Audi Q5 8R - 55 Headlight Range (8H0 907 357 D) will not accept coding - 01042 / 01539
Bartas222
Poland
C?ID=381563
Hi,
I need some help with the Headlight Range Control module on my 2012 Audi Q5 8R.
Vehicle:
Audi Q5 8R
VIN: WAUZZZ8R6CA111118
3.0 TDI
Automatic transmission 0B5
Address 55 currently shows:
Address 55: Headlight Range
Part No SW: 8H0 907 357 D
HW: 8H0 907 357 D
Component: AFS 1 H01 0020
Coding: 0000255
Faults:
000 - - - MIL ON
The module communicates normally, but I cannot get it to accept coding.
I tried coding it with VCDS after entering Security Access, but VCDS rejects the coding with a request sequence / sequence error.
I also tried with VCTool. VCTool initially allowed access to the module, but when trying to write the coding it displayed:
Unable to write coding: Shifter not in park position
The transmission is automatic and the selector is physically in P. The transmission control module has no fault codes and communicates normally.
Transmission information:
Address 02: Auto Trans (J217)
Part No SW: 8R0 927 156 S
HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0013
ABS and CAN Gateway also have no faults.
I understand that the current coding 0000255 means the AFS module is effectively not coded. After successful coding I also expect that Basic Settings for the headlight adjustment will need to be performed because of fault 01539.
My questions are:
  1. What is the correct Security Access procedure for 8H0 907 357 D / AFS 1 H01 0020?
  2. What is the correct coding for this Q5 8R?
  3. Is there a specific required sequence before Coding 07 that would explain the VCDS request sequence error?
  4. Does the module require a particular diagnostic session or transmission selector status before accepting coding?
  5. Could coding 0000255 indicate that the module was replaced or lost its coding?
During all attempts:
Ignition ON
Engine OFF
Transmission in P
Parking brake applied
I can provide the full Auto-Scan if needed.
Thanks for any help.
Tuesday,11,August,2026,19:26:16:24862
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4713.4
VIN: WAUZZZ8R6CA111118   License Plate:
Mileage: 177070km-110026mi   Repair Order:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
          69 6D 72
VIN: WAUZZZ8R6CA111118   Mileage: 177070km-110026miles
Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8R0 907 401 J    HW: 8K1 907 401 A
   Component: 3.0TDI EDC17  H14 0008
   Revision: 15H14---    CVN: D4623111
   Coding: 0121002C240F0928
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
   ROD: EV_ECM30TDI0118R0907401J.rod
   VCID: 392F2AE7A9DF8322C8D-806C
   VINID: 9D196AAAA22219344104104120681DD30F
5581 - Oil Pressure Switch
          P164A 00 [00100111] - Implausible Signal
                    Mileage: 177077 km
                    Date: 2026.08.11
                    Time: 19:20:56
                    Engine speed: 0.00 /min
                    Coolant temperature: 79 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.920 V
                    Crankshaft speed (RPM): 0.0 /min
                    Vehicle speed: 0.00 km/h
                    Vehicle voltage terminal 30: 11920 mV
                    Accelerator position: 0.00 %
                    C Eng Ds T u Raw: 829.0 mV
                    Co Eng st: COENG_READY
                    Engine oil temperature: 73.6 °C
   Part No SW: 8R0 927 156 S    HW: 0B5 927 156 F
   Revision: --H10---    Serial number: 0000000194 CVN: 00000D20
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501 A02203
   ROD: EV_TCMDL501.rod
   VCID: 4BC3602FF34301B26A1-801E
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 G    HW: 8R0 907 379 G
   Component: ESP8 quattro  H07 0070
   Coding: 0F9540
   Shop #: WSC 06334 000 00000
   VCID: 44D14B13DE9DCECAABB-8010
   Part No SW: 8K0 907 064 FG    HW: 8K0 907 064 FG
   Component: BCM2 2.0      H10 0602
   Coding: 01854000000000000000
   VCID: 7AADF5EBECD9483A817-802E
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0512000027186007
   Part No SW: 8T1 820 043 AP    HW: 8T1 820 043 AP
   Component: KLIMA 3 ZONEN H08 0182
   Revision: C0000000    Serial number: 01110420121907
   Coding: 36110000
   Shop #: WSC 57566 001 1048576
   VCID: 7F5B04FFF7FB6D12B69-802A
   Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
   Component: BCM1 1.0      H30 0392
   Revision: 09030001    Serial number: 00000001451642
   Coding: 260050914034AF010001000000001D0D001C670802010141000000
   VCID: 3A2D35EBAC59883AC17-806E
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 120403  H11 0050
   Serial number: 90243014120319020932
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 20142034
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001110170277
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12591113372558
   Coding: 310105
   Shop #: WSC 40584 222 106270
   VCID: 78A9EFE3D2D55A2AF73-802C
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Serial number: 003JPD90VG1V   Dataset Number: 8R0909602E  0010
   Coding: 30463331313030303030554A304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48C95F23E235EAAA473-801C
   Serial number: 6334MSME6D430949L
   Serial number: 6344MSME6D046C24L
   Serial number: 6352QSME331204741
   Serial number: 6362QSME0B13307AD
   Serial number: 63732SME6E11517A1
   Serial number: 63832SME54110952R
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372LDA0015G
   Coding: 000017
   VCID: 3D273EF7BD77BF02E45-8068
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 931 B    HW: 8R0 920 931 B
   Component: KOMBIINSTR.   H44 0640
   Revision: 00000000    Serial number: P9Y11VA4D
   Coding: 0F0622000A000008010000
   VCID: 34311BD38E3D7E4A1BB-8060
