Sunday,23,August,2026,11:39:20:13576
VCDS Version: 26.3.0.0 (x64) HEX-V2 CB: 0.4701.5
VIN: WAUZZZ4E55N016354 License Plate: CC181GG
Mileage: 167075 Repair Order:
Address 01: Engine (4E0 910 018 )
11:38:55
640 /min Engine Speed (G28)
68.0°C Coolant Temperature (G62)
-23.4 % Lambda Control Bank 1
-27.3 % Lambda Control Bank 2
23.3 % Engine Load
0.00 g/s Mass Air Flow Sensor
0.00 g/s Mass Air Flow Sensor (G70)
0.0 km/h Vehicle Speed
Sunday,23,August,2026,11:43:09:13576
Address 11: Engine II (4E0 910 018 )
11:42:48
73.0°C Coolant Temperature (G62)
-3.1 % Lambda Control Bank 3
0.8 % Lambda Control Bank 4
22.6 % Engine Load
0.00 g/s Mass Air Flow Sensor (G246)
1.2 % Throttle Valve Angle
11:43:44
75.0°C Coolant Temperature (G62)
1.6 % Lambda Control Bank 3
-2.3 % Lambda Control Bank 4
22.6 % Engine Load
11:43:47
1.6 % Lambda Control Bank 4
22.6 % Engine Load
Sunday,01,March,2026,17:46:20:13576
VCDS Version: 25.3.2.0 (x64) HEX-V2 CB: 0.4671.5
11:43:51
600 /min Engine Speed (G28)
23.3 % Engine Load
Sunday,23,August,2026,11:44:29:13576
VIN: License Plate: CC181GG
11:44:17
76.0°C Coolant Temperature (G62)
-2.3 % Lambda Control Bank 3
22.6 % Engine Load
11:44:17
22.6 % Engine Load
Sunday,23,August,2026,11:55:17:13576
Mileage: 167078 Repair Order:
11:54:31
N/A Engine Speed (G28)
108.0°C Coolant Temperature (G62)
-16.4 % Lambda Control Bank 3
-19.5 % Lambda Control Bank 4
37.6 % Engine Load
N/A Mass Air Flow Sensor (G70)
N/A Throttle Valve Angle
N/A Vehicle Speed
Sunday,23,August,2026,12:12:01:13576
Mileage: 167081 Repair Order:
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Control Module Part Number: 4E0 910 018 HW: 4E0 906 018
Component and/or Version: 6.0L W12/4V A ª0110
Software Coding: 0011773
Work Shop Code: WSC 00999 444 64523
VCID: 5CE676775A28D76AF3B-8008
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit - Intermittent
19490 - Intake Air Temperature Sensor 2 (G299)
P3034 - 002 - Signal too Large
17481 - Mass Air Flow Sensor 2 (G246)
P1073 - 002 - Signal too Low
Sunday,23,August,2026,12:07:40:13576
12:07:17
109.0°C Coolant Temperature (G62)
1.6 % Lambda Control Bank 1
-3.1 % Lambda Control Bank 2
25.6 % Engine Load
1.6 % Throttle Valve Angle
Sunday,23,August,2026,12:11:28:13576
12:11:16
-18.0 % Lambda Control Bank 3
-27.3 % Lambda Control Bank 4
24.8 % Engine Load
Sunday,23,August,2026,12:12:24:13576
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low
18331 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Readiness: 0010 1101
