- Mar 2, 2014
- 36
- 15
- Bucharest, Romania
- C?ID=80804
Hello
Today I discovered on the forum that SFD is in the beta procedure and I want to participate too if is possible.
This is autoscan from my ID.3 1st 2020
I also made a request to purchase SFD to which I am waiting for a response
I also redone the interface activation procedure, even though it was successfully activated in 2017, I changed the city and address and I read that the data must be the same in both requests, in the SFD request I passed the data from the new address.
thank you.
I am waiting for interface activation.
Wednesday,02,September,2026,14:25:52:49483
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.4
Dealer/Shop Name: Al Bundy Garage
Workshop Code: 973 01973 001973
VIN: WVWZZZE1ZLP012289 License Plate:
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 19 23 2B 42 44 51 52 5F 6C 75 7E
8C A5 C0 C6 D6 D7 8105 8107 811E 811F 8120 8121 8123 8124 8125 8128 C002 C003
VIN: WVWZZZE1ZLP012289 Mileage: 43895km-27275miles
7E-Ctrl Head Dash -- Status: OK 0000
8C-HV Battery -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBJC) Labels: 0EA-907-425-V1.clb
Part No SW: 0EA 906 012 DG HW: 0EA 907 425 C
Component: E-Vehicle H01 2604
CVN: 0DF7E241
Coding: 010200000364140070080000001000402000060000000000
ASAM Dataset: EV_VCU00XXX0200EA906012DG 001001
ROD: EV_VCU00XXX0200EA906012DN.rod
VCID: 73B0D65B6B393C22EA2-8026 SFD [x]
VINID: 9E69EAAAA541A9C8000420882425652590
Radiator shutter:
Subsystem 1 - Part No SW: 1EA 965 501 HW: 1EA 965 501
Component: V711 021 0005
Serial number: 20200325060404055580
31949 - Front Camera for Driver Assist Systems
U1229 00 [00100000] - Implausible Message
[Front camera for driver assistance systems implausible]
Reset counter: 12
Mileage: 43072 km
Date: 2026.06.15
Time: 05:00:37
Engine speed: 16383.75 /min
Normed load value: 100.0 %
Vehicle speed: 6 km/h
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Ambient air pressure: 2550 mbar
Voltage terminal 30: 14.472 V
Unlearning counter according OBD: 12
LF_MVB_PDU_INTC_DIAG_1: 32792
LF_MVB_PDU_INTC_DIAG_2: 15360
LF_MVB_PDU_INTC_DIAG_3: 0
LF_MVB_PDU_INTC_DIAG_4: 32768
LF_MVB_PDU_INTC_DIAG_5: 258
LF_MVB_PDU_INTC_DIAG_6: 8072
LF_MVB_BUS_INTC_DIAG: 256
Address 03: ABS Brakes (J104) Labels: 1EA-614-517-V1.clb
Part No SW: 1EA 614 517 BC HW: 1EA 614 517
Component: ESC-ZF_EBC470 H14 0526
Serial number: B000CWV Dataset Number: V03935378JG 0001
Coding: 09954A84153C9038523EA8E611E211A648294916443161492888886512949268228C869214CECBBCFD0073D33DBF00
ASAM Dataset: EV_Brake1ZFESCEPBMEB 013164
ROD: EV_Brake1ZFESCEPBMEB.rod
VCID: 74B2D5476E373B1AF38-8020 SFD [x]
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AB HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0725
Serial number: --------------- Dataset Number: V03935344RT 0001
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003.rod
VCID: 1472B5C74EF79B1A538-8040
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 1EA 907 727 AJ HW: 1EA 907 727 C
Component: Climatronic H01 0465
