Vehicle Identification No. WVWVE7CD5TW271426
Model golf 2.0
GO
Date of production 30.05.2026
Year 2026
Sales type DA19UZ
Engine Code DZMA
Transmission Code WJY
Model golf 2.0
GO
Year 2026
Sales type DA19UZ
Engine Code DZMA
Wednesday,19,August,2026,10:52:10:58926
VCDS Version: 26.7.2.1 (x64) HEX-NET2 CB: 0.4716.5
Data version: 20260708 DS378.0
VIN: WVWVE7CD5TW271426 License Plate:
Chassis Type: CD-VW38P PA* (5QS)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 23 2B 32 36 42 44 47 4B
52 5F 6C 75 82 A5 A9 CA D6 D7 8109 810A 810B 810C C002 C003
VIN: WVWVE7CD5TW271426 Mileage: 24km-14miles
CA-Sunroof -- Status: OK 0000
8109-Close Rge Radar 1 -- Status: OK 0000
810A-Close Rge Radar 2 -- Status: OK 0000
810B-Close Rge Radar 3 -- Status: Malfunction 0010
810C-Close Rge Radar 4 -- Status: Malfunction 0010
Address 01: Engine (J623-DZMA) Labels: None
Part No SW: 5WA 906 264 C HW: 06K 907 425 AA
Component: R4 2.0l TFS H80 0001
Dataset Number: 06Q909102DP 0001 CVN: 330002870C94DFB4
Coding: 092500322364090E30000000000000000000000000000000
ASAM Dataset: EV_ECM20TFS0205WA906264C 001001
ROD: EV_ECM20TFS0205WA906264C.rod
VCID: 4BC8093A734B72B27B0-801E-R SFD+SFD2 [x]
VINID: 9E69E65474D41649C21C110218AB9B8A29
31949 - Front Camera for Driver Assist Systems
U1229 00 [00101000] - Implausible Message
[Front camera for driver assistance systems implausible]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:49
Engine speed: 808.75 /min
Normed load value: 20.4 %
Coolant temperature: 62 °C
Intake air temperature: 35 °C
Voltage terminal 30: 13.066 V
LF_MVB_PDU_INTC_DIAG_8: 0
LF_MVB_PDU_INTC_DIAG_9: 0
LF_MVB_PDU_INTC_DIAG_10: 0
LF_MVB_PDU_INTC_DIAG_11: 8192
LF_MVB_PDU_INTC_DIAG_13: 16
LF_MVB_BUS_INTC_DIAG: 256
38468 - Implausible Data Received from ESP Control Module
U0416 00 [00101000] - -
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:37
Engine speed: 1511.25 /min
Normed load value: 41.2 %
Coolant temperature: 60 °C
Intake air temperature: 34 °C
Voltage terminal 30: 11.777 V
Engine status: Deceleration
ECU_STATE: SYN_ENG_IGK_ON
ACC variants (coding): ACC with braking until at standstill/Stop & Go
Drivetrain coordinator: brake fault status-ESP system malfunction: No
Readiness: 0010 0101
Part No SW: 0GC 906 557 QL HW: 0GC 300 028
Component: GSG DQ381 H06 0860
CVN: 24943602
ASAM Dataset: EV_TCMDQ381064 001012
ROD: EV_TCMDQ381064.rod
VCID: 1760A54A7F03C6520F8-8042-R SFD [x]
Parking lock:
Subsystem 1 - Part No SW: 5WA 907 484 A HW: 5WA 907 484
Component: ZSB_SB_AUTO H03 1092
Serial number: 00000000000103401725
Selector lever:
Subsystem 2 - Part No SW: 5H0 713 059 T HW: 5H0 713 059 T
Component: ZSB_SB_Mono H01 0014
Serial number: 92478AEE01639
MTF pump:
Subsystem 3 - Part No SW: 0GC 927 373 M HW: 0GC 927 373 M
Component: SMOP DQ381 H04 0001
Serial number: C7458810700008681119
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5WA 614 517 EA HW: 5WA 614 517 BS
Component: ESC H31 0339
Serial number: 61046000001874 Dataset Number: V03935500YP 0001 CVN: 6311693771E35BB0
Coding: 4D28956CA04A359C000355AC9E0401C50ACF75345CA000
ASAM Dataset: EV_Brake1ESCMQB37WUNECE 006026
ROD: EV_Brake1ESCMQB37WUNECE_006_VW38P.rod
VCID: 0B48C93A33CB32B2BB0-805E-R SFD+SFD2 [x]
8796 - Implausible Data Received from Suspension Control Module
