Audi Q5 FY - ACC not working after A4 Virtual Cockpit retrofit (U112200 / Wheel Circumference)
Bartas222
Poland
C?ID=381563
Hi everyone,
I'm looking for some advice regarding an ACC issue after replacing the instrument cluster in my Audi Q5 FY 2018.
The original cluster failed, so I installed a used 8W5 920 790 D cluster from an Audi A4.
  • Component Protection was removed successfully with ODIS online.
  • However, SVM refused to complete the configuration.
  • The car otherwise works normally.
The only remaining issue is Adaptive Cruise Control.
Both ACC modules report:
U112200 - Data bus implausible message
FAULT_QBIT_REIFENUMFANG
I also noticed that I cannot change the Wheel circumference adaptation/coding in the cluster. Every attempt results in:
Request out of range
The ABS module appears to be correctly coded and the ACC radar has the correct coding/ZDC. I have attached a complete Auto-Scan.
My questions are:
  • Has anyone seen this after installing an A4 cluster into a Q5?
  • Is the wheel circumference value controlled by the cluster dataset/parameterization rather than coding?
  • Is there any way to parameterize this cluster for a Q5 using ODIS/VCP/VCTool, or is a genuine Q5 cluster required?
  • Could the failed SVM configuration be the reason for the invalid wheel circumference signal?
Any help would be greatly appreciated.
Friday,07,August,2026,20:35:57:24862
VCDS Version: 25.3.3.0 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260227 DS365.0
VIN: WAUZZZFY5J2107062   License Plate: AUDI Q5
Mileage: 153184km-95184mi   Repair Order:
Chassis Type: FY-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 39 3C 42 44 46 52 5F 69
          6C 6D 81 8B A5 BB BC CA CF D6 D7
VIN: WAUZZZFY5J2107062   Mileage: 153184km-95184miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DAXB)       Labels: Redir Fail!
   Part No SW: 80A 906 259     HW: 06L 907 425 C
   Component: 2.0l R4 TFSI  H15 0004
   Revision: --H15---    CVN: 1BDC48EA
   Coding: 2A6500322576052B74380000000000000000000000000000
   Shop #: WSC 04531 995 00000
   ASAM Dataset: EV_ECM20TFS02080A906259 001006
   ROD: EV_ECM20TFS02080A906259.rod
   VCID: 6889BFA382F5CAAA26B-803C
   VINID: 9D196AAAA5A915A081007006083B15C4F7
Readiness: 1110 0001
   Part No SW: 80A 927 155 AG    HW: 0CJ 927 156
   Component: 0CJ 20TFSIRdW H04 0001
   Revision: --H04---    Serial number: 0000000385 CVN: B75A1EFD
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 6E85C9BBA011149A6C7-803A
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041170263000843
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-V1.clb
   Part No SW: 80A 907 379 C    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0767
   Dataset Number: 80B909504S  0001 CVN: A941ECBF
   Coding: 48AA40BE28A20A9DD19E5897207F52A2E4A5DA120214508B1A044A4527A55B
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 2F3B14BF679B5D92271-807A
409344 - Display for Tire Pressure Monitoring
          C1146 54 [00101110] - Missing Calibration / Basic Setting
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:15
                    7F 00 80 00 C2 00 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
303104 - Databus
          U1122 00 [00101111] - Implausible Message
          [Signal_KBI_Reifenumfang_invalid]
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:16
   Part No SW: 80A 820 043 F    HW: 80A 820 043 F
   Component: Klima Zone 3  H32 0095
   Coding: 640808095544400D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 2019E7832A45F2EAAEB-8074
