- May 2, 2016
- 425
- 134
- Netherlands
- C?ID=143747
I have this Audi E-Tron with strange problem. I can change al coding from modules, but only 01 ECU i can't change. Keeps saying conditions not correct and coding rejected.
Have tried battery reset, also with ODIS-E (development mode). All won't except. Maybe someone had this problem before. Below the scan of VCDS.
Wednesday,02,September,2026,18:57:15:43540
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.4
VIN: WAUZZZ8V2LAXXXXXX License Plate: ETRONCCR
Mileage: 138723km-86198mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 29 2B 39 42 44 4B 51 52
5F 75 8C A5 BB BC C0 C6 D6 D7
VIN: WAUZZZ8V2LAXXXXXX Mileage: 138723km-86198miles
51-Electric Drive -- Status: Malfunction 0010
Address 01: Engine (J623-DGEA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 024 F HW: 04E 907 309 CG
Component: 1.4 TFSI hy H20 9821
Revision: DCH20000 CVN: D8CB695B
Coding: 021D4012630401083008
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM14TFS01104E906024F 002005
ROD: EV_ECM14TFS01104E906024F_002.rod
VCID: 24101A35CE515E6AA38-8070
VINID: 9D196AAAA22609C4401821C01C04D8ED25
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels:. 0DD-927-770-V1.clb
Part No SW: 0DD 300 046 C HW: 0DD 927 770 C
Component: GSG DQ400E H32 2201
Revision: 00032056 Serial number: TFK01912060003 CVN: 9C66E7F7
Shop #: WSC 61449 003 1048576
ROD: EV_TCMDQ400021_VW37.rod
VCID: 28080E05B279BA0A8F0-807C
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-OMG-V1.clb
Part No SW: 5Q0 614 517 EK HW: 5Q0 614 517 AH
Component: ESC H62 0865
Revision: 00000000 Serial number: 60110000000644 Dataset Number: 8V0909504AA 0061 CVN: 2DDD50F5
Coding: 12F140A23826226E897E0E0061CA2848021C44917086147210B15074822802
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_Brake1UDSContiMK100OMG 003022
ROD: EV_Brake1UDSContiMK100OMG_003.rod
VCID: 7EA4085D007DD4BA95C-802A
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0540185984 Dataset Number: 8V0909577G 0002
Coding: 030C0C1720
VCID: 45D6A7B1252B4762946-8010
Part No SW: 8V0 820 043 AQ HW: 8V0 820 043 AQ
Component: AC Automat H03 0120
Revision: 20001000 Serial number: 00000001972028 Dataset Number: 8V1909862C
Coding: 0300001000001000080000000000100001000000
ASAM Dataset: EV_AirCondiFrontRDWAU37X 001019
ROD: EV_AirCondiFrontRDWAU37X.rod
VCID: 015E73A17183AB42E8E-8054
Subsystem 1 - Part No SW: 3Q0 963 231 E HW: 3Q0 963 231 E
Component: J848 HV-PTC 200 0204
Serial number: -00100.5X.2C20370038
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 C HW: 4H0 907 658 C
Component: G935 MuFu H04 0010
Serial number: A0D5112000PAG0MUFU04
459029 - Electric A/C Compressor
U016B 00 [00101111] - No Communication
[EKK - kein Signal/Kommunikation]
Mileage: 138723 km
Date: 2026.09.02
Time: 11:29:24
Unlearning counter according OBD-OBD Parameter: 40
Voltage terminal 30: 12.000 V
Outside temperature: 21 °C
Refrigerant pressure: 6.8 bar
Compressor shut-off condition: Invalid signals
Compressor status: global-A/C compressor release status: transmitted
Compressor status: global-A/C compressor: target speed: 0 /min
Compressor status: global-A/C compressor: actual speed: Measuring value not available
Compressor status: global-A/C compressor: function status: Air conditioner compressor off
Compressor status: global-A/C compressor error indicator: not active
Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
Compressor status: global-A/C compressor: inverter temperature: Measuring value not available
Part No SW: 5Q0 937 084 DG HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H42 0312
Serial number: 02002003100843 Dataset Number: 8V0909514AE 0028
ASAM Dataset: EV_BCMMQB 020001
ROD: EV_BCMBOSCH_020_VW27.rod
VCID: 005876A57A89A24AE70-8054
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 191029 043 0580
Serial number: 191218175910
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 22139478X81A955547A0
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 27 11 2019 20000717
Sunroof control module:
Subsystem 4 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST002GX1GW00000
Coding: 901E00
Steering Column Switch:
Subsystem 5 - Part No SW: 82A 953 521 BJ HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000016012020240215
204290 - Remote key 1
B1479 18 [00001001] - Current Too Low
Reset counter: 249
Mileage: 138723 km
Date: 2026.09.02
Time: 17:08:30
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 12.8 V
Outside temperature: 22.5 °C
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058420031 Dataset Number: 8V0909526L 0065
Coding: 0470051011
ASAM Dataset: EV_EPHVA18AU3700000 009046
VCID: 50F886E5EA6992CA370-8004
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Dataset Number: 8V1909863AD 0003
Coding: 550000C159F7C728949C814500402400000000000000000004
VCID: 44D0BAB52E117E6A838-8010
Part No SW: 5Q0 959 655 BP HW: 5Q0 959 655 BP
Component: AirbagVW21 008 0403
Serial number: 003FJR61ZFE6 Dataset Number: 8V0909602AD 0002
Coding: 98CCC0000C2000009C5400000048000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
VCID: 0F7A459937D7CD326EA-805A
Subsystem 1 - Part No SW: ----------- HW: 480 002 801 20
Serial number: 35700000000A2AACD44.