   Part No SW: 8T0 907 468 AH    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0120
   Revision: EC101057    Serial number: 5700E1230800E6
   Coding: 00C303
   VCID: 074B9C1FAF2B25D28E9-8052
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790746551
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000028551228
   Coding: 011003205000440004
   VCID: 4DC76E370DD70F82745-8018
   Revision: 00002001    Serial number: 0175098584
   Coding: 013A063820B934948520053280000000
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H04 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H04 0090
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 108
                    Mileage: 177077 km
                    Date: 2026.08.11
                    Time: 19:22:43
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804014629704
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000027781011
   VCID: 4CC16333F6CD068A63B-8018
   Revision: 00000003    Serial number: 10000000906728
Address 55: Headlight Range        Labels: 8T0-907-357.clb
   Part No SW: 8H0 907 357 D    HW: 8H0 907 357 D
   Revision: 00H01001    Serial number:
   Coding: 0000255
   Shop #: WSC 18038 003 1048576
   VCID: 333318CF87337972021-8066
   Subsystem 1 - Part No: -----------
   Component: AFS-Modul links
   Subsystem 2 - Part No: -----------
   Component: AFS-Modul rechts
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 177077 km
                    Date: 2026.08.11
                    Time: 19:20:52
                    Fault Status: 11100101
                    Mileage: 177077 km
                    Date: 2026.08.11
                    Time: 19:20:52
   Part No SW: 4G1 035 053 D    HW: 4G1 035 053
   Component: Radio U Basic H41 0094
   Revision: AB001007    Serial number: 226DV0C7545080
   Coding: 010003010000000001
   Shop #: WSC 06335 123 12345
   VCID: 2019E7832AC5F2EAEF3-8074
   Part No SW: 8T1 035 666 J    HW: 8T1 035 666 E
   Component: H-BN-EU       H52 0174
   Revision: --------    Serial number: 483D/0C7774009
   Coding: 01010006000581ED01002B1E000000030000
   VCID: 41DF4207C18FDBE280D-8014
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130DA0CS147908
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000001124619
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
02612 - Audio Wire Adapter Set
                    Reset counter: 108
                    Mileage: 177077 km
                    Date: 2026.08.11
                    Time: 19:21:04
                    Voltage: 12.20 V
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000028326915
   Coding: 010003204000240004
   VCID: 43D3480FDB93C9F2921-8016
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Revision: 1G001001    Serial number: 00000174878659
   Coding: 0109080000000000
   Shop #: WSC 25397 000 00000
   VCID: 353726D7854767422C5-8060
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B2330EFA363B132DA1-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000028326914
End----(Elapsed Time: 01:47, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------5 Faults Found-------------------------------
It looks to me like the 55-Headight Range module has no communications with either of its sub-systems, the headlights/ballasts.
Since you posted this in the Retrofits section, I assume you have retrofitted something. Please tell us exactly what parts you've installed.
Bartas222
Poland
C?ID=381563
Yes, it is a modernization because different lamps were installed than those that came after the VIN.
Bartas222
Poland
C?ID=381563
I take it my topic is dead?
Bartas222
Poland
C?ID=381563
Hi,
I did some more research and compared the Audi wiring diagrams for the AFS and non-AFS xenon versions.
The car was originally equipped with PR-code 8Q5 / AFS and still has:
55 - Headlight Range
8H0 907 357 D
AFS 1 H01 0020
VCDS shows:
AFS-Modul links - Part No: -----------
AFS-Modul rechts - Part No: -----------
together with:
The currently installed xenon headlights work normally: low beam, high beam, DRL and indicators all function correctly. The only issue is the AFS/headlight range control system and the warning in the instrument cluster.
After comparing the Audi wiring diagrams, it appears that the headlights currently installed are the non-AFS version.
In the AFS version, J667/J668 are fitted in the headlights and control the leveling and cornering motors.
In the non-AFS xenon version, J667/J668 are not present and the leveling motors are wired differently.
Therefore, my current assumption is that coding the existing 8H0 907 357 D will not solve the problem, because the controller is still expecting two AFS slave modules which are not present in the currently installed headlights.
My goal is not to restore the cornering function.
I only want to keep the current xenon headlights, retain automatic headlight leveling, and eliminate the AFS warning from the instrument cluster.
I am therefore considering converting the car from 8Q5 to the non-AFS xenon configuration.
Before I change any wiring, could someone please confirm:
  1. Is this the correct approach?
  2. Can the existing AFS wiring be re-pinned and reused for the non-AFS leveling motors?
  3. Should Address 55 remain active after the conversion, or is the later non-AFS system controlled directly by J519?
  4. Is there a known factory coding/configuration for this conversion?
I have also attached the Audi wiring diagrams for the AFS and non-AFS versions for comparison.
Thanks.
I concur.
1. I suspect you will need a non-AFS Headlight Range module.
2. I don't know. You will need to compare wiring diagrams.
3. Do the non-AFS diagrams show a Headlight Range module?
4. Most people up-fit cars, rather than down-fitting them. ;)