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J216 FLuftV  H08 0003
   Serial number: 00000000000001501759
   Humidity sensor: exterior:
   Serial number: 76129CC800PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0267
   Dataset Number: 80B909514H  0029
   Coding: 07501143C13900CD051487149CFF80F9130B3108000000000000000060001C810A4502AB22B70A
   Shop #: WSC 99999 999 2097151
   VCID: 015F8207818F1BE2815-8054
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 171025  040 0570
   Serial number: 00000001710202104866
   Coding: 5FC7F7
   Serial number: 20808149X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 30 11 2017  73340456
   Serial number: GX1CE106111723810518
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 AE    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00006727
   Coding: 0D0101
   Subsystem 6 - Part No SW: 8W0 925 301 BG    HW: 8W0 925 301 BG
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2817000298795002
131944 - Databus
          [Parking assistance control module: no signal / communication]
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:15
                    average_Voltage_terminals: 12.60 V
                    Outside air temperature sensor-Outside air temperature on CAN: 22.00 °C
                    interior_temperature: 24.50 °C
                    Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 80A 907 561 D    HW: 8W0 907 561
   Component: LRR4          H10 0340
   Dataset Number: 80B909863G  0004
   Coding: 3477FFFB58FFEC0A959A81A0
   Shop #: WSC 99999 999 12345
   ASAM Dataset: EV_ACCBOSCHAU49X 003022
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: 290FFAA7597F33A2F95-807C
0860 - Databus
          [FAULT_QBIT_REIFENUMFANG]
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:13
                    Control Module temperature: 43 °C
                    Voltage terminal 15: 12.6 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s˛
                    Adaptive distance regulation: status: ACC_reversible_error
Address 15: Airbags (J234)       Labels:| 80A-959-655-V1.clb
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM032EVW Dataset Number: 80A909602G  0014
   Coding: AACCF0C00C800000985400FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   VCID: 3E2539FBB0F1A41ABC7-806A
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 80A857705G0233R01267
   Coding: 88001B
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 80A857706G0222R00733
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 480 002 309 17
   Serial number: 35700000000E0039D72K
   Subsystem 4 - Part No SW: -----------    HW: 480 002 309 17
   Serial number: 3580000000008D49D72T
   Subsystem 5 - Part No SW: -----------    HW: 480 031 510 17
   Serial number: 351001C04374E4F14923
   Subsystem 6 - Part No SW: -----------    HW: 480 032 210 17
   Serial number: 352001C048C46E9088EO
   Subsystem 7 - Part No SW: -----------    HW: 480 030 809 17
   Serial number: 355000C24E3230F01E96
   Subsystem 8 - Part No SW: -----------    HW: 480 030 809 17
   Serial number: 356000C24E3238F0FEAU
   Subsystem 9 - Part No SW: -----------    HW: 480 032 210 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C08EF24A810A9D
   Subsystem 10 - Part No SW: -----------    HW: 480 000 902 18
   Serial number: I0M00000000CE54C3BAP
   Subsystem 11 - Part No SW: -----------    HW: 480 000 902 18
   Serial number: I0N000000006F54C3BAL
   Central crash sensor X/Y:
   Subsystem 12 - Part No SW: -----------    HW: 480 020 709 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O00019F271BF63452.