Subsystem 2 - Part No SW: ----------- HW: 480 002 801 20
Serial number: 3580000000052AACD44X
Subsystem 3 - Part No SW: ----------- HW: 480 402 901 20
Serial number: 3510001B731DC1B23480
Subsystem 4 - Part No SW: ----------- HW: 480 402 901 20
Serial number: 3520001A532BE593E416
Subsystem 5 - Part No SW: ----------- HW: 480 402 201 20
Component: FrontSensor_D 004 6149
Serial number: 35500010C62F5865D5AF
Subsystem 6 - Part No SW: ----------- HW: 480 402 801 20
Component: PedP_Sensor_D 003 6149
Serial number: 2280001B731DC1B1F3BG
Subsystem 7 - Part No SW: ----------- HW: 480 402 801 20
Component: PedP_Sensor_P 003 6149
Serial number: 2290001C331DC1B39523
Subsystem 8 - Part No SW: ----------- HW: 480 001 501 20
Serial number: I0M00000000F36592442
Subsystem 9 - Part No SW: ----------- HW: 480 001 501 20
Serial number: I0N0000000004659244W
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 794 B HW: 8V0 920 794 B
Component: FHybRDW H19 0108
Dataset Number: 8V0909525AE 0025
Coding: 04040C506B8400080083E8101200000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001032
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3FDAB55947F71DB2DEA-806A
Part No SW: 3Q0 907 530 AD HW: 3Q0 907 530 D
Component: GW MQB EV 621 6383
Serial number: 20012011602224 Dataset Number: 8V0909515S 0103
Coding: 0201001726E200005B10100A581000000001010100010000000300000000
GVL: 01463C0000000608508C80009000C81800000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 71BE23614123BBC218E-8024
Subsystem 1 - Part No SW: 8W0 951 523 E HW: 8W0 951 523 E
Component: J453 MFL H04 0004
Serial number: 20191210205854 32018
Subsystem 2 - Part No SW: 5QE 915 181 A HW: 5QE 915 181 A
Serial number: 1362423305
Address 23: Brake Booster (J539) Labels:. 5QE-909-059.clb
Part No SW: 5QE 909 059 H HW: 5QE 909 059 B
Component: EBKV H14 0230
Serial number: 085460010490 Dataset Number: 8V0909524D 0001
Coding: 03720100331900010002050500
ASAM Dataset: EV_BrakeBoostBoschMQBOMG 005002
ROD: EV_BrakeBoostBoschMQBOMG_005_VW37.rod
VCID: 53F289E9DB7FE9D20A2-8006
Brake pressure reservoir:
Subsystem 1 - Part No SW: 5QE 909 057 D HW: 5QE 909 057 A
Component: VX70BrakeAssi H04 0155
Serial number: 05802861230120061217
89600 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [10101000] - -
[iBoVAG_ComScl_Motor_EV_02_Timeout]
Fault Frequency: 8
Mileage: 138723 km
Date: 2026.09.02
Time: 11:37:33
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
Dataset Number: 8V0909519D 0006
VCID: 42DCBCAD3405705AB14-8016
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 20000007468006 Dataset Number: 8V0909564C 0005
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313EE36181A3FBC258E-8064
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Dataset Number: 8V0909520D 0006
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS002 0330
Serial number: YE007SKU3006B Dataset Number: 8V0909872M 0064
Coding: 001C1F204000000000001002
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 49CEAB810933A30270E-801C
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Dataset Number: 8V0909852AA 0001
Coding: D11E0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B02A753E318EEAF38-8020
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 23012010520914 Dataset Number: 8V0909583B 0009
Coding: 000000050900142A00102B03020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003_VW27.rod
VCID: 372ADD796FC725F216A-8062
Address 51: Electric Drive (J841) Labels:. 5G0-907-080.clb
Part No SW: 5G0 907 080 E HW: 5G0 907 080 E
Component: LE Gen 3.3H15 1032
Revision: 00H15000 CVN: 0C4EF12C
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM08530115G0907080E 001008
ROD: EV_DMCM08530115G0907080E.rod
VCID: 290E0B01A973830290E-807C
31857 - No Communication with Engine Control Module (SAE ECM/PCM)
U0100 00 [00101000] - -
Mileage: 138723 km
Date: 2026.09.02
Time: 11:37:33
Voltage terminal 30: 11.675 V
Drive control condition: Standby
Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 2
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS002 0330
Serial number: YE007SKI04332 Dataset Number: 8V0909873M 0064
