2010 S5 Cabriolet (DSG) losing communication with TCM
pmarseille
Canada
C?ID=406679
Hi, I own a 2010 S5 Cabriolet with the 3.0L and DSG transmission.
I have an intermittent problem with the TCU that stops communicating.
Problem occurs approx 20-30min after startup. ATF at around 40c.
Problem occurs while driving or parked on idle.
what's weird is when it happens, if I let the car run a few minutes, the TCM reconnects and I can scan it (see scan below). it goes on and off like that until I shut the car off to let it cool down. the next day, it takes another 20-30min to lose the communication for the first time. Looks like something is getting hot and breaks the com...
I did "backprobe" my T16R connector with a multimeter before and during the issues, everything is good, no change in voltage or ground. Can High and Low also show similar voltage to ground. I also have approx 50 omh resistance between Can wires.
Car is low mileage, never saw winter, no corrosion.
I checked the 16pin connector on transmission and it looks new.
I also checked water damage in Ebox and right trunk area, everything looks fine.
I checked a few relays including J329, the relay becomes kinda hot to the touch, like the accessory one in the trunk but I swapped it for a new one and it's the same.
Mecatronic internal circuit boards have been replaced 20000km ago (6 years) with latest revision OEM parts, was running fine until this summer.
I did park the car outside for about 2 months and it rained heavily, but no water ingress anywhere I can find.
I did a lot of troubleshooting using Chatgpt (I know it might sound stupid, but I'm impress by all the help I got)
I also found a few forum post with similar issues but no solutions.
Is there something I could check before replacing the TCM (might just swap it to 6mt haha..)
Thanks!
See attached Full Scan:
Monday,24,August,2026,20:39:40:47007
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN:    License Plate: APRES PANNE TCM COMMUNIQUE
Gateway Installation List:  8T0 907 468 AA
02-Auto Trans -- Status: Malfunction 1010
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 26 36 3C 42 46 47 52 53
          55 56 5F 62 6C 72
VIN: WAULGBFH7AN014027   Mileage: 96040km-59676miles
Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
   Component: 3.0T SIMOS84  H06 0003
   Revision: --H06---    CVN: BC966676
   Coding: 011C000A240F0128
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
   ROD: EV_ECM30TFS0218K0907551D.rod
   VCID: 323D1F49B4A4186A097-8066
   VINID: 9D195C5D25981D17800440021C26F2A90D
6088 - No Communication with Transmission Control Module
          U0101 00 [00100110] - -
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:07
                    Engine speed: 680.00 /min
                    Normed load value: 11.8 %
                    Coolant temperature: 88  C
                    Intake air temperature: 33  C
                    Voltage terminal 30: 14.218 V
                    Engine speed: actual: 704 /min
                    T_AST_ENVD: 1953.20 s
                    Gear: 0
                    Engine: operating status: IS
                    Battery voltage: 14.015625 V
                    Vehicle speed: actual: 0 km/h
Readiness: 1110 1001
   Part No SW: 8K0 927 156 M    HW: 0B5 927 156 E
   Component: 0B5 30TFSINAR H03 0007
   Revision: --H03---    Serial number: 0000001227 CVN: 00005EB1
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 3E253B7970FCCC0AFDF-806A
7993 - Powertrain Databus
          U0002 00 [00100110] - No Communications
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:06
                    Engine speed: 680 /min
                    Transmission input speed: 680 /min
                    Engine torque: 0 Nm
                    ATF temperature: 34  C
                    Accelerator pedal position: 0.0 %
                    Clutch status: Beide Kupplungen offen
   Part No SW: 8K0 907 379 AL    HW: 8K0 907 379 AL
   Component: ESP8 quattro  H04 0080
   Coding: 290500
   Shop #: WSC 02391 823 56573
   VCID: 03538A8D5B1E61E2D21-8056
                    Reset counter: 212
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:07
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x0026
                    Hex Value: 0x85B0
                    Hex Value: 0x00FF
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 212
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:07
                    Hex Value: 0x0000
                    Hex Value: 0x40A2
                    Hex Value: 0x002E
                    Hex Value: 0x02B0
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0326
   Coding: 0D0300
   Shop #: WSC 02399 823 56573
   VCID: 045189915E1066DAEBB-8050
   Serial number: 0209000083888010
