2023 Ford Grand Tourneo
YASA
Dublin, Ireland
C?ID=618621
Hi,
I would be grateful to obtain a one year free subscription to unlock SFD. The cable HEX-V2 was purchased last year on a German website, so all registration was done there, but they redirected me from their forum to here.
I've wasted aimlessly too much time on their forums, so I hope to get some valuable help here. The cable was purchased mostly for making service on one car, which I intensively use every day (1000km a veek), so I do the service myself every two month, changing oil, all filters etc, brake pads every 10 month. So I need a useful cable, not just for AutoScan and erise errors.
Have installed VCDS Beta 26.7.2
Config channel changed to Beta, Updated
Even trying to purchase subscriptions and have this message:
Well, you were posting in English on a German forum. :rolleyes:
You have a VIN-Limited ("Enthusiast") interface. It is not eligible for a free year. However, you can get three months for free if you follow the instructions in the first post of this thread:
https://forums.ross-tech.com/index.php?threads/54957/
Pay particular attention to the last paragraph in boldface.
Note however, that if you are still driving a Ford, our SFD Service may not work on it, despite it being "95% VW Caddy". VW is not giving us SFD tokens for Ford VINs.
YASA
Dublin, Ireland
C?ID=618621
OK, I'll be happy to get even three month for free. But why is SFD service not available for my interface even if I want to buy a year subscription?
I did unlock SFD on my car before when I changed rear brake pads, so your SFD Service is working on my car. The guy from PCI remotely connected to my PC by team viewer and unlocked it (cost me €30 for one session). It was already done twice.
Because we are not yet selling subscriptions.
I have no doubt that VCDS can unlock SFD on your car -- with the requisite tokens. But that does not mean that VW will give us tokens for your VIN. PCI's off-line source for tokens is different than our official on-line source.
YASA
Dublin, Ireland
C?ID=618621
Hi all,
Still can't use SFD protected controllers.
But did another jobs, VCDS auto-scan find some problems in my and my wife cars, which I'm sharing here, maybe will useful for somebody.
1). VW T-Rock 2021 VCDS Scan:
VCID: 0B47766433CB36A2BB0-805E
VINID: 9E65EAAAA441A9C9810C40890054CDCCB9
28252 - Coolant Pump 3
P26FA 00 [00100000] - Air in System
Resolution:
Go to 01-Engine Control Module
Go to Adaptations and find-select Bleed Cooling System Pres Go,
I waited about 15-18 minutes until it was finished. During the process will be shown - "Running", and the "Finished Correct" will appear in the end. Was in my case.
2) My Ford Grand Tourneo 2023 VCDS Scan:
VCID: 7DA328BC7D7F0812B44-8028
VINID: 9D6015A288DB0A0A000051810C2AD60EC6
28253 - Coolant Pump 3
P26F8 00 [10101111] - Stuck
Mileage: 160868 km
Date: 2026.07.20
Time: 21:39:46
Engine speed: 990.00 /min
Normed load value: 58.4 %
Vehicle speed: 4 km/h
Coolant temperature: 74 °C
Intake air temperature: 27 °C
Voltage terminal 30: 14.320 V
Heater support pump 1 bank 1 second.circuit: activat.: 43.78 %
Outside temperature sensor 1: B1: raw value: 25.0 °C
Shut-off timer: last engine shut-off time: 242 s
Temperature sensor for cylinder block: 75.4 °C
Heater support pump 1 bank 1 primary circuit: activation: 35.00 %
Turbocharger 1 turbine input: temp. sensor 1: bank 1: raw value: 188.3 °C
Readiness: 1 1 0 0 0
Resolution:
Auxiliary electric water pump need to be changed. It's stuck. The Critical Final Step (Bleeding) have to be done as described above.
Will do next week. Report will aploud.
Now I have a question.
I have installed a rear view camera on my car. It's working mostly well, very helpful. But VCDS demand basic setting.
Address 6C: Back-up Cam. (J772) Labels:| 5WA-980-556.clb
Part No SW: 5WA 980 556 B HW: 5WA 980 556 B
Component: RV eCompact H26 0254
Serial number: FCLK20050821000
Coding: 0603E000E43000
ASAM Dataset: EV_CamSysRVCCompaFicos 009020
ROD: EV_CamSysRVCCompaFicos_009_VN3S.rod
VCID: 50FDA1089A6D557A0E2-8004
10489856 - No Basic Setting
B2010 00 [00101111] - -
[System not calibrated]
Any idea what the coding I have to input?
