Wednesday,12,August,2026,23:41:33:33606
VCDS Version: 26.3.0.0 (x64) HEX-NET2 CB: 0.4713.5
VIN: WUAZZZ8V9JA905014 License Plate:
Mileage: 138362km-85974mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 29 39 42 44 4B 52 5F 6C
BB BC D6 D7
VIN: WUAZZZ8V9JA905014 Mileage: 138362km-85974miles
20-High Beam Assist. -- Status: Malfunction 0010
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 E HW: 07K 907 309 E
Component: R5 2.5l TFSI H22 0003
Revision: 53H22000 CVN: 0CE16C72
Coding: 12250032242601032600
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM25TFS0118V0907404E 001003
ROD: EV_ECM25TFS0118V0907404E.rod
VCID: 3B285A66F3ED94B2DA1-806E
VINID: 9E546AAAA22625A4490050011052687A0D
28212 - Exhaust Pressure Control Valve 2
P049F 00 [00100111] - Malfunction
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:27
Engine speed: 0.00 /min
Coolant temperature: 39 C
Intake air temperature: 37 C
Voltage terminal 30: 14.440 V
Engine status: COENG_READY
19305 - Exhaust Pressure Control Valve
P0475 00 [00100111] - Electrical Malfunction
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:27
Readiness: 1110 0001
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2110
Revision: 00H06V07 CVN: F9250F4B
ROD: EV_TCMDQ500021.rod
VCID: 2E0E6332309F711A6DF-807A
Part No SW: 8V0 614 517 E HW: 8V0 614 517 C
Component: ESC H25 0625
Revision: 00000000 Serial number: 63147000000088
Coding: 2F9C938DD49913AE8B910B65419569F4C92BC8D1D082967702415074820812
Shop #: WSC 99999 999 2097151
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
ROD: EV_Brake1UDSContiMK100IPB_035.rod
0297 - Steering Angle Sensor
B1168 F2 [10001001] - Not Initialized
Reset counter: 241
Date: 2026.08.12
Time: 23:22:25
16412 - Display for Tire Pressure Monitoring
C1146 02 [10001001] - Signal Failure
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:36
16413 - Display for Tire Pressure Monitoring
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:36
Part No SW: 8V0 820 043 Q HW: 8V0 820 043 Q
Component: AC Automat H03 0130
Revision: 20002000 Serial number: 00000001386390
Coding: 03100005000000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 40D22D8A9A0BF76A8F3-8014
Humidity sensor: exterior:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 34098BB7000000000001
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001732402304 Dataset Number: 8V0909514AA 0012
ROD: EV_BCMBOSCH_018_VW37.rod
VCID: 0842F5AAF2BB0F2A873-805C
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 150703 042 0580
Serial number: 150709232343
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 24085131
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 25 06 2017 00001556
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY151670CCD
Serial number: 00000000000099994823
558100 - Databus
[Airbag_02 Datenbus empfangener Fehlerwert]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:29
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): On
Status Bremslichtschalter (CAN): On
OFF: Not operated
Position lamps: Not operated
Low beams: Not operated
Voltage: 14.4 V
Outside temperature: 25.5 C
568086 - Databus
[LCM links - Blinker defekt]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.3 V
568342 - Databus
[LCM rechts - Blinker defekt]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:27:19
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.4 V
722436 - No Communications with Moveable Sunroof Control Module
U0207 00 [00001001] - -
[Steuerger t f r Schiebedach->kein Signal/ Kommunikation]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:27
CAN-Bus_aktiv: On
OFF: Not operated
Voltage: 14.4 V
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617315 Dataset Number: 8V0909526J 0062
Coding: 0470151011
Shop #: WSC 99999 999 12345
VCID: 4BC80AA6A34D24326A1-801E
13637426 - Databus
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR3LDTNA Dataset Number: 8V0909602S 0001
Coding: 98CCC000008000005C5400CA00C8000000C5
VCID: 0944F0AEE9B1762298D-805C
Subsystem 1 - Part No SW: ----------- HW: 480 001 607 15
Serial number: 357000000000F844651F
