient voltage,10,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,38,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,31501,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,1,
IDE03011-MAS02515,Number of requested start processes-System malfunction,40,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03310,Brake lamp,OFF,
IDE03310-MAS01167,Brake lamp-Actuation time,0 s,
IDE03310-ENG170421,Brake lamp-IoReached Status,Output diagnostic test not active,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,4.9, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,12.6, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,12.5, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,12.5, V
IDE03680-MAS01468,Supply voltages-Terminal 15,On,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.11, bar
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Not available due to specific system,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.00, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04425-MAS09580,Left front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.00, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-MAS09580,Right front ABS wheel speed sensor-Sensor status,No malfunction,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.00, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04427-MAS09580,Left rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.00, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-MAS09580,Right rear ABS wheel speed sensor-Sensor status,No malfunction,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.16677, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-0.09810, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.00000, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.00000, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.326, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,-2.931, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,-4.069, °
IDE04446-IDE14988,Hill descent control-Incline,0, %
IDE04446-MAS01299,Hill descent control-Offroad,Off-road deactivated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04446-MAS05585,Hill descent control-Standby,not active,
IDE04446-MAS12601,Hill descent control-HDC intervention,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not available due to specific system,
IDE04452-IDE03664,Brake system button-Button for driving program,Not available due to specific system,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,29916, km
IDE04461-MAS01481,Internal measured values-Temperature in control module,64.6, °C
IDE04461-MAS10973,Internal measured values-Hardware reset,9,
IDE04461-MAS10974,Internal measured values-Software reset,3699,
IDE04461-MAS15830,Internal measured values-Data block description,Block 2,
IDE04461-MAS17870,Internal measured values-Number of resets,0,
IDE04461-ENG264503,Internal measured values-C1 Idle Task,42, %
IDE04461-ENG264509,Internal measured values-Ct mainloop,51, %
IDE04461-ENG264510,Internal measured values-Ct prc task,53, %
IDE04461-ENG264511,Internal measured values-Ct valve task,53, %
IDE04461-ENG126445,Internal measured values-Idle Task,33, %
IDE04461-ENG264549,Internal measured values-Idp Task,33, %
IDE04461-ENG264551,Internal measured values-Ipb main task,15, %
IDE04461-ENG264552,Internal measured values-Ipb safety task,75, %
IDE04461-ENG264663,Internal measured values-Task BAP 10ms,44, %
IDE04461-ENG264664,Internal measured values-Task C0 Com task 5ms AsilD,0, %
IDE04461-ENG264665,Internal measured values-Task C1 10ms AsilB,39, %
IDE04461-ENG264666,Internal measured values-Task C1 1ms AsilB,36, %
IDE04461-ENG264667,Internal measured values-Task Com task1 5ms AsilD,41, %
IDE04461-ENG264668,Internal measured values-Task Com task1 5ms Qm,47, %
IDE04461-ENG264669,Internal measured values-Task Com task2 5ms Qm,68, %
IDE04461-ENG264670,Internal measured values-Task mFDR 5ms_AsilD,59, %
IDE04461-ENG264671,Internal measured values-Task mFDR 5ms_Qm,64, %
IDE04461-ENG264672,Internal measured values-Task TPI 20ms,50, %
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,not activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,not activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,0, m/s²
IDE04765-IDE02955,Counter steer support-System status,Not available due to specific system,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,0, km
IDE04772,Indicator light in the button for electromech. parking brake,On,
IDE04772-MAS01167,Indicator light in the button for electromech. parking brake-Actuation time,Without time limit,
IDE04772-ENG170421,Indicator light in the button for electromech. parking brake-IoReached Status,Output diagnostic test not active,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Not available due to specific system,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04939-IDE02763,Tire Pressure Monitoring System (TPMS)-System malfunction lamp: status,OFF,
IDE04939-IDE02765,Tire Pressure Monitoring System (TPMS)-Pressure warning lamp: status,OFF,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,30598, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,23167, km
IDE04939-IDE09286,Tire Pressure Monitoring System (TPMS)-Software version of tire monitoring display,R1906A26,
IDE04939-IDE09287,Tire Pressure Monitoring System (TPMS)-Param. set version tire press monitoring display,0,
IDE04939-IDE09288,Tire Pressure Monitoring System (TPMS)-Param. set tire press monitor display: checksum,32,
IDE04939-IDE09289,Tire Pressure Monitoring System (TPMS)-Tire press monitor.display: diagnosis status,00 00 20 02 00 00 00 60 00 30,
IDE04939-IDE11039,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: le. frt,255,
IDE04939-IDE11040,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast pres.loss: ri. frt.,254,
IDE04939-IDE11041,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.:counter for fast press. loss: le. rr.,255,
IDE04939-IDE11042,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for fast press. loss: ri. rr.,255,
IDE04939-IDE11043,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. frt,245,
IDE04939-IDE11044,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. frt.,245,
IDE04939-IDE11045,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: le. rr.,245,
IDE04939-IDE11046,Tire Pressure Monitoring System (TPMS)-Tire pr.monit.sys.: counter for slow press. loss: ri. rr.,245,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2026,
IDE04939-MAS00106,Tire Pressure Monitoring System (TPMS)-Year,2025,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,8,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,5,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,6,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,7,
IDE04939-MAS00107,Tire Pressure Monitoring System (TPMS)-Month,4,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,20,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,8,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,13,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,12,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,23,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,26,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,1,
