Redneck Rigging
   #21
@Bruce
While under load with your current set up,
How about driving some wedges on each side of that plate ; and once under that plate drive them deeper near the shaft. Not sure what you would use for wedges ; some pry bars perhaps? Tire change bars?
Here is another technique with the Push bolts! (and heat).
Time ~ 9:00 - 12:00...... (Surprise at 11:59!).
Apendiixator
Czech Republic
C?ID=569308
We left tension on it overnight. This morning we brought out the torch we inherited a while back. Increased the tension as much as felt safe before applying heat:
No joy.
heating to high temperature is a good way. As soon as the metal glows red, cool it with a strong and copious stream of water. for example from a bucket. And then the connection will be enabled
   #23
Bruce
Near Philadelphia, PA, USA
Yep been there. Done that. We have photos! if I get a chance I'll edit this post and add the photos. No joy.
Trust us when we say, this thing is really stuck. We're about to give up and we plans for how we can tighten the bolts that hold the gear box on. However, that will be a one fix. If the box blows up, we will not be able to replace it. We will end buggering the threads to tighten the nuts.
Why they did not tack weld the heads of the bolts when building this thing is beyond my understanding. And why they did nothing to prevent the seizing of the collar to the spline is beyond me.
   #25
OK, how about the push bolt set up and HEAT! I think that would be a bit more positive than the wedges and load even more force. (you have oxy/acetylene). But, those are going to have to be some large diameter bolts! 1" plus.
   #26
Apendiixator
Czech Republic
C?ID=569308
Yes, I think the method from post #18 has the greatest potential. But after maximum heating, it must also be followed by rapid cooling with water (or liquid nitrogen :-)). Do not hesitate to repeat this change of state several times. The result must come. I keep my fingers crossed
   #27
No joy.
You're doing it wrong!
Heat the HUB on the inside of that disk.
Heat expands metal..... right now, you're giving the shaft more girth, thus making it even more of an interference fit!
   #28
That push bolt(s) technique will develop far more force (and safer) than that drive screw -bar-chain could ever deliver. Sure the bolts and the wrench are going to cost you some $$$$, but that technique alone with the heat will do it.
   #29
NZDubNurd
New Zealand
C?ID=230482
Can you get a long punch/drift in the side, to hit around the hub, on all sides? That may help loosen it up a touch or if you can do it hard enough, stretch the hub microscopically.
Sometimes a centre punch can create enough stress in a small area too - enough to break a rust seal, if that's what's making it stick.
If you're REALLY lucky; it'll be one of those things that you decide to go have a break before you set fire to the whole thing and when you come back, it's fallen off :D
   #30
I don't have any bolts like that, but did like this guy's technique of heating it from behind. We have a bit less clearance between the plate and the deck, which makes it a bit fidgety getting the flame from the torch pointed the right way, but we did just try that while everything was under tension from the puller. No joy yet.
Yeah, we were hoping for that overnight last night; that all the Kroil we had applied would work its way in there, and we'd wake up with it off. Needless to say, that didn't happen.
We are literally in the middle of nowhere in Appalachia. Liquid nitrogen does not grow on trees. :D
Boki Ar
Arandjelovac, Serbia
C?ID=57300
I believe you applied it tonight as well, let it stand all night. I hope it will help.
I can't translate "Srećan rad!" exactly, but I wish you success in removing that "plate". "Happy wrenching!", Good luck! :thumbs:
I think you'll have to go with the wedge technique, but you need to get the wedging closer to the shaft; perhaps some tire irons / spoons for a base, then some smaller degree wedges placed on top of the bars ; you can then drive/hammer them in with a long punch/drift ; then same 180 degrees on the opposite side. Then, under that tension pour on the heat.
   #34
Apendiixator
Czech Republic
C?ID=569308
My first job was in a company that had equipment for land reclamation work. Heavy work loads, excavators, extreme terrain, extreme conditions. I often wanted to give up on jobs similar to the one in Uwe's post... Then an older workshop foreman came with a torch, a hammer and a bucket of water :-) Miracles happened everywhere. The workshop foreman said: "there is no joint that you would not open with this equipment"
It's been a long time... they paid me really poorly, but when I think back on that experience, it makes me very rich.:)
RGH0
Australia
C?ID=433612
For some more redneck rigging you could try drilling some holes near the hub and using jacking bolts provided there us something solid for them to bear on i.e. the gear box / bearing housing. Heat the hub but keep it off the shaft as best you can and then spray the shaft with freeze spray while you have tension on the the jacking bolts. Repeat the heat and freeze cycle a few times. Use a hammer (ideally a air hammer or electric hammer) on the shaft end while doing that.
They all eventually give up.
   #36
RGH0
Australia
C?ID=433612
In the end if it still refuses to surrender nicely take the oxy and cut off the disk so you can access the hub more directly and then remove the hub with a pulley and / or grinder. You then need a new disk / hub but given how badly its rusted on that may not be a bad idea
   #37
Nah, we won't go to that extreme.
At some point here, I'll explain why we want to take that blade-carrier disk (a.k.a. "Stump Jumper") off, but not tonight. There is a Plan C that will solve the problem without removing the stubborn disk, but we wanted to avoid that because it would make other future servicing much more difficult.
This is a Stumpjumper (06).... just to be clear :p (although, I've probably done more crashing with it than jumping....)
30712
  • Haha
Boki Ar
C?ID=57300
I wonder if there is a thread on this "circle" on the plate for a suitable tool? :confused:
   #40
Bruce
What's the model of that deck\attachment?
There should be manuals or diagrams of the parts floating around on the net.
Reference post #11....
Today while doing another project as we are tired of fighting the brush hog, we found the manual. We looked to see what they suggest.
"Remove the castle nut and the plate will just fall off. If not, thread the castle nut on the end of the spindle and then strike it with a hammer a couple of times. It should just fall off."
No drawings. No part explosion. Nothing more.
FYI - turning the castle nut and playing whack-a-fool was step #1 back in June when we first started this madness. We need the cutter in a little over 2 weeks to do our Fall mowing.
No matter, it will be fixed so that we can use it. Just not fixed as we want to be.