Coding: 002022017010120000100010110001102000102100101101000000000000
ASAM Dataset: EV_ACClimaBHBMEB31X 002015
ROD: EV_ACClimaBHBMEB31X.rod
VCID: 025E839F248305AAF14-8056
Subsystem 1 - Part No SW: 1EA 820 021 HW: 1EA 820 021
Component: J126 J126 001 0003
Serial number: 00000000000000000736
Air quality sensor:
Subsystem 2 - Part No SW: 5Q0 907 659 D HW: 5Q0 907 659 D
Component: G238 _AQS H01 0002
Serial number: 00000000000000104452
A/C compressor sub:
Subsystem 3 - Part No SW: 1EA 816 797 F HW: 1EA 816 797 F
Component: J842 eKK H06 0002
Serial number: 1EA816797F0406200143
Auxiliary Heater Control Module/PTC 2:
Subsystem 4 - Part No SW: 1EA 963 581 HW: 1EA 963 581
Component: 0123456789012 010 0160
Serial number: 1996460EA20167000349
Interior temperature sensor:
Subsystem 5 - Part No SW: 5WA 907 527 HW: 5WA 907 527
Component: E857 H01 0103
Serial number: 00001310320061017515
Expansion valve 1 for refrigerant:
Subsystem 6 - Part No SW: 1EA 816 590 B HW: 1EA 816 590 B
Component: N636 EV1_KaMi H05 0001
Serial number: 0138767
Subsystem 7 - Part No SW: 4M0 959 603 C HW: 4M0 959 603 C
Component: G395 pT-Sens1 H11 0010
Address 09: Cent. Elect. (J519) Labels: 1EA-937-BCM-V1.clb
Part No SW: 1EA 937 089 AJ HW: 1EA 937 089 A
Component: SAM_H H22 0311
Serial number: 06102015601313- Dataset Number: V03935341HX 0001
ASAM Dataset: EV_SAMVW31x 004001
ROD: EV_SAMVW31x_004.rod
VCID: 06569F8F08AB398ADDC-8052 SFD [x]
Subsystem 1 - Part No SW: 10A 955 119 HW: 10A 955 119
Component: FWISCHER_MYJT 003 0050
Serial number: 909353F0401934600505
Wiper motor control unit 2:
Subsystem 2 - Part No SW: 10A 955 120 HW: 10A 955 120
Component: FWISCHER_SL02 003 0050
Serial number: 909453F0402005402182
Subsystem 3 - Part No SW: 5Q0 955 555 A HW: 5Q0 955 555 A
Component: RLHSS 054 0207
Serial number: S6Y20M06D03H16M10S29
Subsystem 4 - Part No SW: 10A 941 193 H HW: 10A 941 193 H
Component: LiSi H04 0513
Serial number: TW571422062000010693
Subsystem 5 - Part No SW: 10A 925 200 D HW: 10A 925 200 D
Component: DiEta H06 0513
Serial number: TW571416062000010334
Subsystem 6 - Part No SW: 5H0 959 561 K HW: 5H0 959 561 K
Component: DACHKONSOLE 006 0006
Serial number: 92413TF100395-------
1074806 - Databus
U1123 00 [00100100] - Received Error Message
[ICAS1_Gateway Datenbus empfangener Fehlerwert]
Reset counter: 38
Date: 2026.08.25
Time: 17:19:41
Terminal 15 status: OFF
Terminal 50 status: OFF
Status of brake lamp switch: discrete: OFF
Brake lamp switch via CAN: status: OFF
Voltage: 12.3 V
Outside temperature: 29.5 °C
0: not active
Position lamps: not active
automatic: not active
Low beams: not active
Malfunction: not active
15401472 - Secure Onboard Communication
U14FF 00 [01101101] - Signature Generation Failed
[Sichere on-board Kommunikation: Signaturerstellung fehlgeschlagen]
Date: 2026.08.22
Time: 19:03:03
Voltage: 12.5 V
0: not active
Address 10: Park/Steer Assist (-----) Labels:| 1EA-919-294.clb
Part No SW: 1EA 919 294 D HW: 1EA 919 294
Component: PDC08K H01 0421
Serial number: 000015062094630 Dataset Number: V03935360LC 0001