IDE04939-MAS00108,Tire Pressure Monitoring System (TPMS)-Day,6,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,17,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,20,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,13,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,15,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,0,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,14,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,16,
IDE04939-MAS00109,Tire Pressure Monitoring System (TPMS)-Hours,9,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,30,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,0,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,31,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,47,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,4,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,25,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,8,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,33,
IDE04939-MAS00110,Tire Pressure Monitoring System (TPMS)-Minutes,35,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,18,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,11,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,43,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,59,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,53,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,4,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,36,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,42,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,7,
IDE04939-MAS00111,Tire Pressure Monitoring System (TPMS)-Seconds,51,
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,29983, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,25316, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,23619, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,23167, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,23167, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,23078, km
IDE04939-MAS14292,Tire Pressure Monitoring System (TPMS)-Analysis data of latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14293,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14294,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14295,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest programming,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS14296,Tire Pressure Monitoring System (TPMS)-Analysis data of the latest warning,02 25 01 A8 00 00 00 00 00 10,
IDE04939-MAS14297,Tire Pressure Monitoring System (TPMS)-Analysis data of the second latest warning,02 25 01 A8 00 00 00 00 00 10,
IDE04939-MAS14298,Tire Pressure Monitoring System (TPMS)-Analysis data of the third latest warning,01 21 00 00 00 00 00 00 00 10,
IDE04939-MAS14299,Tire Pressure Monitoring System (TPMS)-Analysis data of the fourth latest warning,01 21 00 00 00 00 00 00 00 10,
IDE04939-MAS18039,Tire Pressure Monitoring System (TPMS)-Odometer reading at fifth most recent configuration,19839, km
IDE04939-MAS18041,Tire Pressure Monitoring System (TPMS)-Analysis data from fifth most recent configuration,00 00 00 00 00 00 00 00 00 10,
IDE04939-MAS18042,Tire Pressure Monitoring System (TPMS)-Temperature at time of most recent warning,22, °C
IDE04939-MAS18066,Tire Pressure Monitoring System (TPMS)-Temperature at time of second to last warning,31, °C
IDE04939-MAS18067,Tire Pressure Monitoring System (TPMS)-Temperature at time of third most recent warning,32, °C
IDE04939-MAS18069,Tire Pressure Monitoring System (TPMS)-Temperature at time of fourth most recent warning,0, °C
IDE04939-MAS18070,Tire Pressure Monitoring System (TPMS)-Odometer reading of fifth most recent warning,4294967295, km
IDE04939-MAS18072,Tire Pressure Monitoring System (TPMS)-Temperature at time of fifth most recent warning,24, °C
IDE04939-MAS18073,Tire Pressure Monitoring System (TPMS)-Analysis data of fifth most recent warning,01 21 00 00 00 00 00 00 00 10,
IDE04939-MAS18074,Tire Pressure Monitoring System (TPMS)-Tire control display parameter set info,195,
IDE04939-MAS18076,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during most recent warning,30, °C
IDE04939-MAS18077,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during second most recent warning,30, °C
IDE04939-MAS18078,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during third most recent warning,15, °C
IDE04939-MAS18079,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fourth most recent warning,15, °C
IDE04939-MAS18080,Tire Pressure Monitoring System (TPMS)-Mean temperature calibration during fifth most recent warning,15, °C
IDE04939-ENG135557,Tire Pressure Monitoring System (TPMS)-RKA_Config_Info, ,
IDE05053,Right parking brake motor: close gradually,Open,
IDE05053-MAS01167,Right parking brake motor: close gradually-Actuation time,Without time limit,
IDE05053-ENG170421,Right parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05054,Left parking brake motor: close gradually,Open,
IDE05054-MAS01167,Left parking brake motor: close gradually-Actuation time,Without time limit,
IDE05054-ENG170421,Left parking brake motor: close gradually-IoReached Status,Output diagnostic test not active,
IDE05333,Indicator light in AUTO HOLD button,OFF,
IDE05333-MAS01167,Indicator light in AUTO HOLD button-Actuation time,Without time limit,
IDE05333-ENG170421,Indicator light in AUTO HOLD button-IoReached Status,Output diagnostic test not active,
IDE06307,Stop prevention history data,|Year,Month,Day,Hours,Minutes,Seconds,,,,,,,,,,|2026,9,1,18,5,15,Inclination limit,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,1,18,5,15,Inclination limit,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,1,18,5,8,Inclination limit,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,1,18,5,8,Inclination limit,not active,not active,not active,not active,not active,not active,not active,not active,not active|2026,9,1,18,5,7,Inclination limit,not active,not active,not active,not active,not active,not active,not active,not active,not active|,
IDE06308,Start request history data,|Year,Month,Day,Hours,Minutes,Seconds,,,,,|2026,5,13,0,30,57,not active,System malfunction,not active,not active,not active|2026,5,13,0,30,57,not active,System malfunction,not active,not active,not active|2026,5,13,0,30,39,not active,System malfunction,not active,not active,not active|2026,5,13,0,30,39,not active,System malfunction,not active,not active,not active|2026,5,13,0,30,17,not active,System malfunction,not active,not active,not active|,
IDE06422-ENG103176,IUMPR_1-General Denominator,751,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,3464,
IDE06422-ENG100120,IUMPR_1-Milage,29810,
IDE06422-ENG101622,IUMPR_1-Record Number,41,
IDE06423-ENG101817,IUMPR_2-Denominator,751,
IDE06423-ENG103772,IUMPR_2-DFCC Value,00 8B,
IDE06423-ENG99150,IUMPR_2-Numerator,2857,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,751,
IDE06424-ENG103772,IUMPR_3-DFCC Value,10 BD,
IDE06424-ENG99150,IUMPR_3-Numerator,2857,
IDE06424-ENG101622,IUMPR_3-Record Number,2,
IDE07183,Parking brake motors: close incrementally,Open,
IDE07183-MAS01167,Parking brake motors: close incrementally-Actuation time,Without time limit,
IDE07183-ENG170421,Parking brake motors: close incrementally-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,not active,
