‘15 Passat TDI; replaced 2 defroster flap motors, cannot get working.
Chumpy
N Texas, USA
C?ID=65821
I know I have other issues, new O2 sensor coming, but the defrost comes first, no A/C out center console vents. This was my starting auto-scan:
Monday,31,August,2026,16:50:17:53968
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.4
VIN: 1VWCV7A36FC061924 License Plate: 5YJYL
Mileage: 350350km-217697mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 75 77
VIN: 1VWCV7A36FC061924 Mileage: 350350km-217697miles
37-Navigation -- Status: Cannot be reached 1100
Address 01: Engine (J623-CVCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 AF HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9289
Revision: 8AH20--- CVN: 170F16E738D3FF82
Coding: 011D0012032410089000
Shop #: WSC 25169 444 00000
ASAM Dataset: EV_ECM20TDI01104L906016AF 004017
ROD: EV_ECM20TDI01104L906016AE_004.rod
VCID: 6D87D92A6D1CD362145-8038
VINID: 0669D39874431964C018124210F88B0ABD
18111 - Oxygen (Lambda) Sensor B1 S1
P2237 00 [11101101] - Pump Current Open Circuit
Mileage: 350281 km
Date: 2026.08.31.
Time: 21:07:37
Engine speed: 1427.00 /min
Vehicle speed: 53 km/h
Coolant temperature: 77 C
Intake air temperature: 109 C
Voltage terminal 30: 13.680 V
Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 14
Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 6
O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
Oxygen sensor bank 1 before oxi cat: heater activation: 34.634 %
O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value: 0.7715 V
Oxygen sensor bank 1 before oxi cat: adjustable resistor: 84.8 Ohm
Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0437
Readiness: 1 1 0 0 0
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6  531 4518
Revision: 05653104 Serial number: 00001410270974
Shop #: WSC 09003 957 00200
VCID: 2517E10AF9EC2B229C5-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Reset counter: 37
Mileage: 350294 km
Date: 2021.01.21.
Time: 23:17:27
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492800FBA31403E6921D0042A1100012
VCID: 04519C8E5E16322AEBB-8050
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0344075501 Dataset Number: 560116v____ 0002
Coding: 130C0C
ROD: EV_KESSYPQ35G_A02_VW41.rod
VCID: 372B3B425FC0A9B23E9-8062
Part No SW: 561 907 044 AR HW: 561 907 044 AR
Component: Climatronic H03 0808
Revision: 00001K01
Coding: 0050019012
VCID: 678BAB024FE0F9326E9-8032
9474161 - Motor for Defroster Flap
B1090 71 [00001000] - Actuator Stuck
Reset counter: 234
Mileage: 347320 km
Date: 2026.08.20.
Time: 00:57:12
9474162 - Motor for Defroster Flap
B1090 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 114
Mileage: 273473 km
Date: 2024.04.27.
Time: 00:52:27
9672723 - Heated Seat; Front Left
B1398 13 [00001001] - Open Circuit
Reset counter: 75
Mileage: 284832 km
Date: 2024.08.23.
Time: 18:32:34
Part No SW: 5K0 937 087 AE HW: 5K0 937 087 AE
Component: BCM PQ35 H+  122 0174
Revision: BL122001
Coding: EF200E1B882B2AD4098802013600854800F1A08645A005B064806000BC70
Shop #: WSC 17515 002 1048576
VCID: 78A9F87E12DE66CAF73-802C
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 291014 05 54 0403
Coding: 02300A
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 27
Mileage: 311567 km
Date: 2019.10.18.
Time: 22:59:21
Voltage: 14.40 V
03189 - Bulb for Side Marker Light; Front Right
Fault Status: 00101010
Reset counter: 15
Mileage: 273473 km
Date: 2018.09.18.
Time: 22:32:21
Voltage: 11.70 V
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10  500 0975
Serial number: 003LZD04DCV3 Dataset Number: 560003v__A_ 0112
Coding: 00004D35
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 72BDCA5674220C9AC97-8026
Seat occupant detection:
Serial number: 6940000Y1400019X4E0X
Coding: 303047
Serial number: 3572MSME24417D49ZZZ.