U042B 00 [00101000] - -
[CCan_DR_Funktionsstatus_inv]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:38
Vehlicle_speed: 0.0 km/h
Resolution Mileage: 750 m
Voltage_value_KL.30_ESC_V: 12.0 V
Wake up EPB: not active
Wake up CAN: not active
Postrun_activ: not active
Comparison_pressure_sensor: completed successfully
Comparison_longitudinal_accleration: completed successfully
Comparison_transverse_accleration: not completed successfully
Comparison_yaw_rate_sensor: not completed successfully
LWS_comparison: not completed successfully
Internal_failure_code: 00 38
00 42 00 00 04 08 10 08 80 00 00 00 80 00 00 48 30 00 21 00 04
0257 - Sensor Module for Yaw Rate
C136D F4 [01100000] - Offset
[Offset_Yaw_rate_sens]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:06
Voltage_value_KL.30_ESC_V: 12.2 V
Internal_failure_code: 02 7B
00 00 00 00 04 08 10 08 80 00 00 00 80 00 00 48 00 00 21 00 04
C1146 02 [00101000] - Signal Failure
[RKA+: missing input signal(s)]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:46
Voltage_value_KL.30_ESC_V: 13.0 V
Internal_failure_code: 02 88
00 42 00 00 04 08 10 08 80 00 00 00 80 00 00 40 30 00 21 00 04
Address 05: Acc/Start Auth. (J518) Labels: 5WA-959-436.clb
Part No SW: 5WA 959 436 AD HW: 5WA 959 436 N
Component: Kessy IOBOX 122 0771
Serial number: --------------- Dataset Number: V03935428XR 0001
ASAM Dataset: EV_Kessy37w 005030
ROD: EV_Kessy37w_005_VW38.rod
VCID: 167EA84E7809FF5A14E-8042-R
Address 08: Auto HVAC (J979) Labels:* Redir Fail!
Part No SW: 3WA 907 007 F HW: 3WA 907 007
Component: Climatronic H01 5089
Serial number: 223022610471260 Dataset Number: V03935478AH 0001
Coding: 002000010011020011101010101111110000132100200100000000001000
ASAM Dataset: EV_ACClimaBHBE3ADV 002062
ROD: EV_ACClimaBHBE3ADV_002_VW41.rod
VCID: 48C23636623D99AA562-801C-R SFD+SFD2 [x]
Interior temperature sensor:
Subsystem 1 - Part No SW: 5WA 907 527 A HW: 5WA 907 527 A
Component: E857 H01 0103
Serial number: 00003260426012743505
Subsystem 2 - Part No SW: 3G0 963 345 C HW: 3G0 963 345 C
Component: SysNameFanLin 016 0103
Serial number: ESEYSKC0488614
Subsystem 3 - Part No SW: 3G0 963 345 D HW: 3G0 963 345 D
Serial number: ESEYSKD0471478
Subsystem 4 - Part No SW: 3G0 963 345 C HW: 3G0 963 345 C
Serial number: ESEYSKC0488379
Subsystem 5 - Part No SW: 3G0 963 345 D HW: 3G0 963 345 D
Serial number: ESEYSKD0471475
Subsystem 6 - Part No SW: 11A 907 049 B HW: 11A 907 049 B
Component: E265 KPH SH H02 0184
Serial number: G09S02.02.2600971475
Address 09: Cent. Elect. (J519) Labels: 5WA-937-08X-V1.clb
Part No SW: 5WA 937 086 CD HW: 5WA 937 086 BJ
Component: BCM37w_M238 0517
Serial number: BXJ53F120526940 Dataset Number: V03935476BD 0001
ASAM Dataset: EV_BCMwBL 005001
ROD: EV_BCMwBL_005.rod
VCID: 157CAF42650FF4421D4-8040-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 5H1 955 119 B HW: 5H1 955 119
Component: FWISCHER_MYJT 003 0061
Serial number: 900K53F0302609902394
Subsystem 2 - Part No SW: 89A 955 555 B HW: 89A 955 555 B
Component: G397_RLFSS 004 0007
Serial number: TTZ53507032600024298
Subsystem 3 - Part No SW: 5H0 941 193 AP HW: 5H0 941 193 AP
Component: LiSi H06 0008
Serial number: 92471ADH0016W
Subsystem 4 - Part No SW: 5H0 925 200 R HW: 5H0 925 200 R
Component: DiETa H07 0008
Serial number: 92471AEE00081
