First of all, thank you all for your input. I set the values according to your description, but I am still getting an active DTC.
@Sebastian , don't you mean:
IDE00514 (ESI: Max. Time Oil Service) = 730 d
IDE00827 (ESI: Min. Time Oil Service) = 365 d
I think you mixed up these two.
I found the SRILog and confirmed the previously stored values, and they match everything you guys said.
After a lot of research, another topic came up: the WSC, VZ, and Equipment code.
I was having a hard time performing the SRI because the control unit was rejecting 00000 and 12345.
So, I set a random WSC, VZ, and Equipment code, and the process went through.
I can see now that it was a BIG mistake, and I guess I'll have to request a reset by email...
But my point is: could this be the cause of the DTC?
@Sebastian , when I buy a "new" car, I always read the service manual to check which oils I can use.
And it was in the service manual that I found information stating that I could use flexible intervals, as long as I use a 0W-20 VW 508 00 oil. And so I did.
It's nice to be able to postpone the oil change for an extra year. I, too, am familiar with the convenience of having an EV, but for long drives, I would still rather have an ICE.
@Uwe , I only use the Passat for long drives. I only drive in electric mode until I reach the highway, and when I do, the ICE takes over. If I'm driving short trips where the ICE cannot reach operating temperature, I go full electric or use the ID.3.
Friday,04,September,2026,22:25:15:32152
VCDS Release 26.9.0: SRI Reset-SRI3.CLB -- Data version: 20260828 DS378.0
WVWZZZ3CZME009325
Control Module Part Number: 3G0 920 324 B Labels: .*5G0-920-XXX-17.clb-SRI3
Component:KOMBI 502 5176, Coding:05A408186FC40008018B62531001002880700300
Operation: Please select an operation -- 1/3
Channel Description Current val. New val.
IDE00342-ESI: Resetting ESI ESI: Service Status no warning ---
IDE00510-ESI: distance driven from inspection ESI: Distance SINCE last Oil Service 9191 km ---
IDE00511-ESI: time from inspection ESI: Time SINCE last Oil Service 241 d ---
IDE00512-ESI: minimum value km-driving distance/inspection ESI: Minimum Distance to Oil Service(s) 15000 km ---
IDE00513-ESI: maximum value km-driving distance/inspection ESI: Maximum Distance to Oil Service(s) 30000 km ---
IDE00827-ESI: minimum value of time between inspections ESI: Minimum Time to Oil Service(s) 365 d ---
IDE00514-ESI: maximum value of time between inspections ESI: Maximum Time to Oil Service(s) 730 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance SINCE last mileage-dependent Inspection 23500 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time SINCE last time-dependent Inspection 437 d ---
IDE03349-FIX: Max. distance until next mileage-related inspection FIX: Max. Distance to mileage-dependent Inspection(s) 30000 km ---
IDE03350-FIX: Maximum time until next time-dependent inspection FIX: Max. Time to time-dependent Inspection(s) 730 d ---
IDE01153-SIA: maximum value of distance to service SIA/SID: Maximum Distance to Service/Inspection 15000 km ---
IDE01154-SIA: maximum value of time to service SIA/SID: Maximum Time to Service/Inspection 365 d ---
ESI/INFO: Theoretical Oil Service Interval ---
ESI/INFO: Remaining Distance to Oil Service ---
ESI/INFO: Remaining Time to Oil Service ---
ESI/INFO: Oil Service Exceedance ---
INFO: Day Counter (since Delivery Inspection) ---
INFO: Vehicle/Odomoter Mileage --- ---
IDE00517-ESI: soot entry ESI/INFO: Soot Entry 0 km ---
IDE00518-ESI: thermal load ESI/INFO: Thermal Load 8800 km ---
IDE00515-ESI: oil quality ESI/INFO: Oil Quality poor oil quality ---
ESI/CODING: Oil Level Evaluation --- ---
ESI/CODING: ESI-SIA/SID ON/OFF --- ---
ESI/CODING: ESI or SIA/SID --- ---
ESI/CODING: Oil Pressure Warning --- ---
ESI/CODING: Remote Clock Receiver --- ---
ESI/CODING: Oil Quality --- ---
ESI/CODING: Oil Level & Thermal Sensor --- ---
Friday,04,September,2026,22:25:26:32152
Operation: Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later) -- 2/3
IDE00342-ESI: Resetting ESI ESI: Service Status no warning 0
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance SINCE last mileage-dependent Inspection 23500 km 0
IDE03352-FIX: Time since last time-dependent inspection FIX: Time SINCE last time-dependent Inspection 437 d 0
The new values have been saved successfully, SRI reset complete!
Friday,04,September,2026,22:25:57:32152
Operation: Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later) -- 3/3
IDE00342-ESI: Resetting ESI ESI: Service Status Resetting ---
IDE00510-ESI: distance driven from inspection ESI: Distance SINCE last Oil Service 0 km ---
IDE00511-ESI: time from inspection ESI: Time SINCE last Oil Service 0 d ---
IDE03351-FIX: Distance covered since last mileage-dependent inspection FIX: Distance SINCE last mileage-dependent Inspection 0 km ---
IDE03352-FIX: Time since last time-dependent inspection FIX: Time SINCE last time-dependent Inspection 0 d ---
IDE00518-ESI: thermal load ESI/INFO: Thermal Load 0 km ---