Coding: 0040010001
ASAM Dataset: EV_EPHBO18VW3100000 002016
ROD: EV_EPHBO18VW3100000_VWE3.rod
VCID: 3D2430631DFDBA52CC6-8068
Address 13: Auto Dist. Reg (J428) Labels:| 1EA-907-572.clb
Part No SW: 1EA 907 572 H HW: 1EA 907 572
Component: ARS510VW19 H01 0236
Dataset Number: V03935362QL 0001
Coding: 010310E14071404512474008000040C5AF4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARCONTIVW310 003010
ROD: EV_FRONTRADARCONTIVW310_003.rod
Address 15: Airbags (J234) Labels: 1EA-959-655.clb
Part No SW: 1EA 959 655 ER HW: 1EA 959 655 AF
Component: VW40Airbag 009 0385
Serial number: U154HyE0118 Dataset Number: V03935399CU 0001
Coding: 88CC008000F0C000000000200000000051540000A1540000C000F680002B0065
Shop #: WSC 99999 999 2097151
ASAM Dataset: EV_AirbaVW40ALVVW38X 001016
ROD: EV_AirbaVW40ALVVW38X.rod
VCID: 1574C8C3450D8212246-8040 SFD [x]
Left seat belt tensioner:
Subsystem 1 - Part No SW: 10A 980 945 HW: 10A 980 945
Component: BeltPretRevFL 602 0100
Serial number: 10B857705C0155U00819
Right seat belt tensioner:
Subsystem 2 - Part No SW: 10A 980 946 HW: 10A 980 946
Component: BeltPretRevFR 602 0100
Serial number: 10B857706C0155U00610
Subsystem 3 - Part No SW: ----------- HW: 440 001 001 20
Component: SideSensor_Df 00A 0887
Serial number: 357CJ00000080859E24A
Subsystem 4 - Part No SW: ----------- HW: 440 001 001 20
Component: SideSensor_Pf 00A 0887
Serial number: 358CJ0000003D359E24E
Subsystem 5 - Part No SW: ----------- HW: 440 002 401 20
Component: SideSensor_Dr 00A 0189
Serial number: 351CJ0A62E750355100C
Subsystem 6 - Part No SW: ----------- HW: 440 002 401 20
Component: SideSensor_Pr 00A 0189
Serial number: 352CJ3062E7504B5A00M
Subsystem 7 - Part No SW: ----------- HW: 440 001 703 20
Component: FrontSensor_D 00A 014A
Serial number: 355CJ202BFE08295900Z
9444359 - Safety belt switch - driver side
B101C 07 [00101111] - Mechanical Failure
Mileage: 43824 km
Date: 2026.08.24
Time: 10:37:05
Address 16: Steering wheel (J527) Labels:* None
Part No SW: 1EA 953 508 J HW: 1EA 953 508 J
Component: GSMMEB 007 0072
Serial number: 000000130721260
Coding: 0000
ASAM Dataset: EV_SMLSKLOMEB 010001
ROD: EV_SMLSKLOMEB.rod
VCID: 3FD84A6B17F1A842DEA-806A
Address 19: CAN Gateway (J533) Labels: 1EA-937-012.clb
Part No SW: 1EA 937 012 AD HW: 1EA 937 012 A
Component: ICAS1 Host-SG 062 0329
Serial number: SJ8ICS200620117 Dataset Number: V03935494GC 0001
GVL: 2D0000002608508C8062904248180040C400400000060000000000000000DE57
ASAM Dataset: EV_GatewICAS1MEB 005001
ROD: EV_GatewICAS1MEB.rod
VCID: 72BED35F1423352AE14-8026 SFD [x]
Subsystem 1 - Part No SW: 1EA 915 181 HW: 1EA 915 181
Component: J367-BDMConti H04 1074
Serial number: 7646660400200221074B
Left taillight 1:
Subsystem 2 - Part No SW: 10A 945 207 HW: 10A 945 207 H
Component: iSBBR li 1 H04 0016
Serial number: 000000000_H04_157524
Right taillight 1:
Subsystem 3 - Part No SW: 10A 945 208 HW: 10A 945 208 E
Component: iSBBR re 1 H04 0013
Serial number: 000000000_H04_028416
Subsystem 4 - Part No SW: 1EA 959 442 H HW: 1EA 959 442
Component: MFL H08 0032