   Part No SW: 80A 907 129 AG    HW: 80A 907 129 AG
   Component: Lenks.Modul   H02 0003
   VCID: 6D87CEB7AD17EF8255D-8038
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0371
   Coding: 00858E40AC9800080083E9601000300000000000
   VCID: 43D3480FDB13C9F2D39-8016
          U1014 00 [00001001] - -
          [ECU incorrectly coded]
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:13
   Part No SW: 8W7 907 468 E    HW: 8W7 907 468 E
   Component: Gateway       H42 0119
   Revision: 6C030004    Serial number: 0486C815717A11 Dataset Number: 80B909515D  0047
   Coding: 030100010000064029070000005900325C3A0007100000000175078E10000000
   GVL: 01D03C0008000000C0CCC8000002C800100C0000000000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003092
   VCID: 4DC76E370D570F8235D-8018
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0002
   Serial number: 20171124232936 00776
   Serial number: 7780605400
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 80A 927 755     HW: 0CJ 927 749
   Component: Q5_DL3_N_SD4  H18 0004
   Serial number: 1727523677
   Coding: 11070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 6C81C3B3960DE68A423-8038
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 80A 907 397 D    HW: 80A 907 397 D
   Component: LCM_MLBevo    H06 0017
   Dataset Number: 80B909519C  0009
   VCID: 303917C37AA5426A3EB-8064
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Dataset Number: 80B909520C  0009
Address 3C: Lane Change (J769)       Labels:| 4M0-907-566.clb
   Part No SW: 80A 907 566     HW: 80A 907 566
   Component: MRR1Rear      H18 0420
   Revision: --------    Dataset Number: 80B909535B  0013
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001022
   VCID: 6A8DC5AB9CF9F8BA30F-803E
   Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
   Component: TSG FS006 0737
   Serial number: CLSM1QL100JAJ Dataset Number: 80B909872A  0025
   Coding: 001F9B0150000480000010B0
   ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
Address 44: Steering Assist (J500)       Labels:* 4N0-909-144-V1.clb
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000300680 Dataset Number: 80B909852K  0001
   Coding: B0112101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: 34311BD38EBD7E4A5A3-8060
   Part No SW: 8W0 907 064 DP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   019 0366
   Dataset Number: 80B909501E  0029
   Coding: 01340000002000E06309A0006E00D80233034000804F06502F0000000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU49.rod
   VCID: 0D47AE37CDD74F82F5D-8058
   ID - sensor:
   Subsystem 1 - Part No SW: 4M0 959 754 AJ    HW: 4M0 959 754 AJ
   Component: ID-Geber  H40 0105
   Serial number: 3617000173533020
   Subsystem 2 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58247341
   Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
   Component: TSG BFS006 0737
   Serial number: CLSM1QL20046D Dataset Number: 80B909873A  0025
   Coding: 001F9B015C000480000010B0
   ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
   VCID: 3D273EF7BDF7BF02A5D-8068
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 036 B    HW: 8W5 035 036
   Component: MU-P-LN-EU    034 1177
   Serial number: A795L0H9400589 Dataset Number: 80B909545K  0024
   Coding: 01240601FF0A000053110001000A00332F0015E5017001009E
   VCID: 372B2CDF9FCB95527F1-8062
   Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
   Component: ECE 2020  --- 0184
   Multimedia display unit 1:
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL02QW8
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 13101700000000000372
   Compact disc data bank:
   Component: Gracenote2  --- 1016
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Revision: 9A001003    Serial number: 0480148777 Dataset Number: 80B909527A  0008
   Coding: 0110000202000000
   VCID: 353726D785C767426DD-8060
   Part No SW: 4M0 907 428 F    HW: 4M0 907 428
   Component: Areaview 2    H13 0318
   Serial number: C854607JG021084 Dataset Number: 80B909460G  0011
   Coding: 02240601BF0FA10008404004
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
   ROD: EV_CamSysRVAV2CE2MLBEv_005_AU49.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙ Dataset Number: 80B909541C  0009
   Coding: 0730
   VCID: 48C95F23E235EAAA06B-801C
   Part No SW: 80B 713 041 G    HW: 80B 713 041 G
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20171114003528
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 211FE287214FFBE2A15-8074
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   Component: LRR4          H10 0220
   Dataset Number: 80B909885D  0009
