Vehicle Identification No. 3VW1T7BU7SM057846
Model jetta 2.0
JEM
Date of production 05.02.2025
Year 2025
Sales type BU59V2
Engine Code DXSA
Transmission Code ULQ
AutoScan: 3VW1T7BU7SM057846
Wednesday,19,August,2026,10:32:34:58926
VCDS Version: 26.7.2.1 (x64) HEX-NET2 CB: 0.4716.5
Data version: 20260708 DS378.0
VIN: 3VW1T7BU7SM057846 License Plate:
Chassis Type: BU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 14 15 17 19 32 36 3C 42 44 4B 52 5F 75 A5
A9 BB BC CA
VIN: 3VW1T7BU7SM057846 Mileage: 11476km-7130miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DXSA) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 AK HW: 06K 907 425 J
Component: R4 2.0l TFS H13 0002
Revision: --H13--- CVN: A60B2D42
Coding: 091900122444002F3000
Shop #: WSC 00066 790 00541
ASAM Dataset: EV_ECM20TFS0205G0906259AK 001004
ROD: EV_ECM20TFS0205G0906259AK.rod
VCID: 77A085CA5F432652EF8-8022-R
VINID: 0E69C19074A51E37401472041854D7D4AD
15125 - Cylinder 1
P0301 00 {01100000} - Misfire Detected
15131 - Cylinder 3
P0303 00 {01100000} - Misfire Detected
15134 - Cylinder 4
P0304 00 {01100000} - Misfire Detected
15128 - Cylinder 2
P0302 00 {01100000} - Misfire Detected
15137 - Random/Multiple Cylinder Misfire Detected
P0300 00 {01100000} - -
15236 - Implausible Data Received from Body Control Module (Central Electric)
U0422 00 {00100000} - -
{Invalid Data Received From Body Control Module}
Part No SW: 5Q0 614 517 GA HW: 5Q0 614 517 BN
Component: ESC H36 0114
Revision: 00000000 Serial number: 62064000003635 Dataset Number: V03935432C 0001
Coding: 70FB6BA150250973457F0204A0C9A90ED60A90A2400595361443F5D5D0A94B0B0000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049_VW37.rod
VCID: 76BE88CE58495F5AF4E-8022-R
Part No SW: 3Q1 959 435 C HW: 3Q1 959 435 C
Component: VWKESSYMQB 037 1501
Revision: 00037000 Serial number: 0652851009 Dataset Number: V03935432CE 0001
Coding: 132C0C0623
Shop #: WSC 00066 790 00511
ASAM Dataset: EV_KessyHellaMQBAB 004056
VCID: 3B2859FA23EBC232CB0-806E-R
Part No SW: 2GJ 907 044 L HW: 2GJ 907 044 L
Component: Climatronic H20 0306
Dataset Number: V03935450RV 0001
Coding: 0102001420011C0C0104000C1211D014
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002005
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 47C0350A6F2396D25F8-8012-R
Part No SW: 5Q1 937 085 C HW: 5Q1 937 085 C
Component: BCM MQBAB HLN H56 0711
Serial number: 5010004502ÿÿÿÿ Dataset Number: V03935454LV 0001
ASAM Dataset: EV_BCMMQB 023001
ROD: EV_BCMBOSCH_023.rod
VCID: 3A265CFE2CD1FB3AD06-806E-R SFD+SFD2 {x}
Subsystem 1 - Part No SW: 81D 955 555 A HW: 81D 955 555
Component: G397_RLFSS H06 0004
Serial number: 20391832X81D955555A0
Coding: 8000DE
Steering Column Switch:
Subsystem 2 - Part No SW: 5Q1 953 521 JC HW: 5Q1 953 569 K
Component: Lenks.Modul H24 0190
Serial number: 0300191220240C201103
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0102
Serial number: ESE4348377
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE4348407
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE4349791
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE4346155
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 2Q0 907 567 C HW: 2Q0 907 819
Component: ACCCONTIMQB H04 0541
Dataset Number: V03935448T 0001
Coding: 280200C158FF8748949C812460409700000000000000004034
Shop #: WSC 00066 790 00577
ASAM Dataset: EV_ACCMRRCONTIUNECEMQB 004021
ROD: EV_ACCMRRCONTIUNECEMQB_VW27.rod
VCID: 382246F612DDE92A262-806C-R SFD+SFD2 {x}
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 D HW: 5Q0 907 376 D
Component: DAEMPFUNGS-SG H18 0140
Serial number: 27082441350019 Dataset Number: V03935285SE 0001
ROD: EV_DRCONTITEMIC_VW37.rod
Part No SW: 5Q0 959 655 CB HW: 5Q0 959 655 CB
Component: AirbagVW21 010 0421
Serial number: 003J4M0UVL23 Dataset Number: V03935447TP 0001
Coding: 8CCCFCC0000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
VCID: 0256E41E048173FAC86-8056-R
Component: BF-Gewichtss. H17 0022
Serial number: IBH00000000000NZU4IR
Coding: 30374E
Subsystem 2 - Part No SW: ----------- HW: 480 001 810 24
Serial number: 3570000000061829C27J
Subsystem 3 - Part No SW: ----------- HW: 480 001 810 24
Serial number: 35800000000799CCC270
Subsystem 4 - Part No SW: ----------- HW: 480 050 711 24
Component: SideSensor_Dr 000 0149
Serial number: 3510000A6D8C2252446/
Subsystem 5 - Part No SW: ----------- HW: 480 050 711 24
Component: SideSensor_Pr 000 0149
Serial number: 3520000A4D8C22474897
Subsystem 6 - Part No SW: ----------- HW: 480 052 711 24
Component: FrontSensor_D 000 0149
Serial number: 3550000B8D8C260EA95P
Subsystem 7 - Part No SW: ----------- HW: 480 052 711 24
Component: FrontSensor_P 000 0149
Serial number: 35600009CD8E4C91491O
Part No SW: 17A 920 420 F HW: 17A 920 420 F
Component: KOMBI 712 8125
Dataset Number: V03935456AA 0001
Coding: 082408007788CF050288624B5000000880600802
ASAM Dataset: EV_DashBoardVDDMQBA0 003062
ROD: EV_DashBoardVDDMQBA0_003_VW27.rod
VCID: 20128E96AA4D81EAFE2-8074-R SFD+SFD2 {x}
Part No SW: 3Q0 907 530 BF HW: 3Q0 907 530 BB
Component: GW 2023 CLA 550 5585
Revision: -------- Serial number: 423702500250280 Dataset Number: V03935441YV 0001
Coding: 0000800D0C00000000000000000000000000000000000300030000000001000000000000000000000000000000000000
GVL: 3D500000040040DC800000004C00100000000002000000000000000000000042
ASAM Dataset: EV_GatewMQB2020Class 001001
ROD: EV_GatewMQB2020Class_VW37.rod
VCID: 74BAB2C64E354D4ACAA-8020 SFD+SFD2 {x}
Generator:
Component: 5-00-14-00-04
Subsystem 2 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H11 9070
Serial number: 4212041601
Subsystem 3 - Part No SW: 1EA 959 442 E HW: 1EA 959 442 E
Component: MFL H03 0219
Serial number: 17036218142992401411
Subsystem 4 - Part No SW: 5H0 959 542 N HW: 5H0 959 542 N
Component: KLR_JSS_1Zone 089 0023
Serial number: 3136188AA24322149603
8417280 - Diagnostic Filter
U17A0 00 {00101000} - Not Activated
{Filter_is_not_active}
Mileage: 11466 km
Date: 2026.07.09
Time: 15:11:23
Address 32: Differential Locks (J492) Labels:| 0CQ-907-554-V2.clb
Part No SW: 0CQ 907 554 P HW: 0CQ 907 554 P
Component: Quersperre H55 8043
Serial number: HA1-00004.09.24 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
VCID: 52F6145E9461237A386-8006-R
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 H HW: 3Q0 959 760 H
Component: SCU_FS 003 0114
Serial number: YN007XIN5350500 Dataset Number: V03935426UU 0001
Coding: 00080240000120400000010101000000000000010000000000000000044000
ASAM Dataset: EV_SeatMemorDriveSideKo 001003
ROD: EV_SeatMemorDriveSideKo_VW27.rod
VCID: 40D22E164A0DA1EA9E2-8014-R SFD+SFD2 {x}
9654612 - Motor for Lumbar Support Height Adjustment
B1351 54 {00101111} - Missing Calibration / Basic Setting
Mileage: 11466 km
Date: 2026.07.09
Time: 15:11:22
9655380 - Motor for seat height adjustment
B1354 54 {00101000} - Missing Calibration / Basic Setting
Reset counter: 11
Mileage: 11466 km
Date: 2026.07.09
Time: 15:11:22
9655124 - Motor for Seat Tilt Adjustment
B1353 54 {00101111} - Missing Calibration / Basic Setting
Mileage: 11466 km
Date: 2026.07.09
Time: 15:11:22
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 H HW: 2Q0 907 686 H
Component: HRE_Master H26 0320
Serial number: 11230086052948 Dataset Number: V03935424TY 0001
Coding: 5694C640
ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
VCID: 3FD02DEA37F3DE12E78-806A-R
Subsystem 1 - Part No SW: 2Q0 907 685 H HW: 2Q0 907 685 H
Component: HRE_Slave H26 0320
Serial number: 11230086214953
Part No SW: 5Q4 959 593 Q HW: 5Q4 959 593 Q
Component: TSG FS 016 0921
Serial number: 26045501701312 Dataset Number: V03935412FR 0001
Coding: 003D1B200200028000000000
Shop #: WSC 00066 790 00593
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001023
VCID: 53F8115AAB7B2A72330-8006-R
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000021908787
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5WA-907-14X-V2.clb
Part No SW: 3WA 907 145 E HW: 3WA 907 145
Component: BASGEN1MQB37 503 1122
Serial number: 02811811 Dataset Number: V03935435QA 0001
Coding: 01000000010000010000020101000100000001000100
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
ROD: EV_SteerAssisBASGEN1MQB37_017.rod
VCID: 4AC60C3E7C316BBA406-801E-R SFD+SFD2 {x}
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 P HW: 3Q0 907 338 R
Component: FCM MQB High H09 0408
Serial number: 08012500842125 Dataset Number: V03935425KG 0001
Coding: 000000000800450A00000000000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiMQBCl 001009
ROD: EV_MultiModulContiMQBCl_VW27.rod
VCID: 42D6241E4401B3FA886-8016-R
Part No SW: 5Q4 959 592 Q HW: 5Q4 959 592 Q
Component: TSG BFS 016 0921
Serial number: 27045501600728 Dataset Number: V03935419DH 0001
Coding: 003D13200200028000000000
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001023
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000021910223
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G8 035 842 HW: 3G8 035 842
Component: MU-O-NS-US H04 5422
Serial number: WG8LGM311024003 Dataset Number: V03935456ZE 0001
Coding: 23710000000210000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 002001
ROD: EV_MUOIMQB_002_VW27.rod
VCID: 6882D6B602FDB9AA762-803C-R SFD+SFD2 {x}
Subsystem 1 - Part No SW: 5NN 919 605 C HW: 5NN 919 605 C
Component: ABT_Std-2 291 8321
Serial number: VWZ6ZMD0125190
Subsystem 2 - Part No: V03 959 821 P
Component: NAR 2025 2119
Part No SW: 2GA 035 285 HW: 2GA 035 285
Component: OCUClas2023_H H11 0615
Serial number: 0000000411VIKEF Dataset Number: V03935433ZN 0001
Coding: 02020500000100211000010013002E07111112111012011110
ASAM Dataset: EV_OCUClass2023 001063
ROD: EV_OCUClass2023.rod
VCID: 71B4BBD23127786221C-8024-R SFD+SFD2 {x}
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 H HW: 2Q0 980 653 A
Component: MQB MFK 3.0 H19 1602
Serial number: EF1689303243240 Dataset Number: V03935453VN 0001
Coding: 00000A88016E4020089F00000020002000418000800000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007058
Part No SW: 5G0 907 159 F HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0004
Serial number: 241113293475
VCID: 31347BD2F1A7386261C-8064-R
Part No SW: 4K8 907 594 AD HW: 4K0 907 594
Component: SAD_STG_1 010 0010
Dataset Number: V03935394WW 0001
Coding: 00800073710B
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 7EAE90EE7079171AACE-802A-R
End----------(Elapsed Time: 12:42, VBatt start/end: 14.5V/14.4V)-----------
------------------------------10 Faults Found------------------------------
;SW:5G0-906-259-AK HW:06K-907-425-J --- 01: Engine
;Component:R4 2.0l TFS H13 0002, Coding:091900122444002F3000
;EV_ECM20TFS0205G0906259AK,001004,EV_ECM20TFS0205G0906259AK.rod
;Wednesday,19,August,2026,10:37:07:58926
;VCDS Version: 26.7.2.1 (x64) Data version: 20260708 DS378.0
;VCID: 77A085CA5F432652EF8-8022-R
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),||3VW1T7BU7SM05784|6|,
IDE00018,Voltage terminal 15,14.082, V
IDE00019,Voltage terminal 30,14.355, V
IDE00021,Engine speed,799, /min
IDE00025,Coolant temperature,107, °C
IDE00078,Time since engine start,1093, s
IDE00083,Throttle valve position (absolute),12.2, %
IDE00084,Absolute load value,19, %
IDE00085,Normed load value,11.8, %
IDE00086,Accelerator pedal position,14.5, %
IDE00090,selected gear,Shifting process active,
IDE00097,OBD - requirements for which this vehicle is designed,OBD + OBD II,
IDE00102,Control Module temperature,51.0, °C
IDE00148,Mean injection time,0.5, ms
IDE00149,Ignition angle of current cylinder: actual value,2.62, °
IDE00150,Pressure in brake servo unit,1.150, bar
IDE00151,Oil fill level,87, mm
IDE00155,Ignition timing angle retard cylinder 1,0.00, °
IDE00156,Ignition timing angle retard cylinder 2,0.00, °
IDE00157,Ignition timing angle retard cylinder 3,0.00, °
IDE00158,Ignition timing angle retard cylinder 4,0.00, °
IDE00167,Exhaust temperature 1 bank 1,312.5, °C
IDE00172,A/C compressor torque,-3.41, Nm
IDE00173,Cruise Control System: specified speed,0.00, km/h
IDE00174,Camshaft adjustment: exhaust: bank 1: specified value,9.0, °
IDE00175,Camshaft adjustment: exhaust: bank 1: actual value,9.4, °
IDE00178,Camshaft adjustment intake bank 1: specified value,10.0, °
IDE00179,Camshaft adjustment intake bank 1: actual value,10.4, °
IDE00182,Camshaft adaptation intake bank 1: phase position,0.3, °
IDE00184,Camshaft adaptation exhaust bank 1: phase position,-1.1, °
IDE00186,Fuel low pressure: actual value,6.666, bar
IDE00187,Coolant temperature at engine start,24.0, °C
IDE00188,Fuel high-pressure: actual value,95.1, bar
IDE00189,Activation of fuel pump electronics,67.49, %
IDE00190,Charge air pressure: specified value,0.986, bar
IDE00191,Charge air pressure: actual value,0.986, bar
IDE00192,Coolant temperature at radiator outlet: actual value,36.6, °C
IDE00193,Coolant temperature at engine outlet: specified value,107.2, °C
IDE00194,Coolant temperature at radiator output: specified value,-48.0, °C
IDE00195,Coolant temperature difference between engine and radiator,70.5, °C
IDE00196,Engine oil temperature,89.0, °C
IDE00199,Mean engine air mass,10, kg/h
IDE00200,Average vehicle speed,0.00, km/h
IDE00201,Fuel high-pressure: specified value,95.2, bar
IDE00202,Low fuel pressure: specified value,6.945, bar
IDE00252,Vacuum pump for brakes,Pump off,
IDE00304,Fuel level,11, l
IDE00348,Intake air temperature,43, °C
IDE00349,Throttle valve position: normed,2.0, %
IDE00350,Air mass: specified value,10, kg/h
IDE00355,Cruise Control System (CCS): status,main switch off,
IDE00357,Fuel temperature,89.2, °C
IDE00358,Limitation: torque,237.8, Nm
IDE00371,Fuel consumption,0.86, l/h
IDE00375,Generator: load signal,51.63, %
IDE00380,Coolant fan 1: activation,32.81, %
IDE00381,Coolant fan 2: activation,32.42, %
IDE00392,Accelerator pedal: sensor voltage 1,0.737, V
IDE00393,Accelerator pedal: sensor voltage 2,0.371, V
IDE00396,Charge air pressure actuator: acknowledgment,3.608, V
IDE00400,Intake manifold Runner Control (IMRC): activation,100.00, %
IDE00401,Intake manifold Runner Control (IMRC): acknowledgment,100.00, %
IDE00404,Throttle valve: activation,13.49, %
IDE00405,Crankshaft speed (RPM),797, /min
IDE00406,Camshaft RPM,0, /min
IDE00407,Rail pressure regulation: status,Regulated operation via quantity control valve,
IDE00408,Engine mount 1,not active,
IDE00409,Engine mount 2,not active,
IDE00412,Starter control: terminal 50,not active,
IDE00413,Starter control: Interlock- or P/N-signal,01,
IDE00414,Starter control: relay 1,00,
IDE00415,Starter control: relay 2,00,
IDE00416,Starter control: terminal 50 feedback,01,
IDE00417,Starter control: shut-off conditions 1,01 01,
IDE00432,Particle filter: time since last regeneration,8731, min
IDE00434,Particle filter: soot mass calculated,0.00, g
IDE00436,Particle filter: kilometers since last regeneration,6553.5,
IDE00451,Currently running routine,Unknown (0)
IDE00472,Mean injection quantity,7, mg/stroke
IDE00474,Ambient air pressure,98, kPa abs
IDE00476,Fuel Metering Valve,24.46, %
IDE00477,Torque request: sum of auxiliary aggregate,16.2, Nm
IDE00478,Engine-drag torque,12.3, Nm
IDE00482,Limitation: torque of clutch protection,1024.0, Nm
IDE00495,Calculated oil temperature,90.0, °C
IDE00496,Oil pressure switch valve activation,Low pressure,
IDE00497-MAS00627,Status of oil pressure switches-Oil pressure switch for high pressure,Open,
IDE00497-MAS00628,Status of oil pressure switches-Oil pressure switch for low pressure,closed,
IDE00556,Outside temperature,27, °C
IDE00559,Current of oxygen sensor bank 1 sensor 1 (broadband sensor),0.992 Lambda / -0.020 mA,
IDE00560-MAS04121,Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage,0.630, V
IDE00582,Specified value of equivalence ratio,0.992, Lambda
IDE00583,Throttle valve specified value,2.0, %
IDE00584,Distance driven since erasing DTC memory,11466, km
IDE00588,Fuel tank fill level,23.9, %
IDE00589,Fuel pressure,9400, kPa rel
IDE00592,Status of oxygen sensor control,Closed loop, / using O2 sensors
IDE00593,Ignition timing adjustment cylinder 1,2.5, Degrees
IDE00594,Absolute intake pressure,31, kPa abs
IDE00597,Long term adaptation of mixture formation bank 1,2.3, %
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00603,Number of driving cycles since erasing DTC memory,255,
IDE00604,Short term adaptation of mixture formation bank 1,0.0, %
IDE00608,Fuel type,Gasoline,
IDE00612,Target position of EVAP canister valve,7.1, %
IDE00949-ENG98517,Hide cylinder-Cylinder 1,not active,
IDE00949-ENG98491,Hide cylinder-Cylinder 10,not active,
IDE00949-ENG98492,Hide cylinder-Cylinder 11,not active,
IDE00949-ENG98493,Hide cylinder-Cylinder 12,not active,
IDE00949-ENG98518,Hide cylinder-Cylinder 13,not active,
IDE00949-ENG98519,Hide cylinder-Cylinder 14,not active,
IDE00949-ENG98520,Hide cylinder-Cylinder 15,not active,
IDE00949-ENG98494,Hide cylinder-Cylinder 16,not active,
IDE00949-ENG98521,Hide cylinder-Cylinder 2,not active,
IDE00949-ENG98522,Hide cylinder-Cylinder 3,not active,
IDE00949-ENG98523,Hide cylinder-Cylinder 4,not active,
IDE00949-ENG98495,Hide cylinder-Cylinder 5,not active,
IDE00949-ENG98524,Hide cylinder-Cylinder 6,not active,
IDE00949-ENG98496,Hide cylinder-Cylinder 7,not active,
IDE00949-ENG98497,Hide cylinder-Cylinder 8,not active,
IDE00949-ENG98498,Hide cylinder-Cylinder 9,not active,
IDE00968,Compressor speed,0, /min
IDE01076-MAS00109,Time since ignition off-Hours,0, H
IDE01076-MAS00110,Time since ignition off-Minutes,0, min
IDE01076-MAS00111,Time since ignition off-Seconds,0, s
IDE01098,Test of knock sensors: short trip result,Test not started,
IDE01196,Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.,0.000,
IDE01266,Coolant shut-off valve,Open,
IDE01369,Intake manifold runner control (IMRC): offset closed,0.000, V
IDE01377,Throttle valve adapter: actual value,2.5, °
IDE01378,Fuel high pressure: control deviation,0, bar
IDE01385,Wear index,0.00000018,
IDE01405-MAS05513,Starter activation: status-Bit 0,OK,
IDE01405-MAS05514,Starter activation: status-Bit 1,Before starter activation,
IDE01405-MAS05515,Starter activation: status-Bit 2,Before starter activation,
IDE01407,Particle filter: fuel consumption since last regeneration,655.35, l
IDE01638,Result O2 sensor aging test bank 1 or 3 before cat. conv.,Test not started,
IDE01644,Oxygen sensor voltage B1 downstream CAT,0.632, V
IDE01649,Throttle valve position 1,0.625, V
IDE01650,Throttle valve position 2,12, %
IDE01665,Result of test of camshaft adjustment intake bank 1,Test not started,
IDE01667,Result of test of camshaft adjustment outlet bank 1,Test not started,
IDE01670,Short trip status for oil pressure control,Test not started,
IDE01671,Starter control: clutch switch,not depressed,
IDE01672,Starter control: automatic start,possible,
IDE01673-MAS05513,Starter control: readiness bits-Bit 0,Mechanical test of starter not complete,
IDE01673-MAS05514,Starter control: readiness bits-Bit 1,Test of starter relay switching contacts not complete,
IDE01673-MAS05515,Starter control: readiness bits-Bit 2,Test of starter relay activation not complete,
IDE01673-MAS05516,Starter control: readiness bits-Bit 3,Test of terminal 50R return measuring line not completed,
IDE01673-MAS05517,Starter control: readiness bits-Bit 4,Test of starter request double injection not complete,
IDE01673-MAS05518,Starter control: readiness bits-Bit 5,Test of PN signal not complete,
IDE01673-MAS05519,Starter control: readiness bits-Bit 6,Test of interlock switch not complete,
IDE01673-MAS05520,Starter control: readiness bits-Bit 7,Test of clutch pedal switch not complete,
IDE01677,Result: oxygen sensor test operational readiness B1 downstream CAT,Test not started,
IDE01683-MAS05304,Valve stroke switch of AVS from small to large-Cylinder 1,switched,
IDE01683-MAS05305,Valve stroke switch of AVS from small to large-Cylinder 2,switched,
IDE01683-MAS05306,Valve stroke switch of AVS from small to large-Cylinder 3,switched,
IDE01683-MAS05307,Valve stroke switch of AVS from small to large-Cylinder 4,switched,
IDE01683-MAS05308,Valve stroke switch of AVS from small to large-Cylinder 5,switched,
