Incorrect vin Audi A4 B9
Sydney VAG
Australia
Hi All 👋🏼
Could I please get some advice and guidance. I brought this car off a wrecker complete with all faults. Car starts and drives after an accident but can’t go back on the road until all faults are sorted
I thought I’d start with the steering combination switch. The one they put in car was wrong part number. I’ve replaced with correct part. I need help to program this to the car please. When I went into the steering wheel the option to code was blanked out. I don’t know what has been replaced so thought I’d start with the steering sensor
All advice greatly appreciated
Regards
VIN: WAUZZZF44JA099118 License Plate:
Chassis Type: F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 29 39 42 44 46 52 5F 6C 81 A5 BB
BC CA D6 D7
VIN: WAUZZZF44JA099118 Mileage: 55122km-34251miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (MA----CVKB) Labels:. 06K-907-309-V2.clb
Part No SW: 8W0 907 115 K HW: 06L 907 309 A
Component: 2.0 R4 TFSI H41 0003
Revision: S1H41--- CVN: A52E9BC7
Coding: 0A2500132324050334280000000000000000000000000000
Shop #: WSC 19100 006 1048576
ASAM Dataset: EV_ECM20TFS0118W0907115K 001004
ROD: EV_ECM20TFS0118W0907115K.rod
VCID: 41CA62FBD002CA978C-8014
VINID: 9D196AAAA58411A440249041209A83923C
17158 - Databus
U1123 00 [00100111] - Received Error Message
Date: 2047.15.31
Time: 31:63:63
Engine speed: 994.00 /min
Normed load value: 12.9 %
Coolant temperature: 95 C
Intake air temperature: 70 C
Voltage terminal 30: 11.320 V
Engine status: COENG_RUNNING
23476 - Implausible Data Received from Steering Column Control Module
U0429 00 [00100110] - -
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
Engine speed: 760.50 /min
Normed load value: 14.9 %
Coolant temperature: 98 C
Intake air temperature: 53 C
Voltage terminal 30: 13.960 V
Com st X Set1 Val1-Bits 0-7: 0
Com st X Set1 Val2-Bits 0-7: 0
Com st X Set1 Val3-Bits 0-7: 0
Com st X Set1 Val4-Bits 0-7: 0
Com st X Set1 Val5-Bits 0-7: 0
Com st X Set1 Val6-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 1
26521 - Lane change assistant control module
U1045 00 [00100111] - No communication
[Lane change assistance control moduleNo communication]
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
Com st X Set2 Val1-Bits 0-7: 32
Com st X Set2 Val1-Bits 0-7: 0
Com st X Set2 Val2-Bits 0-7: 0
Com st X Set2 Val2-Bits 0-7: 192
Com st X Set2 Val3-Bits 0-7: 0
Com st X Set2 Val4-Bits 0-7: 0
Com st X Set2 Val5-Bits 0-7: 0
Com st X Set2 Val6-Bits 0-7: 0
Com st X Set2 Val7-Bits 0-7: 1
Com st X Set2 Val7-Bits 0-7: 0
Readiness: 1110 0001
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 AF HW: 0CJ 927 156
Component: 0CK 20TFSIRdW H05 0002
Revision: --H05--- Serial number: 0000002355 CVN: 305D7488
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 0542B6EB84AA26B7F0-8050
MTF pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041170310001319
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Dataset Number: 8W0909504M 0007 CVN: 18E61C2C
Coding: 08AA089910AB0A9F119F489200855292E4A5DA101008508812004A4927A55B
Shop #: WSC 06324 790 00001
ROD: EV_ESP9BOSCHCMP_004_AU49.rod
VCID: 4DD24ECB1C5A1EF778-8018
451328 - Databus
U1121 00 [00101111] - Missing Message
[ComScl:_Signal_Group_SG_RCTA_01_-_Timeout_error]
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
8F C0 82 00 CA 00 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
6293504 - Steering Angle Sensor
C2008 00 [00101110] - Signal Qualification
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
6293505 - Steering Angle Sensor
C2008 00 [10101111] - Signal Qualification
Mileage: 55122 km
Date: 2026.08.28
Time: 00:00:14
80 C0 82 00 CA 00 00 00 00 00
13636611 - Control Module Incorrectly Coded
U1014 00 [10101111] - -
[Variant_Plausibility_fault_for_the_DSR_with_NET_data]
Fault Frequency: 13
Mileage: 55122 km
Date: 2025.01.29
Time: 01:00:38
77 00 82 00 C2 00 00 00 00 00
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0210
Coding: 140805885544040D10000100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44C46BEFCF10DFBFA7-8010
Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000001932592
Humidity sensor: exterior:
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 8AE097D800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
262914 - High Pressure Sensor
B10AE 21 [00001001] - Signal Amplitude Too Low
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:39
Outside temperature: 36.00 C
Engine speed: 758 /min
Compressor current: actual value: 0.00 A
Temperature downstream of evaporator: 34.30 C
Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Dataset Number: 8W0909514L 0048
Coding: 07501143E11800CD051551181B2800F9110B3108000000000000000020001A810A450122025705
Shop #: WSC 00046 000 00000
VCID: 0248ADF79584118FD5-8056
Subsystem 1 - Part No SW: 8W2 955 119 HW: 8V2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS491 171016 043 0813
Serial number: 89425300301728900490
Coding: 5BC7F7
Serial number: 21878928X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 18 08 2017  01094683
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE104021924210760
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AF HW: 4K0 947 135 AF
Component: Dachmodul H42 0415
Serial number: B01168341
Coding: 010104
Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000167215003
65915 - Databus
[Side assist control module: no signal/communication]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
average_Voltage_terminals: 14.30 V
Outside air temperature sensor-Outside air temperature on CAN: 35.00 C
interior_temperature: 31.00 C
Vehicle speed: 0.00 km/h
131945 - Databus
[EPS control module: received error value in signal EPS_steering-rack_pos]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
Outside air temperature sensor-Outside air temperature on CAN: 35.50 C
196758 - Databus
[Brake control module: received error value in signal ESP system status]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
average_Voltage_terminals: 14.20 V
196761 - Databus
[Power steering control module: received error value in signal EPS steering rack position]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
Address 15: Airbags (J234) Labels:| 8W0-959-655-V1.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00A2K37 Dataset Number: 8W0909602AH 0007
Coding: AAFCF0C00C80000058540033D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006.rod
VCID: 4CD443CFE74017FF6F-8018
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2040
Serial number: 8W0857705F0149T00831
Coding: 88001B
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2040
Serial number: 8W0857706G0150T00710
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 062 210 17
Serial number: 3577Y00B326068A4931X
Subsystem 4 - Part No SW: ----------- HW: 442 062 210 17
Serial number: 3587Y00B126068A3103M
Subsystem 5 - Part No SW: ----------- HW: 442 0B1 910 17
Serial number: 35177009B279C264A37J
Subsystem 6 - Part No SW: ----------- HW: 442 0B1 910 17
Serial number: 35277009B279C26472BK
Subsystem 7 - Part No SW: ----------- HW: 442 0C1 707 18
Component: FrontSensor_D 1C5 014A
Serial number: 3557500A72AC0994D06L
Subsystem 8 - Part No SW: ----------- HW: 442 0C1 707 18
Component: FrontSensor_P 1C5 014A
Serial number: 3567500A72AC0990D16J
Subsystem 9 - Part No SW: ----------- HW: 442 0C1 607 18
Component: PedP_Sensor_C 1C5 014A
Serial number: 23075009F29F7DC2D0D+
Subsystem 10 - Part No SW: ----------- HW: 442 430 807 18
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00BD27DBDE2C467
Subsystem 11 - Part No SW: ----------- HW: 442 430 807 18
Component: PedPSensor_P2 256 0887
Serial number: I0N9M00BD27DBDE2C435
B13BC F2 [10001001] - No function
Reset counter: 67
Mileage: 55121 km
Date: 2023.03.04
Time: 02:16:18
1050624 - Databus
[NWD: 0x322 PCR_01 Timeout]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
1050117 - Databus
[NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
Reset counter: 107
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1056768 - Databus
[NWD: 0x17F PCR_02 Timeout]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
1061893 - Databus
[NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1062656 - Databus
[NWD: 0x189 SWA_Header Timeout]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:36
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76A0C127C94C3D2FE9-8022
5648384 - Control Module
C104A F0 [00001001] - Incorrect VIN
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:01:54
Freeze_Frame_VIN_Plausi_Errors-Vehicle_Speed_FL: 0.00 km/h
Freeze_Frame_VIN_Plausi_Errors-VIN11: 00
Freeze_Frame_VIN_Plausi_Errors-VIN12: 00
Freeze_Frame_VIN_Plausi_Errors-VIN13: 00
Freeze_Frame_VIN_Plausi_Errors-VIN14: 00
Freeze_Frame_VIN_Plausi_Errors-VIN15: 00
Freeze_Frame_VIN_Plausi_Errors-VIN16: 00
Freeze_Frame_VIN_Plausi_Errors-VIN17: 00
Freeze_Frame_VIN_Plausi_Errors-Voltage_12V: 13150.78 mV
Freeze_Frame_VIN_Plausi_Errors-VZ_Vehicle_Speed_VL: 00
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 8W5 920 770 C HW: 8W5 920 770 C
Component: MMA4T18BENRW H13 0512
Revision: 0512v3.0 Serial number: 81YC6S6BT
