- Apr 29, 2026
- 12
- 6
- Tampa, FL, USA
- C?ID=448217
Hello all,
I have a client here with a 2012 Audi R8 and the convertible top is not happy. He opened it, and it would not close. The cluster would give the "Convertible top not working" or whatever generic warning.
Upon scanning, the Auto top shows no codes, but if I look at the switch list, I see one is showing a fault. I can't find anything online when searching for the numbers associated with the fault.
Here's a full auto scan, and also a separate listing of the switch at fault. I have found that the rear window/windbreak won't roll up. At this point, I am assuming there's maybe an issue with the actual window switch in the center console.
Thoughts before I start tearing everything apart?
Thank you
Thank you
Tuesday,25,August,2026,15:51:42:09044
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4701.5
VIN: WUATNAFG3CN002649 License Plate:
Mileage: 42160km-26197mi Repair Order:
Chassis Type: FG-AU35 (7N0)
Scan: 01 03 08 09 0F 10 11 31 14 15 16 17 19 25 26 37 42 46 47 52
56 61 65 6C 77 A6
VIN: WUATNAFG3CN002649 Mileage: 42160km-26197miles
37-Navigation -- Status: Cannot be reached 1100
A6-Microphone -- Status: Cannot be reached 1100
Address 01: Engine (BUJ) Labels:. 07L-910-552-BUJ1.clb
Part No SW: 424 910 552 M HW: 420 907 552 B
Component: 5.2L V10HDZ/4V F ª0010
Revision: F5H10--- Serial number: AUX7Z0L4FNA07Z
Coding: 01100009180F0120
Shop #: WSC 66565 257 00032
VCID: 1D6CB02E01B3FBA2C45-8048
VINID: 9E54647915970D378000218424925CA705
001110 - EVAP System
P0456 - 001 - Very Small Leak Detected - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 42079 km
Date: 2026.08.08
Time: 13:31:07
RPM: 1405 /min
Load: 21.6 %
Speed: 9.0 km/h
Temperature: 95.0°C
Temperature: 45.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.097 V
Address 03: ABS Brakes Labels: 420-614-517-V2.clb
Part No SW: 420 907 379 HW: 420 614 517 D
Component: ESP8 quattro H01 0200
Coding: 0000266
Shop #: WSC 02197 785 00200
VCID: 59E4E43E551B4782E8D-800C
Address 08: Auto HVAC Labels: 420-820-043.clb
Part No SW: 420 820 043 G HW: 420 820 043 G
Component: J255 Klima 1 Zone 0100
Revision: 00H06007 Serial number: 00000001213575
Coding: 1572906
VCID: 0E4EC762DC55503A4DF-805A
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 S HW: 8P0 907 063 S
Component: BCM PQ35 H 110 0667
Revision: AG110667
Coding: 6F000A00A893362420746CE00120004950F26A001120C92ADC080E1C0045
Shop #: WSC 02391 823 56573
VCID: 44DA254ACE99EA6AABB-8010
Subsystem 1 - Part No SW: 427 955 113 HW: 427 955 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiR H23 0011
Coding: 005912
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 025B32
Reset counter: 174
Mileage: 42150 km
Date: 2026.08.14
Time: 20:06:05
Term 15 Off
Voltage: 12.75 V
Term 50 Off
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 P HW: 8E0 035 593 P
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7M0616207
Coding: 0000100
VCID: 363E4F82844548FA25F-8062
Reset counter: 155
Mileage: 41936 km
Date: 2026.06.16
Time: 13:57:28
01304 - Radio
Fault Frequency: 71
Reset counter: 215
Mileage: 42166 km
Date: 2026.08.25
Time: 15:41:45
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X2.clb
Part No SW: 8P0 919 475 Q HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0150
Revision: 11001001 Serial number: 12531708300249
Coding: 30000C
Shop #: WSC 28047 001 1048576
VCID: 4CCA0D6AE6C9222A63B-8018
Address 11: Engine II Labels:. 07L-910-552-BUJ2.clb
Address 14: Susp. Elect. Labels: 8P0-907-376.lbl
Part No SW: 420 910 376 A HW: 420 907 376 A
Component: J250 Raddaempfung 0170
Revision: --H16--- Serial number: 190DPH 2083155
Coding: 0000054
VCID: 1174DC1ECD6B4FC250D-8044
Address 15: Airbags Labels: None
Part No SW: 427 959 655 HW: 427 959 655
