Tuesday,25,August,2026,10:39:11:30988
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4713.5
VIN: WVWZZZ3CZME106490 License Plate: AV21SVT 25.08.26
Mileage: 200287km-124452mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 69 75 A5
VIN: WVWZZZ3CZME106490 Mileage: 200287km-124452miles
Address 01: Engine (J623-DTSB) Labels:. 05L-907-309-V1.clb
Part No SW: 05L 906 022 A HW: 05L 907 309 B
Component: R4 2.0l TDI H30 0827
Revision: E3H30--- CVN: CFFBA958644B2C53FDCF42ED644B2C5343FB2DAA
Coding: 0125041204741D0830000000000000000000000000000000
Shop #: WSC 05311 115 00069
ASAM Dataset: EV_ECM20TDI01105L906022A 006005
ROD: EV_ECM20TDI01105L906022A_006_VW48.rod
VCID: 25102E9E356696E29C5-8070
VINID: 9E69EAAAA0D3A9D54100610900C124C987
Readiness: 0 0 0 1 1
Part No SW: 0GC 300 046 P HW: 0GC 927 711 H
Component: GSG DQ381 H06 2805
Revision: 00H06V13 CVN: D1671FCE
ASAM Dataset: EV_TCMDQ381061 001001
ROD: EV_TCMDQ381061.rod
VCID: 372CF4D69FCA14723E9-8062
No subsystems:
Part No SW: 5Q0 614 517 GD HW: 5Q0 614 517 BR
Component: ESC H82 0114
Revision: 00000000 Serial number: 60781000003020
Coding: 0FECBA8FA1203B72477B060960C349F05D85DCE2600692713872F078D2224A0B0003010312121212B435351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 79A832EEE95EC20288D-802C
Part No SW: 3Q0 959 435 M HW: 3Q0 959 435 M
Component: VWKESSYMQB 027 1307
Revision: 00027000 Serial number: 0571721279 Dataset Number: V03935321YJ 0001
Coding: 002F0F0723
Shop #: WSC 05311 115 00310
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 44D6931ADE1C4FEAABB-8010
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 BJ HW: 5G0 907 426 BJ
Component: AC Manuell H03 2201
Revision: 00001K07
Coding: 1212010420011000110000008000C006
Shop #: WSC 00015 115 08193
ASAM Dataset: EV_ACManueBHBVW37X 004136
ROD: EV_ACManueBHBVW37X_004_VW48.rod
VCID: 74B603DACE3CBF6ADBB-8020
Part No SW: 5Q0 937 086 CJ HW: 5Q0 937 086 BQ
Component: BCM PQ37BOSCH 040 0400
Revision: -------- Serial number: J53F1503211668 Dataset Number: V03935326TD 0001
ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
ROD: EV_BCMBOSCH_021_VW48.rod
VCID: 0456531A9E9C8FEAEBB-8050
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 210113 043 0607
Serial number: 210126125238
Subsystem 2 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S2Y21M01D06H23M28S03
Coding: 0008DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 23 12 2020 10001228
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY2034520V2
Subsystem 5 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000001658007
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 521 KK HW: 5Q1 953 569 H
Component: Lenks.Modul H04 0190
Serial number: 0100130320210C104393
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058321056 Dataset Number: V03935341UZ 0001
Coding: 8471051911
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_009_VW48.rod
VCID: 53F4A0462B72D852221-8006
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 S HW: 3Q0 907 567 A
Component: ACC BOSCH MQB H02 0780
Dataset Number: V03935347H 0001
Coding: 32017FCA55FFC728949C812481408680000000000000000066
ASAM Dataset: EV_ACCBOSCHVW416 003015
ROD: EV_ACCBOSCHVW416_003_VW48.rod
VCID: 47CC8416EF2A64F24E9-8012
Part No SW: 5QF 959 655 AF HW: 5QF 959 655 AF
Component: Airbag VW22 015 0753
Revision: -------- Serial number: 003018KP6A012X Dataset Number: V03935342QE 0001
Coding: 98FCC0C0000000005C5400CF008C40000065
ASAM Dataset: EV_AirbaVW22TS6VW48X 001036
ROD: EV_AirbaVW22TS6VW48X_VW27.rod
VCID: 1A6A0D620C18291A217-804E
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705B0089V00101
Coding: 80000D
Right seat belt tensioner:
Component: BeltPretRevFR 106 1040
Serial number: 3G0857706B0090V01133
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 000 703 21
Serial number: 35700000000498E0F05R
Subsystem 4 - Part No SW: ----------- HW: 454 000 703 21
Serial number: 35800000000798E0F05V
Subsystem 5 - Part No SW: ----------- HW: 454 801 502 21
Serial number: 351005364721D0000007
Subsystem 6 - Part No SW: ----------- HW: 454 802 002 21
Serial number: 352004730961D000000A
