NAR '19 Mk7.5 Golf R: Rear Intermittent Wiper Frequency Adjustment or Rain Sensor Control?
nabeelr
Ottawa, Canada
C?ID=395028
I've noticed that if I shut the car off with my rear wiper switched on, on the next ignition cycle, it won't actually be on, until the rain sensor gets triggered, or I toggle the switch again. (Which I find desirable!)
I've also noticed, that when the rain sensor is triggered, and I go into reverse, it will wipe the rear window once, although the rear wiper switch is off. (I know this is a setting in the infotainment screen, but I've also noticed it doesn't always happen, even though it's set, and only seems to happen when it's raining.)
This has made me wonder: Can I somehow adjust the frequency at which the rear wiper wipes? Could I make it stop cycling if it's left on and it's not raining?
I would love if the frequency of the rear wiper was also adjusted by intermittent wiper adjustment/auto wiper sensitivity switch, or if it just reacted to the Rain sensor, the way the front wipers do, and stopped a few minutes after the sensor stopped detecting rain.
Really, any adjustment at all on this would be interesting to know about... Even if it's just changing the base frequency.
Ideally, if it could wipe three or four times when initially switched on, and then park itself if the rain sensor isn't seeing any rain, and start up again when it starts raining again.
Is any of this or anything even slightly related possible?
I know you can use VCDS to enable wiping the rear window a few minutes after using the rear washer to catch any drips. I really hoping there is more customization hidden there.
nabeelr
Ottawa, Canada
C?ID=395028
Not at my car at the moment, but I have an older Auto-Scan from it:
Thursday,28,October,2021,23:48:05:56773
VCDS Version: 21.3.0.0  HEX-NET CB: 0.4543.4
VIN: WVWWA7AU8KW205454   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F A5 A9 D6 D7
VIN: WVWWA7AU8KW205454   Mileage: 38362km-23837miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (J623-DLRA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0002
   Revision: --H13---
   Coding: 091900122446000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
   ROD: EV_ECM20TFS0208V0906259Q.rod
   VCID: 4ED04DDF110AE0FB01-801A
   Part No SW: 5Q0 614 517 DS    HW: 5Q0 614 517 BN
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 60339000000007
   Coding: 01FA6BA150200971457B030560C76980D60A90A2C0069637344050D4D0A84B0B0000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0542B2F384FCE3A3F0-8050
8382 - Databus
          [FCAN: HCA_01 not received]
                    Reset counter: 231
                    Mileage: 36218 km
                    Date: 2021.10.07
                    Time: 20:21:09
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0516048445
   Coding: 132C0C0623
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43C66CEBCA481D939E-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010001010500000010102A
   VCID: 6D92EA53BC4C3BE318-8038
   Air quality sensor:
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 01001914100068
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0B5684CBA29895D3A6-805E
   Component: WWS    190417  043 0551
   Serial number:         190429163415
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051 0205
   Serial number: S5Y19M05D17H20M32S49
   Coding: 0008DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000004051904220962
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 226
                    Mileage: 36111 km
                    Date: 2021.10.06
                    Time: 16:37:22
204293 - Remote key 1
          B1479 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 226
                    Mileage: 37811 km
                    Date: 2021.10.20
                    Time: 15:43:06
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019135
   Coding: 0471155801
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   ROD: EV_EPHVA18AU3700000.rod
   VCID: 4CD447D7E716D2EB6F-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 2B0000C159FFC728949C810560400600000000000000000004
   VCID: 44C46FF7CF461AABA7-8010
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Reset counter: 224
                    Mileage: 37776 km
                    Date: 2021.10.19
                    Time: 23:27:59
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 14.3 V
                    Velocity_vehicle_reference: 2.45 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.34 m/s²
   Serial number: 22041941350072
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383C0B07838E4E4B3B-806C
   Serial number: 003GCR0BX5F-
   VCID: 47DE78FBFE7031B342-8012
   Serial number: IBH00000000000BJMD6V
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 001 905 19
   Serial number: 3570000000044B355C3J
   Subsystem 3 - Part No SW: -----------    HW: 480 001 905 19
   Serial number: 358000000006DAD47C3+
   Subsystem 4 - Part No SW: -----------    HW: 480 401 605 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001C0EFE786663CR
   Subsystem 5 - Part No SW: -----------    HW: 480 402 005 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001B6EFE7866E45Z
   Subsystem 6 - Part No SW: -----------    HW: 480 401 705 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001C2F001355979$
   Subsystem 7 - Part No SW: -----------    HW: 480 401 705 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001C2F0013558A5
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 0BAD30177F8C880902887B0B5401000080000000
   VCID: 2B16244B42D8F5D346-807E
16776969 - Databus
          [LDW_02 keine Kommunikation]
                    Reset counter: 240
                    Mileage: 36218 km
                    Date: 2021.10.07
                    Time: 20:21:05
   Component: GW MQB High   442 4368
