- Dec 30, 2015
- 72
- 27
- Bentley Workshop. South Wales. UK
- C?ID=263294
Hi, Ive got a Bentley GTC with a roof fault. I'm trying to find out which switch is faulty, but the diagnostics doesn't seem to say which one it is.
The roof goes down perfectly. When you start to raise it, the cover unlatches but will not rise. If you raise it by hand, as soon as the cover gets to clicks to it's raised position, the hood will carry on and close correctly. Any tips on how to find out which switch it is? Thanks in Advance.
Saturday,25,July,2026,18:32:45:45172
VCDS Version: 26.3.0.0 (x64) HEX-NET CB: 0.4713.4
VIN: SCBDE23W28C056176 License Plate: WHITE GTC
Address 26: Auto Roof Labels: 3W7-959-255.clb
Control Module Part Number: 3W7 959 255
Component and/or Version: VSG BY615 0509
Software Coding:
Work Shop Code: WSC 00999 444 64523
VCID: 84442D10C3ABEBBF67-80D0
Fault Codes have been Erased
02000 - Switch Position
Address 26,3W7 959 255 ,channel 2,adapted from,184,to,0,
Address 26,3W7 959 255 ,channel 3,adapted from,254,to,254,
Address 26,3W7 959 255 ,channel 2,adapted from,0,to,0,
Address 26,3W7 959 255 ,channel 3,adapted from,254,to,0,
Address 26: DTCs cleared
Software Coding:
Thursday,23,July,2026,11:45:22:45172
Software Coding:
Address 26: Auto Roof Labels: 3W7-959-255.CLB
Software Coding:
Chassis Type: 3W (3W - Bentley Continental (2004 > 2007))
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 26 28 34 36
37 38 46 47 53 54 57 65 66 68 69 6C 71 75 76 77
VIN: SCBDE23W28C056176 Mileage: 107740km-66946miles
Address 01: Engine ( ) Labels: 07C-906-018-BWR1.clb
Part No SW: 07C 906 018 FK HW: 07C 906 018 FK
Component: BY- 6.0L -TT NC G 1548
Revision: --H06--- Serial number: VWX3Z0H3704554
Coding: 0001175
Shop #: WSC 52971 001 1048576
VCID: F3A67ECC9305DC074E-5160
VINID: 8D34945420E70884C0146047187EDAD9CA
001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
P0544 - 002 - Circuit Malfunction
Fault Status: 01100010
Mileage: 107721 km
RPM: 3030 /min
Load: 11.8 %
Speed: 74.0 km/h
Temperature: 95.0 C
Temperature: 38.0 C
Absolute Pres.: 1000.0 mbar
Voltage: 13.208 V
006435 - Please Check DTC Memory of ECU Number 2
P1923 - 008 -
Fault Status: 01101000
Mileage: 107739 km
Temperature: 21.0 C
Temperature: 24.0 C
Voltage: 11.430 V
Address 02: Auto Trans Labels: 09E-927-156.clb
Part No SW: 09E 927 760 P HW: GS1 911 4
Component: ZWDU3404 6L W12TT 3404
Revision: --H04--- Serial number: 0119258
Coding: 0000111
Shop #: WSC 00083 790 00000
VCID: BD3298F4E5C15A7768-5160
Address 03: ABS Brakes Labels:
VCID: D5E220542CB1A23740-FFFE
Note: Excessive Comm Errors
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 F HW: 3D0 909 137 F
Component: 7A Kessy 6850
Revision: 00H24072 Serial number: VWX3Z0H3704554
Coding: 0422125
Shop #: WSC 04940 001 00001
VCID: AA18A3A8014FDDCF3D-80FE
Component: ELV XXXX
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
Fault Frequency: 0
Reset counter: 200
Date: 2026.07.22
Time: 16:24:18