IDE13239-IDE04947,Loose wheel warning system-Odometer reading of last warning,0, km
IDE13239-MAS00106,Loose wheel warning system-Year,2000,
IDE13239-MAS00107,Loose wheel warning system-Month,0,
IDE13239-MAS00108,Loose wheel warning system-Day,0,
IDE13239-MAS00109,Loose wheel warning system-Hours,0,
IDE13239-MAS00110,Loose wheel warning system-Minutes,0,
IDE13239-MAS00111,Loose wheel warning system-Seconds,0,
IDE13239-MAS04541,Loose wheel warning system-Odometer reading of next-to-last warning,0, km
IDE13239-MAS04542,Loose wheel warning system-Odometer reading of third-to-last warning,0, km
IDE13239-MAS16487,Loose wheel warning system-Wheels affected by the latest warning,no warning,
IDE13239-MAS16489,Loose wheel warning system-Wheels affected by the penultimate warning,no warning,
IDE13239-MAS16491,Loose wheel warning system-Wheels affected by the third last warning,no warning,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,Available,
IDE14227-MAS18085,modular vehicle dynamic controller-Electronic Stability Program function status,mFDR_not_active_by_failure,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_controlled,
IDE14227-MAS18087,modular vehicle dynamic controller-Haldex function status,mFDR_active_haldex_not_configured,
IDE14227-MAS18088,modular vehicle dynamic controller-Min Haldex target locking rate,0.0, %
IDE14227-MAS18089,modular vehicle dynamic controller-Max Haldex target locking rate,50.0, %
IDE14227-ENG264561,modular vehicle dynamic controller-mFDR Sollfaktor DCC HL,100, %
IDE14227-ENG264562,modular vehicle dynamic controller-mFDR Sollfaktor DCC HR,100, %
IDE14227-ENG264563,modular vehicle dynamic controller-mFDR Sollfaktor DCC VL,100, %
IDE14227-ENG264564,modular vehicle dynamic controller-mFDR Sollfaktor DCC VR,100, %
IDE14479-IDE02657,Parking brake system status-Cut-off current: left: reached,0.00, A
IDE14479-IDE02658,Parking brake system status-Cut-off current: right: reached,0.00, A
IDE14479-IDE04496,Parking brake system status-Left parking brake motor: status,closed,
IDE14479-IDE04497,Parking brake system status-Right parking brake motor: status,closed,
IDE14479-IDE04506,Parking brake system status-Calculated left rear brake temperature,53.0, °C
IDE14479-IDE04507,Parking brake system status-Calculated right rear brake temperature,53.0, °C
IDE14479-IDE04647,Parking brake system status-Left parking brake motor: current,0.00, A
IDE14479-IDE04648,Parking brake system status-Right parking brake motor: current,0.00, A
IDE14479-IDE05048,Parking brake system status-Left parking brake motor: actuation counter,3013,
IDE14479-IDE05049,Parking brake system status-Right parking brake motor: actuation counter,3013,
IDE14623,Commutation test status,not active,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,35.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,35.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,35.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,35.5, °C
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Not available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Not available,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,1,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,56,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,27,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,30921, km
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Not open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0.0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver´s door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02286-MAS01167,Hydraulic pump-Actuation time,0 s,
MAS02286-MAS06857,Hydraulic pump-Speed,0, /min
MAS02286-ENG170421,Hydraulic pump-IoReached Status,Output diagnostic test not active,
MAS02426-MAS01167,Text display in instrument cluster-Actuation time,Without time limit,
MAS02426,Text display in instrument cluster,0,
MAS02426-ENG170421,Text display in instrument cluster-IoReached Status,Output diagnostic test not active,
MAS04012-IDE03297,Intake valves-Left front ABS inlet valve,OFF,
MAS04012-IDE03299,Intake valves-Right front ABS inlet valve,OFF,
MAS04012-IDE03301,Intake valves-left rear ABS intake valve,OFF,
MAS04012-IDE03303,Intake valves-right rear ABS intake valve,OFF,
MAS04012-MAS01167,Intake valves-Actuation time,0 s,
MAS04012-ENG170421,Intake valves-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
ENG101413,Calibration Identifications,5WA517BL01330290,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,7E D0 12 46,
ENG100152,ECUNAME,BSCM-BrakeSystem,
ENG264445,Entwicklermesswert_08,|VZM_function_request,VZM_Participant,VZM_failure_status,Vehicle speed,Odometer reading of most up-to-date warning,Year,Month,Day,Hours,Minutes,Seconds,VZM_terminal_state|0,5,0,36,30788.0,2026,8,31,20,24,12,2|0,5,0,89,30756.0,2026,8,30,12,25,41,2|0,10,0,93,30576.0,2026,8,23,13,21,58,2|0,5,0,48,30504.0,2026,8,20,18,12,27,2|1,5,0,45,30488.0,2026,8,19,18,2,51,2|0,10,0,59,30428.0,2026,8,17,9,38,36,2|0,10,0,62,30428.0,2026,8,17,9,38,3,2|0,10,0,54,30428.0,2026,8,17,9,37,47,2|0,10,0,43,30424.0,2026,8,17,9,35,18,2|0,10,0,58,30416.0,2026,8,16,17,27,25,2|,
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,3013,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,3013,
ENG264448,Entwicklermesswert_12,40081D,
ENG264449-ENG135765,Entwicklermesswert_13-Input_Signal_A_Belt_Error,No malfunction,
ENG264449-ENG135764,Entwicklermesswert_13-Input_Signal_A_Belt_Status,not selected,
ENG264449-ENG135767,Entwicklermesswert_13-Input_Signal_B_Door_Error,No malfunction,
ENG264449-ENG135766,Entwicklermesswert_13-Input_Signal_B_Door_Status,closed,
ENG264450-MAS01167,Entwicklerstellglied_01_status-Actuation time,0 s,
ENG264450-MAS11641,Entwicklerstellglied_01_status-OBD lamp,OFF,
ENG264450-ENG170421,Entwicklerstellglied_01_status-IoReached Status,Output diagnostic test not active,
Elapsed Time: 00:16
;SW:5WA-959-655-M HW:5WA-959-655-M --- 15: Airbags
;Component:AirbagVW40 007 0636, Coding:8CCC000000FCC00000000000000000005100000000000000000036F800130065
;EV_AirbaVW40SMEVW38X,001032,EV_AirbaVW40SMEVW38X.rod
;Tuesday,01,September,2026,19:04:34:51924
;VCID: 61987A0011C5074288E-8034 SFD [x]
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE05178-Conclude start of operation,locked ,1
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE12055-IDE12056-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12057-Adaptation airbag 2-Igniter for interaction airbag 2nd row: driver side,not defined ,8
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-IDE14239-Adaptation airbag 2-Igniter for high-voltage battery 2 open circuit,not defined ,8
IDE12055-IDE14240-Adaptation airbag 2-Driver side seat occupancy detection,not defined ,8
IDE12055-IDE14841-Adaptation airbag 2-Seat Belt Tensioner Igniter: center 3rd row,not defined ,8
IDE12055-IDE15776-Adaptation airbag 2-Deactivation igniter: DC/DC converter,not defined ,8
IDE12055-IDE16063-Adaptation airbag 2-Igniter for high-voltage battery 3 open circuit,not defined ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE00947-Airbag adaptations-Rear driver head curtain airbag igniter,not defined ,8
MAS00975-IDE00948-Airbag adaptations-Rear passenger head curtain airbag igniter,not defined ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,not defined ,8