   Revision: --------    Serial number: 0009612354
   Coding: 0101000838085900FB00823A880F00000001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E90ED5FB14AC0FB21-803A
   Generator:
   Component: 0-00-00-00-00
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H12 0052
   Serial number: 29190000869200089157
   Coding: 2CFFFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00026.04.19
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 234
                    Mileage: 36863 km
                    Date: 2021.10.10
                    Time: 22:38:27
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000138192013
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312A362360F49F037C-8064
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Fault Frequency: 9
                    Reset counter: 238
                    Mileage: 37115 km
                    Date: 2021.10.11
                    Time: 20:30:11
   Serial number: 0515328742
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D321A13ACAC6B63E8-8068
   Component: HRE_Slave  H12 0081
   Serial number: 0515744123
   Coding: 020111
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SE315604
   Coding: 003E13208000040000000000
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000030279593
   Coding: 111000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 910A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C341717B7B6626BDF-8068
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 231
                    Mileage: 36218 km
                    Date: 2021.10.07
                    Time: 20:21:09
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.00 V
                    Temperature: 38.0 °C
                    KFC: 55
                    KFA: 00 00
                    Freeze frame conditions: 20
                    uioUdNotFilt_xdu16: 14.13 V
                    uAdSensI_SwitchedKl30_xdu16: 14.13 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1KMD057NW6
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E102D5F71CA80FB61-807A
   Component: FCM MQB Low   002 0345
   Serial number: 04051910800834
   Coding: 000000050900161206710F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 35220233949CB32320-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SE71801C
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000030299405
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027310020000000041220002001828001F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 33263C2B9AE8AD130E-8066
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H60 8214
   Serial number: VWZ6ZJW1353581
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
          B11CF 53 [009] - Deactivated
                    Reset counter: 161
                    Mileage: 36110 km
                    Date: 2021.10.06
                    Time: 16:31:54
                    Voltage terminal 30: 12.0 V
                    SDARS_tuner_status_2-Satellite radio antenna status: electrically OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 98 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 18121815P20898
   Coding: 0003070000000201002213548150890094000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CC63E7DB5E068B83-8014
4195331 - Databus
          [LH_EPS_03_EPS_HCA_Status]
                    Reset counter: 231
                    Mileage: 36218 km
                    Date: 2021.10.07
                    Time: 20:21:10
                    Control Module temperature: 23 °C
                    Outside temperature: 16.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 210.9 s
                    Voltage terminal 15: 13.9 V
                    mid: 02 A7
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1275 - Unknown Error Code
          B182E F0 [008] - Unknown Error Elaboration
          [Frontsensorik_for_driver_assistance_systems_functinal_constraints_due_to_enviromental_influences]
                    Reset counter: 184
                    Mileage: 36768 km
                    Date: 2021.10.10
                    Time: 18:07:25
                    Control Module temperature: 42 °C
                    Outside temperature: 18.0 °C
                    Vehicle speed: 44.72 km/h
                    System run time: 4484.4 s
                    Voltage terminal 15: 14.0 V
                    mid: 01 63
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 190411201277
   VCID: 2F2E305B76C089F36A-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393A0E03B8845743C4-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 02:53, VBatt start/end: 12.1V/12.0V)-----------
          52 5F A5 A9 D6 D7
   Revision: --H13---
   Coding: 132C0C0623
   Revision: 00001K08
   Air quality sensor:
          B10CD 00 [009] - -
                    Reset counter: 204
                    Mileage: 38362 km
                    Date: 2021.10.28
                    Time: 23:46:51
                    Voltage terminal 30: 11.2 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Coding: 0008DD
   Coding: 0471155801
   Coding: 303344
   Generator:
   Coding: 2CFFFF
   Coding: 0001
                    Reset counter: 234
                    Mileage: 36863 km
                    Date: 2021.10.10
                    Time: 22:38:27
                    Fault Frequency: 9
                    Reset counter: 238
                    Mileage: 37115 km
                    Date: 2021.10.11
                    Time: 20:30:11
   Coding: 02011103
   Coding: 020111
   Coding: 111000
   Coding: 910A0000
   Coding: 091000
                    Reset counter: 161
                    Mileage: 36110 km
                    Date: 2021.10.06
                    Time: 16:31:54
End----(Elapsed Time: 02:42, VBatt start/end: 11.6V/11.7V. VIgn 11.8V)-----
Westbury, UK
That's from nearly 5 years ago! Has anything been changed or replaced since then?