Subsystem 2 - Part No SW: ----------- HW: 480 001 607 15
Serial number: 358000000000A294651A
Subsystem 3 - Part No SW: ----------- HW: 480 401 607 15
Serial number: 3510002C11C52F45425-
Subsystem 4 - Part No SW: ----------- HW: 480 401 607 15
Serial number: 3520002C11C52F41213S
Subsystem 5 - Part No SW: ----------- HW: 480 402 709 17
Serial number: 355000299252D87201B+
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [10001001] - Resistance Too High
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
9447189 - Seat Occupied Sensor; Passenger's Side
B1027 15 [10001001] - Open or Short to Plus
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:26
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [10001001] - Open or Short to Plus
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:26
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [10001001] - Open or Short to Plus
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:26
Part No SW: 8V0 953 521 EH HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 20071504400310
Coding: A408
Shop #: WSC 12345 123 61029
ROD: EV_SMLSKLOMQB_017.rod
VCID: 045AE19ACE932B4AEBB-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 A HW: 8V0 920 790 A
Component: FBenRDW H16 0066
Coding: 242D08422B8006000104EC041000001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3A265F62FCD7ADBAC17-806E
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: -------- Serial number: 0009458492 Dataset Number: 8V0909515R 0101
Coding: 030100043F085D005B00806A380B00000001010000000000000000000000
Shop #: WSC 06335 790 00021
GVL: 01D63C0000000100400C00000002C8000000C000000200000000000000000000
ROD: EV_GatewNF_AU37.rod
VCID: 6E8EA332F01F311A2DF-803A
Generator:
Component: 1-01-09-01-04
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20180123074139 21035
131734 - No Communications with Undefined Control Module
U1126 00 [00001001] - -
[Timeout Knoten 0x96]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Terminal 30 power supply: 14.1 V
Terminal 15: On
131735 - No Communications with Undefined Control Module
[Timeout Knoten 0x97]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Terminal 15: On
197175 - Control unit for battery monitoring
U1050 00 [00001001] - No Communication
[BDM (LIN#1) Timeout]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Terminal 15: On
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 81A 857 511 G HW: 81A 857 511 A
Component: FLA H10 0008
Revision: AA001001 Dataset Number: 8V0909546D 0004
Coding: 0408010701000000010000
Shop #: WSC 06325 790 00021
ASAM Dataset: EV_HighBeamAssisMXBAU33X 001003
ROD: EV_HighBeamAssisMXBAU33X.rod
VCID: 2C0A693A0683030A43B-8078
13241866 - Databus
[Data bus received erroneous signal]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:28
Communication status of data bus 1-ABS Control Module: No communication
Communication status of data bus 1-Data Bus On Board Diagnostic Interface: Communication
Communication status of data bus 1-Engine/Motor Control Module: No communication
Communication status of data bus 1-Headlamp range control module: No communication
Communication status of data bus 1-Vehicle Electrical System Control Module: Communication
Communication status of data bus 1-Steering column electronics control module: Communication
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00030.10.17 Dataset Number: v1260x015G0 0000
Coding: 0601
ROD: EV_AllWheelContrHA1VW37X_002_VW37.rod
VCID: 4DCC04BE5D592A02745-8018
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
Dataset Number: 8V0909519D 0006
VCID: 42D627829407E57A997-8016
0560 - LED Turn Signals
C11BF 01 [00001001] - Electrical Failure
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
0395 - Headlights in Service Position
C1241 00 [00001001] - -
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:29:34
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Dataset Number: 8V0909520D 0006
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:27:19
Address 42: Door Elect, Driver (J386) Labels:* Redir Fail!
