2015 Bentley Continental GT V8 S, 4.0L V8 TFSI (CYCA)
golfi_vend
Tartu, Estonia
C?ID=195131
It's a little bit broken, but per coding wise it has SVM-d with ODIS.
Bentley could use update of label files based on prbably similar Phaeton maps, but I understand it's a nieche market and may not carry the effect.
PS! These older modules don't offer dataset name? - Newer UDS shows it in identification data after regular autoscan, but not these? - Example Seats.
TL;DR: cleared a batch of unrelated DTCs, reset the ACC radar's angle adaptation, fixed a swapped driver/passenger seat-memory identity coding fault, and recoded the Bluetooth module.
Before:
Thursday,27,August,2026,19:01:58:63851
VCDS Version: 26.3.0.0 (x64)  HEX-NET2 CB: 0.4714.5
Data version: 20260624 DS375.2
VIN: SCBFE63W1FC   License Plate: BENTLEY_AGAIN
Mileage: 92500km-57476mi   Repair Order:
Chassis Type: 3W-BY62 (3W0)
Scan: 01 02 03 05 06 07 08 09 13 15 16 17 19 23 2E 34 36 37 38 46
          47 53 56 65 68 6C 6D 71 76 77
VIN: SCBFE63W1FC   Mileage: 92500km-57476miles
38-Roof Electronics -- Status: OK 0000
68-Wiper Electr. -- Status: Malfunction 0010
71-Battery Charger -- Status: OK 0000
Address 01: Engine (------CYCA)       Labels: None
   Part No SW: 4W0 906 560 C    HW: 079 907 309
   Component: 4.0l V8TFSI / H57 0003
   Revision: NFH57---    Serial number: VWX3Z0N3014426 CVN: 4FE5D2B6
   Coding: 1D2A00124566000B0001
   Shop #: WSC 00083 790 00190
   ASAM Dataset: EV_ECM40TFS0114W0906560C 001004
   ROD: EV_ECM40TFS0114W0906560C.rod
   VCID: 382243A812DC1D7A373-806C
   VINID: 8D34965460E70564C01051420CAA0A01C0
4330 - Function Restriction due to Faults in Other Modules
          U1113 00 [00100111] - -
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:56:42
                    Engine speed: 656.50 /min
                    Normed load value: 8.2 %
                    Coolant temperature: 84 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 14.088 V
                    Engine status: COENG_RUNNING
Readiness: 1110 1001
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 3W0 927 158 D    HW: 0CU 927 760 A
   Component: OBL 40TFSIRdW H19 0002
   Revision: --H19---    Serial number: VWX3Z0N3014426 CVN: 31249D81
   Shop #: WSC 00083 790 00191
   ASAM Dataset: EV_TCMAL450211 002010
   ROD: EV_TCMAL450211_BY62.rod
   VCID: 3E2E55B030F8234AFDF-806A
Address 03: ABS Brakes        Labels: 3W0-614-517-V2.clb
   Part No SW: 4W0 614 517 D    HW: 4W0 614 517 D
   Component: ESP 8.1 4WD     H01 1250
   Coding: 0002536
   Shop #: WSC 00083 790 00196
   VCID: 37204094130212023E9-8062
   Part No SW: 3D0 909 137 F    HW: 3D0 909 137 F
   Component: C3 Kessy            6850
   Revision: 00H24072    Serial number: VWX3Z0N3014426
   Coding: 0422125
   Shop #: WSC 00083 790 00187
   VCID: 2A0669E0D0B0BFEAB17-807E
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
                    Fault Frequency: 0
                    Reset counter: 201
                    Date: 2026.08.27
                    Time: 19:00:14
   Part No SW: 4W0 959 760     HW: 4W0 959 760
   Component: MEM-BFS       H04 0600
   Revision: AA000000    Serial number: 00000059272336
   Coding: 503A1B2480A70000000001010101010000212121000000
   Shop #: WSC 00083 790 00236
   VCID: 7F5068B477B2EA42B69-802A
03776 - Motor for Lumbar Support Adjustment
                    Fault Status: 01100101
                    Reset counter: 89
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:58:50
03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:05
03331 - Motor for Backrest Angle Adjustment
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:05
03332 - Motor for Height Adjustment
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:05
03768 - Motor for Seat Depth Adjustment
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:05
Address 07: Control Head        Labels: 3D0-907-048.clb
   Part No SW: 3D0 907 048     HW: 3D0 907 048
   Component: J127 KBT vorn       0100
