- Oct 20, 2019
- 17
- 4
- New Zealand
- C?ID=428598
Hi Team. Need help please
Was driving today, floored it at the red light for about 100m when I heard a clutter coming from the front. Slowed down and opened the window to hear it. When I increased speed the clutter would come back but when I slowed down the clutter went away. The next moment the car just died. Pulled over with the momentum.
Tried starting the car but it was like when you broke a timing belt, like it is stuck with just dim dash and motor trying to turn.
I still don’t think it is the timing belt. At one point the starter tried to turn the engine but stopped after a couple of turns. I think my starter ben-dicks got stuck on the ring gear and I've burned out the starter and that is preventing the motor to turn. I will look tomorrow morning by removing the spark plugs and looking into the sleeves to see if I can see broken pistons or bend/broken valves with a pipe camera. There is no water in the oil and also no oil in the water.
Any who....here is my scan
Wednesday,26,August,2026,05:05:11:05001
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.4
VIN: WAUZZZ8V7G1056648 License Plate: QED977
Mileage: 122074km-75853mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 42 44 52 55 57 5F
6C A9 BB BC
VIN: WAUZZZ8V7G1056648 Mileage: 122074km-75853miles
Address 01: Engine (J623-CJXF) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: AA90C353
Coding: 0A1D00122466010B3000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259F 001004
ROD: EV_ECM20TFS0208V0906259F.rod
VCID: 43D344A69B14E082921-8016
VINID: 9D196AAAA2261D7040146184206F9A11FB
16452 - Implausible Data Received from ESP Control Module
U0416 00 [00100110] - -
Mileage: 122074 km
Date: 2026.08.26
Time: 16:56:45
Engine speed: 0.00 /min
Coolant temperature: 26 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.109 V
Engine: operating status: ES
PV: 0.00 %
T_IGK: 2.35 s
Drivetrain coordinator: brake fault status-ESP system malfunction: No
15077 - Idle Control System RPM
P0507 00 [01100000] - Higher than Expected.
15282 - Starter Will Not Turn
P3054 00 [10100111] - Jammed or Electrical Malfunction
Fault Frequency: 14
Mileage: 122074 km
Date: 2026.08.26
Time: 14:21:30
Coolant temperature: 87 °C
Intake air temperature: 25 °C
Voltage terminal 30: 7.871 V
STATE_LS_SAE[1]: INI
T_AST_SAE: 263 s
MAP_MES_SAE: 102 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.119 V
FAC_TPS_1_SAE: 15.625000 %
FUP_H_SAE: 11940.0 kPa
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4912
Revision: 06253104 Serial number: TFK01510011175 CVN: 0000A93D
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 53F374E66B747002221-8006
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 62745000001067
Coding: 31F193A254252A72017D070441CB698CC92A5480E08296F6184150040208
VCID: 7AADF942AC5E614A817-802E
0213 - Vacuum sensor
C10A3 29 [00001000] - Signal Implausible
[Single Vacuum Pressure Sensor sends no valid data]
Reset counter: 96
Mileage: 122074 km
Date: 2026.08.26
Time: 16:56:46
Revision: 00021000 Serial number: 0383511756 Dataset Number: 8V0909577C 0009
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_002_AU37.rod
VCID: 3A2D3942ECDEA14AC17-806E
Part No SW: 8V0 820 043 C HW: 8V0 820 043 C
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000774055
Coding: 03100004110000011000000000001500
VCID: 323D116234AE590A097-8066
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: FAF844D7000000000001
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061528800534 Dataset Number: 8V0909514M 0091
Coding: 07051C42C24106FD05804004B10007A8080E000000000000000000000000
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 015F8EAEC1883292C0D-8054
Subsystem 1 - Part No SW: 8V2 955 119 C HW: 8V2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150821 042 0585
Serial number: 151028101828
Coding: 0A47F7
Component: G397_RLFS H06 0004
Serial number: 20805880
Coding: 1EA86C
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Serial number: 27 07 2015 00000673
