VW Caddy 2025
RTS
C?ID=492458
Post scan as forgot to do beforehand
VCDS Version: 26.7.2.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260708 DS378.0
VIN: WV1ZZZSK9SX07****   License Plate:
Chassis Type: SK-VN3SP PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5
          D6 D7 C002 C003
VIN: WV1ZZZSK9SX07****   Mileage: 12600km-7829miles
13-Auto Dist. Reg -- Status: Cannot be reached 0100
Address 01: Engine (J623-DXRA)       Labels: Redir Fail!
   Part No SW: 05L 906 023 QL    HW: 05L 907 309 AH
   Component: R4 2.0l TDI   H80 3772
   Revision: NEH80---    CVN: D5DAAF3110A70AD289980D21252F1ED389980D2145690194
   Coding: 012500320324050930080000001000000000000000000000
   Shop #: WSC 35110 377 00021
   ASAM Dataset: EV_ECM20TDI01105L906023QL 010002
   ROD: EV_ECM20TDI01105L906023QL.rod
   VCID: 0256E213248329FAC86-8056 SFD+SFD2 [ ]
   VINID: 9E606AAAA8DB263A001C32400CFC57F5EA
   Heater for exhaust gas catalytic converter:
   Flush-air pump:
   Active oil separating system:
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [00100110] - -
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:04:00
                    Engine speed: 0.00 /min
                    Coolant temperature: 20  C
                    Intake air temperature: 21  C
                    Voltage terminal 30: 11.540 V
                    Acceleration: 0.000 m/s
                    Drive train coordinator: Acceleration Requester Status: 0
                    Drive train coordinator current status: 2
                    Drivetrain coordinator: ACC fault status: 0
                    Drive train coordinator irreversible switch off conditions: 0
                    Drivetrain coordinator: brake fault status: 5
                    Drive train coordinator: acceleration request target value: 0.000 m/s
43796 - Implausible Data Received from Transmission Control Module
          U0402 00 [00100110] - -
          [Invalid Data Received From Transmission Control Module]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:38
                    Voltage terminal 30: 12.900 V
                    Engine status: COENG_READY
44047 - Front Camera for Driver Assist Systems
          U1229 00 [00100111] - Implausible Message
          [Front camera for driver assistance systems implausible]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:38
                    Voltage terminal 30: 12.920 V
43768 - Release / Enable Active
          B184C 00 [00100111] - -
          [Activation active]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:59
                    Vehicle speed: 255 km/h
                    Voltage terminal 30: 11.860 V
   Part No SW: 0GC 906 555 GE    HW: 0GC 300 058 B
   Component: GSG DQ381     H06 0661
   CVN: 58D2AEBD
   ASAM Dataset: EV_TCMDQ381064 001011
   ROD: EV_TCMDQ381064.rod
   VCID: 045AE40B3E9727CAFAA-8050 SFD [x]
   Parking lock:
   Subsystem 1 - Part No SW: 5WA 907 484 A    HW: 5WA 907 484
   Component: ZSB_SB_AUTO    H03 1092
   Serial number: 00000000000087218642
   Selector lever:
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 10122406S00000110937
   MTF pump:
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700007282158
21193 - No Communication with Cruise Control Module
          U0104 00 [00101111] - -
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:38
                    Clutch: primary stat: New
                    selected gear: Gang_N
                    Position: P
                    Engine torque: -100 Nm
                    Control Module temperature: 20  C
                    Accelerator pedal position: 14.1 %
                    DTC memory status: 79
Address 03: ABS Brakes (J104)       Labels:. 5WA-614-517-V2.clb
   Part No SW: 5WA 614 517 DQ    HW: 5WA 614 517 BS
   Component: ESC           H31 0331
   Serial number: 60105000009878  Dataset Number: V03935455DH 0001 CVN: 191549AA4841C0C7
   Coding: 52185428B04B399C4001A5AC9EB701450ACF952151A000
   ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026
   ROD: EV_Brake1ESCMQB37WUNECE_006_VN3SP.rod
   VCID: 1A66BA73AC13813A306-804E SFD+SFD2 [x]
17257 - Implausible Data Received from Airbag Control Module
          U0452 00 [10101111] - -
          [CCan_Airbag_01_CALID_Index_13_inv]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:49