Coding: 25A450C0288000080120E9601000000000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 40CC67FFDB08C39F83-8014
Part No SW: 4M1 907 468 F HW: 4M1 907 468 E
Component: Gateway H22 0123
Revision: 7K010001 Serial number: 0147K00C217B03 Dataset Number: 8W0909515J 0059
Coding: 03010001000086402907000000590012CC180007100000000100000000000000
GVL: 01503C0000000000408C08000002C80010080000000000000000000000000000
ASAM Dataset: EV_GatewCONTIAU736 003111
VCID: 3A381517BDD4994FCD-806E
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170922214220 22339
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 5612845704
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AC HW: 4M0 907 397 C
Component: LCM_MLBevoH05 0024
Dataset Number: 8W0909519B 0010
ROD: EV_LCMLeftHELLAAU736_AU37.rod
VCID: 78BCCF1FC3584B5FFB-802C
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Dataset Number: 8W0909520B 0010
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS  005 0125
Serial number: 0000287847389 Dataset Number: 8W0909872E 0029
Coding: 001D1B2141010080000010A0
Shop #: WSC 06325 790 00001
ROD: EV_DCU2DriveSideMAXHCONT_VW41.rod
VCID: 43C668F3CA1ED8879E-8016
Address 44: Steering Assist (J500) Labels:| 8W0-909-144-V1.clb
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 00000000000000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42C86DF7D504D18F95-8016
27136 - Databus
[KFC_LWI_01_SNA]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:34
Expanded ambient data 1-Engine is running: Engine_Running_Stable
Expanded ambient data 1-Supply voltage: 0.00 V
Expanded ambient data 1-Temperature: -70 C
Expanded ambient data 1-System status: 5
Expanded ambient data 1: 00
Expanded ambient data 1-driving_direction: 0
Expanded ambient data 1-KFA: 0
Expanded ambient data 1-KFC: 106
Expanded ambient data 1-Ready_To_Drive_Bit: 0
Expanded ambient data 1-StartStop Info: 0
Expanded ambient data 1-Steering_Angle_Calculated: 0
Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
Expanded ambient data 1-Steering_torque: 0.00 Nm
Expanded ambient data 1-Steering_Torque_Sign: 1
Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
Expanded ambient data 15-MsgStateFifo_Byte1: FF FF FF FF
Expanded ambient data 15-MsgStateFifo_Byte2: FF FF FF FF
Expanded ambient data 15-MsgStateFifo_Byte3: FF FF FF FF
Expanded ambient data 15-NumOfMsgCntFaults: 00
Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
Expanded ambient data 15-NumOfMsgNoFaults_3: 00
Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
18432 - invalid data record
B2005 00 [00001001] - -
[KFC_DDL]
Reset counter: 67
Mileage: 55122 km
Expanded ambient data 1-Engine is running: Engine_not_running
Expanded ambient data 1-System status: 3
Expanded ambient data 1-KFC: 72
Expanded ambient data 1-Steering_Torque_Sign: 0
Expanded ambient data 14-KFA_FAST_RESET: 0
Expanded ambient data 14-KFC_FAST_RESET: 0
Expanded ambient data 14-Register_seg_flag: 0
Expanded ambient data 14-Rom_ram_ecc_adr_1: 0
Expanded ambient data 14-Rom_ram_ecc_eipc: 0
Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 12.33 V
Expanded ambient data 14-Voltage_terminal_30_unfiltered: 12.42 V
Part No SW: 8W0 907 064 EC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 025 0387
Dataset Number: 8W0909501J 0052
Coding: 0135000000200080630180002E00000031024010804B02502F0400000104803F001F0001000000
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 014AA2FB90820A97CC-8054
Power rear lid opening control module:
Subsystem 1 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: >1179001
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS  005 0125
Serial number: 0000287108686 Dataset Number: 8W0909873E 0029
ROD: EV_DCU2PasseSideMAXHCONT_VW41.rod
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 8W0 035 192 H HW: 8W0 035 192 A
Component: MU-HS-LND-EU 050 0213
Serial number: Dataset Number: 8W0909545AC 0044
Coding: 01940108FF00000013511101000A00102F0001E601F00104CE
ROD: EV_MUHigScl6C3DELP.rod
VCID: 3B361013B2EEA047D6-806E
Subsystem 1 - Part No SW: 8W0 919 866 AD HW: -----------
Component: ROW 2018 --- 0018
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8W2 919 604 HW: 8W2 919 604
Component: AU49x_DU_STD H40 0008
Serial number: AUZ8Z9HBH0159W
Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK101111700040546
B201A 00 [00001000] - -
Reset counter: 107
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
Voltage terminal 30: 14.4 V
Status_Software_Version_Management-module_name: C
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Dataset Number: 8W0909460B 0010
Coding: 0294010102002001400040
ROD: EV_CamSysRVRVCPANAMLBEv_005.rod