Address 06: Seat Mem. Pass Labels: 3W0-959-759.clb
Part No: 3W0 959 759 B
Component: CM Seat Pass. 0017
Coding: 0000002
Shop #: WSC 00046 000 00000
VCID: C8DCF920BF030FDFCB-809C
01900 - Passengers Seat Fore / Aft Adjusting Motor (V31)
01975 - Passengers Seat Height Adjustment Motor (V191)
01904 - Passengers Backrest Adjusting Motor (V46)
01903 - Seat Tilt Adjustment Motor (V231)
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3W0 035 007 Q
Component: ZAB COCKPIT 2215
Coding: 0401337
VCID: BA3893E8F4EF6D4F4D-5184
Address 08: Auto HVAC Labels: 3W7-907-040.clb
Part No: 3W7 907 040
Component: Climatronic BY615 2026
Coding: 0000111
VCID: F5A240D49871C23760-80A0
00041 - Indirect Ventilation Flap Motor (V213)
Address 09: Cent. Elect. Labels:. 3D0-937-049-V2.clb
Part No SW: 3D0 937 049 M HW: 3D0 937 049 M
Component: J519 6500
Revision: -4004--- Serial number: --------------
Coding: 40020000AB2A11000000000000000000
VCID: B424BDD0D38B9B3F97-80E0
Address 11: Engine II Labels: 07C-906-018-BWR2.clb
Coding: 0001175
001351 - Sensor 1 for Exhaust Temp Bank 2 (G236)
P0547 - 002 - Circuit Malfunction
Mileage: 107719 km
RPM: 2874 /min
Load: 11.4 %
Speed: 46.0 km/h
Temperature: 93.0 C
Temperature: 36.0 C
Voltage: 13.208 V
Address 15: Airbags Labels: 3W7-909-601.clb
Part No SW: 3W7 909 601 HW: 3W7 909 601
Component: 07 Airbag 9.42 H09 0050
Revision: 92H09005 Serial number: 003880007C3+
Coding: 0012343
VCID: FAB853E8B46FAD4F0D-5160
Subsystem 1 - Serial number: 63328RB403389661E
Subsystem 2 - Serial number: 63428RB40338966ES
Subsystem 3 - Serial number: 63700RB4 I
Subsystem 4 - Serial number: 63800RB4 J
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 K
Component: J527 3601
Coding: 0000012
VCID: C7DEFA1CB21D00A7C2-8092
Address 17: Instruments Labels: 3Wx-920-xxx-17.clb
Part No SW: 3W0 920 841 E HW: 3W0 920 841 E
Component: J285 KOMBI-INST. 1623
Revision: K0H10V35
Coding: 0005402
Shop #: WSC 29293 001 104857
VCID: B73E8ADCC6FD7027B2-80E2
Address 19: CAN Gateway Labels: Redir Fail!
Part No SW: 6N0 909 901 HW: 3W0 920 841 E
Component: J533 GW-K-CAN TP20 1623
Coding: DFF8FFAE9F065701
VCID: F0AC71C0E313E71FB3-80A4
Part No: 3W7 959 255
Component: VSG BY615 0509
Revision: 00005000 Serial number: 00000007500706
Shop #: WSC 00999 444 64523
Address 34: Level Control Labels: 3Wx-907-553-34.clb
Part No: 3W7 907 553
Component: LUFTFDR.-CDC- 3C3V0 7405
Coding: 0005581
VCID: FEB05FF8AD47816F31-80AA
Address 36: Seat Mem. Drvr Labels: 3W0-959-759.clb
Part No: 3W0 959 760 B
Component: CM Seat Driver 0017
Coding: 0000002
VCID: C0CCE1009733379F03-8094
00997 - Motor for Driver's Seat Position; Fore/Aft (V48)
01174 - Driver Seat Height Adjustment Motor (V138)
00998 - Motor for Driver's Seat Recline (V45)
01895 - Motor for Steering Column Adjustment; Vertical (V123)
01896 - Motor for Steering Column Adjustment; Axial (V124)
Address 37: Navigation Labels: None
Part No: 3W0 919 887 J
Component: NAVIGATION 2197
Coding: 0400000
VCID: CED0CF385867D1EF81-5160