   Revision: ABH27001    Serial number: VWZ6Z7S0064017
   VCID: 6398C4C4F71A2EA2B21-8036
Address 08: Auto HVAC        Labels: 3W7-907-040.clb
   Part No: 3W0 907 040 L
   Component: Climatronic BY624   3019
   Coding: 0000111
   Shop #: WSC 00083 790 00166
   VCID: 3A2659A020100F6AC17-806E
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
   Component: J519                7700
   Revision: -4006---    Serial number: --------------
   Coding: 40820000AB2A11800508030000000000
   Shop #: WSC 99999 999 2097151
   VCID: 382243A81E1C1D7A373-806C
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4W0 907 567 A    HW: 4W0 907 567 A
   Component: AC201  RDW BY684   00941
   Revision: 00041000    Serial number: 00000000644242
   Coding: 0010684
   Shop #: WSC 69905 136 139810
   VCID: 3E2E55B03C38234AFDF-806A
00234 - Sensor for Automatic Distance Regulation Misadjusted
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Fault Frequency: 69
                    Reset counter: 88
                    Mileage: 91336 km
                    Date: 2026.08.06
                    Time: 02:52:20
                    Count: 139
Address 15: Airbags (J234)       Labels:| 3W3-959-655.clb
   Part No SW: 3W3 959 655 A    HW: 3W3 959 655 A
   Component: VW10Airbag20I H01 0004
   Revision: --------    Serial number: 003FW000GLLM Dataset Number: V03935197ZS 0002
   Coding: 000000000000000000000000000000003049
   Shop #: WSC 00083 790 00188
   ASAM Dataset: EV_AirbaVW10BPABY62X 001002
   ROD: EV_AirbaVW10BPABY62X.rod
   VCID: 45DC3A5C552E7092BC5-8010
   Serial number: 3572DRB40000F71869C1
   Serial number: 3582DRB40000F720C08V
   Serial number: 35128RB40000719A938M
   Serial number: 35228RB40000719BDAC$
   Serial number: 35547RB40000733A431B
   Serial number: 35647RB40000733A445H
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000042
   VCID: 47C0305463E262824E9-8012
Address 17: Instruments        Labels: 3Wx-920-xxx-17.clb
   Part No SW: 3W0 920 851 P    HW: 3W0 920 851 P
   Component: J285 KOMBI-INST.    5555
   Revision: KPH10V04
   Coding: 0046114
   VCID: 43D82444579A4EA2921-8016
Address 19: CAN Gateway        Labels:. 3W0-909-901.clb
   Part No SW: 3W0 909 901     HW: 3W0 920 851 P
   Component: J533  GW-K-CAN TP20 5555
   Revision: KPH10V04
   Coding: DFF3FFAEEB154700
   VCID: 76BE8D9054C8AB0AE5F-8022
Address 23: Brake Booster        Labels: None
   Part No: 3W0 907 563 B
   Component: BREMSBOOSTER    007 0430
   Revision: 00007000    Serial number: 00000000031561
   Revision: A1001003    Serial number: 7665690108
   Coding: 030100
   VCID: 2B086CE4D30AA6E24A1-807E
Address 34: Level Control        Labels: 3Wx-907-553-34.clb
   Part No: 3W0 907 553 J
   Component: LUFTFDR.-CDC- 3C3V0 7509
   Coding: 0005531
   VCID: 41D42E4C4DC65CB280D-8014
   Component: MEM-FS        H04 0600
   Revision: AA000000    Serial number: 00000059267609
   Shop #: WSC 00083 790 00242
02005 - Coding Pin
                    Fault Status: 01101000
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:56
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:56
03777 - Sensor for Lumbar Support Adjustment
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:56
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:57:56
03607 - Control Module for Electrically Adjustable Steering Column
                    Reset counter: 88
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 18:58:00
Address 37: Navigation (J0506)       Labels:. 3D0-035-680.clb
   Part No SW: 3W0 035 017 T    HW: 3W0 035 017 T
   Component: RNS-MID       H27 0290
   Revision: AB001001    Serial number: VWZ6Z7S0064017
   Coding: 06010002000000010000
   Shop #: WSC 00083 790 00195
   VCID: 3E2E55B03078234AFDF-806A
   Subsystem 1 - Part No: 3W0 919 859 CK
   Component: EU West V6  8316
Address 38: Roof Electronics        Labels: None
   Part No: 3W0 907 135 G
   Component: Dachmodul           0803
   Coding: 0006589
Address 46: Central Conv.