                    Fault Status: 00101101
                    Reset counter: 252
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:37:37
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001010025887
   Coding: 00017025002C00000000
   VCID: 43D34A8D1B9EA1E2921-8016
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01021120090365
   Coding: 66132000
   VCID: 005985814A087AFACF3-8054
   Component: BCM1 1.0      H28 0380
   Revision: 10028001    Serial number: 00000000495642
   Coding: 26001017443CAF211400080300003D3D4F9C538800010161000000
   VCID: 3C2131716660DE1AD3B-8068
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 201009  H06 0021
   Serial number: SWF09100205052
   Coding: 00F511
   Component: RLS  H04 0003
   Serial number: 10651032
   Coding: 02562A
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002110091402
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
                    Reset counter: 252
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:00
03207 - Charisma Switch Module
                    Reset counter: 211
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:08:00
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940930204506
   Coding: 200102
   VCID: 3E253B79707CCC0AFDF-806A
Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
   Part No SW: 8F0 959 655 A    HW: 8F0 959 655 A
   Component: AirbagVW-AU10 H10 0430
   Serial number: 003A5D060TE.   Dataset Number: 8F0909602B0020
   Coding: 30383735363130303030554A304C38463053
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 3635235958CC044A25F-8062
   Serial number: 6334MSME4C554D5CX
   Serial number: 6344MSME4A461567H
   Serial number: 6352QSME5C3F2418R
   Serial number: 6362QSME653F4B26U
   Serial number: 63732SME183F200A
   Serial number: 63832SME29421C22Y
   Revision: --------    Serial number: 90319IJT0000C
   Coding: 000036
   VCID: 3D273C757D7AD712E45-8068
   Part No SW: 8T0 920 931 E    HW: 8T0 920 931 E
   Component: KOMBIINSTR.   H34 0255
   Revision: 00000000    Serial number: CI343YVA9
   Coding: 8B0719000A000008020000
   VCID: 392F28656952EB32C8D-806C
   Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0105
   Revision: FB900055    Serial number: 5500F09A2300F5
   Coding: 00C303
   Component: J367-BDM  H06 0170
   Serial number: 19097826231009
                    Reset counter: 252
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:07
                    Bin. Bits:    11111
                    Voltage: 14.10 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 25.40 s
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H09 0170
   Coding: 030000
   ASAM Dataset: EV_ElectRoofContr 001007
   ROD: EV_ElectRoofContr.rod
   VCID: 71BFD0457122637230D-8024
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010026002
   Coding: 00197B25002C00000000
Address 3C: Lane Change        Labels: 8K0-907-566.clb
   Part No SW: 8K0 907 566 F    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0010
   Revision: 00H01000    Serial number: 6PZ 009 014-19
   Coding: 0000005
   VCID: 3A2D37696054E02AC17-806E
   Subsystem 1 - Part No: 8K0 907 568 F
   Component: J0770_SWA_Slave_H01 0010
   Subsystem 2 - Serial number: 6PZ 009 014-39
   Subsystem 3 - Serial number: 5F25.09.0900H010003CR10996
   Subsystem 4 - Serial number: R10996
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009547502
   Coding: 011C53724E08332C03
   VCID: 45D7549515AA9FD2BC5-8010
   Revision: 00002001    Serial number: 0122865983
   Coding: 010602BA007A442100B0033200000000
   Shop #: WSC 94753 999 57361
   Subsystem 1 - Part No SW: 8F0 959 719     HW: 8F0 959 719
   Component: GTO BF  H06 0050
   Serial number: 00000000000000181105
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 211
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:08:18
                    Reset counter: 252
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:37:37
   Part No SW: 8F0 035 223 D    HW: 8F0 035 223 C
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34863000127402
   VCID: 211FE005E1C293F2E0D-8074
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009585390
   Coding: 011C53324E08332C03
   VCID: 44D149911E90A6DAABB-8010
   Revision: 00000003    Serial number: 10000000352313
   VCID: 343119514E30165A1BB-8060
                    Reset counter: 252
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:25:07
                    Voltage: 14.40 V
                    Count: 66
                    Hex Value: 0x0263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 A    HW: 8H0 907 357
   Coding: 0000017
   VCID: 30391541B6282A7A7F3-8064
   Subsystem 1 - Part No: 7L6 941 329 C
   Component: AFS-Modul links H01 0004
   Subsystem 2 - Part No: 7L6 941 329 C
   Component: AFS-Modul rechtsH01 0004
