More adblue issue 500 miles count down
trebor
C?ID=531493
Hi. To save you asking i have done a full scan and there are no faults to report.
Ive refilled my adblue tank and the level sensor is working 200.0 mm unfortunately I have no reductant pump pressure 0 pHa. The scr metering quality test will not run. The scr lock is off.
The raw temperature-272 c and urea is also 0.0.
Im running out of time before the van is toast.
nugentp
C?ID=6386
How can anyone help if nobody knows what vehicle it is (except you) ?
Forum posts do not convey psychic powers so pls post a full unedited AutoScan.
trebor
C?ID=531493
Agreed, sorry im just abit upset with my adblue. I wish it would just go away. United Kingdom registered right hand drive. December build 2016 dfsd engine 2.0 tdi Vw caddy maxi. Im on my second used adblue tank will it ever work correctly.
nugentp
C?ID=6386
SCR is the devils work alright. I am no expert on that stuff but if you post the scan with your VIN then I can source correct schematics etc - maybe you just have a bad connection or blown fuse.
trebor
C?ID=531493
If only it was that easy. Let me see if I can dig up a perfect vcds full scan with my vin and ecu software and all will right.. bare with.....
Dr Sheldon
Windsor UK
C?ID=334979
It is that easy !!
trebor
C?ID=531493
:banghead:
Dr Sheldon
Windsor UK
C?ID=334979
There is so much more in that Autoscan than just Fault Codes. You are the one asking for help, on what basis have you decided that I / We do not need to see the scan ??
For that reason please post the F*****g thing !
  • Agree
trebor
C?ID=531493
hursday,28,December,2023,12:28:18:57681<br>VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64<br>VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4<br>Data version: 20231027 DS351.0<br>www.Ross-Tech.com<br><br><br>VIN: WV1ZZZ2KZHX039809   License Plate:<br>Mileage: 94150km-58502mi   Repair Order:<br><br><br><br>--------------------------------------------------------------------------------<br>--------------------------------------------------------------------------------<br><br><br>Chassis Type: 2K-VN35 (7N0)<br>Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F 61<br><br>VIN: WV1ZZZ2KZHX039809   Mileage: 94150km-58502miles<br><br>01-Engine -- Status: OK 0000<br>03-ABS Brakes -- Status: OK 0000<br>04-Steering Angle -- Status: OK 0000<br>08-Auto HVAC -- Status: OK 0000<br>09-Cent. Elect. -- Status: OK 0000<br>15-Airbags -- Status: OK 0000<br>16-Steering wheel -- Status: OK 0000<br>17-Instruments -- Status: OK 0000<br>19-CAN Gateway -- Status: OK 0000<br>25-Immobilizer -- Status: OK 0000<br>42-Door Elect, Driver -- Status: OK 0000<br>44-Steering Assist -- Status: OK 0000<br>46-Central Conv. -- Status: OK 0000<br>52-Door Elect, Pass. -- Status: OK 0000<br>5F-Information Electr. -- Status: OK 0000<br>61-Battery Regul. -- Status: OK 0000<br>-------------------------------------------------------------------------------<br>Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb<br>   Part No SW: 04L 906 016 GT    HW: 04L 907 309 K<br>   Component: R4 2.0l TDI   H20 4648 <br>   Revision: 8AH20---    CVN: BCEEEF1835B454D1<br>   Coding: 01110012040509090000<br>   Shop #: WSC 00304 210 00000<br>   ASAM Dataset: EV_ECM20TDI01104L906016GT 004004<br>   ROD: EV_ECM20TDI01104L906016GR_004.rod<br>   VCID: 015F896B31871F1220D-8054<br>   VINID: 9E606AAAA09BA98A000C9200248F678A89<br><br>No fault code found.<br>Readiness: 0 0 0 0 0<br><br>-------------------------------------------------------------------------------<br>Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb<br>   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M<br>   Component: ESC           H06 0133 <br>   Revision: 00000000    Serial number: 42286000003612<br>   Coding: 1479409B9265A487287D0276498B25E3790000<br>   Shop #: WSC 35110 790 50316<br>   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001<br>   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod<br>   VCID: 3FDB4F9307F3A9E2169-806A<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb<br>   Part No SW: 1K8 907 426 AT    HW: 1K8 907 426 AT<br>   Component: AC Manuell    H21 0909 <br>   Revision: 00001002   <br>   Coding: 0010004003<br>   Shop #: WSC 35110 790 50316<br>   ASAM Dataset: EV_ACManueBHBVW36X A01010<br>   ROD: EV_ACManueBHBVW36X_VW32.rod<br>   VCID: 05579D7B25AF33321C5-8050<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb<br>   Part No SW: 5K0 937 085 AD    HW: 5K0 937 085 AD<br>   Component: BCM PQ35 B+   122 0184 <br>   Revision: BB122001   <br>   Coding: 411A583A8025086B08800082900000640301000842028060648087000041<br>   