Maps Passat GTE B8.5 MY 2021 Maps
Maps
Trevas
Portugal
C?ID=516418
Hi guys!
I'm here to share the maps and the auto-scan of my recently acquired Passat GTE.
Sunday,23,August,2026,21:14:11:32152
VCDS Version: 26.7.2.1 (x64)  HEX-NET2 CB: 0.4713.5
Data version: 20260708 DS378.0
VIN: WVWZZZ3CZME009325   License Plate:
Mileage: 136252km-84663mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 4B 51 52 5F 6C
          6D 75 8C A5 A9 BB BC C6 D6 D7
VIN: WVWZZZ3CZME009325   Mileage: 136252km-84663miles
Address 01: Engine (J623-DGEB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 024 G    HW: 04E 907 309 CG
   Component: 1.4 TFSI hy   H20 9819
   Revision: DCH20000    CVN: ACEF4ACD
   Coding: 011D4012636405083008
   Shop #: WSC 05311 115 00290
   ASAM Dataset: EV_ECM14TFS01104E906024G 002006
   ROD: EV_ECM14TFS01104E906024AE_002.rod
   VCID: 251C9EEE4566DFA28D4-8070
   VINID: 9E69EAAAA0D3A9D5400090C21474FF5483
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels:. 0DD-927-770-V1.clb
   Part No SW: 0DD 300 046 E    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 2201
   Revision: 00032056    Serial number: TFK02007170041 CVN: 3D5E9018
   Shop #: WSC 05311 115 00074
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 2A066DD22C78F0DAA06-807E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 GF    HW: 5QM 614 517
   Component: ESC           H26 0314
   Revision: 00000000    Serial number: 61920000000557 CVN: 9507FFD9
   Coding: 4FEC728FA3203B75477A060268C849F24EC5DCE26016927538B1F078D2224A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
   ROD: EV_Brake1UDSContiMK100OMG_060.rod
   VCID: 7BA898969362B9528B0-802E
   Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Component: VWKESSYMQB    027 1307
   Revision: 00027000    Serial number: 0550683711 Dataset Number: V03935321YJ 0001
   Coding: 002F0F0723
   ROD: EV_KessyHellaMQBAB_VW41.rod
   VCID: 44DA236AAE1C06AABAA-8010
   Part No SW: 3G8 907 056 A    HW: 3G8 907 056 A
   Component: Climatronic   H10 0205
   Coding: 12021004200114010915100080101832
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001050
   ROD: EV_AirCondiBHTCMQB3rTranc_001_VW48.rod
   VCID: 2E0E61C210909CFA7CE-807A
   Subsystem 1 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.1X.2C20370019
   Air quality sensor:
   Humidity sensor: exterior:
   A/C compressor sub:
   Subsystem 4 - Part No SW: 5QE 816 803 H    HW: 5QE 816 803 H
   Component: J842 eKK  H03 0009
   Subsystem 5 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 086 CK    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F1707201467 Dataset Number: V03935326TD 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW27.rod
   VCID: 055CFE6EE5A6FFA2ED4-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    200623  042 0607
   Serial number:         200707184144
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S7Y20M07D02H20M52S15
   Coding: 0008DD
   Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
   Serial number: 31 12 2019  10000391
   Subsystem 4 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
   Component: J528 Dachelek  H08 0009
   Serial number: 20072000010058C
   Coding: F38380
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 GE    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0100190520200C301115
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058320195 Dataset Number: V03935315CY 0001
   Coding: 9471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_009_VW48.rod
   VCID: 53F810365B729112330-8006
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Dataset Number: V03935324MZ 0001
   Coding: 52017F425DFFC728949C812481408680000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 46DE3962982034BAA4E-8012
   Part No SW: 5QF 959 655 AA    HW: 5QF 959 655 AA
   Component: Airbag VW22   011 0639
   Revision: --------    Serial number: 003014CPE9ZQMM Dataset Number: V03935330YL 0001
   Coding: 98CCC0C0002000005C5400CF000C40000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001030
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 157CAE2E95064F221D4-8040
   Subsystem 1 - Part No SW: -----------    HW: 454 000 107 20
   Serial number: 3570000000069638084G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 107 20
   Serial number: 3580000000036638084B
   Subsystem 3 - Part No SW: -----------    HW: 454 800 107 20
   Serial number: 3510082728C1B000000H
   Subsystem 4 - Part No SW: -----------    HW: 454 800 107 20
   Serial number: 35200AACD6F1B0000002
   Subsystem 5 - Part No SW: -----------    HW: 454 802 906 20
   Serial number: 355000195B11B0000009
   Part No SW: 3G0 920 324 B    HW: 3G0 920 324 B
   Component: KOMBI         502 5176
   Coding: 05A408186FC40008018B62531001002880700300
   ASAM Dataset: EV_DashBoardVDDMQBA0 001045
   ROD: EV_DashBoardVDDMQBA0_001_VW48.rod
   VCID: 20128FFA5A443A8AFE2-8074
   Part No SW: 3Q0 907 530 AH    HW: 3Q0 907 530 D
   Component: GW MQB EV     621 6423
   Serial number: 11082011600176 Dataset Number: V03935324TE 0001
   Coding: 020900172CE21000FB0052FA581D00000001070100010000000300000000
   GVL: 01463C1008000608508C80008002C81800000000000200000000000000000000
   ROD: EV_GatewNF_VW48.rod
   VCID: 75BC8EAEB546EF22FD4-8020
   Subsystem 1 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440066183203574
   Coding: 2D0B00
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H11 9070
   Serial number: 4525164905
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0069
   Serial number: BPA085300720013
   Coding: 0202C104340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW48.rod
   VCID: 3B285896D3E27952CB0-806E
   Serial number: 20000160933002
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW48.rod
   VCID: 333870B6FBB2B112130-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TFN0034D Dataset Number: V03935310MJ 0001
   Coding: 003F0F20D000020000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW48.rod
   VCID: 49C4325E893EDBC249C-801C
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 075012 00  Dataset Number: V03935290ME 0001
   Coding: 0100001100410010
   Shop #: WSC 00015 115 00290
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2.rod
   VCID: 2B0868D62382E9D25B0-807E
   Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 F
   Component: FCM MQB High  004 0370
   Serial number: 06072010520645 Dataset Number: V03935329VZ 0001
   Coding: 000000070B0004CA00000F11000302040000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW48.rod
   VCID: 3822479AE2D4524A262-806C
   Antenna for short-range communication:
   Subsystem 1 - Part No SW: 3G1 959 121     HW: 3G1 959 121
   Component: R350 NFCTGS  701 0509
   Serial number: 0000000000B34ED900ED
   Antenna 2 for short-range communication:
   Subsystem 2 - Part No SW: 3G0 980 611     HW: 3G0 980 611
   Component: J524 NFCMIKO  H09 0059
   Serial number: 32000000000001623332
Address 51: Electric Drive (J841)       Labels:. 3G0-907-080.clb
   Part No SW: 3G0 907 080 G    HW: 3G0 907 080 G
   Component: LE Gen 3.3H17 0090
   Revision: 00H17000    CVN: 228B6A44
   Coding: 03090000000000000000
   ASAM Dataset: EV_DMCM08530113G0907080G 001020
   ROD: EV_DMCM08530113G0907080G.rod
   VCID: 290492DE297EFBC2A9C-807C
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TFQ13524 Dataset Number: V03935310MD 0001
   Coding: 003F0120DC00020000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW48.rod
   VCID: 48C2375A923422CA562-801C
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 816 B    HW: 3G5 035 816 B
   Component: MU-O-ND-EU    H22 0270
   Serial number: VWZAZ2X0631832  Dataset Number: V03935352YP 0001
   Coding: 24820000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW48.rod
   VCID: 280297DA3274C2CAB62-807C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2     H61 9216
   Serial number: VWZ6ZJX1761396
   Subsystem 2 - Part No: V03 959 809 BN
   Component: EU 2020/21     3085
   Dataset Number: V03935314JY 0001
   Coding: 0184020162002017000041
   VCID: 3924429ED9DE4B42D9C-806C
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C737-6331-9 Dataset Number: V03935322   0001
   Coding: 0200
   VCID: 77A084A6AF4A9D32EF8-8022
Address 75: Telematics (J949)       Labels:* 5WA-035-28X-V1.clb
   Part No SW: 5WA 035 284 G    HW: 5WA 035 284 B
   Component: OCUGen3High   H22 0143
   Serial number: 0000000311VICLF Dataset Number: V03935450DD 0001
   Coding: 024827001968A8209005460160002607
   ASAM Dataset: EV_OCUGen3High 003007
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4AC60D528C38D0DA406-801E
Address 8C: HV Battery (J840)       Labels: 3Q0-915-183.clb
   Part No SW: 3Q0 915 183 E    HW: 3Q0 915 183 D
   Component: J840 K8C  BMC 004 0940
   Serial number: 000000090620040 CVN: D33F78A57D759AE21DF230341DF230341DF230341DF230341DF230341DF23034
   ASAM Dataset: EV_BMCeVWBSMQB48 001007
   ROD: EV_BMCeVWBSMQB48_VW48.rod
   VCID: 343A73AAFEBCB62A0AA-8060
   Cell module control module 1:
   Subsystem 1 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Component: CMC            H04 0340
   Serial number: 20103B28AH0403302728
   Cell module control module 2:
   Subsystem 2 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403300995
   Cell module control module 3:
   Subsystem 3 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301334
   Cell module control module 4:
   Subsystem 4 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301330
   Cell module control module 5:
   Subsystem 5 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301797
   Cell module control module 6:
   Subsystem 6 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301796
   Cell module control module 7:
   Subsystem 7 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20103B28AH0403303309
   Cell module control module 8:
   Subsystem 8 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403300935
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1030
   Serial number: E33417012202170 Dataset Number: V03935329NZ 0001
   Coding: 00000888214C4020109E10001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72B6B5B2C428F81AD86-8026
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 200624200393
   ROD: EV_SoundActuaGen2AU64X_003_VW48.rod
   VCID: 6984D2DEE9FE3BC269C-803C
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TFP01924 Dataset Number: V03935306SB 0001
   Coding: 000E01200100020000001000
   ROD: EV_DCU2RearDriveMAXHKLO_VW48.rod
   VCID: 4BC808568342C9D27B0-801E
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS004 0330
   Serial number: YE007TFP05453 Dataset Number: V03935306RQ 0001
   ROD: EV_DCU2RearPasseMAXHKLO_VW48.rod
   Part No SW: 5QE 915 682 AR    HW: 5QE 915 682 AR
   Component: OBC KOSTAL    H42 4031
   Revision: --------    Serial number: 1206200FA000IM Dataset Number: V03935331LN 0001
   Coding: 115069222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
   ROD: EV_OBCSinglPhaseKLOMQB15P_001_VW48.rod
   VCID: 1D6CB60E6D361762D54-8048
   Part No SW: 992 941 572 CA    HW: 992 941 572 C
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW48.rod
   VCID: 649AC3EA0EDC66AA5AA-8030
   Component: LED1R         H08 9002
End----------(Elapsed Time: 02:07, VBatt start/end: 13.3V/13.0V)-----------
---------------------------No fault code found.----------------------------
Trevas
Portugal
C?ID=516418
blockmap-01-04E-906-024-G_WVWZZZ3CZME009325-20260823-2119.CSV
;SW:04E-906-024-G   HW:04E-907-309-CG ---  01: Engine
;Component:1.4 TFSI hy   H20 9819, Coding:011D4012636405083008
;EV_ECM14TFS01104E906024G,002006,EV_ECM14TFS01104E906024AE_002.rod
;Sunday,23,August,2026,21:19:34:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 251C9EEE4566DFA28D4-8070
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),WVWZZZ3CZME009325,
IDE00019,Voltage terminal 30,13.140, V
IDE00020-ENG188621,Terminal 15 status-Bits 0-7,1,
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,30, °C
IDE00078,Time since engine start,0, s
IDE00083,Throttle valve position (absolute),16.5, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,14.5, %
IDE00090-ENG188621,selected gear-Bits 0-7,0,
IDE00094,Kick-down status,Not operated,
IDE00094-ENG127320,Kick-down status-Test_Program_Channel 284,167,
IDE00097,OBD - requirements for which this vehicle is designed,Euro-OBD,
IDE00100,Engine torque,0.0, Nm
IDE00148,Mean injection time,0.000, ms
IDE00151,Oil fill level,73.268, mm
IDE00152,Oil warning threshold,36.000, mm
IDE00155,Ignition timing angle retard cylinder 1,0.0, °
IDE00156,Ignition timing angle retard cylinder 2,0.0, °
IDE00157,Ignition timing angle retard cylinder 3,0.0, °
IDE00158,Ignition timing angle retard cylinder 4,0.0, °
IDE00167,Exhaust temperature 1 bank 1,21.6, °C
IDE00172,A/C compressor torque,0.0, Nm
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,-22.875, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,-25.000, °
IDE00178,Camshaft adjustment intake bank 1: specified value,19.797, °
IDE00179,Camshaft adjustment intake bank 1: actual value,22.000, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.00, °
IDE00187,Coolant temperature at engine start,30.0, °C
IDE00188,Fuel high-pressure: actual value,0.580, MPa
IDE00190,Charge air pressure: specified value,336.33, hPa
IDE00191,Charge air pressure: actual value,1004.45, hPa
IDE00192,Coolant temperature at radiator outlet: actual value,27.8, °C
IDE00194,Coolant temperature at radiator output: specified value,95.0, °C
IDE00196,Engine oil temperature,27.9, °C
IDE00201,Fuel high-pressure: specified value,17.000, MPa
IDE00202,Low fuel pressure: specified value,550.0, kPa
IDE00304,Fuel level,50.00, l
IDE00348,Intake air temperature,29, °C
IDE00349,Throttle valve position: normed,7.1, %
IDE00350,Air mass: specified value,5.5, kg/h
IDE00354,Engine start: start synchronization,EPM_MODE_WAIT,
IDE00354-ENG127291,Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE,1,
IDE00355-ENG188621,Cruise Control System (CCS): status-Bits 0-7,6,
IDE00357,Fuel temperature,27.8, °C
IDE00358,Limitation: torque,400.0, Nm
IDE00360,Limitation: accelerator pedal,0.0, Nm
IDE00361,Ambient air pressure,1006.21, hPa
IDE00371,Fuel consumption,0.00, l/h
IDE00375,Generator: load signal,0.00, %
IDE00380,Coolant fan 1: activation,10.15, %
IDE00392,Accelerator pedal: sensor voltage 1,736.2, mV
IDE00393,Accelerator pedal: sensor voltage 2,363.6, mV
IDE00394,Camshaft position: start of phase window,110.65, °
IDE00406,Camshaft RPM,0.0, /min
IDE00407-ENG188621,Rail pressure regulation: status-Bits 0-7,0,
IDE00412-ENG188621,Starter control: terminal 50-Bits 0-7,0,
IDE00413-ENG188621,Starter control: Interlock- or P/N-signal-Bits 0-7,17,
IDE00414-ENG188621,Starter control: relay 1-Bits 0-7,0,
IDE00416-ENG188621,Starter control: terminal 50 feedback-Bits 0-7,4,
IDE00417-ENG188621,Starter control: shut-off conditions 1-Bits 0-7,0,
IDE00434,Particle filter: soot mass calculated,137, mg
IDE00436,Particle filter: kilometers since last regeneration,384647, m
IDE00443-ENG188621,Accelerator pedal: switch positions-Bits 0-7,8,
IDE00451,Currently running routine,Unknown (0)
IDE00474,Ambient air pressure,100, kPa abs
IDE00477,Torque request: sum of auxiliary aggregate,0.0, Nm
IDE00496-ENG188621,Oil pressure switch valve activation-Bits 0-7,0,
IDE00497-ENG188621,Status of oil pressure switches-Bits 0-7,0,
IDE00541,Acceleration,0.000, m/s²
IDE00556,Outside temperature,26, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),1.012 Lambda / -0.004 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.455, V
IDE00582,Specified value of equivalence ratio,1.999, Lambda
IDE00583,Throttle valve specified value,1.6, %
IDE00584,Distance driven since erasing DTC memory,0, km
IDE00587,Vapor pressure in tank ventilation system,1086, Pa
IDE00588,Fuel tank fill level,99.6, %
IDE00592,Status of oxygen sensor control,Engine off,
IDE00593,Ignition timing adjustment cylinder 1,0.0, Degrees
IDE00594,Absolute intake pressure,100, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,0.0, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,0,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,0.0, %
IDE00657,Hybrid battery voltage,391.75, V
IDE00699,ESI: minimum oil level in service interval,16.076, mm
IDE00700,ESI: maximum oil level in service interval,24.796, mm
IDE00738,Oxygen sensor test: bank 1: delta lambda,0.00003,
IDE00752,Oxygen sensor control test,Syst. OK,
IDE00752-ENG127302,Oxygen sensor control test-Test_Program_Channel 213,228,
IDE00773,Terminal 15 status via CAN,1,
IDE00949,Hide cylinder,not active,
IDE00949-ENG127318,Hide cylinder-Test_Program_cylinder 1,0,
IDE00949-ENG127309,Hide cylinder-Test_Program_cylinder 10,0,
IDE00949-ENG127308,Hide cylinder-Test_Program_cylinder 11,0,
IDE00949-ENG127307,Hide cylinder-Test_Program_cylinder 12,0,
IDE00949-ENG127306,Hide cylinder-Test_Program_cylinder 13,0,
IDE00949-ENG127305,Hide cylinder-Test_Program_cylinder 14,0,
IDE00949-ENG127304,Hide cylinder-Test_Program_cylinder 15,0,
IDE00949-ENG127303,Hide cylinder-Test_Program_cylinder 16,0,
IDE00949-ENG127317,Hide cylinder-Test_Program_cylinder 2,0,
IDE00949-ENG127316,Hide cylinder-Test_Program_cylinder 3,0,
IDE00949-ENG127315,Hide cylinder-Test_Program_cylinder 4,0,
IDE00949-ENG127314,Hide cylinder-Test_Program_cylinder 5,0,
IDE00949-ENG127313,Hide cylinder-Test_Program_cylinder 6,0,
IDE00949-ENG127312,Hide cylinder-Test_Program_cylinder 7,0,
IDE00949-ENG127311,Hide cylinder-Test_Program_cylinder 8,0,
IDE00949-ENG127310,Hide cylinder-Test_Program_cylinder 9,0,
IDE00950-ENG188621,A/C compressor status-Bits 0-7,0,
IDE00973,Outside temperature,26.2, °C
IDE01076,Time since ignition off,65535, s
IDE01098,Test of knock sensors: short trip result,Test off,
IDE01098-ENG127299,Test of knock sensors: short trip result-Test_Program_Channel 165,235,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,1.0000,
IDE01260,Generator performance,0, W
IDE01267,Height correction,0.99329,
IDE01378,Fuel high pressure: control deviation,16.3835, MPa
IDE01385-ENG188621,Wear index-Bits 0-7,0,
IDE01386-ENG188621,Soot index-Bits 0-7,0,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.455, V
IDE01650,Throttle valve position 2,17, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test off,
IDE01665-ENG127298,Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140,235,
IDE01680,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve,Test off,
IDE01680-ENG127300,Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195,235,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,locked,
IDE01774-ENG127319,Status misfire recognition-Test_Program_Channel 232,104,
IDE01834,Battery voltage,13140, mV
IDE01869,Long-term fuel trim bank 1 at idle,0.00, %
IDE01870,Oxygen sensor after catalytic converter: operating status,Test off,
IDE01870-ENG127295,Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113,235,
IDE01872,Result of oxygen sensor aging test after catalytic converter,Test off,
IDE01872-ENG127321,Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378,235,
IDE01873,Test of catalytic converter: measured value,5.0000,
IDE01874,Test of catalytic converter: result,Test off,
IDE01874-ENG127322,Test of catalytic converter: result-Test_Program_Channel 486,235,
IDE01876,Adaptation of loss torque,4.2, Nm
IDE01877-ENG188621,Operating condition of idle speed control-Bits 0-7,0,
IDE01878-ENG159537,Adaptation of throttle valve-Byte,00000000 ,
IDE01879,Adaptation of throttle valve: result,ADP is OK,
IDE01879-ENG127324,Adaptation of throttle valve: result-Test_Program_Channel 698,2,
IDE01880,Accelerator pedal position 2,14.5, %
IDE01881,Adaptation of kick-down shifting point,4125.2, mV
IDE01884,Camshaft adjustment intake bank 1: activation,0.000, %
IDE01885,Shut off of oxygen sensor control,l-Reg.OFF,
IDE01885-ENG127301,Shut off of oxygen sensor control-Test_Program_Channel 212,3,
IDE01888,Cold start enrichment: adaptation area 1,1.000,
IDE01889,Cold start enrichment: adaptation area 2,1.000,
IDE01890,Cold start enrichment: adaptation area 3,1.000,
IDE01891,Cold start enrichment: adaptation area 4,1.000,
IDE01892,Cold start enrichment: adaptation area 5,1.000,
IDE01893,Fuel pump: specified value,3.999, %
IDE01900,Charge press. ctrl.: spec. value,0.0, %
IDE01901,Lost torque adaptation: idle,4.2, Nm
IDE01902,Lost torque adaptation A/C compressor,0.0, Nm
IDE01903,Lost torque adaptation driving mode,4.9, Nm
IDE01904,Lost torque adaptation A/C compressor and driving mode,0.0, Nm
IDE01909,Short term adapt. throttle valve for mass air flow sensor,1.00000,
IDE01910,Long term adaptation of throttle valve for mass air flow sensor,1.03375,
IDE01911,Leakage air,3.3, kg/h
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,15.9998,
IDE01914-ENG188621,Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7,2,
IDE01922,Vehicle distance driven,136252, km
IDE01923,Control module distance driven,135947258, m
IDE01928,Close cam shaft angle at quantity control valve,90.0, °
IDE01929,Open cam shaft angle at quantity control valve,-60.0, °
IDE01930,High pressure regulation: adaptation value,0.026, MPa
IDE01932,High pressure pump injection volume,221.10, mm³
IDE01975,Numb.of misfir.: cylinder 1,1530,
IDE01976,Numb.of misfir.: cylinder 2,1021,
IDE01977,Numb.of misfir.: cylinder 3,1324,
IDE01978,Numb.of misfir.: cylinder 4,1893,
IDE02115-ENG188621,Requirements for basic setting-Bits 0-7,178,
IDE02116,Exhaust gas temperature before catalytic converter,22.05, °C
IDE02117,Relative load value,79.69, %
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02211,Brake pressure,0.03, MPa
IDE02540-ENG188621,Longitudinal acceleration sensor: status-Bits 0-7,0,
IDE02756-ENG188621,Number of manual engine starts-Bits 0-7,0,
IDE02757-ENG188621,Number of automatic engine starts-Bits 0-7,0,
IDE02832,Coolant circulation pump: activation,10.00, %
IDE03108,Result of test of oxygen sensors bank 1,Test off,
IDE03108-ENG127369,Result of test of oxygen sensors bank 1-Test_Program_Channel 976,235,
IDE03262,Adapt of angle sensor 1 f throttle valve,0.487, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.496, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.845, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.138, V
IDE03362,Requested transmission torque,1000.0, Nm
IDE03377,Coolant temp at radiator output: unconditioned voltage,3255.0, mV
IDE03393-ENG188621,Selector lever position-Bits 0-7,8,
IDE03692-ENG188621,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7,138,
IDE03693-ENG188621,Monitoring status of additional Onboard Diagnosis-Bits 0-7,229,
IDE03709,Angle difference actual-specified camshaft adjuster,-2.203, °
IDE03711,Mass flow through throttle valve,0.0, kg/h
IDE03767,Engine status,COENG_READY,
IDE03767-ENG127290,Engine status-Test_Program_Co Eng st COMPU VERB UBYTE,1,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,0.000, %
IDE03806-ENG188621,Oxygen sensor bank 1 sensor 1: status-Bits 0-7,0,
IDE03807-ENG188621,Oxygen sensor bank 1 sensor 2: status-Bits 0-7,0,
IDE03814,Test of secondary air system: deviation mass air flow Bank 1,1.000,
IDE03818-ENG99405,Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120,0.000, Ohm
IDE03818-ENG127296,Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister,0,
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,Htg.aC.OFF,
IDE03819-ENG127297,Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123,217,
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,0.00, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,0.000, %
IDE03932,Charge pressure actuator: specified position,18.26, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3233.4, mV
IDE03935,Charge air pressure actuator: adaptation for upper stop,133.4, mV
IDE03951-ENG114937,Intake manifold pressure adjustment recovery conditions-Bhedp sr,0,
IDE03953,Oxygen control: adaptation value at partial load: bank 1,1.00000,
IDE04002,Charge air pressure control,BP_A act:100.4, kPa
IDE04003,Charge air temperature sensor,B1S1:29, °C
IDE04010,Engine torque: normalized,0.0, %
IDE04011,Nominal torque,350, Nm
IDE04016,Fuel Pressure Regulation,FRP CMD:---/--- kPa / FRP ACT:480/--- kPa,
IDE04088,Turbocharger 1: temperature,Compr. in/out---/31 °C / Turbine in/out---/--- °C,
IDE04090,Exhaust temperature bank 1,S1/S2/S3/S4:  / ---/22/21/--- °C,
IDE04092,Particulate filter bank 1,0.01/0.10/0.06, kPa
IDE04110,Additional inputs and outputs,GEAR_RCMD: N,
IDE04278,Bypass valve f high press turboch turbine inlet: target value,0.00, %
IDE04279,Bypass valve f high press turboch turbine inlet: actual value,18.29, %
IDE04280,Bypass valve f high press turboch turbine inlet: offset closed,1.39, %
IDE04281,Bypass valve f high press turboch turbine inlet: offset open,-1.39, %
IDE04301,Bypass valve for high press turboch turbine inlet: activation,0.00, %
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,7,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,64,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,0,
IDE04302-ENG188621,Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7,16,
IDE04303,Bypass valve for high press turboch turbine inlet: uncond volt,701.4, mV
IDE04410,Intake manifold pressure: specified value,319.61, hPa
IDE04604,Accelerator pedal travel,0.00, %
IDE04651,Torque request: A/C compressor,0.0, Nm
IDE04654-ENG188621,CAN status - engine control module-Bits 0-7,0,
IDE04670,Crankshaft signal evaluation: status,WAITSIG,
IDE04670-ENG127292,Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE,2,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,15.9998,
IDE04685,Setpoint generation interior torque,0.0, Nm
IDE04693,Increasing desired torque intervention of ESP,-45875.2, Nm
IDE04695-ENG99946,Immobilizer snapshot A-Sia Error Snap A,00 00 00,
IDE04696-ENG102592,Immobilizer snapshot B-Sia Error Snap B,00 00 00,
IDE04872,Brake pedal value sensor: relative value filtered,-0.01, %
IDE04875,Brake pedal value sensor: learned zero point offset value,0.00, %
IDE04882,Operating mode control expanded electrical driving,Correct result,
IDE04882-ENG127289,Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE,1,
IDE04885,Hybrid batt charge cond act val standardized,98.86, %
IDE04887,Powertrain target torque,0.0, Nm
IDE04889,Target torque for combustion engine crankshaft level,-20.5, Nm
IDE04909-ENG188621,Operating mode of hybrid system-Bits 0-7,8,
IDE04913,Current speed of electric motor,0.0, /min
IDE05135,Status of compressor release,False result,
IDE05135-ENG127289,Status of compressor release-Test_Program_B TRUE UBYTE,0,
IDE05138,Shut-off timer: last engine shut-off time,77110, s
IDE05140,Intake manifold pressure raw value,1004.45, hPa
IDE05213,Activation pulse duty factor for tank vent valve for diag,0.000, %
IDE05214,EVAP valve diagnosis ratio of pressure difference,0.00,
IDE05217,Hybrid battery charge current actual value,-0.75, A
IDE05219,Electric drive torque: actual value,0.00, A
IDE05220,Electric drive voltage: actual value,392.00, V
IDE05221,Electric drive torque: actual value,0.0, Nm
IDE05240-ENG188621,Request for A/C compressor power reduction-Bits 0-7,0,
IDE05241-ENG188621,A/C compressor release status-Bits 0-7,1,
IDE05242,Phase angle adaptation request,Correct result,
IDE05242-ENG127289,Phase angle adaptation request-Test_Program_B TRUE UBYTE,1,
IDE05243,Power consumption E-machine: actual value,0, W
IDE05261-ENG188621,Gear position sensor: last valid value-Bits 0-7,14,
IDE05327,Activation for electrical auxiliary coolant pump in HT circuit,0.00, %
IDE05332-ENG188621,Heat request from heater to thermal management-Bits 0-7,3,
IDE05436,Engine operating condition,Idle,
IDE05436-ENG127326,Engine operating condition-Test_Program_Channel 87,5,
IDE05437,Outside air temperature via CAN,26.3, °C
IDE05438,Rear cat conv temp main cat conv model value,21.55, °C
IDE05440,ESI: Soot equiv 2 calculated from soot index,0.00000000,
IDE05442,Roadway slope angle acceleration interface: calculated,0.0000, rad
IDE05444,Air filling: specified value,16.99, %
IDE05449,O2 sensor 2: B1: internal resistance limit,131070, Ohm
IDE05462,Oxy sensor 1 bank 1 char curve offset,0.00000,
IDE05468,Oxygen sensor 1 bank 1 ceramic temp,-273.15, °C
IDE05470,Cat converter oxygen storage capacity,1000.0, mg
IDE05474,Main cat converter OSC age correction factor,0.797,
IDE05476,Cat converter oxygen storage capacity measured,0.0, mg
IDE05478,Exh mss flw bef main cat conv bank 1 filtered,0.0, kg/h
IDE05479,Misfire recognition reference moment,0.000, %
IDE05482,Tank venting adaptation factor,0.000,
IDE05485-ENG188621,Irregular shutdown of the counter control mod-Bits 0-7,0,
IDE05486,Current system status,SYC_DRIVE,
IDE05486-ENG127293,Current system status-Test_Program_Exe Con State 02 UBYTE,4,
IDE05508,Adaptation val cyl 1 with slow diagnosis,1.00000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,1.00000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,1.00000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,1.00000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,1.00000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,1.00000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,1.00000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,1.00000,
IDE05593,Secondary air injection sensor 1,1623.75, hPa
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,255,
IDE05797,Throttle valve adapter: specified value,1.700, %
IDE06015,Time since terminal 15 off: start/stop,65535, s
IDE06017,Camshaft position deviation from reference position,0.00, °
IDE06020,Intake air temperature in intake manifold bank raw value,29.3, °C
IDE06021,Intake air temperature before throttle valve: raw value,30.8, °C
IDE06023-ENG188621,BDE operating mode flag register-Bits 0-7,65,
IDE06039,Required RPM at idle speed,0.0, /min
IDE06040,High fuel pressure: regulator output value,4.4420, MPa
IDE06045-ENG188621,Output Diagnostic Test Mode (DTM) status-Bits 0-7,0,
IDE06048,Drive time with activated exhaust malfunction indicator lamp,0, s
IDE06056,Electric driving button status,Correct result,
IDE06056-ENG127289,Electric driving button status-Test_Program_B TRUE UBYTE,1,
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06098,Sensor control factor: output value,1.00000,
IDE06198-ENG188621,Tank vent valve: diagnostic status-Bits 0-7,0,
IDE06386,Oil level: static measurement,73.336, mm
IDE06387,Oil level: last valid dynamic value,17.640, mm
IDE06388,Oil level: condition for static measurement fulfilled,1,
IDE06393,Oil level: dynamic average value,22.160, mm
IDE06435,A/C compressor: refrigerant pressure,0, hPa
IDE06446-ENG188621,Status: incline angle-Bits 0-7,1,
IDE06607,Distance at last active oil overfill warning,0.0, km
IDE06608,Total distance with active oil overfill warnings,0.0, km
IDE06703-ENG188621,Drivetrain coordinator: ACC fault status-Bits 0-7,0,
IDE06705-ENG188621,Drivetrain coordinator: brake function status-Bits 0-7,0,
IDE06706-ENG188621,ACC variants-Bits 0-7,2,
IDE06707-ENG188621,CCS Switch-Bits 0-7,2,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,1,
IDE06708-ENG188621,Cruise control switch actuation-Bits 0-7,32,
IDE06709-ENG188621,ACC variants (coding)-Bits 0-7,3,
IDE06710-ENG188621,Cruise control system: permanent deactivation-Bits 0-7,0,
IDE06711-ENG188621,Cruise control system: temporary deactivation-Bits 0-7,0,
IDE06758,Air mass since engine start,0.00, kg
IDE06759,Cam shaft adaptation inlet: counter,3,
IDE06760,Camshaft adaptation: exhaust: counter,3,
IDE06828,Coolant recirc. pump 2: spec. value,49.93, %
IDE06830,Coolant pump for charge-air cooling: spec. value,38.67, %
IDE06946-ENG188621,Brake actuated status-Bits 0-7,0,
IDE06947-ENG188621,E-machine operating mode: spec. state-Bits 0-7,0,
IDE06948-ENG188621,High-volt. battery mode: spec. value-Bits 0-7,1,
IDE06953,Radiator bypass change-over valve activation,0.00, %
IDE06957,Unfiltered clutch input rpm,0.0, /min
IDE06965,Coolant temp. before power electronics: act. value,31.1, °C
IDE06972,High-volt. battery: charge state: abs. value,94.09, %
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,active,
IDE06983-MAS05386,Diesel emissions re-treatment: status-Status of regeneration,Available,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Passive Regeneration,
IDE06983-MAS05387,Diesel emissions re-treatment: status-Type of regeneration,Not available,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Adsorption,
IDE06983-MAS05388,Diesel emissions re-treatment: status-Status of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,Not available,
IDE06983-MAS05389,Diesel emissions re-treatment: status-Desulfurization of DeNOx catalytic converter,not active,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,Available,
IDE06983-MAS05390,Diesel emissions re-treatment: status-Regeneration criteria fulfilled,100.0, %
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,Not available,
IDE06983-MAS05391,Diesel emissions re-treatment: status-Average time between DPF regeneration,0, min
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,Available,
IDE06983-MAS05392,Diesel emissions re-treatment: status-Average distance between DPF regenerations,257, km
IDE07048,Gasoline tank pressure sensor unconditioned voltage,1.792, V
IDE07049,Gasoline tank pressure sensor: offset corrected,10.86, hPa
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,244,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,7,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,0,
IDE07050-ENG188621,Starter control: release conditions-Bits 0-7,182,
IDE07051-ENG188621,Engaged gear: raw signal-Bits 0-7,0,
IDE07094,Correction factor injector cylinder 1,0.0000,
IDE07095,Correction factor injector cylinder 2,0.0000,
IDE07096,Correction factor injector cylinder 3,0.0000,
IDE07097,Correction factor injector cylinder 4,0.0000,
IDE07164,Number injections,0,
IDE07194,Calculated increasing transmission engagement torque,-3276.8, Nm
IDE07224-ENG188621,Overrun cut-off-Bits 0-7,0,
IDE07233-ENG188621,Bit string for status of oil level-Bits 0-7,2,
IDE07233-ENG188621,Bit string for status of oil level-Bits 0-7,4,
IDE07234,Status bid for valid static oil level,1,
IDE07235,Status bid for dynamic oil level,1,
IDE07239-ENG188621,Operating state of electric drive-Bits 0-7,20,
IDE07254,Gasoline pressure tank refueling request button,0,
IDE07255-ENG188621,Number of refueling processes with time exceedance-Bits 0-7,0,
IDE07256-ENG188621,Number of refueling processes without time exceedance-Bits 0-7,134,
IDE07257,Tank pressure from leakage diagnosis: calculated,0.000, hPa
IDE07573,Throttle valve adapter: actual value,8.67, %
IDE07796-ENG188621,Turbocharger 1 turbine bypass valve 1 bank 1: position feedback  breakaway attempts-Bits 0-7,0,
IDE07904-ENG188621,Brake test switch status-Bits 0-7,0,
IDE07905-ENG188621,Brake light switch status-Bits 0-7,0,
IDE07906-ENG188621,Upper clutch switch: status-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,0,
IDE08353-ENG188621,Bypass valve turbocharger: adaptation status-Bits 0-7,6,
IDE08562,Basic correction factor: Injector cyl. 1: filtered,1.0000,
IDE08563,Basic correction factor: Injector cyl. 2: filtered,0.0000,
IDE08564,Basic correction factor: Injector cyl. 3: filtered,0.0000,
IDE08565,Basic correction factor: Injector cyl. 4: filtered,0.0000,
IDE09307-ENG188621,Pre-ignition counter cylinder 1-Bits 0-7,0,
IDE09308-ENG188621,Pre-ignition counter cylinder 2-Bits 0-7,0,
IDE09309-ENG188621,Pre-ignition counter cylinder 3-Bits 0-7,0,
IDE09310-ENG188621,Pre-ignition counter cylinder 4-Bits 0-7,0,
IDE09313-ENG188621,Pre-ignition counter over serv.life cylinder 1-Bits 0-7,0,
IDE09314-ENG188621,Pre-ignition counter over serv.life cylinder 2-Bits 0-7,0,
IDE09315-ENG188621,Pre-ignition counter over serv.life cylinder 3-Bits 0-7,0,
IDE09316-ENG188621,Pre-ignition counter over serv.life cylinder 4-Bits 0-7,0,
IDE09531,Total mass of gasoline and alcohol in oil,0.77, g
IDE09574,O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean,0.00, s
IDE09925-ENG188621,Intake camshaft bank 1: adaption error cause-Bits 0-7,0,
IDE09927,Intake camshaft bank 1: adaption hardware offset active,False result,
IDE09927-ENG127289,Intake camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09928,Outlet camshaft bank 1: adaption hardware offset active,False result,
IDE09928-ENG127289,Outlet camshaft bank 1: adaption hardware offset active-Test_Program_B TRUE UBYTE,0,
IDE09929,Intake camshaft bank 1: adaption value hardware offset active,-2.203, °
IDE09930,Outlet camshaft bank 1: adaption value hardware offset active,2.125, °
IDE09931,Outlet camshaft bank 1: adaption value sensor tolerance,-0.99, °
IDE09932,Intake camshaft B1: adaptation value sensor tolerance,2.22, °
IDE10040,Outlet camshaft bank 1 active operating mode,0,
IDE10041-ENG188621,Intake camshaft B1 active operating state-Bits 0-7,0,
IDE10043,intake camshaft bank 1 status adaption,EPMCAS_STFULLADAP,
IDE10043-ENG127372,intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE,4,
IDE10302,Time since engine start,0.0, s
IDE10303,Integrated air masse at first engine start,0.0000, kg
IDE10560-ENG188621,Adaption of radiator shutters: status-Bits 0-7,0,
IDE10630,O2 sensor befor CAT: delay time changeover rich -> lean,0.00, s
IDE10641,Low fuel pressure adaptation value for EFP: modeled,120.0, kPa
IDE10670,O2 sensor befor CAT: filter time constant changeover rich -> lean,0.00, s
IDE11290,Heating circuit temp.: raw value,27.3, °C
IDE11293,Fuel consumption difference: injectors/sensors,0.000, l
IDE11294,Fuel level difference: fuel level sensor vs. actual consumption,0.000, l
IDE11522-ENG188621,Gasoline pressure tank fueling status-Bits 0-7,10,
IDE11523,State of shut-off valve to the gasoline pressure tank,false,
IDE11523-ENG127289,State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE,0,
IDE11574,Status max. oil level dynamically exceeded,0,
IDE11575,Status max. oil level permanently exceeded,0,
IDE11576,Oil level: last valid dynamic value overfilling,18.608, mm
IDE12000,Combustion: minimum number calculated of active crankshaft segments,0.0, %
IDE12001,Combustion: calculated crankshaft angle after TO,0.00, °
IDE12002,Combustion: average calculated crankshaft angle after TO,0.00, °
IDE12003,Combustion: minimum calculated crankshaft angle after TO,0.00, °
IDE12004,Combustion: number of calculated active crankshaft segments,0.0, %
IDE12005,Combustion: average value calculated of active crankshaft segments,0.0, %
IDE12197,High-pressure fuel injection valve adapted value: cylinder 1,0.00, %
IDE12199,High-pressure fuel injection valve adapted value: cylinder 2,0.00, %
IDE12200,High-pressure fuel injection valve adapted value: cylinder 3,0.00, %
IDE12201,High-pressure fuel injection valve adapted value: cylinder 4,0.00, %
IDE12210,Particle filter: water mass,0.2, g
IDE12355,ESI: consumption equivalent of the engine control module,0.00000000,
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,4715, mg
IDE13086,Particle filter: maximum soot build-up reached,26947, mg
IDE13087,Particle filter: maximum ash build-up reached,30, g
IDE13088,Particle filter: maximum ash loading ratio reached,2.5000,
IDE13089,Particle filter: high soot accumulation ratio,4.0000,
IDE13090,Particle filter: maximum soot loading ratio reached,10.0000,
IDE13091,Particle filter: ash loading ratio,1.0000,
IDE13092,Particle filter: soot accumulation ratio,2.0422,
IDE13301,Drivetrain coordinator: brake fault status,0,
IDE13336,Drive train coordinator reversible switch off conditions,8388608,
IDE13337,Drive train coordinator irreversible switch off conditions,0,
IDE14753,Particulate filter: loading stage,2,
IDE15723,Distance with combustion engine operation,70881.1, km
MAS15845,Fuel: tank fill level,50.0, l
MAS16534-ENG188621,A/C compressor info: switch-off status-Bits 0-7,0,
ENG119898,Actual_section_of_standard_test,0,
ENG101413,Calibration Identifications,04E024G 9819BEAJ,
ENG99697,Calibration Verification Numbers,AC EF 4A CD,
ENG126402-ENG188621,Cruise_control_shutoff_conditions_irreversible-Bits 0-7,0,
ENG100152-ENG104003,ECUNAME-ECU,ECM,
ENG100152,ECUNAME,EngineControl,
ENG247045,Engine Exhaust Flow Rate,0.0, kg/h
ENG151174,Engine Friction - Percent Torque,5.0, %
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.00, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.00, g/s
ENG157300,Fueled Engine Operation Ignition Cycle Counter,||274|21760|,
ENG251836-ENG251864,Hybrid/EV Vehicle System Data-Enhanced Hybrid/EV Charging State,Not PSA,
ENG251836-ENG251865,Hybrid/EV Vehicle System Data-Enhanced Hybrid/EV Vehicle State supported,Available,
ENG251836-ENG251868,Hybrid/EV Vehicle System Data-Hybrid/EV Battery Current supported,Not available,
ENG251836-ENG228853,Hybrid/EV Vehicle System Data-Hybrid/EV Battery System Current,0.0, A
ENG251836-ENG251857,Hybrid/EV Vehicle System Data-Hybrid/EV Battery System Voltage,0.00, V
ENG251836-ENG251869,Hybrid/EV Vehicle System Data-Hybrid/EV Battery Voltage supported,Not available,
ENG251836-ENG251870,Hybrid/EV Vehicle System Data-Hybrid/EV Charging State,CSM,
ENG251836-ENG251871,Hybrid/EV Vehicle System Data-Hybrid/EV Vehicle State supported,Not available,
ENG100634,In-use Performance Tracking: 16 or 20 counters,0A 5B 23 64 09 4A 06 FB 00 00 00 00 08 86 06 FB 00 00 00 00 0E 8E 06 F6 00 00 00 00 00 00 00 00 08 7D 06 FB 00 00 00 00 00 00 00 00 00 00 00 00 03 E7 06 FB 00 00 00 00,
ENG112668,O2 sensor_controller_bank_1_p-rate,0.00000,
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG247048,Vehicle Odometer,136252.2, km
Elapsed Time: 00:39
blockmap-02-0DD-300-046-E_WVWZZZ3CZME009325-20260823-2120.CSV
;SW:0DD-300-046-E   HW:0DD-927-770-C ---  02: Auto Trans
;Component:GSG DQ400E    H32 2201, Coding:0014
;EV_TCMDQ400021,001001,EV_TCMDQ400021_VW41.rod
;Sunday,23,August,2026,21:20:21:32152
;VCID: 2A066DD22C78F0DAA06-807E
IDE00007,VW/Audi part number,0DD300046E ,
IDE00018,Voltage terminal 15,12.8, V
IDE00019,Voltage terminal 30,12.6, V
IDE00021-ENG99543,Engine speed-Engine RPM,0, /min
IDE00022-ENG103074,Transmission input speed-Transmission Input Speed Sensor,0, /min
IDE00023,Transmission output speed,0, /min
IDE00024-ENG98981,ATF temperature-Transmission fluid temperature,33, °C
IDE00075-ENG99967,Vehicle speed-Vehicle Speed Sensor,0.00, km/h
IDE00086,Accelerator pedal position,0.0, %
IDE00091-ENG101172,Status of starter lock-Status Engine Starter Lock,Activate,
IDE00094,Kick-down status,OFF,
IDE00095-ENG101643,Status of selector lever lock-Status Shift Lock,active,
IDE00096-ENG100569,Selector lever position-Shift Position,Position P Stop,
IDE00101-ENG103259,Engine specified torque during transmission intervention-Calculated engine preset torque,1022.0, Nm
IDE00102-ENG102028,Control Module temperature-Control modul temperature,38, °C
IDE00130-ENG103124,Transmission specified idle RPM-Idle Speed Commanded Value,0, /min
IDE00322-ENG100540,Status of basic setting-Basic Settings Status,0,
IDE00323-ENG140165,Security Access: Number of invalid keys-Counter Value,0,
IDE00450-ENG143393,Operating instruction-Requested Action,---,
IDE00451-ENG103018,Currently running routine-Current Test Routine,0,
IDE00872-ENG102188,Current of main pressure valve-Oil Pressure Actual Current,601.0, mA
IDE00970-ENG114816,Coolant fan activation: actual value-Radiator fan activation actual value,10.0, %
IDE00972,Idle speed increase,OFF,
IDE01588-ENG101855,Direction of travel-M015 SvnNAbRichtung,not known,
IDE01716-ENG103234,Terminal 50 status-Status terminal 50,OFF,
IDE02211,Brake pressure,0.30, bar
IDE02221,Engine torque: qualification,valid,
IDE02713-ENG98471,Brake lamp switch-Brake Light Switch,Not operated,
IDE02714,Brake test switch,Not operated,
IDE02715-ENG103190,Validity of brake pressure-Brake Pressure State,valid,
IDE02716,Tiptronic source,via CAN,
IDE02717-ENG102076,Tiptronic upshift-Tiptronic Up,OFF,
IDE02718-ENG101063,Tiptronic downshift-Tiptronic Down,OFF,
IDE02719-ENG99606,Selector lever position made plausible-Shift Position Plausible,P,
IDE02720-ENG103810,Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1,0, /min
IDE02721-ENG100916,Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2,0, /min
IDE02722-ENG101964,Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1,0, /min
IDE02723-ENG100382,Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2,0, /min
IDE02724,Direction of rotation shaft 1,not known,
IDE02725,Direction of rotation shaft 2,not known,
IDE02726-ENG100799,E-Pump: power supply-Voltage Supply Electric Motor,12.6, V
IDE02727-ENG99192,Shift Lock Solenoid Specified Status-Shift Lock Desired State,active,
IDE02728-ENG101668,Shift lock indicator lamp-Indicator Light Shift Lock,Indicator lamp off,
IDE02735-ENG100209,Display of driving mode in instrument panel-Display Driving Position,P,
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged,
IDE02738-ENG100412,Selector lever illumination-Display Shift Lighting,P,
IDE02740-ENG99750,Temperature of friction lining for clutch 1-Temperatur_Friction_Lining_Clutch_1,31, °C
IDE02741-ENG102724,Temperature of friction lining for clutch 2-Temperatur_Friction_Lining_Clutch_2,31, °C
IDE02742,Oil pressure actual value,0.00, bar
IDE02775-ENG101304,Status of basic setting data-State Of Basic Adjustmentdata,valid,
IDE02776-ENG102757,Pressure of partial transmission 1 specified value-Pressure Transmission Part 1 Commanded Value,1.50, bar
IDE02777-ENG101539,Pressure of partial transmission 1 actual value-Pressure Transmission Part 1 Actual Value,1.50, bar
IDE02779-ENG100646,Pressure of partial transmission 2 specified value-Pressure Transmission Part 2 Commanded Value,1.50, bar
IDE02780-ENG103741,Pressure of partial transmission 2 actual value-Pressure Transmission Part 2 Actual Value,1.50, bar
IDE02782-ENG103418,Current of valve for partial transmission 1 specified value-Current Valve Transmission Part 1 Commanded Value,303.1, mA
IDE02783-ENG99260,Current of valve for partial transmission 1 actual value-Current Valve Transmission Part 1 Actual Value,304.0, mA
IDE02785-ENG120854,Pulse duty factor of valve for partial transmission 1-Duty_Factor_Valve_Transmission_Part_1,0.0, %
IDE02786-ENG101222,Current of valve for partial transmission 2 specified value-Current Valve Transmission Part 2 Commanded Value,311.1, mA
IDE02787-ENG101614,Current of valve for partial transmission 2 actual value-Current Valve Transmission Part 2 Actual Value,313.0, mA
IDE02789-ENG120856,Pulse duty factor of valve for partial transmission 2-Duty_Factor_Valve_Transmission_Part_2,0.0, %
IDE02790-ENG104124,Specified torque clutch 1-Clutch 1 Commanded Torque,-100.00, Nm
IDE02791-ENG101742,Actual torque clutch 1-Clutch 1 Actual Torque,-100.00, Nm
IDE02792-ENG101464,Specified position clutch 1-Clutch 1 Commanded Position,0.00, bar
IDE02793-ENG102450,Actual position clutch 1-Clutch 1 Actual Position,0.02, bar
IDE02796-ENG103463,Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value,0.0, mA
IDE02797-ENG100730,Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value,3.0, mA
IDE02799-ENG120860,Duty cycle of valve for clutch 1-Duty_Factor_Valve_Clutch_1,0.0, %
IDE02800-ENG100171,Specified torque clutch 2-Clutch 2 Commanded Torque,-100.00, Nm
IDE02801-ENG120891,Specified position clutch 2-Clutch_2_Commanded_Position,0.00, bar
IDE02802-ENG102780,Actual position clutch 2-Clutch 2 Actual Position,-0.02, bar
IDE02805-ENG99237,Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value,0.0, mA
IDE02806-ENG103118,Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value,2.0, mA
IDE02808-ENG120864,Duty cycle of valve for clutch 2-Duty_Factor_Valve_Clutch_2,0.0, %
IDE02820,Transmission mileage,135706.0, km
IDE02821-ENG101653,Pressure Supply Specified Pressure/Threshold 1-Pressure Supply Commanded Value Threshold 1,53.00, bar
IDE02823-ENG100173,Identification of selector lever-Identification Selector Lever,3Q1713023AJ VL19,
IDE02824-ENG99279,Main status of abort code basic setting-Basic Settings Main Status,0,
IDE02825-ENG100313,Substatus of abort code basic setting-Basic Settings Sub Status,0,
IDE02827-ENG103491,Installation information steering wheel paddles-Application Info Steering Paddels,59,
IDE02828-ENG103640,Installation information brakes-Application Info Breaksystem,59,
IDE02829-ENG103127,Installation information steering column module-Application Info Steering Modul,59,
IDE02830-ENG100103,Installation information gateway-Application Info Gateway,59,
IDE02858-ENG100590,Status of basic setting data: gear selector-State Of Basic Adjustmentdata Gearpositioner,Valid basic calibration,
IDE02859-ENG99797,Status of basic setting data for clutch-State Of Basic Adjustmentdata Clutch,Valid basic calibration,
IDE02864-ENG99505,Actual position of gear positioner A-Gearpositioner A Actual Position,7.43, mm
IDE02865-ENG104121,AD value 1 of actual position of gear actuator A-Gearpositioner A Actual Position AD Value 1,0,
IDE02867-ENG103746,Specified current of gear Solen.val. A-Gearpositioner A Valve Commanded Current,0.0, mA
IDE02868-ENG102455,Actual current of gear Solen.val. A-Gearpositioner A Valve Actual Current,1.0, mA
IDE02870-ENG120871,Duty cycle of gear Solen.val. A-Gearpositioner_A_Valve_Duty_Factor,0.0, %
IDE02872-ENG102218,Actual position of gear adjuster B-Gearpositioner B Actual Position,-0.01, mm
IDE02873-ENG101728,AD value 1 of actual position of gear actuator B-Gearpositioner B Actual Position AD Value 1,0,
IDE02875-ENG101174,Specified current of gear Solen.val. B-Gearpositioner B Valve Commanded Current,0.0, mA
IDE02876-ENG99266,Actual current of gear Solen.val. B-Gearpositioner B Valve Actual Current,1.0, mA
IDE02878-ENG120875,Pulse duty factor of gear Solen.val. B-Gearpositioner_B_Valve_Duty_Factor,0.0, %
IDE02880-ENG103036,Actual position of gear positioner C-Gearpositioner C Actual Position,0.11, mm
IDE02881-ENG99453,AD value 1 of actual position of gear actuator C-Gearpositioner C Actual Position AD Value 1,0,
IDE02883-ENG103740,Specified current of gear Solen.val. C-Gearpositioner C Valve Commanded Current,0.0, mA
IDE02884-ENG99821,Actual current of gear Solen.val. C-Gearpositioner C Valve Actual Current,2.0, mA
IDE02886-ENG120879,Pulse duty factor of gear Solen.val. C-Gearpositioner_C_Valve_Duty_Factor,0.0, %
IDE02888-ENG103826,Actual position of gear positioner D-Gearpositioner D Actual Position,-7.63, mm
IDE02889-ENG100525,AD value 1 of actual position of gear actuator D-Gearpositioner D Actual Position AD Value 1,0,
IDE02891-ENG101968,Specified current of gear Solen.val. D-Gearpositioner D Valve Commanded Current,698.0, mA
IDE02892-ENG99541,Actual current of gear Solen.val. D-Gearpositioner D Valve Actual Current,699.0, mA
IDE02894-ENG120883,Duty cycle of gear Solen.val. D-Gearpositioner_D_Valve_Duty_Factor,35.3, %
IDE02989-ENG100843,Status of torque requirements on engine-State Of Torque Demand Engine,OFF,
IDE03107-ENG126246,Kilometers at last basic setting-Kilometer At Last Basic Adjustment,0, km
IDE03152-ENG104154,Neutral due to driver registr. proced. cond.: cause-Driver Registration Procedure Condition Cause,00 00,
IDE03153-ENG102498,Driver logon procedure: number of activations-Driver Registration Procedure Activation Counter,2,
IDE03155-ENG99516,GE clutch data: Status-GE Clutch Data Status,Data for basic calibration valid,
IDE03156-ENG102903,Last change to GE clutch data: odometer reading-Last Changing GE Clutch Data Km,0, km
IDE03160-ENG100046,Remaining Clutch Quick Adaptations Kiss Point-Remaining Clutch Fastadaption Kisspoint,0,
IDE03163-ENG103608,Protect. function temp. clutch 1 warn. level 1 number-Protective Function Temperature Clutch 1 Warning 1 Numbers,0,
IDE03164-ENG101576,Protect. function temp. clutch 1 warn. level 2 number-Protective Function Temperature Clutch 1 Warning 2 Numbers,0,
IDE03165-ENG102133,Protective function temp. clutch 1 protect. level 1 number-Protective Function Temperature Clutch 1 Protection 1 Numbers,0,
IDE03167-ENG102425,Protect. function temp. clutch 2 warn. level 1 number-Protective Function Temperature Clutch 2 Warning 1 Numbers,0,
IDE03168-ENG100182,Protect. function temp. clutch 2 warn. level 2 number-Protective Function Temperature Clutch 2 Warning 2 Numbers,0,
IDE03169-ENG104175,Protective function temp. clutch 2 protect. level 1 number-Protective Function Temperature Clutch 2 Protection 1 Numbers,0,
IDE03171-ENG102987,Driving strategy transmission mileage-Q002 Total Driving Time,133923.4, km
IDE03172-ENG100789,Driving Strategy Percentage Driving in D or S w/Cruise-Q003 Driving Time Ecological,74, %
IDE03173-ENG103567,Driving Strategy Percentage Driving in S w/o cruise-Q004 Driving Time Sporty,24, %
IDE03174-ENG100415,Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual,2, %
IDE03180-ENG103176,Number of standard trips-General Denominator,1787,
IDE03181-ENG102823,Number of ignition cycles-Ignition Cycle Counter,0,
IDE04612-ENG101246,Clutch temperature air / splash oil-Centrifugal oil temperature,0, °C
IDE05303-ENG99893,Actual torque clutch 2-Clutch 2 Actual Torque,-100.00, Nm
IDE05987-ENG110524,Engine stop prohibitions-Basic setting,not active,
IDE05987-ENG159578,Engine stop prohibitions-Demontagestellung,not active,
IDE05987-ENG159577,Engine stop prohibitions-Drucksensorausfall,not active,
IDE05987-ENG159579,Engine stop prohibitions-Eingeschränkte Fahrfunktion / Notlauf / Liegenbleiber,not active,
IDE05987-ENG110508,Engine stop prohibitions-km-Stand des letzten Stoppverbots,0.0, km
IDE05987-ENG159710,Engine stop prohibitions-Motorstoppverbote Anzahl Stoppverbote,0,
IDE05987-ENG110525,Engine stop prohibitions-Stop prohibition via application,not active,
IDE05987-ENG159576,Engine stop prohibitions-Temperaturbedingung,not active,
IDE05987-ENG122385,Engine stop prohibitions-unsortierte Gangsteller im Stand,not active,
IDE05988-ENG110505,Pressure of clutch 2: actual value-Clutch_2_actual_value,-0.02, bar
IDE05989-ENG110503,Pressure of clutch 1: actual value-Clutch_1_actual_value,0.02, bar
IDE05990-ENG110506,Pressure of clutch 2: specified value-Clutch_2_commanded_value,0.00, bar
IDE05991-ENG110504,Pressure of clutch 1: specified value-Clutch_1_commanded_value,0.00, bar
IDE06241-ENG120892,Uneven road surface recognition: total driving portion-Drivingpart_of_roug_road_detection_total,0.0, %
IDE06243-ENG120894,Longest active distance with uneven road surface recognition-Longest_active_mileage_of_rough_road_detection,0, km
IDE06425,Dynamometer mode: functional,not activated,
IDE08133-ENG121991,Basic setting: cause for cancellation-Routine_abort_reason,Basic setting not active,
IDE10834-ENG127894,Identification data hybrid module-Anfang,#,
IDE10834-ENG98612,Identification data hybrid module-Date of manufacture,200804,
IDE10834-ENG98577,Identification data hybrid module-END,#,
IDE10834-ENG112382,Identification data hybrid module-Index,J ,
IDE10834-ENG120774,Identification data hybrid module-Lfd. Nr. pro Tag,0242,
IDE10834-ENG120775,Identification data hybrid module-Linienkennung,G04,
IDE10834-ENG124826,Identification data hybrid module-Measuring value,Angle=212,3
IDE10834-ENG126639,Identification data hybrid module-Messwert G1,G1=33,90
IDE10834-ENG126640,Identification data hybrid module-Messwert G2,G2=29,65
IDE10834-ENG126641,Identification data hybrid module-Messwert K1,K1=76,27
IDE10834-ENG126634,Identification data hybrid module-Standort,K,
IDE10834-ENG126637,Identification data hybrid module-Trennzeichen 1,*&*,
IDE10834-ENG126638,Identification data hybrid module-Trennzeichen 2,*,
IDE10834-ENG126643,Identification data hybrid module-Trennzeichen 3,*,
IDE10834-ENG126642,Identification data hybrid module-Trennzeichen 4,*,
IDE10834-ENG126633,Identification data hybrid module-VW-Teilenummer,0DD901152,
IDE10835-IDE00009,Identification data: electric machine-Date of manufacture,200804,
IDE10835-MAS04970,Identification data: electric machine-Part Number,0EC901091,
IDE10835-ENG112382,Identification data: electric machine-Index,AD,
IDE10835-ENG126635,Identification data: electric machine-Kennbuchstabe,EAJ_,
IDE10835-ENG126636,Identification data: electric machine-Laufnummer (über Alles),AL1495,
IDE10835-ENG120774,Identification data: electric machine-Lfd. Nr. pro Tag,0032,
IDE10835-ENG120775,Identification data: electric machine-Linienkennung,G06,
IDE10835-ENG126634,Identification data: electric machine-Standort,K,
IDE10889-ENG127918,Pulse duty ratio: clutch cooling valve-Duty Factor Valve Clutch Cooling,100.0, %
IDE10890-ENG127919,Pulse duty ratio: reservoir filling valve-Duty Factor Accumulator Pressure Valve,36.3, %
IDE10891-ENG127920,Pulse duty ratio: clutch valve K0-Duty Factor Valve Clutch 0,0.0, %
IDE11135-ENG127823,Capacity protection function: clutch 2 number-Protective_Function_Capacity_Clutch_2_Numbers,1,
IDE11136-ENG127822,Capacity protection function: clutch 1 number-Protective_Function_Capacity_Clutch_1_Numbers,2,
IDE11206-ENG98675,Mechatronics identification DQ400e-Construction version,D2,
IDE11206-ENG98612,Mechatronics identification DQ400e-Date of manufacture,200804,
IDE11206-ENG112382,Mechatronics identification DQ400e-Index,J-,
IDE11206-ENG120774,Mechatronics identification DQ400e-Lfd. Nr. pro Tag,0231,
IDE11206-ENG120775,Mechatronics identification DQ400e-Linienkennung,G05,
IDE11206-ENG126634,Mechatronics identification DQ400e-Standort,K,
IDE11206-ENG120776,Mechatronics identification DQ400e-Ventilkennung,A,
IDE11206-ENG126633,Mechatronics identification DQ400e-VW-Teilenummer,0DD325025,
IDE11241-ENG127896,Clutch 0 kiss point: successful adaptation counter-Clutch 0 adaption kisspoint positive case counter,6747,
IDE11242-ENG127897,Clutch 0 upper point adaptation: success counter-Clutch 0 adaption upper point positive case counter,6138,
IDE11243-ENG127898,Clutch 0 adaptation: reference start counter-Clutch 0 adaption counter for reference start counter,8487,
IDE11244-ENG127899,Couple 0 adaptation: characteristic point 1 pressure-Clutch 0 adaption characteristic point 1 pressure,8.77, bar
IDE11245-ENG127900,Couple 0 adaptation: characteristic point 1 torque-Clutch 0 adaption characteristic point 1 torque,0.0, Nm
IDE11246-ENG127901,Couple 0 adaptation: characteristic point 2 pressure-Clutch 0 adaption characteristic point 2 pressure,9.77, bar
IDE11247-ENG127902,Couple 0 adaptation: characteristic point 2 torque-Clutch 0 adaption characteristic point 2 torque,10.0, Nm
IDE11248-ENG127903,Couple 0 adaptation: characteristic point 3 pressure-Clutch 0 adaption characteristic point 3 pressure,25.65, bar
IDE11249-ENG127904,Couple 0 adaptation: characteristic point 3 torque-Clutch 0 adaption characteristic point 3 torque,400.0, Nm
IDE11885-ENG140244,Error status of pump motor activation-Failure_status,0,
IDE11885-ENG140348,Error status of pump motor activation-Failure_status_cumulated,0,
IDE11921-ENG140269,Reason for cancelling emptying of oil pressure reservoir-Abort_reason_automatic_transmission_fluid_pressure_accumulator_discharge,Do not cancel,
IDE12712-ENG167245,Mileage at last initialization clutch friction coefficient model-Mileage of setting resetting gearbox mileage,0.0, km
IDE12713-ENG167207,Clutch friction coefficient model mileage-Gearbox mileage,135706.0, km
IDE13947-ENG167877,Mileage since last activation: uneven road surface recognition-Kilometer_at_last_ activation_rough_road_detection,655340, km
IDE14121-MAS17861,Hydraulic shutoff path sub-transmission data-Number of successful tests in sub-transmission 1,0,
IDE14121-MAS17862,Hydraulic shutoff path sub-transmission data-Number of successful tests in sub-transmission 2,0,
IDE14121-MAS17863,Hydraulic shutoff path sub-transmission data-Number of failed tests in sub-transmission 1,0,
IDE14121-MAS17864,Hydraulic shutoff path sub-transmission data-Number of failed tests in sub-transmission 2,0,
IDE14121-MAS17865,Hydraulic shutoff path sub-transmission data-Number of canceled tests in sub-transmission 1,0,
IDE14121-MAS17866,Hydraulic shutoff path sub-transmission data-Number of canceled tests in sub-transmission 2,0,
IDE14121-MAS17867,Hydraulic shutoff path sub-transmission data-Mileage at last data reset,0, km
IDE80001-ENG100467,Analysis 1-Snapshot 1 Failure ID,304,
IDE80002-ENG102386,Analysis 2-Snapshot 1 Mileage,135890, km
IDE80003-ENG101467,Analysis 3-Snapshot 1 Counter,7,
IDE80004-ENG110548,Analysis 4-Snapshot 1 Oil Pressure Actual Value,28.0, bar
IDE80005-ENG103330,Analysis 5-Snapshot 1 Shift Position Plausible,d,
IDE80006-ENG99650,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Fahrzeugzustand,Driving,
IDE80006-ENG102000,Analysis 6-Snapshot 1 Main Status Vehicle Clutch Kupplungshauptzustand,Drive off,
IDE80007-ENG101090,Analysis 7-Snapshot 1  Commanded Gear,GANG_2,
IDE80008-ENG100048,Analysis 8-Snapshot 1 Preselection Gear,GANG N,
IDE80009-ENG102100,Analysis 9-Snapshot 1 Transmission Input Speed,1280, /min
IDE80010-ENG101565,Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1,160, /min
IDE80011-ENG100379,Analysis 11-Snapshot 1 Transmission Speed Shaft 1,1280, /min
IDE80012-ENG103459,Analysis 12-Snapshot 1 Transmission Speed Shaft 2,1280, /min
IDE80013-ENG99331,Analysis 13-Snapshot 1 Gearpositioner A Actual Value,0.00, mm
IDE80014-ENG99512,Analysis 14-Snapshot 1 Gearpositioner B Actual Value,-7.84, mm
IDE80015-ENG100338,Analysis 15-Snapshot 1 Gearpositioner C Actual Value,0.16, mm
IDE80016-ENG100656,Analysis 16-Snapshot 1 Gearpositioner D Actual Value,0.16, mm
IDE80017-ENG99158,Analysis 17-Snapshot 1 Gearpositioner A Valve Actual Current,0, mA
IDE80018-ENG101917,Analysis 18-Snapshot 1 Gearpositioner B Valve Actual Current,0, mA
IDE80019-ENG102153,Analysis 19-Snapshot 1 Gearpositioner C Valve Actual Current,0, mA
IDE80020-ENG100002,Analysis 20-Snapshot 1 Gearpositioner D Valve Actual Current,0, mA
IDE80021-ENG102762,Analysis 21-Snapshot 1 Clutch 1 Actual Pressure,0.0, bar
IDE80022-ENG100347,Analysis 22-Snapshot 1 Clutch 2 Actual Pressure,9.0, bar
IDE80023-ENG99119,Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value,5, mA
IDE80024-ENG101123,Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value,555, mA
IDE80025-ENG103611,Analysis 25-Snapshot 1 Accelerator Pedal Position,0.0, %
IDE80026-ENG101503,Analysis 26-Snapshot 1 Engine torque,-4, Nm
IDE80027-ENG101521,Analysis 27-Snapshot 1 Current Valve Transmission Part 1 Actual Value,305, mA
IDE80028-ENG103949,Analysis 28-Snapshot 1 Current Valve Transmission Part 2 Actual Value,1275, mA
IDE80029-ENG103070,Analysis 29-Snapshot 1 Voltage Terminal 15,13.8, V
IDE80030-ENG101050,Analysis 30-Snapshot 1 Voltage Supply Electric Motor,13.5, V
IDE80031-ENG102899,Analysis 31-Snapshot 1 Transmission Fluid Temperature,27, °C
IDE80032-ENG99872,Analysis 32-Snapshot 1 Maximum Temperature Clutch 1 Clutch 2,34, °C
IDE80033-ENG103098,Analysis 33-Snapshot 2 Failure ID,303,
IDE80034-ENG101047,Analysis 34-Snapshot 2 Mileage,57710, km
IDE80035-ENG99915,Analysis 35-Snapshot 2 Counter,6,
IDE80036-ENG110549,Analysis 36-Snapshot 2 Oil Pressure Actual Value,8.0, bar
IDE80037-ENG99369,Analysis 37-Snapshot 2 Shift Position Plausible,P,
IDE80038-ENG99350,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Fahrzeugzustand,WARTE_DRUCK,
IDE80038-ENG102372,Analysis 38-Snapshot 2 Main Status Vehicle Clutch Kupplungshauptzustand,New,
IDE80039-ENG101369,Analysis 39-Snapshot 2  Commanded Gear,GANG_R,
IDE80040-ENG103638,Analysis 40-Snapshot 2 Preselection Gear,GANG_1,
IDE80041-ENG103367,Analysis 41-Snapshot 2 Transmission Input Speed,0, /min
IDE80042-ENG102476,Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1,0, /min
IDE80043-ENG102699,Analysis 43-Snapshot 2 Transmission Speed Shaft 1,0, /min
IDE80044-ENG101900,Analysis 44-Snapshot 2 Transmission Speed Shaft 2,0, /min
IDE80045-ENG100935,Analysis 45-Snapshot 2 Gearpositioner A Actual Position,7.20, mm
IDE80046-ENG102046,Analysis 46-Snapshot 2 Gearpositioner B Actual Position,0.00, mm
IDE80047-ENG100712,Analysis 47-Snapshot 2 Gearpositioner C Actual Position,0.16, mm
IDE80048-ENG101670,Analysis 48-Snapshot 2 Gearpositioner D Actual Position,-7.36, mm
IDE80049-ENG102288,Analysis 49-Snapshot 2 Gearpositioner A Valve Actual Current,0, mA
IDE80050-ENG103952,Analysis 50-Snapshot 2 Gearpositioner B Valve Actual Current,0, mA
IDE80051-ENG99664,Analysis 51-Snapshot 2 Gearpositioner C Valve Actual Current,0, mA
IDE80052-ENG100255,Analysis 52-Snapshot 2 Gearpositioner D Valve Actual Current,700, mA
IDE80053-ENG102973,Analysis 53-Snapshot 2 Clutch 1 Actual Pressure,0.0, bar
IDE80054-ENG100122,Analysis 54-Snapshot 2 Clutch 2 Actual Pressure,0.0, bar
IDE80055-ENG103189,Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value,0, mA
IDE80056-ENG103616,Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value,0, mA
IDE80057-ENG102447,Analysis 57-Snapshot 2 Accelerator Pedal Position,0.0, %
IDE80058-ENG103198,Analysis 58-Snapshot 2 Engine torque,0, Nm
IDE80059-ENG100322,Analysis 59-Snapshot 2 Current Valve Transmission Part 1 Actual Value,0, mA
IDE80060-ENG99335,Analysis 60-Snapshot 2 Current Valve Transmission Part 2 Actual Value,0, mA
IDE80061-ENG101449,Analysis 61-Snapshot 2 Voltage Terminal 15,12.5, V
IDE80062-ENG99916,Analysis 62-Snapshot 2 Voltage Supply Electric Motor,12.1, V
IDE80063-ENG104157,Analysis 63-Snapshot 2 Transmission Fluid Temperature,27, °C
IDE80064-ENG101948,Analysis 64-Snapshot 2 Maximum Temperature Clutch 1 Clutch 2,28, °C
IDE80071-ENG127839,Analysis 71-FID event memory entry 1,FF FF,
IDE80071-ENG127848,Analysis 71-FID event memory entry 10,FF FF,
IDE80071-ENG127849,Analysis 71-FID event memory entry 11,FF FF,
IDE80071-ENG127850,Analysis 71-FID event memory entry 12,FF FF,
IDE80071-ENG127840,Analysis 71-FID event memory entry 2,FF FF,
IDE80071-ENG127841,Analysis 71-FID event memory entry 3,FF FF,
IDE80071-ENG127842,Analysis 71-FID event memory entry 4,FF FF,
IDE80071-ENG127843,Analysis 71-FID event memory entry 5,FF FF,
IDE80071-ENG127844,Analysis 71-FID event memory entry 6,FF FF,
IDE80071-ENG127845,Analysis 71-FID event memory entry 7,FF FF,
IDE80071-ENG127846,Analysis 71-FID event memory entry 8,FF FF,
IDE80071-ENG127847,Analysis 71-FID event memory entry 9,FF FF,
IDE80072-ENG127830,Analysis 72-Temperature hybrid time in range 0,886.4, s
IDE80073-ENG127869,Analysis 73-Temperature hybrid time in range 1,11926447.5, s
IDE80074-ENG127870,Analysis 74-Temperature hybrid time in range 2,962798.7, s
IDE80075-ENG127871,Analysis 75-Temperature hybrid time in range 3,0.0, s
IDE80076-ENG127872,Analysis 76-Temperature hybrid time in range 4,0.0, s
IDE80077-ENG127873,Analysis 77-Temperature hybrid time in range 5,0.0, s
IDE80080-ENG127878,Analysis 80-Temperature hybrid maximum,87, °C
IDE80081-ENG114824,Analysis 81-Clutch 1 temperature time in range 0,12395057.6, s
IDE80082-ENG114820,Analysis 82-Clutch 1 temperature time in range 1,492761.0, s
IDE80083-ENG114814,Analysis 83-Clutch 1 temperature time in range 2,1123.6, s
IDE80084-ENG114813,Analysis 84-Clutch 1 temperature time in range 3,310.3, s
IDE80088-ENG111618,Analysis 88-Clutch 1 temperature maximum,300, °C
IDE80089-ENG114807,Analysis 89-Clutch 2 temperature time in range 0,12623011.5, s
IDE80090-ENG114811,Analysis 90-Clutch 2 temperature time in range 1,266242.9, s
IDE80091-ENG114805,Analysis 91-Clutch 2 temperature time in range 2,72.4, s
IDE80092-ENG114817,Analysis 92-Clutch 2 temperature time in range 3,0.6, s
IDE80096-ENG111619,Analysis 96-Clutch 2 temperature maximum,152, °C
IDE80097-ENG137656,Analysis 97-Snapshot 1 electric motor actual current,16, A
IDE80097-ENG137655,Analysis 97-Snapshot 1 electric motor actual speed,2200, /min
IDE80097-ENG137657,Analysis 97-Snapshot 1 electric motor actual state,geregelt,
IDE80097-ENG137654,Analysis 97-Snapshot 1 electric motor commanded speed,2200, /min
IDE80098-ENG137660,Analysis 98-Snapshot 2 electric motor actual current,37, A
IDE80098-ENG137659,Analysis 98-Snapshot 2 electric motor actual speed,3900, /min
IDE80098-ENG137661,Analysis 98-Snapshot 2 electric motor actual state,geregelt,
IDE80098-ENG137658,Analysis 98-Snapshot 2 electric motor commanded speed,4000, /min
IDE80101-ENG102219,Analysis 101-Betriebszeit Motor (Drehzahlbereich 1),2040.0, H
IDE80101-ENG103682,Analysis 101-Betriebszeit Motor (Drehzahlbereich 2),338.6, H
IDE80101-ENG101200,Analysis 101-Betriebszeit Motor (Drehzahlbereich 3),0.1, H
IDE80101-ENG100226,Analysis 101-Betriebszeit Motor (Drehzahlbereich 4),0.0, H
IDE80101-ENG102223,Analysis 101-Betriebszeit Motor (Drehzahlbereich 5),0.0, H
IDE80102-ENG102381,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 1-Gang,41264,
IDE80102-ENG99964,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 2-Gang,90663,
IDE80102-ENG100231,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 3-Gang,159738,
IDE80102-ENG104160,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 4-Gang,149885,
IDE80102-ENG102663,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 5-Gang,111545,
IDE80102-ENG99465,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 6-Gang,44215,
IDE80102-ENG103205,Analysis 102-Anzahl erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80102-ENG103678,Analysis 102-Anzahl erfolgreiche Einlegevorgänge R-Gang,10777,
IDE80103-ENG103574,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 1-Gang,3,
IDE80103-ENG103754,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 2-Gang,1,
IDE80103-ENG99560,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 3-Gang,0,
IDE80103-ENG101116,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 4-Gang,15,
IDE80103-ENG99083,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 5-Gang,3,
IDE80103-ENG99508,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 6-Gang,1,
IDE80103-ENG101966,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge 7-Gang,0,
IDE80103-ENG103519,Analysis 103-Anzahl nicht erfolgreiche Einlegevorgänge R-Gang,25,
IDE80104-ENG100464,Analysis 104-Anzahl Gangspringer 1-Gang,0,
IDE80104-ENG103518,Analysis 104-Anzahl Gangspringer 2-Gang,0,
IDE80104-ENG101484,Analysis 104-Anzahl Gangspringer 3-Gang,0,
IDE80104-ENG102434,Analysis 104-Anzahl Gangspringer 4-Gang,0,
IDE80104-ENG100828,Analysis 104-Anzahl Gangspringer 5-Gang,0,
IDE80104-ENG99747,Analysis 104-Anzahl Gangspringer 6-Gang,0,
IDE80104-ENG102967,Analysis 104-Anzahl Gangspringer 7-Gang,0,
IDE80104-ENG100893,Analysis 104-Anzahl Gangspringer R-Gang,0,
IDE80105-ENG100707,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 1),3443.0, H
IDE80105-ENG101697,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 2),136.9, H
IDE80105-ENG100556,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 3),0.3, H
IDE80105-ENG100205,Analysis 105-Betriebszeit Kupplung 1 (Temperaturbereich 4),0.1, H
IDE80106-ENG103428,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 1),3506.4, H
IDE80106-ENG101321,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 2),74.0, H
IDE80106-ENG100639,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 3),0.0, H
IDE80106-ENG103433,Analysis 106-Betriebszeit Kupplung 2 (Temperaturbereich 4),0.0, H
IDE80107-ENG101291,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 1),430.1, H
IDE80107-ENG104169,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 2),129.5, H
IDE80107-ENG100021,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 3),19.2, H
IDE80107-ENG101292,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 4),1.2, H
IDE80107-ENG99418,Analysis 107-Betriebszeit Kupplung 1 (Momentenbereich 5),0.0, H
IDE80108-ENG99240,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 1),848.5, H
IDE80108-ENG99973,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 2),231.4, H
IDE80108-ENG103238,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 3),18.8, H
IDE80108-ENG101007,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 4),1.2, H
IDE80108-ENG101190,Analysis 108-Betriebszeit Kupplung 2 (Momentenbereich 5),0.0, H
IDE80135-ENG163713,Analysis 135-Snapshot 1 freewheeling status,Freilauf inaktiv aber möglich,
IDE80136-ENG163714,Analysis 136-Snapshot 2 freewheeling status,Freilauf inaktiv aber möglich,
IDE80260-ENG127862,Pressure supply: act. press.-Pressure supply actual pressure,49.30, bar
IDE80261-ENG127834,Pressure supply: act. press.: AD value-Pressure supply actual pressure AD value,2758,
IDE80262-ENG127829,Pressure supply: spec. RPM-Pressure supply commanded speed,220, /min
IDE80263-ENG127885,Pressure supply: act. RPM-Pressure supply actual speed,221, /min
IDE80265-ENG127855,Pressure supply: act. current-Pressure supply actual current,180.0, mA
IDE80267-ENG127877,Pressure supply: act. condition-Pressure supply actual state,7,
IDE80269-ENG127893,Pressure supply: last error condition of driver-Pressure supply last driver state,0,
IDE80276-ENG127854,Current vehicle odometer reading-Current vehicle mileage,136252, km
IDE80277-ENG127828,Neutral due to driver's workplace oper: veh odom.read.-Driver registration procedure condition vehicle mileage,0, km
IDE80278-ENG127882,Driver logon procedure: vehicle odometer reading-Driver registration procedure vehicle mileage,0, km
IDE80279-ENG127826,Driver logon procedure: cause-Driver registration procedure cause,32,
IDE80280-ENG127827,Driver logon procedure: wave-Driver registration procedure shaft,0,
IDE80282-ENG114823,Clutch 1 Adaption basic charac. point 0 moment-Clutch 1 adaption basic characteristic point 0 torque,0.0, Nm
IDE80283-ENG114819,Clutch 1 Adaption basic charac. point 1 moment-Clutch 1 adaption basic characteristic point 1 torque,100.0, Nm
IDE80284-ENG114822,Clutch 1 Adaption basic charac. point 2 moment-Clutch 1 adaption basic characteristic point 2 torque,400.0, Nm
IDE80285-ENG114815,Clutch 1 Adaption basic charac. point 3 moment-Clutch 1 adaption basic characteristic point 3 torque,500.0, Nm
IDE80287-ENG127832,Clutch 1 Friction value correction factor-Clutch 1 frictional correction factor,100.0, %
IDE80288-ENG114818,Clutch 1 Characteristic line shift-Clutch 1 characteristic shift,0.00, mm
IDE80289-ENG114806,Clutch 2 Adaption basic charac. point 0 moment-Clutch 2 adaption basic characteristic point 0 torque,0.0, Nm
IDE80290-ENG114810,Clutch 2 Adaption basic charac. point 1 moment-Clutch 2 adaption basic characteristic point 1 torque,100.0, Nm
IDE80291-ENG114821,Clutch 2 Adaption basic charac. point 2 moment-Clutch 2 adaption basic characteristic point 2 torque,400.0, Nm
IDE80292-ENG114809,Clutch 2 Adaption basic charac. point 3 moment-Clutch 2 adaption basic characteristic point 3 torque,500.0, Nm
IDE80294-ENG127876,Clutch 2 Friction value correction factor-Clutch 2 frictional correction factor,100.0, %
IDE80295-ENG114808,Clutch 2 Characteristic line shift-Clutch 2 characteristic shift,0.00, mm
IDE80296-ENG127853,Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter,10069,