MAS00975-IDE07190-Airbag adaptations-Igniter for battery open circuit 2nd battery,not defined ,8
MAS00975-IDE07192-Airbag adaptations-Thorax airbag igniter,not defined ,8
MAS00975-IDE08436-Airbag adaptations-Front driver side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE08437-Airbag adaptations-Front passenger side third row seat belt tensioner igniter,not defined ,8
MAS00975-IDE12208-Airbag adaptations-Igniter for deactivation of A/C system 1,not defined ,8
MAS00975-IDE12209-Airbag adaptations-Igniter for deactivation of A/C system 2,not defined ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,not defined ,8
MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00021-Airbag adaptations-Center rear seat belt tensioner igniter,not defined ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00023-Airbag adaptations-Driver active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00024-Airbag adaptations-Front passenger active head restraint igniter/trigger,not defined ,8
MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch not parameterized ,8
MAS00975-MAS00231-Airbag adaptations-Seat occupant detection passenger side,not defined ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:11
;Tuesday,01,September,2026,19:04:16:51924
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,not installed,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,no measured value present,
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,not installed,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,no measured value present,
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,not installed,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,no measured value present,
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,not installed,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,no measured value present,
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,not installed,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,no measured value present,
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Rear driver head curtain airbag igniter-Status,not installed,
IDE00947-MAS05030,Rear driver head curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Rear passenger head curtain airbag igniter-Status,not installed,
IDE00948-MAS05030,Rear passenger head curtain airbag igniter-Resistance,no measured value present,
IDE00956,Occupation status: frt.passenger seat,Adult,
IDE01271,Number of rollover bar deployments,0,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,no measured value present,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,no measured value present,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01555,Number of frontal crashes,0,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,not installed,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,no measured value present,
IDE03800-MAS01632,Driver airbag release valve igniter-Status,no measured value present,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,no measured value present,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,|,,|00,0,0|,
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,not installed,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,not installed,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE06959,Seat occupant detection: diagnosis signal,31.5, %
IDE06960,Seat occupant detection: msmt. signal,17.0, %
IDE06961,Seat occupant detection: ref. signal,1.5, %
IDE07159-MAS05583,Control module switch-off: counter-Data bus,255,
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,no measured value present,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,not installed,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Front driver side third row seat belt tensioner igniter-Status,not installed,
IDE08436-MAS05030,Front driver side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,not installed,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,not installed,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,not installed,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,0,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,0,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,0,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,0,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,0,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,0,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,0,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,0,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,0,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,0,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,0,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,not installed,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,not installed,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,no measured value present,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.3, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,not installed,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger front airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger front airbag igniter-Resistance,2.2, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,correct,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,2.2, Ohm
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.5, Ohm
MAS00006-MAS01632,Front passenger thorax airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger thorax airbag igniter-Resistance,2.4, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,no measured value present,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,no measured value present,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.5, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.6, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,no measured value present,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,no measured value present,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver seat belt tension igniter-Resistance,2.5, Ohm
MAS00014-MAS01632,Front passenger seat belt tensioner igniter-Status,correct,
MAS00014-MAS05030,Front passenger seat belt tensioner igniter-Resistance,2.4, Ohm
MAS00015-MAS01632,Driver seat belt tensioner igniter 2-Status,correct,
MAS00015-MAS05030,Driver seat belt tensioner igniter 2-Resistance,2.5, Ohm
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,correct,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,2.4, Ohm
MAS00017-MAS01632,Igniter for Driver Belt Force Limiter-Status,correct,
MAS00017-MAS05030,Igniter for Driver Belt Force Limiter-Resistance,2.4, Ohm
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,correct,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,2.5, Ohm
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.6, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.6, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,not installed,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,not installed,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver active head restraint igniter/trigger-Status,not installed,
MAS00023-MAS05030,Driver active head restraint igniter/trigger-Resistance,no measured value present,
MAS00024-MAS01632,Front passenger active head restraint igniter/trigger-Status,not installed,