Address 47: Sound System        Labels: None
   Part No SW: 3W8 035 465 C    HW: 3W8 035 465 C
   Component: DSP 8 Channel       0030
   Revision: 00H07001    Serial number: 75870000533207
   VCID: 3C2A5FB82A64315AD3B-8068
Address 53: Parking Brake (J540)       Labels: 4W0-907-801.clb
   Part No SW: 4W0 907 801     HW: 4W0 907 801
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 00000000003543 Dataset Number: V03935199CZ 0001
   ASAM Dataset: EV_BY62XParkiBrake 001008
   ROD: EV_BY62XParkiBrake.rod
   VCID: 74BAB7984E34B91ADBB-8020
Address 56: Radio (J0506)       Labels:. 3D0-035-680.clb
Address 65: Tire Pressure        Labels: 3D0-907-273-V5.clb
   Part No SW: 3W7 907 273 D    HW: 3W7 907 273 D
   Component: J0502 RDK           0007
   Revision:   004007    Serial number: 00000900002133
   Coding: 3000E04185C863B8FD43970043DB0063FD004B6E4B6E4B6E4B6E4B6E
Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
   Part No: 3W1 955 023 L
   Component: Wischermodul       ª0401
   Shop #: WSC 00000 725 65552
   VCID: 3FD028B43B322A42F69-806A
00459 - Control Module for Display and Input; Front (J523)
   Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
   Revision: 00H11000    Serial number: 525 PA8J2X0095
   Coding: 2020002
   VCID: 392446AC25560472C8D-806C
   Part No SW: 3W3 959 108     HW: 3W3 959 108
   Component: HDSG-Modul    H01 0803
   Revision: 00000000    Serial number: 259400051 Dataset Number: V03935220MQ 0001
   Coding: 184006C020
   Shop #: WSC 35362 001 1048576
   ASAM Dataset: EV_HDSGBY6245 002001
   ROD: EV_HDSGBY6245_002.rod
   VCID: 7DAC92BC7D7EF852A45-8028
Address 71: Battery Charger (J367)       Labels:* 3W3-915-181.clb
   Part No SW: 3W3 915 181 B    HW: 3W3 915 181 B
   Component: EMM Batt Man  H05 0570
   Serial number: 0000000001
   Coding: 1E0100
   Shop #: WSC 00083 790 00209
   ASAM Dataset: EV_BatteChargVaria1 002019
   ROD: EV_BatteChargVaria1_002.rod
Address 76: Park Assist        Labels: 3W0-919-283-V3.clb
   Part No SW: 3W0 919 283 G    HW: 3W0 919 283 E
   Component: J446  ST Parkhilfe  0111
   Revision: 11H02001    Serial number: 58131419000529
   Coding: 0308036
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3D0 035 730 D    HW: 3D0 035 730 D
   Component: Telefon       024 0982
   Revision: --------    Serial number: 35502105186314
   Coding: 020106010100010000001001
   Shop #: WSC 00029 111 00025
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002_VW32.rod
   VCID: 1D6CB23C9D3E5852C45-8048
End----------(Elapsed Time: 02:01, VBatt start/end: 14.3V/14.2V)-----------
------------------------------14 Faults Found------------------------------
After:
Thursday,27,August,2026,23:04:58:63851
VIN: SCBFE63W1FC   License Plate: BENTLEY BYEBYE
Mileage: 92510km-57483mi   Repair Order:
VIN: SCBFE63W1FC   Mileage: 92510km-57483miles
68-Wiper Electr. -- Status: OK 0000
Readiness: 0010 1001
   Coding: 0002536
   Coding: 0422125
                    Fault Frequency: 0
                    Reset counter: 205
                    Date: 2026.08.27
                    Time: 20:32:54
01049 - Supply Voltage Term 50
                    Fault Status: 00101001
                    Reset counter: 247
                    Date: 2026.08.27
                    Time: 20:49:08