Subsystem 5 - Part No SW: 5H0 959 561 CK HW: 5H0 959 561 CK
Component: -VW----LINDA- 505 0835
Serial number: MW3LND23042600013010
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 GA HW: 5Q1 953 549 F
Component: J527 SMLS MQB 005 0080
Serial number: 00000004052608490394
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 5QS 919 300 H HW: 5QS 919 300
Component: IPA 12ch high H01 0343
Serial number: 000021052695580 Dataset Number: V03935483ZT 0001
Coding: 8210026011
ASAM Dataset: EV_EPHBO3CVW3360000 001014
ROD: EV_EPHBO3CVW3360000_VW42.rod
VCID: 57E0E54ABF830652CF8-8002-R
7 Faults Found:
1080304 - Parking Sensor(s); Rear
B107B F0 [00100000] - Function Limitation due to External Factors
1113328 - Parking Sensor(s); Front
B10FC F0 [00100000] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
12587097 - Databus
U1123 00 [00100000] - Received Error Message
12587100 - Control Module
U110F 00 [00100000] - I'm sorry Dave; I'm afraid I can't do that!
[Funktion Schaltbetätigungsmaster im Motorsteuergerät für Park Assist im Fehler]
12587195 - Databus
U1123 00 [01100000] - Received Error Message
[Bremsensteuergerät - VMM_02_Auth.VMM_Notstopp_Status - Fehlerspeicher auslesen]
12587196 - Databus
[Bremsensteuergerät - VMM_02_Auth.VZM_Systemstatus - Fehlerspeicher auslesen]
13238282 - Parking Aid
B1836 F3 [00100000] - Function Cancelled
[Einparkhilfe Funktionsabbruch]
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1N3 907 567 E HW: 1N3 907 819 A
Component: ACC Bosch MQB H03 0550
Dataset Number: V03935474BA 0001
Coding: 0E2920EE4071C0404002000000004000000020008006000000000000000000
ASAM Dataset: EV_FRONTRADARBOSCHVW412 002017
ROD: EV_FRONTRADARBOSCHVW412_002_VW41.rod
VCID: 392443F229D7F022D9C-806C-R SFD+SFD2 [x]
21 Faults Found:
0322 - Databus
U1122 00 [00101110] - Implausible Message
[FAULT_SWA_MODE_SYSTEM_NOT_AVAILABLE]
Mileage: 23 km
Date: 2026.08.10
Time: 12:53:36
Outside temperature: 23.00 °C
Control Module temperature: 28 °C
Voltage terminal 30: 11.7 V
Vehicle speed: -0.00 m/s
Longitudinal acceleration: -0.00 m/s²
Adaptive distance regulation: status: initialized
kilometer reading: 23 km
Monitoring_debug_information: 00 00 00 00 00 00 00 00
Event_Id: 02 36
0577 - Databus
U1123 00 [00101000] - Received Error Message
[FAULT_VZM_SYSTEM_STATUS_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:26:37
Outside temperature: 25.00 °C
Control Module temperature: 42 °C
Voltage terminal 30: 13.4 V
Vehicle speed: 4.30 m/s
Longitudinal acceleration: 1.00 m/s²
Adaptive distance regulation: status: Reversible error
kilometer reading: 17 km
Event_Id: 02 57
1842 - Databus
U1122 00 [00101000] - Implausible Message
[FAULT_RB_MFK_BLINDNESS_ODACC]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Outside temperature: 26.00 °C
Control Module temperature: 36 °C
Voltage terminal 30: 13.0 V
Adaptive distance regulation: status: Readiness
Event_Id: 02 05
1848 - Databus
[FAULT_RB_MFK_LDA_INIT]
Mileage: 17 km
Date: 2026.07.27
Time: 09:26:36
Control Module temperature: 41 °C
Vehicle speed: 3.73 m/s
Longitudinal acceleration: 1.21 m/s²
Event_Id: 02 08
1858 - Databus
[FAULT_RB_MFK_OD_FAILURE]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 0D
1859 - Databus
[FAULT_RB_MFK_PED_FAILURE]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 16
