Redneck Rigging
   #41
RGH0
Australia
C?ID=433612
From looking at a few videos it appears the plate is not supposed to be fixed to the cross bar underneath and thus it should "just fall off" Have tried just pully / hammering on / levering on just the plate and not the cross bar ? The cross bar itself has the tapered spline onto the shaft and that will be harder to remove but if the cross plate comes off first at least it will be more accessible
   #42
Bruce
Near Philadelphia, PA, USA
The plate is welded to the crossbar. To cut the welds would be next to impossible owing to space. I suppose if we were wild and crazy, we could cut the plate away from the crossbar, which is the piece that slide up the splined spindle.
I know the style of design to which your refer. This is not that style. Stump jumper plate and the crossbar are one part...
   #43
BlueR32
C?ID=58325
Have you tried unthreading it from the center hub... ;)
   #44
RGH0
Australia
C?ID=433612
Do you suspect welding it to the cross bar was a modification someone did and not original ?
   #45
Bruce
The welding to cross bar is part of design of this unit. Lots of units are made this way.
The cross bar with the pan and the splined collar are pressed onto the splined shaft. We spoke with our dealer and he said he just beats the unit off with a piece of pipe and sledge hammer. There is an access hole in the top of the mower deck from which one can beat on the pan/crossbar.
We tried the beating method. No Joy.
   #46
Mats@MFT
C?ID=56967
...Uwe holds the pipe while you´re hammering????
   #47
Boki Ar
Arandjelovac, Serbia
C?ID=57300
If the "stump jumper" has ever hit a stump, rock or heavy roots, it creates an extreme torsional impact (twisting force).
Under this impact, the grooves of the inner hub of the blade plate twist slightly and dig into the grooves of the gearbox shaft.
The assembly then behaves as if it were welded, very stuck.
   #48
Bruce
Sometimes... and then when I get tired, we change positions.. so even opportunity for attitude corrections. :D
Oh yes, we have hit stumps, rocks and telco (telephone company) boxes... so yes, I think you may indeed have hit on the problem Boki...
Its built to take a beating and when learning new land, it does get beat. Now that we know the land and have removed most of the hazards, its pretty rare we get on such. It still occasionally happens when cutting brush.
That said, this red brush hog is moving into more mowing duty than brush cutting duty now that we have Skidder (our tracked skid steer) with his two heavy duty brush mowers. These HD cutters are both built very different than this low cost brush mower. Skidder is the right machine for clearing heavy brush in the woods.
We want the red brush cutter because mowing cleared land is much easier on a tractor than on a tracked skid steer. Could it be done with Skidder? Sure. It will take more time. Time here is precious. We do not have all the hours we would like to have to play in the woods!
   #49
Fixit
Michigan, USA
C?ID=506336
I wonder if there is a thread on this "circle" on the plate for a suitable tool? :confused:
Along those lines ^^^^
Do you have access to pipe, tubing or even a steel pipe coupling and a large threaded nut and bolt? Weld the nut to the tube and then the tube to the plate and crank the bolt down. The heat from welding the tube to the plate will assist in getting it off. Once off just grind the tube off the plate.
   #50
No drawings. No part explosion. Nothing more.
Well, you also didn't provide me with what I asked for, so I can only guess as a result.
Mahindra does have all that info available, but you need to know what you're looking for in order to search.
   #51
Boki Ar
C?ID=57300
In addition to @Fixit good idea (that I thought of too), here's another trick that's guaranteed to make the thing come apart right away: thermal shock.
While the outer ring/plate is still hot from the welding process, immediately take some freeze spray (a rust remover that freezes) and apply it strictly to the center of the gear shaft. I've also used CO2 from a fire extinguisher for this a few times - it works wonders.
This will cause the splined shaft to contract slightly from the extreme cold, while the welded ring remains expanded from the heat. This temperature difference should immediately break the bond and lock created by those twisted splines. Then just tighten that bolt!
If it's still sticking after that, a vibration while the bolt is under tension is guaranteed to do the job.
I also like that idea with the two screws from above.
   #52
Bruce
@SaVAGeSoot - real close to our machine. The collar and wings off the collar are different. There is a flat bar welded to the collar, the pan is welded to the flat bar. The bar extends to the rotating blade holes to support those super heavy blades.
As I reported earlier, the manual had no parts diagrams. The unit we have is not a Mahindra made unit. it is a rebranded unit... and I need to get the name of the manufacturer.
Still, your drawing describes closely what we have.
   #53
Bruce
@SaVAGeSoot the machine is a Kodiak made by Paladin.. no model shown on the manual... so later I will have to go pull from the serial plate if still readable. 60" cutter.. about 8 years old... maybe a little older.. no more than 10. I'm guessing we are pushing 500 hours on the machine.
   #55
Bruce
To end this thread, we gave it 3 more days. We let the oil soak, we kept the tension on, we beat it regularly, we heated it. NO JOY! The parts have joined the collective and become one!
This means a gear box fail makes the machine junk. So, on to plan -- I've stopped counting. Do you even remember why we were trying to get the stump jumper off? Right, to tighten 4 bolts holding the gear box. We resorted to the finest redneck engineering and butchering and now have a running brush hog:
