Low Boost pressure 2013 Passat TDI
pike
C?ID=264790
2013 VW Passat TDI SE-1 owner
164k on the odometer
>35k on the turbo
1400 miles since regen
Started with a Particulate filter code and before I could fix that code the malfunction light of the flashing coil, Installed another particulate filter and that code left. Had a transmission code and it left with the filter.
Installed a new map sensor, Boost controller and checked line for leaks. Checked the actuator for the waste gate and it moved and held vacuum. Removed the intercooler and cleaned it as it was pretty dirty.
Under engine-basics did a turbo test, engine ran at 1400rpms and finished correctly as did the adaptation of the turbo.
could not get a copy of the read out to paste in so here are the 2 codes
5171-Boost pressure Regulation
PO299 00 [01101101]-control range not reached
Engine speed: 2028.00/min
normal load value: 65.5%
Vehicle speed: 66km/h
coolant temp:52C
Intake air temp: 35C
Voltage terminal 30: 13.7 volts
unlearning counter according to OBD: 40
Charge air pressure: specified value: 2004 hPa
Charge air pressure actual value: 1480 hPa
Air mass: actual value:(mg/stroke): 916.3 mg/stroke
EGR Solen. val,: actual value 99.58%
Throttle valve adapter: actual value 23.77
Charge air pressure actuator: acknowledgment: 98.16
Mean injection quantity: 37.17 mg/stroke
12896-boost pressure regulation
P0299 00-control range not reached
MIL ON
rest is the same as above.
Start the car and it has nothing lit up. Runs great for about a half mile and the malfunction light comes on and sometime the engine light. Shut it off and re-start and it runs great for about a half mile. Have borescope both sides of the turbo, zero damage to blades, alot of soot on exhaust side. removed the plastic fitting so I could get a finger into the intake side and was able to spin the turbo and it had a smooth rotation.
Rick
S.E. Tenn.
Vdub
C?ID=57533
Did you learn/adapt the new filter?
I would say a blocked DPF, new or not.
pike
C?ID=264790
Have gone in, gotten security access, into adaptation, picked a channel “particle filter initialization”. Gave a new value of 1, asked me about the value change-yes, got a panel that says “this appears to been uninitialized control module, valid WSC/Importer/Equipment data may be required. Click yes for VCDS to use default values 12345/123/12345-will not accept this. Click no for VCDS to try the values currently on the module-get window requiring 5 Numeric digit workshop code. Click cancel to get back and manually edit the values.
Not sure where to go next. Have had this software for 13 years for the two TDIs we have. This is the deepest problem I’ve had.
P F difference pressure-0 hPa
DFP offset for diffential pressure—6 hPa
P F oil ash volume-0.021
P F soot mass calculated-1.79g
P F soot mass measured-17.7g
pike
C?ID=264790
Dr Sheldon
Windsor UK
C?ID=334979
Still waiting for the Autoscan
Important that we see it !!
pike
C?ID=264790
The only thing that seems to work is a jpeg copy
  • Disagree
pike
C?ID=264790
pike
C?ID=264790
Ran into a wall as explained above
Westbury, UK
Open the folder C:\Ross-Tech\VCDS\Scans and you see a .txt file of the Auto-Scan - copy that using Notepad and paste it here using the forum editor </> icon.
pike
C?ID=264790
Even using the icon above </> with it in notepad it will not post because it contains txt. Its probably me that's the problem. I still miss windows 7, which makes me a dinosaur.
Copy & paste the text.
pike
C?ID=264790
Had to email it to another computer, tried my Ipad with zero success, finally to a desktop and it seems to have worked. Got a new code on this one for the filter.
Wednesday,02,September,2026,09:02:09:11970
VCDS Version: 26.9.0.3 (x64)
VIN: 1VWBN7A37DC137594   License Plate: R9-2-26A
Mileage: 264370km-164271mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
VIN: 1VWBN7A37DC137594   Mileage: 264370km-164271miles
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:                CVN: D240C61F5C3E0D04
   Coding: 001D0012042400000000
   Shop #: WSC 07459 444 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B7557A1B24B624555-806E
   VINID: 0669D27874431D44C10C71491049637A46
5171 - Boost Pressure Regulation
          P0299 00 [01100101] - Control Range Not Reached
                    Mileage: 264370 km
                    Date: 2026.09.02.
                    Time: 10:38:22
                    Engine speed: 2626.50 /min
                    Normed load value: 60.4 %
                    Vehicle speed: 32 km/h
                    Coolant temperature: 67  C
                    Intake air temperature: 32  C
                    Voltage terminal 30: 13.320 V
                    Charge air pressure: specified value: 2378 hPa
                    Charge air pressure: actual value: 1450 hPa
                    Air mass: actual value (mg/stroke): 1064.8 mg/stroke
                    EGR Solen.val.: actual value: 99.61 %
                    Throttle valve adapter: actual value: 99.57 %
                    Charge air pressure actuator: acknowledgment: 77.64 %
                    Mean injection quantity: 31.76 mg/stroke
8863 - Particulate Filter
          P2459 00 [01100101] - Regeneration Frequency
                    Mileage: 264370 km
                    Date: 2026.09.02.
                    Time: 10:38:02
                    Engine speed: 1810.50 /min
                    Normed load value: 1.2 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 64  C
                    Intake air temperature: 31  C
                    Voltage terminal 30: 13.380 V
                    Exhaust gas jet volume in particle filter: 191.8 m /h
                    Particle filter: difference pressure: 194 hPa
                    Particle filter: soot mass measured: 24.21 g
                    Particle filter: soot mass calculated: 24.18 g
                    Particle filter: differential pressure: dynamic offset: -7 hPa
                    Exhaust gas temperature sensor 3: 349.0  C
                    Exhaust gas temperature sensor 4: 222.0  C
12896 - Boost Pressure Regulation
                    Mileage: 264370 km
                    Date: 2026.09.02.