1860 - Databus
[FAULT_RB_MFK_LDA_FAILURE]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 07
1862 - Databus
[FAULT_RB_CAL_FC1_POSXKONSTRKS_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 01 DE
1864 - Databus
[FAULT_RB_CAL_FC1_POSYKONSTRKS_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 01 E0
1865 - Databus
[FAULT_RB_CAL_FC1_POSZKONSTRKS_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 01 E2
1877 - Databus
[FAULT_RB_MFK_OD_TIMESTAMP_INVALID]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 10
1878 - Databus
[FAULT_RB_CAL_FC1_STATUS_ERROR_OOR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 01 E5
1880 - Databus
[FAULT_RB_MFK_PD_TIMESTAMP_INVALID]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 13
1883 - Databus
[FAULT_RB_MFK_LDA_TIMESTAMP_INVALID]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 0A
1884 - Databus
[FAULT_RB_MFK_BLINDNESS_OD_PED]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 06
1885 - Databus
U1122 00 [00100000] - Implausible Message
[FAULT_RB_MFK_BLINDNESS_LDA]
1886 - Databus
[FAULT_RB_BHE_FC1_STATUS_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 01 DC
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:38
Control Module temperature: 34 °C
Voltage terminal 30: 11.8 V
Event_Id: 01 A0
2261 - Databus
[FAULT_RB_MFK_OD_TIMESTAMP_NOT_PLAUSIBLE]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 11
2262 - Databus
[FAULT_RB_MFK_PD_TIMESTAMP_NOT_PLAUSIBLE]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 14
2263 - Databus
[FAULT_RB_MFK_LDA_TIMESTAMP_NOT_PLAUSIBLE]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
Event_Id: 02 0B
Address 14: Susp. Elect. (J250) Labels: 1EA-907-376.clb
Part No SW: 3WA 907 376 E HW: 3WA 907 376 E
Component: DAEMPFUNGS-SG H10 0508
Serial number: 2C7752680813032 Dataset Number: V03935421JX 0001
ASAM Dataset: EV_DCC3CONTITEMIC 003014
ROD: EV_DCC3CONTITEMIC.rod
VCID: 50F21E569A6D516A0E2-8004-R
9437187 - Inconsistent Configuration Detected
B17D8 00 [00101000] - -
[mFDR_Aktiv_Cfg_Error]
Mileage: 7 km
Date: 2026.07.24
Time: 16:28:21
00
KL15_Status: 00
NM State: 00
Last Valid Value of Signal: 00 00
Raw Signal Value: 00 00
9437191 - Databus
[MFDR_Kurfenrichtung_error_value_received]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:38
01
KL15_Status: 01
NM State: 01
Last Valid Value of Signal: 01 00
Raw Signal Value: 01 00
Address 15: Airbags (J234) Labels:| 5QS-959-655.clb
Part No SW: 5QS 959 655 AF HW: 5QS 959 655 AF
Component: AirbagVW50 010 0251
Serial number: 000000003C0UDRG Dataset Number: V03935483SB 0001
Coding: 8CCC000000FCC00000000000000000005100000081000000800036F8001300A7
ASAM Dataset: EV_AirbaVW50SMEVW49X 001062
ROD: EV_AirbaVW50SMEVW49X.rod
VCID: 2700958ACF6376D2BF8-8072-R SFD+SFD2 [x]
Component: BF-Gewichtss. H17 0022
Serial number: IBH0000D26000QMJCZ00
Subsystem 2 - Part No SW: ----------- HW: 480 001 204 1A
Serial number: 35700000088D4F7E5F70
Subsystem 3 - Part No SW: ----------- HW: 480 001 204 1A
Serial number: 35800001E78953306110
Subsystem 4 - Part No SW: ----------- HW: 480 051 205 1A
Component: SideSensor_Dr 000 0149
Serial number: 3510000B8FECB0CCA770
Subsystem 5 - Part No SW: ----------- HW: 480 051 405 1A
Component: SideSensor_Pr 000 0149