Coding: 001C17204000000000001002
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 48C8AE8512395A0A6F0-801C
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8V1 035 036 E HW: 8V1 035 036 C
Component: MU-P-LN-EU 055 1326
Serial number: A699A0LB012727 Dataset Number: 8V2909545AD 0037
Coding: 01739301FF0A000011110001000A02102F002965017001009E
VCID: 3536D77175CBD7E2046-8060
Subsystem 1 - Part No SW: V03 959 802 DF HW: -----------
Component: ECE 2019/2020 --- 0177
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9K1Y0N6H0
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL102121900050301
Compact disc data bank:
Component: Gracenote2 --- 1017
Address 75: Telematics (J949) Labels:| 5QE-035-28X-V1.clb
Part No SW: 5QE 035 284 C HW: 5QE 035 284 C
Component: OCULowMQBEU 020 0717
Dataset Number: 8V0909612E 0009
Coding: 017393011082BA0100F800000000
ROD: EV_OCULowMQB_VW37.rod
Address 8C: HV Battery (J840) Labels: None
Part No SW: 5Q0 915 182 E HW: 5Q0 915 182 C
Component: BECM H05 1101
Serial number: W7110002 CVN: ACC81AF8C05121EDB797EC16B797EC16B797EC16B797EC16B797EC16B797EC16
Coding: 00000000
ASAM Dataset: EV_BECM09620115Q0915182 006042
ROD: EV_BECM06020115C6915182_AU37.rod
High-Voltage Battery Switch Box:
Subsystem 1 - Part No SW: 5Q0 915 250 E HW: 5Q0 915 250 E
Component: BJB H28 0240
Cell module control module 1:
Subsystem 2 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D1 H14 0481
Serial number: V013C1872530053
Cell module control module 2:
Subsystem 3 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D2 H14 0481
Serial number: V013C1872430786
Cell module control module 3:
Subsystem 4 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D3 H14 0481
Serial number: V013C1872530056
Cell module control module 4:
Subsystem 5 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D4 H14 0481
Serial number: V013C1872430785
Cell module control module 5:
Subsystem 6 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D5 H14 0481
Serial number: V013C1872530058
Cell module control module 6:
Subsystem 7 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D6 H14 0481
Serial number: V013C1872530055
Cell module control module 7:
Subsystem 8 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D7 H14 0481
Serial number: V013C1872530057
Cell module control module 8:
Subsystem 9 - Part No SW: 5QE 915 591 K HW: 5QE 915 591 K
Component: 6D8 H14 0481
Serial number: V013C1872530054
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 30012015K13428 Dataset Number: 8V0909466R 0016
Coding: 040307030000040101222344814EA90094000E20002000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D8B6A53A09624AA70-8014
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 5Q0 959 395 K HW: 8W1 959 395 D
Component: TSG HFS004 0330
Serial number: YE007SKK24072 Dataset Number: 8V0909897K 0063
Coding: 000C17204000000000001002
ROD: EV_DCU2RearDriveMAXHKLO_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS004 0330
Serial number: YE007SKK24427 Dataset Number: 8V0909896K 0063
ROD: EV_DCU2RearPasseMAXHKLO_VW37.rod
Address C0: Act. for Ext. Noise (----) Labels:| 5QE-035-335.clb
Part No SW: 5QE 035 335 M HW: 5QE 035 335 B
Component: E_SOUND_SG H11 0225
Serial number: EN200319140000 Dataset Number: 8V0909470C 0002
Coding: 04
ASAM Dataset: EV_ENoiseS1NNVW3707 007015
ROD: EV_ENoiseS1NNVW3707_007_VW37.rod
VCID: 4BC29189034FB112422-801E
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 5QE 915 682 BG HW: 5QE 915 682 BG
Component: OBC KOSTAL H41 4115
Revision: -------- Serial number: 2012190KM001A0 Dataset Number: 8V0909811J 0024
Coding: 115068223000
ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
ROD: EV_OBCSinglPhaseKLOMQB12P_VW37.rod
VCID: 137249E91BFF29D24A2-8046
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
Dataset Number: 8V0909471E 0008
VCID: 176A3DF90F0705F236A-8042
Component: LED1R H09 0008
Dataset Number: 8V0909472E 0008
End----------(Elapsed Time: 01:58, VBatt start/end: 12.1V/12.1V)-----------
------------------------------4 Faults Found-------------------------------