nabeelr
Ottawa, Canada
C?ID=395028
Only about 100,000km. more, and the haldex that was replaced under warranty. No firmware updates or anything like that, that I'm aware of. Definately no module replacements.
I can try to grab a fresh one today. Just been a busy last couple days.
wildstar87
C?ID=252770
I'd be interested in what you find out, I've tried all the coding I could find, none of them seem to adjust the frequency of the rear wiper, that I have been able to find.
nabeelr
Ottawa, Canada
C?ID=395028
Just got around to pulling one just now.
VCDS Mobile 0.4713.0.4
VCDS Mobile: 0.4713
Data Version: 30000060
     52 5F A5 A9 D6 D7
Address 01: Engine  (J623-DLRA)    Labels: 06K-907-425-V1.clb
    Revision: --H13---
    VCID: 4EDFFD3BD773AD97811D34-801B
No fault codes found.
    Revision: 00000000
    VCID: 854D8217C2852ECFF027D3-80D0
Address 05: Acc/Start Auth.  (J518)    Labels: 5Q0-959-435.clb
    Revision: 00037000
    Coding: 132C0C0623
    ROD: EV_KessyHellaMQBAB_004.rod
    VCID: 43C9DC0F0C3150FF1EB38D-8016
Address 08: Auto HVAC  (J255)    Labels: 5G0-907-044.clb
    Revision: 00001K08
    VCID: 6D9D5AB77A35768F9857DB-8038
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
Address 09: Cent. Elect.  (J519)    Labels: 5Q0-937-08X-V2.clb
    ROD: EV_BCMMQB_019.rod
    VCID: 8B59B42FE4E158BFA66395-80DE
    Subsystem 1 -     Part No SW: 5G1-955-119-A    Labels: 5Qx-955-119-V1.clb
    Component: WWS    190417043 0551
    Serial Number:         190429163415
    Subsystem 2 -     Part No SW: 5Q0-955-547-C    Labels: 5Q0-955-547.clb
    Serial Number: S5Y19M05D17H20M32S49
    Coding: 0008DD
    Subsystem 3 -     Part No SW: 5Q1-953-507-M
    Component: J527 SMLS MQB004 0070
    Serial Number: 00000004051904220962
13578 - Bulb for Left Tail Light 2
    B12C0 15 [009] - Open or Short to Plus
        Fault Frequency: 22
        Reset Counter: 47
        Mileage: 133157 km
        Date: 2026.08.16
        Time: 06:38:35
Address 10: Park/Steer Assist  (J446)    Labels: 5Q0-919-294.clb
    Coding: 0471155801
    VCID: 4CDBF733216F9F87EFE92E-8019
Address 13: Auto Dist. Reg  (J428)    Labels: 3Q0-907-572.clb
    VCID: 44CBDF13093F57C727B986-8011
2137 - Databus
        Reset Counter: 85
        Mileage: 133161 km
        Date: 2026.08.16
        Time: 06:44:02
2092 - Databus
        Fault Frequency: 11
        Reset Counter: 86
        Mileage: 133139 km
        Date: 2026.08.15
        Time: 22:50:50
1113 - Databus
        Reset Counter: 80
        Mileage: 133144 km
        Date: 2026.08.15
        Time: 23:11:53
2190 - Databus
        Reset Counter: 83
        Mileage: 133144 km
        Date: 2026.08.15
        Time: 23:11:48
    Shop #: WSC 00000 000
    VCID: 3833BBE345F70327BB2102-806D
Address 15: Airbags  (J234)    Labels: 5Q0-959-655.clb
    VCID: 47D1C81F38097CDFC2DB79-8012
    Subsystem 1 -     Part No SW: 4M0-959-339-B
    Component: BF-Gewichtss.H13 0022
    Serial Number: IBH00000000000BJMD6V
    Coding: 303344
    Subsystem 2 -     Part No SW: --------------
    Component: SideSensor_Df001 0887
    Serial Number: 3570000000044B355C3J
    Subsystem 3 -     Part No SW: --------------
    Component: SideSensor_Pf001 0887
    Serial Number: 358000000006DAD47C3+
    Subsystem 4 -     Part No SW: --------------