Serial number: 3520000C0FED3C1108F0
Subsystem 6 - Part No SW: ----------- HW: 480 050 305 1A
Component: FrontSensor_D 000 014A
Serial number: 3550000B4FED4F4A89F0
Subsystem 7 - Part No SW: ----------- HW: 480 050 305 1A
Component: FrontSensor_P 000 014A
Serial number: 3560000B4FED4F4CC250
Address 17: Instruments (J285) Labels:| 5H0-920-KOM-V1.clb-SRI2
Part No SW: 5H0 920 340 F HW: 5H0 920 340 F
Component: KOMBI 501 3365
Dataset Number: V03935467KE 0001
Coding: 083C04427B9CCF850280620B2000030830307C0000
ASAM Dataset: EV_DashBoardVDDMQB37W 006052
ROD: EV_DashBoardVDDMQB37W_006_VW38.rod
VCID: 251C9F82B56F64C28D4-8070-R SFD [x]
8667138 - Distance
U197A 00 [00001000] - Plausibility Check
[Wegstrecke Plausibilisierung ist fehlerhaft]
Mileage: 7 km
Date: 2026.07.24
Time: 16:28:19
Part No SW: 5QS 907 530 K HW: 5QS 907 530
Component: GW MQB 23 005 2097
Serial number: SMERBG130526007 Dataset Number: V03935493ZU 0001
Coding: 000000000000000000000000000000000000000000000301030000000000000000000000000000000000000000000000
GVL: 3D4800000228409C804080C2CC00104004404002007800000200000000000044
ASAM Dataset: EV_GatewMQBwBL 001027
ROD: EV_GatewMQBwBL_VW41.rod
VCID: 5CEAFA66C6A5E50AE2A-8008 SFD+SFD2 [x]
Generator:
Component: 5-00-17-01-03
Subsystem 2 - Part No SW: 5QS 915 181 HW: 5QS 915 181
Component: J367-BDMHella H01 2362
Serial number: 8851778406
Subsystem 3 - Part No SW: 571 959 442 C HW: 571 959 442 C
Component: E221__MFL-8TH H07 0130
Serial number: 8TH-0070066066261911
Subsystem 4 - Part No SW: 5H0 959 542 AD HW: 5H0 959 542 AD
089 0023
Address 23: Brake Booster (J539) Labels: None
Part No SW: 5WA 909 059 AH HW: 3Q0 909 059 D
Component: EBKV H10 0563
Serial number: BPA085110526013 Dataset Number: V03935479DT 0001
Coding: 5003C5009F00000080BDF7DE000049922449922400
ASAM Dataset: EV_BrakeBoostVW37WUNECE 013005
ROD: EV_BrakeBoostVW37WUNECE_013.rod
VCID: 167EA84E7809FF5A14E-8042-R SFD+SFD2 [x]
Address 2B: Steer. Col. Lock (J764) Labels:. 3WA-905-861.clb
Part No SW: 3WA 905 861 A HW: 3WA 905 861
Component: ELV-MQB_UNECE H05 0071
Serial number: 26000111205006- Dataset Number: V03935459HN 0001
Coding: 8820000000000000
ASAM Dataset: EV_ELVMarqUNECE 004001
ROD: EV_ELVMarqUNECE_004_VW27.rod
VCID: 49C43332793760A249C-801C-R SFD+SFD2 [x]
Address 32: Differential Locks (J647) Labels:* None
Part No SW: 5WA 907 554 Q HW: 5WA 525 130
Component: Quersperre H66 3020
Serial number: 000008.04.26000 Dataset Number: V03935343VH 0001
Coding: 0001
ASAM Dataset: EV_VAQMQB37WPA 001001
ROD: EV_VAQMQB37WPA.rod
VCID: 5CEAFA66C6A5E50AE2A-8008-R
Part No SW: 3QH 959 760 H HW: 3QH 959 760 H
Component: MEM-FS 011 0374
Serial number: 2650101KA06000 Dataset Number: V03935481FN 0001
Coding: 01589A400000B0408803010101010000000000212100000000000000215000
ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
VCID: 58E2E676B29D092AC62-800C-R
Part No SW: 3WA 959 593 A HW: 3WA 959 593
Component: TSG FS 001 0222
Serial number: Y3007ZDS01JEB Dataset Number: V03935478XZ 0001
Coding: 003B1320D200000001400010
ASAM Dataset: EV_DCU4DriveSideMAXHKLO 001016
ROD: EV_DCU4DriveSideMAXHBRO_VW42.rod
VCID: 54FA1246AE752D4A2AA-8000-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 5Q0 959 408 G HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000103048483