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 6393A88F7BD3A9F2F39-8036
0860 - Databus
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:13
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H16 0050
   Dataset Number: 80B909466D  0027
   Coding: 0404020600000401022023A7C50000FEB0F0C020E280
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 2411EB933E5DEECACA3-8070
Address BB: Door Rear Drv (J388)       Labels:* 5QX-959-DCR-V2.clb
   Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
   Component: TSG HFS006 0737
   Serial number: CLSM1QL1001RZ Dataset Number: 80B909897A  0026
   Coding: 000F990000000480000010A0
   VCID: 40D94703CA05D2EACEB-8014
Address BC: Door Rear Pass (J389)       Labels:* 5QX-959-DCR-V2.clb
   Component: TSG HBFS006 0737
   Serial number: CLSM1QL1001RS Dataset Number: 80B909896A  0026
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Dataset Number: 80B909469D  0006
   Coding: 628000042602
   ROD: EV_SunRoofCONTIAU736_006_VW37.rod
Address CF: Lane Chge Asst 2 (J770)       Labels:. 4M0-907-566.clb
   Part No SW: 80A 907 590     HW: 80A 907 590
   Revision: --------
   Coding: 1EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001022
   VCID: 678BBC9F8FEBC5D22F1-8032
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
   Part No SW: 7PP 941 592 CB    HW: 7PP 941 592 C
   Component: LED1L         H10 2003
   Dataset Number: 80B909471B  0004
   VCID: 1A6DD56B0C19A83A60F-804E
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
   Component: LED1R         H10 2003
   Dataset Number: 80B909472B  0004
End----------(Elapsed Time: 02:07, VBatt start/end: 12.7V/12.7V)-----------
------------------------------6 Faults Found-------------------------------
NEtech
Denmark
C?ID=56995
Change Coding in [17], Byte 03, from 40 to 44
It is not always possible to change Tire Circumference
Bartas222
Poland
C?ID=381563
Sorry for the delay, but I'll have my car tomorrow; I'll check it then and let you know the result.
Bartas222
Poland
C?ID=381563
Unfortunately, it won't accept it.
Bartas222
Poland
C?ID=381563
Or perhaps this meter needs to be flashed for the Q5—meaning, configured according to its datasheet? I’d appreciate any suggestions you might have.
vastechnics
C?ID=143747
Tire circ can not be changed in Audi cluster. Only NEW. Used can not change, need put from same car specs
Bartas222
Poland
C?ID=381563
I don't think the Q5 will have wheels as large as the A4's, though. Unless someone has a different solution regarding the speedometer...
zhaowg172
China
C?ID=273798
Hi everyone,
My questions are:
   MTF pump:
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:15
303104 - Databus
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:16
   Coding: 5FC7F7
   Coding: 02006E
   Coding: 030000
   Coding: 0D0101
131944 - Databus
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:15
0860 - Databus
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:13
   Coding: 88001B
   Coding: 88001B
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:13
   Coding: 11070000
   Coding: 1EC002
   ID - sensor:
   Coding: 0730
0860 - Databus
                    Reset counter: 153
                    Mileage: 153184 km
                    Date: 2026.08.07
                    Time: 20:32:13
   Revision: --------
   Coding: 1EC002
zhaowg172
China
C?ID=273798
The A4 dashboard cannot be installed on the Q5 model. You can only solve this problem by finding a dashboard removed from a Q5 model.
Bartas222
Poland
C?ID=381563
So, there’s no sensible solution to this?
golfi_vend
Tartu, Estonia
C?ID=195131
You are from Poland...I know ppl from Poland have tricks to reset this FPK mileage to 0km, which allows setting wheel circum. from coding.
Bartas222
Poland
C?ID=381563
Only no one would say so... I know someone from Croatia is capable of doing it. I don't think there is anyone in Poland itself.
vastechnics
C?ID=143747
I also know someone, but he asks that much better buy new!
vastechnics
C?ID=143747
Which Part no do you need?
golfi_vend
Tartu, Estonia
C?ID=195131
I wouldn't want to replace the dash with another one again.
You only have 3 options:
1) brand new
2) adjust mileage to 0km on this one
3) find another used cluster with correct wheel coding
Bartas222
Poland
C?ID=381563
Then what do you want???!!
If you find someone reliable nearby in Europe, they’ll be able to reset the mileage to zero. Buying a used dashboard is a gamble because nobody knows what the actual mileage is—the sellers just want to offload it.
vastechnics
C?ID=143747
I know someone who can. He done a couple for me. But the price is even more then buy new.