                    Time: 10:38:22
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05651213    Serial number: 00001302140028
   Shop #: WSC 09003 957 00200
   VCID: 24478CDDE7F53DBD04-8070
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-EC1-V3.clb
   Revision: 00H31001
   Coding: C54BC0F549250001A31003ED921D0042A71000
   VCID: 7DF199B9E4DFAC752B-8028
   Part No SW: 561 907 426 A    HW: 561 907 426 A
   Component: AC Manuell    H02 0101
   Revision: 00001K07
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW41.rod
   VCID: 1939AD2918B77055A7-804C
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B802B2AD408880001160085480071008640A00560648060000C70
   Shop #: WSC 05082 001 1048576
   VCID: 74E7BC9DD795ED3D54-8020
   Component: RLS 210313 05  54  0403
   Coding: 22300A
                    Reset counter: 15
                    Mileage: 264372 km
                    Date: 2021.01.23.
                    Time: 11:56:56
                    Voltage: 11.75 V
   Serial number: 003MWM01HE9Y   Dataset Number: 560003v__A_ 0126
   Coding: 00004D4A
   Shop #: WSC 15550 007 1048576
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75E18199D4EFF43563-8020
   Seat occupant detection:
   Serial number: 6940000Y130000SS0T0D
   Coding: 303044
   Serial number: 3572MSME59181374ZZZV
   Serial number: 3582MSME2A126575ZZZW
   Serial number: 3516KSME752A1B23ZZZU
   Serial number: 3526KSME481D6C22ZZZ
   Serial number: 3556LSME270E6821ZZZY
   Serial number: 3566LSME7B476921ZZZ%
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20130221201487
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWSXS.rod
   VCID: 76E38695C9E9FF2D6A-8022
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 1C37B43D1785057DBC-8048
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 20041303290486
   Coding: 461000
   VCID: 76E38695C1E9FF2D6A-8022
   Component: IMMO          H07 0705
   ROD: EV_Immo_UDS_VDD_RM09_VW41.rod
   VCID: 6ADBA2E58D512BCDFE-803E
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664066133
   Coding: 020100
   VCID: 2A5B62E545D1EBCD3E-807E
   Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
   Component: RNS315-NAR    H55 0319
   Serial number: VWZAZ2M4294466
   Coding: 0400040104000B000000100A
   ROD: EV_RNS315NARV2UDS_VW41.rod
   VCID: 254191D924CFC4B513-8070
   Component: NAR_V9N  0070
                    Reset counter: 13
                    Mileage: 264367 km
                    Date: 2026.09.02.
                    Time: 10:43:03
   Revision: 13110009    Serial number: 0006589164
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BB5F721520B424575-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630130423205802
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 377D4B9146634625B1-8062
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FEDB3F1BEB3CEE5A9-803A
   Serial number: 53388786011230700664
   Coding: 181100
   Revision: 15110009    Serial number: 0006586875
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CB7F43D5705457D7C-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130416190913
   Coding: 800000
End-------------------------(Elapsed Time: 03:40)--------------------------
------------------------------5 Faults Found-------------------------------
                    Mileage: 264370 km
                    Date: 2026.09.02.
                    Time: 10:38:22
                    Mileage: 264370 km
                    Date: 2026.09.02.
                    Time: 10:38:02
                    Mileage: 264370 km
                    Date: 2026.09.02.
                    Time: 10:38:22
   Revision: 00H31001
   Revision: 00001K07
   Coding: 0010001002
   Revision: BL121001
   Coding: 22300A
                    Reset counter: 15
                    Mileage: 264372 km
                    Date: 2021.01.23.
                    Time: 11:56:56
                    Voltage: 11.75 V
   Coding: 00004D4A
   Coding: 303044
   Coding: 088A140000
   Coding: E20000
   Coding: 231E01
   Coding: 461000
   Coding: 020100
                    Reset counter: 13
                    Mileage: 264367 km
                    Date: 2026.09.02.
                    Time: 10:43:03
   Coding: 0404F5
   Slave Driver:
   Coding: 800000
   Revision: 00H22000
   Coding: 01030108
   Coding: 181100
   Coding: 0404F4
   Slave Passenger:
   Coding: 800000
End-------------------------(Elapsed Time: 02:52)--------------------------
Have you checked for a massive boost leak?
Were all the parts thrown at this thing thus far OEM and known good?
pike
C?ID=264790
The particulate filter came off a wreck I purchased, 2012 Passat with 130k. The car was caught in a squeeze with an 18 wheeler and two other cars on the interstate. Damage was in door areas on both sides. Car had been driven from Idaho to Georgia where the mishap occurred. Filter and converter were clean as a whistle and I blew air through it easily and nothing exited out. Replaced map sensor, removed and cleaned the interior of the inner cooler. Also replaced the boost controller. Borascoped both sides of the turbo, exhaust thru the sensor and intake thru the intake line. Removed the plastic adapter to get a finger to the turbine blades and got it to rotate and has a smooth rotation. Less than 40k on turbo. Checked the turbo actuator and it moves easily when a slight vacuum is applied and the line and actuator with no leakage. I did find that the aftermarket valve cover is letting oil into the intake line, apparently there isn’t a PRV valve, have just gotten a new one with a pct and will put it on shortly.
What was the ash load of the DPF on the donor vehicle? How close to EOL was it?
Did you answer my questions up above?