Address 38: Roof Electronics Labels: None
Part No: 3W0 907 135 F
Component: Dachmodul 0802
Coding: 0006077
VCID: B93A8CE4F4E9665744-80EC
Address 46: Central Conv. Labels: 3D0-959-933.clb
Part No: 3D0 959 933 H
Component: A1 HSG 0200
Coding: 0000040
Shop #: WSC 00143 106 186473
VCID: B52280D4DDF18237A0-4B00
Subsystem 1 - Part No: 3W7 959 701 A
Component: Tuersteuergeraet FS 1103
Subsystem 2 - Part No: 3W7 959 702 A
Component: Tuersteuergeraet BF 1103
Subsystem 3 - Part No: 3W7 959 703 B
Component: Tuersteuergeraet HL 0704
Subsystem 4 - Part No: 3W7 959 704 B
Component: Tuersteuergeraet HR 0704
Subsystem 5 - Part No: 3W0 909 610 H
Component: 15 HDSG 2013
00485 - Drivers Outside Door Handle Central Locking Button (E369)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3W7 035 456 C
Component: 12K-AUDIOVERST 5002
VCID: BB3696ECFED5544756-80EE
Address 57: TV Tuner Labels: None
Part No SW: 3D0 919 148 HW: 3D0 919 148
Component: TV-Tuner 0160
Revision: R0H16000 Serial number: 91100500350002
Coding: 0000001
VCID: E79E1A9CD2DD20A7E2-80B2
00864 - Antenna 2 for TV (R56)
010 - Open or Short to Plus
Fault Status: 01101010
Address 65: Tire Pressure Labels: 3D0-907-273-V4.clb
Part No SW: 3W7 907 273 A HW: 3W7 907 273 A
Component: J0502 RDK 0004
Revision: 0004 004 Serial number: 00000900003082
Coding: 3501E05286FD5286FDA7DA00A7DA00
VCID: BE309FF8EDC7416F71-80EA
Address 68: Wiper Electr. Labels: 3Wx-955-023.clb
Part No: 3W2 955 023 E
Component: Wischermodul 9326
Shop #: WSC 00000 725 65552
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3W3 907 441 HW: 3W3 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: PA8 J810332
Coding: 2000002
VCID: F6A047D88577C92F69-80A2
Address 71: Battery Charger Labels: 3D0-915-181.lbl
Part No: 3D0 915 181 D
Component: Batteriemanagement 2800
VCID: A4044D90636B0BBF07-80F0
Address 75: Telematics Labels: None
Part No: 3W0 907 722 E
Component: TRACKER VTTS 0043
VCID: BA3893E8F4EF6D4F4D-508A
Address 76: Park Assist Labels: 3W0-919-283-V1.clb
Part No: 3W0 919 283 B
Component: 0C Einparkhilfe 0404
VCID: BC3495F0FBDB537F5F-80E8
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
01626 - Sensor for Parking-Aid; Front Right (G252)
014 - Defective
Address 77: Telephone Labels: None
Part No SW: 3W0 035 385 AS HW: 3W0 035 385 AS
Component: rSAP Bentley 0262
Revision: 00008000 Serial number: 30700000094207
Coding: 0031000
VCID: 86403718F597D9AF79-80D2
00003 - Control Module
014 - Defective
End----------(Elapsed Time: 05:55, VBatt start/end: 13.9V/13.9V)-----------
------------------------------22 Faults Found------------------------------
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 11: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 38: DTCs cleared
Address 46: DTCs cleared
Address 47: DTCs cleared
Address 57: DTCs cleared
Address 65: DTCs cleared
Address 68: DTCs cleared
Address 6C: DTCs cleared
Address 71: DTCs cleared
Address 75: DTCs cleared
Address 76: DTCs cleared
Address 77: DTCs cleared