MAS00024-MAS05030,Front passenger active head restraint igniter/trigger-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,not connected,
MAS00025-MAS05030,Driver seat belt switch-Resistance,0.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,0.0, Ohm
MAS00031,Airbag deactivation status,On,
MAS00032-MAS01632,Key switch terminal 1-Status,not installed,
MAS00032-MAS05030,Key switch terminal 1-Resistance,too large,
MAS00033-MAS01632,Key switch terminal 2-Status,not installed,
MAS00033-MAS05030,Key switch terminal 2-Resistance,too large,
MAS00035-MAS01632,Seat position sensor: driver side-Status,Rear,
MAS00035-MAS04136,Seat position sensor: driver side-Current,5.6, mA
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,Rear,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,5.6, mA
MAS00037,Calibration status,0,
MAS00038-MAS01632,Seat occupied recognition rear driver side-Status,not installed,
MAS00038-MAS05030,Seat occupied recognition rear driver side-Resistance,no measured value present,
MAS00039-MAS01632,Seat occupied recognition rear passenger side-Status,not installed,
MAS00039-MAS05030,Seat occupied recognition rear passenger side-Resistance,no measured value present,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,not installed,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,no measured value present,
MAS00231-MAS01632,Seat occupant detection passenger side-Status,assigned,
MAS00231-MAS05030,Seat occupant detection passenger side-Resistance,no measured value present,
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,12.3, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,12.6, V
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:18
;SW:5WA-909-059-K HW:3Q0-909-059-D --- 23: Brake Booster
;Component:EBKV H09 0307, Coding:5003C5009F00007BEFBDF7DE000049922449922400
;EV_BrakeBoostG2BoschVW37W,016028,EV_BrakeBoostG2BoschVW37W_016_VW38.rod
;Tuesday,01,September,2026,19:07:59:51924
;VCID: 58EE57E4429FC68AFF0-800C SFD [x]
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,20 min,2
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements-,US OBD ,2
IDE11985-Expected OBD requirements-,Combustion engine ,2
IDE14698-Parameters of leak test-,15.0000000 mm,20
IDE14698-Parameters of leak test-,30.0000000 mm/s,20
IDE14698-Parameters of leak test-,4 ,20
IDE14698-Parameters of leak test-,0.5 s,20
IDE14698-Parameters of leak test-,0.0 s,20
IDE14698-Parameters of leak test-,10.0000000 mm/s,20
IDE14698-Parameters of leak test-,15.0 s,20
IDE14698-Parameters of leak test-,10.0 s,20
IDE14698-Parameters of leak test-,65 bar,20
IDE14698-Parameters of leak test-,5.0000000 mm,20
IDE14698-Parameters of leak test-,12.0000000 mm,20
IDE14699-Parameters of heaviness test-,12.0000000 mm,13
IDE14699-Parameters of heaviness test-,30.0000000 mm/s,13
IDE14699-Parameters of heaviness test-,0 ,13
IDE14699-Parameters of heaviness test-,0.5 s,13
IDE14699-Parameters of heaviness test-,0.0 s,13
IDE14699-Parameters of heaviness test-,1.29980468750 Nm,13
IDE14699-Parameters of heaviness test-,50.0000000 mm/s,13
IDE14700-Parameters of ventilation routine-,21.0000000 mm,18
IDE14700-Parameters of ventilation routine-,180.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,25 ,18
IDE14700-Parameters of ventilation routine-,50.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,0.0 s,18
IDE14700-Parameters of ventilation routine-,30.0000000 mm,18
IDE14700-Parameters of ventilation routine-,5.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,5 ,18
IDE14700-Parameters of ventilation routine-,1.7968750 mm/s,18
IDE14700-Parameters of ventilation routine-,1.0 s,18
IDE80111-Analysis 111,active ,1
IDE80121-Analysis 121-,80 s,2
IDE80121-Analysis 121-,0 ,2
IDE80122-Analysis 122-,10 s,2
IDE80122-Analysis 122-,0 ,2
IDE80123-Analysis 123,OFF ,1
IDE80124-Analysis 124-,00 ,2
IDE80124-Analysis 124-,0 ,2
IDE80125-Analysis 125-,0 ,2
IDE80126-Analysis 126,0 ,2
IDE80131-MAS05513-Analysis 131-Bit 0,OFF ,1
IDE80131-MAS05514-Analysis 131-Bit 1,OFF ,1
IDE80131-MAS05515-Analysis 131-Bit 2,OFF ,1
IDE80131-MAS05516-Analysis 131-Bit 3,OFF ,1
IDE80131-MAS05517-Analysis 131-Bit 4,OFF ,1
IDE80131-MAS05518-Analysis 131-Bit 5,OFF ,1
IDE80131-MAS05519-Analysis 131-Bit 6,OFF ,1
IDE80131-MAS05520-Analysis 131-Bit 7,OFF ,1
IDE80134-Analysis 134-,00 00 00 00 ,40
IDE80134-Analysis 134-,00 ,40
IDE80135-Analysis 135-,00 00 00 00 ,40
IDE80135-Analysis 135-,00 ,40
IDE80136-Analysis 136-,00 00 00 00 ,40
IDE80136-Analysis 136-,00 ,40
IDE80137-Analysis 137-,00 00 00 00 ,40
IDE80137-Analysis 137-,00 ,40
MAS00194----,00 00 ,2
Elapsed Time: 00:06
;Tuesday,01,September,2026,19:07:56:51924
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,28.000, km/h
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.90000, bar
IDE05816-IDE09696,Input signals from data bus-Charisma driving program: CAN output value,Program 3,
IDE05816-MAS01078,Input signals from data bus-Vehicle model,Combustion engine,
IDE05816-MAS02357,Input signals from data bus-Vehicle identification,00 33 39 30 31 34,
IDE05816-MAS08111,Input signals from data bus-OBD std.,US OBD,
IDE05816-MAS19863,Input signals from data bus-Status of parking brake: electromechanical,Bremse_geschl_(Spannkraft_voll/reduziert),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08588-IDE00020,Sensor signals for electromechanical power brake-Terminal 15 status,Terminal 15 on,
IDE08588-IDE00102,Sensor signals for electromechanical power brake-Control Module temperature,60.0, C
IDE08588-IDE02222,Sensor signals for electromechanical power brake-Driver brakes: qualification,OFF,
IDE08588-IDE02713,Sensor signals for electromechanical power brake-Brake lamp switch,OFF,
IDE08588-IDE02714,Sensor signals for electromechanical power brake-Brake test switch,On,
IDE08588-IDE11037,Sensor signals for electromechanical power brake-Brake light switch: qualification,On,
IDE08588-MAS00043,Sensor signals for electromechanical power brake-Terminal 30 power supply,12.4, V
IDE08588-MAS05192,Sensor signals for electromechanical power brake-Driver braking,OFF,
IDE08588-MAS06928,Sensor signals for electromechanical power brake-Supply voltage pedal travel sensor,4.9, V
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.0546875000, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.00000, Nm
IDE08588-MAS11639,Sensor signals for electromechanical power brake-Input rod travel,0.000000, mm
IDE08588-MAS18095,Sensor signals for electromechanical power brake-Output rod,0.000000, mm
IDE08588-MAS18096,Sensor signals for electromechanical power brake-Brake pedal travel,Initialization,
IDE08588-MAS18097,Sensor signals for electromechanical power brake-Brake test switch: qualification,On,
IDE08588-MAS18098,Sensor signals for electromechanical power brake-Driver brakes clearly,OFF,
IDE08623-MAS02163,OBD configuration-coded,US OBD,
IDE08623-MAS08097,OBD configuration-Status: OBD lamp,OFF,
IDE08623-MAS14472,OBD configuration-calculated,US OBD,
IDE08623-MAS19862,OBD configuration-Status of generic scan tool,OFF,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00000, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00000000000, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,Open,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.0000000, mm
IDE13845,Production mode status,not active,