    Component: SideSensor_Dr005 6149
    Serial Number: 3510001C0EFE786663CR
    Subsystem 5 -     Part No SW: --------------
    Component: SideSensor_Pr005 6149
    Serial Number: 3520001B6EFE7866E45Z
    Subsystem 6 -     Part No SW: --------------
    Component: FrontSensor_D005 6149
    Serial Number: 3550001C2F001355979$
Address 17: Instruments  (J285)    Labels: 5G0-920-XXX-17.clb
    VCID: 2B1994AF84A1B8BFC6A3B5-807E
16776960 - ROD - Unknown faultcode
        Fault Frequency: 11
        Reset Counter: 86
        Mileage: 133139 km
        Date: 2026.08.15
        Time: 22:50:49
Address 19: CAN Gateway  (J533)    Labels: 3Q0-907-530-V1.clb
    Revision: --------
    VCID: 6E9F5DBB77338D97A15DD4-803B
    Subsystem 1 -     Component: 0-00-00-00-00
    Subsystem 2 -     Part No SW: 5G0-959-442-AE    Labels: 3C8-959-537.clb
    Component: E221__MFL-DC1H12 0052
    Serial Number: 29190000869200089157
    Coding: 2CFFFF
Address 22: AWD  (J492)    Labels: 0CQ-907-554.clb
    Coding: 0001
        Reset Counter: 85
        Mileage: 133306 km
        Date: 2026.08.18
        Time: 22:57:17
Address 2B: Steer. Col. Lock  (J764)    Labels: 5Q0-905-861.clb
    VCID: 312586C7A68DD26FFCFF77-8064
    ROD: EV_LCMRightHELLAAU736_VW37.rod
Address 3C: Lane Change  (J1086)    Labels: 5Q0-907-686.clb
    Coding: 02011103
    ROD: EV_HREntryHella.rod
    VCID: 3D3DAAF76AD5260F6877CB-8068
Address 42: Door Elect, Driver  (J386)    Labels: 5QX-959-X93-42.clb
    Component: TSG FS
Address 44: Steering Assist  (J500)    Labels: 5Q0-909-144.clb
    Coding: 910A0000
    VCID: 3C3BA7F371CF2F075F49FE-8069
Address 47: Sound System  (J525)    Labels: 5Q0-035-456.clb
    Revision: 00000001
    VCID: 2E1F9DBBB7B3CD97E1DD94-807B
Address 4B: Multifunc. Module  (J745)    Labels: 3Q0-907-338-V2.clb
    ROD: EV_MultiModulContiVW48X_002.rod
    VCID: 352DB2D752E5FE4FA00723-8060
Address 52: Door Elect, Pass.  (J387)    Labels: 5QX-959-X92-52.clb
    Component: TSG BFS
Address 5F: Information Electr.  (J794)    Labels: 5G0-035-MIB-STD2.clb
    Component: MU-S-NS-US    853 0883
    ROD: EV_MUStd4CDELP_VW37.rod
    VCID: 33298CCF5C91E07F8E135D-8066
    Subsystem 1 -     Part No SW: 5G6-919-605-D
    Component: ABT_Std-2_NavH60 8214
    Serial Number: VWZ6ZJW1353581
    Subsystem 2 -     Part No SW: 5NA-919-866-ED
    Component: NAR 2024     --- 2110
    Serial Number: --------------------
    B201A 00 [009] -  -
        Reset Counter: 40
        Mileage: 133139 km
        Date: 2026.08.15
        Time: 22:47:51
0020 - Tuner for Satelite Radio
        Reset Counter: 40
        Mileage: 133139 km
        Date: 2026.08.15
        Time: 22:48:38
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: 3Q0-980-65X-A5.clb
    VCID: 40C3D3031D274BE70391AA-8015
Address A9: Struct. Borne Sound  (J869)    Labels: 5G-a9.lbl
    VCID: 2F2180BFB0B9C49FEACB61-807A
    VCID: 3935BEE77EFD1A2F442F1F-806C
End--(Elapsed Time: 02:52, VBatt start/end: 12.1/12.1 Vign: 12.2)-
The problem is my VCDS machine is an air-gapped Windows XP based Snap-On Verus Pro… Getting files in and out of that thing is a pain and a risk, because that thing is infested with so many viruses due to it's lack of security and age. It's always an ordeal to get things into and off of that thing.