   Coding: D01A1B2485A70000090001010101010000212727000000
                    Reset counter: 89
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 20:32:55
03943 - Pump for Pneumatic Seat Adjustment
                    Fault Status: 00101110
                    Reset counter: 129
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 20:32:58
   Coding: 0000111
01498 - Bulb for Parking Lamps; Right (M3)
   Coding: 0010684
   Coding: 0000042
   Revision: KPH10V04
   Coding: 0046114
   Revision: KPH10V04
   Coding: 030100
   Coding: 0005531
                    Reset counter: 89
                    Mileage: 92501 km
                    Date: 2026.08.27
                    Time: 20:32:54
   Coding: 0006589
00420 - Front Right DSP Midrange Speaker (R104)
                    Reset counter: 89
                    Mileage: 92509 km
                    Date: 2026.08.27
                    Time: 21:12:42
   Coding: 2020002
   Coding: 184006C020
Address 71: Battery Charger (J367)       Labels:* None
   Coding: 1E0100
   Coding: 0308036
   Coding: 020105010100010000000000
End----------(Elapsed Time: 02:03, VBatt start/end: 14.2V/14.0V)-----------
------------------------------7 Faults Found-------------------------------
Fixes:
  1. ACC angle reset
    31 B8 01 03                         Start                → 71 B8 01 03
    31 BA 01 03  (poll)                  → 71 BA 01 03 81       armed
    31 B9 01 03 05                      Adjust               → 71 B9 01 03
    31 BA 01 03  (poll ×6)               → 71 BA 01 03 82 03 00 00 04 25 00 C3 FF   angle = 0xC3
    31 B9 01 03 00 00                   Adjust               → 71 B9 01 03
    31 BA 01 03  (poll ×2)               → 71 BA 01 03 82 03 00 00 04 25 00 C2 FF   angle converges → 0xC2
    31 BB 01 03 00 00 FF FF FF CF 86 9F   COMMIT              → (7F 31 78 ×10 pending) → 71 BB 01 03
    31 BA 01 03                          → 71 BA 01 03 05 03 00 00 04 25 00 C2 FF   status 0x05 = idle/complete
    32 B8 01 03                         Stop                  → 72 B8 01 03 62
  2. Driver and Passenger Seat params and coding with ODIS. Also I messed up identification adaption that says either driver or passenger.
    Passenger (0x315):
    31 B9 01 03 03                      Adjust (id=03)       → 71 B9 01 03
    31 BA 01 03  (poll ×6)               → 71 BA 01 03 82 03 00 00 FF   value = 0x00
    31 BA 01 03  (poll ×2)               → 71 BA 01 03 82 03 00 00 FF   value stays 0x00
    31 B9 01 03 00 00                   Adjust (again)       → 71 B9 01 03
    31 BA 01 03  (poll)                  → 71 BA 01 03 82 03 00 00 FF   value stays 0x00
    31 BB 01 03 00 00 FF FF FF CF 86 9F   COMMIT              → 71 BB 01 03
    31 BA 01 03                          → 71 BA 01 03 05 03 00 00 FF   status 0x05 = idle/complete
    Driver (0x306):
    31 B9 01 03 01                      Adjust (id=01)       → 71 B9 01 03
    31 BA 01 03  (poll ×6)               → 71 BA 01 03 82 03 00 12 FF   value = 0x12
    31 BA 01 03  (poll ×2)               → 71 BA 01 03 82 03 00 00 FF   value converges → 0x00
  3. Bluetooth module coding fixed by ODIS.
  4. Failed to code Airbag moduel to correct coding.... Expected
NEtech
Denmark
C?ID=56995
Do you have Controller maps from [13]?
