- Jun 4, 2021
- 46
- 7
- Ottawa, Canada
- C?ID=395028
I remember, when test driving the 2019 DSG Mk7.5 Golf R, when Auto-hold was on and engaged, there was an indicator in the cluster to signify that the car was currently being held.
On my Manual 2019 Golf R, there is no such indicator, even though it also has Auto-hold.
This indicator was separate from the light on the button itself that just shows if Auto-hold was on or off, and only illuminated when the brakes were being held by the system.
Is it possible to turn that indicator on in a car that has a manual transmission?
If you do a "chauffeur stop", auto hold often won't engage, unless you press the brake firmly when fully stopped. It would be really nice to see an indication on the instrument cluster for confirmation.
(Attached is the icon on an Audi, plus this link to the owners manual of the Golf referencing it I recall it being the green foot on the brake icon though, but either is fine for me, I just want some indicator that it's actually holding)
Thanks in advanced!
Obligatory Auto Scan:
Thanks in advanced!
VCDS Mobile 0.4623.0.4
VCDS Mobile: 0.4623
Data Version: 30000060
VIN: WVWWA7AU8KW205454
Scan: 01 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F A5 A9 D6 D7
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (DLRA J623) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0002
Revision: --H13---
Coding: 091900122446000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
ROD: EV_ECM20TFS0208V0906259Q.rod
VCID: 4EDFFD3BD773AD97811D52-801B
14846 - Turbocharger Boost Control Position Sensor Circuit
P2563 00 [167] - Implausible Signal
22008 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [032] -
Address 03: ABS Brakes (J104) Labels:
Part No SW: 5Q0 614 517 DS HW: 5Q0 614 517 BN
Component: ESC H35 0108
Revision: 00000000
Coding: 01FA6BA150200971457B030560C76980D60A90A2C0069637344050D4D0A84B0B0000000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 854D8217C2852ECFF027B5-80D0
No fault codes found.
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000
Coding: 132C0C0623
ASAM Dataset: EV_KessyHellaMQBAB 004046
ROD: EV_KessyHellaMQBAB_004.rod
VCID: 43C9DC0F0C3150FF1EB3EB-8016
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] -
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010001010500000010102A
VCID: 6D9D5AB77A35768F9857BD-8038
Subsystem 1 -
Subsystem 2 -
Subsystem 3 -
B10CD 00 [008] - -
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
ROD: EV_BCMMQB_019.rod
VCID: 8B59B42FE4E158BFA663F3-80DE
Subsystem 1 - Part No SW: 5G1-955-119-A Labels: 5Qx-955-119-V1.clb
Component: WWS 190417043 0551
Serial Number: 190429163415
Subsystem 2 - Part No SW: 5Q0-955-547-C Labels: 5Q0-955-547.clb
Component: RLHS 051 0205
Serial Number: S5Y19M05D17H20M32S49
Coding: 0008DD
Subsystem 3 - Part No SW: 5Q1-953-507-M
Component: J527 SMLS MQB004 0070
Serial Number: 00000004051904220962
934149 - Rain/light recognition sensor
B1366 76 [008] - Wrong mounting position
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 Kanal
Coding: 0471155801
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CDBF733216F9F87EFE948-8019
Address 13: Auto Dist. Reg (J428) Labels: 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 2B0000C159FFC728949C810560400600000000000000000004
VCID: 44CBDF13093F57C727B9E0-8011
2137 - Databus
2092 - Databus
1236 - Databus
1113 - Databus
2068 - Databus
2190 - Databus
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Shop #: WSC 00000 000
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3833BBE345F70327BB2164-806D
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
VCID: 47D1C81F38097CDFC2DB1F-8012
Subsystem 1 - Part No SW: 4M0-959-339-B
Component: BF-Gewichtss.H13 0022
Serial Number: IBH00000000000BJMD6V
Coding: 303344
Subsystem 2 - Part No SW: --------------
Component: SideSensor_Df001 0887
Serial Number: 3570000000044B355C3J
Subsystem 3 - Part No SW: --------------
Component: SideSensor_Pf001 0887
Serial Number: 358000000006DAD47C3+
Subsystem 4 - Part No SW: --------------
Component: SideSensor_Dr005 6149
Serial Number: 3510001C0EFE786663CR
Subsystem 5 - Part No SW: --------------
Component: SideSensor_Pr005 6149
Serial Number: 3520001B6EFE7866E45Z
Subsystem 6 - Part No SW: --------------
Component: FrontSensor_D005 6149
Serial Number: 3550001C2F001355979$
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 403 4191
Coding: 0BAD30177F8C880902887B0B5401000080000000
VCID: 2B1994AF84A1B8BFC6A3D3-807E
16776960 - ROD - Unknown faultcode
16776969 - ROD - Unknown faultcode
Address 19: CAN Gateway (J533) Labels: 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: --------
Coding: 0101000838085900FB00823A880F00000001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E9F5DBB77338D97A15DB2-803B
Subsystem 1 - Component: 0-00-00-00-00
Subsystem 2 - Part No SW: 5G0-959-442-AE Labels: 3C8-959-537.clb
Component: E221__MFL-DC1H12 0052
Serial Number: 29190000869200089157
Coding: 2CFFFF
65794 - Data Bus for Suspension
U10AE 00 [008] - 1-Wire Mode
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevo
0033 - Supply voltage
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 312586C7A68DD26FFCFF11-8064
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ROD: EV_LCMRightHELLAAU736_VW37.rod
Address 3C: Lane Change (J1086) Labels: 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Coding: 02011103
ROD: EV_HREntryHella.rod
VCID: 3D3DAAF76AD5260F6877AD-8068
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS
Coding: 003E13208000040000000000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 910A0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C3BA7F371CF2F075F4998-8069
21760 - Databus
Address 47: Sound System (J525) Labels: 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E1F9DBBB7B3CD97E1DDF2-807B
Address 4B: Multifunc. Module (J745) Labels: 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Coding: 000000050900161206710F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002.rod
VCID: 352DB2D752E5FE4FA00745-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Coding: 027310020000000041220002001828001F0507F401200405C6
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 33298CCF5C91E07F8E133B-8066
Subsystem 1 - Part No SW: 5G6-919-605-D
Component: ABT_Std-2_NavH60 8214
Serial Number: VWZ6ZJW1353581
Subsystem 2 - Part No SW: 5NA-919-866-E
Component: NAR 2018/19 --- 0810
Serial Number: --------------------
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Address A5: Frt Sens. Drv. Assist (R242) Labels: 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0610
Coding: 0003070000000201002213548150890094000E20012000
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40C3D3031D274BE70391CC-8015
1123202 - Databus
4195331 - ROD - Unknown faultcode
001275 - 001275 - Unknown faultcode
Address A9: Struct. Borne Sound (J869) Labels: 5G-a9.lbl
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
VCID: 2F2180BFB0B9C49FEACB07-807A
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 3935BEE77EFD1A2F442F79-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxR_KEBODAVW481_VW37.rod
End--(Elapsed Time: 02:52, VBatt start/end: 14.4/14.4 Vign: 14.5)-
I'd much rather waste it roasting the tires on the launch I'll do the moment the light turns green.