Serial number: 17029815051292000889
8471814 - Databus
U1123 00 [00101110] - Received Error Message
[error_value_ESC_50_EPB_Fehlerstatus_02]
Fault Frequency: 66
Date: 2026.08.20
Time: 17:02:45
8491266 - Secure Onboard Communication
U14FE 00 [00101111] - Signature Verification Failed
[SOK_signature_verification_failed]
Fault Frequency: 89
Mileage: 43794 km
Date: 2026.08.20
Time: 11:25:55
8511745 - Occupant Detection
U173E 00 [00101111] - Function Restriction due to Implausible Message
[Occupant_Presence_Service_Restriction]
Fault Frequency: 21
Mileage: 43794 km
Date: 2026.08.20
Time: 11:23:28
9371914 - Predictive Route Data
B1630 02 [01101101] - Signal Failure
Mileage: 43794 km
Date: 2026.08.20
Time: 11:29:19
8398626 - Control Module 2 for Electric Drive Power
U0292 00 [00101111] - No Communications
[EM2_01_no_communication]
Mileage: 43794 km
Date: 2026.08.22
Time: 10:40:50
Address 23: Brake Booster (J539) Labels: 1EA-909-059-V1.clb
Part No SW: 1EA 909 059 AN HW: 1EA 909 059
Component: EBB-ZF-Gen1 H27 0626
Serial number: ÿÿÿÿÿÿÿ Dataset Number: V03935344AZ 0001
Coding: 08951384003C1038C83E00E620E22020202020202021212121000404040404040404848484840008001000
ASAM Dataset: EV_BrakeBoostZFMEB 012153
ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 1EA 905 861 HW: 2Q0 905 861 B
Component: ELV-MEB H08 0040
Serial number: 20000097255015
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW27.rod
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 1EA 959 593 E HW: 1EA 959 593
Component: TSG FS 003 0551
Serial number: 0000409227672 Dataset Number: V03935403FE 0001
Coding: 003D1320D00084800D001000
ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
ROD: EV_DCU3DriveSideMAXHCONT.rod
VCID: 44D245877E17CB9A838-8010
Door operating panel: driver side:
Subsystem 1 - Part No SW: 10A 959 862 N HW: 10A 959 862 N
Component: EX36 TBF_FS H21 0107
Serial number: 0946-14.08.20-------
Subsystem 2 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000014741039
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V1.clb
Part No SW: 1EA 907 144 AP HW: 1EA 907 144 G
Component: BASGEN1MQB37 215 5033
Serial number: 00096008 Dataset Number: V03935360FX 0001
Coding: 00000000000002010000020101000100000001000101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 009050
ROD: EV_SteerAssisBASGEN1MQB37_009.rod
VCID: 015C8C9321851EB2E8E-8054
Address 51: Electric Drive (J841) Labels: 1EA-907-121.clb
Part No SW: 1EA 907 121 BT HW: 1EA 907 121 C
Component: MEB INV4.0 H08 6051
Serial number: NRR_M5000052830 CVN: 4E52525F4D35303030303532
ASAM Dataset: EV_DMCM15000F11EA907121BT 001013
ROD: EV_DMCM15000F11EA907121AC.rod
VCID: 015C8C9321851EB2E8E-8054 SFD [x]
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 1EA 959 592 E HW: 1EA 959 592
Component: TSG BFS 003 0551
Serial number: 0000406341275 Dataset Number: V03935403FF 0001
Coding: 003D1120DC00048001801000
ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
ROD: EV_DCU3PasseSideMAXHCONT.rod
VCID: 43D0469B7B19CCA2BA2-8016