IDE01683-MAS05309,Valve stroke switch of AVS from small to large-Cylinder 6,switched,
IDE01683-MAS05310,Valve stroke switch of AVS from small to large-Cylinder 7,switched,
IDE01683-MAS05311,Valve stroke switch of AVS from small to large-Cylinder 8,switched,
IDE01684-MAS05304,Valve stroke switch of AVS from large to small-Cylinder 1,switched,
IDE01684-MAS05305,Valve stroke switch of AVS from large to small-Cylinder 2,switched,
IDE01684-MAS05306,Valve stroke switch of AVS from large to small-Cylinder 3,switched,
IDE01684-MAS05307,Valve stroke switch of AVS from large to small-Cylinder 4,switched,
IDE01684-MAS05308,Valve stroke switch of AVS from large to small-Cylinder 5,switched,
IDE01684-MAS05309,Valve stroke switch of AVS from large to small-Cylinder 6,switched,
IDE01684-MAS05310,Valve stroke switch of AVS from large to small-Cylinder 7,switched,
IDE01684-MAS05311,Valve stroke switch of AVS from large to small-Cylinder 8,switched,
IDE01685,Result of test of valve stroke switch AVS,Test not started,
IDE01773,Misfire totalizer,0,
IDE01774,Status misfire recognition,active,
IDE01870,Oxygen sensor after catalytic converter: operating status,Bank 1: sensor 1 OK,
IDE01873,Test of catalytic converter: measured value,0.078,
IDE01874,Test of catalytic converter: result,Test not started,
IDE01876,Adaptation of loss torque,0.0, Nm
IDE01878,Adaptation of throttle valve,Test of closing springs ended,
IDE01880,Accelerator pedal position 2,14.9, %
IDE01881,Adaptation of kick-down shifting point,4.126, V
IDE01884,Camshaft adjustment intake bank 1: activation,42.89, %
IDE01886,Number of high pressure incursions,0,
IDE01894,Charge press. ctrl.: adapt. higher than max. threshold,0.00, %
IDE01895,Charge pressure control: less than min. threshold adaptation,0.00, %
IDE01901,Lost torque adaptation: idle,5.8, Nm
IDE01905,Average of ignition timing angle delay adjustment,21.00, °
IDE01906,Dynamic average of ignition timing angle delay adjustment,2.62, °
IDE01912,Oxygen sensor bank 1 sensor 1: specified value,0,
IDE01913,Number of oxygen sensor dynamic tests: bank 1 sensor 1,0,
IDE01922,Vehicle distance driven,11476, km
IDE01923,Control module distance driven,11479, km
IDE01924,Load shift flaps: actual value,closed,
IDE01925,Load shift flaps: specified value,closed,
IDE01926,Adaptation of intake manifold runner flaps,Cancel: prerequisites have not been met,
IDE01928,Close cam shaft angle at quantity control valve,39.4, °
IDE01929,Open cam shaft angle at quantity control valve,1.0, °
IDE01931,High pressure pump injection volume control deviation,-16, mg/stroke
IDE01932,High pressure pump injection volume,-10, mg/stroke
IDE01975,Numb.of misfir.: cylinder 1,6,
IDE01976,Numb.of misfir.: cylinder 2,1,
IDE01977,Numb.of misfir.: cylinder 3,2,
IDE01978,Numb.of misfir.: cylinder 4,1,
IDE01986,Contact for tank leak test,Open,
IDE02116,Exhaust gas temperature before catalytic converter,387.9, °C
IDE02119,Long term adaptation of oxygen sensor control: bank 1,0.0, %
IDE02229,Exhaust gas temperature sensor 1,1110.0, °C
IDE02756,Number of manual engine starts,1215,
IDE02757,Number of automatic engine starts,0,
IDE03008-MAS04415,Stop process prevented-Ambient air pressure,not active,
IDE03008-MAS04416,Stop process prevented-Sporadic function prevention,not active,
IDE03008-MAS04417,Stop process prevented-Poor start detection,not active,
IDE03008-MAS04590,Stop process prevented-Mixture adaptation,not active,
IDE03008-MAS06602,Stop process prevented-Engine temperature,not active,
IDE03008-MAS06604,Stop process prevented-Start/stop sensors:,not active,
IDE03008-MAS06605,Stop process prevented-Regeneration Mode,not active,
IDE03008-MAS06606,Stop process prevented-Brake under pressure too low,not active,
IDE03010-IDE00924,Number of prevented stop processes-Steering angle,0,
IDE03010-MAS01627,Number of prevented stop processes-Steering,0,
IDE03010-MAS02040,Number of prevented stop processes-Anti-play protection,0,
IDE03010-MAS04415,Number of prevented stop processes-Ambient air pressure,0,
IDE03010-MAS04416,Number of prevented stop processes-Sporadic function prevention,0,
IDE03010-MAS04417,Number of prevented stop processes-Poor start detection,0,
IDE03010-MAS04589,Number of prevented stop processes-Diagnosis of exhaust system,0,
IDE03010-MAS04590,Number of prevented stop processes-Mixture adaptation,0,
IDE03010-MAS04591,Number of prevented stop processes-Air system diagnosis,0,
IDE03010-MAS04592,Number of prevented stop processes-Hybrid battery power too low,0,
IDE03010-MAS04593,Number of prevented stop processes-Auxiliary equipment power consumption too high,0,
IDE03010-MAS04595,Number of prevented stop processes-Deceleration takeover active,0,
IDE03010-MAS04805,Number of prevented stop processes-Clutch protection K0,0,
IDE03010-MAS04870,Number of prevented stop processes-Thermostat testing not completed,0,
IDE03010-MAS05758,Number of prevented stop processes-Driving situation,0,
IDE03010-MAS06602,Number of prevented stop processes-Engine temperature,0,
IDE03010-MAS06605,Number of prevented stop processes-Regeneration Mode,0,
IDE03010-MAS06606,Number of prevented stop processes-Brake under pressure too low,0,
IDE03010-MAS08032,Number of prevented stop processes-DTC memory entry in engine control module,0,
IDE03010-MAS09416,Number of prevented stop processes-Learning function active,0,
IDE03010-MAS11563,Number of prevented stop processes-hood open,0,
IDE03010-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE03010-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE03010-MAS12864,Number of prevented stop processes-Slow traffic detected,0,
IDE03010-MAS13643,Number of prevented stop processes-E machine output too low,0,
IDE03010-MAS13644,Number of prevented stop processes-Engine protection active,0,
IDE03010-MAS13645,Number of prevented stop processes-Fuel gelling protection active,0,
IDE03010-MAS13661,Number of prevented stop processes-Exhaust treatment diagnosis,0,
IDE03010-MAS16918,Number of prevented stop processes-Restriction in start system,0,
IDE03011-MAS01627,Number of requested start processes-Steering,0,
IDE03011-MAS04369,Number of requested start processes-Engine temperature too high,0,
IDE03011-MAS04370,Number of requested start processes-Engine temperature too low,0,
IDE03011-MAS04416,Number of requested start processes-Sporadic function prevention,0,
IDE03011-MAS04592,Number of requested start processes-Hybrid battery power too low,0,
IDE03011-MAS04593,Number of requested start processes-Auxiliary equipment power consumption too high,0,
IDE03011-MAS04595,Number of requested start processes-Deceleration takeover active,0,
IDE03011-MAS06606,Number of requested start processes-Brake under pressure too low,0,
IDE03011-MAS06607,Number of requested start processes-SCR System requires restart,0,
IDE03011-MAS09730,Number of requested start processes-CAT heating,0,
IDE03011-MAS11563,Number of requested start processes-hood open,0,
IDE03011-MAS11834,Number of requested start processes-Rolling vehicle,0,
IDE03011-MAS13644,Number of requested start processes-Engine protection active,0,
IDE03011-MAS13645,Number of requested start processes-Fuel gelling protection active,0,
IDE03011-MAS16918,Number of requested start processes-Restriction in start system,0,
IDE03108,Result of test of oxygen sensors bank 1,Test not started,
IDE03235,Neutral position sensor: current transmission angle,20.00, °
IDE03236,Neutral position sensor: adapted transmission angle,-179.96, °
IDE03246,Neutral position sensor: upper adaptation value,0.000, V
IDE03247,Neutral position sensor: lower adaptation value,0.000, V
IDE03262,Adapt of angle sensor 1 f throttle valve,0.503, V
IDE03263,Adapt of angle sensor 2 f throttle valve,4.492, V
IDE03264,Adaptation of angle sensor 1 throttle valve: emerg. air gap,0.830, V
IDE03265,Adaptation of angle sensor 2 throttle valve: emerg. air gap,4.165, V
IDE03267,Intake air temperature: unconditioned voltage,1.460, V
IDE03276,Charge air pressure sensor: unconditioned voltage,1.592, V
IDE03277,Intake manifold Runner Control (IMRC): unconditioned voltage,3.828, V
IDE03328,Transmission neutral position sensor voltage,0.000, V
IDE03361,Driver intention torque,28.3, Nm
IDE03362,Requested transmission torque,1024.0, Nm
IDE03375,Adaptation status of neutral position sensor,4,
IDE03377,Coolant temp at radiator output: unconditioned voltage,2.856, V
IDE03582,Temperature sensor for engine temperature management,-48.0, °C
IDE03585,System status for the start/stop function master,System malfunction,
IDE03587-IDE02697,Stopping prohibitions for active participants-Multifunction unit control module,not active,
IDE03587-MAS00124,Stopping prohibitions for active participants-A/C system,not active,
IDE03587-MAS00127,Stopping prohibitions for active participants-Brake,not active,
IDE03587-MAS00506,Stopping prohibitions for active participants-Adaptive Cruise Control,not active,
IDE03587-MAS00832,Stopping prohibitions for active participants-Convertible top control module,not active,
IDE03587-MAS01090,Stopping prohibitions for active participants-Gearbox,not active,
IDE03587-MAS01106,Stopping prohibitions for active participants-Level control system,not active,
IDE03587-MAS01490,Stopping prohibitions for active participants-Energy management,not active,
IDE03587-MAS01627,Stopping prohibitions for active participants-Steering,not active,
IDE03587-MAS02237,Stopping prohibitions for active participants-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03587-MAS02569,Stopping prohibitions for active participants-All-wheel drive electronics,not active,
IDE03587-MAS03757,Stopping prohibitions for active participants-Quattro Sport,not active,
IDE03587-MAS05129,Stopping prohibitions for active participants-Motor,not active,
IDE03587-MAS06709,Stopping prohibitions for active participants-Keyless operation,not active,
IDE03587-MAS08785,Stopping prohibitions for active participants-Parking aid,not active,
IDE03587-MAS13018,Stopping prohibitions for active participants-Front sensor for driver assistance systems,not active,
IDE03588-IDE02697,System malfunctions for active participants start/stop-Multifunction unit control module,not active,
IDE03588-MAS00124,System malfunctions for active participants start/stop-A/C system,not active,
IDE03588-MAS00127,System malfunctions for active participants start/stop-Brake,not active,
IDE03588-MAS00506,System malfunctions for active participants start/stop-Adaptive Cruise Control,not active,
IDE03588-MAS00832,System malfunctions for active participants start/stop-Convertible top control module,not active,
IDE03588-MAS01090,System malfunctions for active participants start/stop-Gearbox,not active,
IDE03588-MAS01106,System malfunctions for active participants start/stop-Level control system,not active,
IDE03588-MAS01490,System malfunctions for active participants start/stop-Energy management,not active,
IDE03588-MAS01627,System malfunctions for active participants start/stop-Steering,not active,
IDE03588-MAS02237,System malfunctions for active participants start/stop-Body computer 1/ veh. elec sys CM / cent elec.,not active,
IDE03588-MAS02569,System malfunctions for active participants start/stop-All-wheel drive electronics,not active,
IDE03588-MAS03757,System malfunctions for active participants start/stop-Quattro Sport,not active,
IDE03588-MAS05129,System malfunctions for active participants start/stop-Motor,not active,
IDE03588-MAS06709,System malfunctions for active participants start/stop-Keyless operation,not active,
IDE03588-MAS08785,System malfunctions for active participants start/stop-Parking aid,not active,
IDE03588-MAS13018,System malfunctions for active participants start/stop-Front sensor for driver assistance systems,not active,
IDE03589-MAS01161,Error status for start-stop related sensors-Communication errors,not active,
IDE03589-MAS11563,Error status for start-stop related sensors-hood open,not active,
IDE03589-MAS11868,Error status for start-stop related sensors-Driver door status,not active,
IDE03589-MAS12097,Error status for start-stop related sensors-driver door open,not active,
IDE03589-MAS12098,Error status for start-stop related sensors-Start/Stop deactivated with button,not active,
IDE03589-MAS12099,Error status for start-stop related sensors-Clutch signal error,not active,
IDE03589-MAS12100,Error status for start-stop related sensors-Brake or speed signal error,not active,
IDE03589-MAS12101,Error status for start-stop related sensors-Steering signal error,not active,
IDE03692-MAS05513,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 0,Test of camshaft adjustment bank 2 outlet not complete,
IDE03692-MAS05514,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 1,Test of camshaft adjustment bank 1 outlet complete,
IDE03692-MAS05515,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 2,Test of camshaft adjustment bank 2 intake not complete,
IDE03692-MAS05516,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 3,Test of camshaft adjustment bank 1 intake complete,
IDE03692-MAS05517,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 4,Test of knock sensor 4 not complete,
IDE03692-MAS05518,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 5,Test of knock sensor 3 not complete,
IDE03692-MAS05519,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 6,Test of knock sensor 2 not complete,
IDE03692-MAS05520,Monitoring status Onboard Diagnosis camshaft and knock sensor-Bit 7,Test of knock sensor 1 complete,
IDE03693-MAS05513,Monitoring status of additional Onboard Diagnosis-Bit 0,Test of brake light switch not complete,
IDE03693-MAS05514,Monitoring status of additional Onboard Diagnosis-Bit 1,Test of clutch switch complete,
IDE03693-MAS05515,Monitoring status of additional Onboard Diagnosis-Bit 2,Test of idle control not complete,
IDE03693-MAS05516,Monitoring status of additional Onboard Diagnosis-Bit 3,Test of coolant temperature sensor not complete,
IDE03693-MAS05517,Monitoring status of additional Onboard Diagnosis-Bit 4,Test of throttle valve potentiometer not complete,
IDE03693-MAS05518,Monitoring status of additional Onboard Diagnosis-Bit 5,Thermostat testing not completed,
IDE03693-MAS05519,Monitoring status of additional Onboard Diagnosis-Bit 6,Test of charge pressure control not complete,
IDE03693-MAS05520,Monitoring status of additional Onboard Diagnosis-Bit 7,Test of CCS switch not complete,
IDE03693-MAS05521,Monitoring status of additional Onboard Diagnosis-Bit 8,Test of oxygen adaptation bank 1 complete,
IDE03711,Mass flow through throttle valve,8, kg/h
IDE03767,Engine status,Idle,
IDE03795,Camshaft adjustment: exhaust: bank 1: activation,38.72, %
IDE03806,Oxygen sensor bank 1 sensor 1: status,1,
IDE03807,Oxygen sensor bank 1 sensor 2: status,1,
IDE03816,Exhaust flap bank 1,Open,
IDE03818,Heated oxygen sensor bank 1: sensor 2: resistance,398, Ohm
IDE03819,Heated oxygen sensor bank 1: sensor 2: activation,49.61, %
IDE03820,Heated oxygen sensor bank 1: sensor 1: resistance,162, Ohm
IDE03821,Heated oxygen sensor bank 1: sensor 1: activation,27.73, %
IDE03832,Oxygen sensor B1: sensor 2: response time,0, ms
IDE03834,Oxygen sensor bank 1 sensor 2: response time filtered,0, ms
IDE03836,Result of O2 sensor aging test bank 1 after cat. conv.,Test not started,
IDE03892,Fuel high pressure sensor: unconditioned voltage,1.848, V
IDE03918,Engine reverse rotation recognition,not recognised,
IDE03919,Oxygen regulation operability and status,On,
IDE03920,Oxygen adaptation status,Condition not met,
IDE03921,Mixture adaptation factor at partial load,0.08, %
IDE03922,Mixture adaptation factor at idle speed,2.38, %
IDE03923,Adaptive long-term value of mix. condition after cat. conv,0.00000,
IDE03924,Relay for reserve coolant pump: status,not activated,
IDE03928,Counter for fuel entry in oil,0,
IDE03930,Charge pressure actuator: operating status,Operating mode,
IDE03931,Charge pressure actuator: actual position,0.62, %
IDE03932,Charge pressure actuator: specified position,23.99, %
IDE03933,Charge pressure actuator: specified value,0.00, %
IDE03934,Charge pressure actuator: adaptation for lower stop,3.633, V
IDE03935,Charge air pressure actuator: adaptation for upper stop,0.633, V
IDE03953,Oxygen control: adaptation value at partial load: bank 1,0.09, %
IDE03957,Throttle valve angle: specified value,2.6, °
IDE03963,Low fuel pressure adaptation value for EFP,0, mbar
IDE03966,Transmission neutral position sensor PWM signal,0.00, %
IDE03998,Clutch Position Sensor,9.38, %
IDE04002,Charge air pressure control,BP_A act:98.5, kPa
IDE04010,Engine torque: normalized,8.0, %
IDE04011,Nominal torque,350, Nm
IDE04083,Coolant temperatures,ECT 1:107 °C / ECT 2:36 °C,
IDE04405,Mixture variation in adapted part load range 1,0.09, %
IDE04409,Intake manifold pressure: corrected,0.310, bar
IDE04410,Intake manifold pressure: specified value,0.312, bar
IDE04412,Pressure upstream of throttle valve: corrected,0.986, bar
IDE04415,Oxygen sensor control factor with with pre-control correction,0.01, %
IDE04420,Secondary air system activation,Atmosphere/off,
IDE04629,AVS operating condition,Test runs,
IDE04630,AVS valve stroke position: current,AVS Stroke,
IDE04632-MAS05304,AVS error status of last switch-over standard stroke direction-Cylinder 1,OK,
IDE04632-MAS05305,AVS error status of last switch-over standard stroke direction-Cylinder 2,OK,
IDE04632-MAS05306,AVS error status of last switch-over standard stroke direction-Cylinder 3,OK,
IDE04632-MAS05307,AVS error status of last switch-over standard stroke direction-Cylinder 4,OK,
IDE04632-MAS05308,AVS error status of last switch-over standard stroke direction-Cylinder 5,OK,
IDE04632-MAS05309,AVS error status of last switch-over standard stroke direction-Cylinder 6,OK,
IDE04632-MAS05310,AVS error status of last switch-over standard stroke direction-Cylinder 7,OK,
IDE04632-MAS05311,AVS error status of last switch-over standard stroke direction-Cylinder 8,OK,
IDE04633-MAS05304,AVS error status of last switch-over AVS stroke direction-Cylinder 1,OK,
IDE04633-MAS05305,AVS error status of last switch-over AVS stroke direction-Cylinder 2,OK,
IDE04633-MAS05306,AVS error status of last switch-over AVS stroke direction-Cylinder 3,OK,
IDE04633-MAS05307,AVS error status of last switch-over AVS stroke direction-Cylinder 4,OK,
IDE04633-MAS05308,AVS error status of last switch-over AVS stroke direction-Cylinder 5,OK,
IDE04633-MAS05309,AVS error status of last switch-over AVS stroke direction-Cylinder 6,OK,
IDE04633-MAS05310,AVS error status of last switch-over AVS stroke direction-Cylinder 7,OK,
IDE04633-MAS05311,AVS error status of last switch-over AVS stroke direction-Cylinder 8,OK,
IDE04634,AVS switch-over meter for reg activation of curr. drive cycle,0,
IDE04635,AVS switch-over meter: total,4336,
IDE04636,AVS overflow meter for all switch-overs,0,
IDE04637,Engine temperature control actuator,0.00, %
IDE04638,Transmission coolant valve,Open,
IDE04677,Oxygen sensor 1 bank 1: lambda actual value,0,
IDE04680,Oxygen sensor 1 bank 1: voltage raw value O2 signal,1.953, V
IDE04713,Active brake system status,Not operated,
IDE04814,Transmission oil cooler valve,Open,
IDE04937,Sensor for engine block temperature: raw value,-48.0, °C
IDE05140,Intake manifold pressure raw value,0.311, bar
IDE05259,Gear position sensor: raw value,0.00, %
IDE05260,Gear position sensor: current value,Neutral,
IDE05261,Gear position sensor: last valid value,Neutral,
IDE05262,Gear position sensor: gear position valid,invalid,
IDE05310,Charge air pressure control valve position: target value,24.01, %
IDE05311,Charge air pressure control valve position: actual value,0.62, %
IDE05312,Charge air pressure control valve uncond voltage sensor,3.6084, V
IDE05313,Charge air pressure control valve activation pulse duty factor,-14.80, %
IDE05314,Status of charge air pressure control valve basic setting,00000000 ,
IDE05315,Charge air pressure control valve voltage: position closed,3.6328, V
IDE05316,Charge air pressure control valve voltage: position open,0.6329, V