VCID: 332638339ABE68070E-8066
13705996 - Databus
[Errorvalue-monitoring LH_EPS_04.EPS_Zahnstangen_Pos]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
passive
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 G HW: 8W2 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 17102344559629
ROD: EV_GSMWaehlZFAU736.rod
VCID: 383C0F1F83D88B5F3B-806C
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W0 907 217 D HW: 8W0 907 217 C
Component: BVS H18 0052
Dataset Number: 8W0909466F 0035
Coding: 0404090200000403024023A4C50000FCA0F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
VCID: 3D321E0BACFAAE77E8-8068
14 Faults Found:
1122561 - Databus
[TIMEOUT_ACC_10]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
Control Module temperature: 53 C
Voltage terminal 15: 14.40 V
1122632 - Databus
[TIMEOUT_APS_Master]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
Control Module temperature: 52 C
1123080 - Databus
[LWI_01_LWI_QBit_Lenkradwinkel]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1123714 - Databus
[Airbag_01_AB_Systemfehler]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:39
1123157 - Databus
[LH_EPS_03_EPS_Berechneter_LW]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1123159 - Databus
[LH_EPS_04_EPS_Zahnstangen_Pos]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1123186 - Databus
[LWI_01_LWI_Lenkradwinkel]
Reset counter: 107
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
1123188 - Databus
[LWI_01_LWI_Lenkradw_Geschw]
Reset counter: 107
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
0657 - invalid data record
[Dataset_invalid]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:34
0659 - Steering
C10AC F2 [00001001] - Lane-Holding Assistance Not Coded
[HC_interface_at_the_steering_not_activated]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
4195334 - Steering
C10AC F4 [00001001] - Traffic Jam Assistance Not Coded
[STA_deactivated]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:35
0660 - No Basic Setting
B2010 00 [00001001] - -
[Initial_calibration_missing]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:34
1123907 - Internal Fault
B200F F5 [00001001] - -
[Rectification_initial]
Reset counter: 67
Mileage: 55122 km
Date: 2026.08.28
Time: 00:42:34
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 4M0 959 795 H HW: 4M0 959 795 F
Component: TSG HFS  005 0125
Serial number: 0000287537687 Dataset Number: 8W0909897E 0029
Coding: 000D192000010080000010A0
ROD: EV_DCU2RearDriveMAXHCONT_VW41.rod
VCID: 45C276EBC42AE6B7B0-8010
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS  005 0125
Serial number: 0000287537652 Dataset Number: 8W0909896E 0029
ROD: EV_DCU2RearPasseMAXHCONT_VW41.rod
Part No SW: 4M0 907 594 H HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Dataset Number: 8W0909469D 0009
Coding: 7A8000049100
ROD: EV_SunRoofCONTIAU736_006_VW37.rod
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
Dataset Number: 8W0909471C 0008
VCID: 1660E1A7E90C9D2F09-8042
Component: LED1R H09 0003
Dataset Number: 8W0909472C 0008
End----------(Elapsed Time: 01:51, VBatt start/
Jef
HQ
Please don't edit the Auto-Scan. :mad:
I'm not sure what is up with Address 16: Steering wheel (J527), for now, my guess is it is fine, but getting wonky data from some other module(s) and is confused.
Address 44: Steering Assist (J500), this has a 18432 - invalid data record B2005 fault code. Generally that means a trip to the dealer so that the factory scan tool, ODIS, can do something of a firmware flash. By chance, was the J500 replaced on this car? Address 15: Airbags (J234) has 9682162 - Multiple collision brake B13BC that we've seen due to unplanned off road adventures and damages the J500.
There are lot of "Databus" type fault codes... in general, this is due to some module not putting data on the network than another module is expecting. With the B2005 in the J500, I'd get that sorted out sooner and see if things start to fall into place.
Side note... if the J500 was replaced and with a used unit.... good luck with that. :eek:
Sydney VAG
Australia
Thank you very much for your response. I just talked to the guy I purchased from, he says steering rack was not replaced, just left front suspension however he says airbag module was replaced, perhaps it’s this that needs coding ?
Jef
HQ
The airbag overall looks to be happy with itself, but does have several "Databus" codes... so it is unhappy due to bad or missing information from other control modules. I would still get the J500 sorted out first... from an American point of view, that J500 is worse than Vegemite. :p