Subsystem 7 - Part No SW: ----------- HW: 454 802 102 21
Serial number: 355006106761D000000A
Part No SW: 3G0 920 951 G HW: 3G0 920 951 G
Component: KOMBI 302 8500
Coding: 27A4091867840600018B6A031001000880600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 2B04D8A65382A0924A1-807E
1048578 - No Basic Setting
B2010 00 [00001001] - -
[Steuerger t keine oder falsche Grundeinstellung]
Reset counter: 203
Mileage: 200287 km
Date: 2026.08.24
Time: 16:39:37
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 442 4424
Revision: -------- Serial number: 0001561822 Dataset Number: V03935337DK 0001
Coding: 030900345F087300FB10405C180F00000001070000000000000000000000
GVL: 01443C0000000608C08C80008000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW48.rod
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 3G0 959 442 R HW: 3G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440036032212810
Coding: 2D0B00
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003002103090A33
Address 23: Brake Booster (J539) Labels:. 5QE-909-059.clb
Part No SW: 3Q0 909 059 AA HW: 3Q0 909 059 A
Component: EBKV H06 0074
Serial number: BPA085310321013
Coding: 0102C500340000C618638C31000049922449920400
ASAM Dataset: EV_BrakeBoostG2BoschVW48X 012121
ROD: EV_BrakeBoostG2BoschVW48X_012_VW48.rod
VCID: 76B239D2D840AD7AE5F-8022
172400 - System Voltage
P0562 00 [00101110] - Too Low
[PSCUnderVoltageLevel1]
Reset counter: 0
Mileage: 200287 km
Date: 2026.08.25
Time: 10:34:59
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 B HW: 2Q0 905 861 B
Component: ELV-MQBB H09 0040
Serial number: 21000077179006
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW48.rod
VCID: 323AC5C274A8F15A097-8066
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS003 0330
Serial number: YE007UCJ10916 Dataset Number: V03935310MJ 0001
Coding: 00350A20D001028000001000
ROD: EV_DCU2DriveSideMAXHKLO_VW48.rod
VCID: 49C8822EF93E928258D-801C
Subsystem 1 - Part No SW: 5Q4 959 811 H HW: 5Q4 959 811 H Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000118424353
Coding: 0D0000
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Dataset Number: V03935322FE 0001
Coding: 911F0000
ROD: EV_SteerAssisMQB_015.rod
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS003 0330
Serial number: YE007UC51621E Dataset Number: V03935310MD 0001
Coding: 00350020DC01028000001000
ROD: EV_DCU2PasseSideMAXHKLO_VW48.rod
VCID: 48CE872AE2346B8A473-801C
Subsystem 1 - Part No SW: 5Q4 959 812 H HW: 5Q4 959 812 H Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000118425675
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 820 D HW: 3G5 035 820
Component: MU-O-ND-EU H56 0841
Serial number: WG8LGM310321000 Dataset Number: V03935420YS 0001
Coding: 24820008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001002
ROD: EV_MUOIMQB_001_VW48.rod
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 361 8214
Serial number: VWZ6ZHY0870233
Subsystem 2 - Part No SW: V03 959 809 CP HW: -----------
Component: EU 2021 --- 4031
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 HW: 5H2 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005728 Dataset Number: V03935305CE 0001
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW48.rod
VCID: 6D8016BEAD166EA2145-8038
Address 75: Telematics (J949) Labels:* 5WA-035-28X-V1.clb
Part No SW: 5WA 035 284 G HW: 5WA 035 284 B
Component: OCUGen3High H22 0143
Serial number: 0000000311VILZJ Dataset Number: V03935450DD 0001
Coding: 024820001968A8209005460160002607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
VCID: 4ACABD22FC38999A517-801E
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 B HW: 2Q0 980 653
Component: MQB MFK 3.0 H13 1202
Serial number: E57829512210810 Dataset Number: V03935342LW 0001
Coding: 00000908115E4020089E10001020000000418000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
ROD: EV_MFK3ValeoMQB_007_VW48.rod
VCID: 3436C3DA8EBCFF6A1BB-8060
End----------(Elapsed Time: 01:44, VBatt start/end: 13.9V/14.3V)-----------
------------------------------2 Faults Found-------------------------------