Shop #: WSC 35110 377 08192<br>   VCID: 75B7EDBB75CF23B20C5-8020<br><br>   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB<br>   Component: Wischer 12081  26  0512<br>   Coding: 009795<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb<br>   Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B<br>   Component: VW10Airbag00K H08 0018 <br>   Revision: --------    Serial number: 003V10012DY% Dataset Number: 2KC003V__A_ 0765<br>   Coding: 00000000000000000000000000000000304B<br>   Shop #: WSC 35110 790 50316<br>   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028<br>   ROD: EV_AirbaVW10BPAVN750.rod<br>   VCID: 3B233B8313EBB5C23A1-806E<br><br>   Crash sensor for side airbag: driver side:<br>   Serial number: 3497ARB404T43EHKDP7$<br><br>   Front Passenger's Side Airbag Crash Sensor:<br>   Serial number: 3507ARB404T43EHKG147<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb<br>   Part No SW: 1K5 953 521 CF    HW: 5K0 953 569 BB<br>   Component: LENKS.MODUL   018 0230 <br>   Revision: FF010042    Serial number: 20160819300153<br>   Coding: 0080060000<br>   Shop #: WSC 35110 790 50316<br>   ASAM Dataset: EV_SMLSNGVOLWSR8C 001001<br>   ROD: EV_SMLSNGVOLWSR8C.rod<br>   VCID: 73B3D3A37B3B3D82221-8026<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1<br>   Part No SW: 2K5 920 966 C    HW: 2K5 920 966 C<br>   Component: KOMBI         H03 1104 <br>   Serial number: 00000000000000<br>   Coding: 4102000200<br>   Shop #: WSC 35110 790 50316<br>   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733<br>   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod<br>   VCID: 35372DBB35CF63B2CC5-8060<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb<br>   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL<br>   Component: J533  Gateway H58 1682 <br>   Revision:   H58       Serial number: 230816F1001347<br>   Coding: 357421<br>   Shop #: WSC 35110 377 08192<br>   VCID: 79AFE18B59D747D268D-802C<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb<br>   Part No SW: 5K0 953 234     HW: 5K0 953 234<br>   Component: IMMO          H03 1104 <br>   Serial number: 00000000000000<br>   Coding: 000000<br>   Shop #: WSC 00000 000 00000<br>   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710<br>   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod<br>   VCID: 6A8DCEC72CF1FC4A917-803E<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb<br>   Part No SW: 2K5 959 701     HW: 2K5 959 701<br>   Component: Tuer-SG         009 2144 <br>   Coding: 0131632<br>   Shop #: WSC 35110 377 08192<br>   VCID: 71BFD9AB0DA70F92D0D-8024<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb<br>   Part No: 1K0 909 144 R<br>   Component: EPS_ZFLS Kl. 140    3501 <br>   Revision: 00H22000   <br>   Shop #: WSC 35110 377 08192<br>   VCID: 392F218B155787D228D-806C<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb<br>   Part No SW: 2K5 959 702     HW: 2K5 959 702<br>   Component: Tuer-SG         009 2144 <br>   Coding: 0131632<br>   Shop #: WSC 35110 377 08192<br>   VCID: 72BDD6A708A1348A297-8026<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb<br>   Part No SW: 1K8 035 150 L    HW: 1K8 035 150 L<br>   Component: MU-E-D-ER     055 7067 <br>   Serial number: 06071600012931 Dataset Number: V03935239NF 0001<br>   Coding: 063307002800000041111101008000001F0000C60000010001<br>   Shop #: WSC 35110 790 50316<br>   ASAM Dataset: EV_MUEnt4CGen2LGE 001032<br>   ROD: EV_MUEnt4CGen2LGE_VW32.rod<br>   VCID: 2E0502D7D099506A8DF-807A<br><br>No fault code found.<br><br>-------------------------------------------------------------------------------<br>Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb<br>   Part No SW: 7N0 907 534     HW: 7N0 907 530 AL<br>   Component: Batt.regelung H58 1682 <br>   Serial number: 230816F1001347<br>   Coding: 030F1873<br>   Shop #: WSC 35110 377 08192<br>   VCID: 71BFD9AB01A70F92D0D-8024<br><br>   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181<br>   Component: J367-BDMConti  H03 1050<br>   Serial number: 75410603001608040055<br><br>No fault code found.<br><br>End----------(Elapsed Time: 00:53, VBatt start/end: 11.8V/12.0V)-----------
Tuesday,01,September,2026,15:54:01:57681
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
VIN: WV1ZZZ2KZHX039809   License Plate: VCDS FORUM
VIN: WV1ZZZ2KZHX039809   Mileage: 117600km-73073miles
   Revision: 8AH20---    CVN: BCEEEF18AF135584
   VCID: 015F896B31871F12E8E-8054
29630 - Reductant Flow
          P218F 00 [01100101] - No Flow Detected
                    Mileage: 117609 km
                    Date: 2026.08.31.