IDE14229-MAS18099,Brake booster control status-Control mode,No activation,
IDE14229-MAS18101,Brake booster control status-Actuator Position,0.05467, mm
IDE14229-MAS18102,Brake booster control status-Actuator torque,0.00000, Nm
IDE14229-MAS18103,Brake booster control status-Actuator speed,0.00000, mm/s
IDE14229-MAS18104,Brake booster control status-Remaining hold time,0, s
IDE14696-MAS03458,Leak test-Differential pressure,0.0000, bar
IDE14696-MAS19863,Leak test-Status of parking brake: electromechanical,Open,
IDE14696-MAS19864,Leak test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leak test-Brake pressure 2,0, bar
IDE80221-ENG252453,Analysis 221-Driver On Pedal,false,
IDE80221-ENG252454,Analysis 221-iBooster Ready for Actuation,OFF,
IDE80221-ENG252457,Analysis 221-iBooster System Mode,ready,
IDE80221-ENG252455,Analysis 221-Pedal Apply Recognition HW Output,false,
IDE80221-ENG252458,Analysis 221-Thermal Limitation,not_active,
IDE80221-ENG252452,Analysis 221-Wakeup Information HW,On,
IDE80221-ENG252456,Analysis 221-Wakeup Information NET,On,
IDE80222,Analysis 222,00 6A E7,
IDE80223,Analysis 223,1.7578125, mm/s
IDE80223,Analysis 223,0.0000000, mm
IDE80223,Analysis 223,102.8750000, mm/s
IDE80223,Analysis 223,0.00000000000, Nm
IDE80223,Analysis 223,40.7421875, mm
IDE80223,Analysis 223,2.08251953125, Nm
IDE80225,Analysis 225,1,
IDE80225,Analysis 225,0,
IDE80225,Analysis 225,not active,
IDE80226-ENG249302,Analysis 226-Umgesetztes Charisma-Fahrprogramm_Wert,3,
MAS10409-MAS00106,Time stamp-Year,2026,
MAS10409-MAS00107,Time stamp-Month,9,
MAS10409-MAS00108,Time stamp-Day,1,
MAS10409-MAS00109,Time stamp-Hours,19,
MAS10409-MAS00110,Time stamp-Minutes,7,
MAS10409-MAS00111,Time stamp-Seconds,29,
Elapsed Time: 00:02
;SW:5WA-035-285-A HW:5WA-035-285-A --- 75: Telematics
;Component:OCU3HMQB37W H12 0015, Coding:02380020906828208005460070102607
;EV_OCU3HMQB37W,002012,EV_OCU3HMQB37W_002_VW38.rod
;Tuesday,01,September,2026,19:11:11:51924
;VCID: 45D08E90A52D4B62946-8010 SFD [x]
IDE00608-MAS00713-Fuel type-Petrol,installed ,1
IDE00608-MAS00716-Fuel type-Diesel,not installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,not installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE02330-Call number 2 for info call,+18334227638 ,15
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,not activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,not activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,not activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane departure warning,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Auxiliary heating,activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,not activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,not activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,11
IDE04307-MAS07249-Vehicle function list BAP-Main beam,activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,not activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,not activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,not activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,not activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,not activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,CAN ,11
IDE04307-MAS23125-Vehicle function list BAP-BAP distance RemonteStartOnline_0x70,not activated ,11
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,255 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,60 min,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,not activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,40 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,10 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14170-Timeout for service key query,10 ,1
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Tracking Data group selected ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic settings not detected guest: services,Workshop settings adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with balancing of interests,Workshop settings adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with consent,Workshop settings adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Tracking Data group selected ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15695-Front radar-based localization-,not activated ,1
IDE15695-ENG263520-Front radar-based localization-Front_radar_rem_data_output,not activated ,1
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://t-h-m.dp.us00.p.con-veh.net:15443/vas/vehicles/v2/deviceRegistered ,86
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,86
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,AERIS ,86
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Normal/Hybrid ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,0 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-GNSS: data transmission rate,10 Hz ,2
MAS13841-GNSS: minimum height,5 ,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Rear left door,installed ,1
MAS17427-MAS00221-Door configuration-Rear right door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,not installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,not installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,400 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19240-Authorization level after-run time,0 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
ENG253242-ENG259195-a2b_data_streams-Emergency_mic_transducer_selection,mic_transducer_3 ,10
ENG253242-ENG260060-a2b_data_streams-Multi_Center_Speaker_via_Connectivity_Unit,present ,10
ENG253242-ENG113413-a2b_data_streams-reserved_01,0 ,10
ENG253242-ENG261390-a2b_data_streams-reserved_02,0 ,10
ENG253242-ENG261450-a2b_data_streams-reserved_03,0 ,10
ENG253242-ENG261451-a2b_data_streams-reserved_04,0 ,10
ENG253242-ENG261386-a2b_data_streams-Reserved_05,0 ,10
ENG253242-ENG261387-a2b_data_streams-Reserved_06,0 ,10
ENG253242-ENG261388-a2b_data_streams-Reserved_07,0 ,10
ENG253242-ENG259380-a2b_data_streams-Transducer_amount_mic_front_module_node,3 ,10
ENG253242-ENG260344-a2b_data_streams-Transducer_amount_mic_module_rear_left_node,0 ,10
ENG253242-ENG259983-a2b_data_streams-Transducer_amount_mic_module_rear_right_node,0 ,10
ENG261370-Airbag_Signal_Setting,100 ms ,1
ENG275595-IDE01762-BAP_Connection_Control-Doors,OFF ,25
ENG275595-IDE03031-BAP_Connection_Control-Seat adjustment,OFF ,25
ENG275595-IDE03111-BAP_Connection_Control-Interior lighting,automatic ,25
ENG275595-MAS00688-BAP_Connection_Control-Multi-function display,automatic ,25
ENG275595-MAS01118-BAP_Connection_Control-Air Conditioning,automatic ,25
ENG275595-MAS01282-BAP_Connection_Control-Wiper,automatic ,25
ENG275595-MAS01891-BAP_Connection_Control-Lane departure warning,OFF ,25
ENG275595-MAS02444-BAP_Connection_Control-Central locking,OFF ,25
ENG275595-MAS03385-BAP_Connection_Control-Lane change assistance,automatic ,25
ENG275595-MAS03420-BAP_Connection_Control-Head-Up-Display,OFF ,25
ENG275595-MAS03853-BAP_Connection_Control-Road sign detection,OFF ,25
ENG275595-MAS05087-BAP_Connection_Control-ACC,OFF ,25
ENG275595-MAS05506-BAP_Connection_Control-Stopping distance reduction,OFF ,25
ENG275595-MAS07249-BAP_Connection_Control-Main beam,automatic ,25
ENG275595-MAS08072-BAP_Connection_Control-Driving profile selection,automatic ,25
