Piston did not wind in far enough for Retracting the Brakes (Service Mode)
Timbob
Taos, NM, USA
C?ID=661160
Open VCDS and click Select Control Module.Choose module 03 - ABS Brakes (on 2014 Audi Allroad a4, trying to replace pads, its in that service mode but the caliper looks extended....er, now what?
And the motor back there did run and then stop on its own.
Eric
HC800000
Autoscan please. It will likely show that you need to go to address 53 instead, on this platform.
You have used a piston wind back tool as well? It engages in the slots.
Note time beginning at 2:42 - 3:31
The push back piston method only applies to ATE calipers, not the TRW type used in the subject vehicle. If you wind back ATE calipers, it destroys the internals.
Also, if you try and push back a TRW caliper, it won’t move.
Timbob
Taos, NM, USA
C?ID=661160
Oy, well, I didn't think to know there were "special" procedures for EPB, I could loosen up the pads so thought, its ready to change em, when I took the caliper off, no problem but then it would not move to wider for the new pads....so then I see there is a control in vcds to move it to servicing, so I just found it and pushed the button....So, not sure what to do next....unbolt the motor driver for the piston and just get it back on? Only one side is off at the moment. This is in the USA, not a euro version.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Timbob
Taos, NM, USA
C?ID=661160
Basically want to get'er done, on this side....THEN folllow the best practices for the next side...without munging the EPBmotor/controller as I get the side I started back together...now that I know.
Viking
C?ID=151455
Well then, post an Autoscan, so people know exactly what your current situation is. All we know at present is that you might have some brakes or you might not...
Timbob
Taos, NM, USA
C?ID=661160
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 10000000345210
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2AD320DCD6FB8AC17-806F
66560 - Right Parking Brake Motor; Holding Force Not Attained
          C1009 00 [10001001] - -
                    Reset counter: 144
                    Mileage: 169841 km
                    Date: 2026.08.22
                    Time: 17:52:54
                    Voltage terminal 30: 12.1 V
                    Internal Fault ID: 3
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: applied
                    Status ParkingBrake right: is closed
71168 - Right Parking Brake Motor Voltage Supply
          C100E 13 [00001000] - Electrical Malfunction
                    Reset counter: 144
                    Mileage: 169841 km
                    Voltage terminal 30: 12.5 V
                    Internal Fault ID: 27
                    Yellow warning lamp: On
                    Terminal 15 status: OFF
                    RWU: not active
                    DSD: not active
                    HTR: active
                    ECD: not active
                    Internal Parking Brake state: No enabling
                    Status ParkingBrake right: applied
Timbob
Taos, NM, USA
C?ID=661160
At this point I have the other wheel off, the brake is holding the pads fast (Ithink), SO, I'll take off the motor driving the left hand brake, manually unwind the brake, counting the winds as I didn't do that on the other side which I think I'll have to jack up again too, with both jacked, and wheels off I'll then try and sort out the EPB...after I change the pads on the left. I did plug in the car for charging. These are TRW motors and I did wind the right side all the way clockwise before I reattached the motor....no buttons have been pushed since the earlier episode and I shut it all down yesterday with it in the line maintenance mode that I had enabled in the PBR control panel.
Ga!
Viking
C?ID=151455
Now at work I can check and elsaWin says that caliper is push back
