Polo check engine and multiple fault codes
REQFAW
Sweden
C?ID=662685
Hi, so my polo like a year ago got a check engine light and it just low power, like the turbo isnt even working, the check engine light is on and i have like 5 error codes, when this happened the car wasn't even driveable, so i pulled the vacuum hose from the top of the EGR, and it goes somewhat, max like 110, and ive been driving it like this for a year but now i wanna fix it, i tried changing all the relays, checked fuses, not sure what else i tried, one thing that once worked was i was messing around with the wiring below the battery, and i tried erasing the codes, and i erased them, but that only lasted for a day. Then i checked all the wires there but i could not find a damaged wired or anything, so im just clueless at this point, if someone has an idea what it could be?
Monday,31,August,2026,15:00:32:48043
VCDS Version: 26.3.0.0  HEX-V2 CB: 0.4713.5
VIN: WVWZZZ9NZ6Y219725   License Plate:
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6Y219725   Mileage: 209400km-130115miles
   Part No: 045 906 019 BP
   Component: 1,4l R3 EDC 0000SG  7501
   Coding: 00002
   Shop #: WSC 00788
   VCID: 649579F99740059A4BB-4B1E
   WVWZZZ9NZ6Y219725     VWZ7Z0F3444755
17932 - Fuel Pump Relay (J17)
            P1524 - 35-10 - Open or Short to Ground - Intermittent
17849 - EGR Valve (N18)
            P1441 - 35-10 - Open Circuit or Short to Ground - Intermittent
19557 - Motor for Intake Manifold Flap (V157)
            P3101 - 35-10 - Open or Short to Ground - Intermittent
17957 - Boost Pressure Regulation Valve (N75)
            P1549 - 35-10 - Open or Short to Ground - Intermittent
19586 - EGR System
            P3130 - 35-10 - Regulation Range Exceeded - Intermittent
Readiness: 1 5 0 0 0
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No: 6Q0 907 379 AF
   Component: ABS 8.0 front   H04 0002
   Coding: 0002136
   Shop #: WSC 00788 785 00200
   VCID: 015B506D6D12B0B2C0D-5160
Address 08: Auto HVAC        Labels: 6Q0-820-045-V1.clb
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: 6A8917C1756453EA717-5160
01271 - Positioning Motor for Temperature Flap (V68)
            29-00 - Short to Ground
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00AF BN-SG.         1S34
   Coding: 26046
   Shop #: WSC 31414
   VCID: 3C25E1994F701D5AD3B-5160
01598 - Drive Battery Voltage
   Part No: 1C0 909 605 K
   Component: 18 AIRBAG VW51 0P   0008
   Coding: 12600
   Shop #: WSC 00788
   VCID: 2C05D1D9BF108DDA43B-5160
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 803 D
   Coding: 01131
   VCID: 313BC0AD9832E03270D-5160
   Part No: 6N0 909 901
   Component: 0B7L GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70BD05A953B8A93A3F3-5160
   Part No: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10110
   VCID: 6FBF06D54E86B6C2269-5160
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 3F Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 00788
   VCID: 3D23EC9D546A1452E45-4B1E
End----(Elapsed Time: 02:52, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
------------------------------8 Faults Found-------------------------------
I am not at work until tomorrow so I can’t check electrical interconnects to the components but I would fit a new fuel pump relay first, clear the codes and see how it drives. This is revised part number 4H0 951 253 A, is fitted at position 4 and has the control group number 53 or 373 printed on top where the new revised part is CGN 643.
nugentp
C?ID=6386
I was of the feeling that all the intermittent faults were from experimental unplugging/replugging events. If the fuel pump relay is properly dead it wouldn't start. Poor performance could be EGR or WGFV/N75 related. It could also just be good old fashioned tired/failed turbo.
Suggest to clear all fault codes again and try OUTPUT TESTS for the engine in VCDS with everything connected and report back. That should make the ECU tickle all the outputs one at a time which you can feel and/or hear as a good sanity check that wiring to each actuator is good and it clicks when commanded.
REQFAW
Sweden
C?ID=662685
I have changed all the relays below the steering wheel, no luck. Even changed their sockets.
REQFAW
Sweden
C?ID=662685
Thing is when i was messing with the wiring, i tried clearing the codes and they cleared, then i reconnected the vacuum hose back and the car worked perfectly, only lasted a day tho.
nugentp
C?ID=6386
Maybe EGR is the culprit then (or at least partly guilty), but you need to do ECU output tests and other methodical steps as the answer is not to just replace parts until the problem goes away.
REQFAW
Sweden
C?ID=662685
Egr was changed too. But wait Crasher mentioned the 53 relay, I don’t remember if changed that one. Will try another one, also try the output test and I’ll let you know.
REQFAW
Sweden
C?ID=662685
Cant buy a relay right now but i did try swapping the socket 4 relay 53 with the same one below it, then tried erasing but it just comes back. Dont think its that relay.
The fuel pump relay isn't connected here BUT the N75, N18 and V157 (plus the G40) share the same power feed from fuse 14 which receives its power from the J317 line 30 relay, which also provides the fuel pump relay power although it also powers the ECU so you would expect more codes or no comms.
The box 37 at current track 85 is from fuse 14, E30 is a welded junction in the harness.