ENG275595-MAS08785-BAP_Connection_Control-Parking aid,automatic ,25
ENG275595-MAS20539-BAP_Connection_Control-BAP distance PaCo_0x55,automatic ,25
ENG275595-MAS20545-BAP_Connection_Control-BAP distance doors2_0x63,OFF ,25
ENG275595-MAS20550-BAP_Connection_Control-BAP distance infotainment_settings_0x50,OFF ,25
ENG275595-MAS20553-BAP_Connection_Control-BAP distance mirror_0x0E,automatic ,25
ENG275595-MAS20556-BAP_Connection_Control-BAP distance unit_master_0x13,automatic ,25
ENG275595-ENG98891-BAP_Connection_Control-Reserved,OFF ,25
ENG275595-ENG113413-BAP_Connection_Control-reserved_01,OFF ,25
ENG275595-ENG261390-BAP_Connection_Control-reserved_02,OFF ,25
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG253218-ENG260862-function_configuration_a2b_topology-a2b_topology,Infotainment_Unit_with_external_mic ,5
ENG253218-ENG253474-function_configuration_a2b_topology-connectivity_unit,present ,5
ENG253218-ENG259051-function_configuration_a2b_topology-Infotainment_Mic_Unit,Not_present ,5
ENG253218-ENG253475-function_configuration_a2b_topology-infotainment_unit,present ,5
ENG253218-ENG258377-function_configuration_a2b_topology-MIC_MOD_rear_L,Not_present ,5
ENG253218-ENG259527-function_configuration_a2b_topology-MIC_MOD_rear_R,Not_present ,5
ENG253218-ENG258583-function_configuration_a2b_topology-Mic_Module_Display,Not_present ,5
ENG253218-ENG258542-function_configuration_a2b_topology-Mic_Module_Roof,present ,5
ENG253218-ENG113413-function_configuration_a2b_topology-reserved_01,0 ,5
ENG253218-ENG261390-function_configuration_a2b_topology-reserved_02,0 ,5
ENG253218-ENG261450-function_configuration_a2b_topology-reserved_03,0 ,5
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 ,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 ,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 ,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 ,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Direction of travel,30 ,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,not activated ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:37
;Tuesday,01,September,2026,19:09:33:51924
;VCDS Version: 26.9.0.3 (x64) Data version: 20260828 DS378.0
Group,Description,Actual
IDE00019,Voltage terminal 30,12.5, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,61, °C
IDE00608,Fuel type,Petrol,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Dimmer terminal 58d,32.55, %
IDE01216,Dimmer terminal 58s,53, %
IDE01588,Direction of travel,256, °
IDE01588-MAS01632,Direction of travel-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,78°54'1.7"W,
IDE01712-MAS01780,GPS Position-Width,36°0'12.1"N,
IDE01712-MAS02230,GPS Position-Height,128, m
IDE01713-MAS01632,Status GPS reception-Status,GPS almanac is being loaded,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,0,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,26, mA
IDE01971,Lowest recorded control module temperature,3, °C
IDE01972,Highest recorded control module temperature,75, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,32, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,0,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE03477-MAS00106,GPS time-Year,2127,
IDE03477-MAS00107,GPS time-Month,0,
IDE03477-MAS00108,GPS time-Day,0,
IDE03477-MAS00109,GPS time-Hours,24,
IDE03477-MAS00110,GPS time-Minutes,60,
IDE03477-MAS00111,GPS time-Seconds,60,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE04293,Operating state for emer call module,registerstate_registered,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,311480796130035,
IDE04750-MAS04226,SIM card-Telephone number, ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89148000007772757361,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000006380030383,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,015446000203297,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG170421,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG170421,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2000,
IDE07589-MAS00107,Update programming: status-Month,0,
IDE07589-MAS00108,Update programming: status-Day,0,
IDE07589-MAS00109,Update programming: status-Hours,0,
IDE07589-MAS00110,Update programming: status-Minutes,0,
IDE07589-MAS00111,Update programming: status-Seconds,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG170421,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG170421,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 0D 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,D8 22 A2 DD,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,32, %
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge status,97, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 B4 B8 FF FE C7 D4 09|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|FD 53 7C B8 03 83 00 07 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF C7 D4 09|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|7|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|30 B4 B8 C7 D4 09|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|00 36 F8 64 77 19,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10,4|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|00 36 F8 64 77 19|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|4|7|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,Write only channel,
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Speaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Speaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWG87CD9NW139014,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 02,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,17,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2026, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,5, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,13, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,0, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,29, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,59, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2026, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),5, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),14, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),15, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),53, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),7, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,No expiry,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 00 00 00 00 00 00 00,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,1,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 2F,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,0D,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,9,
MAS00464-MAS00108,Standard - ambient data 1-Day,1,
MAS00464-MAS00109,Standard - ambient data 1-Hours,19,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,9,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,24,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,147,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,30921, km
MAS01490-MAS08403,Energy management-Remaining short term energy budget,851, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,3615,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,311,
MAS04394-IDE07699,Connection status-Mobile network operator,480,