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V2.clb
Part No SW: 3WA 907 145 E HW: 3WA 907 145
Component: BASGEN1MQB37 504 1122
Serial number: 05901851 Dataset Number: V03935476UT 0001
Coding: 00000000000000010001020101000100000001010101
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37_017.rod
VCID: 4AC60C3E7C316BBA406-801E-R SFD+SFD2 [x]
Part No SW: 5H0 035 456 G HW: 5H0 035 456 G
Component: AMPeth12CDoIP H06 4352
Serial number: A1129P00243456 Dataset Number: V03935452L 0001
Coding: 23000000000000000000000000000000000000000000000000
ASAM Dataset: EV_AMPEthMQB37w 001005
ROD: EV_AMPEthMQB37w_VW38.rod
VCID: 2B0869BAD38B52B25B0-807E-R SFD [x]
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 5QS 907 338 E HW: 5QS 907 338 B
Component: FCM Baseline 019 4010
Serial number: 780542040026139 Dataset Number: V03935467CX 0001
Coding: 000000000900074A06110311040003000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiWBL 001008
ROD: EV_MultiModulContiWBL.rod
VCID: 5CEAFA66C6A5E50AE2A-8008-R SFD [x]
Part No SW: 3WA 959 592 A HW: 3WA 959 592
Component: TSG BFS 001 0222
Serial number: Y3007ZE4001SE Dataset Number: V03935478YB 0001
Coding: 003B1320DE00000001400010
ASAM Dataset: EV_DCU4PasseSideMAXHKLO 001016
ROD: EV_DCU4PasseSideMAXHKLO_VW41.rod
VCID: 53F8115AAB7B2A72330-8006-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 5Q0 959 407 G HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000103074822
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 571 035 877 A HW: 571 035 877
Component: MU-O-NS-US H11 2756
Serial number: WG8LGM050526004 Dataset Number: V03935479BU 0001
Coding: 23800006000220000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB37w 002001
ROD: EV_MUOIMQB37w_002_VW38P.rod
VCID: 1C6ABA668625A50A22A-8048-R SFD+SFD2 [x]
Subsystem 1 - Part No SW: 14A 919 605 N HW: 14A 919 605
Component: ABT-E3_13 H50 4047
Serial number: CKS00729042611553502
Subsystem 2 - Part No: V03 959 822 LG
Component: NAR 2025/26 3129
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 G HW: 5WA 980 556 C
Component: RV eCompact H52 0604
Serial number: FCLK20090426010 Dataset Number: V03935437YN 0001
Coding: 0203401026140000
ASAM Dataset: EV_CamSysRVCeCFicosBL 003010
ROD: EV_CamSysRVCeCFicosBL.rod
VCID: 55FCEF42A58F3442DD4-8000-R
Part No SW: 571 035 285 B HW: 571 035 285
Component: OCUMQBW2023_H H09 0672
Serial number: 0000000601VIBBG Dataset Number: V03935503QH 0001
Coding: 02020601000000211000010013002E07101112111012011110
ASAM Dataset: EV_OCUMWB2023 001072
ROD: EV_OCUMWB2023_VW42.rod
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 5H1 919 617 B HW: 5H1 919 617 B
Component: HeadupDisplay H02 2529
Dataset Number: V03935421FP 0001
Coding: 5700A000
ASAM Dataset: EV_HUDMQBwBL 002013
ROD: EV_HUDMQBwBL_002.rod
VCID: 31347BD2F1A7386261C-8064-R SFD+SFD2 [x]
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 3WA 907 217 F HW: 3WA 907 217
Component: MFK120_MQB H18 1550
Dataset Number: V03935484P 0001
Coding: 00070000000000000000009AF940E00600000000204000000000FE0000002BDE43F240748000000000800000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK120MAGNAMQBWB 005004
ROD: EV_MFK120MAGNAMQBWB_005_VW41.rod
9 Faults Found:
221210 - Internal Fault
B200F FE [00101000] - -
[Calibration_internal_fault]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:49