IDE05317,Charge air pressure control valve adaptation performed,00000000 ,
IDE05508,Adaptation val cyl 1 with slow diagnosis,0.000,
IDE05509,Adaptation val cyl 3 with slow diagnosis,0.000,
IDE05510,Adaptation val cyl 4 with slow diagnosis,0.000,
IDE05511,Adaptation val cyl 2 with slow diagnosis,0.000,
IDE05512,Adaptation val cyl 1 with fast diagnosis,0.000,
IDE05513,Adaptation val cyl 3 with fast diagnosis,0.000,
IDE05514,Adaptation val cyl 4 with fast diagnosis,0.000,
IDE05515,Adaptation val cyl 2 with fast diagnosis,0.000,
IDE05593,Secondary air injection sensor 1,0.983, bar
IDE05622,Status of tank leak diagnosis with electrical diagnostic pump,30,
IDE06006,Idle speed specified value,800, /min
IDE06059,Particulate filter: oil ash mass,0.00, g
IDE06192,Knock sensor: cylinder 2: voltage,0.346, V
IDE06193,Knock sensor: cylinder 3: voltage,0.478, V
IDE06194,Knock sensor: cylinder 4: voltage,0.372, V
IDE06195,Knock sensor: cylinder 1: voltage,0.454, V
IDE06296,Activation of oxygen control after main cat,00000000 ,
IDE06307,Stop prevention history data,|Year,Month
IDE06308,Start request history data,|Year,Month
IDE06386,Oil level: static measurement,0, mm
IDE06387,Oil level: last valid dynamic value,10, mm
IDE06388,Oil level: condition for static measurement fulfilled,Condition not met,
IDE06389,Oil level: maximum value,13, mm
IDE06390,Oil level: minimum value,8, mm
IDE06391,Oil temperature sensor 2,86.0, °C
IDE06392,Oil temperature sensor 2: raw value,65.535, V
IDE06393,Oil level: dynamic average value,24, mm
IDE06394,Sensor 1 for secondary air pressure: unconditioned voltage,2.432, V
IDE06395,Fuel low pressure sensor: unconditioned voltage,4.995, V
IDE06396,Coolant temperature at engine outlet: unconditioned voltage,0.691, V
IDE06397,Temperature sensor for engine temp. management: target value,107.3, °C
IDE06398,Temperature sensor for engine temp. management: uncond. voltage,0.690, V
IDE06399,Manifold absolute pressure sensor: unconditioned voltage,0.688, V
IDE06432,Oxygen sensor 1 bank 1 signal status,active,
IDE06444,Oxygen sensor before cat bank 1 (LSB) voltage,1.973, V
IDE06567,Frequency counter deactivate start/stop function,0,
IDE06568,Stop prevention by driver frequency counter,3,
IDE06569,Frequency counter vehicle standstill,3,
IDE06573,Long-term adaptation of intake manifold injection,0.00, %
IDE06574,Long-term adaptation of intake manifold injection in idle,0.00, mg/stroke
IDE06610,Frequency counter vehicle standstill with stop,0,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system malfunction,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,No,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,Yes,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,No,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC,
IDE06710,Cruise control system: permanent deactivation,No switch-off occurs,
IDE06726,Timing deviation after chain replacement: intake bank 1,0.00, °
IDE06728,Timing deviation after chain replacement: exhaust bank 1,-2.25, °
IDE06730,Timing deviation after other repairs: intake bank 1,0.00, °
IDE06732,Timing deviation after other repairs: exhaust bank 1,0.00, °
IDE06734,Timing deviation: current value intake bank 1,0.00, °
IDE06736,Timing deviation: current value exhaust bank 1,-1.88, °
IDE06738,Chain elongation: no. of valid initial values: intake bank 1,0,
IDE06740,Chain elongation: no. of valid initial values: exhaust bank 1,5,
IDE06742,Chain elongation: initial values valid: intake bank 1,not active,
IDE06744,Chain elongation: initial values valid: exhaust bank 1,active,
IDE07001,Piston-cooling jets: activation,On,
IDE07008,Tank leak: number no leak detected,0,
IDE07011,Tank leak: number communication errors to engine control,0,
IDE07014,Tank leak: number very small leaks detected,0,
IDE07019,Number of ignitions direct injection,49301017,
IDE07020,Number of ignitions intake manifold injection,0,
IDE07023,Misfires per 1000 revolutions of cyl. 1 intake manif. injection,0,
IDE07024,Misfires per 1000 revolutions of cyl. 2 intake manif. injection,0,
IDE07025,Misfires per 1000 revolutions of cyl. 3 intake manif. injection,0,
IDE07026,Misfires per 1000 revolutions of cyl. 4 intake manif. injection,0,
IDE07027,Heat quantity that was transported via the catalytic converter,1.197e+009, J
IDE07031,Oil pressure switch for piston-cooling jets: status,Open,
IDE07242,Heater support pump: spec. value,10.00, %
IDE07548,Engine temp. mangmt. actuator: specified value of angle,88.75, °
IDE07549,Engine temp. mangmt. actuator: actual value of angle,89.17, °
IDE07550,Engine temp. management actuator: raw value,1441,
IDE07551,Engine temp. management actuator: duty cycle activation,0.00, %
IDE07552,Engine temper.managem.actuator adaptation: result adaptation,Start,
IDE07553,Engine temperature management actuator: after-run stop,3948,
IDE07554,Engine temperature management actuator: stop open,145,
IDE07564,Required torque adjustment by idling regulator,-0.3, Nm
IDE07571,Engine torque,16.2, Nm
IDE07572,High pressure regulation: adaptation value,-10.00, mg
IDE07574,Long-term fuel trim bank 1 at idle,0.17, mg/stroke
IDE07575,Driver intention torque,-0.3, Nm
IDE07576,Lost torque adaptation driving mode,0.0, Nm
IDE07577,Lost torque adaptation A/C compressor and driving mode,5.4, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,Not operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,Not operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,Not operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07599-MAS01505,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine off,No,
IDE07599-MAS03849,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Crash signal,No,
IDE07599-MAS04795,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-main switch off,Yes,
IDE07599-MAS05135,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Open or no gear selected,Yes,
IDE07599-MAS05136,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Hill descent control,No,
IDE07599-MAS05190,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Parking brake or hand brake actuated,Yes,
IDE07599-MAS05192,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Driver braking,No,
IDE07599-MAS05196,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error,No,
IDE07599-MAS05814,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN communication error,No,
IDE07599-MAS05815,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CAN signal error,No,
IDE07599-MAS05816,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESP control response error,No,
IDE07599-MAS05817,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-RPM limitation,No,
IDE07599-MAS05818,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Transmission coding not plausible,No,
IDE07599-MAS05819,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC active during braking,No,
IDE07599-MAS05820,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC malfunction,No,
IDE07599-MAS05821,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking intervention too weak,No,
IDE07599-MAS05822,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Braking control not available,No,
IDE07599-MAS05823,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Speed signal error during initialization,No,
IDE07599-MAS05824,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Emer. engine operation,No,
IDE07599-MAS05825,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Engine control module fault,No,
IDE07599-MAS05826,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Torque reduction due to fault,No,
IDE07599-MAS05827,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Diagnosis requirements not met,No,
IDE07599-MAS05828,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake excess temperature,No,
IDE07599-MAS05829,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake light fault,No,
IDE07599-MAS05830,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-CCS deactivated due to fault in control component,No,
IDE07599-MAS05831,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC deactivated due to fault in control component,No,
IDE07599-MAS05832,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Coding error,No,
IDE07599-MAS05833,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ESC error,No,
IDE07599-MAS05834,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Brake pedal fault,No,
IDE07599-MAS05835,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Clutch pedal fault,No,
IDE07599-MAS05836,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Acceleration monitoring error,No,
IDE07599-MAS05837,Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-ACC control response error,No,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07669,Oxygen sensor 2 bank 1 after catalytic converter operational readiness status,active,
IDE07901,Error counter bad fuel,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,Not operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,0,
IDE07905-ENG118117,Brake light switch status-actuated__activated,Not operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,0,
IDE07906-ENG118117,Upper clutch switch: status-actuated__activated,Not operated,
IDE07906-ENG114825,Upper clutch switch: status-Ident_32,0,
IDE07945-MAS00334,Status of intermittent monitoring-Catalytic converter monitoring,completed successfully,
IDE07945-MAS00335,Status of intermittent monitoring-Monitoring of catalytic converter at operating temperature,completed successfully,
IDE07945-MAS00336,Status of intermittent monitoring-Monitoring of tank ventilation system,completed successfully,
IDE07945-MAS00337,Status of intermittent monitoring-Monitoring of Secondary Air Injection (AIR) system,completed successfully,
IDE07945-MAS00338,Status of intermittent monitoring-Monitoring of A/C system refrigerant,completed successfully,
IDE07945-MAS00339,Status of intermittent monitoring-Monitoring oxygen sensor,completed successfully,
IDE07945-MAS00340,Status of intermittent monitoring-Monitoring oxygen sensor heater,completed successfully,
IDE07945-MAS00341,Status of intermittent monitoring-Monitoring Exhaust Gas Recirculation (EGR),not completed successfully,
IDE08071,Remote start cancellation reason store 1,0,
IDE08072,Remote start cancellation reason store 2,0,
IDE08073,Remote start cancellation reason store 3,0,
IDE08074,Remote start cancellation reason store 4,0,
IDE08075,Remote start cancellation reason store 5,0,
IDE08495,Activation radiator shutter result,0.00, %
IDE08805,EVAP valve diag. activation condition at minimal load,0.161, counts
IDE08806,EVAP valve diag. activation condition at maximum load,676, mbar
IDE10366,Chg. press. ctrl. valve: sensor voltage max. value,3.684, V
IDE10380,Knock sensor average voltage bank 1,0.293, V
IDE10551-MAS05304,Pre-ignition counter for oxygen shift-Cylinder 1,0,
IDE10551-MAS05305,Pre-ignition counter for oxygen shift-Cylinder 2,0,
IDE10551-MAS05306,Pre-ignition counter for oxygen shift-Cylinder 3,0,
IDE10551-MAS05307,Pre-ignition counter for oxygen shift-Cylinder 4,0,
IDE10551-MAS05308,Pre-ignition counter for oxygen shift-Cylinder 5,0,
IDE10551-MAS05309,Pre-ignition counter for oxygen shift-Cylinder 6,0,
IDE10551-MAS05310,Pre-ignition counter for oxygen shift-Cylinder 7,0,
IDE10551-MAS05311,Pre-ignition counter for oxygen shift-Cylinder 8,0,
IDE10552-MAS05304,Pre-ignition counter for torque reduction-Cylinder 1,0,
IDE10552-MAS05305,Pre-ignition counter for torque reduction-Cylinder 2,0,
IDE10552-MAS05306,Pre-ignition counter for torque reduction-Cylinder 3,0,
IDE10552-MAS05307,Pre-ignition counter for torque reduction-Cylinder 4,0,
IDE10552-MAS05308,Pre-ignition counter for torque reduction-Cylinder 5,0,
IDE10552-MAS05309,Pre-ignition counter for torque reduction-Cylinder 6,0,
IDE10552-MAS05310,Pre-ignition counter for torque reduction-Cylinder 7,0,
IDE10552-MAS05311,Pre-ignition counter for torque reduction-Cylinder 8,0,
IDE10553-MAS05304,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 1,0,
IDE10553-MAS05305,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 2,0,
IDE10553-MAS05306,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 3,0,
IDE10553-MAS05307,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 4,0,
IDE10553-MAS05308,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 5,0,
IDE10553-MAS05309,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 6,0,
IDE10553-MAS05310,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 7,0,
IDE10553-MAS05311,Pre-ignition counter: cylinder suppress. pre-ignition-Cylinder 8,0,
IDE10554-MAS05304,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 1,0,
IDE10554-MAS05305,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 2,0,
IDE10554-MAS05306,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 3,0,
IDE10554-MAS05307,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 4,0,
IDE10554-MAS05308,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 5,0,
IDE10554-MAS05309,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 6,0,
IDE10554-MAS05310,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 7,0,
IDE10554-MAS05311,Pre-ignition counter: cylinder suppress. glow ignition-Cylinder 8,0,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE10922,Pump current of tank leakage diag.: corrected & filtered,0.000, mA
IDE10970-MAS11563,Number of prevented stop processes-hood open,0,
IDE10970-MAS11835,Number of prevented stop processes-Function locked due to frequent stalling,0,
IDE10970-MAS12085,Number of prevented stop processes-Brake pedal information: plausibility,0,
IDE10989,Immobilizer: historic data,|Year,Month
IDE10994,Poor start counter at start-stop,0,
IDE11115,Start/stop driver request: counter restart by starter,0,
IDE11116,Start/stop driver request: counter internal-motor restart,0,
IDE11598,Tank deaeration valve diagnosis: unweighted input value,0.000, counts
IDE11599,Tank deaeration valve diagnosis: weighted output value,0.000, counts
IDE11600,Tank tightness: ambient temperature,-48.00, °C
IDE11919,Lock time for cooling down of secondary air pump,0, s
IDE12137,Tank fill level diagnostic reference value,24.0, l
IDE12138,Fuel consumption per driving cycle,92.52, l/100km
IDE12210,Particle filter: water mass,0.0, g
IDE13084,Particle filter: high level moisture buildup,1000.0, g
IDE13085,Particle filter: high level of soot buildup,6.40, g
IDE13086,Particle filter: maximum soot build-up reached,8.00, g
IDE13087,Particle filter: maximum ash build-up reached,30.00, g
IDE13088,Particle filter: maximum ash loading ratio reached,5.000, counts
IDE13089,Particle filter: high soot accumulation ratio,3.000, counts
IDE13090,Particle filter: maximum soot loading ratio reached,4.000, counts
IDE13091,Particle filter: ash loading ratio,1.000, counts
IDE13092,Particle filter: soot accumulation ratio,0.000, counts
IDE14753,Particulate filter: loading stage,0, counts
IDE14758,Particulate filter: diagnostic value installation test,0.0, %
IDE14760,Particulate filter: oil ash load measured,0.0, %
IDE14761,Particulate filter: oil ash load calculated,0.0, %
IDE14763,Particulate filter: water load,0.0, %
IDE14765,Particulate filter: soot load measured,0.0, %
IDE14767,Particulate filter: soot load calculated,0.0, %
ENG102981,AC compressor: speed increase,00000001 ,
ENG103860,AC request: speed increase,00000000 ,
ENG103042,Accelerator pedal sender: learned end stop,4.126, V
ENG103719,Accelerator position,0.00, %
ENG101488,ACF: load,1.17801,
ENG103474,Activation of oil pressure switching valve,00000001 ,
ENG252358,Active Powertrain Warm-up Features Off-cycle Credit Vehicle Data,|Active Engine Warm-up Timer (Recent),Active Engine Warm-up Timer (Lifetime)
ENG103323,Additional water pump,00000001 ,
ENG101828,Air mass,8.06, kg/h
ENG104264,Alternator load,1050, W
ENG103910,Ambient temperature,25.50, °C
ENG112539,AR_THR_AD_ADD_MMV,-0.0188, cm²
ENG98377,As,none,
ENG103165,Battery voltage,14.3, V
ENG138673,Bypasstool_a2l_name,ORIGINAL A2L,
ENG138672,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identifications,||5G0259AK0002AXA|D|,
ENG99697,Calibration Verification Numbers,||01 A6 0B 2D|42 00 00 00|,
ENG128780,CAM_DIF_VCP{EX_1},0.125, °
ENG128781,CAM_DIF_VCP{IN_1},-0.336, °
ENG102002,CAM_OFS_IVVT_IN{1},0.000, °
ENG112540,CAM_PHA_ENG{GES_EX}{CBK_1},9.203, °
ENG112541,CAM_PHA_ENG{GES_IN}{CBK_1},9.805, °
ENG101169,CAM_PHA_OFS_MAF{IN}{1},0.000, °
ENG112542,CAM_SP_IND_VCP{EX_1},9.000, °
ENG112543,CAM_SP_IND_VCP{IN_1},10.000, °
ENG112544,CAM_VCP{EX_1},9.172, °
ENG112545,CAM_VCP{IN_1},10.016, °
ENG103849,Cat. ageing: bank 1: actual,0.078,
ENG252361,Certification Test Group/Engine Family Number,|Certification Test Group/Engine Family Number|SVGAJ02.0V3|A|,
ENG102214,CPU_LOAD,51.6, %
ENG125189,CTR_CAM_IN_SP_PI_DET_REQ{0},0,
ENG125190,CTR_CAM_IN_SP_PI_DET_REQ{1},0,
ENG125191,CTR_CAM_IN_SP_PI_DET_REQ{2},0,
ENG125192,CTR_CAM_IN_SP_PI_DET_REQ{3},0,
ENG101127,CTR_CDN_OBD_RBM,381,
ENG114826,CTR_EDGE_CAM_EX{1},211,
ENG114827,CTR_EDGE_CAM_IN{1},215,
ENG100536,CTR_IGK_CYC_RBM,1155,
ENG125193,CTR_LAMB_SP_PI_REQ{0},0,
ENG125194,CTR_LAMB_SP_PI_REQ{1},0,
ENG125195,CTR_LAMB_SP_PI_REQ{2},0,
ENG125196,CTR_LAMB_SP_PI_REQ{3},0,
ENG112554,CTR_MIS_DC_MMV_CYL_SAE{0},2,
ENG112555,CTR_MIS_DC_MMV_CYL_SAE{1},1,
ENG112556,CTR_MIS_DC_MMV_CYL_SAE{2},2,
ENG112557,CTR_MIS_DC_MMV_CYL_SAE{3},2,
ENG112558,CTR_MIS_TOT_NVMY_SAE,12600,
ENG125197,CTR_REQ_IV_OFF_PI_FAST{0},0,
ENG125198,CTR_REQ_IV_OFF_PI_FAST{1},0,
ENG125199,CTR_REQ_IV_OFF_PI_FAST{2},0,
ENG125200,CTR_REQ_IV_OFF_PI_FAST{3},0,
ENG125201,CTR_REQ_IV_OFF_PI_SLOW{0},0,
ENG125202,CTR_REQ_IV_OFF_PI_SLOW{1},0,
ENG125203,CTR_REQ_IV_OFF_PI_SLOW{2},0,
ENG125204,CTR_REQ_IV_OFF_PI_SLOW{3},0,
ENG128782,CTR_REQ_IV_OFF_PI_SLOW_TMP{0},0,
ENG128783,CTR_REQ_IV_OFF_PI_SLOW_TMP{1},0,
ENG128784,CTR_REQ_IV_OFF_PI_SLOW_TMP{2},0,
ENG128785,CTR_REQ_IV_OFF_PI_SLOW_TMP{3},0,
ENG100764,CTR_SUM_SRV_INTL,282.1,
ENG125205,CTR_TQI_POW_MAX_PI_REQ{0},0,
ENG125206,CTR_TQI_POW_MAX_PI_REQ{1},0,
ENG125207,CTR_TQI_POW_MAX_PI_REQ{2},0,
ENG125208,CTR_TQI_POW_MAX_PI_REQ{3},0,
ENG119929,CTR_VLD_CAT_GAP_AFL{1},0,
ENG119930,CTR_VLD_CAT_GAP_AFR{1},0,
ENG99428,CTR_VLFT_1_SWI_NOT{0},0,
ENG103626,CTR_VLFT_1_SWI_NOT{1},0,
ENG100809,CTR_VLFT_1_SWI_NOT{2},0,
ENG99336,CTR_VLFT_1_SWI_NOT{3},0,
ENG103025,CTR_VLFT_STND_SWI_NOT{0},0,
ENG100017,CTR_VLFT_STND_SWI_NOT{1},0,
ENG100438,CTR_VLFT_STND_SWI_NOT{2},0,
ENG100736,CTR_VLFT_STND_SWI_NOT{3},0,
ENG112559,CTR_VVL_LIH_ACT,0,
ENG101271,CTR_VVL_LIH_DEAC,0,
ENG100551,CTR_VVL_SWI_DC,0,
ENG99561,CTR_VVL_SWI_H,0,
ENG101173,CTR_VVL_SWI_L,4336,
ENG99084,Cycle flags: (completed cycles): cat: lambda probe heater,9,
ENG100943,Cycle flags: (completed cycles): lambda probes: EGR,0,
ENG99495,Cycle flags: (completed tests): lambda adaption:,8,
ENG103597,Cycle flags:(completed cycles):lambda probes:sec.air sys.,56,
ENG101652,Cylinder shut-off: cylinder suppression,00000000 ,
ENG102657,DIAG_INST{0},NO_ERROR,
ENG99120,DIAG_INST{1},NO_ERROR,
ENG103260,DIAG_INST{2},NO_ERROR,
ENG99710,DIAG_INST{3},NO_ERROR,
ENG102667,DIAG_INST{4},NO_ERROR,
ENG102739,DIAG_INST{5},NO_ERROR,
ENG100162,DIAG_INST{6},NO_ERROR,
ENG99103,DIAG_INST{7},NO_ERROR,
ENG99261,DIAG_INST{8},NO_ERROR,
ENG103622,DIAG_INST{9},NO_ERROR,
ENG112560,DIST_ACT_MIL_SAE,0, km
ENG112561,DIST_DTC_CLR_SAE,11466, km
ENG103766,DIST_ENG_RUN_IN,0.6, m
ENG100531,DIST_ST,1.14792e+007, m
ENG275645,Distance Traveled Since Evap Monitoring Decision,|Distance Traveled Since Evap Monitoring Decision|256|1280|, km
ENG100131,ECU_STATE,SYN_ENG_IGK_ON,
ENG100152,ECUNAME,|ECU,ECUNAME|ECM
ENG103712,EFPPWM_MIN_AD,0.000, %
ENG247045,Engine Exhaust Flow Rate,11.4, kg/h
ENG151174,Engine Friction - Percent Torque,4.0, %
ENG104044,Engine load,12.109375, %
ENG102494,Engine speed: actual,768, /min
ENG102783,Engine: operating status,IS,
ENG103667,ENVD_0_MON,0,
ENG100777,ENVD_0_MON_3,0,
ENG126934,ENVD_0_MON_3_VD,0,
ENG99424,ENVD_1_MON,0,
ENG100344,ENVD_1_MON_3,0,
ENG126935,ENVD_1_MON_3_VD,0,
ENG99790,ENVD_2_MON,0,
ENG100541,ENVD_2_MON_3,0,