IDE80297-ENG127883,Clutch 1 Adaption kiss point part 1: vehicle odometer reading-Clutch 1 adaption part 1 vehicle mileage,136240, km
IDE80298-ENG127880,Clutch 2 adaption kiss point part 1: success counter-Clutch 2 adaption part 1 positive case counter,7974,
IDE80299-ENG127884,Clutch 2 adaption kiss point part 1: vehicle mileage-Clutch 2 adaption part 1 vehicle mileage,136240, km
IDE80303-ENG127833,Overall software description-Software full name,H22,
IDE80305-ENG125922,Parameter set description-Data set name,0DD300046E_2201_cJDP,
IDE80307-ENG127879,Clutch 1 Adaption kiss point part 1: remaining fast adaptations-Clutch 1 adaption part 1 remaining fastadaptions,0,
IDE80308-ENG127881,Clutch 2 Adaption kiss point part 1: remaining fast adaptations-Clutch 2 adaption part 1 remaining fastadaptions,0,
IDE80313-ENG127174,Transmission identification DQ400e-Baugruppennummer,006,
IDE80313-ENG98612,Transmission identification DQ400e-Date of manufacture,200805,
IDE80313-ENG112382,Transmission identification DQ400e-Index,  ,
IDE80313-ENG126635,Transmission identification DQ400e-Kennbuchstabe,TRS,
IDE80313-ENG120774,Transmission identification DQ400e-Lfd. Nr. pro Tag,0244,
IDE80313-ENG120775,Transmission identification DQ400e-Linienkennung,G01,
IDE80313-ENG126634,Transmission identification DQ400e-Standort,K,
IDE80313-ENG126633,Transmission identification DQ400e-VW-Teilenummer,0DD300046E,
IDE80314-ENG127917,Clutch 0 Adaption vehicle odometer reading-Clutch 0 adaption vehicle mileage,136250, km
ENG98625-ENG103724,Accelerator position: qualification-Accelerator pedal position: qualification,OK,
ENG100091,Ambient temperature,26, °C
ENG157501-ENG130284,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157501-ENG130285,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157501-ENG130286,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157501-ENG130287,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157501-ENG161272,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 1,00 00 00 00,
ENG157501-ENG167224,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 2,0,
ENG157501-ENG167225,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 3,0,
ENG157501-ENG161273,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 4,0,
ENG157501-ENG161274,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 5,0,
ENG157501-ENG167226,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Data_Extended 6,0,
ENG157501-ENG130283,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Gesamt-Software-Version,
ENG157501-ENG160009,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Häufigkeit,0,
ENG157501-ENG98689,Ausgabe der Abschalt- und Resetdaten 1 DKSW-kilometer reading,655350, km
ENG157501-ENG130295,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 15-Spannung,51.0, V
ENG157501-ENG130296,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Klemme 30-Spannung,51.0, V
ENG157501-ENG130297,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Mechatroniktemperatur,215, °C
ENG157501-ENG130291,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Quelle,0,
ENG157501-ENG112343,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Status,0,
ENG157501-ENG130293,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Reset Typ,0,
ENG157501-ENG130300,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Status des Eintrags,FF,
ENG157501-ENG130299,Ausgabe der Abschalt- und Resetdaten 1 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157502-ENG130284,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157502-ENG130285,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157502-ENG130286,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157502-ENG130287,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157502-ENG161272,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 1,00 00 00 00,
ENG157502-ENG167224,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 2,0,
ENG157502-ENG167225,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 3,0,
ENG157502-ENG161273,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 4,0,
ENG157502-ENG161274,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 5,0,
ENG157502-ENG167226,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Data_Extended 6,0,
ENG157502-ENG130283,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Gesamt-Software-Version,
ENG157502-ENG160009,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Häufigkeit,0,
ENG157502-ENG98689,Ausgabe der Abschalt- und Resetdaten 2 DKSW-kilometer reading,655350, km
ENG157502-ENG130295,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 15-Spannung,51.0, V
ENG157502-ENG130296,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Klemme 30-Spannung,51.0, V
ENG157502-ENG130297,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Mechatroniktemperatur,215, °C
ENG157502-ENG130291,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Quelle,0,
ENG157502-ENG112343,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Status,0,
ENG157502-ENG130293,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Reset Typ,0,
ENG157502-ENG130300,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Status des Eintrags,FF,
ENG157502-ENG130299,Ausgabe der Abschalt- und Resetdaten 2 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157503-ENG130284,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157503-ENG130285,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157503-ENG130286,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157503-ENG130287,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157503-ENG161272,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 1,00 00 00 00,
ENG157503-ENG167224,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 2,0,
ENG157503-ENG167225,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 3,0,
ENG157503-ENG161273,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 4,0,
ENG157503-ENG161274,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 5,0,
ENG157503-ENG167226,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Data_Extended 6,0,
ENG157503-ENG130283,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Gesamt-Software-Version,
ENG157503-ENG160009,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Häufigkeit,0,
ENG157503-ENG98689,Ausgabe der Abschalt- und Resetdaten 3 DKSW-kilometer reading,655350, km
ENG157503-ENG130295,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 15-Spannung,51.0, V
ENG157503-ENG130296,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Klemme 30-Spannung,51.0, V
ENG157503-ENG130297,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Mechatroniktemperatur,215, °C
ENG157503-ENG130291,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Quelle,0,
ENG157503-ENG112343,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Status,0,
ENG157503-ENG130293,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Reset Typ,0,
ENG157503-ENG130300,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Status des Eintrags,FF,
ENG157503-ENG130299,Ausgabe der Abschalt- und Resetdaten 3 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157504-ENG130284,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157504-ENG130285,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157504-ENG130286,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157504-ENG130287,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157504-ENG161272,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 1,00 00 00 00,
ENG157504-ENG167224,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 2,0,
ENG157504-ENG167225,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 3,0,
ENG157504-ENG161273,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 4,0,
ENG157504-ENG161274,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 5,0,
ENG157504-ENG167226,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Data_Extended 6,0,
ENG157504-ENG130283,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Gesamt-Software-Version,
ENG157504-ENG160009,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Häufigkeit,0,
ENG157504-ENG98689,Ausgabe der Abschalt- und Resetdaten 4 DKSW-kilometer reading,655350, km
ENG157504-ENG130295,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 15-Spannung,51.0, V
ENG157504-ENG130296,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Klemme 30-Spannung,51.0, V
ENG157504-ENG130297,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Mechatroniktemperatur,215, °C
ENG157504-ENG130291,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Quelle,0,
ENG157504-ENG112343,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Status,0,
ENG157504-ENG130293,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Reset Typ,0,
ENG157504-ENG130300,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Status des Eintrags,FF,
ENG157504-ENG130299,Ausgabe der Abschalt- und Resetdaten 4 DKSW-Uds-Lesestatus des Eintrages,1,
ENG157505-ENG130284,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 0,00 00 00 00,
ENG157505-ENG130285,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 1,00 00 00 00,
ENG157505-ENG130286,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 2,00 00 00 00,
ENG157505-ENG130287,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Call-Stack-Element 3,00 00 00 00,
ENG157505-ENG161272,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 1,00 00 00 00,
ENG157505-ENG167224,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 2,0,
ENG157505-ENG167225,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 3,0,
ENG157505-ENG161273,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 4,0,
ENG157505-ENG161274,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 5,0,
ENG157505-ENG167226,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Data_Extended 6,0,
ENG157505-ENG130283,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Gesamt-Software-Version,
ENG157505-ENG160009,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Häufigkeit,0,
ENG157505-ENG98689,Ausgabe der Abschalt- und Resetdaten 5 DKSW-kilometer reading,655350, km
ENG157505-ENG130295,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 15-Spannung,51.0, V
ENG157505-ENG130296,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Klemme 30-Spannung,51.0, V
ENG157505-ENG130297,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Mechatroniktemperatur,215, °C
ENG157505-ENG130291,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Quelle,0,
ENG157505-ENG112343,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Status,0,
ENG157505-ENG130293,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Reset Typ,0,
ENG157505-ENG130300,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Status des Eintrags,FF,
ENG157505-ENG130299,Ausgabe der Abschalt- und Resetdaten 5 DKSW-Uds-Lesestatus des Eintrages,1,
ENG99187,CAN version,0,
ENG98482-ENG99180,Checksum of flash-Calibration Checksumme,CF 59 99 27,
ENG98482-ENG100495,Checksum of flash-Cboot Checksumme,CA 94 05 82,
ENG98482-ENG100117,Checksum of flash-Checksumme ECU + CAL,3D 5E 90 18,
ENG98482-ENG102221,Checksum of flash-ECU Checksumme,AC E1 9F CE,
ENG101012,Clutch 1 adaption basic characteristic point 0 position,6.17, bar
ENG102187,Clutch 1 adaption basic characteristic point 1 position,12.21, bar
ENG99501,Clutch 1 adaption basic characteristic point 2 position,30.41, bar
ENG99792,Clutch 1 adaption basic characteristic point 3 position,40.00, bar
ENG110529,Clutch 1 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110528,Clutch 1 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110530,Clutch 1 adaption kiss point part 1 fault counter,0,
ENG104250,Clutch 2 adaption basic characteristic point 0 position,6.36, bar
ENG100941,Clutch 2 adaption basic characteristic point 1 position,13.04, bar
ENG99957,Clutch 2 adaption basic characteristic point 2 position,31.93, bar
ENG99481,Clutch 2 adaption basic characteristic point 3 position,40.00, bar
ENG110535,Clutch 2 adaption kiss point part 1 fault cause,00 00 00 00,
ENG110534,Clutch 2 adaption kiss point part 1 fault cause cumulative,00 00 00 00,
ENG110536,Clutch 2 adaption kiss point part 1 fault counter,0,
ENG102882,Clutch adaptation kiss-point fast adaptation remaining km tr,0, km
ENG103186,Clutch center central plate temperature,31, °C
ENG107241-ENG103334,Coefficient vmd_k_Clutch_1C0-Koeffizient,324.029,
ENG107242-ENG103334,Coefficient vmd_k_Clutch_1C1-Koeffizient,29.764,
ENG107243-ENG103334,Coefficient vmd_k_Clutch_1C2-Koeffizient,-131.972,
ENG107244-ENG103334,Coefficient vmd_k_Clutch_1C3-Koeffizient,-9.783,
ENG107245-ENG103334,Coefficient vmd_k_Clutch_2C0-Koeffizient,286.207,
ENG107246-ENG103334,Coefficient vmd_k_Clutch_2C1-Koeffizient,28.948,
ENG107247-ENG103334,Coefficient vmd_k_Clutch_2C2-Koeffizient,-75.264,
ENG107248-ENG103334,Coefficient vmd_k_Clutch_2C3-Koeffizient,-0.410,
ENG107249-ENG103334,Coefficient vmd_k_Cool_C0-Koeffizient,650.356,
ENG107250-ENG103334,Coefficient vmd_k_Cool_C1-Koeffizient,280.164,
ENG107251-ENG103334,Coefficient vmd_k_Cool_C2-Koeffizient,-0.657,
ENG107252-ENG103334,Coefficient vmd_k_Cool_C3-Koeffizient,-2.203,
ENG107253-ENG103334,Coefficient vmd_k_Cool_C4-Koeffizient,-0.000,
ENG107254-ENG103334,Coefficient vmd_k_Cool_Qmax-Koeffizient,10.866,
ENG107265-ENG103334,Coefficient vmd_k_FlwC0_Even_ABw-Koeffizient,584.959,
ENG107266-ENG103334,Coefficient vmd_k_FlwC0_Even_AFw-Koeffizient,831.061,
ENG107267-ENG103334,Coefficient vmd_k_FlwC0_Even_BBw-Koeffizient,616.325,
ENG107268-ENG103334,Coefficient vmd_k_FlwC0_Even_BFw-Koeffizient,790.199,
ENG107269-ENG103334,Coefficient vmd_k_FlwC0_OddABw-Koeffizient,596.711,
ENG107270-ENG103334,Coefficient vmd_k_FlwC0_OddAFw-Koeffizient,786.995,
ENG107271-ENG103334,Coefficient vmd_k_FlwC0_OddBBw-Koeffizient,589.073,
ENG107272-ENG103334,Coefficient vmd_k_FlwC0_OddBFw-Koeffizient,808.738,
ENG107273-ENG103334,Coefficient vmd_k_FlwC1_Even_ABw-Koeffizient,35.974,
ENG107274-ENG103334,Coefficient vmd_k_FlwC1_Even_AFw-Koeffizient,36.835,
ENG107275-ENG103334,Coefficient vmd_k_FlwC1_Even_BBw-Koeffizient,10.956,
ENG107276-ENG103334,Coefficient vmd_k_FlwC1_Even_BFw-Koeffizient,15.265,
ENG107277-ENG103334,Coefficient vmd_k_FlwC1_OddABw-Koeffizient,27.051,
ENG107278-ENG103334,Coefficient vmd_k_FlwC1_OddAFw-Koeffizient,0.187,
ENG107279-ENG103334,Coefficient vmd_k_FlwC1_OddBBw-Koeffizient,31.290,
ENG107280-ENG103334,Coefficient vmd_k_FlwC1_OddBFw-Koeffizient,21.301,
ENG107281-ENG103334,Coefficient vmd_k_FlwC2_Even_ABw-Koeffizient,7.975,
ENG107282-ENG103334,Coefficient vmd_k_FlwC2_Even_AFw-Koeffizient,6.814,
ENG107283-ENG103334,Coefficient vmd_k_FlwC2_Even_BBw-Koeffizient,2.567,
ENG107284-ENG103334,Coefficient vmd_k_FlwC2_Even_BFw-Koeffizient,4.166,
ENG107285-ENG103334,Coefficient vmd_k_FlwC2_OddABw-Koeffizient,6.080,
ENG107286-ENG103334,Coefficient vmd_k_FlwC2_OddAFw-Koeffizient,2.739,
ENG107287-ENG103334,Coefficient vmd_k_FlwC2_OddBBw-Koeffizient,5.961,
ENG107288-ENG103334,Coefficient vmd_k_FlwC2_OddBFw-Koeffizient,3.634,
ENG107289-ENG103334,Coefficient vmd_k_FlwC3_Even_ABw-Koeffizient,-49.130,
ENG107290-ENG103334,Coefficient vmd_k_FlwC3_Even_AFw-Koeffizient,64.960,
ENG107291-ENG103334,Coefficient vmd_k_FlwC3_Even_BBw-Koeffizient,-103.682,
ENG107292-ENG103334,Coefficient vmd_k_FlwC3_Even_BFw-Koeffizient,99.528,
ENG107293-ENG103334,Coefficient vmd_k_FlwC3_OddABw-Koeffizient,-62.805,
ENG107294-ENG103334,Coefficient vmd_k_FlwC3_OddAFw-Koeffizient,115.394,
ENG107295-ENG103334,Coefficient vmd_k_FlwC3_OddBBw-Koeffizient,-51.187,
ENG107296-ENG103334,Coefficient vmd_k_FlwC3_OddBFw-Koeffizient,90.047,
ENG99212,Common highside 1 specified condition,Common Highside soll eingeschaltet werden,
ENG99878,Common highside 2 specified condition,Common Highside soll eingeschaltet werden,
ENG103403,Converter Loss Torque,0.0, Nm
ENG100625,Coolant temperature,24, °C
ENG157510-ENG167264,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet,1352.0, mJ
ENG157510-ENG167265,Daten des Lebensdauermodells der K1-Reibarbeit gewichtet HR,14933.0, J
ENG157510-ENG167266,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet,1352.0, mJ
ENG157510-ENG167267,Daten des Lebensdauermodells der K1-Reibarbeit ungewichtet HR,14933.0, J
ENG157510-ENG161282,Daten des Lebensdauermodells der K1-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG157511-ENG167264,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet,1485.5, mJ
ENG157511-ENG167265,Daten des Lebensdauermodells der K2-Reibarbeit gewichtet HR,471948.1, J
ENG157511-ENG167266,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet,1485.5, mJ
ENG157511-ENG167267,Daten des Lebensdauermodells der K2-Reibarbeit ungewichtet HR,471948.1, J
ENG157511-ENG161282,Daten des Lebensdauermodells der K2-Reibwertkorrekturfaktor Lebensmodell,0.0, %
ENG104016,Designation VWDQ-Lib,H21D11,
ENG98602,Driver intention torque,0.0, Nm
ENG100746,Driving strategy: sport factor,0.0, %
ENG122353-ENG122493,Einfachsynchronisationszählerstände Klasse 1-1-Gang,1,
ENG122353-ENG122494,Einfachsynchronisationszählerstände Klasse 1-2-Gang,0,
ENG122353-ENG122495,Einfachsynchronisationszählerstände Klasse 1-3-Gang,0,
ENG122353-ENG122496,Einfachsynchronisationszählerstände Klasse 1-4-Gang,0,
ENG122353-ENG122497,Einfachsynchronisationszählerstände Klasse 1-5-Gang,0,
ENG122353-ENG122498,Einfachsynchronisationszählerstände Klasse 1-6-Gang,0,
ENG122353-ENG122499,Einfachsynchronisationszählerstände Klasse 1-7-Gang,0,
ENG122353-ENG108465,Einfachsynchronisationszählerstände Klasse 1-R-Gang,1,
ENG122354-ENG122493,Einfachsynchronisationszählerstände Klasse 2-1-Gang,0,
ENG122354-ENG122494,Einfachsynchronisationszählerstände Klasse 2-2-Gang,0,
ENG122354-ENG122495,Einfachsynchronisationszählerstände Klasse 2-3-Gang,0,
ENG122354-ENG122496,Einfachsynchronisationszählerstände Klasse 2-4-Gang,0,
ENG122354-ENG122497,Einfachsynchronisationszählerstände Klasse 2-5-Gang,0,
ENG122354-ENG122498,Einfachsynchronisationszählerstände Klasse 2-6-Gang,0,
ENG122354-ENG122499,Einfachsynchronisationszählerstände Klasse 2-7-Gang,0,
ENG122354-ENG108465,Einfachsynchronisationszählerstände Klasse 2-R-Gang,0,
ENG122355-ENG122493,Einfachsynchronisationszählerstände Klasse 3-1-Gang,0,
ENG122355-ENG122494,Einfachsynchronisationszählerstände Klasse 3-2-Gang,0,
ENG122355-ENG122495,Einfachsynchronisationszählerstände Klasse 3-3-Gang,0,
ENG122355-ENG122496,Einfachsynchronisationszählerstände Klasse 3-4-Gang,0,
ENG122355-ENG122497,Einfachsynchronisationszählerstände Klasse 3-5-Gang,0,
ENG122355-ENG122498,Einfachsynchronisationszählerstände Klasse 3-6-Gang,0,
ENG122355-ENG122499,Einfachsynchronisationszählerstände Klasse 3-7-Gang,0,
ENG122355-ENG108465,Einfachsynchronisationszählerstände Klasse 3-R-Gang,0,
ENG127824-ENG127910,Electrical_oil_pump_teach_in_parameters-Cosinus Amplitude Korreturwert,804,
ENG127824-ENG127908,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert,2020,
ENG127824-ENG127911,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert 1,0,
ENG127824-ENG127912,Electrical_oil_pump_teach_in_parameters-Cosinus Offset Korrekturwert 2,0,
ENG127824-ENG127909,Electrical_oil_pump_teach_in_parameters-Sinus Amplitude Korrekturwert,804,
ENG127824-ENG127907,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert,2019,
ENG127824-ENG127913,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert 1,0,
ENG127824-ENG127914,Electrical_oil_pump_teach_in_parameters-Sinus Offset Korrekturwert 2,0,
ENG127824-ENG127905,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude,1.00002,
ENG127824-ENG184423,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude 1,0.00000,
ENG127824-ENG184304,Electrical_oil_pump_teach_in_parameters-Verhältnis Cosinus / Sinus Amplitude 2,0.00000,
ENG127824-ENG127906,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur,-139.53063,
ENG127824-ENG184280,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur 1,0.00000,
ENG127824-ENG184417,Electrical_oil_pump_teach_in_parameters-Wert Winkelkorrektur 2,0.00000,
ENG99932,Engine coding info,19,
ENG98756,Engine torque,0.0, Nm
ENG104230,Engine torque loss,0.0, Nm
ENG106287-ENG104036,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 1,300, °C
ENG106287-ENG103379,Enriched maximum temperature clutch 1-Erreichte Maximaltemperatur Kupplung 2,152, °C
ENG123019-ENG99024,Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission,0.0, km/h
ENG100414,Gangsteller A Adaption Neutralposition,-0.0, mm
ENG100089,Gangsteller B Adaption Neutralposition,-0.0, mm
ENG103055,Gangsteller C Adaption Neutralposition,0.1, mm
ENG101354,Gangsteller D Adaption Neutralposition,0.3, mm
ENG110510,Gear actuator adaption engaged position G1,7.3, mm
ENG110511,Gear actuator adaption engaged position G2,-8.5, mm
ENG110512,Gear actuator adaption engaged position G3,-7.8, mm
ENG99484,Gear actuator adaption engaged position G4,7.7, mm
ENG110513,Gear actuator adaption engaged position G5,8.1, mm
ENG110514,Gear actuator adaption engaged position G6,8.2, mm
ENG110516,Gear actuator adaption engaged position GR,-7.9, mm
ENG110517,Gear actuator adaption synchro position G1,2.5, mm
ENG110518,Gear actuator adaption synchro position G2,-2.5, mm
ENG110519,Gear actuator adaption synchro position G3,-2.0, mm
ENG99198,Gear actuator adaption synchro position G4,2.6, mm
ENG110520,Gear actuator adaption synchro position G5,2.1, mm
ENG110521,Gear actuator adaption synchro position G6,2.4, mm
ENG110523,Gear actuator adaption synchro position GR,-2.1, mm
ENG157514-ENG161285,Gear_ratio_control-Status 1-Gang,Übersetzung i.O.,
ENG157514-ENG161286,Gear_ratio_control-Status 2-Gang,Übersetzung i.O.,
ENG157514-ENG161287,Gear_ratio_control-Status 3-Gang,Übersetzung i.O.,
ENG157514-ENG161288,Gear_ratio_control-Status 4-Gang,Übersetzung i.O.,
ENG157514-ENG161289,Gear_ratio_control-Status 5-Gang,Übersetzung i.O.,
ENG157514-ENG161290,Gear_ratio_control-Status 6-Gang,Übersetzung i.O.,
ENG157514-ENG161291,Gear_ratio_control-Status 7-Gang,Übersetzung noch nicht ermittelt,
ENG157514-ENG161292,Gear_ratio_control-Status R-Gang,Übersetzung noch nicht ermittelt,
ENG157514-ENG167281,Gear_ratio_control-Übersetzung 1-Gang,13.018,
ENG157514-ENG167282,Gear_ratio_control-Übersetzung 2-Gang,7.972,
ENG157514-ENG167283,Gear_ratio_control-Übersetzung 3-Gang,5.334,
ENG157514-ENG167284,Gear_ratio_control-Übersetzung 4-Gang,3.820,
ENG157514-ENG167285,Gear_ratio_control-Übersetzung 5-Gang,2.949,
ENG157514-ENG167286,Gear_ratio_control-Übersetzung 6-Gang,2.419,
ENG157514-ENG167287,Gear_ratio_control-Übersetzung 7-Gang,0.000,
ENG157514-ENG167288,Gear_ratio_control-Übersetzung R-Gang,0.000,
ENG299053-ENG127174,Getriebe-ID_Entw._DQ400E-Baugruppennummer,006,
ENG299053-ENG112382,Getriebe-ID_Entw._DQ400E-Index,E ,
ENG299053-ENG126635,Getriebe-ID_Entw._DQ400E-Kennbuchstabe,TRS,
ENG299053-ENG303054,Getriebe-ID_Entw._DQ400E-Laufende_Nummer,1024,
ENG299053-ENG120775,Getriebe-ID_Entw._DQ400E-Linienkennung, G0,
ENG299053-ENG299077,Getriebe-ID_Entw._DQ400E-Produktions_monat,00,
ENG299053-ENG299076,Getriebe-ID_Entw._DQ400E-Produktions_tag,80,
ENG299053-ENG299081,Getriebe-ID_Entw._DQ400E-Produktionsjahr,K2,
ENG299053-ENG126634,Getriebe-ID_Entw._DQ400E-Standort,4,
ENG299053-ENG299074,Getriebe-ID_Entw._DQ400E-Trennzeichen_1,#,
ENG299053-ENG299078,Getriebe-ID_Entw._DQ400E-Trennzeichen_2,5,
ENG299053-ENG126633,Getriebe-ID_Entw._DQ400E-VW-Teilenummer,0DD300046,
ENG99720,Height info,1003, mbar
ENG98604,Hill factor driving strategy,0.0, %
ENG99596,Indicated engine torque without external interventions,0.0, Nm
ENG99582,Intake air temperature,29, °C
ENG299054-ENG299080,Kennlinie K0-Schieber Punkt 0 Druck-Kennlinie K0-Schieber Druck,0.0, bar
ENG299055-ENG299079,Kennlinie K0-Schieber Punkt 0 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,1.1, l/min
ENG299056-ENG299080,Kennlinie K0-Schieber Punkt 1 Druck-Kennlinie K0-Schieber Druck,3.3, bar
ENG299057-ENG299079,Kennlinie K0-Schieber Punkt 1 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,1.2, l/min
ENG299058-ENG299080,Kennlinie K0-Schieber Punkt 2 Druck-Kennlinie K0-Schieber Druck,6.7, bar
ENG299059-ENG299079,Kennlinie K0-Schieber Punkt 2 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,3.4, l/min
ENG299060-ENG299080,Kennlinie K0-Schieber Punkt 3 Druck-Kennlinie K0-Schieber Druck,14.8, bar
ENG299061-ENG299079,Kennlinie K0-Schieber Punkt 3 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,3.8, l/min
ENG299062-ENG299080,Kennlinie K0-Schieber Punkt 4 Druck-Kennlinie K0-Schieber Druck,22.9, bar
ENG299063-ENG299079,Kennlinie K0-Schieber Punkt 4 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,3.4, l/min
ENG299064-ENG299080,Kennlinie K0-Schieber Punkt 5 Druck-Kennlinie K0-Schieber Druck,26.2, bar
ENG299065-ENG299079,Kennlinie K0-Schieber Punkt 5 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,3.4, l/min
ENG299066-ENG299080,Kennlinie K0-Schieber Punkt 6 Druck-Kennlinie K0-Schieber Druck,26.8, bar
ENG299067-ENG299079,Kennlinie K0-Schieber Punkt 6 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,0.9, l/min
ENG299068-ENG299080,Kennlinie K0-Schieber Punkt 7 Druck-Kennlinie K0-Schieber Druck,30.9, bar
ENG299069-ENG299079,Kennlinie K0-Schieber Punkt 7 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,0.9, l/min
ENG299070-ENG299080,Kennlinie K0-Schieber Punkt 8 Druck-Kennlinie K0-Schieber Druck,40.0, bar
ENG299071-ENG299079,Kennlinie K0-Schieber Punkt 8 Volumenstrom-Kennlinie K0-Schieber Volumenstrom,0.9, l/min
ENG110556-ENG110541,Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung,0,
ENG110556-ENG110542,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß,0,
ENG110556-ENG110543,Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein,0,
ENG110556-ENG120771,Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen,0,
ENG110557-ENG110545,Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung,0,
ENG110557-ENG110546,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß,0,
ENG110557-ENG110547,Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein,0,
ENG110557-ENG110544,Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen,0,
ENG101251,Leergas,Leergas,
ENG299072-ENG98675,Mechatronik-ID_Entw._DQ400E-Construction version,D2,
ENG299072-ENG112382,Mechatronik-ID_Entw._DQ400E-Index,J-,
ENG299072-ENG120775,Mechatronik-ID_Entw._DQ400E-Linienkennung,31K,
ENG299072-ENG299077,Mechatronik-ID_Entw._DQ400E-Produktions_monat,08,
ENG299072-ENG299076,Mechatronik-ID_Entw._DQ400E-Produktions_tag,04,
ENG299072-ENG299081,Mechatronik-ID_Entw._DQ400E-Produktionsjahr,20,
ENG299072-ENG108451,Mechatronik-ID_Entw._DQ400E-reserve,AX,
ENG299072-ENG299073,Mechatronik-ID_Entw._DQ400E-Serial number,G050,
ENG299072-ENG126634,Mechatronik-ID_Entw._DQ400E-Standort,2,
ENG299072-ENG299074,Mechatronik-ID_Entw._DQ400E-Trennzeichen_1,#,
ENG299072-ENG299078,Mechatronik-ID_Entw._DQ400E-Trennzeichen_2,#,
ENG299072-ENG126633,Mechatronik-ID_Entw._DQ400E-VW-Teilenummer,0DD325025,
ENG111613-ENG101555,Motordrehmoment Begrenzung-Engine torque limitation,0.0, Nm
ENG104079,Odometer state: last chng GE clutch mov press. char. curve,4294967295, km
ENG105329-ENG101124,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1),0.2, H
ENG105329-ENG100216,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2),3312.9, H
ENG105329-ENG103067,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3),267.4, H
ENG105329-ENG101168,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4),0.0, H
ENG105329-ENG104150,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5),0.0, H
ENG105329-ENG100130,Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6),0.0, H
ENG100188,Reached maximum temperature control module,87, °C
ENG123020-ENG102793,Rollwiderstand-Road Resistance,0.5, %
ENG103000,Run time complete system,3580.8854, H
ENG102748,Selector lever error flags,00 00,
ENG101057,Specified idle speed,0, /min
ENG100803,Speed: output,0, /min
ENG100141,Transmission coding info,23,
ENG103964,Veh. odometer state: last change of GE gear selector data,0, km
ENG299043-ENG103334,Ventilkoeffizient Kupplungsventil 0 C0-Koeffizient,263.339,
ENG299044-ENG103334,Ventilkoeffizient Kupplungsventil 0 C1-Koeffizient,27.444,
ENG299045-ENG103334,Ventilkoeffizient Kupplungsventil 0 C2-Koeffizient,-66.790,
ENG299046-ENG103334,Ventilkoeffizient Kupplungsventil 0 C3-Koeffizient,10.570,
ENG299035-ENG299075,Ventilkoeffizient Teilgetriebeventil 1 C0-Ventilkoeffizient Teilgetriebeventil 1 Cx,274.940,
ENG299036-ENG299075,Ventilkoeffizient Teilgetriebeventil 1 C1-Ventilkoeffizient Teilgetriebeventil 1 Cx,17.681,
ENG299037-ENG299075,Ventilkoeffizient Teilgetriebeventil 1 C2-Ventilkoeffizient Teilgetriebeventil 1 Cx,-83.047,
ENG299038-ENG299075,Ventilkoeffizient Teilgetriebeventil 1 C3-Ventilkoeffizient Teilgetriebeventil 1 Cx,10.873,
ENG299039-ENG328449,Ventilkoeffizient Teilgetriebeventil 2 C0-Ventilkoeffizient Teilgetriebeventil 2 Cx,342.274,
ENG299040-ENG328449,Ventilkoeffizient Teilgetriebeventil 2 C1-Ventilkoeffizient Teilgetriebeventil 2 Cx,21.012,
ENG299041-ENG328449,Ventilkoeffizient Teilgetriebeventil 2 C2-Ventilkoeffizient Teilgetriebeventil 2 Cx,-128.913,
ENG299042-ENG328449,Ventilkoeffizient Teilgetriebeventil 2 C3-Ventilkoeffizient Teilgetriebeventil 2 Cx,-20.303,
ENG101346,Version info driving strategy,FEJRMRHEH.039,
ENG109959-ENG101914,vmd_i_FlwVlvCurMin_mA_EvenA-vmd i FlwVlvCurMin mA EvenA,437,
ENG109960-ENG104144,vmd_i_FlwVlvCurMin_mA_EvenB-vmd i FlwVlvCurMin mA EvenB,432,
ENG109961-ENG101870,vmd_i_FlwVlvCurMin_mA_OddA-vmd i FlwVlvCurMin mA OddA,440,
ENG109962-ENG102688,vmd_i_FlwVlvCurMin_mA_OddB-vmd i FlwVlvCurMin mA OddB,446,
ENG109963-ENG103264,vmd_i_NulFlw_mA_Even_ABw-vmd i NulFlw mA Even ABw,624,
ENG109964-ENG100102,vmd_i_NulFlw_mA_Even_AFw-vmd i NulFlw mA Even AFw,803,
ENG109965-ENG103659,vmd_i_NulFlw_mA_Even_BBw-vmd i NulFlw mA Even BBw,609,
ENG109966-ENG100519,vmd_i_NulFlw_mA_Even_BFw-vmd i NulFlw mA Even BFw,787,
ENG109967-ENG99410,vmd_i_NulFlw_mA_OddABw-vmd i NulFlw mA OddABw,620,
ENG109968-ENG99443,vmd_i_NulFlw_mA_OddAFw-vmd i NulFlw mA OddAFw,793,
ENG109969-ENG100167,vmd_i_NulFlw_mA_OddBBw-vmd i NulFlw mA OddBBw,613,
ENG109970-ENG99387,vmd_i_NulFlw_mA_OddBFw-vmd i NulFlw mA OddBFw,805,
ENG109005,Voltage Common Highside 1,13.1, V
ENG99955,Voltage Common Highside 2,13.1, V
Elapsed Time: 00:46
blockmap-03-5Q0-614-517-GF_WVWZZZ3CZME009325-20260823-2121.CSV
;SW:5Q0-614-517-GF   HW:5QM-614-517 ---  03: ABS Brakes
;Component:ESC           H26 0314, Coding:4FEC728FA3203B75477A060268C849F24EC5DCE26016927538B1F078D2224A0B0003010312121212B435351919323200
;EV_Brake1UDSContiMK100OMG,060015,EV_Brake1UDSContiMK100OMG_060.rod
;Sunday,23,August,2026,21:21:16:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 7BA898969362B9528B0-802E
Group,Description,Actual
IDE00019,Voltage terminal 30,13.168, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,29, °C
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,14.5, %
IDE00097,OBD - requirements for which this vehicle is designed,NO OBD,
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00609-MAS01156,Communication status of data bus 1-Communication status,|Control module,Communication status|Engine Electronics
IDE00780,Mode,running_mode,
IDE02270-IDE00086,CAN input signal(s) status-Accelerator pedal position,0, %
IDE02270-IDE02049,CAN input signal(s) status-Trailer detected,Malfunction,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,Not operated,
IDE02270-MAS00025,CAN input signal(s) status-Driver seat belt switch,not connected,
IDE02270-MAS00218,CAN input signal(s) status-Driver´s door,closed,
IDE02270-MAS00314,CAN input signal(s) status-Clutch Pedal Switch,operated,
IDE02270-MAS00364,CAN input signal(s) status-Shift lever / selector lever position,Neutral,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,3C09325,
IDE02270-MAS03992,CAN input signal(s) status-Clutch pedal switch: interlock position,active,
IDE02271-IDE03311,CAN output signal(s) status-Emergency braking display,not active,
IDE02271-IDE03660,CAN output signal(s) status-Longitudinal acceleration,0.03125, m/s²
IDE02486,Data logger triggering,not initialized,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module active,
IDE02986-IDE04431,Indicator lamps-ASR and ESP indicator lamp,OFF,
IDE02986-IDE04451,Indicator lamps-Tire press monitoring display indictor lamp,OFF,
IDE02986-IDE04498,Indicator lamps--AUTO HOLD- Indicator Lamp,OFF,
IDE02986-IDE04771,Indicator lamps-Indicator lamp for electro-mechanical parking brake malfunction,OFF,
IDE02986-MAS00253,Indicator lamps-ABS indicator lamp,OFF,
IDE02986-MAS00556,Indicator lamps-Electromechanical parking brake indicator lamp,On,
IDE02986-MAS01206,Indicator lamps-Hill descent control indicator lamp,Not available due to specific system,
IDE02986-MAS02925,Indicator lamps-Brake system indicator lamp,OFF,
IDE02986-MAS03234,Indicator lamps-ESP_off indicator lamp,OFF,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.braking,1,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,43094,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,3,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,830,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03207,Hardware version for suppliers,Texas_Instruments,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,No release by coordinator,
IDE03527-IDE02070,CAN signals-Wake-up cause,1,
IDE03527-IDE02445,CAN signals-Transmission type,23,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE03680-IDE00018,Supply voltages-Voltage terminal 15,On,
IDE03680-IDE01232,Supply voltages-Supply voltage for external components,5.005, V
IDE03680-IDE04444,Supply voltages-Terminal 30 voltage for pump,0.014, V
IDE03680-IDE04445,Supply voltages-Terminal 30 voltage for valves,13.190, V
IDE03680-IDE04500,Supply voltages-Terminal 30 voltage for logic,On,
IDE04422-IDE04442,Brake system sensor-Vacuum sensor,-0.001, bar
IDE04422-IDE04450,Brake system sensor-Brake pressure sensor 1,0.50, bar
IDE04422-IDE04494,Brake system sensor-Brake pressure sensor 1: uncond voltage 1,Not available due to specific system,
IDE04422-IDE04495,Brake system sensor-Brake pressure sensor 1: uncond voltage 2,Not available due to specific system,
IDE04422-MAS00179,Brake system sensor-Brake lamp switch,Not operated,
IDE04422-MAS02152,Brake system sensor-EPB clutch pedal travel,Malfunction,
IDE04425-IDE00920,Left front ABS wheel speed sensor-Front left wheel speed,0.0, km/h
IDE04425-IDE04435,Left front ABS wheel speed sensor-Air gap,Malfunction,
IDE04425-MAS01466,Left front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04426-IDE00921,Right front ABS wheel speed sensor-Wheel speed: right front,0.0, km/h
IDE04426-IDE04435,Right front ABS wheel speed sensor-Air gap,Malfunction,
IDE04426-MAS01466,Right front ABS wheel speed sensor-Direction of rotation,Not available due to specific system,
IDE04427-IDE00922,Left rear ABS wheel speed sensor-Left rear wheel speed,0.0, km/h
IDE04427-IDE04435,Left rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04427-MAS01466,Left rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04428-IDE00923,Right rear ABS wheel speed sensor-Right rear wheel speed,0.0, km/h
IDE04428-IDE04435,Right rear ABS wheel speed sensor-Air gap,Malfunction,
IDE04428-MAS01466,Right rear ABS wheel speed sensor-Direction of rotation,forward,
IDE04442-IDE00009,Vacuum sensor-Date of manufacture,----------,
IDE04442-IDE00010,Vacuum sensor-Serial number,FF FF FF FF FF,
IDE04442-IDE00104,Vacuum sensor-DTC,65535,
IDE04442-IDE02955,Vacuum sensor-System status,Not available due to specific system,
IDE04442-IDE03205,Vacuum sensor-Manufacturer code,65535,
IDE04442,Vacuum sensor,-0.01, bar
IDE04442-MAS12759,Vacuum sensor-Type of individual vacuum sensor,65535,
IDE04443-IDE02241,Slip control system sensor-Lateral acceleration sensor 1,0.00000, m/s²
IDE04443-IDE02538,Slip control system sensor-Longitude Acceleration Sensor,-0.11772, m/s²
IDE04443-IDE04429,Slip control system sensor-Lateral acceleration sensor 1: offset,-0.19620, m/s²
IDE04443-IDE04430,Slip control system sensor-Longitudinal acceleration sensor: offset,0.03125, m/s²
IDE04443-IDE04449,Slip control system sensor-Rotation rate sensor 1: Z-axis,-0.051, °/s
IDE04443-IDE04460,Slip control system sensor-Steering angle sensor: offset straight line running,40.775, °
IDE04443-MAS00815,Slip control system sensor-Steering angle sensor,4.681, °
IDE04446-IDE01599,Hill descent control-Slope,0, %
IDE04446-IDE03664,Hill descent control-Button for driving program,not activated,
IDE04446-MAS03095,Hill descent control-Function status,not active,
IDE04452-IDE03662,Brake system button-ASR/ESP button,Not operated,
IDE04452-IDE03663,Brake system button--AUTO HOLD- Button,Not operated,
IDE04452-IDE03664,Brake system button-Button for driving program,Not operated,
IDE04452-IDE04432,Brake system button-Tire Pressure Monitoring Display Button,Not operated,
IDE04452-IDE04769,Brake system button-Electro-mechanical parking brake button: status,Not operated,
IDE04456-IDE02955,Brake disk drying-System status,Available,
IDE04456-IDE04775,Brake disk drying-Odometer reading of last activation,135533, km
IDE04461-IDE03208,Internal measured values-Software version for suppliers,MXERAH00014,
IDE04461-IDE03649,Internal measured values-Fill/bleed brake system,completed successfully,
IDE04461-MAS01481,Internal measured values-Temperature in control module,33, °C
IDE04461-MAS04484,Internal measured values-Flashloader version, TSCBAF00012,
IDE04499-IDE02955,Sensor for roof rack recognition-System status,Not available due to specific system,
IDE04499-MAS03095,Sensor for roof rack recognition-Function status,not recognised,
IDE04508-IDE02955,Hydraulic brake booster-System status,Available,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,Malfunction,
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.50, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,0, mbar
IDE04644-IDE02955,Roll-over protection-System status,Available,
IDE04644-IDE04775,Roll-over protection-Odometer reading of last activation,0, km
IDE04645-IDE00003,Electromechanical parking brake-Coding,will be performed.,
IDE04645-IDE00902,Electromechanical parking brake-Automatic distance control: status,activated,
IDE04645-IDE02652,Electromechanical parking brake-Start-stop status,activated,
IDE04645-IDE02955,Electromechanical parking brake-System status,Available,
IDE04645-IDE03493,Electromechanical parking brake-Driver's door status,activated,
IDE04645-IDE04871,Electromechanical parking brake-Dynamic starting assist,activated,
IDE04645-IDE04944,Electromechanical parking brake-Brake pedal evaluation,activated,
IDE04645-IDE04948,Electromechanical parking brake-Fall-back level,0,
IDE04645-IDE05711,Electromechanical parking brake-Automatic application during engine stalling,activated,
IDE04645-IDE06590,Electromechanical parking brake-Play protection counter: button for electromech. parking brake,0,
IDE04645-MAS02666,Electromechanical parking brake-Seat belt buckle scan,activated,
IDE04645-MAS03998,Electromechanical parking brake-Delay interface for electro-mechanical parking brake,6,
IDE04646-IDE02657,Electromechanical parking brake: parking brake motors-Cut-off current: left: reached,0.00, A
IDE04646-IDE02658,Electromechanical parking brake: parking brake motors-Cut-off current: right: reached,0.00, A
IDE04646-IDE04496,Electromechanical parking brake: parking brake motors-Left parking brake motor: status,closed,
IDE04646-IDE04497,Electromechanical parking brake: parking brake motors-Right parking brake motor: status,closed,
IDE04646-IDE04506,Electromechanical parking brake: parking brake motors-Calculated left rear brake temperature,26.5, °C
IDE04646-IDE04507,Electromechanical parking brake: parking brake motors-Calculated right rear brake temperature,26.5, °C
IDE04646-IDE04647,Electromechanical parking brake: parking brake motors-Left parking brake motor: current,0.00, A
IDE04646-IDE04648,Electromechanical parking brake: parking brake motors-Right parking brake motor: current,0.00, A
IDE04646-IDE05048,Electromechanical parking brake: parking brake motors-Left parking brake motor: actuation counter,9367,
IDE04646-IDE05049,Electromechanical parking brake: parking brake motors-Right parking brake motor: actuation counter,9367,
IDE04765-IDE02955,Counter steer support-System status,Available,
IDE04765-IDE04775,Counter steer support-Odometer reading of last activation,136248, km
IDE04772-IDE03530,Indicator light in the button for electromech. parking brake-Monitoring status,7,
IDE04772-MAS03745,Indicator light in the button for electromech. parking brake-Function light,On,
IDE04774-IDE02955,Vehicle and trailer stabilization-System status,Available,
IDE04774-IDE04775,Vehicle and trailer stabilization-Odometer reading of last activation,0, km
IDE04871-IDE01599,Dynamic starting assist-Slope,0, %
IDE04871-IDE02445,Dynamic starting assist-Transmission type,automatic,
IDE04871-MAS01447,Dynamic starting assist-Actual value,normal,
IDE04871-MAS03995,Dynamic starting assist-Clutch pedal threshold: initial value,60, %
IDE04871-MAS03996,Dynamic starting assist-Clutch pedal threshold: learned value,0, %
IDE04871-MAS04734,Dynamic starting assist-Required engine torques: current slope (TARGET),0, Nm
IDE04871-MAS04735,Dynamic starting assist-Current engine torques (ACTUAL),0, Nm
IDE04871-MAS04736,Dynamic starting assist-Expected achievable engine torques,0, Nm
IDE04939-IDE02955,Tire Pressure Monitoring System (TPMS)-System status,Available,
IDE04939-IDE04248,Tire Pressure Monitoring System (TPMS)-Left front tire pressure diffusion indicator,252,
IDE04939-IDE04249,Tire Pressure Monitoring System (TPMS)-Right front tire pressure diffusion indicator,252,
IDE04939-IDE04250,Tire Pressure Monitoring System (TPMS)-Left rear tire pressure diffusion indicator,252,
IDE04939-IDE04251,Tire Pressure Monitoring System (TPMS)-Right rear tire pressure diffusion indicator,252,
IDE04939-IDE04432,Tire Pressure Monitoring System (TPMS)-Tire Pressure Monitoring Display Button,Not operated,
IDE04939-IDE04946,Tire Pressure Monitoring System (TPMS)-Odometer reading at last adaptation,136054, km
IDE04939-IDE04947,Tire Pressure Monitoring System (TPMS)-Odometer reading of last warning,122883, km
IDE04939-MAS04538,Tire Pressure Monitoring System (TPMS)-Odometer reading two adaptations ago,134943, km
IDE04939-MAS04539,Tire Pressure Monitoring System (TPMS)-Odometer reading three adaptations ago,122923, km
IDE04939-MAS04540,Tire Pressure Monitoring System (TPMS)-Odometer reading four adaptations ago,113269, km
IDE04939-MAS04541,Tire Pressure Monitoring System (TPMS)-Odometer reading of next-to-last warning,63057, km
IDE04939-MAS04542,Tire Pressure Monitoring System (TPMS)-Odometer reading of third-to-last warning,57360, km
IDE04939-MAS04543,Tire Pressure Monitoring System (TPMS)-Odometer reading of fourth-to-last warning,44564, km
IDE04939-MAS04544,Tire Pressure Monitoring System (TPMS)-Left front flat tire indicator,255,
IDE04939-MAS04545,Tire Pressure Monitoring System (TPMS)-Right front flat tire indicator,255,
IDE04939-MAS04546,Tire Pressure Monitoring System (TPMS)-Left rear flat tire indicator,254,
IDE04939-MAS04547,Tire Pressure Monitoring System (TPMS)-Right rear flat tire indicator,254,
IDE05712-IDE02955,AUTO HOLD-System status,Available,
IDE05712-IDE03530,AUTO HOLD-Monitoring status,7,
IDE05712-IDE04498,AUTO HOLD--AUTO HOLD- Indicator Lamp,OFF,
IDE05712-IDE04561,AUTO HOLD-Switch-on and shut-off conditions,valid,
IDE05712-IDE05333,AUTO HOLD-Indicator light in AUTO HOLD button,OFF,
IDE05712-MAS00025,AUTO HOLD-Driver seat belt switch,not connected,
IDE05712-MAS03095,AUTO HOLD-Function status,not active,
IDE05712-MAS04006,AUTO HOLD-Operating mode,Last setting,
IDE05712-MAS04409,AUTO HOLD-Active hold,not active,
IDE05712-MAS04411,AUTO HOLD-Hydraulic pressure transfer to electro-mechanical parking brake,No,
IDE06422-ENG103176,IUMPR_1-General Denominator,3493,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,17553,
IDE06422-ENG100120,IUMPR_1-Milage,130470,
IDE06422-ENG102846,IUMPR_1-Number of IUMPR Records,1,
IDE06423-ENG101817,IUMPR_2-Denominator,1787,
IDE06423-ENG103772,IUMPR_2-DFCC Value,01 06,
IDE06423-ENG99150,IUMPR_2-Numerator,1787,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06591-ENG118150,Pump load counter-Comp_Rotatation_of_pump_motor,625680,
IDE06591-ENG118152,Pump load counter-Load_on_feeding_side_of_Pump,3441892,
IDE06591-ENG118151,Pump load counter-Load_on_suction_side_of_Pump,19323,
IDE06591-ENG118153,Pump load counter-Pump_motor_start_counter,64573,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,0,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,0,
IDE07280-MAS00110,Multiple collision brake-Minutes,0,
IDE07280-MAS00111,Multiple collision brake-Seconds,0,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
IDE80101,Analysis 101,A3 32 38 35 31 36 33 31 39 33 31 33 30 30 30 30 36 32 30 37 31 30 30 30 32 32 44 2F 02 00 3E 45 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE80102-ENG122580,Analysis 102-value_1_percentaged,98.4312, %
IDE80102-ENG122579,Analysis 102-value_1_quantity,0,
IDE80102-ENG122582,Analysis 102-value_2_percentaged,103.118, %
IDE80102-ENG122581,Analysis 102-value_2_quantity,0,
IDE80102-ENG122584,Analysis 102-value_3_percentaged,96.8688, %
IDE80102-ENG122583,Analysis 102-value_3_quantity,6035,
IDE80102-ENG122586,Analysis 102-value_4_percentaged,98.0406, %
IDE80102-ENG122585,Analysis 102-value_4_quantity,7918,
IDE80102-ENG122588,Analysis 102-value_5_percentaged,98.0406, %
IDE80102-ENG122587,Analysis 102-value_5_quantity,2696,
IDE80102-ENG122590,Analysis 102-value_6_percentaged,105.462, %
IDE80102-ENG122589,Analysis 102-value_6_quantity,5737,
IDE80103-MAS00976,Analysis 103-Counter,0,
MAS00121-IDE02955,Electronic Differential Lock-System status,Available,
MAS00121-IDE04504,Electronic Differential Lock-Calculated left front brake temperature,26.5, °C
MAS00121-IDE04505,Electronic Differential Lock-Calculated right front brake temperature,26.5, °C
MAS00121-IDE04506,Electronic Differential Lock-Calculated left rear brake temperature,26.5, °C
MAS00121-IDE04507,Electronic Differential Lock-Calculated right rear brake temperature,26.5, °C
MAS00121-MAS00179,Electronic Differential Lock-Brake lamp switch,Not operated,
MAS00121-MAS01853,Electronic Differential Lock-Left front,Available,
MAS00121-MAS01854,Electronic Differential Lock-Right front,Available,
MAS00121-MAS01855,Electronic Differential Lock-Left rear,Available,
MAS00121-MAS01856,Electronic Differential Lock-Right rear,Available,
MAS00210-IDE80007,Parking Brake-Analysis 7,0, km
MAS00210-IDE80008,Parking Brake-Analysis 8,136159, km
MAS00210-IDE80009,Parking Brake-Analysis 9,136252, km
MAS00210-IDE80010,Parking Brake-Analysis 10,99321, km
MAS00210-IDE80011,Parking Brake-Analysis 11,136252, km
MAS00210-IDE80012,Parking Brake-Analysis 12,8F 0A 11 10 02 0C,
MAS00210-ENG167752,Parking Brake-ActDbg_ECR_EvCnt,0,
MAS00210-ENG167753,Parking Brake-ActDbg_ESA_EvCnt,0,
MAS00210-ENG167754,Parking Brake-ActDbg_OTH_EvCnt,0,
MAS00210-ENG167755,Parking Brake-ActDbg_SAR_EvCnt,0,
MAS00210-ENG167756,Parking Brake-ActDbg_UV_EvCnt,0,
MAS00210-ENG167757,Parking Brake-ActDbg_UVE_EvCnt,0,
MAS00911-IDE02955,All Wheel Drive (AWD)-System status,Not available due to specific system,
MAS00911-IDE04502,All Wheel Drive (AWD)-Haldex clutch: status,No malfunction detected,
MAS00911-IDE04943,All Wheel Drive (AWD)-Haldex clutch,Fully open,
MAS00911-MAS04730,All Wheel Drive (AWD)-Degree of blockage,0, Nm
MAS02138-IDE02955,Hill-start assistant-System status,Available,
MAS02138-MAS00025,Hill-start assistant-Driver seat belt switch,not connected,
MAS02138-MAS00218,Hill-start assistant-Driver´s door,closed,
MAS02138-MAS03095,Hill-start assistant-Function status,not active,
MAS02426-MAS00580,Text display in instrument cluster-Electromechanical parking brake text 1,0,
MAS02426-MAS03359,Text display in instrument cluster-Text,0,
MAS02672-IDE02955,Start-stop-System status,Available,
MAS02672-IDE03214,Start-stop-Engine stop using start-stop function,not active,
MAS02672-IDE03215,Start-stop-Engine start using start-stop function,not active,
MAS02672-MAS00025,Start-stop-Driver seat belt switch,not connected,
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
ENG101413,Calibration Identifications,5Q0517GF03144AC9,
ENG99697,Calibration Verification Numbers,95 07 FF D9,
ENG100152-ENG104003,ECUNAME-ECU,BSCM,
ENG100152,ECUNAME,BrakeSystem,
ENG157353-IDE01011,HBV_Event_Counter-Data record,0,
Elapsed Time: 00:16
blockmap-05-3Q0-959-435-M_WVWZZZ3CZME009325-20260823-2121.CSV
;SW:3Q0-959-435-M   HW:3Q0-959-435-M ---  05: Acc/Start Auth.
;Component:VWKESSYMQB    027 1307, Coding:002F0F0723
;EV_KessyHellaMQBAB,004052,EV_KessyHellaMQBAB_VW41.rod
;Sunday,23,August,2026,21:21:52:32152
;VCID: 44DA236AAE1C06AABAA-8010
IDE00019,Voltage terminal 30,13.163, V
IDE00021,Engine speed,0.0, /min
IDE00021-MAS02248,Engine speed-Signal status,valid,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal status,valid,
IDE00096-MAS02248,Selector lever position-Signal status,Current,
IDE00096,Selector lever position,OK,
IDE00322,Status of basic setting,Basic setting ended,
IDE02406,Key number of last identified ID sensor,Not available,
IDE02407,Status of vehicle locking,Vehicle unlocked,
IDE02408-MAS00218,Individual door locking: status-Driver´s door,closed,
IDE02408-MAS00219,Individual door locking: status-Passenger´s door,closed,
IDE02408-MAS00220,Individual door locking: status-Rear left door,closed,
IDE02408-MAS00221,Individual door locking: status-Rear right door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Not available,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,Not coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,Not coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,0,
IDE02419,Proximity sensor frt.pass. door: number of triggers,0,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,FF,
IDE02422-MAS01483,Driver door handle: version information-Software version,FF,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,FF,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,FF,
IDE02423-MAS01483,ass. door handle: version information-Software version,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,00,
IDE02424-MAS01483,Left rear door handle: version information-Software version,00,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,00,
IDE02425-MAS01483,Right rear door handle: version information-Software version,00,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,00,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,No,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,No,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,No,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,No,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,No,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,No,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72h-Signaling counter left rear door,0,
IDE02485,72h-Signaling counter right rear door,0,
IDE02495,Service-Key: Number of activations,3928,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,Not operated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,Not operated,
IDE02579,Park selector lever position,Engaged and locked,
IDE02581,Drive train uncoupling,decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake lamp switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal status,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,Closed,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,0,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,Empty,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Empty,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Empty,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Empty,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Empty,
IDE03128,Requested start processes (ring memory),Empty,
IDE03213,Start/stop enable,All releases are present,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,PASSIVE_SERVICE_KEY,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,SERVICE_KEY,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,00,
IDE05204,Manufacturer production data door handle drivers door,FF FF FF FF FF,
IDE05205,Manufacturer production data door handle front pass.door,FF FF FF FF FF,
IDE05206,Manufacturer production data door handle left rear,00 00 00 00 00,
IDE05207,Manufacturer production data door handle right rear,00 00 00 00 00,
IDE07028,Time until shut-off terminal S,1800, s
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition not met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,99,
IDE08440,Recommendation energy management,no restriction,
IDE80258,Immobilizer status,Electronic steering locking device installed,
IDE80258-MAS00106,Immobilizer status-Year,2020,
IDE80258-MAS00107,Immobilizer status-Month,8,
IDE80258-MAS00108,Immobilizer status-Day,25,
IDE80258-MAS00109,Immobilizer status-Hours,8,
IDE80258-MAS00110,Immobilizer status-Minutes,33,
IDE80258-MAS00111,Immobilizer status-Seconds,54,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,21,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,125,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,136252, km
MAS01493,Engine is running,not active,
MAS03554,Clutch pedal operation,Yes,
MAS03607,Engine stop active in Start/Stop mode,active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG160891,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG160890,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG160889,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG160888,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,13.146, V
ENG139762,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_nicht_entriegelt,
ENG245551,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2026,
ENG125220-MAS00107,History last automatic terminal switch off-Month,6,
ENG125220-MAS00107,History last automatic terminal switch off-Month,8,
ENG125220-MAS00108,History last automatic terminal switch off-Day,17,
ENG125220-MAS00108,History last automatic terminal switch off-Day,14,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,13,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,16,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,9,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,48,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,58,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,39,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,57,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,53,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,5,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,11,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,8,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,51,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,135895, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,135888, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,135891, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,135895, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,135895, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG249150-MAS00111,History_low_voltage-Seconds,0, s
ENG249150-MAS00111,History_low_voltage-Seconds,2703872, s
ENG249150-ENG249469,History_low_voltage-Function_restriction_n,No_function_restriction,
ENG249150-ENG249453,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG249150-ENG249295,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG249150-ENG249381,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG249150-ENG249352,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG249150-ENG249461,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG249150-ENG249401,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG249150-ENG249354,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG249150-ENG249339,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG249150-ENG249350,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_UNDERVOLTAGE_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,ECUEXT_RR_HPM_EOL,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG157998-MAS00106,lf_shutdowns-Year,2026,
ENG157998-MAS00107,lf_shutdowns-Month,8,
ENG157998-MAS00108,lf_shutdowns-Day,22,
ENG157998-MAS00108,lf_shutdowns-Day,21,
ENG157998-MAS00109,lf_shutdowns-Hours,20,
ENG157998-MAS00109,lf_shutdowns-Hours,17,
ENG157998-MAS00109,lf_shutdowns-Hours,10,
ENG157998-MAS00109,lf_shutdowns-Hours,16,
ENG157998-MAS00110,lf_shutdowns-Minutes,33,
ENG157998-MAS00110,lf_shutdowns-Minutes,54,
ENG157998-MAS00110,lf_shutdowns-Minutes,17,
ENG157998-MAS00110,lf_shutdowns-Minutes,58,
ENG157998-MAS00111,lf_shutdowns-Seconds,48,
ENG157998-MAS00111,lf_shutdowns-Seconds,59,
ENG157998-MAS00111,lf_shutdowns-Seconds,50,
ENG157998-MAS00111,lf_shutdowns-Seconds,1,
ENG157998-ENG163142,lf_shutdowns-Mileage_lf_shutdown_n,136204, km
ENG157998-ENG163143,lf_shutdowns-Mileage_lf_shutdown_n-1,136145, km
ENG157998-ENG163144,lf_shutdowns-Mileage_lf_shutdown_n-2,136129, km
ENG157998-ENG163145,lf_shutdowns-Mileage_lf_shutdown_n-3,136098, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,not active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,not active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,13,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,1,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG157420-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG157420-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG157420-ENG161108,Scan_cycle_data-Mileage_n,136080, km
ENG157420-ENG161109,Scan_cycle_data-Mileage_n-1,135987, km
ENG157420-ENG161110,Scan_cycle_data-Mileage_n-10,135496, km
ENG157420-ENG161111,Scan_cycle_data-Mileage_n-11,135459, km
ENG157420-ENG161112,Scan_cycle_data-Mileage_n-12,134945, km
ENG157420-ENG161113,Scan_cycle_data-Mileage_n-13,134847, km
ENG157420-ENG161114,Scan_cycle_data-Mileage_n-14,134847, km
ENG157420-ENG161115,Scan_cycle_data-Mileage_n-15,133713, km
ENG157420-ENG161116,Scan_cycle_data-Mileage_n-16,133635, km
ENG157420-ENG161117,Scan_cycle_data-Mileage_n-17,133635, km
ENG157420-ENG161118,Scan_cycle_data-Mileage_n-18,133635, km
ENG157420-ENG161119,Scan_cycle_data-Mileage_n-19,133195, km
ENG157420-ENG161120,Scan_cycle_data-Mileage_n-2,135987, km
ENG157420-ENG161121,Scan_cycle_data-Mileage_n-3,135895, km
ENG157420-ENG161122,Scan_cycle_data-Mileage_n-4,135891, km
ENG157420-ENG161123,Scan_cycle_data-Mileage_n-5,135849, km
ENG157420-ENG161124,Scan_cycle_data-Mileage_n-6,135836, km
ENG157420-ENG161125,Scan_cycle_data-Mileage_n-7,135783, km
ENG157420-ENG161126,Scan_cycle_data-Mileage_n-8,135706, km
ENG157420-ENG161127,Scan_cycle_data-Mileage_n-9,135613, km
ENG157420-ENG161148,Scan_cycle_data-Retry_count_n,9,
ENG157420-ENG161149,Scan_cycle_data-Retry_count_n -6,1,
ENG157420-ENG161150,Scan_cycle_data-Retry_count_n-1,10,
ENG157420-ENG161151,Scan_cycle_data-Retry_count_n-10,9,
ENG157420-ENG161152,Scan_cycle_data-Retry_count_n-11,9,
ENG157420-ENG161153,Scan_cycle_data-Retry_count_n-12,9,
ENG157420-ENG161154,Scan_cycle_data-Retry_count_n-13,28,
ENG157420-ENG161155,Scan_cycle_data-Retry_count_n-14,9,
ENG157420-ENG161156,Scan_cycle_data-Retry_count_n-15,9,
ENG157420-ENG161157,Scan_cycle_data-Retry_count_n-16,7,
ENG157420-ENG161158,Scan_cycle_data-Retry_count_n-17,12,
ENG157420-ENG161159,Scan_cycle_data-Retry_count_n-18,9,
ENG157420-ENG161160,Scan_cycle_data-Retry_count_n-19,9,
ENG157420-ENG161161,Scan_cycle_data-Retry_count_n-2,9,
ENG157420-ENG161162,Scan_cycle_data-Retry_count_n-3,9,
ENG157420-ENG161163,Scan_cycle_data-Retry_count_n-4,5,
ENG157420-ENG161164,Scan_cycle_data-Retry_count_n-5,9,
ENG157420-ENG161165,Scan_cycle_data-Retry_count_n-7,9,
ENG157420-ENG161166,Scan_cycle_data-Retry_count_n-8,9,
ENG157420-ENG161167,Scan_cycle_data-Retry_count_n-9,9,
ENG157420-ENG161186,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG157420-ENG161187,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG157420-ENG161188,Scan_cycle_data-Scan_reason_n-10,Driver_door,
ENG157420-ENG161189,Scan_cycle_data-Scan_reason_n-11,Driver_door,
ENG157420-ENG161190,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG157420-ENG161191,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG157420-ENG161192,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG157420-ENG161193,Scan_cycle_data-Scan_reason_n-15,Driver_door,
ENG157420-ENG161194,Scan_cycle_data-Scan_reason_n-16,trunk,
ENG157420-ENG161195,Scan_cycle_data-Scan_reason_n-17,Driver_door,
ENG157420-ENG161196,Scan_cycle_data-Scan_reason_n-18,Driver_door,
ENG157420-ENG161197,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG157420-ENG161198,Scan_cycle_data-Scan_reason_n-2,rear_left_door,
ENG157420-ENG161199,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG157420-ENG161200,Scan_cycle_data-Scan_reason_n-4,Driver_door,
ENG157420-ENG161201,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG157420-ENG161202,Scan_cycle_data-Scan_reason_n-6,Driver_door,
ENG157420-ENG161203,Scan_cycle_data-Scan_reason_n-7,Driver_door,
ENG157420-ENG161204,Scan_cycle_data-Scan_reason_n-8,Driver_door,
ENG157420-ENG161205,Scan_cycle_data-Scan_reason_n-9,Driver_door,
ENG157420-ENG161206,Scan_cycle_data-Scan_trigger_n,Set_stop_car,
ENG157420-ENG161207,Scan_cycle_data-Scan_trigger_n-1,Reset_stop_car,
ENG157420-ENG161208,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG157420-ENG161209,Scan_cycle_data-Scan_trigger_n-11,Set_stop_car,
ENG157420-ENG161210,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG157420-ENG161211,Scan_cycle_data-Scan_trigger_n-13,Reset_stop_car,
ENG157420-ENG161212,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG157420-ENG161213,Scan_cycle_data-Scan_trigger_n-15,Set_stop_car,
ENG157420-ENG161214,Scan_cycle_data-Scan_trigger_n-16,Reset_stop_car,
ENG157420-ENG161215,Scan_cycle_data-Scan_trigger_n-17,Reset_stop_car,
ENG157420-ENG161216,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG157420-ENG161217,Scan_cycle_data-Scan_trigger_n-19,Set_stop_car,
ENG157420-ENG161218,Scan_cycle_data-Scan_trigger_n-2,Set_stop_car,
ENG157420-ENG161219,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG157420-ENG161220,Scan_cycle_data-Scan_trigger_n-4,Reset_stop_car,
ENG157420-ENG161221,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG157420-ENG161222,Scan_cycle_data-Scan_trigger_n-6,Reset_stop_car,
ENG157420-ENG161223,Scan_cycle_data-Scan_trigger_n-7,Set_stop_car,
ENG157420-ENG161224,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG157420-ENG161225,Scan_cycle_data-Scan_trigger_n-9,Set_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2026,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00107,service_key_internal_status-Month,8,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00108,service_key_internal_status-Day,23,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,17,
ENG129035-MAS00111,service_key_internal_status-Seconds,13,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-MAS00111,service_key_internal_status-Seconds,14,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK.,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG139702-ENG140253,WFS_key_signature-clap_15_activateing_signature,01,
ENG139702-ENG140248,WFS_key_signature-signature_key_1,05 B6,
ENG139702-ENG140249,WFS_key_signature-signature_key_2,05 DB,
ENG139702-ENG140250,WFS_key_signature-signature_key_3,00 00,
ENG139702-ENG140251,WFS_key_signature-signature_key_4,00 00,
ENG139702-ENG140252,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:19
blockmap-08-3G8-907-056-A_WVWZZZ3CZME009325-20260823-2123.CSV
;SW:3G8-907-056-A   HW:3G8-907-056-A ---  08: Auto HVAC
;Component:Climatronic   H10 0205, Coding:12021004200114010915100080101832
;EV_AirCondiBHTCMQB3rTranc,001050,EV_AirCondiBHTCMQB3rTranc_001_VW48.rod
;Sunday,23,August,2026,21:23:27:32152
;VCID: 2E0E61C210909CFA7CE-807A
IDE00019,Voltage terminal 30,13.0, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,24.0, °C
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00198,Refrigerant pressure,7.2, bar
IDE00767,No. of unscheduled ECU resets,15,
IDE00965,Compressor shut-off condition,Electric compressor: not ready to drive,
IDE00968,Compressor speed,0, /min
IDE00970,Coolant fan activation: actual value,10.0, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,26.0, °C
IDE00974,Outside air temperature internally calculated,26.0, °C
IDE00976,Left front vent temperature,27.0, °C
IDE00977,Right front vent temperature,27.0, °C
IDE00981,Footwell vent temperature,27.0, °C
IDE00982,Temperature downstream of evaporator,27.0, °C
IDE00983,Inside temperature,31.2, °C
IDE00984,Sun intensity left,0, W/m²
IDE00985,Sun intensity right,0, W/m²
IDE00987,Blower voltage: specified value,1.4, V
IDE00989,Blower status,not active,
IDE00994,Actual value for fresh air/recirculation air flow flap,94,
IDE00994,Actual value for fresh air/recirculation air flow flap,32.5, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,93,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,37,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,212,
IDE00998,Left temperature flap - actual value,71,
IDE00998,Left temperature flap - actual value,20.0, %
IDE00999,Temperature door left - Specified value,159,
IDE01040,Left Temperature Control Door - cold stop,30,
IDE01041,Left temperature flap: warm stop,233,
IDE01042,Right temperature flap: actual value,62,
IDE01042,Right temperature flap: actual value,17.5, %
IDE01043,Temperature door right - Specified value,155,
IDE01044,Right temperature flap: cold stop,26,
IDE01045,Right temperature flap: warm stop,229,
IDE01050,Front air distribution flap: actual value,0.0, %
IDE01050,Front air distribution flap: actual value,21,
IDE01051,Air distribution door front - Specified value,20,
IDE01052,Front air distribution flap: air outlet stop,25,
IDE01053,Front air distribution flap: footwell air outlet stop,236,
IDE01054,Defroster flap: actual value,75.5, %
IDE01054,Defroster flap: actual value,181,
IDE01055,Defrost door - Specified value,237,
IDE01056,Defroster flap: stop open,20,
IDE01057,Defroster flap: stop closed,232,
IDE01063,Status of recirculation air,Fresh air,
IDE01065,Rear vent temperature,26.0, °C
IDE01066,Convertible top status,Closed,
IDE01076,Time since ignition off,240, min
IDE01088,Rear temperature flap: actual value,74.0, %
IDE01088,Rear temperature flap: actual value,183,
IDE01089,Rear temperature flap: specified value,244,
IDE01090,Rear temperature flap: cold stop,21,
IDE01091,Rear temperature flap: warm stop,239,
IDE01217-MAS01447,Left heated seat stage-Actual value,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Actual value,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,0.1, V
IDE01227,Blower current,0.00, A
IDE01232,Supply voltage for external components,5.0, V
IDE01264,Remaining time of parking heater/ventilation operation,0, s
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,2750,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,0,
IDE01419,Compressor shut-off condition: last,Shut-off from Engine Control Module (ECM) via CAN,
IDE01420,Compressor shut-off requirement: penultimate,Compressor activation: malfunction in activation path,
IDE01421,Compressor shut-off requirement: antepenultimate,Shut-off from Engine Control Module (ECM) via CAN,
IDE01433,Air quality status,Clean air,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01577,Pressing a button-Auxiliary heating,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01442-MAS17527,Pressing a button-Air Care,Not operated,
IDE01443,Left push-and-rotary knob counter,255,
IDE01444,Right push-and-rotary knob counter,255,
IDE02270-IDE01268,CAN input signal(s) status-Front windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management: shut-off stage,Deactivation stage 0,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,OFF,
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127,Prevented stop processes (ring memory),Stop release,
IDE03128,Requested start processes (ring memory),Stop release,
IDE03213,Start/stop enable,System malfunction,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,0, s
IDE04312-MAS00084,System run time-Terminal 15 on,253, s
IDE04797,Center push-and-rotary knob counter,255,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,100,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,27.0, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,27.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,68.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,20.5, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,30.60, °C
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,34.70, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,54.00, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,24.1, °C
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,No enabling,
IDE06234-MAS01447,Auxiliary heater: in stages-Actual value,1,
IDE06234-MAS01448,Auxiliary heater: in stages-Specified value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE07617-IDE05241,Compressor status: global-A/C compressor release status,transmitted,
IDE07617-IDE06336,Compressor status: global-A/C compressor: target speed,0.00, /min
IDE07617-IDE06337,Compressor status: global-A/C compressor: actual speed,0.00, /min
IDE07617-MAS04770,Compressor status: global-A/C compressor: function status,Air conditioner compressor off,
IDE07617-MAS05974,Compressor status: global-A/C compressor error indicator,not active,
IDE07617-MAS05975,Compressor status: global-A/C compressor: veh. elec. syst. volt.,Measuring value not available,
IDE07617-MAS05976,Compressor status: global-A/C compressor: inverter temperature,37.00, °C
IDE07618-MAS04779,Compressor status: internal-A/C compressor: power limitation,not active,
IDE07618-MAS05976,Compressor status: internal-A/C compressor: inverter temperature,OK,
IDE07618-MAS05979,Compressor status: internal-A/C compressor: start-up monitor,OK,
IDE07618-MAS05980,Compressor status: internal-A/C compressor: internal inverter communication,OK,
IDE07618-MAS05981,Compressor status: internal-A/C compressor: Communication internal gateway,OK,
IDE07618-MAS05982,Compressor status: internal-A/C compressor: icing protection,not active,
IDE07618-MAS05983,Compressor status: internal-Inverter: Status,not active,
IDE07618-MAS05984,Compressor status: internal-A/C compressor: speed (RPM) protection,not active,
IDE09168-MAS01632,Refrigerant Shut-Off Valve 1-Status,Open,
IDE09169-MAS01632,Refrigerant Shut-Off Valve 2-Status,Open,
IDE09171-MAS01447,Coolant circulation pump 1-Actual value,440,
IDE09171-MAS01448,Coolant circulation pump 1-Specified value,0,
IDE09172,Coolant change-over valve 1,not installed,
IDE09173-MAS01447,Coolant circulation pump 2-Actual value,0,
IDE09173-MAS01448,Coolant circulation pump 2-Specified value,0,
IDE09174,Coolant change-over valve 2,operated,
IDE09179,Relay for standstill A/C: status,operated,
IDE09186-MAS01447,Coolant circulation pump 3-Actual value,65535,
IDE09186-MAS01448,Coolant circulation pump 3-Specified value,0,
IDE09189-IDE09201,HV heater temperature-Intake temperature,27.00, °C
IDE09189-IDE09202,HV heater temperature-Exhaust Temperature,27.00, °C
IDE09190,Coolant change-over valve 3,not installed,
IDE09193,Temperature sensor 1,30.40, °C
IDE09196,Temperature sensor 4,13067.00, °C
IDE09197,Temperature sensor 5,13067.00, °C
IDE09198-MAS01448,HV heater status: global-Specified value,0, %
IDE09198-MAS08432,HV heater status: global-Requirement,not active,
IDE09199-IDE00008,HV heater status: internal-Software version,0,
IDE09199-IDE09201,HV heater status: internal-Intake temperature,27.00, °C
IDE09199-IDE09202,HV heater status: internal-Exhaust Temperature,27.00, °C
IDE09199-MAS01481,HV heater status: internal-Temperature in control module,38.00, °C
IDE09199-MAS01482,HV heater status: internal-Hardware version,0,
IDE09199-MAS01634,HV heater status: internal-Supply voltage,OK,
IDE09199-MAS01634,HV heater status: internal-Supply voltage,13.10,
IDE09199-MAS02246,HV heater status: internal-Timeout,OK,
IDE09199-MAS03746,HV heater status: internal-Current: actual value,0.00, A
IDE09199-MAS07055,HV heater status: internal-Response error,OK,
IDE09199-MAS09468,HV heater status: internal-Vehicle high voltage system,OK,
IDE09199-MAS09469,HV heater status: internal-HV heater: status,OK,
IDE09199-ENG128274,HV heater status: internal-PTC_HV_Err_Heizkreis_1,OK,
IDE09199-ENG128275,HV heater status: internal-PTC_HV_Err_Heizkreis_2,OK,
IDE09199-ENG128276,HV heater status: internal-PTC_HV_Err_Heizkreis_3,OK,
IDE09199-ENG128280,HV heater status: internal-PTC_HV_Err_intern,OK,
IDE09199-ENG128277,HV heater status: internal-PTC_HV_Err_Leckagestrom,OK,
IDE09199-ENG128279,HV heater status: internal-PTC_HV_Err_Temperaturschutz,OK,
IDE09199-ENG128278,HV heater status: internal-PTC_HV_Err_Ueberstromabschaltung,OK,
IDE09203,HV heater shut-off condition,No enabling,
IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,0, min
IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,1,
IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,0.00, W
IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,0, W
IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,0, Ws
IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,no overflow,
IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,0, Ws
IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,no overflow,
IDE12141-MAS02526,History memory: parking heater-Activation,Unknown (15)
IDE12141-MAS04390,History memory: parking heater-Active source,Unknown (15)
IDE12141-ENG98504,History memory: parking heater-Day,31,
IDE12141-ENG98653,History memory: parking heater-Hour,31,
IDE12141-ENG98739,History memory: parking heater-Minute,63,
IDE12141-ENG98748,History memory: parking heater-Month,15,
IDE12141-ENG98884,History memory: parking heater-Seconds,63,
IDE12141-ENG99063,History memory: parking heater-Year,2127,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine is running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-ENG98504,Standard - ambient data 1-Day,23,
MAS00464-ENG98653,Standard - ambient data 1-Hour,21,
MAS00464-ENG98739,Standard - ambient data 1-Minute,23,
MAS00464-ENG98748,Standard - ambient data 1-Month,8,
MAS00464-ENG98884,Standard - ambient data 1-Seconds,34,
MAS00464-ENG99063,Standard - ambient data 1-Year,2026,
MAS05977-IDE01233,Compressor: energy monitor-Compressor motor current,0.00, A
MAS05977-IDE05237,Compressor: energy monitor-A/C compressor power consumption: actual value,0.00, kW
MAS05977-MAS05978,Compressor: energy monitor-High voltage supply voltage,390.00, V
MAS11295,Refrigerant temperature,6513.50, °C
Elapsed Time: 00:15
blockmap-09-5Q0-937-086-CK_WVWZZZ3CZME009325-20260823-2124.CSV
;SW:5Q0-937-086-CK   HW:5Q0-937-086-BR ---  09: Cent. Elect.