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY152510W4M
Component: Sirene, DWA 005 0312
Serial number: 00000000000033476710
204546 - Remote key 2
B147A 18 [00001000] - Current Too Low
Reset counter: 57
Mileage: 121179 km
Date: 2026.07.27
Time: 05:46:04
Terminal 15 status: OFF
Terminal 50 status: OFF
CAN-Bus_aktiv: OFF
OFF: Not operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 12.7 V
Outside temperature: 4.5 °C
526359 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:38
Terminal 15 status: On
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 11.9 V
Outside temperature: 2.5 °C
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391529406119 Dataset Number: 8V0909526E 0042
Coding: 0070150011
ROD: EV_EPHVA18AU3700000_002_AU37.rod
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 22101503072378 Dataset Number: 8V0909863D 0016
Coding: 023E1301FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46D55DB2A826D5AAB5F-8012
Part No SW: 5Q0 959 655 AB HW: 5Q0 959 655 AB
Component: AirbagVW20 015 0388
Serial number: 003MMR16ZY0L Dataset Number: 8V0909602D 0009
Coding: 98FCC0000C0000005C54000000C800000065
VCID: 00598BAACA823B9ACF3-8054
Subsystem 1 - Part No SW: ----------- HW: 480 001 610 15
Serial number: 35767000000BA921671W
Subsystem 2 - Part No SW: ----------- HW: 480 001 610 15
Serial number: 3586700000078921671R
Subsystem 3 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 35165029B1CF1D20D21G
Subsystem 4 - Part No SW: ----------- HW: 480 402 010 15
Serial number: 3526502A91CF1D13F2AT
Subsystem 5 - Part No SW: ----------- HW: 480 401 708 15
Serial number: 3556502B71D1B6236337
Subsystem 6 - Part No SW: ----------- HW: 480 400 505 15
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B91A87872307C
Subsystem 7 - Part No SW: ----------- HW: 480 400 505 15
Component: PedP_Sensor_P 001 6149
Serial number: 2296502AD1A87874829R
Subsystem 8 - Part No SW: ----------- HW: 480 002 809 15
Serial number: I0M80000000EBA61661H
Subsystem 9 - Part No SW: ----------- HW: 480 002 809 15
Serial number: I0N8000000070A616610
Part No SW: 8V0 953 521 FK HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 31101504400953
Coding: E018
ASAM Dataset: EV_SMLSKLOMQB 020001
VCID: 0849938AE2B203DA873-805C
Part No SW: 8V0 920 872 D HW: 8V0 920 872 D
Component: KOMBI H03 6420
Coding: 23AD181A2E80000C0181EA001000000000000000
VCID: 3E253552F0F68D6AFDF-806A
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 21101510803584 Dataset Number: 8V0909515K 0065
Coding: 030100043F085A005B0002781C0B00000001010000000000000000000000
GVL: 01D43C1000000600400C90000002C80000000000000000000000000000000000
ROD: EV_GatewConti_013_AU37.rod
VCID: 79AFE64EA9586A5288D-802C
Generator:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 01 10 2015 D0006752
Subsystem 3 - Part No SW: 5Q0 915 181 H HW: 5Q0 915 181 H
Component: J367-BDMConti H02 1011
Serial number: 74185704001511041924
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Serial number: HA1-00010.09.15 Dataset Number: v1260x015G0 0000
Coding: 0001
VCID: 4ACD6982BC3E31CA517-801E
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000237329005
Coding: 5D00000000000000
VCID: 3431177ACEBA573A1BB-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-DCD-V1.clb
Component: TSG FS 020 0041
Serial number: 140715BGD04956 Dataset Number: 8V0909872G 0036
Coding: 001C1A205C01040000001003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
65650 - Turn Signal in Exterior Mirror
B11FD 13 [00001000] - Open Circuit
Reset counter: 88
Mileage: 121988 km
Date: 2026.08.22
Time: 10:02:21
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Dataset Number: 8V0909852K 0022
Coding: 8103
VCID: 392F264EE9D8AA52C8D-806C
Component: TSG BFS 020 0041
Serial number: 300715BGU06621 Dataset Number: 8V0909873G 0036
Coding: 001C12205E01040000001003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 42DD41A2840EE98A997-8016
Reset counter: 89
Mileage: 121991 km
Date: 2026.08.22
Time: 11:05:59