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000014734625
Address 5F: Information Electr. (J794) Labels:| 10A-035-IC3-V1.clb
Part No SW: 10A 035 820 P HW: 10A 035 820 A
Component: IC3-SF--EU H20 1771
Dataset Number: V03935392WL 0001
Coding: 23106030000000000000000000000000000000000000000000
ASAM Dataset: EV_MUICASSAFEPart 001001
ROD: EV_MUICASSAFEPart_001_VWE3.rod
VCID: 2412E5079E57EB9AA38-8070 SFD [x]
Subsystem 1 - Part No SW: 10A 919 605 H HW: 10A 919 605 H
Component: ABT_E_10 H41 3082
Serial number: VDD02426052007010115
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 1EA 980 556 J HW: 5WA 980 556 A
Component: RV eCompact H18 0397
Serial number: FCLK20090420000 Dataset Number: V03935338YM 0001
Coding: 02036204E43000
ASAM Dataset: EV_CamSysRVCCompaFicosMEB 004014
ROD: EV_CamSysRVCCompaFicosMEB_004_VWE3.rod
VCID: 42DE439F6403C5AAB14-8016
Part No SW: 10A 035 284 J HW: 10A 035 284
Component: OCUGen4 H17 0716
Serial number: 0000000204VIDN5 Dataset Number: V03935351PP 0001
Coding: 02310010106880008005460000000000
ASAM Dataset: EV_OCUGen4 001054
ROD: EV_OCUGen4_VWE3.rod
VCID: 221EE31F8443E5AAD14-8076 SFD [x]
1375744 - Secure Onboard Communication
U14FE 00 [00101000] - Signature Verification Failed
Fault Frequency: 26
Reset counter: 33
Date: 2026.08.22
Time: 08:14:15
Address 7E: Ctrl Head Dash (J1254) Labels:| 10A-920-320.clb
Part No SW: 10A 920 320 C HW: 10A 920 320
Component: FAHRERDISPLAY 009 0531
Serial number: 9M1X0968-856729
Coding: E670
ASAM Dataset: EV_DashBoardLGMEB 001027
ROD: EV_DashBoardLGMEB_001_VWE3.rod
Address 8C: HV Battery (J840) Labels: 0Z1-915-184.clb
Part No SW: 0Z1 915 184 J HW: 0Z1 915 184 D
Component: J840 K8C BMC 007 1041
Serial number: 000000220520160 Dataset Number: V03935382CA 0001 CVN: 9534C8BD00000000000000000000000000000000
ASAM Dataset: EV_BMCeVWBSMEB 002015
ROD: EV_BMCeVWBSMEB_002_VWE3.rod
VCID: 41DC4C936105DEB2A8E-8014
Cell module control module 1:
Subsystem 1 - Part No SW: 0Z1 915 140 BE HW: 0Z1 915 140 BC
Component: SX6 X74 CMC 005 1000
Serial number: 00000028052018020518
Cell module control module 5:
Subsystem 2 - Part No SW: 0Z1 915 140 F HW: 0Z1 915 140 D
Serial number: 00000030042018010055
Cell module control module 9:
Subsystem 3 - Part No SW: 0Z1 915 140 F HW: 0Z1 915 140 D
Serial number: 00000030042018020056
Coolant heating:
Subsystem 4 - Part No SW: 1EA 963 231 HW: 1EA 963 231
Component: J848 HV-PTC H03 0500
Serial number: CD193573014402000145
42532 - HV Battery System
U163F 00 [00101110] - No Communication with Application Server
[Diag_C_EVCAN_ORU_01_TO]
Fault Frequency: 127
Mileage: 42541 km
Date: 2026.05.20
Time: 15:47:07
Mode HV battery actual value: Driving mode
Voltage terminal 30: 13.620 V
H-V battery voltage: 392.500 V
Current of H-V / hybrid battery: -40 °C
Current of H-V / hybrid battery: -5.320 A
Current 2 of H-V / hybrid battery: -5.560 A
maximum voltage for battery cells-Index 1: 0
maximum voltage for battery cells-Value: 3.644 V
minimum voltage for battery cells-Index 1: 0
minimum voltage for battery cells-Value: 3.630 V