;Component:BCM PQ37BOSCH 040 0400, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,021001,EV_BCMBOSCH_021_VW27.rod
;Sunday,23,August,2026,21:24:14:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 055CFE6EE5A6FFA2ED4-8050
Group,Description,Actual
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded / not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded / not installed,
IDE00844-MAS07314,Switch for hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for hood-Bonnet_Magnetic_Lock,not coded / not installed,
IDE00973,Outside temperature,26.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded / not installed,
IDE01066,Convertible top status,not coded / not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded / not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded / not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded / not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded / not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlock button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,Closed,
IDE02092-MAS02447,Tailgate condition-Activation,Enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded / not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded / not installed,
IDE02515,Low beams,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not active,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear wiper,not active,
IDE02743,Main beam,|Connector number,Connector terminal number
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,254,
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,0, mA
IDE02857-IDE06012,Activation current-Background lighting,110, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,10, mA
IDE02857-ENG128455,Activation current-Cockpittaster_2,0, mA
IDE02857-ENG128456,Activation current-Cockpittaster_3,65532, mA
IDE02857-ENG128457,Activation current-Cockpittaster_4,65532, mA
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,65532, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,|Connector number,Connector terminal number
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,0.0, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,0.0,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,0.0, V
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,19.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,25.00, °C
IDE03504,Personalized settings,|profile,Comfort opening
IDE03638,Static cornering light,|Connector number,Connector terminal number
IDE04213,Central locking button,not coded / not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded / not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE02515,Expanded freeze frame conditions-Low beams,Not operated,
IDE04347-IDE04639,Expanded freeze frame conditions-Last wake-up cause,Button for rear lid unlocking in rear lid,
IDE04347-IDE07956,Expanded freeze frame conditions-redundant signal line,Resistance,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,26.5, °C
IDE04347-MAS02462,Expanded freeze frame conditions-Automatic high beam assist,operated,
IDE04347-MAS02788,Expanded freeze frame conditions-CAN,On,
IDE04347-MAS03835,Expanded freeze frame conditions-Position lamps,Not operated,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,13.1, V
IDE04347-MAS06466,Expanded freeze frame conditions-Parking light left,Not operated,
IDE04347-MAS06467,Expanded freeze frame conditions-Parking light right,Not operated,
IDE04347-MAS14232,Expanded freeze frame conditions-Light switch: zero setting,Not operated,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04925,Daytime running lamps,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,21.00, %
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,247900,
IDE05045-MAS05878,Front wiper module-level,not coded / not installed,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05533,Heater for nozzles,not active,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,Not operated,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,Not operated,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beams,Not operated,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded / not installed,
IDE05742-IDE07956,Light switch position-redundant signal line,Position lamps,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,Not operated,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded / not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded / not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator lamp in button,not coded / not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded / not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded / not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded / not installed,
IDE05829,Rear spoiler history data,|Spoiler_Activation_Trigger,Spoiler_Activation_Trigger_Date
IDE05830-MAS02282,Rear Spoiler-Position,not coded / not installed,
IDE05830-ENG115793,Rear Spoiler-Spoiler_Button,not coded / not installed,
IDE05830-ENG115792,Rear Spoiler-Spoiler_Cycle_Protection,not coded / not installed,
IDE05830-ENG115794,Rear Spoiler-Spoiler_Indication_Light,not coded / not installed,
IDE05830-ENG115791,Rear Spoiler-Spoiler_Position,not coded / not installed,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,kilometer reading
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,0, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,60, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,On,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,On,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,command_direction_locking
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,|Connector number,terminal
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.6, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,27.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,69.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.7, °C
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,100.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,100.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,100.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,99.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,Not operated,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,closed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,Not operated,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,On,
IDE06507-MAS13130,Button in center console-Status of button 2,Not operated,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,OFF,
IDE06507-MAS13133,Button in center console-Status of button 3,not coded / not installed,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,not coded / not installed,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded / not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded / not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded / not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded / not installed,
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-ENG247157,Wireless transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG247187,Wireless transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving
IDE06864,Daytime running lights,|Connector number,Connector terminal number
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,46.80, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,793.6, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.004, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,0, %
IDE07344-MAS02447,Sunroof shade-Activation,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Standardization,not standardized,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Implausible,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,Closed,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left neck heater-Operating State,not coded / not installed,
IDE08125-MAS06651,Left neck heater-PTC heater element: current consumption,not coded / not installed,
IDE08125-MAS06652,Left neck heater-Blower motor: speed,not coded / not installed,
IDE08125-MAS06653,Left neck heater-Indicator light for head area heater,not coded / not installed,
IDE08126-MAS01458,Right neck heater-Operating State,not coded / not installed,
IDE08126-MAS06651,Right neck heater-PTC heater element: current consumption,not coded / not installed,
IDE08126-MAS06652,Right neck heater-Blower motor: speed,not coded / not installed,
IDE08126-MAS06653,Right neck heater-Indicator light for head area heater,not coded / not installed,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Signal from door lock: released,
IDE08177-MAS13126,Central locking-Luggage hold closure,not coded / not installed,
IDE08211-MAS03129,History data control module reset-Reset counter,8,
IDE08211,History data control module reset,|last cause of reset,Year
IDE08343,Immobilizer Challenge,EC F2 B0 83,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,0, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,0, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,200, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,200, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,10, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,0, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,0, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,0, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,20, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,20, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,260, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,280, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,0, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,120, mA
IDE08949-MAS07893,Operating current: light driver-Conn. pin 26,380, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,380, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,40, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,0,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded / not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded / not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded / not installed,
IDE10753-IDE05540,Ambient light button-Internal light button,Not operated,
IDE10753-MAS10419,Ambient light button-Front reading lamp button: left,Not operated,
IDE10753-MAS10420,Ambient light button-Front reading lamp button: right,Not operated,
IDE10753-MAS10421,Ambient light button-Left rear reading lamp switch,Not operated,
IDE10753-MAS10422,Ambient light button-Right rear reading lamp button,Not operated,
IDE10753-MAS10423,Ambient light button-Left reading light button: 3rd seat row,Not operated,
IDE10753-MAS10424,Ambient light button-Right reading light button: 3rd seat row,Not operated,
IDE10753-MAS15633,Ambient light button-Rear interior light button,Not operated,
IDE10753-MAS15634,Ambient light button-Button for int. light dimming/door contact,Not operated,
IDE10753-MAS15635,Ambient light button-Button for areal light,Not operated,
IDE10753-MAS15636,Ambient light button-Supply voltage: interior light,0, V
IDE10754,Ambient light light status,|Light function,PWM pulse duty factor
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beams,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-Main beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Static cornering light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,Installed: not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,Installed: not active,
IDE11134-MAS11025,Light sequence HU test result-Status,no restriction,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,0, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,0, W/m²
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded / not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded / not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded / not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded / not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded / not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded / not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded / not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded / not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded / not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,Start-stop,
IDE11727-MAS13129,Function of the central console button-Function of button 2,GTE,
IDE11727-MAS13132,Function of the central console button-Function of button 3,not coded / not installed,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not available,
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Intermittent operation,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 1,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded / not installed,
IDE14110-MAS17842,Digital Key-NFC control section,Not operated,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded / not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,not inoperative,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,not inoperative,
IDE14172-MAS03695,Remote key movement information-Key 4,not inoperative,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Neck heating-Crash status,not coded / not installed,
IDE80251-MAS06646,Neck heating-Head area heater left: specified level,not coded / not installed,
IDE80251-MAS06647,Neck heating-Head area heater right: specified level,not coded / not installed,
IDE80251-MAS06648,Neck heating-Continuation at terminal 15 on,not coded / not installed,
IDE80251-MAS06649,Neck heating-Left front seat occupation status,not coded / not installed,
IDE80251-MAS06650,Neck heating-Right front occupation status,not coded / not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,13.15, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,13.15, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,13.15, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,13.15, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,13.10, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,13.15, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00043-ENG250713,Terminal 30 power supply-Messauswertung Pruefspannung Wischerablagenheizung,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,24,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,32,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,125,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,136252, km
MAS00829-MAS00244,Access/start authorization-Wake-up wire,Not operated,
MAS00829-MAS01763,Access/start authorization-Field intensity,-62,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,5, ms
MAS01281,Back-up lamps,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge status,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,OK,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,not enabled,
MAS01490-IDE04216,Energy management-Mirror heater,not enabled,
MAS01490-IDE80251,Energy management-Neck heating,not coded / not installed,
MAS01490-MAS01535,Energy management-Rear window defogger,not enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,not coded / not installed,
MAS01490-MAS01564,Energy management-Windshield defogger,not coded / not installed,
MAS01490-MAS01632,Energy management-Status,active,
MAS01490-MAS02390,Energy management-Shutoff,7,
MAS01490-MAS05795,Energy management-Rear seat heating,not enabled,
MAS01490-MAS05796,Energy management-Emergency shut-off,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,not coded / not installed,
MAS01490-MAS06552,Energy management-Seat heating: front,No enabling,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,1,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,0, %
MAS01597-MAS02447,Sunroof-Activation,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Standardization,not standardized,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS08202-MAS09607,CAN p locked-Switch p locked,Engaged and locked,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded / not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
ENG116910,Control unit internal measured value (supplier),32 30 30 30 30 30 30 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin A32 Heckdeckel Softtouch TasterPin,
ENG116908-ENG115779,Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an,0, H
ENG116908-ENG115778,Ecu_Intern_Meas._Values_2-Hours_of_operation,0, H
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0,
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,0,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG117286-ENG116724,Kopfraumheizung_Entwicklung-KRH_l_Error,not coded / not installed,
ENG117286-ENG116725,Kopfraumheizung_Entwicklung-KRH_l_Error_Gueltigkeit,not coded / not installed,
ENG117286-ENG116723,Kopfraumheizung_Entwicklung-KRH_l_Luefter_Error,not coded / not installed,
ENG117286-ENG116727,Kopfraumheizung_Entwicklung-KRH_l_PTC_Error,not coded / not installed,
ENG117286-ENG116726,Kopfraumheizung_Entwicklung-KRH_l_ResponseError,not coded / not installed,
ENG117286-ENG116730,Kopfraumheizung_Entwicklung-KRH_r_Error,not coded / not installed,
ENG117286-ENG116731,Kopfraumheizung_Entwicklung-KRH_r_Error_Gueltigkeit,not coded / not installed,
ENG117286-ENG116728,Kopfraumheizung_Entwicklung-KRH_r_Luefter_Error,not coded / not installed,
ENG117286-ENG116729,Kopfraumheizung_Entwicklung-KRH_r_PTC_Error,not coded / not installed,
ENG117286-ENG116732,Kopfraumheizung_Entwicklung-KRH_r_ResponseError,not coded / not installed,
ENG247080-IDE10662,light_swich_module-Light switch (button module),not coded / not installed,
ENG247080-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded / not installed,
ENG116909-ENG107391,LIN activity-LIN 1,active,
ENG116909-ENG107392,LIN activity-LIN 2,not coded / not installed,
ENG116909-ENG114948,LIN activity-LIN 3,active,
ENG116909-ENG114949,LIN activity-LIN 4,not coded / not installed,
ENG116909-ENG114950,LIN activity-LIN 5,active,
ENG116909-ENG114951,LIN activity-LIN 6,active,
ENG128380,Parametermonitor_0,82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 50 50 50 50 00 00 50 50 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 01 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 00 00 00 00 00 00 05 00 00 00 00 00 00 14 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 28 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 3C 00 60 7E 7F 60 60 7E 60 60 60 7F 60 60 60 60 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 28 7F 3C 7E 7F 7F 7F 7E 7F 7F 7F 7F 7F 7F 7F 7F 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 1C 00 00 05 3C 02 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130145,Parametermonitor_10,00 5A 00 F0 05 05 05 2D 0F 32 32 0A 01 2C 14 01 03 0A 0A 05 01 02 05 01 09 00 9E 02 BC 5F 4B 41 06 9A 86 00 32 00 01 00 01 02 08 04 05 05 05 06 03 09 0A 07 07 FF FF FF 01 02 02 03 03 04 05 05 05 FF 01 01 01 01 01 01 01 01 01 FF 01 01 01 01 01 01 01 01 01 FF 02 01 03 03 04 06 07 05 FF FF 01 02 03 03 03 04 05 06 07 FF 00 00 00 00 00 00 28 12 10 0E 0C 0A 06 04 00 00 19 16 15 18 16 1D 15 16 14 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 08 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 05 02 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18 14 14 78 14 06 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,0A 00 00 19 19 00 03 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,04 04 14 1E 03 B4 00 0A 05 05 0A 4B 4B 32 0A 03 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FE FD FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116812,Parametermonitor_FF,00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG126653,Personalized_Account_Key_History,|Account,Key number
ENG126652-MAS03692,Personalized_key__Setting-Key 1,0,
ENG126652-MAS03693,Personalized_key__Setting-Key 2,0,
ENG126652-MAS03694,Personalized_key__Setting-Key 3,0,
ENG126652-MAS03695,Personalized_key__Setting-Key 4,0,
ENG126652-MAS03696,Personalized_key__Setting-Key 5,0,
ENG126652-MAS03697,Personalized_key__Setting-Key 6,0,
ENG126652-MAS03698,Personalized_key__Setting-Key 7,0,
ENG126654,Personalized_Signals,|Perso_Konto,Perso_Steuerung
ENG116792-ENG115817,Power up history-Funktionsanforderung,|Funktionsanforderung|26|26|26|26|26|26|26|26|26|26|,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-kilometer reading,3052, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.0, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.4, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,13.1, V
ENG116791,Temperatures,26.50, °C
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG161085,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 01 84 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG161099,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG161147,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG161254,Valeo_Entwickler_MWB-WakeUp2,OFF,
Elapsed Time: 00:43
blockmap-10-5QA-919-294-J_WVWZZZ3CZME009325-20260823-2127.CSV
;SW:5QA-919-294-J   HW:5QA-919-294 ---  10: Park/Steer Assist
;Component:PDC 8 Kanal   H08 0073, Coding:9471151811
;EV_EPHVA18AU3700000,009053,EV_EPHVA18AU3700000_009_VW48.rod
;Sunday,23,August,2026,21:27:11:32152
;VCID: 53F810365B729112330-8006
IDE00018,Voltage terminal 15,12.8, V
IDE00325,Diagnostic mode,OBD-diagnostic mode,
IDE00957-MAS01632,Resulting distance of front sensors-Status,infinite,
IDE00958-MAS01632,Resulting distance of rear sensors-Status,infinite,
IDE00974,Outside air temperature internally calculated,26.50, °
IDE01122-MAS00988,Parking aid input signal-Reverse gear,No,
IDE01122-MAS01374,Parking aid input signal-Trailer,not installed,
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,infinite,
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,infinite,
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,Malfunction,
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,Malfunction,
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,Malfunction,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,Malfunction,
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,Malfunction,
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,Malfunction,
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,Malfunction,
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,Malfunction,
IDE01162-MAS01426,Factory setting for park assist volume/frequencies-Rear parking aid buzzer: volume,Stage 4,
IDE01162-MAS01427,Factory setting for park assist volume/frequencies-Speaker frequency for rear park assist,Stage 1,
IDE01162-MAS01428,Factory setting for park assist volume/frequencies-Front parking aid buzzer: volume,Stage 4,
IDE01162-MAS01429,Factory setting for park assist volume/frequencies-Speaker frequency for front park assist,Stage 7,
IDE01163,Sound output for park assist in selector lever position P,OFF,
IDE01164,Parking aid button,Not operated,
IDE01165,Park assist activation tone,On,
IDE01166,Supply voltage for park assist sensor,12.8, V
IDE01167,Convertible offset for volume level 1,not installed,
IDE01168,Increment for convertible volume levels,not installed,
IDE01169,Audio lowering request,Yes,
IDE01171,Convertible factory setting offset for volume level 1,not installed,
IDE01172,Factory setting for increment for convertible volume levels,not installed,
IDE01173,Factory setting: audio lowering,Yes,
IDE01411-IDE11215,Personalization 1 for park assist-Automatic Activation,activated,
IDE01411-IDE11217,Personalization 1 for park assist-Show parking space,not activated,
IDE01411-MAS01426,Personalization 1 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01411-MAS01427,Personalization 1 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01411-MAS01428,Personalization 1 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01411-MAS01429,Personalization 1 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01411-MAS06193,Personalization 1 for park assist-Profile 1,not active,
IDE01411-MAS12843,Personalization 1 for park assist-Maneuvering brake function,activated,
IDE01412-IDE11215,Personalization 2 for park assist-Automatic Activation,activated,
IDE01412-IDE11217,Personalization 2 for park assist-Show parking space,not activated,
IDE01412-MAS01426,Personalization 2 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01412-MAS01427,Personalization 2 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01412-MAS01428,Personalization 2 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01412-MAS01429,Personalization 2 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01412-MAS06194,Personalization 2 for park assist-Profile 2,Parking aid active,
IDE01412-MAS12843,Personalization 2 for park assist-Maneuvering brake function,activated,
IDE01413-IDE11215,Personalization 3 for park assist-Automatic Activation,activated,
IDE01413-IDE11217,Personalization 3 for park assist-Show parking space,not activated,
IDE01413-MAS01426,Personalization 3 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01413-MAS01427,Personalization 3 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01413-MAS01428,Personalization 3 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01413-MAS01429,Personalization 3 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01413-MAS06195,Personalization 3 for park assist-Profile 3,not active,
IDE01413-MAS12843,Personalization 3 for park assist-Maneuvering brake function,activated,
IDE01414-IDE11215,Personalization 4 for park assist-Automatic Activation,activated,
IDE01414-IDE11217,Personalization 4 for park assist-Show parking space,not activated,
IDE01414-MAS01426,Personalization 4 for park assist-Rear parking aid buzzer: volume,Stage 4,
IDE01414-MAS01427,Personalization 4 for park assist-Speaker frequency for rear park assist,Stage 1,
IDE01414-MAS01428,Personalization 4 for park assist-Front parking aid buzzer: volume,Stage 4,
IDE01414-MAS01429,Personalization 4 for park assist-Speaker frequency for front park assist,Stage 7,
IDE01414-MAS06196,Personalization 4 for park assist-Profile 4,not active,
IDE01414-MAS12843,Personalization 4 for park assist-Maneuvering brake function,activated,
IDE01588,Direction of travel,forward,
IDE01632,System status of parking aid,not active,
IDE01633,Cause for parking aid shut-off,No shut-off requirement,
IDE01943,Turn signal lamp,Not operated,
IDE03782,Switch-off speed for parking assist,15, km/h
IDE03784,Temporary function limitation due to environmental influences,No,
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,07 F1,
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,07 EF,
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,07 F2,
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,07 F3,
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,0, %/s
IDE12038-IDE00086,Brake requirements (ring buffer)-Accelerator pedal position,20, %/s
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,15, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,25, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,111, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,14, bar
IDE12038-IDE02211,Brake requirements (ring buffer)-Brake pressure,0, bar
IDE12038-IDE16238,Brake requirements (ring buffer)-Escape request: event list,0,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2026,
IDE12038-MAS00106,Brake requirements (ring buffer)-Year,2025,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,1,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,9,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,11,
IDE12038-MAS00107,Brake requirements (ring buffer)-Month,7,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,17,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,30,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,27,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,4,
IDE12038-MAS00108,Brake requirements (ring buffer)-Day,14,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,15,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,7,
IDE12038-MAS00109,Brake requirements (ring buffer)-Hours,17,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,17,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,20,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,3,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,39,
IDE12038-MAS00110,Brake requirements (ring buffer)-Minutes,57,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,27,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,52,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,31,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,4,
IDE12038-MAS00111,Brake requirements (ring buffer)-Seconds,49,
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,-1.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,6.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,4.0, km/h
IDE12038-MAS00370,Brake requirements (ring buffer)-Vehicle speed,3.0, km/h
IDE12038-MAS11940,Brake requirements (ring buffer)-Brake electronics fault,Parking aid active,
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,4.5, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,-1.0, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,4.1, m
IDE12038-MAS13914,Brake requirements (ring buffer)-Object horizontal position,4.2, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-0.3, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.0, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,0.2, m
IDE12038-MAS13915,Brake requirements (ring buffer)-Object vertical position,-0.9, m
MAS00464-MAS00110,Standard - ambient data 1-Minutes,27,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,16,
MAS01426,Rear parking aid buzzer: volume,Stage 4,
MAS01427,Speaker frequency for rear park assist,Stage 1,
MAS01428,Front parking aid buzzer: volume,Stage 4,
MAS01429,Speaker frequency for front park assist,Stage 7,
MAS10122,ARA operating condition,Initialization,
MAS10122-MAS11700,ARA operating condition-ARA function request door control module,no request,
MAS16451-IDE11215,Personalization 5-Automatic Activation,activated,
MAS16451-IDE11217,Personalization 5-Show parking space,not activated,
MAS16451-MAS01426,Personalization 5-Rear parking aid buzzer: volume,Stage 4,
MAS16451-MAS01427,Personalization 5-Speaker frequency for rear park assist,Stage 1,
MAS16451-MAS01428,Personalization 5-Front parking aid buzzer: volume,Stage 4,
MAS16451-MAS01429,Personalization 5-Speaker frequency for front park assist,Stage 7,
MAS16451-MAS06197,Personalization 5-Profile 5,not active,
MAS16451-MAS12843,Personalization 5-Maneuvering brake function,activated,
MAS16452-IDE11215,Personalization 6-Automatic Activation,activated,
MAS16452-IDE11217,Personalization 6-Show parking space,not activated,
MAS16452-MAS01426,Personalization 6-Rear parking aid buzzer: volume,Stage 4,
MAS16452-MAS01427,Personalization 6-Speaker frequency for rear park assist,Stage 1,
MAS16452-MAS01428,Personalization 6-Front parking aid buzzer: volume,Stage 4,
MAS16452-MAS01429,Personalization 6-Speaker frequency for front park assist,Stage 7,
MAS16452-MAS06198,Personalization 6-Profile 6,not active,
MAS16452-MAS12843,Personalization 6-Maneuvering brake function,activated,
MAS16453-IDE11215,Personalization 7-Automatic Activation,activated,
MAS16453-IDE11217,Personalization 7-Show parking space,not activated,
MAS16453-MAS01426,Personalization 7-Rear parking aid buzzer: volume,Stage 4,
MAS16453-MAS01427,Personalization 7-Speaker frequency for rear park assist,Stage 1,
MAS16453-MAS01428,Personalization 7-Front parking aid buzzer: volume,Stage 4,
MAS16453-MAS01429,Personalization 7-Speaker frequency for front park assist,Stage 7,
MAS16453-MAS06199,Personalization 7-Profile 7,not active,
MAS16453-MAS12843,Personalization 7-Maneuvering brake function,activated,
ENG113995,Dimming_Signal_Terminal_58xd_pdc_pla,10, %
Elapsed Time: 00:14
[/CODE]
Trevas
Portugal
C?ID=516418
blockmap-13-5Q0-907-572-R_WVWZZZ3CZME009325-20260823-2127.CSV
;SW:5Q0-907-572-R   HW:3Q0-907-567-A ---  13: Auto Dist. Reg
;Component:ACC BOSCH MQB H01 0771, Coding:52017F425DFFC728949C812481408680000000000000000066
;EV_ACCBOSCHVW416,003014,EV_ACCBOSCHVW416_003_VW48.rod
;Sunday,23,August,2026,21:27:41:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 46DE3962982034BAA4E-8012
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018-ENG99033,Voltage terminal 15-Voltage,13.0, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,44, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE01788-ENG98502,Heated lens control signal-Data,0.00, %
IDE01794,ACC operating lever signal,00000000 10101000 ,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,92 7F 46 26,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead approaching: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead approaching: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead approaching: ACC OFF,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead approaching: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead approaching: ACC OFF,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead approaching: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead approaching: ACC OFF,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04334-MAS02643,Public key for SWaP function-Key,C2 F7 2F 35 53 5E E2 17 A5 77 DB 79 FD 19 AF 44 A3 60 AB 15 CA A5 5E F9 45 CD 6F 1E F6 A2 BE 4E 8D 28 64 CF 1C 34 C7 C9 16 DE DE 67 B5 57 39 00 C2 53 57 B6 FB 19 A1 41 40 A0 F5 B2 60 C0 18 01 6D C7 8E B5 02 83 63 E2 BA D4 28 DD 96 22 FD D1 F4 87 8B 5F EC EC 1D 9D 62 41 0B 2B 9F 3C 6B 2B AE 87 95 D3 A9 B9 72 54 56 6C 80 1C 53 40 5F 4E CE C1 CD 32 AD 83 5B 53 DE BA EF E3 D0 D0 B8 A7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS01448,Driving profile selection-Specified value,0,
IDE05814,Individualization characteristic,69 22 26 2C 06,
IDE06307-MAS00106,Stop prevention history data-Year,2000,
IDE06307-MAS00107,Stop prevention history data-Month,0,
IDE06307-MAS00108,Stop prevention history data-Day,0,
IDE06307-MAS00109,Stop prevention history data-Hours,0,
IDE06307-MAS00110,Stop prevention history data-Minutes,0,
IDE06307-MAS00111,Stop prevention history data-Seconds,0,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06307,Stop prevention history data,not active,
IDE06308-MAS00106,Start request history data-Year,2000,
IDE06308-MAS00107,Start request history data-Month,0,
IDE06308-MAS00108,Start request history data-Day,0,
IDE06308-MAS00109,Start request history data-Hours,0,
IDE06308-MAS00110,Start request history data-Minutes,0,
IDE06308-MAS00111,Start request history data-Seconds,0,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,not active,
IDE06308,Start request history data,not active,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,00,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08768,Mirror deviation: horizontal,24.464, °
IDE08769,Mirror deviation: vertical,-24.464, °
IDE08770-MAS01466,Adjustment of screw top left-Direction of rotation,none,
IDE08770-MAS02559,Adjustment of screw top left-Rotations,0.00,
IDE08771-MAS01466,Adjustment of screw top right-Direction of rotation,none,
IDE08771-MAS02559,Adjustment of screw top right-Rotations,0.00,
IDE08772-MAS01466,Adjustment of screw bottom left-Direction of rotation,none,
IDE08772-MAS02559,Adjustment of screw bottom left-Rotations,0.00,
IDE08773-MAS01466,Adjustment of screw bottom right-Direction of rotation,none,
IDE08773-MAS02559,Adjustment of screw bottom right-Rotations,0.00,
IDE08936,Misalignment angle: horiz,0.116, °
IDE08937,Misalignment angle: horiz: fast algorithm,0.261, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,20,
IDE09380-MAS00107,Performed adjustment-Month,08,
IDE09380-MAS00108,Performed adjustment-Day,25,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,-0.29, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,1.90, °
IDE09906,Vertical deadjustment,1.509, °
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,0.260, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,1.510, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,-0.290, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,1.890, °
ENG107860,Number_of_ANB_partial_bracings,3,
ENG107861,Number_of_ANB_target_bracings,6,
ENG107862,Number_of_ANB-CM,0,
ENG131998,Number_of_boost_function_active,0,
ENG131999,Number_of_deactivation_ASR_active,0,
ENG132000,Number_of_deactivation_ESC_active,0,
ENG131985,Number_of_Emergency_steer_assist,0,
ENG131987,Number_of_fully_developed_deceleration_1,0,
ENG131988,Number_of_fully_developed_deceleration_2,0,
ENG137753,Number_of_mainwarnings,0,
ENG135070,number_of_prewarnings,54,
ENG131986,Number_of_Turn_off_assistant_intervention,0,
ENG107928,Operating_time_ACC,9797, min
ENG131991,Operating_time_ACC_active_driving_programm_auto,50, min
ENG131990,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG131989,Operating_time_ACC_active_driving_programm_dynamic,9747, min
ENG131992,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG131993,Operating_time_ACC_active_timegap_1,4339, min
ENG131994,Operating_time_ACC_active_timegap_2,3379, min
ENG131995,Operating_time_ACC_active_timegap_3,896, min
ENG131996,Operating_time_ACC_active_timegap_4,481, min
ENG131997,Operating_time_ACC_active_timegap_5,81, min
ENG132001,Operating_time_ACC_active_v-delta_0,9797, min
ENG132004,Operating_time_ACC_active_v-delta_large,0, min
ENG132003,Operating_time_ACC_active_v-delta_medium,0, min
ENG132002,Operating_time_ACC_active_v-delta_small,0, min
ENG132005,Operating_time_STA_active,0, min
ENG132006,Operating_time_STA_off_activation_possible,0, min
ENG139832,Sw_version_supplier,1037607185;PF_R28.12.0_VW.MQB_48PA.0771_I1.4;0;Compiled by gzu2bp on Tue Mar 24 11:07:43 2020$!,
Elapsed Time: 00:14
blockmap-15-5QF-959-655-AA_WVWZZZ3CZME009325-20260823-2128.CSV
;SW:5QF-959-655-AA   HW:5QF-959-655-AA ---  15: Airbags
;Component:Airbag VW22   011 0639, Coding:98CCC0C0002000005C5400CF000C40000065
;EV_AirbaVW22TS6VW48X,001030,EV_AirbaVW22TS6VW48X.rod
;Sunday,23,August,2026,21:28:10:32152
;VCID: 157CAE2E95064F221D4-8040
IDE00821,Seat belt switch 2nd row driver's side,not connected,
IDE00822,Safety belt switch 2nd row frt.passenger side,not connected,
IDE00823,Seat belt switch 2nd row center,not connected,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,3.0, Ohm
IDE01100,Passenger side airbag igniter ohm value,2.3, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,no measured value present,
IDE01102,Driver thorax airbag igniter ohm value,2.5, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.5, Ohm
IDE01104,driver side rear airbag igniter ohm value,too large,
IDE01105,Ft. pass.side rear airbag igniter ohm value,too large,
IDE01106,Driver side head curtain airbag igniter ohm value,2.4, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.4, Ohm
IDE01108,Driver side knee airbag igniter ohm value,2.3, Ohm
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.2, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.1, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,too large,
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,too large,
IDE01114,Driver side belt force limiter igniter ohm value,too large,
IDE01115,side belt force limiter igniter ohm value,too large,
IDE01116,driver side rear belt tensioner igniter ohm value,2.5, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.4, Ohm
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,464.0, Ohm
IDE01197,Key switch contact 1 ohm value,680.0, Ohm
IDE01198,Key switch contact 2 ohm value,1460.0, Ohm
IDE01200,Driver seat position sensor current value,no measured value present,
IDE01201,Frt.pass. seat position sensor current value,no measured value present,
IDE01205,Safety belt switch 2nd row driver side ohm value,Too Small,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,Too Small,
IDE01207,Safety belt switch center 2nd row ohm value,Too Small,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01357,Left pedestrian protection igniter,not installed,
IDE01358,Right pedestrian protection igniter,not installed,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE01634,Pedestrian protection trigger: driver side ohmic value,too large,
IDE01635,Pedestrian protection trigger: frt.pass. side ohmic value,too large,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,correct,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,2.9, Ohm
IDE03730,Driver airbag release valve igniter ohm value,no measured value present,
IDE03731,Igniter for frt.pass. side air bag release valve: ohm value,no measured value present,
IDE03800,Driver airbag release valve igniter,cannot be measured currently,
IDE03801,Frt.pass. airbag release valve igniter,cannot be measured currently,
IDE06034,Rollover protection trigger: driver side,cannot be measured currently,
IDE06035,Rollover protection trigger: front passenger side,cannot be measured currently,
IDE06036,Rollover protection trigger: driver side ohm value,no measured value present,
IDE06038,Rollover protection trigger: frt.pass. side ohm value,no measured value present,
IDE10187,Supply voltage {V},13.1, V
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger front airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,cannot be measured currently,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger thorax airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,not installed,
MAS00008,Passenger side rear thorax airbag igniter,not installed,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,correct,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver seat belt tension igniter,correct,
MAS00014,Front passenger seat belt tensioner igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,not installed,
MAS00016,Front passenger seat belt tensioner igniter 2,not installed,
MAS00017,Igniter for Driver Belt Force Limiter,not installed,
MAS00018,Front passenger side belt force limiter igniter,not installed,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00022,Battery Interrupt Igniter,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupant detection,Not assigned,
MAS00031,Airbag deactivation status,On,
MAS00032,Key switch terminal 1,On,
MAS00033,Key switch terminal 2,On,
MAS00035,Seat position sensor: driver side,not installed,
MAS00036,Seat position sensor: front passenger side,not installed,
MAS00038,Seat occupied recognition rear  driver side,not installed,
MAS00039,Seat occupied recognition rear  passenger side,not installed,
MAS00040,Seat occupied recognition: center: rear,not installed,
MAS01634,Supply voltage,correct,
Elapsed Time: 00:15
blockmap-17-3G0-920-324-B_WVWZZZ3CZME009325-20260823-2116.CSV
;SW:3G0-920-324-B   HW:3G0-920-324-B ---  17: Instruments
;Component:KOMBI         502 5176, Coding:05A408186FC40008018B62531001002880700300
;EV_DashBoardVDDMQBA0,001045,EV_DashBoardVDDMQBA0_001_VW48.rod
;Sunday,23,August,2026,21:16:55:32152
;VCID: 20128FFA5A443A8AFE2-8074
IDE00019,Voltage terminal 30,13.1, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,27.00, °C
IDE00196,Engine oil temperature,27, °C
IDE00301,Distance,136252, km
IDE00310,Outside temperature,26.5, °C
IDE00316-IDE00500,Time-Hour,21, H
IDE00316-IDE00501,Time-Minute,16, min
IDE00316-MAS00111,Time-Seconds,48, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,8, Months
IDE00317-IDE00504,Date-Day,23, d
IDE00510,ESI: distance driven from inspection,8643, km
IDE00511,ESI: time from inspection,229, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,8300, km
IDE00520,Photo transistor,1,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,6360, km
IDE00698,ESI: remaining running time,136, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,2188, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2056, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2138, mm
IDE00935,ESI: Theoretical service interval,51600, km
IDE01076,Time since ignition off,75541, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,26.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,64,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,64,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,4088,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,22900, km
IDE03352,FIX: Time since last time-dependent inspection,425, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,12.1, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,50.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,53.2, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,11.6, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,23.4, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,23.4, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,19.5, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,21.7, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,5.4, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,40.8, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,40.8, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,6.9, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,31.3, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,50.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,53.2, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,26.6, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,136100,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,135800,
IDE03472-MAS06155,Volume after refueling-Third to last distance,135600,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,134800,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,50, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,-3, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,850,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,2460,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,50.0, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,47, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,53.2, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-53.7, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,53.2, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,53.0, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,53.2, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.06250, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.02,
IDE03474-ENG101623,Calculated volume-reference_volume,53.2, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,208,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0024996,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,21, H
IDE03477-IDE00501,GPS time-Minute,10, min
IDE03477-IDE00501,GPS time-Minute,16, min
IDE03477-IDE00502,GPS time-Year,2026, yr
IDE03477-IDE00503,GPS time-Month,8, Months
IDE03477-IDE00504,GPS time-Day,23, d
IDE03477-MAS00111,GPS time-Seconds,46, s
IDE03477-MAS00111,GPS time-Seconds,57, s
IDE03477-MAS03493,GPS time-last synchronization year,2026, yr
IDE03506,Distance: high resolution,08 1F 0B 8D,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,Write only channel,
IDE03880-MAS03425,MOST address-Physical address,Write only channel,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,8F F0 00 06,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,CF F0 00 0D,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,4F F0 00 0D,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,0F F0 00 06,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,3F F0 3A 9D,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,2F F0 3E 47,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,6F F0 01 2B,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,BF F0 75 35,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,3F F0 78 DF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,0F F0 7C F0,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,4F F0 02 07,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,8F F0 7C F0,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,CF F0 02 07,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,3F F0 B7 88,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,0F F0 E1 6C,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,4F F0 03 4F,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,8F F0 E1 6C,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,CF F0 03 4F,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,3F F1 1C 04,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,4F F0 04 BB,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,8F F1 3B 31,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,CF F0 04 D2,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,0F F1 3B 31,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,3F F1 75 C9,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,0F F1 7B 8D,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,4F F0 05 D3,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,8F F1 7B 8D,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,CF F0 05 D3,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,3F F1 B6 23,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,0F F1 BA 75,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,4F F0 06 E2,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,8F F1 BA 75,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,CF F0 06 E2,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,4F F0 07 A7,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,0F F1 F2 79,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,365, d
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,06,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,08,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,F8,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,F8,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,F8,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,C0 CD 76 E0,
IDE08240,Transponder ID Key 2,AF 1D 74 E0,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,2C C1 DE CE,
IDE08343,Immobilizer Challenge,39 49 A6 42,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 54 AF 86 02 F9|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 73
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,Yes,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,01,
IDE12263,Virtual radio key: vehicle ID,CE 8E E9 7F E9 67 81 4E B5 DA 54 A9 F3 E3 0C 57,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 01 DE 18 72 35 B8 74 26 EA 35 06 D8 05 23 09 A4 F0 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,30 5A 38 9E,
IDE14186-MAS17993,Communication transponder-Phase value,14,
IDE14186-MAS17994,Communication transponder-Compensation constant,3D,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,04,
MAS00077-ENG99298,Immobilizer-State,02 01 03 73 02 00 00 00 17 00,
MAS03121,Ring break diagnostic line status,Ground (GND),
ENG250331-ENG250595,Condition_check_1-State_info_1,4,
ENG250331-ENG250481,Condition_check_1-State_info_2,1,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG250332-ENG250595,Condition_check_2-State_info_1,4,
ENG250332-ENG250481,Condition_check_2-State_info_2,1,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,3, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,5, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,22, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,6, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,37, km
ENG99439,Instrument_recorder,06 51 76 00 46 50 4B 45 56 57 32 30 53 31 46 41 43 35 44 33 66 65 62 36 61 31 5F 00 0B 00 29 00 0A 00 00 02 E2 00 00 00 00 80 00 00 64 00 06 59 A3 A8 93 35 68 00 C6 00 1E 00 00 02 88 00 00 00 02 00 00 00 64 00 06 59 A2 0A E8 E0 C0 00 B4 00 1F 00 00 02 8F 00 00 00 01 00 00 00 64 00 06 59 A2 0A E8 E0 C0 00 94 00 1A 00 00 0D 73 00 00 00 00 00 00 00 21 00 06 59 7A 0A 61 FC E0 01 3D 00 32 00 00 09 10 00 00 00 00 00 00 00 23 00 06 59 7A 0A 62 0C 80 01 3D 00 32 00 00 09 10 00 00 00 01 00 00 00 23 00 06 59 7A 0A 62 0C 80 00 94 00 1A 00 00 0D 18 00 00 00 00 00 00 00 01 00 06 44 97 24 2A 01 38 00 9C 00 19 00 00 01 90 00 00 00 00 00 00 00 01 00 06 44 97 24 2A 01 38 01 34 00 13 00 00 03 29 00 00 00 00 00 00 00 13 00 06 4D AE 87 8C 5C 38 00 24 00 08 00 00 C1 01 00 00 00 11 00 00 00 0A 00 06 53 6E 0B 1C 8F 68 01 42 00 14 00 00 00 F6 00 00 00 01 00 00 00 02 00 06 34 B6 30 86 0A 58 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 43 00 35 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 03 03 03 0D 0D 05 06 FF FF FF 03 00 0A 00 29 00 E2 02 00 00 00 00 00 00 A3 59 06 00 68 35 93 A8 1F 00 B4 00 8F 02 00 00 01 00 00 00 A2 59 06 00 C0 E0 E8 0A 1E 00 C6 00 88 02 00 00 02 00 00 00 A2 59 06 00 C0 E0 E8 0A 32 00 3D 01 10 09 00 00 01 00 00 00 7A 59 06 00 80 0C 62 0A 32 00 3D 01 10 09 00 00 00 00 00 00 7A 59 06 00 80 0C 62 0A 1A 00 94 00 73 0D 00 00 00 00 00 00 7A 59 06 00 E0 FC 61 0A FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 2A 00 03 00 00 00 03 00 03 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 51 76 00 46 50 4B 45 56 57 32 30 53 31 46 47 43 5F 56 57 00 00 01 B4 00 43 00 00 01 79 00 00 00 00 00 00 00 06 59 BD 41 53 16 25 00 00 00 75 00 06 00 0F 01 46 00 00 00 00 00 00 00 06 59 B9 90 97 C9 06 00 00 02 A6 00 68 00 00 00 7B 00 00 00 00 00 04 00 06 59 AB 5C C6 D5 1B 00 00 00 EF 00 0F 00 00 01 85 00 00 00 00 00 00 00 06 59 BD 43 F7 78 BC 00 00 00 EA 00 0E 00 00 03 10 00 00 00 01 00 01 00 06 59 AB 5A 40 30 CD 00 00 02 A7 00 68 00 00 00 7B 00 00 00 00 00 00 00 06 59 02 4A D9 C7 85 00 00 04 F5 00 97 00 1C 00 80 00 00 00 00 00 01 00 06 52 6E A9 CC B9 EE 00 00 04 F5 00 97 00 1C 00 AC 00 00 00 00 00 00 00 06 53 B9 D4 F6 93 12 00 00 03 99 00 77 00 00 05 B1 00 00 04 02 00 00 00 06 44 44 F6 66 8D 8F 00 00 04 2C 00 51 00 00 03 35 5A A5 C8 38 00 00 00 05 C8 69 D7 6B EC 69 00 00 04 37 00 84 00 00 03 3F 00 00 00 00 00 00 00 06 53 A7 FF 44 53 84 00 00 03 95 00 77 00 00 08 0D 00 00 00 00 00 01 00 06 53 B9 DD 45 D5 66 00 00 04 38 00 84 00 00 03 0E 00 00 00 00 00 03 00 06 53 B9 EA C0 26 06 00 00 04 37 00 84 00 00 02 A7 00 00 00 00 00 00 00 06 3B EF 71 D7 8C 95 00 00 02 54 00 59 00 00 00 E8 00 00 00 00 00 00 00 06 53 CE 22 A1 27 63 00 00 02 54 00 59 00 00 00 CE 00 00 00 00 00 00 00 06 2A 51 32 6B 27 8E 00 00 02 77 00 61 00 00 00 E8 00 00 00 00 00 00 00 06 15 AC 5D 8B 58 B1 00 00 04 2C 00 51,
ENG107920-ENG98868,onboard_computer-Range,1028, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,4.6, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,4.6, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,4.6, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,1028, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,153,
ENG103405,read_out_measured_value_block,136,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,3928,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,1,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,0,
Elapsed Time: 00:29
blockmap-19-3Q0-907-530-AH_WVWZZZ3CZME009325-20260823-2118.CSV
;SW:3Q0-907-530-AH   HW:3Q0-907-530-D ---  19: CAN Gateway
;Component:GW MQB EV     621 6423, Coding:020900172CE21000FB0052FA581D00000001070100010000000300000000
;EV_GatewNF,013026,EV_GatewNF_VW48.rod
;Sunday,23,August,2026,21:18:09:32152
;VCID: 75BC8EAEB546EF22FD4-8020
IDE00019,Voltage terminal 30,13.0, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00056,History data 1,|Life Cycle Data String|2026-08-17-15:33*00.3*01*01091***
2026-08-17-10:21*00.0*01**
2026-08-16-19:20*00.0*01**
2020-10-02-15:07*00.7*01*00068***
2020-10-02-13:37*00.2*01**
2020-10-02-13:24*00.0*01**
2020-10-02-02:30*00.8*01*00000***
2020-10-01-08:04*00.0*01**
2020-10-01-05:25*00.0*01**|,
IDE00057,History data 2,|Life Cycle Data String|2020-10-24-15:16*006*040*-2.136*0-1-0-0-0-0-0*0*01*00046**
2020-10-01-19:52*005*000*-2.147*0-1-0-0-0-0-1*0*01**
2020-09-22-15:55*022*005*-2.132*0-1-0-0-0-0-1*0*01**
2020-09-09-22:07*013*000*-2.150*0-1-0-0-0-0-1*0*01**
IDE00058,History data 3,|Life Cycle Data String|2020-10-02-12:49*1*0*025*006*0-0-0-0-0-0-1*0*0*00.2*00.0**
2020-10-02-02:31*1*0*018*002*0-0-0-0-0-0-1*0*0*00.2*00.0**
2020-10-02-02:48*3*0*016*000*0-1-0-0-0-0-1*0*0*00.2*00.0**
2020-10-02-01:32*2*0*020*003*0-1-0-0-0-0-1*0*0*00.2*00.0**
2020-10-02-00:04*1*0*026*006*0-1-0-0-0-0-1*0*0*00.2*00.0**
2020-10-01-05:23*3*0*021*000*0-1-0-0-0-0-1*0*0*00.2*00.0**
2020-10-01-05:22*0*1*021*000*0-0-1-0-1-0-1*0*0*00.2*00.0**
2020-09-23-16:41*3*0*016*000*0-0-0-0-0-0-1*0*0*00.0*00.0**
2020-09-23-16:40*1*0*016*000*0-0-0-0-0-0-1*0*0*00.0*00.0**
2020-09-23-16:25*3*0*016*000*0-1-0-0-0-0-1*0*0*00.0*00.0**|,
IDE00059,History data 4,|Life Cycle Data String|       0000000km*01*068*JCB*1111111111*10010*06594*000.0*000.0*000.0**
IDE00060,History data 5,|Life Cycle Data String|2020-09-10-10:04*3*-2.150*11.64*000*03*+00.0*06594*09952*000007*0-0-0-0-0-0-1*0*1*0*00.0*00.1*023.6*15*00*00*00*01**
IDE00061,History data 6,|Life Cycle Data String|2026-08-22-23:37*045*+25*+001.0*00.60*0.00*000**
2026-08-22-20:11*045*+26*+001.1*00.70*0.00*000**
2026-08-22-10:59*041*+26*+000.7*00.00*0.00*000**
2026-08-22-10:46*041*+25*+000.1*00.00*0.00*000**
2026-08-22-10:32*042*+25*+000.8*00.20*0.00*000**
2026-08-22-10:28*040*+25*+000.4*00.00*0.00*000**
2026-08-22-10:05*042*+25*+000.6*00.20*0.00*000**
2026-08-21-18:59*045*+27*+000.1*00.00*0.00*000**
2026-08-21-18:56*045*+27*+000.1*00.00*0.00*000**
2026-08-21-18:47*045*+27*+000.2*00.10*0.00*000**|,
IDE00062,History data 7,|Life Cycle Data String|2026-08-22-20:55*041*+000.9*002.6*00.0*00.0**
2026-08-22-11:05*040*+001.6*009.0*00.0*00.0**
2026-08-22-10:47*041*+000.8*000.1*00.0*00.0**
2026-08-22-10:43*041*+000.4*000.0*00.0*00.0**
2026-08-22-10:17*040*+000.6*000.1*00.0*00.0**
2026-08-21-19:02*040*+001.2*014.9*00.0*00.0**
2026-08-21-18:55*045*+000.1*000.0*00.0*00.0**
2026-08-21-18:46*045*+000.1*000.0*00.0*00.0**
2026-08-21-18:12*044*+000.5*000.3*00.0*00.0**
2026-08-21-18:01*044*+000.4*000.1*00.0*00.0**|,
IDE00063,History data 8,|Life Cycle Data String|       0135598km*4*99*00*00*15*2026-06-05-15:37*01**
2026-02-18-22:11*4*99*00*00*14*2026-02-19-10:54*01**
2026-02-18-09:34*4*99*00*00*13*2067-04-26-15:55*01**|,
IDE00064,History data 9,|Life Cycle Data String|       0000000km*000*000*000*000*00000*09.00*+00*00*01*00.00*00000*00000**
2026-08-10-17:25*074*074*058*021*06545*12.20*+34*04*01*12.70*65535*00000**
2026-07-13-08:04*076*075*068*025*06534*12.40*+19*04*01*12.70*65535*00000**
2026-05-25-17:06*080*080*088*039*06461*12.60*+24*04*01*12.70*65535*00000**
2026-04-27-17:05*079*079*095*041*06428*12.70*+24*04*01*12.70*65535*00000**
2026-03-30-17:02*077*079*096*038*06399*12.70*+11*04*01*12.70*65535*00000**
2026-03-11-12:11*078*081*095*037*06344*12.70*+11*04*01*12.70*65535*00000**
2026-02-20-07:09*078*078*085*030*06292*12.60*+04*04*01*12.70*65535*00000**
2026-01-31-15:53*073*080*100*038*06241*12.80*+14*04*01*12.70*65535*00000**
2026-01-28-11:44*073*079*100*037*06233*12.80*+11*04*01*12.70*65535*00000**
2026-01-15-16:47*080*081*089*036*06184*12.60*+12*04*01*12.70*65535*00000**
2026-01-12-16:34*074*074*087*029*06175*12.60*+05*04*01*12.70*65535*00000**|,
IDE00065,History data 10,|Life Cycle Data String|-------------:--*-*---.-*----.-*-*---.-*----.-*--.--*-------**
IDE00066,History data 11,|Life Cycle Data String|-------------:--*---*---*---*---*----*---*--.-*--.-*---*---*---*---*--*-----*-----*-----*-----*-----**
IDE00067,History data 12,|Life Cycle Data String|-------------:--*---------------**
2026-03-01-13:23*1*079*027*+07*04*070*+15.19*14.6*1**
2026-02-18-07:06*1*086*024*+01*04*070*+06.44*13.7*1**
2026-02-15-13:33*1*082*025*+00*04*070*+07.89*13.6*1**
2026-02-14-11:07*1*078*024*+02*04*070*+08.24*13.6*1**
2026-02-08-12:31*1*085*027*+04*04*070*+09.43*13.6*1**
00043*00000*00000**|,
IDE00068,History data 13,|Life Cycle Data String|-------------:--*---------*---.-*-----**
IDE00069,History data 14,|Life Cycle Data String|2026-08-22-23:39*1*00060*0000*0000*00.60*020040*+25*0017.6*0000.2*0000.0**
2026-08-22-23:37*3*00000*0000*0000*00.00*020040*+25**
2026-08-22-20:11*3*00000*0000*0000*00.70*020040*+26**
2026-08-22-10:59*3*00000*0000*0000*00.00*020040*+26**
2026-08-22-10:46*3*00000*0000*0000*00.00*020040*+25**
00162*00000*00496*00000*00000**
IDE00071,History data 16,|Life Cycle Data String|       0136252km**
04768*04606*00259*00003*00004**
06003*00003*00001*00000**
18955*12233*00055*01350**
01244*03554*00804*03849**
04877*03126*01448**
00000*00000*00000*00000**
10283*00033*00010**
00048*00004*00017**
00008*00001*00000**
00000*00000*00000*00000*00000*00000*00000*00000*00000*00000*00000**|,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,5,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,Cruise control switch with ACC,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,5,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,45,
IDE00767-ENG123029,No. of unscheduled ECU resets-Counter_Watchdog_Resets,3,
IDE01459,Energy management heat output control status,not active,
IDE01803,History data 17,|Life Cycle Data String|-------------:--*--.-*-----*-----**
2020-10-02-08:47*3*000*16.8*000*000*000*000*033**
2020-10-02-02:48*3*000*06.4*016*000*000**
2020-10-01-05:24*3*000*06.0*020*000*000**
2020-10-01-05:23*3*000*06.0*021*000*000**
2020-09-23-16:40*3*000*05.4*016*000*000**|,
IDE01804,History data 18,|Life Cycle Data String|-------------:--*---*---*--*---*-*---*---*-----**
IDE01805,History data 19,|Life Cycle Data String|-------------:--*-----*---*---*---**
IDE01807-IDE07142,History data 21-Time since terminal 15 off,0.5, H
IDE01807-MAS00106,History data 21-Year,2025,
IDE01807-MAS00107,History data 21-Month,5,
IDE01807-MAS00108,History data 21-Day,11,
IDE01807-MAS00109,History data 21-Hours,11, H
IDE01807-MAS00110,History data 21-Minutes,30, min
IDE01807-MAS14375,History data 21-Cycle counter,7966,
IDE01807-MAS14376,History data 21-ECU 1,Information electronics 1,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,0.5, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,Node_0x-- $-- (empty entry),
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,0.0, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,Node_0x-- $-- (empty entry),
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,Node_0x-- $-- (empty entry),
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,Node_0x-- $-- (empty entry),
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.1, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03175,History data 22-Extended data bus,0.1, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03177,History data 22-Infotainment data bus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.1, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.2, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,0.0, H
IDE01809-MAS00106,History data 23-Year,2026,
IDE01809-MAS00107,History data 23-Month,8,
IDE01809-MAS00108,History data 23-Day,17,
IDE01809-MAS00109,History data 23-Hours,17, H
IDE01809-MAS00110,History data 23-Minutes,2, min
IDE01809-MAS14375,History data 23-Cycle counter,9619,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Comfort data bus,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,28,
IDE01809-MAS14397,History data 23-Rousing ECU 1,Electronic central electric,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,27,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,1,
IDE01809-MAS14400,History data 23-Rousing ECU 2,Node_0x-- $-- (empty entry),
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,Node_0x-- $-- (empty entry),
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,Node_0x-- $-- (empty entry),
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,Node_0x-- $-- (empty entry),
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,17.0, H
IDE01810-MAS00106,History data 24-Year,2025,
IDE01810-MAS00107,History data 24-Month,9,
IDE01810-MAS00108,History data 24-Day,20,
IDE01810-MAS00109,History data 24-Hours,14, H
IDE01810-MAS00110,History data 24-Minutes,5, min
IDE01810-MAS14375,History data 24-Cycle counter,8575,
IDE01810-MAS14399,History data 24-CarWakeUp bit 1,0,
IDE01810-MAS14402,History data 24-CarWakeUp bit 2,0,
IDE01810-MAS14405,History data 24-CarWakeUp bit 3,0,
IDE01810-MAS14408,History data 24-CarWakeUp bit 4,0,
IDE01810-MAS14411,History data 24-CarWakeUp bit 5,0,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Comfort data bus,
IDE01810-MAS14413,History data 24-Alert events in current cycle,47,
IDE01810-MAS14414,History data 24-ID of the alerting message 1,1B 00 00 09,
IDE01810-MAS14415,History data 24-Counter of the alerting message 1,2,
IDE01810-MAS14416,History data 24-Bus of the alerting message 1,Extended data bus,
IDE01810-MAS14417,History data 24-ID of the alerting message 2,00 00 05 84,
IDE01810-MAS14418,History data 24-Counter of the alerting message 2,1,
IDE01810-MAS14419,History data 24-Bus of the alerting message 2,Comfort data bus,
IDE01810-MAS14420,History data 24-ID of the alerting message 3,00 00 03 D4,
IDE01810-MAS14421,History data 24-Counter of the alerting message 3,1,
IDE01810-MAS14422,History data 24-Bus of the alerting message 3,Comfort data bus,
IDE01810-MAS14423,History data 24-ID of the alerting message 4,00 00 00 00,
IDE01810-MAS14424,History data 24-Counter of the alerting message 4,0,
IDE01810-MAS14425,History data 24-Bus of the alerting message 4,Unknown,
IDE01810-MAS14426,History data 24-ID of the alerting message 5,00 00 00 00,
IDE01810-MAS14427,History data 24-Counter of the alerting message 5,0,
IDE01810-MAS14428,History data 24-Bus of the alerting message 5,Unknown,
IDE01812-MAS01468,History data 26-Terminal 15,9672,
IDE01812-MAS03173,History data 26-Powertrain data bus,1905,
IDE01812-MAS03174,History data 26-Comfort data bus,23399,
IDE01812-MAS03175,History data 26-Extended data bus,19891,
IDE01812-MAS03177,History data 26-Infotainment data bus,19,
IDE01812-MAS03178,History data 26-Suspension data bus,80,
IDE01812-MAS03180,History data 26-Local data bus,21,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS14374,History data 26-Totals,45315,
IDE01813-MAS03173,History data 27-Powertrain data bus,50855,
IDE01813-MAS03174,History data 27-Comfort data bus,65535,
IDE01813-MAS03175,History data 27-Extended data bus,8119,
IDE01813-MAS03177,History data 27-Infotainment data bus,10387,
IDE01813-MAS03178,History data 27-Suspension data bus,16192,
IDE01813-MAS14374,History data 27-Totals,65535,
IDE01814-MAS03173,History data 28-Powertrain data bus,23869,
IDE01814-MAS03174,History data 28-Comfort data bus,65535,
IDE01814-MAS03175,History data 28-Extended data bus,0,
IDE01814-MAS03177,History data 28-Infotainment data bus,205,
IDE01814-MAS03178,History data 28-Suspension data bus,177,
IDE01814-MAS14374,History data 28-Totals,65535,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,275.1, H
IDE01816-MAS00106,History data 30-Year,2020,
IDE01816-MAS00107,History data 30-Month,10,
IDE01816-MAS00108,History data 30-Day,12,
IDE01816-MAS00109,History data 30-Hours,16, H
IDE01816-MAS00110,History data 30-Minutes,21, min
IDE01816-MAS14375,History data 30-Cycle counter,70,
IDE01816-ENG151642,History data 30-Bus_1,Comfort data bus,
IDE01816-ENG151644,History data 30-Bus_2,Extended data bus,
IDE01816-ENG151646,History data 30-Bus_3,Infotainment data bus,
IDE01816-ENG151648,History data 30-Bus_4,Suspension data bus,
IDE01816-ENG151650,History data 30-Bus_5,Powertrain data bus,
IDE01816-ENG151643,History data 30-Bus_Active_Time_1,1.1, H
IDE01816-ENG151645,History data 30-Bus_Active_Time_2,0.9, H
IDE01816-ENG151647,History data 30-Bus_Active_Time_3,0.8, H
IDE01816-ENG151649,History data 30-Bus_Active_Time_4,0.6, H
IDE01816-ENG151651,History data 30-Bus_Active_Time_5,0.5, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,0.5, H
IDE01817-MAS00106,History data 31-Year,2025,
IDE01817-MAS00107,History data 31-Month,5,
IDE01817-MAS00108,History data 31-Day,11,
IDE01817-MAS00109,History data 31-Hours,11, H
IDE01817-MAS00110,History data 31-Minutes,30, min
IDE01817-MAS14375,History data 31-Cycle counter,7966,
IDE01817-MAS14376,History data 31-ECU 1,Information electronics 1,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,0.5, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,Node_0x-- $-- (empty entry),
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,0.0, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,Node_0x-- $-- (empty entry),
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,Node_0x-- $-- (empty entry),
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,Node_0x-- $-- (empty entry),
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,0.0, H
IDE01818-MAS00106,History data 32-Year,2026,
IDE01818-MAS00107,History data 32-Month,8,
IDE01818-MAS00108,History data 32-Day,17,
IDE01818-MAS00109,History data 32-Hours,17, H
IDE01818-MAS00110,History data 32-Minutes,2, min
IDE01818-MAS14375,History data 32-Cycle counter,9619,
IDE01818-MAS14391,History data 32-Alerting ECU,Electronic central electric,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,1,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,17.0, H
IDE01819-MAS00106,History data 33-Year,2025,
IDE01819-MAS00107,History data 33-Month,9,
IDE01819-MAS00108,History data 33-Day,20,
IDE01819-MAS00109,History data 33-Hours,14, H
IDE01819-MAS00110,History data 33-Minutes,5, min
IDE01819-MAS14375,History data 33-Cycle counter,8575,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 05 84,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Comfort data bus,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,20.8, H
IDE01820-MAS00106,History data 34-Year,2026,
IDE01820-MAS00107,History data 34-Month,8,
IDE01820-MAS00108,History data 34-Day,23,
IDE01820-MAS00109,History data 34-Hours,21, H
IDE01820-MAS00110,History data 34-Minutes,6, min
IDE01820-MAS14375,History data 34-Cycle counter,9672,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 44,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2011,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,8, H
IDE01823-MAS00110,History data 37-Minutes,59, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,9673,
IDE01823-MAS14429,History data 37-Time in current cycle,0.1, H
IDE01827,Specified generator voltage,13.2, V
IDE01828,Generator DF Signal,6.475, %
IDE01829,Generator exciter current,0.000, A
IDE01830-MAS01632,Generator Status-Status,Thermal OK,
IDE01830-MAS02970,Generator Status-Status 2:,Mechanical OK,
IDE01830-MAS02971,Generator Status-Status 3:,electrically OK,
IDE01831-MAS03159,Generator variant-Manufacturer,Others,
IDE01831-MAS06310,Generator variant-Generator identifier,Unknown (31)
IDE01834,Battery voltage,13.187, V
IDE01836,Battery current,0.546, A
IDE01837,Temperature of battery sensor,26, °C
IDE01838,Battery temperature,25, °C
IDE01839,Battery charge status,87, %
IDE01841,Battery internal resistance,3.8, mOhm
IDE01842,Usable battery charge,40, Ah
IDE01843,Battery voltage at rest,12.6, V
IDE01844,request idle speed increase,no request,
IDE01845,Reduce internal fan request,no request,
IDE01846,Static current shut-off stage,Deactivation stage 0,
IDE01847,Auxiliary heater activation restriction request,Permitted,
IDE01847-MAS06319,Auxiliary heater activation restriction request-Allowed parking heater runtime,60, min
IDE01848,Energy balance of last driving cycle,0.3, Ah
IDE01849,Duration of last driving cycle,0.1, H
IDE01852,Static current measurement: result,Initialization,
IDE01853,Static current measurement: status,Cancel,
IDE01854,Energy reclamation request,not active,
IDE01855,Generator current,21.0, A
IDE01948,Battery internal resistance not normed,3.8, mOhm
IDE01985-ENG101043,FAZIT identification test sum-Checksum,AF 10 3E 75,
IDE01985-ENG99027,FAZIT identification test sum-Version,129,
IDE02578-ENG137113,Play protection status-fiddle_proofing_1,not active,
IDE02578-ENG137115,Play protection status-fiddle_proofing_2,not active,
IDE02578-ENG137116,Play protection status-fiddle_proofing_3,not active,
IDE02578-ENG137117,Play protection status-fiddle_proofing_4,not active,
IDE02578-ENG137118,Play protection status-fiddle_proofing_5,not active,
IDE02578-ENG137119,Play protection status-fiddle_proofing_6,not active,
IDE02578-ENG137120,Play protection status-fiddle_proofing_7,not active,
IDE02578-ENG137121,Play protection status-fiddle_proofing_8,not active,
IDE02578-ENG137114,Play protection status-function_calls_counter_1,0,
IDE02578-ENG137122,Play protection status-function_calls_counter_2,0,
IDE02578-ENG137123,Play protection status-function_calls_counter_3,0,
IDE02578-ENG137124,Play protection status-function_calls_counter_4,0,
IDE02578-ENG137125,Play protection status-function_calls_counter_5,0,
IDE02578-ENG137126,Play protection status-function_calls_counter_6,0,
IDE02578-ENG137127,Play protection status-function_calls_counter_7,0,
IDE02578-ENG137128,Play protection status-function_calls_counter_8,0,
IDE03008-IDE01838,Stop process prevented-Battery temperature,not active,
IDE03008-IDE01844,Stop process prevented-request idle speed increase,not active,
IDE03008-MAS02193,Stop process prevented-Outside temperature,not active,
IDE03008-MAS04054,Stop process prevented-Consumer/component current too high,not active,
IDE03008-MAS04055,Stop process prevented-Extractable battery charge too low,not active,
IDE03008-MAS04056,Stop process prevented-Battery state of charge too low,not active,
IDE03008-MAS04062,Stop process prevented-Possible standing time too short,not active,
IDE03008-MAS06001,Stop process prevented-Energy management special veto,not active,
IDE03008-MAS06002,Stop process prevented-DC/DC converter Veto,not active,
IDE03008-MAS19121,Stop process prevented-Successful restart done through freight quota,not active,
IDE03009-MAS01478,Start process requested-insufficient voltage,not active,
IDE03009-MAS02885,Start process requested-Restart because of outside temperature,not active,
IDE03009-MAS04054,Start process requested-Consumer/component current too high,not active,
IDE03009-MAS04055,Start process requested-Extractable battery charge too low,not active,
IDE03009-MAS04056,Start process requested-Battery state of charge too low,not active,
IDE03009-MAS04058,Start process requested-Standing time timed out,not active,
IDE03009-MAS06003,Start process requested-Charge contingency,not active,
IDE03009-MAS06004,Start process requested-Special start request,not active,
IDE03010-IDE01838,Number of prevented stop processes-Battery temperature,0,
IDE03010-IDE01844,Number of prevented stop processes-request idle speed increase,0,
IDE03010-MAS02193,Number of prevented stop processes-Outside temperature,0,
IDE03010-MAS04054,Number of prevented stop processes-Consumer/component current too high,0,
IDE03010-MAS04055,Number of prevented stop processes-Extractable battery charge too low,0,
IDE03010-MAS04056,Number of prevented stop processes-Battery state of charge too low,0,
IDE03010-MAS04062,Number of prevented stop processes-Possible standing time too short,0,
IDE03010-MAS05998,Number of prevented stop processes-Frequency counter DC/DC converter Veto,0,
IDE03010-MAS06350,Number of prevented stop processes-Frequency counter: energy management special veto,0,
IDE03011-MAS01478,Number of requested start processes-insufficient voltage,0,
IDE03011-MAS02885,Number of requested start processes-Restart because of outside temperature,0,
IDE03011-MAS04054,Number of requested start processes-Consumer/component current too high,0,
IDE03011-MAS04055,Number of requested start processes-Extractable battery charge too low,0,
IDE03011-MAS04056,Number of requested start processes-Battery state of charge too low,0,
IDE03011-MAS04058,Number of requested start processes-Standing time timed out,0,
IDE03011-MAS05999,Number of requested start processes-Frequency counter charging contingent,0,
IDE03011-MAS06000,Number of requested start processes-Frequency counter special start requirements,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2127,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,15,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,31,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,31,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,63,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,63,
IDE03127-ENG118156,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n,no measured value present,
IDE03127-ENG118158,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-1,no measured value present,
IDE03127-ENG118160,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-2,no measured value present,
IDE03127-ENG118162,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-3,no measured value present,
IDE03127-ENG118164,Prevented stop processes (ring memory)-Start_/_Stop_prohibition_n-4,no measured value present,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2127,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,15,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,31,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,31,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,63,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,63,
IDE03128-ENG118166,Requested start processes (ring memory)-Restart_n,no measured value present,
IDE03128-ENG118168,Requested start processes (ring memory)-Restart_n-1,no measured value present,
IDE03128-ENG118170,Requested start processes (ring memory)-Restart_n-2,no measured value present,
IDE03128-ENG118172,Requested start processes (ring memory)-Restart_n-3,no measured value present,
IDE03128-ENG118174,Requested start processes (ring memory)-Restart_n-4,no measured value present,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,All releases are present,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03256-MAS06105,Battery adaptation-Rated battery capacity,68, Ah
IDE03256-MAS06106,Battery adaptation-Battery technology,Fleece,
IDE03256-MAS06107,Battery adaptation-Battery manufacturer,JCB,
IDE03256-MAS06108,Battery adaptation-Battery Serial Number,1111111111,
IDE03588-MAS05683,System malfunctions for active participants start/stop-Battery fault,0,
IDE03588-MAS06321,System malfunctions for active participants start/stop-System malfunction generator,0,
IDE03588-MAS06322,System malfunctions for active participants start/stop-System malfunction due to battery throughput,0,
IDE03588-MAS06323,System malfunctions for active participants start/stop-Start/stop coordinator implausible,0,
IDE03588-MAS06324,System malfunctions for active participants start/stop-DCDC converter system malfunction,0,
IDE03588-MAS06326,System malfunctions for active participants start/stop-Communication malfunction battery data module,0,
IDE03588-MAS06327,System malfunctions for active participants start/stop-Battery data module defective,0,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334,Public key for SWaP function,99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05583-IDE02766,Break recommendation-Malfunction status,No malfunction,
IDE05583-MAS03095,Break recommendation-Function status,Initialization,
IDE05583-MAS04622,Break recommendation-Break recommend. message,No message,
IDE05583-MAS13162,Break recommendation-Icon deactivated,No,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG136079,Driving profile selection: system status-profile_state_1,engaged,
IDE05740-ENG136080,Driving profile selection: system status-profile_state_2,engaged,
IDE05740-ENG136081,Driving profile selection: system status-profile_state_3,not engaged,
IDE05740-ENG136082,Driving profile selection: system status-profile_state_4,not engaged,
IDE05740-ENG136083,Driving profile selection: system status-profile_state_5,not engaged,
IDE05740-ENG136084,Driving profile selection: system status-profile_state_6,not engaged,
IDE05740-ENG136085,Driving profile selection: system status-profile_state_7,not engaged,
IDE05740-ENG136086,Driving profile selection: system status-profile_state_8,not engaged,
IDE05814,Individualization characteristic,FB 8C E2 7F 43,
IDE06007-IDE00105,Driving profile history data 1-Malfunction type,no entry,
IDE06007-IDE04805,Driving profile history data 1-Driving profile selection,0,
IDE06007-IDE07643,Driving profile history data 1-Faulty function,no entry,
IDE06007-MAS00106,Driving profile history data 1-Year,2000,
IDE06007-MAS00107,Driving profile history data 1-Month,0,
IDE06007-MAS00108,Driving profile history data 1-Day,0,
IDE06007-MAS00109,Driving profile history data 1-Hours,0,
IDE06007-MAS00110,Driving profile history data 1-Minutes,0,
IDE06007-MAS00111,Driving profile history data 1-Seconds,0,
IDE06007-MAS00711,Driving profile history data 1-kilometer reading,0, km
IDE06007-MAS03095,Driving profile history data 1-Function status,Initialization,
IDE06008-IDE00105,Driving profile history data 2-Malfunction type,no entry,
IDE06008-IDE04805,Driving profile history data 2-Driving profile selection,0,
IDE06008-IDE07643,Driving profile history data 2-Faulty function,no entry,
IDE06008-MAS00106,Driving profile history data 2-Year,2000,
IDE06008-MAS00107,Driving profile history data 2-Month,0,
IDE06008-MAS00108,Driving profile history data 2-Day,0,
IDE06008-MAS00109,Driving profile history data 2-Hours,0,
IDE06008-MAS00110,Driving profile history data 2-Minutes,0,
IDE06008-MAS00111,Driving profile history data 2-Seconds,0,
IDE06008-MAS00711,Driving profile history data 2-kilometer reading,0, km
IDE06008-MAS03095,Driving profile history data 2-Function status,Initialization,
IDE06009-IDE00105,Driving profile history data 3-Malfunction type,no entry,
IDE06009-IDE04805,Driving profile history data 3-Driving profile selection,0,
IDE06009-IDE07643,Driving profile history data 3-Faulty function,Transmission Control Module (TCM),
IDE06009-MAS00106,Driving profile history data 3-Year,2000,
IDE06009-MAS00107,Driving profile history data 3-Month,0,
IDE06009-MAS00108,Driving profile history data 3-Day,0,
IDE06009-MAS00109,Driving profile history data 3-Hours,0,
IDE06009-MAS00110,Driving profile history data 3-Minutes,0,
IDE06009-MAS00111,Driving profile history data 3-Seconds,0,
IDE06009-MAS00711,Driving profile history data 3-kilometer reading,0, km
IDE06009-MAS03095,Driving profile history data 3-Function status,Initialization,
IDE06010-IDE00105,Driving profile history data 4-Malfunction type,no entry,
IDE06010-IDE04805,Driving profile history data 4-Driving profile selection,0,
IDE06010-IDE07643,Driving profile history data 4-Faulty function,Engine/Motor Control Module,
IDE06010-MAS00106,Driving profile history data 4-Year,2000,
IDE06010-MAS00107,Driving profile history data 4-Month,0,
IDE06010-MAS00108,Driving profile history data 4-Day,0,
IDE06010-MAS00109,Driving profile history data 4-Hours,0,
IDE06010-MAS00110,Driving profile history data 4-Minutes,0,
IDE06010-MAS00111,Driving profile history data 4-Seconds,0,
IDE06010-MAS00711,Driving profile history data 4-kilometer reading,0, km
IDE06010-MAS03095,Driving profile history data 4-Function status,Initialization,
IDE06011-ENG136071,Selected driving profile-driving_profile_1,unknown_profile_2,
IDE06011-ENG136072,Selected driving profile-driving_profile_2,not working,
IDE06011-ENG136073,Selected driving profile-driving_profile_3,not working,
IDE06011-ENG136074,Selected driving profile-driving_profile_4,not working,
IDE06011-ENG136075,Selected driving profile-driving_profile_5,not working,
IDE06011-ENG136076,Selected driving profile-driving_profile_6,not working,
IDE06011-ENG136077,Selected driving profile-driving_profile_7,not working,
IDE06011-ENG136078,Selected driving profile-driving_profile_8,not working,
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,0,
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0,
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,0,
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0,
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0,
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0,
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0,
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,32279,
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,130275,
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0,
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0,
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0,
IDE06230-MAS00106,Break recommend.: last message-Year,2026,
IDE06230-MAS00107,Break recommend.: last message-Month,1,
IDE06230-MAS00108,Break recommend.: last message-Day,31,
IDE06230-MAS00109,Break recommend.: last message-Hours,11,
IDE06230-MAS00110,Break recommend.: last message-Minutes,22,
IDE06230-MAS00111,Break recommend.: last message-Seconds,0,
IDE06230-MAS03095,Break recommend.: last message-Function status,valid,
IDE06230-MAS04622,Break recommend.: last message-Break recommend. message,Stage 2,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,03,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07424-IDE04447,Status: driving profile selection for engine-Function status,not engaged,
IDE07424-IDE06260,Status: driving profile selection for engine-ID number,7,
IDE07424-MAS01156,Status: driving profile selection for engine-Communication status,OK,
IDE07424-MAS01447,Status: driving profile selection for engine-Actual value,2,
IDE07425-IDE04447,Status: driving profile selection for start-stop function-Function status,not engaged,
IDE07425-IDE06260,Status: driving profile selection for start-stop function-ID number,0,
IDE07425-MAS01156,Status: driving profile selection for start-stop function-Communication status,OK,
IDE07425-MAS01447,Status: driving profile selection for start-stop function-Actual value,0,
IDE07426-IDE04447,Status: driving profile selection for transmission-Function status,not engaged,
IDE07426-IDE06260,Status: driving profile selection for transmission-ID number,8,
IDE07426-MAS01156,Status: driving profile selection for transmission-Communication status,OK,
IDE07426-MAS01447,Status: driving profile selection for transmission-Actual value,2,
IDE07473-MAS06303,Generator limitation-Status overvoltage limitation,not active,
IDE07473-MAS06304,Generator limitation-Status overvoltage diagnosis,not active,
IDE07473-MAS06305,Generator limitation-Status of diagnosis for energy balance,not active,
IDE07473-MAS06306,Generator limitation-Status generator release by engine,no request,
IDE07473-MAS06307,Generator limitation-Status of battery charging function,active,
IDE07473-MAS06308,Generator limitation-Power steering support active,not active,
IDE07473-MAS06309,Generator limitation-Coolant fan activation request by BEM,not active,
IDE07474-MAS06313,Adapting for energy management-Adaptation static current management,not active,
IDE07474-MAS06314,Adapting for energy management-Battery coding active,not active,
IDE07616,Battery degradation for start/stop mode,Malfunction,
IDE07619-IDE07621,Start/stop starting voltage prediction-Permitted engine stop time,max.value,
IDE07619-IDE07622,Start/stop starting voltage prediction-Power consumption during idle phase,70, A
IDE07623-MAS06328,Open-circuit voltage gateway-Battery voltage last wakeup,13.1, V
IDE07623-MAS06329,Open-circuit voltage gateway-Batter voltage penultimate wakeup,15.0, V
IDE07623-MAS06330,Open-circuit voltage gateway-Open-circuit voltage valid,invalid,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,locked,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,locked,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,13.2, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,21, A
IDE07636-MAS06337,Status hybrid DC/DC converter-DCDC converter reserve current,213, A
IDE07638-MAS06339,Status condition determin. ready for idle-Sleep readiness BEM,ended,
IDE07638-MAS06340,Status condition determin. ready for idle-Busstat readiness BEM,Run busstat,
IDE07638-MAS06341,Status condition determin. ready for idle-After-run for power receptacle,not active,
IDE07639-MAS06342,Methods for support of high voltage side-Operating range support request,no request,
IDE07639-MAS06343,Methods for support of high voltage side-Voltage decrease range extension,not active,
IDE07640-MAS06344,Analysis of start voltage behavior-Minimum voltage at last engine start,13.00,
IDE07640-MAS06345,Analysis of start voltage behavior-Minimum voltage at last engine start recognized,not recognised,
IDE07640-MAS06346,Analysis of start voltage behavior-Voltage drop through engine start recognized,not recognised,
IDE07640-MAS06347,Analysis of start voltage behavior-Current voltage drop last start,Initialization,
IDE07640-MAS06348,Analysis of start voltage behavior-Normed voltage drop,Initialization,
IDE07640-MAS11064,Analysis of start voltage behavior-Current last engine start,7, A
IDE07640-MAS11065,Analysis of start voltage behavior-Current delta last engine start,0, A
IDE07681-MAS06086,Battery total charging throughput-Total re-charge,7147.1, Ah
IDE07681-MAS06087,Battery total charging throughput-Entire energy throughput,6593.4, Ah
IDE07873-MAS06193,Driving mode selection activated profiles-Profile 1,Not Used,
IDE07873-MAS06194,Driving mode selection activated profiles-Profile 2,Not Used,
IDE07873-MAS06195,Driving mode selection activated profiles-Profile 3,Not Used,
IDE07873-MAS06196,Driving mode selection activated profiles-Profile 4,Not Used,
IDE07873-MAS06197,Driving mode selection activated profiles-Profile 5,Not Used,
IDE07873-MAS06198,Driving mode selection activated profiles-Profile 6,Not Used,
IDE07873-MAS06199,Driving mode selection activated profiles-Profile 7,Not Used,
IDE07873-MAS06200,Driving mode selection activated profiles-Profile 8,unknown_profile_2,
IDE07873-MAS08875,Driving mode selection activated profiles-Profile 9,unknown_profile_2,
IDE07873-MAS08876,Driving mode selection activated profiles-Profile 10,Not Used,
IDE07873-MAS08877,Driving mode selection activated profiles-Profile 11,Not Used,
IDE07873-MAS08878,Driving mode selection activated profiles-Profile 12,Not Used,
IDE07907,Bus communication,active,
IDE08343,Immobilizer Challenge,B4 0B DD 6C,
IDE08346-MAS06117,Generator Analysis-Specified voltage,10.6, V
IDE08346-MAS06864,Generator Analysis-Generator actual voltage,8.0, V
IDE08346-MAS06865,Generator Analysis-Voltage difference generator battery,0.0, V
IDE08346-MAS06866,Generator Analysis-Generator speed,0, /min
IDE08346-MAS06867,Generator Analysis-Generator chip temperature,-40, °C
IDE08347,adapted battery capacity,68, Ah
IDE08660,Recharging the NV battery,no request,
IDE08680-MAS03173,Allocation data bus identifier-Powertrain data bus,11,
IDE08680-MAS03174,Allocation data bus identifier-Comfort data bus,12,
IDE08680-MAS03175,Allocation data bus identifier-Extended data bus,15,
IDE08680-MAS03177,Allocation data bus identifier-Infotainment data bus,13,
IDE08680-MAS03178,Allocation data bus identifier-Suspension data bus,14,
IDE08680-MAS03179,Allocation data bus identifier-Local data bus 2,52,
IDE08680-MAS03180,Allocation data bus identifier-Local data bus,51,
IDE08680-MAS05686,Allocation data bus identifier-Data bus diagnostics,10,
IDE08680-MAS05972,Allocation data bus identifier-Local data bus 3,53,
IDE08681-MAS03173,Data bus defect error-Powertrain data bus,OK,
IDE08681-MAS03174,Data bus defect error-Comfort data bus,OK,
IDE08681-MAS03175,Data bus defect error-Extended data bus,OK,
IDE08681-MAS03177,Data bus defect error-Infotainment data bus,OK,
IDE08681-MAS03178,Data bus defect error-Suspension data bus,OK,
IDE08681-MAS03179,Data bus defect error-Local data bus 2,OK,
IDE08681-MAS03180,Data bus defect error-Local data bus,OK,
IDE08681-MAS05686,Data bus defect error-Data bus diagnostics,OK,
IDE08681-MAS05972,Data bus defect error-Local data bus 3,not installed,
IDE08682-MAS03173,Data bus single wire err.-Powertrain data bus,OK,
IDE08682-MAS03174,Data bus single wire err.-Comfort data bus,OK,
IDE08682-MAS03175,Data bus single wire err.-Extended data bus,OK,
IDE08682-MAS03177,Data bus single wire err.-Infotainment data bus,OK,
IDE08682-MAS03178,Data bus single wire err.-Suspension data bus,OK,
IDE08682-MAS03179,Data bus single wire err.-Local data bus 2,Not coded,
IDE08682-MAS03180,Data bus single wire err.-Local data bus,Not coded,
IDE08682-MAS05686,Data bus single wire err.-Data bus diagnostics,Not coded,
IDE08682-MAS05972,Data bus single wire err.-Local data bus 3,not installed,
IDE08683-MAS03173,Data bus TimeOut error-Powertrain data bus,OK,
IDE08683-MAS03174,Data bus TimeOut error-Comfort data bus,OK,
IDE08683-MAS03175,Data bus TimeOut error-Extended data bus,OK,
IDE08683-MAS03177,Data bus TimeOut error-Infotainment data bus,OK,
IDE08683-MAS03178,Data bus TimeOut error-Suspension data bus,OK,
IDE08683-MAS03179,Data bus TimeOut error-Local data bus 2,Not coded,
IDE08683-MAS03180,Data bus TimeOut error-Local data bus,Not coded,
IDE08683-MAS05686,Data bus TimeOut error-Data bus diagnostics,Not coded,
IDE08683-MAS05972,Data bus TimeOut error-Local data bus 3,not installed,
IDE08684-SFT271901,Allocation LIN system number-Generator,00 1D,
IDE08684-SFT271921,Allocation LIN system number-Multi-function steering wheel control module,00 31,
IDE08684-SFT271927,Allocation LIN system number-Battery Monitoring Control Module,00 37,
IDE08684-SFT271977,Allocation LIN system number-Inverter for socket,00 69,
IDE08684-SFT271986,Allocation LIN system number-Analog clock,00 72,
IDE08684-SFT272175,Allocation LIN system number-Control head driving profile,01 2F,
IDE08684-SFT272190,Allocation LIN system number-Steering Wheel Touch Recognition Control Module,01 3E,
IDE08685-SFT271901,Status LIN user-Generator,not active,
IDE08685-SFT271921,Status LIN user-Multi-function steering wheel control module,active,
IDE08685-SFT271927,Status LIN user-Battery Monitoring Control Module,active,
IDE08685-SFT271977,Status LIN user-Inverter for socket,not active,
IDE08685-SFT271986,Status LIN user-Analog clock,not active,
IDE08685-SFT272175,Status LIN user-Control head driving profile,not active,
IDE08685-SFT272190,Status LIN user-Steering Wheel Touch Recognition Control Module,active,
IDE08794-MAS06106,Battery cell analysis-Battery technology,Unknown,
IDE08794-MAS07703,Battery cell analysis-Cell voltage,0.0000, V
IDE08794-MAS07704,Battery cell analysis-Cell temp.,-40, °C
IDE08794-MAS07705,Battery cell analysis-Cell limit voltage (binary coded),0,
IDE08794-MAS07706,Battery cell analysis-Can be analyzed,Initialization,
IDE08794-MAS07707,Battery cell analysis-Health condition acc. to calendar,126, %
IDE08794-MAS07708,Battery cell analysis-Cut-off element,closed,
IDE09057,HV battery charge state,99.0, %
IDE09074-MAS01078,Vehicle properties-Vehicle model,Plugin Hybrid,
IDE09074-MAS08256,Vehicle properties-Max energy content,2.3936e+006, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),19.2, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,6.1, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,16.9, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,40.5, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,530, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,10.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,10.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,768, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,43, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,30, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,811, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,768, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,43, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,0, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,813,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,770,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,43,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,Kilometres,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,5.1, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,7.3, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,5.9, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,6.3, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,6.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,5.3, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,6.1, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,15.0, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,14.4, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,14.3, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,14.3, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,14.3, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,21.9, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,16.9, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,47.3, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery:  RWB-internal deduction,8000, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.3, l
IDE09561,Static current last LIN sleep phase,-4.226, A
IDE09562,Range extension counter: stage 2,65535,
IDE10674-MAS11055,Extended battery diagnosis-Pulse interior resistance,2.2, mOhm
IDE10674-MAS11056,Extended battery diagnosis-Counter battery warning,0,
IDE10674-MAS11059,Extended battery diagnosis-Power state LV battery singular operation,OK,
IDE10674-MAS11060,Extended battery diagnosis-Status Handshake HVK,OK,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,not engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,10,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Actual value,0,
IDE11573,Energy management in heating power allocation,1000, W
IDE12084,Component protection participant status,00 14 1B 00 00 00 0E 13 00 00 00 57 13 00 00 00 15 13 00 00 00 6F 20 00 00 00 6D 20 00 00 00 73 13 00 00 00 4E 20 00 00 00 8A 20 00 00 00 2C 20 00 00 00 4F 13 00 00 00 7B 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,25,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,33,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,41,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE13754-IDE04447,Diagnostic filter: status-Function status,Function active,
IDE13754-MAS16866,Diagnostic filter: status-Mileage recorder,0, km
IDE13754-MAS16867,Diagnostic filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnostic filter: status-Filter status,Filter active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,0136135*2026-08-21-18-32-23*1**,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,0136046*2026-08-21-07-03-15*1**,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,0136046*2026-08-20-21-50-43*1**,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,0000000*2026-08-20-21-50-43*1**,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,0136046*2026-08-20-21-49-34*1**,
IDE14424,Historical data info status,00000110 ,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,18,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,41,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,125,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,136252, km
MAS00769-IDE02717,Multi-function steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multi-function steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multi-function steering wheel control module-MFL Variant code,9,
MAS00769-MAS01065,Multi-function steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multi-function steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multi-function steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multi-function steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multi-function steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multi-function steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multi-function steering wheel control module-MFL message counter,2,
MAS00769-MAS06030,Multi-function steering wheel control module-MFL Toggle Bit,1,
MAS00769-MAS06034,Multi-function steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multi-function steering wheel control module-MFL M button,Not operated,
MAS04447-IDE06339,Engine running status-Hybrid readiness: status,not active,
MAS04447-MAS01493,Engine running status-Engine is running,Engine is running,
MAS04447-MAS03023,Engine running status-Driving mode,Driving mode,
MAS04447-MAS06320,Engine running status-Status rolling mode,not active,
MAS07408,Available power for low-voltage systems,1500, W
MAS07409,Status automatic recharging of low-voltage battery,Malfunction,
MAS07410,Requirement for consumer reduction,none,
SFT271901,Generator,-,
SFT271901-ENG250861,Generator-alternator_family,30,
SFT271901-ENG245985,Generator-asic_manufacturer,30 37,
SFT271901-ENG250451,Generator-asic_variant,31 66,
SFT271901-ENG171470,Generator-Manufacturer,30 37,
SFT271901-ENG99001,Generator-Variant,31 66,
ENG118784-ENG124497,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Actuator_Exterior_Noise,not active,
ENG118784-ENG118736,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Adaptive_Cruise_Control,not active,
ENG118784-ENG137111,Driv._Prof._Sel._Coord._Retry_State-Retry_State_AGK,not active,
ENG118784-ENG124493,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Air_Condition,not active,
ENG118784-ENG118739,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Ambient_Illumination,not active,
ENG118784-ENG124501,Driv._Prof._Sel._Coord._Retry_State-Retry_State_area_view,not active,
ENG118784-ENG124495,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Belt_Pretensioner,not active,
ENG118784-ENG124499,Driv._Prof._Sel._Coord._Retry_State-Retry_State_brake_control_system,not active,
ENG118784-ENG124503,Driv._Prof._Sel._Coord._Retry_State-Retry_State_central_differential,not active,
ENG118784-ENG118734,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Damper_Control,not active,
ENG118784-ENG137112,Driv._Prof._Sel._Coord._Retry_State-Retry_State_EDS,not active,
ENG118784-ENG126254,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Electronic_Brake_Booster,not active,
ENG118784-ENG118730,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Engine_Control,not active,
ENG118784-ENG152042,Driv._Prof._Sel._Coord._Retry_State-Retry_State_FMA,not active,