                    Vehlicle_speed: 0.0 km/h
                    Resolution Mileage: 316 m
                    Voltage_value_KL.30_ESC_V: 12.8 V
                    Wake up EPB: not active
                    Wake up CAN: not active
                    Postrun_activ: not active
                    Comparison_pressure_sensor: completed successfully
                    Comparison_longitudinal_accleration: completed successfully
                    Comparison_transverse_accleration: not completed successfully
                    Comparison_yaw_rate_sensor: not completed successfully
                    LWS_comparison: not completed successfully
                    Internal_failure_code: 00 14
                    00 40 00 00 04 08 10 08 80 00 00 00 81 00 00 40 30 00 21 00 04
8516 - Control Module for ACC
          U164C 00 [00100111] - No Communications
          [CCan_AWV_03_Timeout]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:38
                    Internal_failure_code: 00 28
0294 - Steering Angle Sensor
          B1168 F2 [00100110] - Not Initialized
          [Swa_init_fail]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:38
                    Internal_failure_code: 01 DC
          C1146 02 [00100110] - Signal Failure
          [RKA+: missing input signal(s)]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:49
                    Internal_failure_code: 02 8A
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 AC    HW: 5WA 959 436 M
   Component: Kessy IOBOX   122 0771
   Serial number: --------------- Dataset Number: V03935389DZ 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 157CA94F450DAE421D4-8040
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 5WA 907 727 BL    HW: 5WA 907 727 AG
   Component: AC Manuell    H01 5088
   Serial number: 122122419122750 Dataset Number: V03935452UX 0001
   Coding: 023110010211000000100000011001010000010010000000000000000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002062
   ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
   VCID: 1B68BF77A329F8322B0-804E SFD+SFD2 [x]
523532 - BCM
          U15BA 00 [00100111] - Received Malfunction Value
          [Body computer 1/vehicle electrical system control module/el.ZE Received malfunction value 2]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:06
393635 - High Pressure Sensor
          B10AE 21 [00100111] - Signal Amplitude Too Low
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:11
                    Voltage terminal 30: 12.90 V
                    Outside temperature: 20.50  C
                    Inside temperature: 13067.00  C
                    Engine running time: 121 s
                    Terminal 15 on: 190 s
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BK    HW: 5WA 937 086 BK
   Component: BCM37w_M1238 0434
   Serial number: BXJ53F200125951 Dataset Number: V03935446LR 0001
   ASAM Dataset: EV_BCMwBL 004001
   ROD: EV_BCMwBL_004.rod
   Subsystem 1 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53529102400026724
   Subsystem 2 - Part No SW: 5H0 941 193 G    HW: 5H0 941 193 G
   Component: LiSi           H04 0513
   Serial number: TW571414012500010575
   Subsystem 3 - Part No SW: 5H0 925 200 T    HW: 5H0 925 200 T
   Component: DiETa          H07 0008
   Serial number: 92471YA8000O5
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000005551449
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 507 EB    HW: 5Q1 953 549 D
   Serial number: 00000009012508490502
525060 - Local Data Bus 3
          U10C8 00 [00101111] - No Communications
          [LIN3 keine Kommunikation]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:08
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: On
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating State: Normal mode
                    Voltage: 13.10 V
                    Outside temperature: 20.00  C
                    Light switch position: automatic
                    Wiper motor control module: Available
                    Wiper motor control unit 2: Available
                    Rain/Light Recognition Sensor: Available
                    Light switch: Available
                    Control head for driving and comfort functions: Available