ENG126936,ENVD_2_MON_3_VD,0,
ENG99455,ENVD_3_MON,0,
ENG101268,ENVD_3_MON_3,0,
ENG126937,ENVD_3_MON_3_VD,0,
ENG132815,ENVD_4_MON,0,
ENG132816,ENVD_5_MON,0,
ENG132817,ENVD_6_MON,0,
ENG99752,Error flags: (completed cycles): cat: lambda probe heater,0,
ENG101275,Error flags: (completed cycles): lambda probes: EGR,0,
ENG104132,Error flags: (completed cycles): lambda probes:sec.air sys.,0,
ENG101942,ESI (extended service intervals) oil warning threshold,64.06, mm
ENG112562,FAC_AR_THR_AD,0.000, %
ENG104194,FAC_H_RNG_LAM_AD{1},0.000, %
ENG104151,FAC_L_RNG_LAM_AD{1},0.095, %
ENG100298,FAC_LAM_CP,-0.815, %
ENG100108,FAC_LAM_LIM{1},-0.687, %
ENG99722,FAC_LAM_TCO_A{1},0.000, %
ENG103521,FAC_LAM_TCO_B{1},0.000, %
ENG103641,FAC_LAM_TCO_C{1},0.000, %
ENG101578,FAC_LAM_TCO_D{1},0.000, %
ENG100685,FAC_LAM_TCO_E{1},0.000, %
ENG103307,FAC_MAF_MAX,0.16006,
ENG99791,FAC_SLOP_IV{1},0.00000,
ENG102306,FAC_TPS_1_SAE,12.500000, %
ENG102292,FAC_TPS_1_SAE,12.500000, %
ENG99630,Fan control relay: fan run-on,2,
ENG101437,Fan request from air conditioner,29.7, %
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG128786,FTL_SAE,23.92156902, %
ENG104248,Fuel consumption signal,34603, µl
ENG101667,Fuel pump: adaption value,0.000, %
ENG100969,Fuel pump: fuel pressure: I-controller,0.000, %
ENG247046-ENG186450,Fuel Rate-Engine Fuel Rate,0.18, g/s
ENG247046-ENG247209,Fuel Rate-Vehicle Fuel Rate,0.18, g/s
ENG100250,Fuel regulating valve: duty cycle,24.034, %
ENG101692,Fuel supply system: high-pressure regulator,-276.295, hPa
ENG114828,FUP_EFP_MES,6665.24, hPa
ENG103553,FUP_EFP_ST_H,0, hPa
ENG101056,FUP_EFP_ST_L,0, hPa
ENG99950,FUP_EFP_STOP_H,0, hPa
ENG100784,FUP_EFP_STOP_L,0, hPa
ENG102108,FUP_H,94634.8, hPa
ENG112563,FUP_H_SAE,9420.0, kPa
ENG103368,Gearbox -CAN bus messages,94079,
ENG99170,Height correction,986.06, hPa
ENG103575,High-pressure system: regulator,0.64, mg
ENG103879,High-pressure system: regulator: mobile part,-6.02, mg
ENG102603,High-pressure system: status,MFP_CTL,
ENG101567,Idling speed stabilisation: duty cycle/AC compressor torque,9.0, Nm
ENG101946,Idling stabilisation: operating status,00000000 ,
ENG100345,IGA_ADJ_KNK{0},0.000, °
ENG103593,IGA_ADJ_KNK{1},0.000, °
ENG103360,IGA_ADJ_KNK{2},0.000, °
ENG99404,IGA_ADJ_KNK{3},0.000, °
ENG100425,IGA_IGC{0},3.000, °
ENG101655,IGA_IGC{1},3.000, °
ENG100410,IGA_IGC{2},3.000, °
ENG100407,IGA_IGC{3},2.250, °
ENG112564,IGA_IGC_SAE,2.5, °
ENG101741,Intake air temperature,42.75, °C
ENG100634-ENG299122,In-use Performance Tracking: 16 or 20 counters-Counters 3-EOP,|Completion Condition Counts,Conditions Encountered Counts|33537
ENG100634-ENG102823,In-use Performance Tracking: 16 or 20 counters-Ignition Cycle Counter,0, counts
ENG100634-ENG99988,In-use Performance Tracking: 16 or 20 counters-OBD Monitoring Conditions Encountered Counts,0, counts
ENG100634-ENG250449,In-use Performance Tracking: 16 or 20 counters-Raw Data,00,
ENG125209,KNKS_ERR_REL{0},0.0391, V
ENG99741,LAMB_DELTA_AD_LAM_ADJ{1},-0.00037,
ENG99601,LAMB_DELTA_I_LAM_ADJ{1},0.00000,
ENG112565,LAMB_DELTA_SUM_LAM_ADJ_AD{1},-0.00037,
ENG99674,Lambda controller: bank 1 (averaged value),-0.471, %
ENG101381,Lambda probe 1: bank 1: status,00000001 ,
ENG101039,Lambda probe 1: bank 1: status,00000000 ,
ENG102886,Lambda probe 1: bank 1: status,00000000 ,
ENG104200,Lambda probe 2: bank 1: status,00000000 ,
ENG101336,Lambda probe 2: bank 1: status,00000000 ,
ENG99661,Lambda probe ageing: bank 1: dynamic factor,0.0000,
ENG100478,Lambda probe correction: duty cycle offset: bank 1,0.00000,
ENG103776,Lambda probe heater: bank 1: probe 2: short trip result,00000000 ,
ENG102380,Lambda probe heater: resistance: bank 1: probe 2,401, Ohm
ENG99353,Lambda probe voltage: bank 1: probe 1 (broadband probe),1.973, V
ENG102763,Lambda probes actual: bank1,0.9980,
ENG104114,Lambda probes specified: bank1,0.9922,
ENG137664,LF_COSI_CTL_ERR_A,0,
ENG137665,LF_COSI_CTL_ERR_B,0,
ENG112566,LF_DPS_CYC_ERR_RAW_BSW{1},16384,
ENG112567,LF_DPS_CYC_ERR_RAW_BSW{2},16384,
ENG112568,LF_DPS_CYC_ERR_VLD_BSW{1},65535,
ENG112569,LF_DPS_CYC_ERR_VLD_BSW{2},65535,
ENG112570,LF_DPS_INI_ERR_RAW_BSW{1},0,
ENG112571,LF_DPS_INI_ERR_RAW_BSW{2},0,
ENG112572,LF_IV_ERR_RAW_BSW{0},0,
ENG112573,LF_IV_ERR_RAW_BSW{1},0,
ENG112574,LF_IV_ERR_RAW_BSW{2},0,
ENG112575,LF_IV_ERR_RAW_BSW{3},0,
ENG112576,LF_IV_ERR_VLD_BSW{0},8191,
ENG112577,LF_IV_ERR_VLD_BSW{1},8191,
ENG112578,LF_IV_ERR_VLD_BSW{2},8191,
ENG112579,LF_IV_ERR_VLD_BSW{3},8191,
ENG101645,LF_VVL_DIAG_SWI_NOT,0,
ENG127734,Life_cycle_data_start_requirement_development,|Year,Month
ENG127735,Life_cycle_data_stop_prohibition_development,|Year,Month
ENG127733,Life_cycle_data_system_failure,|Year,Month
ENG122701,LMVDes_st_Mod_Out_VW,0,
ENG122702,LMVDes_v_Max_Man_Lim_VW,511.992, km/h
ENG122703,LMVLim_v_Auth_Max_Out_VW,200.0000, km/h
ENG100402,LOIL_SUM_SRV_INTL,7266.44, mm
ENG99162,LV_ACC_RED_CMD,00000000 ,
ENG102235,LV_ATB_ACT_1,00000000 ,
ENG102541,LV_ATB_ACT_2,00000000 ,
ENG114829,LV_BPA_LIH_REQ{0},0,
ENG99095,LV_CAN_HOOD_SWI,00000000 ,
ENG128787,LV_CMD_RCL_OPEN,00000000 ,
ENG138691,LV_ECRAS_FB_DIAG_POS_RESP{1},00000000 ,
ENG103049,LV_EFPPWM_AD_STOP,00000001 ,
ENG101712,LV_ENG_RUN_IN,00000000 ,
ENG100267,LV_ENG_RUN_IN_EXT_ADJ,00000000 ,
ENG103319,LV_ERR_VLFT_1_SWI{1},00000000 ,
ENG103549,LV_ERR_VLFT_1_SWI{2},00000000 ,
ENG103191,LV_ERR_VLFT_1_SWI{3},00000000 ,
ENG101989,LV_ERR_VLFT_1_SWI{4},00000000 ,
ENG102313,LV_ERR_VLFT_STND_SWI{1},00000000 ,
ENG103044,LV_ERR_VLFT_STND_SWI{2},00000000 ,
ENG103443,LV_ERR_VLFT_STND_SWI{3},00000000 ,
ENG100487,LV_ERR_VLFT_STND_SWI{4},00000000 ,
ENG112471,LV_IGK,00000001 ,
ENG100044,LV_LOIL_L_WARN,00000000 ,
ENG103492,LV_LOIL_L_WARN_ACT,00000000 ,
ENG103908,LV_LOIL_L_WARN_TMP,00000000 ,
ENG103716,LV_POIL_SWI_H,00000000 ,
ENG100912,LV_POIL_SWI_L,00000001 ,
ENG112586,LV_PWR_RLY{0},00000001 ,
ENG167646,LV_ST_PROT_ACT_ERR,00000000 ,
ENG102417,LV_TPS_AD_ACT,00000000 ,
ENG100842,LV_TPS_AD_DIAG_ERR,0,
ENG103996,LV_TPS_AD_REQ,00000000 ,
ENG112587,LV_VCP_AD_END,00000001 ,
ENG102523,MAF,112.37, mg/stroke
ENG99288,MAF_DIF_CAM_OFS_AD_SQ_TOT,0.000, kg²/h²
ENG112588,MAP_MES_SAE,31, kPa
ENG103501,MASS_SA_REL{0},0.945,
ENG100896,MASS_SA_REL_21_PHA,0.000,
ENG103045,MASS_SA_REL_22_PHA,0.000,
ENG103346,MFF_ADD_LAM_AD{1},0.00, mg/stroke
ENG126493,MFF_MPL_ADD_LAM_AD{1}{1},0.00, mg/stroke
ENG101360,Misfire detection active,00000000 ,
ENG102335,Misfires all cylinders per 1000 rpm,0,
ENG128796,N_SP_IS_CLC,800, /min
ENG103004,N_TCHA,14813.2, /min
ENG112590,N_TOOTH,808, /min
ENG107737,NC_NR_DIAG_RBM,206,
ENG126111,NL_PRE{0},0.13710, V
ENG126112,NL_PRE{1},0.17578, V
ENG126113,NL_PRE{2},0.15343, V
ENG126114,NL_PRE{3},0.13855, V
ENG128789,NR_CYC_AD_DC_BAL_HOM{RNG_H},0,
ENG128790,NR_CYC_AD_DC_BAL_HOM{RNG_IS},0,
ENG128791,NR_CYC_AD_DC_BAL_HOM{RNG_L},0,
ENG128792,NR_CYC_AD_DIAG_BAL_HOM{0},0,
ENG128793,NR_CYC_AD_DIAG_BAL_HOM{1},0,
ENG128794,NR_CYC_AD_DIAG_BAL_HOM{2},0,
ENG128795,NR_CYC_AD_DIAG_BAL_HOM{3},0,
ENG112589,NR_CYL_FIRST_VVL_SWI,0,
ENG99776,NR_CYL_VVL_H_ACK,0,
ENG119936,O2L_MAX_CAT_GAP_AFL_MV{1},0.00000, g
ENG119937,O2L_MAX_CAT_GAP_AFR_MV{1},0.00000, g
ENG99157,PRS_SA_DIF,0.39, hPa
ENG133536,PRS_UP_THR_MES,986.22, hPa
ENG112591,PSN_EDGE_REL_AD_CAM_EX{1}{1},-1.3750, °
ENG112592,PSN_EDGE_REL_AD_CAM_IN{1}{1},1.7500, °
ENG114830,PSN_EDGE_REL_AD_CAM_SAVE_EX{1}{1},-1.3750, °
ENG114831,PSN_EDGE_REL_AD_CAM_SAVE_EX{1}{2},-1.8750, °
ENG114832,PSN_EDGE_REL_AD_CAM_SAVE_IN{1}{1},1.7500, °
ENG114833,PSN_EDGE_REL_AD_CAM_SAVE_IN{1}{2},0.0625, °
ENG128797,PV,0.00, %
ENG102195,PV_AV_1,0.00, %
ENG99137,PV_AV_2,0.00, %
ENG101068,PV_AV_H,0.00, %
ENG112593,PWM_ACT_VCP{EX_1},90.002, %
ENG112594,PWM_ACT_VCP{IN_1},90.002, %
ENG101350,PWM_ETC,-18.341, %
ENG112595,PWM_HLD_VCP{EX_1},38.696, %
ENG112596,PWM_HLD_VCP{IN_1},43.689, %
ENG112597,PWM_PAS_VCP{EX_1},9.375, %
ENG112598,PWM_PAS_VCP{IN_1},9.534, %
ENG101201,Radiator fan 1: run-on: status,600W,
ENG102359,Radiator fan 2: run-on: status,NO_ECF,
ENG119939,RATIO_O2L_LIM_CAT_GAP_AFL_MV{1},0.0000000,
ENG119940,RATIO_O2L_LIM_CAT_GAP_AFR_MV{1},0.0000000,
ENG102377,Ready and error flags,0,
ENG112599,RVC_AV,89.17, °
ENG112601,RVC_SP,88.75, °
ENG112600,RVCPWM,0.000, %
ENG103248,SEG_AD_MMV_ER{0},0.0000,
ENG101135,SEG_AD_MMV_ER{1},-0.0973,
ENG99078,SEG_AD_MMV_ER{2},-0.0837,
ENG103257,SEG_AD_MMV_ER{3},0.0117,
ENG102511,SEG_AD_MMV_ER_H{0},0.0000,
ENG103258,SEG_AD_MMV_ER_H{1},-0.3288,
ENG99291,SEG_AD_MMV_ER_H{2},-0.0572,
ENG99954,SEG_AD_MMV_ER_H{3},-0.2751,
ENG100568,SEG_AD_MMV_ER_L{0},0.0000,
ENG100601,SEG_AD_MMV_ER_L{1},-0.0973,
ENG102668,SEG_AD_MMV_ER_L{2},-0.0837,
ENG101232,SEG_AD_MMV_ER_L{3},0.0117,
ENG101561,SEG_AD_MMV_ER_MID{0},0.0000,
ENG102964,SEG_AD_MMV_ER_MID{1},-0.2410,
ENG100890,SEG_AD_MMV_ER_MID{2},-0.0603,
ENG99793,SEG_AD_MMV_ER_MID{3},-0.2067,
ENG103381,Shut-off time,16.90, s
ENG109006,Spark_efficiency_deviation_at_idle_maximum,92, %
ENG109007,Spark_efficiency_deviation_at_part_load_maximum,57, %
ENG102971,Start adaption: temperature adaption factor 1,1.000000,
ENG102489,Start adaption: temperature adaption factor 2,1.000000,
ENG100723,Start adaption: temperature adaption factor 3,1.000000,
ENG100919,Starter control: interlock switch,00000000 ,
ENG102033,STATE_BPA{0},OPM,
ENG102127,STATE_COMC_NVLD,Wait,
ENG112602,STATE_CRK_STST,CRK_STST_ACQ_SHO_LEVEL,
ENG114834,STATE_CRU_OFF_IRR_CUS,0,
ENG114835,STATE_CRU_OFF_REV_CUS,18433088,
ENG112603,STATE_EOL_VVL,DEAC,
ENG112605,STATE_LS_SAE{1},CL,
ENG104238,STATE_NVLD,INI,
ENG112606,STATE_PWM_VCP{EX_1},HLD,
ENG112607,STATE_PWM_VCP{IN_1},HLD,
ENG101078,STATE_READY_OBD_1,7,
ENG100369,STATE_READY_OBD_3,0,
ENG100342,STATE_REQ_NVLD,NO_REQ,
ENG109090,STATE_SW_MVB,SCGH1010 CB60050,
ENG128798,STATE_T_ES_RD,0,
ENG128799,STATE_T_ES_VLD_RD,1,
ENG112608,STATE_VCP,enable,
ENG114836,STATE_VCV_CLOSE_SL,OFF,
ENG103723,STATE_VVL_MNG,VVL_L,
ENG112609,T_ACT_MIL_SAE,0, min
ENG112494,T_AST_SAE,1161, s
ENG104148,T_COOL_LOIL,387.0, ms
ENG112613,T_DTC_CLR_SAE,19921, min
ENG102790,T_EFP_MEM_H,0.00, s
ENG102123,T_EFP_MEM_L,0.00, s
ENG109299,T_ES,0, min
ENG112615,T_ES_CNT,0,
ENG112616,T_ES_DC,2644, min
ENG99463,T_ES_H,0, s
ENG128802,T_IGK,655.35, s
ENG99398,T_POP_COC_INTER_1,0.0, s
ENG102747,T_PWL,0.0, s
ENG128803,T_PWL_CAN,90.6, s
ENG112636,T_SWI_VVL_ACR,68.3, ms
ENG101325,T_TEMP_SIG_LOIL,61.6, ms
ENG99126,T_VS_TOL_LOCK,0, min
ENG125440,TAA,26.000, °C
ENG102048,Tank breather valve: duty cycle,7.031250, %
ENG101339,Tank breather valve: short trip result,0.0520, kg/h
ENG100439,Tank level,00000000 ,
ENG112610,TCO_1_FIRST_ST,24, °C
ENG112611,TCO_1_ST,24, °C
ENG112612,TCO_1_SYS,106, °C
ENG103434,TCO_A_LAM_AD_WUP{1},-5.25, °C
ENG100381,TCO_B_LAM_AD_WUP{1},9.75, °C
ENG101581,TCO_C_LAM_AD_WUP{1},24.75, °C
ENG100354,TCO_D_LAM_AD_WUP{1},35.25, °C
ENG101973,TCO_E_LAM_AD_WUP{1},45.00, °C
ENG128800,TCO_MDL{STUCK_L_COOL_MON},47.336, °C
ENG124460,TCO_MDL{TH},50.000, °C
ENG100390,TCO_MIN_INTER_LAM_AD_WUP{1},105.75, °C
ENG100853,TCO_MIN_LAM_AD_WUP{1},50.25, °C
ENG102279,TCS/ESP: specified torque,28.31, Nm
ENG99857,TCS: status,00000000 ,
ENG167653,TEG_DYN_LS_DOWN{0},300.4750, °C
ENG101250,TEG_DYN_LS_UP{0},388.3500, °C
ENG167654,TEG_DYN_UP_CAT{0},279.4125, °C
ENG167655,TEMP_CAT_DYN_MDL{0},327.9750, °C
ENG167656,TEMP_CAT_STAT_MDL{0},336.6000, °C
ENG112614,TEMP_CAT_UP_1_SAE,313.6, °C
ENG114837,TFPA,94, °C
ENG114838,TFU_HPP,92.25, °C
ENG99608,Throttle valve adjuster: adaption status,ST_CHK_END,
ENG101411,Throttle valve angle,2.509, °
ENG102845,Throttle valve deviation,-7.443, %
ENG126115,TI_1_MES_MPI{0},0.000, ms
ENG126116,TI_1_MES_MPI{1},0.000, ms
ENG126117,TI_1_MES_MPI{2},0.000, ms
ENG126118,TI_1_MES_MPI{3},0.000, ms
ENG126119,TI_MES_4{PLS_1}{0},0.552, ms
ENG126120,TI_MES_4{PLS_1}{1},0.564, ms
ENG126121,TI_MES_4{PLS_1}{2},0.568, ms
ENG126122,TI_MES_4{PLS_1}{3},0.564, ms
ENG126123,TI_MES_4{PLS_2}{0},0.000, ms
ENG126124,TI_MES_4{PLS_2}{1},0.000, ms
ENG126125,TI_MES_4{PLS_2}{2},0.000, ms
ENG126126,TI_MES_4{PLS_2}{3},0.000, ms
ENG126127,TI_MES_4{PLS_3}{0},0.000, ms
ENG126128,TI_MES_4{PLS_3}{1},0.000, ms
ENG126129,TI_MES_4{PLS_3}{2},0.000, ms
ENG126130,TI_MES_4{PLS_3}{3},0.000, ms
ENG128801,TIA_CHA_DOWN_MV,47.338, °C
ENG125276,TIG_MES_SAE{IM},43, °C
ENG103351,Time since engine start,1168.0, s
ENG112634,TLTS_MES{TCE},106.563, °C
ENG112635,TMAG_VCP,92, °C
ENG110444,TPS_AD_CDN_MIS,0,
ENG114839,TPS_ETC,2.509, °
ENG99274,TPS_SP,2.516, °
ENG103021,TQ_CONV,0.00, Nm
ENG128804,TQI_ADD_ACT,33.15625, Nm
ENG101426,TQI_GS_FAST_INC,0.00, Nm
ENG128805,TQI_N_TCHA_MAX,1023.96875, Nm
ENG247047-ENG247196,Transmission Actual Gear-Transmission Actual Gear Ratio,0.000,
ENG247047-ENG247180,Transmission Actual Gear-Transmission Actual Gear Ratio Supported,Not available,
ENG247047-ENG247177,Transmission Actual Gear-Transmission Actual Gear Status,NEUT,
ENG247047-ENG247188,Transmission Actual Gear-Transmission Actual Gear Status Supported,Available,
ENG102329,TTIP_MES_LS_UP{1},720.1875, °C
ENG100355,V_FUP_EFP_MV,4.995, V
ENG100739,V_PVS_1_BAS,0.7373, V
ENG114840,V_PVS_KD,0.000, V
ENG99514,VBOOST,64.5, V
ENG103201,VCV_CLOSE_RNG,30.0, °
ENG247048,Vehicle Odometer,11476.6, km
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime)
ENG252425,Vehicle Operation Data - Engine Run/Idle Time,|Ignition Counter (Recent),Ignition Counter (Lifetime)
ENG252426,Vehicle Operation Data - PKE/EOE,|Positive Kinetic Energy (Recent),Positive Kinetic Energy (Lifetime)
ENG252427,Vehicle Operation Data - PSA,|Total Propulsion System Active Time (Recent),Total Propulsion System Active Time (Lifetime)
ENG102311,Vehicle speed: filtered,0.000, km/h
ENG122704,VLCAvl_st_Pt_VW,4296,
ENG122705,VLCReq_st_Dem_VW,0,
ENG112639,VLS_DOWN_SAE{1},0.615, V
ENG128806,VOL_FLOW_CHA_UP_RED_MV,0.001984, m³/s
ENG101929,VP_TPS_1,0.6250, V
ENG102985,VP_TPS_2,4.3750, V
ENG100421,VP_TPS_AD_EL_BOL_1,0.5029, V
ENG103444,VP_TPS_AD_EL_BOL_2,4.4922, V
ENG101674,VP_TPS_AD_LIH_1,0.8301, V
ENG99507,VP_TPS_AD_LIH_2,4.1650, V
Elapsed Time: 01:16
;SW:5Q0-614-517-GA HW:5Q0-614-517-BN --- 03: ABS Brakes
;Component:ESC H36 0114, Coding:70FB6BA150250973457F0204A0C9A90ED60A90A2400595361443F5D5D0A94B0B0000000012121212B835351919323200
;EV_Brake1UDSContiMK100IPB,049015,EV_Brake1UDSContiMK100IPB_049_VW37.rod
;Wednesday,19,August,2026,10:23:00:58926
;VCDS Version: 26.7.2.1 (x64) Data version: 20260708 DS378.0
;VCID: 76BE88CE58495F5AF4E-8022-R
Group,Description,Actual
IDE02492,Start/Stop Function: coding information,Start-stop function in control module not active,
IDE03008-IDE05181,Stop process prevented-Emerg.braking,not active,
IDE03008-MAS04513,Stop process prevented-ABS control module pump running,not active,
IDE03008-MAS04515,Stop process prevented-Roll-back detected,not active,
IDE03009-IDE04446,Start process requested-Hill descent control,not active,
IDE03009-IDE06139,Start process requested-AUTO HOLD slippage recognition,not active,
IDE03009-MAS02515,Start process requested-System malfunction,not active,
IDE03009-MAS04485,Start process requested-ESP function deactivation,not active,
IDE03009-MAS04515,Start process requested-Roll-back detected,not active,
IDE03010-IDE04446,Number of prevented stop processes-Hill descent control,0,
IDE03010-IDE05181,Number of prevented stop processes-Emerg.braking,0,
IDE03010-IDE06139,Number of prevented stop processes-AUTO HOLD slippage recognition,0,
IDE03010-MAS04485,Number of prevented stop processes-ESP function deactivation,0,
IDE03010-MAS04513,Number of prevented stop processes-ABS control module pump running,0,
IDE03010-MAS04515,Number of prevented stop processes-Roll-back detected,0,
IDE03010-MAS07931,Number of prevented stop processes-Retaining function unavailable,0,
IDE03010-MAS07932,Number of prevented stop processes-Inclination limit,25,
IDE03011-IDE06139,Number of requested start processes-AUTO HOLD slippage recognition,0,
IDE03011-MAS02515,Number of requested start processes-System malfunction,0,
IDE03011-MAS04515,Number of requested start processes-Roll-back detected,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2000,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,0,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,0,
IDE03127-MAS00109,Prevented stop processes (ring memory)-Hours,0,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,0,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,0,
IDE03127,Prevented stop processes (ring memory),Initial value,
IDE03128-MAS00106,Requested start processes (ring memory)-Year,2000,
IDE03128-MAS00107,Requested start processes (ring memory)-Month,0,
IDE03128-MAS00108,Requested start processes (ring memory)-Day,0,
IDE03128-MAS00109,Requested start processes (ring memory)-Hours,0,
IDE03128-MAS00110,Requested start processes (ring memory)-Minutes,0,
IDE03128-MAS00111,Requested start processes (ring memory)-Seconds,0,
IDE03128,Requested start processes (ring memory),Initial value,
IDE03212,Start/stop conditions,System malfunction,
IDE03213,Start/stop enable,At least one release missing,
IDE03651,Bleed brake system (rework bleeding),0.00, s
IDE04508-IDE02955,Hydraulic brake booster-System status,Not available due to specific system,
IDE04508-IDE04442,Hydraulic brake booster-Vacuum sensor,Malfunction,
IDE04508-IDE04450,Hydraulic brake booster-Brake pressure sensor 1,0.10, bar
IDE04508-MAS03095,Hydraulic brake booster-Function status,not active,
IDE04508-MAS04002,Hydraulic brake booster-Low intake manifold pressure,Malfunction,
IDE07280-IDE04775,Multiple collision brake-Odometer reading of last activation,0, km
IDE07280-IDE06609,Multiple collision brake-Odometer reading of last deactivation,0, km
IDE07280-MAS00106,Multiple collision brake-Year,2000,
IDE07280-MAS00107,Multiple collision brake-Month,0,
IDE07280-MAS00108,Multiple collision brake-Day,0,
IDE07280-MAS00109,Multiple collision brake-Hours,0,
IDE07280-MAS00110,Multiple collision brake-Minutes,0,
IDE07280-MAS00111,Multiple collision brake-Seconds,0,
IDE07280-MAS07659,Multiple collision brake-Frequency counter for multi-collision brake active,0,
IDE07280-MAS07660,Multiple collision brake-Frequency counter for multi-collision brake deactivated,0,
IDE07280-MAS07661,Multiple collision brake-Frequency counter function deactivated by driver,0,
IDE07280-MAS07662,Multiple collision brake-Mileage reading of the last deactivation by driver,0, km
MAS08072-MAS13685,Driving profile selection-Actual value of downhill driving assistant,0,
MAS08072-MAS13686,Driving profile selection-Actual value uphill driving assistant,0,
MAS08072-MAS13687,Driving profile selection-Actual value of differential lock,0,
MAS08072-MAS13688,Driving profile selection-ESC actual value,0,
MAS08072-MAS13689,Driving profile selection-Compatibility of downhill driving assistant,Yes,
MAS08072-MAS13690,Driving profile selection-Compatibility of uphill driving assistant,Yes,
MAS08072-MAS13691,Driving profile selection-Compatibility of differential lock,Yes,
MAS08072-MAS13692,Driving profile selection-ESC compatibility,Yes,
MAS08072-MAS13693,Driving profile selection-Spec. value of downhill driving assistant,0,
MAS08072-MAS13694,Driving profile selection-Spec. value of uphill driving assistant,0,
MAS08072-MAS13695,Driving profile selection-Spec. value of differential lock,0,
MAS08072-MAS13696,Driving profile selection-ESC spec. value,0,
MAS08072-MAS13697,Driving profile selection-System status of downhill driving assistant,Available,
MAS08072-MAS13698,Driving profile selection-System status uphill driving assistant,Not available,
MAS08072-MAS13699,Driving profile selection-System status of differential lock,Not available,
MAS08072-MAS13700,Driving profile selection-ESC system status,Available,
MAS08072-MAS13701,Driving profile selection-Switchover status of downhill driving assistant,Shifting carried out,
MAS08072-MAS13702,Driving profile selection-Switchover status of uphill driving assistant,Shifting carried out,
MAS08072-MAS13703,Driving profile selection-ESC switchover status,Shifting carried out,
MAS08072-MAS13704,Driving profile selection-Switchover status_differential lock,Shifting carried out,
Elapsed Time: 00:14
;SW:3Q1-959-435-C HW:3Q1-959-435-C --- 05: Acc/Start Auth.
