- Feb 16, 2024
- 13
- 1
- Colorado, USA
- C?ID=560418
Having an incorrect purge valve issue, so I thought to do tests via my VCDS-Lite. Following some instructions I found, I went to Output Tests, and got a menu with Start/Next at the bottom. Hitting Start, the first test was the N80 purge valve. It seemed to click this valve on and off continuously until I hit /Next, at which time it went to N75. The testing made continuous clicks until I hit next, and got another solenoid valve, etc, until it ran all the way through each fuel injector, at which time, it finished. I could easily hear the clicks of each test, so I presume it was telling me all were ok. I saw no result file I could examine, but didn't feel I needed one. After doing something else, I thought to repeat this test, but this time the procedure behavior was different. It started with the purge valve again, but this time, it didn't automatically keep clicking it open/closed until I hit next, to go to the next solenoid. This time, I only got one valve operation per Start/Next mouse click. And after several of these, it still wouldn't go to the next solenoid in the testing sequence. Apparently I didn't set up the test the same for each of these occurrences. Can someone tell me what I did differently?
Just in case you want to see it, here's my Engine module scan:
VCDS-Lite Version: Release 1.2
Saturday, 08 August 2026, 17:56:04:17397
Control Module Part Number: 4Z7 907 551 K
Component and/or Version: 2.7l V6/5VT G 0001
Software Coding: 06752
Work Shop Code: WSC 02325
VCID: 4BE9A7DA6ADD
Additional Info: WAUYP54B41N126175 AUZ7Z0Y1766497
Saturday, 08 August 2026, 17:36:59:17397
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4Z7 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 06752
Shop #: WSC 02325
VCID: 4BE9A7DA6ADD
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -
VCID: 4BE9A7DA6ADD
Coding: 06752
Shop #: WSC 02325
VCID: 4BE9A7DA6ADD
P1453 - 35-00 - -
P0441 - 35-00 - -