                    Alarm horn: Available
                    Anti-theft alarm system sensor: Available
                    Roof electronics control module: Available
                    Garage door opener control module: Available
                    Valve block 1 in front seat driver side: Available
                    Valve block 1 in front seat passenger side: Available
                    Blower 1 for left front backrest: Available
                    Blower 1 for left front seat cushion: Available
                    Blower 1 for right front backrest: Available
                    Blower 1 for right front seat cushion: Available
                    Left neck heater: Available
                    Right neck heater: Available
                    Steering Column Switch: Available
                    Radio receiver for remote start: Available
                    Power rear lid opening control module: Available
                    Left taillight 1: Available
                    Left taillight 2: Available
                    Right taillight 1: Available
                    Right taillight 2: Available
                    Antenna for short-range communication: Available
                    Control unit 2 for driving and convenience functions: Available
                    Humidity sensor: interior: Available
                    Virtual pedal door opening: rear driver's side: Available
                    Virtual pedal door opening: rear passenger's side: Available
                    Left rear door control module: Available
                    Right rear door control module: Available
   Part No SW: 5QS 919 294 A    HW: 5QS 919 294
   Component: PDC 08ch low  H01 0075
   Serial number: 000009012595580 Dataset Number: V03935446MF 0001
   Coding: 0040010011
   ASAM Dataset: EV_EPHBO18VW3360000 001010
   ROD: EV_EPHBO18VW3360000_VW42.rod
   VCID: 5CEAFC6BE6A7BF0AE2A-8008
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [00100011] - Open or Short to Ground
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [00100011] - Open or Short to Ground
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [00100011] - Open or Short to Ground
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [00100011] - Open or Short to Ground
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [00101111] - Open Circuit
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:04
Address 13: Auto Dist. Reg
Address 15: Airbags (J234)       Labels:| 5QS-959-655.clb
   Part No SW: 5QS 959 655 D    HW: 5QS 959 655 D
   Component: AirbagVW50    004 0126
   Serial number: 000000003C0RVRC Dataset Number: V03935446GS 0001
   Coding: 88CC000000C00000000000000000000091000000A1000000C000F68000AB00A7
   ASAM Dataset: EV_AirbaVW50SMEVW49X 001014
   ROD: EV_AirbaVW50SMEVW49X.rod
   VCID: 649AC48BDED787CA5AA-8030 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: -----------    HW: 480 000 A01 19
   Serial number: 3570000576892E835D20
   Subsystem 2 - Part No SW: -----------    HW: 480 000 A01 19
   Serial number: 3580000256852D618A40
   Subsystem 3 - Part No SW: -----------    HW: 480 051 90B 18
   Component: FrontSensor_D  000 014A
   Serial number: 3550000A0DAA288C6900
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 4 - Part No SW: -----------    HW: 480 050 B01 19
   Component: Side_Sens_B_D  000 0149
   Serial number: I0P0000AADEAE6532B10
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 5 - Part No SW: -----------    HW: 480 050 A01 19
   Component: Side_Sens_B_P  000 0149
   Serial number: I0Q0000ACDEAE6524A70
9438746 - Igniter for Seat Belt Tensioner; Driver's Side
          B1006 1A [10101111] - Resistance Too Low
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:06
9438491 - Igniter for Driver head airbag
          B1005 1B [10101111] - Resistance Too High
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:06
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [10101111] - Resistance Too High
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:06
1078272 - Databus
          U1121 00 [10101111] - Missing Message
          [NWD: 0x16A954FD PAO_Status_01 Timeout]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:10
Address 17: Instruments (J285)       Labels:| 5H0-920-KOM-V1.clb-SRI2