;Component:VWKESSYMQB 037 1501, Coding:132C0C0623
;EV_KessyHellaMQBAB,004056,EV_KessyHellaMQBAB_004_VW37.rod
;Wednesday,19,August,2026,10:23:18:58926
;VCID: 3B2859FA23EBC232CB0-806E-R
IDE00019,Voltage terminal 30,14.572, V
IDE00021,Engine speed,799.0, /min
IDE00021-MAS02248,Engine speed-Signal status,valid,
IDE00075,Vehicle speed,0.0, km/h
IDE00075-MAS02248,Vehicle speed-Signal status,valid,
IDE02406,Key number of last identified ID sensor,ID sensor 2,
IDE02407,Status of vehicle locking,Vehicle unlocked at single door,
IDE02408-MAS00218,Individual door locking: status-Driver´s door,Open,
IDE02408-MAS00219,Individual door locking: status-Passenger´s door,closed,
IDE02408-MAS00220,Individual door locking: status-Rear left door,closed,
IDE02408-MAS00221,Individual door locking: status-Rear right door,closed,
IDE02409,ID-sensor 1 authentication: status,No response,
IDE02410,ID-sensor 2 authentication: status,No response,
IDE02411,ID-sensor 3 authentication: status,No response,
IDE02412,ID-sensor 4 authentication: status,No response,
IDE02413,Door handle touch sensor: last operation,Driver´s door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,73,
IDE02419,Proximity sensor frt.pass. door: number of triggers,27,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,FF,
IDE02422-MAS01483,Driver door handle: version information-Software version,FF,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,FF,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,FF,
IDE02423-MAS01483,ass. door handle: version information-Software version,FF,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,FF,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,FF,
IDE02424-MAS01483,Left rear door handle: version information-Software version,FF,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,FF,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,FF,
IDE02425-MAS01483,Right rear door handle: version information-Software version,FF,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,FF,
IDE02426-MAS02398,Key number last identified in left exterior area-ID sensor 1,No,
IDE02426-MAS02399,Key number last identified in left exterior area-ID sensor 2,Yes,
IDE02426-MAS02400,Key number last identified in left exterior area-ID sensor 3,No,
IDE02426-MAS02401,Key number last identified in left exterior area-ID sensor 4,No,
IDE02427-MAS02398,Key number last identified in right exterior area-ID sensor 1,Yes,
IDE02427-MAS02399,Key number last identified in right exterior area-ID sensor 2,Yes,
IDE02427-MAS02400,Key number last identified in right exterior area-ID sensor 3,No,
IDE02427-MAS02401,Key number last identified in right exterior area-ID sensor 4,No,
IDE02428-MAS02398,Key number last identified in rear exterior area-ID sensor 1,Yes,
IDE02428-MAS02399,Key number last identified in rear exterior area-ID sensor 2,No,
IDE02428-MAS02400,Key number last identified in rear exterior area-ID sensor 3,No,
IDE02428-MAS02401,Key number last identified in rear exterior area-ID sensor 4,No,
IDE02429-MAS02398,Key number last identified in interior area-ID sensor 1,No,
IDE02429-MAS02399,Key number last identified in interior area-ID sensor 2,No,
IDE02429-MAS02400,Key number last identified in interior area-ID sensor 3,No,
IDE02429-MAS02401,Key number last identified in interior area-ID sensor 4,No,
IDE02430-MAS02398,Key number last identified in luggage compartment area-ID sensor 1,Yes,
IDE02430-MAS02399,Key number last identified in luggage compartment area-ID sensor 2,Yes,
IDE02430-MAS02400,Key number last identified in luggage compartment area-ID sensor 3,No,
IDE02430-MAS02401,Key number last identified in luggage compartment area-ID sensor 4,No,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02484,72h-Signaling counter left rear door,0,
IDE02485,72h-Signaling counter right rear door,0,
IDE02495,Service-Key: Number of activations,669,
IDE02496,Service-Key: Number of Timeouts,0,
IDE02497,Service-Key: Number of incomplete messages,0,
IDE02569-MAS02240,Terminal S: line status-Steering column lock specified value,On,
IDE02569-MAS02241,Terminal S: line status-Steering column lock actual value,On,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02570-MAS02240,Terminal 15: line status-Steering column lock specified value,On,
IDE02570-MAS02241,Terminal 15: line status-Steering column lock actual value,On,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02571-MAS02240,Terminal 50: line status-Steering column lock specified value,OFF,
IDE02571-MAS02241,Terminal 50: line status-Steering column lock actual value,OFF,
IDE02572-MAS02350,Starter button: status-Switch contact 1,Not operated,
IDE02572-MAS02351,Starter button: status-Switch contact 2,Not operated,
IDE02581,Drive train uncoupling,not decoupled,
IDE02582-MAS00179,Brake activation: switch status-Brake lamp switch,OFF,
IDE02582-MAS02248,Brake activation: switch status-Signal status,valid,
IDE02582-MAS02253,Brake activation: switch status-Brake test switch,OFF,
IDE02589,Rotary latch status,Open,
IDE02590-MAS02256,External vehicle locking: SPECIFIED condition-SPECIFIED condition of lock per remote/key,unlocked,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02760-MAS02240,Terminal 15 redundancy: line status-Steering column lock specified value,On,
IDE02760-MAS02241,Terminal 15 redundancy: line status-Steering column lock actual value,On,
IDE02760-MAS02242,Terminal 15 redundancy: line status-Electronic central electric actual value,On,
IDE03008-MAS05971,Stop process prevented-Missing from ECM,not active,
IDE03008-MAS06116,Stop process prevented-Antenna malfunction of a go-relevant antenna,not active,
IDE03008-MAS06118,Stop process prevented-ID sensor not found,not active,
IDE03008-MAS06119,Stop process prevented-CAN Signal: read coil operation is set,not active,
IDE03009-MAS12704,Start process requested-System error if motor stops,not active,
IDE03010-MAS05971,Number of prevented stop processes-Missing from ECM,2,
IDE03010-MAS06116,Number of prevented stop processes-Antenna malfunction of a go-relevant antenna,0,
IDE03010-MAS06118,Number of prevented stop processes-ID sensor not found,0,
IDE03010-MAS06119,Number of prevented stop processes-CAN Signal: read coil operation is set,0,
IDE03011-MAS12704,Number of requested start processes-System error if motor stops,0,
IDE03127-MAS00106,Prevented stop processes (ring memory)-Year,2011,
IDE03127-MAS00107,Prevented stop processes (ring memory)-Month,1,
IDE03127-MAS00108,Prevented stop processes (ring memory)-Day,1,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,29,
IDE03127-MAS00110,Prevented stop processes (ring memory)-Minutes,28,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,6,
IDE03127-MAS00111,Prevented stop processes (ring memory)-Seconds,26,
IDE03127-MAS02886,Prevented stop processes (ring memory)-Last prohibited stop,Missing from ECM,
IDE03127-MAS02888,Prevented stop processes (ring memory)-Penultimate prohibited stop,Missing from ECM,
IDE03127-MAS02890,Prevented stop processes (ring memory)-Third-last prohibited stop,Empty,
IDE03127-MAS02892,Prevented stop processes (ring memory)-Fourth last prohibited stop,Empty,
IDE03127-MAS02894,Prevented stop processes (ring memory)-Fifth-last prohibited stop,Empty,
IDE03128,Requested start processes (ring memory),Empty,
IDE03212,Start/stop conditions,Stop release,
IDE03213,Start/stop enable,System malfunction,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS05103,CAN signals-Driver information: roll warning,not active,
IDE03527-MAS08112,CAN signals-Drive readiness,not active,
IDE03527-MAS09771,CAN signals-Driver information comfort switching,not active,
IDE03527-MAS10894,CAN signals-Hybrid error,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04042-ENG123041,ID sensor history data-Scan 1: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123040,ID sensor history data-Scan 1: Scan_trigger_en,GO_AUTHENTIFICATION_REQUEST,
IDE04042-ENG123042,ID sensor history data-Scan 1: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123043,ID sensor history data-Scan 1: Trigger_Information_u8,62,
IDE04042-ENG123045,ID sensor history data-Scan 2: Scan_origin_en,PASSIVE_GO,
IDE04042-ENG123044,ID sensor history data-Scan 2: Scan_trigger_en,GO_ID_REQUEST,
IDE04042-ENG123046,ID sensor history data-Scan 2: Single_scan_en,INTERIOR_WITH_TRUNK,
IDE04042-ENG123047,ID sensor history data-Scan 2: Trigger_Information_u8,52,
IDE04042-ENG123049,ID sensor history data-Scan 3: Scan_origin_en,KEY_MINDER,
IDE04042-ENG123048,ID sensor history data-Scan 3: Scan_trigger_en,ENTRY_WITHOUT_PROXIMITY,
IDE04042-ENG123050,ID sensor history data-Scan 3: Single_scan_en,DRIVER_FRONT,
IDE04042-ENG123051,ID sensor history data-Scan 3: Trigger_Information_u8,A4,
IDE05204,Manufacturer production data door handle drivers door,FF FF FF FF FF,
IDE05205,Manufacturer production data door handle front pass.door,FF FF FF FF FF,
IDE05206,Manufacturer production data door handle left rear,FF FF FF FF FF,
IDE05207,Manufacturer production data door handle right rear,FF FF FF FF FF,
IDE07028,Time until shut-off terminal S,1800, s
IDE07290-MAS08119,Conditions for turning on the ignition-Request active,Condition not met,
IDE07290-MAS08136,Conditions for turning on the ignition-Enabling Steering Column Lock,Condition met,
IDE07290-MAS08137,Conditions for turning on the ignition-Enabling immobilizer,Condition not met,
IDE07290-MAS08138,Conditions for turning on the ignition-No active error mode,Condition met,
IDE07290-MAS08139,Conditions for turning on the ignition-Key signature validity,Condition met,
IDE07359,Dimming of starter button lighting,89,
IDE08440,Recommendation energy management,no restriction,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19405,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: locked,not active,
IDE14837-MAS19406,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: locked,not active,
IDE14837-MAS19407,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: locked,not active,
IDE14837-MAS19408,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: locked,not active,
IDE80258,Immobilizer status,Electronic steering locking device not installed,
IDE80258-MAS00106,Immobilizer status-Year,2011,
IDE80258-MAS00107,Immobilizer status-Month,1,
IDE80258-MAS00108,Immobilizer status-Day,1,
IDE80258-MAS00109,Immobilizer status-Hours,0,
IDE80258-MAS00110,Immobilizer status-Minutes,27,
IDE80258-MAS00111,Immobilizer status-Seconds,33,
IDE80258-MAS02349,Immobilizer status-Learn mode,Adapted,
IDE80258-MAS06793,Immobilizer status-Number of adapted keys,02,
MAS00025,Driver seat belt switch,not connected,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,19,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,19,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,27,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,68,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,11476, km
MAS00464-ENG279797,Standard - ambient data 1-time indication,00,
MAS01493,Engine is running,active,
MAS03554,Clutch pedal operation,No,
MAS03607,Engine stop active in Start/Stop mode,not active,
MAS04004,Transmission code,OK,
MAS05104,Driver request: start engine,not active,
MAS08076,Exiting the vehicle,Condition not met,
MAS08788,Driving Cycle,Condition not met,
MAS08790,Driver absence,Condition met,
MAS09771,Driver information comfort switching,No switch-off,
ENG125217,Active_requirement_light_lag,not activated,
ENG129039-ENG129149,Car_keys_RSSI_measurements-Abort_counter,0,
ENG129039-ENG129148,Car_keys_RSSI_measurements-Easy_close_function_counter,0,
ENG129039-ENG129150,Car_keys_RSSI_measurements-Last_abort_reason,none,
ENG129039-ENG160891,Car_keys_RSSI_measurements-RSSI_Value_1,0,
ENG129039-ENG160890,Car_keys_RSSI_measurements-RSSI_Value_2,0,
ENG129039-ENG160889,Car_keys_RSSI_measurements-RSSI_Value_3,0,
ENG129039-ENG160888,Car_keys_RSSI_measurements-RSSI_Value_4,0,
ENG102274,Control Module Voltage,14.589, V
ENG139762,Easy_open_unavailable_reason,Kl15_is_active,
ENG129032,ELV_Status,ELV_Entriegelt,
ENG245551,Enginestart_variant_coded,---,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2025,
ENG125220-MAS00106,History last automatic terminal switch off-Year,2000,
ENG125220-MAS00107,History last automatic terminal switch off-Month,12,
ENG125220-MAS00107,History last automatic terminal switch off-Month,5,
ENG125220-MAS00107,History last automatic terminal switch off-Month,3,
ENG125220-MAS00107,History last automatic terminal switch off-Month,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,27,
ENG125220-MAS00108,History last automatic terminal switch off-Day,11,
ENG125220-MAS00108,History last automatic terminal switch off-Day,0,
ENG125220-MAS00108,History last automatic terminal switch off-Day,19,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,14,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,22,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,0,
ENG125220-MAS00109,History last automatic terminal switch off-Hours,8,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,16,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,30,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,11,
ENG125220-MAS00110,History last automatic terminal switch off-Minutes,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,0,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,1,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,29,
ENG125220-MAS00111,History last automatic terminal switch off-Seconds,2,
ENG125220-ENG125227,History last automatic terminal switch off-Mileage_shutoff_reason_n,14, km
ENG125220-ENG125230,History last automatic terminal switch off-Mileage_shutoff_reason_n-1,1621, km
ENG125220-ENG125233,History last automatic terminal switch off-Mileage_shutoff_reason_n-2,7218, km
ENG125220-ENG125236,History last automatic terminal switch off-Mileage_shutoff_reason_n-3,0, km
ENG125220-ENG125239,History last automatic terminal switch off-Mileage_shutoff_reason_n-4,0, km
ENG125220-ENG125225,History last automatic terminal switch off-shutoff_reason_n,Leaving the car,
ENG125220-ENG125228,History last automatic terminal switch off-shutoff_reason_n-1,Leaving the car,
ENG125220-ENG125231,History last automatic terminal switch off-shutoff_reason_n-2,Leaving the car,
ENG125220-ENG125234,History last automatic terminal switch off-shutoff_reason_n-3,Leaving the car,
ENG125220-ENG125237,History last automatic terminal switch off-shutoff_reason_n-4,Leaving the car,
ENG249150-MAS00111,History_low_voltage-Seconds,3430809, s
ENG249150-MAS00111,History_low_voltage-Seconds,3437136, s
ENG249150-MAS00111,History_low_voltage-Seconds,3426637, s
ENG249150-MAS00111,History_low_voltage-Seconds,3424683, s
ENG249150-MAS00111,History_low_voltage-Seconds,3427904, s
ENG249150-MAS00111,History_low_voltage-Seconds,3424893, s
ENG249150-MAS00111,History_low_voltage-Seconds,3425601, s
ENG249150-MAS00111,History_low_voltage-Seconds,3430464, s
ENG249150-MAS00111,History_low_voltage-Seconds,3426168, s
ENG249150-MAS00111,History_low_voltage-Seconds,3424689, s
ENG249150-ENG249469,History_low_voltage-Function_restriction_n,No_function_restriction,
ENG249150-ENG249453,History_low_voltage-Function_restriction_n-1,No_function_restriction,
ENG249150-ENG249295,History_low_voltage-Function_restriction_n-2,No_function_restriction,
ENG249150-ENG249381,History_low_voltage-Function_restriction_n-3,No_function_restriction,
ENG249150-ENG249352,History_low_voltage-Function_restriction_n-4,No_function_restriction,
ENG249150-ENG249461,History_low_voltage-Function_restriction_n-5,No_function_restriction,
ENG249150-ENG249401,History_low_voltage-Function_restriction_n-6,No_function_restriction,
ENG249150-ENG249354,History_low_voltage-Function_restriction_n-7,No_function_restriction,
ENG249150-ENG249339,History_low_voltage-Function_restriction_n-8,No_function_restriction,
ENG249150-ENG249350,History_low_voltage-Function_restriction_n-9,No_function_restriction,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,ECUEXT_RR_WDGM_TEST_EARLY,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,SBC_UNDERVOLTAGE_RESET,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,SBC_POWER_ON_RESET,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,ECUEXT_RR_WDGM_TEST_LATE,
ENG157998-MAS00106,lf_shutdowns-Year,2000,
ENG157998-MAS00107,lf_shutdowns-Month,0,
ENG157998-MAS00108,lf_shutdowns-Day,0,
ENG157998-MAS00109,lf_shutdowns-Hours,0,
ENG157998-MAS00110,lf_shutdowns-Minutes,0,
ENG157998-MAS00111,lf_shutdowns-Seconds,0,
ENG157998-ENG163142,lf_shutdowns-Mileage_lf_shutdown_n,0, km
ENG157998-ENG163143,lf_shutdowns-Mileage_lf_shutdown_n-1,0, km
ENG157998-ENG163144,lf_shutdowns-Mileage_lf_shutdown_n-2,0, km
ENG157998-ENG163145,lf_shutdowns-Mileage_lf_shutdown_n-3,0, km
ENG120048,Overtemperaturecounter for ADRIMA,0,
ENG129034-ENG129128,power_state_door_handle-power_state_bt,active,
ENG129034-ENG129127,power_state_door_handle-power_state_ft,active,
ENG129034-ENG129129,power_state_door_handle-power_state_hl,not active,
ENG129034-ENG129130,power_state_door_handle-power_state_hr,not active,
ENG129030,Request_steering_column_lock_terminal_approval,not requested,
ENG108452,Reset_counter,17,
ENG129033,s_anf_klemmenfreigabe_wfs,not requested,
ENG126972,s_klemmenfreigabe_wfs,No enabling,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,1,
ENG157420-ENG129140,Scan_cycle_data-Car_key_1,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,0,
ENG157420-ENG129141,Scan_cycle_data-Car_key_2,1,
ENG157420-ENG129142,Scan_cycle_data-Car_key_3,0,
ENG157420-ENG129143,Scan_cycle_data-Car_key_4,0,
ENG157420-ENG161108,Scan_cycle_data-Mileage_n,11462, km
ENG157420-ENG161109,Scan_cycle_data-Mileage_n-1,11462, km
ENG157420-ENG161110,Scan_cycle_data-Mileage_n-10,10259, km
ENG157420-ENG161111,Scan_cycle_data-Mileage_n-11,9972, km
ENG157420-ENG161112,Scan_cycle_data-Mileage_n-12,9972, km
ENG157420-ENG161113,Scan_cycle_data-Mileage_n-13,9968, km
ENG157420-ENG161114,Scan_cycle_data-Mileage_n-14,9968, km
ENG157420-ENG161115,Scan_cycle_data-Mileage_n-15,9850, km
ENG157420-ENG161116,Scan_cycle_data-Mileage_n-16,9850, km
ENG157420-ENG161117,Scan_cycle_data-Mileage_n-17,9850, km
ENG157420-ENG161118,Scan_cycle_data-Mileage_n-18,9850, km
ENG157420-ENG161119,Scan_cycle_data-Mileage_n-19,9349, km
ENG157420-ENG161120,Scan_cycle_data-Mileage_n-2,11435, km
ENG157420-ENG161121,Scan_cycle_data-Mileage_n-3,11435, km
ENG157420-ENG161122,Scan_cycle_data-Mileage_n-4,10912, km
ENG157420-ENG161123,Scan_cycle_data-Mileage_n-5,10912, km
ENG157420-ENG161124,Scan_cycle_data-Mileage_n-6,10710, km
ENG157420-ENG161125,Scan_cycle_data-Mileage_n-7,10259, km
ENG157420-ENG161126,Scan_cycle_data-Mileage_n-8,10259, km
ENG157420-ENG161127,Scan_cycle_data-Mileage_n-9,10259, km
ENG157420-ENG161148,Scan_cycle_data-Retry_count_n,10,
ENG157420-ENG161149,Scan_cycle_data-Retry_count_n -6,9,
ENG157420-ENG161150,Scan_cycle_data-Retry_count_n-1,9,
ENG157420-ENG161151,Scan_cycle_data-Retry_count_n-10,9,
ENG157420-ENG161152,Scan_cycle_data-Retry_count_n-11,10,
ENG157420-ENG161153,Scan_cycle_data-Retry_count_n-12,9,
ENG157420-ENG161154,Scan_cycle_data-Retry_count_n-13,10,
ENG157420-ENG161155,Scan_cycle_data-Retry_count_n-14,9,
ENG157420-ENG161156,Scan_cycle_data-Retry_count_n-15,10,
ENG157420-ENG161157,Scan_cycle_data-Retry_count_n-16,9,
ENG157420-ENG161158,Scan_cycle_data-Retry_count_n-17,19,
ENG157420-ENG161159,Scan_cycle_data-Retry_count_n-18,9,
ENG157420-ENG161160,Scan_cycle_data-Retry_count_n-19,10,
ENG157420-ENG161161,Scan_cycle_data-Retry_count_n-2,10,
ENG157420-ENG161162,Scan_cycle_data-Retry_count_n-3,9,
ENG157420-ENG161163,Scan_cycle_data-Retry_count_n-4,63,
ENG157420-ENG161164,Scan_cycle_data-Retry_count_n-5,9,
ENG157420-ENG161165,Scan_cycle_data-Retry_count_n-7,55,
ENG157420-ENG161166,Scan_cycle_data-Retry_count_n-8,9,
ENG157420-ENG161167,Scan_cycle_data-Retry_count_n-9,18,
ENG157420-ENG161186,Scan_cycle_data-Scan_reason_n,Driver_door,
ENG157420-ENG161187,Scan_cycle_data-Scan_reason_n-1,Driver_door,
ENG157420-ENG161188,Scan_cycle_data-Scan_reason_n-10,rear_left_door,
ENG157420-ENG161189,Scan_cycle_data-Scan_reason_n-11,Driver_door,
ENG157420-ENG161190,Scan_cycle_data-Scan_reason_n-12,Driver_door,
ENG157420-ENG161191,Scan_cycle_data-Scan_reason_n-13,Driver_door,
ENG157420-ENG161192,Scan_cycle_data-Scan_reason_n-14,Driver_door,
ENG157420-ENG161193,Scan_cycle_data-Scan_reason_n-15,Driver_door,
ENG157420-ENG161194,Scan_cycle_data-Scan_reason_n-16,rear_right_door,
ENG157420-ENG161195,Scan_cycle_data-Scan_reason_n-17,Passenger_door,
ENG157420-ENG161196,Scan_cycle_data-Scan_reason_n-18,Driver_door,
ENG157420-ENG161197,Scan_cycle_data-Scan_reason_n-19,Driver_door,
ENG157420-ENG161198,Scan_cycle_data-Scan_reason_n-2,Driver_door,
ENG157420-ENG161199,Scan_cycle_data-Scan_reason_n-3,Driver_door,
ENG157420-ENG161200,Scan_cycle_data-Scan_reason_n-4,rear_left_door,
ENG157420-ENG161201,Scan_cycle_data-Scan_reason_n-5,Driver_door,
ENG157420-ENG161202,Scan_cycle_data-Scan_reason_n-6,trunk,
ENG157420-ENG161203,Scan_cycle_data-Scan_reason_n-7,Driver_door,
ENG157420-ENG161204,Scan_cycle_data-Scan_reason_n-8,Driver_door,
ENG157420-ENG161205,Scan_cycle_data-Scan_reason_n-9,rear_left_door,
ENG157420-ENG161206,Scan_cycle_data-Scan_trigger_n,Reset_stop_car,
ENG157420-ENG161207,Scan_cycle_data-Scan_trigger_n-1,Set_stop_car,
ENG157420-ENG161208,Scan_cycle_data-Scan_trigger_n-10,Set_stop_car,
ENG157420-ENG161209,Scan_cycle_data-Scan_trigger_n-11,Reset_stop_car,
ENG157420-ENG161210,Scan_cycle_data-Scan_trigger_n-12,Set_stop_car,
ENG157420-ENG161211,Scan_cycle_data-Scan_trigger_n-13,Reset_stop_car,
ENG157420-ENG161212,Scan_cycle_data-Scan_trigger_n-14,Set_stop_car,
ENG157420-ENG161213,Scan_cycle_data-Scan_trigger_n-15,Reset_stop_car,
ENG157420-ENG161214,Scan_cycle_data-Scan_trigger_n-16,Set_stop_car,
ENG157420-ENG161215,Scan_cycle_data-Scan_trigger_n-17,Reset_stop_car,
ENG157420-ENG161216,Scan_cycle_data-Scan_trigger_n-18,Set_stop_car,
ENG157420-ENG161217,Scan_cycle_data-Scan_trigger_n-19,Reset_stop_car,
ENG157420-ENG161218,Scan_cycle_data-Scan_trigger_n-2,Reset_stop_car,
ENG157420-ENG161219,Scan_cycle_data-Scan_trigger_n-3,Set_stop_car,
ENG157420-ENG161220,Scan_cycle_data-Scan_trigger_n-4,Reset_stop_car,
ENG157420-ENG161221,Scan_cycle_data-Scan_trigger_n-5,Set_stop_car,
ENG157420-ENG161222,Scan_cycle_data-Scan_trigger_n-6,Set_stop_car,
ENG157420-ENG161223,Scan_cycle_data-Scan_trigger_n-7,Reset_stop_car,
ENG157420-ENG161224,Scan_cycle_data-Scan_trigger_n-8,Set_stop_car,
ENG157420-ENG161225,Scan_cycle_data-Scan_trigger_n-9,Reset_stop_car,
ENG125222-ENG129124,Selective_catalytic_reduction-Possible_Engine_Start,OK,
ENG125222-ENG129123,Selective_catalytic_reduction-SCR_install_state,not installed,
ENG129035-MAS00106,service_key_internal_status-Year,2026,
ENG129035-MAS00106,service_key_internal_status-Year,2000,
ENG129035-MAS00107,service_key_internal_status-Month,8,
ENG129035-MAS00107,service_key_internal_status-Month,0,
ENG129035-MAS00108,service_key_internal_status-Day,17,
ENG129035-MAS00108,service_key_internal_status-Day,0,
ENG129035-MAS00109,service_key_internal_status-Hours,0,
ENG129035-MAS00109,service_key_internal_status-Hours,13,
ENG129035-MAS00110,service_key_internal_status-Minutes,0,
ENG129035-MAS00110,service_key_internal_status-Minutes,54,
ENG129035-MAS00111,service_key_internal_status-Seconds,55,
ENG129035-MAS00111,service_key_internal_status-Seconds,0,
ENG129035-ENG129135,service_key_internal_status-checksum_comparison_service_key1,OK,
ENG129035-ENG129136,service_key_internal_status-checksum_comparison_service_key2,not OK.,
ENG129031,Steering_column_lock_terminal_approval,No enabling,
ENG125218,Suppression_ignition_message,not activated,
ENG129036,To_block_terminal_upshift,not active,
ENG129037,Trigger_terminal_deactivation_central_locking,not activated,
ENG129038,Valid_time_control_section_diagnostics,0, s
ENG139702-ENG140253,WFS_key_signature-clap_15_activateing_signature,02,
ENG139702-ENG140248,WFS_key_signature-signature_key_1,01 5E,
ENG139702-ENG140249,WFS_key_signature-signature_key_2,01 85,
ENG139702-ENG140250,WFS_key_signature-signature_key_3,00 00,
ENG139702-ENG140251,WFS_key_signature-signature_key_4,00 00,
ENG139702-ENG140252,WFS_key_signature-signature_key_5,00 00,
Elapsed Time: 00:20
;SW:2GJ-907-044-L HW:2GJ-907-044-L --- 08: Auto HVAC
;Component:Climatronic H20 0306, Coding:0102001420011C0C0104000C1211D014
;EV_AirCondiBHTCMQB3rTranc,002005,EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
;Wednesday,19,August,2026,10:23:43:58926
;VCID: 47C0350A6F2396D25F8-8012-R
IDE00019,Voltage terminal 30,14.3, V
IDE00021,Engine speed,794.00, /min
IDE00025,Coolant temperature,80.0, °C
IDE00085,Normed load value,13.3, %
IDE00086,Accelerator pedal position,14.5, %
IDE00198,Refrigerant pressure,11.4, bar
IDE00556,Outside temperature,26, °C
IDE00601,Monitoring status since erasing DTC memory,
IDE00602,Monitoring status in current driving cycle,
IDE00767,No. of unscheduled ECU resets,15,
IDE00965,Compressor shut-off condition,Compressor active: no shut-off condition is present,
IDE00966,Compressor current: actual value,0.48, A
IDE00967,Compressor current: specified value,0.48, A
IDE00968,Compressor speed,800, /min
IDE00969,Compressor load,10.1, Nm
IDE00970,Coolant fan activation: actual value,40.0, %
IDE00971,Coolant fan activation: specified value,38.8, %
IDE00973,Outside temperature,26.0, °C
IDE00974,Outside air temperature internally calculated,26.5, °C
IDE00976,Left front vent temperature,7.0, °C
IDE00977,Right front vent temperature,6.0, °C
IDE00981,Footwell vent temperature,19.0, °C
IDE00982,Temperature downstream of evaporator,1.0, °C
IDE00983,Inside temperature,27.0, °C
IDE00984,Sun intensity left,80, W/m²
IDE00985,Sun intensity right,10, W/m²
IDE00987,Blower voltage: specified value,6.1, V
IDE00989,Blower status,active,
IDE00994,Actual value for fresh air/recirculation air flow flap,170,
IDE00994,Actual value for fresh air/recirculation air flow flap,100.0, %
IDE00995,Fresh air/recirculating air/back pressure door specified value,172,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,80,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,167,
IDE00998,Left temperature flap - actual value,26,
IDE00998,Left temperature flap - actual value,0.0, %
IDE00999,Temperature door left - Specified value,25,
IDE01040,Left Temperature Control Door - cold stop,30,
IDE01041,Left temperature flap: warm stop,232,
IDE01042,Right temperature flap: actual value,18,
IDE01042,Right temperature flap: actual value,0.0, %
IDE01043,Temperature door right - Specified value,18,
IDE01044,Right temperature flap: cold stop,23,
IDE01045,Right temperature flap: warm stop,229,
IDE01050,Front air distribution flap: actual value,0.0, %
IDE01050,Front air distribution flap: actual value,20,
IDE01051,Air distribution door front - Specified value,19,
IDE01052,Front air distribution flap: air outlet stop,24,
IDE01053,Front air distribution flap: footwell air outlet stop,234,
IDE01054,Defroster flap: actual value,232,
IDE01054,Defroster flap: actual value,100.0, %
IDE01055,Defrost door - Specified value,233,
IDE01056,Defroster flap: stop open,19,
IDE01057,Defroster flap: stop closed,228,
IDE01063,Status of recirculation air,Automatic recirc. active,
IDE01066,Convertible top status,Closed,
IDE01076,Time since ignition off,240, min
IDE01088,Rear temperature flap: actual value,0.0, %
IDE01088,Rear temperature flap: actual value,20,
IDE01089,Rear temperature flap: specified value,255,
IDE01090,Rear temperature flap: cold stop,0,
IDE01091,Rear temperature flap: warm stop,0,
IDE01217-MAS01447,Left heated seat stage-Actual value,0,
IDE01217-MAS01448,Left heated seat stage-Specified value,0,
IDE01218-MAS01447,Right heated seat stage-Actual value,0,
IDE01218-MAS01448,Right heated seat stage-Specified value,0,
IDE01226,Blower voltage: actual value,6.1, V
IDE01227,Blower current,3.50, A
IDE01232,Supply voltage for external components,5.0, V
IDE01264,Remaining time of parking heater/ventilation operation,0, s
IDE01287-MAS01260,Counter of compressor switch-offs-Shut-off from Engine Control Module (ECM) via CAN,676,
IDE01287-MAS01265,Counter of compressor switch-offs-Speed shut-off,5,
IDE01419,Compressor shut-off condition: last,Low pressure event,
IDE01420,Compressor shut-off requirement: penultimate,Low pressure event,
IDE01421,Compressor shut-off requirement: antepenultimate,Low pressure event,
IDE01433,Air quality status,Initialization,
IDE01442-MAS01533,Pressing a button-Defrost,Not operated,
IDE01442-MAS01534,Pressing a button-Recirculating air,Not operated,
IDE01442-MAS01535,Pressing a button-Rear window defogger,Not operated,
IDE01442-MAS01550,Pressing a button-AC,Not operated,
IDE01442-MAS01554,Pressing a button-Left heated seat,Not operated,
IDE01442-MAS01556,Pressing a button-Right heated seat,Not operated,
IDE01442-MAS01560,Pressing a button-OFF,Not operated,
IDE01442-MAS01577,Pressing a button-Auxiliary heating,Not operated,
IDE01442-MAS02015,Pressing a button-AUTO,Not operated,
IDE01442-MAS02192,Pressing a button-SYNC,Not operated,
IDE01442-MAS03196,Pressing a button-Menu,Not operated,
IDE01442-MAS03830,Pressing a button-Footwell air distribution,Not operated,
IDE01442-MAS03831,Pressing a button-Upper body vent air distribution,Not operated,
IDE01442-MAS03832,Pressing a button-Air distribution up,Not operated,
IDE01442-MAS04605,Pressing a button-AC MAX,Not operated,
IDE01442-MAS17527,Pressing a button-Air Care,Not operated,
IDE01443,Left push-and-rotary knob counter,255,
IDE01444,Right push-and-rotary knob counter,255,
IDE02270-IDE01268,CAN input signal(s) status-Front windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management: shut-off stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamps,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02271-IDE00972,CAN output signal(s) status-Idle speed increase,not active,
IDE02271-MAS00130,CAN output signal(s) status-Compressor on,On,
IDE03008-MAS01564,Stop process prevented-Windshield defogger,not active,
IDE03008-MAS02802,Stop process prevented-Interior temperature difference to specifications,not active,
IDE03008-MAS02803,Stop process prevented-Interior vent difference to setting,not active,
IDE03008-MAS02804,Stop process prevented-Manual fan speed increase,not active,
IDE03008-MAS06551,Stop process prevented-Seat ventilation,not active,
IDE03008-MAS09538,Stop process prevented-max A/C,not active,
IDE03009-MAS01517,Start process requested-Defrost active,not active,
IDE03009-MAS01564,Start process requested-Windshield defogger,not active,
IDE03009-MAS02802,Start process requested-Interior temperature difference to specifications,not active,
IDE03009-MAS02803,Start process requested-Interior vent difference to setting,not active,
IDE03009-MAS02804,Start process requested-Manual fan speed increase,not active,
IDE03009-MAS04353,Start process requested-Fogging hazard (humidity sensor),not active,
IDE03009-MAS04354,Start process requested-Interior comfort humidity too high (humidity sensor),not active,
IDE03009-MAS05047,Start process requested-Maximum cooling and heating set,not active,
IDE03009-MAS06551,Start process requested-Seat ventilation,not active,
IDE03009-MAS09538,Start process requested-max A/C,not active,
IDE03010-MAS00478,Number of prevented stop processes-Reserved,0,
IDE03010-MAS01517,Number of prevented stop processes-Defrost active,0,
IDE03010-MAS01564,Number of prevented stop processes-Windshield defogger,0,
IDE03010-MAS02802,Number of prevented stop processes-Interior temperature difference to specifications,0,
IDE03010-MAS02803,Number of prevented stop processes-Interior vent difference to setting,0,
IDE03010-MAS02804,Number of prevented stop processes-Manual fan speed increase,0,
IDE03010-MAS04353,Number of prevented stop processes-Fogging hazard (humidity sensor),0,
IDE03010-MAS04354,Number of prevented stop processes-Interior comfort humidity too high (humidity sensor),0,
IDE03010-MAS05047,Number of prevented stop processes-Maximum cooling and heating set,0,
IDE03010-MAS06551,Number of prevented stop processes-Seat ventilation,0,
IDE03010-MAS09538,Number of prevented stop processes-max A/C,0,
IDE03011-MAS00478,Number of requested start processes-Reserved,0,
IDE03011-MAS01517,Number of requested start processes-Defrost active,0,
IDE03011-MAS01564,Number of requested start processes-Windshield defogger,0,
IDE03011-MAS02802,Number of requested start processes-Interior temperature difference to specifications,0,
IDE03011-MAS02803,Number of requested start processes-Interior vent difference to setting,0,
IDE03011-MAS02804,Number of requested start processes-Manual fan speed increase,0,
IDE03011-MAS04353,Number of requested start processes-Fogging hazard (humidity sensor),0,
IDE03011-MAS04354,Number of requested start processes-Interior comfort humidity too high (humidity sensor),0,
IDE03011-MAS05047,Number of requested start processes-Maximum cooling and heating set,0,
IDE03011-MAS06551,Number of requested start processes-Seat ventilation,0,
IDE03011-MAS09538,Number of requested start processes-max A/C,0,
IDE03127,Prevented stop processes (ring memory),Stop release,
IDE03128,Requested start processes (ring memory),Stop release,
IDE03214,Engine stop using start-stop function,not active,
IDE03215,Engine start using start-stop function,not active,
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE04312-IDE04095,System run time-Engine running time,253, s
IDE04312-MAS00084,System run time-Terminal 15 on,253, s
IDE04797,Center push-and-rotary knob counter,255,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-MAS01447,Driving profile selection-Actual value,2,
IDE04805-MAS01448,Driving profile selection-Specified value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05725,Dimmer terminal 58xs,100, %
IDE05726,Dimmer terminal 58xd,253,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,39.1, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,39.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,29.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,18.1, °C
IDE06234-IDE01270,Auxiliary heater: in stages-Enabling for auxiliary heater operation,Enabling stage 3,
IDE06234-MAS01447,Auxiliary heater: in stages-Actual value,1,
IDE06234-MAS01448,Auxiliary heater: in stages-Specified value,0,
IDE06234-MAS04992,Auxiliary heater: in stages-Specified value for control,0,
IDE07991,A/C clutch,active,
IDE12141-MAS02526,History memory: parking heater-Activation,Unknown (15)
IDE12141-MAS04390,History memory: parking heater-Active source,Unknown (15)
IDE12141-ENG98504,History memory: parking heater-Day,31,
IDE12141-ENG98653,History memory: parking heater-Hour,31,
IDE12141-ENG98739,History memory: parking heater-Minute,63,
IDE12141-ENG98748,History memory: parking heater-Month,15,
IDE12141-ENG98884,History memory: parking heater-Seconds,63,
IDE12141-ENG99063,History memory: parking heater-Year,2127,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine is running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
MAS00464-ENG98504,Standard - ambient data 1-Day,19,
MAS00464-ENG98653,Standard - ambient data 1-Hour,10,
MAS00464-ENG98739,Standard - ambient data 1-Minute,19,
MAS00464-ENG98748,Standard - ambient data 1-Month,8,
MAS00464-ENG98884,Standard - ambient data 1-Seconds,57,
MAS00464-ENG99063,Standard - ambient data 1-Year,2026,
ENG101413,Calibration Identifications,2GJ044L 03060000,
ENG99697,Calibration Verification Numbers,41 E4 2A 47,
ENG102274,Control Module Voltage,14.300, V
ENG100152-ENG104003,ECUNAME-ECU,HVAC,
ENG100152,ECUNAME,HVACCtrl,
Elapsed Time: 00:16
;SW:5Q1-937-085-C HW:5Q1-937-085-C --- 09: Cent. Elect.