ENG118784-ENG124498,Driv._Prof._Sel._Coord._Retry_State-Retry_State_front_axle_differential_lock,not active,
ENG118784-ENG124500,Driv._Prof._Sel._Coord._Retry_State-Retry_State_hill_descent_control,not active,
ENG118784-ENG137110,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Hill_Distence_Control,not active,
ENG118784-ENG124494,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Lighting_Control,not active,
ENG118784-ENG126252,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Operation_Mode,not active,
ENG118784-ENG124496,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Overrunning_Clutch,not active,
ENG118784-ENG137108,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Park_Distence_Control,not active,
ENG118784-ENG126251,Driv._Prof._Sel._Coord._Retry_State-Retry_State_range_Calculation,not active,
ENG118784-ENG124502,Driv._Prof._Sel._Coord._Retry_State-Retry_State_rear_spoiler,not active,
ENG118784-ENG126253,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Seat_Sidebolster_Adjustment,not active,
ENG118784-ENG118737,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Sound_Actuator,not active,
ENG118784-ENG124492,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Start_/_Stop,not active,
ENG118784-ENG118733,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Steering_Support,not active,
ENG118784-ENG118732,Driv._Prof._Sel._Coord._Retry_State-Retry_State_Transmission_Control,not active,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not recognised,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not recognised,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG118766,eASS_operation_status,Emergency running mode,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG106123,EM_blAlternator On,On,
ENG106140,EM_Current_Control_Recu,not active,
ENG151180,EM_electrical_system_current,21.512, A
ENG118437,EM_IAlternatorReserve,213.0, A
ENG118434,EM_LoadResponse Time,3, s
ENG106154,EM_PAltMechanical,0, W
ENG106155-ENG118436,EM_prcSoh-SOH_P,82, %
ENG106155-ENG118435,EM_prcSoh-SOH_Q,82, %
ENG106157,EM_RecuMode_Engine,not coded / not installed,
ENG118780-ENG246261,EM_Recuperation_Precondition-48V_emergency_run,0,
ENG118780-ENG118443,EM_Recuperation_Precondition-acid_lamination,0,
ENG118780-ENG118438,EM_Recuperation_Precondition-available_charge,0,
ENG118780-ENG118442,EM_Recuperation_Precondition-battery_aging_charge,0,
ENG118780-ENG118441,EM_Recuperation_Precondition-battery_aging_power,0,
ENG118780-ENG118440,EM_Recuperation_Precondition-battery_charging_state,0,
ENG118780-ENG118447,EM_Recuperation_Precondition-battery_regeneration,1,
ENG118780-ENG103388,EM_Recuperation_Precondition-battery_temperature,0,
ENG118780-ENG112320,EM_Recuperation_Precondition-Battery_Voltage,0,
ENG118780-ENG167301,EM_Recuperation_Precondition-climate_electronics_enable,1,
ENG118780-ENG118448,EM_Recuperation_Precondition-energy_net,0,
ENG118780-ENG118445,EM_Recuperation_Precondition-generator_diagnosis,0,
ENG118780-ENG118449,EM_Recuperation_Precondition-idle_increase,0,
ENG118780-ENG167323,EM_Recuperation_Precondition-kfg_enable,1,
ENG118780-ENG118439,EM_Recuperation_Precondition-LIN_communication,0,
ENG118780-ENG118450,EM_Recuperation_Precondition-special_veto,0,
ENG118781-ENG118673,EM_Recuperation_Restriction-component_protection_engine,0,
ENG118781-ENG118675,EM_Recuperation_Restriction-component_protection_EPS,0,
ENG118781-ENG118674,EM_Recuperation_Restriction-component_protection_ESP,0,
ENG118781-ENG118672,EM_Recuperation_Restriction-component_protection_high_beam_light,0,
ENG118781-ENG118668,EM_Recuperation_Restriction-inside_light_active,0,
ENG118781-ENG118670,EM_Recuperation_Restriction-left_turn_signal_active,0,
ENG118781-ENG252593,EM_Recuperation_Restriction-limited_by_48V_consumer,0,
ENG118781-ENG107413,EM_Recuperation_Restriction-low_beam_light_active,0,
ENG118781-ENG110583,EM_Recuperation_Restriction-PLA,0,
ENG118781-ENG113826,EM_Recuperation_Restriction-RekuLight,0,
ENG118781-ENG118669,EM_Recuperation_Restriction-right_turn_signal_active,0,
ENG118781-ENG167381,EM_Recuperation_Restriction-voltage_requirement_bcm,0,
ENG118781-ENG167382,EM_Recuperation_Restriction-voltage_Requirement_kfg,0,
ENG118781-ENG118667,EM_Recuperation_Restriction-workload_inside_blaster,0,
ENG118782-ENG118462,Gateway app. software identification-software_version_BCmE,1035,
ENG118782-ENG118457,Gateway app. software identification-software_version_eASS,2015,
ENG118782-ENG137098,Gateway app. software identification-software_version_ehr,1014,
ENG118782-ENG118454,Gateway app. software identification-software_version_em,7103,
ENG118782-ENG118453,Gateway app. software identification-software_version_fpa,-010,
ENG118782-ENG118455,Gateway app. software identification-software_version_history_data,0700,
ENG118782-ENG125888,Gateway app. software identification-software_version_hv-em,0901,
ENG118782-ENG118456,Gateway app. software identification-software_version_ks,----,
ENG118782-ENG118458,Gateway app. software identification-software_version_mfl,0200,
ENG118782-ENG118463,Gateway app. software identification-software_version_mke,3148,
ENG118782-ENG163716,Gateway app. software identification-software_version_mv-em,----,
ENG118782-ENG163717,Gateway app. software identification-software_version_rtm,----,
ENG118782-ENG122591,Gateway app. software identification-software_version_rwb,A013,
ENG118782-ENG118459,Gateway app. software identification-software_version_service_key_1a,0100,
ENG118782-ENG118460,Gateway app. software identification-software_version_SWaP,0630,
ENG118782-ENG118461,Gateway app. software identification-software_version_wakeup_monitor,0100,
ENG118782-ENG118452,Gateway app. software identification-version_routing_gateway,7220,
ENG125882-ENG123177,HV-EM_currents-DCDC_HV_current,0.8, A
ENG125882-ENG123148,HV-EM_currents-ekk_air_condition_current,0.00,
ENG125882-ENG123147,HV-EM_currents-ptc_heater_current,0.00,
ENG151181-ENG152029,HV-EM_Energy_information-High_voltage_battery_energy_information,8000, Wh
ENG151181-ENG152032,HV-EM_Energy_information-HV-EM_high_voltage_battery_energy_information,7750, Wh
ENG151181-ENG152039,HV-EM_Energy_information-NV_energy_requirement,2550, Wh
ENG151182-ENG152030,HV-EM_High_voltage_requirements-HV_system_error,No malfunction,
ENG151182-ENG152033,HV-EM_High_voltage_requirements-HV-EM_HV_requirement,no request,
ENG151182-ENG152036,HV-EM_High_voltage_requirements-HV-EM_recharging_requirement,no request,
ENG151182-ENG152037,HV-EM_High_voltage_requirements-HV-LM_HV_requirement,not_requested,
ENG151182-ENG152040,HV-EM_High_voltage_requirements-Requirement_autonomous_charging_via_HV_battery,no request,
ENG151182-ENG152041,HV-EM_High_voltage_requirements-Requirement_autonomous_charging_via_HV_charger,no request,
ENG125881,HV-EM_operation_mode,HV-EM_active_clamp_15,
ENG151183-ENG152028,HV-EM_Power_current_limitation-High_voltage_battery_current_limitation,282, A
ENG151183-ENG152034,HV-EM_Power_current_limitation-HV-EM_NV_power_limitation,1500, W
ENG151183-ENG152035,HV-EM_Power_current_limitation-HV-EM_power_limitation,0, W
ENG125883-ENG123181,HV-EM_reduction_of_comfort_consumers-cutoff_climate_aggregates,No enabling,
ENG125883-ENG123182,HV-EM_reduction_of_comfort_consumers-cutoff_HV_comfort_consumers,not requested,
ENG125883-ENG123178,HV-EM_reduction_of_comfort_consumers-max_current_climate_aggregates,0, A
ENG125883-ENG123180,HV-EM_reduction_of_comfort_consumers-max_power_HV_comfort_consumers,25400, W
ENG125883-ENG123179,HV-EM_reduction_of_comfort_consumers-reduction_climate_aggregates,25_percent,
ENG151184-ENG152031,HV-EM_values-HV-EM_ approval_dcdc_converter,Activation,
ENG151184-ENG152043,HV-EM_values-RWV_reduction_level,no request,
ENG118666,MKE_HFC_filtrated,1.9,
ENG126247-ENG126257,MKE_TTNR-TTNR_DS,60021,
ENG126247-ENG126256,MKE_TTNR-TTNR_SW,60039,
ENG250370-ENG250534,NVEM_Grund_BEM_falsch_codiert-Grund_BEM_falsch_codiert,0,
Elapsed Time: 00:50
blockmap-23-3Q0-909-059-G_WVWZZZ3CZME009325-20260823-2128.CSV
;SW:3Q0-909-059-G   HW:3Q0-909-059-A ---  23: Brake Booster
;Component:EBKV          H06 0069, Coding:0202C104340000C618638C31000049922449920400
;EV_BrakeBoostG2BoschVW48X,011019,EV_BrakeBoostG2BoschVW48X_011_VW48.rod
;Sunday,23,August,2026,21:28:36:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 3B285896D3E27952CB0-806E
Group,Description,Actual
IDE05816-IDE00075,Input signals from data bus-Vehicle speed,13.248, km/h
IDE05816-IDE00773,Input signals from data bus-Terminal 15 status via CAN,Terminal 15 on,
IDE05816-IDE02211,Input signals from data bus-Brake pressure,0.60000, bar
IDE05816-IDE09696,Input signals from data bus-Charisma driving program: CAN output value,Program 2,
IDE05816-MAS01078,Input signals from data bus-Vehicle model,Hybrid vehicle,
IDE05816-MAS02357,Input signals from data bus-Vehicle identification,00 60 72 66 64 6A,
IDE05816-MAS08111,Input signals from data bus-OBD std.,EOBD,
IDE05816-MAS19863,Input signals from data bus-Status of parking brake: electromechanical,Bremse_geschl_(Spannkraft_voll/reduziert),
IDE07159-MAS01155,Control module switch-off: counter-Control module,0, min
IDE07159-MAS05583,Control module switch-off: counter-Data bus,0, min
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE08587-MAS08097,Power brake displays-Status: OBD lamp,OFF,
IDE08588-IDE00020,Sensor signals for electromechanical power brake-Terminal 15 status,Terminal 15 on,
IDE08588-IDE00102,Sensor signals for electromechanical power brake-Control Module temperature,36.0, °C
IDE08588-IDE02222,Sensor signals for electromechanical power brake-Driver brakes: qualification,OFF,
IDE08588-IDE02713,Sensor signals for electromechanical power brake-Brake lamp switch,OFF,
IDE08588-IDE02714,Sensor signals for electromechanical power brake-Brake test switch,On,
IDE08588-IDE11037,Sensor signals for electromechanical power brake-Brake light switch: qualification,On,
IDE08588-MAS00043,Sensor signals for electromechanical power brake-Terminal 30 power supply,13.2, V
IDE08588-MAS05192,Sensor signals for electromechanical power brake-Driver braking,OFF,
IDE08588-MAS06928,Sensor signals for electromechanical power brake-Supply voltage pedal travel sensor,4.9, V
IDE08588-MAS10345,Sensor signals for electromechanical power brake-Position of booster,0.0351562500, mm
IDE08588-MAS10346,Sensor signals for electromechanical power brake-Engine torque,0.00000, Nm
IDE08588-MAS11639,Sensor signals for electromechanical power brake-Input rod travel,0.00, mm
IDE08588-MAS18095,Sensor signals for electromechanical power brake-Output rod,0.000000, mm
IDE08588-MAS18096,Sensor signals for electromechanical power brake-Brake pedal travel,Initialization,
IDE08588-MAS18097,Sensor signals for electromechanical power brake-Brake test switch: qualification,On,
IDE08588-MAS18098,Sensor signals for electromechanical power brake-Driver brakes clearly,OFF,
IDE08623-MAS02163,OBD configuration-coded,EOBD,
IDE08623-MAS08097,OBD configuration-Status: OBD lamp,OFF,
IDE08623-MAS14472,OBD configuration-calculated,EOBD,
IDE08623-MAS19862,OBD configuration-Status of generic scan tool,OFF,
IDE10300,OBD Driving Cycle detected,not active,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00000, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00000000000, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,Open,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.0000000, mm
IDE14229-MAS18099,Brake booster control status-Control mode,No activation,
IDE14229-MAS18101,Brake booster control status-Actuator Position,0.03124, mm
IDE14229-MAS18102,Brake booster control status-Actuator torque,0.00000, Nm
IDE14229-MAS18103,Brake booster control status-Actuator speed,0.00000, mm/s
IDE14229-MAS18104,Brake booster control status-Remaining hold time,0, s
IDE14696-MAS03458,Leak test-Differential pressure,0.0000, bar
IDE14696-MAS19863,Leak test-Status of parking brake: electromechanical,Open,
IDE14696-MAS19864,Leak test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leak test-Brake pressure 2,0, bar
IDE80221-ENG252453,Analysis 221-Driver On Pedal,false,
IDE80221-ENG252454,Analysis 221-iBooster Ready for Actuation,OFF,
IDE80221-ENG252457,Analysis 221-iBooster System Mode,ready,
IDE80221-ENG252455,Analysis 221-Pedal Apply Recognition HW Output,false,
IDE80221-ENG252458,Analysis 221-Thermal Limitation,not_active,
IDE80221-ENG252452,Analysis 221-Wakeup Information HW,On,
IDE80221-ENG252456,Analysis 221-Wakeup Information NET,On,
IDE80222,Analysis 222,01 D6 EB,
IDE80223,Analysis 223,40.7421875, mm
IDE80223,Analysis 223,0.00000000000, Nm
IDE80223,Analysis 223,1.7578125, mm/s
IDE80223,Analysis 223,102.8750000, mm/s
IDE80223,Analysis 223,0.0000000, mm
IDE80223,Analysis 223,1.78027343750, Nm
IDE80225,Analysis 225,0,
IDE80225,Analysis 225,not active,
IDE80226-ENG249302,Analysis 226-Umgesetztes Charisma-Fahrprogramm_Wert,15,
MAS10409-MAS00106,Time stamp-Year,2026,
MAS10409-MAS00107,Time stamp-Month,8,
MAS10409-MAS00108,Time stamp-Day,23,
MAS10409-MAS00109,Time stamp-Hours,21,
MAS10409-MAS00110,Time stamp-Minutes,28,
MAS10409-MAS00111,Time stamp-Seconds,30,
Elapsed Time: 00:02
blockmap-2B-3Q0-905-861-B_WVWZZZ3CZME009325-20260823-2128.CSV
;SW:3Q0-905-861-B   HW:3Q0-905-861-B ---  2B: Steer. Col. Lock
;Component:ELV-MQBB      H05 0020, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW48.rod
;Sunday,23,August,2026,21:28:50:32152
;VCID: 333870B6FBB2B112130-8066
IDE00019,Voltage terminal 30,13.1,
IDE00021,Engine speed,0.00, /min
IDE00021-MAS00058,Engine speed-Implausible,No,
IDE00021-MAS00103,Engine speed-invalid,No,
IDE00021-MAS02239,Engine speed-outdated,No,
IDE00021-MAS02246,Engine speed-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,OK,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,2,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,8884,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,Closed,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine speed,Condition met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition met,
IDE06746-MAS02349,Locking requirements-Learn mode,Not adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition not met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,28,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,44,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128820,Free_Releases_Numbers,255,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Confirmed,
ENG128822-ENG255750,functional_check-Functional_Check_VW_EOL,Not confirmed,
Elapsed Time: 00:04
blockmap-42-5Q0-959-593-K_WVWZZZ3CZME009325-20260823-2129.CSV
;SW:5Q0-959-593-K   HW:5Q0-959-593-F ---  42: Door Elect, Driver
;Component:TSG FS002 0330, Coding:003F0F20D000020000001000
;EV_DCU2DriveSideMAXHKLO,001018,EV_DCU2DriveSideMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:29:01:32152
;VCID: 49C4325E893EDBC249C-801C
IDE00310,Outside temperature,26.50, °C
IDE01766-MAS02248,Distance impulses-Signal status,OK,
IDE01992-MAS12276,Installation list: current installations-Front door control module,reachable,
IDE01992-MAS12277,Installation list: current installations-Rear door control module,reachable,
IDE01993-MAS12276,Control module reference number-Front door control module,Driver door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Left rear door control module,
IDE02262,synchronous mirror adjustment,not active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,12.80, V
IDE02384-MAS12276,Status of event memory-Front door control module,No malfunctions in DTC memory,
IDE02384-MAS12277,Status of event memory-Rear door control module,No malfunctions in DTC memory,
IDE03150-MAS12276,Readiness for bus sleep mode-Front door control module,active,
IDE03150-MAS12277,Readiness for bus sleep mode-Rear door control module,Bus sleep mode,
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating State,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,Not operated,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04343-MAS03180,Bus identification-Local data bus,assigned,
IDE04343-MAS12276,Bus identification-Front door control module,Bus master,
IDE04411,Child safety button,Not operated,
IDE04539-MAS01634,Mirror memory-Supply voltage,not active,
IDE04539-MAS02228,Mirror memory-X coordinate,Not available,
IDE04539-MAS02229,Mirror memory-Y coordinate,Not available,
IDE04539-MAS02476,Mirror memory-installed,not installed,
IDE04540,Mirror adjustment (X/Y direction),Center position,
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator lamp in button,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,Implausible,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,14, %
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,No,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,No,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,Yes,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator lamp in button,not coded / not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded / not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,not active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,95.50, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,not active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Idle state,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,21.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07405-MAS02447,Enable driver front window regulator relay-Activation,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,26, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08205-MAS01453,Closing aid-Blocking detection,not active,
IDE08205-MAS02103,Closing aid-Signal from door lock: catch,Implausible,
IDE08205-MAS05370,Closing aid-Direction of movement,Not available,
IDE08205-MAS08613,Closing aid-Return contact,closed,
IDE08205-MAS08614,Closing aid-Closing assist motor current,Not available,
IDE08205-MAS09346,Closing aid-Door position,closed,
IDE08205-MAS09347,Closing aid-Redundant door contact,not installed,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE08795,Rear shade button,not installed,
IDE09071-MAS00030,Seat belt positioner-Seat occupant detection,not active,
IDE09071-MAS02666,Seat belt positioner-Seat belt buckle scan,Open,
IDE09071-MAS05370,Seat belt positioner-Direction of movement,Not available,
IDE09071-MAS08502,Seat belt positioner-Standardized belt feeder,No,
IDE09071-MAS08503,Seat belt positioner-End stop of Hall sensor,not recognised,
IDE09071-MAS08504,Seat belt positioner-Position of belt feeder,Not available,
IDE09071-MAS08505,Seat belt positioner-Motor current of belt feeder,Not available,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatic dimming outside mirror-Status,not installed,
IDE10164-MAS03691,Automatic dimming outside mirror-Dimming,0, %
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
IDE12336-MAS03095,Door heating element 2-Function status,not installed,
IDE12336-MAS04136,Door heating element 2-Current,not installed,
IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
IDE12422-IDE02266,Driver side front door control head-Passenger side rear power window button,Not operated,
IDE12422-IDE04220,Driver side front door control head-Driver power window button,Not operated,
IDE12422-IDE04411,Driver side front door control head-Child safety button,Not operated,
IDE12422-IDE04540,Driver side front door control head-Mirror adjustment (X/Y direction),bottom position,
IDE12422-IDE06621,Driver side front door control head-Driver side rear power window button,Not operated,
IDE12422-IDE06872,Driver side front door control head-Front passenger power window button,Not operated,
IDE12422-IDE10158,Driver side front door control head-Window lift: switch-over from front to rear,not installed,
IDE12422-IDE11140,Driver side front door control head-Mirror folding position,Driving setting,
IDE12422-MAS14179,Driver side front door control head-Child safety lock rear driver side: status,not active,
IDE12422-MAS14180,Driver side front door control head-Child safety lock rear passenger side: status,not active,
IDE12422-MAS15309,Driver side front door control head-Mirror selector switch: left,Not operated,
IDE12422-MAS15310,Driver side front door control head-Mirror selection switch: right,Not operated,
IDE12422-MAS15311,Driver side front door control head-Button: open rear lid,Not operated,
IDE12422-MAS15312,Driver side front door control head-Close rear lid button,not installed,
IDE12422-MAS15313,Driver side front door control head-Bus signal: open rear lid,Not operated,
IDE12422-MAS15314,Driver side front door control head-Close rear lid bus signal,Not operated,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,not installed,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,not installed,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,not installed,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,not installed,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6)
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,Not available,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,Not available,
IDE14109,Excess temperature shutdown of close assist,not active,
IDE15336,Light output 1 pin D8 target brightness on front driver side,Not available,
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,Not available,
IDE15339,Light output 4 pin D16 target brightness on front driver side,Not available,
IDE15636,Light output 2 pin D3 target brightness on front driver side,Not available,
MAS01872,Rear lid remote release button,Not operated,
MAS02101,Child safety,not active,
MAS06010,Ambient light,41, %
Elapsed Time: 00:08
blockmap-44-5Q0-910-143-C_WVWZZZ3CZME009325-20260823-2129.CSV
;SW:5Q0-910-143-C   HW:5Q0-910-143 ---  44: Steering Assist
;Component:MQB_VWBS_GEN2 212 2211, Coding:0100001100410010
;EV_SteerAssisVWBSMQBGen2,002119,EV_SteerAssisVWBSMQBGen2.rod
;Sunday,23,August,2026,21:29:17:32152
;VCID: 2B0868D62382E9D25B0-807E
IDE00019,Voltage terminal 30,13.14, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,45, °C
IDE02006-IDE02955,Lane departure warning-System status,Function cannot be performed,
IDE02006-IDE04227,Lane departure warning-Directional stab. asst w/ pwr steering asst: steering status,0.00, Nm
IDE02006-MAS03095,Lane departure warning-Function status,active,
IDE02006-MAS03368,Lane departure warning-Steering wheel vibration,0.0, Nm
IDE02202,End stage temperature,30, °C
IDE02216-IDE07542,Steering angle sensor: basic setting-Prerequisites: basic setting,not possible,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02955,System status,Drive_down,
IDE02955-MAS02545,System status-Last,Pre_Drive,
IDE02955-MAS02546,System status-Second to last,Nm_wait,
IDE02955-MAS02547,System status-Third to last,Shutdown,
IDE02955-MAS02548,System status-Fourth to last,Shutdown,
IDE02955-MAS05380,System status-fifth to last,Drive_down,
IDE02955-MAS12215,System status-sixth to last,Pre_Drive,
IDE02955-MAS12216,System status-seventh to last,Nm_wait,
IDE03214,Engine stop using start-stop function,Condition not met,
IDE03682-IDE04457,motor position sensor-Speed of electric drive motor,14, /min
IDE03682-MAS02961,motor position sensor-Engine angle,287.23, °
IDE03682-MAS03083,motor position sensor-Cosine signal,1.13, V
IDE03682-MAS03211,motor position sensor-Sine signal,2.64, V
IDE03682-MAS05053,motor position sensor-Reference value,1.12, V
IDE03725-IDE03734,Steering Assistance-Support power,0.00, %
IDE03725-MAS03001,Steering Assistance-Mode,Not assigned,
IDE03725-MAS03095,Steering Assistance-Function status,not activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not activated,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,0.00, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,0.00, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not active,
IDE03726-ENG110676,Parallel Parking Assistance-Status_abort_PLA,Initial value,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,0.00, °
IDE04118-MAS03095,Straight line running correction-Function status,not active,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,0.00, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.00, °
IDE04119-MAS03737,Active default-Return speed: setpoint,-53.06, °/s
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04181,Rotor temperature,30.0, °C
IDE04182,Stator temperature,30.0, °C
IDE04183,Steering assistance: target engine torque,0.00, Nm
IDE04184,Steering assistance: engine output,0.00, %
IDE04185,Terminal 30 voltage filtered,13.17, V
IDE04188,Steering torque: raw value 2,81 04,
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,50.06, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,49.98, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,49.98, %
IDE04194,Steering assistance: electromotor power,0.00, Nm
IDE04423-ENG131397,Steering angle sensor: current segment-Offset_Motor_rotation,2,
IDE04439-MAS01853,Wheel speed-Left front,0.00, km/h
IDE04439-MAS01854,Wheel speed-Right front,0.00, km/h
IDE04439-MAS01855,Wheel speed-Left rear,0.00, km/h
IDE04439-MAS01856,Wheel speed-Right rear,0.00, km/h
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,4.85, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-0.88, °/s
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,500.05, °
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,No,
IDE04459,Steering angle sensor: offset index mark mechanical middle,-1.32, °
IDE04460,Steering angle sensor: offset straight line running,-2.50, °
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04510-MAS12131,Steering angle sensor: slope detection index-Counter for main index,0,
IDE04510-MAS12132,Steering angle sensor: slope detection index-Status of last index marks,Condition not met,
IDE04765-IDE02955,Counter steer support-System status,01 02,
IDE04765-MAS03095,Counter steer support-Function status,active,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.00, Nm
IDE04765-MAS03740,Counter steer support-Steering angle request: brake electronics,not active,
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,not active,
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,50.00, km/h
IDE04766-MAS00371,Replacement values-Engine speed,not active,
IDE04766-MAS02955,Replacement values-Engine temperature,active,
IDE04787,Hybrid status,active,
IDE04805-MAS01447,Driving profile selection-Actual value,Not assigned,
IDE04805-MAS01448,Driving profile selection-Specified value,automatic,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE04805-MAS05631,Driving profile selection-System status,Initialization,
IDE05154-MAS01849,Steering angle sensor: steering stroke software limitation-Left,500.05, °
IDE05154-MAS01850,Steering angle sensor: steering stroke software limitation-Right,500.05, °
IDE05155,Power steering current consumption,0.00, A
IDE05156,Current gradient,0.00, A/s
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS01849,Software end stop-Left,500.05, °
IDE05162-MAS01850,Software end stop-Right,500.05, °
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Activation,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,720736,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,707808,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG124482,Steering wheel angle load--550_to_-500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,0,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,60500,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,0,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,0,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG120739,Engine specified torque load-above_10_kilo_newton,0,
IDE05994-ENG120718,Engine specified torque load-below_-10_kilo_newton,0,
IDE05994-ENG124483,Engine specified torque load-Spezial_1,0,
IDE05994-ENG124484,Engine specified torque load-Spezial_2,60500,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,12805273,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,0,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,0,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,0,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,161,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,136,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,153,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,8895,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0, N
IDE06678-MAS03000,Pull compensation-Adaptation value,42.00, kg
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07541-MAS01632,Freeze recognition-Status,not active,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01258,Prerequisites: basic setting-Supply voltage too low,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition not met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
IDE08133-IDE03315,Basic setting: cause for cancellation-Warnings,inactive,
IDE08133-MAS00546,Basic setting: cause for cancellation-Cancel,Initialization,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,29,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,15,
MAS01172-MAS01156,Development messages-Communication status,no function,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,initialized,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
MAS02357-MAS03726,Vehicle identification-is received,33 43 5A 4D,
MAS02357-ENG131435,Vehicle identification-VIN_RAM,39 33 32 35,
MAS02978-MAS01632,Steering torque sensor 1-Status,OK,
MAS02978,Steering torque sensor 1,-0.14, Nm
MAS02979-MAS01632,Steering torque sensor 2-Status,OK,
MAS02979,Steering torque sensor 2,-0.13, Nm
MAS03679,Terminal 15 status,On,
MAS03843,Engine steering torque: actual,-0.14, Nm
ENG245523-MAS01155,CAN Communication Timeout Status-Control module,not active,
ENG245523-MAS16601,CAN Communication Timeout Status-KlemmenStatus_01,not active,
ENG245523-SFT00001,CAN Communication Timeout Status-Engine Electronics,not active,
ENG245523-SFT00003,CAN Communication Timeout Status-Brake electronics,not active,
ENG245523-SFT00025,CAN Communication Timeout Status-Data Bus OBD Interface,not active,
ENG245523-SFT00118,CAN Communication Timeout Status-Parking aid,not active,
ENG245523-ENG113024,CAN Communication Timeout Status-Charisma_01,not active,
ENG245523-ENG122523,CAN Communication Timeout Status-Diagnose_01,not active,
ENG245523-ENG122513,CAN Communication Timeout Status-ESP_02,not active,
ENG245523-ENG122514,CAN Communication Timeout Status-ESP_05,not active,
ENG245523-ENG122515,CAN Communication Timeout Status-ESP_10,not active,
ENG245523-ENG110809,CAN Communication Timeout Status-ESP_14,not active,
ENG245523-ENG122516,CAN Communication Timeout Status-ESP_19,not active,
ENG245523-ENG122517,CAN Communication Timeout Status-ESP_20,not active,
ENG245523-ENG131311,CAN Communication Timeout Status-ESP_24,not active,
ENG245523-ENG122519,CAN Communication Timeout Status-Gateway_72,not active,
ENG245523-ENG110800,CAN Communication Timeout Status-HCA_01,not active,
ENG245523-ENG122503,CAN Communication Timeout Status-Motor_11,not active,
ENG245523-ENG122505,CAN Communication Timeout Status-Motor_14,not active,
ENG245523-ENG122508,CAN Communication Timeout Status-Motor_20,not active,
ENG245523-ENG122510,CAN Communication Timeout Status-Motor_Code_01,not active,
ENG245523-ENG131545,CAN Communication Timeout Status-SYSTEM_INFO_01,not active,
ENG245523-ENG110806,CAN Communication Timeout Status-VIN_01,not active,
ENG110669,Force_target_steering_support_LKU,-94, N
ENG131295,Motor_temperature_model,30.0, °C
ENG131303-IDE04459,Position_Upper_Stop-Steering angle sensor: offset index mark mechanical middle,-1.32, °
ENG131303-MAS00478,Position_Upper_Stop-Reserved,0,
ENG131303-MAS02996,Position_Upper_Stop-Steering stroke measured,500.05, °
ENG131303-ENG246237,Position_Upper_Stop-Index_angle_offset,-3.82, °
ENG131303-ENG246187,Position_Upper_Stop-Motor_angle_offset,459.01, °
ENG131303-ENG246155,Position_Upper_Stop-Motor_Rotation_Offset,2,
ENG245733-MAS01155,Status_counter_messages-Control module,not active,
ENG245733-SFT00001,Status_counter_messages-Engine Electronics,not active,
ENG245733-SFT00003,Status_counter_messages-Brake electronics,not active,
ENG245733-SFT00025,Status_counter_messages-Data Bus OBD Interface,not active,
ENG245733-SFT00118,Status_counter_messages-Parking aid,not active,
ENG245733-ENG113024,Status_counter_messages-Charisma_01,not active,
ENG245733-ENG122523,Status_counter_messages-Diagnose_01,not active,
ENG245733-ENG122513,Status_counter_messages-ESP_02,not active,
ENG245733-ENG122514,Status_counter_messages-ESP_05,not active,
ENG245733-ENG122515,Status_counter_messages-ESP_10,not active,
ENG245733-ENG110809,Status_counter_messages-ESP_14,not active,
ENG245733-ENG122516,Status_counter_messages-ESP_19,not active,
ENG245733-ENG122517,Status_counter_messages-ESP_20,not active,
ENG245733-ENG131311,Status_counter_messages-ESP_24,not active,
ENG245733-ENG122519,Status_counter_messages-Gateway_72,not active,
ENG245733-ENG110800,Status_counter_messages-HCA_01,not active,
ENG245733-ENG131312,Status_counter_messages-Klemmen_Status_01,not active,
ENG245733-ENG122503,Status_counter_messages-Motor_11,not active,
ENG245733-ENG122505,Status_counter_messages-Motor_14,not active,
ENG245733-ENG122508,Status_counter_messages-Motor_20,not active,
ENG245733-ENG122510,Status_counter_messages-Motor_Code_01,not active,
ENG245733-ENG143934,Status_counter_messages-systeminfo_01,not active,
ENG245733-ENG110806,Status_counter_messages-VIN_01,not active,
ENG245734-MAS01155,Status_datalength_messages-Control module,not active,
ENG245734-MAS16601,Status_datalength_messages-KlemmenStatus_01,not active,
ENG245734-SFT00001,Status_datalength_messages-Engine Electronics,not active,
ENG245734-SFT00003,Status_datalength_messages-Brake electronics,not active,
ENG245734-SFT00025,Status_datalength_messages-Data Bus OBD Interface,not active,
ENG245734-SFT00118,Status_datalength_messages-Parking aid,not active,
ENG245734-ENG113024,Status_datalength_messages-Charisma_01,not active,
ENG245734-ENG122523,Status_datalength_messages-Diagnose_01,not active,
ENG245734-ENG122513,Status_datalength_messages-ESP_02,not active,
ENG245734-ENG122514,Status_datalength_messages-ESP_05,not active,
ENG245734-ENG122515,Status_datalength_messages-ESP_10,not active,
ENG245734-ENG110809,Status_datalength_messages-ESP_14,not active,
ENG245734-ENG122516,Status_datalength_messages-ESP_19,not active,
ENG245734-ENG122517,Status_datalength_messages-ESP_20,not active,
ENG245734-ENG131311,Status_datalength_messages-ESP_24,not active,
ENG245734-ENG122519,Status_datalength_messages-Gateway_72,not active,
ENG245734-ENG110800,Status_datalength_messages-HCA_01,not active,
ENG245734-ENG122503,Status_datalength_messages-Motor_11,not active,
ENG245734-ENG122505,Status_datalength_messages-Motor_14,not active,
ENG245734-ENG122508,Status_datalength_messages-Motor_20,not active,
ENG245734-ENG122510,Status_datalength_messages-Motor_Code_01,not active,
ENG245734-ENG131545,Status_datalength_messages-SYSTEM_INFO_01,not active,
ENG245734-ENG110806,Status_datalength_messages-VIN_01,not active,
ENG245738-MAS01155,Status_messages_checksum-Control module,not active,
ENG245738-SFT00001,Status_messages_checksum-Engine Electronics,not active,
ENG245738-SFT00003,Status_messages_checksum-Brake electronics,not active,
ENG245738-SFT00025,Status_messages_checksum-Data Bus OBD Interface,not active,
ENG245738-SFT00118,Status_messages_checksum-Parking aid,not active,
ENG245738-ENG113024,Status_messages_checksum-Charisma_01,not active,
ENG245738-ENG122523,Status_messages_checksum-Diagnose_01,not active,
ENG245738-ENG122513,Status_messages_checksum-ESP_02,not active,
ENG245738-ENG122514,Status_messages_checksum-ESP_05,not active,
ENG245738-ENG122515,Status_messages_checksum-ESP_10,not active,
ENG245738-ENG110809,Status_messages_checksum-ESP_14,not active,
ENG245738-ENG122516,Status_messages_checksum-ESP_19,not active,
ENG245738-ENG122517,Status_messages_checksum-ESP_20,not active,
ENG245738-ENG131311,Status_messages_checksum-ESP_24,not active,
ENG245738-ENG122519,Status_messages_checksum-Gateway_72,not active,
ENG245738-ENG110800,Status_messages_checksum-HCA_01,not active,
ENG245738-ENG131312,Status_messages_checksum-Klemmen_Status_01,not active,
ENG245738-ENG122503,Status_messages_checksum-Motor_11,not active,
ENG245738-ENG122505,Status_messages_checksum-Motor_14,not active,
ENG245738-ENG122508,Status_messages_checksum-Motor_20,not active,
ENG245738-ENG122510,Status_messages_checksum-Motor_Code_01,not active,
ENG245738-ENG143934,Status_messages_checksum-systeminfo_01,not active,
ENG245738-ENG110806,Status_messages_checksum-VIN_01,not active,
ENG245514-IDE04192,Steering_Support_Engine_Current-Steering assistance: motor current,0.00, A
Elapsed Time: 00:11
blockmap-4B-3Q0-907-338-F_WVWZZZ3CZME009325-20260823-2129.CSV
;SW:3Q0-907-338-F   HW:3Q0-907-338-F ---  4B: Multifunc. Module
;Component:FCM MQB High  004 0370, Coding:000000070B0004CA00000F11000302040000000000000000000000000000
;EV_MultiModulContiVW48X,003003,EV_MultiModulContiVW48X_003_VW48.rod
;Sunday,23,August,2026,21:29:37:32152
;VCID: 3822479AE2D4524A262-806C
IDE00019,Voltage terminal 30,13.1, V
IDE00075,Vehicle speed,0.0, km/h
IDE00326,Steering wheel angle,4.80, °
IDE00690-MAS03939,Connection to antenna-Connection between antenna amplifier and antenna,electrically OK,
IDE00690-MAS14478,Connection to antenna-Connection between control module and antenna amplifier,electrically OK,
IDE00690-MAS14624,Connection to antenna-Antenna amplifier: status,electrically OK,
IDE00767-MAS03945,No. of unscheduled ECU resets-Watchdog Reset,0,
IDE01714,Status reverse gear,OFF,
IDE01717-ENG161283,Processor load-Software_component_AFS_MXB,47, %
IDE01717-ENG161295,Processor load-Total_system_FCM,48, %
IDE01943,Turn signal lamp,Not operated,
IDE01946,ESP intervention,not active,
IDE02389,Ambient brightness,60, lx
IDE02515,Low beams,On,
IDE02743,Main beam,OFF,
IDE03214,Engine stop using start-stop function,OFF,
IDE03215,Engine start using start-stop function,OFF,
IDE03602,Left front level control system sensor,-0.01, %
IDE03604,Left rear level control system sensor,48.00, %
IDE03616,Motor status,OFF,
IDE03620,Front jounce travel,0.0, mm
IDE03621,Rear jounce travel,-14.7, mm
IDE03622,Left headlight beam adjusting motor: status,No malfunction,
IDE03623,Right headlight beam adjusting motor: status,No malfunction,
IDE03624,Left dynamic AFS light motor: specified value,32.000000, °
IDE03625,Right dynamic AFS light motor: specified value,32.000000, °
IDE03626,Left dynamic AFS light motor: status,No malfunction,
IDE03627,Right dynamic AFS light motor: status,No malfunction,
IDE03628,Adjusting motor for variable left front lighting: status,No malfunction,
IDE03629,Adjusting motor for variable right front lighting: status,No malfunction,
IDE03630,Left headlight beam adjusting motor: specified value,-39.0, mm
IDE03631,Right headlight beam adjusting motor: specified value,-39.0, mm
IDE03632,Left-/right hand driving switch-over,OFF,
IDE03638-IDE03717,Static cornering light-Dim static left AFS light,101.6, %
IDE03638-IDE03718,Static cornering light-Dim static right AFS light,101.6, %
IDE03640,Dynamic AFS light,On,
IDE03669,Status of light distribution,not activated,
IDE03727,Variable left front lighting specified position,204.70, %
IDE03728,Variable right front lighting specified position,204.70, %
IDE03788,Status of basic headlamp setting,no request,
IDE03850,Left front level ctrl sys sensor: adapt. value (zero pos),-0.01, %
IDE03866,Left rear level ctrl sys sensor: adaptation value (zero pos),50.80, %
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Actual value,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE07245-MAS01447,Left rear seat backrest fan 1: activation-Actual value,not coded / not installed,
IDE07245-MAS01448,Left rear seat backrest fan 1: activation-Specified value,not coded / not installed,
IDE07247-MAS01447,Left rear seat cushion fan 1: activation-Actual value,not coded / not installed,
IDE07247-MAS01448,Left rear seat cushion fan 1: activation-Specified value,not coded / not installed,
IDE07249-MAS01447,Right rear seat backrest fan 1: activation-Actual value,not coded / not installed,
IDE07249-MAS01448,Right rear seat backrest fan 1: activation-Specified value,not coded / not installed,
IDE07251-MAS01447,Right rear seat cushion fan 1: activation-Actual value,not coded / not installed,
IDE07251-MAS01448,Right rear seat cushion fan 1: activation-Specified value,not coded / not installed,
IDE07253-IDE11719,Installation info: rear seat ventilation-Fan 1 for left rear seat backrest,not installed,
IDE07253-IDE11720,Installation info: rear seat ventilation-Fan 1 for left rear seat cushion,not installed,
IDE07253-IDE11721,Installation info: rear seat ventilation-Fan 1 for right rear seat backrest,not installed,
IDE07253-IDE11722,Installation info: rear seat ventilation-Fan 1 for right rear seat cushion,not installed,
IDE08447,Driving axis angle,0.0, '
IDE08516-IDE02743,LED headlights: light distribution requirement-Main beam,not requested,
IDE08516-IDE06864,LED headlights: light distribution requirement-Daytime running lights,not requested,
IDE08516-MAS02922,LED headlights: light distribution requirement-City light,not requested,
IDE08516-MAS02923,LED headlights: light distribution requirement-Highway light,not requested,
IDE08516-MAS02931,LED headlights: light distribution requirement-Rural highway light,both sides,
IDE08516-MAS02946,LED headlights: light distribution requirement-Static cornering light,not requested,
IDE08516-MAS07013,LED headlights: light distribution requirement-All-weather light,not requested,
IDE08516-MAS07014,LED headlights: light distribution requirement-Tourist light,not requested,
IDE08516-MAS07015,LED headlights: light distribution requirement-Running light,not requested,
IDE08516-MAS07234,LED headlights: light distribution requirement-Eco mode 1,not requested,
IDE08516-MAS07235,LED headlights: light distribution requirement-Eco mode 2,not requested,
IDE08706-MAS17323,Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes,62.0, '
IDE08706-MAS17324,Actual angle of ref. segments-Horizontal angle reference segment left: in degrees,1.03, °
IDE08706-MAS17325,Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage,1.80, %
IDE08706-MAS17326,Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes,-15.0, '
IDE08706-MAS17327,Actual angle of ref. segments-Horizontal angle reference segment right: in degrees,-0.26, °
IDE08706-MAS17328,Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage,-0.45, %
IDE08706-MAS17329,Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes,0.0, '
IDE08706-MAS17330,Actual angle of ref. segments-Vertical angle reference segment left: in degrees,-0.00, °
IDE08706-MAS17331,Actual angle of ref. segments-Vertical angle reference segment left: as a percentage,-0.00, %
IDE08706-MAS17332,Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes,0.0, '
IDE08713-MAS17335,Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes,40.0, '
IDE08713-MAS17336,Matrix light: calculated offset values-Horizontal offset: left headlight in degrees,0.66, °
IDE08713-MAS17337,Matrix light: calculated offset values-Horizontal: left headlight as a percentage,1.17, %
IDE08713-MAS17338,Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes,-4.0, '
IDE08713-MAS17339,Matrix light: calculated offset values-Horizontal offset: right headlight in degrees,-0.06, °
IDE08713-MAS17340,Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage,-0.12, %
IDE08713-MAS17341,Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes,0.0, '
IDE08713-MAS17342,Matrix light: calculated offset values-Vertical offset: left headlight in degrees,-0.00, °
IDE08713-MAS17343,Matrix light: calculated offset values-Vertical offset: left headlight as a percentage,-0.00, %
IDE08713-MAS17344,Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes,0.0, '
IDE08713-MAS17345,Matrix light: calculated offset values-Vertical offset: right headlight in degrees,-0.00, °
IDE08713-MAS17346,Matrix light: calculated offset values-Vertical offset: right headlight as a percentage,-0.00, %
IDE08714-MAS06929,Axle offsets-Axle offset front,0.0, mm
IDE08714-MAS06930,Axle offsets-Axle offset rear,0.0, mm
IDE08715,Func. status matrix high beam,not active,
IDE12451-MAS14479,Mobile device: status-Power category of the mobile terminal device,0.0, W
IDE12503-MAS01634,Antenna 1 for short-range communication: status-Supply voltage,OK,
IDE12503-MAS14628,Antenna 1 for short-range communication: status-Antenna Status,active,
IDE12503-MAS14629,Antenna 1 for short-range communication: status-NFC device capable of authentication,not recognised,
IDE12503-MAS14630,Antenna 1 for short-range communication: status-NFC device recognized in actuator test,No,
IDE12503-MAS17116,Antenna 1 for short-range communication: status-Fixture guard for virtual radio key,not active,
IDE12503-MAS17118,Antenna 1 for short-range communication: status-Fixture guard counter for virtual radio key,0,
IDE12504-MAS01634,Antenna 2 for short-range communication: status-Supply voltage,OK,
IDE12504-MAS14628,Antenna 2 for short-range communication: status-Antenna Status,active,
IDE12504-MAS14629,Antenna 2 for short-range communication: status-NFC device capable of authentication,not recognised,
IDE12504-MAS14630,Antenna 2 for short-range communication: status-NFC device recognized in actuator test,No,
IDE12504-MAS17116,Antenna 2 for short-range communication: status-Fixture guard for virtual radio key,not active,
IDE12504-MAS17118,Antenna 2 for short-range communication: status-Fixture guard counter for virtual radio key,0,
IDE12582-MAS01481,Mobile device charger: status-Temperature in control module,34, °C
IDE12582-MAS14480,Mobile device charger: status-Object recognition: status,No object detected,
IDE12582-MAS14484,Mobile device charger: status-Charging process: status,not active,
IDE12582-MAS14485,Mobile device charger: status-Charging technology used,1,
IDE12582-ENG177058,Mobile device charger: status-Charging_power,0.0,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,1.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,FF FF FF FE,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,Navigation,
MAS16431-MAS16982,Online data acquisition warning overview-Type of first warning,24,
MAS16431-MAS16983,Online data acquisition warning overview-Type of second warning,27,
MAS16431-MAS16984,Online data acquisition warning overview-Type of third warning,31,
MAS16431-MAS16985,Online data acquisition warning overview-Type of fourth WARNING,15,
MAS16431-MAS16986,Online data acquisition warning overview-Type of fifth WARNING,14,
MAS16431-MAS16987,Online data acquisition warning overview-Type of sixth WARNING,0,
MAS16431-MAS16988,Online data acquisition warning overview-Type of seventh WARNING,0,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2000,
MAS16432-MAS00106,Online data acquisition: warning 1-Year,2026,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,0,
MAS16432-MAS00107,Online data acquisition: warning 1-Month,8,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,24,
MAS16432-MAS00108,Online data acquisition: warning 1-Day,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,0,
MAS16432-MAS00109,Online data acquisition: warning 1-Hours,4,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,6,
MAS16432-MAS00110,Online data acquisition: warning 1-Minutes,0,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,28,
MAS16432-MAS00111,Online data acquisition: warning 1-Seconds,0,
MAS16432-MAS16989,Online data acquisition: warning 1-Index of the warning,2,
MAS16432-MAS16990,Online data acquisition: warning 1-Number of warnings,171,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2000,
MAS16433-MAS00106,Online data acquisition: warning 2-Year,2026,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,0,
MAS16433-MAS00107,Online data acquisition: warning 2-Month,8,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,24,
MAS16433-MAS00108,Online data acquisition: warning 2-Day,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,0,
MAS16433-MAS00109,Online data acquisition: warning 2-Hours,4,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,6,
MAS16433-MAS00110,Online data acquisition: warning 2-Minutes,0,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,0,
MAS16433-MAS00111,Online data acquisition: warning 2-Seconds,28,
MAS16433-MAS16989,Online data acquisition: warning 2-Index of the warning,2,
MAS16433-MAS16990,Online data acquisition: warning 2-Number of warnings,171,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2026,
MAS16434-MAS00106,Online data acquisition: warning 3-Year,2000,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,8,
MAS16434-MAS00107,Online data acquisition: warning 3-Month,0,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,24,
MAS16434-MAS00108,Online data acquisition: warning 3-Day,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,0,
MAS16434-MAS00109,Online data acquisition: warning 3-Hours,4,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,0,
MAS16434-MAS00110,Online data acquisition: warning 3-Minutes,6,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,0,
MAS16434-MAS00111,Online data acquisition: warning 3-Seconds,28,
MAS16434-MAS16989,Online data acquisition: warning 3-Index of the warning,2,
MAS16434-MAS16990,Online data acquisition: warning 3-Number of warnings,171,
MAS16435-MAS00106,Online data acquisition: warning 4-Year,2011,
MAS16435-MAS00107,Online data acquisition: warning 4-Month,1,
MAS16435-MAS00108,Online data acquisition: warning 4-Day,1,
MAS16435-MAS00109,Online data acquisition: warning 4-Hours,0,
MAS16435-MAS00110,Online data acquisition: warning 4-Minutes,0,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,4,
MAS16435-MAS00111,Online data acquisition: warning 4-Seconds,33,
MAS16435-MAS16989,Online data acquisition: warning 4-Index of the warning,3,
MAS16435-MAS16990,Online data acquisition: warning 4-Number of warnings,1,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2020,
MAS16436-MAS00106,Online data acquisition: warning 5-Year,2000,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,0,
MAS16436-MAS00107,Online data acquisition: warning 5-Month,8,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,25,
MAS16436-MAS00108,Online data acquisition: warning 5-Day,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,0,
MAS16436-MAS00109,Online data acquisition: warning 5-Hours,14,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,44,
MAS16436-MAS00110,Online data acquisition: warning 5-Minutes,0,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,4,
MAS16436-MAS00111,Online data acquisition: warning 5-Seconds,0,
MAS16436-MAS16989,Online data acquisition: warning 5-Index of the warning,2,
MAS16436-MAS16990,Online data acquisition: warning 5-Number of warnings,5,
MAS16437-MAS00106,Online data acquisition: warning 6-Year,2000,
MAS16437-MAS00107,Online data acquisition: warning 6-Month,0,
MAS16437-MAS00108,Online data acquisition: warning 6-Day,0,
MAS16437-MAS00109,Online data acquisition: warning 6-Hours,0,
MAS16437-MAS00110,Online data acquisition: warning 6-Minutes,0,
MAS16437-MAS00111,Online data acquisition: warning 6-Seconds,0,
MAS16437-MAS16989,Online data acquisition: warning 6-Index of the warning,0,
MAS16437-MAS16990,Online data acquisition: warning 6-Number of warnings,0,
MAS16438-MAS00106,Online data acquisition: warning 7-Year,2000,
MAS16438-MAS00107,Online data acquisition: warning 7-Month,0,
MAS16438-MAS00108,Online data acquisition: warning 7-Day,0,
MAS16438-MAS00109,Online data acquisition: warning 7-Hours,0,
MAS16438-MAS00110,Online data acquisition: warning 7-Minutes,0,
MAS16438-MAS00111,Online data acquisition: warning 7-Seconds,0,
MAS16438-MAS16989,Online data acquisition: warning 7-Index of the warning,0,
MAS16438-MAS16990,Online data acquisition: warning 7-Number of warnings,0,
ENG101323,Headlight leveling control state,static,
ENG107365,Left dynamic cornering light value,Initialization,
ENG157518-ENG161284,Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB,0170,
ENG157518-ENG161297,Multifunction_Module_Application_Software_Version-Version_Routing_FCM,7200,
ENG158062-ENG162937,NFC_central_console_intern_conditions-Intern_conditions,00,
ENG158063,NFC_driver_side_intern_conditions,00,
ENG124613,Predictive_Route_Data_Intown_Flag,Not available,
ENG124610,Predictive_Route_Data_Number_Of_Lanes,Not available,
ENG124612,Predictive_Route_Data_Placename_Sign,Not available,
ENG124611,Predictive_Route_Data_Speed_Limit,Not available,
ENG124609,Predictive_Route_Data_Street_Class,Not available,
ENG108468,Right dynamic cornering light value,Initialization,
Elapsed Time: 00:15
blockmap-51-3G0-907-080-G_WVWZZZ3CZME009325-20260823-2130.CSV
;SW:3G0-907-080-G   HW:3G0-907-080-G ---  51: Electric Drive
;Component:LE Gen 3.3H17 0090, Coding:03090000000000000000
;EV_DMCM08530113G0907080G,001020,EV_DMCM08530113G0907080G.rod
;Sunday,23,August,2026,21:30:21:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 290492DE297EFBC2A9C-807C
Group,Description,Actual
IDE00018,Voltage terminal 15,1,
IDE00019,Voltage terminal 30,13.035, V
IDE00021,Engine speed,0, /min
IDE00025,Coolant temperature,29, °C
IDE00083,Throttle valve position (absolute),16.5, %
IDE00084,Absolute load value,0, %
IDE00085,Normed load value,0.0, %
IDE00086,Accelerator pedal position,14.5, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00613,Phase current phase U,1.81, A
IDE00614,Phase current phase V,0.69, A
IDE00615,Phase current phase W,2.63, A
IDE00619,RPM of electric machine,0, /min
IDE00626,Temperature of electric machine,27.94, °C
IDE00628,Specified value of intermediate circuit voltage,0.00, V
IDE00635,Intermediate circuit current,0.00, A
IDE00637,Intermediate circuit voltage,391.56, V
IDE00643,Minimum torque of electric machine,0.00, Nm
IDE00644,Maximum torque of electric machine,0.00, Nm
IDE00645,Specified torque of electric machine,0.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00796,Offset angles of rotor positions,214.003, °el
IDE00938,Calculated actual torque of electric machine,0.00, Nm
IDE00952,Availability of high voltage,1,
IDE04096,Engine running time w. additional exhaust gas ctrl device 1-5,0H00s / 0H00s  / 0H00s / 0H00s ,
IDE04097,Engine running time w. additional exhaust gas ctrl device 6-10,0H00s / 0H00s,
IDE04222,Test voltage for insulation measurement for power electronics,500.00, V
IDE04223,Test voltage for electric drive insulation measurement,500.00, V
IDE05246,Power electronics heat sink temperature,33.09, °C
IDE05248,Speed of E-machine: actual value,0, /min
IDE05249,Regulation due to excessive temperature,0,
IDE05250,Drive control condition,Standby,
IDE05250-ENG145763,Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE,2,
IDE05419,Intermediate circuit current maximum limit,271.94, A
IDE05420,Intermediate circuit current minimum threshold,-26.94, A
IDE05421,Torque: current value,0.00, Nm
IDE05425,Output current of DC/DC converter,20.81, A
IDE05426,Buck converter operation due to current limit being exceeded,0,
IDE05427,Boost converter operation due to current limit being exceeded,0,
IDE05428,Buck converter operation due to voltage limit being exceeded,0,
IDE05429,Boost converter operation due to voltage limit being exceeded,0,
IDE05578,Intermediate circuit voltage DC/DC converter,391.56, V
IDE06501,Adaptation of magnetic flow: status,0,
IDE06502,Offset angle adaptation: status,OfsEstimated_E,
IDE06502-ENG145766,Offset angle adaptation: status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb St Ag Rtr Offs UBYTE,1,
IDE06805,Status of voltage freedom,2,
IDE09094,CAN signal battery management sys: traction network current,-0.75, A
IDE09095,CAN signal battery management sys: traction network voltage,391.25, V
IDE09096,CAN signal battery management system high voltage protection: status,MaiClsd,
IDE09096-ENG145772,CAN signal battery management system high voltage protection: status-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Hvb Cntct UBYTE,2,
IDE09097,E-machine electrical rotor frequency,0.0, Hz
IDE09098,E-machine electrical power,0, W
IDE09099,E-machine mechanical power,96, W
IDE09100,E-machine free-run status,WithoutStatorCurrent,
IDE09100-ENG145770,E-machine free-run status-Test_Program_Rbe Asw Invr MCT enum Frwhl UBYTE,0,
IDE09101,E-machine magnetic flux reference value,0.000000, Wb
IDE09102,E-machine effective current,0.63, A
IDE09103,E-machine stator temperature,27.92, °C
IDE09104,E-machine stator temperature characteristic,1,
IDE09105,Power electronics: intermediate circuit current,0.00, A
IDE09107,Power electronics: internal power supply 2,0.436, V
IDE09108,Power electronics: internal power supply IGBT,29.943, V
IDE09111,Power electronics gate driver status,ShortCircuitBot,
IDE09111-ENG145768,Power electronics gate driver status-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Gate Drv UBYTE,0,
IDE09113,Power Electronics IGBT-Module Temperature Phase U,32.94, °C
IDE09114,Power Electronics IGBT-Module Temperature Phase V,32.89, °C
IDE09115,Power Electronics IGBT-Module Temperature Phase W,32.89, °C
IDE09117,Position offset calibration: stay,0.00, s
IDE09118,Magnetic flow calibration: status,0,
IDE09119,Position offset calibration: diagnostic status,NotTested__E,
IDE09119-ENG145769,Position offset calibration: diagnostic status-Test_Program_Rbe Asw Invr ISC enum St Diag Al Rtr Ofs Clb UBYTE,0,
IDE09123,DC/DC Converter temperature of power component,32.88, °C
IDE09124,DC/DC Converter traction system current,-0.719, A
IDE09126,Vehicle switch-off time,1288, min
IDE09127,Status: switch-off time,Abstellzeit_berechnet,
IDE09127-ENG145767,Status: switch-off time-Test_Program_Rbe Asw Cif Enum rbe Cmn Glb Dwn Ti UBYTE,1,
IDE09128,DC/DC converter: status,rbe_AswDcdc_BuckReq_e,
IDE09128-ENG145771,DC/DC converter: status-Test_Program_Rbe Asw Dcdc Enum rbe Cmn Glb Dcdc Mod Cust Des UBYTE,4,
IDE09129,DC/DC Converter output current terminal 30,21.25, A
IDE09130,DC/DC Converter controlled output current terminal 30,13.219, V
IDE09210,Phase current phase U unrestricted,2.50, A
IDE09211,Phase current phase V unrestricted,2.06, A
IDE09212,Phase current phase W unrestricted,0.63, A
MAS06713,Supply voltage Terminal 30 - internal,12.547, V
MAS09947,Cond. of interm. circuit discharging circuit,DchaNotActv,
MAS09947-ENG145773,Cond. of interm. circuit discharging circuit-Test_Program_Rbe Asw Invr SYM enum St Dcha UBYTE,0,
MAS12577,Rotor position sensor 2 sine offset,0.000, V
MAS12578,Rotor position sensor 2 cosines offset,0.000, V
MAS12772,DC/DC changer: high voltage current restriction,14.00, A
MAS12773,DC/DC Converter: specified operating mode,1,
MAS12774,DC/DC changer: spec. output voltage terminal 30,13.199, V
MAS13360,Discharge current HV intermediate circuit power electronics,0.00, A
MAS13361,PCB temperature power electronics,51.50, °C
MAS13362,Calculated coolant temperature DCDC converter,32.50, °C
MAS13363,Redundant intermediate circuit voltage power electronics,393.97, V
MAS13431,Low-voltage fuse: current,1.023, A
MAS13432,Low-voltage fuse: voltage,13.041, V
MAS13802,Rotor position sensor 2: cosine amplitude,0.000, V
MAS13803,Rotor position sensor 2: sine amplitude,0.000, V
MAS13804,Rotor position sensor 2: exciter amplitude,8.834, V
ENG101413,Calibration Identifications,3G0080G 0090 P  ,
ENG99697,Calibration Verification Numbers,22 8B 6A 44,
ENG105721,Current_DC_Link_power,0, W
ENG105722,Current_in_d-direction,-0.19, A
ENG105723,Current_in_q-direction,0.38, A
ENG157325,DCDC_derating_due_to_overtemp,0,
ENG105797,Desired_current_in_d-direction,0.00, A
ENG105798,Desired_current_in_q-direction,0.00, A
ENG105799,Desired_torque,0.00, Nm
ENG100152-ENG104003,ECUNAME-ECU,DMCM,
ENG100152,ECUNAME,DriveMotorCtrl,
ENG106053,Effective_value_stator_current,0.25, A
ENG106109,Electric_drive_cooling_activated,option_not_available,
ENG106109-ENG145765,Electric_drive_cooling_activated-Test_Program_Rbe Asw Cif Enum rbe Asw Cif Sttr Coolt Circ UBYTE,3,
ENG106482,Failure_emergency_shut_off,0,
ENG106483,Failure_free_wheeling,0,
ENG157343,Failure_inverter_limited_prfmnc,0,
ENG106485,Failure_inverter_shut_off,0,
ENG157344,Field_weakening_active,0,
ENG144279,HV-circuit_operation_mode,rbe_CddHvMcu_NormMod_e,
ENG144279-ENG145775,HV-circuit_operation_mode-Test_Program_Rbe Cdd Hv Mcu Enum rbe Cdd Hv Mcu St Mod UBYTE,0,
ENG157356,IGBT_temperatur_charact_curve_state,0,
ENG157370,Internal_sum_error_item,0,
ENG144277,Internal_supply_voltage_15_inverter_IGBT,15.387, V
ENG107077,Inverter_state,0,
ENG157384,ISC t Dbc Invr Snsr Max,32.92, °C
ENG157388,Load_moment_auxiliary,-5.63, Nm
ENG107584,Maximal_DC-Link_voltage,402.00, V
ENG107585,Maximal_torque_hybrid_controller,2047.94, Nm
ENG107589,Maximum_power_limit,110000, W
ENG107590,Maximum_torque_derating_reason,inactive,
ENG107590-ENG145764,Maximum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG157393,MCT Temp Rtr,29.44, °C
ENG107604,Mechanical_angular_speed,0.00, rad/s
ENG107623,Minimal_torque_hybrid_controller,-2047.94, Nm
ENG107624,Minimum_DC-Link_voltage,250.00, V
ENG107625,Minimum_power_limit,-110000, W
ENG107626,Minimum_torque_derating_reason,inactive,
ENG107626-ENG145764,Minimum_torque_derating_reason-Test_Program_Rbe Asw Invr TQL enum Der UBYTE,1,
ENG107742,Necessary_generator_torque,0.00, Nm
ENG144278,Operation_mode_DCDC_actual_state,rbe_AswDcdc_Buck_e,
ENG144278-ENG145774,Operation_mode_DCDC_actual_state-Test_Program_Rbe Com Dcdc Can Enum rbe Cmn Glb Dcdc Oper Mod UBYTE,1,
ENG144276,Periodic_time_gate_driver,111.10, µs
ENG157413,Rbe Asw Invr Isc t Lnk Cap,37.94, °C
ENG157415,Rec rbe Com Drv Can 10ms t Oil Gbx Smp,32, °C
ENG109097,Stator_frequency,0.0, Hz
Elapsed Time: 00:11
blockmap-52-5Q0-959-592-K_WVWZZZ3CZME009325-20260823-2130.CSV
;SW:5Q0-959-592-K   HW:5Q0-959-592-F ---  52: Door Elect, Pass.
;Component:TSG BFS002 0330, Coding:003F0120DC00020000001000
;EV_DCU2PasseSideMAXHKLO,001018,EV_DCU2PasseSideMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:30:38:32152
;VCID: 48C2375A923422CA562-801C
IDE01993-MAS12276,Control module reference number-Front door control module,Front passenger door control module,
IDE01993-MAS12277,Control module reference number-Rear door control module,Right rear door control module,
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,12.80, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,51, %
IDE04539-MAS02229,Mirror memory-Y coordinate,45, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,not installed,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,95.50, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,not active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Idle state,
IDE06872,Front passenger power window button,Not operated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Activation,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,26, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE10930-IDE02266,Window regulator control unit: front passenger side-Passenger side rear power window button,not installed,
IDE10930-IDE04220,Window regulator control unit: front passenger side-Driver power window button,not installed,
IDE10930-IDE06621,Window regulator control unit: front passenger side-Driver side rear power window button,not installed,
IDE10930-IDE06872,Window regulator control unit: front passenger side-Front passenger power window button,not installed,
IDE15340,Light output 1 pin D8 target brightness on front passenger side,Not available,
IDE15341,Light output 2 pin D3 target brightness on front passenger side,Not available,
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,Not available,
IDE15343,Light output 4 pin D16 target brightness on front passenger side,Not available,
Elapsed Time: 00:07
blockmap-5F-3G5-035-816-B_WVWZZZ3CZME009325-20260823-2130.CSV
;SW:3G5-035-816-B   HW:3G5-035-816-B ---  5F: Information Electr.
;Component:MU-O-ND-EU    H22 0270, Coding:24820000000020000000000000000000000000000000000000
;EV_MUOIMQB,001001,EV_MUOIMQB_001_VW48.rod
;Sunday,23,August,2026,21:30:54:32152
;VCID: 280297DA3274C2CAB62-807C
IDE00019,Voltage terminal 30,13.10, V
IDE00021,Engine speed,0.00, /min
IDE00655-MAS01424,Temperature of processor circuit board-max.value,62, °C
IDE00655-MAS01425,Temperature of processor circuit board-min.value,-8, °C
IDE00655-MAS02238,Temperature of processor circuit board-Current,44, °C
IDE00767,No. of unscheduled ECU resets,47,
IDE00916-ENG249445,Speaker status-loudspeaker_config_channel_1,Right rear speaker,
IDE00916-ENG249480,Speaker status-loudspeaker_config_channel_10,Not available,
IDE00916-ENG249518,Speaker status-loudspeaker_config_channel_11,Not available,
IDE00916-ENG249486,Speaker status-loudspeaker_config_channel_12,Not available,
IDE00916-ENG249341,Speaker status-loudspeaker_config_channel_13,Not available,
IDE00916-ENG249407,Speaker status-loudspeaker_config_channel_14,Not available,
IDE00916-ENG249456,Speaker status-loudspeaker_config_channel_15,Not available,
IDE00916-ENG249515,Speaker status-loudspeaker_config_channel_16,Not available,
IDE00916-ENG249507,Speaker status-loudspeaker_config_channel_17,Not available,
IDE00916-ENG249452,Speaker status-loudspeaker_config_channel_18,Not available,
IDE00916-ENG249466,Speaker status-loudspeaker_config_channel_19,Not available,
IDE00916-ENG249455,Speaker status-loudspeaker_config_channel_2,Right front speaker,
IDE00916-ENG249434,Speaker status-loudspeaker_config_channel_20,Not available,
IDE00916-ENG249416,Speaker status-loudspeaker_config_channel_21,Not available,
IDE00916-ENG249527,Speaker status-loudspeaker_config_channel_22,Not available,
IDE00916-ENG249489,Speaker status-loudspeaker_config_channel_23,Not available,
IDE00916-ENG249520,Speaker status-loudspeaker_config_channel_24,Not available,
IDE00916-ENG249288,Speaker status-loudspeaker_config_channel_3,Left front speaker,
IDE00916-ENG249509,Speaker status-loudspeaker_config_channel_4,Left rear speaker,
IDE00916-ENG249362,Speaker status-loudspeaker_config_channel_5,Not available,
IDE00916-ENG249491,Speaker status-loudspeaker_config_channel_6,Not available,
IDE00916-ENG249410,Speaker status-loudspeaker_config_channel_7,Not available,
IDE00916-ENG249340,Speaker status-loudspeaker_config_channel_8,Not available,
IDE00916-ENG249470,Speaker status-loudspeaker_config_channel_9,Not available,
IDE00916-ENG249411,Speaker status-loudspeaker_state_channel_1,OK,
IDE00916-ENG249429,Speaker status-loudspeaker_state_channel_10,Measuring value not available,
IDE00916-ENG249464,Speaker status-loudspeaker_state_channel_11,Measuring value not available,
IDE00916-ENG249451,Speaker status-loudspeaker_state_channel_12,Measuring value not available,
IDE00916-ENG249436,Speaker status-loudspeaker_state_channel_13,Measuring value not available,
IDE00916-ENG249447,Speaker status-loudspeaker_state_channel_14,Measuring value not available,
IDE00916-ENG249426,Speaker status-loudspeaker_state_channel_15,Measuring value not available,
IDE00916-ENG249317,Speaker status-loudspeaker_state_channel_16,Measuring value not available,
IDE00916-ENG249528,Speaker status-loudspeaker_state_channel_17,Measuring value not available,
IDE00916-ENG249492,Speaker status-loudspeaker_state_channel_18,Measuring value not available,
IDE00916-ENG249409,Speaker status-loudspeaker_state_channel_19,Measuring value not available,
IDE00916-ENG249305,Speaker status-loudspeaker_state_channel_2,OK,
IDE00916-ENG249435,Speaker status-loudspeaker_state_channel_20,Measuring value not available,
IDE00916-ENG249417,Speaker status-loudspeaker_state_channel_21,Measuring value not available,
IDE00916-ENG249404,Speaker status-loudspeaker_state_channel_22,Measuring value not available,
IDE00916-ENG249319,Speaker status-loudspeaker_state_channel_23,Measuring value not available,
IDE00916-ENG249408,Speaker status-loudspeaker_state_channel_24,Measuring value not available,
IDE00916-ENG249290,Speaker status-loudspeaker_state_channel_3,OK,
IDE00916-ENG249312,Speaker status-loudspeaker_state_channel_4,OK,
IDE00916-ENG249303,Speaker status-loudspeaker_state_channel_5,Measuring value not available,
IDE00916-ENG249399,Speaker status-loudspeaker_state_channel_6,Measuring value not available,
IDE00916-ENG249508,Speaker status-loudspeaker_state_channel_7,Measuring value not available,
IDE00916-ENG249335,Speaker status-loudspeaker_state_channel_8,Measuring value not available,
IDE00916-ENG249382,Speaker status-loudspeaker_state_channel_9,Measuring value not available,
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,0,
IDE01351,Terminal 75 status,On,
IDE01627-MAS01167,Search for Bluetooth devices-Actuation time,Without time limit,
IDE01627-ENG170421,Search for Bluetooth devices-IoReached Status,Output diagnostic test not active,
IDE01628-MAS01167,Establish connection to last Bluetooth device-Actuation time,Without time limit,
IDE01628-ENG170421,Establish connection to last Bluetooth device-IoReached Status,Output diagnostic test not active,
IDE01700-MAS01763,Status of tuner for digital radio (DAB)-Field intensity,0,
IDE01700-MAS02572,Status of tuner for digital radio (DAB)-Mute,not active,
IDE01700-MAS02949,Status of tuner for digital radio (DAB)-Frequency,0,
IDE01700-MAS03786,Status of tuner for digital radio (DAB)-Audio Codec,MPEG Audio Layer 2,
IDE01700-MAS06242,Status of tuner for digital radio (DAB)-Signal quality,0,
IDE01700-MAS19004,Status of tuner for digital radio (DAB)-DAB bit rate malfunction FIC,0.00,
IDE01700-MAS19005,Status of tuner for digital radio (DAB)-DAB bit rate malfunction NET,0.00,
IDE01700-MAS19006,Status of tuner for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE01700-MAS19007,Status of tuner for digital radio (DAB)-TP traffic data,Not available,
IDE01700-MAS19010,Status of tuner for digital radio (DAB)-TPEG,Not available,
IDE01700-MAS19011,Status of tuner for digital radio (DAB)-Ensemble ID,0,
IDE01700-MAS19012,Status of tuner for digital radio (DAB)-Ensemble Label,        ,
IDE01700-MAS19013,Status of tuner for digital radio (DAB)-Ensemble label mask,0,
IDE01700-MAS19014,Status of tuner for digital radio (DAB)-Ensemble country code,0,
IDE01700-MAS19018,Status of tuner for digital radio (DAB)-Bit rate,0,
IDE01700-MAS19019,Status of tuner for digital radio (DAB)-Sample Rate,0,
IDE01700-MAS19020,Status of tuner for digital radio (DAB)-Audio mode,00,
IDE01700-MAS19022,Status of tuner for digital radio (DAB)-DAB transfer mode,0,
IDE01700-MAS19023,Status of tuner for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE01700-MAS19024,Status of tuner for digital radio (DAB)-Audio quality,0,
IDE01700-MAS19041,Status of tuner for digital radio (DAB)-Protection level,1_A_equal_protection_level,
IDE01700-ENG117346,Status of tuner for digital radio (DAB)-Charset,00,
IDE01700-ENG249430,Status of tuner for digital radio (DAB)-Count_Audio_Services,0,
IDE01700-ENG249296,Status of tuner for digital radio (DAB)-Count_Services,0,
IDE01700-ENG117340,Status of tuner for digital radio (DAB)-Data_Service_Identifier,00 00 00 00,
IDE01700-ENG117341,Status of tuner for digital radio (DAB)-Data_Service_Label,                ,
IDE01700-ENG117345,Status of tuner for digital radio (DAB)-Data_Service_Label_Mask,00 00,
IDE01700-ENG117335,Status of tuner for digital radio (DAB)-Program_Service_Identifier,Service deactivated,
IDE01700-ENG117336,Status of tuner for digital radio (DAB)-Service_Component_Identifier,0,
IDE01700-ENG117338,Status of tuner for digital radio (DAB)-Service_Label,                                                ,
IDE01700-ENG117343,Status of tuner for digital radio (DAB)-Service_Label_Mask,00 00,
IDE01700-ENG117337,Status of tuner for digital radio (DAB)-Sub_Channel_Identifier,0,
IDE01700-ENG117339,Status of tuner for digital radio (DAB)-Sub_Service_Label,                                ,
IDE01700-ENG117344,Status of tuner for digital radio (DAB)-Sub_Service_Label_Mask,00 00,
IDE01712-MAS01779,GPS Position-Length,Redacted by Ross-Tech for User Privacy,
IDE01712-MAS01780,GPS Position-Width,Redacted by Ross-Tech for User Privacy,
IDE01713-MAS01632,Status GPS reception-Status,No GPS reception,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,3,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,0,
IDE01716,Terminal 50 status,OFF,
IDE01767-MAS00940,Status of telephone-Antenna diagnostic,Not available,
IDE01768-MAS01808,Status of antenna 1 for radio-Antenna current,77, mA
IDE01768-MAS03938,Status of antenna 1 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01768-MAS03939,Status of antenna 1 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01769-MAS01808,Status of antenna 2 for radio-Antenna current,51, mA
IDE01769-MAS03938,Status of antenna 2 for radio-Connection between radio and antenna amplifier,electrically OK,
IDE01769-MAS03939,Status of antenna 2 for radio-Connection between antenna amplifier and antenna,electrically OK,
IDE01770-MAS01632,Status of GPS antenna-Status,Not available,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,Not available,
IDE01771-MAS01808,Status of digital radio antenna 1-Antenna current,56, mA
IDE01771-MAS03938,Status of digital radio antenna 1-Connection between radio and antenna amplifier,electrically OK,
IDE01771-MAS03939,Status of digital radio antenna 1-Connection between antenna amplifier and antenna,electrically OK,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,25 25 D1 32,
IDE02178-MAS01167,Status remote control-Actuation time,Without time limit,
IDE02178-ENG170421,Status remote control-IoReached Status,Output diagnostic test not active,
IDE02179-MAS01167,Remote control for selecting the audio source-Actuation time,Without time limit,
IDE02179-ENG170421,Remote control for selecting the audio source-IoReached Status,Output diagnostic test not active,
IDE02180-MAS01167,Remote control for FM frequency selection-Actuation time,Without time limit,
IDE02180-ENG170421,Remote control for FM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02181-MAS01167,Remote control for AM frequency selection-Actuation time,Without time limit,
IDE02181-ENG170421,Remote control for AM frequency selection-IoReached Status,Output diagnostic test not active,
IDE02182-MAS01167,Remote control for volume-Actuation time,Without time limit,
IDE02182-ENG170421,Remote control for volume-IoReached Status,Output diagnostic test not active,
IDE02326-MAS17347,GPS signal strength-Satellite 1: identification,0,
IDE02326-MAS17348,GPS signal strength-Satellite 1: signal strength,0, dBµV
IDE02326-MAS17349,GPS signal strength-Satellite 2: signal strength,0, dBµV
IDE02326-MAS17350,GPS signal strength-Satellite 3: signal strength,0, dBµV
IDE02326-MAS17351,GPS signal strength-Satellite 4: signal strength,0, dBµV
IDE02326-MAS17352,GPS signal strength-Satellite 2: identification,255,
IDE02326-MAS17353,GPS signal strength-Satellite 3: identification,255,
IDE02326-MAS17354,GPS signal strength-Satellite 4: identification,255,
IDE02454-MAS01167,Remote control for digital radio service selection (DSB)-Actuation time,Without time limit,
IDE02454-ENG170421,Remote control for digital radio service selection (DSB)-IoReached Status,Output diagnostic test not active,
IDE02470-MAS01167,Remote control frequency selection digital radio (band III)-Actuation time,Without time limit,
IDE02470-ENG170421,Remote control frequency selection digital radio (band III)-IoReached Status,Output diagnostic test not active,
IDE02475-MAS01167,Acoustic check of loudspeakers-Actuation time,Without time limit,
IDE02475-ENG170421,Acoustic check of loudspeakers-IoReached Status,Output diagnostic test not active,
IDE02476-MAS01167,Electrical test of speakers-Actuation time,Without time limit,
IDE02476-ENG170421,Electrical test of speakers-IoReached Status,Output diagnostic test not active,
IDE02501-MAS01167,Remote control for voice operation-Actuation time,Without time limit,
IDE02501-ENG170421,Remote control for voice operation-IoReached Status,Output diagnostic test not active,
IDE02505-MAS01763,Status of tuner 2 for digital radio (DAB)-Field intensity,255,
IDE02505-MAS02949,Status of tuner 2 for digital radio (DAB)-Frequency,0,
IDE02505-MAS06242,Status of tuner 2 for digital radio (DAB)-Signal quality,0,
IDE02505-MAS19004,Status of tuner 2 for digital radio (DAB)-DAB bit rate malfunction FIC,0.00,
IDE02505-MAS19005,Status of tuner 2 for digital radio (DAB)-DAB bit rate malfunction NET,Not available,
IDE02505-MAS19006,Status of tuner 2 for digital radio (DAB)-DAB fault bit rate MSC,0.00,
IDE02505-MAS19011,Status of tuner 2 for digital radio (DAB)-Ensemble ID,00 00 00 00,
IDE02505-MAS19012,Status of tuner 2 for digital radio (DAB)-Ensemble Label,                ,
IDE02505-MAS19023,Status of tuner 2 for digital radio (DAB)-SYNC / OFDM Lock,not active,
IDE02508-MAS00951,Bluetooth: Visibility-Bluetooth,On,
IDE02508-MAS03001,Bluetooth: Visibility-Mode,Bluetooth not visible: connection possible,
IDE03477-MAS00106,GPS time-Year,2000,
IDE03477-MAS00107,GPS time-Month,1,
IDE03477-MAS00108,GPS time-Day,1,
IDE03477-MAS00109,GPS time-Hours,0,
IDE03477-MAS00110,GPS time-Minutes,0,
IDE03477-MAS00111,GPS time-Seconds,0,
IDE03477-MAS01632,GPS time-Status,invalid,
IDE03610-MAS02573,Voice operation: last detected command-Reception quality,0, %
IDE03610-MAS03874,Voice operation: last detected command-last detected command,0,
IDE03610-MAS03875,Voice operation: last detected command-Reliability,0, %
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,24, min
IDE04317-MAS00108,Total system run time-Day,162, d
IDE04317-MAS00109,Total system run time-Hours,7, H
IDE04317-MAS00110,Total system run time-Minutes,46, min
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04546-IDE00301,Calibration of navigation-Distance,23.83, mm
IDE04546-MAS03647,Calibration of navigation-Calibration condition,complete,
IDE04649-MAS01968,Activation for housing fan-Fan,Stage 1,
IDE04649-MAS06857,Activation for housing fan-Speed,2400, /min
IDE04767-MAS01240,Update software via medium-Programming status,not active,
IDE04767-MAS02111,Update software via medium-Data consistency,valid,
IDE04767-MAS02112,Update software via medium-Programmability,Waiting for data transmission,
IDE04768,Bluetooth: device address,58 D5 0A FD DA E1,
IDE05040-MAS01632,Video input status-Status,Not available,
IDE05040-MAS04390,Video input status-Active source,Not available,
IDE05107-MAS01167,Test image display unit 1 for multimedia system-Actuation time,0 s,
IDE05107-ENG170421,Test image display unit 1 for multimedia system-IoReached Status,Output diagnostic test not active,
IDE05595-MAS00106,Last time GPS without satellite reception-Year,2000,
IDE05595-MAS00107,Last time GPS without satellite reception-Month,0,
IDE05595-MAS00108,Last time GPS without satellite reception-Day,OFF,
IDE05595-MAS00109,Last time GPS without satellite reception-Hours,0,
IDE05595-MAS00110,Last time GPS without satellite reception-Minutes,0,
IDE05595-MAS00111,Last time GPS without satellite reception-Seconds,0,
IDE05596-MAS00106,Last time GPS position outside map-Year,2000,
IDE05596-MAS00107,Last time GPS position outside map-Month,0,
IDE05596-MAS00108,Last time GPS position outside map-Day,OFF,
IDE05596-MAS00109,Last time GPS position outside map-Hours,0,
IDE05596-MAS00110,Last time GPS position outside map-Minutes,0,
IDE05596-MAS00111,Last time GPS position outside map-Seconds,0,
IDE05602-IDE03615,Bluetooth: connected device 1-Variant,0x0100              ,
IDE05602-IDE04768,Bluetooth: connected device 1-Bluetooth: device address,60 B4 A2 CD A6 29,
IDE05602-MAS01483,Bluetooth: connected device 1-Software version,0x0201              ,
IDE05602-MAS02159,Bluetooth: connected device 1-Remote SIM Access Profile (rSAP),0,
IDE05602-MAS02160,Bluetooth: connected device 1-Hands free profile (HFP),265,
IDE05602-MAS03159,Bluetooth: connected device 1-Manufacturer,0x0075              ,
IDE05602-MAS04326,Bluetooth: connected device 1-Device name,S25 FE de Carlos    ,
IDE05602-MAS17538,Bluetooth: connected device 1-Received Signal Strength Indicator (RSSI),-128,
IDE05602-MAS17539,Bluetooth: connected device 1-Determining the existing profile (SDAP),0,
IDE05602-MAS17540,Bluetooth: connected device 1-Serial data transfer (SPP),0,
IDE05602-MAS17541,Bluetooth: connected device 1-Streaming audio data (A2DP),259,
IDE05602-MAS17542,Bluetooth: connected device 1-Remote control for audio/video (AVRCP),259,
IDE05602-MAS17543,Bluetooth: connected device 1-Network connections (PAN),0,
IDE05602-MAS17544,Bluetooth: connected device 1-Message exchange between devices (MAP),260,
IDE05602-MAS17545,Bluetooth: connected device 1-Generic data transfer between two devices (OBEX),0,
IDE05602-MAS17546,Bluetooth: connected device 1-Sending individual files (OPP),0,
IDE05602-MAS17547,Bluetooth: connected device 1-File transfer (FTP),0,
IDE05602-MAS17548,Bluetooth: connected device 1-Read-only access to telephone directory (PBAP),258,
IDE05602-MAS17549,Bluetooth: connected device 1-Telephone directory download (AT),0,
IDE05602-MAS17550,Bluetooth: connected device 1-Sharing calendars or notes between two devices (CTN),0,
IDE05602-MAS17551,Bluetooth: connected device 1-iAP protocol (iAP),0,
IDE05603-IDE03615,Bluetooth: connected device 2-Variant,0xffff              ,
IDE05603-IDE04768,Bluetooth: connected device 2-Bluetooth: device address,00 00 00 00 00 00,
IDE05603-MAS01483,Bluetooth: connected device 2-Software version,0xffff              ,
IDE05603-MAS02159,Bluetooth: connected device 2-Remote SIM Access Profile (rSAP),0,
IDE05603-MAS02160,Bluetooth: connected device 2-Hands free profile (HFP),0,
IDE05603-MAS03159,Bluetooth: connected device 2-Manufacturer,0xffff              ,
IDE05603-MAS04326,Bluetooth: connected device 2-Device name,                    ,
IDE05603-MAS17538,Bluetooth: connected device 2-Received Signal Strength Indicator (RSSI),-128,
IDE05603-MAS17539,Bluetooth: connected device 2-Determining the existing profile (SDAP),0,
IDE05603-MAS17540,Bluetooth: connected device 2-Serial data transfer (SPP),0,
IDE05603-MAS17541,Bluetooth: connected device 2-Streaming audio data (A2DP),0,
IDE05603-MAS17542,Bluetooth: connected device 2-Remote control for audio/video (AVRCP),0,
IDE05603-MAS17543,Bluetooth: connected device 2-Network connections (PAN),0,
IDE05603-MAS17544,Bluetooth: connected device 2-Message exchange between devices (MAP),0,
IDE05603-MAS17545,Bluetooth: connected device 2-Generic data transfer between two devices (OBEX),0,
IDE05603-MAS17546,Bluetooth: connected device 2-Sending individual files (OPP),0,
IDE05603-MAS17547,Bluetooth: connected device 2-File transfer (FTP),0,
IDE05603-MAS17548,Bluetooth: connected device 2-Read-only access to telephone directory (PBAP),0,
IDE05603-MAS17549,Bluetooth: connected device 2-Telephone directory download (AT),0,
IDE05603-MAS17550,Bluetooth: connected device 2-Sharing calendars or notes between two devices (CTN),0,
IDE05603-MAS17551,Bluetooth: connected device 2-iAP protocol (iAP),0,
IDE05604-IDE03615,Bluetooth: connected device 3-Variant,0xffff              ,
IDE05604-IDE04768,Bluetooth: connected device 3-Bluetooth: device address,00 00 00 00 00 00,
IDE05604-MAS01483,Bluetooth: connected device 3-Software version,0xffff              ,
IDE05604-MAS02159,Bluetooth: connected device 3-Remote SIM Access Profile (rSAP),0,
IDE05604-MAS02160,Bluetooth: connected device 3-Hands free profile (HFP),0,
IDE05604-MAS03159,Bluetooth: connected device 3-Manufacturer,0xffff              ,
IDE05604-MAS04326,Bluetooth: connected device 3-Device name,                    ,
IDE05604-MAS17538,Bluetooth: connected device 3-Received Signal Strength Indicator (RSSI),-128,
IDE05604-MAS17539,Bluetooth: connected device 3-Determining the existing profile (SDAP),0,
IDE05604-MAS17540,Bluetooth: connected device 3-Serial data transfer (SPP),0,
IDE05604-MAS17541,Bluetooth: connected device 3-Streaming audio data (A2DP),0,
IDE05604-MAS17542,Bluetooth: connected device 3-Remote control for audio/video (AVRCP),0,
IDE05604-MAS17543,Bluetooth: connected device 3-Network connections (PAN),0,
IDE05604-MAS17544,Bluetooth: connected device 3-Message exchange between devices (MAP),0,
IDE05604-MAS17545,Bluetooth: connected device 3-Generic data transfer between two devices (OBEX),0,
IDE05604-MAS17546,Bluetooth: connected device 3-Sending individual files (OPP),0,
IDE05604-MAS17547,Bluetooth: connected device 3-File transfer (FTP),0,
IDE05604-MAS17548,Bluetooth: connected device 3-Read-only access to telephone directory (PBAP),0,
IDE05604-MAS17549,Bluetooth: connected device 3-Telephone directory download (AT),0,
IDE05604-MAS17550,Bluetooth: connected device 3-Sharing calendars or notes between two devices (CTN),0,
IDE05604-MAS17551,Bluetooth: connected device 3-iAP protocol (iAP),0,
IDE05605-IDE03615,Bluetooth: connected device 4-Variant,0xffff              ,
IDE05605-IDE04768,Bluetooth: connected device 4-Bluetooth: device address,00 00 00 00 00 00,
IDE05605-MAS01483,Bluetooth: connected device 4-Software version,0xffff              ,
IDE05605-MAS02159,Bluetooth: connected device 4-Remote SIM Access Profile (rSAP),0,
IDE05605-MAS02160,Bluetooth: connected device 4-Hands free profile (HFP),0,
IDE05605-MAS03159,Bluetooth: connected device 4-Manufacturer,0xffff              ,
IDE05605-MAS04326,Bluetooth: connected device 4-Device name,                    ,
IDE05605-MAS17538,Bluetooth: connected device 4-Received Signal Strength Indicator (RSSI),-128,
IDE05605-MAS17539,Bluetooth: connected device 4-Determining the existing profile (SDAP),0,
IDE05605-MAS17540,Bluetooth: connected device 4-Serial data transfer (SPP),0,
IDE05605-MAS17541,Bluetooth: connected device 4-Streaming audio data (A2DP),0,
IDE05605-MAS17542,Bluetooth: connected device 4-Remote control for audio/video (AVRCP),0,
IDE05605-MAS17543,Bluetooth: connected device 4-Network connections (PAN),0,
IDE05605-MAS17544,Bluetooth: connected device 4-Message exchange between devices (MAP),0,
IDE05605-MAS17545,Bluetooth: connected device 4-Generic data transfer between two devices (OBEX),0,
IDE05605-MAS17546,Bluetooth: connected device 4-Sending individual files (OPP),0,
IDE05605-MAS17547,Bluetooth: connected device 4-File transfer (FTP),0,
IDE05605-MAS17548,Bluetooth: connected device 4-Read-only access to telephone directory (PBAP),0,
IDE05605-MAS17549,Bluetooth: connected device 4-Telephone directory download (AT),0,
IDE05605-MAS17550,Bluetooth: connected device 4-Sharing calendars or notes between two devices (CTN),0,
IDE05605-MAS17551,Bluetooth: connected device 4-iAP protocol (iAP),0,
IDE05606-IDE03615,Bluetooth: connected device 5-Variant,0xffff              ,
IDE05606-IDE04768,Bluetooth: connected device 5-Bluetooth: device address,00 00 00 00 00 00,
IDE05606-MAS01483,Bluetooth: connected device 5-Software version,0xffff              ,
IDE05606-MAS02159,Bluetooth: connected device 5-Remote SIM Access Profile (rSAP),0,
IDE05606-MAS02160,Bluetooth: connected device 5-Hands free profile (HFP),0,
IDE05606-MAS03159,Bluetooth: connected device 5-Manufacturer,0xffff              ,
IDE05606-MAS04326,Bluetooth: connected device 5-Device name,                    ,
IDE05606-MAS17538,Bluetooth: connected device 5-Received Signal Strength Indicator (RSSI),-128,
IDE05606-MAS17539,Bluetooth: connected device 5-Determining the existing profile (SDAP),0,
IDE05606-MAS17540,Bluetooth: connected device 5-Serial data transfer (SPP),0,
IDE05606-MAS17541,Bluetooth: connected device 5-Streaming audio data (A2DP),0,
IDE05606-MAS17542,Bluetooth: connected device 5-Remote control for audio/video (AVRCP),0,
IDE05606-MAS17543,Bluetooth: connected device 5-Network connections (PAN),0,
IDE05606-MAS17544,Bluetooth: connected device 5-Message exchange between devices (MAP),0,
IDE05606-MAS17545,Bluetooth: connected device 5-Generic data transfer between two devices (OBEX),0,
IDE05606-MAS17546,Bluetooth: connected device 5-Sending individual files (OPP),0,
IDE05606-MAS17547,Bluetooth: connected device 5-File transfer (FTP),0,
IDE05606-MAS17548,Bluetooth: connected device 5-Read-only access to telephone directory (PBAP),0,
IDE05606-MAS17549,Bluetooth: connected device 5-Telephone directory download (AT),0,
IDE05606-MAS17550,Bluetooth: connected device 5-Sharing calendars or notes between two devices (CTN),0,
IDE05606-MAS17551,Bluetooth: connected device 5-iAP protocol (iAP),0,
IDE05700-MAS01456,USB connection-Speed,Not available,
IDE05700-MAS01632,USB connection-Status,Not available,
IDE05700-MAS03159,USB connection-Manufacturer,0,
IDE05700-MAS04393,USB connection-USB device class,0,
IDE05700-MAS04394,USB connection-Connection status,not connected,
IDE05700-MAS04436,USB connection-USB device sub-class,0,
IDE05700-MAS06173,USB connection-Protocol,0,
IDE05700-MAS06174,USB connection-Product ID,0,
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE05725,Dimmer terminal 58xs,NOT-DEFINED,
IDE05726,Dimmer terminal 58xd,Initialization,
IDE05814,Individualization characteristic,81 F4 7D 25 F8,
IDE06028-MAS02317,Control head button operation-Button code 1,Not available,
IDE06028-MAS02318,Control head button operation-Button code 2,Not available,
IDE06028-MAS04151,Control head button operation-Joystick,Not available,
IDE06028-MAS04413,Control head button operation-Push-and rotary knob for selection,0,
IDE06028-MAS04414,Control head button operation-Volume control,0,
IDE06516-MAS01424,Temperature: optical drive-max.value,Not available,
IDE06516-MAS01425,Temperature: optical drive-min.value,Not available,
IDE06516-MAS02238,Temperature: optical drive-Current,Not available,
IDE06517-MAS01424,Temperature: audio amplifier-max.value,Not available,
IDE06517-MAS01425,Temperature: audio amplifier-min.value,Not available,
IDE06517-MAS02238,Temperature: audio amplifier-Current,Not available,
IDE06519-MAS01424,Temperature of MOST transceiver-max.value,Not available,
IDE06519-MAS01425,Temperature of MOST transceiver-min.value,Not available,
IDE06519-MAS02238,Temperature of MOST transceiver-Current,Not available,
IDE06521-MAS01424,Temperature of MMX PC boards-max.value,Not available,
IDE06521-MAS01425,Temperature of MMX PC boards-min.value,Not available,
IDE06521-MAS02238,Temperature of MMX PC boards-Current,Not available,
IDE06522-MAS01424,Temperature of phone unit-max.value,Not available,
IDE06522-MAS01425,Temperature of phone unit-min.value,Not available,
IDE06522-MAS02238,Temperature of phone unit-Current,Not available,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,02,
IDE07174,Connection for extern. audio sources (USB): overcurrent detect.,OK,
IDE07364,GPS reception status,GPS data available,
IDE07543,Vehicle speed,0.00, km/h
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Others,
IDE09544-MAS01167,Locking information electronic 1 operation-Actuation time,Without time limit,
IDE09544-ENG170421,Locking information electronic 1 operation-IoReached Status,Output diagnostic test not active,
IDE09563-MAS09154,Proximity detection for touchscreen 1-Proximity sensor 1,No object in sector,
IDE10300,OBD Driving Cycle detected,not active,
IDE10478-MAS01632,Interface for external media: status-Status,OK,
IDE10481-MAS01167,Interface for external media: diagnosis-Actuation time,Without time limit,
IDE10481-ENG170421,Interface for external media: diagnosis-IoReached Status,Output diagnostic test not active,
IDE10600-MAS01632,Status of the navigation database-Status,valid,
IDE10600-ENG98502,Status of the navigation database-Data,|Country Code,Region Code
IDE10781,Ethernet counter checksum malfunction,0,
IDE10843-ENG98502,Function module: identification-Data,|Device name,Module Name
customerupdates                 , customerupdates.wlan            ,32,0F 00 00 00
customerupdates                 , customerupdates.stationdb       ,32,0F 00 00 00
customerupdates                 , customerupdates.radio-tuner     ,32,0F 00 00 00
customerupdates                 , customerupdates.sds-asr-resource,115,0F 00 00 00
emmc                            , emmc.audio.amplifierclr_ampcontr,32,0F 00 00 00
emmc                            , emmc.audio.audiomgr_mib3-res-mqb,32,0F 00 00 00
emmc                ,  emmc.audio.audiomgr_audio-commo,110,20 0F 00 00
IDE10857-MAS02476,Touchless loading of mobile phone: status-installed,Available,
IDE10857-MAS11500,Touchless loading of mobile phone: status-Foreign object,No,
IDE10857-MAS11501,Touchless loading of mobile phone: status-Charging,No,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,0,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11728,Ethernet signal quality: branch 1,good: link available,
IDE11729,Ethernet signal quality: branch 2,no link,
IDE11730,Ethernet signal quality: branch 3,no link,
IDE11731,Ethernet signal quality: branch 4,good: link available,
IDE11736,Ethernet counter connection interruptions: branch 1,0,
IDE11737,Ethernet counter connection interruptions: branch 2,0,
IDE11738,Ethernet counter connection interruptions: branch 3,0,
IDE11739,Ethernet counter connection interruptions: branch 4,0,
IDE11744,Ethernet counter checksum error: branch 1,0,
IDE11745,Ethernet counter checksum error: branch 2,0,
IDE11746,Ethernet counter checksum error: branch 3,0,
IDE11747,Ethernet counter checksum error: branch 4,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 73|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 73|FE 80 00 00 00 00 00 00 42 FA 7F FF FE 05 2A DD|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 73|FF 02 00 00 00 00 00 00 00 00 00 01 FF 05 2A DD|FF 05 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|00 54 AF 86 02 F9|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|00 00 00 00 00 00|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|00 00 00 00 00 00|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|30 0E B8 3B 4C DC|30 0E B8 3B 4C DC|,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|5|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|0|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|0|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,23972,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F
IDE12267-MAS03231,Microphone current draw-Microphone 1,6.00, mA
IDE12267-MAS03232,Microphone current draw-Microphone 2,Not available,
IDE12267-MAS03233,Microphone current draw-Microphone 3,Not available,
IDE12267-MAS14201,Microphone current draw-Microphone 4,Not available,
IDE12625,IP network: current link deceleration: branch 1,65535, ns
IDE12626,IP network: current link deceleration: branch 2,0, ns
IDE12627,IP network: current link deceleration: branch 3,0, ns
IDE12628,IP network: current link deceleration: branch 4,65535, ns
IDE12633,IP Network maximum correction of the synchronized clock,0, ns
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13344-MAS01167,Acoustic check of loudspeakers: sequential analysis-Actuation time,Without time limit,
IDE13344-ENG170421,Acoustic check of loudspeakers: sequential analysis-IoReached Status,Output diagnostic test not active,
IDE13737-MAS01763,Status of tuner for digital radio 1b (DAB)-Field intensity,0,
IDE13737-MAS19004,Status of tuner for digital radio 1b (DAB)-DAB bit rate malfunction FIC,0.00,
IDE13737-MAS19005,Status of tuner for digital radio 1b (DAB)-DAB bit rate malfunction NET,0.00,
IDE13737-MAS19006,Status of tuner for digital radio 1b (DAB)-DAB fault bit rate MSC,0.00,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVWZZZ3CZME009325,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 02,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,7,
IDE14128-MAS01167,Activation for blower housing status-Actuation time,Without time limit,
IDE14128-ENG170421,Activation for blower housing status-IoReached Status,Output diagnostic test not active,
IDE14715-MAS18871,Acoustic test of loudspeakers: status-Current channel,OFF,
IDE14715-MAS18921,Acoustic test of loudspeakers: status-Current loudspeaker,Not available,
MAS00778-IDE03619,Multimedia display unit 1-System condition,On,
MAS00778-IDE05228,Multimedia display unit 1-Operating hour counter,2817, H
MAS00778-MAS00110,Multimedia display unit 1-Minutes,6, min
MAS00778-MAS01634,Multimedia display unit 1-Supply voltage,13.30, V
MAS00778-MAS02200,Multimedia display unit 1-Highest measured temperature,73, °C
MAS00778-MAS02201,Multimedia display unit 1-Temperature,32, °C
MAS00778-MAS03691,Multimedia display unit 1-Dimming,100, %
MAS00951-MAS04325,Bluetooth-Bluetooth: Paired devices,1,
MAS01760-MAS01765,Radio Tuner 1-Audio Signal,Analog,
MAS01760-MAS02949,Radio Tuner 1-Frequency,0.00, MHz
MAS01760-MAS03991,Radio Tuner 1-Reception level antenna 1,0,
MAS01760-MAS04344,Radio Tuner 1-Reception level antenna 2,0,
MAS01760-MAS04345,Radio Tuner 1-Frequency (AM),0,
MAS01760-MAS19025,Radio Tuner 1-IBOC fault rate,0, %
MAS01760-MAS19026,Radio Tuner 1-IBOC audio signal:,Not available,
MAS01760-MAS19028,Radio Tuner 1-IBOC DRM Service,0,
MAS01760-MAS19030,Radio Tuner 1-IBOC DRM counter,OFF,
MAS01761-MAS01763,Radio Tuner 2-Field intensity,0,
MAS03782-MAS17355,WLAN-MAC address 2: tethering,5A D5 0A 3D 74 5E,
MAS03782-MAS17356,WLAN-MAC address 1,58 D5 0A FD 74 5E,
MAS03782-MAS17357,WLAN-MAC address 2,58 D5 0A FD 74 5E,
MAS03782-MAS17559,WLAN-MAC address 1: tethering,5A D5 0A 5D 74 5E,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,61 F2 BA 3F,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,61 F2 BA 3F,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1690,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 75,
MAS17833,Remaining period of test activation,4294967295, s
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG117866-ENG117457,DAB_FM_linking-dab_mute_status,No,
ENG117866-ENG117456,DAB_FM_linking-DAB_quality,0, %
ENG117866-ENG117455,DAB_FM_linking-fm_quality,0, %
ENG117866-ENG117458,DAB_FM_linking-service_linking_status,no_link,
ENG249161-MAS01167,Operating_Unit_Simulation_Keys_status-Actuation time,Without time limit,
ENG249161-ENG170421,Operating_Unit_Simulation_Keys_status-IoReached Status,Output diagnostic test not active,
ENG249168-MAS01167,Remote_Seek_Activation_status-Actuation time,Without time limit,
ENG249168-ENG170421,Remote_Seek_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249169-MAS01167,Remote_Set_AF_status-Actuation time,Without time limit,
ENG249169-ENG170421,Remote_Set_AF_status-IoReached Status,Output diagnostic test not active,
ENG249170-MAS01167,Remote_Set_Concealment_Level_status-Actuation time,Without time limit,
ENG249170-ENG170421,Remote_Set_Concealment_Level_status-IoReached Status,Output diagnostic test not active,
ENG249171-MAS01167,Remote_Set_DAB_Announcement_status-Actuation time,Without time limit,
ENG249171-ENG170421,Remote_Set_DAB_Announcement_status-IoReached Status,Output diagnostic test not active,
ENG249172-MAS01167,Remote_Set_DAB_Default_status-Actuation time,Without time limit,
ENG249172-ENG170421,Remote_Set_DAB_Default_status-IoReached Status,Output diagnostic test not active,
ENG249173-MAS01167,Remote_Set_DAB_Linking_status-Actuation time,Without time limit,
ENG249173-ENG170421,Remote_Set_DAB_Linking_status-IoReached Status,Output diagnostic test not active,
ENG249174-MAS01167,Remote_Set_DAB_Mute_status-Actuation time,Without time limit,
ENG249174-ENG170421,Remote_Set_DAB_Mute_status-IoReached Status,Output diagnostic test not active,
ENG249175-MAS01167,Remote_Set_Hidden_Tune_status-Actuation time,Without time limit,
ENG249175-ENG170421,Remote_Set_Hidden_Tune_status-IoReached Status,Output diagnostic test not active,
ENG249177-MAS01167,Remote_Set_TP_status-Actuation time,Without time limit,
ENG249177-ENG170421,Remote_Set_TP_status-IoReached Status,Output diagnostic test not active,
ENG249178-MAS01167,Remote_Shift_Frequency_AM_Activation_status-Actuation time,Without time limit,
ENG249178-ENG170421,Remote_Shift_Frequency_AM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249179-MAS01167,Remote_Shift_Frequency_DAB_Activation_status-Actuation time,Without time limit,
ENG249179-ENG170421,Remote_Shift_Frequency_DAB_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249180-MAS01167,Remote_Shift_Frequency_FM_Activation_status-Actuation time,Without time limit,
ENG249180-ENG170421,Remote_Shift_Frequency_FM_Activation_status-IoReached Status,Output diagnostic test not active,
ENG249197-MAS01167,set_amfm_measurement_mode_status-Actuation time,Without time limit,
ENG249197-ENG170421,set_amfm_measurement_mode_status-IoReached Status,Output diagnostic test not active,
ENG249198-MAS01167,set_tuner_mode_status-Actuation time,Without time limit,
ENG249198-ENG170421,set_tuner_mode_status-IoReached Status,Output diagnostic test not active,
ENG117864-MAS01632,Status_Position_Touchscreen_1-Status,Not operated,
ENG117864-ENG117402,Status_Position_Touchscreen_1-calibrate_delta_x,Not available,
ENG117864-ENG117403,Status_Position_Touchscreen_1-calibrate_delta_y,Not available,
ENG117864-ENG117396,Status_Position_Touchscreen_1-position_x1,Not available,
ENG117864-ENG117397,Status_Position_Touchscreen_1-position_x2,Not available,
ENG117864-ENG117398,Status_Position_Touchscreen_1-position_x3,Not available,
ENG117864-ENG117399,Status_Position_Touchscreen_1-position_y1,Not available,
ENG117864-ENG117400,Status_Position_Touchscreen_1-position_y2,Not available,
ENG117864-ENG117401,Status_Position_Touchscreen_1-position_y3,Not available,
Elapsed Time: 00:31
Trevas
Portugal
C?ID=516418
blockmap-6C-5Q0-980-556-B_WVWZZZ3CZME009325-20260823-2132.CSV
;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  6C: Back-up Cam.
