2010 Jetta se ABS module issues
shane353
Texas, USA
C?ID=664064
Recently purchased this car that is loaded with codes for ABS module. The module that is in the car I am unsure it is the correct one for the car or long coding is not correct as it looks like it has a used one installed a while ago (still see paint pen writing under connector from salvage yard) Off the scanner it shows 1K0907379AD with long coding of 114B400C492300FE881302E9922000413000. I ordered a VCDS with HEX-V2 so I can pull the download to share all the codes in the system but here is what is off scanner:
1.Supply voltage too low
2.ABS brake control module read out DTC
3.Invaliid data received from Anti lock brake system control module
4. Lost communication with ABS control module
5.Brake control module no signal
6. Speed signal left front, right front, left rear, right rear error in circuit
Can anyone confirm this is the right ABS module for the car with vin: 3VWRX7AJXAM014857
Thank you in advance for the help.
Ziddywerks
Northern NJ USA
C?ID=208579
Auto scan to start of no soup for you!!
Original was 1K0907379AN
shane353
Texas, USA
C?ID=664064
Thank you. I am waiting for new scanner to pull auto scan download to upload