Thanks in advance.
Please post a complete Auto Scan without any editing.
YASA
Dublin, Ireland
C?ID=618621
Friday,24,July,2026,22:53:47:58991
VCDS Version: 26.7.0.1 (x64)  HEX-V2 CB: 0.4713.5
Data version: 20260708 DS378.0
VIN: WF0EXXSK2PX005613   License Plate: 231-D-21868
Mileage: 161164   Repair Order:
Chassis Type: SK-VN3S (5WB)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 42 44 52 5F 6C 75 A5
          C002 C003
6C-Back-up Cam. -- Status: Not registered 0001
Address 01: Engine (J623-DTRC)       Labels:. 05L-907-309-V1.clb
   Part No SW: 05L 906 023 ES    HW: 05L 907 309 AA
   Component: R4 2.0l TDI   H80 2098
   Revision: ECH80---    Dataset Number: V03935347HQ 0001 CVN: 3AFC006304B77F64660402296604022943FB2DAA
   Coding: 012500320324050930080000000000000000000000000000
   Shop #: WSC 35110 377 00131
   ASAM Dataset: EV_ECM20TDI01105L906023ES 009001
   ROD: GV_ECM20TDI011VN35S.rod
                    Mileage: 160868 km
                    Date: 2026.07.20
                    Time: 21:39:46
   Part No SW: 0GC 906 555 S    HW: 0GC 300 047 L
   Component: GSG DQ381     H06 4161
   CVN: 3160EFEF
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 4BC7B664734B76A27A0-801E
   Subsystem 1 - Part No SW: 5WA 713 033 BS    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20220929000083974653
   Subsystem 2 - Part No SW: 7T0 713 052 D    HW: 7T0 713 052 D
   Component: ZSB_SB_mono    H01 0005
   Serial number: 18102202S00000003402
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810600004675071
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 BL    HW: 5WA 614 517 N
   Component: ESC           H13 0133
   Serial number: 63092000000089  Dataset Number: V03935383C  0001 CVN: 3EFB6C98
   Coding: 540C2A9744202271827D900109C660066DB658F55AC8670821BCA23121CFF300001C38
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013056
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 13776E046BFBEE62720-8046 SFD [x]
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 P    HW: 5WA 959 436 P
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935351JQ 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004.rod
   VCID: 619B74CCE1C7CCF2B0C-8034
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 AB    HW: 5WA 907 727 AB
   Component: AC Manuell    H02 0440
   Serial number: --------------- Dataset Number: V03935362SF 0001
   Coding: 023110010211000000100000101000010000010010000000000000000000
   ASAM Dataset: EV_ACManueBHBVW38X 001027
   ROD: EV_ACManueBHBVW38X_VN3S.rod
   VCID: 107D61085AED157A4F2-8044
459533 - Databus
          U1123 00 [00100000] - Received Error Message
          [Databus_error_value_received_Botschaft_Airbag_02]
                    Reset counter: 38
                    Mileage: 160906 km
                    Date: 2026.07.21
                    Time: 17:24:23
Address 09: Cent. Elect. (J519)       Labels: 5WA-937-08X-V1.clb
   Part No SW: 5WA 937 086 BA    HW: 5WA 937 086 BA
   Component: BCM37w_M1132 0179
   Serial number: BXJ53F070922940 Dataset Number: V03935361CA 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_VN3S.rod
   VCID: 117B640C51E71C7240C-8044 SFD [x]
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS            054 0206
   Serial number: S2Y22M11D13H22M11S34
   Subsystem 2 - Part No SW: 2KF 941 501 A    HW: 2KF 941 501 A
   Component: E1-LTM         004 0006
   Serial number: __2022_10_11___00051
   Subsystem 3 - Part No SW: 2KF 925 200 D    HW: 2KF 925 200 D
   Component: DiETa          H03 0002
   Serial number: 93309VDQ00021
   Subsystem 4 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA    004 0007
   Serial number: 00000000000002828469
   Subsystem 5 - Part No SW: 5Q0 951 172 A    HW: 5Q0 951 172 B
   Component: Sensor, DWA    005 0403
   Serial number: 000000000ZL2230702DZ
   Subsystem 6 - Part No SW: 7T0 959 561 R    HW: 7T0 959 561 R
   Component: -VW----LINDA-  504 0831