   Part No SW: 5H0 920 340 E    HW: 5H0 920 340 E
   Component: KOMBI         402 1552
   Dataset Number: V03935442EM 0001
   Coding: 24A4054763840600018062032000080800301C0800
   ASAM Dataset: EV_DashBoardVDDMQB37W 005050
   ROD: EV_DashBoardVDDMQB37W_005_VN3S.rod
   VCID: 241A848B9E57C7CA9AA-8070 SFD [x]
16777028 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00001001] - -
          [AWV_0x18 communication error bap_error_timeout heartbeat]
                    Reset counter: 88
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:07
16776976 - Databus
          [AWV_02 communication error can_error_timeout]
                    Reset counter: 88
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:04
   Part No SW: 5QS 907 530 E    HW: 5QS 907 530
   Component: GW MQB 23     005 2091
   Serial number: SMERBG070125007 Dataset Number: V03935451CD 0001
   Coding: 000000000000000000000000000000000000000000000000030000000000000000000000000000000000000000000000
   GVL: 3D0000000208408C80008002C800004004004000004000000000000000000044
   ASAM Dataset: EV_GatewMQBwBL 001018
   ROD: EV_GatewMQBwBL_VW41.rod
   VCID: 56FEEE43988B655AD4E-8002 SFD+SFD2 [ ]
   Generator:
   Component: 5-00-17-01-03
   Subsystem 2 - Part No SW: 5QS 915 181     HW: 5QS 915 181
   Component: J367-BDMHella  H01 2362
   Serial number: 7549745506
   Subsystem 3 - Part No SW: 571 959 442     HW: 571 959 442
   Component: E221__MFL-PR6  H07 0130
   Serial number: PR6-0440036344245890
2232407 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00101111] - -
          [Cruise_control_front_distance_range_sensor_no_communication]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:42
2269194 - No Communications with Parking Assist Control Module A
          U0159 00 [00100100] - -
          [Parking_assist_control_module_no_communication]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:53
8389392 - Control Module for Driver Assist Systems
          C12D5 87 [00100110] - Missing Message
          [FAS messsages retention time to long]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:03:51
   Part No SW: 5WA 909 059 AG    HW: 3Q0 909 059 D
   Component: EBKV          H10 0562
   Serial number: BPA085181224018 Dataset Number: V03935447DC 0001
   Coding: 5402C100700000008018638C000049922449922400
   ASAM Dataset: EV_BrakeBoostVW37WUNECE 013003
   ROD: EV_BrakeBoostVW37WUNECE_013.rod
   VCID: 157CA94F450DAE421D4-8040 SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000319653012 Dataset Number: V03935396Z  0001
   Coding: 8820000000000000
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE_003_VW27.rod
   VCID: 0842F03B02BF03AA962-805C SFD+SFD2 [x]
   Part No SW: 3WA 959 593 A    HW: 3WA 959 593
   Component: TSG FS        001 0222
   Serial number: YE007XLK17603   Dataset Number: V03935443PN 0001
   Coding: 00208320D001000100001020
   ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
   ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
   VCID: 54FA144B8E77774A2AA-8000 SFD+SFD2 [x]
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V2.clb
   Part No SW: 5QS 907 144 E    HW: 5QS 907 144
   Component: BASGEN1MQB37  104 1122
   Serial number: 03943105 Dataset Number: V03935447BA 0001
   Coding: 00000000000000000001020101000100000001010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017.rod
   VCID: 57E0E3479F815C52CF8-8002 SFD+SFD2 [x]
   Part No SW: 3WA 959 592 A    HW: 3WA 959 592
   Component: TSG BFS       001 0222
   Serial number: YE007XLL13833   Dataset Number: V03935443PP 0001
   Coding: 00200120D001000100001020
   ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
   ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
   VCID: 53F817578B797072330-8006 SFD+SFD2 [x]
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 572 035 816 B    HW: 572 035 816
   Component: MU-O-ND-EU    H10 2632
   Serial number: WG8LGM080125004 Dataset Number: V03935454SM 0001
   Coding: 6352100A000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 002001
   ROD: EV_MUOIMQB37w_002_VW41.rod
   VCID: 1760A3475F019C520F8-8042 SFD+SFD2 [x]
   Subsystem 1 - Part No SW: 5H0 919 605 D    HW: 5H0 919 605 D
   Component: ABT_W_10       H49 2112
   Serial number: APUFM812122400010448