Eric
HC800000
Those are what we call "service 22"; the intermediate step between CAN TP2.0 and UDS. So you start a session with them like TP2.0 modules, but they don't respond to "old world"/KWP2000 commands like 1A 9B for identification. Most everything is done via command 22 read data by identifier. However they're not full fledged UDS either, besides the old-style session start I don't think they have an identifier and therefore no file-defined specific data.
golfi_vend
Tartu, Estonia
C?ID=195131
DID F1A0 across other modules:
AWD / Battery Charger        -> ------------  (dashes = no dataset)
Parking Brake                -> V03935199CZ
Airbag                        -> V03935197ZS
Door Electronics Passenger   -> ------------
Seat Rear PS                  -> ------------
Telephone                     -> ------------
Trunk Electronics             -> V03935220MQ
Seat Mem. Passenger (0x315)  -> V03935171GL
Seat Mem. Driver (0x306)     -> V03935171GK
Eric
HC800000
Oh I think we may be talking about different things. I was thinking 22 F1 9E (UDS dataset). You meant 22 F1 A0 ("firmware" dataset). They may be shown in Advanced ID? I'll investigate if it's doable time-wise to put them in the Autoscan.
Eric
HC800000
My B8 turned out to be the perfect testbed for this. Maybe I should have Uwe pitch in for maintenance ;)
Sunday,06,September,2026,21:38:19:05054
VCDS Version: 26.10.0.1 (x64)  HEX-NET CB: 0.4717.4
Data version: 20260708 DS379.0
VIN: WAUDGAFL1GA000773   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 22 36 3C 42 44 46 47 52 53 56 5F
          62 6C 72 A9
VIN: WAUDGAFL1GA000773   Mileage: 119990km-74558miles
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIX07 0007
   Revision: --X07---    CVN: 2F730C17
   Coding: 0A190034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS021_AU48.rod
   VCID: BA37314E3D4CA74D0C-80EE
   VINID: 9D19545D159C0574400001C70C917A895B
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 281D1A01
   Shop #: WSC 06325 000 00000
   VCID: 89559E82202A7CD555-80DC
02214 - Tire Pressure Warning
                    Reset counter: 153
                    Mileage: 119041 km
                    Date: 2026.07.24
                    Time: 11:38:48
                    Hex Value: 0x3C00
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x1BB2
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
   Component: BCM2 2.0      H15 0711
   Revision: 00002001    Dataset Number: 8K0909517G  0007
   Coding: 0F814040000000000000
   VCID: 854D92B20C3218B531-80D0
   Serial number: 3215000088448006
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01200520152526
   Coding: 6600228000
   VCID: F7B1E87A46DE7A2533-80A2
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00001077846201 Dataset Number: 8K0909514R  0044
   Coding: 26000093863CAFE0240048C300003D0D0F9C9208A2090221000008004000030100000030000000
   Shop #: WSC 06325 123 12345
   VCID: F8B3EB464BC0755D3A-80AC
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA230415  H19 0461
   Serial number: 1504200605724
   Coding: 004577
   Serial number: 20306644
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000505150103
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01F2784E
   Serial number: FE2949A7000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD137WPY   Dataset Number: 8K0909602S  0001
   Coding: 303844354730383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: CBD9648A62D62EC5A7-809E
   Seat occupant detection:
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R150000LN8G
   Serial number: 6334MSME514C4A72I
   Serial number: 6344MSME4F59443FX
   Serial number: 6352QSME63540C66J
   Serial number: 6362QSME4854305CJ
   Serial number: 63732SME0A574D5CC
   Serial number: 63832SME71561154U
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372OEE0004X
   Coding: 000016
   VCID: C4CB4FB64788E1BD66-8090
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 63-65HA5G
   Coding: 83DD09008301D705020002
   VCID: F2A7D96E2DBC1F0D04-80A6
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1550603B7 Dataset Number: 8K0909515P  0072
   Coding: 80C003FF00
   VCID: CCDB67966FD829FDAE-8098
   Serial number: 1708246603
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H15 0100
   Serial number: 000803150001007 Dataset Number: 8K0909104D  0025
   VCID: AF21101AF60E72E5AB-80FA
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000148314357