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335J$097536283
   Coding: 020000010000000101
   VCID: 1D67DCF5DDBAB712C45-8048
   Part No SW: 8T1 035 664 F    HW: 8T1 035 664 B
   Component: H-BN-NA       H45 0189
   Revision: --------    Serial number: 490J+097531909
   Coding: 010200030206C1EF55000F0E000000010000
   VCID: 3B23326D636ED922DA1-806E
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000386411
   Subsystem 3 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 211
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:08:19
                    Voltage: 14.50 V
                    Bin. Bits:       10
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 211
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:08:20
                    Voltage: 14.50 V
                    Fault Status: 01101000
                    Reset counter: 211
                    Mileage: 96046 km
                    Date: 2026.08.24
                    Time: 20:08:20
                    Voltage: 14.50 V
   Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
   Revision:             Serial number: 0000102177145
   Coding: 010C13324008372C03
   Part No SW: 8F0 907 441     HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J99B09H
   Coding: 1000009
   VCID: 678BBE1D4366ADC26E9-8032
   Revision:             Serial number: 0000102177138
End----------(Elapsed Time: 01:58, VBatt start/end: 14.6V/14.5V)-----------
------------------------------14 Faults Found------------------------------
an earlier Scan also reported some other voltage error like on terminal 15:
Sunday,02,August,2026,11:57:59:47007
          55 56 5F 62 6C 72
          U0101 00 [10101100] - -
                    Fault Frequency: 14
                    Mileage: 96042 km
                    Date: 2009.06.26
                    Time: 00:17:12
                    Engine speed: 0.00 /min
                    Coolant temperature: 93  C
                    Voltage terminal 30: 12.085 V
                    Engine speed: actual: 2048 /min
                    T_AST_ENVD: 282.70 s
                    Gear: 3
                    Engine: operating status: PL
                    Vehicle speed: actual: 40 km/h
6506 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [01100101] - -
                    Mileage: 96046 km
                    Date: 2009.06.26
                    Time: 00:29:01
                    Engine speed: 1158.00 /min
                    Normed load value: 6.3 %
                    Vehicle speed: 41 km/h
                    Coolant temperature: 99  C
                    Voltage terminal 30: 14.116 V
                    Engine speed: actual: 992 /min
                    MAF_ENVD: 125.28235 mg/stroke
                    Coolant temperature (unfiltered): 97.5  C
                    Engine load: 16.015625 %
                    Vehicle speed: actual: 25 km/h
Readiness: 0010 1100
7969 - Signal Line for Tiptronic
          P1890 00 [00100000] - Electrical Malfunction
                    Mileage: 96042 km
                    Date: 2009.06.26
                    Time: 00:09:54
                    Engine speed: 1965 /min
                    Transmission input speed: 1965 /min
                    Engine torque: -52 Nm
                    ATF temperature: 38  C
9723 - Shift Lock Solenoid (N110)
          P1761 00 [00100000] - Short to Ground
                    Mileage: 96042 km
                    Date: 2009.06.26
                    Time: 00:09:54
7971 - Transmission Control Unit
          P1701 00 [00101100] - Locked
                    Mileage: 96042 km
                    Date: 2009.06.26
                    Time: 00:15:32
                    Engine speed: 1016 /min
                    Transmission input speed: 1016 /min
                    Engine torque: 20 Nm
                    ATF temperature: 44  C
          U0002 00 [10101100] - No Communications
                    Fault Frequency: 14
                    Mileage: 96041 km
                    Date: 2009.06.26
                    Time: 00:09:05
                    Engine speed: 1398 /min
                    Transmission input speed: 1398 /min
                    Transmission output speed: 477 /min
                    Engine torque: 0 Nm
                    Accelerator pedal position: 25.2 %
                    Clutch status: Kupplung 2 kann Moment  bertragen
8463 - Supply Voltage: Terminal 15
          P1758 00 [00100000] - Open Circuit
                    Mileage: 96042 km
                    Date: 2009.06.26
                    Time: 00:09:54
   Coding: 290500
                    Reset counter: 247
                    Mileage: 96041 km
                    Date: 2009.06.26
                    Time: 00:09:05
                    Hex Value: 0x3900
                    Hex Value: 0x4006