;Component:RVC Compact   H18 0231, Coding:0184020162002017000041
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB.rod
;Sunday,23,August,2026,21:32:30:32152
;VCID: 3924429ED9DE4B42D9C-806C
IDE00019,Voltage terminal 30,13.04, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS00223,Status: doors/lids 1-Hood,Measuring value not available,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,detected,
IDE00924-IDE08941,Steering angle-Rack position,0.000, mm
IDE00924-MAS02471,Steering angle-Sign,Positive,
IDE00924-MAS02983,Steering angle-Steering wheel angle,4.800, °
IDE00924,Steering angle,0.300, °
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,0.000, °
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE01714,Status reverse gear,not selected,
IDE03619,System condition,passive,
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,100, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,No malfunction,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07402,External activation,not active,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,32,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,23,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,125, counts
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,136252, km
ENG119197-ENG128717,camera_calibration_parameters-Cam0 Calibration binary threshold,00,
ENG119197-ENG119070,camera_calibration_parameters-Cam0 Calibration Result judgment,00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 A0 40 00 00 20 41,
ENG119197-ENG119060,camera_calibration_parameters-Cam0 Changing default data - Ground to Camera Z,0.00, mm
ENG119197-ENG119061,camera_calibration_parameters-Cam0 Changing default data - Ground to wheel arch Z,726.00, mm
ENG119197-ENG119068,camera_calibration_parameters-Cam0 division counts horizontal,1,
ENG119197-ENG119069,camera_calibration_parameters-Cam0 division counts vertical,1,
ENG119197-ENG119062,camera_calibration_parameters-Cam0 Fixed value input - Ground to Camera Z,0.00, mm
ENG119197-ENG119063,camera_calibration_parameters-Cam0 Fixed value input - Ground to wheel arch Z,0.00, mm
ENG119197-ENG119067,camera_calibration_parameters-Cam0 height of marker,50.00, mm
ENG119197-ENG119064,camera_calibration_parameters-Cam0 Marker size Full-size or Half-size,full size,
ENG119197-ENG119058,camera_calibration_parameters-Cam0 Transversal position front axle,0.80, mm
ENG119197-ENG119059,camera_calibration_parameters-Cam0 Transversal position rear axle,-0.20, mm
ENG119197-ENG119065,camera_calibration_parameters-Cam0 X direction of marker red ribbon,4588.00, mm
ENG119197-ENG119066,camera_calibration_parameters-Cam0 Y direction of marker,0.00, mm
ENG119196-ENG119090,camera_calibration_tolerance-RV_Calibration_Result,0.46, px
ENG119196-ENG119084,camera_calibration_tolerance-RV_Calibration_Tolerance_alpha,-0.71, °
ENG119196-ENG119085,camera_calibration_tolerance-RV_Calibration_Tolerance_beta,0.71, °
ENG119196-ENG119086,camera_calibration_tolerance-RV_Calibration_Tolerance_gamma,0.91, °
ENG119196-ENG119087,camera_calibration_tolerance-RV_Calibration_Tolerance_x,0.00, mm
ENG119196-ENG119088,camera_calibration_tolerance-RV_Calibration_Tolerance_y,0.00, mm
ENG119196-ENG119089,camera_calibration_tolerance-RV_Calibration_Tolerance_z,11.16, mm
Elapsed Time: 00:02
blockmap-6D-5Q0-959-107-AA_WVWZZZ3CZME009325-20260823-2132.CSV
;SW:5Q0-959-107-AA   HW:5Q0-959-107-H ---  6D: Trunk Elect.
;Component:HDSG-Modul    H13 0272, Coding:0200
;EV_DeckLidCONTIAU736,001017,EV_DeckLidCONTIAU736_VW37.rod
;Sunday,23,August,2026,21:32:44:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 77A084A6AF4A9D32EF8-8022
Group,Description,Actual
IDE00019,Voltage terminal 30,13.14, V
IDE00542,Excessive temperature protection,not active,
IDE02010,Motor 1 for rear lid: activation,0, %
IDE02011,Motor 1 for tailgate: current,0.00, A
IDE02013,Motor 2 for rear lid: activation,0, %
IDE02014,Motor 2 for tailgate: current,0.00, A
IDE02017,Rear lid position: relative,0, %
IDE02018,Rear lid position: absolute,0,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,96, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,2139,
IDE02049,Trailer detected,Not available,
IDE02093-MAS09014,Status of rear lid lock-pre-latch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main latch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,Not operated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,Not operated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,Not operated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,Not operated,
IDE02171-MAS01913,Terminals for closing assist-Closing aid,not locked,
IDE02171-MAS01943,Terminals for closing assist-Terminal 1,Open,
IDE02171-MAS01944,Terminals for closing assist-Terminal 2,Open,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,2174,
IDE03615-MAS02672,Variant-Start-stop,2,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,OFF,
IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,END,
IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,END,
IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,END,
IDE05584,Rear lid basic setting status,Unknown (7)
IDE07159-MAS05583,Control module switch-off: counter-Data bus,3,
IDE09491-IDE03434,Lock-in area-Detection area lower,70,
IDE09491-IDE03435,Lock-in area-Detection area upper,35,
IDE09492-MAS06165,Temperatures-Processor,19.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,26.00, °C
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,31.00, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,25.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,26.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,26.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,25.00, °C
IDE09492-MAS09053,Temperatures-Output stage for pull-shut assist.: calc.,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,28.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,25.00, °C
IDE09493,Status of basic tailgate setting,Basic setting not active,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Cancel,
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Cancel,
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Cancel,
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Cancel,
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Cancel,
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Supply voltage error,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Supply voltage error,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Supply voltage error,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Supply voltage error,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Supply voltage error,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,Not operated,
IDE09498-MAS01872,Status of control points-Rear lid remote release button,Not operated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,Not operated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,Not operated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,Not operated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,Malfunction,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,Malfunction,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,OFF,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.57, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,8525,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,8724,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,67,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,672,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,7815,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,7998,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,359,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,2,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,2,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,334,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,3,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,659,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,1625,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,1591,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,289,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,47384,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,0,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,17,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,5,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,3,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09506,Rear lid anti-play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,OFF,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000000 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000000 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000000 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000000 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,0,
IDE10697-MAS02282,Luggage compartment cover: position-Position,0,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initialization,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,not active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,5,
Elapsed Time: 00:07
blockmap-75-5WA-035-284-G_WVWZZZ3CZME009325-20260823-2133.CSV
;SW:5WA-035-284-G   HW:5WA-035-284-B ---  75: Telematics
;Component:OCUGen3High   H22 0143, Coding:024827001968A8209005460160002607
;EV_OCUGen3High,003007,EV_OCUGen3High_003_VW27.rod
;Sunday,23,August,2026,21:33:03:32152
;VCID: 4AC60D528C38D0DA406-801E
IDE00019,Voltage terminal 30,13.1, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,44, °C
IDE00608,Fuel type,Petrol,
IDE00667-MAS03231,Microphone status-Microphone 1,electrically OK,
IDE00667-MAS03232,Microphone status-Microphone 2,Not available,
IDE00668-MAS03231,Microphone voltage consumption-Microphone 1,5.7, mA
IDE00668-MAS03232,Microphone voltage consumption-Microphone 2,0.0, mA
IDE00672,Roadside Assistance Button,Not operated,
IDE00673,Information Service Button -E450-,Not operated,
IDE00767,No. of unscheduled ECU resets,0,
IDE01215,Dimmer terminal 58d,39.70, %
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Direction of travel,256, °
IDE01588-MAS01632,Direction of travel-Status,Available,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS02230,GPS Position-Height,0, m
IDE01713-MAS01632,Status GPS reception-Status,GPS almanac is being loaded,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,4,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,26, mA
IDE01971,Lowest recorded control module temperature,-2, °C
IDE01972,Highest recorded control module temperature,63, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,0, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,0,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,0,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,0,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,0,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,0, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,0, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,0, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,0, dBµV
IDE03477-MAS00106,GPS time-Year,2127,
IDE03477-MAS00107,GPS time-Month,0,
IDE03477-MAS00108,GPS time-Day,0,
IDE03477-MAS00109,GPS time-Hours,24,
IDE03477-MAS00110,GPS time-Minutes,60,
IDE03477-MAS00111,GPS time-Seconds,60,
IDE04293,Operating state for emer call module,registerstate_roaming,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,901280082992784,
IDE04750-MAS04226,SIM card-Telephone number,               ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89882390000694406094,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000029582863391,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,353775363076761,
IDE05431-MAS01167,Lock for high-voltage charging connector-Actuation time,0 s,
IDE05431-ENG170421,Lock for high-voltage charging connector-IoReached Status,Output diagnostic test not active,
IDE07007-MAS01167,Air conditioning/heating function via remote control-Actuation time,0 s,
IDE07007-ENG170421,Air conditioning/heating function via remote control-IoReached Status,Output diagnostic test not active,
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2024,
IDE07589-MAS00107,Update programming: status-Month,10,
IDE07589-MAS00108,Update programming: status-Day,22,
IDE07589-MAS00109,Update programming: status-Hours,11,
IDE07589-MAS00110,Update programming: status-Minutes,53,
IDE07589-MAS00111,Update programming: status-Seconds,32,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE07975-MAS01167,Remote control for charging function of high-voltage battery-Actuation time,0 s,
IDE07975-ENG170421,Remote control for charging function of high-voltage battery-IoReached Status,Output diagnostic test not active,
IDE08156-MAS01167,Transmission of configuration for online services-Actuation time,0 s,
IDE08156-ENG170421,Transmission of configuration for online services-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobilizer status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 73 00 00 00 00 00 0C 03 00 3C,
IDE08343,Immobilizer Challenge,70 A9 D9 B6,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,0, %
IDE09602-MAS01167,Locale hazard warning-Actuation time,0 s,
IDE09602-ENG170421,Locale hazard warning-IoReached Status,Output diagnostic test not active,
IDE10300,OBD Driving Cycle detected,active,
IDE11307-IDE01839,eCall battery status-Battery charge status,97, %
IDE11307-MAS08415,eCall battery status-Battery condition,normal,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FE 80 00 00 00 00 00 00 32 0E B8 FF FE 3B 4C DC|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF 3B 4C DC|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|30 0E B8 3B 4C DC|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|40 FA 7F 05 2A DD|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,Write only channel,
IDE12230-MAS14856,IP network: VLANs of Ethernet switch ports branch 1-VLAN,|VLAN|4|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|4|,
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 73
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Speaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Speaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 02,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,12,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2024, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,10, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,22, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,13, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,35, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,43, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2024, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),10, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),22, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),11, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),35, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),45, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,activated,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2050, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,10, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,30, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P-Class:,73,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,33,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,12,
MAS01490-MAS08403,Energy management-Remaining short term energy budget,895, mAh
MAS01490-MAS08404,Energy management-Remaining long term energy budget,3600, mAh
MAS01490-MAS08405,Energy management-Wake up cycles counter,6976,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,268,
MAS04394-IDE07699,Connection status-Mobile network operator,1,
MAS04394-MAS03991,Connection status-Reception level antenna 1,0, %
MAS04394-MAS04460,Connection status-Validity,valid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,130578483,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS06413,Audio signal output,electrically OK,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS08374-MAS01167,Remote control for lights and horn-Actuation time,0 s,
MAS08374-ENG170421,Remote control for lights and horn-IoReached Status,Output diagnostic test not active,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,Support from metadata version 0x10,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,00 5F,
MAS18226-MAS01167,Sending the driver assistance data-Actuation time,0 s,
MAS18226-ENG170421,Sending the driver assistance data-IoReached Status,Output diagnostic test not active,
MAS18461-MAS18463,FoD product list-Product number,0,
MAS18461-MAS18464,FoD product list-Function ID,
MAS18461-MAS18465,FoD product list-Import regulation,No Info,
MAS18461-MAS18471,FoD product list-Product regulation,No Info,
MAS18461-MAS18474,FoD product list-Change information regulation,No Info,
MAS18461-MAS18477,FoD product list-Notification control,No Info,
MAS18461-MAS18481,FoD product list-Activate regulation,No Info,
MAS18461-MAS18484,FoD product list-Deactivate regulation,No Info,
MAS18461-MAS18487,FoD product list-Warning interval,0,
MAS18461-MAS18488,FoD product list-additional meta info 1,00,
MAS18461-MAS18489,FoD product list-additional meta info 2,00,
MAS18490-IDE06260,Read FoD assignment products on FSIDs-ID number,00 00 00 00,
MAS18490-MAS18463,Read FoD assignment products on FSIDs-Product number,0,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,M103,
MAS19234,Status of user-related refresh tokens,invalid,
MAS19235,Back end (MBB) active user ID,1Zu9V3ZGXEuQLyrNyruA3PQxGjR   ,
MAS19236-MAS00106,Expiration date of user-related refresh tokens-Year,2000,
MAS19236-MAS00107,Expiration date of user-related refresh tokens-Month,0,
MAS19236-MAS00108,Expiration date of user-related refresh tokens-Day,0,
MAS19237,Status of user-related safety pin in vehicle,locked,
MAS19245-MAS19246,Safety mode-Safety mode status,OFF,
MAS19247-MAS19256,Authentication stage-User-related instantaneous authentication stage,0,
MAS19248-MAS19257,User role-User role for active user,Main user,
MAS19255-MAS19238,Status of user image for current user-Image reference value,00 00,
MAS19270,Parameter list,|Parameter ID,Data description
MAS19273,Shadow drive metadata,|User ID,Year
MAS19295,Historical memory for synchronization,|Year,Month
MAS19313,BAP historical memory,|Year,Month
MAS19326,CAN signals for OCU customization,|Year,Month
ENG123206,Antenna_Switch,LTE antenna 1,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,77.839,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,2993, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,84,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,84,
ENG125913,Hybrid_Type,PlugIn_Hybrid,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,10.65.131.8,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,120,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,3088,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,8196, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,32,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,No malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,120,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,No malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,1024,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,4096,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,0,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,30720,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,8196,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,0,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,14336,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,8204,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,16,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,0,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,4096, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,No malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,825438510, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,30720,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,775304494, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,No malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,36, m
ENG247812-ENG159329,Second_Last_Position-Latitude,--------------,
ENG247812-ENG159328,Second_Last_Position-Longitude,--------------,
ENG247822-ENG159329,Third_Last_Position-Latitude,--------------,
ENG247822-ENG159328,Third_Last_Position-Longitude,--------------,
ENG254851-MAS01779,VTT_First_GPS_fix-Length,---           ,
ENG254851-MAS01780,VTT_First_GPS_fix-Width,---           ,
ENG254851-MAS02230,VTT_First_GPS_fix-Height,65034, m
ENG254852,VTT_Last_SMS_Content,2D 2D 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
Elapsed Time: 01:12
blockmap-8C-3Q0-915-183-E_WVWZZZ3CZME009325-20260823-2134.CSV
;SW:3Q0-915-183-E   HW:3Q0-915-183-D ---  8C: HV Battery
;Component:J840 K8C  BMC 004 0940, Coding:
;EV_BMCeVWBSMQB48,001007,EV_BMCeVWBSMQB48_VW48.rod
;Sunday,23,August,2026,21:34:54:32152
;VCID: 343A73AAFEBCB62A0AA-8060
IDE00010,Serial number,00000009062004010044,
IDE00019,Voltage terminal 30,12.849, V
IDE00056,History data 1,6,
IDE00056,History data 1,48,
IDE00056,History data 1,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 02 92 46|00 03 F3 CE|00 04 A7 BB|00 00 AE EA|00 00 00 00|00 00 00 00|00 EC 8F EC|01 0D F1 9F|01 39 55 7F|00 7D 22 50|00 3F 9B C7|00 00 00 00|01 46 5A CA|01 3E AD 66|01 41 BC C0|00 E4 CB 7E|00 E7 EF 14|00 00 00 00|00 0B 27 CD|00 0A 34 E7|00 10 B4 2A|00 0C 23 FE|00 05 86 6B|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00056,History data 1,0,
IDE00057,History data 2,8,
IDE00057,History data 2,64,
IDE00057,History data 2,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 21 FC|00 00 12 08|00 00 11 1A|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 2D C5 7D|00 14 82 51|00 17 69 3C|00 08 20 BD|00 01 07 3E|00 00 00 00|00 00 00 00|00 00 00 00|00 8F 6C C7|00 40 22 0A|00 38 92 27|00 1C F7 46|00 05 79 B2|00 00 E0 1F|00 00 00 00|00 00 00 00|00 15 2F EB|00 0A D2 58|00 07 D3 E9|00 03 C4 6F|00 00 E9 94|00 00 40 12|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00058,History data 3,8,
IDE00058,History data 3,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 27 F9|00 00 42 19|00 00 28 35|00 00 11 84|00 00 0A A9|00 00 02 5E|00 00 00 00|00 00 00 00|00 5E 6D C6|00 34 A2 25|00 38 CE 74|00 18 E6 4B|00 0C 0E BD|00 03 91 8F|00 00 0C C9|00 00 00 00|01 66 10 C9|00 83 98 3E|00 A5 16 D8|00 38 2B CC|00 20 08 E6|00 09 AC 2B|00 00 44 0D|00 00 00 00|00 29 FB 72|00 0E 37 C0|00 0F E7 D2|00 05 3F 5C|00 03 4B 32|00 00 FB 2B|00 00 08 9A|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00058,History data 3,0,
IDE00059,History data 4,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 49|00 00 54 4F|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 02 A0 A5|00 84 F6 F9|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|02 7F 12 B1|05 25 61 F9|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 13 F5 05|00 38 F5 F1|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00059,History data 4,0,
IDE00060,History data 5,||00 00 00 00|00 22 65 E4|00 23 D5 15|00 29 60 E9|00 22 D1 BE|00 05 F5 45|,
IDE00060,History data 5,0,
IDE00061,History data 6,10,
IDE00061,History data 6,2,
IDE00061,History data 6,||00 04 65 48|00 00 43 38|00 00 24 39|00 00 03 35|00 00 00 17|00 00 00 08|00 00 00 05|00 00 00 00|00 00 00 00|00 00 00 00|00 04 79 0C|00 00 08 D9|00 00 02 F5|00 00 00 57|00 00 00 0E|00 00 00 02|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00061,History data 6,0,
IDE00062,History data 7,||00 00|00 00|00 00|00 00|00 00|00 00|00 0E|00 27|00 30|00 33|01 D7|00 13|00 22|00 2D|01 CF|00 15|00 21|00 74|00 2F|00 30|00 15|,
IDE00062,History data 7,0,
IDE00062,History data 7,21,
IDE00064,History data 9,96,
IDE00064,History data 9,||00 18 91 AF|00 1C 95 5C|00 19 CB 3A|00 1A 40 99|00 1C 27 45|00 1C 2F 3E|00 1B DC 20|00 1B 7F 12|00 1B F2 2A|00 1A FC F3|00 1A 5E 53|00 1A 45 56|00 1A C0 35|00 1C 89 CB|00 1A BB EF|00 1C 56 B0|00 1B 01 A8|00 1C 03 82|00 1B 4E C9|00 18 C1 69|00 1B 00 80|00 1B B0 74|00 1A 2F E2|00 1B C6 EE|00 1A 11 48|00 1B 49 0F|00 1A C6 A1|00 1C E4 FD|00 1A 57 0E|00 1A CB 00|00 19 8B D9|00 1A DB A2|00 19 45 3F|00 1D 46 47|00 17 23 BC|00 1A 58 88|00 19 9A CE|00 1B 23 8D|00 1A 62 2E|00 1B 27 A5|00 1A ED AA|00 1A 8F 23|00 1A 98 78|00 1A 95 2A|00 1A EA 9D|00 1A 26 12|00 1A D4 FB|00 1C 3D E0|00 19 A5 A2|00 1B E4 82|00 1A F0 3F|00 1C 51 DD|00 1A C8 CD|00 1C 35 3A|00 1C 87 57|00 19 D7 9C|00 1A EE 18|00 1A 82 12|00 1B F5 C2|00 1C 06 AF|00 1B 99 DA|00 1B D5 D4|00 1A 81 60|00 1C 70 AF|00 1A 82 04|00 19 DB CC|00 1A 07 30|00 1B D6 2B|00 1A 7E 8E|00 1B 7A B7|00 1A EB 5C|00 19 21 F6|00 1A 94 44|00 19 A1 E2|00 19 27 08|00 19 BD 91|00 1A B2 01|00 1B 58 D8|00 1A 4C AB|00 1A F5 82|00 19 C6 7E|00 1B 3E 91|00 18 AA 87|00 1C 33 8C|00 1A 9A 18|00 1A 94 27|00 1B 7A BC|00 1B 4E 79|00 1A BC 8F|00 1A CB 31|00 1A 19 DB|00 1A 32 4C|00 1A F8 7B|00 1B 60 2A|00 1A B5 24|00 1A 8A CE|,
IDE00065,History data 10,10,
IDE00065,History data 10,||09 AE 77 C0|01 12 94 16|00 6E 19 7D|00 1D 49 CC|00 00 06 EF|00 00 00 01|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00066,History data 11,16,
IDE00066,History data 11,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00066,History data 11,0,
IDE00067,History data 12,16,
IDE00067,History data 12,2,
IDE00067,History data 12,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00067,History data 12,0,
IDE00068,History data 13,||00 00 10 7C|00 00 00 71|00 00 00 6B|00 00 00 34|00 00 00 0F|00 00 00 0B|00 00 00 10|00 00 00 3E|,
IDE00068,History data 13,0,
IDE00069,History data 14,||A5|A4|A5|A5|A4|A4|A4|A5|A4|A5|A5|A5|A4|A5|A4|A4|A4|A5|A4|A4|A5|A4|A5|A5|A5|A5|A5|A5|A5|A4|A5|A5|A5|A4|A5|A5|A5|A5|A5|A5|A5|A5|A5|A5|A5|A5|A5|A5|A6|A5|A5|A5|A5|A5|A4|A5|A5|A5|A4|A5|A5|A4|A6|A4|A5|A6|A5|A5|A5|A5|A5|A6|A5|A5|A6|A5|A5|A5|A5|A5|A5|A4|A5|A4|A4|A4|A5|A4|A5|A4|A5|A4|A4|A5|A4|A4|,
IDE00069,History data 14,A4 00,
IDE00069,History data 14,0,
IDE00070,History data 15,40,
IDE00070,History data 15,320,
IDE00070,History data 15,8,
IDE00070,History data 15,||00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|,
IDE00071,History data 16,00 00,
IDE00071,History data 16,FF,
IDE00071,History data 16,01 6F,
IDE00071,History data 16,00 79,
IDE00071,History data 16,8B,
IDE00071,History data 16,1,
IDE00961-MAS05695,Exhaust emissions warning lamp-Start request,not active,
IDE00973,Outside temperature,26.500, °C
IDE01021,Current of H-V / hybrid battery,-0.820, A
IDE01028-MAS01422,Air temperature of H-V / hybrid battery-Intake,28.500, °C
IDE01028-MAS01423,Air temperature of H-V / hybrid battery-Exhaust,28.000, °C
IDE01028-MAS18294,Air temperature of H-V / hybrid battery-Outlet 2,28.000, °C
IDE01028-MAS18295,Air temperature of H-V / hybrid battery-Intake 2,28.500, °C
IDE01036-MAS01375,High voltage / Hybrid Battery history data 1-Counter for amp hour charge,39589.353, Ah
IDE01036-MAS01376,High voltage / Hybrid Battery history data 1-Counter for amp hour discharge,-38958.409, Ah
IDE01036-MAS01377,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour charge,14464.140, kWh
IDE01036-MAS01378,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour discharge,-13768.901, kWh
IDE01718,Crash signal,not active,
IDE01803,History data 17,||2B 2D|00 00|00 00|00 00|00 00|00 00|,
IDE01803,History data 17,0,
IDE01804,History data 18,8,
IDE01804,History data 18,||00 D1 89 9A|00 4B 6C 0C|02 52 51 1B|00 D1 FD 3F|01 8A 08 B5|00 91 0C 9A|00 00 18 65|00 00 0A E1|,
IDE01805,History data 19,7,
IDE01805,History data 19,||01 20 D0 97|00 FA 33 38|00 0F 3C FB|00 15 B8 4E|00 00 00 00|00 01 A6 A2|00 00 01 74|,
IDE01806,History data 20,7,
IDE01806,History data 20,||13 47 1B A6|10 0C 5C 68|01 36 E5 20|01 E3 50 2A|00 00 00 00|00 20 6B E5|00 00 1E 0F|,
IDE01838,Battery temperature,29.500, °C
IDE01839,Battery charge status,93.600, %
IDE03410-MAS05695,Yellow warning lamp-Start request,not active,
IDE03411-MAS05695,Red warning lamp-Start request,not active,
IDE05416,H-V battery insulation measurement test voltage,500, V
IDE05417,Serial number of H-V / hybrid battery,288 XX10000CGR6,
IDE05963,ASSY part number,3Q0915590M  ,
IDE06346,H-V battery voltage,391.000, V
IDE06404,Pilot line,not active,
IDE06422-ENG106773,IUMPR_1-General_Denominator,2584,
IDE06422-ENG106916,IUMPR_1-Ignition_Cycle_Counter,9244,
IDE06422-ENG100120,IUMPR_1-Milage,135860, km
IDE06422-ENG128699,IUMPR_1-Number_of_IUMPR_Records,102,
IDE06423-ENG128703,IUMPR_2-Denominator_to_DFCC_ID2_2,2584,
IDE06423-ENG128701,IUMPR_2-DFCC_Value_to_Record_ID2_1,39274,
IDE06423-ENG128702,IUMPR_2-Numerator_to_DFCC_ID2_2,8783,
IDE06423-ENG128700,IUMPR_2-Recordnumber_uneven,1,
IDE06424-ENG128707,IUMPR_3-Denominator_to_DFCC_ID3_2,2584,
IDE06424-ENG128705,IUMPR_3-DFCC_value_of_record_ID_3_2,39276,
IDE06424-ENG128706,IUMPR_3-Numerator_to_DFCC_ID3_2,8783,
IDE06424-ENG128704,IUMPR_3-Recordnumber_even,2,
IDE06673,Initialization status,not active,
IDE06805,Status of voltage freedom,high-voltage de-energization not detected,
IDE06948,High-volt. battery mode: spec. value,Driving mode,
IDE06973,Power reduction status,not active,
IDE07044-MAS01420,Predictive limit for charge current-Limit for charge current,3, A
IDE07045-MAS01420,Dynamic limit for charge current-Limit for charge current,30, A
IDE07227-IDE01024,Voltage in H-V system-Voltage of hybrid battery after protection,390.500, V
IDE07227-MAS05684,Voltage in H-V system-Voltage at power electronics,391.250, V
IDE07227-MAS05685,Voltage in H-V system-Voltage at high-voltage charging device,391, V
IDE08215,Current 2 of H-V / hybrid battery,-0.880, A
IDE08217-MAS01234,maximum voltage for battery cells-Index 1,11,
IDE08217-MAS02985,maximum voltage for battery cells-Value,4.079, V
IDE08218-MAS01234,minimum voltage for battery cells-Index 1,92,
IDE08218-MAS02985,minimum voltage for battery cells-Value,4.070, V
IDE08230-MAS01421,Dynamic limit for discharge current-Limit for discharge current,282, A
IDE08231-MAS01421,Predictive limit for discharge current-Limit for discharge current,78, A
IDE11985,Expected OBD requirements,EOBD,
IDE14477,Traction battery: China serial number,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE15769-MAS00155,Battery: synchronous current/voltage measurement: counter-Synchronous operation,254688397,
IDE15769-MAS12545,Battery: synchronous current/voltage measurement: counter-Send attempt: status,254780586,
IDE80253,Voltage terminal 30C,12.773, V
MAS00464-MAS00110,Standard - ambient data 1-Minutes,34,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00474,Counter over-run,3A 0D,
MAS01302,Protection of posit. terminal of high voltage / hybrid battery,closed,
MAS01303,Protection of neg. terminal of high voltage / hybrid battery,closed,
MAS02199-MAS01966,Lowest measured temperature-Temperature sensor,4,
MAS02199-MAS02985,Lowest measured temperature-Value,28.500, °C
MAS02200-MAS01966,Highest measured temperature-Temperature sensor,2,
MAS02200-MAS02985,Highest measured temperature-Value,29.500, °C
MAS04266,Temperature sensor 1,29.000, °C
MAS04267,Temperature sensor 2,29.500, °C
MAS04268,Temperature sensor 3,29.000, °C
MAS04269,Temperature sensor 4,28.500, °C
MAS04270,Temperature sensor 5,28.500, °C
MAS04271,Temperature sensor 6,29.000, °C
MAS04272,Temperature sensor 7,29.500, °C
MAS04273,Temperature sensor 8,29.000, °C
MAS04291,Positive voltage of high volt battery after protection,390.969, V
MAS04293-MAS01632,Entire HV system positive terminal insulation resistance-Status,Measurement running: please wait,
MAS04293,Entire HV system positive terminal insulation resistance,10000, kOhm
MAS04294-MAS01632,HV battery positive terminal insulation resistance-Status,invalid,
MAS04294,HV battery positive terminal insulation resistance,10000, kOhm
MAS04295-MAS01632,Entire HV system minus terminal insulation resistance-Status,Measurement running: please wait,
MAS04295,Entire HV system minus terminal insulation resistance,10000, kOhm
MAS04296-MAS01632,HV battery minus terminal insulation resistance-Status,invalid,
MAS04296,HV battery minus terminal insulation resistance,10000, kOhm
MAS04649,Cell 1,4.076, V
MAS04650,Cell 2,4.075, V
MAS04651,Cell 3,4.074, V
MAS04652,Cell 4,4.076, V
MAS04653,Cell 5,4.075, V
MAS04654,Cell 6,4.074, V
MAS04655,Cell 7,4.074, V
MAS04656,Cell 8,4.074, V
MAS04657,Cell 9,4.074, V
MAS04658,Cell 10,4.075, V
MAS04659,Cell 11,4.078, V
MAS04660,Cell 12,4.077, V
MAS04661,Cell 13,4.074, V
MAS04662,Cell 14,4.075, V
MAS04663,Cell 15,4.077, V
MAS04664,Cell 16,4.074, V
MAS04665,Cell 17,4.076, V
MAS04666,Cell 18,4.075, V
MAS04667,Cell 19,4.074, V
MAS04668,Cell 20,4.073, V
MAS04669,Cell 21,4.076, V
MAS04670,Cell 22,4.076, V
MAS04671,Cell 23,4.076, V
MAS04672,Cell 24,4.075, V
MAS04673,Cell 25,4.076, V
MAS04674,Cell 26,4.076, V
MAS04675,Cell 27,4.077, V
MAS04676,Cell 28,4.073, V
MAS04677,Cell 29,4.074, V
MAS04678,Cell 30,4.077, V
MAS04679,Cell 31,4.075, V
MAS04680,Cell 32,4.075, V
MAS04681,Cell 33,4.076, V
MAS04682,Cell 34,4.074, V
MAS04683,Cell 35,4.076, V
MAS04684,Cell 36,4.075, V
MAS04685,Cell 37,4.077, V
MAS04686,Cell 38,4.077, V
MAS04687,Cell 39,4.077, V
MAS04688,Cell 41,4.076, V
MAS04689,Cell 42,4.076, V
MAS04690,Cell 43,4.077, V
MAS04691,Cell 44,4.076, V
MAS04692,Cell 45,4.076, V
MAS04693,Cell 46,4.075, V
MAS04694,Cell 47,4.079, V
MAS04695,Cell 48,4.076, V
MAS04696,Cell 49,4.077, V
MAS04697,Cell 50,4.075, V
MAS04698,Cell 51,4.077, V
MAS04699,Cell 52,4.075, V
MAS04700,Cell 53,4.076, V
MAS04701,Cell 54,4.075, V
MAS04702,Cell 55,4.076, V
MAS04703,Cell 56,4.075, V
MAS04704,Cell 57,4.075, V
MAS04705,Cell 58,4.074, V
MAS04706,Cell 59,4.075, V
MAS04707,Cell 60,4.074, V
MAS04708,Cell 61,4.075, V
MAS04709,Cell 62,4.075, V
MAS04710,Cell 63,4.076, V
MAS04711,Cell 64,4.076, V
MAS04712,Cell 65,4.076, V
MAS04713,Cell 66,4.075, V
MAS04714,Cell 67,4.077, V
MAS04715,Cell 68,4.075, V
MAS04716,Cell 69,4.075, V
MAS04717,Cell 70,4.076, V
MAS04718,Cell 71,4.076, V
MAS04719,Cell 72,4.076, V
MAS04720,Cell 40,4.076, V
MAS04721-MAS01234,Minimum charge level-Index 1,92,
MAS04721-MAS02985,Minimum charge level-Value,92.750, %
MAS04722-MAS01234,Maximum charge level-Index 1,47,
MAS04722-MAS02985,Maximum charge level-Value,93.440, %
MAS06761,Sum of voltage of all battery cells,391.219, V
MAS07735,Cell 73,4.075, V
MAS07736,Cell 74,4.075, V
MAS07737,Cell 75,4.076, V
MAS07738,Cell 76,4.075, V
MAS07739,Cell 77,4.076, V
MAS07740,Cell 78,4.075, V
MAS07741,Cell 79,4.075, V
MAS07742,Cell 80,4.075, V
MAS07743,Cell 81,4.075, V
MAS07744,Cell 82,4.076, V
MAS07745,Cell 83,4.075, V
MAS07746,Cell 84,4.075, V
MAS07747,Cell 85,4.074, V
MAS07748,Cell 86,4.073, V
MAS07749,Cell 87,4.075, V
MAS07750,Cell 88,4.073, V
MAS07751,Cell 89,4.075, V
MAS07752,Cell 90,4.073, V
MAS07753,Cell 91,4.076, V
MAS07754,Cell 92,4.070, V
MAS07755,Cell 93,4.074, V
MAS07756,Cell 94,4.074, V
MAS07757,Cell 95,4.073, V
MAS07758,Cell 96,4.073, V
MAS07792,Expanded battery limits,not active,
MAS07798,Status pre-loader,Open,
MAS07804,Pump for HV battery coolant: specified speed value,0, %
MAS07826,Request emergency discharge HV intermittent circuit condenser,not active,
MAS07827,Mode HV battery actual value,Driving mode,
MAS09283,HV interlock detector voltage,0.901, V
MAS09284,HV interlock source voltage,1.781, V
MAS09285,HV interlock detector current,10.869, mA
MAS09286,HV interlock source current,11.188, mA
Elapsed Time: 00:19
blockmap-A5-2Q0-980-653_WVWZZZ3CZME009325-20260823-2135.CSV
;SW:2Q0-980-653   HW:2Q0-980-653 ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H11 1030, Coding:00000888214C4020109E10001030008000418000000000000000000000000000
;EV_MFK3ValeoMQB,005035,EV_MFK3ValeoMQB_005_VW27.rod
;Sunday,23,August,2026,21:35:20:32152
;VCID: 72B6B5B2C428F81AD86-8026
IDE00018,Voltage terminal 15,13.2, V
IDE00973,Outside temperature,26.5, °C
IDE01968,Dynamic calibration: yaw angle offset,0.039, °
IDE01969,Dynamic calibration: pitch angle offset,-0.470, °
IDE01970,Dynamic calibration: roll angle offset,0.181, °
IDE01971,Lowest recorded control module temperature,-40, °C
IDE01972,Highest recorded control module temperature,86, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,0 s,
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Actuator test terminated due to client request,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Actuator test terminated due to client request,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,0 s,
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Actuator test terminated due to client request,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,0 s,
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Actuator test terminated due to client request,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02486,Data logger triggering,not initialized,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,0 s,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Actuator test terminated due to client request,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,11460, km
IDE03948-MAS01167,High beam recommendation-Actuation time,0 s,
IDE03948-MAS08863,High beam recommendation-Status of actuator test,Actuator test terminated due to client request,
IDE04036-MAS01632,High beam assistant: status-Status,not active,
IDE04036-MAS17492,High beam assistant: status-Switching state,OFF,
IDE04036-MAS17493,High beam assistant: status-Sensor view,Not assigned,
IDE04036-MAS17494,High beam assistant: status-Higher sensitivity active,No,
IDE04123-MAS01480,High beam: reason for shut-off-excessive temperature,No,
IDE04123-MAS06833,High beam: reason for shut-off-Ambient brightness too high,No,
IDE04123-MAS06846,High beam: reason for shut-off-Location detected,No,
IDE04123-MAS14875,High beam: reason for shut-off-Fog detected,No,
IDE04123-MAS17489,High beam: reason for shut-off-Oncoming vehicle detected,No,
IDE04123-MAS17490,High beam: reason for shut-off-Vehicle ahead detected,No,
IDE04123-MAS17491,High beam: reason for shut-off-Speed not achieved,No,
IDE04123,High beam: reason for shut-off,0,
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Unknown (1)
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.00, Nm
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,0 s,
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Actuator test terminated due to client request,
IDE05814,Individualization characteristic,68 4B 71 3D 47,
IDE06592-MAS00478,Status: special functions-Reserved,00,
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06786,Component protection properties-SSW RND Generation,used,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE07214,Dynamic calibration: camera height offset,20, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,1023, m
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,1023, m
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,0.000000, °
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,0.000000, °
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,-16.000000, °
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,-16.000000, °
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0.00, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0.00, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Right hand driv.,
IDE09492-MAS11790,Temperatures-Control Module temperature,48, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,52, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,50, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10403,Current initial calibration: status,Initial static calibration KD OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0,
IDE10406-MAS00106,Last initial calibrations: details-Year,2024,
IDE10406-MAS00107,Last initial calibrations: details-Month,10,
IDE10406-MAS00108,Last initial calibrations: details-Day,14,
IDE10406-MAS00109,Last initial calibrations: details-Hours,9,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,26,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,0,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2024,
IDE10664-MAS00107,Current initial calibration: details-Month,10,
IDE10664-MAS00108,Current initial calibration: details-Day,14,
IDE10664-MAS00109,Current initial calibration: details-Hours,9,
IDE10664-MAS00110,Current initial calibration: details-Minutes,26,
IDE10664-MAS00111,Current initial calibration: details-Seconds,0,
IDE10664-MAS00711,Current initial calibration: details-kilometer reading,98207,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WVWZZZ3CZME009325,
IDE10664,Current initial calibration: details,00110011 ,
IDE10664,Current initial calibration: details,00111111 ,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,1.056, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,-0.087, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-0.093, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1308, mm
IDE12939-MAS02643,Public key for SWaP function (3072)-Key,A1 3C 3F 3E DB 3B C7 26 46 C8 A4 60 86 76 E2 B2 7C 49 E0 E1 7A 1D 94 D7 C5 3B C1 67 2D A4 14 CC CE 63 6F 13 57 0D FE 90 D7 72 D3 56 2B 8C 68 43 6E 73 E2 EE 50 F7 11 EE 51 46 49 F7 16 0E CB 5B 98 D2 66 93 17 79 C4 43 92 9A A9 A5 57 8A EC F1 CD FC 78 C7 97 B0 84 0E A8 B0 B0 FF 3C 28 8C 12 45 E1 7D 0E 3B 73 4E DD DF 49 90 9E 8E 8C 19 6A A7 F7 AC D9 2C 26 5D B5 E4 B2 68 17 B3 C3 76 73 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,646.96, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,569.29, px
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1465.24, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1465.24, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.000468891,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.000363679,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.000638848,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.00,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2400.00, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,825.00, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1516.00, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2400.00, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-825.00, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1516.00, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2400.00, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,825.00, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,856.00, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2400.00, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-825.00, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,856.00, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,0.8, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,-0.2, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,700.00, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,700.00, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,710.00, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,710.00, mm
IDE13998,Distance to calibration field: stored values,1500.00, mm
IDE14000,Windshield defogger camera: activation status,OFF,
MAS01634-MAS09193,Supply voltage-PLA,13.2, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,0.9, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.0, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.8, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,0.0, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,0.0, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17473,Functional state and lane boundary information,0,
MAS19593-MAS01167,Upload for expanded static navigation data activation-Actuation time,0 s,
MAS19593-MAS08863,Upload for expanded static navigation data activation-Status of actuator test,Actuator test terminated due to client request,
MAS19594-MAS01167,Upload for expanded dynamic navigation data activation-Actuation time,0 s,
MAS19594-MAS08863,Upload for expanded dynamic navigation data activation-Status of actuator test,Actuator test terminated due to client request,
ENG152732-MAS06854,CRC32 Checksum of FAZIT Identification String-Version,81,
ENG152732-MAS06855,CRC32 Checksum of FAZIT Identification String-Test sum,9F B1 59 0C,
ENG106922,Immobilizer - Challenge,FE B7 FF A8,
ENG185847-MAS01167,Light_assist_blockage_detection-Actuation time,0 s,
ENG185847-MAS08863,Light_assist_blockage_detection-Status of actuator test,Actuator test terminated due to client request,
ENG185858-MAS01167,Light_assist_self_glare_detection-Actuation time,0 s,
ENG185858-MAS08863,Light_assist_self_glare_detection-Status of actuator test,Actuator test terminated due to client request,
ENG185848-MAS01167,Main_beam_defect_message-Actuation time,0 s,
ENG185848-MAS08863,Main_beam_defect_message-Status of actuator test,Actuator test terminated due to client request,
ENG251654-MAS01167,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251654-MAS08863,REM_Dynamic_EyeQ_Data_Test_Trigger_status-Status of actuator test,Actuator test terminated due to client request,
ENG251655-MAS01167,REM_Static_EyeQ_Data_Test_Trigger_status-Actuation time,0 s,
ENG251655-MAS08863,REM_Static_EyeQ_Data_Test_Trigger_status-Status of actuator test,Actuator test terminated due to client request,
ENG185865-MAS01167,SAE_mode_activation-Actuation time,0 s,
ENG185865-MAS08863,SAE_mode_activation-Status of actuator test,Actuator test terminated due to client request,
Elapsed Time: 00:40
blockmap-A9-3G0-907-159_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:3G0-907-159   HW:4H0-907-159-A ---  A9: Struct. Borne Sound
;Component:SAS-GEN 2     H07 0006, Coding:
;EV_SoundActuaGen2AU64X,003010,EV_SoundActuaGen2AU64X_003_VW48.rod
;Sunday,23,August,2026,21:36:14:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 6984D2DEE9FE3BC269C-803C
Group,Description,Actual
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Actual value,0,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
Elapsed Time: 00:00
blockmap-BB-5Q0-959-595-K_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:5Q0-959-595-K   HW:8W1-959-595-D ---  BB: Door Rear Drv
;Component:TSG HFS004 0330, Coding:000E01200100020000001000
;EV_DCU2RearDriveMAXHKLO,001018,EV_DCU2RearDriveMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:36:21:32152
;VCID: 4BC808568342C9D27B0-801E
IDE00310,Outside temperature,26.50, °C
IDE01766-MAS02248,Distance impulses-Signal status,Not available,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,12.80, V
IDE04580,Dimming of inside door handle lighting,100, %
IDE04581,Dimming for interior ambient lighting,Not available,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: released,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,14, %
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.50, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,0, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Top position,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06621,Driver side rear power window button,Not operated,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,Not available,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Activation,Yes,
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,26, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE08205-MAS01453,Closing aid-Blocking detection,not active,
IDE08205-MAS02103,Closing aid-Signal from door lock: catch,Implausible,
IDE08205-MAS05370,Closing aid-Direction of movement,Not available,
IDE08205-MAS08613,Closing aid-Return contact,closed,
IDE08205-MAS08614,Closing aid-Closing assist motor current,Not available,
IDE08205-MAS09346,Closing aid-Door position,closed,
IDE08205-MAS09347,Closing aid-Redundant door contact,not installed,
IDE08795,Rear shade button,not installed,
IDE09277-MAS02040,Side window shade: driver side rear-Anti-play protection,Yes,
IDE09277-MAS02282,Side window shade: driver side rear-Position,Not available,
IDE09277-MAS04337,Side window shade: driver side rear-Engine current,Not available,
IDE09277-MAS05563,Side window shade: driver side rear-Standardization,No,
IDE09277-MAS06528,Side window shade: driver side rear-Release status,No,
IDE09277-MAS08533,Side window shade: driver side rear-Comfort enable status,No,
IDE09277-MAS08535,Side window shade: driver side rear-Movement status,Idle state,
IDE09301-IDE02266,Window lifter control panel driver side rear-Passenger side rear power window button,not installed,
IDE09301-IDE06621,Window lifter control panel driver side rear-Driver side rear power window button,not installed,
IDE09301-MAS08615,Window lifter control panel driver side rear-Rear sunroof,not installed,
IDE09301-MAS08616,Window lifter control panel driver side rear-Rear roof shade,not installed,
IDE12335-IDE12338,Door heating element 1-Sensor for door heating element 1,not installed,
IDE12335-MAS03095,Door heating element 1-Function status,not installed,
IDE12335-MAS04136,Door heating element 1-Current,not installed,
IDE12335-MAS09022,Door heating element 1-PWM value,not installed,
IDE12336-IDE12474,Door heating element 2-Sensor for door heating element 2,not installed,
IDE12336-MAS03095,Door heating element 2-Function status,not installed,
IDE12336-MAS04136,Door heating element 2-Current,not installed,
IDE12336-MAS09022,Door heating element 2-PWM value,not installed,
IDE13421-IDE06842,Memory seat adjustment control panel-Status - Button 1,not installed,
IDE13421-IDE06843,Memory seat adjustment control panel-Status - Button 2,not installed,
IDE13421-IDE06844,Memory seat adjustment control panel-Status - Button 3,not installed,
IDE13421-IDE06845,Memory seat adjustment control panel-Status - Button 4,not installed,
IDE13421-MAS05766,Memory seat adjustment control panel-Status of button for seat position storing,not installed,
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Unknown (6)
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE14109-MAS14614,Excess temperature shutdown of close assist-Switch-on threshold,Not available,
IDE14109-MAS15599,Excess temperature shutdown of close assist-Counter reading,Not available,
IDE14109,Excess temperature shutdown of close assist,not active,
IDE15344,Light output 1 pin C3 target brightness on rear driver side,Not available,
IDE15345,Light output 2 pin C1 target brightness on rear driver side,Not available,
IDE15346,Light output 3 pin B1 target brightness on rear driver side,Not available,
IDE15347,Light output 4 pin C12 target brightness on rear driver side,Not available,
MAS06010,Ambient light,41, %
Elapsed Time: 00:07
blockmap-BC-5Q0-959-595-K_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:5Q0-959-595-K   HW:8W1-959-595-D ---  BC: Door Rear Pass
;Component:TSG HBFS004 0330, Coding:000E01200100020000001000
;EV_DCU2RearPasseMAXHKLO,001018,EV_DCU2RearPasseMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:36:39:32152
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,12.90, V
IDE02266,Passenger side rear power window button,Not operated,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: released,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,0, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Top position,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06941,Rear window regulator child lock: frt.pass. side,Not available,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Activation,Yes,
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,26, °C
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,127.50, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE09259-MAS08489,Seat control unit frt. pass. side rear-Seat position,Implausible,
IDE09259-MAS08501,Seat control unit frt. pass. side rear-Position of backrest,Implausible,
IDE09278-MAS02040,Side window shade: frt.pass. side rear-Anti-play protection,Yes,
IDE09278-MAS02282,Side window shade: frt.pass. side rear-Position,Not available,
IDE09278-MAS04337,Side window shade: frt.pass. side rear-Engine current,Not available,
IDE09278-MAS05563,Side window shade: frt.pass. side rear-Standardization,No,
IDE09278-MAS06528,Side window shade: frt.pass. side rear-Release status,No,
IDE09278-MAS08533,Side window shade: frt.pass. side rear-Comfort enable status,No,
IDE09278-MAS08535,Side window shade: frt.pass. side rear-Movement status,Idle state,
IDE09302-IDE02266,Window lifter control panel frt. pass. side rear-Passenger side rear power window button,not installed,
IDE09302-IDE06621,Window lifter control panel frt. pass. side rear-Driver side rear power window button,not installed,
IDE09302-MAS08615,Window lifter control panel frt. pass. side rear-Rear sunroof,not installed,
IDE09302-MAS08616,Window lifter control panel frt. pass. side rear-Rear roof shade,not installed,
IDE15348,Light output 1 pin C3 target brightness on rear passenger side,Not available,
IDE15349,Light output 2 pin C1 target brightness on rear passenger side,Not available,
IDE15350,Light output 3 pin B1 target brightness on rear passenger side,Not available,
IDE15351,Light output 4 pin C12 target brightness on rear passenger side,Not available,
Elapsed Time: 00:07
blockmap-C6-5QE-915-682-AR_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:5QE-915-682-AR   HW:5QE-915-682-AR ---  C6: Batt. Chrg.