   Coding: 00581B00000000000000
   VCID: BB39344A3A769E4517-80EE
   Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
   Serial number: 0369617599 Dataset Number: 8K0909535J  0029
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: BFC1405A266E82653B-80EA
   Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0369128300
   Coding: 010211
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Revision: --------    Serial number: -------------- Dataset Number: 8K0909872H  0041
   Coding: 011C13204E00410001
   VCID: D6EF85FEA114632D08-8082
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0011804830 Dataset Number: 8K0909852L  0026
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: BE3F3D5E21648B6D30-80EA
   Revision: 00002001    Serial number: 0369008092     Dataset Number: 8K0909501Q  0026
   Coding: 0106063A00FE404781B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000994732
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS051  H08 0043
   Revision: 00005001    Serial number: 94813044147806 Dataset Number: 8K2909510B  0003
   VCID: AD1D0A12F40200F599-80F8
                    Reset counter: 161
                    Mileage: 110353 km
                    Date: 2025.12.17
                    Time: 10:54:25
                    Voltage: 14.20 V
                    Temperature: 1.0°C
                    Temperature: 2.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   Revision: --------    Serial number: -------------- Dataset Number: 8K0909873H  0041
   VCID: D5ED82F2BC12683501-8080
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000628511
   ROD: EV_ParkiBrake_AU48.rod
   Part No SW: 4G0 035 082 H    HW: 4G0 035 082
   Component: Radio U SIRIU H66 0138
   Revision: AB001007    Serial number: 156E20F8267356 Dataset Number: 8K2909454E  0026
   Coding: 020007010000000001
   VCID: A50DF232ACF238B551-80F0
   Part No SW: 8R1 035 746 K    HW: 8R1 035 746 G
   Component: H-BNT-NA      H43 1040
   Revision: --------    Serial number: 523ET0FB004170 Dataset Number: 8K0909545AE 0049
   Coding: 110200000206E1FF5502CF5E00000403140000000000000000
   VCID: BFC1405A2E6E82653B-80EA
   Subsystem 1 - Part No: 8R0 060 884 JE
   Component: NAR 2021/2022  2400
   Component: DU7 High  H42 0104
   Serial number: A130ES0F3357325
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000002241022
   Component: CD-Database  6208
                    Reset counter: 199
                    Mileage: 113051 km
                    Date: 2026.03.08
                    Time: 11:54:44
                    Text: ARU9471,,D,0,0,6
00658 - Control Head
                    Reset counter: 163
                    Mileage: 117953 km
                    Date: 2026.06.24
                    Time: 20:36:52
                    Voltage: 13.40 V
02244 - Button in Control Head is Stuck
                    Fault Frequency: 78
                    Reset counter: 178
                    Mileage: 119945 km
                    Date: 2026.09.05
                    Time: 13:14:12
                    Voltage: 14.30 V
                    Hex Value: 0x0002
                        not available
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Revision: --------    Serial number: -------------- Dataset Number: 8K0909875G  0038
   Coding: 010C13204000210001
   VCID: D9F58EC2D00A4C5525-808C
   Revision: --H09---    Serial number: 525PA8-JA391AX
   Coding: 1000006
   VCID: B8332B46CB40B55DFA-80EC
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Reset counter: 175
                    Mileage: 118819 km
                    Date: 2026.07.15
                    Time: 10:57:56
                        Reverse OFF
                    Count: 3
   Component: TSG HR        H08 0305
   Revision: --------    Serial number: -------------- Dataset Number: 8K0909874G  0038
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0006
   Serial number: 150515200592
   VCID: F2A7D96E25BC1F0D04-80A6
End----------(Elapsed Time: 01:54, VBatt start/end: 13.1V/13.1V)-----------
------------------------------6 Faults Found-------------------------------
Service 22 datasets at addresses 05, 09, 19, 42, 46, 47, 52, 56, 5F, 62, 72.
There's something to be said for keeping some older cars around. How many times have we wished we still had a B7 A4?
Corrected that for you :D
Except there's no "still". Sadly, we never has a B7 RS4. Bruce did have a 2006 B7 2.0T 6MT, and Shaun had a ~2008 for quite a few years.