;Component:BCM MQBAB HLN H56 0711, Coding:
;EV_BCMMQB,023001,EV_BCMBOSCH_023.rod
;Wednesday,19,August,2026,10:24:06:58926
;VCID: 3A265CFE2CD1FB3AD06-806E-R SFD+SFD2 {x}
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,No communication,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,No communication,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Adaptive Cruise Control,No communication,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,No communication,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,No communication,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,No communication,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,No communication,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Abort,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,No communication,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,No communication,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,No communication,
IDE00374-MAS05377,Electric auxiliary heater: relay activation-Low heat output relay,not coded / not installed,
IDE00374-MAS05378,Electric auxiliary heater: relay activation-High heat output relay,not coded / not installed,
IDE00844-MAS07314,Switch for hood-Status engine hood contact,closed,
IDE00844-ENG122175,Switch for hood-Bonnet_Magnetic_Lock,Measuring value not available,
IDE00973,Outside temperature,26.50, °C
IDE01066-IDE02092,Convertible top status-Tailgate condition,not coded / not installed,
IDE01066,Convertible top status,not coded / not installed,
IDE01464-IDE04741,Rear window defogger-Rear window defogger button,Not operated,
IDE01464-IDE04744,Rear window defogger-Rear window defogger indicator lamp,OFF,
IDE01537-IDE04742,Windshield defogger-Windshield defogger button,not coded / not installed,
IDE01537-IDE04743,Windshield defogger-Windshield defogger indicator lamp,not coded / not installed,
IDE01537-MAS01580,Windshield defogger-Activation,not coded / not installed,
IDE01943,Turn signal lamp,|Connector number,Connector terminal number
IDE02092-IDE02093,Tailgate condition-Status of rear lid lock,not coded / not installed,
IDE02092-IDE02133,Tailgate condition-Activation using rear lid unlock button,OFF,
IDE02092-MAS01872,Tailgate condition-Rear lid remote release button,Not operated,
IDE02092-MAS02405,Tailgate condition-Pre-engagement contact for rotary latch,not coded / not installed,
IDE02092-MAS02447,Tailgate condition-Activation,not enabled,
IDE02092-MAS06265,Tailgate condition-Release button in rear lid handle,Not operated,
IDE02092-MAS06430,Tailgate condition-Main notch contact of rotary latch,Closed,
IDE02488-MAS01632,Anti-theft system interior monitoring-Status,not coded / not installed,
IDE02488-MAS04508,Anti-theft system interior monitoring-Alarm detected,not coded / not installed,
IDE02515,Low beams,|Connector number,Connector terminal number
IDE02588-IDE00020,Terminal signals and start release-Terminal 15 status,active,
IDE02588-IDE00773,Terminal signals and start release-Terminal 15 status via CAN,active,
IDE02588-IDE01351,Terminal signals and start release-Terminal 75 status,On,
IDE02588-IDE01715,Terminal signals and start release-Status terminal S,active,
IDE02588-IDE01716,Terminal signals and start release-Terminal 50 status,OFF,
IDE02588-IDE06027,Terminal signals and start release-Terminal S status via CAN,active,
IDE02588-MAS12787,Terminal signals and start release-Terminal 15 ignition switch signal 1,active,
IDE02588-MAS12788,Terminal signals and start release-Terminal 15 ignition switch signal 2,active,
IDE02614-MAS02788,Reversing light switch-CAN,not coded / not installed,
IDE02614-MAS05360,Reversing light switch-Discreet wire,not active,
IDE02711,Rear wiper,not coded / not installed,
IDE02743,Main beam,|Connector number,Connector terminal number
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Not operated,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,81,
IDE02857-IDE03111,Activation current-Interior lighting,32, mA
IDE02857-IDE05533,Activation current-Heater for nozzles,2, mA
IDE02857-IDE06012,Activation current-Background lighting,48, mA
IDE02857-MAS01554,Activation current-Left heated seat,0, mA
IDE02857-MAS01556,Activation current-Right heated seat,0, mA
IDE02857-ENG128454,Activation current-Cockpittaster_1,No malfunction,
IDE02857-ENG128455,Activation current-Cockpittaster_2,No malfunction,
IDE02857-ENG128456,Activation current-Cockpittaster_3,No malfunction,
IDE02857-ENG128457,Activation current-Cockpittaster_4,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,0, mV
IDE02857-ENG126436,Activation current-signal_horn,65533, mV
IDE02957,Ambient lighting,|Channel,Connector number
IDE03111,Interior lighting,|Connector number,Connector terminal number
IDE03195-IDE03854,High values for automatic vertical headlight aim-Left front level control system sensor: height value current,0.0,
IDE03195-IDE04144,High values for automatic vertical headlight aim-Left rear level control system sensor: height value current,0.0,
IDE03195-IDE07143,High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage,18.4, V
IDE03195-MAS13964,High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor,127.5,
IDE03195-MAS13965,High values for automatic vertical headlight aim-Vehicle level sensor: control voltage,14.4, V
IDE03310,Brake lamp,|Connector number,Connector terminal number
IDE03388-IDE01217,Left front heated seat: status-Left heated seat stage,OFF,
IDE03388-MAS02201,Left front heated seat: status-Temperature,34.50, °C
IDE03389-IDE01218,Right front heated seat: status-Right heated seat stage,OFF,
IDE03389-MAS02201,Right front heated seat: status-Temperature,34.50, °C
IDE03638,Static cornering light,|Connector number,Connector terminal number
IDE04213,Central locking button,not coded / not installed,
IDE04213-IDE07357,Central locking button-Indicator lamp for central locking,not coded / not installed,
IDE04254-MAS06517,Play protection for central locking-Rear spoiler counter,not active,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE02515,Expanded freeze frame conditions-Low beams,operated,
IDE04347-IDE04639,Expanded freeze frame conditions-Last wake-up cause,Radio telegram: valid,
IDE04347-IDE07956,Expanded freeze frame conditions-redundant signal line,infinite,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,26.5, °C
IDE04347-MAS02462,Expanded freeze frame conditions-Automatic high beam assist,Not operated,
IDE04347-MAS02788,Expanded freeze frame conditions-CAN,On,
IDE04347-MAS03835,Expanded freeze frame conditions-Position lamps,Not operated,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.4, V
IDE04347-MAS06466,Expanded freeze frame conditions-Parking light left,Not operated,
IDE04347-MAS06467,Expanded freeze frame conditions-Parking light right,Not operated,
IDE04347-MAS14232,Expanded freeze frame conditions-Light switch: zero setting,Not operated,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,OFF,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,OFF,
IDE04925,Daytime running lamps,|Connector number,Connector terminal number
IDE05042-MAS03873,Emergency flasher button-Pulse duty factor,17.50, %
IDE05045-IDE05183,Front wiper module-Malfunction left,not coded / not installed,
IDE05045-IDE05184,Front wiper module-Malfunction right,not coded / not installed,
IDE05045-MAS03638,Front wiper module-Wipe speed,0, /min
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,29700,
IDE05045-MAS05878,Front wiper module-level,Stage 1,
IDE05323,Fog lamp,|Connector number,Connector terminal number
IDE05434,Rear entry light,|Connector number,Side
IDE05533,Heater for nozzles,not coded / not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded / not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not coded / not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05722-IDE02589,Door status: driver side rear-Rotary latch status,closed,
IDE05722-IDE04213,Door status: driver side rear-Central locking button,not coded / not installed,
IDE05722-MAS06256,Door status: driver side rear-Status door lock,Signal from door lock: engaged,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,Not operated,
IDE05727-MAS06256,Front passenger side door status-Status door lock,Signal from door lock: engaged,
IDE05729-IDE02589,Door status: frt. pass. side rear-Rotary latch status,closed,
IDE05729-IDE04213,Door status: frt. pass. side rear-Central locking button,not coded / not installed,
IDE05729-MAS06256,Door status: frt. pass. side rear-Status door lock,Signal from door lock: engaged,
IDE05730,Luggage compartment light,|Connector number,Connector terminal number
IDE05739,Footwell lamp,|Connector number,Connector terminal number
IDE05742-IDE02515,Light switch position-Low beams,operated,
IDE05742-IDE05323,Light switch position-Fog lamp,not coded / not installed,
IDE05742-IDE07956,Light switch position-redundant signal line,OFF,
IDE05742-MAS00063,Light switch position-OFF,Not operated,
IDE05742-MAS02462,Light switch position-Automatic high beam assist,Not operated,
IDE05742-MAS03835,Light switch position-Position lamps,Not operated,
IDE05742-MAS03836,Light switch position-Rear fog lamp,not coded / not installed,
IDE05822-MAS01632,Anti-theft alarm system vehicle inclination sensor-Status,not coded / not installed,
IDE05822-MAS04508,Anti-theft alarm system vehicle inclination sensor-Alarm detected,not coded / not installed,
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator lamp in button,not coded / not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded / not installed,
IDE05826-MAS01632,DWA Sirens / alarm horn for anti-theft warning system-Status,not coded / not installed,
IDE05826-MAS04508,DWA Sirens / alarm horn for anti-theft warning system-Alarm detected,No,
IDE05826-MAS04509,DWA Sirens / alarm horn for anti-theft warning system-Alarm activated,No,
IDE05827,Horn for anti-theft warning system,not coded / not installed,
IDE05833,Anti-theft warning system: history data,|Cause for alarm activation,kilometer reading
IDE05834-IDE01718,Driver info-Crash signal,not active,
IDE05834-MAS00212,Driver info-Washer fluid low,not active,
IDE05834-MAS00214,Driver info-Brake pad wear,not coded / not installed,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,not coded / not installed,
IDE05838-MAS02248,Light recognition sensor-Signal status,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,8000, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,6126, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE05839,Parking lamps,|Connector number,Connector terminal number
IDE05841,Central locking history data,|Control-section / cause,command_direction_locking
IDE05842,Comfort function history data,|Control-section / cause,Operating command
IDE06012,Background lighting,|Connector number,terminal
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,-38.4, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,39.5, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,30.0, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,-38.7, °C
IDE06096-IDE03111,Interior lights-Interior lighting,0, %
IDE06096-IDE05724,Interior lights-Dimmer terminal 58xt,88.0, %
IDE06096-IDE05725,Interior lights-Dimmer terminal 58xs,88.0, %
IDE06096-IDE05726,Interior lights-Dimmer terminal 58xd,125.0, %
IDE06096-MAS01634,Interior lights-Supply voltage,88.0, %
IDE06096-MAS04528,Interior lights-Instrument panel and switch illumination dimmer switch,100, %
IDE06324-IDE04217,Tank cap lock-Fuel filler door release button,not coded / not installed,
IDE06324-MAS01580,Tank cap lock-Activation,not active,
IDE06324-MAS06251,Tank cap lock-Contact switch,not coded / not installed,
IDE06470,Periphery lighting,|Connector number,Connector terminal number
IDE06507-MAS13127,Button in center console-Status of button 1,not coded / not installed,
IDE06507-MAS13128,Button in center console-Indicator lamp button 1,not coded / not installed,
IDE06507-MAS13130,Button in center console-Status of button 2,not coded / not installed,
IDE06507-MAS13131,Button in center console-Indicator lamp button 2,not coded / not installed,
IDE06507-MAS13133,Button in center console-Status of button 3,Not operated,
IDE06507-MAS13134,Button in center console-Indicator lamp button 3,On,
IDE06507-MAS13136,Button in center console-Indicator lamp button 4,not coded / not installed,
IDE06507-MAS13137,Button in center console-Status of button 4,not coded / not installed,
IDE06644-IDE06864,Vehicle positioning system-Daytime running lights,not coded / not installed,
IDE06644-MAS01288,Vehicle positioning system-Horn,not coded / not installed,
IDE06644-MAS03834,Vehicle positioning system-Emergency signal flashing,not coded / not installed,
IDE06644-MAS03835,Vehicle positioning system-Position lamps,not coded / not installed,
IDE06649-MAS05016,Wireless transmitter-Receiver status,not installed,
IDE06649-MAS05048,Wireless transmitter-Number of transmitters adapted,0,
IDE06649-ENG247157,Wireless transmitter-Kom.Schlüssel eFFB Handsender 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06649-ENG247187,Wireless transmitter-Kom.Schlüssel eFFB Handsender 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06695,Energy management: last critical state,|Energy management heat output control status,Maximum switch-off priority while driving
IDE06864,Daytime running lights,|Connector number,Connector terminal number
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,04,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,00,
IDE07187-MAS06538,Level control system sensor-Left Front Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06539,Level control system sensor-Left Rear Level Control System Sensor: PWM signal,655.35, %
IDE07187-MAS06540,Level control system sensor-Left front level control system sensor: frequency,6553.5, Hz
IDE07187-MAS06541,Level control system sensor-Left Rear Left Control System Sensor: frequency,6553.5, Hz
IDE07187-MAS06542,Level control system sensor-Vehicle level sensor: supply voltage,5.000, V
IDE07344-IDE00542,Sunroof shade-Excessive temperature protection,not active,
IDE07344-IDE03114,Sunroof shade-Comfort function,not active,
IDE07344-MAS01979,Sunroof shade-Adapting,Not adapted,
IDE07344-MAS02282,Sunroof shade-Position,126, %
IDE07344-MAS02447,Sunroof shade-Activation,not active,
IDE07344-MAS03656,Sunroof shade-Reverse,not active,
IDE07344-MAS05563,Sunroof shade-Standardization,not standardized,
IDE07345-MAS07997,Sunroof front closed position switch-Rotary switch activation,Not operated,
IDE07345,Sunroof front closed position switch,Not operated,
IDE07345-ENG122183,Sunroof front closed position switch-rotary_switch_position,Closed,
IDE07346,Sunroof shade switches,Not operated,
IDE08125-MAS01458,Left neck heater-Operating State,not coded / not installed,
IDE08125-MAS06651,Left neck heater-PTC heater element: current consumption,not coded / not installed,
IDE08125-MAS06652,Left neck heater-Blower motor: speed,not coded / not installed,
IDE08125-MAS06653,Left neck heater-Indicator light for head area heater,not coded / not installed,
IDE08126-MAS01458,Right neck heater-Operating State,not coded / not installed,
IDE08126-MAS06651,Right neck heater-PTC heater element: current consumption,not coded / not installed,
IDE08126-MAS06652,Right neck heater-Blower motor: speed,not coded / not installed,
IDE08126-MAS06653,Right neck heater-Indicator light for head area heater,not coded / not installed,
IDE08177-MAS06456,Central locking-Auto lock,not active,
IDE08177-MAS06740,Central locking-Release button in rear lid handle locked,not active,
IDE08177-MAS09894,Central locking-Status exterior skin,closed,
IDE08177-MAS09896,Central locking-Act. condition: Status central locking internal locked,not active,
IDE08177-MAS09897,Central locking-Act. condition: Status central locking external locked,not active,
IDE08177-MAS09898,Central locking-Act. condition: Status central locking safe,not active,
IDE08177-MAS09900,Central locking-Spec. condition: Status central lock,Vehicle unlocked at single door,
IDE08177-MAS13126,Central locking-Luggage hold closure,not coded / not installed,
IDE08343,Immobilizer Challenge,DA 5E 59 A6,
IDE08356-IDE00102,Left seat backrest fan 1-Control Module temperature,33, °C
IDE08356-MAS01447,Left seat backrest fan 1-Actual value,0, /min
IDE08356-MAS01634,Left seat backrest fan 1-Supply voltage,14, V
IDE08356-MAS09948,Left seat backrest fan 1-Pin coding. spec. value,7,
IDE08356-MAS09949,Left seat backrest fan 1-Pin coding. act. value,7,
IDE08356-MAS10342,Left seat backrest fan 1-No. of start-up attempts after blocking error,0,
IDE08358-IDE00102,Left seat cushion fan 1-Control Module temperature,28, °C
IDE08358-MAS01447,Left seat cushion fan 1-Actual value,0, /min
IDE08358-MAS01634,Left seat cushion fan 1-Supply voltage,14, V
IDE08358-MAS09948,Left seat cushion fan 1-Pin coding. spec. value,6,
IDE08358-MAS09949,Left seat cushion fan 1-Pin coding. act. value,6,
IDE08358-MAS10342,Left seat cushion fan 1-No. of start-up attempts after blocking error,0,
IDE08360-IDE00102,Right seat backrest fan 1-Control Module temperature,34, °C
IDE08360-MAS01447,Right seat backrest fan 1-Actual value,0, /min
IDE08360-MAS01634,Right seat backrest fan 1-Supply voltage,14, V
IDE08360-MAS09948,Right seat backrest fan 1-Pin coding. spec. value,3,
IDE08360-MAS09949,Right seat backrest fan 1-Pin coding. act. value,3,
IDE08360-MAS10342,Right seat backrest fan 1-No. of start-up attempts after blocking error,0,
IDE08362-IDE00102,Right seat cushion fan 1-Control Module temperature,27, °C
IDE08362-MAS01447,Right seat cushion fan 1-Actual value,0, /min
IDE08362-MAS01634,Right seat cushion fan 1-Supply voltage,14, V
IDE08362-MAS09948,Right seat cushion fan 1-Pin coding. spec. value,2,
IDE08362-MAS09949,Right seat cushion fan 1-Pin coding. act. value,2,
IDE08362-MAS10342,Right seat cushion fan 1-No. of start-up attempts after blocking error,0,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,2, mA
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,5, mA
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,480, mA
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,132, mA
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,936, mA
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,936, mA
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,0, mA
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,0, mA
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,82, mA
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,92, mA
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,144, mA
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,160, mA
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,324, mA
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,294, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,96, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,108, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,102, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,288, mA
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,258, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE09065-MAS07964,Status: remote start-Engine run time after remote start,0, s
IDE09065-MAS16464,Status: remote start-Number of RemoteStarts carried out,2,
IDE09850-MAS07146,Garage door opener control head-Button 1,not coded / not installed,
IDE09850-MAS07147,Garage door opener control head-Button 2,not coded / not installed,
IDE09850-MAS07148,Garage door opener control head-Button 3,not coded / not installed,
IDE11134-IDE01943,Light sequence HU test result-Turn signal lamp,Installed: not active,
IDE11134-IDE02515,Light sequence HU test result-Low beams,Installed: not active,
IDE11134-IDE02614,Light sequence HU test result-Reversing light switch,Installed: not active,
IDE11134-IDE02743,Light sequence HU test result-Main beam,Installed: not active,
IDE11134-IDE03310,Light sequence HU test result-Brake lamp,Installed: not active,
IDE11134-IDE03638,Light sequence HU test result-Static cornering light,Installed: not active,
IDE11134-IDE05323,Light sequence HU test result-Fog lamp,not installed / not active,
IDE11134-IDE05839,Light sequence HU test result-Parking lamps,not installed / not active,
IDE11134-IDE06470,Light sequence HU test result-Periphery lighting,not installed / not active,
IDE11134-IDE06864,Light sequence HU test result-Daytime running lights,Installed: not active,
IDE11134-MAS02354,Light sequence HU test result-Headlamp flasher,Installed: not active,
IDE11134-MAS03835,Light sequence HU test result-Position lamps,Installed: not active,
IDE11134-MAS03836,Light sequence HU test result-Rear fog lamp,not installed / not active,
IDE11134-MAS11025,Light sequence HU test result-Status,RESTRICTION,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,80, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,10, W/m²
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-cause:,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,6,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,7,
IDE11551-ENG303032,Status of identification data query on LIN-Bus-complete_config_hash,Yes,
IDE11551-ENG303033,Status of identification data query on LIN-Bus-complete_programming_hash,Yes,
IDE11551-ENG303064,Status of identification data query on LIN-Bus-slave_hash_valid,Yes,
IDE11668-MAS06256,Driver side rear sliding door: central locking signals-Status door lock,not coded / not installed,
IDE11668-MAS06431,Driver side rear sliding door: central locking signals-Door contact switch,not coded / not installed,
IDE11668-MAS06433,Driver side rear sliding door: central locking signals-Door lock: safe status,not coded / not installed,
IDE11669-MAS06256,Passenger side rear sliding door: central locking signals-Status door lock,not coded / not installed,
IDE11669-MAS06431,Passenger side rear sliding door: central locking signals-Door contact switch,not coded / not installed,
IDE11669-MAS06433,Passenger side rear sliding door: central locking signals-Door lock: safe status,not coded / not installed,
IDE11670-MAS06256,Rear wing door: central locking signals-Status door lock,not coded / not installed,
IDE11670-MAS06431,Rear wing door: central locking signals-Door contact switch,not coded / not installed,
IDE11670-MAS06433,Rear wing door: central locking signals-Door lock: safe status,not coded / not installed,
IDE11727-IDE04806,Function of the central console button-Driving profile selection button,LED installed,
IDE11727-MAS13125,Function of the central console button-Function of button 1,not coded / not installed,
IDE11727-MAS13129,Function of the central console button-Function of button 2,not coded / not installed,
IDE11727-MAS13132,Function of the central console button-Function of button 3,Driving program,
IDE11727-MAS13135,Function of the central console button-Function of button 4,not coded / not installed,
IDE11943,Signature lamp,|Connector number,Connector terminal number
IDE11999-IDE03853,High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted,-100.0,
IDE11999-IDE04143,High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted,-100.0,
IDE12060,Headlight range adjustment counter,00 00 00 00,
IDE12212,Cause control module incorrectly coded,Not available,
IDE12940-IDE01268,Lever functions of the steering column electronics-Front windshield wiper,Not operated,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,Not operated,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,Not operated,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,Not operated,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,Not operated,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,Not operated,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,Not operated,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,No malfunction detected,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,Not operated,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,Stage 4,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,Not operated,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,Not operated,