Serial number: 3582MSME542D7E49ZZZ9
Serial number: 3516KSME356E4932ZZZZ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME751D4F32ZZZ/
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME3A0E1032ZZZR
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME40341032ZZZC
9440027 - Driver's side; side-airbag igniter
B100B 1B [10001000] - Resistance Too High
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:08
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [10001000] - Resistance Too High
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:08
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [10001001] - Open or Short to Ground
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:07
9444885 - Driver's seat position sensor
B101E 15 [10001000] - Open or Short to Plus
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:07
9445141 - Passenger's seat position sensor
B101F 15 [10001000] - Open or Short to Plus
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:07
Part No SW: 1K5 953 521 BR HW: 5K0 953 569 AH
Component: LENKS.MODUL  016 0140
Revision: FF010042 Serial number: 20141031200729
Coding: 000A140000
ROD: EV_SMLSNGVOLWSXS.rod
VCID: 7EA5EE66307A58FABDF-802A
Component: E221__MFL-8LP H07 0023
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H05 0813
Coding: 231E01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 1E65CEE6D03AF8FADDF-804A
Part No SW: 7N0 907 530 AR HW: 7N0 907 530 AM
Component: J533 Gateway H55 1653
Revision: H55 Serial number: 11121403000603
Coding: 461000
VCID: 0059909E4A0E2E0ACF3-8054
Reset counter: 108
01304 - Radio
Reset counter: 17
Component: IMMO H05 0813
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
VCID: 6A8DD2365CF2C45A717-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000331858005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X_VW41.rod
VCID: 3039005EBAAE7E8A7F3-8064
Address 2E: Media Player 3
Address 36: Seat Mem. Drvr (J136) Labels: 561-959-760.clb
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0182
Revision: AA000000 Serial number: 00000126940664
Coding: 00581B0000000000000021010100202020202120202020
VCID: 221DFA16E4C2DC1AF97-8076
Address 37: Navigation
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT  002 0525
Revision: 12110009 Serial number: 0009190540
Coding: 0405FD
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1C61C4EEC626EAEA33B-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL  006 5470
Serial number: 14102630141212200423
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 215 3501
Revision: 00H22000
VCID: 392F3D7A6554BFC2C8D-806C
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0015605 Dataset Number: 560050v____ 0007
ROD: EV_AudioVerst10KanalSTT3_VW41.rod
VCID: 2809E83E827E364AA73-807C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1653
Coding: 01030108
VCID: 6FBBC32267902172269-803A
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011416401271
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr  009 0005
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT  002 0525
Revision: 14110009 Serial number: 0009180688
Coding: 0405FC
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D67C9EADD3CE3E2C45-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR  006 5470
Serial number: 14202631141211180318
Coding: 800000
131584 - Motor for Rear Window Regulator
B11EE 54 [00001000] - Missing Calibration / Basic Setting
Reset counter: 242
Address 56: Radio
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA  020 0156
Serial number: 000003554140531 Dataset Number: 561098V____ 0017
Coding: 02140102C24232007F1606000000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002_VW41.rod
VCID: 1471ACCE2EF6A2AA7BB-8040
0036 - Databus
[CAN TO GPS data]
Reset counter: 233
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:12
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666870250 Dataset Number: 5N0035729E 0001
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 323D0A56B4A24C9A097-8066
B104F 13 [00001001] - Short to GND
Reset counter: 108
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:53:28
B104E 13 [00001001] - Short to GND
Reset counter: 108
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:53:28
End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
------------------------------18 Faults Found------------------------------
Address 0x08,561 907 044 AR,UDS Basic Settings,IDE01546-Adapt door end stops
This is
Address 08: DTCs cleared
I have tried Basic Settings-adapt door end stops and could hear the motor(s?) working. I then cleared the faults in HVAC module. This is the immediate autoscan.
Monday,31,August,2026,18:02:35:53968
52 56 62 72 75 77
Mileage: 350281 km
Date: 2026.08.31.
Time: 21:07:37
Reset counter: 37
Mileage: 350294 km
Date: 2021.01.21.
Time: 23:17:27
Revision: 00H46001
Coding: 130C0C
Revision: 00001K01
Coding: 0050019012
9474418 - Motor for Front Air Distribution Flap
B1091 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 233
Mileage: 350351 km
Date: 2026.08.31.
Time: 04:55:46
Revision: BL122001
Coding: 02300A
Reset counter: 27
Mileage: 311567 km
Date: 2019.10.18.
Time: 22:59:21
Voltage: 14.40 V
Reset counter: 15
Mileage: 273473 km
Date: 2018.09.18.
Time: 22:32:21
Voltage: 11.70 V
Coding: 00004D35
Coding: 303047
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:08
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:08
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:07
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:07
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:07
Coding: 000A140000
Coding: E20000
Coding: 231E01
Coding: 461000
Reset counter: 108
01304 - Radio
Reset counter: 17
Coding: 000007
Coding: 0405FD
Slave Driver:
Coding: 800000
Revision: 00H22000
Coding: 01030108
Coding: 181100
Coding: 0405FC
Slave Passenger:
Coding: 800000
Reset counter: 242
Address 56: Radio
0036 - Databus
[CAN TO GPS data]
Reset counter: 233
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:00:12
ROD: EV_UHVUMI.rod
Reset counter: 108
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:53:28
Reset counter: 108
Mileage: 341835 km
Date: 2026.05.26.
Time: 00:53:28
End----(Elapsed Time: 01:19, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
------------------------------16 Faults Found------------------------------
HELP?!?
All the best,
Diez
DrPeter
16.4905° S, 151.7375° W
Hi there...
So Silly question, after you cleared the fault codes, did you again try the Basic Settings for the flaps? or did you just perform the Auto-Scan and post it here?
You may want to perform the Basic Settings again and this time first press the [Show Measuring Data] button, then select the 'flaps' values and then press Go to activate the Basic Settings.
If you see any 'stuck' value(s(, you may have a faulty flap motor(s).
We recommend the official repair information from the manufacture, Official Factory Repair Information
Hope this helps,
drpeter
Chumpy
N Texas, USA
C?ID=65821
Hi there...
Hope this helps,
drpeter
Thank you. Will give it a whirl in am.