;Component:OBC KOSTAL    H42 4031, Coding:115069222000
;EV_OBCSinglPhaseKLOMQB15P,001001,EV_OBCSinglPhaseKLOMQB15P_001_VW48.rod
;Sunday,23,August,2026,21:36:55:32152
;VCID: 1D6CB60E6D361762D54-8048
IDE00019,Voltage terminal 30,13.2, V
IDE00637,Intermediate circuit voltage,0.0, V
IDE00767,No. of unscheduled ECU resets,01,
IDE06954,Actual HV charge current,0, A
IDE06955-ENG114223,Target HV charge current-Charger_HV_current_commanded_value,0.0, A
IDE07975,Remote control for charging function of high-voltage battery,not activated,
IDE08421-IDE05431,Socket A for charging the battery-Lock for high-voltage charging connector,not locked,
IDE08421-MAS07220,Socket A for charging the battery-Status connect. recognition,Not available,
IDE08421-MAS07221,Socket A for charging the battery-Connector locking requirement,00000000 ,
IDE08421-MAS07222,Socket A for charging the battery-Connector unlocking requirement,00000000 ,
IDE08421-MAS07223,Socket A for charging the battery-Max. current of charge connector,0, A
IDE08421-MAS07565,Socket A for charging the battery-Activation charge cover lock charge socket A,not requested,
IDE08421-MAS07567,Socket A for charging the battery-Status charge cover lock charge socket A,locked,
IDE08421-MAS10983,Socket A for charging the battery-Activation charge cover unlock charge socket A,not requested,
IDE08421-MAS12565,Socket A for charging the battery-Charging socket temperature sensor AC,25.5, °C
IDE08421-MAS12566,Socket A for charging the battery-Charge socket temperature sensor DC,0.0, °C
IDE08422-IDE05431,Power outlet B for battery charging-Lock for high-voltage charging connector,not locked,
IDE08422-MAS07220,Power outlet B for battery charging-Status connect. recognition,Not available,
IDE08422-MAS07221,Power outlet B for battery charging-Connector locking requirement,00000000 ,
IDE08422-MAS07222,Power outlet B for battery charging-Connector unlocking requirement,00000000 ,
IDE08422-MAS07223,Power outlet B for battery charging-Max. current of charge connector,63, A
IDE08422-MAS07224,Power outlet B for battery charging-Temp. of charge socket,25.5, °C
IDE08422-MAS07566,Power outlet B for battery charging-Activation charge cover lock charge socket B,not requested,
IDE08422-MAS07568,Power outlet B for battery charging-Status: chg. cover lock. device: chg. socket B,locked,
IDE08423-MAS02949,Control signal for socket A for battery charging-Frequency,0, Hz
IDE08423-MAS02952,Control signal for socket A for battery charging-Control voltage,0, mV
IDE08423-MAS03873,Control signal for socket A for battery charging-Pulse duty factor,0.0, %
IDE08423-MAS04136,Control signal for socket A for battery charging-Current,0.0, A
IDE08423-MAS07262,Control signal for socket A for battery charging-Signal recognized,00000000 ,
IDE08424-MAS02949,Control signal for power outlet B for battery charging-Frequency,0, Hz
IDE08424-MAS02952,Control signal for power outlet B for battery charging-Control voltage,0, mV
IDE08424-MAS03873,Control signal for power outlet B for battery charging-Pulse duty factor,0.0, %
IDE08424-MAS04136,Control signal for power outlet B for battery charging-Current,0.0, A
IDE08424-MAS07262,Control signal for power outlet B for battery charging-Signal recognized,00000000 ,
IDE08425-MAS07225,Indicator lamps for socket A for battery charging-Status: indicator lamp 1,OFF,
IDE08425-MAS07226,Indicator lamps for socket A for battery charging-Status: indicator lamp 2,OFF,
IDE08425-MAS07227,Indicator lamps for socket A for battery charging-Status: indicator lamp 3,OFF,
IDE08425-MAS07228,Indicator lamps for socket A for battery charging-Intensity: indicator light 1,100, %
IDE08425-MAS07229,Indicator lamps for socket A for battery charging-Intensity: indicator light 2,100, %
IDE08425-MAS07230,Indicator lamps for socket A for battery charging-Intensity: indicator light 3,100, %
IDE08425-MAS07231,Indicator lamps for socket A for battery charging-Period duration: indicator light 1,2000, ms
IDE08425-MAS07232,Indicator lamps for socket A for battery charging-Period duration: indicator light 2,2000, ms
IDE08425-MAS07233,Indicator lamps for socket A for battery charging-Period duration: indicator light 3,2000, ms
IDE08425-MAS07582,Indicator lamps for socket A for battery charging-Intensity: activation 4,0, %
IDE08425-MAS07590,Indicator lamps for socket A for battery charging-Period duration: activation 4,0, ms
IDE08425-MAS13012,Indicator lamps for socket A for battery charging-Status: indicator lamp 4,OFF,
IDE08426-MAS07225,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 1,OFF,
IDE08426-MAS07226,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 2,OFF,
IDE08426-MAS07227,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 3,OFF,
IDE08426-MAS07228,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 1,100, %
IDE08426-MAS07229,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 2,100, %
IDE08426-MAS07230,Indicator lamps for power outlet B for battery charging-Intensity: indicator light 3,100, %
IDE08426-MAS07231,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 1,2000, ms
IDE08426-MAS07232,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 2,2000, ms
IDE08426-MAS07233,Indicator lamps for power outlet B for battery charging-Period duration: indicator light 3,2000, ms
IDE08426-MAS07582,Indicator lamps for power outlet B for battery charging-Intensity: activation 4,0, %
IDE08426-MAS07590,Indicator lamps for power outlet B for battery charging-Period duration: activation 4,0, ms
IDE08426-MAS13012,Indicator lamps for power outlet B for battery charging-Status: indicator lamp 4,OFF,
IDE08427-MAS07237,Statistics of power outlet A for battery charging-No. of connections,3210,
IDE08427-MAS07238,Statistics of power outlet A for battery charging-No. of lockings,3899,
IDE08428-MAS07237,Statistics of power outlet B for battery charging-No. of connections,0,
IDE08428-MAS07238,Statistics of power outlet B for battery charging-No. of lockings,0,
IDE08430,Cause of cancellation of charge procedure,not active,
IDE08431,Remaining time for charge procedure,0, min
IDE08432-MAS02158,Button for battery charging-Actuation condition,Not operated,
IDE08432-MAS04737,Button for battery charging-Indicator lamp,OFF,
IDE08638-MAS04721,SOC limits: set by customer-Minimum charge level,50, %
IDE08638-MAS04722,SOC limits: set by customer-Maximum charge level,0, %
IDE08639,max. loading power,0, W
IDE08640,Spec. mode: load mgmnt.,Standby,
IDE08649-IDE06971,Ready to charge-Operational readiness in high-voltage system,active,
IDE08649-MAS07214,Ready to charge-Status charge readiness: engine,operational,
IDE08649-MAS07215,Ready to charge-Status charge readiness charge mngmt.,operational,
IDE08659-MAS07237,Statistic of DC charger for battery charging-No. of connections,0,
IDE08659-MAS07238,Statistic of DC charger for battery charging-No. of lockings,0,
IDE08659-MAS07239,Statistic of DC charger for battery charging-No. of charging process.,0,
IDE08677-MAS07258,Load mode-Stat.: charge mode,no request,
IDE08677-MAS07259,Load mode-Chg. type,Immediate charging,
IDE08717,Status mains voltage,Not available,
IDE08719-IDE08720,Values from battery mgmt system-Current condition of battery mgmt. system,HV mains activ.,
IDE08719-MAS01420,Values from battery mgmt system-Limit for charge current,30, A
IDE08719-MAS04059,Values from battery mgmt system-Battery temperature,29.5, °C
IDE08719-MAS07289,Values from battery mgmt system-A/C requirement,no request,
IDE08719-MAS07396,Values from battery mgmt system-Actual voltage high-voltage battery,391.0, V
IDE08719-MAS07397,Values from battery mgmt system-Act. current HV battery,-0.8, A
IDE08719-MAS07407,Values from battery mgmt system-Max. battery charging voltage,402, V
IDE08751-MAS02158,Load button-Actuation condition,Not operated,
IDE08751-MAS04737,Load button-Indicator lamp,OFF,
IDE08751-MAS07596,Load button-Locating illum. charge button,OFF,
IDE08938,Chrgr cooling reqrmnt,no request,
IDE08985,AC line current: actual val,0.0, A
IDE08986,AC line voltage: actual val,0, V
IDE09039,HV charger - current output voltage,391, V
IDE09057,HV battery charge state,98.0, %
IDE11570-ENG161140,Activation periods of charging cover locking-raw_value_in_develop_by_ODXauthor,C8,
IDE11571-ENG161140,Voltage terminal 30 battery data module-raw_value_in_develop_by_ODXauthor,A3,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,23,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,36,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,125,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,136252, km
MAS06335-ENG161140,Voltage low voltage side DCDC - converter-raw_value_in_develop_by_ODXauthor,84,
MAS07396-ENG161140,Actual voltage high-voltage battery-raw_value_in_develop_by_ODXauthor,06 1B,
MAS07407-ENG161140,Max. battery charging voltage-raw_value_in_develop_by_ODXauthor,01 92,
MAS07558,Spec. charger operating condition,Standby,
MAS07559,Act. charger operating condition,Standby,
MAS07563,Function limitation charging due to temp. charge socket,not active,
MAS07564,Function limitation charging due to temp. charge unit,not active,
MAS12397-ENG161140,Number of lockings: charge cover A-raw_value_in_develop_by_ODXauthor,44 1B,
ENG125865,AC_maximum_input_current_value,0.0, A
ENG125867,AC_network_frequency,Initialization,
ENG125873,charger_coolant_temperature,25, °C
ENG123145-ENG123175,Charging_Connector_Locking_Parameter-delocking_request_time_CAN,0, ms
ENG123145-ENG123173,Charging_Connector_Locking_Parameter-delocking_time_lag,0, ms
ENG123145-ENG123174,Charging_Connector_Locking_Parameter-locking_delay_time,0, ms
ENG123145-ENG123176,Charging_Connector_Locking_Parameter-locking_time_lag,0, ms
ENG123142,charging_process_request,not requested,
ENG123144,charging_status,OFF,
ENG125862,current_voltage_protection,not active,
ENG123148,ekk_air_condition_current,0.0, A
ENG125863,error_status_battery_charger,not active,
ENG126556,gate_driver_voltage_DCDC,0.0, V
ENG126555,gate_driver_voltage_PFC,0.0, V
ENG126544,high_voltage_activation_request,not requested,
ENG123143,max_HV_DC_voltage_obc,402, V
ENG125870,power_efficiency,Initialization,
ENG125869,power_loss_battery_charger,0, W
ENG138720-ENG161140,prx_voltage_charging_connector_A-raw_value_in_develop_by_ODXauthor,10 06,
ENG123147,ptc_heater_current,0.0, A
ENG138719,temperature_battery_charger_PFC_coil,33, °C
ENG125871,temperature_battery_charger_system_board,45, °C
ENG125872,temperature_DCDC_coil,34, °C
ENG125876,temperature_DCDC_powerline,38, °C
ENG125864,warning_status_battery_charger,Warning active,
Elapsed Time: 00:08
blockmap-D6-992-941-572-CA_WVWZZZ3CZME009325-20260823-2137.CSV
;SW:992-941-572-CA   HW:992-941-572-C ---  D6: Light Ctrl Left 2
;Component:LED1L         H08 9002, Coding:
;EV_LLPGen3LKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_001_VW48.rod
;Sunday,23,August,2026,21:37:11:32152
;VCID: 649AC3EA0EDC66AA5AA-8030
IDE09774-MAS02923,Number of activations-Highway light,0,
IDE09774-MAS14159,Number of activations-Coming Home,0,
IDE09774-MAS14160,Number of activations-Leaving Home,0,
IDE09774-MAS18763,Number of activations-Headlight contour light,0,
IDE09774-ENG187780,Number of activations-additional highbeam,33,
IDE09774-ENG186684,Number of activations-All weather light,0,
IDE09774-ENG108961,Number of activations-Camera lock,0,
IDE09774-ENG186410,Number of activations-City light,0,
IDE09774-ENG186757,Number of activations-daytimerunning light,0,
IDE09774-ENG255608,Number of activations-design light 2,0,
IDE09774-ENG274344,Number of activations-design light 3,0,
IDE09774-ENG186554,Number of activations-Eco mode 1,0,
IDE09774-ENG186555,Number of activations-Eco mode 2,0,
IDE09774-ENG247934,Number of activations-Express light,0,
IDE09774-ENG187761,Number of activations-higbeam,34,
IDE09774-ENG186491,Number of activations-Low beam,353,
IDE09774-ENG186411,Number of activations-Parking light,1,
IDE09774-ENG186853,Number of activations-position light,318,
IDE09774-ENG186603,Number of activations-race mode,33,
IDE09774-ENG166761,Number of activations-Sidemarker,0,
IDE09774-ENG186659,Number of activations-Static cornering light,0,
IDE09774-ENG186553,Number of activations-Tourist light,0,
IDE09774-ENG187378,Number of activations-turn indicator,1644,
IDE10165-MAS02201,LED channel 1: Master 1-Temperature,200, °C
IDE10165-MAS04121,LED channel 1: Master 1-Voltage,0.00, V
IDE10165-MAS04136,LED channel 1: Master 1-Current,0, mA
IDE10165-MAS04625,LED channel 1: Master 1-Power: actual value,0, W
IDE10165-MAS09022,LED channel 1: Master 1-PWM value,0.0, %
IDE10165-MAS09326,LED channel 1: Master 1-Function,no function,
IDE10165-MAS09327,LED channel 1: Master 1-LED brightness class,Not Used,
IDE10165-ENG186571,LED channel 1: Master 1-Output,ERROR,
IDE10167-MAS02201,LED channel 1: Slave-Temperature,200, °C
IDE10167-MAS04121,LED channel 1: Slave-Voltage,0.00, V
IDE10167-MAS04136,LED channel 1: Slave-Current,0, mA
IDE10167-MAS04625,LED channel 1: Slave-Power: actual value,0, W
IDE10167-MAS09022,LED channel 1: Slave-PWM value,0.0, %
IDE10167-MAS09326,LED channel 1: Slave-Function,no function,
IDE10167-MAS09327,LED channel 1: Slave-LED brightness class,Not Used,
IDE10167-ENG186571,LED channel 1: Slave-Output,ERROR,
IDE10168-FSS01570,LED channel 2: Master-Temperature,52, °C
IDE10168-MAS02201,LED channel 2: Master-Temperature,0, mA
IDE10168-MAS04136,LED channel 2: Master-Current,0.00, V
IDE10168-MAS09022,LED channel 2: Master-PWM value,0.0, %
IDE10168-MAS09326,LED channel 2: Master-Function,Highbeam,
IDE10168-MAS09327,LED channel 2: Master-LED brightness class,LK2,
IDE10168-ENG186571,LED channel 2: Master-Output,LED,
IDE10168-ENG186891,LED channel 2: Master-output power,0, W
IDE10169-MAS02201,LED channel 2: Slave-Temperature,200, °C
IDE10169-MAS04121,LED channel 2: Slave-Voltage,0.00, V
IDE10169-MAS04136,LED channel 2: Slave-Current,0, mA
IDE10169-MAS04625,LED channel 2: Slave-Power: actual value,0, W
IDE10169-MAS09022,LED channel 2: Slave-PWM value,0.0, %
IDE10169-MAS09326,LED channel 2: Slave-Function,no function,
IDE10169-MAS09327,LED channel 2: Slave-LED brightness class,Not Used,
IDE10169-ENG186571,LED channel 2: Slave-Output,ERROR,
IDE10170-MAS02201,LED channel 3: Master-Temperature,31, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,15.00, V
IDE10170-MAS04136,LED channel 3: Master-Current,90, mA
IDE10170-MAS04625,LED channel 3: Master-Power: actual value,1, W
IDE10170-MAS09022,LED channel 3: Master-PWM value,12.8, %
IDE10170-MAS09326,LED channel 3: Master-Function,DRL & PO,
IDE10170-MAS09327,LED channel 3: Master-LED brightness class,LK1,
IDE10170-ENG186571,LED channel 3: Master-Output,LED,
IDE10171-FSS01570,LED channel 3: Slave-Temperature,200, °C
IDE10171-MAS02201,LED channel 3: Slave-Temperature,0, mA
IDE10171-MAS04136,LED channel 3: Slave-Current,0.00, V
IDE10171-MAS09022,LED channel 3: Slave-PWM value,0.0, %
IDE10171-MAS09326,LED channel 3: Slave-Function,no function,
IDE10171-MAS09327,LED channel 3: Slave-LED brightness class,Not Used,
IDE10171-ENG186571,LED channel 3: Slave-Output,ERROR,
IDE10171-ENG186891,LED channel 3: Slave-output power,0, W
IDE10205,Control module version,MAX_LWR_MQB,
IDE13678-MAS02201,LED channel 4: Master-Temperature,52, °C
IDE13678-MAS04121,LED channel 4: Master-Voltage,20.67, V
IDE13678-MAS04136,LED channel 4: Master-Current,816, mA
IDE13678-MAS04625,LED channel 4: Master-Power: actual value,17, W
IDE13678-MAS09022,LED channel 4: Master-PWM value,100.0, %
IDE13678-MAS09326,LED channel 4: Master-Function,lowbeam,
IDE13678-MAS09327,LED channel 4: Master-LED brightness class,LK2,
IDE13678-ENG186571,LED channel 4: Master-Output,LED,
IDE13898-MAS02201,LED channel 5: Master-Temperature,27, °C
IDE13898-MAS04121,LED channel 5: Master-Voltage,0.00, V
IDE13898-MAS04136,LED channel 5: Master-Current,0, mA
IDE13898-MAS04625,LED channel 5: Master-Power: actual value,0, W
IDE13898-MAS09022,LED channel 5: Master-PWM value,0.0, %
IDE13898-MAS09326,LED channel 5: Master-Function,turn indicator,
IDE13898-MAS09327,LED channel 5: Master-LED brightness class,LK1,
IDE13898-ENG186571,LED channel 5: Master-Output,WIPING-TI,
IDE13899-FSS01570,LED channel 6: Master-Temperature,32, °C
IDE13899-MAS02201,LED channel 6: Master-Temperature,468, mA
IDE13899-MAS04136,LED channel 6: Master-Current,3.00, V
IDE13899-MAS09022,LED channel 6: Master-PWM value,100.0, %
IDE13899-MAS09326,LED channel 6: Master-Function,mixed functionality,
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,LK2,
IDE13899-ENG186571,LED channel 6: Master-Output,MXB,
IDE13899-ENG186891,LED channel 6: Master-output power,2, W
IDE13900-FSS01570,LED channel 7: Master-Temperature,32, °C
IDE13900-MAS02201,LED channel 7: Master-Temperature,0, mA
IDE13900-MAS04136,LED channel 7: Master-Current,0.00, V
IDE13900-MAS09022,LED channel 7: Master-PWM value,0.0, %
IDE13900-MAS09326,LED channel 7: Master-Function,Highbeam,
IDE13900-MAS09327,LED channel 7: Master-LED brightness class,LK2,
IDE13900-ENG186571,LED channel 7: Master-Output,MXB,
IDE13900-ENG186891,LED channel 7: Master-output power,0, W
IDE13901-FSS01570,LED channel 8: Master-Temperature,32, °C
IDE13901-MAS02201,LED channel 8: Master-Temperature,468, mA
IDE13901-MAS04136,LED channel 8: Master-Current,0.00, V
IDE13901-MAS09022,LED channel 8: Master-PWM value,100.0, %
IDE13901-MAS09326,LED channel 8: Master-Function,lowbeam,
IDE13901-MAS09327,LED channel 8: Master-LED brightness class,LK2,
IDE13901-ENG186571,LED channel 8: Master-Output,MXB,
IDE13901-ENG186891,LED channel 8: Master-output power,0, W
IDE13902-MAS02201,LED channel 9: Master-Temperature,200, °C
IDE13902-MAS04121,LED channel 9: Master-Voltage,0.00, V
IDE13902-MAS04136,LED channel 9: Master-Current,0, mA
IDE13902-MAS04625,LED channel 9: Master-Power: actual value,0, W
IDE13902-MAS09022,LED channel 9: Master-PWM value,0.0, %
IDE13902-MAS09326,LED channel 9: Master-Function,no function,
IDE13902-MAS09327,LED channel 9: Master-LED brightness class,Not Used,
IDE13902-ENG186571,LED channel 9: Master-Output,ERROR,
IDE13903-MAS02201,LED channel 10: Master-Temperature,200, °C
IDE13903-MAS04121,LED channel 10: Master-Voltage,0.00, V
IDE13903-MAS04136,LED channel 10: Master-Current,0, mA
IDE13903-MAS04625,LED channel 10: Master-Power: actual value,0, W
IDE13903-MAS09022,LED channel 10: Master-PWM value,0.0, %
IDE13903-MAS09326,LED channel 10: Master-Function,no function,
IDE13903-MAS09327,LED channel 10: Master-LED brightness class,Not Used,
IDE13903-ENG186571,LED channel 10: Master-Output,ERROR,
IDE13904-FSS01570,LED channel 11: Master-Temperature,200, °C
IDE13904-MAS02201,LED channel 11: Master-Temperature,0, mA
IDE13904-MAS04136,LED channel 11: Master-Current,0.00, V
IDE13904-MAS09022,LED channel 11: Master-PWM value,0.0, %
IDE13904-MAS09326,LED channel 11: Master-Function,no function,
IDE13904-MAS09327,LED channel 11: Master-LED brightness class,Not Used,
IDE13904-ENG186571,LED channel 11: Master-Output,ERROR,
IDE13904-ENG186891,LED channel 11: Master-output power,0, W
IDE13905-MAS02201,LED channel 12: Master-Temperature,200, °C
IDE13905-MAS04121,LED channel 12: Master-Voltage,0.00, V
IDE13905-MAS04136,LED channel 12: Master-Current,0, mA
IDE13905-MAS04625,LED channel 12: Master-Power: actual value,0, W
IDE13905-MAS09022,LED channel 12: Master-PWM value,0.0, %
IDE13905-MAS09326,LED channel 12: Master-Function,no function,
IDE13905-MAS09327,LED channel 12: Master-LED brightness class,Not Used,
IDE13905-ENG186571,LED channel 12: Master-Output,ERROR,
ENG105152,AktiveDiagnoseSession,Extended Session,
ENG186146-ENG188375,DKL stepper motor-DKL_fault_position,not active,
ENG186146-ENG248062,DKL stepper motor-DKL_motor_position_in_degree,32, °
ENG186146-ENG187407,DKL stepper motor-DKL_motor_position_in_percent,100.0, %
ENG186146-ENG188280,DKL stepper motor-DKL_reference_run,nicht erfolgt,
ENG186146-ENG188233,DKL stepper motor-DKL_speed_adjustment,warm,
ENG186082-MAS02201,ECU Temperature-Temperature,47, °C
ENG186166-ENG188338,GLW stepper motor-GLW_fault_position,not active,
ENG186166-ENG187719,GLW stepper motor-GLW_motor_position_in_percent,0.0, %
ENG186166-ENG188477,GLW stepper motor-GLW_reference_run,nicht erfolgt,
ENG186166-ENG248013,GLW stepper motor-GLW_shutter_position_in_percent,200, %
ENG186166-ENG188478,GLW stepper motor-GLW_speed_adjustment,warm,
ENG186197,headlamp variant,8E,
ENG186197,headlamp variant,E0,
ENG186197-ENG186889,headlamp variant-dataset country variant,ECE,
ENG186197-ENG247966,headlamp variant-SOA Checking Status,Finished and OK,
ENG186197-ENG186964,headlamp variant-via CAN country variant,ECE,
ENG186197-ENG187223,headlamp variant-via CAN SOA variant,E0,
ENG186197-ENG187100,headlamp variant-via CAN SOA variant 2,8E,
ENG186198-MAS02201,highside channel 1-Temperature,0, mA
ENG186198-MAS09022,highside channel 1-PWM value,0.0, %
ENG186198-MAS09326,highside channel 1-Function,no function,
ENG186198-ENG186571,highside channel 1-Output,Not Used,
ENG186199-MAS02201,highside channel 2-Temperature,0, mA
ENG186199-MAS09022,highside channel 2-PWM value,0.0, %
ENG186199-MAS09326,highside channel 2-Function,no function,
ENG186199-ENG186571,highside channel 2-Output,Not Used,
ENG186200-MAS02201,highside channel 3-Temperature,270, mA
ENG186200-MAS09022,highside channel 3-PWM value,100.0, %
ENG186200-MAS09326,highside channel 3-Function,no function,
ENG186200-ENG186571,highside channel 3-Output,FAN 1,
ENG186201-MAS02201,highside channel 4-Temperature,0, mA
ENG186201-MAS09022,highside channel 4-PWM value,0.0, %
ENG186201-MAS09326,highside channel 4-Function,no function,
ENG186201-ENG186571,highside channel 4-Output,Not Used,
ENG186202-MAS18765,identification headlamp-Identification,15,
ENG186215-ENG188404,LWR stepper motor-LWR__speed_adjustment,warm,
ENG186215-ENG188356,LWR stepper motor-LWR_fault_position,not active,
ENG186215-ENG187101,LWR stepper motor-LWR_motor_position_in_mm,-39.00, mm
ENG186215-ENG187107,LWR stepper motor-LWR_motor_position_in_percent,60.0, %
ENG186215-ENG188443,LWR stepper motor-LWR_reference_run,erfolgt,
ENG157274-MAS14159,Operating time-Coming Home,0.00, H
ENG157274-MAS14160,Operating time-Leaving Home,0.00, H
ENG157274,Operating time,0.00, H
ENG157274,Operating time,24.60, H
ENG157274,Operating time,98.85, H
ENG157274,Operating time,3.47, H
ENG157274-ENG187780,Operating time-additional highbeam,0.05, H
ENG157274-ENG187666,Operating time-cornerlight,0.00, H
ENG157274-ENG187323,Operating time-Designlight,0.00, H
ENG157274-ENG255609,Operating time-designlight 2,0.00, H
ENG157274-ENG274345,Operating time-designlight 3,0.00, H
ENG157274-ENG186554,Operating time-Eco mode 1,0.00, H
ENG157274-ENG186555,Operating time-Eco mode 2,0.00, H
ENG157274-ENG186523,Operating time-Highbeam,0.06, H
ENG157274-ENG186491,Operating time-Low beam,24.17, H
ENG157274-ENG186603,Operating time-race mode,0.05, H
ENG157274-ENG166761,Operating time-Sidemarker,0.00, H
ENG157274-ENG166116,Operating time-Turn_indicator,1.78, H
ENG186104,Operating times in temperature ranges,98.85, H
ENG186104,Operating times in temperature ranges,0.00, H
ENG186228-MAS03378,production data headlamp-Supplier,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG186228-ENG187298,production data headlamp-partnumber headlamp,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG186228-ENG186473,production data headlamp-production date,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG186228-ENG98897,production data headlamp-Serial number,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
ENG186229-MAS09833,PWM value CH 1-LED 1,0.0, %
ENG186229-MAS09834,PWM value CH 1-LED 2,0.0, %
ENG186229-MAS09835,PWM value CH 1-LED 3,0.0, %
ENG186229-MAS09836,PWM value CH 1-LED 4,0.0, %
ENG186229-MAS09837,PWM value CH 1-LED 5,0.0, %
ENG186229-MAS09838,PWM value CH 1-LED 6,0.0, %
ENG186229-MAS09839,PWM value CH 1-LED 7,0.0, %
ENG186229-MAS09840,PWM value CH 1-LED 8,0.0, %
ENG186229-MAS09841,PWM value CH 1-LED 9,0.0, %
ENG186229-MAS09842,PWM value CH 1-LED 10,0.0, %
ENG186229-MAS09843,PWM value CH 1-LED 11,0.0, %
ENG186229-MAS09844,PWM value CH 1-LED 12,0.0, %
ENG186230-MAS09833,PWM value CH 10-LED 1,0.0, %
ENG186230-MAS09834,PWM value CH 10-LED 2,0.0, %
ENG186230-MAS09835,PWM value CH 10-LED 3,0.0, %
ENG186230-MAS09836,PWM value CH 10-LED 4,0.0, %
ENG186230-MAS09837,PWM value CH 10-LED 5,0.0, %
ENG186230-MAS09838,PWM value CH 10-LED 6,0.0, %
ENG186230-MAS09839,PWM value CH 10-LED 7,0.0, %
ENG186230-MAS09840,PWM value CH 10-LED 8,0.0, %
ENG186230-MAS09841,PWM value CH 10-LED 9,0.0, %
ENG186230-MAS09842,PWM value CH 10-LED 10,0.0, %
ENG186230-MAS09843,PWM value CH 10-LED 11,0.0, %
ENG186230-MAS09844,PWM value CH 10-LED 12,0.0, %
ENG186231-MAS09833,PWM value CH 11-LED 1,0.0, %
ENG186231-MAS09834,PWM value CH 11-LED 2,0.0, %
ENG186231-MAS09835,PWM value CH 11-LED 3,0.0, %
ENG186231-MAS09836,PWM value CH 11-LED 4,0.0, %
ENG186231-MAS09837,PWM value CH 11-LED 5,0.0, %
ENG186231-MAS09838,PWM value CH 11-LED 6,0.0, %
ENG186231-MAS09839,PWM value CH 11-LED 7,0.0, %
ENG186231-MAS09840,PWM value CH 11-LED 8,0.0, %
ENG186231-MAS09841,PWM value CH 11-LED 9,0.0, %
ENG186231-MAS09842,PWM value CH 11-LED 10,0.0, %
ENG186231-MAS09843,PWM value CH 11-LED 11,0.0, %
ENG186231-MAS09844,PWM value CH 11-LED 12,0.0, %
ENG186232-MAS09833,PWM value CH 12-LED 1,0.0, %
ENG186232-MAS09834,PWM value CH 12-LED 2,0.0, %
ENG186232-MAS09835,PWM value CH 12-LED 3,0.0, %
ENG186232-MAS09836,PWM value CH 12-LED 4,0.0, %
ENG186232-MAS09837,PWM value CH 12-LED 5,0.0, %
ENG186232-MAS09838,PWM value CH 12-LED 6,0.0, %
ENG186232-MAS09839,PWM value CH 12-LED 7,0.0, %
ENG186232-MAS09840,PWM value CH 12-LED 8,0.0, %
ENG186232-MAS09841,PWM value CH 12-LED 9,0.0, %
ENG186232-MAS09842,PWM value CH 12-LED 10,0.0, %
ENG186232-MAS09843,PWM value CH 12-LED 11,0.0, %
ENG186232-MAS09844,PWM value CH 12-LED 12,0.0, %
ENG186233-MAS09833,PWM value CH 2-LED 1,0.0, %
ENG186233-MAS09834,PWM value CH 2-LED 2,0.0, %
ENG186233-MAS09835,PWM value CH 2-LED 3,0.0, %
ENG186233-MAS09836,PWM value CH 2-LED 4,0.0, %
ENG186233-MAS09837,PWM value CH 2-LED 5,0.0, %
ENG186233-MAS09838,PWM value CH 2-LED 6,0.0, %
ENG186233-MAS09839,PWM value CH 2-LED 7,0.0, %
ENG186233-MAS09840,PWM value CH 2-LED 8,0.0, %
ENG186233-MAS09841,PWM value CH 2-LED 9,0.0, %
ENG186233-MAS09842,PWM value CH 2-LED 10,0.0, %
ENG186233-MAS09843,PWM value CH 2-LED 11,0.0, %
ENG186233-MAS09844,PWM value CH 2-LED 12,0.0, %
ENG186234-MAS09833,PWM value CH 3-LED 1,0.0, %
ENG186234-MAS09834,PWM value CH 3-LED 2,0.0, %
ENG186234-MAS09835,PWM value CH 3-LED 3,0.0, %
ENG186234-MAS09836,PWM value CH 3-LED 4,0.0, %
ENG186234-MAS09837,PWM value CH 3-LED 5,0.0, %
ENG186234-MAS09838,PWM value CH 3-LED 6,0.0, %
ENG186234-MAS09839,PWM value CH 3-LED 7,0.0, %
ENG186234-MAS09840,PWM value CH 3-LED 8,0.0, %
ENG186234-MAS09841,PWM value CH 3-LED 9,0.0, %
ENG186234-MAS09842,PWM value CH 3-LED 10,0.0, %
ENG186234-MAS09843,PWM value CH 3-LED 11,0.0, %
ENG186234-MAS09844,PWM value CH 3-LED 12,0.0, %
ENG186235-MAS09833,PWM value CH 4-LED 1,0.0, %
ENG186235-MAS09834,PWM value CH 4-LED 2,0.0, %
ENG186235-MAS09835,PWM value CH 4-LED 3,0.0, %
ENG186235-MAS09836,PWM value CH 4-LED 4,0.0, %
ENG186235-MAS09837,PWM value CH 4-LED 5,0.0, %
ENG186235-MAS09838,PWM value CH 4-LED 6,0.0, %
ENG186235-MAS09839,PWM value CH 4-LED 7,0.0, %
ENG186235-MAS09840,PWM value CH 4-LED 8,0.0, %
ENG186235-MAS09841,PWM value CH 4-LED 9,0.0, %
ENG186235-MAS09842,PWM value CH 4-LED 10,0.0, %
ENG186235-MAS09843,PWM value CH 4-LED 11,0.0, %
ENG186235-MAS09844,PWM value CH 4-LED 12,0.0, %
ENG186236-MAS09833,PWM value CH 5-LED 1,0.0, %
ENG186236-MAS09834,PWM value CH 5-LED 2,0.0, %
ENG186236-MAS09835,PWM value CH 5-LED 3,0.0, %
ENG186236-MAS09836,PWM value CH 5-LED 4,0.0, %
ENG186236-MAS09837,PWM value CH 5-LED 5,0.0, %
ENG186236-MAS09838,PWM value CH 5-LED 6,0.0, %
ENG186236-MAS09839,PWM value CH 5-LED 7,0.0, %
ENG186236-MAS09840,PWM value CH 5-LED 8,0.0, %
ENG186236-MAS09841,PWM value CH 5-LED 9,0.0, %
ENG186236-MAS09842,PWM value CH 5-LED 10,0.0, %
ENG186236-MAS09843,PWM value CH 5-LED 11,0.0, %
ENG186236-MAS09844,PWM value CH 5-LED 12,0.0, %
ENG186237-MAS09833,PWM value CH 6-LED 1,0.0, %
ENG186237-MAS09834,PWM value CH 6-LED 2,0.0, %
ENG186237-MAS09835,PWM value CH 6-LED 3,0.0, %
ENG186237-MAS09836,PWM value CH 6-LED 4,0.0, %
ENG186237-MAS09837,PWM value CH 6-LED 5,0.0, %
ENG186237-MAS09838,PWM value CH 6-LED 6,0.0, %
ENG186237-MAS09839,PWM value CH 6-LED 7,0.0, %
ENG186237-MAS09840,PWM value CH 6-LED 8,0.0, %
ENG186237-MAS09841,PWM value CH 6-LED 9,11.0, %
ENG186237-MAS09842,PWM value CH 6-LED 10,16.5, %
ENG186237-MAS09843,PWM value CH 6-LED 11,20.5, %
ENG186237-MAS09844,PWM value CH 6-LED 12,24.0, %
ENG186238-MAS09833,PWM value CH 7-LED 1,0.0, %
ENG186238-MAS09834,PWM value CH 7-LED 2,0.0, %
ENG186238-MAS09835,PWM value CH 7-LED 3,0.0, %
ENG186238-MAS09836,PWM value CH 7-LED 4,0.0, %
ENG186238-MAS09837,PWM value CH 7-LED 5,0.0, %
ENG186238-MAS09838,PWM value CH 7-LED 6,0.0, %
ENG186238-MAS09839,PWM value CH 7-LED 7,0.0, %
ENG186238-MAS09840,PWM value CH 7-LED 8,0.0, %
ENG186238-MAS09841,PWM value CH 7-LED 9,0.0, %
ENG186238-MAS09842,PWM value CH 7-LED 10,0.0, %
ENG186238-MAS09843,PWM value CH 7-LED 11,0.0, %
ENG186238-MAS09844,PWM value CH 7-LED 12,0.0, %
ENG186239-MAS09833,PWM value CH 8-LED 1,22.0, %
ENG186239-MAS09834,PWM value CH 8-LED 2,20.5, %
ENG186239-MAS09835,PWM value CH 8-LED 3,19.0, %
ENG186239-MAS09836,PWM value CH 8-LED 4,0.0, %
ENG186239-MAS09837,PWM value CH 8-LED 5,0.0, %
ENG186239-MAS09838,PWM value CH 8-LED 6,0.0, %
ENG186239-MAS09839,PWM value CH 8-LED 7,0.0, %
ENG186239-MAS09840,PWM value CH 8-LED 8,0.0, %
ENG186239-MAS09841,PWM value CH 8-LED 9,14.0, %
ENG186239-MAS09842,PWM value CH 8-LED 10,16.5, %
ENG186239-MAS09843,PWM value CH 8-LED 11,15.0, %
ENG186239-MAS09844,PWM value CH 8-LED 12,12.0, %
ENG186240-MAS09833,PWM value CH 9-LED 1,0.0, %
ENG186240-MAS09834,PWM value CH 9-LED 2,0.0, %
ENG186240-MAS09835,PWM value CH 9-LED 3,0.0, %
ENG186240-MAS09836,PWM value CH 9-LED 4,0.0, %
ENG186240-MAS09837,PWM value CH 9-LED 5,0.0, %
ENG186240-MAS09838,PWM value CH 9-LED 6,0.0, %
ENG186240-MAS09839,PWM value CH 9-LED 7,0.0, %
ENG186240-MAS09840,PWM value CH 9-LED 8,0.0, %
ENG186240-MAS09841,PWM value CH 9-LED 9,0.0, %
ENG186240-MAS09842,PWM value CH 9-LED 10,0.0, %
ENG186240-MAS09843,PWM value CH 9-LED 11,0.0, %
ENG186240-MAS09844,PWM value CH 9-LED 12,0.0, %
ENG138939-MAS01632,Status InputOutputControl-Status,not active,
ENG186117-IDE00019,Supply_informations-Voltage terminal 30,12.9, V
ENG186117-ENG187145,Supply_informations-Voltage terminal 30G,13.0, V
ENG99026,Unlearning counter,125,
Elapsed Time: 00:10
blockmap-D7-992-941-572-CA_WVWZZZ3CZME009325-20260823-2137.CSV
;SW:992-941-572-CA   HW:992-941-572-C ---  D7: Light Ctrl Right 2
;Component:LED1R         H08 9002, Coding:
;EV_LLPGen3RKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_001_VW48.rod
;Sunday,23,August,2026,21:37:27:32152
IDE09774-ENG187780,Number of activations-additional highbeam,2,
IDE09774-ENG187761,Number of activations-higbeam,3,
IDE09774-ENG186491,Number of activations-Low beam,95,
IDE09774-ENG186411,Number of activations-Parking light,0,
IDE09774-ENG186853,Number of activations-position light,84,
IDE09774-ENG186603,Number of activations-race mode,2,
IDE09774-ENG187378,Number of activations-turn indicator,339,
IDE10168-FSS01570,LED channel 2: Master-Temperature,51, °C
IDE10170-MAS04121,LED channel 3: Master-Voltage,15.33, V
IDE13678-MAS02201,LED channel 4: Master-Temperature,51, °C
IDE13678-MAS04121,LED channel 4: Master-Voltage,20.33, V
IDE13899-MAS02201,LED channel 6: Master-Temperature,540, mA
IDE13899-MAS04136,LED channel 6: Master-Current,2.67, V
IDE13899-MAS09327,LED channel 6: Master-LED brightness class,LK1,
IDE13900-MAS09327,LED channel 7: Master-LED brightness class,LK1,
IDE13901-MAS02201,LED channel 8: Master-Temperature,540, mA
IDE13901-MAS09327,LED channel 8: Master-LED brightness class,LK1,
ENG186082-MAS02201,ECU Temperature-Temperature,48, °C
ENG186200-MAS02201,highside channel 3-Temperature,264, mA
ENG157274,Operating time,7.76, H
ENG157274,Operating time,25.56, H
ENG157274,Operating time,0.59, H
ENG157274-ENG187780,Operating time-additional highbeam,0.01, H
ENG157274-ENG186523,Operating time-Highbeam,0.01, H
ENG157274-ENG186491,Operating time-Low beam,7.53, H
ENG157274-ENG186603,Operating time-race mode,0.01, H
ENG157274-ENG166116,Operating time-Turn_indicator,0.32, H
ENG186104,Operating times in temperature ranges,25.56, H
ENG186237-MAS09841,PWM value CH 6-LED 9,10.0, %
ENG186237-MAS09842,PWM value CH 6-LED 10,10.0, %
ENG186237-MAS09843,PWM value CH 6-LED 11,12.5, %
ENG186237-MAS09844,PWM value CH 6-LED 12,15.0, %
ENG186239-MAS09833,PWM value CH 8-LED 1,17.5, %
ENG186239-MAS09834,PWM value CH 8-LED 2,22.0, %
ENG186239-MAS09835,PWM value CH 8-LED 3,20.5, %
ENG186239-MAS09836,PWM value CH 8-LED 4,19.5, %
ENG186239-MAS09837,PWM value CH 8-LED 5,19.0, %
ENG186239-MAS09841,PWM value CH 8-LED 9,0.0, %
ENG186239-MAS09842,PWM value CH 8-LED 10,0.0, %
ENG186239-MAS09843,PWM value CH 8-LED 11,0.0, %
ENG186239-MAS09844,PWM value CH 8-LED 12,0.0, %
Elapsed Time: 00:10
blockmap-OBD_WVWZZZ3CZME009325-20260823-2137.CSV
;33-OBD2
;Sunday,23,August,2026,21:37:46:32152
03,Fuel system 1/2 status,Engine off,Engine off
04,Calculated load value,0.0 %,0.0 %
05,Engine coolant temperature,29 °C,29 °C
06,Short Term Trim - Bank 1,0.0 %
07,Long Term Trim - Bank 1,0.0 %
0B,Intake Manifold Absolute Pressure,100 kPa abs
0C,Engine RPM,0 /min,0 /min
0D,Vehicle speed,0 km/h,0 km/h
0E,Ignition timing advance for cyl #1,0.0 Degrees
0F,Intake air temperature,29 °C
11,Absolute Throttle Position,16.5 %,16.5 %
13,Location of O2 sensors,B1S1 B1S2
15,Bank 1 Sensor 2 Status,0.455 V
1C,OBD Requirements Met,Euro-OBD
1F,Time since engine start,0 s
21,Distance travelled with MIL on,0 km
2E,Commanded Evaporative Purge,0.0 %
2F,Fuel Level Input,99.6 %
30,Warm-ups since DTC cleared,0
31,Distance since DTC cleared,0 km
33,Barometric pressure,100 kPa abs
34,Bank 1 Sensor 1 Status,1.012 Lambda,-0.004 mA
3C,B1S1 Cat. Temp.,22.9 °C
42,Control module voltage,13.140 V,12.800 V
43,Absolute Load Value,0 %,0 %
44,Commanded Equivalence Ratio,1.999 Lambda
45,Relative Throttle Position,7.1 %
46,Ambient Air Temp,27 °C
47,Absolute Throttle Position B,17 %
49,Accelerator Pedal Position D,14.5 %,14.5 %
4A,Accelerator Pedal Position E,14.5 %
4C,Commanded Throttle Actuator Control,1.6 %
51,Fuel type,Gasoline
54,Evap. vapour. press.,1086 Pa
56,Long term sec. O2 trim bank 1/3,0.0 %
5B,Battery Pack Remain. Life,92.9 %
62,Torque actual,0.0 %
63,Torque Reference,350 Nm
65,Auxiliary Input/Output,GEAR_RCMD: N
6D,Fuel Press. Control A/B,FRP CMD:---/--- kPa,FRP ACT:510/--- kPa
70,Boost Press Ctrl A/B,BP_A act:100.4 kPa
75,Turbo A Temp.,Compr. in/out---/31 °C,Turbine in/out---/--- °C
77,Charge Air Temp.,B1S1:29 °C
78,EGT B1-S1-4,S1/S2/S3/S4:,---/22/22/--- °C
7A,DPF Bank 1 Delta/In/Out,0.01/0.10/0.08 kPa
8B,Aftertreatment status,PF_Regen:Status:Y,PF_Load: 100.0 %
8E,Eng. friction %torque,5.0 %
9A,Hybrid/EV data,---,---
9D,Fuel rate,Engine: 0.00 g/s,Vehicle: 0.00 g/s
9E,Exhaust flow rate,0.0 kg/h
A4,Transm gear,N
A6,Odometer,136252.2 km
Type 02 - VIN : WVWZZZ3CZME009325 (Address E8)
Type 04 - Calibration ID : 04E024G 9819BEAJ (Address E8)
Type 04 - Calibration ID : 0DD300046E  2201 (Address E9)
Type 04 - Calibration ID : 3Q0183E 0940E   5QE682AR0300KYFA5KE591  0340CD  5KE591  0340CD  5KE591  0340CD  5KE591  0340CD  5KE591  0340CD  5KE591  0340CD  (Address ED)
Type 06 - Calibration Verification Number : ACEF4ACD (Address E8)
Type 06 - Calibration Verification Number : 3D5E9018 (Address E9)
Type 06 - Calibration Verification Number : D33F78A5 (Address ED)
Type 06 - Calibration Verification Number : 7D759AE2 (Address ED)
Type 06 - Calibration Verification Number : 1DF23034 (Address ED)
Type 08 - In-use performance tracking :
    OBD Monitoring Conditions Encountered count : 2651
    Ignition cycle count : 9060
         Catalyst monitor bank 1 : 2378 / 1787
         Catalyst monitor bank 2 : 0 / 0
         O2 Sensor monitor bank 1 : 2182 / 1787
         O2 Sensor monitor bank 2 : 0 / 0
         EGR-VVT monitor : 3726 / 1782
         AIR monitor : 0 / 0
         EVAP monitor : 0 / 0
         Secondary O2 Sensor monitor bank 1 : 2173 / 1787
         Secondary O2 Sensor monitor bank 2 : 0 / 0
         Air Fuel Ratio Imbalance Monitor bank 1 : 0 / 0
         Air Fuel Ratio Imbalance Monitor bank 2 : 0 / 0
         Particulate Filter Monitor bank 1 : 999 / 1787
         Particulate Filter Monitor bank 2 : 0 / 0
Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
Type 0A - Controller Name : BECM-B+EnergyCtrl (Address ED)
Trevas
Portugal
C?ID=516418
adpmap-01-04E-906-024-G_WVWZZZ3CZME009325-20260823-2120.CSV
;SW:04E-906-024-G   HW:04E-907-309-CG ---  01: Engine
;Component:1.4 TFSI hy   H20 9819, Coding:011D4012636405083008
;EV_ECM14TFS01104E906024G,002006,EV_ECM14TFS01104E906024AE_002.rod
;Sunday,23,August,2026,21:20:13:32152
;VCID: 251C9EEE4566DFA28D4-8070
IDE02248-Individually adjustable top speed limit,222.0 km/h,2
IDE04617-Protective function,OFF ,1
IDE05847-Hybrid drive customer service,not active ,1
IDE07903-Adaptation of ash mass,0.00 g,2
IDE11520-Open tank shut-off valve to the gasoline pressure tank,0 s,1
Elapsed Time: 00:02
adpmap-02-0DD-300-046-E_WVWZZZ3CZME009325-20260823-2121.CSV
;SW:0DD-300-046-E   HW:0DD-927-770-C ---  02: Auto Trans
;Component:GSG DQ400E    H32 2201, Coding:0014
;EV_TCMDQ400021,001001,EV_TCMDQ400021_VW41.rod
;Sunday,23,August,2026,21:21:08:32152
;VCID: 2A066DD22C78F0DAA06-807E
Elapsed Time: 00:01
adpmap-03-5Q0-614-517-GF_WVWZZZ3CZME009325-20260823-2121.CSV
;SW:5Q0-614-517-GF   HW:5QM-614-517 ---  03: ABS Brakes
;Component:ESC           H26 0314, Coding:4FEC728FA3203B75477A060268C849F24EC5DCE26016927538B1F078D2224A0B0003010312121212B435351919323200
;EV_Brake1UDSContiMK100OMG,060015,EV_Brake1UDSContiMK100OMG_060.rod
;Sunday,23,August,2026,21:21:32:32152
;VCID: 7BA898969362B9528B0-802E
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-Electromechanical parking brake,not activated ,1
IDE04774-Vehicle and trailer stabilization,not activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
IDE12030-Rough road optimization,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,activated ,1
ENG118148-Developer_Function_1,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG130301-Developer_Function_121,not activated ,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG127702-Developer_Function_5,Security access required,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
Elapsed Time: 00:13
adpmap-05-3Q0-959-435-M_WVWZZZ3CZME009325-20260823-2122.CSV
;SW:3Q0-959-435-M   HW:3Q0-959-435-M ---  05: Acc/Start Auth.
;Component:VWKESSYMQB    027 1307, Coding:002F0F0723
;EV_KessyHellaMQBAB,004052,EV_KessyHellaMQBAB_VW41.rod
;Sunday,23,August,2026,21:22:11:32152
;VCID: 44DA236AAE1C06AABAA-8010
IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
IDE03251-Stop enable for Start/Stop function,Always ,1
IDE10844-Control module rear lid opening: duration status query,4960 ms,1
IDE10845-Control module rear lid opening: vehicle type,FE ,1
ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
ENG244871-ENG297724-Byte13_vit_lf-toggleVariante,China ,1
ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
ENG126956-ENG126976-Byte9_VIP-active_vip,not activated ,1
ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
ENG105462-CAN-timeout service-key message,260 ms,1
ENG105634-Correction value LED dimming,1.0 ,1
ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
ENG126961-deactivation_time_vip_slidingdoor,15 s,1
ENG126960-Debounce_time_detection,500 ms,2
ENG126959-Debounce_time_driver_presence,200 ms,1
ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,not activated ,1
ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",not activated ,1
ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,Left hand steering ,1
ENG105825-Diagnostic: wait time after power on,500 ms,1
ENG126943-Display_duration_emergency_off,3000 ms,1
ENG126944-Display_duration_error_mode_2_SPN,10 s,1
ENG126941-Display_duration_please_engage_P,10 s,1
ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
ENG126950-duration_ZAT_debounce,50 ms,1
ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,30 %,9
ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,5.00 s,9
ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,150 ,9
ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,70 %,9
ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,500 ms,9
ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,0E ,5
ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,05 ,5
ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,70 mV/m,5
ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,65 mV/m,5
ENG248425-EasyOpen_optical_active,not activated ,1
ENG126966-environment_scan_cyclic_step1,700 ms,1
ENG126967-environment_scan_cyclic_step2,2000 ms,1
ENG126965-environment_scan_duration_step1,300 min,1
ENG126971-environment_scan_duration_step2,24 H,1
ENG126969-environment_scan_level_bem,2 ,1
ENG126968-environment_scan_responselevel_reduction,500 ,1
ENG126970-environment_scan_startdelay_time,5 s,1
ENG126958-Ignition_For_Immobilizer,Default ,1
ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
ENG107052-Interior scan: opening threshold sliding roof,1 %,1
ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
ENG107054-Interior scan: Speed - threshold,20 km/h,1
ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
ENG98656-internal,0 B,1
ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,not activated ,1
ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,not activated ,1
ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,not activated ,1
ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,not activated ,1
ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,not activated ,1
ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,not activated ,1
ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,not activated ,1
ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,activated ,1
ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,not activated ,1
ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
ENG107592-MCTX Pause,1 B,1
ENG107593-MCTX pause for Go / Key Minder,20 ms,1
ENG107594-MCTX pause for Go authentification,7 B,1
ENG107595-MCTX settling phase,10 B,1
ENG129013-min_receptiontime_vit,0 ms,1
ENG126945-min_time_for_Terminal_50_request,200 ms,1
ENG244880-Minimum_holdtime_ak,500 ms,1
ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,210 ms,1
ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
ENG108309-Proximity Sensor: max. signal-length,120 s,1
ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
ENG108317-Proximity Sensor: SP_X2,10 min,1
ENG108318-Proximity Sensor: SP_X3,1 ,1
ENG108319-Proximity Sensor: SP_X4,80 ,1
ENG108320-Proximity Sensor: SP_X5,1 ,1
ENG108321-Proximity Sensor: SP_X6,30 min,1
ENG108322-Proximity Sensor: SP_X7,1 ,1
ENG108323-Proximity Sensor: Time Power On,1960 ms,1
ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
ENG120045-Reduced current for transponder-ID request,0 Step,1
ENG126939-rpm_threshold_engine_runnning,100 /min,1
ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
ENG108577-Scan Procedure: Number of Repeats,1 ,1
ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
ENG108586-ScanProcedure: Timeout Response,100 ms,1
ENG126963-settime_trigger_entry_vehicle,500 ms,1
ENG126962-settime_trigger_exit_vehicle,500 ms,1
ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,not activated ,1
ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
ENG109053-Standard dimming value ZAT,80 %,1
ENG126946-Terminal_S_Timeout,30 min,1
ENG102207-Time Sensor Power Off Group 2,3600 min,1
ENG129027-Time_frame_VIP_kick_forecast,5 ,1
ENG126942-time_to_drive_cycle_detection,1.00 s,1
ENG126947-time_to_ignore_ignition_trigger,35 s,1
ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
ENG126949-time_ZAT_actuation_detection,3000 ms,1
ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
ENG129019-timeout_convenience_coverage_limiting,75 s,1
ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
ENG120047-ZAT init value,0 %,1
ENG110364-ZAT nominal voltage,13.0 V,1
ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
Elapsed Time: 00:51
adpmap-08-3G8-907-056-A_WVWZZZ3CZME009325-20260823-2123.CSV
;SW:3G8-907-056-A   HW:3G8-907-056-A ---  08: Auto HVAC
;Component:Climatronic   H10 0205, Coding:12021004200114010915100080101832
;EV_AirCondiBHTCMQB3rTranc,001050,EV_AirCondiBHTCMQB3rTranc_001_VW48.rod
;Sunday,23,August,2026,21:23:43:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 2E0E61C210909CFA7CE-807A
IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
IDE01479-Gear ratio of engine - A/C compressor,0.00 dB,1
IDE01483-Blower voltage with voice control,not activated ,1
IDE01488-Auxiliary heating retrofit without CAN,not installed ,1
IDE01493-Sensitivity of air quality sensor,Maximum ,1
IDE01503-Running time of basic setting for compressor break-in,10 s,1
IDE01536-Post heating of auxiliary heating,0 min,1
IDE03176-Duration of compressor run in,0 s,1
IDE06097-Target temperature of A/C - heater function via remote control,22.00 °C,1
IDE06544-Speed shut-off threshold for compressor break-in (engine speed),1500 /min,1
IDE06545-Blower voltage for production routines,6.0 V,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE07108-A/C styles,activated ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,3
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,3
IDE07160-MAS07135-Control module switch-off: switch-off time-Activation status,not activated ,3
IDE07301-Remote start function: activation of seat heating,Seat heating: front ,1
IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
IDE07303-Rem.start funct.:activ.temper. of windshield defrost.heat.,4 ,1
IDE07304-Remote start function: activation of seat ventilation,activated ,1
IDE07305-Rem. start funct.: activat.temper. of seat heating,15.00 °C,1
IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20.00 °C,1
IDE07307-Remote start function: activation stage of seat heating,2 ,1
IDE07308-Remote start function: activation stage of seat ventilation,2 ,1
IDE07398-Blower logic with manual adjustment,Matching coding ,1
IDE07585-Hand heater function during cold start,not activated ,1
IDE07865-Automatic activation of front windshield defroster at MAX-Defrost,not active ,1
IDE07948-Retention of frt.pass. seat heater level,not active ,1
IDE12229-Filtering of interior air: store,Service life-dependent store ,1
IDE13676-Remote start function: rear window defogger,activated ,1
IDE13677-Remote start function: seat climate control takeover,activated ,1
MAS06405-Compressor switch-on reduction,Matching coding ,1
MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
MAS07251-Cut-in behavior,Matching coding ,1
MAS14860-Remote start function: windshield defogger takeover,activated ,1
MAS14861-Remote start function: windshield defogger,activated ,1
MAS17226-Remote start function: windshield defogger can be activated,activated ,1
ENG253366-22_degree_jump_temp_slider,not active ,1
ENG252011-Detection_time_hold,0.00 ms,1
ENG252012-Detection_time_tap,0.00 ms,1
ENG253208-ENG101574-dimming_characteristic_new_1-X1,0 ,18
ENG253208-ENG99557-dimming_characteristic_new_1-X2,10 ,18
ENG253208-ENG102140-dimming_characteristic_new_1-X3,50 ,18
ENG253208-ENG102936-dimming_characteristic_new_1-X4,100 ,18
ENG253208-ENG103548-dimming_characteristic_new_1-X5,150 ,18
ENG253208-ENG113992-dimming_characteristic_new_1-X6,253 ,18
ENG253208-ENG99777-dimming_characteristic_new_1-Y1,16 ,18
ENG253208-ENG100480-dimming_characteristic_new_1-Y2,16 ,18
ENG253208-ENG100773-dimming_characteristic_new_1-Y3,60 ,18
ENG253208-ENG100631-dimming_characteristic_new_1-Y4,125 ,18
ENG253208-ENG102174-dimming_characteristic_new_1-Y5,500 ,18
ENG253208-ENG113993-dimming_characteristic_new_1-Y6,1000 ,18
ENG253345-ENG101574-dimming_characteristic_new_2-X1,0 ,18
ENG253345-ENG99557-dimming_characteristic_new_2-X2,10 ,18
ENG253345-ENG102140-dimming_characteristic_new_2-X3,25 ,18
ENG253345-ENG102936-dimming_characteristic_new_2-X4,50 ,18
ENG253345-ENG103548-dimming_characteristic_new_2-X5,75 ,18
ENG253345-ENG113992-dimming_characteristic_new_2-X6,100 ,18
ENG253345-ENG99777-dimming_characteristic_new_2-Y1,0 ,18
ENG253345-ENG100480-dimming_characteristic_new_2-Y2,100 ,18
ENG253345-ENG100773-dimming_characteristic_new_2-Y3,250 ,18
ENG253345-ENG100631-dimming_characteristic_new_2-Y4,500 ,18
ENG253345-ENG102174-dimming_characteristic_new_2-Y5,750 ,18
ENG253345-ENG113993-dimming_characteristic_new_2-Y6,1000 ,18
ENG253211-ENG101574-dimming_characteristic_new_3-X1,0 ,18
ENG253211-ENG99557-dimming_characteristic_new_3-X2,10 ,18
ENG253211-ENG102140-dimming_characteristic_new_3-X3,50 ,18
ENG253211-ENG102936-dimming_characteristic_new_3-X4,100 ,18
ENG253211-ENG103548-dimming_characteristic_new_3-X5,150 ,18
ENG253211-ENG113992-dimming_characteristic_new_3-X6,253 ,18
ENG253211-ENG99777-dimming_characteristic_new_3-Y1,2 ,18
ENG253211-ENG100480-dimming_characteristic_new_3-Y2,2 ,18
ENG253211-ENG100773-dimming_characteristic_new_3-Y3,10 ,18
ENG253211-ENG100631-dimming_characteristic_new_3-Y4,20 ,18
ENG253211-ENG102174-dimming_characteristic_new_3-Y5,100 ,18
ENG253211-ENG113993-dimming_characteristic_new_3-Y6,100 ,18
ENG253234-ENG101574-dimming_characteristic_new_4-X1,0 ,18
ENG253234-ENG99557-dimming_characteristic_new_4-X2,10 ,18
ENG253234-ENG102140-dimming_characteristic_new_4-X3,50 ,18
ENG253234-ENG102936-dimming_characteristic_new_4-X4,100 ,18
ENG253234-ENG103548-dimming_characteristic_new_4-X5,150 ,18
ENG253234-ENG113992-dimming_characteristic_new_4-X6,253 ,18
ENG253234-ENG99777-dimming_characteristic_new_4-Y1,15 ,18
ENG253234-ENG100480-dimming_characteristic_new_4-Y2,15 ,18
ENG253234-ENG100773-dimming_characteristic_new_4-Y3,40 ,18
ENG253234-ENG100631-dimming_characteristic_new_4-Y4,80 ,18
ENG253234-ENG102174-dimming_characteristic_new_4-Y5,600 ,18
ENG253234-ENG113993-dimming_characteristic_new_4-Y6,1000 ,18
ENG253181-ENG101574-dimming_characteristic_new_5-X1,0 ,18
ENG253181-ENG99557-dimming_characteristic_new_5-X2,10 ,18
ENG253181-ENG102140-dimming_characteristic_new_5-X3,50 ,18
ENG253181-ENG102936-dimming_characteristic_new_5-X4,100 ,18
ENG253181-ENG103548-dimming_characteristic_new_5-X5,150 ,18
ENG253181-ENG113992-dimming_characteristic_new_5-X6,253 ,18
ENG253181-ENG99777-dimming_characteristic_new_5-Y1,1 ,18
ENG253181-ENG100480-dimming_characteristic_new_5-Y2,1 ,18
ENG253181-ENG100773-dimming_characteristic_new_5-Y3,5 ,18
ENG253181-ENG100631-dimming_characteristic_new_5-Y4,10 ,18
ENG253181-ENG102174-dimming_characteristic_new_5-Y5,300 ,18
ENG253181-ENG113993-dimming_characteristic_new_5-Y6,1000 ,18
ENG253303-ENG101574-dimming_characteristic_new_6-X1,0 ,18
ENG253303-ENG99557-dimming_characteristic_new_6-X2,10 ,18
ENG253303-ENG102140-dimming_characteristic_new_6-X3,50 ,18
ENG253303-ENG102936-dimming_characteristic_new_6-X4,100 ,18
ENG253303-ENG103548-dimming_characteristic_new_6-X5,150 ,18
ENG253303-ENG113992-dimming_characteristic_new_6-X6,253 ,18
ENG253303-ENG99777-dimming_characteristic_new_6-Y1,1 ,18
ENG253303-ENG100480-dimming_characteristic_new_6-Y2,1 ,18
ENG253303-ENG100773-dimming_characteristic_new_6-Y3,5 ,18
ENG253303-ENG100631-dimming_characteristic_new_6-Y4,10 ,18
ENG253303-ENG102174-dimming_characteristic_new_6-Y5,300 ,18
ENG253303-ENG113993-dimming_characteristic_new_6-Y6,1000 ,18
ENG253035-ENG101574-dimming_characteristic_new_7-X1,0 ,18
ENG253035-ENG99557-dimming_characteristic_new_7-X2,10 ,18
ENG253035-ENG102140-dimming_characteristic_new_7-X3,50 ,18
ENG253035-ENG102936-dimming_characteristic_new_7-X4,100 ,18
ENG253035-ENG103548-dimming_characteristic_new_7-X5,150 ,18
ENG253035-ENG113992-dimming_characteristic_new_7-X6,253 ,18
ENG253035-ENG99777-dimming_characteristic_new_7-Y1,10 ,18
ENG253035-ENG100480-dimming_characteristic_new_7-Y2,10 ,18
ENG253035-ENG100773-dimming_characteristic_new_7-Y3,25 ,18
ENG253035-ENG100631-dimming_characteristic_new_7-Y4,50 ,18
ENG253035-ENG102174-dimming_characteristic_new_7-Y5,400 ,18
ENG253035-ENG113993-dimming_characteristic_new_7-Y6,1000 ,18
ENG253316-ENG101574-dimming_characteristic_new_8-X1,0 ,18
ENG253316-ENG99557-dimming_characteristic_new_8-X2,10 ,18
ENG253316-ENG102140-dimming_characteristic_new_8-X3,50 ,18
ENG253316-ENG102936-dimming_characteristic_new_8-X4,100 ,18
ENG253316-ENG103548-dimming_characteristic_new_8-X5,150 ,18
ENG253316-ENG113992-dimming_characteristic_new_8-X6,253 ,18
ENG253316-ENG99777-dimming_characteristic_new_8-Y1,3 ,18
ENG253316-ENG100480-dimming_characteristic_new_8-Y2,3 ,18
ENG253316-ENG100773-dimming_characteristic_new_8-Y3,7 ,18
ENG253316-ENG100631-dimming_characteristic_new_8-Y4,9 ,18
ENG253316-ENG102174-dimming_characteristic_new_8-Y5,300 ,18
ENG253316-ENG113993-dimming_characteristic_new_8-Y6,1000 ,18
ENG253075-ENG101574-dimming_characteristic_new_9-X1,0 ,18
ENG253075-ENG99557-dimming_characteristic_new_9-X2,10 ,18
ENG253075-ENG102140-dimming_characteristic_new_9-X3,50 ,18
ENG253075-ENG102936-dimming_characteristic_new_9-X4,100 ,18
ENG253075-ENG103548-dimming_characteristic_new_9-X5,150 ,18
ENG253075-ENG113992-dimming_characteristic_new_9-X6,253 ,18
ENG253075-ENG99777-dimming_characteristic_new_9-Y1,3 ,18
ENG253075-ENG100480-dimming_characteristic_new_9-Y2,3 ,18
ENG253075-ENG100773-dimming_characteristic_new_9-Y3,7 ,18
ENG253075-ENG100631-dimming_characteristic_new_9-Y4,9 ,18
ENG253075-ENG102174-dimming_characteristic_new_9-Y5,300 ,18
ENG253075-ENG113993-dimming_characteristic_new_9-Y6,1000 ,18
ENG261737-Evaporator_offset,not active ,1
ENG253022-Flick_function_temp_slider,not active ,1
ENG248446-HMI_View_Switch,Yes ,1
ENG252027-Off_time_neighbor_key_during_sliding,0.00 ms,1
ENG253172-Profile_selection_touch,0 ,1
ENG252031-Sensitivity_touch,-2.0 ,1
ENG253135-Step_size_temp_slider,0.5° ,1
ENG253291-Steps_temp_slider,Unknown (0),1
ENG264036-Sun_sensor_supplier_differentiation,none ,1
ENG276151-Touch_sound_on_off,active ,1
Elapsed Time: 00:22
adpmap-09-5Q0-937-086-CK_WVWZZZ3CZME009325-20260823-2124.CSV
;SW:5Q0-937-086-CK   HW:5Q0-937-086-BR ---  09: Cent. Elect.
;Component:BCM PQ37BOSCH 040 0400, Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BodyContrModul1UDSBosc,021001,EV_BCMBOSCH_021_VW27.rod
;Sunday,23,August,2026,21:24:58:32152
;VCID: 055CFE6EE5A6FFA2ED4-8050
IDE01550-Service position,153.296551 °,2
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,DELAY ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,250 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,250 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,250 ms,10
IDE02711-ENG112304-Rear wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck,0 ms,8
IDE03638-IDE04231-Static cornering light-Steering wheel angle: offset,0.3 °,16
IDE03638-ENG116677-Static cornering light-Abdimmgeschwindigkeit,100.0 %/s,16
IDE03638-ENG116673-Static cornering light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-Static cornering light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-Static cornering light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-Static cornering light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-Static cornering light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-Static cornering light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-Static cornering light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-Static cornering light-Upper speed threshold,40.0 km/h,16
IDE03638-ENG116674-Static cornering light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-Static cornering light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
IDE04928-MAS01577-Anti-theft protection-Auxiliary heating,not installed ,8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn,not active ,8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system,not active ,8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI,not_active ,8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder,not installed ,8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm,not_active ,8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm,activ ,8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung,No ,8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor,No ,8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm,keine verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,130 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,26 08 00 16 24 00 7F 06 00 80 02 00 7F 00 00 00 26 18 00 18 24 00 7F 07 00 80 04 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 3A 00 49 14 00 7F 00 00 00 0B 00 7F 00 00 00 01 44 00 4B 14 00 7F 00 00 00 0C 00 7F 00 00 00 35 52 00 5D 52 00 7F 08 09 7F 00 00 00 00 00 00 35 53 00 5E 52 00 7F 08 0A 7F 00 00 00 00 00 00 20 00 00 00 1E 00 7F 28 00 80 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 0B 00 19 00 00 00 00 00 00 04 4C 00 4C 14 00 64 0C 00 19 00 00 00 00 00 00 ,224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,1 ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,18.50 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,17.50 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,27.50 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,26.50 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06507-MAS13129-Button in center console-Function of button 2,GTE ,8
IDE06507-MAS13132-Button in center console-Function of button 3,not coded / not installed ,8
IDE06507-MAS13135-Button in center console-Function of button 4,not coded / not installed ,8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07356-Position during interval mode,24.890085 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor,installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,2 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,coupled ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,50 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting,Keine_Spannungsanforderung ,19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,21 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,installed ,5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting,installed ,5
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumatics,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
IDE10298-Alternating park position 1,8.296695 °,2
IDE10299-Alternating park position 2,24.890085 °,2
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,0.40 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.40 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,0.60 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000101  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00111100  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000010  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00011100  ,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,127 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,96 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,127 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,96 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,127 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,0 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,127 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,127 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,127 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,126 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,126 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,60 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,96 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,127 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,96 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,127 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,96 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,127 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,96 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0.5 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,64 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,20 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,170 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,30 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,30 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,11 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,255 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,250 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,100 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,160 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,190 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,230 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,238 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,255 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,175 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,170 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,250 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,230 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,230 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,230 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,255 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,230 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,210 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,210 ,30
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Left neck heater,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Right neck heater,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,64 ,30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,3 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,24 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,1 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,4 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,5 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,4 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,3 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,3 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,255 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,255 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,226 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,3 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,88 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,178 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,198 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,255 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,255 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,175 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,78 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,138 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,255 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,255 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,255 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,182 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,149 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,114 ,30
MAS01490-ENG141950-Energy management-Hybrid vehicle,Yes ,5
MAS01490-ENG141978-Energy management-Recuperation,not active ,5
MAS05055-lower turn position,26.296677 °,2
MAS05056-upper turn position,171.296533 °,2
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,30 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,30 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,110 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,140 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,160 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,200 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,255 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,255 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,255 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,255 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,255 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,255 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,255 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,255 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,255 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,255 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,115 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,90 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,70 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,100 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,255 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,235 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,235 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,255 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,225 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,225 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,200 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,160 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,120 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,90 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,40 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,30 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,30 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,30 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,40 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,90 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,110 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,60 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,50 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,10 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,30 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,65 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,120 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,195 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,220 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,255 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,255 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,255 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,255 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,240 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,3 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,2 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,27 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,17 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,60 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,43 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,125 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,200 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,255 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,255 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,255 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,255 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,247 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,255 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,255 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,244 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,42 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,19 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,19 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,42 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,255 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,255 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,255 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,255 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,255 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,255 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,255 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,255 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,146 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,65 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,20 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,3 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,38 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,60 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,30 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,32 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,8 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,34 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,79 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,138 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,59 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,6 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,24 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,70 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,19 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,3 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,1 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,32 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,20 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,9 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,1 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,28 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,63 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,142 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,188 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,255 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,255 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,255 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,255 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,255 ,60
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,I-panel ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,multicolor ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,multicolor ,30
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,1 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,2 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,3 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,4 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,5 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,6 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,04 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,8 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,12 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,16 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,20 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,21 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,installed ,60
ENG126650-ENG126926-Ambiente_light-Dimmung_auf_Zielwert deaktivieren_Suchbeleuchtung,not active ,13
ENG126650-ENG126927-Ambiente_light-Dimmung_auf_Zielwert_deaktivieren_Innen_und_Leselicht,not active ,13
ENG126650-ENG126922-Ambiente_light-Korrekturfaktor_ Flaechenlicht_vorne_Farbe_1,1.00 ,13
ENG126650-ENG126924-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_1,1.00 ,13
ENG126650-ENG126925-Ambiente_light-Korrekturfaktor_Flaechenlicht_hinten_Farbe_2,0.73 ,13
ENG126650-ENG126923-Ambiente_light-Korrekturfaktor_Flaechenlicht_vorne_Farbe_2,0.17 ,13
ENG126650-ENG126921-Ambiente_light-Korrekturfaktor_Funktionsbeleuchtung,1.00 ,13
ENG126650-ENG126918-Ambiente_light-Korrekturfaktor_Leselicht_hinten,0.86 ,13
ENG126650-ENG126919-Ambiente_light-Korrekturfaktor_Leselicht_Reihe_3,1.00 ,13
ENG126650-ENG126917-Ambiente_light-Korrekturfaktor_Leselicht_vorne,0.86 ,13
ENG126650-ENG126920-Ambiente_light-Korrekturfaktor_Schalter_und_Suchbeleuchtung,1.00 ,13
ENG128378-ENG115658-Ambiente_Light_Kennlinie_Hochdimmen-x0,0 ms,22
ENG128378-ENG101574-Ambiente_Light_Kennlinie_Hochdimmen-X1,200 ms,22
ENG128378-ENG115664-Ambiente_Light_Kennlinie_Hochdimmen-x10,2000 ms,22
ENG128378-ENG99557-Ambiente_Light_Kennlinie_Hochdimmen-X2,400 ms,22
ENG128378-ENG102140-Ambiente_Light_Kennlinie_Hochdimmen-X3,600 ms,22
ENG128378-ENG102936-Ambiente_Light_Kennlinie_Hochdimmen-X4,800 ms,22
ENG128378-ENG103548-Ambiente_Light_Kennlinie_Hochdimmen-X5,1000 ms,22
ENG128378-ENG113992-Ambiente_Light_Kennlinie_Hochdimmen-X6,1200 ms,22
ENG128378-ENG115661-Ambiente_Light_Kennlinie_Hochdimmen-x7,1400 ms,22
ENG128378-ENG115662-Ambiente_Light_Kennlinie_Hochdimmen-x8,1600 ms,22
ENG128378-ENG115663-Ambiente_Light_Kennlinie_Hochdimmen-x9,1800 ms,22
ENG128378-ENG115659-Ambiente_Light_Kennlinie_Hochdimmen-y0,0.0 %,22
ENG128378-ENG99777-Ambiente_Light_Kennlinie_Hochdimmen-Y1,0.5 %,22
ENG128378-ENG115668-Ambiente_Light_Kennlinie_Hochdimmen-y10,100.0 %,22
ENG128378-ENG100480-Ambiente_Light_Kennlinie_Hochdimmen-Y2,2.0 %,22
ENG128378-ENG100773-Ambiente_Light_Kennlinie_Hochdimmen-Y3,5.0 %,22
ENG128378-ENG100631-Ambiente_Light_Kennlinie_Hochdimmen-Y4,10.0 %,22
ENG128378-ENG102174-Ambiente_Light_Kennlinie_Hochdimmen-Y5,20.0 %,22
ENG128378-ENG113993-Ambiente_Light_Kennlinie_Hochdimmen-Y6,40.0 %,22
ENG128378-ENG115665-Ambiente_Light_Kennlinie_Hochdimmen-y7,80.0 %,22
ENG128378-ENG115666-Ambiente_Light_Kennlinie_Hochdimmen-y8,95.0 %,22
ENG128378-ENG115667-Ambiente_Light_Kennlinie_Hochdimmen-y9,99.0 %,22
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,6 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,19 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,3 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,8 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,18 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,21 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,21 ,23
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken_Bremsblinken ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light,not installed ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,3000 ms,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beams ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manually ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp,Keine_Spannungsanforderung ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,696 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,800 lx,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,No ,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),LIN ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beams,Keine_Spannungsanforderung ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp,Keine_Spannungsanforderung ,18
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,nfc ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,active ,3
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141645-MAS00212-HW_Verbau-Washer fluid low,installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,installed ,8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,active ,8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,installed ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,active ,8
ENG126651-ENG115658-Kennlinie Abdimmen-x0,0 ,22
ENG126651-ENG101574-Kennlinie Abdimmen-X1,200 ,22
ENG126651-ENG115664-Kennlinie Abdimmen-x10,2000 ,22
ENG126651-ENG99557-Kennlinie Abdimmen-X2,400 ,22
ENG126651-ENG102140-Kennlinie Abdimmen-X3,600 ,22
ENG126651-ENG102936-Kennlinie Abdimmen-X4,800 ,22
ENG126651-ENG103548-Kennlinie Abdimmen-X5,1000 ,22
ENG126651-ENG113992-Kennlinie Abdimmen-X6,1200 ,22
ENG126651-ENG115661-Kennlinie Abdimmen-x7,1400 ,22
ENG126651-ENG115662-Kennlinie Abdimmen-x8,1600 ,22
ENG126651-ENG115663-Kennlinie Abdimmen-x9,1800 ,22
ENG126651-ENG115659-Kennlinie Abdimmen-y0,100.0 ,22
ENG126651-ENG99777-Kennlinie Abdimmen-Y1,99.0 ,22
ENG126651-ENG115668-Kennlinie Abdimmen-y10,0.0 ,22
ENG126651-ENG100480-Kennlinie Abdimmen-Y2,95.0 ,22
ENG126651-ENG100773-Kennlinie Abdimmen-Y3,80.0 ,22
ENG126651-ENG100631-Kennlinie Abdimmen-Y4,40.0 ,22
ENG126651-ENG102174-Kennlinie Abdimmen-Y5,20.0 ,22
ENG126651-ENG113993-Kennlinie Abdimmen-Y6,10.0 ,22
ENG126651-ENG115665-Kennlinie Abdimmen-y7,5.0 ,22
ENG126651-ENG115666-Kennlinie Abdimmen-y8,2.0 ,22
ENG126651-ENG115667-Kennlinie Abdimmen-y9,0.5 ,22
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,56.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,56.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,56.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,56.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,51.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,47.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,40.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,33.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,26.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,127 ,16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,127 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,16 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,08 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,38 - LED Blinkleuchten ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Quittierungsfunktion 1 ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links aktiv (beide Phasen) ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,Blinken links Hellphase ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,25 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,4A ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,48 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,4 - LED Tagfahrlichtmodul Signal ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Daytime running lights ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,Abblendlicht links ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,25 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,4C ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,4C ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,4 - LED Tagfahrlichtmodul Signal ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Daytime running lights ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,Abblendlicht rechts ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,39 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,10 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,3A ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,20 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parking light right ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,minimize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,127 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Quittierungsfunktion 1 ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,Blinken links aktiv (beide Phasen) ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,Blinken links Hellphase ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,minimize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,127 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Quittierungsfunktion 1 ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,Blinken rechts aktiv (beide Phasen) ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,Blinken rechts Hellphase ,16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,minimize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,127 ,16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,127 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,18 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,18 ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,38 - LED Blinkleuchten ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Quittierungsfunktion 1 ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,Blinken rechts aktiv (beide Phasen) ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,Blinken rechts Hellphase ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake lamp ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake lamp ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,minimize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,25 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,25 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,2E ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0C ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Brake lamp ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,Rear lid open ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,Brake lamp ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,minimize ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,38 ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,00 ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,34 - LED Bremsleuchten ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Brake lamp ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Nebelschlusslicht wenn kein Anhaenger gesteckt ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,29 ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0A ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,32 - allgemeine LED bis 12W ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,2A ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,Parking light right ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,37 - allgemeine LED bis 12W ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,37 - allgemeine LED bis 12W ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Abblendlicht links ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Abblendlicht rechts ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,5D ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,52 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,53 - LED LeiMo3G o Open Load ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,5E ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,53 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,53 - LED LeiMo3G o Open Load ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Versorgungsbedarf der LED-LeiMo3G-Module ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,Parking light right ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,minimize ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,00 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,32 - allgemeine LED bis 12W ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Coming Home oder Leaving Home aktiv ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Klemme 15 mit Nachlauf bis Fahrzeugstillstand ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,00 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00 ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 24 00 7F 06 00 80 02 00 7F 00 00 00 26 18 00 18 24 00 7F 07 00 80 04 00 7F 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 18 00 99 1A 00 7F 21 00 80 18 00 19 22 00 00 38 18 00 7F 1A 00 80 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 20 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 20 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 25 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 25 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,2B 10 00 39 08 09 7F 00 00 00 00 00 00 00 00 00 2B 20 00 3A 08 0A 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.50 ,27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,25.0 %,27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,40 °C,27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,45 °C,27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,50 °C,27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,57 °C,27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear wiper,installed ,2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition Switch Key Lock Solenoid,not installed ,2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Adaptive Cruise Control,not installed ,2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,installed ,2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
ENG99457-ENG117394-Neck heating-blower_speed,1 ,2
ENG99457-ENG98971-Neck heating-Temperature,-2 ,2
ENG122979-ENG99457-Networking-Neck heating,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,installed ,8
ENG124714-OCU-,installed ,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,7 ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 2.x) ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering assignment,Left ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2550 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,1200 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,1200 ms,10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,active ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,unidirectional ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,Tuersteuergeraet im Fond verbaut oder keine Fondtuer ,5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,Inverted ,5
Elapsed Time: 02:07
adpmap-10-5QA-919-294-J_WVWZZZ3CZME009325-20260823-2127.CSV
;SW:5QA-919-294-J   HW:5QA-919-294 ---  10: Park/Steer Assist
;Component:PDC 8 Kanal   H08 0073, Coding:9471151811
;EV_EPHVA18AU3700000,009053,EV_EPHVA18AU3700000_009_VW48.rod
;Sunday,23,August,2026,21:27:26:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 53F810365B729112330-8006
IDE00820-ENG118120-Activating and deactivating all development messages-Dev_Id_High_Nibble,not activated ,1
IDE00820-ENG118119-Activating and deactivating all development messages-Dev_Id_Low_Nibble,not activated ,1
IDE00845-Wheel circumference,2070 mm,2
IDE01167-Convertible offset for volume level 1,255 ,1
IDE01168-Increment for convertible volume levels,255 ,1
IDE01169-Audio lowering request,On ,1
IDE02328-Distance to curb,15 cm,1
IDE03782-Switch-off speed for parking assist,15 km/h,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE11215-Automatic Activation,activated ,1
IDE14666-Parking aid: personalization,activated ,1
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 1 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 7 ,1
MAS07110-Muting of audio sources,activated ,1
MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.234 1/m,6
MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,0.180 1/m,6
MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,1.185 m,6
MAS12843-Maneuvering brake function,activated ,1
Elapsed Time: 00:08
adpmap-13-5Q0-907-572-R_WVWZZZ3CZME009325-20260823-2127.CSV
;SW:5Q0-907-572-R   HW:3Q0-907-567-A ---  13: Auto Dist. Reg
;Component:ACC BOSCH MQB H01 0771, Coding:52017F425DFFC728949C812481408680000000000000000066
;EV_ACCBOSCHVW416,003014,EV_ACCBOSCHVW416_003_VW48.rod
;Sunday,23,August,2026,21:27:56:32152
;VCID: 46DE3962982034BAA4E-8012
IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
IDE01795-Heated lens,OFF ,1
IDE01949-Distance basic setting option,On ,1
IDE05815-Sail function,Deactivating ,1
IDE08935-Expanded restart function,On ,1
IDE09564-Distance change via speed adjustment,On ,1
IDE09565-Prioritized target object display,OFF ,1
IDE10280-Constant delay after transfer request,Yes ,1
IDE12516-Predictive speed limit regulation,activated ,1
MAS19336-Active participant function activated,activated ,1
Elapsed Time: 00:06
adpmap-15-5QF-959-655-AA_WVWZZZ3CZME009325-20260823-2128.CSV
;SW:5QF-959-655-AA   HW:5QF-959-655-AA ---  15: Airbags
;Component:Airbag VW22   011 0639, Coding:98CCC0C0002000005C5400CF000C40000065
;EV_AirbaVW22TS6VW48X,001030,EV_AirbaVW22TS6VW48X.rod
;Sunday,23,August,2026,21:28:26:32152
;VCID: 157CAE2E95064F221D4-8040
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
IDE05178-Conclude start of operation,locked ,1
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
IDE06527-IDE06311-Adaptation pre-crash-Left seat belt tensioner,not defined ,4
IDE06527-IDE06312-Adaptation pre-crash-Right seat belt tensioner,not defined ,4
IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
MAS00975-IDE02852-Airbag adaptations-Battery Interrupt Igniter High-Voltage Battery,activated ,8
MAS00975-MAS00003-Airbag adaptations-Front passenger front airbag igniter,activated ,8
MAS00975-MAS00006-Airbag adaptations-Front passenger thorax airbag igniter,activated ,8
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
MAS00975-MAS00013-Airbag adaptations-Driver seat belt tension igniter,activated ,8
MAS00975-MAS00014-Airbag adaptations-Front passenger seat belt tensioner igniter,activated ,8
MAS00975-MAS00020-Airbag adaptations-Passenger side rear seat belt tensioner igniter,activated ,8
MAS00975-MAS00022-Airbag adaptations-Battery Interrupt Igniter,not defined ,8
MAS00975-MAS00030-Airbag adaptations-Seat occupant detection,activated ,8
MAS00975-MAS00079-Airbag adaptations-Key-operated switch,Airbag deactivation key switch installed ,8
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter hood,not defined ,8
Elapsed Time: 00:04
adpmap-17-3G0-920-324-B_WVWZZZ3CZME009325-20260823-2117.CSV
;SW:3G0-920-324-B   HW:3G0-920-324-B ---  17: Instruments
;Component:KOMBI         502 5176, Coding:05A408186FC40008018B62531001002880700300
;EV_DashBoardVDDMQBA0,001045,EV_DashBoardVDDMQBA0_001_VW48.rod
;Sunday,23,August,2026,21:17:24:32152
;VCID: 20128FFA5A443A8AFE2-8074
IDE00295-Oil temperature display,On ,1
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language variant,Portuguese ,1
IDE00500-Hour,21 H,1
IDE00501-Minute,17 min,1
IDE00502-Year,2026 yr,2
IDE00503-Month,8 Months,1
IDE00504-Day,23 d,1
IDE00510-ESI: distance driven from inspection,8643 km,3
IDE00511-ESI: time from inspection,229 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00515-ESI: oil quality,poor oil quality ,1
IDE00518-ESI: thermal load,8300 km,2
IDE00819-Day counter,2188 d,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE02489-Display depiction,Variant 1 ,1
IDE03329-Driving profiled for range remaining,4.6 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,30 ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,22900 km,2
IDE03352-FIX: Time since last time-dependent inspection,425 d,2
IDE03372-Source for synchronization of time,internal clock ,1
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
IDE06588-Ignition active message: actuator,Driver´s door ,1
IDE07161-temporary VIN,Conditions not correct or request sequence error,1
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12467-Tubes illustration,Variant 1 ,1
IDE12722-Driving profile display,No ,1
IDE13094-Tachometer end value,Variant 0 ,1
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE14184-Active participant personalization,Yes ,1
IDE14220-Vehicle speed warning for India-,60 s,1
IDE14984-R Logo,no R logo ,1
IDE14986-ACC illustration China,No display ,1
IDE15073-ENG249922-Digital Key 3-number_of_repeats_of_authentication_of_central_locking,05 ,3
IDE15073-ENG249951-Digital Key 3-time_for_waiting_of_receive_of_message_MDK_ZV_Resp,00 0A s,3
IDE15113-Shift exit warning,Car exit warning ,1
IDE15132-Activate/deactivate development messages via Ethernet,not active ,1
MAS03555-Lap counter,Conditions not correct or request sequence error,1
ENG114742-Activation of Development Messages,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,14 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,02 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,04 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,32 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,01 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,01 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,03 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,06 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,01 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,01 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,03 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,06 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,28 ,12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 96 ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0C ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0C ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 23 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 46 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,01 F4 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG119833-Display_Save_CP,Yes ,1
ENG128742-Gauge_dimming_condition,OFF ,1
ENG251650-GPS_speed,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG249798-MDK_coding-,00 ,8
ENG249798-MDK_coding-,01 ,8
ENG249799-ENG249828-MDK_parameter-AZK bConfig COV,00 ,36
ENG249799-ENG249829-MDK_parameter-AZK num Time resp KY,800 ms,36
ENG249799-ENG249830-MDK_parameter-AZK num Time resp MDK,800 ms,36
ENG249799-ENG249831-MDK_parameter-AZK num Time resp WFS,5000 ms,36
ENG249799-ENG249904-MDK_parameter-MDK num Time Zv Cmd High,200 ms,36
ENG249799-ENG249905-MDK_parameter-MDK num Time Zv Cmd Low,100 ms,36
ENG249799-ENG249929-MDK_parameter-Rep Cmd Apdu,01 ,36
ENG249799-ENG249930-MDK_parameter-Rep User Auth,01 ,36
ENG249799-ENG249944-MDK_parameter-Time Esm Aktiv,10 s,36
ENG249799-ENG249945-MDK_parameter-Time Out Mob Dev Key Cmd,30 s,36
ENG249799-ENG249946-MDK_parameter-Time Out Resp Apdu,500 s,36
ENG249799-ENG249947-MDK_parameter-Time Out Ticket Table,120 s,36
ENG249799-ENG249948-MDK_parameter-Time Out VTAN Dec,30 s,36
ENG249799-ENG249949-MDK_parameter-Time Out VTAN Resp,10 s,36
ENG249799-ENG249950-MDK_parameter-Time SKC1,15 s,36
ENG249799-ENG249953-MDK_parameter-Veh Arch,00 ,36
ENG249800-ENG249840-MDK_parameter_2-Dev Param 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG249800-ENG249841-MDK_parameter_2-Dev Param 2,14 02 46 46 46 32 32 32 02 C8 C8 05 0A 1E 64 01 0A 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG103063-Mileage,136252 km,3
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,70 °C,16
ENG135292-phev_stat_intervall-,1.0 ,3
ENG135292-phev_stat_intervall-,64 m,3
ENG135292-phev_stat_intervall-,00 min,3
ENG153765-Second_digital_speed,No display ,1
ENG98918-Sport,No display ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,65 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:34
adpmap-19-3Q0-907-530-AH_WVWZZZ3CZME009325-20260823-2118.CSV
;SW:3Q0-907-530-AH   HW:3Q0-907-530-D ---  19: CAN Gateway
;Component:GW MQB EV     621 6423, Coding:020900172CE21000FB0052FA581D00000001070100010000000300000000
;EV_GatewNF,013026,EV_GatewNF_VW48.rod
;Sunday,23,August,2026,21:18:59:32152
;VCID: 75BC8EAEB546EF22FD4-8020
IDE01457-Energy management: shut-off stage,Mode not active ,1
IDE01844-request idle speed increase,Mode not active ,1
IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,coded ,32
IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32
IDE01996-SFT00008-Installation list: specified installations-HVAC electronics,coded ,32
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32
IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32
IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32
IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,coded ,32
IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32
IDE01996-SFT00043-Installation list: specified installations-Steering column lock,coded ,32
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32
IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,Not coded ,32
IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32
IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32
IDE01996-SFT00081-Installation list: specified installations-Electric drive,coded ,32
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32
IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,Not coded ,32
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32
IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32
IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,coded ,32
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,coded ,32
IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32
IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,coded ,32
IDE01996-SFT00165-Installation list: specified installations-Front sensor for driver assistance systems,coded ,32
IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,coded ,32
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,coded ,32
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,coded ,32
IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32
IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistance 2,Not coded ,32
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
IDE03903-Production process data 1,00 00 ,2
IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,1
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,not activated ,4
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,not activated ,4
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,not activated ,4
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
IDE08348-Start/stop start voltage limit,7.6 V,1
IDE09797-IDE10294-Adaptation of range calculation-Initialization of LPG range consumption,1.0 l/100km,48
IDE09797-MAS09198-Adaptation of range calculation-Init. value of average speed electrical trip,4 km/h,48
IDE09797-MAS09199-Adaptation of range calculation-Init. value absolute forecast deviation air-condition. interior,-15000 W,48
IDE09797-MAS09200-Adaptation of range calculation-Init. value average performance A/C components,0 W,48
IDE09797-MAS09201-Adaptation of range calculation-Init. value average perf. low voltage basic consumer,0 W,48
IDE09797-MAS09202-Adaptation of range calculation-Init. value RWDS load profile,15 A,48
IDE09797-MAS09203-Adaptation of range calculation-Init. value of elec. average consumption on street class 0,1.0 kWh/100 km,48
IDE09797-MAS09204-Adaptation of range calculation-Init. value of elec. average consumption on street class 1,1.0 kWh/100 km,48
IDE09797-MAS09205-Adaptation of range calculation-Init. value of elec. average consumption on street class 2,1.0 kWh/100 km,48
IDE09797-MAS09206-Adaptation of range calculation-Init. value of elec. average consumption on street class 3,1.0 kWh/100 km,48
IDE09797-MAS09207-Adaptation of range calculation-Init. value of elec. average consumption on street class 4,1.0 kWh/100 km,48
IDE09797-MAS09208-Adaptation of range calculation-Init. value of elec. average consumption on street class 5,1.0 kWh/100 km,48
IDE09797-MAS09209-Adaptation of range calculation-Init. value average consumption BMS electric (forecast horizon),1.5 kWh/100 km,48
IDE09797-MAS09210-Adaptation of range calculation-Init. value cons. eng. range cons.,1.0 l/100km,48
IDE09797-MAS09211-Adaptation of range calculation-Init. value average range consumption: electric traction,1.0 kWh/100 km,48
IDE09797-MAS09212-Adaptation of range calculation-Init. value of elec. average consumption on street class 6,1.0 kWh/100 km,48
IDE09797-MAS10126-Adaptation of range calculation-Initialization of CNG range consumption,1.0 kg/100 km,48
IDE09797-MAS10294-Adaptation of range calculation-Initial value of average fuel consumption on street class 0,1.0 l/100km,48
IDE09797-MAS10295-Adaptation of range calculation-Initial value of average fuel consumption on street class 1,1.0 l/100km,48
IDE09797-MAS10296-Adaptation of range calculation-Initial value of average fuel consumption on street class 2,1.0 l/100km,48
IDE09797-MAS10297-Adaptation of range calculation-Initial value of average fuel consumption on street class 3,1.0 l/100km,48
IDE09797-MAS10298-Adaptation of range calculation-Initial value of average fuel consumption on street class 4,1.0 l/100km,48
IDE09797-MAS10299-Adaptation of range calculation-Initial value of average fuel consumption on street class 5,1.0 l/100km,48
IDE09797-MAS10300-Adaptation of range calculation-Initial value of average fuel consumption on street class 6,1.0 l/100km,48
IDE10735-Number requests autonomous recharging,3 ,1
IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
IDE10748-MAS19099-Range gain-Convenience consumption socket,not activated ,3
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
IDE12132-Dynamic reserve capacity,10 W,1
IDE15331-Multifunction steering wheel extended adaptation,Configuration 4 ,3
MAS16372-Security version number,3 ,2
SFT271921-IDE02583-Multi-function steering wheel control module-Steering wheel Tiptronic switch,installed ,3
SFT271921-MAS02311-Multi-function steering wheel control module-Steering wheel heating button,not active ,3
SFT271921-MAS04733-Multi-function steering wheel control module-Two-stage,not active ,3
SFT271921-MAS06614-Multi-function steering wheel control module-Variant,ACC ,3
SFT271921-MAS09758-Multi-function steering wheel control module-Temperature sensor,not installed ,3
SFT271921-MAS13892-Multi-function steering wheel control module-Platform,MQB ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,not active ,3
SFT271921-MAS19104-Multi-function steering wheel control module-Alarm horn wake-up function,active ,3
SFT271921-ENG258379-Multi-function steering wheel control module-clamp behaviour,active with terminal 58 ,3
SFT271921-ENG260738-Multi-function steering wheel control module-FoD ACC,activated ,3
SFT271921-ENG258784-Multi-function steering wheel control module-FoD Travel Assist,activated ,3
SFT271921-ENG262857-Multi-function steering wheel control module-Kombi_02_gueltig,not active ,3
SFT272190-Steering Wheel Touch Recognition Control Module,data_set_1 ,3
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4
ENG137075-EM_heating_power_quota_adjustment,1000 W,1
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-HVAC electronics,activated ,32
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,activated ,32
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,activated ,32
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for driver assistance systems,activated ,32
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistance 2,activated ,32
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
Elapsed Time: 00:27
Trevas
Portugal
C?ID=516418
adpmap-23-3Q0-909-059-G_WVWZZZ3CZME009325-20260823-2128.CSV
;SW:3Q0-909-059-G   HW:3Q0-909-059-A ---  23: Brake Booster
;Component:EBKV          H06 0069, Coding:0202C104340000C618638C31000049922449920400
;EV_BrakeBoostG2BoschVW48X,011019,EV_BrakeBoostG2BoschVW48X_011_VW48.rod
;Sunday,23,August,2026,21:28:39:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 3B285896D3E27952CB0-806E
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,20 min,2
IDE11447-electro-mechanical brake booster,active ,1
IDE11985-Expected OBD requirements,EOBD ,1
IDE14698-Parameters of leak test-,14.0000000 mm,20
IDE14698-Parameters of leak test-,30.0000000 mm/s,20
IDE14698-Parameters of leak test-,4 ,20
IDE14698-Parameters of leak test-,1.0 s,20
IDE14698-Parameters of leak test-,15.0000000 mm,20
IDE14698-Parameters of leak test-,3.0000000 mm/s,20
IDE14698-Parameters of leak test-,12.0 s,20
IDE14698-Parameters of leak test-,10.0 s,20
IDE14698-Parameters of leak test-,60 bar,20
IDE14698-Parameters of leak test-,5.0000000 mm,20
IDE14698-Parameters of leak test-,12.0000000 mm,20
IDE14699-Parameters of heaviness test-,12.0000000 mm,13
IDE14699-Parameters of heaviness test-,30.0000000 mm/s,13
IDE14699-Parameters of heaviness test-,5 ,13
IDE14699-Parameters of heaviness test-,0.5 s,13
IDE14699-Parameters of heaviness test-,0.0 s,13
IDE14699-Parameters of heaviness test-,1.29980468750 Nm,13
IDE14699-Parameters of heaviness test-,50.0000000 mm/s,13
IDE14700-Parameters of ventilation routine-,21.0000000 mm,18
IDE14700-Parameters of ventilation routine-,180.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,25 ,18
IDE14700-Parameters of ventilation routine-,50.0000000 ,18
IDE14700-Parameters of ventilation routine-,0.0 s,18
IDE14700-Parameters of ventilation routine-,30.0000000 mm,18
IDE14700-Parameters of ventilation routine-,5.0000000 mm/s,18
IDE14700-Parameters of ventilation routine-,5 ,18
IDE14700-Parameters of ventilation routine-,1.7968750 mm/s,18
IDE14700-Parameters of ventilation routine-,1.0 s,18
IDE80111-Analysis 111,active ,1
IDE80121-Analysis 121-,65 s,2
IDE80121-Analysis 121-,0 ,2
IDE80122-Analysis 122-,60 s,2
IDE80122-Analysis 122-,0 ,2
IDE80123-Analysis 123,OFF ,1
IDE80124-Analysis 124-,00 ,2
IDE80124-Analysis 124-,0 ,2
IDE80125-Analysis 125-,0 ,2
IDE80126-Analysis 126,0 ,2
IDE80131-MAS05513-Analysis 131-Bit 0,OFF ,1
IDE80131-MAS05514-Analysis 131-Bit 1,OFF ,1
IDE80131-MAS05515-Analysis 131-Bit 2,OFF ,1
IDE80131-MAS05516-Analysis 131-Bit 3,OFF ,1
IDE80131-MAS05517-Analysis 131-Bit 4,OFF ,1
IDE80131-MAS05518-Analysis 131-Bit 5,OFF ,1
IDE80131-MAS05519-Analysis 131-Bit 6,OFF ,1
IDE80131-MAS05520-Analysis 131-Bit 7,OFF ,1
IDE80134-Analysis 134-,00 00 00 00 ,40
IDE80134-Analysis 134-,00 ,40
IDE80135-Analysis 135-,00 00 00 00 ,40
IDE80135-Analysis 135-,00 ,40
IDE80136-Analysis 136-,00 00 00 00 ,40
IDE80136-Analysis 136-,00 ,40
IDE80137-Analysis 137-,00 00 00 00 ,40
IDE80137-Analysis 137-,00 ,40
MAS00194----,00 00 ,2
Elapsed Time: 00:06
adpmap-2B-3Q0-905-861-B_WVWZZZ3CZME009325-20260823-2128.CSV
;SW:3Q0-905-861-B   HW:3Q0-905-861-B ---  2B: Steer. Col. Lock
;Component:ELV-MQBB      H05 0020, Coding:0800000000000000
;EV_ELVMarqMQBA0,002002,EV_ELVMarqMQBA0_VW48.rod
;Sunday,23,August,2026,21:28:54:32152
;VCID: 333870B6FBB2B112130-8066
IDE07566-Steering column lock unlocked,unlock ,1
ENG128823-functional_check_manufacturer,tested ,1
ENG128824-functional_check_steering_column_supplier,tested ,1
Elapsed Time: 00:01
adpmap-42-5Q0-959-593-K_WVWZZZ3CZME009325-20260823-2129.CSV
;SW:5Q0-959-593-K   HW:5Q0-959-593-F ---  42: Door Elect, Driver
;Component:TSG FS002 0330, Coding:003F0F20D000020000001000
;EV_DCU2DriveSideMAXHKLO,001018,EV_DCU2DriveSideMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:29:10:32152
;VCID: 49C4325E893EDBC249C-801C
IDE09067-Side window shade: service mode,Deactivating ,1
Elapsed Time: 00:03
adpmap-44-5Q0-910-143-C_WVWZZZ3CZME009325-20260823-2129.CSV
;SW:5Q0-910-143-C   HW:5Q0-910-143 ---  44: Steering Assist
;Component:MQB_VWBS_GEN2 212 2211, Coding:0100001100410010
;EV_SteerAssisVWBSMQBGen2,002119,EV_SteerAssisVWBSMQBGen2.rod
;Sunday,23,August,2026,21:29:28:32152
;VCID: 2B0868D62382E9D25B0-807E
IDE03724-Straight line running,active ,1
IDE04130-Characteristic curve of steering assistance,selection_by_charisma ,1
IDE06419-Driving profile switchover,Incremental: controlled over time ,1
ENG167423-Activation_of_steering_assist_without_engine_running_100_perCent_noInit,not active ,1
Elapsed Time: 00:02
adpmap-4B-3Q0-907-338-F_WVWZZZ3CZME009325-20260823-2129.CSV
;SW:3Q0-907-338-F   HW:3Q0-907-338-F ---  4B: Multifunc. Module
;Component:FCM MQB High  004 0370, Coding:000000070B0004CA00000F11000302040000000000000000000000000000
;EV_MultiModulContiVW48X,003003,EV_MultiModulContiVW48X_003_VW48.rod
;Sunday,23,August,2026,21:29:53:32152
;VCID: 3822479AE2D4524A262-806C
IDE03641-Presentation run dynamic AFS light,active ,1
IDE08418-Matrix light: total dimming,100.8 %,1
IDE09156-Matrix headlamp: function at standstill,not active ,1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46,OFF ,12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47,OFF ,12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48,OFF ,12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49,OFF ,12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50,OFF ,12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51,OFF ,12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52,OFF ,12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53,OFF ,12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54,OFF ,12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55,OFF ,12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56,OFF ,12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57,OFF ,12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58,OFF ,12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59,OFF ,12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60,OFF ,12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61,OFF ,12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62,OFF ,12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63,OFF ,12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64,OFF ,12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65,OFF ,12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66,OFF ,12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67,OFF ,12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68,OFF ,12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69,OFF ,12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70,OFF ,12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71,OFF ,12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72,OFF ,12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73,OFF ,12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74,OFF ,12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75,OFF ,12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76,OFF ,12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77,OFF ,12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78,OFF ,12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79,OFF ,12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80,OFF ,12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81,OFF ,12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82,OFF ,12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83,OFF ,12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84,OFF ,12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85,OFF ,12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86,OFF ,12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87,OFF ,12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88,OFF ,12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89,OFF ,12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90,OFF ,12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46,OFF ,12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47,OFF ,12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48,OFF ,12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49,OFF ,12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50,OFF ,12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51,OFF ,12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52,OFF ,12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53,OFF ,12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54,OFF ,12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55,OFF ,12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56,OFF ,12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57,OFF ,12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58,OFF ,12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59,OFF ,12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60,OFF ,12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61,OFF ,12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62,OFF ,12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63,OFF ,12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64,OFF ,12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65,OFF ,12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66,OFF ,12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67,OFF ,12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68,OFF ,12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69,OFF ,12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70,OFF ,12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71,OFF ,12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72,OFF ,12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73,OFF ,12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74,OFF ,12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75,OFF ,12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76,OFF ,12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77,OFF ,12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78,OFF ,12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79,OFF ,12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80,OFF ,12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81,OFF ,12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82,OFF ,12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83,OFF ,12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84,OFF ,12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85,OFF ,12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86,OFF ,12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87,OFF ,12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88,OFF ,12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89,OFF ,12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90,OFF ,12
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest,30 %,12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion,30 %,12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest,30 %,12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion,30 %,12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest,50 %,12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion,50 %,12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest,50 %,12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion,50 %,12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest,75 %,12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion,75 %,12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest,80 %,12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion,80 %,12
IDE12488-Antenna 1 for short-range communication,40 00 01 05 3F 14 05 0A 48 05 01 28 00 00 00 00 F0 03 14 00 A4 04 00 0F A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 FF 10 00 00 00 00 00 00 00 14 1E ,50
IDE12489-Antenna 2 for short-range communication,00 A1 00 05 0A 14 00 02 02 32 0A 00 00 00 00 00 0A 03 64 00 A4 04 00 0F A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 00 10 00 00 03 00 00 00 00 00 00 ,50
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
IDE13611-Cornering lamp in operation,not active ,1
IDE13612-Matrix head lamps: steering angle,9600.00 °,2
IDE14431-Wireless charging: functions-,11 ,2
IDE14431-Wireless charging: functions-,level 1 ,2
SFT272093-MAS10342-Fan 1 for left rear seat backrest-No. of start-up attempts after blocking error,No Response From Subnet Component,2
SFT272093-MAS20139-Fan 1 for left rear seat backrest-Block detection latency period,No Response From Subnet Component,2
SFT272093-MAS20140-Fan 1 for left rear seat backrest-Maximum fan speed,No Response From Subnet Component,2
SFT272093-MAS20141-Fan 1 for left rear seat backrest-Blower speed minimum,No Response From Subnet Component,2
SFT272093-ENG125700-Fan 1 for left rear seat backrest-Critical_Temperature_Treshold,No Response From Subnet Component,2
SFT272093-ENG125697-Fan 1 for left rear seat backrest-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,2
SFT272093-ENG125695-Fan 1 for left rear seat backrest-Overvoltage_treshold,No Response From Subnet Component,2
SFT272093-ENG125696-Fan 1 for left rear seat backrest-Undervoltage_treshold,No Response From Subnet Component,2
SFT272095-MAS10342-Fan 1 for left rear seat cushion-No. of start-up attempts after blocking error,No Response From Subnet Component,2
SFT272095-MAS20139-Fan 1 for left rear seat cushion-Block detection latency period,No Response From Subnet Component,2
SFT272095-MAS20140-Fan 1 for left rear seat cushion-Maximum fan speed,No Response From Subnet Component,2
SFT272095-MAS20141-Fan 1 for left rear seat cushion-Blower speed minimum,No Response From Subnet Component,2
SFT272095-ENG125700-Fan 1 for left rear seat cushion-Critical_Temperature_Treshold,No Response From Subnet Component,2
SFT272095-ENG125697-Fan 1 for left rear seat cushion-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,2
SFT272095-ENG125695-Fan 1 for left rear seat cushion-Overvoltage_treshold,No Response From Subnet Component,2
SFT272095-ENG125696-Fan 1 for left rear seat cushion-Undervoltage_treshold,No Response From Subnet Component,2
SFT272097-MAS10342-Fan 1 for right rear seat backrest-No. of start-up attempts after blocking error,No Response From Subnet Component,2
SFT272097-MAS20139-Fan 1 for right rear seat backrest-Block detection latency period,No Response From Subnet Component,2
SFT272097-MAS20140-Fan 1 for right rear seat backrest-Maximum fan speed,No Response From Subnet Component,2
SFT272097-MAS20141-Fan 1 for right rear seat backrest-Blower speed minimum,No Response From Subnet Component,2
SFT272097-ENG125700-Fan 1 for right rear seat backrest-Critical_Temperature_Treshold,No Response From Subnet Component,2
SFT272097-ENG125697-Fan 1 for right rear seat backrest-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,2
SFT272097-ENG125695-Fan 1 for right rear seat backrest-Overvoltage_treshold,No Response From Subnet Component,2
SFT272097-ENG125696-Fan 1 for right rear seat backrest-Undervoltage_treshold,No Response From Subnet Component,2
SFT272099-MAS10342-Fan 1 for right rear seat cushion-No. of start-up attempts after blocking error,No Response From Subnet Component,2
SFT272099-MAS20139-Fan 1 for right rear seat cushion-Block detection latency period,No Response From Subnet Component,2
SFT272099-MAS20140-Fan 1 for right rear seat cushion-Maximum fan speed,No Response From Subnet Component,2
SFT272099-MAS20141-Fan 1 for right rear seat cushion-Blower speed minimum,No Response From Subnet Component,2
SFT272099-ENG125700-Fan 1 for right rear seat cushion-Critical_Temperature_Treshold,No Response From Subnet Component,2
SFT272099-ENG125697-Fan 1 for right rear seat cushion-Hysteresis_Treshold_For_Undervoltage,No Response From Subnet Component,2
SFT272099-ENG125695-Fan 1 for right rear seat cushion-Overvoltage_treshold,No Response From Subnet Component,2
SFT272099-ENG125696-Fan 1 for right rear seat cushion-Undervoltage_treshold,No Response From Subnet Component,2
ENG153902-NFC_FS_debug_switch,00 ,1
ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
ENG103979-Reference_Run_Start_Condition,Engine start ,1
ENG153761-Reset_Rear_left_seat_backrest_fan_1,No Response From Subnet Component,1
ENG153762-Reset_Rear_left_seat_cushion_fan_1,No Response From Subnet Component,1
ENG153763-Reset_Rear_right_seat_backrest_fan_1,No Response From Subnet Component,1
ENG153764-Reset_Rear_right_seat_cushion_fan_1,No Response From Subnet Component,1
Elapsed Time: 00:23
adpmap-51-3G0-907-080-G_WVWZZZ3CZME009325-20260823-2130.CSV
;SW:3G0-907-080-G   HW:3G0-907-080-G ---  51: Electric Drive
;Component:LE Gen 3.3H17 0090, Coding:03090000000000000000
;EV_DMCM08530113G0907080G,001020,EV_DMCM08530113G0907080G.rod
;Sunday,23,August,2026,21:30:32:32152
;VCID: 290492DE297EFBC2A9C-807C
Elapsed Time: 00:01
adpmap-52-5Q0-959-592-K_WVWZZZ3CZME009325-20260823-2130.CSV
;SW:5Q0-959-592-K   HW:5Q0-959-592-F ---  52: Door Elect, Pass.