1049429 - Data Fusion for Driver Assistance Systems Service
U198B 00 [00101000] - Received Malfunction Value
[Service_AdasFusedObjectsSmall_Front_Radar_Error]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
3145746 - Databus
[ACC_Status_ACC_reversibel_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:52
3145750 - Databus
[ESP_Systemstatus_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:41
3145772 - Databus
[VZM_Warnruckeln_nicht_verfuegbar_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:26:37
1049218 - Internal Fault
B200F F3 [00101000] - -
[LDA_FC1_Status_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:49
1049857 - Internal Fault
[BHE_FC1_Status_ERROR]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:49
1049858 - Data Fusion for Driver Assistance Systems Service
[Service_AdasFusedObjectsSmall_MFK_OD_Error]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:51
1049859 - Data Fusion for Driver Assistance Systems Service
[Service_AdasFusedObjectsSmall_MFK_PED_Error]
Mileage: 17 km
Date: 2026.07.27
Time: 09:23:51
Part No SW: 5H0 907 159 H HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 260327291200
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
VCID: 343A72C60EB50D4A0AA-8060-R
Part No SW: 8Y1 907 594 AB HW: 4K1 907 594
Component: SAD_STG_1 010 0010
Dataset Number: V03935439DB 0001
Coding: 008000738001
VCID: 0740F50A2FA356D29F8-8052-R
Part No SW: 992 941 572 AK HW: 992 941 572 A
Component: LED1L H35 9204
ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
VCID: 6C8AAAA61605958A12A-8038-R
Component: LED1R H35 9204
ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
Address 8109: Close Rge Radar 1 (J1088) Labels:* None
Part No SW: 3WA 907 541 F HW: 95C 907 541
Component: Nanoradar 1 H08 0162
Serial number: 36306010692430 Dataset Number: V03935488SG 0001
Coding: 55555E1529C405000000
ASAM Dataset: EV_NR1HELLAVW38X 002116
ROD: EV_NR1HELLAVW38X_001_VWE3.rod
Address 810A: Close Rge Radar 2 (J1089) Labels:* None
Component: Nanoradar 2 H08 0162
Serial number: 36306010692392 Dataset Number: V03935488TJ 0001
ASAM Dataset: EV_NR2HELLAVW38X 002116
ROD: EV_NR2HELLAVW38X_001_VWE3.rod
Address 810B: Close Rge Radar 3 (J770) Labels:* None
Part No SW: 3WA 907 670 F HW: 95C 907 550
Component: Nanoradar 3 H09 0162
Serial number: 10140140777487 Dataset Number: V03935488TT 0001
ASAM Dataset: EV_NR3HELLAVW38X 002116
ROD: EV_NR3HELLAVW38X_001_VWE3.rod
VCID: 4ECE002E8059479A1CE-801A-R SFD+SFD2 [x]
12582983 - No Basic Setting
B2010 00 [00101110] - -
[No_basic_setting]
Fault Frequency: 83
Address 810C: Close Rge Radar 4 (J769) Labels:* None
Component: Nanoradar 4 H09 0162
Serial number: 10140140764770 Dataset Number: V03935488UG 0001
Coding: 55696E1631C40A000000
ASAM Dataset: EV_NR4HELLAVW38X 002116
ROD: EV_NR4HELLAVW38X_001_VWE3.rod
[No_basic_setting]
Fault Frequency: 83
15859797 - Databus
[error_value_APSOPS_PaCo_MainState_FASCANFD2]
Mileage: 17 km
Date: 2026.07.27
Time: 09:26:16
15859837 - Databus
[error_value_VZM_Systemstatus_FASCANFD_FASCANFD2]
Mileage: 17 km
Date: 2026.07.27
Time: 09:26:37
End----------(Elapsed Time: 02:47, VBatt start/end: 12.3V/12.2V)-----------
------------------------------49 Faults Found------------------------------