                    Time: 02:34:24
                    Engine speed: 0.00 /min
                    Coolant temperature: 56 °C
                    Intake air temperature: 53 °C
                    Voltage terminal 30: 11.820 V
                    Outside temperature sensor 1: B1: raw value: 27.0 °C
                    Reducing agent pump module relative press.: calculated: 0 hPa
                    Reducing agent fill level sensor: act. value: 195.8 mm
                    Sensor for reducing agent tank temperature: temperature: 23.1 °C
                    Reducing agent system pressurization release conditions-Bits 0-7: 2
                    Reducing agent system pressurization release conditions-Bits 0-7: 71
                    Reducing agent system: current status: COSCR_STANDBY
                    Reducing agent system: current status-Test_Program_SCR Con State 01 UBYTE: 1
   VCID: 3FDB4F9307F3A9E2DEA-806A
   Revision: 00001002
   Coding: 0010004003
   VCID: 05579D7B25AF3332D46-8050
   Revision: BB122001
   VCID: 75B7EDBB75CF23B2C46-8020
   Coding: 009795
   VCID: 3B233B8313EBB5C2F22-806E
   Coding: 0080060000
   ROD: EV_SMLSNGVOLWSR8C_VW32.rod
   VCID: 73B3D3A37B3B3D82EA2-8026
   Coding: 4102000200
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: 35372DBB35CF63B2046-8060
   Coding: 357421
   VCID: 79AFE18B59D747D2A0E-802C
   VCID: 6A8DCEC72CF1FC4A594-803E
   Coding: 0131632
   VCID: 71BFD9AB0DA70F9218E-8024
   Revision: 00H22000
   VCID: 392F218B155787D2E0E-806C
   Coding: 0131632
   VCID: 72BDD6A708A1348AE14-8026
   VCID: 2E0502D7D099506A45C-807A
   Coding: 030F1873
   VCID: 71BFD9AB01A70F9218E-8024
End----(Elapsed Time: 00:53, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
-------------------------------1 Fault Found-------------------------------
So it appears clear as day based on what you've said and what the DTC says, that you have no DEF flowing.
What is it that you're asking here? :confused:
  • Agree
nugentp
C?ID=6386
I don't have access to WD for that Caddy Maxi - was wanting to see if something as stupid/simple as a fuse or bad connection was the root cause here. Weirdly I could access fuse & relay info... apparently J963 at position 8 under the dash is exclusively for the AdBlue pump. Might be worth checking that one and its associated fuse SB24.
Dr Sheldon
Windsor UK
C?ID=334979
And then
1 Fault Found: 29630 - Reductant Flow P218F 00 [01100101] - No Flow Detected
Are you ok ?
Why say there are no faults when what whopper is staring at you ?
trebor
C?ID=531493
Yeah the van had a 12 hours sleep. I ran another scan and hour ago and it has just recored a fault. I know there would be faults as the adblue doesn't function correctly..
I would like to run the adblue pump with scr quantity test but keeps aborting for safety reasons probably trying to protect the pump as there is no flow detected.
I thought my main problem was the deductant level sensor. How ever the ecu has excepted the new tank and the 195mm reductant level holds stable.
The scr lock is off but the ecu will not release the 500mile reductant count down probably because of other issues it's not happy with.
trebor
C?ID=531493
My adblue just reset and given me 4000 range. I now have no fault codes and all is well. I checked the advanced measurements and nothing really has changed. I guess the Ecu is happy with the information it's relieving also it not registering in vcds.
nugentp
C?ID=6386
Ummmm - what did you do for that to happen all by itself ?
Have you looked in the advanced measuring blocks for all things SCR/AdBlue related to see if you now have some flow being reported ?
trebor
C?ID=531493
Yes. Its worst all reports 0.0. Although no faults. Im great full for the 4000 range though. Maybe it just needs a god run.
trebor
C?ID=531493
Going back though my vcds full scan for the last 2 years, most of the problems have started with the Nox sensor which does seem quite important to the SCR [ selective catalytic reduction }. Specially when there is only one with the rest of the system relying on calculated and expected figures..
The van was driven for 22 months on very short 2x4miles journeys, I think that probably screwed the SCR system up.
Also my refusals to purchase a genuine and correct VW Nox sensors at £800 sterling, which leaves buying second hand, amazon and ebay sensors.
Early vcds scan shows errors snowballing with different cheap sensors which had been plugged in and out. u029e (No communication) 9560 Nox sensor Voltage 9880 Nox heating circuit.
Going though the old scans (very useful the full scan by the way,hehe). Things did settle a bit only recording 15733 scr cat efficiency.. Possibly might have confused the Ecu with the cheap Nox sensors and maybe the odd fuse in the wrong location. The Nox sensor did settle but then started to get loads of other fault codes like 22585 reducing level implausible p218f No reductant flow detected..
Replacing the adblue tank for a second time was abit lazy really has didn't want to remove front bumper to check for a wiring harness issues without replacing the tank which I suspect is broken (dont know really might be ok) and easier than checking wiring harness. Anyway new tank fitted and 100 miles driven and hoping for positive reading for the SCR monitoring. Still not getting results from the scr pump but it must be dozing adblue as the no-start count down has lifted the inducement figures are zero.
Still not completely convinced that it is fixed but its seems ok today.