;Component:TSG BFS002 0330, Coding:003F0120DC00020000001000
;EV_DCU2PasseSideMAXHKLO,001018,EV_DCU2PasseSideMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:30:46:32152
;VCID: 48C2375A923422CA562-801C
Elapsed Time: 00:03
adpmap-5F-3G5-035-816-B_WVWZZZ3CZME009325-20260823-2131.CSV
;SW:3G5-035-816-B   HW:3G5-035-816-B ---  5F: Information Electr.
;Component:MU-O-ND-EU    H22 0270, Coding:24820000000020000000000000000000000000000000000000
;EV_MUOIMQB,001001,EV_MUOIMQB_001_VW48.rod
;Sunday,23,August,2026,21:31:25:32152
;VCID: 280297DA3274C2CAB62-807C
IDE00001-ENG248499-Production mode-air_condition_operation,not activated ,3
IDE00001-ENG154175-Production mode-Bluetooth,not activated ,3
IDE00001-ENG248636-Production mode-display_1_move,not activated ,3
IDE00001-ENG248637-Production mode-display_1_on_off,not activated ,3
IDE00001-ENG248638-Production mode-display_2_move,not activated ,3
IDE00001-ENG248639-Production mode-display_2_on_off,not activated ,3
IDE00001-ENG251560-Production mode-display_3_on_off,not activated ,3
IDE00001-ENG282031-Production mode-Display_4_on_off,not activated ,3
IDE00001-ENG252053-Production mode-early_audio,not activated ,3
IDE00001-ENG248670-Production mode-extendible_tweeters,not activated ,3
IDE00001-ENG175909-Production mode-FPK,not activated ,3
IDE00001-ENG248687-Production mode-fpk_display,not activated ,3
IDE00001-ENG248690-Production mode-frequency_modification,not activated ,3
IDE00001-ENG146079-Production mode-Operation,not activated ,3
IDE00001-ENG248771-Production mode-p_mode_id_13,not activated ,3
IDE00001-ENG248772-Production mode-p_mode_id_14,not activated ,3
IDE00001-ENG248485-Production mode-Parameter_21,not activated ,3
IDE00001-ENG248486-Production mode-Parameter_22,not activated ,3
IDE00001-ENG248487-Production mode-Parameter_23,not activated ,3
IDE00001-ENG248791-Production mode-paramter_24,not activated ,3
IDE00001-ENG248796-Production mode-radio_link_esim,not activated ,3
IDE00001-ENG248480-Production mode-SDS,not activated ,3
IDE00001-ENG168106-Production mode-volume_control,not activated ,3
IDE00001-ENG248489-Production mode-Wifi,not activated ,3
IDE00346-Summertime-automatic,manually ,1
IDE00768-Country identification: country of sale,BE ,2
IDE00769-Call number 1 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-MAS03180-Activating and deactivating all development messages-Local data bus,OFF ,1
IDE00820-MAS05583-Activating and deactivating all development messages-Data bus,OFF ,1
IDE02125-MAS08233-Voice operation for telephone-other,installed ,1
IDE02125-MAS18502-Voice operation for telephone-Apple device,not installed ,1
IDE02330-Call number 2 for info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,121
IDE02476-ENG248529-Electrical test of speakers-channel_1_lower_threshold,255 ,121
IDE02476-ENG248531-Electrical test of speakers-channel_1_upper_threshold,255 ,121
IDE02476-ENG248533-Electrical test of speakers-channel_10_lower_threshold,255 ,121
IDE02476-ENG248535-Electrical test of speakers-channel_10_upper_threshold,255 ,121
IDE02476-ENG248537-Electrical test of speakers-channel_11_lower_threshold,255 ,121
IDE02476-ENG248539-Electrical test of speakers-channel_11_upper_threshold,255 ,121
IDE02476-ENG248541-Electrical test of speakers-channel_12_lower_threshold,255 ,121
IDE02476-ENG248543-Electrical test of speakers-channel_12_upper_threshold,255 ,121
IDE02476-ENG248545-Electrical test of speakers-channel_13_lower_threshold,255 ,121
IDE02476-ENG248547-Electrical test of speakers-channel_13_upper_threshold,255 ,121
IDE02476-ENG248549-Electrical test of speakers-channel_14_lower_threshold,255 ,121
IDE02476-ENG248551-Electrical test of speakers-channel_14_upper_threshold,255 ,121
IDE02476-ENG248553-Electrical test of speakers-channel_15_lower_threshold,255 ,121
IDE02476-ENG248555-Electrical test of speakers-channel_15_upper_threshold,255 ,121
IDE02476-ENG248557-Electrical test of speakers-channel_16_lower_threshold,255 ,121
IDE02476-ENG248559-Electrical test of speakers-channel_16_upper_threshold,255 ,121
IDE02476-ENG248561-Electrical test of speakers-channel_17_lower_threshold,255 ,121
IDE02476-ENG248563-Electrical test of speakers-channel_17_upper_threshold,255 ,121
IDE02476-ENG248565-Electrical test of speakers-channel_18_lower_threshold,255 ,121
IDE02476-ENG248567-Electrical test of speakers-channel_18_upper_threshold,255 ,121
IDE02476-ENG248569-Electrical test of speakers-channel_19_lower_threshold,255 ,121
IDE02476-ENG248570-Electrical test of speakers-channel_19_upper_threshold,255 ,121
IDE02476-ENG248573-Electrical test of speakers-channel_2_lower_threshold,255 ,121
IDE02476-ENG248575-Electrical test of speakers-channel_2_upper_threshold,255 ,121
IDE02476-ENG248577-Electrical test of speakers-channel_20_lower_threshold,255 ,121
IDE02476-ENG248579-Electrical test of speakers-channel_20_upper_threshold,255 ,121
IDE02476-ENG248581-Electrical test of speakers-channel_21_lower_threshold,255 ,121
IDE02476-ENG248583-Electrical test of speakers-channel_21_upper_threshold,255 ,121
IDE02476-ENG248585-Electrical test of speakers-channel_22_lower_threshold,255 ,121
IDE02476-ENG248587-Electrical test of speakers-channel_22_upper_threshold,255 ,121
IDE02476-ENG248589-Electrical test of speakers-channel_23_lower_threshold,255 ,121
IDE02476-ENG248591-Electrical test of speakers-channel_23_upper_threshold,255 ,121
IDE02476-ENG248593-Electrical test of speakers-channel_24_lower_threshold,255 ,121
IDE02476-ENG248595-Electrical test of speakers-channel_24_upper_threshold,255 ,121
IDE02476-ENG248599-Electrical test of speakers-channel_3_lower_threshold,255 ,121
IDE02476-ENG248601-Electrical test of speakers-channel_3_upper_threshold,255 ,121
IDE02476-ENG248603-Electrical test of speakers-channel_4_lower_threshold,255 ,121
IDE02476-ENG248605-Electrical test of speakers-channel_4_upper_threshold,255 ,121
IDE02476-ENG248607-Electrical test of speakers-channel_5_lower_threshold,255 ,121
IDE02476-ENG248609-Electrical test of speakers-channel_5_upper_threshold,255 ,121
IDE02476-ENG248611-Electrical test of speakers-channel_6_lower_threshold,255 ,121
IDE02476-ENG248613-Electrical test of speakers-channel_6_upper_threshold,255 ,121
IDE02476-ENG248615-Electrical test of speakers-channel_7_lower_threshold,255 ,121
IDE02476-ENG248617-Electrical test of speakers-channel_7_upper_threshold,255 ,121
IDE02476-ENG248619-Electrical test of speakers-channel_8_lower_threshold,255 ,121
IDE02476-ENG248621-Electrical test of speakers-channel_8_upper_threshold,255 ,121
IDE02476-ENG248623-Electrical test of speakers-channel_9_lower_threshold,255 ,121
IDE02476-ENG248625-Electrical test of speakers-channel_9_upper_threshold,255 ,121
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,121
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,49 ,121
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,121
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,49 ,121
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,121
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,49 ,121
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,121
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,49 ,121
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,121
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,49 ,121
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,121
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,49 ,121
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,121
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,49 ,121
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,121
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,49 ,121
IDE02476-ENG126164-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Frequency,19000 Hz,121
IDE02476-ENG126165-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_17_Test_Volume,49 ,121
IDE02476-ENG126166-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Frequency,19000 Hz,121
IDE02476-ENG126167-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_18_Test_Volume,49 ,121
IDE02476-ENG126168-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Frequency,19000 Hz,121
IDE02476-ENG126169-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_19_Test_Volume,49 ,121
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,121
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,49 ,121
IDE02476-ENG126170-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Frequency,19000 Hz,121
IDE02476-ENG126171-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_20_Test_Volume,49 ,121
IDE02476-ENG126172-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Frequency,19000 Hz,121
IDE02476-ENG126173-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_21_Test_Volume,49 ,121
IDE02476-ENG126174-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Frequency,19000 Hz,121
IDE02476-ENG126175-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_22_Test_Volume,49 ,121
IDE02476-ENG126176-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Frequency,19000 Hz,121
IDE02476-ENG126177-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_23_Test_Volume,49 ,121
IDE02476-ENG126178-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Frequency,19000 Hz,121
IDE02476-ENG126179-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_24_Test_Volume,49 ,121
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,121
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,49 ,121
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,121
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,49 ,121
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,121
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,49 ,121
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,121
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,49 ,121
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,121
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,49 ,121
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,121
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,49 ,121
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,121
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,49 ,121
IDE02502-Confirmation of installation change,A9 A2 ,2
IDE02506-MAS03229-Copy multimedia data-Data carrier,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,OFF ,1
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04300-ENG331904-Vehicle menu operation-menu_AirHeater,not activated ,256
IDE04300-ENG331905-Vehicle menu operation-menu_AirHeater_after_disclaimer,not activated ,256
IDE04300-ENG331906-Vehicle menu operation-menu_AirHeater_clamp_15_off,not activated ,256
IDE04300-ENG331907-Vehicle menu operation-menu_AirHeater_over_threshold_high,not activated ,256
IDE04300-ENG331908-Vehicle menu operation-menu_AirHeater_standstill,not activated ,256
IDE04300-ENG252089-Vehicle menu operation-menu_ambient_illumination_2,not activated ,256
IDE04300-ENG252074-Vehicle menu operation-menu_ambient_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252062-Vehicle menu operation-menu_ambient_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252061-Vehicle menu operation-menu_ambient_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252091-Vehicle menu operation-menu_ambient_illumination_2_stillstand,not activated ,256
IDE04300-ENG125811-Vehicle menu operation-menu_auxiliary_climatization,not activated ,256
IDE04300-ENG125814-Vehicle menu operation-menu_auxiliary_climatization_after_disclaimer,not activated ,256
IDE04300-ENG126995-Vehicle menu operation-menu_auxiliary_climatization_clamp_15_off,not activated ,256
IDE04300-ENG125812-Vehicle menu operation-menu_auxiliary_climatization_over_threshold_high,not activated ,256
IDE04300-ENG125813-Vehicle menu operation-menu_auxiliary_climatization_standstill,not activated ,256
IDE04300-ENG152538-Vehicle menu operation-menu_auxiliary_ventilation,not activated ,256
IDE04300-ENG152539-Vehicle menu operation-menu_auxiliary_ventilation_after_disclaimer,not activated ,256
IDE04300-ENG152540-Vehicle menu operation-menu_auxiliary_ventilation_clamp_15_off,not activated ,256
IDE04300-ENG152541-Vehicle menu operation-menu_auxiliary_ventilation_over_threshold_high,not activated ,256
IDE04300-ENG152542-Vehicle menu operation-menu_auxiliary_ventilation_standstill,not activated ,256
IDE04300-ENG297698-Vehicle menu operation-menu_BSIS,not activated ,256
IDE04300-ENG297699-Vehicle menu operation-menu_BSIS_after_disclaimer,not activated ,256
IDE04300-ENG297700-Vehicle menu operation-menu_BSIS_clamp_15_off,not activated ,256
IDE04300-ENG297701-Vehicle menu operation-menu_BSIS_over_threshold_high,not activated ,256
IDE04300-ENG297702-Vehicle menu operation-menu_BSIS_standstill,not activated ,256
IDE04300-ENG248728-Vehicle menu operation-menu_Car2X,not activated ,256
IDE04300-ENG248729-Vehicle menu operation-menu_Car2X_after_disclaimer,not activated ,256
IDE04300-ENG248730-Vehicle menu operation-menu_Car2X_clamp_15_off,not activated ,256
IDE04300-ENG248731-Vehicle menu operation-menu_Car2X_over_threshold_high,not activated ,256
IDE04300-ENG248732-Vehicle menu operation-menu_Car2X_stillstand,not activated ,256
IDE04300-ENG249906-Vehicle menu operation-menu_chassis_control,not activated ,256
IDE04300-ENG249907-Vehicle menu operation-menu_chassis_control_after_disclaimer,not activated ,256
IDE04300-ENG249908-Vehicle menu operation-menu_chassis_control_clamp_15_off,not activated ,256
IDE04300-ENG249909-Vehicle menu operation-menu_chassis_control_over_threshold_high,not activated ,256
IDE04300-ENG282005-Vehicle menu operation-menu_chassis_control_standstill,not activated ,256
IDE04300-ENG152495-Vehicle menu operation-menu_connection_manager,not activated ,256
IDE04300-ENG152499-Vehicle menu operation-menu_connection_manager_after_disclaimer,not activated ,256
IDE04300-ENG152496-Vehicle menu operation-menu_connection_manager_clamp_15_off,not activated ,256
IDE04300-ENG152497-Vehicle menu operation-menu_connection_manager_over_threshold_high,not activated ,256
IDE04300-ENG152498-Vehicle menu operation-menu_connection_manager_standstill,not activated ,256
IDE04300-ENG152543-Vehicle menu operation-menu_crossroad_assistent,not activated ,256
IDE04300-ENG152544-Vehicle menu operation-menu_crossroad_assistent_after_disclaimer,not activated ,256
IDE04300-ENG152545-Vehicle menu operation-menu_crossroad_assistent_clamp_15_off,not activated ,256
IDE04300-ENG152546-Vehicle menu operation-menu_crossroad_assistent_over_threshold_high,not activated ,256
IDE04300-ENG152547-Vehicle menu operation-menu_crossroad_assistent_standstill,not activated ,256
IDE04300-ENG152548-Vehicle menu operation-menu_daf_profile,not activated ,256
IDE04300-ENG152549-Vehicle menu operation-menu_daf_profile_after_disclaimer,not activated ,256
IDE04300-ENG152550-Vehicle menu operation-menu_daf_profile_clamp_15_off,not activated ,256
IDE04300-ENG152551-Vehicle menu operation-menu_daf_profile_over_threshold_high,not activated ,256
IDE04300-ENG152552-Vehicle menu operation-menu_daf_profile_stillstand,not activated ,256
IDE04300-ENG251562-Vehicle menu operation-menu_DCC_monitor,not activated ,256
IDE04300-ENG251561-Vehicle menu operation-menu_DCC_monitor_after_disclaimer,not activated ,256
IDE04300-ENG251559-Vehicle menu operation-menu_DCC_monitor_clamp_15_off,not activated ,256
IDE04300-ENG251557-Vehicle menu operation-menu_DCC_monitor_over_threshold_high,not activated ,256
IDE04300-ENG251558-Vehicle menu operation-menu_DCC_monitor_stillstand,not activated ,256
IDE04300-ENG117486-Vehicle menu operation-menu_display_ACC,activated ,256
IDE04300-ENG117490-Vehicle menu operation-menu_display_ACC_after_disclaimer,not activated ,256
IDE04300-ENG117487-Vehicle menu operation-menu_display_ACC_operation_clamp_15_off,not activated ,256
IDE04300-ENG117488-Vehicle menu operation-menu_display_ACC_over_threshold_high,activated ,256
IDE04300-ENG117489-Vehicle menu operation-menu_display_ACC_standstill,not activated ,256
IDE04300-ENG117646-Vehicle menu operation-menu_display_adaptive_key,not activated ,256
IDE04300-ENG117650-Vehicle menu operation-menu_display_adaptive_key_after_disclaimer,not activated ,256
IDE04300-ENG117647-Vehicle menu operation-menu_display_adaptive_key_clamp_15_off,not activated ,256
IDE04300-ENG117648-Vehicle menu operation-menu_display_adaptive_key_over_threshold_high,not activated ,256
IDE04300-ENG117649-Vehicle menu operation-menu_display_adaptive_key_standstill,not activated ,256
IDE04300-ENG126152-Vehicle menu operation-menu_display_Adblue,not activated ,256
IDE04300-ENG126155-Vehicle menu operation-menu_display_Adblue_after_disclaimer,not activated ,256
IDE04300-ENG127002-Vehicle menu operation-menu_display_Adblue_clamp_15_off,not activated ,256
IDE04300-ENG126153-Vehicle menu operation-menu_display_Adblue_over_threshold_high,not activated ,256
IDE04300-ENG126154-Vehicle menu operation-menu_display_Adblue_standstill,not activated ,256
IDE04300-ENG117591-Vehicle menu operation-menu_display_air_damper,not activated ,256
IDE04300-ENG117595-Vehicle menu operation-menu_display_air_damper_after_disclaimer,not activated ,256
IDE04300-ENG117592-Vehicle menu operation-menu_display_air_damper_clamp_15_off,not activated ,256
IDE04300-ENG117593-Vehicle menu operation-menu_display_air_damper_over_threshold_high,not activated ,256
IDE04300-ENG117594-Vehicle menu operation-menu_display_air_damper_standstill,not activated ,256
IDE04300-ENG117491-Vehicle menu operation-menu_display_ambient_illumination,activated ,256
IDE04300-ENG117495-Vehicle menu operation-menu_display_ambient_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117492-Vehicle menu operation-menu_display_ambient_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117493-Vehicle menu operation-menu_display_ambient_illumination_over_threshold_high,activated ,256
IDE04300-ENG117494-Vehicle menu operation-menu_display_ambient_illumination_standstill,not activated ,256
IDE04300-ENG122296-Vehicle menu operation-menu_display_angle_of_slope,not activated ,256
IDE04300-ENG122300-Vehicle menu operation-menu_display_angle_of_slope_after_disclaimer,not activated ,256
IDE04300-ENG122297-Vehicle menu operation-menu_display_angle_of_slope_clamp_15_off,not activated ,256
IDE04300-ENG122298-Vehicle menu operation-menu_display_angle_of_slope_over_threshold_high,not activated ,256
IDE04300-ENG122299-Vehicle menu operation-menu_display_angle_of_slope_standstill,not activated ,256
IDE04300-ENG117641-Vehicle menu operation-menu_display_attention_identification,not activated ,256
IDE04300-ENG117645-Vehicle menu operation-menu_display_attention_identification_after_disclaimer,not activated ,256
IDE04300-ENG117642-Vehicle menu operation-menu_display_attention_identification_clamp_15_off,not activated ,256
IDE04300-ENG117643-Vehicle menu operation-menu_display_attention_identification_over_threshold_high,not activated ,256
IDE04300-ENG117644-Vehicle menu operation-menu_display_attention_identification_standstill,not activated ,256
IDE04300-ENG117531-Vehicle menu operation-menu_display_auxiliary_heating,not activated ,256
IDE04300-ENG117535-Vehicle menu operation-menu_display_auxiliary_heating_after_disclaimer,not activated ,256
IDE04300-ENG117532-Vehicle menu operation-menu_display_auxiliary_heating_clamp_15_off,not activated ,256
IDE04300-ENG117533-Vehicle menu operation-menu_display_auxiliary_heating_over_threshold_high,not activated ,256
IDE04300-ENG117534-Vehicle menu operation-menu_display_auxiliary_heating_standstill,not activated ,256
IDE04300-ENG117501-Vehicle menu operation-menu_display_awv,activated ,256
IDE04300-ENG117505-Vehicle menu operation-menu_display_awv_after_disclaimer,not activated ,256
IDE04300-ENG117502-Vehicle menu operation-menu_display_awv_clamp_15_off,not activated ,256
IDE04300-ENG117503-Vehicle menu operation-menu_display_awv_over_threshold_high,activated ,256
IDE04300-ENG117504-Vehicle menu operation-menu_display_awv_standstill,not activated ,256
IDE04300-ENG122301-Vehicle menu operation-menu_display_battery_management,activated ,256
IDE04300-ENG122305-Vehicle menu operation-menu_display_battery_management_after_disclaimer,not activated ,256
IDE04300-ENG122302-Vehicle menu operation-menu_display_battery_management_clamp_15_off,not activated ,256
IDE04300-ENG122303-Vehicle menu operation-menu_display_battery_management_over_threshold_high,activated ,256
IDE04300-ENG122304-Vehicle menu operation-menu_display_battery_management_standstill,not activated ,256
IDE04300-ENG117666-Vehicle menu operation-menu_display_BCmE,activated ,256
IDE04300-ENG117670-Vehicle menu operation-menu_display_BCmE_after_disclaimer,not activated ,256
IDE04300-ENG117667-Vehicle menu operation-menu_display_BCmE_clamp_15_off,not activated ,256
IDE04300-ENG117668-Vehicle menu operation-menu_display_BCmE_over_threshold_high,activated ,256
IDE04300-ENG117669-Vehicle menu operation-menu_display_BCmE_standstill,not activated ,256
IDE04300-ENG117536-Vehicle menu operation-menu_display_board_computer,activated ,256
IDE04300-ENG117540-Vehicle menu operation-menu_display_board_computer_after_disclaimer,not activated ,256
IDE04300-ENG117537-Vehicle menu operation-menu_display_board_computer_clamp_15_off,not activated ,256
IDE04300-ENG117538-Vehicle menu operation-menu_display_board_computer_over_threshold_high,activated ,256
IDE04300-ENG117539-Vehicle menu operation-menu_display_board_computer_standstill,not activated ,256
IDE04300-ENG117671-Vehicle menu operation-menu_display_Brake_Function,activated ,256
IDE04300-ENG117675-Vehicle menu operation-menu_display_Brake_Function_after_disclaimer,not activated ,256
IDE04300-ENG117672-Vehicle menu operation-menu_display_Brake_Function_clamp_15_off,not activated ,256
IDE04300-ENG117673-Vehicle menu operation-menu_display_Brake_Function_over_threshold_high,activated ,256
IDE04300-ENG117674-Vehicle menu operation-menu_display_Brake_Function_standstill,not activated ,256
IDE04300-ENG117651-Vehicle menu operation-menu_display_car_mirror,activated ,256
IDE04300-ENG117655-Vehicle menu operation-menu_display_car_mirror_after_disclaimer,not activated ,256
IDE04300-ENG117652-Vehicle menu operation-menu_display_car_mirror_clamp_15_off,not activated ,256
IDE04300-ENG117653-Vehicle menu operation-menu_display_car_mirror_over_threshold_high,activated ,256
IDE04300-ENG117654-Vehicle menu operation-menu_display_car_mirror_standstill,not activated ,256
IDE04300-ENG117561-Vehicle menu operation-menu_display_central_locking,activated ,256
IDE04300-ENG117565-Vehicle menu operation-menu_display_central_locking_after_disclaimer,not activated ,256
IDE04300-ENG117562-Vehicle menu operation-menu_display_central_locking_clamp_15_off,not activated ,256
IDE04300-ENG117563-Vehicle menu operation-menu_display_central_locking_over_threshold_high,activated ,256
IDE04300-ENG117564-Vehicle menu operation-menu_display_central_locking_standstill,not activated ,256
IDE04300-ENG117601-Vehicle menu operation-menu_display_central_unit_master,activated ,256
IDE04300-ENG117605-Vehicle menu operation-menu_display_central_unit_master_after_disclaimer,not activated ,256
IDE04300-ENG117602-Vehicle menu operation-menu_display_central_unit_master_clamp_15_off,not activated ,256
IDE04300-ENG117603-Vehicle menu operation-menu_display_central_unit_master_over_threshold_high,activated ,256
IDE04300-ENG117604-Vehicle menu operation-menu_display_central_unit_master_standstill,not activated ,256
IDE04300-ENG117571-Vehicle menu operation-menu_display_charisma,activated ,256
IDE04300-ENG117575-Vehicle menu operation-menu_display_charisma_after_disclaimer,not activated ,256
IDE04300-ENG117572-Vehicle menu operation-menu_display_charisma_clamp_15_off,not activated ,256
IDE04300-ENG117573-Vehicle menu operation-menu_display_charisma_over_threshold_high,activated ,256
IDE04300-ENG117574-Vehicle menu operation-menu_display_charisma_standstill,not activated ,256
IDE04300-ENG117526-Vehicle menu operation-menu_display_clima_configuration,activated ,256
IDE04300-ENG117530-Vehicle menu operation-menu_display_clima_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117527-Vehicle menu operation-menu_display_clima_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_high,activated ,256
IDE04300-ENG117529-Vehicle menu operation-menu_display_clima_configuration_standstill,not activated ,256
IDE04300-ENG117586-Vehicle menu operation-menu_display_clock,activated ,256
IDE04300-ENG117590-Vehicle menu operation-menu_display_clock_after_disclaimer,not activated ,256
IDE04300-ENG117587-Vehicle menu operation-menu_display_clock_clamp_15_off,not activated ,256
IDE04300-ENG117588-Vehicle menu operation-menu_display_clock_over_threshold_high,activated ,256
IDE04300-ENG117589-Vehicle menu operation-menu_display_clock_standstill,not activated ,256
IDE04300-ENG117566-Vehicle menu operation-menu_display_compass,activated ,256
IDE04300-ENG117570-Vehicle menu operation-menu_display_compass_after_disclaimer,not activated ,256
IDE04300-ENG117567-Vehicle menu operation-menu_display_compass_clamp_15_off,not activated ,256
IDE04300-ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high,activated ,256
IDE04300-ENG117569-Vehicle menu operation-menu_display_compass_standstill,not activated ,256
IDE04300-ENG125823-Vehicle menu operation-menu_display_Curve_Assist,not activated ,256
IDE04300-ENG125826-Vehicle menu operation-menu_display_Curve_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126998-Vehicle menu operation-menu_display_Curve_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125824-Vehicle menu operation-menu_display_Curve_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125825-Vehicle menu operation-menu_display_Curve_Assist_standstill,not activated ,256
IDE04300-ENG142087-Vehicle menu operation-menu_display_Display_Configuration,activated ,256
IDE04300-ENG142091-Vehicle menu operation-menu_display_Display_Configuration_after_disclaimer,not activated ,256
IDE04300-ENG142088-Vehicle menu operation-menu_display_Display_Configuration_clamp_15_off,not activated ,256
IDE04300-ENG142089-Vehicle menu operation-menu_display_Display_Configuration_over_threshold_high,activated ,256
IDE04300-ENG142090-Vehicle menu operation-menu_display_Display_Configuration_standstill,not activated ,256
IDE04300-ENG117656-Vehicle menu operation-menu_display_driving_school,not activated ,256
IDE04300-ENG117660-Vehicle menu operation-menu_display_driving_school_after_disclaimer,not activated ,256
IDE04300-ENG117657-Vehicle menu operation-menu_display_driving_school_clamp_15_off,not activated ,256
IDE04300-ENG117658-Vehicle menu operation-menu_display_driving_school_over_threshold_high,not activated ,256
IDE04300-ENG117659-Vehicle menu operation-menu_display_driving_school_standstill,not activated ,256
IDE04300-ENG125034-Vehicle menu operation-menu_display_Ecall,activated ,256
IDE04300-ENG125038-Vehicle menu operation-menu_display_Ecall_after_disclaimer,not activated ,256
IDE04300-ENG126999-Vehicle menu operation-menu_display_eCall_clamp_15_off,not activated ,256
IDE04300-ENG125036-Vehicle menu operation-menu_display_Ecall_over_threshold_high,activated ,256
IDE04300-ENG125037-Vehicle menu operation-menu_display_Ecall_standstill,not activated ,256
IDE04300-ENG126160-Vehicle menu operation-menu_display_Efficiency_Assist,not activated ,256
IDE04300-ENG126163-Vehicle menu operation-menu_display_Efficiency_Assist_after_disclaimer,not activated ,256
IDE04300-ENG127004-Vehicle menu operation-menu_display_Efficiency_Assist_clamp_15_off,not activated ,256
IDE04300-ENG126161-Vehicle menu operation-menu_display_Efficiency_Assist_over_threshold_high,not activated ,256
IDE04300-ENG126162-Vehicle menu operation-menu_display_Efficiency_Assist_standstill,not activated ,256
IDE04300-ENG126144-Vehicle menu operation-menu_display_ENI,activated ,256
IDE04300-ENG126147-Vehicle menu operation-menu_display_ENI_after_disclaimer,not activated ,256
IDE04300-ENG127000-Vehicle menu operation-menu_display_ENI_clamp_15_off,not activated ,256
IDE04300-ENG126145-Vehicle menu operation-menu_display_ENI_over_threshold_high,activated ,256
IDE04300-ENG126146-Vehicle menu operation-menu_display_ENI_standstill,not activated ,256
IDE04300-ENG117516-Vehicle menu operation-menu_display_exterior_illumination,activated ,256
IDE04300-ENG117520-Vehicle menu operation-menu_display_exterior_illumination_after_disclaimer,not activated ,256
IDE04300-ENG117517-Vehicle menu operation-menu_display_exterior_illumination_clamp_15_off,not activated ,256
IDE04300-ENG117518-Vehicle menu operation-menu_display_exterior_illumination_over_threshold_high,activated ,256
IDE04300-ENG117519-Vehicle menu operation-menu_display_exterior_illumination_standstill,not activated ,256
IDE04300-ENG117596-Vehicle menu operation-menu_display_headup_display,not activated ,256
IDE04300-ENG117600-Vehicle menu operation-menu_display_headup_display_after_disclaimer,not activated ,256
IDE04300-ENG117597-Vehicle menu operation-menu_display_headup_display_clamp_15_off,not activated ,256
IDE04300-ENG117598-Vehicle menu operation-menu_display_headup_display_over_threshold_high,not activated ,256
IDE04300-ENG117599-Vehicle menu operation-menu_display_headup_display_standstill,not activated ,256
IDE04300-ENG117606-Vehicle menu operation-menu_display_hybrid,activated ,256
IDE04300-ENG117610-Vehicle menu operation-menu_display_hybrid_after_disclaimer,not activated ,256
IDE04300-ENG117607-Vehicle menu operation-menu_display_hybrid_clamp_15_off,not activated ,256
IDE04300-ENG117608-Vehicle menu operation-menu_display_hybrid_over_threshold_high,activated ,256
IDE04300-ENG117609-Vehicle menu operation-menu_display_hybrid_standstill,not activated ,256
IDE04300-ENG125805-Vehicle menu operation-menu_display_lane_assistant,not activated ,256
IDE04300-ENG125809-Vehicle menu operation-menu_display_lane_assistant_after_disclaimer,not activated ,256
IDE04300-ENG125806-Vehicle menu operation-menu_display_lane_assistant_clamp_15_off,not activated ,256
IDE04300-ENG125807-Vehicle menu operation-menu_display_lane_assistant_over_threshold_high,not activated ,256
IDE04300-ENG125808-Vehicle menu operation-menu_display_lane_assistant_standstill,not activated ,256
IDE04300-ENG117506-Vehicle menu operation-menu_display_Lane_Departure_Warning,activated ,256
IDE04300-ENG117510-Vehicle menu operation-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,256
IDE04300-ENG117507-Vehicle menu operation-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,256
IDE04300-ENG117508-Vehicle menu operation-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,256
IDE04300-ENG117509-Vehicle menu operation-menu_display_Lane_Departure_Warning_standstill,not activated ,256
IDE04300-ENG117631-Vehicle menu operation-menu_display_MFL_jocker,not activated ,256
IDE04300-ENG117635-Vehicle menu operation-menu_display_MFL_jocker_after_disclaimer,not activated ,256
IDE04300-ENG117632-Vehicle menu operation-menu_display_MFL_jocker_clamp_15_off,not activated ,256
IDE04300-ENG117633-Vehicle menu operation-menu_display_MFL_jocker_over_threshold_high,not activated ,256
IDE04300-ENG117634-Vehicle menu operation-menu_display_MFL_jocker_standstill,not activated ,256
IDE04300-ENG117616-Vehicle menu operation-menu_display_night_vision,not activated ,256
IDE04300-ENG117620-Vehicle menu operation-menu_display_night_vision_after_disclaimer,not activated ,256
IDE04300-ENG117617-Vehicle menu operation-menu_display_night_vision_clamp_15_off,not activated ,256
IDE04300-ENG117618-Vehicle menu operation-menu_display_night_vision_over_threshold_high,not activated ,256
IDE04300-ENG117619-Vehicle menu operation-menu_display_night_vision_standstill,not activated ,256
IDE04300-ENG117576-Vehicle menu operation-menu_display_oil_level,not activated ,256
IDE04300-ENG117580-Vehicle menu operation-menu_display_oil_level_after_disclaimer,not activated ,256
IDE04300-ENG117577-Vehicle menu operation-menu_display_oil_level_clamp_15_off,not activated ,256
IDE04300-ENG117578-Vehicle menu operation-menu_display_oil_level_over_threshold_high,not activated ,256
IDE04300-ENG117579-Vehicle menu operation-menu_display_oil_level_standstill,not activated ,256
IDE04300-ENG117496-Vehicle menu operation-menu_display_pdc,activated ,256
IDE04300-ENG117500-Vehicle menu operation-menu_display_pdc_after_disclaimer,not activated ,256
IDE04300-ENG117497-Vehicle menu operation-menu_display_pdc_clamp_15_off,not activated ,256
IDE04300-ENG117498-Vehicle menu operation-menu_display_pdc_over_threshold_high,activated ,256
IDE04300-ENG117499-Vehicle menu operation-menu_display_pdc_standstill,not activated ,256
IDE04300-ENG125815-Vehicle menu operation-menu_display_Pedestrian_Assist,not activated ,256
IDE04300-ENG125818-Vehicle menu operation-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,256
IDE04300-ENG126996-Vehicle menu operation-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,256
IDE04300-ENG125816-Vehicle menu operation-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,256
IDE04300-ENG125817-Vehicle menu operation-menu_display_Pedestrian_Assist_standstill,not activated ,256
IDE04300-ENG117541-Vehicle menu operation-menu_display_rdk,activated ,256
IDE04300-ENG117545-Vehicle menu operation-menu_display_rdk_after_disclaimer,not activated ,256
IDE04300-ENG117542-Vehicle menu operation-menu_display_rdk_clamp_15_off,not activated ,256
IDE04300-ENG117543-Vehicle menu operation-menu_display_rdk_over_threshold_high,activated ,256
IDE04300-ENG117544-Vehicle menu operation-menu_display_rdk_standstill,not activated ,256
IDE04300-ENG122306-Vehicle menu operation-menu_display_RearSeatEntertainment,not activated ,256
IDE04300-ENG122310-Vehicle menu operation-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,256
IDE04300-ENG122307-Vehicle menu operation-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,256
IDE04300-ENG122308-Vehicle menu operation-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,256
IDE04300-ENG122309-Vehicle menu operation-menu_display_RearSeatEntertainment_standstill,not activated ,256
IDE04300-ENG117626-Vehicle menu operation-menu_display_reversible_belt_pre_load,not activated ,256
IDE04300-ENG117630-Vehicle menu operation-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,256
IDE04300-ENG117627-Vehicle menu operation-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,256
IDE04300-ENG117628-Vehicle menu operation-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,256
IDE04300-ENG117629-Vehicle menu operation-menu_display_reversible_belt_pre_load_standstill,not activated ,256
IDE04300-ENG117636-Vehicle menu operation-menu_display_road_sign_identification,activated ,256
IDE04300-ENG117640-Vehicle menu operation-menu_display_road_sign_identification_after_disclaimer,not activated ,256
IDE04300-ENG117637-Vehicle menu operation-menu_display_road_sign_identification_clamp_15_off,not activated ,256
IDE04300-ENG117638-Vehicle menu operation-menu_display_road_sign_identification_over_threshold_high,activated ,256
IDE04300-ENG117639-Vehicle menu operation-menu_display_road_sign_identification_standstill,not activated ,256
IDE04300-ENG117556-Vehicle menu operation-menu_display_seat_configuration,not activated ,256
IDE04300-ENG117560-Vehicle menu operation-menu_display_seat_configuration_after_disclaimer,not activated ,256
IDE04300-ENG117557-Vehicle menu operation-menu_display_seat_configuration_clamp_15_off,not activated ,256
IDE04300-ENG117558-Vehicle menu operation-menu_display_seat_configuration_over_threshold_high,not activated ,256
IDE04300-ENG117559-Vehicle menu operation-menu_display_seat_configuration_standstill,not activated ,256
IDE04300-ENG125819-Vehicle menu operation-menu_display_Seat_Pneumatic,not activated ,256
IDE04300-ENG125822-Vehicle menu operation-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,256
IDE04300-ENG126997-Vehicle menu operation-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,256
IDE04300-ENG125820-Vehicle menu operation-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,256
IDE04300-ENG125821-Vehicle menu operation-menu_display_Seat_Pneumatic_standstill,not activated ,256
IDE04300-ENG117551-Vehicle menu operation-menu_display_sia,activated ,256
IDE04300-ENG117555-Vehicle menu operation-menu_display_sia_after_disclaimer,not activated ,256
IDE04300-ENG117552-Vehicle menu operation-menu_display_sia_clamp_15_off,not activated ,256
IDE04300-ENG117553-Vehicle menu operation-menu_display_sia_over_threshold_high,activated ,256
IDE04300-ENG117554-Vehicle menu operation-menu_display_sia_standstill,not activated ,256
IDE04300-ENG117621-Vehicle menu operation-menu_display_side_view,not activated ,256
IDE04300-ENG117625-Vehicle menu operation-menu_display_side_view_after_disclaimer,not activated ,256
IDE04300-ENG117622-Vehicle menu operation-menu_display_side_view_clamp_15_off,not activated ,256
IDE04300-ENG117623-Vehicle menu operation-menu_display_side_view_over_threshold_high,not activated ,256
IDE04300-ENG117624-Vehicle menu operation-menu_display_side_view_standstill,not activated ,256
IDE04300-ENG122311-Vehicle menu operation-menu_display_special_functions,not activated ,256
IDE04300-ENG122314-Vehicle menu operation-menu_display_special_functions_after_disclaimer,not activated ,256
IDE04300-ENG125810-Vehicle menu operation-menu_display_special_functions_clamp_15_off,not activated ,256
IDE04300-ENG122312-Vehicle menu operation-menu_display_special_functions_over_threshold_high,not activated ,256
IDE04300-ENG122313-Vehicle menu operation-menu_display_special_functions_standstill,not activated ,256
IDE04300-ENG142082-Vehicle menu operation-menu_display_Spoiler,not activated ,256
IDE04300-ENG142086-Vehicle menu operation-menu_display_Spoiler_after_disclaimer,not activated ,256
IDE04300-ENG142083-Vehicle menu operation-menu_display_Spoiler_clamp_15_off,not activated ,256
IDE04300-ENG142084-Vehicle menu operation-menu_display_Spoiler_over_threshold_high,not activated ,256
IDE04300-ENG142085-Vehicle menu operation-menu_display_Spoiler_standstill,not activated ,256
IDE04300-ENG126148-Vehicle menu operation-menu_display_SportHMI,not activated ,256
IDE04300-ENG126151-Vehicle menu operation-menu_display_SportHMI_after_disclaimer,not activated ,256
IDE04300-ENG127001-Vehicle menu operation-menu_display_SportHMI_clamp_15_off,not activated ,256
IDE04300-ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high,not activated ,256
IDE04300-ENG126150-Vehicle menu operation-menu_display_SportHMI_standstill,not activated ,256
IDE04300-ENG117676-Vehicle menu operation-menu_display_Start_Stop_reasons,not activated ,256
IDE04300-ENG117680-Vehicle menu operation-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,256
IDE04300-ENG117677-Vehicle menu operation-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,256
IDE04300-ENG117678-Vehicle menu operation-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,256
IDE04300-ENG117679-Vehicle menu operation-menu_display_Start_Stop_reasons_standstill,not activated ,256
IDE04300-ENG122315-Vehicle menu operation-menu_display_trailer_assistant,not activated ,256
IDE04300-ENG122319-Vehicle menu operation-menu_display_trailer_assistant_after_disclaimer,not activated ,256
IDE04300-ENG122316-Vehicle menu operation-menu_display_trailer_assistant_clamp_15_off,not activated ,256
IDE04300-ENG122317-Vehicle menu operation-menu_display_trailer_assistant_over_threshold_high,not activated ,256
IDE04300-ENG122318-Vehicle menu operation-menu_display_trailer_assistant_standstill,not activated ,256
IDE04300-ENG122320-Vehicle menu operation-menu_display_TV_tuner,not activated ,256
IDE04300-ENG122324-Vehicle menu operation-menu_display_TV_tuner_after_disclaimer,not activated ,256
IDE04300-ENG122321-Vehicle menu operation-menu_display_TV_tuner_clamp_15_off,not activated ,256
IDE04300-ENG122322-Vehicle menu operation-menu_display_TV_tuner_over_threshold_high,not activated ,256
IDE04300-ENG122323-Vehicle menu operation-menu_display_TV_tuner_standstill,not activated ,256
IDE04300-ENG117611-Vehicle menu operation-menu_display_ugdo,not activated ,256
IDE04300-ENG117615-Vehicle menu operation-menu_display_ugdo_after_disclaimer,not activated ,256
IDE04300-ENG117612-Vehicle menu operation-menu_display_ugdo_clamp_15_off,not activated ,256
IDE04300-ENG117613-Vehicle menu operation-menu_display_ugdo_over_threshold_high,not activated ,256
IDE04300-ENG117614-Vehicle menu operation-menu_display_ugdo_standstill,not activated ,256
IDE04300-ENG122291-Vehicle menu operation-menu_display_user_eco_rating,activated ,256
IDE04300-ENG122295-Vehicle menu operation-menu_display_user_eco_rating_after_disclaimer,not activated ,256
IDE04300-ENG122292-Vehicle menu operation-menu_display_user_eco_rating_clamp_15_off,not activated ,256
IDE04300-ENG122293-Vehicle menu operation-menu_display_user_eco_rating_over_threshold_high,activated ,256
IDE04300-ENG122294-Vehicle menu operation-menu_display_user_eco_rating_standstill,not activated ,256
IDE04300-ENG117581-Vehicle menu operation-menu_display_vin,activated ,256
IDE04300-ENG117585-Vehicle menu operation-menu_display_vin_after_disclaimer,not activated ,256
IDE04300-ENG117582-Vehicle menu operation-menu_display_vin_clamp_15_off,not activated ,256
IDE04300-ENG117583-Vehicle menu operation-menu_display_vin_over_threshold_high,activated ,256
IDE04300-ENG117584-Vehicle menu operation-menu_display_vin_standstill,not activated ,256
IDE04300-ENG117661-Vehicle menu operation-menu_display_weariness_recognition,activated ,256
IDE04300-ENG117665-Vehicle menu operation-menu_display_weariness_recognition_after_disclaimer,not activated ,256
IDE04300-ENG117662-Vehicle menu operation-menu_display_weariness_recognition_clamp_15_off,not activated ,256
IDE04300-ENG117663-Vehicle menu operation-menu_display_weariness_recognition_over_threshold_high,activated ,256
IDE04300-ENG117664-Vehicle menu operation-menu_display_weariness_recognition_standstill,not activated ,256
IDE04300-ENG117521-Vehicle menu operation-menu_display_windows,activated ,256
IDE04300-ENG117525-Vehicle menu operation-menu_display_windows_after_disclaimer,not activated ,256
IDE04300-ENG117522-Vehicle menu operation-menu_display_windows_clamp_15_off,not activated ,256
IDE04300-ENG117523-Vehicle menu operation-menu_display_windows_over_threshold_high,activated ,256
IDE04300-ENG117524-Vehicle menu operation-menu_display_windows_standstill,not activated ,256
IDE04300-ENG117546-Vehicle menu operation-menu_display_wiper,activated ,256
IDE04300-ENG117550-Vehicle menu operation-menu_display_wiper_after_disclaimer,not activated ,256
IDE04300-ENG117547-Vehicle menu operation-menu_display_wiper_clamp_15_off,not activated ,256
IDE04300-ENG117548-Vehicle menu operation-menu_display_wiper_over_threshold_high,activated ,256
IDE04300-ENG117549-Vehicle menu operation-menu_display_wiper_standstill,not activated ,256
IDE04300-ENG297703-Vehicle menu operation-menu_Doorlocking_2nd,not activated ,256
IDE04300-ENG297704-Vehicle menu operation-menu_Doorlocking_2nd_after_disclaimer,not activated ,256
IDE04300-ENG297705-Vehicle menu operation-menu_Doorlocking_2nd_clamp_15_off,not activated ,256
IDE04300-ENG297706-Vehicle menu operation-menu_Doorlocking_2nd_over_threshold_high,not activated ,256
IDE04300-ENG297707-Vehicle menu operation-menu_Doorlocking_2nd_standstill,not activated ,256
IDE04300-ENG302732-Vehicle menu operation-menu_DrivingDynamics,not activated ,256
IDE04300-ENG302733-Vehicle menu operation-menu_DrivingDynamics_after_disclaimer,not activated ,256
IDE04300-ENG302734-Vehicle menu operation-menu_DrivingDynamics_clamp_15_off,not activated ,256
IDE04300-ENG302735-Vehicle menu operation-menu_DrivingDynamics_over_threshold_high,not activated ,256
IDE04300-ENG302736-Vehicle menu operation-menu_DrivingDynamics_standstill,not activated ,256
IDE04300-ENG248733-Vehicle menu operation-menu_EngineFunctions,not activated ,256
IDE04300-ENG248734-Vehicle menu operation-menu_EngineFunctions_after_disclaimer,not activated ,256
IDE04300-ENG248735-Vehicle menu operation-menu_EngineFunctions_clamp_15_off,not activated ,256
IDE04300-ENG248736-Vehicle menu operation-menu_EngineFunctions_over_threshold_high,not activated ,256
IDE04300-ENG248737-Vehicle menu operation-menu_EngineFunctions_stillstand,not activated ,256
IDE04300-ENG252067-Vehicle menu operation-menu_exterior_illumination_2,not activated ,256
IDE04300-ENG252055-Vehicle menu operation-menu_exterior_illumination_2_after_disclaimer,not activated ,256
IDE04300-ENG252059-Vehicle menu operation-menu_exterior_illumination_2_clamp_15_off,not activated ,256
IDE04300-ENG252069-Vehicle menu operation-menu_exterior_illumination_2_over_threshold_high,not activated ,256
IDE04300-ENG252082-Vehicle menu operation-menu_exterior_illumination_2_stillstand,not activated ,256
IDE04300-ENG152515-Vehicle menu operation-menu_fas_profile,not activated ,256
IDE04300-ENG152519-Vehicle menu operation-menu_fas_profile_after_disclaimer,not activated ,256
IDE04300-ENG152516-Vehicle menu operation-menu_fas_profile_clamp_15_off,not activated ,256
IDE04300-ENG152517-Vehicle menu operation-menu_fas_profile_over_threshold_high,not activated ,256
IDE04300-ENG248738-Vehicle menu operation-menu_fas_profile_stillstand,not activated ,256
IDE04300-ENG185798-Vehicle menu operation-menu_fod,not activated ,256
IDE04300-ENG185799-Vehicle menu operation-menu_fod_after_disclaimer,not activated ,256
IDE04300-ENG185800-Vehicle menu operation-menu_fod_clamp_15_off,not activated ,256
IDE04300-ENG185801-Vehicle menu operation-menu_fod_over_threshold_high,not activated ,256
IDE04300-ENG185802-Vehicle menu operation-menu_fod_stillstand,not activated ,256
IDE04300-ENG248739-Vehicle menu operation-menu_IAA_PSO,activated ,256
IDE04300-ENG248740-Vehicle menu operation-menu_IAA_PSO_after_disclaimer,not activated ,256
IDE04300-ENG248741-Vehicle menu operation-menu_IAA_PSO_clamp_15_off,not activated ,256
IDE04300-ENG248742-Vehicle menu operation-menu_IAA_PSO_over_threshold_high,activated ,256
IDE04300-ENG248743-Vehicle menu operation-menu_IAA_PSO_stillstand,not activated ,256
IDE04300-ENG248744-Vehicle menu operation-menu_ITM,not activated ,256
IDE04300-ENG248745-Vehicle menu operation-menu_ITM_after_disclaimer,not activated ,256
IDE04300-ENG248746-Vehicle menu operation-menu_ITM_clamp_15_off,not activated ,256
IDE04300-ENG248747-Vehicle menu operation-menu_ITM_over_threshold_high,not activated ,256
IDE04300-ENG248748-Vehicle menu operation-menu_ITM_stillstand,not activated ,256
IDE04300-ENG249916-Vehicle menu operation-menu_lift,not activated ,256
IDE04300-ENG249917-Vehicle menu operation-menu_lift_after_disclaimer,not activated ,256
IDE04300-ENG249918-Vehicle menu operation-menu_lift_clamp_15_off,not activated ,256
IDE04300-ENG249919-Vehicle menu operation-menu_lift_over_threshold_high,not activated ,256
IDE04300-ENG249920-Vehicle menu operation-menu_lift_stillstand,not activated ,256
IDE04300-ENG281916-Vehicle menu operation-menu_LLCC,not activated ,256
IDE04300-ENG281940-Vehicle menu operation-menu_LLCC_after_disclaimer,not activated ,256
IDE04300-ENG282002-Vehicle menu operation-menu_LLCC_clamp_15_off,not activated ,256
IDE04300-ENG281920-Vehicle menu operation-menu_LLCC_over_threshold_high,not activated ,256
IDE04300-ENG281919-Vehicle menu operation-menu_LLCC_standstill,not activated ,256
IDE04300-ENG184478-Vehicle menu operation-menu_mascot,not activated ,256
IDE04300-ENG184479-Vehicle menu operation-menu_mascot_after_disclaimer,not activated ,256
IDE04300-ENG184480-Vehicle menu operation-menu_mascot_clamp_15_off,not activated ,256
IDE04300-ENG184481-Vehicle menu operation-menu_mascot_over_threshold_high,not activated ,256
IDE04300-ENG184482-Vehicle menu operation-menu_mascot_stillstand,not activated ,256
IDE04300-ENG152562-Vehicle menu operation-menu_mobile_device_key_profile,activated ,256
IDE04300-ENG152563-Vehicle menu operation-menu_mobile_device_key_profile_after_disclaimer,not activated ,256
IDE04300-ENG152564-Vehicle menu operation-menu_mobile_device_key_profile_clamp_15_off,not activated ,256
IDE04300-ENG152565-Vehicle menu operation-menu_mobile_device_key_profile_over_threshold_high,not activated ,256
IDE04300-ENG152566-Vehicle menu operation-menu_mobile_device_key_profile_stillstand,not activated ,256
IDE04300-ENG297708-Vehicle menu operation-menu_MOIS,not activated ,256
IDE04300-ENG297709-Vehicle menu operation-menu_MOIS_after_disclaimer,not activated ,256
IDE04300-ENG297710-Vehicle menu operation-menu_MOIS_clamp_15_off,not activated ,256
IDE04300-ENG297711-Vehicle menu operation-menu_MOIS_over_threshold_high,not activated ,256
IDE04300-ENG297712-Vehicle menu operation-menu_MOIS_standstill,not activated ,256
IDE04300-ENG248749-Vehicle menu operation-menu_PaCo,not activated ,256
IDE04300-ENG248750-Vehicle menu operation-menu_PaCo_after_disclaimer,not activated ,256
IDE04300-ENG248751-Vehicle menu operation-menu_PaCo_clamp_15_off,not activated ,256
IDE04300-ENG248752-Vehicle menu operation-menu_PaCo_over_threshold_high,not activated ,256
IDE04300-ENG248753-Vehicle menu operation-menu_PaCo_stillstand,not activated ,256
IDE04300-ENG405718-Vehicle menu operation-menu_Plug_and_Charge,not activated ,256
IDE04300-ENG405719-Vehicle menu operation-menu_Plug_and_Charge_after_disclaimer,not activated ,256
IDE04300-ENG405720-Vehicle menu operation-menu_Plug_and_Charge_clamp_15_off,not activated ,256
IDE04300-ENG405721-Vehicle menu operation-menu_Plug_and_Charge_over_threshold_high,not activated ,256
IDE04300-ENG405722-Vehicle menu operation-menu_Plug_and_Charge_standstill,not activated ,256
IDE04300-ENG395156-Vehicle menu operation-menu_PowerOnDemand,not activated ,256
IDE04300-ENG395157-Vehicle menu operation-menu_PowerOnDemand_after_disclaimer,not activated ,256
IDE04300-ENG395158-Vehicle menu operation-menu_PowerOnDemand_clamp_15_off,not activated ,256
IDE04300-ENG395159-Vehicle menu operation-menu_PowerOnDemand_over_threshold_high,not activated ,256
IDE04300-ENG395160-Vehicle menu operation-menu_PowerOnDemand_standstill,not activated ,256
IDE04300-ENG302737-Vehicle menu operation-menu_RollingAbility,not activated ,256
IDE04300-ENG302738-Vehicle menu operation-menu_RollingAbility_after_disclaimer,not activated ,256
IDE04300-ENG302739-Vehicle menu operation-menu_RollingAbility_clamp_15_off,not activated ,256
IDE04300-ENG302740-Vehicle menu operation-menu_RollingAbility_over_threshold_high,not activated ,256
IDE04300-ENG302741-Vehicle menu operation-menu_RollingAbility_standstill,not activated ,256
IDE04300-ENG297713-Vehicle menu operation-menu_RushhourPilot,not activated ,256
IDE04300-ENG297714-Vehicle menu operation-menu_RushhourPilot_after_disclaimer,not activated ,256
IDE04300-ENG297715-Vehicle menu operation-menu_RushhourPilot_clamp_15_off,not activated ,256
IDE04300-ENG297716-Vehicle menu operation-menu_RushhourPilot_over_threshold_high,not activated ,256
IDE04300-ENG297717-Vehicle menu operation-menu_RushhourPilot_standstill,not activated ,256
IDE04300-ENG142092-Vehicle menu operation-menu_soundcontrol,not activated ,256
IDE04300-ENG248754-Vehicle menu operation-menu_SoundControl_2,not activated ,256
IDE04300-ENG248755-Vehicle menu operation-menu_SoundControl_2_after_disclaimer,not activated ,256
IDE04300-ENG248756-Vehicle menu operation-menu_SoundControl_2_clamp_15_off,not activated ,256
IDE04300-ENG248757-Vehicle menu operation-menu_SoundControl_2_over_threshold_high,not activated ,256
IDE04300-ENG248758-Vehicle menu operation-menu_SoundControl_2_stillstand,not activated ,256
IDE04300-ENG142096-Vehicle menu operation-menu_soundcontrol_after_disclaimer,not activated ,256
IDE04300-ENG142093-Vehicle menu operation-menu_soundcontrol_clamp_15_off,not activated ,256
IDE04300-ENG142094-Vehicle menu operation-menu_soundcontrol_over_threshold_high,not activated ,256
IDE04300-ENG142095-Vehicle menu operation-menu_soundcontrol_standstill,not activated ,256
IDE04300-ENG152505-Vehicle menu operation-menu_statistic,not activated ,256
IDE04300-ENG152509-Vehicle menu operation-menu_statistic_after_disclaimer,not activated ,256
IDE04300-ENG152506-Vehicle menu operation-menu_statistic_clamp_15_off,not activated ,256
IDE04300-ENG152507-Vehicle menu operation-menu_statistic_over_threshold_high,not activated ,256
IDE04300-ENG248759-Vehicle menu operation-menu_statistic_stillstand,not activated ,256
IDE04300-ENG152510-Vehicle menu operation-menu_sunroof,not activated ,256
IDE04300-ENG152514-Vehicle menu operation-menu_sunroof_after_disclaimer,not activated ,256
IDE04300-ENG152511-Vehicle menu operation-menu_sunroof_clamp_15_off,not activated ,256
IDE04300-ENG152512-Vehicle menu operation-menu_sunroof_over_threshold_high,not activated ,256
IDE04300-ENG248760-Vehicle menu operation-menu_sunroof_stillstand,not activated ,256
IDE04300-ENG185803-Vehicle menu operation-menu_vas,not activated ,256
IDE04300-ENG185804-Vehicle menu operation-menu_vas_after_disclaimer,not activated ,256
IDE04300-ENG185805-Vehicle menu operation-menu_vas_clamp_15_off,not activated ,256
IDE04300-ENG185806-Vehicle menu operation-menu_vas_over_threshold_high,not activated ,256
IDE04300-ENG185807-Vehicle menu operation-menu_vas_stillstand,not activated ,256
IDE04300-ENG152500-Vehicle menu operation-menu_wireless_charging,not activated ,256
IDE04300-ENG152504-Vehicle menu operation-menu_wireless_charging_after_disclaimer,not activated ,256
IDE04300-ENG152501-Vehicle menu operation-menu_wireless_charging_clamp_15_off,not activated ,256
IDE04300-ENG152502-Vehicle menu operation-menu_wireless_charging_over_threshold_high,not activated ,256
IDE04300-ENG152503-Vehicle menu operation-menu_wireless_charging_standstill,not activated ,256
IDE04307-ENG117700-Vehicle function list BAP-ACC_0x05,activated ,256
IDE04307-ENG117701-Vehicle function list BAP-ACC_0x05_msg_bus,Extended data bus ,256
IDE04307-ENG117702-Vehicle function list BAP-air_suspension_0x06,not activated ,256
IDE04307-ENG117703-Vehicle function list BAP-air_suspension_0x06_msg_bus,not activated ,256
IDE04307-ENG117764-Vehicle function list BAP-Amplifier_0x2D,not activated ,256
IDE04307-ENG117765-Vehicle function list BAP-Amplifier_0x2D_msg_bus,not activated ,256
IDE04307-ENG122334-Vehicle function list BAP-Angle_Of_Slope_0x24,not activated ,256
IDE04307-ENG122335-Vehicle function list BAP-Angle_Of_Slope_0x24_msg_bus,not activated ,256
IDE04307-ENG117696-Vehicle function list BAP-auxilary_heating_0x03,not activated ,256
IDE04307-ENG117697-Vehicle function list BAP-auxilary_heating_0x03_msg_bus,not activated ,256
IDE04307-ENG117744-Vehicle function list BAP-AWV_0x1B,activated ,256
IDE04307-ENG117745-Vehicle function list BAP-AWV_0x1B_msg_bus,Extended data bus ,256
IDE04307-ENG122336-Vehicle function list BAP-Battery_Management_0x25,activated ,256
IDE04307-ENG122337-Vehicle function list BAP-Battery_Management_0x25_msg_bus,Powertrain data bus ,256
IDE04307-ENG117758-Vehicle function list BAP-BCmE_0x23,activated ,256
IDE04307-ENG117759-Vehicle function list BAP-BCmE_0x23_msg_bus,Infotainment data bus ,256
IDE04307-ENG117760-Vehicle function list BAP-Brake_0x26,activated ,256
IDE04307-ENG117761-Vehicle function list BAP-Brake_0x26_msg_bus,Suspension data bus ,256
IDE04307-ENG297672-Vehicle function list BAP-BSMOIS_0x76,not activated ,256
IDE04307-ENG297673-Vehicle function list BAP-BSMOIS_0x76_msg_bus,not activated ,256
IDE04307-ENG297674-Vehicle function list BAP-BSMOIS2_0x7A,not activated ,256
IDE04307-ENG297675-Vehicle function list BAP-BSMOIS2_0x7A_msg_bus,not activated ,256
IDE04307-ENG297676-Vehicle function list BAP-BSMOIS3_0x7B,not activated ,256
IDE04307-ENG297677-Vehicle function list BAP-BSMOIS3_0x7B_msg_bus,not activated ,256
IDE04307-ENG324690-Vehicle function list BAP-California_0x81,not activated ,256
IDE04307-ENG331873-Vehicle function list BAP-California_0x81_msg_bus,not activated ,256
IDE04307-ENG248526-Vehicle function list BAP-Car2X_0x61,not activated ,256
IDE04307-ENG248527-Vehicle function list BAP-Car2X_0x61_msg_bus,not activated ,256
IDE04307-ENG117717-Vehicle function list BAP-central_locking_0x0D,activated ,256
IDE04307-ENG117716-Vehicle function list BAP-central_locking_0x0D_msg_bus,Comfort data bus ,256
IDE04307-ENG117736-Vehicle function list BAP-charisma_0x17,activated ,256
IDE04307-ENG117737-Vehicle function list BAP-charisma_0x17_msg_bus,Infotainment data bus ,256
IDE04307-ENG282048-Vehicle function list BAP-ChassisControl_0x57,not activated ,256
IDE04307-ENG282008-Vehicle function list BAP-ChassisControl_0x57_msg_bus,not activated ,256
IDE04307-ENG117734-Vehicle function list BAP-clima_slave_2_0x16,not activated ,256
IDE04307-ENG117735-Vehicle function list BAP-clima_slave_2_0x16_msg_bus,not activated ,256
IDE04307-ENG248490-Vehicle function list BAP-climate_master_0x42,not activated ,256
IDE04307-ENG248630-Vehicle function list BAP-climate_master_0x42_msg_bus,not activated ,256
IDE04307-ENG117692-Vehicle function list BAP-climatic_master_0x01,activated ,256
IDE04307-ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus,Comfort data bus ,256
IDE04307-ENG117694-Vehicle function list BAP-climatic_slave_0x02,activated ,256
IDE04307-ENG117695-Vehicle function list BAP-climatic_slave_0x02_msg_bus,Comfort data bus ,256
IDE04307-ENG117724-Vehicle function list BAP-clock_0x11,activated ,256
IDE04307-ENG117725-Vehicle function list BAP-clock_0x11_msg_bus,Comfort data bus ,256
IDE04307-ENG117732-Vehicle function list BAP-compass_0x15,activated ,256
IDE04307-ENG117733-Vehicle function list BAP-compass_0x15_msg_bus,not activated ,256
IDE04307-ENG142158-Vehicle function list BAP-connection_manager_0x47,not activated ,256
IDE04307-ENG142159-Vehicle function list BAP-connection_manager_0x47_msg_bus,not activated ,256
IDE04307-ENG152529-Vehicle function list BAP-daf_profile_0x51,not activated ,256
IDE04307-ENG152530-Vehicle function list BAP-daf_profile_0x51_msg_bus,not activated ,256
IDE04307-ENG137043-Vehicle function list BAP-display_configuration_0x45,activated ,256
IDE04307-ENG137044-Vehicle function list BAP-display_configuration_0x45_msg_bus,Comfort data bus ,256
IDE04307-ENG297681-Vehicle function list BAP-Doorlocking_2nd_0x79,not activated ,256
IDE04307-ENG297682-Vehicle function list BAP-Doorlocking_2nd_0x79_msg_bus,not activated ,256
IDE04307-ENG117722-Vehicle function list BAP-driver_seat_0x10,not activated ,256
IDE04307-ENG117723-Vehicle function list BAP-driver_seat_0x10_msg_bus,Comfort data bus ,256
IDE04307-ENG302721-Vehicle function list BAP-DrivingDynamics_0x7E,not activated ,256
IDE04307-ENG302722-Vehicle function list BAP-DrivingDynamics_0x7E_msg_bus,not activated ,256
IDE04307-ENG125039-Vehicle function list BAP-Ecall_0x33,activated ,256
IDE04307-ENG125828-Vehicle function list BAP-eCall_0x33_msg_bus,Comfort data bus ,256
IDE04307-ENG127500-Vehicle function list BAP-efficiency_assis_msg_bus_0x3C,not activated ,256
IDE04307-ENG127499-Vehicle function list BAP-efficiency_assist_0x3C,not activated ,256
IDE04307-ENG248657-Vehicle function list BAP-EngineFunctions_0x5D,not activated ,256
IDE04307-ENG248658-Vehicle function list BAP-EngineFunctions_0x5D_msg_bus,not activated ,256
IDE04307-ENG125829-Vehicle function list BAP-ENI_0x37,activated ,256
IDE04307-ENG125830-Vehicle function list BAP-ENI_0x37_msg_bus,Comfort data bus ,256
IDE04307-ENG264168-Vehicle function list BAP-ENI2_0x58,not activated ,256
IDE04307-ENG264169-Vehicle function list BAP-ENI2_0x58_msg_bus,not activated ,256
IDE04307-ENG264170-Vehicle function list BAP-ENI3_0x6E,not activated ,256
IDE04307-ENG264171-Vehicle function list BAP-ENI3_0x6E_msg_bus,not activated ,256
IDE04307-ENG264172-Vehicle function list BAP-ENI4_0x6F,not activated ,256
IDE04307-ENG264173-Vehicle function list BAP-ENI4_0x6F_msg_bus,not activated ,256
IDE04307-ENG117708-Vehicle function list BAP-exterieur_light_0x09,activated ,256
IDE04307-ENG117709-Vehicle function list BAP-exterieur_light_0x09_msg_bus,Comfort data bus ,256
IDE04307-ENG252073-Vehicle function list BAP-exterieur_light_2_0x6B,not activated ,256
IDE04307-ENG252076-Vehicle function list BAP-exterieur_light_2_0x6B_msg_bus,not activated ,256
IDE04307-ENG142168-Vehicle function list BAP-fas_profile_0x4D,not activated ,256
IDE04307-ENG142169-Vehicle function list BAP-fas_profile_0x4D_msg_bus,not activated ,256
IDE04307-ENG142154-Vehicle function list BAP-front_traffic_assist_0x41,not activated ,256
IDE04307-ENG142155-Vehicle function list BAP-front_traffic_assist_0x41_msg_bus,not activated ,256
IDE04307-ENG117698-Vehicle function list BAP-headup_displ_0x04,not activated ,256
IDE04307-ENG117699-Vehicle function list BAP-headup_displ_0x04_msg_bus,not activated ,256
IDE04307-ENG117746-Vehicle function list BAP-Hybrid_0x1D,activated ,256
IDE04307-ENG117747-Vehicle function list BAP-Hybrid_0x1D_msg_bus,Powertrain data bus ,256
IDE04307-ENG248711-Vehicle function list BAP-IAA_PSO_0x52,activated ,256
IDE04307-ENG248712-Vehicle function list BAP-IAA_PSO_0x52_msg_bus,Comfort data bus ,256
IDE04307-ENG152535-Vehicle function list BAP-infotainmentsettings_profile_0x50,not activated ,256
IDE04307-ENG152536-Vehicle function list BAP-infotainmentsettings_profile_0x50_msg_bus,not activated ,256
IDE04307-ENG117706-Vehicle function list BAP-interieur_light_0x08,activated ,256
IDE04307-ENG117707-Vehicle function list BAP-interieur_light_0x08_msg_bus,Comfort data bus ,256
IDE04307-ENG252052-Vehicle function list BAP-interieur_light_2_0x6A,not activated ,256
IDE04307-ENG252047-Vehicle function list BAP-interieur_light_2_0x6A_msg_bus,not activated ,256
IDE04307-ENG248719-Vehicle function list BAP-ITM_0x65,not activated ,256
IDE04307-ENG248720-Vehicle function list BAP-ITM_0x65_msg_bus,not activated ,256
IDE04307-ENG117740-Vehicle function list BAP-LDW_HCA_0x19,activated ,256
IDE04307-ENG117741-Vehicle function list BAP-LDW_HCA_0x19_msg_bus,Extended data bus ,256
IDE04307-ENG249902-Vehicle function list BAP-lift_0x64,not activated ,256
IDE04307-ENG249903-Vehicle function list BAP-lift_0x64_msg_bus,not activated ,256
IDE04307-ENG281905-Vehicle function list BAP-LLCC_0x78,not activated ,256
IDE04307-ENG281994-Vehicle function list BAP-LLCC_0x78_msg_bus,not activated ,256
IDE04307-ENG248726-Vehicle function list BAP-Mascot_0x53,not activated ,256
IDE04307-ENG248727-Vehicle function list BAP-Mascot_0x53_msg_bus,not activated ,256
IDE04307-ENG117720-Vehicle function list BAP-MFA_0x0F,activated ,256
IDE04307-ENG117721-Vehicle function list BAP-MFA_0x0F_msg_bus,Comfort data bus ,256
IDE04307-ENG117767-Vehicle function list BAP-MFL_Jocker_0x34,not activated ,256
IDE04307-ENG117766-Vehicle function list BAP-MFL_Jocker_msg_bus_0x34,not activated ,256
IDE04307-ENG117719-Vehicle function list BAP-mirror_0x0E,activated ,256
IDE04307-ENG117718-Vehicle function list BAP-mirror_0x0E_msg_bus,Comfort data bus ,256
IDE04307-ENG345841-Vehicle function list BAP-MobDevKey_0x77,not activated ,256
IDE04307-ENG345842-Vehicle function list BAP-MobDevKey_0x77_msg_bus,not activated ,256
IDE04307-ENG117738-Vehicle function list BAP-Night_Vision_0x18,not activated ,256
IDE04307-ENG117739-Vehicle function list BAP-Night_Vision_0x18_msg_bus,not activated ,256
IDE04307-ENG248788-Vehicle function list BAP-PaCo_0x55,not activated ,256
IDE04307-ENG248789-Vehicle function list BAP-PaCo_0x55_msg_bus,not activated ,256
IDE04307-ENG117710-Vehicle function list BAP-parking_assist_0x0A,activated ,256
IDE04307-ENG117711-Vehicle function list BAP-parking_assist_0x0A_msg_bus,Terminal 15 ,256
IDE04307-ENG117752-Vehicle function list BAP-Passenger_Seat_0x20,not activated ,256
IDE04307-ENG117753-Vehicle function list BAP-Passenger_Seat_0x20_msg_bus,not activated ,256
IDE04307-ENG125831-Vehicle function list BAP-Pedestrian_Assist_0x3A,not activated ,256
IDE04307-ENG125832-Vehicle function list BAP-Pedestrian_Assist_msg_bus_0x3A,not activated ,256
IDE04307-ENG325104-Vehicle function list BAP-Plug_and_charge_0x80,not activated ,256
IDE04307-ENG395187-Vehicle function list BAP-Plug_and_Charge_0x80_msg_bus,not activated ,256
IDE04307-ENG122333-Vehicle function list BAP-Range_Data_0x39,activated ,256
IDE04307-ENG125827-Vehicle function list BAP-Range_Data_msg_bus_0x39,Infotainment data bus ,256
IDE04307-ENG122327-Vehicle function list BAP-RearSeatEntertainment_0x2E,not activated ,256
IDE04307-ENG122328-Vehicle function list BAP-RearSeatEntertainment_0x2E_msg_bus,not activated ,256
IDE04307-ENG248801-Vehicle function list BAP-remote_services_0x4E,activated ,256
IDE04307-ENG248802-Vehicle function list BAP-remote_services_0x4E_msg_bus,Comfort data bus ,256
IDE04307-ENG117750-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F,not activated ,256
IDE04307-ENG117751-Vehicle function list BAP-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,256
IDE04307-ENG316850-Vehicle function list BAP-RollingAbility_0x75,not activated ,256
IDE04307-ENG316851-Vehicle function list BAP-RollingAbility_0x75_msg_bus,not activated ,256
IDE04307-ENG297722-Vehicle function list BAP-RushhourPilot_0x7C,not activated ,256
IDE04307-ENG297723-Vehicle function list BAP-RushhourPilot_0x7C_msg_bus,not activated ,256
IDE04307-ENG125833-Vehicle function list BAP-Seat_Pneumatic_0x3B,not activated ,256
IDE04307-ENG125834-Vehicle function list BAP-Seat_Pneumatic_msg_bus_0x3B,not activated ,256
IDE04307-ENG139200-Vehicle function list BAP-Seatmemory_codriver_rear_0x3F,not activated ,256
IDE04307-ENG139201-Vehicle function list BAP-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,256
IDE04307-ENG139198-Vehicle function list BAP-Seatmemory_driver_rear_0x3E,not activated ,256
IDE04307-ENG139199-Vehicle function list BAP-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,256
IDE04307-ENG395209-Vehicle function list BAP-SecurityEvent_0x82,not activated ,256
IDE04307-ENG395210-Vehicle function list BAP-SecurityEvent_0x82_msg_bus,not activated ,256
IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,256
IDE04307-ENG117727-Vehicle function list BAP-service_interval_display_0x12_msg_bus,Comfort data bus ,256
IDE04307-ENG117748-Vehicle function list BAP-SideView_0x1E,not activated ,256
IDE04307-ENG117749-Vehicle function list BAP-SideView_0x1E_msg_bus,not activated ,256
IDE04307-ENG139202-Vehicle function list BAP-Soundcontrol_0x44,not activated ,256
IDE04307-ENG139203-Vehicle function list BAP-Soundcontrol_0x44_msg_bus,not activated ,256
IDE04307-ENG248819-Vehicle function list BAP-SoundControl2_0x66,not activated ,256
IDE04307-ENG248820-Vehicle function list BAP-SoundControl2_0x66_msg_bus,not activated ,256
IDE04307-ENG122329-Vehicle function list BAP-Special_Functions_0x35,not activated ,256
IDE04307-ENG122330-Vehicle function list BAP-Special_Functions_msg_bus_0x35,not activated ,256
IDE04307-ENG127678-Vehicle function list BAP-spoiler_0x40,not activated ,256
IDE04307-ENG127679-Vehicle function list BAP-spoiler_0x40_msg_bus,not activated ,256
IDE04307-ENG117762-Vehicle function list BAP-Start_Stop_reasons_0x27,not activated ,256
IDE04307-ENG117763-Vehicle function list BAP-Start_Stop_reasons_0x27_msg_bus,not activated ,256
IDE04307-ENG142162-Vehicle function list BAP-statistic_0x4A,not activated ,256
IDE04307-ENG142163-Vehicle function list BAP-statistic_0x4A_msg_bus,not activated ,256
IDE04307-ENG142164-Vehicle function list BAP-sunroof_front_0x4B,not activated ,256
IDE04307-ENG142165-Vehicle function list BAP-sunroof_front_0x4B_msg_bus,not activated ,256
IDE04307-ENG142166-Vehicle function list BAP-sunroof_rear_0x4C,not activated ,256
IDE04307-ENG142167-Vehicle function list BAP-sunroof_rear_0x4C_msg_bus,not activated ,256
IDE04307-ENG117742-Vehicle function list BAP-SWA_0x1A,not activated ,256
IDE04307-ENG117743-Vehicle function list BAP-SWA_0x1A_msg_bus,Extended data bus ,256
IDE04307-ENG117704-Vehicle function list BAP-tire_pressure_system_0x07,activated ,256
IDE04307-ENG117705-Vehicle function list BAP-tire_pressure_system_0x07_msg_bus,Suspension data bus ,256
IDE04307-ENG117754-Vehicle function list BAP-traffic_sign_recognition_0x21,activated ,256
IDE04307-ENG117755-Vehicle function list BAP-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,256
IDE04307-ENG122331-Vehicle function list BAP-Trailer_Assistant_0x36,not activated ,256
IDE04307-ENG122332-Vehicle function list BAP-Trailer_Assistant_msg_bus_0x36,not activated ,256
IDE04307-ENG260744-Vehicle function list BAP-Trained_Park_Assist_0x5F,not activated ,256
IDE04307-ENG258630-Vehicle function list BAP-Trained_Park_Assist_0x5F_msg_bus,not activated ,256
IDE04307-ENG122325-Vehicle function list BAP-TV_tuner_0x2C,not activated ,256
IDE04307-ENG122326-Vehicle function list BAP-TV_tuner_0x2C_msg_bus,not activated ,256
IDE04307-ENG117730-Vehicle function list BAP-UGDO_0x14,not activated ,256
IDE04307-ENG117731-Vehicle function list BAP-UGDO_0x14_msg_bus,not activated ,256
IDE04307-ENG117728-Vehicle function list BAP-unit_master_0x13,activated ,256
IDE04307-ENG117729-Vehicle function list BAP-unit_master_0x13_msg_bus,Comfort data bus ,256
IDE04307-ENG185817-Vehicle function list BAP-vas_0x54,not activated ,256
IDE04307-ENG185818-Vehicle function list BAP-vas_0x54_msg_bus,not activated ,256
IDE04307-ENG117712-Vehicle function list BAP-VPS_0x0B,activated ,256
IDE04307-ENG117713-Vehicle function list BAP-VPS_0x0B_msg_bus,Infotainment data bus ,256
IDE04307-ENG117756-Vehicle function list BAP-weariness_rcognition_0x22,activated ,256
IDE04307-ENG117757-Vehicle function list BAP-weariness_rcognition_0x22_msg_bus,Infotainment data bus ,256
IDE04307-ENG117714-Vehicle function list BAP-wiper_comfort_0x0C,activated ,256
IDE04307-ENG117715-Vehicle function list BAP-wiper_comfort_0x0C_msg_bus,Comfort data bus ,256
IDE04307-ENG142160-Vehicle function list BAP-wireless_charging_0x48,not activated ,256
IDE04307-ENG142161-Vehicle function list BAP-wireless_charging_0x48_msg_bus,not activated ,256
IDE04550-Bluetooth: Sniff mode,On ,1
IDE06698-MAS00839-Audio management input gain-TV Tuner,-128 dB,34
IDE06698-MAS00846-Audio management input gain-Satellite radio,-128 dB,34
IDE06698-MAS01984-Audio management input gain-Radio (FM),-128 dB,34
IDE06698-MAS01985-Audio management input gain-Radio (AM),-128 dB,34
IDE06698-MAS01986-Audio management input gain-Digital radio (DAB),-128 dB,34
IDE06698-ENG125854-Audio management input gain-Exbox_DMB,-128 dB,34
IDE06698-ENG117430-Audio management input gain-HFP,-128 dB,34
IDE06698-ENG125846-Audio management input gain-Media_Airplay,-128 dB,34
IDE06698-ENG125837-Audio management input gain-Media_AUX_Adapter,-128 dB,34
IDE06698-ENG125836-Audio management input gain-Media_AUXIN,-128 dB,34
IDE06698-ENG125843-Audio management input gain-Media_Bluray,-128 dB,34
IDE06698-ENG125841-Audio management input gain-Media_BTDevice,-128 dB,34
IDE06698-ENG125838-Audio management input gain-Media_CDA,-128 dB,34
IDE06698-ENG125848-Audio management input gain-Media_Cloud,-128 dB,34
IDE06698-ENG125839-Audio management input gain-Media_DVD,-128 dB,34
IDE06698-ENG125844-Audio management input gain-Media_HDMI,-128 dB,34
IDE06698-ENG125840-Audio management input gain-Media_MFP,-128 dB,34
IDE06698-ENG125847-Audio management input gain-Media_UPNP,-128 dB,34
IDE06698-ENG125855-Audio management input gain-Mirrorlink,-128 dB,34
IDE06698-ENG125859-Audio management input gain-Phone_Ringer_MFP,-128 dB,34
IDE06698-ENG125860-Audio management input gain-Phone_Ringer_OB,-128 dB,34
IDE06698-ENG125858-Audio management input gain-Phone_Voice,-128 dB,34
IDE06698-ENG125842-Audio management input gain-TA_Tuner_FM,-128 dB,34
IDE06698-ENG125850-Audio management input gain-Tone_Beep,-128 dB,34
IDE06698-ENG125853-Audio management input gain-Tone_Messaging,-128 dB,34
IDE06698-ENG125852-Audio management input gain-Tone_Touchscreen,-128 dB,34
IDE06698-ENG125851-Audio management input gain-Tone_Warning,-128 dB,34
IDE06698-ENG251556-Audio management input gain-touch_screen_player,0 dB,34
IDE06698-ENG125856-Audio management input gain-TTS_Nav,-128 dB,34
IDE06698-ENG125857-Audio management input gain-TTS_SDS,-128 dB,34
IDE06698-ENG125845-Audio management input gain-Tuner_Online,-128 dB,34
IDE06698-ENG125849-Audio management input gain-Tuner_Personal,-128 dB,34
IDE06698-ENG125835-Audio management input gain-Tuner_TI,-128 dB,34
IDE06698-ENG125861-Audio management input gain-TV_AV_IN,-128 dB,34
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,not activated ,2
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,not activated ,2
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,not activated ,2
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,not activated ,2
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,not activated ,2
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,activated ,2
IDE08814-MAS15014-Navigation receiver GNSS configuration-Beidou,not activated ,2
IDE08814-MAS18801-Navigation receiver GNSS configuration-external GPS receiver 2 via bus,not activated ,2
IDE08814-MAS18802-Navigation receiver GNSS configuration-GNSS: refresh rate,10 ,2
IDE08814-ENG259336-Navigation receiver GNSS configuration-GNSS_over_ethernet,not activated ,2
IDE10604-Menu entries for mobile online services,activated ,1
IDE11104-MAS18803-FM tuner: mono/stereo setting-lower HF stereo threshold in dBµV,23 ,3
IDE11104-MAS18804-FM tuner: mono/stereo setting-Maximum NF stereo channel separation in dB,35 ,3
IDE11104-MAS18805-FM tuner: mono/stereo setting-lower HF stereo threshold in seconds,15.00 s,3
IDE11122-Country identification: country of sale HMI,BE ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,23
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,23
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,23
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,23
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,23
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,23
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,23
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,23
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,23
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,23
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,23
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,23
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,23
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,23
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,23
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,23
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,23
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,23
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,23
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,23
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,23
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,23
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,23
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,23
IDE11502-ENG248673-Locked menu contents-FB_HELP_0,non_blocked ,23
IDE11502-ENG248674-Locked menu contents-FB_HELP_1,non_blocked ,23
IDE11502-ENG248675-Locked menu contents-FB_HELP_2,non_blocked ,23
IDE11502-ENG248676-Locked menu contents-FB_HELP_3,non_blocked ,23
IDE11502-ENG248677-Locked menu contents-FB_HELP_4,non_blocked ,23
IDE11502-ENG248678-Locked menu contents-FB_HELP_5,non_blocked ,23
IDE11502-ENG248679-Locked menu contents-FB_HELP_6,non_blocked ,23
IDE11502-ENG248680-Locked menu contents-FB_HELP_7,non_blocked ,23
IDE11502-ENG248681-Locked menu contents-FB_HELP_8,non_blocked ,23
IDE11502-ENG248682-Locked menu contents-FB_HELP_9,non_blocked ,23
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,23
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,23
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,23
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,23
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,23
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,23
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,23
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,23
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,23
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,23
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,23
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,blocked ,23
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,23
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,23
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,23
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,23
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,23
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,23
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,23
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,23
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,23
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,23
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,23
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,23
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,23
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked ,23
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked ,23
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked ,23
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked ,23
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked ,23
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked ,23
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked ,23
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked ,23
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked ,23
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked ,23
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked ,23
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked ,23
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked ,23
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked ,23
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked ,23
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked ,23
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked ,23
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,blocked ,23
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked ,23
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked ,23
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked ,23
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked ,23
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked ,23
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked ,23
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,blocked ,23
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked ,23
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked ,23
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked ,23
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked ,23
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked ,23
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked ,23
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked ,23
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked ,23
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked ,23
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked ,23
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,blocked ,23
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked ,23
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked ,23
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked ,23
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked ,23
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked ,23
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked ,23
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,23
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked ,23
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked ,23
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked ,23
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked ,23
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,23
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked ,23
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked ,23
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked ,23
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked ,23
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked ,23
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked ,23
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked ,23
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked ,23
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked ,23
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked ,23
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked ,23
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked ,23
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked ,23
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked ,23
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked ,23
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked ,23
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked ,23
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked ,23
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked ,23