MAS04394-MAS03991,Connection status-Reception level antenna 1,32, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,116690484,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG170421,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS10430,Indicator light for emerg. call,Emergency call function available,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1644,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 19,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,W101,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,#anonymousGuest# ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description,Personal data related to data privacy|00 00 00 00 3D 00 2B 1D,0,0|00 00 00 00 3D 00 2B 39,0,0|00 00 00 00 3E 00 2B 40,0,0|00 00 00 00 3E 00 2B 41,0,0|00 00 00 00 3E 00 2B 42,0,0|00 00 00 00 3E 00 2B 43,0,0|00 00 00 00 3E 00 2B 44,0,0|00 00 00 00 3E 00 2B 45,0,0|00 00 00 00 14 00 27 11,0,0|00 00 00 00 14 00 27 1E,0,0|00 00 00 00 09 00 13 89,0,0|00 00 00 00 09 00 13 8C,0,0|00 00 00 00 09 00 13 8D,0,0|00 00 00 00 09 00 13 91,0,0|00 00 00 00 09 00 13 95,0,0|00 00 00 00 09 00 13 97,0,0|00 00 00 00 09 00 13 98,0,0|00 00 00 00 09 00 13 99,0,0|00 00 00 00 09 00 13 9E,0,0|00 00 00 00 09 00 13 9F,0,0|00 00 00 00 0B 00 17 73,0,0|00 00 00 00 0B 00 17 98,0,0|00 00 00 00 0B 00 17 99,0,0|00 00 00 00 01 00 04 06,1,0|00 00 00 00 01 00 04 11,1,0|00 00 00 00 01 00 04 12,1,0|00 00 00 00 01 00 04 15,1,0|00 00 00 00 01 00 04 02,1,0|00 00 00 00 01 00 04 03,1,0|00 00 00 00 01 00 04 04,1,0|00 00 00 00 01 00 04 05,1,0|00 00 00 00 01 00 03 E9,1,0|00 00 00 00 02 00 04 B0,1,0|00 00 00 00 02 00 04 B1,1,0|00 00 00 00 02 00 04 B2,1,0|00 00 00 00 02 00 04 B3,1,0|00 00 00 00 02 00 04 B8,1,0|00 00 00 00 02 00 04 B9,1,0|00 00 00 00 02 00 04 BA,1,0|00 00 00 00 02 00 04 BB,1,0|00 00 00 00 02 00 04 BC,1,0|00 00 00 00 02 00 04 BD,1,0|00 00 00 00 02 00 04 BE,1,0|00 00 00 00 02 00 04 BF,1,0|00 00 00 00 02 00 04 C0,1,0|00 00 00 00 02 00 04 C2,1,0|00 00 00 00 02 00 04 C3,1,0|00 00 00 00 02 00 04 C4,1,0|00 00 00 00 02 00 04 C5,1,0|00 00 00 00 02 00 04 C6,1,0|00 00 00 00 02 00 04 C7,1,0|00 00 00 00 02 00 04 D0,1,0|00 00 00 00 05 00 0B B9,1,0|00 00 00 00 05 00 0B BA,1,0|00 00 00 00 05 00 0B BB,1,0|00 00 00 00 11 00 23 8E,0,0|00 00 00 00 11 00 23 90,0,0|00 00 00 00 0F 00 1F 68,0,0|00 00 00 00 0F 00 1F 69,0,0|00 00 00 00 3D 00 2A F9,0,0|00 00 00 00 3D 00 2A FA,0,0|00 00 00 00 3D 00 2A FB,0,0|00 00 00 00 3D 00 2A FC,0,0|00 00 00 00 3D 00 2A FD,0,0|00 00 00 00 3D 00 2A FE,0,0|00 00 00 00 3D 00 2B 01,0,0|00 00 00 00 3D 00 2B 02,0,0|00 00 00 00 01 00 04 0C,1,0|00 00 00 00 01 00 04 0E,1,0|,
MAS19273,Shadow drive metadata,|User ID,Year,Month,Day,Hours,Minutes,Seconds,Sync group in shadow drive is more current than active one,Parameter in shadow drive is more current than the one in back end,Shadow drive active,Number of allocated slots,Year,Month,Day,Hours,Minutes,Seconds,Year,Month,Day,Hours,Minutes,Seconds,Last synchronization result|1,2026,9,1,22,7,39,Yes,Yes,active,1,1970,1,1,0,0,0,1970,1,1,0,0,0,No synchronization performed for user yet|,
MAS19295,Historical memory for synchronization,Write only channel,
MAS19313,BAP historical memory,|Year,Month,Day,Hours,Minutes,Seconds,Logical control module identifier,Operation,DTC,User profile memory slot,BAP error repetition number|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|1970,1,1,0,0,0,0,Setting change for active participant available,No malfunction,0,0|,
MAS19326,CAN signals for OCU customization,|Year,Month,Day,Hours,Minutes,Seconds,Customization control command,Current profile slot number for customization,Status of personalization,Personalization active,Parameters to customization control command,Enable customization adjustment,Control point customization|2026,9,1,18,34,31,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,18,35,7,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,9,13,44,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,9,13,44,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,9,53,36,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,9,54,8,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,9,54,26,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,14,15,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,15,51,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,17,14,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,17,52,no control,Personalization of user account 1,no customization,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,17,52,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,17,52,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,17,52,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,10,17,52,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,18,7,8,no control,Personalization of user account 1,no customization,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,18,7,8,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,18,7,8,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,18,7,8,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|2026,9,1,18,33,58,no control,Personalization of user account 1,Customization coded 2.x,Driver customization not activated,No user account,Enabled,Initial value|,
ENG123206,Antenna_Switch,LTE antenna 1,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,3809,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,1970-01-01T00:00:00Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,1970-01-01T00:00:00Z,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,79.867,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,2834, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,80,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,81,
ENG125913,Hybrid_Type,no_Hybrid_Car,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.81.230.149,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11568,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,14128,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,2642939908, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12601,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14896,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,13369,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12336,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,12346,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14896,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,12336,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11568,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,11825,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,12628,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,48,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,12378,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23054, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,775041840, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,57666,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808335409, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,Malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,36, m
ENG247822-ENG159328,Third_Last_Position-Longitude, 78°54'0.8"W ,
ENG254851-MAS01779,VTT_First_GPS_fix-Length,--- ,
ENG254851-MAS01780,VTT_First_GPS_fix-Width,--- ,
ENG254851-MAS02230,VTT_First_GPS_fix-Height,65034, m
Elapsed Time: 01:36
