Bah. There are two separate chains holding it in place; the one to the tractor bucket that stood it up, and a second one wrapped around the trees. It's not going anywhere.STAND - CLEAR !!!![]()
yes and no... its not intended as a cage.. it is just to hold a light piece of crap for a roof. The sun on the open station was too much for this fat old bear who would be out there for 10 hours mowing the field. So, redneck engineering came up with a low cost solution. The ROPS is always up on this property because there is very little level land and this one is a wuss and even wears his safety belt most of the time.Is that a PVC cabin cage you've got going on over there?
I'm skeptical that I'd be able to find a bearing splitter big enough, and all the hydraulic bearing pullers I've seen have three arms at 120°. The problem is that plate is only about 1/4" thick and about 24" in diameter. I'm confident it would bend or crack if that kind of force was applied anywhere except at the 180° locations where the blades you can see in the first pic attach. The plate has got a big, strong stiffener bar under it there. Hence the style of puller we're trying to use. Sadly, the arms that came with with the puller would not fit through those holes, which is why we're using that small length of chain.I would use a big bearing splitter with a hydraulic bearing puller to get the force needed
Sadly, no. We have of course tried beating on things with a 3-lb hammer while applying tension with the puller.Do you have a vibrating impact hammer in your toolbox, electric or air?
I'm not sure what real difference it makes whether it's tapered or not? The "stump jumper" plate is definitely on a splined shaft, and what holds it on there is a castle nut with a cotter pin. In principle, it should come right off once that nut has been removed. In reality that hardly ever happens. There's a shipload of vids on YT showing techniques people use to get these off, and I think we've tried just about all of them.You could use those to confirm that it is a taper that you're dealing with before going into ape mode.
No joy.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