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007SD817756 Dataset Number: 8V0909872L 0063
Coding: 001E0A205001080000001002
ROD: EV_DCU2DriveSideMAXHKLO_AU37.rod
VCID: 44DA219A8E13EB4AABB-8010
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Dataset Number: 8V0909852S 0001
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
16275 - Steering Angle Sensor
B1168 F2 [00001001] - Not Initialized
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Motor status: 00
Supply voltage: 14.25 V
Temperature: 41.0 C
KFC: 3F
KFA: 00 93
Freeze frame conditions: 5F
uioUdNotFilt_xdu16: 14.44 V
uAdSensI_SwitchedKl30_xdu16: 14.36 V
NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
NoInitCause_RackPos_Rohwert: 01 80
RP_VALCNTSAV: activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: activated
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 15111710801648 Dataset Number: 8V0909583A 0006
Coding: 000000050100147602102B5B020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_001_VW37.rod
VCID: 72B6B742E42715FAC97-8026
13705999 - Databus
U1123 00 [10001001] - Received Error Message
[Kamera_FDD_Funktionsstatus_Fehler received error status]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
66881 - Databus
[LED_L_falsch_codiert received error value]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
66882 - Databus
[LED_R_falsch_codiert received error value]
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
5350720 - Left Matrix High Beam
C1175 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
5350976 - Right Matrix High Beam
C1176 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
0032 - Headlight
C107E 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007SDG00138 Dataset Number: 8V0909873L 0063
Coding: 001E02205C01000000011002
ROD: EV_DCU2PasseSideMAXHKLO_AU37.rod
VCID: 43D822868B1DEC72921-8016
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8V1 035 035 D HW: 8V1 035 035
Component: MU-P-LND-EU 054 1168
Serial number: A698K0HS005280 Dataset Number: 8V2909545P 0028
Coding: 017363010000000011111101000A00332F0028E701700100DE
VCID: 33387246DBBD5CF2021-8066
Subsystem 1 - Part No SW: V03 959 802 TL HW: -----------
Component: ECE 2020/2021 --- 0187
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9K1Y0HE94
Subsystem 3 - Part No SW: 8V0 919 614 BJ HW: 8V0 919 614 BJ
Component: ControlUnit_H H85 0855
Serial number: ALJAL128081700050033
Compact disc data bank:
Component: Gracenote2 --- 1016
Part No SW: 5Q0 980 556 B HW: 4M0 980 556 A
Component: RVC Compact H19 0231
Dataset Number: 8V0909460E 0005
Coding: 0237060102002001400040
Shop #: WSC 00046 000 00000
VCID: 3924406EF9D1A6A2C8D-806C
10489856 - No Basic Setting
B2010 00 [00001001] - -
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
passive
Address BB: Door Rear Drv (J388) Labels:* 5QX-959-DCR-V2.clb
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS004 0189
Serial number: YE007SDA06864 Dataset Number: 8V0909897J 0060
Coding: 000C00284001000000001002
ROD: EV_DCU2RearDriveMAXHKLO_AU37.rod
VCID: 4ECE03B2505F111A0DF-801A
196661 - Motor for Window Regulator
B1487 13 [00001001] - Open Circuit
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:23
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:23
Address BC: Door Rear Pass (J389) Labels:* 5QX-959-DCR-V2.clb
Component: TSG HBFS004 0189
Serial number: YE007SDA0638A Dataset Number: 8V0909896J 0060
Coding: 000C92204001000000001002
ROD: EV_DCU2RearPasseMAXHKLO_AU37.rod
196738 - Motor for Child Safety Lock
B14FF 29 [00001001] - Signal Implausible
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
Dataset Number: 8V0909471E 0008
VCID: 1A66BFE25C178DBA217-804E
0019 - Headlamp Type
C119F 00 [00001001] - Implausible
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
0887 - Matrix High-Beam
C119B F3 [00001001] - Output Voltage too Low
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
Dataset Number: 8V0909472E 0008
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
Reset counter: 241
Mileage: 138362 km
Date: 2026.08.12
Time: 23:22:24
End----------(Elapsed Time: 01:38, VBatt start/end: 14.4V/14.5V)-----------
------------------------------37 Faults Found------------------------------