   Subsystem 2 - Part No: V03 959 821 M
   Component: EUR 2025       2119
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 F    HW: 5WA 980 556 C
   Component: RV eCompact   H52 0554
   Serial number: FCLK20231224010 Dataset Number: V03935446TQ 0001
   Coding: 06034F0027140000
   ASAM Dataset: EV_CamSysRVCeCFicosBL 003009
   ROD: EV_CamSysRVCeCFicosBL.rod
   Part No SW: 571 035 284 B    HW: 571 035 284
   Component: OCUMQBW2023_H H09 0626
   Serial number: 0000000409VIZCJ Dataset Number: V03935448RA 0001
   Coding: 06010601000000110000010013002607111012111012000010
   ASAM Dataset: EV_OCUMWB2023 001066
   ROD: EV_OCUMWB2023_VW42.rod
1863 - Automotive Audio Bus (A2B)
          B1994 13 [00100111] - Open Circuit
          [a2b_bus_connection_fault_open_wire_node]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:05
                    Voltage terminal 30: 12.9 V
                    Node number: 0
                    Node name: Microphone module in roof
                    Node status: Open circuit
9458195 - Control Module for Cellular Telephone
          B1052 13 [00100111] - Open Circuit
          [Button Assembly - Interruption]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:07
12866049 - Databus
          U1123 00 [00100111] - Received Error Message
          [Airbag: Error value received]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:06
   Part No SW: 5WA 980 653 F    HW: 5WA 980 653 A
   Component: MQB MFK 3.0   H12 3603
   Serial number: EF8972903250090 Dataset Number: V03935443PF 0001
   Coding: 0001091011484040409E08001020002000018088600000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005071
   ROD: EV_MFK3ValeoMQB_005_SE38P.rod
   VCID: 52F61253B463797A386-8006
1124445 - Databus
          [TIMEOUT_ACC_18]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:04
1124444 - Databus
          [TIMEOUT_ACC_19]
                    Mileage: 12600 km
                    Date: 2026.08.28
                    Time: 16:07:04
   Part No SW: 992 941 571 AJ    HW: 992 941 571 A
   Component: LED1L         H17 9204
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 6A86AAB33CF3D1BA606-803E
   Component: LED1R         H17 9204
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
End----------(Elapsed Time: 01:16, VBatt start/end: 13.1V/13.2V)-----------
------------------------------31 Faults Found---------------------
RTS
C?ID=492458
GES Log
Address 0x19,5QS 907 530 E,UDS Basic Settings,IDE06504-ENG254041-Reset of reversible crash shut-off,Friday,28,August,2026,16:01:05:50062,WV1ZZZSK9SX07****
Address 0x01,05L 906 023 QL,UDS Basic Settings,[SFD ] IDE17266-Unlocking the fuel system after a crash,Friday,28,August,2026,16:02:42:50062,WV1ZZZSK9SX07****
ADP log
Address 19,5QS 907 530 E,channel [SFD ] IDE16611-Diagnosis filter: temporary deactivation,adapted from,not active ,to,not active ,Friday,28,August,2026,16:00:47:50062,WV1ZZZSK9SX07****
SFD Log
WV1ZZZSK9SX07****,,,Start SFD Session,Friday,28,August,2026,15:59:26,HN2-01****,SFD session start successful
WV1ZZZSK9SX07****,Address 0x19,5QS 907 530 E,Online SFD,Friday,28,August,2026,16:00:15,HN2-01****,Interface ID retrieval fail
WV1ZZZSK9SX07****,Address 0x19,5QS 907 530 E,Online SFD,Friday,28,August,2026,16:00:35,HN2-01****,SFD challenge retrieval success, 583 bytes
WV1ZZZSK9SX07****,Address 0x19,5QS 907 530 E,Online SFD,Friday,28,August,2026,16:00:37,HN2-01****,SFD unlock token retrieval success, 852 bytes
WV1ZZZSK9SX07****,Address 0x19,5QS 907 530 E,Online SFD,Friday,28,August,2026,16:00:37,HN2-01****,SFD unlock token transmitted to controller
WV1ZZZSK9SX07****,Address 0x19,5QS 907 530 E,Online SFD,Friday,28,August,2026,16:00:39,HN2-01****,Unlock_successful
WV1ZZZSK9SX07****,Address 0x01,05L 906 023 QL,Online SFD,Friday,28,August,2026,16:02:22,HN2-01****,SFD challenge retrieval success, 583 bytes
WV1ZZZSK9SX07****,Address 0x01,05L 906 023 QL,Online SFD,Friday,28,August,2026,16:02:24,HN2-01****,SFD unlock token retrieval success, 532 bytes
WV1ZZZSK9SX07****,Address 0x01,05L 906 023 QL,Online SFD,Friday,28,August,2026,16:02:24,HN2-01****,SFD unlock token transmitted to controller
WV1ZZZSK9SX07****,Address 0x01,05L 906 023 QL,Online SFD,Friday,28,August,2026,16:02:25,HN2-01****,Unlock_successful