   Serial number: MW3LND15112200011034
   Steering Column Switch:
   Subsystem 7 - Part No SW: 5Q1 953 507 FL    HW: 5Q1 953 549 D
   Serial number: 00000012102204220535
14602 - Bulb for Left Brake Lamp / Tail Lamp
          B133A 15 [00101000] - Open or Short to Plus
                    Reset counter: 20
                    Mileage: 160868 km
                    Date: 2026.07.20
                    Time: 21:39:17
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    Engine run: On
                    Status of brake lamp switch: discrete: On
                    Brake lamp switch via CAN: status: On
                    Voltage: 13.2 V
                    Outside temperature: 19.0 °C
                    Light switch position: automatic
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [00101000] - Open or Short to Plus
                    Reset counter: 20
                    Mileage: 160868 km
                    Date: 2026.07.20
                    Time: 21:39:17
                    Engine run: On
                    Voltage: 13.2 V
   Part No SW: 5WA 919 294 C    HW: 5WA 919 294
   Component: PDC 08 Kanal  H04 0577
   Serial number: 000006102294560 Dataset Number: V03935357BS 0001
   Coding: 0040010011
   ASAM Dataset: EV_EPHBO18VW3800000 002029
   ROD: EV_EPHBO18VW3800000_VN3S.rod
   VCID: 52F9AB009461276A396-8006
Address 13: Auto Dist. Reg (J428)       Labels:| 5WA-907-572.clb
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H40 0461
   Dataset Number: V03935372EJ 0001
   Coding: 09030015007740451247400000D000044E4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VN3S.rod
   VCID: 4EC1BF708059438A1DE-801A
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 EM    HW: 1EA 959 655 EM
   Component: VW40Airbag    011 0182
   Serial number: W315LhE00C7     Dataset Number: V03935383KF 0001
   Coding: 88CC008000E0C00000000000000000005154000020AA00005C00F68000AB0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001016
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 107D61085AED157A4F2-8044 SFD [x]
   Seat occupancy detection 1:
   Subsystem 1 - Part No SW: 2K7 959 760 B    HW: 2K7 959 760 B
   Component: wSBR F-SG      037 0166
   Serial number:         94DC4E08F899
   Subsystem 2 - Part No SW: -----------    HW: 440 003 009 22
   Component: SideSensor_Pf  00A 0887
   Serial number: 358CJ0000000159C146%
   Subsystem 3 - Part No SW: -----------    HW: 440 003 009 22
   Component: SideSensor_Df  00A 0887
   Serial number: 357CJ000000122AC146+
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 440 002 010 22
   Component: Side_Sens_B_P  00A 0149
   Serial number: I0QCJA10B1A301F1B00A
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 440 002 010 22
   Component: Side_Sens_B_D  00A 0149
   Serial number: I0PCJC50B5F042A4D00Q
   Subsystem 6 - Part No SW: -----------    HW: 440 001 910 22
   Component: SideSensor_Pr  00A 0149
   Serial number: 352CJA10B1A305C2400E
   Subsystem 7 - Part No SW: -----------    HW: 440 002 010 22
   Component: SideSensor_Dr  00A 0149
   Serial number: 351CJ9D0B5F042C7000W
   Subsystem 8 - Part No SW: -----------    HW: 440 001 410 21
   Component: FrontSensor_D  00A 014A
   Serial number: 355CJA4C62D1A2A69000
   Part No SW: 2KF 920 741 A    HW: 2KF 920 741 A
   Component: KOMBI         300 6423
   Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ Dataset Number: V03935388LU 0001
   Coding: 24A4184763840008018062032000080800501C00
   ASAM Dataset: EV_DashBoardVISMQB37W 002021
   ROD: EV_DashBoardVISMQB37W_SK38.rod
   VCID: 3B27E6A423EBC622CA0-806E SFD [x]
16711686 - Secure Onboard Communication
          U14FE 00 [00001000] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Reset counter: 19
                    Mileage: 160883 km
                    Date: 2026.07.21
                    Time: 16:08:01
   Part No SW: 5WB 907 530 H    HW: 5WB 907 530 H
   Component: GW2020 High   842 8310