Address A5: Frt Sens. Drv. Assist (R242) Labels:* 1EA-980-65X-V1.clb
Part No SW: 1EA 980 654 L HW: 1EA 980 654
Component: MEB MFK 4.1 H02 5332
Dataset Number: V03935361MN 0001
Coding: 0008302E151110F4162420000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK41ValeoMEB 001057
ROD: EV_MFK41ValeoMEB.rod
1124716 - Internal Fault
B200F F0 [00101000] - -
[SPI_communication_to_PMIC_error]
Mileage: 327757 km
Date: 2000.01.13
Time: 18:11:38
Address C0: Act. for Ext. Noise (J943) Labels: 1EA-035-335.clb
Part No SW: 10A 035 335 C HW: 1EA 035 335
Component: E_SOUND_SG H05 0006
Serial number: JTK072040620812
ASAM Dataset: EV_ESoundMEBHarma 004011
ROD: EV_ESoundMEBHarma_004_VWE3.rod
VCID: 186AC1F7521FBF7A3F0-804C
Address C6: Batt. Chrg. (J1050) Labels:| 1EA-915-684.clb
Part No SW: 1EA 915 684 FG HW: 1EA 915 684 AD
Component: HV_CHARGER H51 2023
Serial number: 92832TDQ0001M
Coding: 1080
ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002019
ROD: EV_OCCXPhase1KLOMEB01B.rod
VCID: 0554988335AD3292D46-8050
3280899 - Charging Station
B1AD0 F0 [01101101] - Identification Failed
[ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
Mileage: 43816 km
Date: 2026.08.24
Time: 05:49:25
DID 1DA0: AC main charge
DID 1DAC: Charging
Frequency: 1000 Hz
Control voltage: 5863.0 mV
Pulse duty factor: 26.2 %
Activation charge cover lock charge socket A: not requested
Lock for high-voltage charging connector: locked
Status connect. recognition: detected
Charging socket temperature sensor AC: 30.0 °C
Temperature sensor 1: resistance value: 1075 Ohm
DID 15E2: 24.0 °C
DID 081C: 3377 W
DID 081D: 3560 W
DID 081E: 3477 W
DID 0286: 13.4 V
DID 497C: not active
DID 537A: 14.2 V
DID 1525: 3229 mV
DID 4219: high-voltage de-energization not detected
DID 5372: 24.0 °C
No. of lockings: 1389
No. of connections: 190
Number of successful charging connector locks: 632
Wake-up counter: contact (proximity): 0
Wake-up counter: Control Pilot: 0
Charging standard abort: status: not active
Loading plan: status: Not available
Price/performance table: status: Not available
Transport Layer Security (TLS) status communication: not active
DID 103A: supported
number_evse_slac: 0
PLC_modem_status: active
number_slac_attemps: 1
DID 1033: SLAC_active
DID 1038: no_description
DID 1039: supported
Target HV charge current: 25.6 A
Powerline communication: charging process status: Standby
Part No SW: 992 941 572 AE HW: 992 941 572 A
Component: LED1L H08 9202
Dataset Number: V03935336SE 0001
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 6696BF0F28EBD98A7DC-8032
Component: LED1R H08 9202
Dataset Number: V03935336SL 0001
Address 8105: DC/DC Converter 12V (A19) Labels: 1EA-907-190-V1.clb
Part No SW: 1EA 907 190 K HW: 1EA 907 190 B
Component: DCDC Gen4H11 1144
Revision: 00H11000
ASAM Dataset: EV_DCDC10030111EA907190K 001023
ROD: EV_DCDC10030111EA907190K.rod
VCID: 3C223D6706E7B35AFB8-8068
Address 8107: Antenna (J666) Labels:* None
Part No SW: 1EA 035 741 P HW: 1EA 035 741 D
Component: TrxModulHigh H07 0257