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Revision: -------- Serial number: -------------- Dataset Number: 8V0909865L 0039
Coding: 01AE00002B200200
VCID: 3FDB4856F7FC8462F69-806A
Coding: E00100
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 57: TV Tuner (R78) Labels:| 8V0-919-DTV-V1.clb
Part No SW: 8V0 919 129 B HW: 8V0 919 129 B
Component: JP-DTV H11 1360
Coding: 01011C0000000100000000
ASAM Dataset: EV_TVMELC 001033
ROD: EV_TVMELC_VW37.rod
Part No SW: 8V0 035 034 N HW: 8V0 035 034 D
Component: MU-H-TN-JP 044 0271
Serial number: K5F AW7HZ0499P Dataset Number: 8V2909545K 0048
Coding: 01730106FF0A000021330001001200102F000226010001007E
ASAM Dataset: EV_MUHig6C3AW7 001115
ROD: EV_MUHig6C3AW7.rod
VCID: 3B233C46E3E49842DA1-806E
Subsystem 1 - Part No SW: V03 959 802 FC HW: -----------
Component: JPN 2018/2019 --- 8011
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9FY2047KM
Subsystem 3 - Part No SW: 8V0 919 614 AA HW: 8V0 919 614 AA
Component: ControlUnit_H H81 0816
Serial number: C1000022081500020027
Compact disc data bank:
Component: Gracenote --- 2009
13 Faults Found:
1584 - invalid data record
B2005 00 [00001001] - -
[Control module (data record download) - invalid data record for DTCP]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
Voltage terminal 30: 12.0 V
1585 - invalid data record
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
1586 - invalid data record
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
Voltage terminal 30: 12.1 V
1587 - invalid data record
[Control module (data record download) - invalid data record for language]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
1588 - invalid data record
[Control module (data record download) - invalid data record for visible MMI system languages]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
1589 - invalid data record
[Control module (data record download) - invalid data record for power management timer]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
1590 - invalid data record
[Control module (data record download) - invalid data record for sound audio parameters]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
1593 - invalid data record
[Control module (data record download) - invalid data record for enhanced audio sound parameters]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:40
1592 - invalid data record
[Control module (data record download) - invalid data record for DAB frequency tables]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:41
1595 - invalid data record
[Control module (data record download) - invalid data record for audio management HMI constants]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:41
1591 - invalid data record
[Control module (data record download) - invalid data record for telephone audio parameters]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:41
1605 - invalid data record
[Control module (data record download) - invalid data record for voice recognition audio parameters]
Reset counter: 239
Mileage: 121170 km
Date: 2026.07.27
Time: 05:31:41
2570 - Control Module for Smart Card Reader
B128F 31 [00001001] - No Signal
Reset counter: 240
Mileage: 121179 km
Date: 2026.07.27
Time: 13:29:48
Voltage terminal 30: 14.9 V
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Dataset Number: 8V0909460C 0017
Coding: 027300060201000300
ROD: EV_2CamSysRearPASE.rod
VCID: 30391B6A3AA26B1A7F3-8064
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150912200029
VCID: 7DA7F25EBD705672A45-8028
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V1.clb
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 010815BGV04185 Dataset Number: 8V0909897E 0022
Coding: 000C12204001040000001002
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V1.clb
Component: TSG HBFS 020 0041
Serial number: 010815BGV04182 Dataset Number: 8V0909896E 0022
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End----------(Elapsed Time: 02:00, VBatt start/end: 12.1V/12.0V)-----------
------------------------------21 Faults Found------------------------------