   Serial number: BXJ53F091122958 Dataset Number: V03935367DE 0001
   Coding: 0000808D0700000000000000012303335301600902000300030100000001000000000000000000000000000000000000
   GVL: 3D0000000208408C80008000C800004000004000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VN3S.rod
   VCID: 4EC1BF708059438A1DE-801A SFD [x]
   Generator:
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 4600460706
   Subsystem 3 - Part No SW: 2KF 959 442 B    HW: 2KF 959 442 B
   Component: E221__MFL-PR6  H07 0120
   Serial number: PR6-0440036276224234
3145728 - Databus
          U1124 00 [00101111] - Additional Installations Detected
          [Multiple_plug_CAN_and_Ethernet]
                    Fault Frequency: 21
                    Mileage: 160853 km
                    Date: 2026.07.20
                    Time: 13:12:09
1049121 - Databus for Driver Assistance Systems
          U15DE 00 [00101100] - No Communications
                    Fault Frequency: 38
                    Reset counter: 39
                    Mileage: 160853 km
                    Date: 2026.07.20
                    Time: 13:20:37
   Part No SW: 5WA 909 059 Q    HW: 3Q0 909 059 D
   Component: EBKV          H09 0309
   Serial number: BPA085161022013 Dataset Number: V03935367RL 0001
   Coding: 5402C10000000031C618638C000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VN3S.rod
   VCID: 5EE14F30D0B9F30A8DE-800A SFD [x]
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 22000260832007 Dataset Number: V03935336NF 0001
   Coding: 8800000000000000
   ROD: EV_ELVMarqMQBA0_VN3S.rod
   VCID: 3239CB80F4A1076A196-8066
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000481682488  Dataset Number: V03935344WL 0001
   Coding: 00308220D001040100001020
   Shop #: WSC 35110 377 00195
   ROD: EV_DCU2DriveSideMAXHCONT_VN3S.rod
   Part No SW: 5WA 907 144 G    HW: 5WA 907 144 C
   Component: BASGEN1MQB37  102 1040
   Serial number: 02272109 Dataset Number: V03935378NT 0001
   Coding: 0000000100000000000102010100010000000101010101
   ROD: EV_SteerAssisBASGEN1MQB37_007.rod
   VCID: 4DC3B87C8D5F7892644-8018
1312 - Databus
          U1121 00 [00100000] - Missing Message
          [DTC_BEM_05_TIMEOUT]
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000482518589  Dataset Number: V03935344YW 0001
   Coding: 00300020D001040100801000
   ROD: EV_DCU2PasseSideMAXHCONT_VN3S.rod
   VCID: 51FBA40C91675C7200C-8004
   Part No SW: 2KF 035 820 D    HW: 2KF 035 820
   Component: MU-O-ND-EU    H58 1900
   Serial number: WG8LGM161122000 Dataset Number: V03935384SS 0001
   Coding: E3521008002000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_VN3S.rod
   VCID: 392BFCAC29D7F432D8C-806C SFD [x]
   Subsystem 1 - Part No SW: 5H0 919 605     HW: 5H0 919 605
   Component: ABT_W_10       H47 2101
   Serial number: APUFG508112200010241
   Subsystem 2 - Part No SW: V03 959 817 SN    HW: -----------
   Component: EUR 2023       --- 8073
   VCID: 50FDA1089A6D557A0F2-8004
Address 75: Telematics (J949)       Labels:* Redir Fail!
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H12 0144
   Serial number: 0000000209VIHJ7 Dataset Number: V03935377QJ 0001
   Coding: 00359010906898009005460000002607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VN3S.rod
   VCID: 49CB8C6C793764B248C-801C SFD [x]
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3403
   Serial number: EA8808904223180 Dataset Number: V03935373JU 0001
   Coding: 0001081011484040409E00001000002002018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_VN3S.rod
End----------(Elapsed Time: 01:12, VBatt start/end: 12.6V/12.6V)-----------
------------------------------9 Faults Found-------------------------------
Now that you have actually posted a proper Auto-Scan with a version of VCDS that's capable of on-line SFD, you may place an order for (free Beta) SFD Service.
However, as I've previously stated, it's quite likely that VW will refuse to give us tokens for this Ford VIN.