                    Hex Value: 0x1226
                    Hex Value: 0x85B0
                    Hex Value: 0x00FF
                    Reset counter: 247
                    Mileage: 96041 km
                    Date: 2009.06.26
                    Time: 00:09:05
                    Hex Value: 0x3900
                    Hex Value: 0x4006
                    Hex Value: 0x122E
                    Hex Value: 0x02B0
                    Hex Value: 0x00FF
   Coding: 0D0300
   Subsystem 1 - Part No SW: 8T0 959 754 S    HW: 8T0 959 754 S
   Component: FBSAUDIB8 IDG  H38 0060
   Serial number: 0509000059230020
                    Reset counter: 247
                    Mileage: 96046 km
                    Date: 2009.06.26
                    Time: 00:29:09
   Coding: 66132000
                    Reset counter: 247
                    Mileage: 96040 km
                    Date: 2009.06.26
                    Time: 00:02:27
   Coding: 00F511
   Coding: 02562A
                    Reset counter: 247
                    Mileage: 96041 km
                    Date: 2009.06.26
                    Time: 00:09:00
                    Reset counter: 206
                    Mileage: 96039 km
                    Date: 2026.06.28
                    Time: 20:39:00
   Coding: 200102
   Coding: 000036
   Coding: 00C303
                    Fault Frequency: 14
                    Reset counter: 247
                    Mileage: 96041 km
                    Date: 2026.07.28
                    Time: 15:41:55
                    Bin. Bits:    00000
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.40 s
   Coding: 030000
   Coding: 0000005
            014 - Defective
                    Reset counter: 206
                    Mileage: 96039 km
                    Date: 2026.06.28
                    Time: 20:40:02
                    Reset counter: 247
                    Mileage: 96046 km
                    Date: 2009.06.26
                    Time: 00:29:09
                    Fault Frequency: 13
                    Reset counter: 247
                    Mileage: 96041 km
                    Date: 2009.06.26
                    Time: 00:09:05
                    Voltage: 14.40 V
                    Count: 66
                    Speed: 56.0 km/h
                    Hex Value: 0x0260
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Coding: 0000017
00658 - Control Head
                    Reset counter: 247
                    Mileage: 96041 km
                    Date: 2026.06.28
                    Time: 20:50:48
                    Voltage: 12.80 V
                    Reset counter: 206
                    Mileage: 96041 km
                    Date: 2026.07.28
                    Time: 14:58:22
                    Voltage: 12.30 V
                    Bin. Bits:      001
                    Reset counter: 206
                    Mileage: 96039 km
                    Date: 2026.06.28
                    Time: 20:39:58
                    Voltage: 14.50 V
                    Bin. Bits:       10
                    Reset counter: 207
                    Mileage: 96041 km
                    Date: 2026.07.28
                    Time: 14:46:01
                    Voltage: 12.90 V
                    Reset counter: 207
                    Mileage: 96039 km
                    Date: 2026.06.28
                    Time: 20:40:04
                    Voltage: 14.50 V
   Coding: 1000009
End----------(Elapsed Time: 02:00, VBatt start/end: 12.4V/12.4V)-----------
------------------------------22 Faults Found------------------------------
Ziddywerks
Northern NJ USA
C?ID=208579
Was the fuse checked? SB1 on ST1 fuse block location? Was TCM connector inspected for coolant ingress? Those are 2 basic steps that should be done to start. Also verify power and ground at TCM connector. After that you can check both can lines at same connector.
pmarseille
Canada
C?ID=406679
Fuse is good on ST1, constant voltage is also good at the connector.
TCM connector (T16r) is clean as new, no trace of coolant or oil.
Power and ground are good on the TCM connector.
My 50 omh reading on the can wires are from the connector.
Ziddywerks
Northern NJ USA
C?ID=208579
Not worried about the resistance on those wires. I would take a voltage measurement on can high and can low to see if there is voltage there and post those results here.
pmarseille
Canada
C?ID=406679
Measuring from can wire to ground: Can High 2.73V, Can low 2.39V
Readings are almost identical when the TCM is communicating and not
pmarseille
Canada
C?ID=406679
BTW, those measurements were taken with "backprobe" on the TCM connector plugged in.
Not related but it was my first time using my Quickjack and wow, way better than using a 3ton jack and jack stands!