IDE12940,Lever functions of the steering column electronics,Not operated,
IDE14095-MAS17564,Wiper park position heater-Relay actuation,not coded / not installed,
IDE14110-MAS17842,Digital Key-NFC control section,not coded / not installed,
IDE14110-MAS17843,Digital Key-Bluetooth control section,not coded / not installed,
IDE14172-MAS03692,Remote key movement information-Key 1,Movement sensor faulty,
IDE14172-MAS03693,Remote key movement information-Key 2,not inoperative,
IDE14172-MAS03694,Remote key movement information-Key 3,Movement sensor faulty,
IDE14172-MAS03695,Remote key movement information-Key 4,Movement sensor faulty,
IDE14963-MAS19705,Remote start: current operating parameters-Captcha List,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE14963-MAS19706,Remote start: current operating parameters-Communication key,00 00 00 00 00 00 00 00,
IDE80251-MAS06439,Neck heating-Crash status,not coded / not installed,
IDE80251-MAS06646,Neck heating-Head area heater left: specified level,not coded / not installed,
IDE80251-MAS06647,Neck heating-Head area heater right: specified level,not coded / not installed,
IDE80251-MAS06648,Neck heating-Continuation at terminal 15 on,not coded / not installed,
IDE80251-MAS06649,Neck heating-Left front seat occupation status,not coded / not installed,
IDE80251-MAS06650,Neck heating-Right front occupation status,not coded / not installed,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.45, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.40, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.40, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.40, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00043-IDE08735,Terminal 30 power supply-Supply voltage for seat heater,14.40, V
MAS00043-MAS00362,Terminal 30 power supply-Battery voltage,5.00, V
MAS00043-MAS07472,Terminal 30 power supply-Battery voltage BEM,14.45, V
MAS00043-MAS07473,Terminal 30 power supply-Test voltage rear window defogger,0.00, V
MAS00043-MAS07474,Terminal 30 power supply-Test voltage windshield defogger,0.00, V
MAS00043-MAS21998,Terminal 30 power supply-Test voltage for wiper tray heater,0.00, V
MAS00179-MAS04422,Brake lamp switch-Brake light signal via CAN,OFF,
MAS00179-MAS07313,Brake lamp switch-Brake light signal via HW,OFF,
MAS00464-MAS00106,Standard - ambient data 1-Year,2026,
MAS00464-MAS00107,Standard - ambient data 1-Month,8,
MAS00464-MAS00108,Standard - ambient data 1-Day,19,
MAS00464-MAS00109,Standard - ambient data 1-Hours,10,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,21,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,16,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,68,
MAS00464-MAS00711,Standard - ambient data 1-kilometer reading,11476, km
MAS00829-MAS00244,Access/start authorization-Wake-up wire,operated,
MAS00829-MAS01763,Access/start authorization-Field intensity,-68,
MAS00829-MAS07866,Access/start authorization-Duration: last awakening wire actua.,0, ms
MAS01281,Back-up lamps,|Connector number,Connector terminal number
MAS01431-IDE01442,Vehicle key with remote control-Pressing a button,Not operated,
MAS01431-IDE01839,Vehicle key with remote control-Battery charge status,Not available,
MAS01431-MAS00077,Vehicle key with remote control-Immobilizer,NOT-DEFINED,
MAS01431-MAS01551,Vehicle key with remote control-Key number,255,
MAS01431-MAS05048,Vehicle key with remote control-Number of transmitters adapted,2,
MAS01431-MAS06362,Vehicle key with remote control-Code in catch area,Not available,
MAS01490-IDE02744,Energy management-Steering wheel heating,Enabled,
MAS01490-IDE04216,Energy management-Mirror heater,Enabled,
MAS01490-IDE80251,Energy management-Neck heating,Enabling stage 3,
MAS01490-MAS01535,Energy management-Rear window defogger,Enabled,
MAS01490-MAS01563,Energy management-Auxiliary Air Heater,Enabling stage 3,
MAS01490-MAS01564,Energy management-Windshield defogger,Enabled,
MAS01490-MAS01632,Energy management-Status,not active,
MAS01490-MAS02390,Energy management-Shutoff,3,
MAS01490-MAS05795,Energy management-Rear seat heating,Enabled,
MAS01490-MAS05796,Energy management-Emergency shut-off,0,
MAS01490-MAS05887,Energy management-Battery cut out relay 2,not enabled,
MAS01490-MAS06551,Energy management-Seat ventilation,Enabled,
MAS01490-MAS06552,Energy management-Seat heating: front,Enabling stage 3,
MAS01490-MAS06553,Energy management-Display consumer switch-off,not active,
MAS01490-MAS06554,Energy management-Switch-off priority while driving,0,
MAS01490-MAS06555,Energy management-Maximum switch-off priority while driving,0,
MAS01490-MAS06556,Energy management-Switch-off with voltage drops,0,
MAS01490-MAS06557,Energy management-Switch-off priority with vehicle crash,0,
MAS01490-MAS06558,Energy management-Current negative charge balance,0, %
MAS01490-MAS06559,Energy management-Switch-off priority with engine off,0,
MAS01490-MAS06560,Energy management-Short distance driving,0,
MAS01597-IDE00542,Sunroof-Excessive temperature protection,not active,
MAS01597-IDE03114,Sunroof-Comfort function,not active,
MAS01597-MAS01979,Sunroof-Adapting,Not adapted,
MAS01597-MAS02282,Sunroof-Position,126, %
MAS01597-MAS02447,Sunroof-Activation,not active,
MAS01597-MAS03656,Sunroof-Reverse,not active,
MAS01597-MAS05563,Sunroof-Standardization,not standardized,
MAS01597-MAS05737,Sunroof-Position,Tilt out posi.,
MAS03835,Position lamps,|Connector number,Connector terminal number
MAS03836,Rear fog lamp,|Connector number,Connector terminal number
MAS07959,Remote start history data,|Stop or cancel cause,Cause for cancellation
MAS08202-MAS09607,CAN p locked-Switch p locked,Malfunction,
MAS08202-MAS09608,CAN p locked-SMLS p locked plausibility,Implausible,
MAS08228-MAS01632,Light sensor-Status,not coded / not installed,
MAS08228-MAS02851,Light sensor-Brightness,22860, lx
MAS08228-MAS04121,Light sensor-Voltage,25.4, V
MAS13141,Test voltage,0, V
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18843,SE references from last used digital key devices,|Secure_element_reference_state,Secure_element_reference
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,1,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,gueltiges Funktelegramm,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG247080-IDE10662,light_swich_module-Light switch (button module),not coded / not installed,
ENG247080-MAS17838,light_swich_module-Exterior lighting: global shutoff,not coded / not installed,
ENG128380,Parametermonitor_0,00 00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116806,Parametermonitor_1,00 14 64 64 00 78 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116807,Parametermonitor_2,50 50 32 32 50 50 50 50 50 50 50 50 00 00 01 00 00 0A 00 1E 00 00 00 03 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115827,Parametermonitor_3-parameter_monitor_3_climatic,06 06 00 00 3C 03 1E 22 00 00 19 05 00 01 01 28 02 00 02 00 64 00 05 00 1E 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116808-ENG115828,Parametermonitor_3-parameter_monitor_3_wiper,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116809,Parametermonitor_4,26 1D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116810,Parametermonitor_5,5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116811,Parametermonitor_6,0A 1E 3C 42 0F 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116911,Parametermonitor_7,63 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG130589-MAS16304,Remotestart_Monitor-Number of driver takeovers from RemoteStart,0,
ENG130589-MAS16305,Remotestart_Monitor-Number of duplicate activations,0,
ENG130589-MAS16306,Remotestart_Monitor-Number of incorrect takeovers,0,
ENG130589-MAS16307,Remotestart_Monitor-Average running time: group 1,0,
ENG130589-MAS16308,Remotestart_Monitor-Average running time: group 2,0,
ENG130589-MAS16309,Remotestart_Monitor-Average running time: group 3,0,
ENG130589-MAS16333,Remotestart_Monitor-Number of RemoteStarts,0,
ENG130589-MAS16334,Remotestart_Monitor-RemoteStart cancellations counter,0,
ENG250298-IDE00104,Specific_ambient_conditions-DTC,03 1E 05,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 03 0D 00 0D 00 1A 00 1A 00 1A 00 65 00 03 28 00 00 00 00 00 00 00 00 00 00 00 00 00 88 00 02 00 05 76 38 00 00 07 15 00 00 00 03 00 00 00 00 00 00 00 00 05 0F 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 0A 06 0B 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 61 00 00 00 00 00 00 4A 64 06 12 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 04 00 00 01 04 00 00 01 00 20 00 00 00 00 04 4C 28 74 00 20 00 00 40 0A 02 02 7B 1F 00 00 00 C4 C4 48 00 3B 00 00 00 00 00 00 00 00 00 00 01 00 03 04 00 00 00 00 00 00 00 00 7A 00 00 00 00 8F,
ENG127111-ENG127149,Valeo_Entwickler_MWB-Batterie_Spannung_KL_15,0.0, V
ENG127111-ENG127148,Valeo_Entwickler_MWB-Batterie_Spannung_KL_30,0.0, V
ENG127111-ENG127156,Valeo_Entwickler_MWB-GRA leitung,0,
ENG127111-ENG161085,Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall,00 00 00 00 8F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG127111-ENG98652,Valeo_Entwickler_MWB-Horn,OFF,
ENG127111-ENG161099,Valeo_Entwickler_MWB-Lenkrad Heizung,0,
ENG127111-ENG161147,Valeo_Entwickler_MWB-Resetmonitor,0,
ENG127111-ENG127158,Valeo_Entwickler_MWB-U12V_SW2,0,
ENG127111-ENG161254,Valeo_Entwickler_MWB-WakeUp2,OFF,
Elapsed Time: 01:46
;SW:2Q0-907-567-C HW:2Q0-907-819 --- 13: Auto Dist. Reg
;Component:ACCCONTIMQB H04 0541, Coding:280200C158FF8748949C812460409700000000000000004034
;EV_ACCMRRCONTIUNECEMQB,004021,EV_ACCMRRCONTIUNECEMQB_VW27.rod
;Wednesday,19,August,2026,10:25:57:58926
;VCDS Version: 26.7.2.1 (x64) Data version: 20260708 DS378.0
;VCID: 382246F612DDE92A262-806C-R SFD+SFD2 {x}
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,14.4, V
IDE00075,Vehicle speed,0.00, m/s
IDE00102,Control Module temperature,47, °C
IDE00391,Adaptive distance regulation: status,ACC_Off_MainSwitch_Off,
IDE01794-ENG161032,ACC operating lever signal-ACC_main_switch,Not operated,
IDE01794-ENG98480,ACC operating lever signal-Cancel,Not operated,
IDE01794-ENG161043,ACC operating lever signal-Control_lever_coding,ACC,
IDE01794-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
IDE01794-ENG161056,ACC operating lever signal-distance_control_minus,Not operated,
IDE01794-ENG161057,ACC operating lever signal-distance_control_plus,Not operated,
IDE01794-ENG161132,ACC operating lever signal-part_control_lever,VW_MFL_Gen2,
IDE01794-ENG159615,ACC operating lever signal-Resume,Not operated,
IDE01794-ENG98911,ACC operating lever signal-Set,Not operated,
IDE01794-ENG161234,ACC operating lever signal-tip_down_in_step_1,Not operated,
IDE01794-ENG161235,ACC operating lever signal-tip_down_in_step_2,Not operated,
IDE01794-ENG161236,ACC operating lever signal-tip_up_in_step_1,Not operated,
IDE01794-ENG161237,ACC operating lever signal-tip_up_in_step_2,Not operated,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,4A 5F E9 EF,
IDE03008-MAS12557,Stop process prevented-Vehicle ahead approaching: ACC active: automatic drive-off disabled,not active,
IDE03008-MAS12559,Stop process prevented-Vehicle ahead approaching: ACC passive,not active,
IDE03008-MAS12560,Stop process prevented-Vehicle ahead approaching: ACC OFF,not active,
IDE03008-MAS16236,Stop process prevented-Vehicle ahead approaching: ECC not coded,not active,
IDE03010-MAS12557,Number of prevented stop processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03010-MAS12559,Number of prevented stop processes-Vehicle ahead approaching: ACC passive,0,
IDE03010-MAS12560,Number of prevented stop processes-Vehicle ahead approaching: ACC OFF,0,
IDE03010-MAS16236,Number of prevented stop processes-Vehicle ahead approaching: ECC not coded,0,
IDE03011-MAS12557,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off disabled,0,
IDE03011-MAS12558,Number of requested start processes-Vehicle ahead approaching: ACC active: automatic drive-off possible,0,
IDE03011-MAS12559,Number of requested start processes-Vehicle ahead approaching: ACC passive,0,
IDE03011-MAS12560,Number of requested start processes-Vehicle ahead approaching: ACC OFF,0,
IDE03011-MAS16236,Number of requested start processes-Vehicle ahead approaching: ECC not coded,0,
IDE03660,Longitudinal acceleration,0.06, m/s²
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04805-MAS01447,Driving profile selection-Actual value,3,
IDE04805-MAS01448,Driving profile selection-Specified value,3,
IDE05228,Operating hour counter,16142, min
IDE05814,Individualization characteristic,98 D5 40 8E 6A,
IDE06307-MAS00106,Stop prevention history data-Year,2127,
IDE06307-MAS00107,Stop prevention history data-Month,15,
IDE06307-MAS00108,Stop prevention history data-Day,31,
IDE06307-MAS00109,Stop prevention history data-Hours,31,
IDE06307-MAS00110,Stop prevention history data-Minutes,63,
IDE06307-MAS00111,Stop prevention history data-Seconds,63,
IDE06307-MAS16236,Stop prevention history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06307,Stop prevention history data,Vehicle ahead approaching: ACC OFF,
IDE06307,Stop prevention history data,Vehicle ahead approaching: ACC passive,
IDE06307,Stop prevention history data,Vehicle ahead approaching: ACC active: automatic drive-off disabled,
IDE06308-MAS00106,Start request history data-Year,2127,
IDE06308-MAS00107,Start request history data-Month,15,
IDE06308-MAS00108,Start request history data-Day,31,
IDE06308-MAS00109,Start request history data-Hours,31,
IDE06308-MAS00110,Start request history data-Minutes,63,
IDE06308-MAS00111,Start request history data-Seconds,63,
IDE06308-MAS16236,Start request history data-Vehicle ahead approaching: ECC not coded,Vehicle ahead approaching: ECC not coded,
IDE06308,Start request history data,Vehicle ahead approaching: ACC active: automatic drive-off disabled,
IDE06308,Start request history data,Vehicle ahead approaching: ACC active: automatic drive-off possible,
IDE06308,Start request history data,Vehicle ahead approaching: ACC OFF,
IDE06308,Start request history data,Vehicle ahead approaching: ACC passive,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE08936,Misalignment angle: horiz,-0.544, °
IDE09380-IDE01784,Performed adjustment-Misalignment angle,0.00, °
IDE09380-MAS00106,Performed adjustment-Year,2025,
IDE09380-MAS00107,Performed adjustment-Month,2,
IDE09380-MAS00108,Performed adjustment-Day,5,
IDE09380-MAS05610,Performed adjustment-Calibration,static,
IDE09380-MAS08804,Performed adjustment-Horizontal offset angle,-0.55, °
IDE09380-MAS08805,Performed adjustment-Vertical offset angle,0.07, °
IDE09906,Vertical deadjustment,-0.230, °
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11923-MAS13423,Number of calibration procedures-Counter for statistical calibration procedures started,1,
IDE11923-MAS13424,Number of calibration procedures-Counter for statistical calibration procedures successful,1,
IDE11923-MAS13425,Number of calibration procedures-Counter for dynamical calibration procedures started,0,
IDE11923-MAS13426,Number of calibration procedures-Counter for dynamical calibration procedures successful,0,
IDE11924-MAS13427,Correction angle-Horizontal correction angle: dynamic,0.000, °
IDE11924-MAS13428,Correction angle-Vertical correction angle: dynamic,0.000, °
IDE11924-MAS13429,Correction angle-Horizontal correction angle: currently,-0.540, °
IDE11924-MAS13430,Correction angle-Vertical correction angle: currently,-0.230, °
IDE11924-MAS13887,Correction angle-Horizontal correction angle static,-0.540, °
IDE11924-MAS13888,Correction angle-Vertical correction angle static,0.070, °
IDE12062,Counter for terminal 15 reset,1215,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE14211,extended memory range,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1719,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via SWaP,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,BF FF,
ENG139711,Freeze_Frame_Dataset_Fct_1_Evt_Last,B0 34 ED 4E 6E 4F 00 90 3E D0 13 BA 1A 1E 00 00 00 4F FF 01 00 2B FE 68 00 26 00 3F 04 18 03 02 70 1F 00 00 00 00 00 00 00 FF FF 02 01 0A 00 68 00 28 FF 0A 81 09,
ENG139710,Freeze_Frame_Dataset_Fct_1_Evt_Prev,90 34 66 44 AE 4A 40 D3 3C 50 9F A1 1A 00 01 FE FE 38 FD FB 00 50 F7 41 04 4E 00 3F 03 13 06 02 70 00 01 FE FE 00 01 FD FD FD FD FB FA 02 00 41 00 50 F7 00 81 00,
ENG139729,Freeze_Frame_Dataset_Fct_10_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139728,Freeze_Frame_Dataset_Fct_10_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139731,Freeze_Frame_Dataset_Fct_11_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139730,Freeze_Frame_Dataset_Fct_11_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139733,Freeze_Frame_Dataset_Fct_12_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139732,Freeze_Frame_Dataset_Fct_12_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139735,Freeze_Frame_Dataset_Fct_13_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139734,Freeze_Frame_Dataset_Fct_13_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139737,Freeze_Frame_Dataset_Fct_14_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139736,Freeze_Frame_Dataset_Fct_14_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139739,Freeze_Frame_Dataset_Fct_15_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139738,Freeze_Frame_Dataset_Fct_15_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139741,Freeze_Frame_Dataset_Fct_16_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139740,Freeze_Frame_Dataset_Fct_16_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139713,Freeze_Frame_Dataset_Fct_2_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139712,Freeze_Frame_Dataset_Fct_2_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139715,Freeze_Frame_Dataset_Fct_3_Evt_Last,B0 34 ED 56 6E 4F 00 90 3E D0 13 BA 1A 00 34 05 05 4E F9 0F 00 24 FE 5F 00 21 00 3F 04 17 03 02 70 00 35 05 05 00 34 04 FF F9 F3 12 0F 00 01 5F 02 24 FE 00 81 00,
ENG139714,Freeze_Frame_Dataset_Fct_3_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139717,Freeze_Frame_Dataset_Fct_4_Evt_Last,B0 34 ED 4E 6E 4F 00 90 3E D0 13 BA 1A 00 00 00 00 4F FF 01 00 28 FF 62 00 1D 00 3F 04 18 03 03 70 00 39 05 10 00 00 00 00 FF F9 0F 00 08 01 62 02 24 FE 07 81 00,
ENG139716,Freeze_Frame_Dataset_Fct_4_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139719,Freeze_Frame_Dataset_Fct_5_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139718,Freeze_Frame_Dataset_Fct_5_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139721,Freeze_Frame_Dataset_Fct_6_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139720,Freeze_Frame_Dataset_Fct_6_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139723,Freeze_Frame_Dataset_Fct_7_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139722,Freeze_Frame_Dataset_Fct_7_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139725,Freeze_Frame_Dataset_Fct_8_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139724,Freeze_Frame_Dataset_Fct_8_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139727,Freeze_Frame_Dataset_Fct_9_Evt_Last,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139726,Freeze_Frame_Dataset_Fct_9_Evt_Prev,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254667,Freeze_Frame_Dataset_Sensor_01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254668,Freeze_Frame_Dataset_Sensor_02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254669,Freeze_Frame_Dataset_Sensor_03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254670,Freeze_Frame_Dataset_Sensor_04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254671,Freeze_Frame_Dataset_Sensor_05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254672,Freeze_Frame_Dataset_Sensor_06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254673,Freeze_Frame_Dataset_Sensor_07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254674,Freeze_Frame_Dataset_Sensor_08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254675,Freeze_Frame_Dataset_Sensor_09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254676,Freeze_Frame_Dataset_Sensor_10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254677,Freeze_Frame_Dataset_Sensor_11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254678,Freeze_Frame_Dataset_Sensor_12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254679,Freeze_Frame_Dataset_Sensor_13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254680,Freeze_Frame_Dataset_Sensor_14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254681,Freeze_Frame_Dataset_Sensor_15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG139742,Freeze_Frame_Fct_1_Cnt,3,
ENG139751,Freeze_Frame_Fct_10_Cnt,0,
ENG139752,Freeze_Frame_Fct_11_Cnt,0,
ENG139753,Freeze_Frame_Fct_12_Cnt,0,
ENG139754,Freeze_Frame_Fct_13_Cnt,0,
ENG139755,Freeze_Frame_Fct_14_Cnt,0,
ENG139756,Freeze_Frame_Fct_15_Cnt,0,
ENG139757,Freeze_Frame_Fct_16_Cnt,0,
ENG139758,Freeze_Frame_Fct_17_Cnt,0,
ENG139743,Freeze_Frame_Fct_2_Cnt,0,
ENG139744,Freeze_Frame_Fct_3_Cnt,1,
ENG139745,Freeze_Frame_Fct_4_Cnt,1,
ENG139746,Freeze_Frame_Fct_5_Cnt,0,
ENG139747,Freeze_Frame_Fct_6_Cnt,0,
ENG139748,Freeze_Frame_Fct_7_Cnt,0,
ENG139749,Freeze_Frame_Fct_8_Cnt,0,
ENG139750,Freeze_Frame_Fct_9_Cnt,0,
ENG254703,Freeze_Frame_Indikator_Temp_Cnt_01,0,
ENG254704,Freeze_Frame_Indikator_Temp_Cnt_02,0,
ENG254705,Freeze_Frame_Indikator_Temp_Cnt_03,0,
ENG254706,Freeze_Frame_Indikator_Temp_Cnt_04,0,
ENG254707,Freeze_Frame_Indikator_Temp_Cnt_05,0,
ENG254708,Freeze_Frame_Indikator_Temp_Cnt_06,0,
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,0, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,77, s
ENG254709,Freeze_Frame_Indikator_Time_Cnt_01,792707, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,15, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,2, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,651673, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,16, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,5, s
ENG254710,Freeze_Frame_Indikator_Time_Cnt_02,24, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,0, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,285639, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,444, s
ENG254711,Freeze_Frame_Indikator_Time_Cnt_03,14, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,0, s
ENG254712,Freeze_Frame_Indikator_Time_Cnt_04,912462, s
ENG254713,Freeze_Frame_Indikator_Time_Cnt_05,0, s
ENG254714,Freeze_Frame_Indikator_Time_Cnt_06,0, s
ENG254715,Freeze_Frame_Sensor_Blind_decision,0,
ENG254716,Freeze_Frame_Sensor_Blind_decision_Time,0, s
ENG254716,Freeze_Frame_Sensor_Blind_decision_Time,792171, s
ENG254716,Freeze_Frame_Sensor_Blind_decision_Time,77, s
ENG131998,Number_of_boost_function_active,0,
ENG131999,Number_of_deactivation_ASR_active,0,
ENG132000,Number_of_deactivation_ESC_active,0,
ENG107928,Operating_time_ACC,0, min
ENG131991,Operating_time_ACC_active_driving_programm_auto,0, min
ENG131990,Operating_time_ACC_active_driving_programm_comfort,0, min
ENG131989,Operating_time_ACC_active_driving_programm_dynamic,0, min
ENG131992,Operating_time_ACC_active_driving_programm_efficiency,0, min
ENG131993,Operating_time_ACC_active_timegap_1,0, min
ENG131994,Operating_time_ACC_active_timegap_2,0, min
ENG131995,Operating_time_ACC_active_timegap_3,0, min
ENG131996,Operating_time_ACC_active_timegap_4,0, min
ENG131997,Operating_time_ACC_active_timegap_5,0, min
ENG132001,Operating_time_ACC_active_v-delta_0,0, min
ENG132004,Operating_time_ACC_active_v-delta_large,0, min
ENG132003,Operating_time_ACC_active_v-delta_medium,0, min
ENG132002,Operating_time_ACC_active_v-delta_small,0, min
ENG139759-ENG98375,Supplier_sw_block_version-Application,5F 07 2D 10,
ENG139759-ENG140150,Supplier_sw_block_version-Bootloader,05 02 05 10,
Elapsed Time: 00:28
;SW:5Q0-907-376-D HW:5Q0-907-376-D --- 14: Susp. Elect.