Serial number: 0000000210VILZ9 Dataset Number: V03935359JW 0001
Coding: 023100110402C0
ASAM Dataset: EV_TrxMLGEMEB 006014
ROD: EV_TrxMLGEMEB.rod
VCID: 3B203E7B03E9B462F22-806E SFD [x]
Address 811E: Burglary Protection FL (J518) Labels: 5WA-962-133.clb
Part No SW: 5WA 962 133 D HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002_VW38.rod
VCID: 49CC54B3593516F270E-801C
Address 811F: Burglary Protection FR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: 5WA-962-133.clb
ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4) Labels: V04-007-XXX-SWC4.clb
Part No: V04 007 006 RS
Component: ICAS1 Sys_Ada 0329
Dataset Number: V03935361TL 0001
ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
ROD: EV_AppServe1Syste1ICAS1.rod
VCID: 0C42ADA716C743DA8B8-8058 SFD [x]
Address 8124: App server 1 system 2 Java (SWC5) Labels: V04-007-XXX-SWC5.clb
Part No: V04 007 006 RT
Component: ICAS1 Sys_Jav 0329
ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
ROD: EV_AppServe1Syste2ICAS1.rod
VCID: 0D44A0A36DDD4AD29C6-8058 SFD [x]
Address 8125: App server 3 system 1 infotaint. (SWC6) Labels:| V04-007-XXX-SWC6.clb
Part No: V04 007 000 AC
Component: IC3-IVI-D-EU 1771
Dataset Number: V03935389XR 0001
ASAM Dataset: EV_MUICASIVIPart 002007
ROD: EV_MUICASIVIPart_002_VWE3.rod
VCID: 6594B803D5EDD292746-8030 SFD [x]
1659 - Data Set Implausible
B2012 00 [00001001] - -
[Control module (data record download) - implausible data record]
Mileage: 43794 km
Date: 2026.08.20
Time: 11:23:27
Voltage terminal 30: 14.1 V
data_set_valid: Yes
data_set_plausible: No
data_set_used_by_application: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_plausible: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_used_by_application: No
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: Yes
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
data_set_valid: No
Address 8128: Light line display (J145) Labels: 10B-919-451.clb
Part No SW: 10B 919 451 C HW: 10B 919 451
Component: Lichtlinie1 003 0107
ASAM Dataset: EV_SmartLight1MEB 002001
ROD: EV_SmartLight1MEB_002_VWE3.rod
VCID: 2310E61B9B59ECA2DA2-8076
Address C002: SW Cluster Embedded (SWC2) Labels: V04-007-XXX-SWC2.clb
Part No: V04 007 006 SA
Component: ICAS1 SWCL_Em 0329
Dataset Number: V03935362KU 0001
ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
ROD: EV_SWCLEmbed1ICAS1.rod
VCID: 7BA0FE7B43697462B22-802E SFD [x]
7467527 - Data Set Implausible
B2012 00 [00101111] - -
[Data_set_implausible_ECP]
Fault Frequency: 65
8491267 - Secure Onboard Communication
U14FF 00 [01101100] - Signature Generation Failed
[SOK_signature_creation_failed]
Mileage: 43893 km
Date: 2026.09.02
Time: 10:24:00
Address C003: SW Cluster Housekeeping (SWC3) Labels: V04-007-XXX-SWC3.clb
Part No: V04 007 006 SB
Component: ICAS1 SWCL_HK 0329
ASAM Dataset: EV_SWCLHouse1ICAS1 005001
ROD: EV_SWCLHouse1ICAS1.rod
VCID: 7CA2FD674667735ABB8-8028 SFD [x]
End----------(Elapsed Time: 02:03, VBatt start/end: 13.9V/14.0V)-----------
------------------------------16 Faults Found------------------------------
thank you.