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked ,23
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked ,23
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked ,23
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,23
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked ,23
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked ,23
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked ,23
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked ,23
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked ,23
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked ,23
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked ,23
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked ,23
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked ,23
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked ,23
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked ,23
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked ,23
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked ,23
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked ,23
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked ,23
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked ,23
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,23
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked ,23
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked ,23
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked ,23
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked ,23
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked ,23
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked ,23
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked ,23
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked ,23
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked ,23
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked ,23
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked ,23
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked ,23
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked ,23
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked ,23
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked ,23
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked ,23
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked ,23
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked ,23
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked ,23
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked ,23
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked ,23
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked ,23
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked ,23
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked ,23
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked ,23
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked ,23
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked ,23
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked ,23
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked ,23
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked ,23
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked ,23
IDE11638-Bluetooth Audio Codec,01 ,1
IDE12364-ENG122340-Head-Up-Display: configuration-crossroad_detail_map_compression_mode,RLE ,3
IDE12364-ENG122344-Head-Up-Display: configuration-crossroad_detail_map_resolution,0 ,3
IDE12364-ENG127006-Head-Up-Display: configuration-crossroad_detail_map_transmission_mode,OFF ,3
IDE14012-MAS18497-Ethernet: configuration-Ethernet activation: branch 1,Master ,2
IDE14012-MAS18498-Ethernet: configuration-Ethernet activation: branch 2,Deactivated ,2
IDE14012-MAS18499-Ethernet: configuration-Ethernet activation: branch 3,Deactivated ,2
IDE14012-MAS18500-Ethernet: configuration-Ethernet activation: branch 4,Master ,2
MAS00951-Bluetooth,On ,1
MAS01968-Fan,normal ,1
MAS03782-WLAN,On ,1
ENG248412-5_ghz_wlan,OFF ,1
ENG248413-alphabetic_scrollbar,On ,1
ENG248422-ENG248496-calendar_reminder-acoustic_reminder,OFF ,1
ENG248422-ENG248696-calendar_reminder-haptic_reminder,OFF ,1
ENG252010-Car_net,we_connect ,1
ENG248423-channel_band_width_802_11ac,40MHz ,1
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,No ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,BAP ,8
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,BAP ,8
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,0 ,8
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,8
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,OFF ,8
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,8
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,1 ,8
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,IP_streaming ,8
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,BAP ,8
ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0 ,12
ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,10 ,12
ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,50 ,12
ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,100 ,12
ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,220 ,12
ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,253 ,12
ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,2 %,12
ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,2 %,12
ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,6 %,12
ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,10 %,12
ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,80 %,12
ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG122933-ENG248643-error_mask-dtc_dfcc_1,00 00 00 ,30
ENG122933-ENG248644-error_mask-dtc_dfcc_10,00 00 00 ,30
ENG122933-ENG248645-error_mask-dtc_dfcc_2,00 00 00 ,30
ENG122933-ENG248646-error_mask-dtc_dfcc_3,00 00 00 ,30
ENG122933-ENG248647-error_mask-dtc_dfcc_4,00 00 00 ,30
ENG122933-ENG248648-error_mask-dtc_dfcc_5,00 00 00 ,30
ENG122933-ENG248649-error_mask-dtc_dfcc_6,00 00 00 ,30
ENG122933-ENG248650-error_mask-dtc_dfcc_7,00 00 00 ,30
ENG122933-ENG248651-error_mask-dtc_dfcc_8,00 00 00 ,30
ENG122933-ENG248652-error_mask-dtc_dfcc_9,00 00 00 ,30
ENG248428-ENG248528-function_configuration_audio-channel_1_HT,installed ,10
ENG248428-ENG248530-function_configuration_audio-channel_1_TT,installed ,10
ENG248428-ENG248532-function_configuration_audio-channel_10_HT,not installed ,10
ENG248428-ENG248534-function_configuration_audio-channel_10_TT,not installed ,10
ENG248428-ENG248536-function_configuration_audio-channel_11_HT,not installed ,10
ENG248428-ENG248538-function_configuration_audio-channel_11_TT,not installed ,10
ENG248428-ENG248540-function_configuration_audio-channel_12_HT,not installed ,10
ENG248428-ENG248542-function_configuration_audio-channel_12_TT,not installed ,10
ENG248428-ENG248544-function_configuration_audio-channel_13_HT,not installed ,10
ENG248428-ENG248546-function_configuration_audio-channel_13_TT,not installed ,10
ENG248428-ENG248548-function_configuration_audio-channel_14_HT,not installed ,10
ENG248428-ENG248550-function_configuration_audio-channel_14_TT,not installed ,10
ENG248428-ENG248552-function_configuration_audio-channel_15_HT,not installed ,10
ENG248428-ENG248554-function_configuration_audio-channel_15_TT,not installed ,10
ENG248428-ENG248556-function_configuration_audio-channel_16_HT,not installed ,10
ENG248428-ENG248558-function_configuration_audio-channel_16_TT,not installed ,10
ENG248428-ENG248560-function_configuration_audio-channel_17_HT,not installed ,10
ENG248428-ENG248562-function_configuration_audio-channel_17_TT,not installed ,10
ENG248428-ENG248564-function_configuration_audio-channel_18_HT,not installed ,10
ENG248428-ENG248566-function_configuration_audio-channel_18_TT,not installed ,10
ENG248428-ENG248568-function_configuration_audio-channel_19_HT,not installed ,10
ENG248428-ENG248571-function_configuration_audio-channel_19TT,not installed ,10
ENG248428-ENG248572-function_configuration_audio-channel_2_HT,installed ,10
ENG248428-ENG248574-function_configuration_audio-channel_2_TT,installed ,10
ENG248428-ENG248576-function_configuration_audio-channel_20_HT,not installed ,10
ENG248428-ENG248578-function_configuration_audio-channel_20_TT,not installed ,10
ENG248428-ENG248580-function_configuration_audio-channel_21_HT,not installed ,10
ENG248428-ENG248582-function_configuration_audio-channel_21_TT,not installed ,10
ENG248428-ENG248584-function_configuration_audio-channel_22_HT,not installed ,10
ENG248428-ENG248586-function_configuration_audio-channel_22_TT,not installed ,10
ENG248428-ENG248588-function_configuration_audio-channel_23_HT,not installed ,10
ENG248428-ENG248590-function_configuration_audio-channel_23_TT,not installed ,10
ENG248428-ENG248592-function_configuration_audio-channel_24_HT,not installed ,10
ENG248428-ENG248594-function_configuration_audio-channel_24_TT,not installed ,10
ENG248428-ENG248596-function_configuration_audio-channel_25_HT,not installed ,10
ENG248428-ENG248597-function_configuration_audio-channel_25_TT,not installed ,10
ENG248428-ENG248598-function_configuration_audio-channel_3_HT,installed ,10
ENG248428-ENG248600-function_configuration_audio-channel_3_TT,installed ,10
ENG248428-ENG248602-function_configuration_audio-channel_4_HT,installed ,10
ENG248428-ENG248604-function_configuration_audio-channel_4_TT,installed ,10
ENG248428-ENG248606-function_configuration_audio-channel_5_HT,not installed ,10
ENG248428-ENG248608-function_configuration_audio-channel_5_TT,not installed ,10
ENG248428-ENG248610-function_configuration_audio-channel_6_HT,not installed ,10
ENG248428-ENG248612-function_configuration_audio-channel_6_TT,not installed ,10
ENG248428-ENG248614-function_configuration_audio-channel_7_HT,not installed ,10
ENG248428-ENG248616-function_configuration_audio-channel_7_TT,not installed ,10
ENG248428-ENG248618-function_configuration_audio-channel_8_HT,not installed ,10
ENG248428-ENG248620-function_configuration_audio-channel_8_TT,not installed ,10
ENG248428-ENG248622-function_configuration_audio-channel_9_HT,not installed ,10
ENG248428-ENG248624-function_configuration_audio-channel_9_TT,not installed ,10
ENG248428-ENG248653-function_configuration_audio-Early_engine_sound,OFF ,10
ENG248428-ENG248491-function_configuration_audio-microphone_1,installed ,10
ENG248428-ENG248492-function_configuration_audio-microphone_2,not installed ,10
ENG248428-ENG248763-function_configuration_audio-microphone_3,not installed ,10
ENG248428-ENG248764-function_configuration_audio-microphone_4,not installed ,10
ENG248428-ENG252056-function_configuration_audio-microphones_ANC,not installed ,10
ENG248428-ENG248818-function_configuration_audio-Signal_flow_topology,20 ,10
ENG248428-ENG248483-function_configuration_audio-Sound_system,internal ,10
ENG248428-ENG248830-function_configuration_audio-welcome_sound,OFF ,10
ENG248429-ENG248511-function_configuration_car-bap_online_functions,OFF ,2
ENG248429-ENG248512-function_configuration_car-bap_sds_sd,On ,2
ENG248429-ENG142151-function_configuration_car-conditioning_variant,0 ,2
ENG248429-ENG248635-function_configuration_car-dashboard_connection,BAP_over_CAN_and_IP ,2
ENG248429-ENG302834-function_configuration_car-Rotary_Knobs_Function,not activated ,2
ENG248430-ENG248504-function_configuration_connectivity-app_connect_over_wifi,Yes ,6
ENG248430-ENG248506-function_configuration_connectivity-apple_car_play,On ,6
ENG248430-ENG152525-function_configuration_connectivity-Baidu_Car_Life,OFF ,6
ENG248430-ENG152559-function_configuration_connectivity-Baidu_Car_Life_ios,OFF ,6
ENG248430-ENG248518-function_configuration_connectivity-Bluetooth_Audio,Not available ,6
ENG248430-ENG248519-function_configuration_connectivity-Bluetooth_Availability,available_without_low_energy ,6
ENG248430-ENG248520-function_configuration_connectivity-Bluetooth_Headphones,Not available ,6
ENG248430-ENG248521-function_configuration_connectivity-Bluetooth_Multimedia_Functionality,Not available ,6
ENG248430-ENG248522-function_configuration_connectivity-Bluetooth_Phone,Not available ,6
ENG248430-ENG405710-function_configuration_connectivity-Bluetooth_secure_transport_on_ethernet,OFF ,6
ENG248430-ENG183597-function_configuration_connectivity-Bluetooth_visibility,On ,6
ENG248430-ENG248525-function_configuration_connectivity-calendar_via_ctn,OFF ,6
ENG248430-ENG369265-function_configuration_connectivity-Conbox_encrytion,not installed ,6
ENG248430-ENG248672-function_configuration_connectivity-external_wlan_antenna,none ,6
ENG248430-ENG248693-function_configuration_connectivity-google_android_auto,On ,6
ENG248430-ENG248761-function_configuration_connectivity-messaging_pagewise_scrolling,not installed ,6
ENG248430-ENG248762-function_configuration_connectivity-messaging_via_map,installed ,6
ENG248430-ENG138662-function_configuration_connectivity-Mirror_link,usb_only ,6
ENG248430-ENG248766-function_configuration_connectivity-mirror_link_country_code,EU ,6
ENG248430-ENG142150-function_configuration_connectivity-MirrorLink_RGB_Preference,RGB565 ,6
ENG248430-ENG127495-function_configuration_connectivity-online_media,OFF ,6
ENG248430-ENG248826-function_configuration_connectivity-viwi_access_mode,no_restriction ,6
ENG248430-ENG248827-function_configuration_connectivity-viwi_function,not installed ,6
ENG248430-ENG252048-function_configuration_connectivity-welink,OFF ,6
ENG248430-ENG248831-function_configuration_connectivity-wifi_client_mode_2_GHz,On ,6
ENG248430-ENG248832-function_configuration_connectivity-wifi_client_mode_5GHz,On ,6
ENG248430-ENG248833-function_configuration_connectivity-WIFI_Hotspot_2_4GHz,On ,6
ENG248430-ENG248834-function_configuration_connectivity-WIFI_Hotspot_5GHz,On ,6
ENG248430-ENG248835-function_configuration_connectivity-wlan_aps_to_ccu_routing,On ,6
ENG248430-ENG248836-function_configuration_connectivity-wlan_module,not activated ,6
ENG248430-ENG248837-function_configuration_connectivity-wlan_tethering_connection_check_via_disgnosis,On ,6
ENG248431-ENG405716-function_configuration_hmi-Google_search_default,On ,5
ENG248431-ENG248699-function_configuration_hmi-helpcontext_0,OFF ,5
ENG248431-ENG248700-function_configuration_hmi-helpcontext_1,OFF ,5
ENG248431-ENG248701-function_configuration_hmi-helpcontext_2,OFF ,5
ENG248431-ENG248702-function_configuration_hmi-helpcontext_3,OFF ,5
ENG248431-ENG248703-function_configuration_hmi-helpcontext_4,OFF ,5
ENG248431-ENG248704-function_configuration_hmi-helpcontext_5,OFF ,5
ENG248431-ENG248705-function_configuration_hmi-helpcontext_6,OFF ,5
ENG248431-ENG248706-function_configuration_hmi-helpcontext_7,OFF ,5
ENG248431-ENG248707-function_configuration_hmi-helpcontext_8,OFF ,5
ENG248431-ENG248708-function_configuration_hmi-helpcontext_9,OFF ,5
ENG248431-ENG248709-function_configuration_hmi-hmi_initial_disclaimer,OFF ,5
ENG248431-ENG248710-function_configuration_hmi-hmi_legal_disclaimer,OFF ,5
ENG248431-ENG248725-function_configuration_hmi-log_book,not_displayed ,5
ENG248431-ENG369611-function_configuration_hmi-Nav_showing,activated ,5
ENG248431-ENG167525-function_configuration_hmi-Popup_if_GPS_services_in_use,OFF ,5
ENG248431-ENG248811-function_configuration_hmi-screenings,0 ,5
ENG248431-ENG405754-function_configuration_hmi-Show_google_search_default,On ,5
ENG248431-ENG248479-function_configuration_hmi-Skinning,1 ,5
ENG248431-ENG248821-function_configuration_hmi-speller,OFF ,5
ENG248431-ENG332397-function_configuration_hmi-Twin_Wheel,Deactivated ,5
ENG248432-ENG248505-function_configuration_media-app_start_automatically_on_customer_device,OFF ,3
ENG248432-ENG248481-function_configuration_media-aux_in,OFF ,3
ENG248432-ENG248671-function_configuration_media-external_cd_drive,OFF ,3
ENG248432-ENG249899-function_configuration_media-external_tv_tuner,OFF ,3
ENG248432-ENG117850-function_configuration_media-gracenote_local_coverarts,OFF ,3
ENG248432-ENG117851-function_configuration_media-gracenote_local_other,OFF ,3
ENG248432-ENG117848-function_configuration_media-gracenote_online_coverarts,OFF ,3
ENG248432-ENG117849-function_configuration_media-gracenote_online_other,OFF ,3
ENG248432-ENG248713-function_configuration_media-Import_Media_Data,not activated ,3
ENG248432-ENG248769-function_configuration_media-online_media_services,On ,3
ENG248432-ENG248770-function_configuration_media-online_tv,OFF ,3
ENG248432-ENG248794-function_configuration_media-picture_viewer,OFF ,3
ENG248432-ENG248804-function_configuration_media-Ripping_Media_Data,not activated ,3
ENG248432-ENG248482-function_configuration_media-USB,usb_ipod ,3
ENG248433-ENG117847-function_configuration_navigation-advanced_range_display,OFF ,4
ENG248433-ENG173863-function_configuration_navigation-Country_Navigation,EU ,4
ENG248433-ENG248692-function_configuration_navigation-gnns_antenna_Availability,not activated ,4
ENG248433-ENG127492-function_configuration_navigation-LGI,On ,4
ENG248433-ENG142152-function_configuration_navigation-Map_Style,0 ,4
ENG248433-ENG248488-function_configuration_navigation-Navigation_system,activated ,4
ENG248433-ENG103811-function_configuration_navigation-PSD,activated ,4
ENG248433-ENG126994-function_configuration_navigation-TPEG_availability,OFF ,4
ENG248433-ENG248824-function_configuration_navigation-ttraffic_information,On ,4
ENG248433-ENG248828-function_configuration_navigation-vza,not activated ,4
ENG248433-ENG127494-function_configuration_navigation-VZO,OFF ,4
ENG248434-ENG142146-function_configuration_phone-allow_message_editing,On ,3
ENG248434-ENG281930-function_configuration_phone-BTLE_Messaging_support,OFF ,3
ENG248434-ENG125043-function_configuration_phone-Dtmf_without_active_call,OFF ,3
ENG248434-ENG142145-function_configuration_phone-esim_data_only_sms_support,OFF ,3
ENG248434-ENG248694-function_configuration_phone-GSM_Antenna_3,Deactivated ,3
ENG248434-ENG248695-function_configuration_phone-GSM_Antenna_4,Deactivated ,3
ENG248434-ENG248715-function_configuration_phone-interlink_box_antenna,installed ,3
ENG248434-ENG345754-function_configuration_phone-interlink_box_CAN,Deactivated ,3
ENG248434-ENG248716-function_configuration_phone-interlink_box_nfc,installed ,3
ENG248434-ENG248717-function_configuration_phone-interlink_box_pwm,not installed ,3
ENG248434-ENG248718-function_configuration_phone-interlink_box_wireless_charging,installed ,3
ENG248434-ENG331901-function_configuration_phone-Kopplebox_Fast_Charger,Deactivated ,3
ENG248434-ENG130246-function_configuration_phone-LTE_modul,Deactivated ,3
ENG248434-ENG142142-function_configuration_phone-map_email_support,On ,3
ENG248434-ENG142143-function_configuration_phone-map_instant_messaging_support,OFF ,3
ENG248434-ENG142141-function_configuration_phone-map_sms_support,On ,3
ENG248434-ENG248792-function_configuration_phone-phone_nad,not installed ,3
ENG248434-ENG125044-function_configuration_phone-Support_for_response_and_hold,OFF ,3
ENG248434-ENG125042-function_configuration_phone-Support_of_threeway_calling,On ,3
ENG248434-ENG130247-function_configuration_phone-Support_second_phone,none ,3
ENG248434-ENG248825-function_configuration_phone-user_menu_three_way_calling,not installed ,3
ENG248435-ENG251555-function_configuration_pso-iaa_function,activated ,2
ENG248435-ENG297696-function_configuration_pso-iaa_function_new,activated ,2
ENG248435-ENG248795-function_configuration_pso-pso_function,Deactivated ,2
ENG248436-ENG248497-function_configuration_radio-AF,persistent ,8
ENG248436-ENG248498-function_configuration_radio-af_hmi_switch_default_value,On ,8
ENG248436-ENG248500-function_configuration_radio-AM_disable,activated ,8
ENG248436-ENG248501-function_configuration_radio-am_fm_dab_antenna,not activated ,8
ENG248436-ENG248502-function_configuration_radio-am_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248508-function_configuration_radio-band_settings_am_tuner,EU_RdW ,8
ENG248436-ENG248509-function_configuration_radio-band_settings_dab_tuner_band_1,EU_Band_III-N ,8
ENG248436-ENG248510-function_configuration_radio-band_settings_fm_tuner,EU_RdW ,8
ENG248436-ENG248633-function_configuration_radio-DAB_Alarm_Announcement,activated ,8
ENG248436-ENG248634-function_configuration_radio-dab_mode_antenna_mode_1,activated ,8
ENG248436-ENG248641-function_configuration_radio-drm_plus_fm,Deactivated ,8
ENG248436-ENG248642-function_configuration_radio-drm30_mf,Deactivated ,8
ENG248436-ENG248683-function_configuration_radio-FM_Antenna,Available ,8
ENG248436-ENG248684-function_configuration_radio-fm_hd_hmi_switch_default_value,not activated ,8
ENG248436-ENG248685-function_configuration_radio-FM_PTY31_Alarm,OFF ,8
ENG248436-ENG248686-function_configuration_radio-fm_radio_profiles,not_valid ,8
ENG248436-ENG248697-function_configuration_radio-HD_FM_Antenna_Mode,AM_FM_ANT ,8
ENG248436-ENG152533-function_configuration_radio-Hybrid_Radio_additional_online_data,Deactivated ,8
ENG248436-ENG152534-function_configuration_radio-Hybrid_Radio_Range_Extender,Deactivated ,8
ENG248436-ENG248767-function_configuration_radio-multiple_entry_switch,On ,8
ENG248436-ENG152553-function_configuration_radio-online_radio,native_hmi_only ,8
ENG248436-ENG248793-function_configuration_radio-PI_ignore,OFF ,8
ENG248436-ENG286264-function_configuration_radio-PTy switch default value,OFF ,8
ENG248436-ENG286265-function_configuration_radio-PTy_switch_visibility,OFF ,8
ENG248436-ENG248797-function_configuration_radio-Radio_Text_Plus,activated ,8
ENG248436-ENG248798-function_configuration_radio-rds_hmi_switch_default_value,On ,8
ENG248436-ENG248799-function_configuration_radio-rds_hmi_switch_visibility,OFF ,8
ENG248436-ENG248812-function_configuration_radio-SDARS_band_activation,Deactivated ,8
ENG248436-ENG249938-function_configuration_radio-SDARS_type,SAT_only ,8
ENG248436-ENG126993-function_configuration_radio-Station_Logo_DB_Mode,1 ,8
ENG248437-ENG248800-function_configuration_rvc-rear_view_low_rvc,not_active ,3
ENG248437-ENG245031-function_configuration_rvc-rvc_low_black_screen_trunk_open,not activated ,3
ENG248437-ENG244966-function_configuration_rvc-rvc_low_black_screen_velocity_threshold,not activated ,3
ENG248437-ENG245015-function_configuration_rvc-rvc_low_failsafe,not activated ,3
ENG248437-ENG248807-function_configuration_rvc-rvc_low_lid_close_delay_time,0 s,3
ENG248437-ENG248808-function_configuration_rvc-rvc_low_videofailure_detection_time,0 ,3
ENG248438-ENG248523-function_configuration_sound-brand_sound,No_Brand_Sound ,1
ENG248438-ENG248765-function_configuration_sound-Microphone_for_vehicle_noise_cancelation,not activated ,1
ENG248438-ENG248803-function_configuration_sound-retractable_tweeters,not activated ,1
ENG248438-ENG142149-function_configuration_sound-vehicle_leaving_sound,not activated ,1
ENG248438-ENG142147-function_configuration_sound-vehicle_readiness_sound,not activated ,1
ENG248439-ENG248632-function_configuration_speech-country_language_change,no_country ,2
ENG248439-ENG138660-function_configuration_speech-SDS_Region_Flag,no_region ,2
ENG244879-ENG137647-function_configuration_sw_update-UOTA,On ,1
ENG244879-ENG167532-function_configuration_sw_update-UOTA_2,OFF ,1
ENG244879-ENG249952-function_configuration_sw_update-UOTA_onboard_tester,Not available ,1
ENG244879-ENG297725-function_configuration_sw_update-UOTA_T_Box,Not available ,1
ENG248440-function_configuration_swap_fod,swap_not_active_fod_slave_master_active ,1
ENG248441-ENG248640-function_configuration_unit-Display_Turn_Out_Speed,normal ,1
ENG248441-ENG167523-function_configuration_unit-Pilot_Parking,Deactivated ,1
ENG248441-ENG249931-function_configuration_unit-reset_type_hardware_reset,IVI_partition_only ,1
ENG248441-ENG126143-function_configuration_unit-RVC_video_input,FBAS ,1
ENG248441-ENG248813-function_configuration_unit-second_display_via_lvds_connection,not connected ,1
ENG248441-ENG248822-function_configuration_unit-Suspend_to_RAM,Deactivated ,1
ENG248441-ENG248829-function_configuration_unit-web_app_plattform_side_loading,Deactivated ,1
ENG248442-geocoordinate_create,do_not_create ,1
ENG248443-geocoordinate_show,do_not show ,1
ENG248448-ENG248814-ipv4_address_of_subnet_1_on_ccu-segment_1,10 ,4
ENG248448-ENG248815-ipv4_address_of_subnet_1_on_ccu-segment_2,173 ,4
ENG248448-ENG248816-ipv4_address_of_subnet_1_on_ccu-segment_3,201 ,4
ENG248448-ENG248817-ipv4_address_of_subnet_1_on_ccu-segment_4,1 ,4
ENG248449-ENG248814-ipv4_address_of_subnet_1_on_mib-segment_1,10 ,4
ENG248449-ENG248815-ipv4_address_of_subnet_1_on_mib-segment_2,173 ,4
ENG248449-ENG248816-ipv4_address_of_subnet_1_on_mib-segment_3,201 ,4
ENG248449-ENG248817-ipv4_address_of_subnet_1_on_mib-segment_4,2 ,4
ENG248450-ENG248814-ipv4_address_of_subnet_2_on_ccu-segment_1,10 ,4
ENG248450-ENG248815-ipv4_address_of_subnet_2_on_ccu-segment_2,173 ,4
ENG248450-ENG248816-ipv4_address_of_subnet_2_on_ccu-segment_3,202 ,4
ENG248450-ENG248817-ipv4_address_of_subnet_2_on_ccu-segment_4,1 ,4
ENG248451-ENG248814-ipv4_address_of_subnet_2_on_mib-segment_1,10 ,4
ENG248451-ENG248815-ipv4_address_of_subnet_2_on_mib-segment_2,173 ,4
ENG248451-ENG248816-ipv4_address_of_subnet_2_on_mib-segment_3,202 ,4
ENG248451-ENG248817-ipv4_address_of_subnet_2_on_mib-segment_4,2 ,4
ENG248454-ENG248814-ipv4_address_of_subnet_4_on_ccu-segment_1,10 ,4
ENG248454-ENG248815-ipv4_address_of_subnet_4_on_ccu-segment_2,175 ,4
ENG248454-ENG248816-ipv4_address_of_subnet_4_on_ccu-segment_3,202 ,4
ENG248454-ENG248817-ipv4_address_of_subnet_4_on_ccu-segment_4,1 ,4
ENG248455-ENG248814-ipv4_address_of_subnet_4_on_mib-segment_1,10 ,4
ENG248455-ENG248815-ipv4_address_of_subnet_4_on_mib-segment_2,175 ,4
ENG248455-ENG248816-ipv4_address_of_subnet_4_on_mib-segment_3,202 ,4
ENG248455-ENG248817-ipv4_address_of_subnet_4_on_mib-segment_4,2 ,4
ENG248456-ENG248814-ipv4_address_of_the_wlan_ap-segment_1,10 ,4
ENG248456-ENG248815-ipv4_address_of_the_wlan_ap-segment_2,173 ,4
ENG248456-ENG248816-ipv4_address_of_the_wlan_ap-segment_3,189 ,4
ENG248456-ENG248817-ipv4_address_of_the_wlan_ap-segment_4,1 ,4
ENG248457-ENG248814-ipv6_address_of_subnet_1_on_ccu-segment_1,FD 30 ,8
ENG248457-ENG248815-ipv6_address_of_subnet_1_on_ccu-segment_2,E0 8E ,8
ENG248457-ENG248816-ipv6_address_of_subnet_1_on_ccu-segment_3,C0 31 ,8
ENG248457-ENG248817-ipv6_address_of_subnet_1_on_ccu-segment_4,00 01 ,8
ENG248458-ENG248814-ipv6_address_of_subnet_1_on_mib-segment_1,FD 30 ,8
ENG248458-ENG248815-ipv6_address_of_subnet_1_on_mib-segment_2,E0 8E ,8
ENG248458-ENG248816-ipv6_address_of_subnet_1_on_mib-segment_3,C0 31 ,8
ENG248458-ENG248817-ipv6_address_of_subnet_1_on_mib-segment_4,00 01 ,8
ENG248459-ENG248814-ipv6_address_of_subnet_2_on_ccu-segment_1,FD 30 ,8
ENG248459-ENG248815-ipv6_address_of_subnet_2_on_ccu-segment_2,E0 8E ,8
ENG248459-ENG248816-ipv6_address_of_subnet_2_on_ccu-segment_3,C0 31 ,8
ENG248459-ENG248817-ipv6_address_of_subnet_2_on_ccu-segment_4,00 02 ,8
ENG248460-ENG248814-ipv6_address_of_subnet_2_on_mib-segment_1,FD 30 ,8
ENG248460-ENG248815-ipv6_address_of_subnet_2_on_mib-segment_2,E0 8E ,8
ENG248460-ENG248816-ipv6_address_of_subnet_2_on_mib-segment_3,C0 31 ,8
ENG248460-ENG248817-ipv6_address_of_subnet_2_on_mib-segment_4,00 02 ,8
ENG248463-ENG248814-ipv6_address_of_subnet_4_on_ccu-segment_1,64816 ,8
ENG248463-ENG248815-ipv6_address_of_subnet_4_on_ccu-segment_2,57486 ,8
ENG248463-ENG248816-ipv6_address_of_subnet_4_on_ccu-segment_3,49201 ,8
ENG248463-ENG248817-ipv6_address_of_subnet_4_on_ccu-segment_4,512 ,8
ENG248464-ENG248814-ipv6_address_of_subnet_4_on_mib-segment_1,64816 ,8
ENG248464-ENG248815-ipv6_address_of_subnet_4_on_mib-segment_2,57486 ,8
ENG248464-ENG248816-ipv6_address_of_subnet_4_on_mib-segment_3,49201 ,8
ENG248464-ENG248817-ipv6_address_of_subnet_4_on_mib-segment_4,512 ,8
ENG248465-ENG248814-ipv6_address_of_the_wlan_ap-segment_1,FD 30 ,8
ENG248465-ENG248815-ipv6_address_of_the_wlan_ap-segment_2,E0 8E ,8
ENG248465-ENG248816-ipv6_address_of_the_wlan_ap-segment_3,C0 31 ,8
ENG248465-ENG248817-ipv6_address_of_the_wlan_ap-segment_4,01 03 ,8
ENG152375-ENG152428-Logging_Configuration-Interface,00 ,3
ENG152375-ENG152494-Logging_Configuration-loglevel,00 ,3
ENG152375-ENG98732-Logging_Configuration-Memory,00 ,3
ENG278389-Market_and_brand_specific_preInstSet_of_webapps,preinstallation_set_0 ,1
ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
ENG248467-number_to_name_matching_algorithm,detect_numbers ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 28 02 50 02 50 02 28 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 48 ,40
ENG252007-ENG297686-Privacy_mode-globe_icon,not activated ,2
ENG252007-ENG252075-Privacy_mode-supress_privacy_mode,not activated ,2
ENG248469-same_ssid_for_2_4_and_5_ghz,Yes ,1
ENG117912-ENG117775-Select_Remote_Test_DAB_Service-Parameter_Adaption_Service_ID,Conditions not correct or request sequence error,1
ENG117912-ENG117776-Select_Remote_Test_DAB_Service-Parameter_Adaption_Subservice_ID,Conditions not correct or request sequence error,1
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,1
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,1
ENG117909-Shift_Remote_Test_Frequency_DAB,Conditions not correct or request sequence error,1
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,1
ENG248470-sortorder,sortorder_1 ,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG248475-wlan_ap_local_net_dhcp_lease_time,72 H,1
ENG244949-ENG248626-wlan_channel_numbers-channel_number_for_2_4GHz,6 ,1
ENG244949-ENG248627-wlan_channel_numbers-channel_number_for_5GHz,12 ,1
Elapsed Time: 00:59
adpmap-6C-5Q0-980-556-B_WVWZZZ3CZME009325-20260823-2132.CSV
;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  6C: Back-up Cam.
;Component:RVC Compact   H18 0231, Coding:0184020162002017000041
;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB.rod
;Sunday,23,August,2026,21:32:32:32152
;VCDS Version: 26.7.2.1 (x64)  Data version: 20260708 DS378.0
;VCID: 3924429ED9DE4B42D9C-806C
IDE02709-Actuator: PWM signal,100 %,1
IDE03531-Wheel/tire description,1950 mm,2
MAS02209-Image contrast,46 %,1
MAS02851-Brightness,50 %,1
ENG119212-camera_off,35.00 km/h,2
ENG119211-camera_on,30.00 km/h,2
ENG119200-color,45 %,1
ENG119218-debounce_time_for_reverse_gear,0 ms,2
ENG119215-display_position,0 px,1
ENG119216-engine_restart_timer,0 ms,2
ENG119209-Frequency_Swinging_Logo,100 Hz,2
ENG119221-FSG_control_state,On ,1
ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
ENG119201-image_delay_timer,0.0 s,1
ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
ENG119214-rv_dark_off,10.00 km/h,2
ENG119213-rv_dark_on,15.00 km/h,2
ENG119203-RV_Last_Mode,90° parking spot ,1
ENG102898-RV_Start_Mode,90° parking spot ,1
ENG119205-Time_to_open_Swinging_Logo,750 ms,2
Elapsed Time: 00:07
adpmap-6D-5Q0-959-107-AA_WVWZZZ3CZME009325-20260823-2132.CSV
;SW:5Q0-959-107-AA   HW:5Q0-959-107-H ---  6D: Trunk Elect.
;Component:HDSG-Modul    H13 0272, Coding:0200
;EV_DeckLidCONTIAU736,001017,EV_DeckLidCONTIAU736_VW37.rod
;Sunday,23,August,2026,21:32:51:32152
;VCID: 77A084A6AF4A9D32EF8-8022
IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
IDE00001-MAS10735-Production mode-Calibration,not active ,3
IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
IDE02158-Program opening stop,2139 ,2
IDE03435-Detection area upper,35 ,2
IDE03776-Offset for maximum programmable opening stop,35 ,2
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,4 min,2
IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,1 ,4
IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,287 ,4
IDE09511-Minimum opening height of tailgate,428 ,2
IDE09512-Deactivation of tailgate,active ,1
IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,not active ,2
IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
IDE09520-Offset for opening height after basic setting,0 ,2
IDE10408-Opening height in production mode,60 %,2
IDE10695-Dectivation of the luggage compartment cover,not active ,1
IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
IDE10705-Luggage compartment cover: number bloom drives,0 ,2
IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,active ,2
ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
ENG131232-MAS08212-Ausstattungen aktivieren-Motor 2,not active ,2
ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,not active ,2
Elapsed Time: 00:06
adpmap-75-5WA-035-284-G_WVWZZZ3CZME009325-20260823-2134.CSV
;SW:5WA-035-284-G   HW:5WA-035-284-B ---  75: Telematics
;Component:OCUGen3High   H22 0143, Coding:024827001968A8209005460160002607
;EV_OCUGen3High,003007,EV_OCUGen3High_003_VW27.rod
;Sunday,23,August,2026,21:34:15:32152
;VCID: 4AC60D528C38D0DA406-801E
IDE00608-MAS00713-Fuel type-Petrol,installed ,1
IDE00608-MAS00716-Fuel type-Diesel,not installed ,1
IDE00608-MAS00717-Fuel type-Petroleum gas,not installed ,1
IDE00608-MAS00718-Fuel type-Natural gas,not installed ,1
IDE00608-MAS00720-Fuel type-Battery / electric,installed ,1
IDE00608-MAS03131-Fuel type-Hydrogen,not installed ,1
IDE00761-MAS08397-Run-on time-Long term energy budget,3600 mAh,5
IDE00761-MAS08398-Run-on time-Short term energy budget,1000 mAh,5
IDE00761-MAS08399-Run-on time-Waiting period from sleep to standby mode,5 min,5
IDE00765-Delay of audio output,1.0 s,1
IDE00769-Call number 1 for info call,empty ,5
IDE00770-Number 1 for roadside assistance,empty ,5
IDE00820-Activating and deactivating all development messages-,not activated ,1
IDE00820-ENG263580-Activating and deactivating all development messages-gnss_position_debug_traces,On ,1
IDE02330-Call number 2 for info call,+4953612771600  ,15
IDE02331-Number 2 for roadside assistance,empty ,5
IDE03581-MAS00478-Vehicle function list CAN-Reserved,0 ,3
IDE03581-ENG183857-Vehicle function list CAN-brakes,activated ,3
IDE03581-ENG252060-Vehicle function list CAN-Central_Electrics,activated ,3
IDE03581-ENG252043-Vehicle function list CAN-Clima,activated ,3
IDE03581-ENG252092-Vehicle function list CAN-Dash_Board,activated ,3
IDE03581-ENG252042-Vehicle function list CAN-Engine,activated ,3
IDE03581-ENG252080-Vehicle function list CAN-Front_door_co_driver,activated ,3
IDE03581-ENG252077-Vehicle function list CAN-Front_door_driver,activated ,3
IDE03581-ENG98593-Vehicle function list CAN-Gateway,activated ,3
IDE03581-ENG252094-Vehicle function list CAN-seat_memory_driver,not activated ,3
IDE03581-ENG252083-Vehicle function list CAN-Steering_Column_Electronics,activated ,3
IDE04307-IDE01762-Vehicle function list BAP-Doors,not activated ,11
IDE04307-IDE03031-Vehicle function list BAP-Seat adjustment,not activated ,11
IDE04307-IDE03111-Vehicle function list BAP-Interior lighting,activated ,11
IDE04307-MAS00688-Vehicle function list BAP-Multi-function display,activated ,11
IDE04307-MAS00903-Vehicle function list BAP-Service interval display (SID),activated ,11
IDE04307-MAS01118-Vehicle function list BAP-Air Conditioning,activated ,11
IDE04307-MAS01282-Vehicle function list BAP-Wiper,activated ,11
IDE04307-MAS01891-Vehicle function list BAP-Lane departure warning,not activated ,11
IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,11
IDE04307-MAS03385-Vehicle function list BAP-Lane change assistance,not activated ,11
IDE04307-MAS03420-Vehicle function list BAP-Head-Up-Display,not activated ,11
IDE04307-MAS03853-Vehicle function list BAP-Road sign detection,not activated ,11
IDE04307-MAS04219-Vehicle function list BAP-Auxiliary heating,not activated ,11
IDE04307-MAS05087-Vehicle function list BAP-ACC,activated ,11
IDE04307-MAS05506-Vehicle function list BAP-Stopping distance reduction,activated ,11
IDE04307-MAS06654-Vehicle function list BAP-Charge manager,activated ,11
IDE04307-MAS07249-Vehicle function list BAP-Main beam,activated ,11
IDE04307-MAS08072-Vehicle function list BAP-Driving profile selection,not activated ,11
IDE04307-MAS08785-Vehicle function list BAP-Parking aid,activated ,11
IDE04307-MAS20539-Vehicle function list BAP-BAP distance PaCo_0x55,not activated ,11
IDE04307-MAS20545-Vehicle function list BAP-BAP distance doors2_0x63,not activated ,11
IDE04307-MAS20550-Vehicle function list BAP-BAP distance infotainment_settings_0x50,not activated ,11
IDE04307-MAS20553-Vehicle function list BAP-BAP distance mirror_0x0E,activated ,11
IDE04307-MAS20556-Vehicle function list BAP-BAP distance unit_master_0x13,not activated ,11
IDE04307-MAS22226-Vehicle function list BAP-BAP distance REM_0x5B,not activated ,11
IDE04307-MAS22227-Vehicle function list BAP-BAP distance REM2_0x67,not activated ,11
IDE04307-MAS22228-Vehicle function list BAP-BAP distance remote_services_0x4E,activated ,11
IDE04307-MAS22229-Vehicle function list BAP-BAP distance info_settings_0x50_Buszuordnung,by_Ethernet ,11
IDE04307-MAS27766-Vehicle function list BAP-Report system for deviations,not activated ,11
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,255 min,2
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,60 min,2
IDE07699-Mobile network operator,info.m2mcubic.com ,21
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
IDE08814-MAS14301-Navigation receiver GNSS configuration-external GPS receiver via bus,OFF ,1
IDE08814-ENG244944-Navigation receiver GNSS configuration-Beidou,OFF ,1
IDE08814-ENG244974-Navigation receiver GNSS configuration-Dead_reckoning_position_transmission,On ,1
IDE08814-ENG245012-Navigation receiver GNSS configuration-GPS_output_on_CAN,On ,1
IDE09244-Fuel tank volume,70 l,1
IDE11108-Remote vehicle immobilizer safety protocol,Fazit4MyCar ,1
IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,activated ,5
IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,5 s,5
IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,10 s,5
IDE13547-ENG101574-Dimming curve of the red functional lighting in case of various colors at the same time-X1,0 ,12
IDE13547-ENG99557-Dimming curve of the red functional lighting in case of various colors at the same time-X2,20 ,12
IDE13547-ENG102140-Dimming curve of the red functional lighting in case of various colors at the same time-X3,50 ,12
IDE13547-ENG102936-Dimming curve of the red functional lighting in case of various colors at the same time-X4,100 ,12
IDE13547-ENG103548-Dimming curve of the red functional lighting in case of various colors at the same time-X5,150 ,12
IDE13547-ENG113992-Dimming curve of the red functional lighting in case of various colors at the same time-X6,253 ,12
IDE13547-ENG99777-Dimming curve of the red functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13547-ENG100480-Dimming curve of the red functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13547-ENG100773-Dimming curve of the red functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13547-ENG100631-Dimming curve of the red functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13547-ENG102174-Dimming curve of the red functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13547-ENG113993-Dimming curve of the red functional lighting in case of various colors at the same time-Y6,50 %,12
IDE13548-ENG101574-Dimming curve of the green functional lighting in case of various colors at the same time-X1,0 ,12
IDE13548-ENG99557-Dimming curve of the green functional lighting in case of various colors at the same time-X2,20 ,12
IDE13548-ENG102140-Dimming curve of the green functional lighting in case of various colors at the same time-X3,50 ,12
IDE13548-ENG102936-Dimming curve of the green functional lighting in case of various colors at the same time-X4,100 ,12
IDE13548-ENG103548-Dimming curve of the green functional lighting in case of various colors at the same time-X5,150 ,12
IDE13548-ENG113992-Dimming curve of the green functional lighting in case of various colors at the same time-X6,253 ,12
IDE13548-ENG99777-Dimming curve of the green functional lighting in case of various colors at the same time-Y1,0 %,12
IDE13548-ENG100480-Dimming curve of the green functional lighting in case of various colors at the same time-Y2,1 %,12
IDE13548-ENG100773-Dimming curve of the green functional lighting in case of various colors at the same time-Y3,2 %,12
IDE13548-ENG100631-Dimming curve of the green functional lighting in case of various colors at the same time-Y4,3 %,12
IDE13548-ENG102174-Dimming curve of the green functional lighting in case of various colors at the same time-Y5,40 %,12
IDE13548-ENG113993-Dimming curve of the green functional lighting in case of various colors at the same time-Y6,50 %,12
IDE14995-MAS19716-Private sphere mode: workshop settings-Services,Maximum private sphere in shape 2 ,7
IDE14995-MAS19722-Private sphere mode: workshop settings-Data collector,not activated ,7
IDE14995-MAS19797-Private sphere mode: workshop settings-Basic settings not detected guest: services,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19798-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with balancing of interests,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19799-Private sphere mode: workshop settings-Basic settings not detected guest: campaigns with consent,Settings from the previous drive cycle are adopted ,7
IDE14995-MAS19887-Private sphere mode: workshop settings-Display info window for current privacy settings,No display ,7
IDE14995-MAS19892-Private sphere mode: workshop settings-Display selection for recurring dialog display,No display ,7
IDE14995-MAS19893-Private sphere mode: workshop settings-Selection for recurring dialog display availability,for personalized users ,7
IDE14995-ENG98891-Private sphere mode: workshop settings-Reserved,0 ,7
IDE15042-MAS19716-Privacy mode: customer settings-Services,Maximum private sphere in shape 2 ,3
IDE15042-MAS19722-Privacy mode: customer settings-Data collector,not activated ,3
IDE15042-MAS19887-Privacy mode: customer settings-Display info window for current privacy settings,No display ,3
IDE15074-MAS13668-Broadband audio-Emergency call,not activated ,1
IDE15074-MAS20714-Broadband audio-Breakdown assistance/information call,not activated ,1
IDE15407-IDE01762-BAP route control-Doors,OFF ,25
IDE15407-IDE03031-BAP route control-Seat adjustment,OFF ,25
IDE15407-IDE03111-BAP route control-Interior lighting,automatic ,25
IDE15407-MAS00688-BAP route control-Multi-function display,OFF ,25
IDE15407-MAS01118-BAP route control-Air Conditioning,automatic ,25
IDE15407-MAS01282-BAP route control-Wiper,automatic ,25
IDE15407-MAS01891-BAP route control-Lane departure warning,OFF ,25
IDE15407-MAS02444-BAP route control-Central locking,automatic ,25
IDE15407-MAS03385-BAP route control-Lane change assistance,OFF ,25
IDE15407-MAS03420-BAP route control-Head-Up-Display,OFF ,25
IDE15407-MAS03853-BAP route control-Road sign detection,OFF ,25
IDE15407-MAS05087-BAP route control-ACC,automatic ,25
IDE15407-MAS05506-BAP route control-Stopping distance reduction,automatic ,25
IDE15407-MAS07249-BAP route control-Main beam,automatic ,25
IDE15407-MAS08072-BAP route control-Driving profile selection,OFF ,25
IDE15407-MAS08785-BAP route control-Parking aid,automatic ,25
IDE15407-MAS20539-BAP route control-BAP distance PaCo_0x55,OFF ,25
IDE15407-MAS20545-BAP route control-BAP distance doors2_0x63,OFF ,25
IDE15407-MAS20550-BAP route control-BAP distance infotainment_settings_0x50,OFF ,25
IDE15407-MAS20553-BAP route control-BAP distance mirror_0x0E,automatic ,25
IDE15407-MAS20556-BAP route control-BAP distance unit_master_0x13,OFF ,25
IDE15407-ENG98891-BAP route control-Reserved,OFF ,25
IDE15407-ENG113413-BAP route control-reserved_01,OFF ,25
IDE15407-ENG261390-BAP route control-reserved_02,OFF ,25
MAS01078-Vehicle model,Passenger car (category M1) ,1
MAS07110-Muting of audio sources,Muting not active ,1
MAS07467-Speed warning maximum speed,0 km/h,2
MAS08170-User profile name,blank ,5
MAS08171-User profile password,blank ,5
MAS08172-Mobile Online services: first host name-,https://mod3vkmsmbbreg-0.prd.eu.dp.vwg-connect.com/mbb/vehicles/v2/deviceRegistered ,86
MAS08172-MAS17438-Mobile Online services: first host name-Preselection of host names,free ,86
MAS08172-ENG247627-Mobile Online services: first host name-Online_Service_Backend_Type,MBB ,86
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
MAS08177-Acoustic warning for vehicle shut-down,activated ,1
MAS08366-MAS01487-Keypad-LED,Direct ,1
MAS08366-MAS10536-Keypad-Keys,Three button keypad ,1
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
MAS09650-Threshold for vehicle movement recognition,5 km/h,2
MAS13395-Transmission_status_activation-,activated ,5
MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,0 d,5
MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-Transmission interval below threshold,5 %,3
MAS13840-GNSS: data transmission rate,10 Hz ,2
MAS13841-GNSS: minimum height,5 °,2
MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,50 ,6
MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,50 %,6
MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
MAS17119-ENG245041-Fault memory mobile online service threshold-Step_00,100 ,32
MAS17119-ENG244993-Fault memory mobile online service threshold-Step_01,100 ,32
MAS17119-ENG244984-Fault memory mobile online service threshold-Step_02,100 ,32
MAS17119-ENG245001-Fault memory mobile online service threshold-Step_03,100 ,32
MAS17119-ENG245016-Fault memory mobile online service threshold-Step_04,100 ,32
MAS17119-ENG245017-Fault memory mobile online service threshold-Step_05,100 ,32
MAS17119-ENG245042-Fault memory mobile online service threshold-Step_06,100 ,32
MAS17119-ENG245043-Fault memory mobile online service threshold-Step_07,100 ,32
MAS17119-ENG244962-Fault memory mobile online service threshold-Step_08,0 ,32
MAS17119-ENG245032-Fault memory mobile online service threshold-Step_09,0 ,32
MAS17119-ENG245002-Fault memory mobile online service threshold-Step_10,0 ,32
MAS17119-ENG245003-Fault memory mobile online service threshold-Step_11,0 ,32
MAS17119-ENG245018-Fault memory mobile online service threshold-Step_12,0 ,32
MAS17119-ENG244967-Fault memory mobile online service threshold-Step_13,0 ,32
MAS17119-ENG244985-Fault memory mobile online service threshold-Step_14,0 ,32
MAS17119-ENG244968-Fault memory mobile online service threshold-Step_15,0 ,32
MAS17427-MAS00220-Door configuration-Rear left door,installed ,1
MAS17427-MAS00221-Door configuration-Rear right door,installed ,1
MAS17427-SFT271922-Door configuration-Left rear door control module,installed ,1
MAS17427-SFT271923-Door configuration-Right rear door control module,installed ,1
MAS17439-Wifi hotspot mobile phone connection: network operator,wifi.m2mcubic.com ,17
MAS17460-Wifi hotspot mobile phone connection: user profile name,blank ,5
MAS17461-Wifi hotspot mobile phone connection: password,blank ,5
MAS17554-Digital key: backend notification,activated ,1
MAS17562-Query interval for Real Time Monitoring,1 s,1
MAS18217-IDE09602-Activation status for local hazard warning service-Locale hazard warning,OFF ,1
MAS18217-MAS18218-Activation status for local hazard warning service-Accident,OFF ,1
MAS18217-MAS18219-Activation status for local hazard warning service-Breakdown,OFF ,1
MAS18217-MAS18220-Activation status for local hazard warning service-Loss of traction,OFF ,1
MAS18217-MAS18221-Activation status for local hazard warning service-Visual obstruction,OFF ,1
MAS18217-MAS18222-Activation status for local hazard warning service-Hydroplaning,OFF ,1
MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
MAS18603-ENG247383-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247384-Damping factor for dimming up and down-Ambient_Light_Illumination_Damping_Up,0.2 s,4
MAS18603-ENG247607-Damping factor for dimming up and down-Functional_Illumination_Damping_Down,0.1 s,4
MAS18603-ENG247608-Damping factor for dimming up and down-Functional_Illumination_Damping_Up,0.2 s,4
MAS18701-Setting the product data,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 4F 04 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D1 00 00 00 C6 02 00 00 62 0C 5F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,3296
MAS19210-Maximum waiting time to transfer UserID from IAA,150 ms,1
MAS19211-Delay time for synchronization with memory site,400 ms,1
MAS19213-Operation during severe BAP errors while storing data,Continue operation ,1
MAS19214-Maximum synchronization of an unused shadow drive,28 d,1
MAS19215-Waiting time until change to settings is transferred,60 s,2
MAS19216-Number of extensions until transfer is completed,3 s,1
MAS19218-Delay time for picking up changes,120 s,1
MAS19219-Maximum waiting time for HMI availability,5 min,1
MAS19220-Download before activating driver (driver already stored),Do not perform download ,1
MAS19221-Maximum storage duration,120 s,1
MAS19222-Maximum waiting time before storing is canceled,5 s,1
MAS19233-Identify Authorize Authenticate - user management,installed ,1
MAS19239-Time window for key recognition,5 min,1
MAS19240-Authorization level after-run time,0 min,1
MAS19241-Key recognition mode setting,automatic ,1
MAS19242-User images display,On ,1
MAS19243-BCM user switching,OFF ,1
MAS19244-Permanent safety mode setting,On ,1
MAS19335-Maximum duration of relocation,60 s,1
ENG123200-Driving_Follow_Up_Time,5 min,1
ENG244879-function_configuration_sw_update,On ,1
ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
ENG247336-MAS01424-Geofencing_Area_Height-max.value,4294967294 m,8
ENG247336-MAS01425-Geofencing_Area_Height-min.value,1 m,8
ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,2147483647 °,8
ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2147483648 °,8
ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,2147483647 °,8
ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2147483648 °,8
ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Direction of travel,30 °,12
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
ENG153744-supress_climatisation_settings,not activated ,1
ENG153745-supress_climatisation_temperature,not activated ,1
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
Elapsed Time: 00:31
adpmap-8C-3Q0-915-183-E_WVWZZZ3CZME009325-20260823-2135.CSV
;SW:3Q0-915-183-E   HW:3Q0-915-183-D ---  8C: HV Battery
;Component:J840 K8C  BMC 004 0940, Coding:
;EV_BMCeVWBSMQB48,001007,EV_BMCeVWBSMQB48_VW48.rod
;Sunday,23,August,2026,21:35:13:32152
;VCID: 343A73AAFEBCB62A0AA-8060
IDE05417-Serial number of H-V / hybrid battery,288 XX10000CGR6 ,15
IDE05963-ASSY part number,3Q0915590M   ,12
IDE09090-Deactivation mode: insulation measurement,not active ,1
IDE14477-Traction battery: China serial number,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ ,26
IDE80001-Analysis 1,active ,1
Elapsed Time: 00:02
adpmap-A5-2Q0-980-653_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:2Q0-980-653   HW:2Q0-980-653 ---  A5: Frt Sens. Drv. Assist
;Component:MQB MFK 3.0   H11 1030, Coding:00000888214C4020109E10001030008000418000000000000000000000000000
;EV_MFK3ValeoMQB,005035,EV_MFK3ValeoMQB_005_VW27.rod
;Sunday,23,August,2026,21:36:01:32152
;VCID: 72B6B5B2C428F81AD86-8026
IDE04733-Road sign detection fusion mode-,Security access required,3
IDE06425-Dynamometer mode: functional-,not activated ,1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved,0 ,1
IDE07358-Distance to calibration field,Security access required,1
IDE09375-IDE05717-Axle offset-Front axle transverse position,Security access required,1
IDE09375-IDE05718-Axle offset-Rear axle transverse position,Security access required,1
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,Security access required,1
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,Security access required,1
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,Security access required,1
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,Security access required,1
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,Security access required,1
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,Security access required,1
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,Security access required,1
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,Security access required,1
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,Security access required,1
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,Security access required,1
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,Security access required,1
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,Security access required,1
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,Security access required,1
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,Security access required,1
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,Security access required,1
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,Security access required,1
IDE10407-Personalization of intervention moment at T. 15 on,Security access required,1
IDE10870-Switch-on condition: lane depart. warn.,Security access required,1
IDE10873-BAP personalization,Security access required,1
IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.000 °,8
IDE10924-MAS05286-Initial calibration: result-Roll angle,0.000 °,8
IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.000 °,8
IDE10924-MAS10678-Initial calibration: result-Camera height,0 mm,8
IDE12097-Menu for roadside fusion persistency,Security access required,8
Elapsed Time: 00:08
adpmap-A9-3G0-907-159_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:3G0-907-159   HW:4H0-907-159-A ---  A9: Struct. Borne Sound
;Component:SAS-GEN 2     H07 0006, Coding:
;EV_SoundActuaGen2AU64X,003010,EV_SoundActuaGen2AU64X_003_VW48.rod
;Sunday,23,August,2026,21:36:15:32152
;VCID: 6984D2DEE9FE3BC269C-803C
IDE04472-Volume of structure-borne noise actuator,100.0 %,1
Elapsed Time: 00:00
adpmap-BB-5Q0-959-595-K_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:5Q0-959-595-K   HW:8W1-959-595-D ---  BB: Door Rear Drv
;Component:TSG HFS004 0330, Coding:000E01200100020000001000
;EV_DCU2RearDriveMAXHKLO,001018,EV_DCU2RearDriveMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:36:28:32152
;VCID: 4BC808568342C9D27B0-801E
IDE09067-Side window shade: service mode,Deactivating ,1
Elapsed Time: 00:02
adpmap-BC-5Q0-959-595-K_WVWZZZ3CZME009325-20260823-2136.CSV
;SW:5Q0-959-595-K   HW:8W1-959-595-D ---  BC: Door Rear Pass
;Component:TSG HBFS004 0330, Coding:000E01200100020000001000
;EV_DCU2RearPasseMAXHKLO,001018,EV_DCU2RearPasseMAXHKLO_VW48.rod
;Sunday,23,August,2026,21:36:46:32152
Elapsed Time: 00:02
adpmap-C6-5QE-915-682-AR_WVWZZZ3CZME009325-20260823-2137.CSV
;SW:5QE-915-682-AR   HW:5QE-915-682-AR ---  C6: Batt. Chrg.
;Component:OBC KOSTAL    H42 4031, Coding:115069222000
;EV_OBCSinglPhaseKLOMQB15P,001001,EV_OBCSinglPhaseKLOMQB15P_001_VW48.rod
;Sunday,23,August,2026,21:37:03:32152
;VCID: 1D6CB60E6D361762D54-8048
IDE00001-Production mode,OFF ,3
IDE08427-MAS07237-Statistics of power outlet A for battery charging-No. of connections,3210 ,4
IDE08427-MAS07238-Statistics of power outlet A for battery charging-No. of lockings,3899 ,4
IDE08428-MAS07237-Statistics of power outlet B for battery charging-No. of connections,0 ,4
IDE08428-MAS07238-Statistics of power outlet B for battery charging-No. of lockings,0 ,4
MAS12691-MAS12692-Activation times: plug locking device-Re-locking time plug,30 s,3
MAS12691-MAS12693-Activation times: plug locking device-Locking activation time,400 ms,3
MAS12691-MAS12694-Activation times: plug locking device-Unlocking activation time,400 ms,3
Elapsed Time: 00:03
adpmap-D6-992-941-572-CA_WVWZZZ3CZME009325-20260823-2137.CSV
;SW:992-941-572-CA   HW:992-941-572-C ---  D6: Light Ctrl Left 2
;Component:LED1L         H08 9002, Coding:
;EV_LLPGen3LKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_001_VW48.rod
;Sunday,23,August,2026,21:37:21:32152
;VCID: 649AC3EA0EDC66AA5AA-8030
ENG178994-Kodiercontainer Teilenummer,----------- ,11
ENG178993-Kodiercontainer Version,---- ,4
ENG178996-VehicleEquipmentCode And ProductionNumberCombination,00 00 00 00 00 00 00 00 00 00 00 00 ,12
Elapsed Time: 00:01
adpmap-D7-992-941-572-CA_WVWZZZ3CZME009325-20260823-2137.CSV
;SW:992-941-572-CA   HW:992-941-572-C ---  D7: Light Ctrl Right 2
;Component:LED1R         H08 9002, Coding:
;EV_LLPGen3RKEBODPO68X,001003,EV_LLPGen3LKEBODPO68X_001_VW48.rod
;Sunday,23,August,2026,21:37:37:32152
Elapsed Time: 00:01
Trevas
Portugal
C?ID=516418
I hope this is of some use.
BTW, I've been trying to perform some basic settings on the DSG, but some of the fields just turn on the pump, and after a few seconds (5-10 seconds), it says that the procedure was aborted for safety reasons.
What are the preconditions to perform these basic settings?
Nice! This car has that OMG ABS and EBKV brake booster combo so it may be useful for your e-golf comparing as well.
The only official DQ400E / ODD procedure we have is fluid change specific from our Danish distributor:
http://www.netech.dk/vcds/vcdsdownload/1-vcdsfiler/37-tip9olie
I found this video on oil service as well but they don't include the identifiers:
Trevas
Portugal
C?ID=516418
That's a great idea, it didn't occur to me before you mentioned it!
So, I took a sneak peek, and there are a lot of differences in basic settings and advanced measuring values, but something caught my eye. This one has a field to measure the brake pedal travel as well. I guess it is no surprise that this value is a little above zero at rest, unlike Golfy which has a negative value at rest. I will try to remove the travel sensor, and since it is not sold separately, I'll try to clean it up and hope for a miracle. I'll let you know the result in the Golfy thread.
You truly are a saint Dana :o Since the pre-conditions are not mentioned in that document, I tried that SA on my gearbox module, and it was not accepted. I could have checked with ODIS, it probably had the pre-conditions detailed there."
NEtech
Denmark
C?ID=56995
First you must an expert in using VCDS for this job!
I suggest using odis.
Either I don't understand what you are writing or you don't explain very good what you mean.
Difference between what?
Is that from my pdf?
[Vis måledata] søg og vælg: 80260
You can see that from your maps:
IDE80260-ENG127862,Pressure supply: act. press.-Pressure supply actual pressure,49.30, bar
Tænding TIL.
Motor FRA.
Gearvælger i P.
Parkeringsbremse aktiveret.
Køretøj placeret vandret.
Afmonter bundplade
SA S11820 is for the Danish label file.
In the English version that is now available as SA S00064
Trevas
Portugal
C?ID=516418
I believe I know my way around VCDS. I wouldn't say that I'm a 100% expert, because there may be some things I don't know.
I'm sorry, let me clarify:
the differences in basic settings and advanced measuring values between the brake booster control module of the Golf and the Passat.
Yes, it's from your PDF. I meant the preconditions to perform the clutch and gear shifting adaptation.
Or are they the same for the oil change procedure you mention in your PDF?
Yes, it's also from your PDF.
I was not aware that different language label files had different SA codes. Thanks for the info :)
Trevas
Portugal
C?ID=516418
I have a new situation here.
I got DTC 1048578 - No Basic Setting after performing an SRI reset.
I understand that this is a little off-topic, but I decided to post it here because I have all the original adaptation values from when the car arrived for comparison.
The full story:
A week ago, I was playing around with ODIS online and performed a conversion from fixed to flexible intervals. This DTC popped right up.
I tried to write a new dataset, and the DTC was cleared.
Today, I performed a full service on the car, and when performing the SRI reset, this DTC came back. I also changed the Oil Quality field to 'Good Quality Oil', but I believe the DTC was already there before I made that change. I think the DTC popped up right after the SRI reset.
I've found a thread here regarding the same DTC, but it appears to me that my situation is different, as I don't have weird km or day values.
Friday,04,September,2026,22:47:48:32152
VCDS Version: 26.9.0.3 (x64)  HEX-NET2 CB: 0.4713.5
Dealer/Shop Name: Carlos
Workshop Code: 133 13384 013384
VIN: WVWZZZ3CZME009325   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 4B 51 52 5F 6C
          6D 75 8C A5 A9 BB BC C6 D6 D7
VIN: WVWZZZ3CZME009325   Mileage: 136800km-85003miles
Address 01: Engine (J623-DGEB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 024 G    HW: 04E 907 309 CG
   Component: 1.4 TFSI hy   H20 9972
   Revision: DCH20000    CVN: 6DC888FF
   Coding: 011D4012636405083008
   Shop #: WSC 99999 999 2097151
   ASAM Dataset: EV_ECM14TFS01104E906024G 002009
   ROD: EV_ECM14TFS01104E906024AE_002.rod
   VCID: 251C9EEE4566DFA2B46-8070
   VINID: 9E69EAAAA0D3A9D5400090C21474FF5483
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels:. 0DD-927-770-V1.clb
   Part No SW: 0DD 300 046 E    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 2201
   Revision: 00032056    Serial number: TFK02007170041 CVN: 3D5E9018
   Shop #: WSC 05311 115 00074
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 2A066DD22C78F0DA994-807E
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 GF    HW: 5QM 614 517
   Component: ESC           H26 0314
   Revision: 00000000    Serial number: 61920000000557 CVN: 9507FFD9
   Coding: 4FEC728FA3203B75477A060268C849F24EC5DCE26016927538B1F078D2224A0B0003010312121212B435351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 060015
   ROD: EV_Brake1UDSContiMK100OMG_060.rod
   VCID: 7BA898969362B952B22-802E
   Part No SW: 3Q0 959 435 M    HW: 3Q0 959 435 M
   Component: VWKESSYMQB    027 1307
   Revision: 00027000    Serial number: 0550683711 Dataset Number: V03935321YJ 0001
   Coding: 002F0F0723
   Shop #: WSC 05311 115 00290
   ROD: EV_KessyHellaMQBAB_VW41.rod
   VCID: 44DA236AAE1C06AA838-8010
   Part No SW: 3G8 907 056 A    HW: 3G8 907 056 A
   Component: Climatronic   H10 0205
   Coding: 12021004200114010915100080101832
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 001050
   ROD: EV_AirCondiBHTCMQB3rTranc_001_VW48.rod
   VCID: 2E0E61C210909CFA45C-807A
   Subsystem 1 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.1X.2C20370019
   Air quality sensor:
   Humidity sensor: exterior:
   A/C compressor sub:
   Subsystem 4 - Part No SW: 5QE 816 803 H    HW: 5QE 816 803 H
   Component: J842 eKK  H03 0009
   Subsystem 5 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
   Part No SW: 5Q0 937 086 CK    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 040 0400
   Revision: --------    Serial number: J53F1707201467 Dataset Number: V03935326TD 0001
   ASAM Dataset: EV_BodyContrModul1UDSBosc 021001
   ROD: EV_BCMBOSCH_021_VW27.rod
   VCID: 055CFE6EE5A6FFA2D46-8050
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    200623  042 0607
   Serial number:         200707184144
   Subsystem 2 - Part No SW: 5Q0 955 555 A    HW: 5Q0 955 555 A
   Component: RLHSS  054 0207
   Serial number: S7Y20M07D02H20M52S15
   Coding: 0008DD
   Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
   Serial number: 31 12 2019  10000391
   Subsystem 4 - Part No SW: 3G0 947 105 C    HW: 3G0 947 105 C
   Component: J528 Dachelek  H08 0009
   Serial number: 20072000010058C
   Coding: F38380
   Humidity sensor: interior:
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 521 GE    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0100190520200C301115
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058320195 Dataset Number: V03935315CY 0001
   Coding: 9471151811
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_009_VW48.rod
   VCID: 53F810365B7291120A2-8006
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Dataset Number: V03935324MZ 0001
   Coding: 52017F425DFFC728949C812481408680000000000000000066
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003_VW48.rod
   VCID: 46DE3962982034BA9DC-8012
   Part No SW: 5QF 959 655 AA    HW: 5QF 959 655 AA
   Component: Airbag VW22   011 0639
   Revision: --------    Serial number: 003014CPE9ZQMM Dataset Number: V03935330YL 0001
   Coding: 98CCC0C0002000005C5400CF000C40000065
   ASAM Dataset: EV_AirbaVW22TS6VW48X 001030
   ROD: EV_AirbaVW22TS6VW48X.rod
   VCID: 157CAE2E95064F22246-8040
   Subsystem 1 - Part No SW: -----------    HW: 454 000 107 20
   Serial number: 3570000000069638084G
   Subsystem 2 - Part No SW: -----------    HW: 454 000 107 20
   Serial number: 3580000000036638084B
   Subsystem 3 - Part No SW: -----------    HW: 454 800 107 20
   Serial number: 3510082728C1B000000H
   Subsystem 4 - Part No SW: -----------    HW: 454 800 107 20
   Serial number: 35200AACD6F1B0000002
   Subsystem 5 - Part No SW: -----------    HW: 454 802 906 20
   Serial number: 355000195B11B0000009
   Part No SW: 3G0 920 324 B    HW: 3G0 920 324 B
   Component: KOMBI         502 5176
   Coding: 05A408186FC40008068B62531001002880700300
   Shop #: WSC 13384 133 13384
   ASAM Dataset: EV_DashBoardVDDMQBA0 001045
   ROD: EV_DashBoardVDDMQBA0_001_VW48.rod
   VCID: 20128FFA5A443A8AC70-8074
          B2010 00 [00001001] - -
          [Steuerger t keine oder falsche Grundeinstellung]
                    Reset counter: 135
                    Mileage: 136800 km
                    Date: 2026.09.04
                    Time: 22:41:06
   Part No SW: 3Q0 907 530 AH    HW: 3Q0 907 530 D
   Component: GW MQB EV     621 6423
   Serial number: 11082011600176 Dataset Number: V03935324TE 0001
   Coding: 020900172CE21000FB0052FA581D00000001070100010000000300000000
   GVL: 01463C1008000608508C80008002C81800000000000200000000000000000000
   ROD: EV_GatewNF_VW48.rod
   VCID: 75BC8EAEB546EF22C46-8020
   Subsystem 1 - Part No SW: 3G0 959 442 R    HW: 3G0 959 442 R
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440066183203574
   Coding: 2D0B00
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Component: J367-BDMHella  H11 9070
   Serial number: 4525164905
Address 23: Brake Booster (J539)       Labels:. 5QE-909-059.clb
   Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
   Component: EBKV          H06 0069
   Serial number: BPA085300720013
   Coding: 0202C104340000C618638C31000049922449920400
   ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
   ROD: EV_BrakeBoostG2BoschVW48X_011_VW48.rod
   VCID: 3B285896D3E27952F22-806E
   Serial number: 20000160933002
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW48.rod
   VCID: 333870B6FBB2B1122A2-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0330
   Serial number: YE007TFN0034D Dataset Number: V03935310MJ 0001
   Coding: 003F0F20D000020000001000
   ROD: EV_DCU2DriveSideMAXHKLO_VW48.rod
   VCID: 49C4325E893EDBC270E-801C
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 075012 00  Dataset Number: V03935290ME 0001
   Coding: 0100001100410010
   Shop #: WSC 00015 115 00290
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2.rod
   VCID: 2B0868D62382E9D2622-807E
   Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 F
   Component: FCM MQB High  004 0370
   Serial number: 06072010520645 Dataset Number: V03935329VZ 0001
   Coding: 000000070B0004CA00000F11000302040000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW48.rod
   VCID: 3822479AE2D4524A1F0-806C
   Antenna for short-range communication:
   Subsystem 1 - Part No SW: 3G1 959 121     HW: 3G1 959 121
   Component: R350 NFCTGS  701 0509
   Serial number: 0000000000B34ED900ED
   Antenna 2 for short-range communication:
   Subsystem 2 - Part No SW: 3G0 980 611     HW: 3G0 980 611
   Component: J524 NFCMIKO  H09 0059
   Serial number: 32000000000001623332
Address 51: Electric Drive (J841)       Labels:. 3G0-907-080.clb
   Part No SW: 3G0 907 080 G    HW: 3G0 907 080 G
   Component: LE Gen 3.3H17 0090
   Revision: 00H17000    CVN: 228B6A44
   Coding: 03090000000000000000
   ASAM Dataset: EV_DMCM08530113G0907080G 001020
   ROD: EV_DMCM08530113G0907080G.rod
   VCID: 290492DE297EFBC290E-807C
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0330
   Serial number: YE007TFQ13524 Dataset Number: V03935310MD 0001
   Coding: 003F0120DC00020000001000
   ROD: EV_DCU2PasseSideMAXHKLO_VW48.rod
   VCID: 48C2375A923422CA6F0-801C
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 3G5 035 816 B    HW: 3G5 035 816 B
   Component: MU-O-ND-EU    H22 0332
   Serial number: VWZAZ2X0631832  Dataset Number: V03935422TR 0001
   Coding: 24820000000020000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB 001001
   ROD: EV_MUOIMQB_001_VW48.rod
   VCID: 280297DA3274C2CA8F0-807C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2     H61 9216
   Serial number: VWZ6ZJX1761396
   Subsystem 2 - Part No: V03 959 809 BN
   Component: EU 2020/21     3085
   Dataset Number: V03935314JY 0001
   Coding: 0184020162002017000041
   VCID: 3924429ED9DE4B42E0E-806C
   Part No SW: 5Q0 959 107 AA    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0272
   Revision: --------    Serial number: A2-C737-6331-9 Dataset Number: V03935322   0001
   Coding: 0200
   VCID: 77A084A6AF4A9D32D6A-8022
   Part No SW: 5WA 035 284 H    HW: 5WA 035 284 B
   Component: OCUGen3High   H22 0311
   Serial number: 0000000311VICLF Dataset Number: V03935450DD 0001
   Coding: 024827001968A8209005460160002607
   ASAM Dataset: EV_OCUGen3High 003021
   ROD: EV_OCUGen3High_003_VW27.rod
   VCID: 4BC808568342C9D2422-801E
Address 8C: HV Battery (J840)       Labels: 3Q0-915-183.clb
   Part No SW: 3Q0 915 183 E    HW: 3Q0 915 183 D
   Component: J840 K8C  BMC 004 0940
   Serial number: 000000090620040 CVN: D33F78A57D759AE21DF230341DF230341DF230341DF230341DF230341DF23034
   ASAM Dataset: EV_BMCeVWBSMQB48 001007
   ROD: EV_BMCeVWBSMQB48_VW48.rod
   VCID: 343A73AAFEBCB62A338-8060
   Cell module control module 1:
   Subsystem 1 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Component: CMC            H04 0340
   Serial number: 20103B28AH0403302728
   Cell module control module 2:
   Subsystem 2 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403300995
   Cell module control module 3:
   Subsystem 3 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301334
   Cell module control module 4:
   Subsystem 4 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301330
   Cell module control module 5:
   Subsystem 5 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301797
   Cell module control module 6:
   Subsystem 6 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403301796
   Cell module control module 7:
   Subsystem 7 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20103B28AH0403303309
   Cell module control module 8:
   Subsystem 8 - Part No SW: 5KE 915 591     HW: 5KE 915 591
   Serial number: 20102B28AH0403300935
   Part No SW: 2Q0 980 653     HW: 2Q0 980 653
   Component: MQB MFK 3.0   H11 1030
   Serial number: E33417012202170 Dataset Number: V03935329NZ 0001
   Coding: 00000888214C4020109E10001030008000418000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005035
   ROD: EV_MFK3ValeoMQB_005_VW27.rod
   VCID: 72B6B5B2C428F81AE14-8026
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 200624200393
   ROD: EV_SoundActuaGen2AU64X_003_VW48.rod
   VCID: 6984D2DEE9FE3BC250E-803C
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0330
   Serial number: YE007TFP01924 Dataset Number: V03935306SB 0001
   Coding: 000E01200100020000001000
   ROD: EV_DCU2RearDriveMAXHKLO_VW48.rod
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS004 0330
   Serial number: YE007TFP05453 Dataset Number: V03935306RQ 0001
   ROD: EV_DCU2RearPasseMAXHKLO_VW48.rod
   Part No SW: 5QE 915 682 AR    HW: 5QE 915 682 AR
   Component: OBC KOSTAL    H42 4031
   Revision: --------    Serial number: 1206200FA000IM Dataset Number: V03935331LN 0001
   Coding: 115069222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB15P 001001
   ROD: EV_OBCSinglPhaseKLOMQB15P_001_VW48.rod
   VCID: 1D6CB60E6D361762EC6-8048
   Part No SW: 992 941 572 CA    HW: 992 941 572 C
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_001_VW48.rod
   VCID: 649AC3EA0EDC66AA638-8030
   Component: LED1R         H08 9002
End----------(Elapsed Time: 02:09, VBatt start/end: 13.2V/13.2V)-----------
-------------------------------1 Fault Found-------------------------------
I've tried to change some km and day values around, but it did not help.
My current values:
;SW:3G0-920-324-B   HW:3G0-920-324-B ---  17: Instruments
;Component:KOMBI         502 5176, Coding:05A408186FC40008068B62531001002880700300
;EV_DashBoardVDDMQBA0,001045,EV_DashBoardVDDMQBA0_001_VW48.rod
;Friday,04,September,2026,23:54:17:32152
;VCDS Version: 26.9.0.3 (x64)  Data version: 20260828 DS378.0
;VCID: 20128FFA5A443A8AC70-8074
IDE00295-Oil temperature display,On ,1
IDE00342-ESI: Resetting ESI,Resetting ,1
IDE00343-Language variant,Portuguese ,1
IDE00500-Hour,23 H,1
IDE00501-Minute,54 min,1
IDE00502-Year,2026 yr,2
IDE00503-Month,9 Months,1
IDE00504-Day,4 d,1
IDE00510-ESI: distance driven from inspection,0 km,3
IDE00511-ESI: time from inspection,0 d,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,2200 d,2
IDE00827-ESI: minimum value of time between inspections,730 d,2
IDE01153-SIA: maximum value of distance to service,30000 km,2
IDE02489-Display depiction,Variant 1 ,1
IDE03329-Driving profiled for range remaining,4.6 l/100km,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometres ,3
IDE03346-MAS02201-Units adjusted-Temperature, C ,3
IDE03346-MAS03032-Units adjusted-Volume,litre ,3
IDE03348-MAS01456-Speed warning-Speed,30 ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,0 km,2
IDE03352-FIX: Time since last time-dependent inspection,0 d,2
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
IDE05932-FIX: Reset value for next time-dependent inspections,730 d,2
IDE06588-Ignition active message: actuator,Driver s door ,1
IDE07161-temporary VIN,Conditions not correct or request sequence error,1
IDE10208-Display correct. of consump. and operating range: elec.,100 %,1
IDE12211-China variant,No ,1
IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,active ,1
IDE12226-MAS05203-Display of longitudinal regulation coordinator-Cruise control system,not active ,1
IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,active ,1
IDE12467-Tubes illustration,Variant 1 ,1
IDE12722-Driving profile display,No ,1
IDE13094-Tachometer end value,Variant 0 ,1
IDE13607-MAS16706-Lock display contents-List time out,0 s,9
IDE14184-Active participant personalization,Yes ,1
IDE14220-Vehicle speed warning for India-,60 s,1
IDE14984-R Logo,no R logo ,1
IDE14986-ACC illustration China,No display ,1
IDE15073-ENG249922-Digital Key 3-number_of_repeats_of_authentication_of_central_locking,05 ,3
IDE15073-ENG249951-Digital Key 3-time_for_waiting_of_receive_of_message_MDK_ZV_Resp,00 0A s,3
IDE15113-Shift exit warning,Car exit warning ,1
IDE15132-Activate/deactivate development messages via Ethernet,not active ,1
MAS03555-Lap counter,Conditions not correct or request sequence error,1
ENG253348-3D_speed,active ,1
ENG114742-Activation of Development Messages,not active ,1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
ENG119875-defuel_threshold,9 l,1
ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,14 ,12
ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,96 ,12
ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,02 ,12
ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,04 ,12
ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,32 ,12
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,01 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,01 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,03 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,06 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,01 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,01 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,03 ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,06 ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,28 ,12
ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 96 ,24
ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0C ,24
ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0C ,24
ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 23 ,24
ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 46 ,24
ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,01 F4 ,24
ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG119833-Display_Save_CP,Yes ,1
ENG128742-Gauge_dimming_condition,OFF ,1
ENG251650-GPS_speed,not active ,1
ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,No ,1
ENG130585-Leaving_warning_delay,1.6 s,1
ENG249798-MDK_coding-,00 ,8
ENG249798-MDK_coding-,01 ,8
ENG249799-ENG249828-MDK_parameter-AZK bConfig COV,00 ,36
ENG249799-ENG249829-MDK_parameter-AZK num Time resp KY,800 ms,36
ENG249799-ENG249830-MDK_parameter-AZK num Time resp MDK,800 ms,36
ENG249799-ENG249831-MDK_parameter-AZK num Time resp WFS,5000 ms,36
ENG249799-ENG249904-MDK_parameter-MDK num Time Zv Cmd High,200 ms,36
ENG249799-ENG249905-MDK_parameter-MDK num Time Zv Cmd Low,100 ms,36
ENG249799-ENG249929-MDK_parameter-Rep Cmd Apdu,01 ,36
ENG249799-ENG249930-MDK_parameter-Rep User Auth,01 ,36
ENG249799-ENG249944-MDK_parameter-Time Esm Aktiv,10 s,36
ENG249799-ENG249945-MDK_parameter-Time Out Mob Dev Key Cmd,30 s,36
ENG249799-ENG249946-MDK_parameter-Time Out Resp Apdu,500 s,36
ENG249799-ENG249947-MDK_parameter-Time Out Ticket Table,120 s,36
ENG249799-ENG249948-MDK_parameter-Time Out VTAN Dec,30 s,36
ENG249799-ENG249949-MDK_parameter-Time Out VTAN Resp,10 s,36
ENG249799-ENG249950-MDK_parameter-Time SKC1,15 s,36
ENG249799-ENG249953-MDK_parameter-Veh Arch,00 ,36
ENG249800-ENG249840-MDK_parameter_2-Dev Param 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG249800-ENG249841-MDK_parameter_2-Dev Param 2,14 02 46 46 46 32 32 32 02 C8 C8 05 0A 1E 64 01 0A 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,96
ENG103063-Mileage,136800 km,3
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4  C,16
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6  C,16
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,70  C,16
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0  C,16
ENG135292-phev_stat_intervall-,1.0 ,3
ENG135292-phev_stat_intervall-,64 m,3
ENG135292-phev_stat_intervall-,00 min,3
ENG153765-Second_digital_speed,No display ,1
ENG98918-Sport,No display ,1
ENG130584-Statistic_phev_mileage,5 km,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,65 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
ENG112418-ENG99298-total_range_gas-State,not active ,4
Elapsed Time: 00:33
I also found this value, which looks suspicious to me:
Saturday,05,September,2026,00:50:19:32152
                Address 17: Instruments  (3G0 920 324 B)
00:50:16
  IDE00935   ESI: Theoretical service interval 52000 km
Can someone help me, please?
Eric
HC800000
Hopefully @RTSupport has time to look into this next business week (monday is off and they'll be short-handed and there's Automechanika). I wanted to point out that your coding in 17 has also changed.
Trevas
Portugal
C?ID=516418
Thanks for the feedback, Eric.
Yes, I did change the instrument cluster language in Coding afterwards. I did not mention it because I thought it would not be relevant to this case.
Jef
HQ
I think that should be 365.
Trevas
Portugal
C?ID=516418
Thanks Jef, I'll give it a try.
BTW, every time I change a value, can I try to clear the DTC right away, or is an ignition cycle required?
NEtech
Denmark
C?ID=56995
Should be: 15000
Sebastian
Magdeburg, Germany
HN0-nnnnnn
As others have already pointed out, you seem to have set some values which are out of spec, most likely causing the DTC B2010. Looking at the vehicle age and mileage, we're past the 1st inspection/oil change...
Per VIN this car was a factory PR-QI4 meaning 15000 km or 1 year (fixed) oil change interval but with an off-cycle inspection schedule (1st inspection after 30.000 km or 2 years, all following inspections 30.000 km or 1 year). So let's clarify what those values ought to look like first...
IDE00515 (ESI: Oil Quality) = poor oil quality
IDE01153 (SIA: Max. Dist. Oil Service) = 15.000 km
IDE01154 (SIA: Max. Time Oil Service) = 365 d
IDE03349 (FIX: Max. Dist. Insp.) = 30.000 km
IDE03350 (FIX: Max. Time Insp.) = 365 d
Now what you seem to be looking for is a a proper PR-QI6 with up to 30.000 km or up to 2 years (flexible) oil change interval and an off-cycle inspection schedule (1st inspection after 30.000 km or 2 years, all following inspections 30.000 km or 1 year).
IDE00515 (ESI: Oil Quality) = good oil quality
IDE00512 (ESI: Min. Dist. Oil Service) = 15.000 km
IDE00513 (ESI: Max. Dist. Oil Service) = 30.000 km
IDE00514 (ESI: Max. Time Oil Service) = 365 d
IDE00827 (ESI: Min. Time Oil Service) = 730 d
That said, I am not aware of a Hybrid/(GTE (Golf, Passat etc.) with this platform, which was sold as PR-QI6 (i.e. flexible intervals). They all had PR-QI4 (fixed intervals) and a brief but multi vehicle and multi markets research in our database confirmed this. If this was my car, I would not put it on flexible in the first place but then I went EV the whole way to avoid oil changes all together. 😉
FWIW, I'm currently preparing an updated data version which should help with properly setting service intervals etc. on several more models of this platform.
One might think that VW did this because they expected the duty cycle on on the engine to be quite low, as in the equivalent of just short trips in a pure ICE car, with the oil rarely getting fully warmed up.
Eric
HC800000