;Component:DAEMPFUNGS-SG H18 0140, Coding:
;EV_DRCONTITEMIC,001019,EV_DRCONTITEMIC_VW37.rod
;Wednesday,19,August,2026,10:26:29:58926
;VCID: 3A265CFE2CD1FB3AD06-806E-R
IDE00019,Voltage terminal 30,14.43, V
IDE03051,Voltage supply for right sensor for level control system,4.95, V
IDE03052,Voltage supply for left sensor for level control system,4.94, V
IDE03607,Front left chassis acceleration sensor,0.16, m/s²
IDE03608,Front right chassis accelerator,0.16, m/s²
IDE03609,Rear body acceleration sensor,-0.10, m/s²
IDE03611-MAS01447,Left front dampening adjustment valve-Actual value,0.01, A
IDE03611-MAS01448,Left front dampening adjustment valve-Specified value,0.00, A
IDE03612-MAS01447,Right front dampening adjustment valve-Actual value,0.01, A
IDE03612-MAS01448,Right front dampening adjustment valve-Specified value,0.00, A
IDE03613-MAS01447,Left rear dampening adjustment valve-Actual value,0.01, A
IDE03613-MAS01448,Left rear dampening adjustment valve-Specified value,0.00, A
IDE03614-MAS01447,Right rear dampening adjustment valve-Actual value,0.01, A
IDE03614-MAS01448,Right rear dampening adjustment valve-Specified value,0.00, A
IDE03849,Left front level control system sensor: raw value,26.08, %
IDE03857,Right front level control system sensor: raw value,71.17, %
IDE03865,Left rear level control system sensor: raw value,38.84, %
IDE04147,Right rear level control system sensor: raw value,Not installed due to specific system,
IDE04195,Left front level ctrl sys sensor: adaptation value (deflected),66.46, %
IDE04196,Left front level ctrl sys sensor: limit 1 (deflected),54.17, %
IDE04197,Left front level ctrl sys sensor: limit 2 (deflected),78.17, %
IDE04198,Right front level ctrl sys sensor: adaptation value (deflected),33.73, %
IDE04199,Right front level ctrl sys sensor: limit 1 (deflected),25.06, %
IDE04200,Right front level ctrl sys sensor: limit 2 (deflected),49.06, %
IDE04201,Left rear level ctrl sys sensor: adaptation value (deflected),63.01, %
IDE04202,Left rear level ctrl sys sensor: limit 1 (deflected),53.33, %
IDE04203,Left rear level ctrl sys sensor: limit 2 (deflected),77.33, %
IDE04204,Right rear level ctrl sys sensor: adaptation value (deflected),Not installed due to specific system,
IDE04348,Right rear level control system sensor: limit 1 (deflected),Not installed due to specific system,
IDE04349,Right rear level control system sensor: limit 2 (deflected),Not installed due to specific system,
IDE04455,Adapted VIN,3VW1T7BU7SM057846,
IDE04805-IDE02955,Driving profile selection-System status,Available,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE04893-MAS01853,Adapting with deflected wheels-Left front,not possible,
IDE04893-MAS01854,Adapting with deflected wheels-Right front,not possible,
IDE04893-MAS01855,Adapting with deflected wheels-Left rear,not possible,
IDE04893-MAS01856,Adapting with deflected wheels-Right rear,possible,
IDE06673,Initialization status,initialized,
IDE80001,Analysis 1,not active,
IDE80002,Analysis 2,not active,
IDE80004,Analysis 4,1,
IDE80006,Analysis 6,not active,
IDE80007,Analysis 7,0,
IDE80008,Analysis 8,4.97, V
IDE80009,Analysis 9,2.53, V
IDE80010,Analysis 10,6.00, V
IDE80011,Analysis 11,26, °C
IDE80012,Analysis 12,27, °C
IDE80013-MAS03401,Analysis 13-Parameter 1,97,
IDE80013-MAS03402,Analysis 13-Parameter 2,97,
IDE80014-MAS03401,Analysis 14-Parameter 1,158501,
IDE80014-MAS03402,Analysis 14-Parameter 2,100039,
IDE80015,Analysis 15,25,
IDE80016,Analysis 16,15,
IDE80017,Analysis 17,Yes,
IDE80018,Analysis 18,00 03,
IDE80019,Analysis 19,00 02,
IDE80020,Analysis 20,00 03 00 03 00 08,
IDE80021,Analysis 21,not activated,
IDE80022,Analysis 22,1019,
IDE80022,Analysis 22,4,
IDE80022,Analysis 22,5,
IDE80022,Analysis 22,-5,
IDE80023,Analysis 23,00 00,
IDE80024,Analysis 24,00 02,
IDE80025,Analysis 25,8.95, V
IDE80026,Analysis 26,00 00 00 00,
IDE80027,Analysis 27,3,
MAS03088,Internal damper mode,1,
Elapsed Time: 00:05
;SW:5Q0-959-655-CB HW:5Q0-959-655-CB --- 15: Airbags
;Component:AirbagVW21 010 0421, Coding:8CCCFCC0000000005000001AC24800000065
;EV_AirbaVW20SMEVW37X,002166,EV_AirbaVW20SMEVW37X_VW37.rod
;Wednesday,19,August,2026,10:26:41:58926
;VCID: 0256E41E048173FAC86-8056-R
IDE00821,Seat belt switch 2nd row driver's side,not installed,
IDE00822,Safety belt switch 2nd row frt.passenger side,not installed,
IDE00823,Seat belt switch 2nd row center,not installed,
IDE00824,Seat belt switch 3rd row driver's side,not installed,
IDE00825,Passenger side 3rd row seat belt switch,not installed,
IDE00919,Driver side airbag igniter ohm value,2.9, Ohm
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01100,Passenger side airbag igniter ohm value,2.2, Ohm
IDE01101,Passenger side airbag igniter 2 ohm value,2.1, Ohm
IDE01102,Driver thorax airbag igniter ohm value,2.4, Ohm
IDE01103,Passenger side side airbag igniter ohm value,2.3, Ohm
IDE01104,driver side rear airbag igniter ohm value,no measured value present,
IDE01105,Ft. pass.side rear airbag igniter ohm value,no measured value present,
IDE01106,Driver side head curtain airbag igniter ohm value,2.3, Ohm
IDE01107,Frt.pass. side head curtain airbag igniter ohm value,2.3, Ohm
IDE01108,Driver side knee airbag igniter ohm value,no measured value present,
IDE01109,Frt.pass. side knee airbag igniter ohm value,no measured value present,
IDE01110,Driver side belt tensioner igniter ohm value,2.2, Ohm
IDE01111,Frt.pass. side belt tensioner igniter ohm value,2.3, Ohm
IDE01112,Driver side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01113,Frt.pass. side belt tensioner igniter 2 ohm value,2.3, Ohm
IDE01114,Driver side belt force limiter igniter ohm value,2.2, Ohm
IDE01115,side belt force limiter igniter ohm value,2.2, Ohm
IDE01116,driver side rear belt tensioner igniter ohm value,2.6, Ohm
IDE01117,Passenger side rear belt tensioner igniter ohm value,2.6, Ohm
IDE01119,Battery open circuit igniter ohm value,no measured value present,
IDE01193,Driver belt tensioner ohm value,Too Small,
IDE01194,Frt.pass. belt tensioner ohm value,Too Small,
IDE01195,Front passenger side seat occupancy detection: Ohm value,no measured value present,
IDE01197,Key switch contact 1 ohm value,too large,
IDE01198,Key switch contact 2 ohm value,too large,
IDE01200,Driver seat position sensor current value,5.8, mA
IDE01201,Frt.pass. seat position sensor current value,5.8, mA
IDE01205,Safety belt switch 2nd row driver side ohm value,no measured value present,
IDE01206,Safety belt switch 2nd row frt.pass. side ohm value,no measured value present,
IDE01207,Safety belt switch center 2nd row ohm value,no measured value present,
IDE01208,Seat belt switch 3rd row driver side ohm value,no measured value present,
IDE01209,Seat belt switch 3rd row frt.pass. side ohm value,no measured value present,
IDE01271,Number of rollover bar deployments,0,
IDE01555,Number of frontal crashes,0,
IDE02852,Battery Interrupt Igniter High-Voltage Battery,not installed,
IDE02853,Igniter for batt. interrupt: high volt. batt. ohm value,no measured value present,
IDE03870,Seat occupied recognition malfunction status,|
IDE03870,Seat occupied recognition malfunction status,0,
IDE06959,Seat occupant detection: diagnosis signal,30.0, %
IDE06960,Seat occupant detection: msmt. signal,7.0, %
IDE06961,Seat occupant detection: ref. signal,0.5, %
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,not installed,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,0.0, Ohm
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,not installed,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,0.0, Ohm
MAS00001,Driver airbag igniter,correct,
MAS00003,Front passenger front airbag igniter,correct,
MAS00004,Front passenger airbag igniter 2,correct,
MAS00005,Driver thorax airbag igniter,correct,
MAS00006,Front passenger thorax airbag igniter,correct,
MAS00007,Driver side rear thorax airbag igniter,cannot be measured currently,
MAS00008,Passenger side rear thorax airbag igniter,cannot be measured currently,
MAS00009,Driver head curtain airbag igniter,correct,
MAS00010,Front passenger head curtain airbag igniter,correct,
MAS00011,Driver knee airbag igniter,cannot be measured currently,
MAS00012,Front passenger knee airbag igniter,cannot be measured currently,
MAS00013,Driver seat belt tension igniter,correct,
MAS00014,Front passenger seat belt tensioner igniter,correct,
MAS00015,Driver seat belt tensioner igniter 2,correct,
MAS00016,Front passenger seat belt tensioner igniter 2,correct,
MAS00017,Igniter for Driver Belt Force Limiter,correct,
MAS00018,Front passenger side belt force limiter igniter,correct,
MAS00019,Driver side rear safety belt tension igniter,correct,
MAS00020,Passenger side rear seat belt tensioner igniter,correct,
MAS00022,Battery Interrupt Igniter,cannot be measured currently,
MAS00025,Driver seat belt switch,not connected,
MAS00026,Front passenger side safety belt switch,not connected,
MAS00030,Seat occupant detection,Not assigned,
MAS00031,Airbag deactivation status,OFF,
MAS00032,Key switch terminal 1,not installed,
MAS00033,Key switch terminal 2,not installed,
MAS00035,Seat position sensor: driver side,Rear,
MAS00036,Seat position sensor: front passenger side,Rear,
MAS00037,Calibration status,0,
MAS00038,Seat occupied recognition rear driver side,not installed,
MAS00039,Seat occupied recognition rear passenger side,not installed,
MAS00040,Seat occupied recognition: center: rear,not installed,
MAS00044,Terminal 15 power supply,14.3, V
MAS01634,Supply voltage,correct,
Elapsed Time: 00:12
;SW:17A-920-420-F HW:17A-920-420-F --- 17: Instruments
;Component:KOMBI 712 8125, Coding:082408007788CF050288624B5000000880600802
;EV_DashBoardVDDMQBA0,003062,EV_DashBoardVDDMQBA0_003_VW27.rod
;Wednesday,19,August,2026,10:20:00:58926
;VCID: 20128E96AA4D81EAFE2-8074-R SFD+SFD2 {x}
IDE00019,Voltage terminal 30,14.5, V
IDE00021,Engine speed,801.00, /min
IDE00025,Coolant temperature,42.00, °C
IDE00191,Charge air pressure: actual value,7.20, %
IDE00196,Engine oil temperature,25, °C
IDE00301,Distance,11476, km
IDE00310,Outside temperature,27.0, °C
IDE00316-IDE00500,Time-Hour,10, H
IDE00316-IDE00501,Time-Minute,16, min
IDE00316-MAS00111,Time-Seconds,1, s
IDE00317-IDE00502,Date-Year,2026, yr
IDE00317-IDE00503,Date-Month,8, Months
IDE00317-IDE00504,Date-Day,19, d
IDE00510,ESI: distance driven from inspection,10, km
IDE00511,ESI: time from inspection,41, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,poor oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,100, km
IDE00520,Photo transistor,253,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,15990, km
IDE00698,ESI: remaining running time,324, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,560, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circumference-Average wheel circumference for trip distance,2019, mm
IDE00845-MAS03214,Wheel circumference-Maximum wheel circumference for speed,2019, mm
IDE00935,ESI: Theoretical service interval,22500, km
IDE01076,Time since ignition off,131068, s
IDE01153,SIA: maximum value of distance to service,16000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE02307,Parking brake status,Not operated,
IDE02642,Outside temp.: displayed value,27.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,FD,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,64,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,167,
IDE03349,FIX: Max. distance until next mileage-related inspection,32200, km
IDE03350,FIX: Maximum time until next time-dependent inspection,731, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,0, km
IDE03352,FIX: Time since last time-dependent inspection,41, d
IDE03471-IDE02383,Vehicle configuration-Dynamic steering,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Damping Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE05830,Vehicle configuration-Rear Spoiler,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring System (TPMS),Correct coding,
IDE03471-IDE07944,Vehicle configuration-electronic brake booster,Correct coding,
IDE03471-MAS01374,Vehicle configuration-Trailer,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane departure warning,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Differential lock electronics,Correct coding,
IDE03471-MAS02725,Vehicle configuration-Customer-specific function control module,Correct coding,
IDE03471-MAS06008,Vehicle configuration-Internal noise sound actuator,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer maneuvering assistant,Correct coding,
IDE03471-MAS08940,Vehicle configuration-Collision warning,Correct coding,
IDE03471-MAS09196,Vehicle configuration-Rear Axle Steering,Correct coding,
IDE03471-MAS12422,Vehicle configuration-intelligent parking assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,17.6, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,17.6, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,18.2, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,16.4, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,7.3, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,24.8, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,24.8, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,8.6, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,6.7, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,48.5, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,51.7, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,8.0, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,10.6, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,22.8, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,22.8, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,11.8, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,11400,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,11400,
IDE03472-MAS06155,Volume after refueling-Third to last distance,10900,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,10800,
IDE03473-IDE00730,tank sensor-Fuel level sensor 1 including soiling resistance,225, Ohm
IDE03473-IDE00731,tank sensor-Fuel level sensor 2 including soiling resistance,65535, Ohm
IDE03473-IDE00732,tank sensor-Fuel level sensor 1 soiling resistance,-2, Ohm
IDE03473-IDE00733,tank sensor-Fuel level sensor 2 soiling resistance,-32768, Ohm
IDE03473-IDE03494,tank sensor-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,tank sensor-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,tank sensor-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,tank sensor-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,tank sensor-Raw value sensor 1 resistor 1,2182,
IDE03473-MAS03799,tank sensor-Raw value sensor 1 resistor 2,1535,
IDE03473-MAS03800,tank sensor-Raw value sensor 2 resistor 1,65535,
IDE03473-MAS03801,tank sensor-Raw value sensor 2 resistor 2,65535,
IDE03473-MAS03802,tank sensor-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,tank sensor-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,tank sensor-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,tank sensor-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,12.2, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,223, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,65535, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,12.7, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03827,Calculated volume-Quality sensor 2,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,-12.7, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-32768.0, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,12.7, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,12.7, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,12.7, l
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.03125, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.01,
IDE03474-ENG101623,Calculated volume-reference_volume,12.6, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,112,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0016661,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,2, H
IDE03477-IDE00501,GPS time-Minute,18, min
IDE03477-IDE00501,GPS time-Minute,20, min
IDE03477-IDE00502,GPS time-Year,2026, yr
IDE03477-IDE00503,GPS time-Month,8, Months
IDE03477-IDE00504,GPS time-Day,19, d
IDE03477-MAS00111,GPS time-Seconds,39, s
IDE03477-MAS00111,GPS time-Seconds,7, s
IDE03477-MAS03493,GPS time-last synchronization year,2026, yr
IDE03506,Distance: high resolution,00 AF 1E 97,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,4F F0 00 22,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,0F F0 00 0C,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 00 0C,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,CF F0 00 22,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,7F F0 01 8F,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,6F F0 02 07,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,2F F0 2C CA,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,AF F0 2C CA,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,EF F0 02 07,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,32200, km
IDE05932,FIX: Reset value for next time-dependent inspections,731, d
IDE07145-MAS06776,Component protection properties-Komponent protection role,WFS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE08235-MAS06806,Status of immobilizer participant-OCU status,00,
IDE08235-MAS06807,Status of immobilizer participant-VTS status,00,
IDE08235-ENG118223,Status of immobilizer participant-ELV_State,00,
IDE08235-ENG118222,Status of immobilizer participant-GSG_State,00,
IDE08235-ENG118217,Status of immobilizer participant-Immobilizer_State,00,
IDE08235-ENG118216,Status of immobilizer participant-key_state,1C,
IDE08235-ENG118218,Status of immobilizer participant-MSG_1_State,F8,
IDE08235-ENG118219,Status of immobilizer participant-MSG_2_State,00,
IDE08235-ENG118220,Status of immobilizer participant-MSG_3_State,00,
IDE08235-ENG118221,Status of immobilizer participant-MSG_4_State,00,
IDE08236-ENG118224,Status locking periods immobilizer-blocking_time,00 00 00 00 00 00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,AF 30 F1 E1,
IDE08240,Transponder ID Key 2,74 30 F1 E1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS11095,Configuration immobilizer-cause:,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,FD CD 96 92,
IDE08343,Immobilizer Challenge,F3 B8 89 77,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 14|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 31|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 32|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 46|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 28|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 29|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 04|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|5|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|00 54 AF 86 02 F9|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 05 00 00 00 00 00 00 00 73
IDE12262-MAS14182,Virtual radio key: status-Master key coded,Yes,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,00,
IDE12263,Virtual radio key: vehicle ID,41 41 D6 AF E5 65 0F 59 15 1E E7 E9 3D C4 8C 17,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,07 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,0B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,0E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12265-MAS06854,Virtual radio key: check sum-Version,C1,
IDE12265-MAS06879,Virtual radio key: check sum-Checksum,31 C4 AD 71,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,3VW1T7BU7SM057846,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,3,
IDE14186-MAS17993,Communication transponder-Phase value,20,
IDE14186-MAS17994,Communication transponder-Compensation constant,61,
IDE14186-MAS17995,Communication transponder-external oscillator frequency,4,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 00 00 00 00 00 00 00,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,1,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 7C,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
MAS00077-ENG99298,Immobilizer-State,02 01 03 07 02 00 00 00 15 00,
MAS10768,Daily mileage,24, km
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS26682,Distance of storage error,00,
MAS26683,Distance of calculation error,00,
MAS27748-MAS00106,Distance data with electronic stabilization program information-Year,2000, yr
MAS27748-MAS00107,Distance data with electronic stabilization program information-Month,1, Months
MAS27748-MAS00108,Distance data with electronic stabilization program information-Day,1, d
MAS27748-MAS00109,Distance data with electronic stabilization program information-Hours,0, H
MAS27748-MAS00110,Distance data with electronic stabilization program information-Minutes,0, min
MAS27748-MAS00111,Distance data with electronic stabilization program information-Seconds,0, s
MAS27748-MAS27735,Distance data with electronic stabilization program information-ESC distance pulses,0, m
MAS27748-MAS27749,Distance data with electronic stabilization program information-Distance pulses: number of jumps,0,
MAS27748-MAS27750,Distance data with electronic stabilization program information-Distance pulses: largest positive jump,0, m
MAS27748-MAS27751,Distance data with electronic stabilization program information-Distance pulses: largest negative jump,0, m
MAS27748-MAS27752,Distance data with electronic stabilization program information-Distance pulses: total jumps,0, m
MAS27748-MAS27753,Distance data with electronic stabilization program information-Distance pulses: jump balance,0.0, m
MAS27748-MAS27754,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: number,0,
MAS27748-MAS27755,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: total duration,0, s
MAS27748-MAS27756,Distance data with electronic stabilization program information-Longest electronic stabilization program communication failure,0, s
ENG250331-ENG250595,Condition_check_1-State_info_1,4,
ENG250331-ENG250481,Condition_check_1-State_info_2,1,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,0,
ENG250332-ENG250595,Condition_check_2-State_info_1,4,
ENG250332-ENG250481,Condition_check_2-State_info_2,1,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,100, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,100, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,100, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,100, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,72, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG99439,Instrument_recorder,06 81 25 00 46 50 4B 45 56 57 32 34 53 31 46 41 43 35 44 36 37 30 32 64 36 35 78 00 06 00 CC 00 1E 00 00 02 9F 00 00 00 00 80 00 00 2B 00 06 56 BB 68 06 10 C8 00 C6 00 1E 00 00 02 F5 00 00 00 00 00 00 00 63 00 06 56 A6 5B 37 6D 98 00 C5 00 1E 00 00 03 B1 00 00 00 00 00 00 00 63 00 06 56 A6 5B 38 2D 00 00 D1 00 1E 00 00 02 8A 00 00 00 02 00 00 00 00 00 06 3D FF 84 B0 01 90 00 BF 00 1F 00 00 02 97 00 00 00 01 00 00 00 00 00 06 3D FF 84 B0 01 90 00 CD 00 1E 00 00 01 8B 00 00 00 00 00 00 00 00 00 06 42 E8 B0 92 DA 60 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 5E 00 37 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 06 05 06 05 06 05 06 FF FF FF 00 00 1E 00 CC 00 9F 02 00 00 00 00 00 00 BB 56 06 00 C8 10 06 68 1E 00 C5 00 B1 03 00 00 00 00 00 00 A6 56 06 00 00 2D 38 5B 1E 00 C6 00 F5 02 00 00 00 00 00 00 A6 56 06 00 98 6D 37 5B 1E 00 CD 00 8B 01 00 00 00 00 00 00 E8 42 06 00 60 DA 92 B0 1F 00 BF 00 97 02 00 00 01 00 00 00 FF 3D 06 00 90 01 B0 84 1E 00 D1 00 8A 02 00 00 02 00 00 00 FF 3D 06 00 90 01 B0 84 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 2F 00 03 00 00 00 03 00 03 00 01 00 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG128745,Instrument_recorder_graphic,04 81 25 00 46 50 4B 45 56 57 32 34 53 31 46 47 43 5F 56 57 00 00 02 DD 00 41 00 00 02 F5 00 00 00 00 00 00 00 06 4E 75 1F 17 F5 84 00 00 02 DC 00 41 00 00 03 B1 00 00 00 00 00 00 00 06 56 BB 80 3F CE F6 00 00 05 19 00 6B 00 08 06 2B 00 00 00 00 00 06 00 06 2D 61 2B 15 E0 EC 00 00 05 19 00 6B 00 08 06 82 00 00 00 00 00 06 00 06 2D 61 2B 15 E1 1B 00 00 02 E3 00 41 00 00 02 9F 00 00 00 00 00 00 00 06 56 A6 6D B7 AD 33 00 00 04 89 00 5D 00 00 02 82 00 00 00 00 00 00 00 06 4F 6A 18 B7 D9 51 00 00 04 8B 00 5D 00 00 00 E4 00 00 00 00 00 00 00 06 4F 6A 18 C7 85 38 00 00 05 15 00 6B 00 8E 00 99 00 00 00 00 00 01 00 06 52 92 33 6D DD 1E 00 00 05 40 00 6D 00 1C 00 80 00 00 00 00 00 00 00 06 55 2E AB A3 81 58 00 00 05 40 00 6D 00 1C 00 AC 00 00 00 00 00 00 00 06 55 2E AB B6 6C 05 00 00 02 74 00 2F 00 00 00 D0 00 00 00 00 00 00 00 06 54 64 AF AD 76 7F 00 00 02 74 00 2F 00 00 00 EA 00 00 00 00 00 01 00 06 54 D0 9F 20 0E 17 00 00 04 70 00 27 00 00 03 35 5A A5 C9 35 00 00 00 06 3C 13 AA 6C BC 5F 00 00 00 F6 00 0E 00 00 04 12 00 00 00 01 00 05 00 06 49 21 B8 F7 DE 10 00 00 05 7A 00 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 7A 00 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 7A 00 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 7A 00 72,
ENG107920-ENG98868,onboard_computer-Range,113, km
ENG107920-ENG119788,onboard_computer-range_average_consumption,8.0, l/100km
ENG107920-ENG126296,onboard_computer-range_average_consumption_cng,6.0, kg/100 km
ENG107920-ENG126292,onboard_computer-range_average_consumption_cng_high,6.0, kg/100 km
ENG107920-ENG126294,onboard_computer-range_average_consumption_cng_low,6.0, kg/100 km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,7.8, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,8.4, l/100km
ENG107920-ENG126297,onboard_computer-range_average_consumption_lpg,10.0, kg/100 km
ENG107920-ENG126293,onboard_computer-range_average_consumption_lpg_high,10.0, kg/100 km
ENG107920-ENG126295,onboard_computer-range_average_consumption_lpg_low,10.0, kg/100 km
ENG107920-ENG126298,onboard_computer-range_cng,0, km
ENG107920-ENG126300,onboard_computer-range_cng_display_value,0, km
ENG107920-ENG119791,onboard_computer-range_display_value,113, km
ENG107920-ENG126299,onboard_computer-range_lpg,0, km
ENG107920-ENG126301,onboard_computer-range_lpg_display_value,0, km
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,154,
ENG103405,read_out_measured_value_block,11,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,669,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,2,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Wait_SpeedlimitExceed,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,0,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,0,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,0,
ENG347772,Total_distance_current,0, km
Elapsed Time: 00:29