USB thumb drive?
There should be a number of Adaptation channels in your BCM (Address 09) that you can find by putting Rear wiper in the search/filter box.
IDE02711-ENG116690 -- Rear wiper - Automatisches Heckwischen
IDE02711-ENG116695 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe 1 (s)
IDE02711-ENG116696 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe 2 (s)
IDE02711-ENG116694 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe Automatik (s)
IDE02711-ENG116693 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe Intervall (s)
IDE02711-ENG116689 -- Rear wiper - Menuesteuerung Komfortwischen HW
IDE02711-ENG116691 -- Rear wiper - Traenenwischen Heck
But I do not know whether adjustments to these channels will get you the behavior you desire.
nabeelr
Ottawa, Canada
C?ID=395028
Thanks for your help Uwe.
USB thumb drive?
Last time I plugged a USB drive into that thing, it put the conficker virus on it.
I'm reasonably sure I've addressed all the viruses on that thing, but I generally try to avoid connecting it to anything else.
If I had another Windows laptop, I'd just use that, but I only have one usable Windows machine right now… Unless you guys have tips for running VCDS on Linux? 😅
Alrighty, time to use Google Translate…
IDE02711-ENG116690 -- Rear wiper - Automatisches Heckwischen - Automatic rear wiper
IDE02711-ENG116695 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe 1 (s) - Comfort wiper rear interval pause time level
IDE02711-ENG116696 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe 2 (s) - Comfort wiper rear interval pause time level
IDE02711-ENG116694 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe Automatik (s) - Comfort wiper rear intervals pause time level automatic
IDE02711-ENG116693 -- Rear wiper - Komofortwischen Heck Intervallpausenzeit Stufe Intervall (s) - Comfort wiper rear interval pause time stage interval
IDE02711-ENG116689 -- Rear wiper - Menuesteuerung Komfortwischen HW - Menu control comfort wiper
IDE02711-ENG116691 -- Rear wiper - Traenenwischen Heck - Tear-wiping rear
Do we know what the difference would be between two pause time level 1 and 2? Or do I just need to try it and see what happens?
Also, the menu option, I assume that would need a modification in the infotainment for that option to show up too? or does Menu have a different meaning in German?
What's a good way to approach this?
The place I would start is to just check the contents of these channels in your BCM.
nabeelr
Ottawa, Canada
C?ID=395028
Thanks Uwe!
I'll take a look and report back!
nabeelr
Ottawa, Canada
C?ID=395028
Hmm, none of the settings seem to make an appreciable difference.
I even tried cycling the key and checking the soft reset option.
Leads me to believe it's either not doing what i think it's supposed to be doing, or perhaps the setting doesn't work?
I couldn't even get the interval to change.
Maybe I didn't wait long enough between key cycles?
davisev5225
C?ID=263265
There should be a checkbox at the bottom of the coding and adaption windows that allows you to reboot a module immediately. I forget what it says exactly, but it should be obvious. Otherwise, you have to wait ~30 minutes or so for your car's modules to fully "go to sleep" before most config changes will actually apply.
nabeelr
Ottawa, Canada
C?ID=395028
Yeah, that's the Soft Reset check box that I mentioned. Still no luck. it's possible I'm doing something wrong, or it's also possible to setting I'm changing isn't the setting I think I'm changing.
Its also possible that that particular module does not have that capability (?).
nabeelr
Ottawa, Canada
C?ID=395028
yeah, definitely possible. I did notice that there was a setting to change between a regular 12v wiper or an intelligently controlled one, and intelligent control option was what was selected by default. I don't remember the exact wording.
But yeah, these modules are made for millions of different cars, so chances are, they have settings for a car that has nothing to do with the car that I have. also, there's a real possibility that this setting is for something completely different from what it seems, or dependent on another setting that hasn't been changed. IDK?