Component: 20 Airbag 9.43 H02 0030
Revision: 93H02003 Serial number: 003B800044L8
Coding: 0012848
VCID: 649AC5CA62598A6A4BB-8030
Subsystem 1 - Part No: 8J0 959 339 C
Component: BF-Gewichtsens. H04 0040
Subsystem 2 - Serial number: 006BX
Subsystem 3 - Serial number: 0001.01.0000H0400000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB406A9D98D3ÿ†63
Subsystem 5 - Serial number: 9D98D3ÿ†63428RB406A9D64E+ÿ†63
Subsystem 6 - Serial number: 9D64E+ÿ†63747RB406A7EA7B5ÿ†63
Subsystem 7 - Serial number: 7EA7B5ÿ†63847RB406A7EAF8Bÿ
Subsystem 8 - Serial number: 7EAF8Bÿ
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H38 0070
Coding: 0004041
VCID: 41D42C5EDD8BFF4280D-8014
Component: E0221 H06 0030
01301 - Control Module for Voice Recognition (J507)
01304 - Radio
Address 17: Instruments Labels: 420-920-xxx-17.clb
Part No SW: 420 920 981 K HW: 420 920 981 K
Component: KOMBIINSTR. VDO H04 0650
Revision: D0H04003 Serial number: 2243L003000505
Coding: 0084288
Shop #: WSC 13093 006 1048576
VCID: 1E6EB7220CB5E0BADDF-804A
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 300412F2001312
Coding: 355100
VCID: 3B285EB6B3679592DA1-806E
Reset counter: 155
Mileage: 41936 km
Date: 2026.06.16
Time: 13:57:26
01304 - Radio
Fault Frequency: 71
Reset counter: 215
Mileage: 41936 km
Date: 2026.06.16
Time: 13:58:16
Reset counter: 155
Mileage: 41936 km
Date: 2026.06.16
Time: 13:57:26
03753 - Control Module for Microphone
Reset counter: 155
Mileage: 41936 km
Date: 2026.06.16
Time: 13:57:26
Revision: D0H04003 Serial number: AUX7Z0L4FNA07Z
Address 26: Auto Roof (J256) Labels:| 427-959-255.clb
Part No SW: 427 959 255 B HW: 427 959 255 B
Component: VSG-AU715 H05 0100
Coding: 000003
Shop #: WSC 02197 785 00000
ASAM Dataset: EV_ElectRoofContrAU715 001006
ROD: EV_ElectRoofContrAU715.rod
VCID: 221683D2344DC45AF97-8076
Address 37: Navigation
Address 42: Door Elect, Driver Labels: None
Part No SW: 427 959 801 E HW: 427 959 801 E
Component: Tuer-SG H05 0106
Coding: 0021629
VCID: 221683D238CDC45AF97-8076
Address 47: Sound System Labels: None
Part No SW: 427 035 223 HW: 427 035 223
Component: J525 Amp High H04 0030
Revision: 00H04001 Serial number: 94844003086000
Coding: 0246121
VCID: 4CCA0D6AEAC9222A63B-8018
Reset counter: 155
Mileage: 41936 km
Date: 2026.06.16
Time: 13:57:27
Address 52: Door Elect, Pass. Labels: None
Part No SW: 427 959 802 E HW: 427 959 802 E
Coding: 0021629
VCID: 231886D627D7CD52F21-8076
00110 - Right Mirror Turn Signal Lamp (L132)
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: F3260148
VCID: 71B4BC9EA1AB2FC230D-8024
Subsystem 1 - Part No SW: 420 915 181 HW: 420 915 181
Component: J367-BDM H07 0140
Serial number: 4A268J16095044098618
Address 65: Tire Pressure Labels: None
Part No SW: 420 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0040
Revision: 00050040 Serial number: 00000900008519
Coding: 0462426
VCID: 0D4CC06ED1536B22B45-8058
02214 - Tire Pressure Warning
Reset counter: 0
Mileage: 42156 km
Date: 2026.08.25
Time: 09:47:18
(no units): 26.0
Temperature: 29.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 6C: Back-up Cam. Labels: 420-910-441.clb
Part No SW: 420 910 441 A HW: 7L6 907 441 C
Component: J772__Rearview 0010
Revision: --H13--- Serial number: 525PA8-J21603O
Coding: 1020412
VCID: 0A46CB72A03D7C1A917-805E
02203 - Audio / Video Input 1
Reset counter: 155
Mileage: 41936 km
Date: 2026.06.16
Time: 13:57:29
Reverse OFF
Count: 3
Address 77: Telephone
Address A6: Microphone
End----(Elapsed Time: 01:35, VBatt start/end: 11.9V/12.0V. VIgn 11.9V)-----
------------------------------17 Faults Found------------------------------
Tuesday,25,August,2026,15:47:36:09044
Address 26: Auto Roof (427 959 255 B)
15:47:21
IDE02664-MAS03545 Switch for folding top-Switch for rear window in center position Malfunction
